Audi Q5 CNC engine broken
Alvaro
Ecuador
C?ID=125686
Hi friends, I have in my workshop a 2015 audi Q5 with 35000 miles ans CNC engine code, the engine has low oil pressure, the client want to change a engine, the question is if I can to install a CXC engine in this car, the two moldes are MQB, thanks for. your attention.
siLc
Tallinn, Estonia
C?ID=330192
Do keep in mind that the CNC and CXC are mounted in different orientations in the engine bay. In such cases the engines are hardly interchangeable.
Alvaro
Ecuador
C?ID=125686
Hi, yes the periferic componentes is not a problem, I talk about a Engine without periferic components.
thanks
Check stuff to see if it crosses on the microfiche, otherwise take this to retrofits & because it isn't VCDS related or of this forum section.
The worst FOD is induced FOD! & be means of negligence!
Ecuador = ECU a DOOR TO PARADISE!
ShaneOF
Ireland
C?ID=295432
have you done a mechanical oil pressure test? because the oil pressure sensors go faulty, the brown ones on the filter housing need to be replaced with the modified grey switch.. think there is a recall for this
