07 Q7 idle and throttle up feels like traction control
rprellidzynr
Carmel, IN, USA
C?ID=339591
Hello All,
Q7 shows EPC and 'fishtail' on dash, feels like traction control at idle. The engine won't die at idle, but idles very roughly around 400rpm.....feels like half the engine is disabled. 10-15% throttle after releasing brake needs 1-2 seconds to clean up and run and runs reasonable well, but not cleanly above 20% throttle. This all came on all at once.
Monday,27,May,2019,21:16:31:28853
VCDS Version: 18.9.1.0 (x64)  HEX-V2 CB: 0.4505.4
VIN: WA1BV74L97D054434   License Plate:
Mileage: 290390km-180439mi   Repair Order:
Chassis Type: 4L (4L0)
Scan: 01 02 03 05 07 08 09 0E 0F 15 16 17 19 28 34 36 37 3C 42 46
          47 4F 52 55 56 61 62 65 67 6C 6D 6F 72 76 77
VIN: WA1BV74L97D054434   Mileage: 290390km-180439miles
05-Acc/Start Auth. -- Status: Malfunction 1010
0E-Media Player 1 -- Status: Malfunction 0010
67-Voice Control -- Status: Malfunction 0010
Address 01: Engine        Labels:. 079-907-560-BAR.clb
   Part No SW: 4L0 910 560 C    HW: 4L0 907 560 A
   Component: 4.2l V8/4V          0060
   Revision: 71H21---    Serial number:
   Coding: 01210009190F0560
   Shop #: WSC 03089 444 84152
   VCID: 2809040C6EF41017F6D-807C
18 Faults Found:
001112 - Evap System Purge Control Valve (N80)
               P0458 - 002 - Short to Ground - MIL ON
                    Fault Status: 11100010
                    Mileage: 288046 km
                    Date: 2019.02.14
                    Time: 20:40:33
                    RPM: 1677 /min
                    Load: 37.6 %
                    Temperature: 35.0°C
                    Temperature: 35.0°C
                    Absolute Pres.: 980.0 mbar
                    Voltage: 11.176 V
005173 - Secondary Air Pump Relay (J299)
               P1435 - 002 - Short to Ground - MIL ON
                    Mileage: 288046 km
                    Date: 2019.02.14
                    Time: 20:40:33
                    RPM: 1677 /min
                    Load: 37.6 %
                    Temperature: 35.0°C
                    Temperature: 35.0°C
                    Voltage: 11.303 V
000258 - Mass Air Flow Sensor (G70)
               P0102 - 002 - Signal too Low - MIL ON
                    Mileage: 288046 km
                    Date: 2019.02.14
                    Time: 20:40:33
                    RPM: 1702 /min
                    Load: 23.1 %
                    Temperature: 35.0°C
                    Temperature: 35.0°C
                    Voltage: 11.303 V
000268 - Mass Air Flow Sensor (G246)
               P010C - 002 - Signal too Low - MIL ON
                    Mileage: 288046 km
                    Date: 2019.02.14
                    Time: 20:40:33
                    RPM: 1702 /min
                    Load: 23.1 %
                    Temperature: 35.0°C
                    Temperature: 35.0°C
                    Voltage: 11.303 V
008852 - Fuel Pressure Regulator Valve (N276)
               P2294 - 004 - Open Circuit - Intermittent - MIL ON
                    Fault Status: 10100100
                    Fault Frequency: 9
                    Mileage: 290240 km
                    Date: 2009.01.28
                    Time: 00:00:39
                    RPM: 1468 /min
                    Load: 43.5 %
                    Temperature: 35.0°C
                    Temperature: 35.0°C
                    Voltage: 11.176 V
004763 - Fuel Pressure Regulator Valve; Bank 2 (N276)
               P129B - 004 - Open Circuit - Intermittent - MIL ON
                    Fault Frequency: 7
                    Mileage: 290240 km
                    Date: 2009.01.28
                    Time: 00:00:39
                    RPM: 1468 /min
                    Load: 43.5 %
                    Temperature: 35.0°C
                    Temperature: 35.0°C
                    Voltage: 11.176 V
008196 - Intake Manifold Flap; Bank 1
               P2004 - 004 - Stuck Open
                    Mileage: 290240 km
                    Date: 2009.01.28
                    Time: 00:00:42
                    RPM: 1275 /min
                    Load: 25.5 %
                    Temperature: 35.0°C
                    Temperature: 34.0°C
                    Voltage: 12.827 V
009217 - EVAP Leak Detection Pump Control Circuit
               P2401 - 002 - Short to GND - MIL ON
                    Mileage: 290240 km
                    Date: 2009.01.28
                    Time: 00:00:49
                    RPM: 826 /min
                    Load: 29.8 %
                    Temperature: 34.0°C
                    Temperature: 33.0°C
                    Voltage: 13.335 V
008197 - Intake Manifold Flap; Bank 2
               P2005 - 004 - Stuck Open
                    Mileage: 290240 km
                    Date: 2009.01.28
                    Time: 00:08:26
                    RPM: 831 /min
                    Load: 32.5 %
                    Temperature: 27.0°C
                    Temperature: 27.0°C
                    Absolute Pres.: 970.0 mbar
                    Voltage: 13.335 V
               P2004 - 002 - Stuck Open - MIL ON
                    Mileage: 290240 km
                    Date: 2009.01.28
                    Time: 00:17:03
                    RPM: 639 /min
                    Load: 49.4 %
                    Speed: 1.0 km/h
                    Temperature: 68.0°C
                    Temperature: 33.0°C
                    Voltage: 13.081 V
               P2005 - 002 - Stuck Open - MIL ON
                    Mileage: 290240 km
                    Date: 2009.01.28
                    Time: 00:17:03
                    RPM: 639 /min
                    Load: 49.4 %
                    Speed: 1.0 km/h
                    Temperature: 68.0°C
                    Temperature: 33.0°C
                    Voltage: 13.081 V
               P0300 - 001 -  - Intermittent
                    Fault Status: 00100001
                    Mileage: 290302 km
                    Date: 2009.02.03
                    Time: 19:22:08
                    RPM: 2167 /min
                    Load: 32.1 %
                    Speed: 99.0 km/h
                    Temperature: 96.0°C
                    Temperature: 15.0°C
                    Voltage: 13.589 V
000772 - Cylinder 4
               P0304 - 001 - Misfire Detected - Intermittent
                    Mileage: 290302 km
                    Date: 2009.02.03
                    Time: 19:22:08
                    RPM: 2167 /min
                    Load: 32.1 %
                    Speed: 99.0 km/h
                    Temperature: 96.0°C
                    Temperature: 15.0°C
                    Voltage: 13.589 V
               P0087 - 002 - Too Low
                    Fault Status: 01100010
                    Mileage: 290330 km
                    Date: 2009.02.03
                    Time: 20:17:22
                    RPM: 703 /min
                    Load: 61.2 %
                    Speed: 2.0 km/h
                    Temperature: 88.0°C
                    Temperature: 53.0°C
                    Voltage: 13.462 V
000049 - Oxygen (Lambda) Sensor B1 S1: Heating Circuit
               P0031 - 002 - Short to Ground - Intermittent
                    Mileage: 290375 km
                    Date: 2009.02.08
                    Time: 05:41:37
                    RPM: 737 /min
                    Load: 43.5 %
                    Temperature: 93.0°C
                    Temperature: 65.0°C
                    Voltage: 13.462 V
000081 - Oxygen (Lambda) Sensor B2 S1: Heating Circuit
               P0051 - 002 - Short to Ground - Intermittent
                    Mileage: 290375 km
                    Date: 2009.02.08
                    Time: 05:41:37
                    RPM: 737 /min
                    Load: 43.5 %
                    Temperature: 93.0°C
                    Temperature: 65.0°C
                    Voltage: 13.462 V
000087 - Oxygen (Lambda) Sensor B2 S2: Heating Circuit
               P0057 - 002 - Short to Ground
                    Mileage: 290375 km
                    Date: 2009.02.08
                    Time: 05:42:08
                    RPM: 1761 /min
                    Load: 62.3 %
                    Speed: 30.0 km/h
                    Temperature: 90.0°C
                    Temperature: 54.0°C
                    Voltage: 13.843 V
000055 - Oxygen (Lambda) Sensor B1 S2: Heating Circuit
               P0037 - 002 - Short to Ground
                    Mileage: 290375 km
                    Date: 2009.02.08
                    Time: 05:42:18
                    RPM: 1245 /min
                    Load: 25.1 %
                    Speed: 28.0 km/h
                    Temperature: 90.0°C
                    Temperature: 57.0°C
                    Voltage: 13.970 V
Readiness: 0010 1101
   Part No SW: 09D 927 750 FH    HW: 09D 927 750 FH
   Component: AL 750 6A           0959
   Revision: 00H52000    Serial number:
   Coding: 0000504
   Shop #: WSC 31414 790 00001
   VCID: 79AF1148C5DE599FD93-802C
            013 - Check DTC Memory
                    Fault Frequency: 7
                    Reset counter: 0
                    Date: 2006.05.10
                    Time: 12:00:02
Address 03: ABS Brakes        Labels:. 4L0-910-517-V1.clb
   Part No SW: 4L0 910 517 A    HW: 4L0 614 517 A
   Component: ESP ALLRAD MK25E1   0130
   Revision: 00H21001
   Coding: 0021553
                    Reset counter: 157
                    Mileage: 290241 km
                    Date: 2009.03.25
                    Time: 15:01:32
                    Count: 12545
                    Count: 8211
                    Count: 40192
            000 -  -  - Intermittent
                    Reset counter: 160
                    Mileage: 289808 km
                    Date: 2009.01.28
                    Time: 03:01:33
                    Count: 192
                    Count: 13057
                    Count: 297
                    Count: 41216
                    Reset counter: 120
                    Mileage: 290397 km
                    Date: 2009.02.18
                    Time: 18:36:30
                    Count: 14593
                    Count: 128
                    Count: 33792
                    Fault Status: 01101101
                    Reset counter: 76
                    Mileage: 288035 km
                    Date: 2019.02.14
                    Time: 19:20:57
                    Count: 12289
                    Count: 8196
                    Count: 42752
   Part No SW: 4F0 910 852 B    HW: 4F0 905 852 F
   Component: FBSAUDIC6 ELV   H05 0130
   Revision: 00H05000    Serial number: 10603401789549
   Coding: 0000143
   Shop #: WSC 03213 444 84058
   VCID: 25170D3819E60D7FCDB-8070
   Subsystem 1 - Part No: 4F0 910 131 L
   Component: FBSAUDIC6 KSG   H28 0080
20 Faults Found:
00190 - Driver's Door Handle Touch Sensor (G415)
            007 - Short to Ground
                    Fault Status: 01100111
                    Fault Frequency: 16
                    Reset counter: 120
00192 - Rear Left Door Handle Touch Sensor (G417)
                    Fault Status: 01110111
                    Reset counter: 242
                    Mileage: 280518 km
                    Date: 2018.11.30
                    Time: 15:42:26
                    Reset counter: 218
                    Mileage: 256955 km
                    Date: 2018.06.13
                    Time: 18:26:30
00191 - Passenger's Door Handle Touch Sensor (G416)
                    Reset counter: 218
                    Mileage: 256955 km
                    Date: 2018.06.13
                    Time: 18:26:30
                    Fault Status: 00111011
                    Reset counter: 110
                    Mileage: 268128 km
                    Date: 2018.08.09
                    Time: 16:25:04
00166 - Access/Start Authorization Switch (E415)
                    Fault Status: 00111010
                    Reset counter: 154
                    Mileage: 275785 km
                    Date: 2018.09.11
                    Time: 14:13:59
00532 - Supply Voltage B+
                    Fault Frequency: 11
                    Reset counter: 160
                    Mileage: 289899 km
                    Date: 2009.02.25
                    Time: 13:25:34
                    Fault Frequency: 16
                    Reset counter: 160
                    Mileage: 289899 km
                    Date: 2009.02.25
                    Time: 13:24:37
                    Reset counter: 157
00288 - Steering Column Lock Actuator (N360)
                    Reset counter: 157
                    Fault Frequency: 19
                    Reset counter: 157
                    Fault Frequency: 19
                    Reset counter: 157
            015 - Cannot Be Tested at this Time - Intermittent - MIL ON
                    Fault Status: 10101111
                    Fault Priority: 15
                    Fault Frequency: 255
                    Reset counter: 157
                    Fault Frequency: 19
                    Reset counter: 157
                    Fault Frequency: 19
                    Reset counter: 157
                    Fault Frequency: 18
                    Reset counter: 157
                    Fault Frequency: 18
                    Reset counter: 157
                    Fault Status: 01111011
                    Reset counter: 243
                    Mileage: 280940 km
                    Date: 2018.12.09
                    Time: 19:31:26
02241 - Engine Control Module; Immobilizer Data not Adapted
                    Reset counter: 157
                    Mileage: 290241 km
                    Date: 2009.03.25
                    Time: 14:53:07
00230 - Transmission Park Selector Switch (F305)
                    Fault Status: 00101010
                    Reset counter: 160
                    Mileage: 290353 km
                    Date: 2009.02.08
                    Time: 03:31:31
Address 07: Control Head        Labels: 4L0-910-7xx-07-H.clb
   Part No SW: 4L0 910 731     HW: 4E0 035 729 A
   Component: Interfacebox    H43 2740
   Revision: 00000000    Serial number: 354J 067509089
   Coding: 0002003
   VCID: 65974D385966CD7F0DB-8030
   Component: E0380 BedienteilH01 0060
   Subsystem 2 - Serial number: 00000001977162
   Subsystem 3 - Serial number: 0131.01.120000000100010766ÿ
   Subsystem 4 - Serial number: 010766ÿ
01327 - Control Module for Parking Aid (J446)
                    Reset counter: 130
                    Mileage: 288841 km
                    Date: 2019.02.19
                    Time: 19:30:42
                    Reset counter: 160
                    Time Indication: 15
   Part No SW: 4L0 910 043     HW: 4L0 820 043 F
   Revision: 00---010    Serial number: 00000030006418
   Coding: 0786472
   VCID: 619F59284D4EA15FF13-8034
6 Faults Found:
00710 - Defroster Flap Positioning Motor (V107)
            003 - Mechanical Failure
                    Fault Status: 01100011
                    Reset counter: 120
                    Mileage: 256955 km
                    Date: 2018.06.13
                    Time: 18:04:14
                    Voltage: 11.70 V
                    Temperature: 33.0°C
                    (no units): 63.0
                    (no units): 193.0
                    Temperature: 43.0°C
                    Fault Status: 01101010
                    Fault Frequency: 110
                    Reset counter: 120
                    Mileage: 286374 km
                    Date: 2019.01.31
                    Time: 08:11:30
                    Temperature: 9.0°C
                    Reset counter: 129
                    Mileage: 288682 km
                    Date: 2019.02.19
                    Time: 06:29:35
                    Temperature: 36.0°C
                    Temperature: 11.0°C
                    Temperature: 13.0°C
                    RPM: 1720 /min
                    Absolute Pres.: 1.0 bar
                    Current: 0.000 A
                    Temperature: 11.0°C
00456 - Control Module for Access and Start Control (J518)
                    Reset counter: 157
                    Mileage: 290241 km
                    Date: 2009.03.25
                    Time: 15:01:36
                    Bin. Bits:    01000
                    Fault Frequency: 15
                    Reset counter: 160
                    Mileage: 290397 km
                    Date: 2009.02.18
                    Time: 18:36:32
                    Voltage: 9.50 V
                    Fault Frequency: 9
                    Reset counter: 160
                    Mileage: 290397 km
                    Date: 2009.02.18
                    Time: 18:45:21
                    Voltage: 6.90 V
   Part No SW: 4F0 910 279 J    HW: 4F0 907 279 A
   Coding: 0113123
   VCID: 3039EC6C562458D72ED-8064
   Component: Wischer AU716   H12 0080
   Coding: 00064792
   Shop #: WSC 31414
   Coding: 00150059
   Shop #: WSC 31414
                    Reset counter: 120
                    Mileage: 262136 km
                    Date: 2019.01.30
                    Time: 21:44:00
                    Reset counter: 157
                    Mileage: 262136 km
                    Date: 2009.03.25
                    Time: 14:33:00
                    Fault Frequency: 13
                    Reset counter: 120
                    Mileage: 262136 km
                    Date: 2019.01.15
                    Time: 16:32:00
                    Fault Frequency: 14
                    Reset counter: 160
                    Mileage: 262136 km
                    Date: 2009.03.11
                    Time: 13:40:00
                    Fault Frequency: 11
                    Reset counter: 160
                    Mileage: 262136 km
                    Date: 2009.03.11
                    Time: 13:40:00
   Part No SW: 4L0 910 111 A    HW: 4L0 035 111
   Component: CD-Changer      H41 0100
   Revision: 00000000    Serial number: AUZ5ZBF3048527
   VCID: 1E6522D43CB0DEA78C1-804A
                    Reset counter: 160
                    Mileage: 289899 km
                    Date: 2009.02.25
                    Time: 13:26:56
Address 0F: Digital Radio        Labels: 4E0-910-593-SIR.lbl
   Part No SW: 4E0 910 593 D    HW: 4E0 035 593
   Component: SDAR SIRIUS     H04 0670
   Revision: 00000000    Serial number: AUZ4Z7F5032162
                    Reset counter: 160
                    Mileage: 289899 km
                    Date: 2009.02.25
                    Time: 13:25:03
                    Voltage: 8.40 V
                    Reset counter: 160
                    Mileage: 289899 km
                    Date: 2009.02.25
                    Time: 13:25:03
                    Voltage: 8.40 V
   Component: 73 AIRBAG AUDI8RH39 0210
   Revision: 03H39000    Serial number: 0038QD03AMA9
   Coding: 0014131
   VCID: 2B03FB007F023B0F1BF-807E
   Subsystem 1 - Part No: 4L0 910 339
   Component: BF-Gewichtsens. H02 0020
   Subsystem 2 - Serial number: 6332QSME127A22335
   Subsystem 3 - Serial number: 6342QSME130B0B1BE
   Subsystem 4 - Serial number: 6352QSME126B4275F
   Subsystem 5 - Serial number: 6362QSME127B2945J
   Subsystem 6 - Serial number: 63734SME1514206BV
   Subsystem 7 - Serial number: 63834SME15162D47+
   Part No SW: 4F0 910 549 A    HW: 4F0 953 549 C
   Revision: 00H03000    Serial number: 90026062490112
   Coding: 0012242
   VCID: 270B073063EA1F6FFF7-8072
   Component: E0221           H07 0090
                    Fault Frequency: 12
                    Reset counter: 160
                    Mileage: 289899 km
                    Date: 2009.02.25
                    Time: 13:26:12
                    Fault Frequency: 11
                    Reset counter: 160
                    Mileage: 289899 km
                    Date: 2009.02.25
                    Time: 13:27:09
                    Reset counter: 159
                    Mileage: 290241 km
                    Date: 2009.03.25
                    Time: 14:33:59
Address 17: Instruments        Labels:. 4L0-920-xxx-17.clb
   Part No SW: 4L0 920 983 M    HW: 4L0 920 983 M
   Component: KOMBIINSTR.         0900
   Revision: 00200000    Serial number: AYF01HN1A
   Coding: 3697283
   Shop #: WSC 03213 444 04841
   VCID: 3C21C85C8A6CACB7825-8068
                    Fault Frequency: 9
                    Reset counter: 160
                    Mileage: 290397 km
                    Date: 2009.02.18
                    Time: 18:44:21
   Part No SW: 4L0 910 468     HW: 4L0 907 468 A
   Component: J533__Gateway   H06 0040
   Revision: 00H06000    Serial number: 0800D0691580E2
   Coding: F5F7FE7F347A02
   Shop #: WSC 03089 444 54655
   VCID: 6C81381CBA8CFC37525-8038
                    Fault Frequency: 11
                    Reset counter: 160
                    Mileage: 289899 km
                    Date: 2009.02.25
                    Time: 13:26:22
                    Reset counter: 157
                    Mileage: 290241 km
                    Date: 2009.03.25
                    Time: 14:33:59
00384 - Optical Databus
                    Fault Status: 00101011
                    Reset counter: 160
                    Mileage: 290397 km
                    Date: 2009.02.18
                    Time: 18:46:30
   Part No SW: 4L0 910 158     HW: 4L0 919 158 D
   Revision: 00---007    Serial number: 00000000075462
   Coding: 0000006
   VCID: 6889440CAE74D01736D-803C
                    Reset counter: 218
                    Mileage: 256955 km
                    Date: 2018.06.13
                    Time: 18:04:20
00003 - Control Module
                    Fault Status: 00100011
                    Mileage: 275778 km
                    Date: 2018.09.11
                    Time: 13:44:43
                    Reset counter: 157
                    Mileage: 290241 km
                    Date: 2009.03.25
                    Time: 15:01:31
                    Bin. Bits:    00000
                    Fault Frequency: 15
                    Reset counter: 160
                    Mileage: 290397 km
                    Date: 2009.02.18
                    Time: 18:36:32
                    Voltage: 9.50 V
                    Fault Frequency: 9
                    Reset counter: 160
                    Mileage: 290397 km
                    Date: 2009.02.18
                    Time: 18:45:21
                    Voltage: 6.90 V
Address 34: Level Control        Labels: 4L0-910-553.lbl
   Part No SW: 4L0 910 553 B    HW: 4L0 907 553
   Component: LUFTFDR.-CDC    H03 7550
   Revision: --H03001    Serial number: 15.1528-0095.2
   Coding: 0015520
   VCID: 290F010875FE291FE93-807C
                    Fault Frequency: 34
                    Reset counter: 160
                    Error Code: 13
                    Fault Frequency: 11
                    Reset counter: 160
                    Error Code: 64
01577 - Turn-Off due to Over-Temp
                    Reset counter: 155
                    Mileage: 289901 km
                    Date: 2009.02.25
                    Time: 13:47:52
                    Error Code: 68
01398 - Signal Conductor for Central Locking; Doors Open
                    Reset counter: 154
                    Mileage: 290008 km
                    Date: 2009.03.11
                    Time: 13:39:47
                    Error Code: 71
                    Reset counter: 157
                    Mileage: 290241 km
                    Date: 2009.03.25
                    Time: 14:53:36
                    Error Code: 116
   Part No SW: 4F0 910 760     HW: 4L0 959 760
   Component: Sitzmemory FS   H01 0100
   Revision: 00000000    Serial number: 00000000896401
   Coding: 0082954
                    Fault Frequency: 11
                    Reset counter: 160
                    Mileage: 27752 km
                    Date: 2009.02.25
                    Time: 13:26:33
                    Reset counter: 157
                    Mileage: 28096 km
                    Date: 2009.03.25
                    Time: 14:34:02
   Part No SW: 4E0 910 888 M    HW: 4E0 919 887 D
   Component: MNS US          H48 1100
   Revision: 00000000    Serial number: 313GJ067503840
   VCID: 3829D44CBE54809766D-806C
                    Reset counter: 160
                    Mileage: 289899 km
                    Date: 2009.02.25
                    Time: 13:26:22
                    Hex Value: 0x499C
                    Hex Value: 0x5741
                    Hex Value: 0x0045
02927 - DVD Read Error
                    Fault Frequency: 13
                    Reset counter: 131
                    Mileage: 281929 km
                    Date: 2018.12.20
                    Time: 20:06:19
                    Hex Value: 0x5C6D
                    Hex Value: 0x3E3E
                    Hex Value: 0x04FF
                    Hex Value: 0x0000
   Part No SW: 4L0 910 566 A    HW: 4L0 907 566 A
   Component: J0769_SWA_MasterH06 0060
   Revision: 00H06000    Serial number: 6PZ 009 014-00
   VCID: 2C01F81C7A0C3C37125-8078
   Subsystem 1 - Part No: 4L0 910 568 A
   Component: J0770_SWA_Slave_H05 0060
   Subsystem 2 - Serial number: 6PZ 009 014-20
   Subsystem 3 - Serial number: 3F28.09.0600H0500000010009ÿ
   Subsystem 4 - Serial number: 010009ÿ
02850 - Control Module 2 for Lane Change Assistance (J770)
            014 - Defective
                    Fault Status: 01101110
                    Reset counter: 239
                    Mileage: 259168 km
                    Date: 2018.06.24
                    Time: 11:22:52
                    Reset counter: 157
                    Mileage: 16 km
                    Date: 2009.03.25
                    Time: 19:05:56
                    Fault Frequency: 14
                    Reset counter: 160
                    Mileage: 16 km
                    Date: 2009.02.18
                    Time: 18:36:58
02857 - Supply Voltage for Lane Change Assistance Control Module 2
                    Fault Frequency: 13
                    Reset counter: 160
                    Mileage: 16 km
                    Date: 2009.02.18
                    Time: 18:37:18
                    Fault Frequency: 9
                    Reset counter: 160
                    Mileage: 16 km
                    Date: 2009.02.18
                    Time: 18:45:11
Address 42: Door Elect, Driver        Labels: 4L0-910-793-42.lbl
   Part No SW: 4L0 910 793 B    HW: 4L0 959 793 B
   Component: TSG FA          H12 0130
   Revision: 00000000    Serial number: a
   Coding: 0051915
   VCID: 2F3BEF104B1A472F377-807A
                    Fault Frequency: 9
                    Reset counter: 160
                    Mileage: 290397 km
                    Date: 2009.02.18
                    Time: 18:45:22
   Part No SW: 4L0 910 289 D    HW: 4L0 907 289 A
   Component: Komfortgeraet   H05 0020
   Revision: 0020 ---    Serial number: 01021089900000
   Coding: 7632925
   VCID: 313FE9685D2E51DF213-8064
                    Fault Frequency: 37
                    Reset counter: 157
                    Mileage: 290241 km
                    Date: 2009.03.25
                    Time: 14:34:04
02956 - Lamp in Trunk/Hatch Lid; Left
            009 - Open or Short to Ground
                    Fault Status: 01101001
                    Reset counter: 120
                    Mileage: 278630 km
                    Date: 2018.09.23
                    Time: 09:15:53
                    Bin. Bits:  000 010
                    Fault Frequency: 9
                    Reset counter: 160
                    Mileage: 290397 km
                    Date: 2009.02.18
                    Time: 18:46:21
Address 47: Sound System        Labels: 4L0-910-223-BO.lbl
   Part No SW: 4L0 910 223 D    HW: 4L0 035 223 A
   Component: DSP-High AU716  H02 0110
   Revision: PROD_01     Serial number: 00000000009593
   Coding: 0000056
   Shop #: WSC 21843 002 1048576
                    Reset counter: 160
                    Mileage: 290008 km
                    Date: 2009.03.11
                    Time: 13:40:31
                    Voltage: 8.30 V
                    Reset counter: 160
                    Mileage: 290008 km
                    Date: 2009.03.11
                    Time: 13:39:41
                    Voltage: 8.30 V
02247 - Subwoofer (R148/R157)
                    Reset counter: 156
                    Mileage: 279900 km
                    Date: 2018.10.28
                    Time: 13:35:56
   Part No SW: 4F0 910 280     HW: 4F0 907 280 B
   Revision:             Serial number: 00000000043549
   Coding: 0012001
   VCID: 5EE562D47C309EA7CC1-800A
                    Reset counter: 157
                    Mileage: 262136 km
                    Date: 2009.03.25
                    Time: 14:33:00
                    Voltage: 11.800 V
                    Temperature: 77.0°C
                    Fault Status: 00110010
                    Fault Frequency: 11
                    Reset counter: 160
                    Mileage: 262136 km
                    Date: 2009.02.25
                    Time: 13:27:00
                    Voltage: 7.000 V
                    Temperature: 77.0°C
                    Fault Frequency: 12
                    Reset counter: 160
                    Mileage: 262136 km
                    Date: 2009.02.25
                    Time: 13:25:00
                    Voltage: 8.300 V
                    Temperature: 77.0°C
Address 52: Door Elect, Pass.        Labels: 4L0-910-793-52.lbl
   Part No SW: 4L0 910 793 B    HW: 4L0 959 792 B
   Component: TSG BF          H12 0130
   Revision: 00-00000
   Coding: 0051915
                    Fault Frequency: 9
                    Reset counter: 157
                    Mileage: 290241 km
                    Date: 2009.03.25
                    Time: 14:34:01
                    Fault Frequency: 9
                    Reset counter: 157
                    Mileage: 290241 km
                    Date: 2009.03.25
                    Time: 14:34:01
                    Fault Frequency: 9
                    Reset counter: 160
                    Mileage: 290397 km
                    Date: 2009.02.18
                    Time: 18:45:18
   Coding: 0000022
                    Fault Frequency: 20
                    Reset counter: 40
                    Mileage: 290248 km
                    Date: 2009.03.25
                    Time: 14:53:08
                    Fault Frequency: 9
                    Reset counter: 160
                    Mileage: 290392 km
                    Date: 2009.02.18
                    Time: 18:45:16
   Part No SW: 4E0 910 541 M    HW: 4E0 035 541 P
   Component: TUNER EU/US/RDW H42 0570
   Revision: 00000000    Serial number: 388I$067552149
   VCID: 2A0DFE0470F82207E09-807E
                    Reset counter: 160
                    Mileage: 289899 km
                    Date: 2009.02.25
                    Time: 13:25:38
                    Fault Frequency: 187
                    Reset counter: 160
                    Mileage: 279905 km
                    Date: 2018.11.11
                    Time: 14:04:21
   Part No SW: 4L0 910 181     HW: 4L0 915 181
   Component: J0644 BEM       H12 0530
   Revision: --------    Serial number: 00000000052559
   Shop #: WSC 03089 444 85777
   VCID: 6491503C525CB4771A5-8030
   Component: von VA0  0123456789
   Coding: 344630393135313035442056413030313233343536373839
02256 - Quiescent Current
                    Reset counter: 160
                    Mileage: 235664 km
                    Date: 2018.02.19
                    Time: 03:18:49
                    Mileage: 237654 km
                    Date: 2018.02.27
                    Time: 20:36:59
                    Fault Frequency: 11
                    Reset counter: 160
                    Mileage: 289899 km
                    Date: 2009.02.25
                    Time: 13:27:30
                    Fault Frequency: 18
                    Reset counter: 157
                    Mileage: 290241 km
                    Date: 2009.03.25
                    Time: 14:33:58
Address 62: Door, Rear Left        Labels: 4L0-910-795.lbl
   Part No SW: 4L0 910 795 B    HW: 4L0 959 795 B
   Coding: 0051722
                    Fault Frequency: 34
                    Reset counter: 120
                    Mileage: 284413 km
                    Date: 2019.01.13
                    Time: 18:17:04
                    Fault Frequency: 9
                    Reset counter: 160
                    Mileage: 290397 km
                    Date: 2009.02.18
                    Time: 18:45:16
   Revision: 00050100    Serial number: 00000900033033
   Coding: 0062424
   VCID: 221D162408C8FA47A89-8076
                    Fault Frequency: 18
                    Reset counter: 157
                    Mileage: 290241 km
                    Date: 2009.03.25
                    Time: 14:34:08
                    (no units): 0.0
                    Voltage: 11.90 V
                    (no units): 33.0
                        Not Recogn.
                        Not Recogn.
                        Not Recogn.
                        Not Recogn.
                    Fault Status: 10100010
                    Fault Frequency: 9
                    Reset counter: 160
                    Mileage: 290397 km
                    Date: 2009.02.18
                    Time: 18:45:53
                    (no units): 255.0
                    Voltage: 6.80 V
                    (no units): 42.0
                        Not Recogn.
                        Not Recogn.
                        Not Recogn.
                        Not Recogn.
                    Reset counter: 93
                    Mileage: 259170 km
                    Date: 2018.06.24
                    Time: 11:26:25
                    (no units): 0.0
                    Voltage: 11.60 V
                    (no units): 19.0
                        Not Recogn.
                        Not Recogn.
                        Not Recogn.
                        Not Recogn.
   Component: SDS 3501 US     H45 0630
   Revision: 00000000    Serial number: 00000609040267
   Shop #: WSC 12336 024 394758
   VCID: 3431E07CA23C64F74A5-8060
                    Reset counter: 160
                    Mileage: 289899 km
                    Date: 2009.02.25
                    Time: 13:25:34
   Part No SW: 4L0 910 441 A    HW: 4L0 907 441 A
   Component: J772__Rearview      0050
   Revision: --H12---    Serial number: 525PA8-J6942CX
   Coding: 1001001
   VCID: 2411103C12DCF477DA5-8070
                    Fault Frequency: 17
                    Reset counter: 160
                    Mileage: 289899 km
                    Date: 2009.02.25
                    Time: 13:24:42
                        Term 15 Off
                        Reverse OFF
                    Count: 3
                    Fault Frequency: 11
                    Reset counter: 160
                    Mileage: 289899 km
                    Date: 2009.02.25
                    Time: 13:25:28
                        Term 15 Off
                        Reverse OFF
                    Count: 3
   Part No SW: 4L0 910 945     HW: 4L0 827 851 B
   Component: ValeoHeckdeckel H21 0280
   Revision: --H21001    Serial number: E5030000B
   Shop #: WSC 98765 666 38354
   Subsystem 3 - Serial number: RD06.10.06--H21001001C0290ÿ
   Subsystem 4 - Serial number: 1C0290ÿ
00317 - Rear Lid Control Module (J605)
                    Reset counter: 159
                    Mileage: 290330 km
                    Date: 2009.02.08
                    Time: 02:41:18
                    Fault Frequency: 18
                    Reset counter: 160
                    Mileage: 290241 km
                    Date: 2009.03.25
                    Time: 14:33:59
   Revision: AAH05061    Serial number: 001005364-----
   Coding: 0003595
   VCID: 26150A3464E00667C41-8072
   Component: J_245_EE15_SKB09H10 0180
   Component: J_394_EE15_SKB09H10 0180
   Component: J_392_EE15_SKB09H10 0180
                    Fault Frequency: 11
                    Reset counter: 160
                    Mileage: 289899 km
                    Date: 2009.02.25
                    Time: 13:25:13
02961 - Lamp in Bumper; Rear Right
                    Reset counter: 114
                    Mileage: 279918 km
                    Date: 2018.11.13
                    Time: 06:37:47
                    Bin. Bits:  000 001
                    Reset counter: 157
                    Mileage: 290241 km
                    Date: 2009.03.25
                    Time: 14:33:59
02907 - Control Module for Roof Shade (J394)
                    Reset counter: 160
                    Mileage: 290397 km
                    Date: 2009.02.18
                    Time: 19:15:51
02906 - Control Module for Sliding Roof; Rear (J392)
                    Reset counter: 160
                    Mileage: 290397 km
                    Date: 2009.02.18
                    Time: 20:24:23
Address 72: Door, Rear Right        Labels: 4L0-910-795.lbl
   Part No SW: 4L0 910 795 B    HW: 4L0 959 794 B
   Coding: 0051722
                    Fault Frequency: 40
                    Reset counter: 120
                    Mileage: 290397 km
                    Date: 2009.02.08
                    Time: 15:12:52
                    Fault Frequency: 9
                    Reset counter: 160
                    Mileage: 290397 km
                    Date: 2009.02.18
                    Time: 18:45:17
   Part No SW: 4F0 910 283 F    HW: 4F0 919 283 F
   Revision: 00H09000    Serial number: 06230701511300
   Coding: 0021246
                    Fault Frequency: 9
                    Reset counter: 160
                    Mileage: 290397 km
                    Date: 2009.02.18
                    Time: 18:45:24
                    Fault Frequency: 14
                    Reset counter: 160
                    Mileage: 290008 km
                    Date: 2009.03.11
                    Time: 13:39:43
                    Fault Frequency: 18
                    Reset counter: 40
                    Mileage: 290241 km
                    Date: 2009.03.25
                    Time: 14:33:58
00576 - Terminal 15
                    Fault Frequency: 14
                    Reset counter: 157
                    Mileage: 290241 km
                    Date: 2009.03.25
                    Time: 14:53:09
   Component: Handyvorb2      H16 1130
   Revision: 00000000    Serial number: 00000007572868
   Coding: 0010900
                    Reset counter: 160
                    Mileage: 289899 km
                    Date: 2009.02.25
                    Time: 13:26:21
End----------(Elapsed Time: 02:46, VBatt start/end: 12.0V/12.4V)-----------
Clear fault codes and repost scan after car idling 1 minute.
Consumers must be isolated for damage, blown fuse, water ingress or wiring damage.
Looks like a power problem of some sort; blown fuse, failed relay, etc.
I would start by looking for a common source of power for the actuators that show "Short to GND" faults in 01-Engine.
Reset counter: 120
Mileage: 290397 km
Date: 2009.02.18
Time: 18:36:30
Count: 14593
Count: 128
Count: 33792
Might be a good idea to charge or install fresh batteries & since lower levels are unacceptable or have been exceeded.
Better double down on some Wet Kessy water penetration?
Kessy scream's water ingress with 20 DTC's!
Jef
HQ
Fuse S13? Engine bay, left side, close to windshield.
rprellidzynr
Carmel, IN, USA
C?ID=339591
Fuse S13 was blown. Replacement fuse blew immediately on startup. Clearly we have an issue on this circuit.
The first consumer to act up was the TPMS, then Side Assist. Where are those modules located in the vehicle?
The battery's been disconnected for a few days now, will reconnect this evening and scan per Jack's instructions.
Best to leave disconnected and open Kessy for inspection and post detailed photos.
Jef
HQ
https://forums.ross-tech.com/showthread.php?4026-Popping-fuses-as-soon-as-you-put-them-in
Rig up a test light tool like that, pop it in place of the S13 fuse. If you have a short to ground, it will light up pretty bright.
Fuse S13 powers several items:
  • N112
  • N320
  • N290
  • N402
  • N80
Unplug all those items, the test light should not light up bright (pop fuses). If it does, you've got a wire shorted to ground, start a careful visual inspection.
Cool, only took 3 hours to post this.... :banghead:
rprellidzynr
Carmel, IN, USA
C?ID=339591
Jeff,
Here's one for ya....I have not one but two brake bulb test lights that I've been using for 30+ years. Ha! Mine have alligator clips on them, I'll just clip them to crimp-on spade terminals and follow your instructions. GMTA indeed!
Best,
Rob
Rob,
That makes you an old timer too because I still have mine.
rprellidzynr
Carmel, IN, USA
C?ID=339591
I was searching for descriptions for N112, N320, etc as detailed above, to hunt them down for inspection.
On searching one of them, I ran across an old post from this forum where a Q7 owner was having a similar myriad of electrical issues. His final solution was to replace the driver's side HPFP.
My driver's side HPFP has been dripping fuel for a while now, mostly just a fuel odor when stopped. This and the figure-8 oil seal under the intake that leaks are on my list, but figured I'd better look at the electrics before tackling anything mechanical.
Normally, fuse S13 was blowing immediately on startup. I replaced fuse S13, unplugged the driver's side HPFP and started the car.....no blown fuse.
