2010 Phaeton - Big Electrical Issues - VCDS not clearing faults
Mr_Rossi
England
C?ID=146235
Not too sure what happened but, the car will not start and the VCDS will not clear the error codes. Pretty sure the ECU is working as I can hear noises when trying to start the car. Any advice gratefully accepted.
Thanks in anticipation.
Sunday,26,May,2019,13:43:45:01891
VCDS Version: 18.9.1.0 (x64)
VIN: WVWZZZ3DZA800xxxx   License Plate:
Chassis Type: 3D (6N0)
Scan: 01 02 03 05 07 08 09 15 16 17 18 19 34 37 38 42 46 47 52 56
          62 68 71 72 76 77
VIN: WVWZZZ3DZA800xxxx   Mileage: 169280km-105185miles
02-Auto Trans -- Status: Cannot be reached 1100
68-Wiper Electr. -- Status: OK 0000
71-Battery Charger -- Status: OK 0000
Address 01: Engine (CEX)       Labels: None
   Part No SW: 3D0 907 401 G    HW: 3D0 907 401 D
   Component: 3.0TDI EDC17G000AG  0030
   Revision: --H01---    Serial number: VWX3Z0I1861025
   Coding: 0406002C191F0160
   Shop #: WSC 01065 000 00000
   VCID: 234FC021E1D29B52E0-50EA
049409 - No Communication with Transmission Control Module
               U0101 - 001 -
                    Fault Status: 01100001
                    Mileage: 169288 km
                    Date: 2019.05.25
                    Time: 19:33:59
                    Load: 0.0 %
                    Voltage: 11.17 V
                    Bin. Bits: 00000000
                    (no units): 8.0
                    Bin. Bits: 00000001
Address 02: Auto Trans
Address 03: ABS Brakes
   Part No SW: 3D0 909 139 D    HW: 3D0 909 139 D
   Component:    Kessy            6850
   Revision: 00H22072    Serial number: VWX3Z0I1861025
   Coding: 0004328
   VCID: 2A512D0581F84A1AA3-807E
   Subsystem 1 - Part No: 4E0 905 852 E
   Component: ELV                 2141
Address 07: Control Head        Labels: 3D0-907-048.clb
   Part No SW: 3D0 907 048     HW: 3D0 907 048
   Component: J127 KBT vorn       0031
   Revision: ABH64001    Serial number: VWZ6Z7M0243072
   VCID: 63CF8021A652DB52A0-8036
Address 08: Auto HVAC        Labels: 3D0-907-040.lbl
   Part No: 3D0 907 040 L
   Component: Climatronic D1      2035
   Coding: 0000001
   VCID: 2757D43192EA7772BC-8072
Address 09: Cent. Elect.
Unable to communicate with address 09. Are you sure the doors are unlocked?
Address 15: Airbags        Labels: 3D0-909-601.lbl
   Part No: 3D0 909 601 E
   Component: 0H Airbag 8.4E+ H12 0935
   Coding: 0012360
   VCID: 254BDE39E8E665628E-8070
Address 16: Steering wheel        Labels: 7L6-953-549.lbl
   Part No: 7L6 953 549 K
   Component: J527                3601
   Coding: 0000011
   VCID: 479774B132AA97725C-8012
Address 17: Instruments        Labels: 3D0-920-xxx-17.lbl
   Part No SW: 3D0 920 983 C    HW: 3D0 920 983 C
   Component: J285 KOMBI-INST.    0616
   Revision: KPH06V01
   Coding: 0039401
   Shop #: WSC 00670 067 57207
   VCID: 2953D20980FE4102AA-807C
                    Reset counter: 84
                    Mileage: 169288 km
                    Date: 2019.05.25
                    Time: 19:56:29
   Part No: 3D0 815 005 AP
   Component: J737__Standheizung  4405
   Revision: 00084000    Serial number: 09020869A00000
   VCID: 6BDFE8014A82931218-803E
Address 19: CAN Gateway        Labels:. 6N0-909-901-7L.clb
   Part No SW: 6N0 909 901     HW: 3D0 920 983 C
   Component: J533  GW-K-CAN TP20 0616
   Coding: 5FF2F3AC3B011003
   VCID: 70E5FF6D63A470CA2D-8024
                    Reset counter: 84
                    Mileage: 169288 km
                    Date: 2019.05.25
                    Time: 19:56:29
Address 34: Level Control
Address 37: Navigation (J0506)       Labels:. 3D0-035-680.clb
   Part No SW: 3D0 035 680     HW: 3D0 035 680
   Component: RNS-MID       H64 0210
   Revision: AB001001    Serial number: VWZ6Z7M0243072
   Coding: 020100000000002200
   Shop #: WSC 00670 210 45725
   VCID: 5DBBB6D94436EDA296-8008
Address 38: Roof Electronics        Labels: 3D0-907-135.lbl
   Part No: 3D0 907 135 E
   Component: Dachmodul           0802
   Coding: 0004157
Address 46: Central Conv.
Address 47: Sound System
Address 56: Radio (J0506)       Labels:. 3D0-035-680.clb
Address 68: Wiper Electr.        Labels: 3Dx-955-1xx-V2.clb
   Part No: 3D2 955 120 B
   Component: Front Wiper         3501
   Coding: 0013685
   Shop #: WSC 01065 000 376832
   VCID: 2143CA29FCCE8942F2-8074
Address 71: Battery Charger        Labels: 3D0-915-181.lbl
   Part No: 3D0 915 181 D
   Component: Batteriemanagement  2800
   VCID: 244DC33DE3DC9C6A99-8070
Address 76: Park Assist        Labels: None
   Part No: 3D0 919 283 E
   Component: 10 Einparkhilfe     1107
   VCID: 2C5D2B1D8B0C542A51-8078
            013 - Check DTC Memory
Address 77: Telephone
End-------------------------(Elapsed Time: 04:27)--------------------------
jyoung8607
FoRT
Cincinnati, OH
C?ID=25607
Welcome to the forum, and welcome to Team Phaeton! We demand to be taken seriously!
Lots of things in the car are unresponsive to diagnostics, but only the transmission controller is actually offline totally. Hmm.
Let's check the simple things first:
                    Load: 0.0 %
                    Voltage: 11.17 V
That's very low. Check the state of BOTH batteries, and then place a charger on them if you can. You can get in a situation where the cabin electronics mostly work, but the engine just can't crank, if the left-side battery (vehicle power supply) is low and the right one (starting) is kaput. The Phaeton has a paralleling relay and some other emergency starting logic to help, but often that just hides a problem until it gets really bad. A MY2009 car with the factory batteries would be well overdue.
In addition to all aforementioned, check fuses & for water ingress!
Apologies for being pedantic here, but based on the VIN, this is a 2010 car (which of course doesn't preclude it having been made and even registered in 2009). But since Model Year is what's most important when it comes to diagnostics, I've fixed the thread title. :cool:
Mr_Rossi
England
C?ID=146235
Have charged both batteries and have same problem - Latest scan below
Both batteries charged all day and still a low voltage. Thanks all for your help. The car is a 59 plate.
Load: 0.0 %
Voltage: 10.03 V
Bin. Bits: 00000000
(no units): 8.0
Bin. Bits: 00000001
Both batteries about 3 years old
Not old enough that they should be bad at this time, but not new enough that they're "known good". I'd pull them and load-test them individually.
jyoung8607
FoRT
Cincinnati, OH
C?ID=25607
I fell victim to one of the classic blunders! The most famous of which is "never get involved in a land war in Asia," but only slightly less well-known is this: "Always check the VIN when a Brit tells you his model-year because 80% of the time he's talking about his license plate!" :D
jyoung8607
FoRT
Cincinnati, OH
C?ID=25607
Load: 0.0 %
Voltage: 10.03 V
Bin. Bits: 00000000
(no units): 8.0
Bin. Bits: 00000001
It's gotten considerably worse since your last scan. That is not consistent with a healthy battery that was on a decent charger for any length of time. Do you have a multimeter? Can you check each battery directly with the car shut off? Phaetons do have some common issues, like water intrusion into the KESSY security module, but the voltage here is just too low to even go down that road yet.
VAG batteries & on a routine, seem to not last past 2 years and or unless they are put on maintainers due to sleep mode failing to be achieved, no?
It's on again, off again. I've had some original (i.e. came with the car when new) batteries last 6-8 years, but I've also seen some fail at 2 years.
Well sure but does this count, when the statistics show themselves at a 2 year lease auction & where almost every battery is dead or requiring a jump start by the "lane starter" & of over 500 cars per show? :rolleyes:
Mr_Rossi
England
C?ID=146235
Hi Guys, thank you so much for your support and I had to get an Auto Electrician to sort out the issue as it was past my ability. He said that the gear lever was not communicating with the steering column and needed re-mapping. The car is working now and lessons learned are;
If it's working, don't go looking for issues
Don't play around with fuses
Below a scan just done and to say thanks again for your help;
Friday,07,June,2019,14:05:28:01891
VIN: WVWZZZ3DZA8000590   License Plate:
          62 68 71 72 76 77
VIN: WVWZZZ3DZA8000590   Mileage: 169290km-105191miles
   VCID: 234FC021E1D29B52E0-5106
   Part No SW: 09L 927 760 R    HW: GS1 911 4
   Component: AG6 09L 3,0 TDI RdW 3606
   Revision: --H04---    Serial number:        4522722
   Coding: 0000001
   VCID: 468979B532A08E7AA7-5124
Address 03: ABS Brakes        Labels: 3D0-614-517.lbl
   Part No: 3D0 614 517 AK
   Component: ESP 5.7 allrad  H35 0047
   Coding: 0008356
   VCID: 6BDFE8014982931218-5140
   Coding: 0004328
   Coding: 0000001
Address 09: Cent. Elect.        Labels:. 3D0-937-049-V2.clb
   Part No SW: 3D0 937 049 N    HW: 3D0 937 049 N
   Component: J519                6900
   Revision: -4005---    Serial number: --------------
   Coding: 60810000AB211DC20100000000000000
   VCID: 356B0E79584615E23E-8060
   Coding: 0012360
   Coding: 0000011
   Revision: KPH06V01
   Coding: 0039401
Address 34: Level Control        Labels: 3D0-907-553-V2.clb
   Part No: 3D0 907 553 C
   Component: LUFTFDR.-CDC- 3C3V0 1122
   Coding: 0005521
   Coding: 0004157
Address 46: Central Conv.        Labels: 3D0-959-933.lbl
   Part No: 3D0 959 933 M
   Component: 4Z HSG              8132
   Coding: 0000040
   Shop #: WSC 56073 001 1048576
   VCID: 3A711D457658FA9AD3-4AEA
   Subsystem 1 - Part No: 3D2 959 701 H
   Subsystem 2 - Part No: 3D2 959 702 H
   Subsystem 3 - Part No: 3D0 959 703 G
   Subsystem 4 - Part No: 3D0 959 704 G
   Subsystem 5 - Part No: 3D0 909 610 E
   Component: 3O HDSG             2530
   Subsystem 6 - Part No: 7L0 907 719 A
   Component:    Neigungssensor   0020
Address 47: Sound System        Labels: 7Lx-035-4xx-47.lbl
   Part No SW: 3D0 035 465 C    HW: 3D0 035 465 C
   Component: 08K Audioverst.     0120
   Revision: 00005000    Serial number: 00000000216602
   VCID: 2143CA29F8CE8942F2-8074
   Coding: 0013685
Address 77: Telephone        Labels: None
   Part No SW: 3D0 035 385 A    HW: 3D0 035 385 A
   Component: J412                8605
   Revision: 00016000    Serial number: 0000B7A085377
   Coding: 0020141
   VCID: 2045CF2DF3C4804AFD-8074
End-------------------------(Elapsed Time: 03:53)--------------------------
Somehow I think your auto-electrician is using different terminology than we do. :confused:
