Fault Codes 02895 & 02897 2013 Audi S5
andrewgovroom
C?ID=370061
Fault Codes 02895 & 02897 for 2013 Audi S5 Please Help!
Hi everyone! Just got my first Ross-Tech VCDS earlier this week. I bought this VCDS because i'm hoping it could help me fix fault codes 02895 & 02897. My mechanic was messing around in my headlight setting because I had a different fault code, at the time, and he some how change some settings some how. I know most people thinks it was the DRL Modules, but I replaced both of them and i'm still getting those 2 fault codes. However after playing around with my mechanics Autel for a couple hours, I believe it is not a hardware issue, it is more like software/setting issue. I concluded that the only reason why i'm getting these 2 fault codes is because when my head lights are on, the LED DRL doesn't dim and light up anymore. Keep in mind my DRL aren't defective, they work perfectly during the day. I notice I only get these fault codes only when my low beam head lights are on.
So my question is, does anyone know if Ross-Tech VCS actually has an option to turn on the DRL dim when low beam is on? Thank you in advance for any help you could provide. I have a 2013 Audi S5.
UPDATE 5-25-2019
I went through all the long code bits in the central electronics, and none of them has an option to turn on DRL with Low Beam. However there was one that allows you to turn on DRL with High Beam, but that didn't do anything that I noticed..
Here is the AutoScan Log I saved right after I finished installing and setting up the software on my laptop. Please note this Autoscan log is after I got the 2 fault codes. I do not have my original autoscan log given this is the first VCDS I ever bought. Thank you again for anyone who can help!
Saturday,25,May,2019,16:19:49:58979
VIN: WAUCGAFR6DA074900   License Plate:
Chassis Type: FR-AU48 (8R0)
Scan: 01 02 03 05 06 08 09 15 16 17 19 22 36 42 44 46 47 52 53 56
          5F 6C A9
VIN: WAUCGAFR6DA074900   Mileage: 79350km-49305miles
Address 01: Engine (J623-CGXC)       Labels:. 06E-907-551-CGW.clb
   Part No SW: 8K5 907 551 E    HW: 4G0 907 551 A
   Component: 3.0l V6 TFSIH07 0004
   Revision: --H07---
   Coding: 1A250034052600060000
   Shop #: WSC 49910 001 1048576
   ASAM Dataset: EV_ECM30TFS0218K5907551E 001004
   ROD: EV_ECM30TFS0218K5907551E.rod
   VCID: 3829292612DDEDF766D-806C
   Part No SW: 8K2 927 156 M    HW: 0B5 927 156 J
   Component: 0B5 30TFSINAR H01 0009
   Revision: --H01---
   Shop #: WSC 06325 000 00000
   ASAM Dataset: EV_TCMDL501021 001012
   ROD: EV_TCMDL501021.rod
   VCID: 40D941C64A0DA537DED-8014
   Part No SW: 8K0 907 379 CK    HW: 8K0 907 379 CK
   Component: ESP8 quattro  H09 0100
   Coding: 291D1A
   VCID: 04518DD61E157917BA5-8050
   Part No SW: 8K0 907 064 GM    HW: 8K0 907 064 FM
   Coding: 0D804000000000000000
   VCID: 015F84C201076C3F913-8054
   Serial number: 2313000061264006
Address 06: Seat Mem. Pass (J521)       Labels:. 8T0-959-760.clb
   Part No SW: 8T0 959 760 E    HW: 8T0 959 760 E
   Component: MEM-BFS       H10 0076
   Revision: AA000000    Serial number: 00000057786625
   Coding: 00037025002C00000000
   VCID: 45D750D255AF801FEDB-8010
   Revision: C1000000    Serial number: 01180420130852
   Coding: 6602228000
   VCID: 392F2C222957F4FF993-806C
   Revision: 08016001    Serial number: 00000595553002
   Coding: 26000095863CBFE0210048C300003D0D0F9CD388A2090221000008004000030100000030000000
   Shop #: WSC 06342 123 12345
   VCID: 78A9E92652DD2DF7A6D-802C
   Subsystem 1 - Part No SW: 8T1 955 119 D    HW: 8J1 955 119   Labels: 1KX-955-119.CLB
   Component: WWS 150413  H15 0080
   Serial number: SWF13040155466
   Coding: 00FD11
   Serial number: 21200973
   Coding: 02005D
   Component: E1 - LDS  H03 0031
   Serial number: 00000000000604131772
   Component: USHL4.2  H30 0030
   Serial number: 0000002274555R5LJ202
   Serial number: D358C0A6000000000001
02895 - Supply Voltage for LED Module for DRL and Parking Light; Left
                    Fault Status: 01101100
                    Fault Frequency: 11
                    Reset counter: 79
                    Mileage: 78678 km
                    Date: 2019.05.12
                    Time: 17:51:19
02897 - Supply Voltage for LED Module for DRL and Parking Light; Right
                    Fault Frequency: 11
                    Reset counter: 79
                    Mileage: 78678 km
                    Date: 2019.05.12
                    Time: 17:51:20
   Serial number: 003KJD91N4TZ
   Coding: 303343334830303030304A55304C38543053
   VCID: 4ACD63EE7C316F67009-801E
   Subsystem 1 - Part No SW: 8K0 959 339 A    HW: 8K0 959 339 A
   Component: BF-Gewichtss.  H02 0060
   Serial number: 5810000R130000CTN4
   Serial number: 6334MSME7B4526019
   Serial number: 6344MSME79053373B
   Serial number: 6352QSME34313F4EO
   Serial number: 6362QSME2730016EB
   Serial number: 63732SME1A303652T
   Serial number: 63832SME1A301E50Y
   Part No SW: 8R0 953 568 S    HW: 8R0 953 568 S
   Component: Lenks.Modul   H07 0171
   Revision: 00000000    Serial number: 20130413000430
   Coding: 000036
   VCID: 51FF748291E75CBF413-8004
   Part No SW: 8T0 920 983 P    HW: 8T0 920 983 P
   Revision: 00200000    Serial number: UUZ25VH4E
   Coding: 8BB701008301D705020200
   Shop #: WSC 06325 123 12345
   VCID: 4BC366EA73CB766F3BF-801E
   Part No SW: 8R0 907 468 N    HW: 8R0 907 468 C
   Component: GW-BEM 4CAN-M H11 0056
   Revision: 1Y070028    Serial number: 2841Y133288178
   Coding: 80C303FF00
   VCID: 4ACD63EE7CB16F67009-801E
   Serial number: 0495750303
   Component: 4 Wheel Drive H14 0100
   Serial number: 000704130001416
   VCID: 2F3B127AE7932A4F377-807A
   Component: MEM-FS        H10 0076
   Revision: AA000000    Serial number: 00000057784899
   Coding: 001B7B25002C00000000
   Component: TSG FA        H09 0304
   Coding: 011C13224E00120102
   VCID: 56F5879EB8093B87941-8002
   Revision: 00001000    Serial number: 0010384982
   Coding: 100000010001
   Shop #: WSC 06324 000 00000
   ROD: EV_RCEPSAU48X_008.rod
   VCID: 34311D160EB509974A5-8060
   Revision: 00002001    Serial number: 0304725176
   Coding: 0106029A00FA400580B0003200000000
   Component: GTO BF  H01 0080
   Serial number: 00000000000000659515
   Component: J245EE20SKB13  H05 0220
   Revision: 00005001    Serial number: 94813013373802
   VCID: 2D070872ED1F585F05B-8078
   Component: TSG BF        H09 0304
   VCID: 55F78092A50F309F9DB-8000
   Revision: --------    Serial number: 10000000199777
   ROD: EV_ParkiBrake_AU48.rod
   Part No SW: 4G0 035 082 E    HW: 4G0 035 082
   Component: Radio U SIRIU H60 0121
   Revision: AB001007    Serial number: 156DZ0D7715082
   Coding: 020007010000000001
   Shop #: WSC 06342 000 00000
   VCID: 221DEB4EA4C19727A89-8076
   Part No SW: 8R1 035 746 C    HW: 8R1 035 746 B
   Component: H-BNT-NA      H44 0624
   Revision: --------    Serial number: 204DX0D7573264
   Coding: 140200020206A1EF45028B4E00000403140000000000000000
   VCID: 372B2A1A1F43E28F6F7-8062
   Subsystem 1 - Part No: 8R0 060 884 BA
   Component: NAR 2013  0703
   Component: DU7 High  H42 0104
   Serial number: A130DL0D2702724
   Serial number: 00000001473118
   Component: CD-Database  4949
   Revision: --H07---    Serial number: 525PA8-J31918V
   Coding: 1000008
   VCID: 382929261E5DEDF766D-806C
   Component: SAS-GEN 2     H06 0005
   Serial number: 130319200578
   VCID: 72BDDB0E342147A7989-8026
End----(Elapsed Time: 01:49, VBatt start/end: 11.9V/11.9V. VIgn 11.8V)-----
-Andrew
As always, when asking a coding/adaptation question it's much easier to answer if you include a full unedited VCDS Auto-Scan :thumbs: - see my signature for a How-To
andrewgovroom
C?ID=370061
Thank you for the advice! I'm very new to this so I will definitely do a VCDS auto-scan.
Andrew has started a duplicate thread here, and merging them would be messy/redundant, so I'm closing this one.
PS: For future reference and as a matter of general forum policy: We can easily move a thread to a more appropriate section one a person becomes verified, and I would much prefer to do that rather than having duplicate threads cluttering up the forum. However, it may not be immediately obvious that this should be done, so if someone things a thread should be relocated, feel free to shoot me a PM.
