GOLF 6 R Retrofit discover media with pdc with rvc
Ljubo
Croatia
C?ID=271067
hello i have retrofit discover media pq35 with pdc and rvc and everything working good.now i have seen in some vw cars pdc screen with path display and i dont know why my pdc module not show path.my pdc module now is 1k8919472 and in coding have vehicle path display but on not shown on screen is it i must changed pdc module to 1k8919472c thanks ljubo
siLc
Tallinn, Estonia
C?ID=330192
Parking lines are generated by the RVC module, not PDC. If your RVC connects straight to the radio, then there is nothing to generate the lines in the RVC picture. The correct RVC module for Discover Media PQ is 7N0907441B, which will need its own +12v, ground and Infotainment CAN connection.
Ljubo
Croatia
C?ID=271067
Not lines from camera when go backward i seen when go forward lines moves when turn wheel
siLc
Tallinn, Estonia
C?ID=330192
Which car visualization have you chosen in 1K8919472 coding Byte 0 for the PDC moving lines?
Ljubo
Croatia
C?ID=271067
Did you mean cameraor ops or automatic my coding now is automatic
Ljubo
Croatia
C?ID=271067
In byte 0 nothing possible change
siLc
Tallinn, Estonia
C?ID=330192
Sorry, I meant Discover Media Byte 0.
Ljubo
Croatia
C?ID=271067
I must look but i think golf 7
Ljubo
Croatia
C?ID=271067
I have normal ops screen with camera and works good but i don't have moving lines when turn the steering wheel
siLc
Tallinn, Estonia
C?ID=330192
Ohh, now I see. There are no PDC turning lines with RVC. This is only with no RVC.
Ljubo
Croatia
C?ID=271067
Maybe i must upgrade pdc module with newer 1k8919972c do you think
Ljubo
Croatia
C?ID=271067
Ljubo
Croatia
C?ID=271067
I want is it possible like that
Ljubo
Croatia
C?ID=271067
Now I have like this
Ljubo
Croatia
C?ID=271067
siLc
Tallinn, Estonia
C?ID=330192
An example. I have Discover Media PQ, PLA module 1K8919475D and highline RVC in my Passat B7 Variant. Before I retrofitted the RVC, I had to code DM first byte so the car image is Passat CC. This is because the PDC turning lines were missing when I selected the car image to be Golf 7 Variant, which physically resembles my B7 Variant better. You may have to experiment with different car image options to get the PDC moving lines to display (when no RVC image is displayed). Also check in PDC coding if BAP 4.0 is selected.
Ljubo
Croatia
C?ID=271067
Ok i try change image of car. Now i have coding BAP 3.3 because when i put 4.0 no have any image on DM.
Ljubo
Croatia
C?ID=271067
Now I try to change image but nothing same only change car image and try to change 4.0 BAP but nothing and try to reset DM and nothing
