Remote control door isn't working anymore
Jopie89
C?ID=253932
Hi Guys,
We have a ross-tech cable for some time now, and mostly use it to reset intervals or read fault codes. Sometimes small changes like seatbelt beep and stuff but normally we don't use the full potential of the cable. But now we have a car that has a problem. I think this problem is solvable with the cable, altough I just don't know how because we are not very used to uncover the full strength of the cable :-p. So thats why I decided to turn to this forum. Expect a lot of silly questions during your answers when helping me, which I'm already appologizing for.
We have a car in the shop. Everything is fine with it but it only can't unlock or close the doors using the remote control. However, the windows roll up/down by the remote control. THis tells me that the antenna for the receiver and the remote control itself are good. It probably is just an error in the coding options. Since label files are not available for this car it's a pain in the ass to find out what is wrong. In the past a made a scan from this car (which posted below) when it was working fine. All the long coding is the same, so I really can't figure out what is wrong.
It's a VW polo beats edition from 2016-2017. The faultcodes in the scan below are already covered and solved.
Does anybody know how to get the central electrics to work again? How can I get the remote control to work again to open/close the doors?
Dinsdag,09,Oktober,2018,10:28:26:41047
VCDS -- VAG/VAS Emulator onder Windows Loopt op Windows 10 x64
VCDS Versie: PRI 17.8.1.0
Data versie: 20171211 DS276.6
Chassisnummer: WVWZZZ6RZHY135739   Kenteken: PR233S
KM-stand: 28502km   Reparatieorder:
Chassis Type: 6R-VW26 (6C0)
Scan: 01 02 03 08 09 10 15 17 19 44 47 5F
Chassisnummer: WVWZZZ6RZHY135739   KM-stand: 28502km
01-Motor -- Status: OK 0000
02-Autom. Transm. -- Status: Functioneert niet 0010
03-ABS Remmen -- Status: OK 0000
08-Airco/Verwarming -- Status: OK 0000
10-Park/Stuurassist -- Status: OK 0000
17-Instrumenten -- Status: OK 0000
19-CAN Gateway -- Status: Functioneert niet 0010
44-Stuur Hulp -- Status: OK 0000
47-Geluidssyteem -- Status: OK 0000
5F-Info Electr. -- Status: OK 0000
Adres 01: Motor (J623-CHZC)       Labels:. 04E-907-309-V1.clb
   Onderdeelnr. SW: 04C 906 026 Q    HW: 04C 907 309 AE
   Component: R3 1.0l TFS   H25 3581
   Revisie: W1H25---
   Codering: 01250032232419080000
   Dealer #: WSC 00788 648 00255
   ASAM Dataset: EV_ECM10TFS01104C906026Q 002007
   ROD: EV_ECM10TFS01104C906026AH_002_VW26.rod
   VCID: 2F67620A76BD1B3E38-807A
   CAN omvormer 01:
Geen foutcodes gevonden.
Gereedheid: 0000 0000
Adres 02: Autom. Transm. (J743)       Labels: 0CW-927-769.clb
   Onderdeelnr. SW: 0CW 300 040 R    HW: 0AM 927 769 E
   Component: GSG DQ200G2_M H05 1006
   Revisie: 00005026    Serienummer: CU501610145847
   Codering: 0014
   ROD: EV_TCMDQ200021_VW26.rod
   VCID: 438F3EBACA358F5ECC-8016
1 Fout Gevonden:
10632 - Keuzehendel
          U0103 00 [040] - Geen communicatie
          Geregeld - Bevestigd - Getest sinds Wissen Geheugen
             Freeze frame:
                    Fout Status: 00000001
                    Fout Prioriteit: 0
                    Fout Frequentie: 1
                    KM-stand: 27971 km
                    Datum: 2018.10.02
                    Tijd: 16:26:11
                    Motortoerental: 18.75 /min
                    Motorkoppel: -100 Nm
                    Rijsnelheid: 88 km/h
                    Regelapparaattemperatuur: 46 °C
                    Werkelijke druk: -9.5 bar
                    Koppeling hoofdtoestand: Rijden
                    ingeschakelde versnelling: GANG_7
                    Rijstand: N
                    Gaspedaalstand: 0.0 %
                    Status storinggeheugen: 0
Adres 03: ABS Remmen (J104)       Labels:. 6R0-907-37x-ESP90.clb
   Onderdeelnr. SW: 6C0 907 379 R    HW: 6R0 907 379 BA
   Component: ESP9.0i       H04 0006
   Serienummer: 08505202161022
   Codering: 21DD4885892633C5111B106C005A841291CC88080005CB098F00
   ASAM Dataset: EV_Brake1ESP90iBOSCHPQ26 100020
   VCID: 3E794F4EA1D7E2B6A3-806A
Adres 08: Airco/Verwarming (J255)       Labels:| 6C0-907-044.clb
   Onderdeelnr. SW: 6C0 907 044 D    HW: 6C0 907 044 D
   Component: Climatronic   H02 0204
   Serienummer:  1611022A-1642
   Codering: 200000001111000001
   ASAM Dataset: EV_ACClimaValeoPQ26 003001
   ROD: EV_ACClimaValeoPQ26_VW26.rod
   VCID: 254B80222441516EC2-8070
Adres 09: Cent. Elect. (J519)       Labels:* Redir Fout!
   Onderdeelnr. SW: 6C0 937 087 D    HW: 6C0 937 087
   Component: BCM PQ26 Me4R H10 0094
   Serienummer: 006298031125
   Codering: 0010184042530AF34F844000402703481000590253010000000000000000
   ASAM Dataset: EV_BCMA0 006002
   ROD: EV_BCMA0_006_VW26.rod
   Sensor voor regen- en lichtherkenning:
   Subsysteem 1 - Onderdeelnr. SW: 5Q0 955 547 B    HW: 5Q0 955 547 B  Labels: 5Q0-955-547.CLB
   Component: RLHS  042 0105
   Serienummer: S6Y16M10D11H22M19S31
   Codering: 0038DD
   Portierregelapparaat bestuurderszijde:
   Subsysteem 2 - Onderdeelnr. SW: 6R0 959 801 DG    HW: 6R0 959 801 DG  Labels: 6R0-959-801.CLB
   Component: J386__TSG_FT  003 0610
   Serienummer: KU0KU018101662925411
   Codering: 0400A0
   Portierregelapparaat bijrijderszijde:
   Subsysteem 3 - Onderdeelnr. SW: 6R0 959 802 DL    HW: 6R0 959 802 DL  Labels: 6R0-959-802.CLB
   Component: J387__TSG_BT  003 0610
   Serienummer: KU0KU012101662862930
   Codering: 1400A0
   Regelapparaat voor schuifdak:
   Subsysteem 4 - Onderdeelnr. SW: 6R0 959 591 D    HW: 6R0 959 591 D
   Component: J245 PS72.403  H03 0004
   Serienummer: 0000FST0018OZ2Y00000
   Codering: 181001
   Sensor luchtvochtigheid: binnen:
   Portierregelapparaat achter: bestuurderszijde:
   Subsysteem 6 - Onderdeelnr. SW: 6R0 959 811 AA    HW: 6R0 959 811 AA
   Component: J388__TSG_HL  003 0610
   Serienummer: KU0KU025101662993394
   Codering: 0400A0
   Portierregelapparaat achter: bijrijderszijde:
   Subsysteem 7 - Onderdeelnr. SW: 6R0 959 812 AA    HW: 6R0 959 812 AA
   Component: J389__TSG_HR  003 0610
   Serienummer: KU0KU017101662918117
   Codering: 1400A0
Adres 10: Park/Stuurassist (J446)       Labels:| 5Q0-919-294.clb
   Onderdeelnr. SW: 5Q0 919 294 K    HW: 5Q0 919 294 A
   Revisie: --------    Serienummer: 39331630202445
   Codering: 0031051011
   ROD: EV_EPHVA18AU3700000_VW26.rod
Adres 15: Airbags (J234)       Labels:| 6C0-959-655.clb
   Onderdeelnr. SW: 6C0 959 655 J    HW: 6C0 959 655 J
   Component: VW20Airbag00N 002 0380
   Revisie: --------    Serienummer: 003TH00CZHH1
   Codering: 88C0C000000000005C0000CA000800000000
   ROD: EV_AirbaVW20BPAVW26X.rod
   VCID: 3A71435EBDFFCE969F-806E
   Ongevalsensor voor zij-airbag: bestuurderszijde:
   Subsysteem 1 - Onderdeelnr. SW: -----------    HW: 410 820 411 16
   Component: SideSensor_Df  151 0800
   Serienummer: 3575H00BD22AE860329V
   Codering: 2D2D2D
   Ongevalsensor voor zij-airbag: bijrijderszijde:
   Subsysteem 2 - Onderdeelnr. SW: -----------    HW: 410 820 411 16
   Component: SideSensor_Pf  151 0800
   Serienummer: 3585H00A1226A6736106
   Codering: 2D2D2D
   Ongevalsensor voor zij-airbag achterin: bestuurderszijde:
   Subsysteem 3 - Onderdeelnr. SW: -----------    HW: 442 152 010 16
   Component: SideSensor_Dr  1CA 0148
   Serienummer: 3517A00B1223B6C3E1AG
   Codering: 2D2D2D
   Ongevalsensor voor zij-airbag achterin: bijrijderszijde:
   Subsysteem 4 - Onderdeelnr. SW: -----------    HW: 442 152 010 16
   Component: SideSensor_Pr  1CA 0148
   Serienummer: 3527A00A521DBB220367
   Codering: 2D2D2D
Adres 17: Instrumenten (J285)       Labels:| 5G0-920-XXX-17.clb
   Onderdeelnr. SW: 6C0 920 740 E    HW: 6C0 920 740 E
   Component: KOMBI         202 2310
   Codering: 072D09082180000801086A001000000000000000
   VCID: 244D9D262F7BA866D5-8070
Adres 19: CAN Gateway (J533)       Labels:| 6C0-909-901-V1.clb
   Onderdeelnr. SW: 6C0 909 901 A    HW: 6C0 937 087
   Component: GW MQB A0     H10 0094
   Revisie: --------    Serienummer: 006298031125
   Codering: 030000046F0A560071000000000000010001010000000000000000000000
   ASAM Dataset: EV_GatewA0Lear 013020
   ROD: EV_GatewA0Lear_VW26.rod
   VCID: 2649872E59475A76CB-8072
   Regelapparaat voor accubewaking:
   Subsysteem 1 - Onderdeelnr. SW: 6C0 915 181 B    HW: 6C0 915 181 B
   Component: J367-BDM  H08 0270
   Serienummer: 63300503365881792761
1 Fout Gevonden:
1282 - Voedingsspanning
          U1011 00 [008] - Spanning te laag
             Freeze frame:
                    Fout Prioriteit: 2
                    Fout Frequentie: 1
                    Reset Teller: 1
                    KM-stand: 28219 km
                    Datum: 2018.10.05
                    Tijd: 20:19:30
                    Voedingsspanning contact 30: 8.3 V
                    Contact 15: aan
Adres 44: Stuur Hulp (J792)       Labels:| 6Rx-909-144-V2.clb
   Onderdeelnr. SW: 6C1 909 144 AJ    HW: 6C1 909 144 D
   Component: EPS_TRW_ALow  313 3242
   Serienummer: CGB80420
   Codering: 000700
   ASAM Dataset: EV_SteerAssisUDSTRW 016134
   ROD: EV_SteerAssisUDSTRW.rod
   VCID: 70E5A176AB0344C661-8024
Adres 47: Geluidssyteem (J525)       Labels:* Geen
   Onderdeelnr. SW: 5Q6 035 456     HW: 5Q6 035 456
   Component: KonzernAmp 8K H01 2426
   Revisie: --------    Serienummer: A1117A00005232
   Codering: 0202000000AAAA00000000000000
   ASAM Dataset: EV_AMPCAN8C1PASE 001015
   ROD: EV_AMPCAN8C1PASE.rod
   VCID: 73EFAE7ADA157FDE9C-8026
Adres 5F: Info Electr. (J794)       Labels:| 5G0-035-MIB-STD2.clb
   Onderdeelnr. SW: 3Q0 035 846 A    HW: 3Q0 035 846 A
   Component: MU-S-N-ER     H30 0359
   Serienummer: VWZAZ2S0614591
   Codering: 02620001AA0000005111000300080A001F0110C401200100CF
   ROD: EV_MUStd4CTSAT_VW26.rod
   Weergave- en bedieningseenheid 1 informatie-elektronica:
   Subsysteem 1 - Onderdeelnr. SW: 6C0 919 603 A    HW: 6C0 919 603 A
   Component: ABTm_Std2_Nav  H53 1031
   Serienummer: VWZ8Z9SKX0211V
   Sticker met gegevens:
   Subsysteem 2 - Onderdeelnr. SW: 3G0 919 866 BJ    HW: -----------
   Component: ECE1 2018  --- 0915
   Serienummer: --------------------
Einde----------------------(Tijd verstreken: 03:26)------------------------
And the scan I made now. Don't mind the fault about the faulty subwoofer.
Friday,17,May,2019,17:14:20:47336
VCDS Version: 18.9.1.0 (x64)
VIN: WVWZZZ6RZHY135739   License Plate: PR223SENGLISH
Mileage: 48814km-30331mi   Repair Order:
VIN: WVWZZZ6RZHY135739   Mileage: 48814km-30331miles
Address 01: Engine (J623-CHZC)       Labels:. 04E-907-309-V1.clb
   Part No SW: 04C 906 026 Q    HW: 04C 907 309 AE
   Revision: W1H25---
   Coding: 01250032232419080000
   Shop #: WSC 00788 648 00255
   ROD: EV_ECM10TFS01104C906026AH.rod
   VCID: 2F6D43B976A5A43274-807A
   CAN Converter 01:
   Part No SW: 0CW 300 040 R    HW: 0AM 927 769 E
   Revision: 00005026    Serial number: CU501610145847
   VCID: 43851F09CA2D305280-8016
Address 03: ABS Brakes (J104)       Labels:. 6R0-907-37x-ESP90.clb
   Part No SW: 6C0 907 379 R    HW: 6R0 907 379 BA
   Serial number: 08505202161022
   Coding: 21DD4885892633C5111B106C005A841291CC88080005CB098F00
   VCID: 3E736EFDA1CF5DBAEF-806A
Address 08: Auto HVAC (J255)       Labels:| 6C0-907-044.clb
   Part No SW: 6C0 907 044 D    HW: 6C0 907 044 D
   Serial number:  1611022A-1642
   Coding: 200000001111000001
   ROD: EV_ACClimaValeoPQ26.rod
   VCID: 2541A1912459EE628E-8070
Address 09: Cent. Elect. (J519)       Labels:* Redir Fail!
   Part No SW: 6C0 937 087 D    HW: 6C0 937 087
   Serial number: 006298031125
   Coding: 0010184042530AF34F844000402703481000590253010000000000000000
   Shop #: WSC 66143 211 72445
   Subsystem 1 - Part No SW: 5Q0 955 547 B    HW: 5Q0 955 547 B  Labels: 5Q0-955-547.CLB
   Serial number: S6Y16M10D11H22M19S31
   Coding: 0038DD
   Drivers Door Control Module:
   Subsystem 2 - Part No SW: 6R0 959 801 DG    HW: 6R0 959 801 DG  Labels: 6R0-959-801.CLB
   Serial number: KU0KU018101662925411
   Coding: 0400A0
   Subsystem 3 - Part No SW: 6R0 959 802 DL    HW: 6R0 959 802 DL  Labels: 6R0-959-802.CLB
   Serial number: KU0KU012101662862930
   Coding: 1400A0
   Sun Roof:
   Subsystem 4 - Part No SW: 6R0 959 591 D    HW: 6R0 959 591 D
   Serial number: 0000FST0018OZ2Y00000
   Coding: 181001
   Subsystem 6 - Part No SW: 6R0 959 811 AA    HW: 6R0 959 811 AA
   Serial number: KU0KU025101662993394
   Coding: 0400A0
   Subsystem 7 - Part No SW: 6R0 959 812 AA    HW: 6R0 959 812 AA
   Serial number: KU0KU017101662918117
   Coding: 1400A0
   Revision: --------    Serial number: 39331630202445
   Coding: 0031051011
Address 15: Airbags (J234)       Labels:| 6C0-959-655.clb
   Part No SW: 6C0 959 655 J    HW: 6C0 959 655 J
   Revision: --------    Serial number: 003TH00CZHH1
   Coding: 88C0C000000000005C0000CA000800000000
   VCID: 3A7B62EDBDE7719AD3-806E
   Subsystem 1 - Part No SW: -----------    HW: 410 820 411 16
   Serial number: 3575H00BD22AE860329V
   Subsystem 2 - Part No SW: -----------    HW: 410 820 411 16
   Serial number: 3585H00A1226A6736106
   Subsystem 3 - Part No SW: -----------    HW: 442 152 010 16
   Serial number: 3517A00B1223B6C3E1AG
   Subsystem 4 - Part No SW: -----------    HW: 442 152 010 16
   Serial number: 3527A00A521DBB220367
   Part No SW: 6C0 920 740 E    HW: 6C0 920 740 E
   Coding: 072D0908218000080D086A001000000000000000
   VCID: 2447BC952F63176A99-8070
Address 19: CAN Gateway (J533)       Labels:| 6C0-909-901-V1.clb
   Part No SW: 6C0 909 901 A    HW: 6C0 937 087
   Revision: --------    Serial number: 006298031125
   Coding: 030000046F0A560071000000000000010001010000000000000000000000
   ROD: EV_GatewA0Lear_013_VW26.rod
   VCID: 2643A69D595FE57A87-8072
   Subsystem 1 - Part No SW: 6C0 915 181 B    HW: 6C0 915 181 B
   Serial number: 63300503365881792761
Address 44: Steering Assist (J792)       Labels:| 6Rx-909-144-V2.clb
   Part No SW: 6C1 909 144 AJ    HW: 6C1 909 144 D
   Serial number: CGB80420
   Coding: 000700
   VCID: 70EF80C5AB1BFBCA2D-8024
   Part No SW: 5Q6 035 456     HW: 5Q6 035 456
   Revision: --------    Serial number: A1117A00005232
   Coding: 0202000000AAAA00000000000000
   ROD: EV_AMPCAN8C1PASE_VW26.rod
   VCID: 73E58FC9DA0DC0D2D0-8026
0568 - Loudspeaker 2 in Double-Subwoofer
          B130D 12 [009] - Short to Plus
                    Fault Frequency: 10
                    Reset counter: 216
                    Mileage: 48681 km
                    Date: 2019.05.16
                    Time: 19:26:02
                    Voltage terminal 30: 11.6 V
   Part No SW: 3Q0 035 846 A    HW: 3Q0 035 846 A
   Serial number: VWZAZ2S0614591
   Coding: 02620001AA0000005111000300080A001F0110C401200100CF
   Subsystem 1 - Part No SW: 6C0 919 603 A    HW: 6C0 919 603 A
   Serial number: VWZ8Z9SKX0211V
   Subsystem 2 - Part No SW: 3G0 919 866 BJ    HW: -----------
End-------------------------(Elapsed Time: 02:57)--------------------------
Please tell me what I can do to find out how to get the remote working again. What options should I check first to get to the problem? I'm really confused :confused:
Thank you in advance!
Edit:
Doors open/close by putting physical key in the lock. All doors wil lock/unlock.
In the car you can lock/unlock doors with the button on the doorhandle.
Maybe related cause problem came at the same time: doors don’t auto lock above certain speed anymore. It can be checked on the car setup in the radio but it just doesn’t auto lock the car.
Looks like you have more than one cables. At least one of them is totally sketchy, and one of them is good. This thread almost ended up in the Hall of Shame due to the scan done with the sketchy one.
Please use the data from the good one to Get Verified.
Also, when posting data in this forum, please use the standard English version of VCDS. You can download it from this page and it will co-exist with the (legitimate) version of the Dutch translation you are using.
Jopie89
C?ID=253932
I've updated with the english log and will ask my boss for the verification proces :-) Sorry for that. In the mean time, do you know anything that can be done to get the fob working again? :-) In a little bit of a rush :-/
Verified. Moving to Car Repair Support.
Jopie89
C?ID=253932
So, I've been doing some sniffing around. And I really think there is a misconfiguration in one of the doors. In the radio I can set the doors to autolock when above a certain speed (15/20km/h?). It isn't working. Maybe that is one of the first problems to solve. Since I have no label files, would anybody know how to put on this autolock thing?
Jopie89
C?ID=253932
I used this video that I came across on youtube. The screens are similiar to what I get. Only thing is, while everything is the same (it already standed that way). It still is nog auto-locking/autounlocking.
https://www.youtube.com/watch?v=Pdq0AXpLC0s
Does anybody have another option? :-) Thank you
Dana
Western PA, USA
That's for Mk7 (MQB based) Golf models so the Adp channels aren't the same.
You can use the search in VCDS but I'd look at Adp channel [*IDE00002-ENG101806*] Transport mode. That should be off/disabled. If that doesn't help you can search for "lock" or create a control module map set to the Adaptation function and post the results here. It would look like Tommy's file under 09 in this thread: https://forums.ross-tech.com/showthread.php?13231-2017-Polo-6C-1-0-TSI-CHZC
P.S. Here's another reference map from Michel's Polo: https://forums.ross-tech.com/showth...ghline-LED-NAV&p=126105&viewfull=1#post126105
Jopie89
C?ID=253932
Thanks for the reply, I tried changing "IDE00002-Transport mode,active ,1" to not active. Didn't make a difference. So I changed it back to active. So I made a control module map. I hope I did it the right way :-/ Sorry if not...
	SW:6C0-937-087-D   HW:6C0-937-087 ---  Cent. Elect. --- SA: 31347
	Component:BCM PQ26 Me4R H10 0094, Coding:1010184042530AF34F844000402703481000590253010000000000000000
	EV_BCMA0,006002,EV_BCMA0_006_VW26.rod
	Wednesday,22,May,2019,11:33:57:47336
	VCDS Version: Release 18.9.1 (x64)  Data version: 20190114 DS296.0
IDE00001-ENG130235-Production mode-Entry_control,not active ,3
IDE00001-ENG130231-Production mode-Window_regulator_nr_1,not active ,3
IDE00001-ENG130232-Production mode-Window_reversing_threshold,not active ,3
IDE01268-ENG115835-Windshield wiper-Adaptives Nachwischen bei SRA,active ,9
IDE01268-ENG116609-Windshield wiper-Anzahl Betaetigungen Frontwaschanlage pro SRA Aktivierung,0 ,9
IDE01268-ENG122992-Windshield wiper-Frontwischer Abtauposition,keine Abtaupostition ,9
IDE01268-ENG115836-Windshield wiper-Frontwischer Notlaufprogramm,active ,9
IDE01268-ENG116614-Windshield wiper-Frontwischer Referenzlauf,active ,9
IDE01268-ENG126573-Windshield wiper-Frontwischer_Serviceposition,active ,9
IDE01268-ENG116617-Windshield wiper-Geschwindigkeitsabhaengige Wischstufenrueckschaltung,active ,9
IDE01268-ENG116615-Windshield wiper-Menuesteuerung Frontwischer,not active ,9
IDE01268-ENG115771-Windshield wiper-Regensensor aktivieren,activated ,9
IDE01268-ENG115769-Windshield wiper-SRA bei Waschwassermangel,not active ,9
IDE01268-ENG115767-Windshield wiper-SRA Einweichpausenzeit,0 ms,9
IDE01268-ENG115768-Windshield wiper-SRA Nachwaschzeit,0 ms,9
IDE01268-ENG116611-Windshield wiper-SRA Pausenzeit,0 ms,9
IDE01268-ENG116610-Windshield wiper-SRA Verzoegerungszeit,0 ms,9
IDE01268-ENG115766-Windshield wiper-SRA Waschzeit,0 ms,9
IDE01268-ENG116618-Windshield wiper-Traenenwischen Front Status,not active ,9
IDE01268-ENG116613-Windshield wiper-Wischer abparken bei Oeffnen der Motorhaube,not active ,9
IDE01268-ENG116612-Windshield wiper-Wischer stop bei KL15 aus,not active ,9
IDE01268-ENG122991-Windshield wiper-Wischer stop bei Motorstart,kein Wischerstopp ,9
IDE01268-ENG122185-Windshield wiper-Wischer Stopp bei Oeffnen der Motorhaube,active ,9
IDE02200-Component protection showroom mode,00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 ,32
IDE02269-MAS04382-Acknowledgement signals-Optical feedback during locking,Decelerate ,2
IDE02269-ENG116666-Acknowledgement signals-Akustische Rueckmeldung entriegeln,active ,2
IDE02269-ENG116669-Acknowledgement signals-Akustische Rueckmeldung global,active ,2
IDE02269-ENG116670-Acknowledgement signals-Akustische Rueckmeldung Signalhorn,active ,2
IDE02269-ENG116667-Acknowledgement signals-Akustische Rueckmeldung verriegeln,active ,2
IDE02269-ENG122187-Acknowledgement signals-Dauer der Akustischen Rueckmeldung vom Einfachhorn,short ,2
IDE02269-ENG122188-Acknowledgement signals-Menuesteuerung akustische Rueckmeldung,active ,2
IDE02269-ENG122995-Acknowledgement signals-Optische Rueckmeldung 3.Bremsleuchte,active ,2
IDE02269-ENG116668-Acknowledgement signals-Optische Rueckmeldung Komfortschliessen,active ,2
IDE02269-ENG130230-Acknowledgement signals-pa_quittungston_beim_zweiten_ZV_Auf_Befehl,not active ,2
IDE02269-ENG130229-Acknowledgement signals-pa_quittungston_beim_zweiten_ZV_Zu_Befehl,not active ,2
IDE02711-ENG116690-Rear Window Wiper-Automatisches Heckwischen,not active ,3
IDE02711-ENG114947-Rear Window Wiper-Heckwischer Weiterlauf,not active ,3
IDE02711-ENG114946-Rear Window Wiper-Komfortwischen Heck,active ,3
IDE02711-ENG116695-Rear Window Wiper-Komofortwischen Heck Intervallpausenzeit Stufe 1,5 s,3
IDE02711-ENG116696-Rear Window Wiper-Komofortwischen Heck Intervallpausenzeit Stufe 2,3 s,3
IDE02711-ENG116694-Rear Window Wiper-Komofortwischen Heck Intervallpausenzeit Stufe Automatik,7 s,3
IDE02711-ENG116693-Rear Window Wiper-Komofortwischen Heck Intervallpausenzeit Stufe Intervall,7 s,3
IDE02711-ENG116689-Rear Window Wiper-Menuesteuerung Komfortwischen HW,active ,3
IDE02711-ENG126572-Rear Window Wiper-no_automativ_parking_after_kl15_on,not active ,3
IDE02711-ENG116691-Rear Window Wiper-Traenenwischen Heck,not active ,3
IDE02957-ENG116688-Ambient lighting-Ambientelicht mit raste heckdeckel,not enabled ,4
IDE02957-ENG115822-Ambient lighting-Defaultwert Ambienteprofil Fussraum,255 %,4
IDE02957-ENG116685-Ambient lighting-Defaultwert Ambienteprofil Tuer,80 %,4
IDE02957-ENG115823-Ambient lighting-Defaultwert Ambienteprofil Vorn,80 %,4
IDE02957-ENG115824-Ambient lighting-Innenlichtinszenierung,not enabled ,4
IDE02957-ENG116687-Ambient lighting-Tuerinnengriff mit Tuertafel,not installed ,4
IDE02957-ENG116686-Ambient lighting-Tuerinnengriffbeleuchtung mit I-Tafel,not installed ,4
IDE03638-IDE04231-static AFS light-Steering wheel angle: offset,-63.50 °,13
IDE03638-ENG116677-static AFS light-Abdimmgeschwindigkeit,50.0 %/s,13
IDE03638-ENG116673-static AFS light-bei Rueckwaertsfahrt,both sides ,13
IDE03638-ENG116675-static AFS light-Lower speed threshold,0.0 km/h,13
IDE03638-ENG116682-static AFS light-Maximaltemperatur,100.0 °C,13
IDE03638-ENG116679-static AFS light-obere Grenztemperatur,95.0 °C,13
IDE03638-ENG116681-static AFS light-Oberer Lenkradwinkel,180 °,13
IDE03638-ENG116680-static AFS light-untere Grenztemperatur,80.0 °C,13
IDE03638-ENG116678-static AFS light-Unterer Lenkradwinkel,120 °,13
IDE03638-ENG116676-static AFS light-Upper speed threshold,40.0 km/h,13
IDE03638-ENG116674-static AFS light-Vorschrift,ECE R119 ,13
IDE04923-ENG133379-Turn signal control-Abbruch Komfortblinken,active ,4
IDE04923-ENG130187-Turn signal control-Blinkkontrolleuchte_fuer_Anhaenger,separate ,4
IDE04923-ENG130192-Turn signal control-Freilaufendes_Warnblinken,not active ,4
IDE04923-ENG115774-Turn signal control-Komfortblinken,active ,4
IDE04923-ENG115854-Turn signal control-Komfortblinken_Blinkzyklen,5 ,4
IDE04923-ENG130186-Turn signal control-Signalprioritaet_fuer_Blinker,SMLS ,4
IDE04923-ENG126568-Turn signal control-Sonderfunktionen_2,not enabled ,4
IDE04923-ENG130191-Turn signal control-Warnblinken_bei_Verdeckentriegelung,not active ,4
IDE04923-ENG130188-Turn signal control-Warnblinktastersuchbeleuchtung_Aktivierung,Always active ,4
IDE04923-ENG130190-Turn signal control-Warnblinktastersuchbeleuchtung_Faktor,0.100 %,4
IDE04923-ENG130189-Turn signal control-Warnblinktastersuchbeleuchtung_Grundwert,3.0 %,4
IDE04924-ENG116705-Driving light and parking light-Allwetterlicht Ausschaltgrenze,350.0 km/h,14
IDE04924-ENG116704-Driving light and parking light-Allwetterlicht Einschaltgrenze,350.0 km/h,14
IDE04924-ENG126566-Driving light and parking light-beidseitiges_dauerparklicht,active ,14
IDE04924-ENG115858-Driving light and parking light-Kontrollleuchte fuer Begrenzungslicht,integrated ,14
IDE04924-ENG115861-Driving light and parking light-Lichthupe bei Zuendung aus moeglich,active ,14
IDE04924-ENG115862-Driving light and parking light-Lichtwarnungsverhalten,klemmenabhaengig ,14
IDE04924-ENG126567-Driving light and parking light-max_scheinwerfer_2limitieren,not active ,14
IDE04924-ENG115863-Driving light and parking light-Menueeinstellung CHO LHO,Menuesteuerung Zeit aktivieren ,14
IDE04924-ENG115782-Driving light and parking light-Nebelschlusslicht Warngeschwindigkeit,255 km/h,14
IDE04924-ENG115859-Driving light and parking light-Parklicht ueber LSS aktiviert,One-sided ,14
IDE04924-ENG115831-Driving light and parking light-Schlusslicht mit Bremslichtfunktion,not active ,14
IDE04924-ENG126565-Driving light and parking light-standlicht_aus_bei_kl_s_aus_s_kontakt,active ,14
IDE04924-ENG122200-Driving light and parking light-Warnung Fahrt mit Standlicht,not active ,14
IDE04924-ENG115830-Driving light and parking light-Zeitwert Einschaltzeit Abbiegelicht,15 min,14
IDE04926-ENG115656-Comfort illumination-Coming Home Leuchten,Low beam ,5
IDE04926-ENG116601-Comfort illumination-Coming Home Verbaustatus,Unknown (3),5
IDE04926-ENG116604-Comfort illumination-Coming-home Einschaltereignis,Driver door ,5
IDE04926-ENG116608-Comfort illumination-Helligkeitsschwelle Forward-Messung,0 ,5
IDE04926-ENG116605-Comfort illumination-Helligkeitsschwelle Infrarot-Messung,72.0 ,5
IDE04926-ENG115657-Comfort illumination-Leaving-Home Verbausstatus,Enabled ,5
IDE04926-ENG126569-Comfort illumination-lho_aktiviert,active ,5
IDE04926-ENG126570-Comfort illumination-lho_zeit,10 seconds ,5
IDE04926-ENG116603-Comfort illumination-Menueeinstellung Cominghome,10 seconds ,5
IDE04926-ENG116602-Comfort illumination-Menuesteuerung Coming Home Werkseinstellung,active ,5
IDE04927-IDE01446-Window heater-Running time of heated front window,6 s,8
IDE04927-ENG142182-Window heater-Abschalttemperatur_fuer_Frontscheibenheizung,170 °C,8
IDE04927-ENG142181-Window heater-Abschalttemperatur_fuer_Heckscheibenheizung,170 °C,8
IDE04927-ENG126613-Window heater-Aussenspiegelheizung,0 s,8
IDE04927-ENG142180-Window heater-Heckscheibenheizung_Zeitwert,15 s,8
IDE04927-ENG142179-Window heater-Temperaturabhaengige_Einschaltzeit_FSH,active ,8
IDE04927-ENG142178-Window heater-Temperaturabhaengige_Einschaltzeit_HSH,active ,8
IDE04928-ENG115867-Anti-theft device-Akustischer Alarm Signalhorn,not active ,1
IDE04928-ENG115864-Anti-theft device-Alarmsignal,frequency modulated ,1
IDE04928-ENG115865-Anti-theft device-DWA Alarmverzoegerung,immidiat_driver_door_contact_thatcham ,1
IDE04928-ENG115812-Anti-theft device-DWA Camper Modus,not active ,1
IDE04928-ENG115866-Anti-theft device-Sirenen Alarmzahl,10 Alarme ,1
IDE04928-ENG115868-Anti-theft device-Verzoegerung Panikalarm,keine verzoegerung ,1
IDE05142-ENG116628-Access control-Autolock Autounlock wirkt auf Heck,active ,4
IDE05142-ENG116621-Access control-automatisches Entriegeln,active ,4
IDE05142-ENG115756-Access control-automatisches Verriegeln bei Geschwindigkeit,active ,4
IDE05142-ENG116706-Access control-Autounlock NAR,not active ,4
IDE05142-ENG116624-Access control-CAN Wecken bei Softtouchbetaetigung,active ,4
IDE05142-ENG125653-Access control-Deaktivierung_SAFE_ueber_DWA_Deaktivierungstaster,not active ,4
IDE05142-ENG115759-Access control-Direkter Auswurf des Heckdeckels,active ,4
IDE05142-ENG116707-Access control-Freigabenachlauf Heck nach Einzeloeffnung ueber HDF-Funktaster,not active ,4
IDE05142-ENG115754-Access control-Funk bei Klemme 15 ein,not active ,4
IDE05142-ENG116627-Access control-Heckdeckel-Bedienstellen nachCrash temporaer sperren,not active ,4
IDE05142-ENG115763-Access control-Manuelle ZV Variantenprogrammierung,not active ,4
IDE05142-ENG116633-Access control-Menuesteuerung Tuerentriegelung,active ,4
IDE05142-ENG116634-Access control-Menuesteuerung ZV Autolock-Unlock,adjustable ,4
IDE05142-ENG115761-Access control-Nach externer Verriegelung ist Heck noch zeitbegrenzt entriegelt,not active ,4
IDE05142-ENG115755-Access control-Notschließfunktion,active ,4
IDE05142-ENG116626-Access control-Oeffnung Heckdeckel bei Wiederentriegelung,not active ,4
IDE05142-ENG115758-Access control-Valet Parking,not active ,4
IDE05142-ENG115760-Access control-ZV entriegelt auch Heckdeckel,active ,4
IDE05142-ENG116629-Access control-ZV Heck nur direkt auswerfen,not active ,4
IDE05142-ENG116623-Access control-ZV Tuerentriegelung,Globale Entriegelung ,4
IDE05142-ENG116635-Access control-ZV-Entriegelung nach Seitencrash,not active ,4
IDE05145-ENG115014-Light configuration-BAP_Bitposition_0,34 ,560
IDE05145-ENG115033-Light configuration-BAP_Bitposition_1,3E ,560
IDE05145-ENG115186-Light configuration-BAP_Bitposition_10,00 ,560
IDE05145-ENG115189-Light configuration-BAP_Bitposition_11,00 ,560
IDE05145-ENG115208-Light configuration-BAP_Bitposition_12,00 ,560
IDE05145-ENG115226-Light configuration-BAP_Bitposition_13,00 ,560
IDE05145-ENG115229-Light configuration-BAP_Bitposition_14,00 ,560
IDE05145-ENG115248-Light configuration-BAP_Bitposition_15,00 ,560
IDE05145-ENG115267-Light configuration-BAP_Bitposition_16,00 ,560
IDE05145-ENG115286-Light configuration-BAP_Bitposition_17,00 ,560
IDE05145-ENG115305-Light configuration-BAP_Bitposition_18,08 ,560
IDE05145-ENG115324-Light configuration-BAP_Bitposition_19,18 ,560
IDE05145-ENG115052-Light configuration-BAP_Bitposition_2,35 ,560
IDE05145-ENG115343-Light configuration-BAP_Bitposition_20,09 ,560
IDE05145-ENG115362-Light configuration-BAP_Bitposition_21,19 ,560
IDE05145-ENG115381-Light configuration-BAP_Bitposition_22,29 ,560
IDE05145-ENG115400-Light configuration-BAP_Bitposition_23,0A ,560
IDE05145-ENG115419-Light configuration-BAP_Bitposition_24,1A ,560
IDE05145-ENG115438-Light configuration-BAP_Bitposition_25,28 ,560
IDE05145-ENG115457-Light configuration-BAP_Bitposition_26,2A ,560
IDE05145-ENG115476-Light configuration-BAP_Bitposition_27,00 ,560
IDE05145-ENG115495-Light configuration-BAP_Bitposition_28,2B ,560
IDE05145-ENG115514-Light configuration-BAP_Bitposition_29,00 ,560
IDE05145-ENG115071-Light configuration-BAP_Bitposition_3,3F ,560
IDE05145-ENG115533-Light configuration-BAP_Bitposition_30,00 ,560
IDE05145-ENG115552-Light configuration-BAP_Bitposition_31,00 ,560
IDE05145-ENG115571-Light configuration-BAP_Bitposition_32,00 ,560
IDE05145-ENG115590-Light configuration-BAP_Bitposition_33,00 ,560
IDE05145-ENG115609-Light configuration-BAP_Bitposition_34,00 ,560
IDE05145-ENG115090-Light configuration-BAP_Bitposition_4,3A ,560
IDE05145-ENG115108-Light configuration-BAP_Bitposition_5,44 ,560
IDE05145-ENG115111-Light configuration-BAP_Bitposition_6,36 ,560
IDE05145-ENG115130-Light configuration-BAP_Bitposition_7,40 ,560
IDE05145-ENG115149-Light configuration-BAP_Bitposition_8,37 ,560
IDE05145-ENG115168-Light configuration-BAP_Bitposition_9,41 ,560
IDE05145-ENG115018-Light configuration-Dimming_AB_0,100 ,560
IDE05145-ENG115037-Light configuration-Dimming_AB_1,100 ,560
IDE05145-ENG114999-Light configuration-Dimming_AB_10,0 ,560
IDE05145-ENG115193-Light configuration-Dimming_AB_11,100 ,560
IDE05145-ENG115212-Light configuration-Dimming_AB_12,0 ,560
IDE05145-ENG114958-Light configuration-Dimming_AB_13,0 ,560
IDE05145-ENG115233-Light configuration-Dimming_AB_14,100 ,560
IDE05145-ENG115252-Light configuration-Dimming_AB_15,100 ,560
IDE05145-ENG115271-Light configuration-Dimming_AB_16,100 ,560
IDE05145-ENG115290-Light configuration-Dimming_AB_17,100 ,560
IDE05145-ENG115309-Light configuration-Dimming_AB_18,100 ,560
IDE05145-ENG115328-Light configuration-Dimming_AB_19,100 ,560
IDE05145-ENG115056-Light configuration-Dimming_AB_2,100 ,560
IDE05145-ENG115347-Light configuration-Dimming_AB_20,100 ,560
IDE05145-ENG115366-Light configuration-Dimming_AB_21,100 ,560
IDE05145-ENG115385-Light configuration-Dimming_AB_22,100 ,560
IDE05145-ENG115404-Light configuration-Dimming_AB_23,60 ,560
IDE05145-ENG115423-Light configuration-Dimming_AB_24,60 ,560
IDE05145-ENG115442-Light configuration-Dimming_AB_25,100 ,560
IDE05145-ENG115461-Light configuration-Dimming_AB_26,100 ,560
IDE05145-ENG115480-Light configuration-Dimming_AB_27,100 ,560
IDE05145-ENG115499-Light configuration-Dimming_AB_28,100 ,560
IDE05145-ENG115518-Light configuration-Dimming_AB_29,100 ,560
IDE05145-ENG115075-Light configuration-Dimming_AB_3,100 ,560
IDE05145-ENG115537-Light configuration-Dimming_AB_30,126 ,560
IDE05145-ENG115556-Light configuration-Dimming_AB_31,0 ,560
IDE05145-ENG115575-Light configuration-Dimming_AB_32,0 ,560
IDE05145-ENG115594-Light configuration-Dimming_AB_33,0 ,560
IDE05145-ENG115613-Light configuration-Dimming_AB_34,0 ,560
IDE05145-ENG115094-Light configuration-Dimming_AB_4,100 ,560
IDE05145-ENG114977-Light configuration-Dimming_AB_5,100 ,560
IDE05145-ENG115115-Light configuration-Dimming_AB_6,100 ,560
IDE05145-ENG115134-Light configuration-Dimming_AB_7,100 ,560
IDE05145-ENG115153-Light configuration-Dimming_AB_8,100 ,560
IDE05145-ENG115172-Light configuration-Dimming_AB_9,100 ,560
IDE05145-ENG115022-Light configuration-Dimming_CD_0,0 ,560
IDE05145-ENG115041-Light configuration-Dimming_CD_1,0 ,560
IDE05145-ENG115003-Light configuration-Dimming_CD_10,0 ,560
IDE05145-ENG115197-Light configuration-Dimming_CD_11,0 ,560
IDE05145-ENG115216-Light configuration-Dimming_CD_12,0 ,560
IDE05145-ENG114962-Light configuration-Dimming_CD_13,0 ,560
IDE05145-ENG115237-Light configuration-Dimming_CD_14,0 ,560
IDE05145-ENG115256-Light configuration-Dimming_CD_15,0 ,560
IDE05145-ENG115275-Light configuration-Dimming_CD_16,0 ,560
IDE05145-ENG115294-Light configuration-Dimming_CD_17,0 ,560
IDE05145-ENG115313-Light configuration-Dimming_CD_18,0 ,560
IDE05145-ENG115332-Light configuration-Dimming_CD_19,0 ,560
IDE05145-ENG115060-Light configuration-Dimming_CD_2,0 ,560
IDE05145-ENG115351-Light configuration-Dimming_CD_20,0 ,560
IDE05145-ENG115370-Light configuration-Dimming_CD_21,0 ,560
IDE05145-ENG115389-Light configuration-Dimming_CD_22,0 ,560
IDE05145-ENG115408-Light configuration-Dimming_CD_23,0 ,560
IDE05145-ENG115427-Light configuration-Dimming_CD_24,0 ,560
IDE05145-ENG115446-Light configuration-Dimming_CD_25,0 ,560
IDE05145-ENG115465-Light configuration-Dimming_CD_26,0 ,560
IDE05145-ENG115484-Light configuration-Dimming_CD_27,0 ,560
IDE05145-ENG115503-Light configuration-Dimming_CD_28,0 ,560
IDE05145-ENG115522-Light configuration-Dimming_CD_29,0 ,560
IDE05145-ENG115079-Light configuration-Dimming_CD_3,0 ,560
IDE05145-ENG115541-Light configuration-Dimming_CD_30,0 ,560
IDE05145-ENG115560-Light configuration-Dimming_CD_31,0 ,560
IDE05145-ENG115579-Light configuration-Dimming_CD_32,0 ,560
IDE05145-ENG115598-Light configuration-Dimming_CD_33,0 ,560
IDE05145-ENG115617-Light configuration-Dimming_CD_34,0 ,560
IDE05145-ENG115098-Light configuration-Dimming_CD_4,0 ,560
IDE05145-ENG114981-Light configuration-Dimming_CD_5,0 ,560
IDE05145-ENG115119-Light configuration-Dimming_CD_6,0 ,560
IDE05145-ENG115138-Light configuration-Dimming_CD_7,0 ,560
IDE05145-ENG115157-Light configuration-Dimming_CD_8,0 ,560
IDE05145-ENG115176-Light configuration-Dimming_CD_9,0 ,560
IDE05145-ENG115023-Light configuration-Dimming_Direction_CD_0,maximize ,560
IDE05145-ENG115042-Light configuration-Dimming_Direction_CD_1,maximize ,560
IDE05145-ENG115004-Light configuration-Dimming_Direction_CD_10,maximize ,560
IDE05145-ENG115198-Light configuration-Dimming_Direction_CD_11,maximize ,560
IDE05145-ENG115217-Light configuration-Dimming_Direction_CD_12,maximize ,560
IDE05145-ENG114963-Light configuration-Dimming_Direction_CD_13,maximize ,560
IDE05145-ENG115238-Light configuration-Dimming_Direction_CD_14,maximize ,560
IDE05145-ENG115257-Light configuration-Dimming_Direction_CD_15,maximize ,560
IDE05145-ENG115276-Light configuration-Dimming_Direction_CD_16,maximize ,560
IDE05145-ENG115295-Light configuration-Dimming_Direction_CD_17,maximize ,560
IDE05145-ENG115314-Light configuration-Dimming_Direction_CD_18,maximize ,560
IDE05145-ENG115333-Light configuration-Dimming_Direction_CD_19,maximize ,560
IDE05145-ENG115061-Light configuration-Dimming_Direction_CD_2,maximize ,560
IDE05145-ENG115352-Light configuration-Dimming_Direction_CD_20,maximize ,560
IDE05145-ENG115371-Light configuration-Dimming_Direction_CD_21,maximize ,560
IDE05145-ENG115390-Light configuration-Dimming_Direction_CD_22,maximize ,560
IDE05145-ENG115409-Light configuration-Dimming_Direction_CD_23,maximize ,560
IDE05145-ENG115428-Light configuration-Dimming_Direction_CD_24,maximize ,560
IDE05145-ENG115447-Light configuration-Dimming_Direction_CD_25,maximize ,560
IDE05145-ENG115466-Light configuration-Dimming_Direction_CD_26,maximize ,560
IDE05145-ENG115485-Light configuration-Dimming_Direction_CD_27,maximize ,560
IDE05145-ENG115504-Light configuration-Dimming_Direction_CD_28,maximize ,560
IDE05145-ENG115523-Light configuration-Dimming_Direction_CD_29,maximize ,560
IDE05145-ENG115080-Light configuration-Dimming_Direction_CD_3,maximize ,560
IDE05145-ENG115542-Light configuration-Dimming_Direction_CD_30,maximize ,560
IDE05145-ENG115561-Light configuration-Dimming_Direction_CD_31,maximize ,560
IDE05145-ENG115580-Light configuration-Dimming_Direction_CD_32,maximize ,560
IDE05145-ENG115599-Light configuration-Dimming_Direction_CD_33,maximize ,560
IDE05145-ENG115618-Light configuration-Dimming_Direction_CD_34,maximize ,560
IDE05145-ENG115099-Light configuration-Dimming_Direction_CD_4,minimize ,560
IDE05145-ENG114982-Light configuration-Dimming_Direction_CD_5,minimize ,560
IDE05145-ENG115120-Light configuration-Dimming_Direction_CD_6,maximize ,560
IDE05145-ENG115139-Light configuration-Dimming_Direction_CD_7,maximize ,560
IDE05145-ENG115158-Light configuration-Dimming_Direction_CD_8,maximize ,560
IDE05145-ENG115177-Light configuration-Dimming_Direction_CD_9,maximize ,560
IDE05145-ENG115027-Light configuration-Dimming_Direction_EF_0,maximize ,560
IDE05145-ENG115046-Light configuration-Dimming_Direction_EF_1,maximize ,560
IDE05145-ENG115008-Light configuration-Dimming_Direction_EF_10,maximize ,560
IDE05145-ENG115202-Light configuration-Dimming_Direction_EF_11,maximize ,560
IDE05145-ENG115221-Light configuration-Dimming_Direction_EF_12,maximize ,560
IDE05145-ENG114967-Light configuration-Dimming_Direction_EF_13,maximize ,560
IDE05145-ENG115242-Light configuration-Dimming_Direction_EF_14,maximize ,560
IDE05145-ENG115261-Light configuration-Dimming_Direction_EF_15,maximize ,560
IDE05145-ENG115280-Light configuration-Dimming_Direction_EF_16,maximize ,560
IDE05145-ENG115299-Light configuration-Dimming_Direction_EF_17,maximize ,560
IDE05145-ENG115318-Light configuration-Dimming_Direction_EF_18,maximize ,560
IDE05145-ENG115337-Light configuration-Dimming_Direction_EF_19,maximize ,560
IDE05145-ENG115065-Light configuration-Dimming_Direction_EF_2,maximize ,560
IDE05145-ENG115356-Light configuration-Dimming_Direction_EF_20,maximize ,560
IDE05145-ENG115375-Light configuration-Dimming_Direction_EF_21,maximize ,560
IDE05145-ENG115394-Light configuration-Dimming_Direction_EF_22,maximize ,560
IDE05145-ENG115413-Light configuration-Dimming_Direction_EF_23,maximize ,560
IDE05145-ENG115432-Light configuration-Dimming_Direction_EF_24,maximize ,560
IDE05145-ENG115451-Light configuration-Dimming_Direction_EF_25,maximize ,560
IDE05145-ENG115470-Light configuration-Dimming_Direction_EF_26,maximize ,560
IDE05145-ENG115489-Light configuration-Dimming_Direction_EF_27,maximize ,560
IDE05145-ENG115508-Light configuration-Dimming_Direction_EF_28,maximize ,560
IDE05145-ENG115527-Light configuration-Dimming_Direction_EF_29,maximize ,560
IDE05145-ENG115084-Light configuration-Dimming_Direction_EF_3,maximize ,560
IDE05145-ENG115546-Light configuration-Dimming_Direction_EF_30,maximize ,560
IDE05145-ENG115565-Light configuration-Dimming_Direction_EF_31,maximize ,560
IDE05145-ENG115584-Light configuration-Dimming_Direction_EF_32,maximize ,560
IDE05145-ENG115603-Light configuration-Dimming_Direction_EF_33,maximize ,560
IDE05145-ENG115622-Light configuration-Dimming_Direction_EF_34,maximize ,560
IDE05145-ENG115103-Light configuration-Dimming_Direction_EF_4,maximize ,560
IDE05145-ENG114986-Light configuration-Dimming_Direction_EF_5,maximize ,560
IDE05145-ENG115124-Light configuration-Dimming_Direction_EF_6,maximize ,560
IDE05145-ENG115143-Light configuration-Dimming_Direction_EF_7,maximize ,560
IDE05145-ENG115162-Light configuration-Dimming_Direction_EF_8,maximize ,560
IDE05145-ENG115181-Light configuration-Dimming_Direction_EF_9,maximize ,560
IDE05145-ENG115031-Light configuration-Dimming_Direction_GH_0,maximize ,560
IDE05145-ENG115050-Light configuration-Dimming_Direction_GH_1,maximize ,560
IDE05145-ENG115012-Light configuration-Dimming_Direction_GH_10,maximize ,560
IDE05145-ENG115206-Light configuration-Dimming_Direction_GH_11,maximize ,560
IDE05145-ENG115225-Light configuration-Dimming_Direction_GH_12,maximize ,560
IDE05145-ENG114971-Light configuration-Dimming_Direction_GH_13,maximize ,560
IDE05145-ENG115246-Light configuration-Dimming_Direction_GH_14,maximize ,560
IDE05145-ENG115265-Light configuration-Dimming_Direction_GH_15,maximize ,560
IDE05145-ENG115284-Light configuration-Dimming_Direction_GH_16,maximize ,560
IDE05145-ENG115303-Light configuration-Dimming_Direction_GH_17,maximize ,560
IDE05145-ENG115322-Light configuration-Dimming_Direction_GH_18,maximize ,560
IDE05145-ENG115341-Light configuration-Dimming_Direction_GH_19,maximize ,560
IDE05145-ENG115069-Light configuration-Dimming_Direction_GH_2,maximize ,560
IDE05145-ENG115360-Light configuration-Dimming_Direction_GH_20,maximize ,560
IDE05145-ENG115379-Light configuration-Dimming_Direction_GH_21,maximize ,560
IDE05145-ENG115398-Light configuration-Dimming_Direction_GH_22,maximize ,560
IDE05145-ENG115417-Light configuration-Dimming_Direction_GH_23,maximize ,560
IDE05145-ENG115436-Light configuration-Dimming_Direction_GH_24,maximize ,560
IDE05145-ENG115455-Light configuration-Dimming_Direction_GH_25,maximize ,560
IDE05145-ENG115474-Light configuration-Dimming_Direction_GH_26,maximize ,560
IDE05145-ENG115493-Light configuration-Dimming_Direction_GH_27,maximize ,560
IDE05145-ENG115512-Light configuration-Dimming_Direction_GH_28,maximize ,560
IDE05145-ENG115531-Light configuration-Dimming_Direction_GH_29,maximize ,560
IDE05145-ENG115088-Light configuration-Dimming_Direction_GH_3,maximize ,560
IDE05145-ENG115550-Light configuration-Dimming_Direction_GH_30,maximize ,560
IDE05145-ENG115569-Light configuration-Dimming_Direction_GH_31,maximize ,560
IDE05145-ENG115588-Light configuration-Dimming_Direction_GH_32,maximize ,560
IDE05145-ENG115607-Light configuration-Dimming_Direction_GH_33,maximize ,560
IDE05145-ENG115626-Light configuration-Dimming_Direction_GH_34,maximize ,560
IDE05145-ENG115107-Light configuration-Dimming_Direction_GH_4,maximize ,560
IDE05145-ENG114990-Light configuration-Dimming_Direction_GH_5,maximize ,560
IDE05145-ENG115128-Light configuration-Dimming_Direction_GH_6,maximize ,560
IDE05145-ENG115147-Light configuration-Dimming_Direction_GH_7,maximize ,560
IDE05145-ENG115166-Light configuration-Dimming_Direction_GH_8,maximize ,560
IDE05145-ENG115185-Light configuration-Dimming_Direction_GH_9,maximize ,560
IDE05145-ENG115026-Light configuration-Dimming_EF_0,0 ,560
IDE05145-ENG115045-Light configuration-Dimming_EF_1,0 ,560
IDE05145-ENG115007-Light configuration-Dimming_EF_10,0 ,560
IDE05145-ENG115201-Light configuration-Dimming_EF_11,0 ,560
IDE05145-ENG115220-Light configuration-Dimming_EF_12,0 ,560
IDE05145-ENG114966-Light configuration-Dimming_EF_13,0 ,560
IDE05145-ENG115241-Light configuration-Dimming_EF_14,0 ,560
IDE05145-ENG115260-Light configuration-Dimming_EF_15,0 ,560
IDE05145-ENG115279-Light configuration-Dimming_EF_16,0 ,560
IDE05145-ENG115298-Light configuration-Dimming_EF_17,0 ,560
IDE05145-ENG115317-Light configuration-Dimming_EF_18,0 ,560
IDE05145-ENG115336-Light configuration-Dimming_EF_19,0 ,560
IDE05145-ENG115064-Light configuration-Dimming_EF_2,0 ,560
IDE05145-ENG115355-Light configuration-Dimming_EF_20,0 ,560
IDE05145-ENG115374-Light configuration-Dimming_EF_21,0 ,560
IDE05145-ENG115393-Light configuration-Dimming_EF_22,0 ,560
IDE05145-ENG115412-Light configuration-Dimming_EF_23,0 ,560
IDE05145-ENG115431-Light configuration-Dimming_EF_24,0 ,560
IDE05145-ENG115450-Light configuration-Dimming_EF_25,0 ,560
IDE05145-ENG115469-Light configuration-Dimming_EF_26,0 ,560
IDE05145-ENG115488-Light configuration-Dimming_EF_27,0 ,560
IDE05145-ENG115507-Light configuration-Dimming_EF_28,0 ,560
IDE05145-ENG115526-Light configuration-Dimming_EF_29,0 ,560
IDE05145-ENG115083-Light configuration-Dimming_EF_3,0 ,560
IDE05145-ENG115545-Light configuration-Dimming_EF_30,0 ,560
IDE05145-ENG115564-Light configuration-Dimming_EF_31,0 ,560
IDE05145-ENG115583-Light configuration-Dimming_EF_32,0 ,560
IDE05145-ENG115602-Light configuration-Dimming_EF_33,0 ,560
IDE05145-ENG115621-Light configuration-Dimming_EF_34,0 ,560
IDE05145-ENG115102-Light configuration-Dimming_EF_4,0 ,560
IDE05145-ENG114985-Light configuration-Dimming_EF_5,0 ,560
IDE05145-ENG115123-Light configuration-Dimming_EF_6,0 ,560
IDE05145-ENG115142-Light configuration-Dimming_EF_7,0 ,560
IDE05145-ENG115161-Light configuration-Dimming_EF_8,0 ,560
IDE05145-ENG115180-Light configuration-Dimming_EF_9,0 ,560
IDE05145-ENG115030-Light configuration-Dimming_GH_0,0 ,560
IDE05145-ENG115049-Light configuration-Dimming_GH_1,0 ,560
IDE05145-ENG115011-Light configuration-Dimming_GH_10,0 ,560
IDE05145-ENG115205-Light configuration-Dimming_GH_11,0 ,560
IDE05145-ENG115224-Light configuration-Dimming_GH_12,0 ,560
IDE05145-ENG114970-Light configuration-Dimming_GH_13,0 ,560
IDE05145-ENG115245-Light configuration-Dimming_GH_14,0 ,560
IDE05145-ENG115264-Light configuration-Dimming_GH_15,0 ,560
IDE05145-ENG115283-Light configuration-Dimming_GH_16,0 ,560
IDE05145-ENG115302-Light configuration-Dimming_GH_17,0 ,560
IDE05145-ENG115321-Light configuration-Dimming_GH_18,0 ,560
IDE05145-ENG115340-Light configuration-Dimming_GH_19,0 ,560
IDE05145-ENG115068-Light configuration-Dimming_GH_2,0 ,560
IDE05145-ENG115359-Light configuration-Dimming_GH_20,0 ,560
IDE05145-ENG115378-Light configuration-Dimming_GH_21,0 ,560
IDE05145-ENG115397-Light configuration-Dimming_GH_22,0 ,560
IDE05145-ENG115416-Light configuration-Dimming_GH_23,0 ,560
IDE05145-ENG115435-Light configuration-Dimming_GH_24,0 ,560
IDE05145-ENG115454-Light configuration-Dimming_GH_25,0 ,560
IDE05145-ENG115473-Light configuration-Dimming_GH_26,0 ,560
IDE05145-ENG115492-Light configuration-Dimming_GH_27,0 ,560
IDE05145-ENG115511-Light configuration-Dimming_GH_28,0 ,560
IDE05145-ENG115530-Light configuration-Dimming_GH_29,0 ,560
IDE05145-ENG115087-Light configuration-Dimming_GH_3,0 ,560
IDE05145-ENG115549-Light configuration-Dimming_GH_30,0 ,560
IDE05145-ENG115568-Light configuration-Dimming_GH_31,0 ,560
IDE05145-ENG115587-Light configuration-Dimming_GH_32,0 ,560
IDE05145-ENG115606-Light configuration-Dimming_GH_33,0 ,560
IDE05145-ENG115625-Light configuration-Dimming_GH_34,0 ,560
IDE05145-ENG115106-Light configuration-Dimming_GH_4,0 ,560
IDE05145-ENG114989-Light configuration-Dimming_GH_5,0 ,560
IDE05145-ENG115127-Light configuration-Dimming_GH_6,0 ,560
IDE05145-ENG115146-Light configuration-Dimming_GH_7,0 ,560
IDE05145-ENG115165-Light configuration-Dimming_GH_8,0 ,560
IDE05145-ENG115184-Light configuration-Dimming_GH_9,0 ,560
IDE05145-ENG115015-Light configuration-Fehlerort (mittleres Byte DTC-DFCC)_0,14 ,560
IDE05145-ENG115034-Light configuration-Fehlerort (mittleres Byte DTC-DFCC)_1,15 ,560
IDE05145-ENG115187-Light configuration-Fehlerort (mittleres Byte DTC-DFCC)_10,00 ,560
IDE05145-ENG115190-Light configuration-Fehlerort (mittleres Byte DTC-DFCC)_11,00 ,560
IDE05145-ENG115209-Light configuration-Fehlerort (mittleres Byte DTC-DFCC)_12,00 ,560
IDE05145-ENG115227-Light configuration-Fehlerort (mittleres Byte DTC-DFCC)_13,00 ,560
IDE05145-ENG115230-Light configuration-Fehlerort (mittleres Byte DTC-DFCC)_14,00 ,560
IDE05145-ENG115249-Light configuration-Fehlerort (mittleres Byte DTC-DFCC)_15,00 ,560
IDE05145-ENG115268-Light configuration-Fehlerort (mittleres Byte DTC-DFCC)_16,00 ,560
IDE05145-ENG115287-Light configuration-Fehlerort (mittleres Byte DTC-DFCC)_17,00 ,560
IDE05145-ENG115306-Light configuration-Fehlerort (mittleres Byte DTC-DFCC)_18,16 ,560
IDE05145-ENG115325-Light configuration-Fehlerort (mittleres Byte DTC-DFCC)_19,18 ,560
IDE05145-ENG115053-Light configuration-Fehlerort (mittleres Byte DTC-DFCC)_2,26 ,560
IDE05145-ENG115344-Light configuration-Fehlerort (mittleres Byte DTC-DFCC)_20,2B ,560
IDE05145-ENG115363-Light configuration-Fehlerort (mittleres Byte DTC-DFCC)_21,2D ,560
IDE05145-ENG115382-Light configuration-Fehlerort (mittleres Byte DTC-DFCC)_22,2C ,560
IDE05145-ENG115401-Light configuration-Fehlerort (mittleres Byte DTC-DFCC)_23,29 ,560
IDE05145-ENG115420-Light configuration-Fehlerort (mittleres Byte DTC-DFCC)_24,2A ,560
IDE05145-ENG115439-Light configuration-Fehlerort (mittleres Byte DTC-DFCC)_25,30 ,560
IDE05145-ENG115458-Light configuration-Fehlerort (mittleres Byte DTC-DFCC)_26,33 ,560
IDE05145-ENG115477-Light configuration-Fehlerort (mittleres Byte DTC-DFCC)_27,08 ,560
IDE05145-ENG115496-Light configuration-Fehlerort (mittleres Byte DTC-DFCC)_28,34 ,560
IDE05145-ENG115515-Light configuration-Fehlerort (mittleres Byte DTC-DFCC)_29,01 ,560
IDE05145-ENG115072-Light configuration-Fehlerort (mittleres Byte DTC-DFCC)_3,27 ,560
IDE05145-ENG115534-Light configuration-Fehlerort (mittleres Byte DTC-DFCC)_30,07 ,560
IDE05145-ENG115553-Light configuration-Fehlerort (mittleres Byte DTC-DFCC)_31,00 ,560
IDE05145-ENG115572-Light configuration-Fehlerort (mittleres Byte DTC-DFCC)_32,00 ,560
IDE05145-ENG115591-Light configuration-Fehlerort (mittleres Byte DTC-DFCC)_33,00 ,560
IDE05145-ENG115610-Light configuration-Fehlerort (mittleres Byte DTC-DFCC)_34,00 ,560
IDE05145-ENG115091-Light configuration-Fehlerort (mittleres Byte DTC-DFCC)_4,20 ,560
IDE05145-ENG115109-Light configuration-Fehlerort (mittleres Byte DTC-DFCC)_5,21 ,560
IDE05145-ENG115112-Light configuration-Fehlerort (mittleres Byte DTC-DFCC)_6,1A ,560
IDE05145-ENG115131-Light configuration-Fehlerort (mittleres Byte DTC-DFCC)_7,1B ,560
IDE05145-ENG115150-Light configuration-Fehlerort (mittleres Byte DTC-DFCC)_8,1C ,560
IDE05145-ENG115169-Light configuration-Fehlerort (mittleres Byte DTC-DFCC)_9,1D ,560
IDE05145-ENG115019-Light configuration-Light_Control_HD_AB_0,Always ,560
IDE05145-ENG115038-Light configuration-Light_Control_HD_AB_1,Always ,560
IDE05145-ENG115000-Light configuration-Light_Control_HD_AB_10,Always ,560
IDE05145-ENG115194-Light configuration-Light_Control_HD_AB_11,Always ,560
IDE05145-ENG115213-Light configuration-Light_Control_HD_AB_12,Always ,560
IDE05145-ENG114959-Light configuration-Light_Control_HD_AB_13,Always ,560
IDE05145-ENG115234-Light configuration-Light_Control_HD_AB_14,Always ,560
IDE05145-ENG115253-Light configuration-Light_Control_HD_AB_15,Always ,560
IDE05145-ENG115272-Light configuration-Light_Control_HD_AB_16,Always ,560
IDE05145-ENG115291-Light configuration-Light_Control_HD_AB_17,Always ,560
IDE05145-ENG115310-Light configuration-Light_Control_HD_AB_18,Always ,560
IDE05145-ENG115329-Light configuration-Light_Control_HD_AB_19,Always ,560
IDE05145-ENG115057-Light configuration-Light_Control_HD_AB_2,Always ,560
IDE05145-ENG115348-Light configuration-Light_Control_HD_AB_20,Always ,560
IDE05145-ENG115367-Light configuration-Light_Control_HD_AB_21,Always ,560
IDE05145-ENG115386-Light configuration-Light_Control_HD_AB_22,Always ,560
IDE05145-ENG115405-Light configuration-Light_Control_HD_AB_23,Always ,560
IDE05145-ENG115424-Light configuration-Light_Control_HD_AB_24,Always ,560
IDE05145-ENG115443-Light configuration-Light_Control_HD_AB_25,Always ,560
IDE05145-ENG115462-Light configuration-Light_Control_HD_AB_26,Always ,560
IDE05145-ENG115481-Light configuration-Light_Control_HD_AB_27,Always ,560
IDE05145-ENG115500-Light configuration-Light_Control_HD_AB_28,Always ,560
IDE05145-ENG115520-Light configuration-Light_Control_HD_AB_29,Always ,560
IDE05145-ENG115076-Light configuration-Light_Control_HD_AB_3,Always ,560
IDE05145-ENG115538-Light configuration-Light_Control_HD_AB_30,Always ,560
IDE05145-ENG115557-Light configuration-Light_Control_HD_AB_31,Always ,560
IDE05145-ENG115576-Light configuration-Light_Control_HD_AB_32,Always ,560
IDE05145-ENG115595-Light configuration-Light_Control_HD_AB_33,Always ,560
IDE05145-ENG115614-Light configuration-Light_Control_HD_AB_34,Always ,560
IDE05145-ENG115095-Light configuration-Light_Control_HD_AB_4,Always ,560
IDE05145-ENG114978-Light configuration-Light_Control_HD_AB_5,Always ,560
IDE05145-ENG115116-Light configuration-Light_Control_HD_AB_6,Always ,560
IDE05145-ENG115135-Light configuration-Light_Control_HD_AB_7,Always ,560
IDE05145-ENG115154-Light configuration-Light_Control_HD_AB_8,Always ,560
IDE05145-ENG115173-Light configuration-Light_Control_HD_AB_9,Always ,560
IDE05145-ENG115016-Light configuration-Light_Function_A_0,2 ,560
IDE05145-ENG115035-Light configuration-Light_Function_A_1,4 ,560
IDE05145-ENG114997-Light configuration-Light_Function_A_10,0 ,560
IDE05145-ENG115191-Light configuration-Light_Function_A_11,62 ,560
IDE05145-ENG115210-Light configuration-Light_Function_A_12,0 ,560
IDE05145-ENG114956-Light configuration-Light_Function_A_13,0 ,560
IDE05145-ENG115231-Light configuration-Light_Function_A_14,63 ,560
IDE05145-ENG115250-Light configuration-Light_Function_A_15,64 ,560
IDE05145-ENG115269-Light configuration-Light_Function_A_16,2 ,560
IDE05145-ENG115288-Light configuration-Light_Function_A_17,4 ,560
IDE05145-ENG115307-Light configuration-Light_Function_A_18,2 ,560
IDE05145-ENG115326-Light configuration-Light_Function_A_19,4 ,560
IDE05145-ENG115054-Light configuration-Light_Function_A_2,8 ,560
IDE05145-ENG115345-Light configuration-Light_Function_A_20,24 ,560
IDE05145-ENG115364-Light configuration-Light_Function_A_21,24 ,560
IDE05145-ENG115383-Light configuration-Light_Function_A_22,24 ,560
IDE05145-ENG115402-Light configuration-Light_Function_A_23,8 ,560
IDE05145-ENG115421-Light configuration-Light_Function_A_24,8 ,560
IDE05145-ENG115440-Light configuration-Light_Function_A_25,8 ,560
IDE05145-ENG115459-Light configuration-Light_Function_A_26,27 ,560
IDE05145-ENG115478-Light configuration-Light_Function_A_27,38 ,560
IDE05145-ENG115497-Light configuration-Light_Function_A_28,25 ,560
IDE05145-ENG115516-Light configuration-Light_Function_A_29,37 ,560
IDE05145-ENG115073-Light configuration-Light_Function_A_3,8 ,560
IDE05145-ENG115535-Light configuration-Light_Function_A_30,41 ,560
IDE05145-ENG115554-Light configuration-Light_Function_A_31,0 ,560
IDE05145-ENG115573-Light configuration-Light_Function_A_32,0 ,560
IDE05145-ENG115592-Light configuration-Light_Function_A_33,0 ,560
IDE05145-ENG115611-Light configuration-Light_Function_A_34,0 ,560
IDE05145-ENG115092-Light configuration-Light_Function_A_4,20 ,560
IDE05145-ENG114975-Light configuration-Light_Function_A_5,20 ,560
IDE05145-ENG115113-Light configuration-Light_Function_A_6,11 ,560
IDE05145-ENG115132-Light configuration-Light_Function_A_7,12 ,560
IDE05145-ENG115151-Light configuration-Light_Function_A_8,13 ,560
IDE05145-ENG115170-Light configuration-Light_Function_A_9,14 ,560
IDE05145-ENG115017-Light configuration-Light_Function_B_0,0 ,560
IDE05145-ENG115036-Light configuration-Light_Function_B_1,0 ,560
IDE05145-ENG114998-Light configuration-Light_Function_B_10,0 ,560
IDE05145-ENG115192-Light configuration-Light_Function_B_11,0 ,560
IDE05145-ENG115211-Light configuration-Light_Function_B_12,0 ,560
IDE05145-ENG114957-Light configuration-Light_Function_B_13,0 ,560
IDE05145-ENG115232-Light configuration-Light_Function_B_14,0 ,560
IDE05145-ENG115251-Light configuration-Light_Function_B_15,0 ,560
IDE05145-ENG115270-Light configuration-Light_Function_B_16,0 ,560
IDE05145-ENG115289-Light configuration-Light_Function_B_17,0 ,560
IDE05145-ENG115308-Light configuration-Light_Function_B_18,0 ,560
IDE05145-ENG115327-Light configuration-Light_Function_B_19,0 ,560
IDE05145-ENG115055-Light configuration-Light_Function_B_2,9 ,560
IDE05145-ENG115346-Light configuration-Light_Function_B_20,0 ,560
IDE05145-ENG115365-Light configuration-Light_Function_B_21,0 ,560
IDE05145-ENG115384-Light configuration-Light_Function_B_22,0 ,560
IDE05145-ENG115403-Light configuration-Light_Function_B_23,9 ,560
IDE05145-ENG115422-Light configuration-Light_Function_B_24,10 ,560
IDE05145-ENG115441-Light configuration-Light_Function_B_25,0 ,560
IDE05145-ENG115460-Light configuration-Light_Function_B_26,0 ,560
IDE05145-ENG115479-Light configuration-Light_Function_B_27,0 ,560
IDE05145-ENG115498-Light configuration-Light_Function_B_28,0 ,560
IDE05145-ENG115517-Light configuration-Light_Function_B_29,0 ,560
IDE05145-ENG115074-Light configuration-Light_Function_B_3,10 ,560
IDE05145-ENG115536-Light configuration-Light_Function_B_30,0 ,560
IDE05145-ENG115555-Light configuration-Light_Function_B_31,0 ,560
IDE05145-ENG115574-Light configuration-Light_Function_B_32,0 ,560
IDE05145-ENG115593-Light configuration-Light_Function_B_33,0 ,560
IDE05145-ENG115612-Light configuration-Light_Function_B_34,0 ,560
IDE05145-ENG115093-Light configuration-Light_Function_B_4,0 ,560
IDE05145-ENG114976-Light configuration-Light_Function_B_5,0 ,560
IDE05145-ENG115114-Light configuration-Light_Function_B_6,30 ,560
IDE05145-ENG115133-Light configuration-Light_Function_B_7,30 ,560
IDE05145-ENG115152-Light configuration-Light_Function_B_8,15 ,560
IDE05145-ENG115171-Light configuration-Light_Function_B_9,15 ,560
IDE05145-ENG115020-Light configuration-Light_Function_C_0,0 ,560
IDE05145-ENG115039-Light configuration-Light_Function_C_1,0 ,560
IDE05145-ENG115001-Light configuration-Light_Function_C_10,0 ,560
IDE05145-ENG115195-Light configuration-Light_Function_C_11,0 ,560
IDE05145-ENG115214-Light configuration-Light_Function_C_12,0 ,560
IDE05145-ENG114960-Light configuration-Light_Function_C_13,0 ,560
IDE05145-ENG115235-Light configuration-Light_Function_C_14,0 ,560
IDE05145-ENG115254-Light configuration-Light_Function_C_15,0 ,560
IDE05145-ENG115273-Light configuration-Light_Function_C_16,0 ,560
IDE05145-ENG115292-Light configuration-Light_Function_C_17,0 ,560
IDE05145-ENG115311-Light configuration-Light_Function_C_18,0 ,560
IDE05145-ENG115330-Light configuration-Light_Function_C_19,0 ,560
IDE05145-ENG115058-Light configuration-Light_Function_C_2,0 ,560
IDE05145-ENG115349-Light configuration-Light_Function_C_20,0 ,560
IDE05145-ENG115368-Light configuration-Light_Function_C_21,0 ,560
IDE05145-ENG115387-Light configuration-Light_Function_C_22,0 ,560
IDE05145-ENG115406-Light configuration-Light_Function_C_23,0 ,560
IDE05145-ENG115425-Light configuration-Light_Function_C_24,0 ,560
IDE05145-ENG115444-Light configuration-Light_Function_C_25,0 ,560
IDE05145-ENG115463-Light configuration-Light_Function_C_26,0 ,560
IDE05145-ENG115482-Light configuration-Light_Function_C_27,0 ,560
IDE05145-ENG115501-Light configuration-Light_Function_C_28,0 ,560
IDE05145-ENG115519-Light configuration-Light_Function_C_29,0 ,560
IDE05145-ENG115077-Light configuration-Light_Function_C_3,0 ,560
IDE05145-ENG115539-Light configuration-Light_Function_C_30,0 ,560
IDE05145-ENG115558-Light configuration-Light_Function_C_31,0 ,560
IDE05145-ENG115577-Light configuration-Light_Function_C_32,0 ,560
IDE05145-ENG115596-Light configuration-Light_Function_C_33,0 ,560
IDE05145-ENG115615-Light configuration-Light_Function_C_34,0 ,560
IDE05145-ENG115096-Light configuration-Light_Function_C_4,18 ,560
IDE05145-ENG114979-Light configuration-Light_Function_C_5,19 ,560
IDE05145-ENG115117-Light configuration-Light_Function_C_6,0 ,560
IDE05145-ENG115136-Light configuration-Light_Function_C_7,0 ,560
IDE05145-ENG115155-Light configuration-Light_Function_C_8,0 ,560
IDE05145-ENG115174-Light configuration-Light_Function_C_9,0 ,560
IDE05145-ENG115021-Light configuration-Light_Function_D_0,0 ,560
IDE05145-ENG115040-Light configuration-Light_Function_D_1,0 ,560
IDE05145-ENG115002-Light configuration-Light_Function_D_10,0 ,560
IDE05145-ENG115196-Light configuration-Light_Function_D_11,0 ,560
IDE05145-ENG115215-Light configuration-Light_Function_D_12,0 ,560
IDE05145-ENG114961-Light configuration-Light_Function_D_13,0 ,560
IDE05145-ENG115236-Light configuration-Light_Function_D_14,0 ,560
IDE05145-ENG115255-Light configuration-Light_Function_D_15,0 ,560
IDE05145-ENG115274-Light configuration-Light_Function_D_16,0 ,560
IDE05145-ENG115293-Light configuration-Light_Function_D_17,0 ,560
IDE05145-ENG115312-Light configuration-Light_Function_D_18,0 ,560
IDE05145-ENG115331-Light configuration-Light_Function_D_19,0 ,560
IDE05145-ENG115059-Light configuration-Light_Function_D_2,0 ,560
IDE05145-ENG115350-Light configuration-Light_Function_D_20,0 ,560
IDE05145-ENG115369-Light configuration-Light_Function_D_21,0 ,560
IDE05145-ENG115388-Light configuration-Light_Function_D_22,0 ,560
IDE05145-ENG115407-Light configuration-Light_Function_D_23,0 ,560
IDE05145-ENG115426-Light configuration-Light_Function_D_24,0 ,560
IDE05145-ENG115445-Light configuration-Light_Function_D_25,0 ,560
IDE05145-ENG115464-Light configuration-Light_Function_D_26,0 ,560
IDE05145-ENG115483-Light configuration-Light_Function_D_27,0 ,560
IDE05145-ENG115502-Light configuration-Light_Function_D_28,0 ,560
IDE05145-ENG115521-Light configuration-Light_Function_D_29,0 ,560
IDE05145-ENG115078-Light configuration-Light_Function_D_3,0 ,560
IDE05145-ENG115540-Light configuration-Light_Function_D_30,0 ,560
IDE05145-ENG115559-Light configuration-Light_Function_D_31,0 ,560
IDE05145-ENG115578-Light configuration-Light_Function_D_32,0 ,560
IDE05145-ENG115597-Light configuration-Light_Function_D_33,0 ,560
IDE05145-ENG115616-Light configuration-Light_Function_D_34,0 ,560
IDE05145-ENG115097-Light configuration-Light_Function_D_4,0 ,560
IDE05145-ENG114980-Light configuration-Light_Function_D_5,0 ,560
IDE05145-ENG115118-Light configuration-Light_Function_D_6,0 ,560
IDE05145-ENG115137-Light configuration-Light_Function_D_7,0 ,560
IDE05145-ENG115156-Light configuration-Light_Function_D_8,0 ,560
IDE05145-ENG115175-Light configuration-Light_Function_D_9,0 ,560
IDE05145-ENG115024-Light configuration-Light_Function_E_0,0 ,560
IDE05145-ENG115043-Light configuration-Light_Function_E_1,0 ,560
IDE05145-ENG115005-Light configuration-Light_Function_E_10,0 ,560
IDE05145-ENG115199-Light configuration-Light_Function_E_11,0 ,560
IDE05145-ENG115218-Light configuration-Light_Function_E_12,0 ,560
IDE05145-ENG114964-Light configuration-Light_Function_E_13,0 ,560
IDE05145-ENG115239-Light configuration-Light_Function_E_14,0 ,560
IDE05145-ENG115258-Light configuration-Light_Function_E_15,0 ,560
IDE05145-ENG115277-Light configuration-Light_Function_E_16,0 ,560
IDE05145-ENG115296-Light configuration-Light_Function_E_17,0 ,560
IDE05145-ENG115315-Light configuration-Light_Function_E_18,0 ,560
IDE05145-ENG115334-Light configuration-Light_Function_E_19,0 ,560
IDE05145-ENG115062-Light configuration-Light_Function_E_2,0 ,560
IDE05145-ENG115353-Light configuration-Light_Function_E_20,0 ,560
IDE05145-ENG115372-Light configuration-Light_Function_E_21,0 ,560
IDE05145-ENG115391-Light configuration-Light_Function_E_22,0 ,560
IDE05145-ENG115410-Light configuration-Light_Function_E_23,0 ,560
IDE05145-ENG115429-Light configuration-Light_Function_E_24,0 ,560
IDE05145-ENG115448-Light configuration-Light_Function_E_25,0 ,560
IDE05145-ENG115467-Light configuration-Light_Function_E_26,0 ,560
IDE05145-ENG115486-Light configuration-Light_Function_E_27,0 ,560
IDE05145-ENG115505-Light configuration-Light_Function_E_28,0 ,560
IDE05145-ENG115524-Light configuration-Light_Function_E_29,0 ,560
IDE05145-ENG115081-Light configuration-Light_Function_E_3,0 ,560
IDE05145-ENG115543-Light configuration-Light_Function_E_30,0 ,560
IDE05145-ENG115562-Light configuration-Light_Function_E_31,0 ,560
IDE05145-ENG115581-Light configuration-Light_Function_E_32,0 ,560
IDE05145-ENG115600-Light configuration-Light_Function_E_33,0 ,560
IDE05145-ENG115619-Light configuration-Light_Function_E_34,0 ,560
IDE05145-ENG115100-Light configuration-Light_Function_E_4,0 ,560
IDE05145-ENG114983-Light configuration-Light_Function_E_5,0 ,560
IDE05145-ENG115121-Light configuration-Light_Function_E_6,0 ,560
IDE05145-ENG115140-Light configuration-Light_Function_E_7,0 ,560
IDE05145-ENG115159-Light configuration-Light_Function_E_8,0 ,560
IDE05145-ENG115178-Light configuration-Light_Function_E_9,0 ,560
IDE05145-ENG115025-Light configuration-Light_Function_F_0,0 ,560
IDE05145-ENG115044-Light configuration-Light_Function_F_1,0 ,560
IDE05145-ENG115006-Light configuration-Light_Function_F_10,0 ,560
IDE05145-ENG115200-Light configuration-Light_Function_F_11,0 ,560
IDE05145-ENG115219-Light configuration-Light_Function_F_12,0 ,560
IDE05145-ENG114965-Light configuration-Light_Function_F_13,0 ,560
IDE05145-ENG115240-Light configuration-Light_Function_F_14,0 ,560
IDE05145-ENG115259-Light configuration-Light_Function_F_15,0 ,560
IDE05145-ENG115278-Light configuration-Light_Function_F_16,0 ,560
IDE05145-ENG115297-Light configuration-Light_Function_F_17,0 ,560
IDE05145-ENG115316-Light configuration-Light_Function_F_18,0 ,560
IDE05145-ENG115335-Light configuration-Light_Function_F_19,0 ,560
IDE05145-ENG115063-Light configuration-Light_Function_F_2,0 ,560
IDE05145-ENG115354-Light configuration-Light_Function_F_20,0 ,560
IDE05145-ENG115373-Light configuration-Light_Function_F_21,0 ,560
IDE05145-ENG115392-Light configuration-Light_Function_F_22,0 ,560
IDE05145-ENG115411-Light configuration-Light_Function_F_23,0 ,560
IDE05145-ENG115430-Light configuration-Light_Function_F_24,0 ,560
IDE05145-ENG115449-Light configuration-Light_Function_F_25,0 ,560
IDE05145-ENG115468-Light configuration-Light_Function_F_26,0 ,560
IDE05145-ENG115487-Light configuration-Light_Function_F_27,0 ,560
IDE05145-ENG115506-Light configuration-Light_Function_F_28,0 ,560
IDE05145-ENG115525-Light configuration-Light_Function_F_29,0 ,560
IDE05145-ENG115082-Light configuration-Light_Function_F_3,0 ,560
IDE05145-ENG115544-Light configuration-Light_Function_F_30,0 ,560
IDE05145-ENG115563-Light configuration-Light_Function_F_31,0 ,560
IDE05145-ENG115582-Light configuration-Light_Function_F_32,0 ,560
IDE05145-ENG115601-Light configuration-Light_Function_F_33,0 ,560
IDE05145-ENG115620-Light configuration-Light_Function_F_34,0 ,560
IDE05145-ENG115101-Light configuration-Light_Function_F_4,0 ,560
IDE05145-ENG114984-Light configuration-Light_Function_F_5,0 ,560
IDE05145-ENG115122-Light configuration-Light_Function_F_6,0 ,560
IDE05145-ENG115141-Light configuration-Light_Function_F_7,0 ,560
IDE05145-ENG115160-Light configuration-Light_Function_F_8,0 ,560
IDE05145-ENG115179-Light configuration-Light_Function_F_9,0 ,560
IDE05145-ENG115028-Light configuration-Light_Function_G_0,0 ,560
IDE05145-ENG115047-Light configuration-Light_Function_G_1,0 ,560
IDE05145-ENG115009-Light configuration-Light_Function_G_10,0 ,560
IDE05145-ENG115203-Light configuration-Light_Function_G_11,0 ,560
IDE05145-ENG115222-Light configuration-Light_Function_G_12,0 ,560
IDE05145-ENG114968-Light configuration-Light_Function_G_13,0 ,560
IDE05145-ENG115243-Light configuration-Light_Function_G_14,0 ,560
IDE05145-ENG115262-Light configuration-Light_Function_G_15,0 ,560
IDE05145-ENG115281-Light configuration-Light_Function_G_16,0 ,560
IDE05145-ENG115300-Light configuration-Light_Function_G_17,0 ,560
IDE05145-ENG115319-Light configuration-Light_Function_G_18,0 ,560
IDE05145-ENG115338-Light configuration-Light_Function_G_19,0 ,560
IDE05145-ENG115066-Light configuration-Light_Function_G_2,0 ,560
IDE05145-ENG115357-Light configuration-Light_Function_G_20,0 ,560
IDE05145-ENG115376-Light configuration-Light_Function_G_21,0 ,560
IDE05145-ENG115395-Light configuration-Light_Function_G_22,0 ,560
IDE05145-ENG115414-Light configuration-Light_Function_G_23,0 ,560
IDE05145-ENG115433-Light configuration-Light_Function_G_24,0 ,560
IDE05145-ENG115452-Light configuration-Light_Function_G_25,0 ,560
IDE05145-ENG115471-Light configuration-Light_Function_G_26,0 ,560
IDE05145-ENG115490-Light configuration-Light_Function_G_27,0 ,560
IDE05145-ENG115509-Light configuration-Light_Function_G_28,0 ,560
IDE05145-ENG115528-Light configuration-Light_Function_G_29,0 ,560
IDE05145-ENG115085-Light configuration-Light_Function_G_3,0 ,560
IDE05145-ENG115547-Light configuration-Light_Function_G_30,0 ,560
IDE05145-ENG115566-Light configuration-Light_Function_G_31,0 ,560
IDE05145-ENG115585-Light configuration-Light_Function_G_32,0 ,560
IDE05145-ENG115604-Light configuration-Light_Function_G_33,0 ,560
IDE05145-ENG115623-Light configuration-Light_Function_G_34,0 ,560
IDE05145-ENG115104-Light configuration-Light_Function_G_4,0 ,560
IDE05145-ENG114987-Light configuration-Light_Function_G_5,0 ,560
IDE05145-ENG115125-Light configuration-Light_Function_G_6,0 ,560
IDE05145-ENG115144-Light configuration-Light_Function_G_7,0 ,560
IDE05145-ENG115163-Light configuration-Light_Function_G_8,0 ,560
IDE05145-ENG115182-Light configuration-Light_Function_G_9,0 ,560
IDE05145-ENG115029-Light configuration-Light_Function_H_0,0 ,560
IDE05145-ENG115048-Light configuration-Light_Function_H_1,0 ,560
IDE05145-ENG115010-Light configuration-Light_Function_H_10,0 ,560
IDE05145-ENG115204-Light configuration-Light_Function_H_11,0 ,560
IDE05145-ENG115223-Light configuration-Light_Function_H_12,0 ,560
IDE05145-ENG114969-Light configuration-Light_Function_H_13,0 ,560
IDE05145-ENG115244-Light configuration-Light_Function_H_14,0 ,560
IDE05145-ENG115263-Light configuration-Light_Function_H_15,0 ,560
IDE05145-ENG115282-Light configuration-Light_Function_H_16,0 ,560
IDE05145-ENG115301-Light configuration-Light_Function_H_17,0 ,560
IDE05145-ENG115320-Light configuration-Light_Function_H_18,0 ,560
IDE05145-ENG115339-Light configuration-Light_Function_H_19,0 ,560
IDE05145-ENG115067-Light configuration-Light_Function_H_2,0 ,560
IDE05145-ENG115358-Light configuration-Light_Function_H_20,0 ,560
IDE05145-ENG115377-Light configuration-Light_Function_H_21,0 ,560
IDE05145-ENG115396-Light configuration-Light_Function_H_22,0 ,560
IDE05145-ENG115415-Light configuration-Light_Function_H_23,0 ,560
IDE05145-ENG115434-Light configuration-Light_Function_H_24,0 ,560
IDE05145-ENG115453-Light configuration-Light_Function_H_25,0 ,560
IDE05145-ENG115472-Light configuration-Light_Function_H_26,0 ,560
IDE05145-ENG115491-Light configuration-Light_Function_H_27,0 ,560
IDE05145-ENG115510-Light configuration-Light_Function_H_28,0 ,560
IDE05145-ENG115529-Light configuration-Light_Function_H_29,0 ,560
IDE05145-ENG115086-Light configuration-Light_Function_H_3,0 ,560
IDE05145-ENG115548-Light configuration-Light_Function_H_30,0 ,560
IDE05145-ENG115567-Light configuration-Light_Function_H_31,0 ,560
IDE05145-ENG115586-Light configuration-Light_Function_H_32,0 ,560
IDE05145-ENG115605-Light configuration-Light_Function_H_33,0 ,560
IDE05145-ENG115624-Light configuration-Light_Function_H_34,0 ,560
IDE05145-ENG115105-Light configuration-Light_Function_H_4,0 ,560
IDE05145-ENG114988-Light configuration-Light_Function_H_5,0 ,560
IDE05145-ENG115126-Light configuration-Light_Function_H_6,0 ,560
IDE05145-ENG115145-Light configuration-Light_Function_H_7,0 ,560
IDE05145-ENG115164-Light configuration-Light_Function_H_8,0 ,560
IDE05145-ENG115183-Light configuration-Light_Function_H_9,0 ,560
IDE05145-ENG154373-Light configuration-Reserved_0,0 ,560
IDE05145-ENG101416-Light configuration-Reserved_1,0 ,560
IDE05145-ENG154318-Light configuration-Reserved_10,0 ,560
IDE05145-ENG99637-Light configuration-Reserved_11,0 ,560
IDE05145-ENG154355-Light configuration-Reserved_12,0 ,560
IDE05145-ENG154196-Light configuration-Reserved_13,0 ,560
IDE05145-ENG154298-Light configuration-Reserved_14,0 ,560
IDE05145-ENG154243-Light configuration-Reserved_15,0 ,560
IDE05145-ENG154297-Light configuration-Reserved_16,0 ,560
IDE05145-ENG154432-Light configuration-reserved_17,0 ,560
IDE05145-ENG154433-Light configuration-reserved_18,0 ,560
IDE05145-ENG154434-Light configuration-reserved_19,0 ,560
IDE05145-ENG99458-Light configuration-Reserved_2,0 ,560
IDE05145-ENG154435-Light configuration-reserved_20,0 ,560
IDE05145-ENG154436-Light configuration-reserved_21,0 ,560
IDE05145-ENG159603-Light configuration-reserved_22,0 ,560
IDE05145-ENG154437-Light configuration-reserved_23,0 ,560
IDE05145-ENG159604-Light configuration-reserved_24,0 ,560
IDE05145-ENG159605-Light configuration-reserved_25,0 ,560
IDE05145-ENG159606-Light configuration-reserved_26,0 ,560
IDE05145-ENG159607-Light configuration-reserved_27,0 ,560
IDE05145-ENG159608-Light configuration-reserved_28,0 ,560
IDE05145-ENG159609-Light configuration-reserved_29,0 ,560
IDE05145-ENG99668-Light configuration-Reserved_3,00 ,560
IDE05145-ENG159610-Light configuration-reserved_30,0 ,560
IDE05145-ENG159611-Light configuration-reserved_31,0 ,560
IDE05145-ENG114291-Light configuration-reserved_32,0 ,560
IDE05145-ENG184465-Light configuration-reserved_33,0 ,560
IDE05145-ENG159612-Light configuration-reserved_34,0 ,560
IDE05145-ENG154261-Light configuration-Reserved_4,0 ,560
IDE05145-ENG154330-Light configuration-Reserved_5,0 ,560
IDE05145-ENG154188-Light configuration-Reserved_6,0 ,560
IDE05145-ENG154256-Light configuration-Reserved_7,0 ,560
IDE05145-ENG154341-Light configuration-Reserved_8,0 ,560
IDE05145-ENG154185-Light configuration-Reserved_9,0 ,560
IDE05145-ENG115013-Light configuration-Type_Of_Load_0,Blinkleuchten ,560
IDE05145-ENG115032-Light configuration-Type_Of_Load_1,Blinkleuchten ,560
IDE05145-ENG114995-Light configuration-Type_Of_Load_10,not active ,560
IDE05145-ENG115188-Light configuration-Type_Of_Load_11,LED Kleinleistung ohne Open Load Diagnose ,560
IDE05145-ENG115207-Light configuration-Type_Of_Load_12,not active ,560
IDE05145-ENG114954-Light configuration-Type_Of_Load_13,not active ,560
IDE05145-ENG115228-Light configuration-Type_Of_Load_14,allgemeineLEDmitOpenLoadDiagnose ,560
IDE05145-ENG115247-Light configuration-Type_Of_Load_15,allgemeineLEDmitOpenLoadDiagnose ,560
IDE05145-ENG115266-Light configuration-Type_Of_Load_16,LED Blinkleuchten ,560
IDE05145-ENG115285-Light configuration-Type_Of_Load_17,LED Blinkleuchten ,560
IDE05145-ENG115304-Light configuration-Type_Of_Load_18,Blinkleuchten ,560
IDE05145-ENG115323-Light configuration-Type_Of_Load_19,Blinkleuchten ,560
IDE05145-ENG115051-Light configuration-Type_Of_Load_2,allgemeineGluehlampe6W:auchH6W ,560
IDE05145-ENG115342-Light configuration-Type_Of_Load_20,Bremsleuchten ,560
IDE05145-ENG115361-Light configuration-Type_Of_Load_21,Bremsleuchten ,560
IDE05145-ENG115380-Light configuration-Type_Of_Load_22,LEDdritteBremsleuchte ,560
IDE05145-ENG115399-Light configuration-Type_Of_Load_23,allgemeineGluehlampe6W:auchH6W ,560
IDE05145-ENG115418-Light configuration-Type_Of_Load_24,allgemeineGluehlampe6W:auchH6W ,560
IDE05145-ENG115437-Light configuration-Type_Of_Load_25,2* 5W ,560
IDE05145-ENG115456-Light configuration-Type_Of_Load_26,allgemeineGluehlampe27W:auchH15-TFL ,560
IDE05145-ENG115475-Light configuration-Type_Of_Load_27,LED Kleinleistung ohne Open Load Diagnose ,560
IDE05145-ENG115494-Light configuration-Type_Of_Load_28,allgemeineGluehlampe27W:auchH15-TFL ,560
IDE05145-ENG115513-Light configuration-Type_Of_Load_29,allgemeineGluehlampe12W ,560
IDE05145-ENG115070-Light configuration-Type_Of_Load_3,allgemeineGluehlampe6W:auchH6W ,560
IDE05145-ENG115532-Light configuration-Type_Of_Load_30,allgemeineGluehlampe12W ,560
IDE05145-ENG115551-Light configuration-Type_Of_Load_31,not active ,560
IDE05145-ENG115570-Light configuration-Type_Of_Load_32,not active ,560
IDE05145-ENG115589-Light configuration-Type_Of_Load_33,not active ,560
IDE05145-ENG115608-Light configuration-Type_Of_Load_34,not active ,560
IDE05145-ENG115089-Light configuration-Type_Of_Load_4,allgemeineGluehlampe27W:auchH15-TFL ,560
IDE05145-ENG114973-Light configuration-Type_Of_Load_5,allgemeineGluehlampe27W:auchH15-TFL ,560
IDE05145-ENG115110-Light configuration-Type_Of_Load_6,Low beam ,560
IDE05145-ENG115129-Light configuration-Type_Of_Load_7,Low beam ,560
IDE05145-ENG115148-Light configuration-Type_Of_Load_8,allgemeineScheinwerferohneAbschaltung ,560
IDE05145-ENG115167-Light configuration-Type_Of_Load_9,allgemeineScheinwerferohneAbschaltung ,560
IDE06096-ENG116596-Interior lighting-Innenlicht bei offenem Heckdeckel einschalten,active ,6
IDE06096-ENG116597-Interior lighting-KL30G ohne PWM,not active ,6
IDE06096-ENG116598-Interior lighting-KL58 Einschalten mit Rampe,not active ,6
IDE06096-ENG116599-Interior lighting-KL58 Verriegelungsausschalten,not active ,6
IDE06096-ENG116600-Interior lighting-Lichtsensor wirkt auf Suchbeleuchtung,active ,6
IDE06096-ENG116595-Interior lighting-Menuesteuerung Ambientebeleuchtung Effektbeleuchtung,active ,6
IDE06096-ENG115631-Interior lighting-Suchbeleuchtung Festwert,100 %,6
IDE06864-ENG115833-Daytime running lights-Fahrlicht bei Tag,Daytime running lights ,2
IDE06864-ENG115832-Daytime running lights-Scheinwerferferreinigungsansteuerung und Abblendlichtanzeige bei Dauerfahrlicht,not active ,2
IDE06864-ENG116592-Daytime running lights-Standlicht aktiviert zusaetzlich Tagfahrlicht,not active ,2
IDE06864-ENG116594-Daytime running lights-Tagfahrlicht Aktivierung durch BAP oder Bedienfolge moeglich,active ,2
IDE06864-ENG122184-Daytime running lights-Tagfahrlicht Dauerfahrlicht bei Handbremse abschalten,active ,2
IDE06864-ENG115734-Daytime running lights-Tagfahrlicht nur in Schalterstellung AUTO,not active ,2
IDE06864-ENG116593-Daytime running lights-Tagfahrlicht-Dauerfahrlicht aktiviert zusaetzlich Standlicht,not active ,2
IDE06864-ENG115733-Daytime running lights-Tagfahrlichtkontrollleuchte,not active ,2
IDE06864-ENG116591-Daytime running lights-Werkseinstellung fuer Tagfahrlicht Freischaltung BAP / Bedienfolge,not active ,2
IDE07007-ENG115783-A/C heater function via remote control-Remote_Start_Duration,0 min,2
IDE07007-ENG126614-A/C heater function via remote control-valid_remote_starts,0 ,2
IDE08542-IDE02021-Access control 2-Comfort closing,active ,6
IDE08542-IDE02022-Access control 2-Comfort opening,active ,6
IDE08542-ENG116663-Access control 2-Fahrertuerbedienung Fensterheber oeffnen,active ,6
IDE08542-ENG116664-Access control 2-Fahrertuerbedienung Fensterheber schliessen,active ,6
IDE08542-ENG116662-Access control 2-FH SAD Kl15Aus Freigabezeit,600 s,6
IDE08542-ENG116648-Access control 2-Freigabenachlauf FH bei Kl 15 aus,active ,6
IDE08542-ENG116649-Access control 2-Freigabenachlauf FH bei Tueroeffnen,active ,6
IDE08542-ENG116652-Access control 2-Funk Komfort oeffnen,active ,6
IDE08542-ENG116651-Access control 2-Funk Komfort schliessen,active ,6
IDE08542-ENG116658-Access control 2-Funk Spiegelanklappen,not active ,6
IDE08542-ENG116665-Access control 2-Funk Spiegelanklappung Modus,by look command via remote control key ,6
IDE08542-ENG116653-Access control 2-Kessy Komfort oeffnen,No ,6
IDE08542-ENG116654-Access control 2-Kessy Komfort schliessen,No ,6
IDE08542-ENG115670-Access control 2-Komfortbedienung global,active ,6
IDE08542-ENG116642-Access control 2-Komfortoeffnen nur FH Fahrertuer,active ,6
IDE08542-ENG116660-Access control 2-Menuesteuerung Funk Spiegel anklappen,not active ,6
IDE08542-ENG122994-Access control 2-Menuesteuerung Komfortbedienung einstellbar,not active ,6
IDE08542-ENG122186-Access control 2-Menuesteuerung Regenschliessen,not active ,6
IDE08542-ENG125658-Access control 2-Profilfunktion für Anklappung der Außenspiegel,active ,6
IDE08542-ENG115671-Access control 2-Regenschließen,not active ,6
IDE08542-ENG125656-Access control 2-Regenschliessen_art,Permanent ,6
IDE08542-ENG116647-Access control 2-SAD Komfort oeffnen,active ,6
IDE08542-ENG116646-Access control 2-SAD Komfort schliessen,active ,6
IDE08542-ENG116661-Access control 2-SAD PreCrash Konturschliessen,active ,6
IDE08542-ENG116645-Access control 2-SAD Richtung Komfortoeffnen,Open ,6
IDE08542-ENG116643-Access control 2-Schliesszylinder Komfort oeffnen,active ,6
IDE08542-ENG116644-Access control 2-Schliesszylinder Komfort schliessen,active ,6
IDE08542-ENG126612-Access control 2-Spiegelanklappung geschwindigkeitsabhängig,not active ,6
IDE08786-ENG116640-Assistance light functions-AFL Zeitverzoegerung,0 ms,4
IDE08786-ENG142177-Assistance light functions-Assistance_lighting_sensitivity_adjustable,present ,4
IDE08786-ENG115723-Assistance light functions-Assistenzfahrlicht bei Regen,not active ,4
IDE08786-ENG126818-Assistance light functions-Fahrlichtwarnung_Hinweis_Konfig,kein Hinweis ,4
IDE08786-ENG116639-Assistance light functions-Fernlichtassistent Reset,active ,4
IDE08786-ENG116638-Assistance light functions-Fernlichtassistent Zeitverzoegerungswert,0 ms,4
IDE08786-ENG115724-Assistance light functions-Lichtsensorempfindlichkeit,normal ,4
IDE08786-ENG116637-Assistance light functions-Menuesteuerung Fernlichtassistent,Not Present ,4
IDE08786-ENG116641-Assistance light functions-Menuesteuerung Fernlichtassistent Werkseinstellung,present ,4
IDE08786-ENG116636-Assistance light functions-Notbremsanzeige NBA,active ,4
IDE08787-ENG115810-Auxiliary functions-Klemmenfehler auf CAN ausgeben,not active ,1
IDE08787-ENG115809-Auxiliary functions-Signalhorn ohne KL15,not active ,1
IDE08788-ENG122212-Dyn. turn signal modes-ABBA_Blinken,not active ,4
IDE08788-ENG121966-Dyn. turn signal modes-Crash flashing,not active ,4
IDE08788-ENG122207-Dyn. turn signal modes-DWA_Alarm_Blinken,not active ,4
IDE08788-ENG122206-Dyn. turn signal modes-DWA_Schaerfungsquittung,not active ,4
IDE08788-ENG122208-Dyn. turn signal modes-Multi_kollisions_Blinken,not active ,4
IDE08788-ENG122209-Dyn. turn signal modes-Notwarn_blinken_NBA_Phase_2,not active ,4
IDE08788-ENG121967-Dyn. turn signal modes-Panic flashing,not active ,4
IDE08788-ENG122211-Dyn. turn signal modes-Richtungs_blinken_links,not active ,4
IDE08788-ENG122210-Dyn. turn signal modes-Richtungs_blinken_rechts,not active ,4
IDE08788-ENG122201-Dyn. turn signal modes-Schluessel_Anlern_Blinken,not active ,4
IDE08788-ENG121968-Dyn. turn signal modes-Taxi alarm flashing,not active ,4
IDE08788-ENG122205-Dyn. turn signal modes-Telematikblinken_STS_Blinken,not active ,4
IDE08788-ENG122202-Dyn. turn signal modes-UGDO_ Anlern_Blinken,not active ,4
IDE08788-ENG122214-Dyn. turn signal modes-Warnblinken_Zuendung_AUS,not active ,4
IDE08788-ENG122213-Dyn. turn signal modes-Warnblinken_Zuendung_EIN,not active ,4
IDE08788-ENG122204-Dyn. turn signal modes-ZV_Blinken_auf,not active ,4
IDE08788-ENG122203-Dyn. turn signal modes-ZV_Blinken_zu,not active ,4
IDE10286-ENG130228-Configuration of light collective diagnostic line 1: instance 1-Defektbit,Unknown (0),7
IDE10286-ENG127071-Configuration of light collective diagnostic line 1: instance 1-DTCDFCC,00 ,7
IDE10286-ENG130193-Configuration of light collective diagnostic line 1: instance 1-Leuchte_0,not active ,7
IDE10286-ENG130194-Configuration of light collective diagnostic line 1: instance 1-Leuchte_1,not active ,7
IDE10286-ENG130203-Configuration of light collective diagnostic line 1: instance 1-Leuchte_10,not active ,7
IDE10286-ENG130204-Configuration of light collective diagnostic line 1: instance 1-Leuchte_11,not active ,7
IDE10286-ENG130205-Configuration of light collective diagnostic line 1: instance 1-Leuchte_12,not active ,7
IDE10286-ENG130206-Configuration of light collective diagnostic line 1: instance 1-Leuchte_13,not active ,7
IDE10286-ENG130207-Configuration of light collective diagnostic line 1: instance 1-Leuchte_14,not active ,7
IDE10286-ENG130208-Configuration of light collective diagnostic line 1: instance 1-Leuchte_15,not active ,7
IDE10286-ENG130209-Configuration of light collective diagnostic line 1: instance 1-Leuchte_16,not active ,7
IDE10286-ENG130210-Configuration of light collective diagnostic line 1: instance 1-Leuchte_17,not active ,7
IDE10286-ENG130211-Configuration of light collective diagnostic line 1: instance 1-Leuchte_18,not active ,7
IDE10286-ENG130212-Configuration of light collective diagnostic line 1: instance 1-Leuchte_19,not active ,7
IDE10286-ENG130195-Configuration of light collective diagnostic line 1: instance 1-Leuchte_2,not active ,7
IDE10286-ENG130213-Configuration of light collective diagnostic line 1: instance 1-Leuchte_20,not active ,7
IDE10286-ENG130214-Configuration of light collective diagnostic line 1: instance 1-Leuchte_21,not active ,7
IDE10286-ENG130215-Configuration of light collective diagnostic line 1: instance 1-Leuchte_22,not active ,7
IDE10286-ENG130216-Configuration of light collective diagnostic line 1: instance 1-Leuchte_23,not active ,7
IDE10286-ENG130217-Configuration of light collective diagnostic line 1: instance 1-Leuchte_24,not active ,7
IDE10286-ENG130218-Configuration of light collective diagnostic line 1: instance 1-Leuchte_25,not active ,7
IDE10286-ENG130219-Configuration of light collective diagnostic line 1: instance 1-Leuchte_26,not active ,7
IDE10286-ENG130220-Configuration of light collective diagnostic line 1: instance 1-Leuchte_27,not active ,7
IDE10286-ENG130221-Configuration of light collective diagnostic line 1: instance 1-Leuchte_28,not active ,7
IDE10286-ENG130222-Configuration of light collective diagnostic line 1: instance 1-Leuchte_29,not active ,7
IDE10286-ENG130196-Configuration of light collective diagnostic line 1: instance 1-Leuchte_3,not active ,7
IDE10286-ENG130223-Configuration of light collective diagnostic line 1: instance 1-Leuchte_30,not active ,7
IDE10286-ENG130224-Configuration of light collective diagnostic line 1: instance 1-Leuchte_31,not active ,7
IDE10286-ENG130225-Configuration of light collective diagnostic line 1: instance 1-Leuchte_32,not active ,7
IDE10286-ENG130226-Configuration of light collective diagnostic line 1: instance 1-Leuchte_33,not active ,7
IDE10286-ENG130227-Configuration of light collective diagnostic line 1: instance 1-Leuchte_34,not active ,7
IDE10286-ENG130197-Configuration of light collective diagnostic line 1: instance 1-Leuchte_4,not active ,7
IDE10286-ENG130198-Configuration of light collective diagnostic line 1: instance 1-Leuchte_5,not active ,7
IDE10286-ENG130199-Configuration of light collective diagnostic line 1: instance 1-Leuchte_6,not active ,7
IDE10286-ENG130200-Configuration of light collective diagnostic line 1: instance 1-Leuchte_7,not active ,7
IDE10286-ENG130201-Configuration of light collective diagnostic line 1: instance 1-Leuchte_8,not active ,7
IDE10286-ENG130202-Configuration of light collective diagnostic line 1: instance 1-Leuchte_9,not active ,7
IDE10286-ENG127072-Configuration of light collective diagnostic line 1: instance 1-Wiederstand,0_Ohm ,7
IDE10288-ENG130228-Configuration of light collective diagnostic line 2: instance 1-Defektbit,Unknown (0),7
IDE10288-ENG127071-Configuration of light collective diagnostic line 2: instance 1-DTCDFCC,00 ,7
IDE10288-ENG130193-Configuration of light collective diagnostic line 2: instance 1-Leuchte_0,not active ,7
IDE10288-ENG130194-Configuration of light collective diagnostic line 2: instance 1-Leuchte_1,not active ,7
IDE10288-ENG130203-Configuration of light collective diagnostic line 2: instance 1-Leuchte_10,not active ,7
IDE10288-ENG130204-Configuration of light collective diagnostic line 2: instance 1-Leuchte_11,not active ,7
IDE10288-ENG130205-Configuration of light collective diagnostic line 2: instance 1-Leuchte_12,not active ,7
IDE10288-ENG130206-Configuration of light collective diagnostic line 2: instance 1-Leuchte_13,not active ,7
IDE10288-ENG130207-Configuration of light collective diagnostic line 2: instance 1-Leuchte_14,not active ,7
IDE10288-ENG130208-Configuration of light collective diagnostic line 2: instance 1-Leuchte_15,not active ,7
IDE10288-ENG130209-Configuration of light collective diagnostic line 2: instance 1-Leuchte_16,not active ,7
IDE10288-ENG130210-Configuration of light collective diagnostic line 2: instance 1-Leuchte_17,not active ,7
IDE10288-ENG130211-Configuration of light collective diagnostic line 2: instance 1-Leuchte_18,not active ,7
IDE10288-ENG130212-Configuration of light collective diagnostic line 2: instance 1-Leuchte_19,not active ,7
IDE10288-ENG130195-Configuration of light collective diagnostic line 2: instance 1-Leuchte_2,not active ,7
IDE10288-ENG130213-Configuration of light collective diagnostic line 2: instance 1-Leuchte_20,not active ,7
IDE10288-ENG130214-Configuration of light collective diagnostic line 2: instance 1-Leuchte_21,not active ,7
IDE10288-ENG130215-Configuration of light collective diagnostic line 2: instance 1-Leuchte_22,not active ,7
IDE10288-ENG130216-Configuration of light collective diagnostic line 2: instance 1-Leuchte_23,not active ,7
IDE10288-ENG130217-Configuration of light collective diagnostic line 2: instance 1-Leuchte_24,not active ,7
IDE10288-ENG130218-Configuration of light collective diagnostic line 2: instance 1-Leuchte_25,not active ,7
IDE10288-ENG130219-Configuration of light collective diagnostic line 2: instance 1-Leuchte_26,not active ,7
IDE10288-ENG130220-Configuration of light collective diagnostic line 2: instance 1-Leuchte_27,not active ,7
IDE10288-ENG130221-Configuration of light collective diagnostic line 2: instance 1-Leuchte_28,not active ,7
IDE10288-ENG130222-Configuration of light collective diagnostic line 2: instance 1-Leuchte_29,not active ,7
IDE10288-ENG130196-Configuration of light collective diagnostic line 2: instance 1-Leuchte_3,not active ,7
IDE10288-ENG130223-Configuration of light collective diagnostic line 2: instance 1-Leuchte_30,not active ,7
IDE10288-ENG130224-Configuration of light collective diagnostic line 2: instance 1-Leuchte_31,not active ,7
IDE10288-ENG130225-Configuration of light collective diagnostic line 2: instance 1-Leuchte_32,not active ,7
IDE10288-ENG130226-Configuration of light collective diagnostic line 2: instance 1-Leuchte_33,not active ,7
IDE10288-ENG130227-Configuration of light collective diagnostic line 2: instance 1-Leuchte_34,not active ,7
IDE10288-ENG130197-Configuration of light collective diagnostic line 2: instance 1-Leuchte_4,not active ,7
IDE10288-ENG130198-Configuration of light collective diagnostic line 2: instance 1-Leuchte_5,not active ,7
IDE10288-ENG130199-Configuration of light collective diagnostic line 2: instance 1-Leuchte_6,not active ,7
IDE10288-ENG130200-Configuration of light collective diagnostic line 2: instance 1-Leuchte_7,not active ,7
IDE10288-ENG130201-Configuration of light collective diagnostic line 2: instance 1-Leuchte_8,not active ,7
IDE10288-ENG130202-Configuration of light collective diagnostic line 2: instance 1-Leuchte_9,not active ,7
IDE10288-ENG127072-Configuration of light collective diagnostic line 2: instance 1-Wiederstand,0_Ohm ,7
IDE11421-ENG116719-Leaving concept-Bedingungen zur Beendigung des Standlichtnachlaufs,not active ,12
IDE11421-ENG133381-Leaving concept-Bedingungen zur Parklichtbegrenzung,Energy management ,12
IDE11421-ENG133380-Leaving concept-Bedingungen zur Standlichtbegrenzung,Energy management ,12
IDE11421-ENG137034-Leaving concept-Faktor fuer Verfuegbarkeitstimer,Faktor fuer x5 Minuten ,12
IDE11421-ENG116720-Leaving concept-Standlicht-Nachlaufzeit,0 min,12
IDE11421-ENG137035-Leaving concept-Standlicht-Verfuegbarkeit,24 s,12
IDE11421-ENG126843-Leaving concept-ZV verriegeln bei Klemme 15 Ein,not active ,12
MAS01490-IDE07474-Energy management-Adapting for energy management,Energy management active ,1
MAS01490-MAS12921-Energy management-Predictive energy management,not active ,1
MAS08233-ENG126574-other-auspraegung_Bremsfluessigkeitsschalter,closed ,1
MAS08233-ENG126575-other-mute_mode_aktiv,not active ,1
MAS08233-ENG125011-other-pa_Funktion_2aus3,not installed ,1
ENG137028-ENG154590-Adaptation_theft_protection_2-Deaktivierung_DWA_ueber_MMI,not active ,2
ENG137028-ENG123016-Adaptation_theft_protection_2-Diebstahlschutz_mit_Anhaenger,not active ,2
ENG137028-ENG154722-Adaptation_theft_protection_2-RHF_Panikalarm,not active ,2
ENG116836-ENG115658-Innenbeleuchtung Abdimmen-x0,0 ms,22
ENG116836-ENG101574-Innenbeleuchtung Abdimmen-X1,200 ms,22
ENG116836-ENG115664-Innenbeleuchtung Abdimmen-x10,2000 ms,22
ENG116836-ENG99557-Innenbeleuchtung Abdimmen-X2,400 ms,22
ENG116836-ENG102140-Innenbeleuchtung Abdimmen-X3,600 ms,22
ENG116836-ENG102936-Innenbeleuchtung Abdimmen-X4,800 ms,22
ENG116836-ENG103548-Innenbeleuchtung Abdimmen-X5,1000 ms,22
ENG116836-ENG113992-Innenbeleuchtung Abdimmen-X6,1200 ms,22
ENG116836-ENG115661-Innenbeleuchtung Abdimmen-x7,1400 ms,22
ENG116836-ENG115662-Innenbeleuchtung Abdimmen-x8,1600 ms,22
ENG116836-ENG115663-Innenbeleuchtung Abdimmen-x9,1800 ms,22
ENG116836-ENG115659-Innenbeleuchtung Abdimmen-y0,100.0 %,22
ENG116836-ENG99777-Innenbeleuchtung Abdimmen-Y1,72.0 %,22
ENG116836-ENG115668-Innenbeleuchtung Abdimmen-y10,0.0 %,22
ENG116836-ENG100480-Innenbeleuchtung Abdimmen-Y2,48.0 %,22
ENG116836-ENG100773-Innenbeleuchtung Abdimmen-Y3,33.0 %,22
ENG116836-ENG100631-Innenbeleuchtung Abdimmen-Y4,18.0 %,22
ENG116836-ENG102174-Innenbeleuchtung Abdimmen-Y5,12.0 %,22
ENG116836-ENG113993-Innenbeleuchtung Abdimmen-Y6,8.0 %,22
ENG116836-ENG115665-Innenbeleuchtung Abdimmen-y7,6.0 %,22
ENG116836-ENG115666-Innenbeleuchtung Abdimmen-y8,4.0 %,22
ENG116836-ENG115667-Innenbeleuchtung Abdimmen-y9,2.0 %,22
ENG116831-ENG115658-Innenbeleuchtung Fotosensor-x0,0 ,22
ENG116831-ENG101574-Innenbeleuchtung Fotosensor-X1,50 ,22
ENG116831-ENG99557-Innenbeleuchtung Fotosensor-X2,100 ,22
ENG116831-ENG102140-Innenbeleuchtung Fotosensor-X3,200 ,22
ENG116831-ENG102936-Innenbeleuchtung Fotosensor-X4,253 ,22
ENG116831-ENG115659-Innenbeleuchtung Fotosensor-y0,0 lx,22
ENG116831-ENG99777-Innenbeleuchtung Fotosensor-Y1,50 lx,22
ENG116831-ENG100480-Innenbeleuchtung Fotosensor-Y2,100 lx,22
ENG116831-ENG100773-Innenbeleuchtung Fotosensor-Y3,200 lx,22
ENG116831-ENG100631-Innenbeleuchtung Fotosensor-Y4,500 lx,22
ENG116835-ENG115658-Innenbeleuchtung Hochdimmen-x0,0 ms,22
ENG116835-ENG101574-Innenbeleuchtung Hochdimmen-X1,200 ms,22
ENG116835-ENG115664-Innenbeleuchtung Hochdimmen-x10,2000 ms,22
ENG116835-ENG99557-Innenbeleuchtung Hochdimmen-X2,400 ms,22
ENG116835-ENG102140-Innenbeleuchtung Hochdimmen-X3,600 ms,22
ENG116835-ENG102936-Innenbeleuchtung Hochdimmen-X4,800 ms,22
ENG116835-ENG103548-Innenbeleuchtung Hochdimmen-X5,1000 ms,22
ENG116835-ENG113992-Innenbeleuchtung Hochdimmen-X6,1200 ms,22
ENG116835-ENG115661-Innenbeleuchtung Hochdimmen-x7,1400 ms,22
ENG116835-ENG115662-Innenbeleuchtung Hochdimmen-x8,1600 ms,22
ENG116835-ENG115663-Innenbeleuchtung Hochdimmen-x9,1800 ms,22
ENG116835-ENG115659-Innenbeleuchtung Hochdimmen-y0,0.0 %,22
ENG116835-ENG99777-Innenbeleuchtung Hochdimmen-Y1,1.0 %,22
ENG116835-ENG115668-Innenbeleuchtung Hochdimmen-y10,100.0 %,22
ENG116835-ENG100480-Innenbeleuchtung Hochdimmen-Y2,3.0 %,22
ENG116835-ENG100773-Innenbeleuchtung Hochdimmen-Y3,5.0 %,22
ENG116835-ENG100631-Innenbeleuchtung Hochdimmen-Y4,11.0 %,22
ENG116835-ENG102174-Innenbeleuchtung Hochdimmen-Y5,22.0 %,22
ENG116835-ENG113993-Innenbeleuchtung Hochdimmen-Y6,40.0 %,22
ENG116835-ENG115665-Innenbeleuchtung Hochdimmen-y7,80.0 %,22
ENG116835-ENG115666-Innenbeleuchtung Hochdimmen-y8,95.0 %,22
ENG116835-ENG115667-Innenbeleuchtung Hochdimmen-y9,100.0 %,22
ENG116975-ENG115658-Innenbeleuchtung KL 58xd log Bus-x0,0.0 %,12
ENG116975-ENG101574-Innenbeleuchtung KL 58xd log Bus-X1,6.0 %,12
ENG116975-ENG99557-Innenbeleuchtung KL 58xd log Bus-X2,16.0 %,12
ENG116975-ENG102140-Innenbeleuchtung KL 58xd log Bus-X3,30.0 %,12
ENG116975-ENG102936-Innenbeleuchtung KL 58xd log Bus-X4,60.0 %,12
ENG116975-ENG103548-Innenbeleuchtung KL 58xd log Bus-X5,100.0 %,12
ENG116975-ENG115659-Innenbeleuchtung KL 58xd log Bus-y0,10 ,12
ENG116975-ENG99777-Innenbeleuchtung KL 58xd log Bus-Y1,10 ,12
ENG116975-ENG100480-Innenbeleuchtung KL 58xd log Bus-Y2,100 ,12
ENG116975-ENG100773-Innenbeleuchtung KL 58xd log Bus-Y3,150 ,12
ENG116975-ENG100631-Innenbeleuchtung KL 58xd log Bus-Y4,220 ,12
ENG116975-ENG102174-Innenbeleuchtung KL 58xd log Bus-Y5,253 ,12
ENG116976-ENG115658-Innenbeleuchtung KL 58xd max-x0,0 lx,10
ENG116976-ENG101574-Innenbeleuchtung KL 58xd max-X1,8 lx,10
ENG116976-ENG99557-Innenbeleuchtung KL 58xd max-X2,200 lx,10
ENG116976-ENG102140-Innenbeleuchtung KL 58xd max-X3,300 lx,10
ENG116976-ENG102936-Innenbeleuchtung KL 58xd max-X4,500 lx,10
ENG116976-ENG115659-Innenbeleuchtung KL 58xd max-y0,16.0 ,10
ENG116976-ENG99777-Innenbeleuchtung KL 58xd max-Y1,16.0 ,10
ENG116976-ENG100480-Innenbeleuchtung KL 58xd max-Y2,100.0 ,10
ENG116976-ENG100773-Innenbeleuchtung KL 58xd max-Y3,100.0 ,10
ENG116976-ENG100631-Innenbeleuchtung KL 58xd max-Y4,100.0 ,10
ENG116980-ENG115658-Innenbeleuchtung KL 58xd min-x0,0 lx,10
ENG116980-ENG101574-Innenbeleuchtung KL 58xd min-X1,8 lx,10
ENG116980-ENG99557-Innenbeleuchtung KL 58xd min-X2,220 lx,10
ENG116980-ENG102140-Innenbeleuchtung KL 58xd min-X3,300 lx,10
ENG116980-ENG102936-Innenbeleuchtung KL 58xd min-X4,500 lx,10
ENG116980-ENG115659-Innenbeleuchtung KL 58xd min-y0,6.0 ,10
ENG116980-ENG99777-Innenbeleuchtung KL 58xd min-Y1,6.0 ,10
ENG116980-ENG100480-Innenbeleuchtung KL 58xd min-Y2,100.0 ,10
ENG116980-ENG100773-Innenbeleuchtung KL 58xd min-Y3,100.0 ,10
ENG116980-ENG100631-Innenbeleuchtung KL 58xd min-Y4,100.0 ,10
ENG116979-ENG115658-Innenbeleuchtung KL 58xd PWM-x0,0 ,12
ENG116979-ENG101574-Innenbeleuchtung KL 58xd PWM-X1,10 ,12
ENG116979-ENG99557-Innenbeleuchtung KL 58xd PWM-X2,50 ,12
ENG116979-ENG102140-Innenbeleuchtung KL 58xd PWM-X3,100 ,12
ENG116979-ENG102936-Innenbeleuchtung KL 58xd PWM-X4,220 ,12
ENG116979-ENG103548-Innenbeleuchtung KL 58xd PWM-X5,253 ,12
ENG116979-ENG115659-Innenbeleuchtung KL 58xd PWM-y0,100.0 %,12
ENG116979-ENG99777-Innenbeleuchtung KL 58xd PWM-Y1,100.0 %,12
ENG116979-ENG100480-Innenbeleuchtung KL 58xd PWM-Y2,100.0 %,12
ENG116979-ENG100773-Innenbeleuchtung KL 58xd PWM-Y3,100.0 %,12
ENG116979-ENG100631-Innenbeleuchtung KL 58xd PWM-Y4,100.0 %,12
ENG116979-ENG102174-Innenbeleuchtung KL 58xd PWM-Y5,100.0 %,12
ENG116972-ENG115658-Innenbeleuchtung KL 58xs max-x0,0 lx,8
ENG116972-ENG101574-Innenbeleuchtung KL 58xs max-X1,8 lx,8
ENG116972-ENG99557-Innenbeleuchtung KL 58xs max-X2,50 lx,8
ENG116972-ENG102140-Innenbeleuchtung KL 58xs max-X3,500 lx,8
ENG116972-ENG115659-Innenbeleuchtung KL 58xs max-y0,100.0 ,8
ENG116972-ENG99777-Innenbeleuchtung KL 58xs max-Y1,100.0 ,8
ENG116972-ENG100480-Innenbeleuchtung KL 58xs max-Y2,100.0 ,8
ENG116972-ENG100773-Innenbeleuchtung KL 58xs max-Y3,100.0 ,8
ENG126561-ENG115658-Innenbeleuchtung KL 58xs min-x0,0 lx,8
ENG126561-ENG101574-Innenbeleuchtung KL 58xs min-X1,8 lx,8
ENG126561-ENG99557-Innenbeleuchtung KL 58xs min-X2,50 lx,8
ENG126561-ENG102140-Innenbeleuchtung KL 58xs min-X3,500 lx,8
ENG126561-ENG115659-Innenbeleuchtung KL 58xs min-y0,6.0 ,8
ENG126561-ENG99777-Innenbeleuchtung KL 58xs min-Y1,6.0 ,8
ENG126561-ENG100480-Innenbeleuchtung KL 58xs min-Y2,100.0 ,8
ENG126561-ENG100773-Innenbeleuchtung KL 58xs min-Y3,100.0 ,8
ENG116977-ENG115658-Innenbeleuchtung KL 58xs PWM-x0,0.0 %,6
ENG116977-ENG101574-Innenbeleuchtung KL 58xs PWM-X1,50.0 %,6
ENG116977-ENG99557-Innenbeleuchtung KL 58xs PWM-X2,100.0 %,6
ENG116977-ENG115659-Innenbeleuchtung KL 58xs PWM-y0,0.0 %,6
ENG116977-ENG99777-Innenbeleuchtung KL 58xs PWM-Y1,50.0 %,6
ENG116977-ENG100480-Innenbeleuchtung KL 58xs PWM-Y2,100.0 %,6
ENG116974-ENG115658-Innenbeleuchtung KL 58xt max-x0,0 lx,8
ENG116974-ENG101574-Innenbeleuchtung KL 58xt max-X1,8 lx,8
ENG116974-ENG99557-Innenbeleuchtung KL 58xt max-X2,50 lx,8
ENG116974-ENG102140-Innenbeleuchtung KL 58xt max-X3,500 lx,8
ENG116974-ENG115659-Innenbeleuchtung KL 58xt max-y0,100.0 ,8
ENG116974-ENG99777-Innenbeleuchtung KL 58xt max-Y1,100.0 ,8
ENG116974-ENG100480-Innenbeleuchtung KL 58xt max-Y2,100.0 ,8
ENG116974-ENG100773-Innenbeleuchtung KL 58xt max-Y3,100.0 ,8
ENG116973-ENG115658-Innenbeleuchtung KL 58xt min-x0,0 lx,8
ENG116973-ENG101574-Innenbeleuchtung KL 58xt min-X1,8 lx,8
ENG116973-ENG99557-Innenbeleuchtung KL 58xt min-X2,50 lx,8
ENG116973-ENG102140-Innenbeleuchtung KL 58xt min-X3,500 lx,8
ENG116973-ENG115659-Innenbeleuchtung KL 58xt min-y0,6.0 ,8
ENG116973-ENG99777-Innenbeleuchtung KL 58xt min-Y1,6.0 ,8
ENG116973-ENG100480-Innenbeleuchtung KL 58xt min-Y2,100.0 ,8
ENG116973-ENG100773-Innenbeleuchtung KL 58xt min-Y3,100.0 ,8
ENG116978-ENG115658-Innenbeleuchtung KL 58xt PWM-x0,0.0 %,6
ENG116978-ENG101574-Innenbeleuchtung KL 58xt PWM-X1,50.0 %,6
ENG116978-ENG99557-Innenbeleuchtung KL 58xt PWM-X2,100.0 %,6
ENG116978-ENG115659-Innenbeleuchtung KL 58xt PWM-y0,0.0 %,6
ENG116978-ENG99777-Innenbeleuchtung KL 58xt PWM-Y1,50.0 %,6
ENG116978-ENG100480-Innenbeleuchtung KL 58xt PWM-Y2,100.0 %,6
ENG116834-ENG115633-Innenbeleuchtung Tasterdimmung-Tasterdimmung x0,0 ms,10
ENG116834-ENG115634-Innenbeleuchtung Tasterdimmung-Tasterdimmung x1,2000 ms,10
ENG116834-ENG115635-Innenbeleuchtung Tasterdimmung-Tasterdimmung x2,3000 ms,10
ENG116834-ENG115636-Innenbeleuchtung Tasterdimmung-Tasterdimmung x3,4000 ms,10
ENG116834-ENG115637-Innenbeleuchtung Tasterdimmung-Tasterdimmung x4,5100 ms,10
ENG116834-ENG115638-Innenbeleuchtung Tasterdimmung-Tasterdimmung y0,1.0 %,10
ENG116834-ENG115639-Innenbeleuchtung Tasterdimmung-Tasterdimmung y1,5.0 ,10
ENG116834-ENG115640-Innenbeleuchtung Tasterdimmung-Tasterdimmung y2,15.0 ,10
ENG116834-ENG115641-Innenbeleuchtung Tasterdimmung-Tasterdimmung y3,40.0 ,10
ENG116834-ENG115642-Innenbeleuchtung Tasterdimmung-Tasterdimmung y4,100.0 ,10
ENG124861-ENG115018-Leuchte 0 BLK VL B35-Dimming_AB_0,100 ,16
ENG124861-ENG115022-Leuchte 0 BLK VL B35-Dimming_CD_0,0 ,16
ENG124861-ENG115023-Leuchte 0 BLK VL B35-Dimming_Direction_CD_0,maximize ,16
ENG124861-ENG115027-Leuchte 0 BLK VL B35-Dimming_Direction_EF_0,maximize ,16
ENG124861-ENG115031-Leuchte 0 BLK VL B35-Dimming_Direction_GH_0,maximize ,16
ENG124861-ENG115026-Leuchte 0 BLK VL B35-Dimming_EF_0,0 ,16
ENG124861-ENG115030-Leuchte 0 BLK VL B35-Dimming_GH_0,0 ,16
ENG124861-ENG126576-Leuchte 0 BLK VL B35-Fehlerort_mittleres_Byte_DTC-DFCC_0,14 ,16
ENG124861-ENG115751-Leuchte 0 BLK VL B35-Lampendefektbit_Position_0,34 ,16
ENG124861-ENG115019-Leuchte 0 BLK VL B35-Light_Control_HD_AB_0,Always ,16
ENG124861-ENG115016-Leuchte 0 BLK VL B35-Light_Function_A_0,Blinken links Hellphase ,16
ENG124861-ENG115017-Leuchte 0 BLK VL B35-Light_Function_B_0,not active ,16
ENG124861-ENG115020-Leuchte 0 BLK VL B35-Light_Function_C_0,not active ,16
ENG124861-ENG115021-Leuchte 0 BLK VL B35-Light_Function_D_0,not active ,16
ENG124861-ENG115024-Leuchte 0 BLK VL B35-Light_Function_E_0,not active ,16
ENG124861-ENG115025-Leuchte 0 BLK VL B35-Light_Function_F_0,not active ,16
ENG124861-ENG115028-Leuchte 0 BLK VL B35-Light_Function_G_0,not active ,16
ENG124861-ENG115029-Leuchte 0 BLK VL B35-Light_Function_H_0,not active ,16
ENG124861-ENG115013-Leuchte 0 BLK VL B35-Type_Of_Load_0,Blinkleuchten ,16
ENG124871-ENG114999-Leuchte10SHUTTER LRB45-Dimming_AB_10,0 ,16
ENG124871-ENG115003-Leuchte10SHUTTER LRB45-Dimming_CD_10,0 ,16
ENG124871-ENG115004-Leuchte10SHUTTER LRB45-Dimming_Direction_CD_10,maximize ,16
ENG124871-ENG115008-Leuchte10SHUTTER LRB45-Dimming_Direction_EF_10,maximize ,16
ENG124871-ENG115012-Leuchte10SHUTTER LRB45-Dimming_Direction_GH_10,maximize ,16
ENG124871-ENG115007-Leuchte10SHUTTER LRB45-Dimming_EF_10,0 ,16
ENG124871-ENG115011-Leuchte10SHUTTER LRB45-Dimming_GH_10,0 ,16
ENG124871-ENG126585-Leuchte10SHUTTER LRB45-Fehlerort_mittleres_Byte_DTC-DFCC_10,00 ,16
ENG124871-ENG114996-Leuchte10SHUTTER LRB45-Lampendefektbit_Position_10,00 ,16
ENG124871-ENG115000-Leuchte10SHUTTER LRB45-Light_Control_HD_AB_10,Always ,16
ENG124871-ENG114997-Leuchte10SHUTTER LRB45-Light_Function_A_10,not active ,16
ENG124871-ENG114998-Leuchte10SHUTTER LRB45-Light_Function_B_10,not active ,16
ENG124871-ENG115001-Leuchte10SHUTTER LRB45-Light_Function_C_10,not active ,16
ENG124871-ENG115002-Leuchte10SHUTTER LRB45-Light_Function_D_10,not active ,16
ENG124871-ENG115005-Leuchte10SHUTTER LRB45-Light_Function_E_10,not active ,16
ENG124871-ENG115006-Leuchte10SHUTTER LRB45-Light_Function_F_10,not active ,16
ENG124871-ENG115009-Leuchte10SHUTTER LRB45-Light_Function_G_10,not active ,16
ENG124871-ENG115010-Leuchte10SHUTTER LRB45-Light_Function_H_10,not active ,16
ENG124871-ENG114995-Leuchte10SHUTTER LRB45-Type_Of_Load_10,not active ,16
ENG124872-ENG115193-Leuchte11WARNBLK TASTERC54-Dimming_AB_11,100 ,16
ENG124872-ENG115197-Leuchte11WARNBLK TASTERC54-Dimming_CD_11,0 ,16
ENG124872-ENG115198-Leuchte11WARNBLK TASTERC54-Dimming_Direction_CD_11,maximize ,16
ENG124872-ENG115202-Leuchte11WARNBLK TASTERC54-Dimming_Direction_EF_11,maximize ,16
ENG124872-ENG115206-Leuchte11WARNBLK TASTERC54-Dimming_Direction_GH_11,maximize ,16
ENG124872-ENG115201-Leuchte11WARNBLK TASTERC54-Dimming_EF_11,0 ,16
ENG124872-ENG115205-Leuchte11WARNBLK TASTERC54-Dimming_GH_11,0 ,16
ENG124872-ENG126586-Leuchte11WARNBLK TASTERC54-Fehlerort_mittleres_Byte_DTC-DFCC_11,00 ,16
ENG124872-ENG115735-Leuchte11WARNBLK TASTERC54-Lampendefektbit_Position_11,00 ,16
ENG124872-ENG115194-Leuchte11WARNBLK TASTERC54-Light_Control_HD_AB_11,Always ,16
ENG124872-ENG115191-Leuchte11WARNBLK TASTERC54-Light_Function_A_11,Warnblinktaster ,16
ENG124872-ENG115192-Leuchte11WARNBLK TASTERC54-Light_Function_B_11,not active ,16
ENG124872-ENG115195-Leuchte11WARNBLK TASTERC54-Light_Function_C_11,not active ,16
ENG124872-ENG115196-Leuchte11WARNBLK TASTERC54-Light_Function_D_11,not active ,16
ENG124872-ENG115199-Leuchte11WARNBLK TASTERC54-Light_Function_E_11,not active ,16
ENG124872-ENG115200-Leuchte11WARNBLK TASTERC54-Light_Function_F_11,not active ,16
ENG124872-ENG115203-Leuchte11WARNBLK TASTERC54-Light_Function_G_11,not active ,16
ENG124872-ENG115204-Leuchte11WARNBLK TASTERC54-Light_Function_H_11,not active ,16
ENG124872-ENG115188-Leuchte11WARNBLK TASTERC54-Type_Of_Load_11,LED Kleinleistung ohne Open Load Diagnose ,16
ENG124873-ENG115212-Leuchte12NL LB40-Dimming_AB_12,0 ,16
ENG124873-ENG115216-Leuchte12NL LB40-Dimming_CD_12,0 ,16
ENG124873-ENG115217-Leuchte12NL LB40-Dimming_Direction_CD_12,maximize ,16
ENG124873-ENG115221-Leuchte12NL LB40-Dimming_Direction_EF_12,maximize ,16
ENG124873-ENG115225-Leuchte12NL LB40-Dimming_Direction_GH_12,maximize ,16
ENG124873-ENG115220-Leuchte12NL LB40-Dimming_EF_12,0 ,16
ENG124873-ENG115224-Leuchte12NL LB40-Dimming_GH_12,0 ,16
ENG124873-ENG126587-Leuchte12NL LB40-Fehlerort_mittleres_Byte_DTC-DFCC_12,00 ,16
ENG124873-ENG115750-Leuchte12NL LB40-Lampendefektbit_Position_12,00 ,16
ENG124873-ENG115213-Leuchte12NL LB40-Light_Control_HD_AB_12,Always ,16
ENG124873-ENG115210-Leuchte12NL LB40-Light_Function_A_12,not active ,16
ENG124873-ENG115211-Leuchte12NL LB40-Light_Function_B_12,not active ,16
ENG124873-ENG115214-Leuchte12NL LB40-Light_Function_C_12,not active ,16
ENG124873-ENG115215-Leuchte12NL LB40-Light_Function_D_12,not active ,16
ENG124873-ENG115218-Leuchte12NL LB40-Light_Function_E_12,not active ,16
ENG124873-ENG115219-Leuchte12NL LB40-Light_Function_F_12,not active ,16
ENG124873-ENG115222-Leuchte12NL LB40-Light_Function_G_12,not active ,16
ENG124873-ENG115223-Leuchte12NL LB40-Light_Function_H_12,not active ,16
ENG124873-ENG115207-Leuchte12NL LB40-Type_Of_Load_12,not active ,16
ENG124874-ENG114958-Leuchte13NL RB3-Dimming_AB_13,0 ,16
ENG124874-ENG114962-Leuchte13NL RB3-Dimming_CD_13,0 ,16
ENG124874-ENG114963-Leuchte13NL RB3-Dimming_Direction_CD_13,maximize ,16
ENG124874-ENG114967-Leuchte13NL RB3-Dimming_Direction_EF_13,maximize ,16
ENG124874-ENG114971-Leuchte13NL RB3-Dimming_Direction_GH_13,maximize ,16
ENG124874-ENG114966-Leuchte13NL RB3-Dimming_EF_13,0 ,16
ENG124874-ENG114970-Leuchte13NL RB3-Dimming_GH_13,0 ,16
ENG124874-ENG126588-Leuchte13NL RB3-Fehlerort_mittleres_Byte_DTC-DFCC_13,00 ,16
ENG124874-ENG114955-Leuchte13NL RB3-Lampendefektbit_Position_13,00 ,16
ENG124874-ENG114959-Leuchte13NL RB3-Light_Control_HD_AB_13,Always ,16
ENG124874-ENG114956-Leuchte13NL RB3-Light_Function_A_13,not active ,16
ENG124874-ENG114957-Leuchte13NL RB3-Light_Function_B_13,not active ,16
ENG124874-ENG114960-Leuchte13NL RB3-Light_Function_C_13,not active ,16
ENG124874-ENG114961-Leuchte13NL RB3-Light_Function_D_13,not active ,16
ENG124874-ENG114964-Leuchte13NL RB3-Light_Function_E_13,not active ,16
ENG124874-ENG114965-Leuchte13NL RB3-Light_Function_F_13,not active ,16
ENG124874-ENG114968-Leuchte13NL RB3-Light_Function_G_13,not active ,16
ENG124874-ENG114969-Leuchte13NL RB3-Light_Function_H_13,not active ,16
ENG124874-ENG114954-Leuchte13NL RB3-Type_Of_Load_13,not active ,16
ENG124876-ENG115252-Leuchte15 SAFE LED C55-Dimming_AB_15,100 ,16
ENG124876-ENG115256-Leuchte15 SAFE LED C55-Dimming_CD_15,0 ,16
ENG124876-ENG115257-Leuchte15 SAFE LED C55-Dimming_Direction_CD_15,maximize ,16
ENG124876-ENG115261-Leuchte15 SAFE LED C55-Dimming_Direction_EF_15,maximize ,16
ENG124876-ENG115265-Leuchte15 SAFE LED C55-Dimming_Direction_GH_15,maximize ,16
ENG124876-ENG115260-Leuchte15 SAFE LED C55-Dimming_EF_15,0 ,16
ENG124876-ENG115264-Leuchte15 SAFE LED C55-Dimming_GH_15,0 ,16
ENG124876-ENG126590-Leuchte15 SAFE LED C55-Fehlerort_mittleres_Byte_DTC-DFCC_15,00 ,16
ENG124876-ENG115800-Leuchte15 SAFE LED C55-Lampendefektbit_Position_15,00 ,16
ENG124876-ENG115253-Leuchte15 SAFE LED C55-Light_Control_HD_AB_15,Always ,16
ENG124876-ENG115250-Leuchte15 SAFE LED C55-Light_Function_A_15,SafeLED ,16
ENG124876-ENG115251-Leuchte15 SAFE LED C55-Light_Function_B_15,not active ,16
ENG124876-ENG115254-Leuchte15 SAFE LED C55-Light_Function_C_15,not active ,16
ENG124876-ENG115255-Leuchte15 SAFE LED C55-Light_Function_D_15,not active ,16
ENG124876-ENG115258-Leuchte15 SAFE LED C55-Light_Function_E_15,not active ,16
ENG124876-ENG115259-Leuchte15 SAFE LED C55-Light_Function_F_15,not active ,16
ENG124876-ENG115262-Leuchte15 SAFE LED C55-Light_Function_G_15,not active ,16
ENG124876-ENG115263-Leuchte15 SAFE LED C55-Light_Function_H_15,not active ,16
ENG124876-ENG115247-Leuchte15 SAFE LED C55-Type_Of_Load_15,allgemeineLEDmitOpenLoadDiagnose ,16
ENG124877-ENG115271-Leuchte16BLK SLC11-Dimming_AB_16,100 ,16
ENG124877-ENG115275-Leuchte16BLK SLC11-Dimming_CD_16,0 ,16
ENG124877-ENG115276-Leuchte16BLK SLC11-Dimming_Direction_CD_16,maximize ,16
ENG124877-ENG115280-Leuchte16BLK SLC11-Dimming_Direction_EF_16,maximize ,16
ENG124877-ENG115284-Leuchte16BLK SLC11-Dimming_Direction_GH_16,maximize ,16
ENG124877-ENG115279-Leuchte16BLK SLC11-Dimming_EF_16,0 ,16
ENG124877-ENG115283-Leuchte16BLK SLC11-Dimming_GH_16,0 ,16
ENG124877-ENG126591-Leuchte16BLK SLC11-Fehlerort_mittleres_Byte_DTC-DFCC_16,00 ,16
ENG124877-ENG115649-Leuchte16BLK SLC11-Lampendefektbit_Position_16,00 ,16
ENG124877-ENG115272-Leuchte16BLK SLC11-Light_Control_HD_AB_16,Always ,16
ENG124877-ENG115269-Leuchte16BLK SLC11-Light_Function_A_16,Blinken links Hellphase ,16
ENG124877-ENG115270-Leuchte16BLK SLC11-Light_Function_B_16,not active ,16
ENG124877-ENG115273-Leuchte16BLK SLC11-Light_Function_C_16,not active ,16
ENG124877-ENG115274-Leuchte16BLK SLC11-Light_Function_D_16,not active ,16
ENG124877-ENG115277-Leuchte16BLK SLC11-Light_Function_E_16,not active ,16
ENG124877-ENG115278-Leuchte16BLK SLC11-Light_Function_F_16,not active ,16
ENG124877-ENG115281-Leuchte16BLK SLC11-Light_Function_G_16,not active ,16
ENG124877-ENG115282-Leuchte16BLK SLC11-Light_Function_H_16,not active ,16
ENG124877-ENG115266-Leuchte16BLK SLC11-Type_Of_Load_16,LED Blinkleuchten ,16
ENG124878-ENG115290-Leuchte17 BLK SR A72-Dimming_AB_17,100 ,16
ENG124878-ENG115294-Leuchte17 BLK SR A72-Dimming_CD_17,0 ,16
ENG124878-ENG115295-Leuchte17 BLK SR A72-Dimming_Direction_CD_17,maximize ,16
ENG124878-ENG115299-Leuchte17 BLK SR A72-Dimming_Direction_EF_17,maximize ,16
ENG124878-ENG115303-Leuchte17 BLK SR A72-Dimming_Direction_GH_17,maximize ,16
ENG124878-ENG115298-Leuchte17 BLK SR A72-Dimming_EF_17,0 ,16
ENG124878-ENG115302-Leuchte17 BLK SR A72-Dimming_GH_17,0 ,16
ENG124878-ENG126592-Leuchte17 BLK SR A72-Fehlerort_mittleres_Byte_DTC-DFCC_17,00 ,16
ENG124878-ENG115799-Leuchte17 BLK SR A72-Lampendefektbit_Position_17,00 ,16
ENG124878-ENG115291-Leuchte17 BLK SR A72-Light_Control_HD_AB_17,Always ,16
ENG124878-ENG115288-Leuchte17 BLK SR A72-Light_Function_A_17,Blinken rechts Hellphase ,16
ENG124878-ENG115289-Leuchte17 BLK SR A72-Light_Function_B_17,not active ,16
ENG124878-ENG115292-Leuchte17 BLK SR A72-Light_Function_C_17,not active ,16
ENG124878-ENG115293-Leuchte17 BLK SR A72-Light_Function_D_17,not active ,16
ENG124878-ENG115296-Leuchte17 BLK SR A72-Light_Function_E_17,not active ,16
ENG124878-ENG115297-Leuchte17 BLK SR A72-Light_Function_F_17,not active ,16
ENG124878-ENG115300-Leuchte17 BLK SR A72-Light_Function_G_17,not active ,16
ENG124878-ENG115301-Leuchte17 BLK SR A72-Light_Function_H_17,not active ,16
ENG124878-ENG115285-Leuchte17 BLK SR A72-Type_Of_Load_17,LED Blinkleuchten ,16
ENG124879-ENG115309-Leuchte18BLK HLA71-Dimming_AB_18,100 ,16
ENG124879-ENG115313-Leuchte18BLK HLA71-Dimming_CD_18,0 ,16
ENG124879-ENG115314-Leuchte18BLK HLA71-Dimming_Direction_CD_18,maximize ,16
ENG124879-ENG115318-Leuchte18BLK HLA71-Dimming_Direction_EF_18,maximize ,16
ENG124879-ENG115322-Leuchte18BLK HLA71-Dimming_Direction_GH_18,maximize ,16
ENG124879-ENG115317-Leuchte18BLK HLA71-Dimming_EF_18,0 ,16
ENG124879-ENG115321-Leuchte18BLK HLA71-Dimming_GH_18,0 ,16
ENG124879-ENG126593-Leuchte18BLK HLA71-Fehlerort_mittleres_Byte_DTC-DFCC_18,16 ,16
ENG124879-ENG115651-Leuchte18BLK HLA71-Lampendefektbit_Position_18,08 ,16
ENG124879-ENG115310-Leuchte18BLK HLA71-Light_Control_HD_AB_18,Always ,16
ENG124879-ENG115307-Leuchte18BLK HLA71-Light_Function_A_18,Blinken links Hellphase ,16
ENG124879-ENG115308-Leuchte18BLK HLA71-Light_Function_B_18,not active ,16
ENG124879-ENG115311-Leuchte18BLK HLA71-Light_Function_C_18,not active ,16
ENG124879-ENG115312-Leuchte18BLK HLA71-Light_Function_D_18,not active ,16
ENG124879-ENG115315-Leuchte18BLK HLA71-Light_Function_E_18,not active ,16
ENG124879-ENG115316-Leuchte18BLK HLA71-Light_Function_F_18,not active ,16
ENG124879-ENG115319-Leuchte18BLK HLA71-Light_Function_G_18,not active ,16
ENG124879-ENG115320-Leuchte18BLK HLA71-Light_Function_H_18,not active ,16
ENG124879-ENG115304-Leuchte18BLK HLA71-Type_Of_Load_18,Blinkleuchten ,16
ENG137051-ENG115328-Leuchte19BLK HRC10-Dimming_AB_19,100 ,16
ENG137051-ENG115332-Leuchte19BLK HRC10-Dimming_CD_19,0 ,16
ENG137051-ENG115333-Leuchte19BLK HRC10-Dimming_Direction_CD_19,maximize ,16
ENG137051-ENG115337-Leuchte19BLK HRC10-Dimming_Direction_EF_19,maximize ,16
ENG137051-ENG115341-Leuchte19BLK HRC10-Dimming_Direction_GH_19,maximize ,16
ENG137051-ENG115336-Leuchte19BLK HRC10-Dimming_EF_19,0 ,16
ENG137051-ENG115340-Leuchte19BLK HRC10-Dimming_GH_19,0 ,16
ENG137051-ENG126594-Leuchte19BLK HRC10-Fehlerort_mittleres_Byte_DTC-DFCC_19,18 ,16
ENG137051-ENG115785-Leuchte19BLK HRC10-Lampendefektbit_Position_19,18 ,16
ENG137051-ENG115329-Leuchte19BLK HRC10-Light_Control_HD_AB_19,Always ,16
ENG137051-ENG115326-Leuchte19BLK HRC10-Light_Function_A_19,Blinken rechts Hellphase ,16
ENG137051-ENG115327-Leuchte19BLK HRC10-Light_Function_B_19,not active ,16
ENG137051-ENG115330-Leuchte19BLK HRC10-Light_Function_C_19,not active ,16
ENG137051-ENG115331-Leuchte19BLK HRC10-Light_Function_D_19,not active ,16
ENG137051-ENG115334-Leuchte19BLK HRC10-Light_Function_E_19,not active ,16
ENG137051-ENG115335-Leuchte19BLK HRC10-Light_Function_F_19,not active ,16
ENG137051-ENG115338-Leuchte19BLK HRC10-Light_Function_G_19,not active ,16
ENG137051-ENG115339-Leuchte19BLK HRC10-Light_Function_H_19,not active ,16
ENG137051-ENG115323-Leuchte19BLK HRC10-Type_Of_Load_19,Blinkleuchten ,16
ENG124862-ENG115037-Leuchte1BLK VRB23-Dimming_AB_1,100 ,16
ENG124862-ENG115041-Leuchte1BLK VRB23-Dimming_CD_1,0 ,16
ENG124862-ENG115042-Leuchte1BLK VRB23-Dimming_Direction_CD_1,maximize ,16
ENG124862-ENG115046-Leuchte1BLK VRB23-Dimming_Direction_EF_1,maximize ,16
ENG124862-ENG115050-Leuchte1BLK VRB23-Dimming_Direction_GH_1,maximize ,16
ENG124862-ENG115045-Leuchte1BLK VRB23-Dimming_EF_1,0 ,16
ENG124862-ENG115049-Leuchte1BLK VRB23-Dimming_GH_1,0 ,16
ENG124862-ENG126571-Leuchte1BLK VRB23-Fehlerort_mittleres_Byte_DTC-DFCC_1,15 ,16
ENG124862-ENG115732-Leuchte1BLK VRB23-Lampendefektbit_Position_1,3E ,16
ENG124862-ENG115038-Leuchte1BLK VRB23-Light_Control_HD_AB_1,Always ,16
ENG124862-ENG115035-Leuchte1BLK VRB23-Light_Function_A_1,Blinken rechts Hellphase ,16
ENG124862-ENG115036-Leuchte1BLK VRB23-Light_Function_B_1,not active ,16
ENG124862-ENG115039-Leuchte1BLK VRB23-Light_Function_C_1,not active ,16
ENG124862-ENG115040-Leuchte1BLK VRB23-Light_Function_D_1,not active ,16
ENG124862-ENG115043-Leuchte1BLK VRB23-Light_Function_E_1,not active ,16
ENG124862-ENG115044-Leuchte1BLK VRB23-Light_Function_F_1,not active ,16
ENG124862-ENG115047-Leuchte1BLK VRB23-Light_Function_G_1,not active ,16
ENG124862-ENG115048-Leuchte1BLK VRB23-Light_Function_H_1,not active ,16
ENG124862-ENG115032-Leuchte1BLK VRB23-Type_Of_Load_1,Blinkleuchten ,16
ENG124881-ENG115347-Leuchte20BR LA70-Dimming_AB_20,100 ,16
ENG124881-ENG115351-Leuchte20BR LA70-Dimming_CD_20,0 ,16
ENG124881-ENG115352-Leuchte20BR LA70-Dimming_Direction_CD_20,maximize ,16
ENG124881-ENG115356-Leuchte20BR LA70-Dimming_Direction_EF_20,maximize ,16
ENG124881-ENG115360-Leuchte20BR LA70-Dimming_Direction_GH_20,maximize ,16
ENG124881-ENG115355-Leuchte20BR LA70-Dimming_EF_20,0 ,16
ENG124881-ENG115359-Leuchte20BR LA70-Dimming_GH_20,0 ,16
ENG124881-ENG126595-Leuchte20BR LA70-Fehlerort_mittleres_Byte_DTC-DFCC_20,2B ,16
ENG124881-ENG115629-Leuchte20BR LA70-Lampendefektbit_Position_20,09 ,16
ENG124881-ENG115348-Leuchte20BR LA70-Light_Control_HD_AB_20,Always ,16
ENG124881-ENG115345-Leuchte20BR LA70-Light_Function_A_20,Brake light ,16
ENG124881-ENG115346-Leuchte20BR LA70-Light_Function_B_20,not active ,16
ENG124881-ENG115349-Leuchte20BR LA70-Light_Function_C_20,not active ,16
ENG124881-ENG115350-Leuchte20BR LA70-Light_Function_D_20,not active ,16
ENG124881-ENG115353-Leuchte20BR LA70-Light_Function_E_20,not active ,16
ENG124881-ENG115354-Leuchte20BR LA70-Light_Function_F_20,not active ,16
ENG124881-ENG115357-Leuchte20BR LA70-Light_Function_G_20,not active ,16
ENG124881-ENG115358-Leuchte20BR LA70-Light_Function_H_20,not active ,16
ENG124881-ENG115342-Leuchte20BR LA70-Type_Of_Load_20,Bremsleuchten ,16
ENG116957-ENG115366-Leuchte21BR RC8-Dimming_AB_21,100 ,16
ENG116957-ENG115370-Leuchte21BR RC8-Dimming_CD_21,0 ,16
ENG116957-ENG115371-Leuchte21BR RC8-Dimming_Direction_CD_21,maximize ,16
ENG116957-ENG115375-Leuchte21BR RC8-Dimming_Direction_EF_21,maximize ,16
ENG116957-ENG115379-Leuchte21BR RC8-Dimming_Direction_GH_21,maximize ,16
ENG116957-ENG115374-Leuchte21BR RC8-Dimming_EF_21,0 ,16
ENG116957-ENG115378-Leuchte21BR RC8-Dimming_GH_21,0 ,16
ENG116957-ENG126596-Leuchte21BR RC8-Fehlerort_mittleres_Byte_DTC-DFCC_21,2D ,16
ENG116957-ENG115811-Leuchte21BR RC8-Lampendefektbit_Position_21,19 ,16
ENG116957-ENG115367-Leuchte21BR RC8-Light_Control_HD_AB_21,Always ,16
ENG116957-ENG115364-Leuchte21BR RC8-Light_Function_A_21,Brake light ,16
ENG116957-ENG115365-Leuchte21BR RC8-Light_Function_B_21,not active ,16
ENG116957-ENG115368-Leuchte21BR RC8-Light_Function_C_21,not active ,16
ENG116957-ENG115369-Leuchte21BR RC8-Light_Function_D_21,not active ,16
ENG116957-ENG115372-Leuchte21BR RC8-Light_Function_E_21,not active ,16
ENG116957-ENG115373-Leuchte21BR RC8-Light_Function_F_21,not active ,16
ENG116957-ENG115376-Leuchte21BR RC8-Light_Function_G_21,not active ,16
ENG116957-ENG115377-Leuchte21BR RC8-Light_Function_H_21,not active ,16
ENG116957-ENG115361-Leuchte21BR RC8-Type_Of_Load_21,Bremsleuchten ,16
ENG124882-ENG115385-Leuchte22BR MC9-Dimming_AB_22,100 ,16
ENG124882-ENG115389-Leuchte22BR MC9-Dimming_CD_22,0 ,16
ENG124882-ENG115390-Leuchte22BR MC9-Dimming_Direction_CD_22,maximize ,16
ENG124882-ENG115394-Leuchte22BR MC9-Dimming_Direction_EF_22,maximize ,16
ENG124882-ENG115398-Leuchte22BR MC9-Dimming_Direction_GH_22,maximize ,16
ENG124882-ENG115393-Leuchte22BR MC9-Dimming_EF_22,0 ,16
ENG124882-ENG115397-Leuchte22BR MC9-Dimming_GH_22,0 ,16
ENG124882-ENG126597-Leuchte22BR MC9-Fehlerort_mittleres_Byte_DTC-DFCC_22,2C ,16
ENG124882-ENG115780-Leuchte22BR MC9-Lampendefektbit_Position_22,29 ,16
ENG124882-ENG115386-Leuchte22BR MC9-Light_Control_HD_AB_22,Always ,16
ENG124882-ENG115383-Leuchte22BR MC9-Light_Function_A_22,Brake light ,16
ENG124882-ENG115384-Leuchte22BR MC9-Light_Function_B_22,not active ,16
ENG124882-ENG115387-Leuchte22BR MC9-Light_Function_C_22,not active ,16
ENG124882-ENG115388-Leuchte22BR MC9-Light_Function_D_22,not active ,16
ENG124882-ENG115391-Leuchte22BR MC9-Light_Function_E_22,not active ,16
ENG124882-ENG115392-Leuchte22BR MC9-Light_Function_F_22,not active ,16
ENG124882-ENG115395-Leuchte22BR MC9-Light_Function_G_22,not active ,16
ENG124882-ENG115396-Leuchte22BR MC9-Light_Function_H_22,not active ,16
ENG124882-ENG115380-Leuchte22BR MC9-Type_Of_Load_22,LEDdritteBremsleuchte ,16
ENG124883-ENG115404-Leuchte23SL HLC7-Dimming_AB_23,60 ,16
ENG124883-ENG115408-Leuchte23SL HLC7-Dimming_CD_23,0 ,16
ENG124883-ENG115409-Leuchte23SL HLC7-Dimming_Direction_CD_23,maximize ,16
ENG124883-ENG115413-Leuchte23SL HLC7-Dimming_Direction_EF_23,maximize ,16
ENG124883-ENG115417-Leuchte23SL HLC7-Dimming_Direction_GH_23,maximize ,16
ENG124883-ENG115412-Leuchte23SL HLC7-Dimming_EF_23,0 ,16
ENG124883-ENG115416-Leuchte23SL HLC7-Dimming_GH_23,0 ,16
ENG124883-ENG126598-Leuchte23SL HLC7-Fehlerort_mittleres_Byte_DTC-DFCC_23,29 ,16
ENG124883-ENG115781-Leuchte23SL HLC7-Lampendefektbit_Position_23,0A ,16
ENG124883-ENG115405-Leuchte23SL HLC7-Light_Control_HD_AB_23,Always ,16
ENG124883-ENG115402-Leuchte23SL HLC7-Light_Function_A_23,Parking light ,16
ENG124883-ENG115403-Leuchte23SL HLC7-Light_Function_B_23,Parking light left ,16
ENG124883-ENG115406-Leuchte23SL HLC7-Light_Function_C_23,not active ,16
ENG124883-ENG115407-Leuchte23SL HLC7-Light_Function_D_23,not active ,16
ENG124883-ENG115410-Leuchte23SL HLC7-Light_Function_E_23,not active ,16
ENG124883-ENG115411-Leuchte23SL HLC7-Light_Function_F_23,not active ,16
ENG124883-ENG115414-Leuchte23SL HLC7-Light_Function_G_23,not active ,16
ENG124883-ENG115415-Leuchte23SL HLC7-Light_Function_H_23,not active ,16
ENG124883-ENG115399-Leuchte23SL HLC7-Type_Of_Load_23,allgemeineGluehlampe6W:auchH6W ,16
ENG124884-ENG115423-Leuchte24SL HRA69-Dimming_AB_24,60 ,16
ENG124884-ENG115427-Leuchte24SL HRA69-Dimming_CD_24,0 ,16
ENG124884-ENG115428-Leuchte24SL HRA69-Dimming_Direction_CD_24,maximize ,16
ENG124884-ENG115432-Leuchte24SL HRA69-Dimming_Direction_EF_24,maximize ,16
ENG124884-ENG115436-Leuchte24SL HRA69-Dimming_Direction_GH_24,maximize ,16
ENG124884-ENG115431-Leuchte24SL HRA69-Dimming_EF_24,0 ,16
ENG124884-ENG115435-Leuchte24SL HRA69-Dimming_GH_24,0 ,16
ENG124884-ENG126599-Leuchte24SL HRA69-Fehlerort_mittleres_Byte_DTC-DFCC_24,2A ,16
ENG124884-ENG115669-Leuchte24SL HRA69-Lampendefektbit_Position_24,1A ,16
ENG124884-ENG115424-Leuchte24SL HRA69-Light_Control_HD_AB_24,Always ,16
ENG124884-ENG115421-Leuchte24SL HRA69-Light_Function_A_24,Parking light ,16
ENG124884-ENG115422-Leuchte24SL HRA69-Light_Function_B_24,Parking light right ,16
ENG124884-ENG115425-Leuchte24SL HRA69-Light_Function_C_24,not active ,16
ENG124884-ENG115426-Leuchte24SL HRA69-Light_Function_D_24,not active ,16
ENG124884-ENG115429-Leuchte24SL HRA69-Light_Function_E_24,not active ,16
ENG124884-ENG115430-Leuchte24SL HRA69-Light_Function_F_24,not active ,16
ENG124884-ENG115433-Leuchte24SL HRA69-Light_Function_G_24,not active ,16
ENG124884-ENG115434-Leuchte24SL HRA69-Light_Function_H_24,not active ,16
ENG124884-ENG115418-Leuchte24SL HRA69-Type_Of_Load_24,allgemeineGluehlampe6W:auchH6W ,16
ENG124885-ENG115442-Leuchte25KZL HA60-Dimming_AB_25,100 ,16
ENG124885-ENG115446-Leuchte25KZL HA60-Dimming_CD_25,0 ,16
ENG124885-ENG115447-Leuchte25KZL HA60-Dimming_Direction_CD_25,maximize ,16
ENG124885-ENG115451-Leuchte25KZL HA60-Dimming_Direction_EF_25,maximize ,16
ENG124885-ENG115455-Leuchte25KZL HA60-Dimming_Direction_GH_25,maximize ,16
ENG124885-ENG115450-Leuchte25KZL HA60-Dimming_EF_25,0 ,16
ENG124885-ENG115454-Leuchte25KZL HA60-Dimming_GH_25,0 ,16
ENG124885-ENG126600-Leuchte25KZL HA60-Fehlerort_mittleres_Byte_DTC-DFCC_25,30 ,16
ENG124885-ENG115725-Leuchte25KZL HA60-Lampendefektbit_Position_25,28 ,16
ENG124885-ENG115443-Leuchte25KZL HA60-Light_Control_HD_AB_25,Always ,16
ENG124885-ENG115440-Leuchte25KZL HA60-Light_Function_A_25,Parking light ,16
ENG124885-ENG115441-Leuchte25KZL HA60-Light_Function_B_25,not active ,16
ENG124885-ENG115444-Leuchte25KZL HA60-Light_Function_C_25,not active ,16
ENG124885-ENG115445-Leuchte25KZL HA60-Light_Function_D_25,not active ,16
ENG124885-ENG115448-Leuchte25KZL HA60-Light_Function_E_25,not active ,16
ENG124885-ENG115449-Leuchte25KZL HA60-Light_Function_F_25,not active ,16
ENG124885-ENG115452-Leuchte25KZL HA60-Light_Function_G_25,not active ,16
ENG124885-ENG115453-Leuchte25KZL HA60-Light_Function_H_25,not active ,16
ENG124885-ENG115437-Leuchte25KZL HA60-Type_Of_Load_25,2* 5W ,16
ENG124886-ENG115461-Leuchte26NSL A65-Dimming_AB_26,100 ,16
ENG124886-ENG115465-Leuchte26NSL A65-Dimming_CD_26,0 ,16
ENG124886-ENG115466-Leuchte26NSL A65-Dimming_Direction_CD_26,maximize ,16
ENG124886-ENG115470-Leuchte26NSL A65-Dimming_Direction_EF_26,maximize ,16
ENG124886-ENG115474-Leuchte26NSL A65-Dimming_Direction_GH_26,maximize ,16
ENG124886-ENG115469-Leuchte26NSL A65-Dimming_EF_26,0 ,16
ENG124886-ENG115473-Leuchte26NSL A65-Dimming_GH_26,0 ,16
ENG124886-ENG126601-Leuchte26NSL A65-Fehlerort_mittleres_Byte_DTC-DFCC_26,33 ,16
ENG124886-ENG115627-Leuchte26NSL A65-Lampendefektbit_Position_26,2A ,16
ENG124886-ENG115462-Leuchte26NSL A65-Light_Control_HD_AB_26,Always ,16
ENG124886-ENG115459-Leuchte26NSL A65-Light_Function_A_26,NebelschlusslichtwennkeinAnhaengergestecktundRechtsverkehr ,16
ENG124886-ENG115460-Leuchte26NSL A65-Light_Function_B_26,not active ,16
ENG124886-ENG115463-Leuchte26NSL A65-Light_Function_C_26,not active ,16
ENG124886-ENG115464-Leuchte26NSL A65-Light_Function_D_26,not active ,16
ENG124886-ENG115467-Leuchte26NSL A65-Light_Function_E_26,not active ,16
ENG124886-ENG115468-Leuchte26NSL A65-Light_Function_F_26,not active ,16
ENG124886-ENG115471-Leuchte26NSL A65-Light_Function_G_26,not active ,16
ENG124886-ENG115472-Leuchte26NSL A65-Light_Function_H_26,not active ,16
ENG124886-ENG115456-Leuchte26NSL A65-Type_Of_Load_26,allgemeineGluehlampe27W:auchH15-TFL ,16
ENG124887-ENG115480-Leuchte27 KL58XS C67-Dimming_AB_27,100 ,16
ENG124887-ENG115484-Leuchte27 KL58XS C67-Dimming_CD_27,0 ,16
ENG124887-ENG115485-Leuchte27 KL58XS C67-Dimming_Direction_CD_27,maximize ,16
ENG124887-ENG115489-Leuchte27 KL58XS C67-Dimming_Direction_EF_27,maximize ,16
ENG124887-ENG115493-Leuchte27 KL58XS C67-Dimming_Direction_GH_27,maximize ,16
ENG124887-ENG115488-Leuchte27 KL58XS C67-Dimming_EF_27,0 ,16
ENG124887-ENG115492-Leuchte27 KL58XS C67-Dimming_GH_27,0 ,16
ENG124887-ENG126602-Leuchte27 KL58XS C67-Fehlerort_mittleres_Byte_DTC-DFCC_27,08 ,16
ENG124887-ENG115648-Leuchte27 KL58XS C67-Lampendefektbit_Position_27,00 ,16
ENG124887-ENG115481-Leuchte27 KL58XS C67-Light_Control_HD_AB_27,Always ,16
ENG124887-ENG115478-Leuchte27 KL58XS C67-Light_Function_A_27,Terminal 58xs dimmer ,16
ENG124887-ENG115479-Leuchte27 KL58XS C67-Light_Function_B_27,not active ,16
ENG124887-ENG115482-Leuchte27 KL58XS C67-Light_Function_C_27,not active ,16
ENG124887-ENG115483-Leuchte27 KL58XS C67-Light_Function_D_27,not active ,16
ENG124887-ENG115486-Leuchte27 KL58XS C67-Light_Function_E_27,not active ,16
ENG124887-ENG115487-Leuchte27 KL58XS C67-Light_Function_F_27,not active ,16
ENG124887-ENG115490-Leuchte27 KL58XS C67-Light_Function_G_27,not active ,16
ENG124887-ENG115491-Leuchte27 KL58XS C67-Light_Function_H_27,not active ,16
ENG124887-ENG115475-Leuchte27 KL58XS C67-Type_Of_Load_27,LED Kleinleistung ohne Open Load Diagnose ,16
ENG124888-ENG115499-Leuchte28RFL C3-Dimming_AB_28,100 ,16
ENG124888-ENG115503-Leuchte28RFL C3-Dimming_CD_28,0 ,16
ENG124888-ENG115504-Leuchte28RFL C3-Dimming_Direction_CD_28,maximize ,16
ENG124888-ENG115508-Leuchte28RFL C3-Dimming_Direction_EF_28,maximize ,16
ENG124888-ENG115512-Leuchte28RFL C3-Dimming_Direction_GH_28,maximize ,16
ENG124888-ENG115507-Leuchte28RFL C3-Dimming_EF_28,0 ,16
ENG124888-ENG115511-Leuchte28RFL C3-Dimming_GH_28,0 ,16
ENG124888-ENG126603-Leuchte28RFL C3-Fehlerort_mittleres_Byte_DTC-DFCC_28,34 ,16
ENG124888-ENG115647-Leuchte28RFL C3-Lampendefektbit_Position_28,2B ,16
ENG124888-ENG115500-Leuchte28RFL C3-Light_Control_HD_AB_28,Always ,16
ENG124888-ENG115497-Leuchte28RFL C3-Light_Function_A_28,Rueckfahrlicht ,16
ENG124888-ENG115498-Leuchte28RFL C3-Light_Function_B_28,not active ,16
ENG124888-ENG115501-Leuchte28RFL C3-Light_Function_C_28,not active ,16
ENG124888-ENG115502-Leuchte28RFL C3-Light_Function_D_28,not active ,16
ENG124888-ENG115505-Leuchte28RFL C3-Light_Function_E_28,not active ,16
ENG124888-ENG115506-Leuchte28RFL C3-Light_Function_F_28,not active ,16
ENG124888-ENG115509-Leuchte28RFL C3-Light_Function_G_28,not active ,16
ENG124888-ENG115510-Leuchte28RFL C3-Light_Function_H_28,not active ,16
ENG124888-ENG115494-Leuchte28RFL C3-Type_Of_Load_28,allgemeineGluehlampe27W:auchH15-TFL ,16
ENG124889-ENG115518-Leuchte29 KL30G A69-Dimming_AB_29,100 ,16
ENG124889-ENG115522-Leuchte29 KL30G A69-Dimming_CD_29,0 ,16
ENG124889-ENG115523-Leuchte29 KL30G A69-Dimming_Direction_CD_29,maximize ,16
ENG124889-ENG115527-Leuchte29 KL30G A69-Dimming_Direction_EF_29,maximize ,16
ENG124889-ENG115531-Leuchte29 KL30G A69-Dimming_Direction_GH_29,maximize ,16
ENG124889-ENG115526-Leuchte29 KL30G A69-Dimming_EF_29,0 ,16
ENG124889-ENG115530-Leuchte29 KL30G A69-Dimming_GH_29,0 ,16
ENG124889-ENG126604-Leuchte29 KL30G A69-Fehlerort_mittleres_Byte_DTC-DFCC_29,01 ,16
ENG124889-ENG115764-Leuchte29 KL30G A69-Lampendefektbit_Position_29,00 ,16
ENG124889-ENG115520-Leuchte29 KL30G A69-Light_Control_HD_AB_29,Always ,16
ENG124889-ENG115516-Leuchte29 KL30G A69-Light_Function_A_29,Klemme 30G ,16
ENG124889-ENG115517-Leuchte29 KL30G A69-Light_Function_B_29,not active ,16
ENG124889-ENG115519-Leuchte29 KL30G A69-Light_Function_C_29,not active ,16
ENG124889-ENG115521-Leuchte29 KL30G A69-Light_Function_D_29,not active ,16
ENG124889-ENG115524-Leuchte29 KL30G A69-Light_Function_E_29,not active ,16
ENG124889-ENG115525-Leuchte29 KL30G A69-Light_Function_F_29,not active ,16
ENG124889-ENG115528-Leuchte29 KL30G A69-Light_Function_G_29,not active ,16
ENG124889-ENG115529-Leuchte29 KL30G A69-Light_Function_H_29,not active ,16
ENG124889-ENG115513-Leuchte29 KL30G A69-Type_Of_Load_29,allgemeineGluehlampe12W ,16
ENG124863-ENG115056-Leuchte2SL VLB22-Dimming_AB_2,100 ,16
ENG124863-ENG115060-Leuchte2SL VLB22-Dimming_CD_2,0 ,16
ENG124863-ENG115061-Leuchte2SL VLB22-Dimming_Direction_CD_2,maximize ,16
ENG124863-ENG115065-Leuchte2SL VLB22-Dimming_Direction_EF_2,maximize ,16
ENG124863-ENG115069-Leuchte2SL VLB22-Dimming_Direction_GH_2,maximize ,16
ENG124863-ENG115064-Leuchte2SL VLB22-Dimming_EF_2,0 ,16
ENG124863-ENG115068-Leuchte2SL VLB22-Dimming_GH_2,0 ,16
ENG124863-ENG126577-Leuchte2SL VLB22-Fehlerort_mittleres_Byte_DTC-DFCC_2,26 ,16
ENG124863-ENG115726-Leuchte2SL VLB22-Lampendefektbit_Position_2,35 ,16
ENG124863-ENG115057-Leuchte2SL VLB22-Light_Control_HD_AB_2,Always ,16
ENG124863-ENG115054-Leuchte2SL VLB22-Light_Function_A_2,Parking light ,16
ENG124863-ENG115055-Leuchte2SL VLB22-Light_Function_B_2,Parking light left ,16
ENG124863-ENG115058-Leuchte2SL VLB22-Light_Function_C_2,not active ,16
ENG124863-ENG115059-Leuchte2SL VLB22-Light_Function_D_2,not active ,16
ENG124863-ENG115062-Leuchte2SL VLB22-Light_Function_E_2,not active ,16
ENG124863-ENG115063-Leuchte2SL VLB22-Light_Function_F_2,not active ,16
ENG124863-ENG115066-Leuchte2SL VLB22-Light_Function_G_2,not active ,16
ENG124863-ENG115067-Leuchte2SL VLB22-Light_Function_H_2,not active ,16
ENG124863-ENG115051-Leuchte2SL VLB22-Type_Of_Load_2,allgemeineGluehlampe6W:auchH6W ,16
ENG124890-ENG115537-Leuchte30 INNENLICHT A68-Dimming_AB_30,126 ,16
ENG124890-ENG115541-Leuchte30 INNENLICHT A68-Dimming_CD_30,0 ,16
ENG124890-ENG115542-Leuchte30 INNENLICHT A68-Dimming_Direction_CD_30,maximize ,16
ENG124890-ENG115546-Leuchte30 INNENLICHT A68-Dimming_Direction_EF_30,maximize ,16
ENG124890-ENG115550-Leuchte30 INNENLICHT A68-Dimming_Direction_GH_30,maximize ,16
ENG124890-ENG115545-Leuchte30 INNENLICHT A68-Dimming_EF_30,0 ,16
ENG124890-ENG115549-Leuchte30 INNENLICHT A68-Dimming_GH_30,0 ,16
ENG124890-ENG126605-Leuchte30 INNENLICHT A68-Fehlerort_mittleres_Byte_DTC-DFCC_30,07 ,16
ENG124890-ENG115797-Leuchte30 INNENLICHT A68-Lampendefektbit_Position_30,00 ,16
ENG124890-ENG115538-Leuchte30 INNENLICHT A68-Light_Control_HD_AB_30,Always ,16
ENG124890-ENG115535-Leuchte30 INNENLICHT A68-Light_Function_A_30,Interior light ,16
ENG124890-ENG115536-Leuchte30 INNENLICHT A68-Light_Function_B_30,not active ,16
ENG124890-ENG115539-Leuchte30 INNENLICHT A68-Light_Function_C_30,not active ,16
ENG124890-ENG115540-Leuchte30 INNENLICHT A68-Light_Function_D_30,not active ,16
ENG124890-ENG115543-Leuchte30 INNENLICHT A68-Light_Function_E_30,not active ,16
ENG124890-ENG115544-Leuchte30 INNENLICHT A68-Light_Function_F_30,not active ,16
ENG124890-ENG115547-Leuchte30 INNENLICHT A68-Light_Function_G_30,not active ,16
ENG124890-ENG115548-Leuchte30 INNENLICHT A68-Light_Function_H_30,not active ,16
ENG124890-ENG115532-Leuchte30 INNENLICHT A68-Type_Of_Load_30,allgemeineGluehlampe12W ,16
ENG124891-ENG115556-Leuchte31AMBL 1C65-Dimming_AB_31,0 ,16
ENG124891-ENG115560-Leuchte31AMBL 1C65-Dimming_CD_31,0 ,16
ENG124891-ENG115561-Leuchte31AMBL 1C65-Dimming_Direction_CD_31,maximize ,16
ENG124891-ENG115565-Leuchte31AMBL 1C65-Dimming_Direction_EF_31,maximize ,16
ENG124891-ENG115569-Leuchte31AMBL 1C65-Dimming_Direction_GH_31,maximize ,16
ENG124891-ENG115564-Leuchte31AMBL 1C65-Dimming_EF_31,0 ,16
ENG124891-ENG115568-Leuchte31AMBL 1C65-Dimming_GH_31,0 ,16
ENG124891-ENG126606-Leuchte31AMBL 1C65-Fehlerort_mittleres_Byte_DTC-DFCC_31,00 ,16
ENG124891-ENG115707-Leuchte31AMBL 1C65-Lampendefektbit_Position_31,00 ,16
ENG124891-ENG115557-Leuchte31AMBL 1C65-Light_Control_HD_AB_31,Always ,16
ENG124891-ENG115554-Leuchte31AMBL 1C65-Light_Function_A_31,not active ,16
ENG124891-ENG115555-Leuchte31AMBL 1C65-Light_Function_B_31,not active ,16
ENG124891-ENG115558-Leuchte31AMBL 1C65-Light_Function_C_31,not active ,16
ENG124891-ENG115559-Leuchte31AMBL 1C65-Light_Function_D_31,not active ,16
ENG124891-ENG115562-Leuchte31AMBL 1C65-Light_Function_E_31,not active ,16
ENG124891-ENG115563-Leuchte31AMBL 1C65-Light_Function_F_31,not active ,16
ENG124891-ENG115566-Leuchte31AMBL 1C65-Light_Function_G_31,not active ,16
ENG124891-ENG115567-Leuchte31AMBL 1C65-Light_Function_H_31,not active ,16
ENG124891-ENG115551-Leuchte31AMBL 1C65-Type_Of_Load_31,not active ,16
ENG124892-ENG115575-Leuchte32AMBL 2C64-Dimming_AB_32,0 ,16
ENG124892-ENG115579-Leuchte32AMBL 2C64-Dimming_CD_32,0 ,16
ENG124892-ENG115580-Leuchte32AMBL 2C64-Dimming_Direction_CD_32,maximize ,16
ENG124892-ENG115584-Leuchte32AMBL 2C64-Dimming_Direction_EF_32,maximize ,16
ENG124892-ENG115588-Leuchte32AMBL 2C64-Dimming_Direction_GH_32,maximize ,16
ENG124892-ENG115583-Leuchte32AMBL 2C64-Dimming_EF_32,0 ,16
ENG124892-ENG115587-Leuchte32AMBL 2C64-Dimming_GH_32,0 ,16
ENG124892-ENG126607-Leuchte32AMBL 2C64-Fehlerort_mittleres_Byte_DTC-DFCC_32,00 ,16
ENG124892-ENG115654-Leuchte32AMBL 2C64-Lampendefektbit_Position_32,00 ,16
ENG124892-ENG115576-Leuchte32AMBL 2C64-Light_Control_HD_AB_32,Always ,16
ENG124892-ENG115573-Leuchte32AMBL 2C64-Light_Function_A_32,not active ,16
ENG124892-ENG115574-Leuchte32AMBL 2C64-Light_Function_B_32,not active ,16
ENG124892-ENG115577-Leuchte32AMBL 2C64-Light_Function_C_32,not active ,16
ENG124892-ENG115578-Leuchte32AMBL 2C64-Light_Function_D_32,not active ,16
ENG124892-ENG115581-Leuchte32AMBL 2C64-Light_Function_E_32,not active ,16
ENG124892-ENG115582-Leuchte32AMBL 2C64-Light_Function_F_32,not active ,16
ENG124892-ENG115585-Leuchte32AMBL 2C64-Light_Function_G_32,not active ,16
ENG124892-ENG115586-Leuchte32AMBL 2C64-Light_Function_H_32,not active ,16
ENG124892-ENG115570-Leuchte32AMBL 2C64-Type_Of_Load_32,not active ,16
ENG124893-ENG115594-Leuchte33AMBL 3C72-Dimming_AB_33,0 ,16
ENG124893-ENG115598-Leuchte33AMBL 3C72-Dimming_CD_33,0 ,16
ENG124893-ENG115599-Leuchte33AMBL 3C72-Dimming_Direction_CD_33,maximize ,16
ENG124893-ENG115603-Leuchte33AMBL 3C72-Dimming_Direction_EF_33,maximize ,16
ENG124893-ENG115607-Leuchte33AMBL 3C72-Dimming_Direction_GH_33,maximize ,16
ENG124893-ENG115602-Leuchte33AMBL 3C72-Dimming_EF_33,0 ,16
ENG124893-ENG115606-Leuchte33AMBL 3C72-Dimming_GH_33,0 ,16
ENG124893-ENG126608-Leuchte33AMBL 3C72-Fehlerort_mittleres_Byte_DTC-DFCC_33,00 ,16
ENG124893-ENG115655-Leuchte33AMBL 3C72-Lampendefektbit_Position_33,00 ,16
ENG124893-ENG115595-Leuchte33AMBL 3C72-Light_Control_HD_AB_33,Always ,16
ENG124893-ENG115592-Leuchte33AMBL 3C72-Light_Function_A_33,not active ,16
ENG124893-ENG115593-Leuchte33AMBL 3C72-Light_Function_B_33,not active ,16
ENG124893-ENG115596-Leuchte33AMBL 3C72-Light_Function_C_33,not active ,16
ENG124893-ENG115597-Leuchte33AMBL 3C72-Light_Function_D_33,not active ,16
ENG124893-ENG115600-Leuchte33AMBL 3C72-Light_Function_E_33,not active ,16
ENG124893-ENG115601-Leuchte33AMBL 3C72-Light_Function_F_33,not active ,16
ENG124893-ENG115604-Leuchte33AMBL 3C72-Light_Function_G_33,not active ,16
ENG124893-ENG115605-Leuchte33AMBL 3C72-Light_Function_H_33,not active ,16
ENG124893-ENG115589-Leuchte33AMBL 3C72-Type_Of_Load_33,not active ,16
ENG124894-ENG115613-Leuchte34AMBL 4C71-Dimming_AB_34,0 ,16
ENG124894-ENG115617-Leuchte34AMBL 4C71-Dimming_CD_34,0 ,16
ENG124894-ENG115618-Leuchte34AMBL 4C71-Dimming_Direction_CD_34,maximize ,16
ENG124894-ENG115622-Leuchte34AMBL 4C71-Dimming_Direction_EF_34,maximize ,16
ENG124894-ENG115626-Leuchte34AMBL 4C71-Dimming_Direction_GH_34,maximize ,16
ENG124894-ENG115621-Leuchte34AMBL 4C71-Dimming_EF_34,0 ,16
ENG124894-ENG115625-Leuchte34AMBL 4C71-Dimming_GH_34,0 ,16
ENG124894-ENG126609-Leuchte34AMBL 4C71-Fehlerort_mittleres_Byte_DTC-DFCC_34,00 ,16
ENG124894-ENG115796-Leuchte34AMBL 4C71-Lampendefektbit_Position_34,00 ,16
ENG124894-ENG115614-Leuchte34AMBL 4C71-Light_Control_HD_AB_34,Always ,16
ENG124894-ENG115611-Leuchte34AMBL 4C71-Light_Function_A_34,not active ,16
ENG124894-ENG115612-Leuchte34AMBL 4C71-Light_Function_B_34,not active ,16
ENG124894-ENG115615-Leuchte34AMBL 4C71-Light_Function_C_34,not active ,16
ENG124894-ENG115616-Leuchte34AMBL 4C71-Light_Function_D_34,not active ,16
ENG124894-ENG115619-Leuchte34AMBL 4C71-Light_Function_E_34,not active ,16
ENG124894-ENG115620-Leuchte34AMBL 4C71-Light_Function_F_34,not active ,16
ENG124894-ENG115623-Leuchte34AMBL 4C71-Light_Function_G_34,not active ,16
ENG124894-ENG115624-Leuchte34AMBL 4C71-Light_Function_H_34,not active ,16
ENG124894-ENG115608-Leuchte34AMBL 4C71-Type_Of_Load_34,not active ,16
ENG124864-ENG115075-Leuchte3SL VRB36-Dimming_AB_3,100 ,16
ENG124864-ENG115079-Leuchte3SL VRB36-Dimming_CD_3,0 ,16
ENG124864-ENG115080-Leuchte3SL VRB36-Dimming_Direction_CD_3,maximize ,16
ENG124864-ENG115084-Leuchte3SL VRB36-Dimming_Direction_EF_3,maximize ,16
ENG124864-ENG115088-Leuchte3SL VRB36-Dimming_Direction_GH_3,maximize ,16
ENG124864-ENG115083-Leuchte3SL VRB36-Dimming_EF_3,0 ,16
ENG124864-ENG115087-Leuchte3SL VRB36-Dimming_GH_3,0 ,16
ENG124864-ENG126578-Leuchte3SL VRB36-Fehlerort_mittleres_Byte_DTC-DFCC_3,27 ,16
ENG124864-ENG115645-Leuchte3SL VRB36-Lampendefektbit_Position_3,3F ,16
ENG124864-ENG115076-Leuchte3SL VRB36-Light_Control_HD_AB_3,Always ,16
ENG124864-ENG115073-Leuchte3SL VRB36-Light_Function_A_3,Parking light ,16
ENG124864-ENG115074-Leuchte3SL VRB36-Light_Function_B_3,Parking light right ,16
ENG124864-ENG115077-Leuchte3SL VRB36-Light_Function_C_3,not active ,16
ENG124864-ENG115078-Leuchte3SL VRB36-Light_Function_D_3,not active ,16
ENG124864-ENG115081-Leuchte3SL VRB36-Light_Function_E_3,not active ,16
ENG124864-ENG115082-Leuchte3SL VRB36-Light_Function_F_3,not active ,16
ENG124864-ENG115085-Leuchte3SL VRB36-Light_Function_G_3,not active ,16
ENG124864-ENG115086-Leuchte3SL VRB36-Light_Function_H_3,not active ,16
ENG124864-ENG115070-Leuchte3SL VRB36-Type_Of_Load_3,allgemeineGluehlampe6W:auchH6W ,16
ENG124865-ENG115094-Leuchte4TFL LB43-Dimming_AB_4,100 ,16
ENG124865-ENG115098-Leuchte4TFL LB43-Dimming_CD_4,0 ,16
ENG124865-ENG115099-Leuchte4TFL LB43-Dimming_Direction_CD_4,minimize ,16
ENG124865-ENG115103-Leuchte4TFL LB43-Dimming_Direction_EF_4,maximize ,16
ENG124865-ENG115107-Leuchte4TFL LB43-Dimming_Direction_GH_4,maximize ,16
ENG124865-ENG115102-Leuchte4TFL LB43-Dimming_EF_4,0 ,16
ENG124865-ENG115106-Leuchte4TFL LB43-Dimming_GH_4,0 ,16
ENG124865-ENG126579-Leuchte4TFL LB43-Fehlerort_mittleres_Byte_DTC-DFCC_4,20 ,16
ENG124865-ENG115808-Leuchte4TFL LB43-Lampendefektbit_Position_4,3A ,16
ENG124865-ENG115095-Leuchte4TFL LB43-Light_Control_HD_AB_4,Always ,16
ENG124865-ENG115092-Leuchte4TFL LB43-Light_Function_A_4,Daytime running lights ,16
ENG124865-ENG115093-Leuchte4TFL LB43-Light_Function_B_4,not active ,16
ENG124865-ENG115096-Leuchte4TFL LB43-Light_Function_C_4,Nebellicht links ,16
ENG124865-ENG115097-Leuchte4TFL LB43-Light_Function_D_4,not active ,16
ENG124865-ENG115100-Leuchte4TFL LB43-Light_Function_E_4,not active ,16
ENG124865-ENG115101-Leuchte4TFL LB43-Light_Function_F_4,not active ,16
ENG124865-ENG115104-Leuchte4TFL LB43-Light_Function_G_4,not active ,16
ENG124865-ENG115105-Leuchte4TFL LB43-Light_Function_H_4,not active ,16
ENG124865-ENG115089-Leuchte4TFL LB43-Type_Of_Load_4,allgemeineGluehlampe27W:auchH15-TFL ,16
ENG124866-ENG114977-Leuchte5 TFL RB6-Dimming_AB_5,100 ,16
ENG124866-ENG114981-Leuchte5 TFL RB6-Dimming_CD_5,0 ,16
ENG124866-ENG114982-Leuchte5 TFL RB6-Dimming_Direction_CD_5,minimize ,16
ENG124866-ENG114986-Leuchte5 TFL RB6-Dimming_Direction_EF_5,maximize ,16
ENG124866-ENG114990-Leuchte5 TFL RB6-Dimming_Direction_GH_5,maximize ,16
ENG124866-ENG114985-Leuchte5 TFL RB6-Dimming_EF_5,0 ,16
ENG124866-ENG114989-Leuchte5 TFL RB6-Dimming_GH_5,0 ,16
ENG124866-ENG126580-Leuchte5 TFL RB6-Fehlerort_mittleres_Byte_DTC-DFCC_5,21 ,16
ENG124866-ENG114974-Leuchte5 TFL RB6-Lampendefektbit_Position_5,44 ,16
ENG124866-ENG114978-Leuchte5 TFL RB6-Light_Control_HD_AB_5,Always ,16
ENG124866-ENG114975-Leuchte5 TFL RB6-Light_Function_A_5,Daytime running lights ,16
ENG124866-ENG114976-Leuchte5 TFL RB6-Light_Function_B_5,not active ,16
ENG124866-ENG114979-Leuchte5 TFL RB6-Light_Function_C_5,Nebellicht rechts ,16
ENG124866-ENG114980-Leuchte5 TFL RB6-Light_Function_D_5,not active ,16
ENG124866-ENG114983-Leuchte5 TFL RB6-Light_Function_E_5,not active ,16
ENG124866-ENG114984-Leuchte5 TFL RB6-Light_Function_F_5,not active ,16
ENG124866-ENG114987-Leuchte5 TFL RB6-Light_Function_G_5,not active ,16
ENG124866-ENG114988-Leuchte5 TFL RB6-Light_Function_H_5,not active ,16
ENG124866-ENG114973-Leuchte5 TFL RB6-Type_Of_Load_5,allgemeineGluehlampe27W:auchH15-TFL ,16
ENG124867-ENG115115-Leuchte6ABL LB44-Dimming_AB_6,100 ,16
ENG124867-ENG115119-Leuchte6ABL LB44-Dimming_CD_6,0 ,16
ENG124867-ENG115120-Leuchte6ABL LB44-Dimming_Direction_CD_6,maximize ,16
ENG124867-ENG115124-Leuchte6ABL LB44-Dimming_Direction_EF_6,maximize ,16
ENG124867-ENG115128-Leuchte6ABL LB44-Dimming_Direction_GH_6,maximize ,16
ENG124867-ENG115123-Leuchte6ABL LB44-Dimming_EF_6,0 ,16
ENG124867-ENG115127-Leuchte6ABL LB44-Dimming_GH_6,0 ,16
ENG124867-ENG126581-Leuchte6ABL LB44-Fehlerort_mittleres_Byte_DTC-DFCC_6,1A ,16
ENG124867-ENG115765-Leuchte6ABL LB44-Lampendefektbit_Position_6,36 ,16
ENG124867-ENG115116-Leuchte6ABL LB44-Light_Control_HD_AB_6,Always ,16
ENG124867-ENG115113-Leuchte6ABL LB44-Light_Function_A_6,Abblendlicht links ,16
ENG124867-ENG115114-Leuchte6ABL LB44-Light_Function_B_6,ComingHome LeavingHome ,16
ENG124867-ENG115117-Leuchte6ABL LB44-Light_Function_C_6,not active ,16
ENG124867-ENG115118-Leuchte6ABL LB44-Light_Function_D_6,not active ,16
ENG124867-ENG115121-Leuchte6ABL LB44-Light_Function_E_6,not active ,16
ENG124867-ENG115122-Leuchte6ABL LB44-Light_Function_F_6,not active ,16
ENG124867-ENG115125-Leuchte6ABL LB44-Light_Function_G_6,not active ,16
ENG124867-ENG115126-Leuchte6ABL LB44-Light_Function_H_6,not active ,16
ENG124867-ENG115110-Leuchte6ABL LB44-Type_Of_Load_6,Low beam ,16
ENG124868-ENG115134-Leuchte7ABL RB5-Dimming_AB_7,100 ,16
ENG124868-ENG115138-Leuchte7ABL RB5-Dimming_CD_7,0 ,16
ENG124868-ENG115139-Leuchte7ABL RB5-Dimming_Direction_CD_7,maximize ,16
ENG124868-ENG115143-Leuchte7ABL RB5-Dimming_Direction_EF_7,maximize ,16
ENG124868-ENG115147-Leuchte7ABL RB5-Dimming_Direction_GH_7,maximize ,16
ENG124868-ENG115142-Leuchte7ABL RB5-Dimming_EF_7,0 ,16
ENG124868-ENG115146-Leuchte7ABL RB5-Dimming_GH_7,0 ,16
ENG124868-ENG126582-Leuchte7ABL RB5-Fehlerort_mittleres_Byte_DTC-DFCC_7,1B ,16
ENG124868-ENG115807-Leuchte7ABL RB5-Lampendefektbit_Position_7,40 ,16
ENG124868-ENG115135-Leuchte7ABL RB5-Light_Control_HD_AB_7,Always ,16
ENG124868-ENG115132-Leuchte7ABL RB5-Light_Function_A_7,Abblendlicht rechts ,16
ENG124868-ENG115133-Leuchte7ABL RB5-Light_Function_B_7,ComingHome LeavingHome ,16
ENG124868-ENG115136-Leuchte7ABL RB5-Light_Function_C_7,not active ,16
ENG124868-ENG115137-Leuchte7ABL RB5-Light_Function_D_7,not active ,16
ENG124868-ENG115140-Leuchte7ABL RB5-Light_Function_E_7,not active ,16
ENG124868-ENG115141-Leuchte7ABL RB5-Light_Function_F_7,not active ,16
ENG124868-ENG115144-Leuchte7ABL RB5-Light_Function_G_7,not active ,16
ENG124868-ENG115145-Leuchte7ABL RB5-Light_Function_H_7,not active ,16
ENG124868-ENG115129-Leuchte7ABL RB5-Type_Of_Load_7,Low beam ,16
ENG124869-ENG115153-Leuchte8FL LB42-Dimming_AB_8,100 ,16
ENG124869-ENG115157-Leuchte8FL LB42-Dimming_CD_8,0 ,16
ENG124869-ENG115158-Leuchte8FL LB42-Dimming_Direction_CD_8,maximize ,16
ENG124869-ENG115162-Leuchte8FL LB42-Dimming_Direction_EF_8,maximize ,16
ENG124869-ENG115147-Leuchte8FL LB42-Dimming_Direction_GH_7,maximize ,16
ENG124869-ENG115161-Leuchte8FL LB42-Dimming_EF_8,0 ,16
ENG124869-ENG115165-Leuchte8FL LB42-Dimming_GH_8,0 ,16
ENG124869-ENG126583-Leuchte8FL LB42-Fehlerort_mittleres_Byte_DTC-DFCC_8,1C ,16
ENG124869-ENG115798-Leuchte8FL LB42-Lampendefektbit_Position_8,37 ,16
ENG124869-ENG115154-Leuchte8FL LB42-Light_Control_HD_AB_8,Always ,16
ENG124869-ENG115151-Leuchte8FL LB42-Light_Function_A_8,Left high beam ,16
ENG124869-ENG115152-Leuchte8FL LB42-Light_Function_B_8,Headlamp flasher ,16
ENG124869-ENG115155-Leuchte8FL LB42-Light_Function_C_8,not active ,16
ENG124869-ENG115156-Leuchte8FL LB42-Light_Function_D_8,not active ,16
ENG124869-ENG115159-Leuchte8FL LB42-Light_Function_E_8,not active ,16
ENG124869-ENG115160-Leuchte8FL LB42-Light_Function_F_8,not active ,16
ENG124869-ENG115163-Leuchte8FL LB42-Light_Function_G_8,not active ,16
ENG124869-ENG115164-Leuchte8FL LB42-Light_Function_H_8,not active ,16
ENG124869-ENG115148-Leuchte8FL LB42-Type_Of_Load_8,allgemeineScheinwerferohneAbschaltung ,16
ENG124870-ENG115172-Leuchte9FL RB7-Dimming_AB_9,100 ,16
ENG124870-ENG115176-Leuchte9FL RB7-Dimming_CD_9,0 ,16
ENG124870-ENG115177-Leuchte9FL RB7-Dimming_Direction_CD_9,maximize ,16
ENG124870-ENG115181-Leuchte9FL RB7-Dimming_Direction_EF_9,maximize ,16
ENG124870-ENG115185-Leuchte9FL RB7-Dimming_Direction_GH_9,maximize ,16
ENG124870-ENG115180-Leuchte9FL RB7-Dimming_EF_9,0 ,16
ENG124870-ENG115184-Leuchte9FL RB7-Dimming_GH_9,0 ,16
ENG124870-ENG126584-Leuchte9FL RB7-Fehlerort_mittleres_Byte_DTC-DFCC_9,1D ,16
ENG124870-ENG115804-Leuchte9FL RB7-Lampendefektbit_Position_9,41 ,16
ENG124870-ENG115173-Leuchte9FL RB7-Light_Control_HD_AB_9,Always ,16
ENG124870-ENG115170-Leuchte9FL RB7-Light_Function_A_9,Right high beam ,16
ENG124870-ENG115171-Leuchte9FL RB7-Light_Function_B_9,Headlamp flasher ,16
ENG124870-ENG115174-Leuchte9FL RB7-Light_Function_C_9,not active ,16
ENG124870-ENG115175-Leuchte9FL RB7-Light_Function_D_9,not active ,16
ENG124870-ENG115178-Leuchte9FL RB7-Light_Function_E_9,not active ,16
ENG124870-ENG115179-Leuchte9FL RB7-Light_Function_F_9,not active ,16
ENG124870-ENG115182-Leuchte9FL RB7-Light_Function_G_9,not active ,16
ENG124870-ENG115183-Leuchte9FL RB7-Light_Function_H_9,not active ,16
ENG124870-ENG115167-Leuchte9FL RB7-Type_Of_Load_9,allgemeineScheinwerferohneAbschaltung ,16
ENG124875-ENG115233-Leuchten14LOCKUNLOCKC61-Dimming_AB_14,100 ,16
ENG124875-ENG115237-Leuchten14LOCKUNLOCKC61-Dimming_CD_14,0 ,16
ENG124875-ENG115238-Leuchten14LOCKUNLOCKC61-Dimming_Direction_CD_14,maximize ,16
ENG124875-ENG115242-Leuchten14LOCKUNLOCKC61-Dimming_Direction_EF_14,maximize ,16
ENG124875-ENG115246-Leuchten14LOCKUNLOCKC61-Dimming_Direction_GH_14,maximize ,16
ENG124875-ENG115241-Leuchten14LOCKUNLOCKC61-Dimming_EF_14,0 ,16
ENG124875-ENG115245-Leuchten14LOCKUNLOCKC61-Dimming_GH_14,0 ,16
ENG124875-ENG126589-Leuchten14LOCKUNLOCKC61-Fehlerort_mittleres_Byte_DTC-DFCC_14,00 ,16
ENG124875-ENG115786-Leuchten14LOCKUNLOCKC61-Lampendefektbit_Position_14,00 ,16
ENG124875-ENG115234-Leuchten14LOCKUNLOCKC61-Light_Control_HD_AB_14,Always ,16
ENG124875-ENG115231-Leuchten14LOCKUNLOCKC61-Light_Function_A_14,LockUnlockLED ,16
ENG124875-ENG115232-Leuchten14LOCKUNLOCKC61-Light_Function_B_14,not active ,16
ENG124875-ENG115235-Leuchten14LOCKUNLOCKC61-Light_Function_C_14,not active ,16
ENG124875-ENG115236-Leuchten14LOCKUNLOCKC61-Light_Function_D_14,not active ,16
ENG124875-ENG115239-Leuchten14LOCKUNLOCKC61-Light_Function_E_14,not active ,16
ENG124875-ENG115240-Leuchten14LOCKUNLOCKC61-Light_Function_F_14,not active ,16
ENG124875-ENG115243-Leuchten14LOCKUNLOCKC61-Light_Function_G_14,not active ,16
ENG124875-ENG115244-Leuchten14LOCKUNLOCKC61-Light_Function_H_14,not active ,16
ENG124875-ENG115228-Leuchten14LOCKUNLOCKC61-Type_Of_Load_14,allgemeineLEDmitOpenLoadDiagnose ,16
ENG126648-MAS02526-LIN-Mirrormode-Activation,not active ,1
ENG117284-ENG115658-LuB Lichtrouter Kennlinie 1-x0,0 ,12
ENG117284-ENG101574-LuB Lichtrouter Kennlinie 1-X1,10 ,12
ENG117284-ENG99557-LuB Lichtrouter Kennlinie 1-X2,100 ,12
ENG117284-ENG102140-LuB Lichtrouter Kennlinie 1-X3,150 ,12
ENG117284-ENG102936-LuB Lichtrouter Kennlinie 1-X4,220 ,12
ENG117284-ENG103548-LuB Lichtrouter Kennlinie 1-X5,253 ,12
ENG122927-RLS_close_glazing,2.0 s,1
ENG122928-ENG121636-RLS_lights_for_autobahn-p_t_autobahn_delay_on,9 s,3
ENG122931-ENG123002-RLS_Lights_on_at_Rain-p_n_regenlichtschwelle_high,12 s,2
ENG122932-ENG123007-RLS_Night_Sensitivity-p_lx_rs_dawn,200 lx,1
ENG122932-ENG123006-RLS_Night_Sensitivity-p_lx_rs_day,500 lx,1
ENG127068-Window_Regulator_VW_Settings_Driver_Side_Rear_PQ25,00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 ,650
ENG127067-Window_Regulator_VW_Settings_Passenger_Side_PQ25,00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 ,650
ENG127069-Window_Regulator_VW_Settings_Passenger_Side_Rear_PQ25,00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 ,650
Elapsed Time: 01:36
Shut off transport mode!
Dana
Western PA, USA
I agree Jack but that channel is on/activated in a lot of MQB/Mk7 based cars which function properly. I'm not entirely sure why those get past the PDI with Transport mode on, and I would turn it off if I had a remote problem, but I almost suspect that's normal.
Jopie89, in addition to turning Transport mode off on the BCM, please make sure the CAN Gateway isn't in Transport Mode via the Applications screen as well:
http://www.ross-tech.com/vcds/tour/applications_screen.php
Using [De-Activate Transport Mode] will turn off Transport Mode in the 19-CAN Gateway. If it was off, you won't cause any harm but if it was on it may resolve your problem.
P.S. I compared your scans (VCDS Versie: PRI 17.8.1.0 and VCDS Version: 18.9.1.0 (x64) and the only coding difference is in address 17. I highly doubt flipping 17 coding back to GB English is going to make difference but please try at some point.
Jopie89
C?ID=253932
Hi guys, still a very big thank you for your time and help. I de activated transportation mode in applications and did check it i adaption. It is off now. But still not solving my problem.. Is there anything else I can check? Sorry for asking so much (and maybe stupid) questions. But again, thanks for your support and help :-)
Dana
Western PA, USA
Sorry for the delay, I was off on an extended holiday weekend, but I don't really have any additional suggestions.
Because the remotes can be used to comfort open/close the windows I wouldn't suspect faulty remotes or a remote to BCM matching problem. You already ruled out Transport Mode in 19 and Factory Mode in 09.
I have experienced inoperative remotes in Mk6 (PQ35 based) vehicles due to incorrect address 16 coding .. but the car in question doesn't even use that address so it couldn't apply. I almost wonder if a battery disconnect might be worth a shot?
Coding: 0010184042530AF34F844000402703481000590253010000000000000000
Coding: 030000046F0A560071000000000000010001010000000000000000000000
Have vehicle SVM'd at dealer and when corrected post the new auto-scan.
Jopie89
C?ID=253932
Guys, thanks for all the info so far :-) I'm pretty sure the coding was okay and it worked before. The adaption channels are okay too as far as I can see and I think you guys didn't see anything that is not normal?
Still a question because I'm doubting myself now. If the adaption chanels are okay, and the long coding is off. Does the long coding overrule that in some sort of way? So if the long coding says: No, we don't use remote control to unlock it, but everything else says I want to use it. Does it still not work?
Maybe I have to search for an even older file or read out similar vehicle for the long coding of the components?
