Am I Ready for a 'De-Coke'?
Zenerdiode
Newcastle, England
C?ID=24330
Inspired by Peter's post; I 'boro-ed' the Boroscope form work to give my CDNC engine an endoscopy. :eek:
Do you think I'm ready for de-carbonising the intake valves? The engine hasn't missed a beat; however I'm getting the lumpy idle and it threw the MIL for 20 seconds on my drive home from work the other day. I can't think of any reason for the misfire other than the carbon.
Friday,03,May,2019,16:25:58:19335
VCDS Version: 19.4.0.0 (x64)  HEX-NET CB: 0.4505.4
Data version: 20190411 DS307.0
VIN: WAUZZZ8K69A093649   License Plate:
Mileage: 91780km-57029mi   Repair Order: After Misfires
Chassis Type: 8K-AU48 (8T0)
Scan: 01 03 05 07 08 09 0E 0F 10 13 15 16 17 19 1E 36 37 42 46 47
          52 53 55 56 57 62 69 6C 72 77
VIN: WAUZZZ8K69A093649   Mileage: 91780km-57029miles
Address 01: Engine (-----CDNC)       Labels:| 06H-907-115-CAB.clb
   Part No SW: 8K2 907 115 A    HW: 8K2 907 115 D
   Component: 2.0l R4/4V TF H12 0002
   Revision: E1H12---
   Coding: 0104000C180F0A60
   Shop #: WSC 06325 000 00000
   ASAM Dataset: EV_ECM20TFS8K2907115A A01003
   ROD: EV_ECM20TFS8K2907115A.rod
   VCID: 2D12C9137C5AB92050-8078
4629 - ECM Power Relay Load Circuit
          P068A 00 [032] - Opens Too Early
4057 - Cylinder 2
          P0302 00 [039] - Misfire Detected
                    Mileage: 91783 km
                    Date: 2019.05.03
                    Time: 16:00:43
                    Engine speed: 1712.50 /min
                    Normed load value: 69.4 %
                    Vehicle speed: 42 km/h
                    Coolant temperature: 98 °C
                    Intake air temperature: 13 °C
                    Voltage terminal 30: 13.075 V
                    Unlearning counter according OBD: 80
4051 - Random/Multiple Cylinder Misfire Detected
          P0300 00 [039] - -
   Part No SW: 8K0 907 379 AD    HW: 8K0 907 379 AD
   Component: ESP8 quattro  H04 0060
   Coding: 07CD00
   VCID: 7BB6374BFAAEE7909E-802E
   Part No SW: 8K0 907 064 AE    HW: 8K0 907 064 AE
   Component: BCM2 1.1      H71 0134
   Coding: 071100
   VCID: 73A61F6BD2FEAFD0C6-8026
   Subsystem 1 - Part No SW: 8K0 905 852 D    HW: 8K0 905 852 D
   Serial number: 0208000037716016
00956 - Key 2
            002 - Lower Limit Exceeded
                    Fault Status: 01100010
                    Reset counter: 154
                    Mileage: 90800 km
                    Date: 2019.03.29
                    Time: 20:10:44
Address 07: Control Head        Labels: 8T0-035-7xx-07-H.clb
   Part No SW: 8T0 035 730     HW: 4E0 035 729 A
   Component: Interfacebox    H43 5570
   Revision: 00000000    Serial number: 331GW087527386
   VCID: 6E900E1F79DC823829-803A
   Subsystem 1 - Part No: 8T0 919 609 C
   Subsystem 2 - Serial number: 00000000122047
   Subsystem 3 - Serial number: 0125.07.080000000100010252ÿ
   Subsystem 4 - Serial number: 010252ÿ
   Part No SW: 8T2 820 043 T    HW: 8T2 820 043 T
   Component: KLIMA 3 ZONEN H06 0140
   Revision: D1000000    Serial number: 0112.07.080038
   Coding: 64040000
   VCID: 43C68FABC2DE5F5096-8016
   Part No SW: 8K0 907 063 D    HW: 8K0 907 063 D
   Revision: 05022001    Serial number: 00000000197362
   Coding: 260050914034AF010001000300001D0D4F1D230800010141000000
   Shop #: WSC 00724 210 01500
   VCID: 302CD0676368D4C87B-8064
   Subsystem 1 - Part No SW: 8K2 955 119 A    HW: 8T2 955 119   Labels: 1KX-955-119.CLB
   Component: WWS 150708  H05 0070
   Serial number: SWFBIE 0000715
   Coding: 00FD11
   Subsystem 2 - Part No SW: 8K0 955 559 C    HW: 8K0 955 559 C  Labels: 8K0-955-559.CLB
   Component: RLS  H04 0003
   Serial number: 20021153
   Coding: 022228
   Subsystem 3 - Part No SW: 8K0 941 531 G    HW: 8K0 941 531 G
   Component: E1 - LDS  H07 0070
   Serial number: 00000000003107081163
   Part No SW: 8T2 035 110 C    HW: 8T2 035 110 C
   Component: MP3-Changer     H44 0390
   Revision: 00044003    Serial number: AUZ5ZBH8521457
   VCID: 2B16C70B8A4EB7104E-807E
Address 0F: Digital Radio        Labels: None
   Part No SW: 4E0 910 563 C    HW: 4E0 035 563
   Component: DAB-Tuner       H41 0830
   Revision: 00000001    Serial number: KE1276W7300525
   Coding: 0000001
   VCID: 24042C37E79078688F-8070
Address 10: Park/Steer Assist (J446)       Labels:. 8K0-919-475.clb
   Part No SW: 8K0 919 475 E    HW: 8K0 919 475 A
   Component: PARKHILFE 8K  H06 0020
   Revision: 11001001    Serial number: 52830821004243
   Coding: 310003
   VCID: 3B36F74BBA2E2790DE-806E
   Part No SW: 8K0 907 561     HW: 8K0 907 561
   Component: ACC2          H07 0080
   Coding: 00C7CF
   VCID: 6FAE131BBED68B3022-803A
   Part No SW: 8K0 959 655 B    HW: 8K0 959 655 B
   Component: AirbagVW-AU10 H26 0410
   Serial number: 0038JD182SKG
   Coding: 30363434363030303030554A3052384B3053
   VCID: 3C34F457B72020A8D7-8068
   Serial number: 6334MSME3E12552BG
   Serial number: 6344MSME3F43723AL
   Serial number: 6352QSME7C522E43Q
   Serial number: 6362QSME7F3A3927Y
   Serial number: 63732SME2D024606W
   Serial number: 63832SME45002800J
   Part No SW: 8K0 953 568 G    HW: 8K0 953 568 G
   Component: Lenks.Modul   H12 0013
   Revision: --------    Serial number: 90304HG3000BA
   Coding: 00001E
   VCID: 3E30FE5FA93C32B8F9-806A
   Part No SW: 8K0 920 980 E    HW: 8K0 920 980 E
   Component: KOMBIINSTR.   H12 0216
   Revision: 00400000    Serial number: 6Y912F1A7
   Coding: 2F0D09000F002600010400
   Shop #: WSC 00783 210 90835
   VCID: 3424DC779770E8E81F-8060
   Part No SW: 8T0 907 468 L    HW: 8T0 907 468 L
   Component: GW-BEM 5CAN-M H10 0092
   Revision: FB402044    Serial number: 4400F087218051
   Coding: 000303
   VCID: 4AD8A28FE5F48E1855-801E
   Component: J367-BDM  H04 0150
   Serial number: 18032EA6150708
Address 1E: Media Player 2 (R199)       Labels:. 4E0-035-785.lbl
   Part No SW: 4E0 035 785 F    HW: 4E0 035 785 C
   Component: SG ext.Player H15 0850
   Revision: 00000000
   VCID: 2B16C70B4A4EB7104E-807E
   Part No SW: 8K0 959 760     HW: 8K0 959 760
   Component: MEM-FS        H05 0043
   Revision: AA000000    Serial number: 00001001111410
   Coding: 00783B00000000000000
   VCID: 77BE2B7BC686C3F0FA-8022
   Part No SW: 4E0 910 888 P    HW: 4E0 919 887 M
   Component: MNS ECE         H51 1060
   Revision: 00000000    Serial number: 333G%087599178
   Shop #: WSC 00762 210 97024
   VCID: 3B36F74B7A2E2790DE-806E
   Part No SW: 8K0 959 793 B    HW: 8K0 959 793
   Component: TSG FA        H10 0170
   Revision:             Serial number: 0000007541200
   Coding: 011C12205E01410001
   VCID: 3FCE835BAE363BB0F2-806A
   Revision: 00002001    Serial number: 0113463471
   Coding: 011B0E22003905C5003001
   Subsystem 3 - Part No SW: 8K0 959 591     HW: 8K0 959 591
   Component: J245 PS034  H06 0037
01503 - Bulb for 3rd Brake Light (M25)
                    Fault Status: 00101100
                    Fault Frequency: 20
                    Reset counter: 239
                    Mileage: 90130 km
                    Date: 2019.03.05
                    Time: 16:10:52
   Part No SW: 8T0 035 223 T    HW: 8T0 035 223 F
   Component: DSP Prem      H14 0400
   Revision: 00H14003    Serial number: 34814002277201
   Coding: 020101
   Shop #: WSC 12336 024 394758
00003 - Control Module
            014 - Defective
                    Fault Status: 01101110
                    Date: 2064.00.00
                    Time: 00:00:10
                    Voltage: 11.30 V
                    Temperature: 251.0°C
                    Temperature: 253.0°C
                    Bin. Bits: 00000100
                    Bin. Bits: 00000100
                    Bin. Bits: 00000000
   Part No SW: 8K0 959 792 B    HW: 8K0 959 792
   Component: TSG BF        H10 0170
   Revision:             Serial number: 0000007516848
   Part No SW: 8K0 907 801 E    HW: 8K0 907 801 E
   Component: EPB Audi B8   H05 0060
   Revision: 00000003    Serial number: 10000000072910
   VCID: 312AD5636862DDC074-8064
03200 - Switch for Electric Parking Brake (E538)
                    Fault Status: 00101011
                    Reset counter: 159
                    Mileage: 91044 km
                    Date: 2019.04.06
                    Time: 14:50:29
                    Voltage: 12.30 V
                    Count: 38
                    Hex Value: 0x0163
                    Hex Value: 0x0008
                    Hex Value: 0x1010
Address 55: Headlight Range        Labels: 8T0-907-357.clb
   Part No SW: 8H0 907 357 A    HW: 8H0 907 357
   Coding: 0000019
   Shop #: WSC 06324 000 00000
   VCID: 302CD067A368D4C87B-8064
   Subsystem 1 - Part No: 8K0 941 329
   Component: AFS-Modul links H01 S001
   Subsystem 2 - Part No: 8K0 941 329
   Component: AFS-Modul rechtsH01 S001
   Part No SW: 4E0 910 541 T    HW: 4F0 035 541 L
   Revision: 00000000    Serial number: 336H+087584845
   Coding: 0000001
   VCID: 312AD563A862DDC074-8064
                    Reset counter: 240
                    Mileage: 85228 km
                    Date: 2018.08.11
                    Time: 14:45:31
Address 57: TV Tuner        Labels: None
   Part No SW: 4E0 910 148 E    HW: 4E0 919 148
   Component: R78 TVHybridDVB     0470
   Revision: R0H06000    Serial number: 76300801710102
   Coding: 0000103
   VCID: 25023133ECAA816098-8070
   Part No SW: 8K0 959 795     HW: 8K0 959 795
   Component: TSG HL        H06 0170
   Revision:             Serial number: 0000007490460
   Coding: 010C12204001210001
   VCID: 7F4EC35BEEB6FBB0B2-802A
   Part No SW: 8K0 907 383 E    HW: 8K0 907 383 E
   Revision: 1A001001    Serial number: 00008200250331
   Coding: 0100000000000000
   VCID: 3620E67F810CFAF821-8062
   Part No SW: 8T0 907 441 B    HW: 4L0 907 441 A
   Component: J772__Rearview      0070
   Revision: --H12---    Serial number: 525PA8-J87910O
   Coding: 1032006
   VCID: 373EEB7B460603F03A-8062
   Part No SW: 8K0 959 794     HW: 8K0 959 795
   Component: TSG HR        H06 0170
   Revision:             Serial number: 0000007559497
   VCID: 7EB03E5FE9BCF2B8B9-802A
Address 77: Telephone        Labels: 4F1-910-336.lbl
   Part No SW: 4F1 910 336 D    HW: 4F1 862 335
   Component: BTA             H11 1120
   Revision: 00H11000    Serial number: 00000007586811
   Coding: 1010021
   Shop #: WSC 00783 210 84012
End----------(Elapsed Time: 01:59, VBatt start/end: 14.2V/14.2V)-----------
Boki Ar
Arandjelovac, Serbia
C?ID=57300
I like the pictures, but I'm thinking where these carbons will go...
DrPeter
16.4905° S, 151.7375° W
Nice!, remind me not to go the the UK and get an esophagogastroduodenoscopy (EDG)... or if needed for some reason, ask if they own a Volkswagen Group vehicle! :p
The patient appears to have slight obstructions, perhaps it has ingested an excessive amount of carbon based and other synthetic compounds.
It is not actually that bad looking. Not as bad as mine. On your engine, the intake port walls look visible and lightly coated. I had heavy build up, maybe 2-3mm or more in some places. I would clean it, it may take another 9 or so years to build back up?
This job, as you know, can turn into a 'might as well' job. They type of job where you say, since I am here I 'might as well' replace this and change that, etc...
But if your going to keep the vehicle, I think it is worth doing the job. I could feel a difference in power!, my wife said it feels the same...:facepalm:
Enjoy!
drpeter
ps.. just do not do any baking with the left over basting soda :p
NZDubNurd
New Zealand
C?ID=230482
Mine, too, was much worse than that on my wifes N.A. 2.0 FSI. Afterwards, it was noticably smoother at idle, but certainly pulled harder at the top end - the buildup on the backs of the valves blocks a suprising amount of the port area!
I was installing some new monitoring equipment in our Endoscopy Suite a couple of weeks back, and a nurse said to make sure they had enough room to rotate the bed 180 degrees, in case they were doing "both ends" in one session...
... I replied "I hope you wipe the scope in between."... coz I bet they never hear that one... :D
