Results 1 to 2 of 2
Thread: 2006 Audi A3 - BPY 200,000 mile service
    16.4905 S, 151.7375 W
    This is a write up of last weeks work of my wife's 2006 Audi A3 BPY, NAR spec (with about 196,000 miles). This all started with an oil leak repair and it turned into a 'might as well' repair job.
    Hopefully this can help others in the future, please feel free to share and add any experiences on the BPY engine you may have had.
    Click on an image, most will have a larger version open in a new window.
    As I was saying, I was in the process of replacing the Oil Filter Housing (06F 115 397H), since last year I had replaced the two gaskets and I suspected the housing was the cause now.
    This time around I decided to gain access to the Oil Filter Housing by removing the intake manifold (instead of pulling the front end), when I pulled the High Pressure Fuel Pump (HPFP) I found this, a failed Fuel Pump Tappet (06D109309C).
    And I found that both the Intake Camshaft (06F109101J) and High Pressure Fuel Pump (06F127025M) were damaged.
    When I removed the intake manifold, I was not surprised when I saw this,
    and
    Nasty as my wife said, yea, I have seen worse... This was that typically gooey, sticky mess these engines are know for, I glad I pulled the intake, time to clean it up.
    The best way I have found to clean the buildup with in the intake ports is to first scrap loose the larger deposit areas. I use a modified pick tool, like a dental scaler tool. Then I used this handheld soda blaster to get the intakes like new!
    I used about 10lbs of medium grit blasting soda (sodium bicarbonate). I chose this over walnut shell due to the ability to clean up afterwards with soap and water. Be sure to seal/tape off any sensitive areas, I do this outside and use a shop vacuum next to the intake port to catch as much material I can, still makes a bit of a mess.
    You can buy the 3D printed adapters , I was too lazy and wanted to get it done!
    Good as new!!
    - I use shop air to remove as much as I can in the ports and in the engine bay.
    I also cleaned the runner plates and inside the intake manifold, lots of buildup in there too. I did NOT use it on the Throttle Body, just some cleaner and a rag works fine.
    In addition to cleaning the intake, replacing the intake camshaft, HPFP, Cam tappet, oil filter housing, I replaced the leaking coolant flange and the coolant pipe that I broke (has a small/weak hose fitting) and the cracked vacuum line to the brake booster. If the vehicle has any lean codes and the breather is okay, check this vacuum line, if could be cracked!!! Mine was!
    The timing belt replacement was due, so that along with the water pump, tensioner and rollers was also done. And topped it off with the rest of the 35K style major service.
    A few months ago I had replaced the crankcase breather valve and gasket replace, so I will include the latest part numbers below (it has superseded like 9 times, from an 'F' to an 'N').
    Prior to these repairs this vehicle did have a history of fault codes, see Auto-Scan below.
    P2187 - Bank 1; System too Lean at Idle
    P119A - Fuel Pressure Sensor (G247) : Malfunction
    ...and sometimes this code would show up and then clear
    P0011 - Bank 1: Camshaft A (Intake): Retard Setpoint not Reached (Over-Advanced)
    I also have an After Auto-Scan and a controller channel map of the [01-Engine] for ref.
    Important!: If you ever take off the Camshaft Chain cover housing, there are three square rings that should be inspected, one of mine was broken and a piece was missing.
    Also there is a tiny oil screen in this cover that should be removed and cleaned, I found a few metal flecks, nothing serious.
    The N205-Camshaft Adjuster Valve was also replaced, just in case
    Here is a break down of all the parts used and their list parts from Audi Parts https://parts.audiusa.com
    Part Number	Description						MSRP Price as of posting
    Oil Leak parts:
    06F115397J 	Oil filter housing					list $273.33
    Camshaft replacement parts:
    06F109101J 	Engine Camshaft 					list $373.00
    038103085C	Exhaust Camshaft Seal					list $12.03
    036103113A	Sealing Cap (Intake Cam)				list $12.00
    06F127025M 	Direct Injection High Pressure Fuel Pump 		list $491.67
    06D109309C 	Fuel Pump Tappet 					list $58.33
    06D109229B 	Engine Timing Chain 					list $170.00
    06D103121B 	Engine Timing Cover Gasket 				list $12.84
    06F109217A 	Engine Timing Chain Tensioner 				list $178.33
    06F103483D 	Engine Valve Cover Gasket 				list $36.20
    06F109257C 	Engine Variable Timing Solenoid 			list $216.67
    06E906051K	Fuel Pressure Sensor					list $71.67
    WHT000285C	Banjo Bolt						list $11.14
    D154103A1		Sealant						list $100.00
    06F198107A	Camshaft Adjuster Ring Set				list $71.67
    Timing Belt replacement parts:
    06F198119A	Timing Belt Repair Kit					list $343.33
    	(Timing Belt, Idler, Roller and Tensioner)
    06F121011	Coolant Pump						list $103.33
    Misc failed and/or 'might as well' parts:
    1K0612041GN	Vacuum pipe						list $78.33
    1K0121087H	Coolant tube						list $15.70
    06F121132H	Coolant Flange						list $41.80
    Ref Parts:
    06F129101N	Crankcase Vent Valve.					list $71.67
    06F103483E	Vent Valve Gasket					list $24.45
    Here is a before and after Auto-Scan
    Before
    Monday,04,February,2019,08:39:33:23046
    VCDS Version: 19.1.0.0 (x64)  HEX-NET CB: 0.4451.4
    Data version: 20190131 DS301.0
    VIN: WAUMF78P86A065608   License Plate:
    Chassis Type: 8P (1K0)
    Scan: 01 02 03 08 09 0F 15 16 17 19 25 42 44 46 47 52 56 62 72
    VIN: WAUMF78P86A065608   Mileage: 313800km-194986miles
       Part No SW: 8P0 907 115 B    HW: 8P0 907 115 B
       Component: 2.0l R4/4V TFSI     0080
       Revision: --H10---    Serial number: AUX7Z0E8FN6015
       Coding: 0103010A1C070160
       Shop #: WSC 66565 257 00032
       VCID: B12A525B2873DCC1A0-80E4
    008583 - Bank 1; System too Lean at Idle
                   P2187 - 004 -  - MIL ON
                        Fault Status: 11100100
                        Fault Frequency: 9
                        Mileage: 312811 km
                        Date: 2018.12.26
                        Time: 16:26:02
                        RPM: 765 /min
                        Load: 11.8 %
                        Temperature: 96.0C
                        Temperature: 42.0C
                        Absolute Pres.: 980.0 mbar
                        Voltage: 14.224 V
    004506 - Fuel Pressure Sensor (G247)
                   P119A - 001 - Malfunction
                        Fault Status: 01100001
                        Mileage: 313064 km
                        Date: 2019.01.02
                        Time: 15:16:25
                        RPM: 831 /min
                        Load: 12.2 %
                        Temperature: 65.0C
                        Temperature: 9.0C
                        Absolute Pres.: 990.0 mbar
                        Voltage: 14.351 V
       Part No SW: 02E 300 042 Q    HW: 02E 927 770 AE
       Component: GSG DSG         070 0926
       Revision: 04507000    Serial number: 00000508130136
       Shop #: WSC 06314 000 00000
       VCID: A10AA21B78936C4130-80F4
    Address 03: ABS Brakes        Labels:. 1K0-614-517-MK60AT.clb
       Part No SW: 1K0 614 517 R    HW: 1K0 614 517 R
       Component: ESP FRONT MK60-AT   0103
       Revision: 00T12001
       Coding: 0053890
       VCID: B6206147C11DFBF9F5-80E2
       Part No SW: 8P0 820 043 H    HW: 8P0 820 043 H
       Component: KlimavollautomatH17 0200
       Revision: 236272      Serial number: 8P0820043H
    Address 09: Cent. Elect.        Labels:. 8P0-907-279-30-H.lbl
       Part No SW: 8P0 907 279 P    HW: 8P0 907 279 P
       Component: Bordnetz-SG     H54 2903
       Revision: 00H54000    Serial number: 00000008988052
       Coding: 858C4F80C014100000181800180000000009FE175C110000000000000000
       Shop #: WSC 29680 444 06830
       VCID: CAD825B7A5E58F1981-809E
       Subsystem 1 - Part No: 8P1 955 119 B  Labels: 1KX-955-119.CLB
       Component: Wischer AU350   H01 0130
       Coding: 00062736
       Shop #: WSC 29680
                        Fault Status: 01111100
                        Reset counter: 144
                        Mileage: 312811 km
                        Date: 2018.12.28
                        Time: 12:56:00
                        Voltage: 14.10 V
    01800 - Light Switch (E1)
                        Reset counter: 145
                        Mileage: 313673 km
                        Date: 2019.01.25
                        Time: 18:13:00
                        Voltage: 14.05 V
    01598 - Drive Battery Voltage
                000 -  -  - Intermittent
                        Reset counter: 177
                        Mileage: 313519 km
                        Date: 2019.01.19
                        Time: 17:28:00
                        Voltage: 14.05 V
       Part No SW: 8E0 035 593 D    HW: 8E0 035 593 D
       Component: SDAR SIRIUS     H03 0060
       Revision: 00000000    Serial number: AUZ4Z7E3015413
       VCID: AA18453705A5AF1961-80FE
    Address 15: Airbags        Labels: 8P0-959-655-94.lbl
       Part No SW: 8P0 959 655 A    HW: 8P0 959 655 A
       Component:    Airbag 9.41  H10 3250
       Revision: 91H10325    Serial number: 0035W0007NJ3
       Coding: 0032605
       VCID: C0CC079F93D945495F-8094
       Subsystem 1 - Part No: 8P0 910 339
       Component: BF-Gewichtsens. 01  0020
       Serial number: 6332DRB4021C11A9J
       Coding: 00032605
       Subsystem 2 - Serial number: 6342DRB4021B872ET
       Subsystem 3 - Serial number: 63528RB400A6DFD2$
       Subsystem 4 - Serial number: 63628RB400A9A63FY
       Subsystem 5 - Serial number: 63729RB400A8F707U
       Subsystem 6 - Serial number: 63829RB400A8F894
    Address 16: Steering wheel        Labels: 8P0-953-549-F.lbl
       Part No SW: 8P0 953 549 F    HW: 8P0 953 549 F
       Component: J0527           H34 0070
       Coding: 0012122
       VCID: C1CA029B98D34C4150-8094
       Component: E0221           H07 0080
       Part No SW: 8P0 920 981 E    HW: 8P0 920 981 E
       Component: KOMBIINSTR. VDO H80 0410
       Revision: D03         Serial number: 2248ED03002877
       Coding: 0002253
       Shop #: WSC 06830 444 29680
       VCID: BA387577F5051F9911-80EE
       Part No SW: 1K0 907 530 F    HW: 1K0 907 951
       Component: Gateway         H10 0120
       Revision:   H10       Serial number: 28001058308388
       Coding: 3F3F0362072102
       Revision: D03         Serial number: AUX7Z0E8FN6015
       Shop #: WSC 07315 444 12625
    Address 42: Door Elect, Driver        Labels: 8P0-959-801-MIN2.lbl
       Part No: 8P0 959 801 H
       Component: Tuer-SG         020 0070
       Coding: 0001177
       Part No: 1K1 909 144 J
       Component: EPS_ZFLS Kl.5   D04 1606
       VCID: B2285D572D75E7D9D9-80E6
       Part No: 8P0 959 433 D
       Component: 02 KSG          H04 0050
       Coding: 92C003582D6C850FC88F445300
       Shop #: WSC 05089 444 29680
       VCID: BD327E6BE42B28A134-80E8
       Component: Neigungssensor  005 0003
       Part No SW: 8P4 035 382     HW: 8P4 035 382
       Component: AB2 SUBWOOFERBOXH04 0180
       Revision: 00003       Serial number: 30674526060926
       VCID: F1AA925BE8F39CC1E0-80A4
    Address 52: Door Elect, Pass.        Labels: 8P0-959-802-MIN2.lbl
       Part No: 8P0 959 802 H
       Coding: 0001177
    Address 56: Radio        Labels: 8P0-035-1xx-56.lbl
       Part No SW: 8P0 035 186 K    HW: 8P0 035 186 K
       Component: concert II US   H52 0460
       Revision:      04S    Serial number: AUZ5Z6E6020052
       Coding: 0101005
       Shop #: WSC 65336 004 00000
    00878 - Connection to Speaker Front Left
                        Fault Frequency: 161
                        Reset counter: 144
                        Mileage: 307257 km
                        Date: 2018.10.01
                        Time: 21:43:56
    Address 62: Door, Rear Left        Labels: 8P4-959-801.lbl
       Part No: 8P4 959 801 D
       Component: Tuer-SG         020 0060
       Coding: 0001176
    Address 72: Door, Rear Right        Labels: 8P4-959-802.lbl
       Part No: 8P4 959 802 D
       Coding: 0001176
    End----------(Elapsed Time: 01:20, VBatt start/end: 14.5V/14.5V)-----------
    After:
    Friday,26,April,2019,16:13:44:30091
    VCDS Version: 19.1.2.0 (x64)  HEX-V2 CB: 0.4503.4
    Mileage: 316120km-196427mi   Repair Order:
    VIN: WAUMF78P86A065608   Mileage: 316120km-196427miles
       VCID: 313C1FACFD2E023F17D-8064
                        Temperature: -40.0C
                        Temperature: -40.0C
                        Absolute Pres.: 0.0 mbar
                        Voltage: 0.000 V
       VCID: 211CEFECADCEB2BF87D-8074
       Revision: 00T12001
       Coding: 0053890
       VCID: 36362CB01440250742F-8062
       VCID: 4ACE684070B851E7367-801E
       Coding: 00062736
       Shop #: WSC 29680
       VCID: 2A0E08C0D0F871E7D67-807E
       Coding: 0032605
       VCID: 40DA4A6846849BB7E83-8014
       Coding: 00032605
       Coding: 0012122
       VCID: 41DC4F6C4D8E92BFE7D-8014
       Coding: 0002253
       VCID: 3A2E38802058C167A67-806E
       Coding: 0001177
       VCID: 323E10A0F82839276E7-8066
       VCID: 3D24339C3176F65F835-8068
       VCID: 71BCDFAC3DAE423F57D-8024
       Coding: 0001177
       Coding: 0101005
       Coding: 0001176
       Coding: 0001176
    End----------(Elapsed Time: 01:07, VBatt start/end: 14.0V/14.0V)-----------
    [01] Controller Channel map - MVBs
    ;SW:8P0-907-115-B   HW:8P0-907-115-B ---  Engine
    ;Component:2.0l R4/4V TFSI     0080, Coding:0103010A1C070160
    ;Friday,26,April,2019,16:14:30:30091
    ;VCDS Version: Beta 19.1.2 (x64)  Data version: 20190131 DS301.0
    ;VCID: 313C1FACFD2E023F17D-8064
    1,0,,
    1,1,,,
    ;720 /min,,
    1,2,,,
    ;91.0C,,
    1,3,,,
    ;2.7 %,,
    1,4,,,
    ;10111111,,
    2,0,,
    2,1,,,
    ;720 /min,,
    2,2,,,
    ;15.8 %,,
    2,3,,,
    ;0.77 ms,,
    2,4,,,
    ;2.25 g/s,,
    3,0,,
    3,1,,,
    ;760 /min,,
    3,2,,,
    ;2.25 g/s,,
    3,3,,,
    ;0.8 %,,
    3,4,,,
    ;0.8 ATDC,,
    4,0,,
    4,1,,,
    ;760 /min,,
    4,2,,,
    ;14.006 V,,
    4,3,,,
    ;90.0C,,
    4,4,,,
    ;48.0C,,
    5,0,,
    5,1,,,
    ;760 /min,,
    5,2,,,
    ;15.0 %,,
    5,3,,,
    ;0.0 km/h,,
    5,4,,,
    ;Idle,,
    6,0,,
    6,1,,,
    ;760 /min,,
    6,2,,,
    ;15.0 %,,
    6,3,,,
    ;48.0C,,
    6,4,,,
    ;-3.9 %,,
    7,0,,
    7,1,,,
    ;760 /min,,
    7,2,,,
    ;15.0 %,,
    7,3,,,
    ;91.0C,,
    7,4,,,
    ;00000001,,
    9,0,,
    9,1,,,
    ;57.5 mm,,
    9,2,,,
    ;40.0 mm,,
    9,3,,,
    ;1233,,
    9,4,,,
    ;18,,
    10,0,,
    10,1,,,
    ;760 /min,,
    10,2,,,
    ;15.0 %,,
    10,3,,,
    ;0.8 %,,
    10,4,,,
    ;0.0 BTDC,,
    11,0,,
    11,1,,,
    ;720 /min,,
    11,2,,,
    ;91.0C,,
    11,3,,,
    ;48.0C,,
    11,4,,,
    ;0.8 BTDC,,
    14,0,,
    14,1,,,
    ;760 /min,,
    14,2,,,
    ;15.0 %,,
    14,3,,,
    ;0,,
    14,4,,,
    ;Enabled,,
    15,0,,
    15,1,,,
    ;0,,
    15,2,,,
    ;0,,
    15,3,,,
    ;0,,
    15,4,,,
    ;Enabled,,
    16,0,,
    16,1,,,
    ;0,,
    16,2,,,
    16,3,,,
    16,4,,,
    ;Enabled,,
    18,0,,
    18,1,,,
    ;0 /min,,
    18,2,,,
    ;0 /min,,
    18,3,,,
    ;0.0 %,,
    18,4,,,
    ;0.0 %,,
    20,0,,
    20,1,,,
    ;0.0KW,,
    20,2,,,
    ;0.0KW,,
    20,3,,,
    ;0.0KW,,
    20,4,,,
    ;0.0KW,,
    22,0,,
    22,1,,,
    ;760 /min,,
    22,2,,,
    ;15.0 %,,
    22,3,,,
    ;0.0KW,,
    22,4,,,
    ;0.0KW,,
    23,0,,
    23,1,,,
    ;760 /min,,
    23,2,,,
    ;15.0 %,,
    23,3,,,
    ;0.0KW,,
    23,4,,,
    ;0.0KW,,
    26,0,,
    26,1,,,
    ;0.312 V,,
    26,2,,,
    ;0.156 V,,
    26,3,,,
    ;0.156 V,,
    26,4,,,
    ;0.000 V,,
    28,0,,
    28,1,,,
    ;720 /min,,
    28,2,,,
    ;15.0 %,,
    28,3,,,
    ;91.0C,,
    28,4,,,
    ;Test OFF,,
    30,0,,
    30,1,,,
    ;   00111,,
    30,2,,,
    ;    0110,,
    30,3,,,
    30,4,,,
    31,0,,
    31,1,,,
    ;0.99,,
    31,2,,,
    ;1.00,,
    31,3,,,
    31,4,,,
    32,0,,
    32,1,,,
    ;3.0 %,,
    32,2,,,
    ;-0.4 %,,
    32,3,,,
    32,4,,,
    33,0,,
    33,1,,,
    ;-1.6 %,,
    33,2,,,
    ;1.48 V,,
    33,3,,,
    33,4,,,
    34,0,,
    34,1,,,
    ;720 /min,,
    34,2,,,
    ;342.0C,,
    34,3,,,
    ;0.69,,
    34,4,,,
    ;Test OFF,,
    36,0,,
    36,1,,,
    ;0.12 V,,
    36,2,,,
    ;Test ON,,
    36,3,,,
    36,4,,,
    37,0,,
    37,1,,,
    ;15.0 %,,
    37,2,,,
    ;0.12 V,,
    37,3,,,
    ;0.000,,
    37,4,,,
    ;Test OFF,,
    41,0,,
    41,1,,,
    ;300 ohms,,
    41,2,,,
    ;41.4 %,,
    41,3,,,
    41,4,,,
    ;Htg. S2 ON,,
    43,0,,
    43,1,,,
    ;720 /min,,
    43,2,,,
    ;342.0C,,
    43,3,,,
    ;0.12 V,,
    43,4,,,
    ;B1-S2 OK,,
    46,0,,
    46,1,,,
    ;760 /min,,
    46,2,,,
    ;102.0C,,
    46,3,,,
    ;2.50,,
    46,4,,,
    ;Test OFF,,
    50,0,,
    50,1,,,
    ;760 /min,,
    50,2,,,
    ;760 /min,,
    50,3,,,
    ;A/C-Low,,
    50,4,,,
    ;Compr.OFF,,
    51,0,,
    51,1,,,
    ;740 /min,,
    51,2,,,
    ;760 /min,,
    51,3,,,
    ;0,,
    51,4,,,
    ;14.100 V,,
    52,0,,
    52,1,,,
    ;750 /min,,
    52,2,,,
    ;760 /min,,
    52,3,,,
    ;A/C-Low,,
    52,4,,,
    ;OFF,,
    53,0,,
    53,1,,,
    ;750 /min,,
    53,2,,,
    ;760 /min,,
    53,3,,,
    ;14.100 V,,
    53,4,,,
    ;43.9 %,,
    54,0,,
    54,1,,,
    ;750 /min,,
    54,2,,,
    ;Idle,,
    54,3,,,
    ;0.0 %,,
    54,4,,,
    ;0.8 %,,
    55,0,,
    55,1,,,
    ;760 /min,,
    55,2,,,
    ;0.0 %,,
    55,3,,,
    ;-2.9 %,,
    55,4,,,
    ;   00000,,
    56,0,,
    56,1,,,
    ;760 /min,,
    56,2,,,
    ;760 /min,,
    56,3,,,
    ;0.0 %,,
    56,4,,,
    ;   00000,,
    57,0,,
    57,1,,,
    ;760 /min,,
    57,2,,,
    ;760 /min,,
    57,3,,,
    ;Compr.OFF,,
    57,4,,,
    ;0.7 Nm,,
    58,0,,
    58,1,,,
    ;770 /min,,
    58,2,,,
    ;15.0 %,,
    58,3,,,
    58,4,,,
    60,0,,
    60,1,,,
    ;11.3 %,,
    60,2,,,
    ;88.7 %,,
    60,3,,,
    ;4,,
    60,4,,,
    ;ADP. O.K.,,
    61,0,,
    61,1,,,
    ;720 /min,,
    61,2,,,
    ;14.100 V,,
    61,3,,,
    ;0.8 %,,
    61,4,,,
    ;   00000,,
    62,0,,
    62,1,,,
    ;11.3 %,,
    62,2,,,
    ;88.7 %,,
    62,3,,,
    ;14.8 %,,
    62,4,,,
    ;7.4 %,,
    63,0,,
    63,1,,,
    ;14.8 %,,
    63,2,,,
    ;88.3 %,,
    63,3,,,
    ;Not Oper.,,
    63,4,,,
    ;ADP. O.K.,,
    64,0,,
    64,1,,,
    ;0.540 V,,
    64,2,,,
    ;4.580 V,,
    64,3,,,
    ;0.820 V,,
    64,4,,,
    ;4.300 V,,
    66,0,,
    66,1,,,
    ;0.0 km/h,,
    66,2,,,
    ;00001000,,
    66,3,,,
    ;0.0 km/h,,
    66,4,,,
    ;00000000,,
    67,0,,
    67,1,,,
    67,2,,,
    ;00001000,,
    67,3,,,
    67,4,,,
    68,0,,
    68,1,,,
    ;720 /min,,
    68,2,,,
    ;15.0 %,,
    68,3,,,
    ;0,,
    68,4,,,
    ;TC Open,,
    70,0,,
    70,1,,,
    ;34.8 %,,
    70,2,,,
    ;0.0 %,,
    70,3,,,
    ;92.2 %,,
    70,4,,,
    ;Test OFF,,
    71,0,,
    71,1,,,
    ;Reed Closed,,
    71,2,,,
    ;Abort,,
    71,3,,,
    71,4,,,
    ;Test OFF,,
    79,0,,
    79,1,,,
    ;720 /min,,
    79,2,,,
    ;15.0 %,,
    79,3,,,
    ;OFF,,
    79,4,,,
    80,0,,
    80,1,,,
    ;BPG-810 01.09.05 --H10--- 1889 0234,,
    81,0,,
    81,1,,,
    ;WAUMF78P86A065608 AUX7Z0E8FN6015 <     >,,
    82,0,,
    82,1,,,
    ;6656525700032 <      >        < > <>,,
    83,0,,
    83,1,,,
    84,0,,
    84,1,,,
    85,0,,
    85,1,,,
    ;316120 km,,
    85,2,,,
    ;25,,
    85,3,,,
    ;565,,
    85,4,,,
    ;1615,,
    86,0,,
    86,1,,,
    ;00000000,,
    86,2,,,
    ;00101101,,
    86,3,,,
    ;00010111,,
    86,4,,,
    87,0,,
    87,1,,,
    ;00000000,,
    87,2,,,
    ;00000000,,
    87,3,,,
    ;00000000,,
    87,4,,,
    88,0,,
    88,1,,,
    ;11001000,,
    88,2,,,
    ;01101001,,
    88,3,,,
    ;10011000,,
    88,4,,,
    89,0,,
    89,1,,,
    ;0 km,,
    89,2,,,
    ;OK,,
    89,3,,,
    89,4,,,
    91,0,,
    91,1,,,
    ;760 /min,,
    91,2,,,
    ;5.9 %,,
    91,3,,,
    ;28.0KW,,
    91,4,,,
    ;28.0KW,,
    93,0,,
    93,1,,,
    ;720 /min,,
    93,2,,,
    ;15.0 %,,
    93,3,,,
    ;0.0KW,,
    93,4,,,
    94,0,,
    94,1,,,
    ;720 /min,,
    94,2,,,
    ;27.5KW,,
    94,3,,,
    ;Test OFF,,
    94,4,,,
    99,0,,
    99,1,,,
    ;760 /min,,
    99,2,,,
    ;91.0C,,
    99,3,,,
    ;-1.2 %,,
    99,4,,,
    ;O2-Reg.ON,,
    100,0,,
    100,1,,,
    ;00000000,,
    100,2,,,
    ;91.0C,,
    100,3,,,
    ;230.4 s,,
    100,4,,,
    ;01010001,,
    101,0,,
    101,1,,,
    ;720 /min,,
    101,2,,,
    ;15.0 %,,
    101,3,,,
    ;0.77 ms,,
    101,4,,,
    ;2.19 g/s,,
    102,0,,
    102,1,,,
    ;720 /min,,
    102,2,,,
    ;91.0C,,
    102,3,,,
    ;48.0C,,
    102,4,,,
    ;0.77 ms,,
    103,0,,
    103,1,,,
    ;4972.5 mbar,,
    103,2,,,
    ;-267,,
    103,3,,,
    ;362,,
    103,4,,,
    ;ADP. O.K.,,
    104,0,,
    104,1,,,
    ;82.0C,,
    104,2,,,
    ;0.0 %,,
    104,3,,,
    ;0.0 %,,
    104,4,,,
    ;0.0 %,,
    106,0,,
    106,1,,,
    ;49.9 bar,,
    106,2,,,
    ;51.0 %,,
    106,3,,,
    106,4,,,
    ;655.35 s,,
    107,0,,
    107,1,,,
    ;720 /min,,
    107,2,,,
    ;0.8 %,,
    107,3,,,
    107,4,,,
    ;Test OFF,,
    110,0,,
    110,1,,,
    ;720 /min,,
    110,2,,,
    ;91.0C,,
    110,3,,,
    ;0.77 ms,,
    110,4,,,
    ;0.8 %,,
    111,0,,
    111,1,,,
    ;0.0 %,,
    111,2,,,
    ;0.6 %,,
    111,3,,,
    ;0.0 %,,
    111,4,,,
    ;0.0 %,,
    112,0,,
    112,1,,,
    112,2,,,
    ;0.0 %,,
    112,3,,,
    ;444.0C,,
    112,4,,,
    ;444.0C,,
    113,0,,
    113,1,,,
    ;760 /min,,
    113,2,,,
    ;15.0 %,,
    113,3,,,
    ;0.8 %,,
    113,4,,,
    ;975.0 mbar,,
    114,0,,
    114,1,,,
    ;116.5 %,,
    114,2,,,
    ;116.5 %,,
    114,3,,,
    ;15.0 %,,
    114,4,,,
    ;0.0 %,,
    115,0,,
    115,1,,,
    ;760 /min,,
    115,2,,,
    ;15.0 %,,
    115,3,,,
    ;290.0 mbar,,
    115,4,,,
    ;970.0 mbar,,
    116,0,,
    116,1,,,
    ;760 /min,,
    116,2,,,
    ;0.0 %,,
    116,3,,,
    ;0.0 %,,
    116,4,,,
    ;0.0 %,,
    117,0,,
    117,1,,,
    ;760 /min,,
    117,2,,,
    ;0.0 %,,
    117,3,,,
    ;0.8 %,,
    117,4,,,
    ;290.0 mbar,,
    118,0,,
    118,1,,,
    ;760 /min,,
    118,2,,,
    ;48.0C,,
    118,3,,,
    ;0.0 %,,
    118,4,,,
    ;970.0 mbar,,
    119,0,,
    119,1,,,
    ;720 /min,,
    119,2,,,
    ;0.0 %,,
    119,3,,,
    ;0.0 %,,
    119,4,,,
    ;970.0 mbar,,
    120,0,,
    120,1,,,
    ;720 /min,,
    120,2,,,
    ;399.8 Nm,,
    120,3,,,
    ;7.8 Nm,,
    120,4,,,
    ;ASR OFF,,
    122,0,,
    122,1,,,
    ;720 /min,,
    122,2,,,
    ;399.8 Nm,,
    122,3,,,
    ;7.8 Nm,,
    122,4,,,
    ;No Torq Red,,
    125,0,,
    125,1,,,
    ;Transm. 1,,
    125,2,,,
    ;ABS 1,,
    125,3,,,
    ;Instruments 1,,
    125,4,,,
    ;HVAC 1,,
    126,0,,
    126,1,,,
    126,2,,,
    126,3,,,
    ;Airbag 1,,
    126,4,,,
    ;Cent Elec 1,,
    127,0,,
    127,1,,,
    127,2,,,
    127,3,,,
    ;St. Wheel 1,,
    127,4,,,
    129,0,,
    129,1,,,
    129,2,,,
    ;Oil Level 1,,
    129,3,,,
    ;Gateway 1,,
    129,4,,,
    130,0,,
    130,1,,,
    ;91.0C,,
    130,2,,,
    ;51.0C,,
    130,3,,,
    130,4,,,
    131,0,,
    131,1,,,
    ;91.0C,,
    131,2,,,
    131,3,,,
    ;51.0C,,
    131,4,,,
    132,0,,
    132,1,,,
    ;90.0C,,
    132,2,,,
    ;40.0C,,
    132,3,,,
    132,4,,,
    ;00000101,,
    134,0,,
    134,1,,,
    ;83.0C,,
    134,2,,,
    ;23.0C,,
    134,3,,,
    ;48.0C,,
    134,4,,,
    ;91.0C,,
    135,0,,
    135,1,,,
    ;51.0C,,
    135,2,,,
    ;9.8 %,,
    135,3,,,
    135,4,,,
    136,0,,
    136,1,,,
    136,2,,,
    136,3,,,
    ;Pump off,,
    136,4,,,
    ;OFF,,
    137,0,,
    137,1,,,
    ;A/C-Low,,
    137,2,,,
    ;Compr.OFF,,
    137,3,,,
    ;8.0 bar,,
    137,4,,,
    ;0.0 %,,
    138,0,,
    138,1,,,
    ;82.0C,,
    138,2,,,
    ;2.22 g/s,,
    138,3,,,
    ;0.0 km/h,,
    138,4,,,
    ;Test OFF,,
    139,0,,
    139,1,,,
    ;76.0C,,
    139,2,,,
    ;5.4 kg,,
    139,3,,,
    ;12.0 kg,,
    139,4,,,
    ;Test OFF,,
    140,0,,
    140,1,,,
    ;51.2,,
    140,2,,,
    ;-30.4,,
    140,3,,,
    ;49.9 bar,,
    140,4,,,
    ;      01,,
    141,0,,
    141,1,,,
    ;-0.14 bar,,
    141,2,,,
    ;283,,
    141,3,,,
    ;6707,,
    141,4,,,
    ;48.6 bar,,
    142,0,,
    142,1,,,
    ;0.000 V,,
    142,2,,,
    ;1.500 V,,
    142,3,,,
    ;0,,
    142,4,,,
    ;ADP. O.K.,,
    143,0,,
    143,1,,,
    ;760 /min,,
    143,2,,,
    ;15.0 %,,
    143,3,,,
    ;0.0 %,,
    143,4,,,
    ;00000001,,
    166,0,,
    166,1,,,
    ;1.00,,
    166,2,,,
    ;0.10 V,,
    166,3,,,
    ;2.69 g/s,,
    166,4,,,
    ;Test OFF,,
    200,0,,
    200,1,,,
    ;0,,
    200,2,,,
    ;Automatic,,
    200,3,,,
    ;Test OFF,,
    200,4,,,
    201,0,,
    201,1,,,
    ;316120 km,,
    201,2,,,
    ;290 km,,
    201,3,,,
    ;280 km,,
    201,4,,,
    ;0 km,,
    202,0,,
    202,1,,,
    ;      00,,
    202,2,,,
    ;0.00 s,,
    202,3,,,
    ;0.0 s,,
    202,4,,,
    ;0,,
    203,0,,
    203,1,,,
    ;11,,
    203,2,,,
    ;1.00,,
    203,3,,,
    ;0.8 ATDC,,
    203,4,,,
    ;00000010,,
    204,0,,
    204,1,,,
    ;-1.2 %,,
    204,2,,,
    ;0.77 ms,,
    204,3,,,
    ;0.00 ms,,
    204,4,,,
    ;0.10 V,,
    205,0,,
    205,1,,,
    ;0.0 %,,
    205,2,,,
    ;0.0 %,,
    205,3,,,
    ;27.5KW,,
    205,4,,,
    ;50.6 bar,,
    206,0,,
    206,1,,,
    ;2.08 g/s,,
    206,2,,,
    ;2.08 g/s,,
    206,3,,,
    ;1.05,,
    206,4,,,
    ;970.0 mbar,,
    207,0,,
    207,1,,,
    ;720 /min,,
    207,2,,,
    ;15.0 %,,
    207,3,,,
    207,4,,,
    208,0,,
    208,1,,,
    ;15.0 %,,
    208,2,,,
    ;15.0 %,,
    208,3,,,
    ;0,,
    208,4,,,
    ;HL,,
    209,0,,
    209,1,,,
    ;-2.9 %,,
    209,2,,,
    ;-2.5 %,,
    209,3,,,
    ;-1.4 %,,
    209,4,,,
    ;0.8 %,,
    210,0,,
    210,1,,,
    ;0,,
    210,2,,,
    210,3,,,
    210,4,,,
    211,0,,
    211,1,,,
    ;760 /min,,
    211,2,,,
    ;0.0 %,,
    211,3,,,
    ;0.4 %,,
    211,4,,,
    ;970.0 mbar,,
    212,0,,
    212,1,,,
    ;0.0KW,,
    212,2,,,
    ;0.0KW,,
    212,3,,,
    ;100.0 %,,
    212,4,,,
    ;100.0 %,,
    213,0,,
    213,1,,,
    ;720 /min,,
    213,2,,,
    ;15.0 %,,
    213,3,,,
    ;1.00,,
    213,4,,,
    ;1.00,,
    214,0,,
    214,1,,,
    ;1.00,,
    214,2,,,
    ;1.00,,
    214,3,,,
    ;1.00,,
    214,4,,,
    ;444.0C,,
    215,0,,
    215,1,,,
    ;720 /min,,
    215,2,,,
    ;15.0 %,,
    215,3,,,
    ;970.0 mbar,,
    215,4,,,
    ;0.0KW,,
    216,0,,
    216,1,,,
    ;-1.5KW,,
    216,2,,,
    ;-1.5KW,,
    216,3,,,
    ;-1.5KW,,
    216,4,,,
    ;-1.5KW,,
    217,0,,
    217,1,,,
    ;-1.5KW,,
    217,2,,,
    ;-3.9 %,,
    217,3,,,
    ;116.5 %,,
    217,4,,,
    ;First Map,,
    218,0,,
    218,1,,,
    ;38.3 %,,
    218,2,,,
    ;6.3 %,,
    218,3,,,
    ;0.0 %,,
    218,4,,,
    ;15.7 %,,
    219,0,,
    219,1,,,
    ;14.9 %,,
    219,2,,,
    ;  100000,,
    219,3,,,
    ;1.33 g/s,,
    219,4,,,
    ;85C,,
    220,0,,
    220,1,,,
    ;2.08 g/s,,
    220,2,,,
    ;1.00,,
    220,3,,,
    ;1.04,,
    220,4,,,
    ;1.33 g/s,,
    221,0,,
    221,1,,,
    ;00000000,,
    221,2,,,
    ;00000000,,
    221,3,,,
    ;00000000,,
    221,4,,,
    ;00000000,,
    222,0,,
    222,1,,,
    ;0.00 s,,
    222,2,,,
    ;20.00 s,,
    222,3,,,
    ;2.05 s,,
    222,4,,,
    ;Test OFF,,
    223,0,,
    223,1,,,
    ;14,,
    223,2,,,
    ;3,,
    223,3,,,
    ;11,,
    223,4,,,
    ;5,,
    224,0,,
    224,1,,,
    ;00000011,,
    224,2,,,
    ;00000111,,
    224,3,,,
    ;00010011,,
    224,4,,,
    ;255,,
    225,0,,
    225,1,,,
    ;0,,
    225,2,,,
    225,3,,,
    225,4,,,
    226,0,,
    226,1,,,
    ;1.00,,
    226,2,,,
    ;0,,
    226,3,,,
    ;1.48 V,,
    226,4,,,
    ;10101000,,
    227,0,,
    227,1,,,
    ;5.76 kOhm,,
    227,2,,,
    227,3,,,
    ;85C,,
    227,4,,,
    228,0,,
    228,1,,,
    ;92.0C,,
    228,2,,,
    ;49.0C,,
    228,3,,,
    ;83.0C,,
    228,4,,,
    ;23.0C,,
    229,0,,
    229,1,,,
    ;0,,
    229,2,,,
    ;27,,
    229,3,,,
    ;9,,
    229,4,,,
    ;565,,
    230,0,,
    230,1,,,
    ;49.9 bar,,
    230,2,,,
    ;50.6 bar,,
    230,3,,,
    ;-0.64 bar,,
    230,4,,,
    231,0,,
    231,1,,,
    ;4998.0 mbar,,
    231,2,,,
    ;4998.0 mbar,,
    231,3,,,
    ;51.0 %,,
    231,4,,,
    232,0,,
    232,1,,,
    ;1615,,
    232,2,,,
    ;565,,
    232,3,,,
    ;139,,
    232,4,,,
    233,0,,
    233,1,,,
    ;594,,
    233,2,,,
    ;1080,,
    233,3,,,
    ;509,,
    233,4,,,
    ;383,,
    234,0,,
    234,1,,,
    ;162,,
    234,2,,,
    ;1285,,
    234,3,,,
    ;0,,
    234,4,,,
    ;259,,
    235,0,,
    235,1,,,
    ;0.95,,
    235,2,,,
    ;-1.000,,
    235,3,,,
    ;-1.000,,
    235,4,,,
    ;11010000,,
    236,0,,
    236,1,,,
    ;38.0C,,
    236,2,,,
    ;56.0C,,
    236,3,,,
    ;29,,
    236,4,,,
    237,0,,
    237,1,,,
    ;0.00,,
    237,2,,,
    ;2.50,,
    237,3,,,
    ;0.0,,
    237,4,,,
    238,0,,
    238,1,,,
    ;92.0C,,
    238,2,,,
    ;0.4 kg,,
    238,3,,,
    ;4.0 kg,,
    238,4,,,
    ;3,,
    239,0,,
    239,1,,,
    ;1.78 g/s,,
    239,2,,,
    ;0.0 km/h,,
    239,3,,,
    ;0.00 s,,
    239,4,,,
    ;48.0C,,
    241,0,,
    241,1,,,
    ;151,,
    241,2,,,
    ;1392,,
    241,3,,,
    ;1392,,
    241,4,,,
    ;1315,,
    242,0,,
    242,1,,,
    ;1390,,
    242,2,,,
    ;555,,
    242,3,,,
    ;1173,,
    242,4,,,
    ;1279,,
    243,0,,
    243,1,,,
    ;1580,,
    243,2,,,
    ;568,,
    243,3,,,
    ;1517,,
    243,4,,,
    ;1515,,
    244,0,,
    244,1,,,
    ;121,,
    244,2,,,
    ;192,,
    244,3,,,
    ;0,,
    244,4,,,
    ;1496,,
    245,0,,
    245,1,,,
    ;0.0 %,,
    245,2,,,
    ;0,,
    245,3,,,
    ;92.0C,,
    245,4,,,
    ;10.2 %,,
    246,0,,
    246,1,,,
    ;4998.0 mbar,,
    246,2,,,
    ;4998.0 mbar,,
    246,3,,,
    ;50.2 %,,
    246,4,,,
    ;358,,
    247,0,,
    247,1,,,
    ;94.0C,,
    247,2,,,
    247,3,,,
    247,4,,,
    250,0,,
    250,1,,,
    ;945,,
    250,2,,,
    250,3,,,
    250,4,,,
    252,0,,
    252,1,,,
    ;5686.5 mbar,,
    252,2,,,
    ;5686.5 mbar,,
    252,3,,,
    ;896.0 s,,
    252,4,,,
    ;94.0C,,
    So now I have a happy A3 and a happy wife and maybe some more time to work on the next project
    Hope this has been a good read and hope this helps,
    drpeter
    Jun 2014
    Newcastle, England
    A bit of car pr0n for a Saturday morning - what could be better! Some eye-watering prices there though, Peter.
  3. Likes Uwe, DrPeter liked this post
