While driving out of a parking lot I stopped at a stop sign and the transmission went into neutral and the D indicator on the shifter started to blink. As this has happened before I shut the engine off, restarted and drove as normal. I stopped at another store and came back to the car ~20 minutes later and the same thing happened this time when I started the car. I shut it off and restarted and drove as normal. This doesn't happen all the time, but eventually after I drive the vehicle on a longer trips it will do it.
Little history with the car repairs - 2 months ago I had leaking water pump and replaced the timing belt with water pump and the Thermostat as well as the cooling fan.
Right now the car has no overheating problems. Mechanic said that the engine was not damaged from the leaking water pump. The gauge is stuck right in the middle and everything looks great.
Need help figuring out what to do to fix my vehicle. Please advice! Thanks
Monday,22,April,2019,22:31:55:42313
VCDS Version: 18.9.0.2 (x64)
VIN: 1VWCN7A35CC060811 License Plate: 7KQP428
Mileage: 380480km-236419mi Repair Order:
Chassis Type: A3-VW41 (7N0)
Scan: 01 02 03 05 08 09 15 16 17 19 25 2B 2E 36 37 42 44 46 47 4F
52 56 62 72 77
VIN: 1VWCN7A35CC060811 Mileage: 380480km-236419miles
Address 01: Engine (J623-CKRA) Labels:. 03L-906-022-CFC.clb
Part No SW: 03L 997 009 J HW: 03L 907 309 S
Component: R4 2.0l TDI H21 9982
Revision: 71H21--- Serial number:
Coding: 001D0012042400008000
Shop #: WSC 26061 444 00000
ASAM Dataset: EV_ECM20TDI01103L997009J 004005
ROD: EV_ECM20TDI01103L997009J.rod
VCID: 3B74BECFB2C0E992C0-806E
8215 - Exhaust Gas Recirculation System
P2457 00 [237] - Insufficient Cooling Performance
Mileage: 380315 km
Date: 2019.04.22
Time: 17:55:59
Engine speed: 1235.00 /min
Normed load value: 66.7 %
Vehicle speed: 28 km/h
Coolant temperature: 98 °C
Intake air temperature: 35 °C
Voltage terminal 30: 14.040 V
Sensor for engine block temperature: raw value: 98.5 °C
Exh.gas temp.sen 4: 277.5 °C
Exhaust mass flow of low-pressure EGR: 15.2 kg/h
Temp sensor for low-pressure EGR after cooler: raw value: 157.6 °C
Low-pressure EGR cooling: model temperature: 154.4 °C
Low-pressure EGR cooling: request status-Bits 0-7: 0
Low-pressure EGR cooling: request status-Bits 0-7: 1
38303 - NOx Sensor 1 Bank 1
P2201 00 [096] - Implausible Signal
Mileage: 379015 km
Date: 2019.04.14
Time: 15:00:58
Intake air temperature: 28 °C
Voltage terminal 30: 12.820 V
Unlearning counter according OBD: 38
Air mass: actual value (mg/stroke): 0.0 mg/stroke
Mean injection quantity: 0.00 mg/stroke
EGR Vacuum Regulator Solen.val.: activation: 100.00 %
NOx emission NOx sensor 1: 0 ppm
Air mass for release of NOx sensor 1 offset test: 0.0 g
Calculated efficiency of NOx conversion: 0.950
Readiness: 1 1 0 0 0
Part No SW: 02E 300 057 P HW: 02E 927 770 AL
Component: GSG DSG AG6 512 9435
Revision: 05551213 Serial number: 00001112090944
Shop #: WSC 40321 001 1048576
VCID: 26427FBB9142447A8F-8072
19143 - Unexpected / Implausible Mechanical Gear Disengagement
P2711 - 007 - - Intermittent
Fault Status: 00100111
Reset counter: 36
Mileage: 379789 km
Date: 2013.09.07
Time: 21:04:52
18172 - Transmission Temperature Monitoring
P1764 - 001 - - Intermittent
Fault Status: 00100001
Reset counter: 5
Mileage: 379960 km
Date: 2013.09.08
Time: 18:07:36
Part No SW: 1K0 907 379 BL HW: 1K0 907 379 BL
Component: ESP MK60EC1 H31 0152
Revision: 00H31001
Coding: C54BC0F5492800FAA31303E5921A0042A71000
Shop #: WSC 09003 957 00200
VCID: 7DF070D7E45427A2BE-8028
Address 05: Acc/Start Auth. (J518) Labels:| 5K0-959-434.clb
Part No SW: 5K0 959 434 B HW: 5K0 959 434
Revision: 00085000 Serial number: 0161487923
Coding: 130C0C
VCID: 346695F39F9E26EA01-8060
Part No SW: 561 907 044 H HW: 561 907 044 H
Component: Climatronic 043 0202
Revision: 00001001
Coding: 0010001012
ROD: EV_ACClimaBHBVW411_VW41.rod
VCID: 1C365D53170E8EAA29-8048
Part No SW: 5K0 937 087 AA HW: 5K0 937 087 AA
Component: BCM PQ35 H+ 121 0164
Revision: BL121001
Coding: 6F200E3B982B08D4088802013600814800710086458005F0648060009C70
VCID: 74E655F3D71E66EAC1-8020
Subsystem 1 - Part No: 1K0 955 559 AH Labels: 1K0-955-559-AG.CLB
Component: RLS 030212 05 54 0403
Coding: 06300A
010 - Open or Short to Plus
Fault Status: 01101010
Fault Frequency: 15
Reset counter: 195
Mileage: 378963 km
Date: 2013.09.04
Time: 12:57:35
Voltage: 12.00 V
Part No SW: 5C0 959 655 HW: 5C0 959 655
Component: AirbagVW10G 013 0809
Serial number: 003ENM01EMZ5
Coding: 00003548
ASAM Dataset: EV_AirbaVW10SMEVW360 A01024
ROD: EV_AirbaVW10SMEVW360.rod
VCID: 6FEC5A9FB63845323C-803A
Subsystem 1 - Part No SW: 5C6 959 339 A HW: 5C6 959 339 A
Component: BF-Gewichtss. H10 0045
Serial number: 6940000Y120000AUAB0V
Coding: 303047
Component: S.Sens.Fahr.V H01 ----
Serial number: 3572MSME326F3068ZZZ-
Component: S.Sens.Beif.V H01 ----
Serial number: 3582MSME47507466ZZZX
Serial number: 3516KSME574E1417ZZZW
Subsystem 5 - Part No SW: 5K0 959 351 A HW: 5K0 959 351 A
Serial number: 3526KSME23681F16ZZZW
Subsystem 6 - Part No SW: 5K0 959 659 A HW: 5K0 959 659 A
Serial number: 3556LSME3A201414ZZZJ
Subsystem 7 - Part No SW: 5K0 959 659 A HW: 5K0 959 659 A
Component: F.Sens.Beif H02 ----
Serial number: 3566LSME34051414ZZZH
Part No SW: 1K5 953 521 AR HW: 5K0 953 569 E
Revision: FF010040 Serial number: 20110729100513
Coding: 000A140000
ROD: EV_SMLSNGVOLWS.rod
VCID: 7DF070D7EC5427A2BE-8028
Component: E221__MFL-YVJ H06 0022
Coding: E20000
Address 17: Instruments (J285) Labels:| 5K0-920-XXX-17.clb-SRI1
Part No SW: 561 920 970 C HW: 561 920 970 C
Component: KOMBI H07 0507
Coding: 231E01
ASAM Dataset: EV_Kombi_UDS_VDD_RM09 A04093
VCID: 1A3A5B4B1D3AF09A3B-804E
Part No SW: 7N0 907 530 P HW: 1K0 907 951
Component: J533 Gateway H40 1623
Revision: H40 Serial number: 07021201290602
Coding: 461000
VCID: 3D70B0D7A4D4E7A2FE-8068
Component: IMMO H07 0507
Coding: 000007
VCID: 6ADA4B8B8DDAA01A6B-803E
Address 2B: Steer. Col. Lock (J764) Labels:* 5K0-905-861.clb
Part No SW: 5K0 905 861 A HW: 5K0 905 861 A
Component: ELV-PQ35 H20 0230
Revision: 00000000 Serial number: 11000274387004
Coding: 4900000000000000
ROD: EV_ELVMarquMPVW36X.rod
VCID: 2E52879B71B20C3A77-807A
Part No SW: 5N0 035 342 E HW: 5N0 035 342 E
Revision: A1001003 Serial number: 7661543498
VCID: 29587487405C6B02A2-807C
Part No SW: 561 959 760 HW: 561 959 760
Component: MEM-FS H04 0181
Revision: AA000000 Serial number: 00000022806321
Coding: 0000000000000000000000000000000000000000000000
VCID: 60CE29A373E6EA4AB5-8034
Address 37: Navigation (J0506) Labels:. 1T0-035-680.clb
Part No SW: 3C8 035 684 E HW: 3C8 035 684 E
Component: RNS-MID H61 3690
Revision: AB001001 Serial number: VWZ6Z7M4047073
Coding: 04090002010000A6000B
VCID: 2D50809774B477224E-8078
Fault Frequency: 45
Reset counter: 194
Mileage: 378920 km
Part No SW: 561 959 701 A HW: 3C0 959 793 C
Component: TUER-SG FT 002 0525
Revision: 12110009 Serial number: 0003494557
Coding: 0405FD
ASAM Dataset: EV_TSGFPQ25BRFVW46X A04001
ROD: EV_TSGFPQ25BRFVW46X.rod
Slave Driver:
Subsystem 1 - Part No SW: 561 959 811 HW: 561 959 811 Labels: 1K0-959-70X-GEN4.CLB
Component: J388__TSG_HL 004 4472
Coding: 800000
Part No: 1K0 909 144 N
Component: EPS_ZFLS Kl. 290 3301
Revision: 00H22000
VCID: 3560A8F75CE43FE236-8060
Part No SW: 5C6 035 456 HW: 5C6 035 456
Component: KonzernAmp10K H07 0468
Revision: -------- Serial number: EAA083A0006189
VCID: 65C038B764C48F6246-8030
Part No SW: 7N0 907 532 HW: 1K0 907 951
Component: EZE_2 H40 1623
Coding: 01030108
VCID: 6FEC5A9FBE3845323C-803A
Subsystem 1 - Part No SW: 561 959 591 HW: 561 959 591
Component: J245 P05 FFD7 H07 0004
Serial number: 53388786011134400591
Coding: 181100
Subsystem 2 - Part No SW: 561 919 204 B HW: 561 919 204 B
Component: Analoguhr 008 0004
Part No SW: 561 959 702 A HW: 3C0 959 792 C
Component: TUER-SG BT 002 0525
Revision: 14110009 Serial number: 0003546138
Coding: 0405FC
ASAM Dataset: EV_TSGBPQ25BRFVW46X A04001
ROD: EV_TSGBPQ25BRFVW46X.rod
VCID: 1D3050570C1487A2DE-8048
Slave Passenger:
Subsystem 1 - Part No SW: 561 959 812 HW: 561 959 812 Labels: 1K0-959-70X-GEN4.CLB
Component: J389__TSG_HR 004 4472
Coding: 800000
Address 56: Radio (J0506) Labels:. 1T0-035-680.clb
Fault Frequency: 45
Reset counter: 194
Mileage: 378920 km
Part No SW: 5K0 035 730 E HW: 5K0 035 730 E
Component: TELEFON H09 2902
Revision: 1B001001 Serial number: 00007661523680
Coding: 0A10040000010110
ASAM Dataset: EV_UHVNA A01719
ROD: UHVNA.rod
VCID: 275C72BF5E485D72B4-8072
End-------------------------(Elapsed Time: 03:24)--------------------------
