New Fault Codes appeared....
niggly60
C?ID=365548
When going in to clear some long standing codes from my 2017 VW Tiguan Mk 2 4WD 2.0L diesel- I ran a new scan.
The following new faults have appeared:
   Part No SW: 5NA 907 044 K    HW: 5NA 907 044 K
   Component: AC Automat    H35 4003
   Revision: 20K08000    Serial number: 00000B00207067
   Coding: 0012012420211001110510000010112A
   ASAM Dataset: EV_ACClimaPrehVW37X 002014
   ROD: EV_ACClimaPrehVW37X_002_VW37.rod
   VCID: 47CAAEA58F2D25CF1F7-8012
   Subsystem 1 - Part No SW: 3G0 907 049 E    HW: 3G0 907 049 E
   Component: E265KlimaHeck  H02 0201
   Serial number: 00000000000000000000
263425 - Air Quality Sensor
          B10AF 04 [008] - Internal System Fault
                    Fault Frequency: 11
                    Reset counter: 200
                    Mileage: 38117 km
                    Date: 2019.05.05
                    Time: 14:03:38
                    Outside air temperature: 11.0 °C
                    Voltage terminal 30: 14.6 V
                    System run time-Engine running time: 253 s
                    Air quality status: ERROR
655628 - Functional Limitation due to Energy Management
          B10CD 00 [008] -  -
          [HeckBT - Sitzheizung - Komforteinschränkung wegen Eingriff Energiemanagement]
                    Reset counter: 198
                    Mileage: 37920 km
                    Date: 2019.05.05
                    Time: 08:04:53
Should I be concerned, and if so, are they an easy fix?
Not sure what to tell you about the air quality sensor fault, but second fault is purely an advisory thing; it tells you that at some point the seat heaters were shut down to conserve the battery's state-of-charge.
niggly60
C?ID=365548
Thanks for correcting my post Uwe. I thought I could get away without the CODE thing- but it does make reading it easier!
The Air Sensor fault is a new one that I've not seen before- so I will keep an eye on it. As for the other, it didn't occur to me to run the German error through Google Translate. It makes sense now: "Seat heating - comfort restriction due to intervention energy management".
MasterTommy
Amsterdam
C?ID=295586
Ive had the same air quality sensor fault appear on my mk2 tiguan. Lets see what it costs...
