My car makes a funny kind of chirping sound when the turbo is spooling changes with boost pressure, its kind of like the vanes are hitting something.
Also when car is cold there is like a pluffing sound from the exhaust from one of the cylinders, or it sounds like that.
Car done about 70K full service history.
Another thing just happened this last week when towing caravan, when car is under load going up a hill, and its done it twice now, it goes into Limp mode.
Which is quite tricky with DSG, as you have to pull over and stop car in N or park, then its fine again.
Does not do it when not towing.
Also is there a way to get the LED DRL to stop throwing up a bulb warning!!!
Thanks for your help.
Neil Sangster
Neil Sangster
Chassis Type: 3C-VW46 (7N0)
Scan: 01 02 03 08 09 10 15 16 17 19 22 25 2E 37 42 44 46 4F 52 53
56 61 62 65 72
VIN: WVWZZZ3CZEE028207 Mileage: 113570km-70569miles
Address 01: Engine (J623-CFGC) Labels:. 03L-906-018-CFF.clb
Part No SW: 03L 906 018 RF HW: 03L 907 309 AE
Component: R4 2,0L EDC X28 4779
Revision: 41X28--- Serial number: 00000000000000
Coding: 001D0012042701080000
Shop #: WSC 92521 052 00000
ASAM Dataset: EV_ECM20TDI01103L906018RF 003003
ROD: EV_ECM20TDI01103L906018RE.rod
VCID: 7F071605E62B29B2A2-802A
5171 - Boost Pressure Regulation
P0299 00 [096] - Control Range Not Reached
Mileage: 113107 km
Date: 2019.03.29
Time: 18:42:45
Engine speed: 1999.50 /min
Normed load value: 72.2 %
Vehicle speed: 76 km/h
Coolant temperature: 93 °C
Intake air temperature: 32 °C
Voltage terminal 30: 14.680 V
Charge air pressure specified value: 2757 hPa
Charge air pressure: actual value: 2346 hPa
Air mass: actual value (mg/stroke): 948.3 mg/stroke
EGR Solen.val.: actual value: 99.90 %
Throttle valve adapter: actual value: 99.98 %
Charge Pressure Actuator: acknowledgment: 83.68 %
Mean injection quantity: 54.48 mg/stroke
Part No SW: 02E 300 016 H HW: 02E 927 770 AL
Component: GSG DSG AG6 521 4011
Revision: 05652104 Serial number: 00001306132600
Coding: 0000024
Shop #: WSC 05311 000 00000
VCID: 1933D89DD04FE7823C-804C
Address 03: ABS Brakes Labels: 3AA-614-109.clb
Part No SW: 3AA 614 109 AK HW: 3AA 614 109 AK
Component: J104 C2 450M V4DF 0055
Revision: --H07--- Serial number: 00000006974948
Coding: 0793361
VCID: 76E9F321011168FAF1-8022
Part No SW: 3AA 907 044 BA HW: 3AA 907 044 BA
Component: Climatronic H03 0404
Revision: 00001K01
Coding: 061400C803
Shop #: WSC 00015 115 00000
VCID: 70E5C539AB7546CA2B-8024
Address 09: Cent. Elect. (J519) Labels:. 3AA-937-087.clb
Part No SW: 3AA 937 087 R HW: 3AA 937 087 R
Component: BCM PQ47 H++ 422 0474
Revision: BD422001
Coding: 0008000000000000049800801400816403510088426D81606480C7200041
VCID: 499348DDE06F57024C-801C
Subsystem 1 - Part No: 3AC 955 119 Labels: 1KX-955-119.CLB
Component: Wischer 13061 26 0612
Coding: 00B795
Component: RLS 170613 05 54 0403
Coding: 0230ED
Fault Status: 00101010
Fault Frequency: 56
Reset counter: 6
Mileage: 106714 km
Date: 2018.11.29
Time: 07:23:40
Term 15 On
Voltage: 11.50 V
Fault Frequency: 49
Reset counter: 6
Mileage: 106714 km
Date: 2018.11.29
Time: 07:23:40
Term 15 On
Voltage: 11.50 V
03789 - Terminal 75 Limp Mode Active
Reset counter: 7
Mileage: 113293 km
Date: 2013.08.21
Time: 14:12:17
Term 15 On
Voltage: 13.20 V
Address 10: Park/Steer Assist (J446) Labels:| 3AE-919-475.clb
Part No SW: 3AE 919 475 C HW: 7N0 919 475
Component: PARKHILFE 8K H06 0018
Revision: -------- Serial number: 28261317202785
Coding: 308105
Shop #: WSC 99999 123 12345
ASAM Dataset: EV_EPHVA18VW47X0000 001006
ROD: EV_EPHVA18VW47X0000.rod
VCID: 3F875605A6ABE9B2E2-806A
Part No SW: 5N0 959 655 AA HW: 5N0 959 655 AA
Component: J234__108 VW10 HI 2118
Revision: 26019000 Serial number: 003L7PCTUS5V
Coding: 0012344
VCID: 7CFDE1093F3D32AA87-8028
Subsystem 1 - Serial number: 6332MTS623061553
Subsystem 2 - Serial number: 6342MTS676051543
Subsystem 3 - Serial number: 6351HTS67ROD2CKJ
Subsystem 4 - Serial number: 6361HTS6E3V22CKR
Address 16: Steering wheel (J527) Labels:| 3C0-953-569.clb
Part No SW: 3C9 953 501 BG HW: 5K0 953 569 T
Revision: FF010042 Serial number: 20130621201492
Coding: 1982250000
VCID: 6FE7C645B64B593232-803A
Component: E221__MFL-TK6 H07 0022
Coding: E20000
Part No SW: 3AA 920 980 Q HW: 3AA 920 980 Q
Component: KOMBI H04 0611
Coding: 451F00
Shop #: WSC 05314 115 00000
VCID: 42815FF1D559845A8D-8016
Part No SW: 7N0 907 530 AN HW: 7N0 907 530 AN
Component: J533 Gateway H56 1642
Revision: H56 Serial number: 070613F1001802
Coding: 462007
Shop #: WSC 05314 000 00000
VCID: 7CFDE109FF3D32AA87-8028
Part No SW: 0BS 907 554 C HW: 0BS 907 554 C
Component: Haldex 4Motion 4016
Coding: 0000005
VCID: 468943E13171B87AA1-8012
Part No SW: 3AA 959 433 B HW: 3AA 959 433 B
Component: IMMO 043 0407
Revision: 00043000 Serial number: VWZCZ000000000
Shop #: WSC 11391 000 1048576
VCID: 38753D194B85DE8A23-806C
Component: ELV 029 0380
3C0905861J ELV 029 0380
Part No SW: 5N0 035 342 G HW: 5N0 035 342 G
Revision: A1001003 Serial number: 7664970286
Coding: 020100
VCID: 2B5F12554AD365125E-807E
Address 37: Navigation (J794) Labels:| 1K0-035-27x-37.clb
Part No SW: 3C8 035 279 M HW: 3C8 035 279 M
Component: RNS315-EU H70 0407
Serial number: VWZAZ2N0373853
Coding: 040004410400110000019002
Shop #: WSC 00015 115 12345
ASAM Dataset: EV_RNS315EUV2UDS 001705
ROD: EV_RNS315EUV2UDS.rod
VCID: 356B342D949723E238-8060
Component: EUR_W_V9 0069
Part No SW: 3AA 959 701 A HW: 3C0 959 793 C
Component: TUER-SG FT 002 0534
Revision: 12110009 Serial number: 0007191618
Coding: 0202B7
Shop #: WSC 05311 115 00000
Slave Driver:
Subsystem 1 - Part No SW: 3AA 959 704 A HW: 3AA 959 794 Labels: 1K0-959-70X-GEN4.CLB
Component: J389__TSG-HR 004 0503
Serial number: 00000003551492
Coding: 010290
Part No: 1K0 909 144 R
Component: EPS_ZFLS Kl. 197 3501
Revision: 00H22000
Shop #: WSC 02069 000 90108
VCID: 3973381D708FC782DC-806C
Component: KSG PQ47 ELV 043 0645
Coding: 0191020052830E76340494157C085FCE105804
Component: Neigungssensor 004 0611
Part No SW: 7N0 907 532 HW: 7N0 907 530 AN
Component: EZE_2 H56 1642
Coding: 00000008
VCID: 6FE7C645BE4B593232-803A
Subsystem 1 - Part No SW: 3AA 919 204 A HW: 3AA 919 204 A
Component: Analoguhr 004 0004
Part No SW: 3AA 959 702 A HW: 3C0 959 792 C
Component: TUER-SG BT 002 0534
Revision: 14110009 Serial number: 0007161580
Coding: 0202B6
ROD: EV_TSGBPQ35BRFVW46X_VW46.rod
VCID: 36693321899128FA31-8062
Slave Passenger:
Subsystem 1 - Part No SW: 3AA 959 703 A HW: 3AA 959 795 Labels: 1K0-959-70X-GEN4.CLB
Component: J388__TSG-HL 004 0503
Serial number: 00000003554885
Coding: 010290
Revision: H19 Serial number: 00000001175083
Coding: 0022167
VCID: 36693321419128FA31-8062
Part No SW: 7N0 907 534 HW: 7N0 907 530 AN
Component: Batt.regelung H56 1642
Coding: 030F1859
VCID: 71E3C03DA87F4FC224-8024
Component: J367-BDM H07 0180
Serial number: 30174D21371491633351
Address 65: Tire Pressure (J502) Labels: 3AA-907-273.clb
Part No SW: 3AA 907 273 D HW: 3AA 907 273 D
Component: RDKBERU30 H09 0010
Serial number: 10000000227804
ASAM Dataset: EV_RDKBERU30 003012
ROD: EV_RDKBERU30_003.rod
End-------------------------(Elapsed Time: 03:30)--------------------------
