MAF failure
alexliebt
C?ID=362745
Hi
How can I read the MAF?
The control modules in my vehicle is UDS. I found many tutorials but are non UDS.
VCDS Version: 18.9.1.0  HEX-V2 CB: 0.4437.4
   License Plate: 16032019
Mileage: 163640km-101681mi   Repair Order:
Chassis Type: 3C-VW46 (3C0)
Scan: 01 03 08 09 15 16 17 19 25 42 44 46 4F 52 53 56 61
VIN: WVWZZZ3CZAE075321   Mileage: 163640km-101681miles
Address 01: Engine (J623-CAYC)       Labels:. 03L-906-023-CAY.clb
   Part No SW: 03L 906 023 GL    HW: 03L 906 023 A
   Component: 1,6l R4 CR td H23 5810
   Coding: 00114014032501080000
   ASAM Dataset: EV_ECM16TDI02103L906023GL 001006
   ROD: EV_ECM16TDI_001_VW46.rod
   VCID: 76B410CDD84FCD57B41-8022
Address 03: ABS Brakes        Labels: 3C0-614-109-C4.clb
   Part No SW: 3C0 614 109 AK    HW: 3C0 614 109 AK
   Component: J104    C4 440 V2   0027
   Revision: --025---    Serial number: 00000795856674
   Coding: 0034287
   Shop #: WSC 05311 000 00000
   VCID: 678A4D89836524DF3F7-8032
   Part No SW: 3C8 907 336 AB    HW: 3C8 907 336 AB
   Component: Climatic      H14 0305
   Revision: 00009001
   Coding: 0000000003
   Shop #: WSC 05311 115 00000
   ROD: EV_ClimaBasis_VW46.rod
   VCID: 6D863FA1AD190E8F45B-8038
   Part No SW: 3C8 937 049 AA    HW: 3C8 937 049 AA
   Component: Bordnetz-SG     H57 3204
   Revision: 00H57000    Serial number: 00000003339756
   Coding: A0900F0700041A00470A00000F000000000159435C000100000308000000
   Shop #: WSC 05124 123 12345
   VCID: 70B826D5B6ABE3676ED-8024
   Subsystem 1 - Part No: 3C2 955 119 C  Labels: 1KX-955-119.CLB
   Component: Wischer 191009 022  0612
   Coding: 00046997
   Shop #: WSC 05124
   Part No SW: 5N0 959 655 J    HW: 5N0 959 655 J
   Component: J234__00J VW10 HI   1916
   Revision: 20013000    Serial number: 003E2PP3YD2Z
   Coding: 0012362
   VCID: 44D0BA05D2932FC7FA5-8010
   Subsystem 1 - Serial number: 6332MTS633892949
   Subsystem 2 - Serial number: 6342MTS658412949
   Subsystem 3 - Serial number: 6351HTS6SKE829KR
   Subsystem 4 - Serial number: 6361HTS6G4C729KR
   Part No SW: 3C5 953 501 BP    HW: 5K0 953 569 AA
   Component: LENKS.MODUL   009 0122
   Revision: FF010E35    Serial number: 20091105200027
   Coding: 4180270002
   ASAM Dataset: EV_VW360SteerWheelUDS A03002
   VCID: 74B02AC5CE33DF478A5-8020
   Part No SW: 3C0 920 972 J    HW: 3C0 920 972 J
   Component: KOMBI         H03 0305
   Coding: 160F00
   Shop #: WSC 05314 115 12345
   VCID: 2D06FFA16D99CE8F05B-8078
   Part No SW: 3C0 907 530 N    HW: 3C0 907 951
   Component: J5
The following measuring values should available in that ECU:
IDE00347-ENG167462 -- Air mass: actual value: (OBD, so likely g/s)
IDE00350-ENG99082 -- Air mass: specified value - MAF_SP_MMV (mg/stroke)
IDE03949-ENG103150 -- Air mass: actual value - MAF_MMV,LINEAR (mg/stroke)
To make them easier to find, type Air mass into the search/filter box.
alexliebt
C?ID=362745
Thank you for info. The readings have to be taken when the engine is warm?
Depends what you exactly you are trying to accomplish.
In general, the best way on a diesel is to log specified and actual while driving under a variety of conditions.
What makes you think you have a possible MAF failure?
alexliebt
C?ID=362745
About 2 days ago, my wife started the car in the morning and she managed to drive less then 1 mile and the car lossed the power and the engine died. She started the car few times and it happend again. 5 minutes later the car was fine, even now is alright. I’ve scan with VCDS and I can’t find any fault.
A MAF failure generally won't cause the engine to die.
It can but is very rare!
This sounds like a fuel or contaminated fuel issue, would be wise to check/change filter and TV function.
Check all ground points and battery connections!
Check motor mounts and for torn intake/charge boots!
LOG requested Boost versus Actual
Component: 1,6l R4 CR td H23 5810 <<<<<<<<<<<<<<<<<<<<<<<<<<<<<<<<<<<<<<<<<<<<<<<<<<<<<<<<<<< Update firmware needed!
alexliebt
C?ID=362745
I changed all filter 2 months ago. I’m using only Shell diesel. I’ll check all the ground points.
