BO_ 960 Klemmen_Status_01: 4 Gateway_MQB
SG_ Klemmen_Status_01_CRC : 0|8@1+ (1,0) [0|255] "" Airbag_MQB,BMS_MQB,Motor_Diesel_MQB,Motor_Hybrid_MQB,Motor_Otto_MQB
SG_ Klemmen_Status_01_BZ : 8|4@1+ (1,0) [0|15] "" Airbag_MQB,BMS_MQB,Motor_Diesel_MQB,Motor_Hybrid_MQB,Motor_Otto_MQB
SG_ ZAS_Kl_S : 16|1@1+ (1,0) [0|1] "" Vector__XXX
SG_ ZAS_Kl_15 : 17|1@1+ (1,0) [0|1] "" Airbag_MQB,BMS_MQB,Motor_Diesel_MQB,Motor_Hybrid_MQB,Motor_Otto_MQB
SG_ ZAS_Kl_X : 18|1@1+ (1,0) [0|1] "" Vector__XXX
SG_ ZAS_Kl_50 : 19|1@1+ (1,0) [0|1] "" Vector__XXX
0x3C0 is not the "ID of the gateway", but the ID of this particular message which contains ignition and start on/off info, which MAY be observed by the instrument cluster.960 dec is 0x3c0 id of gateway
The message needs to be sent at 10Hz, and needs to be 4 bytes long instead of the typical 8, and it needs to be correctly structured.I send can message id 0x3c0 ff ff ff ff ff ff ff ff
I know is incorrect and i need also crc but with this message cluster wakeup for 40seconds and standby again
You can easily obtain replayable messages with correct CRCs easily from a running car. Are you a licensed VCDS user? Anyone with VCDS and an OBD Y-cable (to simultaneously connect a CAN sniffer) can observe these messages at the OBD DLC of an operating car without any disassembly or modification, it's an easy procedure. And, depending on what you're trying to do on the bench, this may not be the only message you need to send.Even if i periodic send this messsage same thing , jyoung8607 need some help
That is... ambitious. Has anyone else done that before?jyoung8607 if you helpme with correct message i willbe so happy.i not have any MQB car to use can sniffer
my project is to "adapt" TT 8S cluster virtual cockpit to my TT 8J 2009 car
Yes that's true, the CAN gateway and cluster interconnect changed with MQB.i connect the new cluster to my TT 8j and nothing works engine speed / wheels speed nothig but now i discovered something new
my old TT have "special" cluster can output from gateway and the new tt 8s cluster connect on convenience CAN.will do more experiments in weekend
I'd pay $5 to see an Auto-Scan from a car with that kind of schizophrenia. I don't think it would end well.my second question is ?
-what will happening if i connect tt 8s gateway on same powertrain can (have two gateways in same time my old gateway and new tt8s gateway)
@CrackerX... Did you figure out the correct CAN msg? I have a Q7 VC on the bench and am seeing the same thing and its based on the TT VC.. except 960 FF FF FF FF FF FF FF FF just reboots the cluster and the screen flashes on then off...
Hi try
3C0 (960), 00 00 FB 00 00 00 00 00
normally FF can repesent error.
Thx for reply!3C0: Ignition on/off states
65D: From ABS/ESP, system info about tone-wheel tooth count, tire circumference, selected Charisma profile
714: I don't know
31B: I don't know
