Audi Q5 - Trailer module removal
Yoshimura
Canada
C?ID=216565
I would like to remove the Trailer module from my 2015 Audi SQ5. I found a few guides to add the module but they seems to be all somewhat different.
So I probably need to remove the "Hitch installer" options from a few modules like Engine, ABS and Cent. Elect and Back-up Cam. If I forget some modules, I will simply get faults that I can then fix?
What would be procedure? Do I disconnect the Trailer module before recoding the others module? From my understanding, I should also remove the module from a gateway. When I should do this? At the beginning? At the end?
Finally, should I disconnect the battery at some point? How reset everything to make sure there is no faults?
Many thanks!
Curious why you want to remove the module?
Please post an Auto-Scan so people can see exactly how the vehicle is equipped and configured.
Yoshimura
Canada
C?ID=216565
Thanks for chiming in Uwe. And to fulfill your curiosity, I want to remove the hitch before trading my car. :-)
Here's the Auto-Scan
Chassis Type: FP-AU48 (8R0)
Scan: 01 02 03 05 08 09 15 16 17 19 36 3C 42 44 46 47 52 53 56 5F
          62 69 6C 6D 72 A9
VIN: WA1LGCFP0FA009583   Mileage: 58530km-36368miles
Address 01: Engine (J623-CTUD)       Labels:. 06E-907-551-CGW.clb
   Part No SW: 8R0 907 551 G    HW: 4G0 907 551 A
   Component: 3.0l V6 TFSIH07 0007
   Revision: --H07---
   Coding: 2A2A0034053600060000
   Shop #: WSC 05372 002 1048576
   ASAM Dataset: EV_ECM30TFS0218R0907551G 001007
   ROD: EV_ECM30TFS0218R0907551G.rod
   VCID: 3C77216AB785A6AAC1-8069
   Part No SW: 8R0 927 158 AB    HW: 0BK 927 156 AM
   Component: 0BK 30TFSIUSA H18 1002
   Revision: --H18---
   VCID: 7DF1EC6EEC1F6FA2B6-8029
Address 03: ABS Brakes (J104)       Labels:. 8R0-907-379-V2.clb
   Part No SW: 8R0 907 379 AS    HW: 8R0 907 379 AS
   Coding: 30950801
   VCID: 1129A0DEC8877BC242-8045
   Part No SW: 8K0 907 064 JP    HW: 8K0 907 064 JP
   Component: BCM2 2.0      H14 0650
   Coding: 0D854040000000000000
   Shop #: WSC 06335 000 00000
   VCID: 071D8E86B6C335729C-8053
   Serial number: 0214000098070012
   Part No SW: 8K1 820 043 AQ    HW: 8K1 820 043 AQ
   Revision: C1000000    Serial number: 01300520141818
   Coding: 6601228000
   VCID: 77FDFE46C62345F2EC-8023
   Part No SW: 8K0 907 063 DJ    HW: 8K0 907 063 DJ
   Revision: 09016001    Serial number: 00000823055602
   Coding: 26008097863CAFE0010048C300003D0D0F9CE708A2090221000008004400010200040034000000
   Shop #: WSC 27838 001 104857
   VCID: 7AFBE772F531589A93-802F
   Subsystem 1 - Part No SW: 8R1 955 119 A    HW: 8R1 955 119   Labels: 1KX-955-119.CLB
   Component: WWS416 140522  H12 0050
   Serial number: 90243014140505224316
   Coding: 01DD13
   Serial number: 22716929
   Coding: 02005C
   Component: E1 - LDS  H03 0031
   Serial number: 00000000002405140832
   Component: USHL4.2  H30 0030
   Serial number: 0000002274555R9HFP03
   Subsystem 5 - Part No SW: 3D0 941 329     HW: 3D0 941 329
H05 0012
   Subsystem 6 - Part No SW: 3D0 941 329     HW: 3D0 941 329
H05 0012
   Subsystem 7 - Part No SW: 4H0 907 658     HW: 4H0 907 658
   Serial number: 33688037000000000001
   Part No SW: 8K0 959 655 R    HW: 8K0 959 655 R
   Component: AirbagVW-AU10 H51 0812
   Serial number: 003NED1231T3
   Coding: 30373431343238313230554A304C38523053
   ASAM Dataset: EV_AirbaECUVWAUDI010 003114
   VCID: 4C9771AAE725162A71-8019
   Serial number: 6334MSME456E323BL
   Serial number: 6344MSME455E3A71N
   Serial number: 6352QSME01403D4EG
   Serial number: 6362QSME7B3E465E%
   Serial number: 63732SME1146155E-
   Serial number: 63832SME11461066P
   Part No SW: 8K0 953 568 Q    HW: 8K0 953 568 Q
   Component: Lenks.Modul   H03 0003
   Revision: C0062331    Serial number: 90862NF60002A
   Coding: 000037
   VCID: 489F4DBAFB5DFA0A55-801D
Address 17: Instruments (J285)       Labels:. 8R0-920-xxx-17.clb
   Part No SW: 8R0 920 931 D    HW: 8R0 920 931 D
   Component: KOMBIINSTR.   H35 0564
   Revision: 00200000    Serial number: ZDS40D56F
   Coding: 8BA722000A010008020000
   VCID: 3663334281A97CFA37-8063
   Revision: 1Z120030    Serial number: 3041Z145220B7D
   Coding: 80C103FF00
   VCID: 4C9771AAEF25162A71-8019
   Subsystem 1 - Part No SW: 8R0 915 181 C    HW: 8R0 915 181 C
   Component: J367-BDMHella  H07 8043
   Serial number: 1055823203
   Part No SW: 8R0 959 760 D    HW: 8R0 959 760 B
   Component: MEM-FS        H07 0077
   Revision: AA000000    Serial number: 00000099709842
   Coding: 00581B00000000000000
   VCID: 428B5F92DD61D05A8B-8017
   Serial number: 0335720086
   Coding: 010221
   VCID: 3F8D5666A693BDB2E4-806B
   Component: SWA Slave  H05 0071
   Serial number: 0336793089
   Coding: 010221
   Component: TSG FA        H02 0510
   Revision:             Serial number: 0000104306510
   Coding: 011D13215E00440004
   VCID: 4FAD66A61E332D3214-801B
   Part No SW: 8R0 909 144 P    HW: 8R0 909 144 B
   Component: RCEPS         H40 0510
   Revision: 00001000    Serial number: 0011578307
   Coding: 100000010000
   Shop #: WSC 06334 000 00000
   ASAM Dataset: EV_RCEPSAU48X 008018
   ROD: EV_RCEPSAU48X_008.rod
   VCID: 4581448EC44FE762AE-8011
   Revision: 00002001    Serial number: 0337366390
   Coding: 0126063A20FA709584B0053200040000
   Component: GTO BF  H01 0080
   Serial number: 00000000000000844542
   Subsystem 3 - Part No SW: 7N0 959 591 B    HW: 7N0 959 591 B
   Component: J245EE04SKB03  H03 0090
   Subsystem 4 - Part No SW: 7N0 959 591 B    HW: 7N0 959 591 B
   Component: J394EE04SKB03  H03 0090
   Revision: 00005001    Serial number: 94813030433604
   VCID: 2D511C2E74FF3F2246-8079
   Component: TSG BF        H02 0510
   Revision:             Serial number: 0000104426351
   VCID: 4E937BA21939243A1F-801B
   Component: EPB-4         H02 0005
   Revision: --------    Serial number: 20000000459321
   ROD: EV_ParkiBrake_AU48.rod
   VCID: 3A7B2772BDB1989AD3-806F
Address 56: Radio
   Part No SW: 8R1 035 664 F    HW: 8R1 035 664 D
   Component: H-BN-NA       H41 0812
   Revision: --------    Serial number: 203EN0EB004260
   Coding: 1A020006020581EF5502AB4E00000403F40000020000000000
   VCID: 3979387EB0B79382DA-806D
   Subsystem 1 - Part No: 8R0 060 884 CA
   Component: NAR 2014  1002
   Component: DU7 High  H42 0104
   Serial number: A130EK0E3045162
   Serial number: 00000001881584
   Component: CD-Database  5950
   Component: TSG HL        H01 0510
   Revision:             Serial number: 0000104834410
   Coding: 010C13204000240004
   VCID: 46834382F149EC7AA7-8013
   Part No SW: 8K0 907 383 E    HW: 8K0 907 383 E
   Revision: 1A001001    Serial number: 00000154649466
   Coding: 0200000000000000
   Shop #: WSC 94754 999 999999
   Part No SW: 8R0 907 441 A    HW: 4L0 907 441 B
   Revision: --H09---    Serial number: 525PA8-J44A1MY
   Coding: 1030010
   VCID: 3467094A57D56EEA09-8061
   Part No SW: 8R0 827 851 D    HW: 8R0 827 851 D
   Component: J605  Master  H53 0330
   Revision: --------    Serial number: 8R0827851D
   VCID: 3D712C6EA49FAFA2F6-8069
   Subsystem 1 - Part No SW: 8R0 827 852 D    HW: 8R0 827 852 D
   Component: J756  Slave  H53 0330
   Serial number: 8R0827852D
   Component: TSG HR        H01 0510
   Revision:             Serial number: 0000104346764
   Part No SW: 8R0 907 159 A    HW: 4H0 907 159 A
   Component: SAS-GEN 2     H06 0001
   Serial number: 140506200085
End-------------------------(Elapsed Time: 05:47)--------------------------
Yeah, there's quite a few other modules that would need to have coding adjusted if you removed the trailer module. If you really want to go there, start by physically removing the trailer module and then un-checking it in the Gateway's [Installation List] function. Then let's see what starts to complain.
However... Do you really want the module? I think the hitch itself can be removed while leaving the module in place and none of the other modules will be any the wiser.
Yoshimura
Canada
C?ID=216565
Ok, I removed the module physically and from the gateway.
I then had fault in the following modules.
01-Engine
03-ABS Brakes
09-Cent. Elect.
3C-Lane Change
5F-Information Electr.
6C-Back-up Cam.
I could fix all the malfunctions (by removing the hitch/trailer option) except for 5F-Information Electr. in which I could not find anything related to trailer/hitch. Any idea how to fix this fault?
I also tried to reboot the MMI.
                Address 5F: Information Electr.       Labels: 4E0-035-6xx-5F.clb
Control Module Part Number: 8R1 035 664 F    HW: 8R1 035 664 D
  Component and/or Version: H-BN-NA       H41 0812
           Software Coding: 1A020006020581EF5502AB4E00000403F40000020000000000
            Work Shop Code: WSC 05372 002 1048576
            000 -  -
                    Reset counter: 61
                    Mileage: 58598 km
                    Date: 2019.03.25
                    Time: 15:22:28
                    Bin. Bits: 00000000 00000000
                    Bin. Bits: 00000000 00000100
NEtech
C?ID=56995
These Codings should be without trailer.
Explanation
[Controller number] > New coding
[01] > 2A2A0034052600060000
[03] > 30150801
[09] > 26008097863CAFE0010048C300003D0D0F9CC708A2090221000008004400010200040034000000
[3C] > 010211
[5F] > 1A020006020581EF55028B4E00000403F40000020000000000
[6C] > 1020010
Yoshimura
Canada
C?ID=216565
Explanation
[03] > 30150801
[3C] > 010211
[6C] > 1020010
No more fault!!!
Thanks a lot for this!
