2004 Audi A8L
Scanned using registered to me version of VCDS 1 of 10 VINS Used with Ross-Tech Cable.
Background:
Car was brought back from the dead (Copart) due to a sunroof leak. I had to fix the kessy (Sent to Speedosolutions for cloning to new one) and replaced the board in the MMI. She's running great but the rear suspension wouldn't pump up. On the advice of a friend I ordered a new valve block and installed today and I got air running to the back...……….. but obviously the suspension is all wonky and needs to be leveled out.
I have tried to no avail to login to the leveling module J197 34-Level Control but every time I try I get the error code 35 invalid Key. (I'm using key 31564) I've followed the Ross-Tech video step by step and searched other forums for info on this....found others with problem but no one followed up with their solution. I promise that I will so that this thread will serve others.
Below please find my autoscan:
Would appreciate any help.
JohnR
https://photos.app.goo.gl/kYmdzfJkahFtVejX9
Background:
JohnR
Saturday,23,March,2019,15:59:54:05782
VCDS Version: 18.9.1.0 (x64) HEX-V2 CB: 0.4437.4
VIN: WAUML44EX4N013950 License Plate: 032319JR
Mileage: 93810km-58290mi Repair Order: Suspension
Chassis Type: 4E (4E0)
Scan: 01 02 03 05 06 07 08 09 0E 15 16 17 19 25 34 36 37 38 42 46
47 4F 52 53 55 56 61 62 65 72 75
VIN: WAUML44EX4N013950 Mileage: 93810km-58290miles
Address 01: Engine Labels: 077-910-560-BFM.clb
Part No SW: 4E0 910 560 A HW: 4E0 907 560
Component: 4.2L V8/5V G 0070
Revision: 00000000 Serial number: AUX3Z0CN527177
Coding: 0007773
Shop #: WSC 02313 785 00200
VCID: 1F1BE1CAABBCB59F877-804A
Readiness: 0110 1101
Part No SW: 4E0 910 156 E HW: 09E 927 156 A
Component: AG6 09E 4,2L5V USA 0110
Revision: 00000001 Serial number: 0024001
VCID: 2411EE2682DA9647DA5-8070
Address 03: ABS Brakes Labels: 4E0-910-517.lbl
Part No SW: 4E0 910 517 A HW: 4E0 614 517 E
Component: ESP 5.7 allrad H29 0420
Coding: 0007597
Shop #: WSC 02313 000 00000
VCID: 211FE7329DC8836FB13-8074
Address 05: Acc/Start Auth. Labels: 4E0-910-131.lbl
Part No SW: 4E0 910 131 HW: 4E0 909 131 A
Component: FBS AUDID3 H03 0130
Revision: 01303703 Serial number: AUX3Z0CN527177
Coding: 0263168
Shop #: WSC 02311 785 00200
VCID: 58E98AD68E1202A786D-800C
Component: ELV XXXX
Part No SW: 4E0 910 760 C HW: 4E0 959 760
Component: Sitzmemory BFS H07 0060
Revision: 00000000 Serial number: 5DS 008 795-03
Coding: 3940448
VCID: 2313ED3A87D4917FA3F-8076
Address 07: Control Head Labels: 4E0-910-7xx-07.clb
Part No SW: 4E0 910 729 J HW: 4E0 035 729
Component: Interfacebox H43 0600
Revision: 00000000 Serial number: 346JP037507026
Coding: 0000103
Shop #: WSC 22102 444 59104
VCID: 2F3B110ADB1C251F377-807A
Component: E0380 BedienteilH01 0040
Subsystem 2 - Serial number: 00000000023587
Subsystem 3 - Serial number: 0131.10.060000000100010029ÿ
Subsystem 4 - Serial number: 010029ÿ
Part No SW: 4E0 910 043 A HW: 4E0 820 043 B
Component: KLIMAAUTOMAT 016 0260
Revision: 00000021 Serial number: 00000000029264
Coding: 1085761
VCID: 1B63D5DABFA4A9BF6BF-804E
Subsystem 1 - Part No: 4E0 910 772 A
Component: Sitzluefter FS H01 010
Subsystem 2 - Part No: 4E0 910 772 A
Component: Sitzluefter BFS H01 010
Subsystem 3 - Serial number: 898053000
Subsystem 4 - Serial number: HO04112003065A000000000166ÿ†89
Subsystem 5 - Serial number: 000166ÿ†898053000 000-SHO
Subsystem 6 - Serial number: 000-SHO04112003065A00000000
Subsystem 7 - Serial number: 65A000000000025ÿ
Address 09: Cent. Elect. Labels: 4E0-910-279.clb
Part No SW: 4E0 910 279 E HW: 4E0 907 279 E
Component: ILM Fahrer H11 0100
Coding: 0111113
VCID: 2A0D001EE0FE4037E09-807E
Subsystem 1 - Part No: 4E1 910 113
Component: Wischer WWS D3 H30 0320
Coding: 00000030
Shop #: WSC 02311
Part No SW: 4E0 910 111 C HW: 4E0 035 111
Component: CD-Changer H43 0340
Revision: 00000501 Serial number: AUZ5ZBC1026265
VCID: 196FCFD2B598DBAF793-804C
Address 15: Airbags Labels: 4E0-910-655-84.lbl
Part No SW: 4E0 910 655 A HW: 4E0 959 655 E
Component: Airbag 8.4E+ H10 0920
Coding: 0530707
Address 16: Steering wheel Labels: 4E0-910-549.lbl
Part No SW: 4E0 910 549 HW: 4E0 953 549 A
Component: Lenksäulenmodul H12 0040
Coding: 0012241
VCID: 6597B322C960AF4F0DB-8030
Address 17: Instruments Labels: 4E0-910-xxx-17.lbl
Part No SW: 4E0 910 900 HW: 4E0 920 950 B
Component: KOMBIINSTR. VDO H44 0080
Revision: D13 Serial number: AUDID3CN004305
Coding: 0016233
Shop #: WSC 25612 444 84583
VCID: 5CE196C6FA2AEE87A25-8008
Address 19: CAN Gateway Labels:. 4E0-910-468.clb
Part No SW: 4E0 910 468 A HW: 4E0 907 468 C
Component: Gateway H07 0030
Revision: 07 Serial number: 0200503A160DDD
Coding: 7CFE7BDD1B2304
VCID: 2615F42EF4E66457C41-8072
Address 25: Immobilizer Labels: 4E0-910-131.lbl
Coding: 0263168
Component: ELV XXXX
XXXXXXXXXXX ELV XXXX
Address 34: Level Control Labels: 4E0-910-553.clb
Part No SW: 4E0 910 553 E HW: 4E0 907 553 E
Component: LUFTFDR.-CDC H05 4290
Coding: 0015510
VCID: 2517F32289E06F4FCDB-8070
Component: Sitzmemory FS H07 0060
Coding: 4071522
Part No SW: 4E0 910 887 K HW: 4E0 919 887 C
Component: MNS US H42 0570
Revision: 00000000 Serial number: 355KM037510505
VCID: 3537236239401FCF7DB-8060
Address 38: Roof Electronics Labels: 4E0-910-135.lbl
Part No SW: 4E0 910 135 A HW: 4E0 907 135
Component: Dachknoten D3 H01 0090
Serial number: 00000328900248
Coding: 0003989
VCID: 1D67DBC2A1B0A78F95B-8048
Address 42: Door Elect, Driver Labels: 4E1-910-802-42.lbl
Part No SW: 4E1 910 802 HW: 4E1 959 801
Component: Türsteuer.FS BRM005 0110
Coding: 0028196
VCID: 5EE59CCEEC36FC97CC1-800A
Address 46: Central Conv. Labels:. 4E0-910-289.lbl
Part No SW: 4E0 910 289 A HW: 4E0 907 289
Component: Komfortgeraet H03 0030
Revision: 00300003 Serial number: W040310290134
Coding: 0065086
VCID: 270BF92AF3EC7D5FFF7-8072
Component: Heckdeckel P27H08 0090
Component: Neigungssensor H02 0020
01134 - Alarm Horn (H12)
Fault Status: 01101100
Fault Frequency: 126
Reset counter: 74
Mileage: 71921 km
Date: 2013.08.20
Time: 05:22:33
00984 - Left Tail Light (M4)
014 - Defective
Fault Status: 01101110
Reset counter: 136
Mileage: 93810 km
Date: 2003.06.18
Time: 22:31:03
Reset counter: 74
Mileage: 71921 km
Date: 2013.08.20
Time: 05:22:33
Address 47: Sound System Labels: 4E0-910-223.lbl
Part No SW: 4E0 910 223 H HW: 4E0 035 223 B
Component: DSP-High D3/AUX H13 0370
Revision: Dev_D01 Serial number: 00000000499524
Coding: 0000016
VCID: 221DE83E98CE9877A89-8076
Address 4F: Centr. Electr. II Labels: None
Part No SW: 4E0 910 280 A HW: 4E0 907 280 A
Component: ILM Beifahrer H08 0020
Revision: Serial number: 00000000026127
Coding: 0010111
VCID: 1E65DCCEACB6BC978C1-804A
Subsystem 1 - Serial number: VK4978T083HE
Address 52: Door Elect, Pass. Labels: 4E1-910-802-52.lbl
Part No SW: 4E1 910 802 HW: 4E1 959 802
Component: Türsteuer.BF BRM005 0110
Coding: 0028196
Address 53: Parking Brake Labels: 4E0-910-801.clb
Part No SW: 4E0 910 801 HW: 4E0 907 801
Component: EPB A01H019 H01 0190
Coding: 0000532
Shop #: WSC 27139 210 01865
16347 - Control Module - EEPROM Error
014 - Defective - MIL ON
Fault Status: 11110000
Voltage: 9.32 V
Count: 187
Address 55: Headlight Range Labels: 4E0-910-357.lbl
Part No SW: 4E0 910 357 HW: 4E0 907 357
Component: Pre-AFS H01 0040
Coding: 0000001
VCID: 629DA83ED84ED877E89-8036
Part No SW: 4E0 910 541 C HW: 4E0 035 541
Component: TUNER EU/US/RDW H41 0290
Revision: 00000000 Serial number: 304KF037551400
VCID: 2019E23696C28A67BED-8074
Address 61: Battery Regul. Labels: 4E0-910-181.lbl
Part No SW: 4E0 910 181 A HW: 4E0 915 181
Component: ENERGIEMANAGER H02 0230
Revision: 00000000 Serial number: 00000004915219
Shop #: WSC 22122 444 00294
Subsystem 1 - Part No: 000 915 105 AK
Component: von VA0 1310240559
Coding: 303030393135313035414B56413031333130323430353539
Shop #: WSC 00000 128 00289
Address 62: Door, Rear Left Labels: 4E0-910-802.lbl
Part No SW: 4E0 910 802 HW: 4E0 959 801 A
Component: Türsteuer.HL BRM005 0110
Coding: 0028196
VCID: 5DE79BC2E130E78FD5B-8008
Address 65: Tire Pressure Labels: 4E0-910-273.lbl
Part No SW: 4E0 910 273 HW: 4E0 907 273
Component: Reifendruck 2 H01 0210
Coding: 0212127
VCID: 5F9BA1CAEB3CF59FC77-800A
Address 72: Door, Rear Right Labels: 4E0-910-802.lbl
Part No SW: 4E0 910 802 HW: 4E0 959 802 A
Component: Türsteuer.HR BRM005 0110
Coding: 0028196
Address 75: Telematics Labels: None
Part No SW: 4E0 910 616 HW: 4E0 035 616
Component: Telematik USA1 0050
Revision: 00000002 Serial number: 0000ATD3005750
Coding: 0000005
VCID: 6099A236D652CA67FED-5160
01531 - Emergency Battery
002 - Lower Limit Exceeded - MIL ON
End----------(Elapsed Time: 02:44, VBatt start/end: 14.1V/14.3V)-----------
Control Module Part Number: 4E0 910 553 E
Component and/or Version: LUFTFDR.-CDC H05 4290
Software Coding: 0015510
Work Shop Code: WSC 02313
Flash Status
Programming Attempts: 1
Successful Attempts: 1
Programming Status: 00000000
Required Conditions: 00000000
Misc.
Hardware number: 4E0 907 553 E
VCDS Info:
Labels: 4E0-910-553.CLB
Flash Status
Misc.
VCDS Info:
