2002 Audi A4 3.0L Runs And Shuts-Off Imediately. Need Advice On What To Check.
Benjisan265
Verified VCDS-Lite User
C?ID=364854
Hi Uwe,
It's KW-1281
Is this reason why I'm not able to do the replacement instrument cluster SKC adaption too?
Now I'm not even able to use the original instrument cluster now in order to keep the car running.
   #22
Hi Uwe,
It's KW-1281
You can remarry the keys in custody to that cluster with VCDS in KW1281 & because the lock bit is set to that cluster!
Would you like me to default that cluster for you with proper documentation & so you can marry a key and do an 050 swap or have me do a real data transfer?
   #23
Benjisan265
C?ID=364854
Hi Jack,
I would greatly appreciate any help you can offer me at this point.
Can you tell me what's involved so I can marry a key and do the 050 swap.
And how could you do a real data transfer?
   #24
Hi Jack,
And could you do a real data transfer?
That's what I do......with all components submitted and credentials.
I will need the engine ECU, all keys and the clusters for transfer!
You could also just send me the cluster with proof of purchase to default/credentials and I could leave blank as if bought from a dealer or marry a transponder to it or leave in programming mode awaiting keys.
Lots of options
Now login to yours and remarry a key or keys by setting the key count as per the RTFB.
0x17-11-SKC
0x17-10-00
0x17-21-00 DCY + 0x17-11 for dropped session 0x17-10-21-KEY count flip keys per DCY until keys are all done.
   #25
Benjisan265
C?ID=364854
Lots of options
0x17-11-SKC
0x17-10-00
Hi Jack,
All that above highlighted in bold sounds very expensive.
My wife already wants to kill me since she was dead set on me buying this car in the first place. Ive already had to hear her tell me multiple times that "I told you so".
If I can't get this all sorted out in a very reasonable cost factor then I'm afraid that I will have to let the car go much cheaper than what I paid for it and hang my head in shame while cutting my losses. Of course my wife is never going to let me forget about this because she wanted me to get a cheap Toyota Camry.
Okay, now that I got that all out what does all this below mean? Are those specific fields that I need to plug in to the VCDS software somewhere in order to do the re-matching of my primary key. I'm sorry if I'm a bit slow with this since I'm not well versed in this Audi Vw software stuff.
0x17-11-SKC
0x17-10-00
   #26
   #27
Benjisan265
C?ID=364854
https://forums.ross-tech.com/showthread.php?3147-What-is-Jack-talking-about-0x01-08-000
Okay talk to me what you call a good deal?
You call it......
And beware and forewarned, at any point if you lie to me, you will regret it, so don't!
OMG Jack, that American Dad video where Stan is afraid that Francine is going to him "I told you so" had me ROFLOL...:thumbs:
A good deal is?
That is going to be where I get this SKC Cluster SNAFU all sorted out without a lot more money being spent going forward, so my wife won't GRIPE anymore that ----> "I told you so" ...:banghead:
Could I follow these steps in the link here ----> http://wiki.ross-tech.com/wiki/index.php/Immobilizer_III_Key_Matching_(Cluster)
Even though I wasn't able to do the "Immobilizer III Immobilizer Swapping (Instrument Cluster)" successfully?
   #29
Benjisan265
C?ID=364854
.........Indeed!
Hi Jack,
I'm going to try the key adaption in VCDS a little while. Could you please explain in simple terms what "DCY" means before I attempt to re-marry my original key back to my original instrument cluster.
   #31
Benjisan265
C?ID=364854
I want to thank you Jack and Uwe.
I got the car running again. I just used the original cluster and key and did the steps in VCDS to adapt the OEM key and cluster again.
I'm going to attempt to adapt the new cluster one more time since the same problems exist with the old cluster.
One quick question I noticed that coding is different between the two clusters.
Could someone point in the right direction in coding (how to) the new cluster to the old cluster before I try to adapt the new.
   #32
If I've got it all straight, this is the replacement cluster:
Address 17: Instruments       Labels: 8E0-920-9xx-8E2.LBL
   Controller: 8E0 920 950 H
   Component: KOMBI+WEGFAHRS. RB4 D26
   Coding: 03200
   VCID: 2E2FCA7AF90F
   WAUVC68E92A245311     AUZ6Z0B0021643
While this is the original:
   Controller: 8E0 920 980 KX
   Component: KOMBI+WEGFAHRS. RB4 D30
   Coding: 00201
   Shop #: WSC 00001
   VCID: 8C6BE0F2AF53
   WAULT68E52A099660     AUZ6Z0A0208491
Coding chart from the label file:
C00,Instrument Cluster (J285) Coding
C01,??xxx: Options
C02,+00 = 1st Distance Impulse Number (Standard - Europe/USA/Rest of World)
C03,+01 = All-Wheel-Drive/Quattro (smaller Fuel Tank Volume)
C04,+02 = Seatbelt Warning (North American Region OLD - < CW 44/2004)
C05,+04 = 3rd Distance Impulse Number (Rental Cars)
C06,+08 = 2nd Distance Impulse Number (Australia)
C07,xx?xx: Country
C08,0 = Germany (D)
C09,1 = Rest of World (RoW)
C10,2 = United States of America (US)
C11,3 = Canada (CAN)
C12,4 = Great Britain (GB)
C13,5 = Japan (JP)
C14,6 = Saudi Arabia
C15,7 = Australia (AUS)
C16,xxx?x: Seatbelt Warning
C17,0 = Seatbelt Warning inactive (or North American Region OLD - < CW 44/2004)
C18,3 = Seatbelt Warning active (North American Region NEW - CW 45/2004 >)
C19,xxxx?: Variant
C20,0 = Variant 1
C21,1 = Variant 2 (Standard)
C22,2 = Variant 3
So the difference is that the replacement has AWD and Seatbelt warning option bits on, plus "Variant 1" while the original has "Variant 2".
But I really don't think any of this is at all related to immobilizer functionality.
Now when doing an Immo-3 parts swap, there are three components: The keys, the cluster, and the ECU that all have to be matched to each other to have a working car. Whenever you try to match a new one (any of these three), the other two must already match, and it sounds like on your previous attempts, the keys and the ECU had somehow lost their matching? I'm speculating here because I think you said the car wouldn't start and run even with the original cluster installed?
MartinsX
Riga, Latvia
C?ID=268515
If original and replacement clusters have the same part numbers, then just copy all coding from original and type in the replacement. It is suggested to go through adaptation channels too, as some options are switched on/off by adaptation, not by coding.
BTW it is possible, that this is the reason why You was not able to adapt replacement cluster. You should code cluster BEFORE adapting it to ECU/immo system.
Edit: Uwe was faster :)
I didn't look at label file like Uwe did. And there are no engine type in coding :confused: Then what I wrote above is not true... :facepalm:
Benjisan265
C?ID=364854
   Coding: 03200
   VCID: 2E2FCA7AF90F
   Coding: 00201
   Shop #: WSC 00001
   VCID: 8C6BE0F2AF53
C01,??xxx: Options
C07,xx?xx: Country
C08,0 = Germany (D)
C13,5 = Japan (JP)
C19,xxxx?: Variant
C20,0 = Variant 1
C22,2 = Variant 3
Hi Uwe,
My car is an A4 Quattro and if I understand you correctly the original cluster is not coded for the AWD Quattro, but the replacement one is?
Also I'm posting another controller "auto scan" below with the car running for about 15 minutes with the original cluster.
I keep seeing this reference "Control Module in Instrument Cluster (J285) 49-10 - No Communications - Intermittent" for most of the fault codes.
Would you be inclined to agree that the original cluster is SNAFU?
Saturday, 23 March 2019, 13:41:42:18369
Chassis Type: 8E - Audi A4 B6
Scan: 01,02,03,08,09,0F,11,15,16,17,18,36,37,45,46,55,56,57,65,67,69,75,76,77
Address 01: Engine       Labels: 06C-909-559-ASN.LBL
   Controller: 8E0 909 559 D
   Component: 3.0L V6/5V      G   0002
   Coding: 0016751
   Shop #: WSC 63351
   VCID: 361FE21A015F
Readiness: 0110 1101
Address 02: Auto Trans       Labels: 01V-927-156.LBL
   Controller: 8E0 927 156 Q
   Component: AG5 01V 3.0l5V  USA 1213
   Coding: 0001002
   Shop #: WSC 06117
   VCID: 3C0BF0323F73
Address 03: ABS Brakes       Labels: 8E0-614-517.LBL
   Controller: 8E0 614 517 A
   Component: ABS/ESP allrad      1726
   Coding: 04497
   Shop #: WSC 06479
   VCID: 263F325AD1FF
01317 -  Control Module in Instrument Cluster (J285)
01826 -  Sensor for Steering Angle (G85); Supply Voltage Terminal 30
            35-00 -   -
Address 08: Auto HVAC       Labels: 8E0-820-043.LBL
   Controller: 8E0 820 043 G
   Component:   A4 Klimaautomat   0712
   Coding: 00000
   Shop #: WSC 63351
   VCID: 253D3556ACF9
6 Faults Found:
01274 -  Air Flow Flap Positioning Motor (V71)
            41-10 -  Blocked or No Voltage - Intermittent
01592 -  Air Quality Sensor (G238)
            37-00 -  Faulty
00474 -  Control Module for Immobilizer
            27-10 -  Implausible Signal - Intermittent
65535 -  Internal Control Module Memory Error
            00-00 -   -
Address 09: Cent. Elect.       Labels: 8E0-907-279-8E2.LBL
   Controller: 8E0 907 279 E
   Component: int. Lastmodul  USA 0204
   Coding: 00013
   Shop #: WSC 63351
   VCID: 341BD8121723
No Faults Found
  or a communication error ocurred
Address 15: Airbags       Labels: 8E0-959-655-84.LBL
   Controller: 8E0 959 655 A
   Component: Airbag 8.4E         3000
   Coding: 0010607
   Shop #: WSC 63351
   VCID: 351DE5161C59
Address 16: Steering wheel       Labels: 8E0-953-549.LBL
   Controller: 8E0 953 549 L
   Component: Lenksáulenmodul     0308
   Coding: 01141
   Shop #: WSC 63351
   VCID: 3C0BF0323F73
   Coding: 00201
   Shop #: WSC 00001
   VCID: 8C6BE0F2AF53
Address 36: Seat Mem. Drvr       Labels: 8E0-959-760.LBL
   Controller: 8E0 959 760
   Component: Sitzmemory R2 F     0201
   Coding: 00002
   Shop #: WSC 63351
   VCID: F1959106A8B1
00466 -  Control Module for Steering Column Electronics (J527)
Address 37: Navigation       Labels: None
   Controller: 4B0 919 887 D
   Component: BNS 4.1 H05    BNO 0005
   VCID: 341BD8121723
Address 45: Inter. Monitor       Labels: 8E0-951-177.LBL
   Controller: 8E0 951 177
   Component: Innenraumueberw.   0504
   Coding: 00001
   VCID: EBA9836E8A9D
Address 46: Central Conv.       Labels: 8E0-959-433-MAX.LBL
   Controller: 8E0 959 433 T
   Component: Komfortgerát T5B    0616
   Coding: 11788
   Shop #: WSC 63351
   VCID: 42F78ECA5D97
Address 55: Xenon Range       Labels: 4Z7-907-357.LBL
   Controller: 4Z7 907 357
   Component: dynamische LWR       D06
   Coding: 00060
   Shop #: WSC 63351
   VCID: 047B48D20703
Address 56: Radio       Labels: 8E0-035-1xx-56.LBL
   Controller: 8E0 035 195 A
   Component: symphony II NP2    0008
   Coding: 00201
   VCID: 253D3556ACF9
End   --------------------------------------------------------------------------------------------------
   #35
What are block values of each cluster?
0x17-08-002?
0x17-08-081?
Please bifurcate and identify each cluster log for full disclosure!
Report!
   #36
Benjisan265
C?ID=364854
0x17-08-002?
0x17-08-081?
Report!
Will do Jack.
But since we have company arriving shortly I won't be able to do it at the moment, but perhaps a little later this evening.
My wife is here and she said "thank you" for saving my behind last night with your sage advice. Also she's starting to warm up to me a just little bit more regarding this Audi.
   #37
Benjisan265
C?ID=364854
0x17-08-002?
0x17-08-081?
Report!
Hi Jack,
Replacement cluster.
002 - odometer 0km - Receiver N.0?? - 110 - 11.0*C
081 - WAUVC68E92??? - A245311 AU - Z6Z0B00216 - 43<>
Original Cluster
002 - 180840 km - Receiver N.O?? - 110 - 10.8*C
081 - WAULT68E52 - A099660 AU - Z6Z0A02084 - 91 <>
I hope that this is what you were looking for Jack.
   #39
Benjisan265
C?ID=364854
It was set to 0 miles with the use of the same software that was able to retrieve the SKC.
