2002 Audi A4 3.0L Runs And Shuts-Off Imediately. Need Advice On What To Check.
Benjisan265
Verified VCDS-Lite User
C?ID=364854
Hi, I recently purchased an inexpensive 2002 Audi A4 3.0L that has some issues.
The car was recently running, but now it starts right up and immediately dies. When I purchased the car the previous owner stated that the car was in need of a replacement instrument cluster because the temp gauge was in operable, fuel gauge would read intermittently and the oil pressure light was coming on and going off randomly. (oil pressure light would come on for about 2 minutes and then stay off for 15 or 20 minutes) The oil pressure was tested and it was well within the specified range for various rpm's. Previous owner had receipts for all sensors being recently changed within the last year and the above problems still remained. The fuel sending unit had also been changed (previous owner claims, but that was over 3 years ago)
Well now here is what I have done.
I used Vag EEprogrammer software to retrieve the SKC from the OEM cluster. Right after I retrieved the SKC from the cluster is when I believe the problem started with the Audi starting right up and then immediately shutting off.
So thinking the original cluster was toast I then swapped out the original cluster and retrieved the SKC from the replacement cluster.
I was able to login to both clusters using VCDS-Lite okay, but when I swapped in the replacement and try to adapt the cluster SKC for some reason I'm not able to change replacement cluster SKC key to the original cluster SKC.
When I read Adaptation - 10 and read channel 050 in the Immobilizer - Vehicle Data Learning box and clear out the new value field and test I don't get the vin# information in field 1 or 2.
When I hit save I get a system error populated in field 1.
I'm attaching the VCDS controller info below, but this is with the replacement cluster still connected.
If anybody has any ideas or sees anything obvious I would sure appreciate any insight.
Right now I'm just scratching my head at all the information contained below because I'm new to Audi's and feeling clueless.
Kind Regards,
Robert
VCDS-Lite Version: Release 1.2
Thursday, 21 March 2019, 18:47:11:18369
Chassis Type: 8E - Audi A4 B6
Scan: 01,02,03,08,09,0F,11,15,16,17,18,36,37,45,46,55,56,57,65,67,69,75,76,77
Address 01: Engine       Labels: 06C-909-559-ASN.LBL
   Controller: 8E0 909 559 D
   Component: 3.0L V6/5V      G   0002
   Coding: 0016751
   Shop #: WSC 63351
   VCID: 361FE21A015F
17978 -  Engine Start Blocked by Immobilizer
            P1570 - 008 -  Implausible Signal
18010 -  Power Supply Terminal 30: Voltage too Low
            P1602 - 002 -  Lower Limit Exceeded - Intermittent
18107 -  Powertrain Data Bus: Missing Message from Steering Wheel Electronics
            P1699 - 008 -  Implausible Signal - Intermittent
18043 -  Powertrain Data Bus: Missing Message from A/C Controller
            P1635 - 008 -  Implausible Signal - Intermittent
18058 -  Powertrain Data Bus: Missing Message from Instrument Cluster
            P1650 - 004 -  No Signal/Communication - Intermittent
Readiness: 0110 1101
Address 02: Auto Trans       Labels: 01V-927-156.LBL
   Controller: 8E0 927 156 Q
   Component: AG5 01V 3.0l5V  USA 1213
   Coding: 0001002
   Shop #: WSC 06117
   VCID: 3C0BF0323F73
Address 03: ABS Brakes       Labels: 8E0-614-517.LBL
   Controller: 8E0 614 517 A
   Component: ABS/ESP allrad      1726
   Coding: 04497
   Shop #: WSC 06479
   VCID: 263F325AD1FF
01317 -  Control Module in Instrument Cluster (J285)
            49-00 -  No Communications
01826 -  Sensor for Steering Angle (G85); Supply Voltage Terminal 30
            35-00 -   -
Address 08: Auto HVAC       Labels: 8E0-820-043.LBL
   Controller: 8E0 820 043 G
   Component:   A4 Klimaautomat   0712
   Coding: 00000
   Shop #: WSC 63351
   VCID: 253D3556ACF9
7 Faults Found:
01274 -  Air Flow Flap Positioning Motor (V71)
            41-10 -  Blocked or No Voltage - Intermittent
01592 -  Air Quality Sensor (G238)
            37-00 -  Faulty
            49-10 -  No Communications - Intermittent
01206 -  Signal for Duration of Ignition Off Time
            27-00 -  Implausible Signal
00474 -  Control Module for Immobilizer
            27-10 -  Implausible Signal - Intermittent
65535 -  Internal Control Module Memory Error
            00-00 -   -
Address 09: Cent. Elect.       Labels: 8E0-907-279-8E2.LBL
   Controller: 8E0 907 279 E
   Component: int. Lastmodul  USA 0204
   Coding: 00013
   Shop #: WSC 63351
   VCID: 341BD8121723
            79-00 -  Please Check Fault Codes
01312 -  Powertrain Data Bus
01326 -  Control Module for Multi-Function Steering Wheel (J453)
Address 15: Airbags       Labels: 8E0-959-655-84.LBL
   Controller: 8E0 959 655 A
   Component: Airbag 8.4E         3000
   Coding: 0010607
   Shop #: WSC 63351
   VCID: 351DE5161C59
Address 16: Steering wheel       Labels: 8E0-953-549.LBL
   Controller: 8E0 953 549 L
   Component: Lenksáulenmodul     0308
   Coding: 01141
   Shop #: WSC 63351
   VCID: 3C0BF0323F73
Address 17: Instruments       Labels: 8E0-920-9xx-8E2.LBL
   Controller: 8E0 920 950 H
   Component: KOMBI+WEGFAHRS. RB4 D26
   Coding: 03200
   VCID: 2E2FCA7AF90F
   WAUVC68E92A245311     AUZ6Z0B0021643
00562 -  Sensor for Oil Level/Temperature (G266)
            30-10 -  Open or Short to Plus - Intermittent
01176 -  Key
            65-10 -  Unauthorized - Intermittent
01314 -  Engine Control Module
01315 -  Transmission Control Module
01304 -  Radio
Address 36: Seat Mem. Drvr       Labels: 8E0-959-760.LBL
   Controller: 8E0 959 760
   Component: Sitzmemory R2 F     0201
   Coding: 00002
   Shop #: WSC 63351
   VCID: F1959106A8B1
00466 -  Control Module for Steering Column Electronics (J527)
Address 37: Navigation       Labels: None
   Controller: 4B0 919 887 D
   Component: BNS 4.1 H05    BNO 0005
   VCID: 341BD8121723
Address 45: Inter. Monitor       Labels: 8E0-951-177.LBL
   Controller: 8E0 951 177
   Component: Innenraumueberw.   0504
   Coding: 00001
   VCID: EBA9836E8A9D
Address 46: Central Conv.       Labels: 8E0-959-433-MAX.LBL
   Controller: 8E0 959 433 T
   Component: Komfortgerát T5B    0616
   Coding: 11788
   Shop #: WSC 63351
   VCID: 42F78ECA5D97
01330 -  Central Control Module for Central Convenience (J393)
            53-10 -  Supply Voltage Too Low - Intermittent
01371 -  Alarm triggered by Door Contact Switch; Driver's Side
            35-00 -   -
00532 -  Supply Voltage B+
            37-10 -  Faulty - Intermittent
01562 -  Right Rear Door
            59-10 -  Can't Unlock - Intermittent
Address 55: Xenon Range       Labels: 4Z7-907-357.LBL
   Controller: 4Z7 907 357
   Component: dynamische LWR       D06
   Coding: 00060
   Shop #: WSC 63351
   VCID: 047B48D20703
Address 56: Radio       Labels: 8E0-035-1xx-56.LBL
   Controller: 8E0 035 195 A
   Component: symphony II NP2    0008
   Coding: 00201
   VCID: 253D3556ACF9
00856 -  Radio Antenna
            36-10 -  Open Circuit - Intermittent
01336 -  Data Bus for Comfort System
End   --------------------------------------------------------------------------------------------------
Please clear all those fault codes, cycle the ignition, and do a new scan so people can see what might be current / relevant.
You have PINs for both clusters, right? As long as the new (used) replacement cluster is not matched to the ECU, it will have a different PIN (that actually belongs to its donor car).
Jef
HQ
Connect to the ECM, go into MVB 081 and verify you see the car's VIN there.
And are you sure the instrument cluster is a matching part number to the original?
Controller: 8E0 920 950 H <==== what as the original cluster part number?
Coding: 03200
VCID: 2E2FCA7AF90F
Ran the VIN, came from a car with a 1.8T and you have a 3.0.
Benjisan265
C?ID=364854
Yes Uwe, I was able to retrieve both SKC's from their respective instrument clusters.
Benjisan265
C?ID=364854
That vin# is probably correct for the replacement instrument cluster. Does the replacement instrument cluster have to be from a 3.0l too?
Replacement instrument cluster is still connected.
I used the part number from the original cluster -----> 8E0920950H and purchased a cluster from a salvage yard with the same part number.
I will clear out the codes tomorrow and repost a controller scan.
01176 - Key
Marry or install correct Key or cluster or both...........
Benjisan265
C?ID=364854
Hi all.
Just re-scanned the car with the original cluster installed and with DTC's cleared. I had to go through each controller (I hope I got them all as it was trial and error) to clear the fault codes since the option to clear all faults was greyed out in auto scan.
Friday, 22 March 2019, 00:07:54:18369
   Coding: 0016751
   Shop #: WSC 63351
   VCID: 361FE21A015F
   Coding: 0001002
   Shop #: WSC 06117
   VCID: 3C0BF0323F73
   Coding: 04497
   Shop #: WSC 06479
   VCID: 263F325AD1FF
            35-00 -   -
   Coding: 00000
   Shop #: WSC 63351
   VCID: 253D3556ACF9
            37-00 -  Faulty
            00-00 -   -
   Coding: 00013
   Shop #: WSC 63351
   VCID: 341BD8121723
   Coding: 0010607
   Shop #: WSC 63351
   VCID: 351DE5161C59
   Coding: 01141
   Shop #: WSC 63351
   VCID: 3C0BF0323F73
   Controller: 8E0 920 980 KX
   Component: KOMBI+WEGFAHRS. RB4 D30
   Coding: 00201
   Shop #: WSC 00001
   VCID: 8C6BE0F2AF53
   WAULT68E52A099660     AUZ6Z0A0208491
   Coding: 00002
   Shop #: WSC 63351
   VCID: F1959106A8B1
   VCID: 341BD8121723
   Coding: 00001
   VCID: EBA9836E8A9D
   Coding: 11788
   Shop #: WSC 63351
   VCID: 42F78ECA5D97
   Coding: 00060
   Shop #: WSC 63351
   VCID: 047B48D20703
   Coding: 00201
   VCID: 253D3556ACF9
Benjisan265
C?ID=364854
I tried to adapt the new cluster once again using VCDS and I'm able to login using that clusters retrieved SKC. When I enter the adaption area and enter channel 050 and hit read the first field populates with the word Pin ? and a question mark. I then put in the original clusters SKC and hit test I never get the Vin# or any other information in the field boxes to populate.
If I hit save the word ERROR populates the first field box and the next 3 read Channel 50 - Not - Available
Anybody have any ideas if there's other channels to be used with and early 2002 A4?
Edit: Also I'm getting the same results with the original cluster too. Car only runs for 3 seconds and dies. Immobilizer flashes with the original cluster and key.
Benjisan265
C?ID=364854
Quick question?
Since I replaced the cluster can my original used key still be used since the immobilizer pill in the key has been used already?
You can't do that 050 swap with an unauthorized key or a cluster in used status RB4 now can you?
Post the advanced ID of both clusters please.
Kids today, I'll tell ya?
Why are you changing the cluster?
Quick question?
With VCDS NO!
With alternate options yes or changing to a fresh transponder than you can use VCDS but only after deleting all keys!
Benjisan265
C?ID=364854
Thanks Jack,
The previous owner of the car was having issues with the fuel gauge, temp gauge and a intermittent oil pressure light that would just randomly appear for about two minutes and then disappear for the next 15 or 20 minutes of driving.
He had receipts from the Audi dealership by him that was servicing the car which showed the fuel sending unit in the tank was replaced a few years back and most recently the replacement of the temp sending switch and oil pressure switch. He was told by that same dealership that the car most likely needed a new instrument cluster but he couldn't justify the $1200 for the cluster and installation cost.
I confirmed oil pressure was well within spec before I purchased the car and did some research which seemed to indicate that I could replace the cluster with a good used one by retrieving the SKC of both clusters and using VCDS to adapt it.
Now I have a car that only runs for 3 seconds and I'm stumped as to why. The Ross Tech video on Imo 3 and cluster swapping made it look so simple.
Can you advise me on how to get the advanced ID of both clusters please.
Kind Regards,
Robert
[Select]
[17-Instruments]
[Advanced ID]
You'll have to screen-shot it because VCDS-Lite does not have a Save button on that screen.
Benjisan265
C?ID=364854
[Select]
[17-Instruments]
[Advanced ID]
Okay, I will try to do that later on this evening and post a screen shot.
Benjisan265
C?ID=364854
[Select]
[17-Instruments]
[Advanced ID]
Hi Uwe,
My version VCDS-Lite doesn't give me that option. All the buttons Readiness, Advanced ID, and the other one are all grayed out. I also don't have the use of the Clear Faults button under Auto Scan for the controllers.
Is there something different with my software then what you guys use.
I bought a activation license a couple of days ago.
I don't remember which protocol the instrument cluster in your car uses. If it's KWP-2000, then the Advanced ID button should be available. However, if it's KW-1281 (the original VAG protocol) then the Advanced ID button will not be available because the protocol doesn't support that function.
[Select]
[17-Insturments]
Let VCDS connect and tell us which of the above-mentioned protocols is shown.
As for Clear All Fault Codes on the Auto-Scan screen, that isn't supported by VCDS-Lite. You have to go to each control module individually to clear faults.
