Had a really strange issue on this.... no lights, no faults prior to doing this work.
The Van went in for it's annual MOT and it failed on various suspension items. So adopting the whilst in there, we replaced everything on the front to make it "as new".
We replaced on both sides at the front
wheel bearings
drive shafts
ABS sensors
Shock absorbers
Springs
Top mounts
ARB bushes
Tie rod ends
bottom ball joints etc etc
built it all back up and we had a 00285 mechanical fault in ABS sensor G45 (front right)... after replacing the wheel bearings 3 times (found 2 were faulty and not giving a reading) , and 2 new ABS sensors, all the wiring was checked back to the ABS ecu, both voltage and continuity and all checked out perfectly. Even physically checked the actual wiring to see that there wasn't any bad joints etc.
On VCDS you can see in measuring blocks 001 all 4 ABS/Speed sensors and you could see the readings, so communications were there, as soon as you drove above 25mph (40km/h) the ABS light came on and the fault reappeared. When driving and looking at the measuring blocks you could see the speed drop on the G45 sensor where the others kept a stable reading.
The Van has gone to a garage (who's owner is usually full of BS) and we asked him to realign the front suspension as it was out after the suspension rebuild and he says he has recalibrated the sensor and we now don't have any warning light or fault code..... I could not find anything on VCDS that allowed us to recalibrate anything, what has he done?
Also before it went to him the speed sensor would read actual speed, now it stops reading at 49-50km/h on all 4 ABS sensors...?
Any ideas at all as i'm baffled......???
wheel bearings
drive shafts
ABS sensors
Shock absorbers
Springs
Top mounts
ARB bushes
Tie rod ends
