HI
i need some help to figure this out. Cruise control is not working. Ecm has code p1698 which tells me to check for codes in the steering wheel electronics. no faults in there., if i clear the codes is comes back right away.
Any ideas. thank you
Monday,18,March,2019,14:24:20:15753
VCDS Version: 18.9.0.4 HEX-NET CB: 0.4436.4
VIN: 3VWRL8AJXAM100297 License Plate: HAROLD
Mileage: 224680km-139609mi Repair Order:
Chassis Type: AJ-VW36 (1K0)
Scan: 01 03 08 09 15 16 17 19 1C 25 2E 42 44 46 52 56 62 72 77
VIN: 3VWRL8AJXAM100297 Mileage: 224680km-139609miles
2E-Media Player 3 -- Status: Cannot be reached 1100
Address 01: Engine (CJA) Labels: 03L-906-022-CBE.clb
Part No SW: 03L 906 019 CL HW: 03L 906 022 TS
Component: R4 2,0L EDC G000SG 7966
Revision: 12H03--- Serial number:
Coding: 0350072
Shop #: WSC 91584 999 85521
VCID: 77BE3BF106F0CDF2EA-8022
005078 - Cylinder 3 Internal Pressure Sensor
P13D6 - 000 - Implausible Signal - Intermittent
Mileage: 224636 km
Date: 2013.08.01
Time: 17:43:60
RPM: 1564 /min
Speed: 61.0 km/h
Bin. Bits: 00001010
Absolute Pres.: 57.0 bar
(no units): 12.70
Ign. Timing: 8.6 °BTDC
(no units): -10.00
005784 - Please Check DTC Memory of Steering Wheel Electronics
P1698 - 000 - - Intermittent
Mileage: 224638 km
Date: 2013.08.01
Time: 17:47:10
RPM: 1633 /min
Speed: 97.0 km/h
Load: 29.8 %
(no units): 255.0
(no units): 255.0
Bin. Bits: 00000000
Part No SW: 1K0 907 379 AH HW: 1K0 907 379 AH
Component: ESP MK60EC1 H30 0107
Revision: 00H30001
Coding: 114B400C492200FA880D02ED92200042300000
VCID: 78BC38CDCBEEC28AE3-802C
Part No SW: 3C8 907 336 AC HW: 3C8 907 336 AC
Component: Climatic H14 0305
Revision: 00009001
Coding: 0000000002
Shop #: WSC 00066 000 00187
ROD: EV_ClimaBasis_VW36.rod
VCID: 6E901E95B1AA8C3A39-803A
Part No SW: 5K0 937 084 C HW: 5K0 937 084 C
Component: BCM PQ35 B 011 0028
Revision: BG011001
Coding: 2D200B1E902F3EE4000800854000000401000086500085605C8020000000
VCID: 3228CAE56D12E8DA1D-8066
Subsystem 1 - Part No: 1K1 955 119 F Labels: 1KX-955-119.CLB
Component: Wischer 15021 21 0512
Coding: 009795
Part No SW: 1K0 909 605 AD HW: 1K0 909 605 AD
Component: 08 AIRBAG VW8R 036 8900
Revision: 06036000 Serial number: 003EVM025X4S
Coding: 0012344
VCID: 6E901E9579AA8C3A39-803A
Subsystem 1 - Serial number: 6332MSME4E36285FS
Subsystem 2 - Serial number: 6342MSME4E346B22I
Subsystem 3 - Serial number: 6351HSME1F17243EE
Subsystem 4 - Serial number: 6361HSME1F172F12C
Subsystem 5 - Serial number: 63727SME1F7142752
Subsystem 6 - Serial number: 63827SME1F710470$
Part No SW: 1K0 953 549 CD HW: 1K0 953 549 CD
Component: J0527 056 0111
Coding: 0000731
VCID: 76A036F501FAB4FAF1-8022
Subsystem 1 - Part No: 5K0 959 542 Labels: 3C8-959-537.CLB
Component: E221__MFL-TAS H05 0010
Coding: 00000130
Part No SW: 5M0 920 870 E HW: 5M0 920 870 E
Component: KOMBI H05 0305
Coding: 371F00
Shop #: WSC 00066 000 00148
VCID: 312AC5E96014D3C264-8064
Part No SW: 1K0 907 530 AD HW: 1K0 907 951
Component: J533 Gateway H07 0112
Revision: H07 01 Serial number: 060110F2000655
Coding: E9807F06001612001002
VCID: 699A6D8940446B026C-803C
01304 - Radio
Reset counter: 122
Mileage: 208689 km
Date: 2013.03.12
Time: 04:45:24
Reset counter: 122
Mileage: 208689 km
Date: 2013.03.12
Time: 04:45:24
03272 - Control Module for Audio Interface
Reset counter: 122
Mileage: 208689 km
Date: 2013.03.12
Time: 04:45:24
Part No SW: 1K5 919 965 D HW: 1K5 919 965 D
Component: Kompass 001 0001
Revision: 00001000 Serial number: 1293324T4V7Z05
Coding: 0000004
VCID: 3C34E4DD7F562EAAC7-8068
Component: IMMO H05 0305
VCID: 6A9812858D42601A65-803E
Address 2E: Media Player 3
Part No SW: 3C0 959 701 B HW: 3C0 959 793
Component: TUER-SG FT 002 0307
Revision: 13101005 Serial number: 0000369799
Coding: 0004B5
Shop #: WSC 01383 790 50316
ASAM Dataset: EV_DCU42BroseDriveSide A03004
ROD: EV_DCU42BroseDriveSide_VW36.rod
VCID: 271E2BB15ED09D72BA-8072
Slave Driver:
Subsystem 1 - Part No SW: 1K0 959 703 AH HW: 1K0 959 795 T Labels: 1K0-959-70X-GEN4.CLB
Component: J388__TSG-HL 006 1401
Serial number: 00000004609138
Coding: 000490
67330 - Switch for Central Locking
B122D 29 [008] - Signal Implausible
Reset counter: 35
Part No: 1K0 909 144 J
Component: EPS_ZFLS Kl. 70 3001
Revision: 00H17000
VCID: 312AC5E9A814D3C264-8064
Part No SW: 3C0 959 702 B HW: 3C0 959 792
Component: TUER-SG BT 002 0307
Revision: 15101005 Serial number: 0000342246
Coding: 0004B4
ASAM Dataset: EV_DCU52BrosePasseSide A03004
ROD: EV_DCU52BrosePasseSide_VW36.rod
VCID: 281C288D53CE920AB3-807C
Slave Passenger:
Subsystem 1 - Part No SW: 1K0 959 704 AH HW: 1K0 959 794 T Labels: 1K0-959-70X-GEN4.CLB
Component: J389__TSG-HR 006 1401
Serial number: 00000004639105
Coding: 000490
Address 56: Radio
Address 77: Telephone
End----------(Elapsed Time: 01:07, VBatt start/end: 14.5V/14.5V)-----------
