Alltrack Blind Spot Monitor/Side Assist Retrofit Issue
pixlgeek
C?ID=44198
I have a 2018 Canadian Alltrack Highline, I had all the Driver Assist functionality except BSM sensors from factory. I ordered the AliExpress BSM retrofit kit and installed, wired, and coded (based on XaGiCo's tutorial), and installed the side mirrors with the integrated LEDs. No matter what I try, I can't get the Blind Spot Monitor option to enable in the MFD. It throws codes about Warning Lamp Open or Short and various other faults. I've been racking my brain about this for weeks now, any help would be greatly appreciated.
Here is an Auto-Scan showing all of the found faults:
Friday,15,February,2019,23:17:08:51593
VCDS -- Windows Based VAG/VAS Emulator Running on Windows XP x86(VMWare)
VCDS Version 18.9.1.0  HEX-V2 CB: 0.4437.4
VIN: 3VWM17AU4JM759805   License Plate:
Mileage: 24746km-15376mi   Repair Order:
Chassis Type: AU-VW37 (3Q0)
Scan: 01 03 05 08 09 10 13 15 16 17 19 22 29 2B 39 3C 42 44 47 4B
          52 5F 69 A5 CA D6 D7
VIN: 3VWM17AU4JM759805   Mileage: 24746km-15376miles
CA-Sunroof -- Status: OK 0000
Address 01: Engine (J623-CXBB)       Labels:. 06K-907-425-V1.clb
   Part No SW: 8V0 906 264 M    HW: 06K 907 425 B
   Component: 1.8l R4 TFSI  H13 0001
   Revision: --H13---
   Coding: 311900322456002F1000
   Shop #: WSC 00066 790 00235
   ASAM Dataset: EV_ECM18TFS0208V0906264M 001003
   ROD: EV_ECM18TFS0208V0906264M.rod
   VCID: 46D5AA3B182B75A7E41-8013
Readiness: 1010 0101
Address 03: ABS Brakes (J104)       Labels:* 5Q0-907-379-ESP-V1.clb
   Part No SW: 5Q0 614 517 AM    HW: 5Q0 614 517 AB
   Component: ESC           H25 0312
   Revision: 00000000    Serial number: 61987000000894
   Coding: 43FA6AA134250975407F030080C829C2562C9002C001943C34435050E0A9430000010312121212B435351919323200
   Shop #: WSC 01383 790 50316
   ASAM Dataset: EV_Brake1UDSContiMK100ESP 036010
   ROD: EV_Brake1UDSContiMK100ESP_036_VW37.rod
   VCID: 7CA108D31667FF77C25-8029
   Part No SW: 5Q0 959 435 C    HW: 5Q0 959 435
   Component: VWKESSYMQB    021 0803
   Revision: 00021000    Serial number: 0451731886
   Coding: 032C0C
   ASAM Dataset: EV_KessyHellaMQBAB 002020
   VCID: 3C21C8D356E73F77825-8069
   Part No SW: 5GM 907 044 G    HW: 5GM 907 044 G
   Component: Climatronic   H04 2001
   Revision: 00001K05
   Coding: 0202002420011801010400000010140A
   ASAM Dataset: EV_ACClimaBHBVW37X 006146
   VCID: 48C9A403123F63D716D-801D
   Part No SW: 5Q0 937 087 AR    HW: 5Q0 937 087 AN
   Component: BCM PQ37BOSCH 034 0243
   Revision: --------    Serial number: C86416101701RO
   Shop #: WSC 00066 790 00395
   ROD: EV_BCMBOSCH_018.rod
   VCID: 0B435B0F43C9C8CFFBF-805F
   Subsystem 1 - Part No SW: 5G1 955 119 A    HW: 5G1 955 119   Labels: 5QX-955-119-V1.CLB
   Component: WWS    170902  043 0551
   Serial number: 97022066170909160759
   Component: RLHS  042 0105
   Serial number: S7Y17M09D11H15M18S52
   Coding: 00A8DD
   Part No SW: 5QA 919 298 C    HW: 5QA 919 298 A
   Serial number: 000116644R17298
   Coding: 0271167901
   ROD: EV_EPHVA2CAU3700000_009_VW37.rod
   VCID: 50F98C63EA6FAB174ED-8005
13688835 - Databus
          [Steuerger‰t f¸r Rear Cross Traffic Alert - RCTA_01.RCTA_Status - Fehlerspeicher auslesen]
                    Reset counter: 205
                    Mileage: 24746 km
                    Date: 2019.02.15
                    Time: 23:14:30
   Part No SW: 5Q0 907 572 J    HW: 3QF 907 572
   Component: ACC BOSCH MQB H10 0654
   Coding: 2D0000C941FFC728949C810510400600000000000000000000
   ASAM Dataset: EV_ACCBOSCHVW416 002006
   VCID: 3E25C2DB40FB2D67AC1-806B
   Part No SW: 5Q0 959 655 T    HW: 5Q0 959 655 T
   Component: AirbagVW20    011 0830
   Serial number: 003MHM040EB7
   ROD: EV_AirbaVW20SMEVW37X.rod
   VCID: 51FF8967E165A21F413-8005
   Occupant Detection:
   Serial number: IBH000000000007UKKGA
   Coding: 303136
   Subsystem 2 - Part No SW: -----------    HW: 480 003 008 17
   Serial number: 35700000000F022D652H
   Subsystem 3 - Part No SW: -----------    HW: 480 003 008 17
   Serial number: 358000000008122D652C
   Subsystem 4 - Part No SW: -----------    HW: 480 403 009 17
   Serial number: 3510001AF2653ED277FN
   Subsystem 5 - Part No SW: -----------    HW: 480 400 209 17
   Serial number: 3520001BF2711E12D22$
   Subsystem 6 - Part No SW: -----------    HW: 480 402 509 17
   Serial number: 3550002A3252D870427Z
   Front Sensor Passenger:
   Subsystem 7 - Part No SW: -----------    HW: 480 402 509 17
   Serial number: 3560002A125629A1B2F4
   Part No SW: 5Q0 953 507 HN    HW: 5Q0 953 549 E
   Revision: --------    Serial number: 13101704401550
   Coding: 0C00
   ROD: EV_SMLSKLOMQB_VW37.rod
   VCID: 094F610749B5DADFC93-805D
   Part No SW: 5G1 920 740 C    HW: 5G1 920 740 C
   Component: KOMBI         242 0310
   Coding: 0BA51015ED88CF0502886B0B1001000080000000
   VCID: 26150ABBB86B95A7C41-8073
   Part No SW: 3Q0 907 530 G    HW: 3Q0 907 530 C
   Component: GW MQB High   518 5304
   Serial number: 31101700840746
   Coding: 0901000830085900FB00221A0A0F00000001070000000000000000000000
   Shop #: WSC 00066 790 00215
   ROD: EV_GatewNF_VW37.rod
   VCID: 3333E3EF7BB9F00F53F-8067
   Subsystem 2 - Part No SW: 5G0 959 442 R    HW: 5G0 959 442 R  Labels: 3C8-959-537.CLB
   Serial number: 26170001760110071439
   Coding: 34FFFF
   Power Converter DC AC:
   Subsystem 3 - Part No SW: 5Q0 907 155 A    HW: 5Q0 907 155 A
   Component: U13DCAC  H25 0780
   Serial number: 0002861
   Serial number: HA1-00013.07.17
   Coding: 0001
   VCID: 4ACD9E0B0C3391C7009-801F
   Part No SW: 8V0 907 399 D    HW: 8V0 907 399 D
   Component: LCM_MLBevoH08 0014
   VCID: 47CBA73F1F216CAF1F7-8013
   Revision: 00000000    Serial number: 17000219357008
   Coding: 5500000000000000
   ROD: EV_ELVMarquMQB.rod
   VCID: 3431E0F37EB7F7374A5-8061
   Component: HRE_Master    H11 0071
   Serial number: 0391048016
   Coding: 02022103
   ROD: EV_HREntryHella_VW37.rod
   Lane Change Assistant 2:
   Component: HRE_Slave  H11 0071
   Serial number: 0390829739
   Coding: 020221
730378 - Warning Lamp for Blind Spot Detection in Left Exterior Mirror
          C122C 15 [009] - Open or Short to Plus
                    Reset counter: 205
                    Mileage: 24746 km
                    Date: 2019.02.15
                    Time: 23:14:30
730634 - Warning Lamp for Blind Spot Detection in Right Exterior Mirror
          C122D 15 [009] - Open or Short to Plus
                    Reset counter: 205
                    Mileage: 24746 km
                    Date: 2019.02.15
                    Time: 23:14:30
   Serial number: 5038729500985
   Coding: 003B13205000020000000000
   Serial number: 00000000000006840570
   Coding: 011000
   Part No SW: 5QM 909 144 A    HW: 5QM 909 144 A
   Component: EPS_MQB_ZFLS  171 1072
   Coding: 9302
   ROD: EV_SteerAssisMQB_013.rod
   VCID: 4FFB8F1FF751B4EF577-801B
Address 47: Sound System (J525)       Labels:| 5Q0-035-456.clb
   Part No SW: 5Q0 035 456 A    HW: 5Q0 035 456 A
   Component: MIB2_lite_amp H40 0200
   Revision: 00000001    Serial number: VWZ8Z1HMD00QJ1P
   Coding: 2200000000AAAAAA000000000000
   ASAM Dataset: EV_AMPMst12C1Gen2ALPI 001003
   ROD: EV_AMPMst12C1Gen2ALPI.rod
   VCID: 2E05F29B909BDDE73C1-807B
   Serial number: 24101700840054
   Coding: 000000050100211200110F01030000000000000000000000000000000000
   VCID: 72BD26EB4423B907989-8027
   Serial number: 6038729701846
   Coding: 003B13205C00020000000000
   Serial number: 00000000000018100107
   Coding: 091000
   Part No SW: 3Q0 035 876 B    HW: 3Q0 035 876 B
   Component: MU-S-NS-US    851 0867
   Coding: 027312020000000051220002001828001F0508F401200505C6
   ROD: EV_MUStd4CDELP_VW26.rod
   Subsystem 1 - Part No SW: 5G6 919 605 D    HW: 5G6 919 605 D
   Component: ABT_Std-2_Nav  H50 8130
   Serial number: VWZ6ZJT2971141
   Subsystem 2 - Part No SW: 3G0 919 866 BH    HW: -----------
   Component: NAR 2017/18  --- 0620
7204 - Function Restricted due to Missing Message(s)
          U1111 00 [009] - -
          [Tilt-angle indicator (0x24) - function restriction due to communication error - BapErr_retry not successful]
                    Reset counter: 205
                    Mileage: 24746 km
                    Date: 2019.02.15
                    Time: 23:11:27
                    Voltage terminal 30: 14.0 V
                    BAP-BAP_Function_ID: 02
   Part No SW: 5Q0 907 383 H    HW: 5Q0 907 383 C
   Component: Anhaenger     H21 0203
   Revision: 8B001003    Serial number: 0382156092
   Coding: 0200000202000000
   Shop #: WSC 00028 028 00066
136203 - Supply Voltage
          P1757 00 [008] - Open Circuit
                    Reset counter: 245
                    Mileage: 24746 km
                    Date: 2019.02.15
                    Time: 23:11:56
   Part No SW: 3Q0 980 654 H    HW: 3Q0 980 654 A
   Component: MQB_B_MFK     H08 0272
   Serial number: 08091712K12083
   Coding: 000307020002020100221347C150490094000E200120
1122656 - Databus
          [TIMEOUT_SWA_Objekt_01_02]
                    Reset counter: 205
                    Mileage: 24746 km
                    Date: 2019.02.15
                    Time: 23:11:24
                    Control Module temperature: 30 ∞C
                    Outside air temperature: 22.0 ∞C
                    Vehicle speed: 0.00 km/h
                    System run time: 547.2 s
                    Voltage terminal 15: 13.8 V
                    mid: 02 10
                    Status of camera: operational
                    Engine_Running_Info: 1
                    Software_Info_4: 2
                    Software_Info_3: 7
                    Software_Info_2: 2
                    Software_Info_1: 0
   Coding: 00804073720C
   VCID: 3D27C5D74DFD367FB5B-8069
   Part No SW: 7P5 941 572 A    HW: 7P5 941 572 A
   Component: LED1L         H06 0002
   ASAM Dataset: EV_LEDMinMaxL_KEBODAVW481 001003
   ROD: EV_LEDMinMaxL_KEBODAVW481.rod
   VCID: 392FD1C759D50A5F993-806D
   Component: LED1R         H06 0002
   ASAM Dataset: EV_LEDMinMaxR_KEBODAVW481 001003
   ROD: EV_LEDMinMaxR_KEBODAVW481.rod
End----------(Elapsed Time: 01:56, VBatt start/end: 13.8V/13.8V)-----------
golfi_vend
Tartu, Estonia
C?ID=195131
Is wiring correct? Which mirrors/glasses have You installed?
Possible that polarity of LED is swapped?
pixlgeek
C?ID=44198
I installed the mirrors that came with the kit, so I can only assume they are correct. I thought about polarity as well and tried reversing the pins on the cable but received the same issue.
pixlgeek
C?ID=44198
Ok, I figured out the issue. The port on the mirrors where the plug enters is deep and the pins were not properly seating into the plugs.
