Lost remote fob function (7L6 Touareg)
Akron04
C?ID=364043
I got my VCDS on Friday, anxious to try it out and wanting to get rid of an annoying TPMS warning I fired up VCDS on my laptop. I followed a youtube video on how to get rid of the warning by going into CAN, adaptation, "do it". All was well. Light went away. I also enabled the function to turn off DRL and seat belt warning. At some point I scanned and cleared codes. Once I was done I had lost key fob functionality.
Today I was able to get my security access code and reprogram the keys. Well sort of, I need to do it over because only one key got programmed properly. Anyway still no remote lock/unlock.
Background: The Touareg (2004 V8) has had the dreaded battery drain. I had pulled some various fuses for phone, sat nav, etc. Finally found it to be the radio/amp fuses. Drain is gone BUT I don't think I had all the other fuses back in. Yesterday and today I checked and made sure all proper fuses were populated per my owners manual. Even after key reprogram I have no remote function. I have an 8:30am appointment at the dealer (11 hours from now) to look at it.
What could I have done to lose the remote function? There is no "remote control adaptation" in any menu I can find in VCDS.
VCDS Windows Based VAG/VAS Emulator Running on Windows 10 x64 VCDS Version: Beta 19.1.2(x64) Data version: 20190131 DS301.0 www.Ross-Tech.com
Dealer/Shop Name: Workshop Code: 000 00000 000000
Self-Diagnosis Log Monday,18,March,2019,15:57:55:59747
VIN: WVGCM77L14D062138   License Plate: Mileage: 165820km-103035mi   Repair Order:
Chassis Type: 7L (7L - VW Touareg (2003 > 11/2006)) Scan: 01 02 03 05 06 08 09 11 13 15 16 17 18 19 1C 22 29 32 34 36          37 39 3C 46 47 55 56 57 64 65 68 69 6C 6D 6E 75 76 77
VIN: WVGCM77L14D062138   Mileage: 165820km-103035miles ------------------------------------------------------------------------------Address 01: Engine        Labels: 077-907-560-AXQ.lbl   Part No SW: 4D0 907 560 DA    HW: 8E0 907 560    Component: 4.2L V8/5V      G   0050     Coding: 0007875   Shop #: WSC 05246 444 58887   VCID: 6889B98F1E6D4D77003-5160
1 Fault Found: 17978 - Engine Start Blocked by Immobilizer         P1570 - 008 -  - Intermittent Readiness: 0000 0000
------------------------------------------------------------------------------Address 02: Auto Trans        Labels: 09D-927-750.clb   Part No: 09D 927 750 BG   Component: AL 600 6Q           0579     Coding: 0004153   Shop #: WSC 26085 444 84534   VCID: 74B1DDFF52A5B997BCB-5160
------------------------------------------------------------------------------Address 03: ABS Brakes        Labels: 7L0-907-379-MK25.lbl   Part No: 7L0 907 379 D   Component: ESP ALLRAD MK25     0108     Coding: 0014593   Shop #: WSC 31414 000 00000   VCID: 3A2D33C730410FE7A67-5160
1 Fault Found: 00778 - Steering Angle Sensor (G85)         000 - - - Intermittent
VCDS Self-Diagnosis Log Monday,18,March,2019,15:57:55:59747 Page 2
Address 05: Acc/Start Auth.        Labels: None   Part No SW: 7L0 909 137 C    HW: 7L0 909 137 C   Component: 1W Kessy            6850     Revision: 00H22071    Serial number: VWZ3Z0D7160299   Coding: 0147688   Shop #: WSC 26071 444 85803   VCID: 33331EE3172BFEAF651-5160
   Subsystem 1 - Part No: 4E0 905 852 D   Component: ELV                 1834
2 Faults Found: 01176 - Key         008 - Implausible Signal - Intermittent         Freeze Frame:                Fault Status: 00101000                Fault Priority: 3                Fault Frequency: 14                Reset counter: 255                Time Indication: 0                Date: 2000.00.00                Time: 03:18:20
01179 - Incorrect Key Programming         000 -          Freeze Frame:                Fault Status: 01100000                Fault Priority: 2                Fault Frequency: 0                Reset counter: 255                Time Indication: 0                Date: 2000.00.00                Time: 03:23:48
------------------------------------------------------------------------------Address 06: Seat Mem. Pass        Labels: None   Part No: 7L0 959 760    Component: Sitzverstellung     0701     Shop #: WSC 00000 000 00000   VCID: 77ABEAF343D3D28F999-5160
VCDS Self-Diagnosis Log Monday,18,March,2019,15:57:55:59747 Page 3
Address 08: Auto HVAC        Labels: 7L6-907-040.clb   Part No: 7L6 907 040 H   Component: CLIMAtronic R/L   X 3716     Coding: 0000030   Shop #: WSC 31414 000 00000   VCID: 353720FB195FE09F4B5-5160
1 Fault Found: 01592 - Air Quality Sensor (G238)         014 - Defective
------------------------------------------------------------------------------Address 09: Cent. Elect.        Labels:. 7Lx-937-049-V1.clb   Part No: 7L6 937 049 K   Component:                     2703     Coding: 0105950   Shop #: WSC 03128 444 45725   VCID: 44D14D3F42854917CCB-5160
2 Faults Found: 00466 - Control Module for Steering Column Electronics (J527)         004 - No Signal/Communication - Intermittent 00907 - Intervention load Management         000 -
------------------------------------------------------------------------------Address 15: Airbags        Labels: 3D0-909-601.lbl   Part No: 3D0 909 601 C   Component: 05 Airbag 8.4E++H01 0352     Revision: BB36963     Serial number: 00010123         Coding: 0012341   Shop #: WSC 31414 000 00000   VCID: 2313EEA3A7CB6E2F951-5160
   Subsystem 1 - Part No: 7L0 959 339 B   Component: BF-Gewichtsens. 005 0006
------------------------------------------------------------------------------Address 16: Steering wheel        Labels: 7L6-953-549.lbl   Part No: 7L6 953 549 D   Component: Lenksäulenmodul     3301     Coding: 0000022   Shop #: WSC 31414 000 00000   VCID: 40D9412F569D5537E83-5160
VCDS Self-Diagnosis Log Monday,18,March,2019,15:57:55:59747 Page 4
Address 17: Instruments        Labels: 7L6-920-xxx-7LA.lbl   Part No: 7L6 920 980 M   Component: KOMBIINSTRUMENT RB8 2935     Coding: 0010231   Shop #: WSC 26085 444 84534   VCID: 42DD4B2758914727FE7-5160
3 Faults Found: 00466 - Control Module for Steering Column Electronics (J527)         004 - No Signal/Communication - Intermittent 01325 - Control Module for Tire Pressure Monitoring (J502)         004 - No Signal/Communication 00464 - Control Module with Display for Radio and Navigation (J503)         004 - No Signal/Communication
------------------------------------------------------------------------------Address 19: CAN Gateway        Labels: 6N0-909-901-19.lbl   Part No: 6N0 909 901    Component: Gateway K<>CAN      0101     Coding: 0000006   Shop #: WSC 31414 000 00000   VCID: 70B9D1EF26BD85B7583-5160
4 Faults Found: 00466 - Control Module for Steering Column Electronics (J527)         004 - No Signal/Communication - Intermittent 01325 - Control Module for Tire Pressure Monitoring (J502)         004 - No Signal/Communication 00463 - Control Module for Digital Sound Package (J525)         004 - No Signal/Communication 00464 - Control Module with Display for Radio and Navigation (J503)         004 - No Signal/Communication
------------------------------------------------------------------------------Address 1C: Position Sensing        Labels: 7L6-919-879.lbl   Part No: 7L6 919 879    Component: JCI PathPoint       1700     Shop #: WSC 00000 000 00000   VCID: 04518D3F020589178CB-5160
------------------------------------------------------------------------------Address 22: AWD        Labels: None   Part No: 0AD 927 755 BE   Component: TRANSFERCASE        0122     Shop #: WSC 00000 000 00000   VCID: 7F5B02D36BE3EACFD19-5160
VCDS Self-Diagnosis Log Monday,18,March,2019,15:57:55:59747 Page 5
Address 29: Left Light        Labels: 3D0-909-157.lbl   Part No: 3D0 909 157    Component: EVG GDL+AutoLWR(l)  X012     Coding: 0000003   Shop #: WSC 31414 000 00000   VCID: 6695B7B714795B0732F-5184
------------------------------------------------------------------------------Address 34: Level Control        Labels: 7Lx-907-553-34.clb   Part No: 7L0 907 553 F   Component: LUFTFDR.-CDC- 3C3P1 3081     Coding: 0015521   Shop #: WSC 31414 000 00000   VCID: 363527F70459EB8742F-5160
1 Fault Found: 00778 - Steering Angle Sensor (G85)         004 - No Signal/Communication - Intermittent
------------------------------------------------------------------------------Address 36: Seat Mem. Drvr        Labels: None   Part No: 7L0 959 760    Component: Sitzverstellung     0701     Shop #: WSC 00000 000 00000   VCID: 77ABEAF343D3D28F999-5160
------------------------------------------------------------------------------Address 39: Right Light        Labels: 3D0-909-158.lbl   Part No: 3D0 909 158    Component: EVG GDL+AutoLWR(r)  0001     Coding: 0000003   Shop #: WSC 62108 001 1048576   VCID: 678BBAB31373420F099-5160
VCDS Self-Diagnosis Log Monday,18,March,2019,15:57:55:59747 Page 6
Address 46: Central Conv.        Labels: 7L0-959-933.lbl   Part No: 7L0 959 933 E   Component: 2M HSG              0201     Coding: 0000085   Shop #: WSC 03128 444 45725   VCID: 3E253FD72C6923C79AF-4B1E
   Subsystem 1 - Part No: 7L0 959 701 B   Component: Tuersteuergeraet FS 0201
   Subsystem 2 - Part No: 7L0 959 702 B   Component: Tuersteuergeraet BF 0201
   Subsystem 3 - Part No: 7L0 959 703 B   Component: Tuersteuergeraet HL 0201
   Subsystem 4 - Part No: 7L0 959 704 B   Component: Tuersteuergeraet HR 0201
------------------------------------------------------------------------------Address 68: Wiper Electr.        Labels: 7L0-955-119-V1.clb   Part No: 7L0 955 119 F   Component: Front Wiper         2416     Coding: 0000004   Shop #: WSC 31414 000 376832   VCID: 372B2AF30353128F599-5160
------------------------------------------------------------------------------Address 6E: Ctrl Head Roof        Labels: None   Part No: 7L6 919 044 F   Component: DACHDISPLAY         0530     Revision: 00600530    Serial number: 2009289.02       Shop #: WSC 31414 000 00000   VCID: 3A2D33C730410FE7A67-5160
------------------------------------------------------------------------------Address 76: Park Assist        Labels: None   Part No: 7L0 919 283 E   Component: 0E Einparkhilfe     0907     Shop #: WSC 00000 000 00000   VCID: 382929CF0E4D1DF7503-5160
End----------(Elapsed Time: 08:55, VBatt start/end: 13.9V/14.0V)----------
This is my latest scan, note I am going back to fix the key issue. I was following the wrong procedure.
Akron04
C?ID=364043
I got my keys programmed properly. Still no remote function.
Monday,18,March,2019,22:43:08:59747
VCDS Version: 19.1.2.0 (x64)  HEX-V2 CB: 0.4502.4
VIN: WVGCM77L14D062138   Mileage: 165840km-103048miles
   Coding: 0007875
   Coding: 0004153
   Coding: 0014593
   Coding: 0147688
   Component: ELV                 1834
01176 - Key
                    Fault Frequency: 14
                    Time: 03:18:20
   Coding: 0000030
   Component:                     2703
   Coding: 0105438
   Coding: 0012341
   Coding: 0000022
   Coding: 0010231
   Coding: 0000006
   Coding: 0000003
   Coding: 0015521
   Coding: 0000003
   Coding: 0000085
   Coding: 0000004
End----------(Elapsed Time: 08:59, VBatt start/end: 13.9V/13.9V)-----------
After DTC clear:
Monday,18,March,2019,22:54:37:59747
   Coding: 0007875
Readiness: 0110 1101
   Coding: 0004153
   Coding: 0014593
   Coding: 0147688
   Component: ELV                 1834
   Coding: 0000030
   Component:                     2703
   Coding: 0105438
   Coding: 0012341
   Coding: 0000022
   Coding: 0010231
   Coding: 0000006
   Coding: 0000003
   Coding: 0015521
   Coding: 0000003
   Coding: 0000085
   Coding: 0000004
End----------(Elapsed Time: 10:30, VBatt start/end: 13.9V/14.0V)-----------
All fuses except two radio fuses and TPMS fuse installed.
On vehicles with a "KESSY" module like yours (Address 05: Acc/Start Auth) there is no separate remote programming; remotes are programmed at the same time as immobilizer part of the keys.
If you're certain that the loss of remote functionality is related to the changes you made, then you might want to have a look at the logs of those changes and un-do them to see if that helps.
Akron04
C?ID=364043
Thank you. I believe I was still using the standard release when this happened. Here is the adapt log:
Address	46,7L0	959	933	E,channel	1,adapted	from,1,to,0,Friday,15,March,2019,20:52:10:59747
Address	46,7L0	959	933	E,channel	1,adapted	from,0,to,0,Friday,15,March,2019,21:01:08:59747
Address	46,7L0	959	933	E,channel	0,adapted	from,---,to,000,Friday,15,March,2019,23:54:26:59747
Address	46,7L0	959	933	E,channel	0,adapted	from,---,to,000,Friday,15,March,2019,23:55:39:59747
Address	46,7L0	959	933	E,channel	25,adapted	from,0,to,1,Friday,15,March,2019,23:57:58:59747
Address	46,7L0	959	933	E,channel	0,adapted	from,---,to,000,Saturday,16,March,2019,00:05:09:59747
Address	46,7L0	959	933	E,channel	0,adapted	from,---,to,000,Saturday,16,March,2019,00:10:15:59747
Address	46,7L0	959	933	E,channel	0,adapted	from,---,to,000,Saturday,16,March,2019,00:10:42:59747
Address	46,7L0	959	933	E,channel	27,adapted	from,0,to,1,Saturday,16,March,2019,00:11:59:59747
Address	46,7L0	959	933	E,channel	0,adapted	from,---,to,000,Saturday,16,March,2019,00:12:21:59747
Address	46,7L0	959	933	E,channel	0,adapted	from,---,to,000,Saturday,16,March,2019,00:15:58:59747
Address	46,7L0	959	933	E,channel	0,adapted	from,---,to,000,Saturday,16,March,2019,00:24:50:59747
Address	46,7L0	959	933	E,channel	0,adapted	from,---,to,000,Saturday,16,March,2019,00:33:11:59747
Address	46,7L0	959	933	E,channel	0,adapted	from,---,to,000,Saturday,16,March,2019,00:34:09:59747
Address	46,7L0	959	933	E,channel	0,adapted	from,---,to,000,Saturday,16,March,2019,03:00:30:59747
Address	46,7L0	959	933	E,channel	0,adapted	from,---,to,000,Saturday,16,March,2019,03:16:30:59747
And the coding log:
Address	19,6N0	909	901	,recoded	(Short	coding),from,0000006,to,0000006,(31414/000/00000),Friday,15,March,2019,18:09:11:59747
Address	17,7L6	920	980	M,recoded	(Short	coding),from,0007231,to,0007251,(26085/444/84534),Friday,15,March,2019,18:17:12:59747
Address	17,7L6	920	980	M,recoded	(Short	coding),from,0007231,to,0009231,(26085/444/84534),Friday,15,March,2019,18:17:31:59747
Address	09,7L6	937	49	K,recoded	(Short	coding),from,0105951,to,0105950,(03128/444/45725),Friday,15,March,2019,20:10:10:59747
Address	16,7L6	953	549	D,recoded	(Short	coding),from,0000032,to,0000232,(31414/000/00000),Friday,15,March,2019,20:20:55:59747
Address	16,7L6	953	549	D,recoded	(Short	coding),from,0000032,to,0000132,(31414/000/00000),Friday,15,March,2019,20:21:24:59747
Address	16,7L6	953	549	D,recoded	(Short	coding),from,0000032,to,0000022,(31414/000/00000),Friday,15,March,2019,20:21:58:59747
Address	17,7L6	920	980	M,recoded	(Short	coding),from,0009231,to,0007231,(26085/444/84534),Friday,15,March,2019,21:40:32:59747
Address	17,7L6	920	980	M,recoded	(Short	coding),from,0007231,to,0009231,(26085/444/84534),Friday,15,March,2019,22:12:42:59747
Address	19,6N0	909	901	,recoded	(Short	coding),from,0000006,to,0000006,(31414/000/00000),Friday,15,March,2019,22:15:18:59747
Address	19,6N0	909	901	,recoded	(Short	coding),from,0000006,to,0000006,(31414/000/00000),Saturday,16,March,2019,00:24:11:59747
Address	46,7L0	959	933	E,recoded	(Short	coding),from,0000085,to,0000085,(03128/444/45725),Saturday,16,March,2019,00:33:48:59747
Anything stand out? I'm going over it line by line now.
What I know is this. The remotes have always worked. On Friday evening I began messing with VCDS. At some point I locked and unlocked the car from the driver's seat using a FOB. Later it would not work. I was TOO EXCITED and not paying good attention. I'm 99% positive It's something I did but I'm not sure what. Would be very odd for the KESSY to "burn out" or another electrical failure while I was tinkering in software I would think.
Dealer appt today was postponed until tomorrow.
Akron04
C?ID=364043
My concern is the procedure for making the TPMS light go away was pull the fuse, go into 19-CAN, coding 07, and make no changes but hit "do it". This was supposed to make the ECU no longer search for the TPMS. IF I had a KESSY related fuse pulled could I have caused the same thing? ie the ECU believes that part is no longer in the car? I have since replaced all fuses, tried a battery disconnect, and various other things to know avail. I WAS able to get my PIN code and reprogram all the keys in 05. Still no remote function though.
Racking my brain wondering WHY did I do the lock unlock while in the car with the FOB, can't remember if I was checking something or what.
Tidbit: my door switch (buttons) have been disconnected since the fall, when fixing the battery drain became a major priority. That was a suggested fix from ClubToureg forums. It didn't help the battery drain. Keyless entry never worked that well anyway and it's not an option I care much about. A scan with my dad's VAG-401 at the time showed one button shorted, so I just unhooked them all. Small connector at the bottom of each door. Didn't affect the remotes.
Akron04
C?ID=364043
might be stupid but, did you try replacing the battery?
Car battery replaced late summer with new VW battery from dealer. Remote batteries replaced around the same time period.
Akron04
C?ID=364043
I CAN say that so far I love this VCDS setup. Six headlight salute! TPMS warning GONE. Seatbelt ding GONE (I'm in sales, often on the side of the road on the phone. It's nice to take it off and be comfortable), optional DRLs. Plus scanning for and saving codes is the best I've ever had. Nice to print them to PDF for later analysis.
Hmm, I wonder if Saving a 0 to channel 0 in the CCM at address 46 could have that effect? It would in a vehicle without a Kessy. But I'm not 100% certain how the Kessy and the CCM interact here.
You didn't do anything with the Kessy itself, and you didn't change the CCM's coding, so that the only possibility that comes to mind.
Do you have the owner's manual for this vehicle? If so, check if there's anything regarding "Remote Synchronization" or similar in there. It usually involves using one key on the ignition and ignition on while locking the vehicle from the outside with the other key and then doing stuff with the buttons on the remote.
Akron04
C?ID=364043
I tried the owner's manual recommendation first. Which is put the key in the ignition and run the car for a bit. Did not work. Tried one key in ignition and one in door procedure, no luck. Tried a couple more I found in online searches.
I did reprogram 05 with all three keys including the valet key, after the fact. They will all start the car.
Akron04
C?ID=364043
Are all antennas being seen for FOB's and Kessy?
No clue. There are no KESSY codes. I DID unplug the small connector at the bottom of each door that supposedly goes to the door button for keyless entry months ago. Remotes worked fine after that. This was a suggestion I found on Club Touareg to try to prevent the battery drain. The only previous "issue" I have had with the remotes is they don't work so well at the tail gate, I have to wave it around the side to pop the trunk. My understanding, and I could be wrong, is the FOB remote antenna runs up one of the A pillars. The door antennas are only for keyless entry. I could be very wrong, but why would it cause an issue now, 6 or more months later? They worked fine before I got into VCDS.
Now ONE thing I do recall. When checking fuses against the factory owner's manual, there was no fuse in the "individualisation" slot or one of the "key" slots. Those have been replaced. This just reinforces my thinking that the ECU "forgot" the remote function when I ran coding 07 on 19 to eliminate the TPMS warning. Below is the video and procedure I used to get rid of the TPMS warning:
https://youtu.be/NNcoEvEdwy0
It worked, maybe TOO well?
Akron04
C?ID=364043
BTW the theory behind unplugging the connectors: The buttons fail closed. This keeps the KESSY awake waiting to sense a key. I did in fact have a code for one rear door when I unplugged them. I figured if one was bad the others would soon follow. After that things worked as expected but didn't help the battery drain at all. I have verified, with an ammeter from the negative battery terminal to the ground cable, that the radio circuits were drawing almost 3 amps. Pulled the two radio fuses and it dropped to about 0.150 amps or less. Apparently this is ALSO a common cause of dead batteries in the T1 Touaregs.
Dana
Western PA, USA
I agree with Uwe meaning Saving a 0 to Channel 0 in 46 probably cleared the remotes (that happens on B8 Audi models where 05 and 46 are one in the same module) but they should have re-learned when you matched all vehicle keys with the PIN.
Even though the remote batteries aren't extremely old I'd be tempted to put a new one in the nicest key (the one that lived on the key rack rather than a key that was in-use daily). I would also change all of the 46 adaptation values back to the factory settings if you haven't done so already and re-match the keys to the KESSY to see if the remotes function.
Additional thoughts would include checking 05 and 46 MVBs for the S-contact portion of the ignition switch and remotes/antennas (per Jack's suggestion). The Driver's door needs to be closed (with a proper micro-switch reading) in order to lock the vehicle via remote but it would unlock even with the LF door open or a faulty door latch switch. Likewise, the hatch and panic functions would work.
Edit, P.S. Uwe or Jack may be able to shed light on this but I don't believe early T'reg support transport mode. That's a CAN thing as explained here but Transport mode would result in non-functional remotes. Another possibility is Factory Mode enabled in a module such as 46 .. but I don't think that applies to the vehicle/module type.
P.P.S. Since there isn't a lbl file for your 05 module please take a look at the 3D0-909-13x-05.lbl located in C:\Ross-Tech\VCDS\Labels using Notepad. That's going to be extremely close, if not identical to, the module in your vehicle.
Well, what that coding does is to cause the Gateway to re-build its installation list based on what it actually finds in in the car at that time. So if you had power pulled from something other than the TPMS module when you did that, it's possible the gateway is now missing an entry for that item too, but I'm not sure what that entry would be.
In any case, if you're sure everything else is powered as it should be now, there's no harm in repeating that procedure.
Akron04
C?ID=364043
I just thought of a great way to test this, to see if it can relearn. Replace the TPMS fuse and see if the light comes back on after coding 19 with the same values. I will also do a continuity test on the fuses for CCM and keys. Could be a bad fuse that doesn't look blown. I've had that happen in the past on other cars. In one case it was corroded contacts in another it was broken but not in the normal break spot and hard to see without a magnifying glass. I figure if the TPMS code comes back then it's capable of relearning the installation list right? It wouldn't hurt to put the radio fuses back in either.
No deletes........
Are Antennas somehow shared somewhere in TPMS with Kessy in tracks for remote functions or supply?
TPMS deletes for shame dismissed treats?
Akron04
C?ID=364043
Well two hours at the dealer, charged for one, they cant figure it out. I have an appt with their touareg specialist in two weeks.
Wondering: buy a used KESSY from eBay and install it and see if that solves it?
