Driving Shool Mode (DSM) on 5F modules with "Gen2" channels?
DV52
C?ID=194404
Driving School Mode (DSM) on 5F modules with "Gen2" channels?
I've been trying to help a local lad here in the Antipodes with DSM on his MIBII unit. As I also have this style 5F module on my A3 8V (virtual cockpit), I thought that I would simply follow the usual instructions without any problems - but I was wrong!!
The "usual" instruction for DSM on MQB platform vehicles generally involve the following 3 x channels in the module @ address hex5F (bracketed settings are default) :
  • Vehicle function list CAN-Driving_school >available (not available)
  • Vehicle menu operation-menu_ display_ driving_ school > activated (not activated)
  • Vehicle menu operation-menu _display _driving _school _over _threshold _high >activated (not activated)
Here is a list of the DSM related channels on MIBII units:
  1. ENG122227-ENG117656-Car_Function_Adaptations_Gen2-menu_display_driving_school > not activated
  2. ENG122227-ENG117660-Car_Function_Adaptations_Gen2-menu_display_driving_school_after_disclaimer > not activated
  3. ENG122227-ENG117657-Car_Function_Adaptations_Gen2-menu_display_driving_school_clamp_15_off > not activated
  4. ENG122227-ENG117658-Car_Function_Adaptations_Gen2-menu_display_driving_school_over_threshold_high > not activated
  5. ENG122227-ENG117659-Car_Function_Adaptations_Gen2-menu_display_driving_school_standstill > not activated
  6. ENG122228-ENG117688-Car_Function_List_CAN_Gen2-Driving_school > Not available
  7. ENG122228-ENG117689-Car_Function_List_CAN_Gen2-Driving_school_msg_bus > Not available
So - aligning the old instructions with the new MIBII channels, I'm guessing that:
First channel maps onto 6
Second channel maps onto 1
Third channel maps onto 4
And I have also changed 7 above to Databus Infotainment - so that it aligned with the setting on my old mk7 Golf in which DSM worked OK
But alas no DSM option appears under the CAR option in the MIB.
Has anyone here had success with this tweak on 5F units with "Gen2" adaptation channels?
TBAx
C?ID=287144
What unit specifically is build into that car in question?
To my knowledge only "low-line" MIB HMIs are able to show the driving school mode, such as the Composition Media or Composition Touch.
Dana
Western PA, USA
The scan and maps from this one may add clarity.
I'm no expert in this area but my retired 2017 SEL had a proper 5F (Discover Media) with those Gen 2 channels and I had it enabled in that car.
My current low-spec 2018 S has a low-end Composition Color unit but I don't believe I attempted to enable Driving School Mode in this car yet. I can certainly try that for science!
DV52
C?ID=194404
^^^^ TBAx: of course - my apology (see below)
Dana:Purely in the pursuit of science - please try
Thursday,16,August,2018,07:00:59:16808
VCDS Version: 18.2.1.5 (x64)  HEX-NET CB: 0.4411.4
VIN: WAUZZZ8V3JA084907   License Plate:
Chassis Type: 8V-AU37 (3Q0)
Scan: 01 02 03 05 08 09 10 13 15 16 17 19 2B 3C 42 44 52 5F 6C A5
          BB BC CF
VIN: WAUZZZ8V3JA084907   Mileage: 173km-107miles
Address 01: Engine (J623-CZEA)       Labels:. 04E-907-309-V1.clb
   Part No SW: 04E 906 027 HF    HW: 04E 907 309 BJ
   Component: R4 1.4l TFS   H24 3744
   Revision: R6H24---
   Coding: 02250032236401083000
   Shop #: WSC 06314 790 00021
   ASAM Dataset: EV_ECM14TFS01104E906027HF 001007
   ROD: EV_ECM14TFS01104E906027HF.rod
   VCID: 6FAE16D4B6DCA43CCD-803A
   CAN Converter 01:
   Part No SW: 0CW 300 041 Q    HW: 0AM 927 769 E
   Component: GSG DQ200G2_M H05 1603
   Revision: 00005008    Serial number: CU501712236712
   Shop #: WSC 17734 418 534600
   ROD: EV_TCMDQ200021_VW27.rod
   VCID: 43C68A64CAD4705C79-8016
   Part No SW: 5Q0 614 517 CH    HW: 5Q0 614 517 AH
   Component: ESC           H62 0743
   Revision: 00000000    Serial number: 63357000000216
   Coding: 12F18AA2242822708B800A00A0CA2948512444D1500594731821503482A8420000000012121212B835351919323200
   ROD: EV_Brake1UDSContiMK100IPB_036_AU37.rod
   VCID: 79BA288CF898FA8C63-802C
   Part No SW: 5Q0 959 435 C    HW: 5Q0 959 435
   Component: VWKESSYMQB    021 0803
   Revision: 00021000    Serial number: 0465996031
   Coding: 030C0C
   ASAM Dataset: EV_KessyHellaMQBAB 002020
   VCID: 3C34F198B72A0FA438-8068
   Part No SW: 8V0 820 043 Q    HW: 8V0 820 043 Q
   Component: AC Automat    H03 0130
   Revision: 20002000    Serial number: 00000001446081
   Coding: 03100004110000001000000000001400
   ASAM Dataset: EV_AirCondiFrontVaAU37X 008022
   VCID: 40CC8568DBC26B4464-8014
   Subsystem 1 - Part No SW: 4H0 907 658 B    HW: 4H0 907 658 B
   Component: AQ_Hum_Sensor  H02 0007
   Serial number: 01501A0900PAG0MUFU03
   Part No SW: 5Q0 937 084 CQ    HW: 5Q0 937 084 CG
   Component: BCM MQBAB H   H36 0253
   Serial number: 01001800901626
   ROD: EV_BCMCONTI.rod
   VCID: 095A584CA878EA0C73-805C
   Subsystem 1 - Part No SW: 8V2 955 119 A    HW: 8V2 955 119   Labels: 5QX-955-119-V1.CLB
   Component: WWS370 171127  043 0580
   Serial number:         171208172857
   Coding: 0A47F7
   Serial number: 21148915X81A955547A0
   Coding: 00006C
   Light switch:
   Subsystem 3 - Part No SW: 8V0 941 531 AR    HW: 8V0 941 531 AR
   Component: E1 - LDS MQB  H06 0032
   Serial number: 16 09 2017  00002183
   Serial number: 000308418918003
   Coding: 0470155811
   ROD: EV_EPHVA18AU3700000_009_AU37.rod
   VCID: 4BD6A244E284B81C81-801E
   Part No SW: 5Q0 907 572 G    HW: 5Q0 907 572 G
   Component: ACC BOSCH MQB H10 0571
   Coding: 3500E7411DFFC428949C8055000026
   ASAM Dataset: EV_ACCBOSCHVW416 001005
   ROD: EV_ACCBOSCHVW416_001_VW37.rod
   VCID: 3B36F284B224089C31-806E
   Part No SW: 5Q0 959 655 BJ    HW: 5Q0 959 655 BJ
   Serial number: 003VWR3SAJL2
   Coding: 98CCC000000000005C54000000C8000000C5
   Subsystem 1 - Part No SW: -----------    HW: 480 001 001 18
   Serial number: 3570000000085DA0AA2U
   Subsystem 2 - Part No SW: -----------    HW: 480 001 001 18
   Serial number: 3580000000016DA0AA2P
   Subsystem 3 - Part No SW: -----------    HW: 480 400 801 18
   Serial number: 3510001BB28DFC73E6A-
   Subsystem 4 - Part No SW: -----------    HW: 480 400 801 18
   Serial number: 35200019F28DFC73E41S
   Subsystem 5 - Part No SW: -----------    HW: 480 401 011 17
   Serial number: 3550002AD25629A3B145
   Part No SW: 8V0 953 521 KF    HW: 5Q0 953 549 E
   Revision: --------    Serial number: 04011804400355
   Coding: 6C18
   VCID: 085C5D48B37293046C-805C
Address 17: Instruments (J285)       Labels:| 5G0-920-XXX-17.clb-SRI2
   Part No SW: 8V0 920 790 A    HW: 8V0 920 790 A
   Component: FBenRDW       H16 0066
   Coding: 248409506F8800080180EA001000000000000000
   ASAM Dataset: EV_DashBoardFPKAU37X 001027
   ROD: EV_DashBoardFPKAU37X.rod
   VCID: 3A38F780BD1E31942A-806E
   Component: GW MQB High   436 4326
   Revision: --------    Serial number: 0007219271
   Coding: 030100043F0857085B000058180B00000001010000000000000000000000
   ASAM Dataset: EV_GatewNF 013044
   ROD: EV_GatewNF_VW27.rod
   VCID: 383CED8883122384DC-806C
   Subsystem 2 - Part No SW: 8W0 951 523 F    HW: 8W0 951 523 F
   Component: J453 MFL  H04 0002
   Serial number: 20180108180606 21736
   Serial number: 75886000001801070888
   Revision: 00000000    Serial number: 17000401984006
   Coding: 5D00000000000000
   ROD: EV_ELVMarquMQB.rod
   VCID: 3424D9B89F7AC7E4F0-8060
Address 3C: Lane Change (J769)       Labels:| 3Q0-907-566.clb
   Part No SW: 3Q0 907 566 F    HW: 3Q0 907 566
   Component: MRR1Rear      H21 0610
   Revision: --------
   Coding: 44C002
   Serial number: 161217ELE26178
   Coding: 001C1B205C01040000001003
   Part No SW: 5Q0 909 144 AA    HW: 5Q0 909 144 AA
   Component: EPS_MQB_ZFLS  130 1081
   Coding: 11170000
   ROD: EV_SteerAssisMQB_015.rod
   VCID: 73A61AA4DAF480DC29-8026
   Serial number: 171217ELG32984
   Coding: 001C13205E01040000001003
   VCID: 42C88F60D5CE795472-8016
   Part No SW: 8V1 035 041 D    HW: 8V1 035 041
   Component: MU-P-LND-RW   054 1168
   Serial number: A838K0HS006144
   Coding: 01730308FF0A000011511101000A00102F002666017001005E
   VCID: 302CD5A86B62FBC494-8064
   Subsystem 1 - Part No SW: V03 959 801 PT    HW: -----------
   Component: ROW 2017/2018  --- 0065
   Component: DU High  H49 0014
   Serial number: AUZ8Z9H1Y08LE7
   Multimedia Operating Unit:
   Subsystem 3 - Part No SW: 8V0 919 614 BK    HW: 8V0 919 614 BK
   Component: ControlUnit_H  H85 0855
   Serial number: ALJAL130101700050258
   Component: Gracenote2  --- 4012
   Coding: 0273100102002001400040
   ROD: EV_CamSysRVRVCPANAMQBAB_006_VW48.rod
   VCID: 393AE88CB8183A8C23-806C
   Part No SW: 3Q0 980 654 H    HW: 3Q0 980 654 A
   Component: MQB_B_MFK     H07 0272
   Serial number: 08011812P20164
   Coding: 040307030000010101022346814EA90088000E100020
   ROD: EV_MFKBoschMQBB_VW36.rod
   Part No SW: 5Q0 959 395 E    HW: 5Q0 959 395 B
   Serial number: 121217ELC09635
   Coding: 000C13204001040000001002
   Serial number: 121217ELC09492
Address CF: Lane Chge Asst 2 (J770)       Labels:. 3Q0-907-566.clb
   Part No SW: 3Q0 907 590 F    HW: 3Q0 907 590
   Revision: --------
   Coding: 44C002
End----(Elapsed Time: 01:50, VBatt start/end: 11.9V/11.9V. VIgn 11.9V)-----
wuplur
C?ID=247333
What does this feature do when activated?
PetrolDave
Westbury, UK
C?ID=1423
Shows this screen on the infotainment
darkchina811
ITALY
C?ID=333184
I also always wondered how is that screen useful...
PetrolDave
Westbury, UK
C?ID=1423
Unless you're a driving instructor maybe not really useful; but it does give a summary of fuel consumption, speed and range which otherwise would need several screens.
Plus it's available so why not enable it?
darkchina811
ITALY
C?ID=333184
cause I am not a driving instructor :D
Dana
Western PA, USA
If my husband was a member of this forum he'd explain that particular function fine tunes spouse micromanagement :D As a passenger, I didn't need to use my imaginary brake pedal as frequently because I could see the speed!
Don I will tweak that and report back. I'm sure Chad will be thrilled it if can be enabled :popcorn:
DV52
C?ID=194404
I'm constantly intrigued by the range of views that folk have about a thing!
I agree that DSM can be seen as being a less-than-useful app, but it can also be viewed as a quite informative app - in situations not related to teaching someone to drive.
As Dana suggests, DSM can be used as a convenient "surveillance" mechanism by the passenger of the car's speed (usually of interest to the driver's CLP - Current Lifetime Partner). Also, it's a nifty way of restoring the digital speed facility when the display between the 2 x dial clocks is used for another purpose (be it a FIS, or an AID display).
But again, whether this is actually "useful" is a matter for the individual - ain't humans a fascinating and diverse species? :cool:
Dana - I have long been of the view that there is a type of Darwinian selection process in successful partnerships.:)
Those that learn early in the relationship to "thrill" their CLP become much wiser and reap the many benefits of the partnership!! ;) Thanks again
Dana
Western PA, USA
Hi Don,
DSM is activated in my low-end Comp color unit. My current 5F maps are:
;SW:5G6-035-868   HW:5G6-035-868 ---  Information Electr.
;Component:MU-E--ER      671 8395, Coding:02731200FF00000041220001001000009F0008D40000030000
;EV_MUEnt4CGen2LGE,001041,EV_MUEnt4CGen2LGE_VW12.rod
;Monday,18,March,2019,10:55:23:04045
;VCDS Version: Release 18.9.1 (x64)  Data version: 20190215 DS296.0
;VCID: 70BADAA93A23EF576ED-8024
IDE00346-Summertime-automatic,manual ,1
IDE00758-Base volume of telephone,50 %,1
IDE00769-Number 1 for Info call,FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF ,23
IDE00770-Number 1 for roadside assistance,FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF ,23
IDE02063-Time display for start screen,2.0 s,1
IDE02122-Developer mode,activated ,1
IDE02330-Number 2 for Info call,FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF ,23
IDE02331-Number 2 for roadside assistance,FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF ,23
IDE02476-ENG117361-Electrical test of loudspeakers-Parameter_AC-Diagnostics_Channel_1_Test_Volume,27 ,49
IDE02476-ENG117379-Electrical test of loudspeakers-Parameter_AC-Diagnostics_Channel_10_Test_Volume,27 ,49
IDE02476-ENG117381-Electrical test of loudspeakers-Parameter_AC-Diagnostics_Channel_11_Test_Volume,27 ,49
IDE02476-ENG117383-Electrical test of loudspeakers-Parameter_AC-Diagnostics_Channel_12_Test_Volume,27 ,49
IDE02476-ENG117385-Electrical test of loudspeakers-Parameter_AC-Diagnostics_Channel_13_Test_Volume,27 ,49
IDE02476-ENG117387-Electrical test of loudspeakers-Parameter_AC-Diagnostics_Channel_14_Test_Volume,27 ,49
IDE02476-ENG117389-Electrical test of loudspeakers-Parameter_AC-Diagnostics_Channel_15_Test_Volume,27 ,49
IDE02476-ENG117391-Electrical test of loudspeakers-Parameter_AC-Diagnostics_Channel_16_Test_Volume,27 ,49
IDE02476-ENG117363-Electrical test of loudspeakers-Parameter_AC-Diagnostics_Channel_2_Test_Volume,27 ,49
IDE02476-ENG117365-Electrical test of loudspeakers-Parameter_AC-Diagnostics_Channel_3_Test_Volume,27 ,49
IDE02476-ENG117367-Electrical test of loudspeakers-Parameter_AC-Diagnostics_Channel_4_Test_Volume,27 ,49
IDE02476-ENG117369-Electrical test of loudspeakers-Parameter_AC-Diagnostics_Channel_5_Test_Volume,27 ,49
IDE02476-ENG117371-Electrical test of loudspeakers-Parameter_AC-Diagnostics_Channel_6_Test_Volume,27 ,49
IDE02476-ENG117373-Electrical test of loudspeakers-Parameter_AC-Diagnostics_Channel_7_Test_Volume,27 ,49
IDE02476-ENG117375-Electrical test of loudspeakers-Parameter_AC-Diagnostics_Channel_8_Test_Volume,27 ,49
IDE02476-ENG117377-Electrical test of loudspeakers-Parameter_AC-Diagnostics_Channel_9_Test_Volume,27 ,49
IDE02502-Confirmation of installation change,DF 07 ,2
IDE02699-Number 1 for roadside assistance,FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF ,23
IDE02701-Number 1 (roaming) for roadside assistance,FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF ,23
IDE03471-ENG142146-Vehicle configuration-allow_message_editing,OFF ,30
IDE03471-ENG130249-Vehicle configuration-Apple_DIO,On ,30
IDE03471-ENG185764-Vehicle configuration-Apple_DIO_Wireless,OFF ,30
IDE03471-ENG152525-Vehicle configuration-Baidu_Car_Life,OFF ,30
IDE03471-ENG152559-Vehicle configuration-Baidu_Car_Life_ios,OFF ,30
IDE03471-ENG185765-Vehicle configuration-Baidu_Car_Life_ios_Wireless,OFF ,30
IDE03471-ENG185766-Vehicle configuration-Baidu_Car_Life_Wireless,OFF ,30
IDE03471-ENG152560-Vehicle configuration-block_hmi_function_p_epb,blocked ,30
IDE03471-ENG142151-Vehicle configuration-conditioning_variant,0 ,30
IDE03471-ENG125043-Vehicle configuration-Dtmf_without_active_call,OFF ,30
IDE03471-ENG142145-Vehicle configuration-esim_data_only_sms_support,OFF ,30
IDE03471-ENG185778-Vehicle configuration-FoD,SWaP ,30
IDE03471-ENG130248-Vehicle configuration-Google_GAL,On ,30
IDE03471-ENG185779-Vehicle configuration-Google_GAL_Wireless,OFF ,30
IDE03471-ENG117850-Vehicle configuration-gracenote_local_coverarts,OFF ,30
IDE03471-ENG117851-Vehicle configuration-gracenote_local_other,OFF ,30
IDE03471-ENG152533-Vehicle configuration-Hybrid_Radio_additional_online_data,not activated ,30
IDE03471-ENG152534-Vehicle configuration-Hybrid_Radio_Range_Extender,Deactivated ,30
IDE03471-ENG142142-Vehicle configuration-map_email_support,OFF ,30
IDE03471-ENG142143-Vehicle configuration-map_instant_messaging_support,OFF ,30
IDE03471-ENG142141-Vehicle configuration-map_sms_support,OFF ,30
IDE03471-ENG142152-Vehicle configuration-Map_Style,0 ,30
IDE03471-ENG152537-Vehicle configuration-media_control,not activated ,30
IDE03471-ENG138662-Vehicle configuration-Mirror_link,On ,30
IDE03471-ENG142148-Vehicle configuration-MirrorLink_Country_Code,MIB_NAR ,30
IDE03471-ENG142150-Vehicle configuration-MirrorLink_RGB_Preference,RGB565 ,30
IDE03471-ENG117843-Vehicle configuration-my_audi,OFF ,30
IDE03471-ENG127495-Vehicle configuration-online_media,OFF ,30
IDE03471-ENG117840-Vehicle configuration-online_navigation,OFF ,30
IDE03471-ENG117837-Vehicle configuration-online_POI,OFF ,30
IDE03471-ENG117838-Vehicle configuration-online_POI_voice,OFF ,30
IDE03471-ENG117839-Vehicle configuration-online_portal_browser_services,OFF ,30
IDE03471-ENG152553-Vehicle configuration-online_radio,Deactivated ,30
IDE03471-ENG117841-Vehicle configuration-online_street_view,OFF ,30
IDE03471-ENG167521-Vehicle configuration-perso_v_threshold,00 ,30
IDE03471-ENG167522-Vehicle configuration-perso_v_threshold_hysteresis,00 ,30
IDE03471-ENG152554-Vehicle configuration-Phone_HMI_Privacy,0 ,30
IDE03471-ENG125046-Vehicle configuration-Phone_module_operation_mode,Data & language service active ,30
IDE03471-ENG117844-Vehicle configuration-picture_navi,OFF ,30
IDE03471-ENG167523-Vehicle configuration-Pilot_Parking,not activated ,30
IDE03471-ENG167525-Vehicle configuration-Popup_if_GPS_services_in_use,not activated ,30
IDE03471-ENG152555-Vehicle configuration-Privacy_WithPINRequest,0 ,30
IDE03471-ENG125047-Vehicle configuration-PSD_Protocol_Version,PSD_1.5 ,30
IDE03471-ENG117846-Vehicle configuration-remote_HMI,OFF ,30
IDE03471-ENG138661-Vehicle configuration-RSE_software_component,activated ,30
IDE03471-ENG245031-Vehicle configuration-rvc_low_black_screen_trunk_open,not activated ,30
IDE03471-ENG244966-Vehicle configuration-rvc_low_black_screen_velocity_threshold,not activated ,30
IDE03471-ENG245015-Vehicle configuration-rvc_low_failsafe,not activated ,30
IDE03471-ENG152556-Vehicle configuration-scon_telephony,not activated ,30
IDE03471-ENG138660-Vehicle configuration-SDS_Region_Flag,no_region ,30
IDE03471-ENG152557-Vehicle configuration-show_volte_hmi_switch,not activated ,30
IDE03471-ENG142144-Vehicle configuration-sim_data_only_sms_support,OFF ,30
IDE03471-ENG126993-Vehicle configuration-Station_Logo_DB_Mode,0 ,30
IDE03471-ENG125042-Vehicle configuration-Support_of_threeway_calling,OFF ,30
IDE03471-ENG130247-Vehicle configuration-Support_second_phone,OFF ,30
IDE03471-ENG167531-Vehicle configuration-Tencent_myCar_canceling_share_location,OFF ,30
IDE03471-ENG152571-Vehicle configuration-unblock_functions_while_piloted_driving,Enabled ,30
IDE03471-ENG167532-Vehicle configuration-UOTA_2,OFF ,30
IDE03471-ENG117852-Vehicle configuration-UPnP,OFF ,30
IDE03471-ENG142149-Vehicle configuration-vehicle_leaving_sound,not activated ,30
IDE03471-ENG142147-Vehicle configuration-vehicle_readiness_sound,not activated ,30
IDE03471-ENG152558-Vehicle configuration-voice_over_lte,not activated ,30
IDE03471-ENG137648-Vehicle configuration-WiFi_Client_HMI,OFF ,30
IDE03471-ENG117842-Vehicle configuration-WIFI_Hotspot,OFF ,30
IDE03471-ENG152572-Vehicle configuration-wlan_5ghz_switch,not activated ,30
IDE10221-MAS00846-Audio Management Input Gain Generation 2-Satellite radio,-128 ,40
IDE10221-ENG125860-Audio Management Input Gain Generation 2-Phone_Ringer_OB,-128 ,40
IDE10480-MAS10742-Interface for external media: activation-Connection 2,not activated ,4
IDE11122-Country identification: country of sale HMI,US ,2
IDE11502-ENG127601-Locked menu contents-FB_CAR_0,blocked ,21
IDE11502-ENG127612-Locked menu contents-FB_CAR_11,blocked ,21
IDE11502-ENG127613-Locked menu contents-FB_CAR_12,blocked ,21
IDE11502-ENG127603-Locked menu contents-FB_CAR_2,blocked ,21
IDE11502-ENG127604-Locked menu contents-FB_CAR_3,blocked ,21
IDE11502-ENG127608-Locked menu contents-FB_CAR_7,blocked ,21
IDE11502-ENG127522-Locked menu contents-FB_MEDIA_1,blocked ,21
IDE11502-ENG127531-Locked menu contents-FB_MEDIA_10,blocked ,21
IDE11502-ENG127532-Locked menu contents-FB_MEDIA_11,blocked ,21
IDE11502-ENG127533-Locked menu contents-FB_MEDIA_12,blocked ,21
IDE11502-ENG127534-Locked menu contents-FB_MEDIA_13,blocked ,21
IDE11502-ENG127536-Locked menu contents-FB_MEDIA_15,blocked ,21
IDE11502-ENG127524-Locked menu contents-FB_MEDIA_3,blocked ,21
IDE11502-ENG127526-Locked menu contents-FB_MEDIA_5,blocked ,21
IDE11502-ENG127528-Locked menu contents-FB_MEDIA_7,blocked ,21
IDE11502-ENG127529-Locked menu contents-FB_MEDIA_8,blocked ,21
IDE11502-ENG127530-Locked menu contents-FB_MEDIA_9,blocked ,21
IDE11502-ENG127625-Locked menu contents-FB_MISC_0,blocked ,21
IDE11502-ENG127635-Locked menu contents-FB_MISC_10,blocked ,21
IDE11502-ENG127636-Locked menu contents-FB_MISC_11,blocked ,21
IDE11502-ENG127638-Locked menu contents-FB_MISC_13,blocked ,21
IDE11502-ENG127643-Locked menu contents-FB_MISC_18,blocked ,21
IDE11502-ENG127644-Locked menu contents-FB_MISC_19,blocked ,21
IDE11502-ENG127627-Locked menu contents-FB_MISC_2,blocked ,21
IDE11502-ENG127645-Locked menu contents-FB_MISC_20,blocked ,21
IDE11502-ENG127647-Locked menu contents-FB_MISC_22,blocked ,21
IDE11502-ENG127655-Locked menu contents-FB_MISC_30,blocked ,21
IDE11502-ENG127669-Locked menu contents-FB_MISC_44,blocked ,21
IDE11502-ENG127670-Locked menu contents-FB_MISC_45,blocked ,21
IDE11502-ENG127671-Locked menu contents-FB_MISC_46,blocked ,21
IDE11502-ENG127672-Locked menu contents-FB_MISC_47,blocked ,21
IDE11502-ENG127630-Locked menu contents-FB_MISC_5,blocked ,21
IDE11502-ENG127634-Locked menu contents-FB_MISC_9,blocked ,21
IDE11502-ENG127561-Locked menu contents-FB_NAV_0,non_blocked ,21
IDE11502-ENG127564-Locked menu contents-FB_NAV_3,non_blocked ,21
IDE11502-ENG127545-Locked menu contents-FB_PHONE_0,blocked ,21
IDE11502-ENG127550-Locked menu contents-FB_PHONE_5,blocked ,21
IDE11502-ENG127552-Locked menu contents-FB_PHONE_7,blocked ,21
IDE11502-ENG127508-Locked menu contents-FB_TUNER_3,blocked ,21
IDE11502-ENG127509-Locked menu contents-FB_TUNER_4,blocked ,21
IDE11502-ENG127512-Locked menu contents-FB_TUNER_7,blocked ,21
IDE13183-Deactivation/activation of the pop-up for active tracking services,00 00 00 00 ,4
MAS00951-Bluetooth,On ,1
ENG122227-ENG125811-Car_Function_Adaptations_Gen2-menu_auxiliary_climatization,activated ,60
ENG122227-ENG152538-Car_Function_Adaptations_Gen2-menu_auxiliary_ventilation,activated ,60
ENG122227-ENG152543-Car_Function_Adaptations_Gen2-menu_crossroad_assistent,activated ,60
ENG122227-ENG117486-Car_Function_Adaptations_Gen2-menu_display_ACC,not activated ,60
ENG122227-ENG117488-Car_Function_Adaptations_Gen2-menu_display_ACC_over_threshold_high,not activated ,60
ENG122227-ENG117646-Car_Function_Adaptations_Gen2-menu_display_adaptive_key,activated ,60
ENG122227-ENG117648-Car_Function_Adaptations_Gen2-menu_display_adaptive_key_over_threshold_high,not activated ,60
ENG122227-ENG122296-Car_Function_Adaptations_Gen2-menu_display_angle_of_slope,activated ,60
ENG122227-ENG117501-Car_Function_Adaptations_Gen2-menu_display_awv,not activated ,60
ENG122227-ENG117503-Car_Function_Adaptations_Gen2-menu_display_awv_over_threshold_high,not activated ,60
ENG122227-ENG117666-Car_Function_Adaptations_Gen2-menu_display_BCmE,activated ,60
ENG122227-ENG117668-Car_Function_Adaptations_Gen2-menu_display_BCmE_over_threshold_high,activated ,60
ENG122227-ENG117671-Car_Function_Adaptations_Gen2-menu_display_Brake_Function,activated ,60
ENG122227-ENG117673-Car_Function_Adaptations_Gen2-menu_display_Brake_Function_over_threshold_high,activated ,60
ENG122227-ENG117651-Car_Function_Adaptations_Gen2-menu_display_car_mirror,activated ,60
ENG122227-ENG117653-Car_Function_Adaptations_Gen2-menu_display_car_mirror_over_threshold_high,activated ,60
ENG122227-ENG117566-Car_Function_Adaptations_Gen2-menu_display_compass,activated ,60
ENG122227-ENG142087-Car_Function_Adaptations_Gen2-menu_display_Display_Configuration,activated ,60
ENG122227-ENG117656-Car_Function_Adaptations_Gen2-menu_display_driving_school,activated ,60
ENG122227-ENG117631-Car_Function_Adaptations_Gen2-menu_display_MFL_jocker,activated ,60
ENG122227-ENG117576-Car_Function_Adaptations_Gen2-menu_display_oil_level,activated ,60
ENG122227-ENG117496-Car_Function_Adaptations_Gen2-menu_display_pdc,not activated ,60
ENG122227-ENG117498-Car_Function_Adaptations_Gen2-menu_display_pdc_over_threshold_high,not activated ,60
ENG122227-ENG117543-Car_Function_Adaptations_Gen2-menu_display_rdk_over_threshold_high,activated ,60
ENG122227-ENG117638-Car_Function_Adaptations_Gen2-menu_display_road_sign_identification_over_threshold_high,not activated ,60
ENG122227-ENG117676-Car_Function_Adaptations_Gen2-menu_display_Start_Stop_reasons,not activated ,60
ENG122227-ENG117678-Car_Function_Adaptations_Gen2-menu_display_Start_Stop_reasons_over_threshold_high,not activated ,60
ENG122227-ENG122291-Car_Function_Adaptations_Gen2-menu_display_user_eco_rating,not activated ,60
ENG122227-ENG122293-Car_Function_Adaptations_Gen2-menu_display_user_eco_rating_over_threshold_high,activated ,60
ENG122227-ENG117661-Car_Function_Adaptations_Gen2-menu_display_weariness_recognition,not activated ,60
ENG122227-ENG117663-Car_Function_Adaptations_Gen2-menu_display_weariness_recognition_over_threshold_high,not activated ,60
ENG122227-ENG117521-Car_Function_Adaptations_Gen2-menu_display_windows,activated ,60
ENG122227-ENG117523-Car_Function_Adaptations_Gen2-menu_display_windows_over_threshold_high,activated ,60
ENG122227-ENG142092-Car_Function_Adaptations_Gen2-menu_soundcontrol,activated ,60
ENG122229-ENG117700-Car_Function_List_BAP_Gen2-ACC_0x05,not activated ,64
ENG122229-ENG117701-Car_Function_List_BAP_Gen2-ACC_0x05_msg_bus,Databus extended ,64
ENG122229-ENG117703-Car_Function_List_BAP_Gen2-air_suspension_0x06_msg_bus,Suspension data bus ,64
ENG122229-ENG117765-Car_Function_List_BAP_Gen2-Amplifier_0x2D_msg_bus,Databus Infotainment ,64
ENG122229-ENG122334-Car_Function_List_BAP_Gen2-Angle_Of_Slope_0x24,activated ,64
ENG122229-ENG122335-Car_Function_List_BAP_Gen2-Angle_Of_Slope_0x24_msg_bus,Suspension data bus ,64
ENG122229-ENG117697-Car_Function_List_BAP_Gen2-auxilary_heating_0x03_msg_bus,Comfort data bus ,64
ENG122229-ENG117744-Car_Function_List_BAP_Gen2-AWV_0x1B,not activated ,64
ENG122229-ENG117745-Car_Function_List_BAP_Gen2-AWV_0x1B_msg_bus,Terminal 15 ,64
ENG122229-ENG122337-Car_Function_List_BAP_Gen2-Battery_Management_0x25_msg_bus,Databus drivetrain ,64
ENG122229-ENG117758-Car_Function_List_BAP_Gen2-BCmE_0x23,activated ,64
ENG122229-ENG117759-Car_Function_List_BAP_Gen2-BCmE_0x23_msg_bus,Databus Infotainment ,64
ENG122229-ENG117760-Car_Function_List_BAP_Gen2-Brake_0x26,activated ,64
ENG122229-ENG117761-Car_Function_List_BAP_Gen2-Brake_0x26_msg_bus,Suspension data bus ,64
ENG122229-ENG117716-Car_Function_List_BAP_Gen2-central_locking_0x0D_msg_bus,Comfort data bus ,64
ENG122229-ENG117737-Car_Function_List_BAP_Gen2-charisma_0x17_msg_bus,Databus Infotainment ,64
ENG122229-ENG117735-Car_Function_List_BAP_Gen2-clima_slave_2_0x16_msg_bus,Comfort data bus ,64
ENG122229-ENG117693-Car_Function_List_BAP_Gen2-climatic_master_0x01_msg_bus,Comfort data bus ,64
ENG122229-ENG117695-Car_Function_List_BAP_Gen2-climatic_slave_0x02_msg_bus,Comfort data bus ,64
ENG122229-ENG117725-Car_Function_List_BAP_Gen2-clock_0x11_msg_bus,Comfort data bus ,64
ENG122229-ENG117732-Car_Function_List_BAP_Gen2-compass_0x15,activated ,64
ENG122229-ENG117723-Car_Function_List_BAP_Gen2-driver_seat_0x10_msg_bus,Comfort data bus ,64
ENG122229-ENG125828-Car_Function_List_BAP_Gen2-eCall_0x33_msg_bus,Comfort data bus ,64
ENG122229-ENG127500-Car_Function_List_BAP_Gen2-efficiency_assis_msg_bus_0x3C,not activated ,64
ENG122229-ENG125830-Car_Function_List_BAP_Gen2-ENI_0x37_msg_bus,Comfort data bus ,64
ENG122229-ENG152532-Car_Function_List_BAP_Gen2-ExBoxM2_0x38_msg_bus,Comfort data bus ,64
ENG122229-ENG117709-Car_Function_List_BAP_Gen2-exterieur_light_0x09_msg_bus,Comfort data bus ,64
ENG122229-ENG117699-Car_Function_List_BAP_Gen2-headup_displ_0x04_msg_bus,Comfort data bus ,64
ENG122229-ENG117747-Car_Function_List_BAP_Gen2-Hybrid_0x1D_msg_bus,Databus drivetrain ,64
ENG122229-ENG117707-Car_Function_List_BAP_Gen2-interieur_light_0x08_msg_bus,Comfort data bus ,64
ENG122229-ENG117740-Car_Function_List_BAP_Gen2-LDW_HCA_0x19,not activated ,64
ENG122229-ENG117741-Car_Function_List_BAP_Gen2-LDW_HCA_0x19_msg_bus,Databus extended ,64
ENG122229-ENG117721-Car_Function_List_BAP_Gen2-MFA_0x0F_msg_bus,Comfort data bus ,64
ENG122229-ENG117767-Car_Function_List_BAP_Gen2-MFL_Jocker_0x34,activated ,64
ENG122229-ENG117766-Car_Function_List_BAP_Gen2-MFL_Jocker_msg_bus_0x34,Databus Infotainment ,64
ENG122229-ENG117719-Car_Function_List_BAP_Gen2-mirror_0x0E,activated ,64
ENG122229-ENG117718-Car_Function_List_BAP_Gen2-mirror_0x0E_msg_bus,Comfort data bus ,64
ENG122229-ENG117710-Car_Function_List_BAP_Gen2-parking_assist_0x0A,not activated ,64
ENG122229-ENG117753-Car_Function_List_BAP_Gen2-Passenger_Seat_0x20_msg_bus,Comfort data bus ,64
ENG122229-ENG125832-Car_Function_List_BAP_Gen2-Pedestrian_Assist_msg_bus_0x3A,Databus extended ,64
ENG122229-ENG125827-Car_Function_List_BAP_Gen2-Range_Data_msg_bus_0x39,Databus Infotainment ,64
ENG122229-ENG122328-Car_Function_List_BAP_Gen2-RearSeatEntertainment_0x2E_msg_bus,Comfort data bus ,64
ENG122229-ENG117751-Car_Function_List_BAP_Gen2-Reversible_Seat_Belt_Tightener_0x1F_msg_bus,Databus drivetrain ,64
ENG122229-ENG125834-Car_Function_List_BAP_Gen2-Seat_Pneumatic_msg_bus_0x3B,Comfort data bus ,64
ENG122229-ENG139201-Car_Function_List_BAP_Gen2-Seatmemory_codriver_rear_msg_bus_0x3F,Comfort data bus ,64
ENG122229-ENG139199-Car_Function_List_BAP_Gen2-Seatmemory_driver_rear_msg_bus_0x3E,Comfort data bus ,64
ENG122229-ENG117727-Car_Function_List_BAP_Gen2-service_interval_display_0x12_msg_bus,Comfort data bus ,64
ENG122229-ENG122330-Car_Function_List_BAP_Gen2-Special_Functions_msg_bus_0x35,Comfort data bus ,64
ENG122229-ENG117762-Car_Function_List_BAP_Gen2-Start_Stop_reasons_0x27,not activated ,64
ENG122229-ENG117763-Car_Function_List_BAP_Gen2-Start_Stop_reasons_0x27_msg_bus,Databus Infotainment ,64
ENG122229-ENG117743-Car_Function_List_BAP_Gen2-SWA_0x1A_msg_bus,Databus extended ,64
ENG122229-ENG117705-Car_Function_List_BAP_Gen2-tire_pressure_system_0x07_msg_bus,Suspension data bus ,64
ENG122229-ENG117755-Car_Function_List_BAP_Gen2-traffic_sign_recognition_0x21_msg_bus,Databus extended ,64
ENG122229-ENG122332-Car_Function_List_BAP_Gen2-Trailer_Assistant_msg_bus_0x36,Comfort data bus ,64
ENG122229-ENG122326-Car_Function_List_BAP_Gen2-TV_tuner_0x2C_msg_bus,Comfort data bus ,64
ENG122229-ENG117731-Car_Function_List_BAP_Gen2-UGDO_0x14_msg_bus,Terminal 15 ,64
ENG122229-ENG117729-Car_Function_List_BAP_Gen2-unit_master_0x13_msg_bus,Comfort data bus ,64
ENG122229-ENG117712-Car_Function_List_BAP_Gen2-VPS_0x0B,not activated ,64
ENG122229-ENG117713-Car_Function_List_BAP_Gen2-VPS_0x0B_msg_bus,Databus Infotainment ,64
ENG122229-ENG117756-Car_Function_List_BAP_Gen2-weariness_rcognition_0x22,not activated ,64
ENG122229-ENG117757-Car_Function_List_BAP_Gen2-weariness_rcognition_0x22_msg_bus,Databus Infotainment ,64
ENG122229-ENG117715-Car_Function_List_BAP_Gen2-wiper_comfort_0x0C_msg_bus,Comfort data bus ,64
ENG122228-ENG127498-Car_Function_List_CAN_Gen2-Adaptive_key,Available ,8
ENG122228-ENG117690-Car_Function_List_CAN_Gen2-Adaptive_key_msg_bus,Comfort data bus ,8
ENG122228-ENG117688-Car_Function_List_CAN_Gen2-Driving_school,Available ,8
ENG122228-ENG117689-Car_Function_List_CAN_Gen2-Driving_school_msg_bus,Databus Infotainment ,8
ENG122228-ENG117684-Car_Function_List_CAN_Gen2-Oil_level_msg_bus,Databus drivetrain ,8
ENG122228-ENG117685-Car_Function_List_CAN_Gen2-PDC_audio_lowering,Not available ,8
ENG122228-ENG117686-Car_Function_List_CAN_Gen2-PDC_audio_lowering_msg_bus,Suspension data bus ,8
ENG122228-ENG101416-Car_Function_List_CAN_Gen2-Reserved_1,Comfort data bus ,8
ENG122228-ENG99458-Car_Function_List_CAN_Gen2-Reserved_2,Comfort data bus ,8
ENG122228-ENG117687-Car_Function_List_CAN_Gen2-VIN_msg_bus,Comfort data bus ,8
ENG117916-ENG102140-Dimming_Illumination_for_Display_Unit-X3,50 ,12
ENG117916-ENG102936-Dimming_Illumination_for_Display_Unit-X4,100 ,12
ENG117916-ENG103548-Dimming_Illumination_for_Display_Unit-X5,150 ,12
ENG117916-ENG100480-Dimming_Illumination_for_Display_Unit-Y2,1 %,12
ENG117916-ENG100773-Dimming_Illumination_for_Display_Unit-Y3,3 %,12
ENG117916-ENG100631-Dimming_Illumination_for_Display_Unit-Y4,6 %,12
ENG117916-ENG102174-Dimming_Illumination_for_Display_Unit-Y5,44 %,12
ENG167428-ENG167502-nhtsa_properties-limitation_dependency,Speed_threshold ,5
ENG167428-ENG167510-nhtsa_properties-nhtsa_limitation_switches_for_androidauto_limit_displayed_message_length,activated ,5
ENG167428-ENG167511-nhtsa_properties-nhtsa_limitation_switches_for_androidauto_no_setup_configuration,activated ,5
ENG167428-ENG167512-nhtsa_properties-nhtsa_limitation_switches_for_androidauto_no_text_input,activated ,5
ENG167428-ENG167513-nhtsa_properties-nhtsa_limitation_switches_for_androidauto_no_video_playback,activated ,5
ENG167428-ENG167514-nhtsa_properties-nhtsa_limitation_switches_for_androidauto_no_voice _input,not activated ,5
ENG167428-ENG167515-nhtsa_properties-nhtsa_limitation_switches_for_carplay_limit_musicLists,not activated ,5
ENG167428-ENG167516-nhtsa_properties-nhtsa_limitation_switches_for_carplay_limit_nonMusicLists,not activated ,5
ENG167428-ENG167517-nhtsa_properties-nhtsa_limitation_switches_for_carplay_no_japanMaps,not activated ,5
ENG167428-ENG167518-nhtsa_properties-nhtsa_limitation_switches_for_carplay_no_softKeyboard,activated ,5
ENG167428-ENG167519-nhtsa_properties-nhtsa_limitation_switches_for_carplay_no_softPhoneKeypad,not activated ,5
ENG117808-p_HMI_Display,13 %,1
Elapsed Time: 00:23
;SW:5G6-035-868   HW:5G6-035-868 ---  Information Electr.
;Component:MU-E--ER      671 8395, Coding:02731200FF00000041220001001000009F0008D40000030000
;EV_MUEnt4CGen2LGE,001041,EV_MUEnt4CGen2LGE_VW12.rod
;Monday,18,March,2019,10:55:07:04045
;VCDS Version: Release 18.9.1 (x64)  Data version: 20190215 DS296.0
;VCID: 70BADAA93A23EF576ED-8024
Group,Description,Actual
IDE00019,Voltage terminal 30,14.5, V
IDE00020,Terminal 15 status,On,
IDE00021,Engine speed,1308.00, /min
IDE00075,Vehicle speed,0.00, km/h
IDE00323,Security Access: Number of invalid keys,0,
IDE00655-MAS01424,Temperature of processor circuit board-max.value,85, °C
IDE00655-MAS01425,Temperature of processor circuit board-min.value,-13, °C
IDE00655-MAS02238,Temperature of processor circuit board-Current,5, °C
IDE00668-MAS03231,Microphone current consumption-Microphone 1,5.50, mA
IDE00668-MAS03232,Microphone current consumption-Microphone 2,25.50, mA
IDE00767,No. of unscheduled ECU resets,1, counts
IDE00916-IDE02127,Speaker status-Left front speaker,Condition not met,
IDE00916-IDE02128,Speaker status-Right front speaker,Condition not met,
IDE00916-IDE02129,Speaker status-Left rear speaker,Condition not met,
IDE00916-IDE02130,Speaker status-Right rear speaker,Condition not met,
IDE00916-ENG117413,Speaker status-loudspeaker_channel_10,Measured value not available,
IDE00916-ENG117414,Speaker status-loudspeaker_channel_11,Measured value not available,
IDE00916-ENG117415,Speaker status-loudspeaker_channel_12,Measured value not available,
IDE00916-ENG117416,Speaker status-loudspeaker_channel_13,Measured value not available,
IDE00916-ENG117417,Speaker status-loudspeaker_channel_14,Measured value not available,
IDE00916-ENG117418,Speaker status-loudspeaker_channel_15,Measured value not available,
IDE00916-ENG117419,Speaker status-loudspeaker_channel_16,Measured value not available,
IDE00916-ENG117408,Speaker status-loudspeaker_channel_5,Measured value not available,
IDE00916-ENG117409,Speaker status-loudspeaker_channel_6,Measured value not available,
IDE00916-ENG117410,Speaker status-loudspeaker_channel_7,Measured value not available,
IDE00916-ENG117411,Speaker status-loudspeaker_channel_8,Measured value not available,
IDE00916-ENG117412,Speaker status-loudspeaker_channel_9,Measured value not available,
IDE01285-ENG101364,Counter of component protection malfunctions-Theft Protection Error Counter,00 01,
IDE01351,Terminal 75 status,On,
IDE01442-MAS06123,Pressing a button-Eject button,Not available,
IDE01698-MAS07206,Status audio signal outputs-Audio signal output channel 1,Measured value not available,
IDE01698-MAS07207,Status audio signal outputs-Audio signal output channel 2,Measured value not available,
IDE01698-MAS07208,Status audio signal outputs-Audio signal output channel 3,Measured value not available,
IDE01698-MAS07209,Status audio signal outputs-Audio signal output channel 4,Measured value not available,
IDE01700-MAS01763,Status of tuner for digital radio (DAB)-Signal Strength,255, dBµV
IDE01700-MAS01765,Status of tuner for digital radio (DAB)-Audio Signal,Not available,
IDE01700-MAS02572,Status of tuner for digital radio (DAB)-Mute,not activated,
IDE01700-MAS02949,Status of tuner for digital radio (DAB)-Frequency,0, kHz
IDE01700-MAS03786,Status of tuner for digital radio (DAB)-Audio Codec,Not available,
IDE01700-ENG117350,Status of tuner for digital radio (DAB)-Audio_Mode,00,
IDE01700-ENG117354,Status of tuner for digital radio (DAB)-Audio_Quality,0,
IDE01700-ENG117330,Status of tuner for digital radio (DAB)-availability_traffic_data_TMC,Not available,
IDE01700-ENG117329,Status of tuner for digital radio (DAB)-availability_traffic_data_TP,Not available,
IDE01700-ENG117348,Status of tuner for digital radio (DAB)-Bit_Rate,65535, kbps
IDE01700-ENG117346,Status of tuner for digital radio (DAB)-Charset,00,
IDE01700-ENG117327,Status of tuner for digital radio (DAB)-DAB_Bit_Error_Rate_FIC,16.777215,
IDE01700-ENG117326,Status of tuner for digital radio (DAB)-DAB_Bit_Error_Rate_MSC,16.777215,
IDE01700-ENG117328,Status of tuner for digital radio (DAB)-DAB_Bit_Error_Rate_NET,16.777215,
IDE01700-ENG117340,Status of tuner for digital radio (DAB)-Data_Service_Identifier,00 00 00 00,
IDE01700-ENG117341,Status of tuner for digital radio (DAB)-Data_Service_Label,                ,
IDE01700-ENG117345,Status of tuner for digital radio (DAB)-Data_Service_Label_Mask,00 00,
IDE01700-ENG117331,Status of tuner for digital radio (DAB)-Ensemble_ID,00 00 00 00,
IDE01700-ENG117332,Status of tuner for digital radio (DAB)-Ensemble_Label,                ,
IDE01700-ENG117333,Status of tuner for digital radio (DAB)-Ensemble_Label_Mask,00 00,
IDE01700-ENG117334,Status of tuner for digital radio (DAB)-Extended_Country_Code,00,
IDE01700-ENG117342,Status of tuner for digital radio (DAB)-Label_Masks,00 00,
IDE01700-ENG117335,Status of tuner for digital radio (DAB)-Program_Service_Identifier,00 00 00 00,
IDE01700-ENG117351,Status of tuner for digital radio (DAB)-Protection_Level,Not available,
IDE01700-ENG117349,Status of tuner for digital radio (DAB)-Sample_Rate,65535, kHz
IDE01700-ENG117336,Status of tuner for digital radio (DAB)-Service_Component_Identifier,00,
IDE01700-ENG117338,Status of tuner for digital radio (DAB)-Service_Label,                ,
IDE01700-ENG117343,Status of tuner for digital radio (DAB)-Service_Label_Mask,00 00,
IDE01700-ENG117325,Status of tuner for digital radio (DAB)-signal_quality,0,
IDE01700-ENG117337,Status of tuner for digital radio (DAB)-Sub_Channel_Identifier,00,
IDE01700-ENG117339,Status of tuner for digital radio (DAB)-Sub_Service_Label,                ,
IDE01700-ENG117344,Status of tuner for digital radio (DAB)-Sub_Service_Label_Mask,00 00,
IDE01700-ENG117353,Status of tuner for digital radio (DAB)-SYNC/OFDM_Lock,not activated,
IDE01700-ENG117352,Status of tuner for digital radio (DAB)-Transmission_Mode,0,
IDE01715,Status terminal S,On,
IDE01716,Terminal 50 status,OFF,
IDE01767-MAS00940,Status of telephone-Antenna diagnostic,Not available,
IDE01767-MAS00941,Status of telephone-Telephone baseplate diagnostic,not connected,
IDE01767-MAS00955,Status of telephone-Handset in handset holder (cradle),not selected,
IDE01767-MAS01806,Status of telephone-Handset holder (cradle),not connected,
IDE01768-MAS01808,Status of antenna 1 for radio-Antenna current,62, mA
IDE01768-MAS03938,Status of antenna 1 for radio-Connection between radio and antenna amplifier,Electrical OK,
IDE01768-MAS03939,Status of antenna 1 for radio-Connection between antenna amplifier and antenna,Electrical OK,
IDE01768-MAS03991,Status of antenna 1 for radio-Reception level antenna 1,44, dBµV
IDE01769-MAS01808,Status of antenna 2 for radio-Antenna current,47, mA
IDE01769-MAS03938,Status of antenna 2 for radio-Connection between radio and antenna amplifier,Electrical OK,
IDE01769-MAS03939,Status of antenna 2 for radio-Connection between antenna amplifier and antenna,Electrical OK,
IDE01769-MAS04344,Status of antenna 2 for radio-Reception level antenna 2,29, dBµV
IDE01771-MAS01808,Status of digital radio antenna 1-Antenna current,0, mA
IDE01771-MAS03938,Status of digital radio antenna 1-Connection between radio and antenna amplifier,Electrical OK,
IDE01771-MAS03939,Status of digital radio antenna 1-Connection between antenna amplifier and antenna,Electrical OK,
IDE01771-ENG117327,Status of digital radio antenna 1-DAB_Bit_Error_Rate_FIC,1.068326,
IDE01771-ENG117326,Status of digital radio antenna 1-DAB_Bit_Error_Rate_MSC,1.068323,
IDE02070-IDE02060,Wake-up cause-Eject optical medium\ (CD/DVD Eject),No,
IDE02070-IDE04544,Wake-up cause-Media type in optical drive,No,
IDE02070-MAS03177,Wake-up cause-Databus Infotainment,Yes,
IDE02070-MAS03180,Wake-up cause-Local data bus,No,
IDE02070-MAS03690,Wake-up cause-Telephone,No,
IDE02070-MAS03782,Wake-up cause-WLAN,No,
IDE02070-MAS03833,Wake-up cause-Optical data bus,No,
IDE02486,Data logger triggering,not active,
IDE02508-MAS00951,Bluetooth: Visibility-Bluetooth,On,
IDE02508-MAS03001,Bluetooth: Visibility-Mode,Bluetooth available,
IDE04312-MAS00109,System run time-Hours,0, H
IDE04312-MAS00110,System run time-Minutes,0, min
IDE04317-MAS00108,Total system run time-Day,4, d
IDE04317-MAS00109,Total system run time-Hours,6, H
IDE04317-MAS00110,Total system run time-Minutes,57, min
IDE04329-IDE04332,Status of all SWaP functions-Release code for a SWaP function,Available,
IDE04329-IDE05814,Status of all SWaP functions-Individualization characteristic,valid,
IDE04329-IDE06260,Status of all SWaP functions-ID number,00 06 03 00,
IDE04329-MAS01340,Status of all SWaP functions-Functions,Available,
IDE04329-MAS01903,Status of all SWaP functions-Configuration,OK,
IDE04329-MAS02934,Status of all SWaP functions-Prerequisites met,Condition met,
IDE04329-MAS05616,Status of all SWaP functions-Cancellation,No,
IDE04329-MAS05617,Status of all SWaP functions-Authentication,valid,
IDE04332,Release code for a SWaP function,Not available,
IDE04334-MAS02643,Public key for SWaP function-Key,B4 CF 3F 44 7C B9 D4 C5 21 6D 4A 2F 2B 1A 20 5F E9 9E 80 90 EB BF 1C 29 EE 40 C2 C8 9F 54 41 7E 1E E2 AD 0C 42 E2 28 A7 7E 20 1F BB D8 61 70 21 DC 61 A6 00 5A 15 05 EA E6 24 85 A8 45 50 4E B8 AA FC F5 AC 93 02 8F 27 89 14 26 07 6B 49 3A BD F4 94 57 E7 44 E8 60 61 A2 76 5D 68 5B C3 9D 13 ED 44 00 C6 23 F0 F3 B9 B4 43 83 70 41 06 49 EF EE B9 94 98 C4 95 7D 6E 51 AF 23 15 D8 67 45 49 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 03,
IDE04541-MAS03621,Status of active media source at output 1-Video codec,--------------------,
IDE04541-MAS03622,Status of active media source at output 1-Horizontal video resolution,65535,
IDE04541-MAS03623,Status of active media source at output 1-Vertical video resolution,65535,
IDE04541-MAS03778,Status of active media source at output 1-Active media source,Bluetooth,
IDE04541-MAS03783,Status of active media source at output 1-Video Bitrate,65535, kbps
IDE04541-MAS03784,Status of active media source at output 1-Audio Bitrate,Not available,
IDE04541-MAS03785,Status of active media source at output 1-Digital rights management (DRM),Not available,
IDE04541-MAS03786,Status of active media source at output 1-Audio Codec,--------------------,
IDE04541-MAS03787,Status of active media source at output 1-Image format,--------------------,
IDE04541-MAS03788,Status of active media source at output 1-Horizontal image resolution,65535,
IDE04541-MAS03789,Status of active media source at output 1-Vertical image resolution,65535,
IDE04541-MAS03793,Status of active media source at output 1-Color depth,65535, bit
IDE04547,Traffic information,OFF,
IDE04639-IDE02060,Last wake-up cause-Eject optical medium\ (CD/DVD Eject),No,
IDE04639-IDE04544,Last wake-up cause-Media type in optical drive,No,
IDE04639-MAS03177,Last wake-up cause-Databus Infotainment,Yes,
IDE04639-MAS03180,Last wake-up cause-Local data bus,No,
IDE04639-MAS03690,Last wake-up cause-Telephone,No,
IDE04639-MAS03782,Last wake-up cause-WLAN,No,
IDE04639-MAS03833,Last wake-up cause-Optical data bus,No,
IDE04640,Over-temperature protection for amplifier,no restriction,
IDE04641,Speed-dependent volume adjustment,0.0, dB
IDE04749-ENG117444,Mute-am_fm_tuner,No,
IDE04749-ENG117443,Mute-audiomanager,No,
IDE04749-ENG117447,Mute-component_protection,No,
IDE04749-ENG117445,Mute-dab_sdars_tuner,No,
IDE04749-ENG117446,Mute-drm_hd_tuner,No,
IDE04749-ENG113342,Mute-Hardware,No,
IDE04767-MAS01240,Update software via medium-Programming status,not active,
IDE04767-MAS02111,Update software via medium-Data consistency,valid,
IDE04767-MAS02112,Update software via medium-Programmability,no request,
IDE04768,Bluetooth device address,48 F0 7B 1C 9B 96,
IDE05040-MAS01632,Video input status-Status,Not available,
IDE05040-MAS04390,Video input status-Active source,Not available,
IDE05597-IDE03615,Bluetooth: Paired device 1-Version,N6¸*Ÿ Pixel 2
     ÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿ
ÿÿÿÿÿÿÿ,
IDE05597-IDE04768,Bluetooth: Paired device 1-Bluetooth device address,40 4E 36 B8 AD 9F,
IDE05597-MAS01483,Bluetooth: Paired device 1-Softwareversion,N6¸*Ÿ Pixel 2
     ÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿ
ÿÿÿÿÿÿÿ,
IDE05597-MAS02159,Bluetooth: Paired device 1-Remote SIM Access Profile (rSAP),40 4E,
IDE05597-MAS02160,Bluetooth: Paired device 1-Hands free profile (HFP),40 4E,
IDE05597-MAS03159,Bluetooth: Paired device 1-Manufacturer,N6¸*Ÿ Pixel 2
     ÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿ
ÿÿÿÿÿÿÿ,
IDE05597-MAS04326,Bluetooth: Paired device 1-Device name,Pixel 2
ÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿ,
IDE05597-ENG117431,Bluetooth: Paired device 1-A2DP,40 4E,
IDE05597-ENG117440,Bluetooth: Paired device 1-ACTIVESYNCML,40 4E,
IDE05597-ENG105233,Bluetooth: Paired device 1-AT,40 4E,
IDE05597-ENG117432,Bluetooth: Paired device 1-AVRCP,40 4E,
IDE05597-ENG117434,Bluetooth: Paired device 1-DUN,40 4E,
IDE05597-ENG106692,Bluetooth: Paired device 1-FTP,40 4E,
IDE05597-ENG117435,Bluetooth: Paired device 1-HIDP,40 4E,
IDE05597-ENG117429,Bluetooth: Paired device 1-HSP,40 4E,
IDE05597-ENG117437,Bluetooth: Paired device 1-IRMC,40 4E,
IDE05597-ENG101499,Bluetooth: Paired device 1-map,40 4E,
IDE05597-ENG117436,Bluetooth: Paired device 1-OBEX,40 4E,
IDE05597-ENG117439,Bluetooth: Paired device 1-OPP,40 4E,
IDE05597-ENG117433,Bluetooth: Paired device 1-PAN,40 4E,
IDE05597-ENG108174,Bluetooth: Paired device 1-PBAP,40 4E,
IDE05597-ENG117427,Bluetooth: Paired device 1-SDAP,40 4E,
IDE05597-ENG117428,Bluetooth: Paired device 1-SPP,40 4E,
IDE05597-ENG117438,Bluetooth: Paired device 1-SYNCML,40 4E,
IDE05598-IDE03615,Bluetooth: Paired device 2-Version,3Ž’™± Chad’s iPhone                  "Apple Inc."                    iPhone11,6                      Version 12.1.2 (Build 16C101) ÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿ,
IDE05598-IDE04768,Bluetooth: Paired device 2-Bluetooth device address,E0 33 8E 92 99 B1,
IDE05598-MAS01483,Bluetooth: Paired device 2-Softwareversion,3Ž’™± Chad’s iPhone                  "Apple Inc."                    iPhone11,6                      Version 12.1.2 (Build 16C101) ÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿ,
IDE05598-MAS02159,Bluetooth: Paired device 2-Remote SIM Access Profile (rSAP),E0 33,
IDE05598-MAS02160,Bluetooth: Paired device 2-Hands free profile (HFP),E0 33,
IDE05598-MAS03159,Bluetooth: Paired device 2-Manufacturer,3Ž’™± Chad’s iPhone                  "Apple Inc."                    iPhone11,6                      Version 12.1.2 (Build 16C101) ÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿ,
IDE05598-MAS04326,Bluetooth: Paired device 2-Device name,Chad’s iPhone
 "Apple Inc."
 iPhone11,6
IDE05598-ENG117431,Bluetooth: Paired device 2-A2DP,E0 33,
IDE05598-ENG117440,Bluetooth: Paired device 2-ACTIVESYNCML,E0 33,
IDE05598-ENG105233,Bluetooth: Paired device 2-AT,E0 33,
IDE05598-ENG117432,Bluetooth: Paired device 2-AVRCP,E0 33,
IDE05598-ENG117434,Bluetooth: Paired device 2-DUN,E0 33,
IDE05598-ENG106692,Bluetooth: Paired device 2-FTP,E0 33,
IDE05598-ENG117435,Bluetooth: Paired device 2-HIDP,E0 33,
IDE05598-ENG117429,Bluetooth: Paired device 2-HSP,E0 33,
IDE05598-ENG117437,Bluetooth: Paired device 2-IRMC,E0 33,
IDE05598-ENG101499,Bluetooth: Paired device 2-map,E0 33,
IDE05598-ENG117436,Bluetooth: Paired device 2-OBEX,E0 33,
IDE05598-ENG117439,Bluetooth: Paired device 2-OPP,E0 33,
IDE05598-ENG117433,Bluetooth: Paired device 2-PAN,E0 33,
IDE05598-ENG108174,Bluetooth: Paired device 2-PBAP,E0 33,
IDE05598-ENG117427,Bluetooth: Paired device 2-SDAP,E0 33,
IDE05598-ENG117428,Bluetooth: Paired device 2-SPP,E0 33,
IDE05598-ENG117438,Bluetooth: Paired device 2-SYNCML,E0 33,
IDE05599-IDE03615,Bluetooth: Paired device 3-Version,N6OtH cmpaint118                       HTC
       HTC U11
     ÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿ
ÿÿÿÿÿÿÿ,
IDE05599-IDE04768,Bluetooth: Paired device 3-Bluetooth device address,40 4E 36 4F 74 48,
IDE05599-MAS01483,Bluetooth: Paired device 3-Softwareversion,N6OtH cmpaint118                       HTC
       HTC U11
     ÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿ
ÿÿÿÿÿÿÿ,
IDE05599-MAS02159,Bluetooth: Paired device 3-Remote SIM Access Profile (rSAP),40 4E,
IDE05599-MAS02160,Bluetooth: Paired device 3-Hands free profile (HFP),40 4E,
IDE05599-MAS03159,Bluetooth: Paired device 3-Manufacturer,N6OtH cmpaint118                       HTC
       HTC U11
     ÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿ
ÿÿÿÿÿÿÿ,
IDE05599-MAS04326,Bluetooth: Paired device 3-Device name,cmpaint118
 HTC
 HTC U11
IDE05599-ENG117431,Bluetooth: Paired device 3-A2DP,40 4E,
IDE05599-ENG117440,Bluetooth: Paired device 3-ACTIVESYNCML,40 4E,
IDE05599-ENG105233,Bluetooth: Paired device 3-AT,40 4E,
IDE05599-ENG117432,Bluetooth: Paired device 3-AVRCP,40 4E,
IDE05599-ENG117434,Bluetooth: Paired device 3-DUN,40 4E,
IDE05599-ENG106692,Bluetooth: Paired device 3-FTP,40 4E,
IDE05599-ENG117435,Bluetooth: Paired device 3-HIDP,40 4E,
IDE05599-ENG117429,Bluetooth: Paired device 3-HSP,40 4E,
IDE05599-ENG117437,Bluetooth: Paired device 3-IRMC,40 4E,
IDE05599-ENG101499,Bluetooth: Paired device 3-map,40 4E,
IDE05599-ENG117436,Bluetooth: Paired device 3-OBEX,40 4E,
IDE05599-ENG117439,Bluetooth: Paired device 3-OPP,40 4E,
IDE05599-ENG117433,Bluetooth: Paired device 3-PAN,40 4E,
IDE05599-ENG108174,Bluetooth: Paired device 3-PBAP,40 4E,
IDE05599-ENG117427,Bluetooth: Paired device 3-SDAP,40 4E,
IDE05599-ENG117428,Bluetooth: Paired device 3-SPP,40 4E,
IDE05599-ENG117438,Bluetooth: Paired device 3-SYNCML,40 4E,
IDE05600-IDE03615,Bluetooth: Paired device 4-Version,ÿÿÿÿÿ--------ÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿ,
IDE05600-IDE04768,Bluetooth: Paired device 4-Bluetooth device address,FF FF FF FF FF FF,
IDE05600-MAS01483,Bluetooth: Paired device 4-Softwareversion,ÿÿÿÿÿ--------ÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿ,
IDE05600-MAS02159,Bluetooth: Paired device 4-Remote SIM Access Profile (rSAP),FF FF,
IDE05600-MAS02160,Bluetooth: Paired device 4-Hands free profile (HFP),FF FF,
IDE05600-MAS03159,Bluetooth: Paired device 4-Manufacturer,ÿÿÿÿÿ--------ÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿ,
IDE05600-MAS04326,Bluetooth: Paired device 4-Device name,--
IDE05600-ENG117431,Bluetooth: Paired device 4-A2DP,FF FF,
IDE05600-ENG117440,Bluetooth: Paired device 4-ACTIVESYNCML,FF FF,
IDE05600-ENG105233,Bluetooth: Paired device 4-AT,FF FF,
IDE05600-ENG117432,Bluetooth: Paired device 4-AVRCP,FF FF,
IDE05600-ENG117434,Bluetooth: Paired device 4-DUN,FF FF,
IDE05600-ENG106692,Bluetooth: Paired device 4-FTP,FF FF,
IDE05600-ENG117435,Bluetooth: Paired device 4-HIDP,FF FF,
IDE05600-ENG117429,Bluetooth: Paired device 4-HSP,FF FF,
IDE05600-ENG117437,Bluetooth: Paired device 4-IRMC,FF FF,
IDE05600-ENG101499,Bluetooth: Paired device 4-map,FF FF,
IDE05600-ENG117436,Bluetooth: Paired device 4-OBEX,FF FF,
IDE05600-ENG117439,Bluetooth: Paired device 4-OPP,FF FF,
IDE05600-ENG117433,Bluetooth: Paired device 4-PAN,FF FF,
IDE05600-ENG108174,Bluetooth: Paired device 4-PBAP,FF FF,
IDE05600-ENG117427,Bluetooth: Paired device 4-SDAP,FF FF,
IDE05600-ENG117428,Bluetooth: Paired device 4-SPP,FF FF,
IDE05600-ENG117438,Bluetooth: Paired device 4-SYNCML,FF FF,
IDE05601-IDE03615,Bluetooth: Paired device 5-Version,ÿÿÿÿÿ--------ÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿ,
IDE05601-IDE04768,Bluetooth: Paired device 5-Bluetooth device address,FF FF FF FF FF FF,
IDE05601-MAS01483,Bluetooth: Paired device 5-Softwareversion,ÿÿÿÿÿ--------ÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿ,
IDE05601-MAS02159,Bluetooth: Paired device 5-Remote SIM Access Profile (rSAP),FF FF,
IDE05601-MAS02160,Bluetooth: Paired device 5-Hands free profile (HFP),FF FF,
IDE05601-MAS03159,Bluetooth: Paired device 5-Manufacturer,ÿÿÿÿÿ--------ÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿ,
IDE05601-MAS04326,Bluetooth: Paired device 5-Device name,--
IDE05601-ENG117431,Bluetooth: Paired device 5-A2DP,FF FF,
IDE05601-ENG117440,Bluetooth: Paired device 5-ACTIVESYNCML,FF FF,
IDE05601-ENG105233,Bluetooth: Paired device 5-AT,FF FF,
IDE05601-ENG117432,Bluetooth: Paired device 5-AVRCP,FF FF,
IDE05601-ENG117434,Bluetooth: Paired device 5-DUN,FF FF,
IDE05601-ENG106692,Bluetooth: Paired device 5-FTP,FF FF,
IDE05601-ENG117435,Bluetooth: Paired device 5-HIDP,FF FF,
IDE05601-ENG117429,Bluetooth: Paired device 5-HSP,FF FF,
IDE05601-ENG117437,Bluetooth: Paired device 5-IRMC,FF FF,
IDE05601-ENG101499,Bluetooth: Paired device 5-map,FF FF,
IDE05601-ENG117436,Bluetooth: Paired device 5-OBEX,FF FF,
IDE05601-ENG117439,Bluetooth: Paired device 5-OPP,FF FF,
IDE05601-ENG117433,Bluetooth: Paired device 5-PAN,FF FF,
IDE05601-ENG108174,Bluetooth: Paired device 5-PBAP,FF FF,
IDE05601-ENG117427,Bluetooth: Paired device 5-SDAP,FF FF,
IDE05601-ENG117428,Bluetooth: Paired device 5-SPP,FF FF,
IDE05601-ENG117438,Bluetooth: Paired device 5-SYNCML,FF FF,
IDE05602-MAS01763,Bluetooth: connected device 1-Signal Strength,-71,
IDE05602-MAS04326,Bluetooth: connected device 1-Device name,22633963955429426,
IDE05603-MAS01763,Bluetooth: connected device 2-Signal Strength,Not available,
IDE05603-MAS04326,Bluetooth: connected device 2-Device name,0,
IDE05604-MAS01763,Bluetooth: connected device 3-Signal Strength,Not available,
IDE05604-MAS04326,Bluetooth: connected device 3-Device name,0,
IDE05605-MAS01763,Bluetooth: connected device 4-Signal Strength,Not available,
IDE05605-MAS04326,Bluetooth: connected device 4-Device name,0,
IDE05606-MAS01763,Bluetooth: connected device 5-Signal Strength,Not available,
IDE05606-MAS04326,Bluetooth: connected device 5-Device name,0,
IDE05700-MAS01456,USB connection-Speed,Not available,
IDE05700-MAS01632,USB connection-Status,Not available,
IDE05700-MAS03159,USB connection-Manufacturer,FF FF,
IDE05700-MAS04393,USB connection-USB device class,FF,
IDE05700-MAS04394,USB connection-Connection status,not connected,
IDE05700-MAS04436,USB connection-USB device sub-class,FF,
IDE05700-ENG111957,USB connection-usb_product_id,FF FF,
IDE05700-ENG111955,USB connection-usb_protocol,FF,
IDE05713-MAS01632,Network diagnosis-Status,Enabled,
IDE05725,Terminal 58xs dimmer,0, %
IDE05726,Terminal 58xd dimmer,99.94, %
IDE05814,Individualization characteristic,89 5E 9A 22 17,
IDE06028-MAS02317,Control head button operation-Button code 1,FF,
IDE06028-MAS02318,Control head button operation-Button code 2,FF,
IDE06028-MAS04151,Control head button operation-Joystick,FF,
IDE06028-MAS04413,Control head button operation-Push-and rotary knob for selection,0,
IDE06028-MAS04414,Control head button operation-Volume control,0,
IDE06425,Roller test bench mode: functional,not activated,
IDE06516-MAS01424,Temperature: optical drive-max.value,205, °C
IDE06516-MAS01425,Temperature: optical drive-min.value,205, °C
IDE06516-MAS02238,Temperature: optical drive-Current,205, °C
IDE06517-MAS01424,Temperature: audio amplifier-max.value,85, °C
IDE06517-MAS01425,Temperature: audio amplifier-min.value,-13, °C
IDE06517-MAS02238,Temperature: audio amplifier-Current,5, °C
IDE06521-MAS01424,Temperature of MMX PC boards-max.value,205, °C
IDE06521-MAS01425,Temperature of MMX PC boards-min.value,205, °C
IDE06521-MAS02238,Temperature of MMX PC boards-Current,205, °C
IDE07589-IDE07590,Update programming: status-Currently processed module,0,
IDE07589-IDE07591,Update programming: status-Number of modules to be programmed,0,
IDE07589-MAS01632,Update programming: status-Status,not active,
IDE07589-MAS10948,Update programming: status-control,Diagnosis,
IDE07938,Cause of system start,Data bus,
IDE07939,Last cause of system start,Data bus,
IDE10478-MAS01632,Interface for external media: status-Status,OK,
IDE10479-MAS01482,Interface for external media: identification-Hardwareversion,---,
IDE10479-MAS01483,Interface for external media: identification-Softwareversion,----,
IDE10479-MAS04970,Interface for external media: identification-Part Number,-----------,
IDE10843-MAS01482,Function module: identification-Hardwareversion,100,
IDE10843-MAS04326,Function module: identification-Device name,MU                               ,
IDE10843-MAS11354,Function module: identification-Bootloader version,8395,
IDE10843-MAS11355,Function module: identification-Application version,8395,
IDE10843-MAS11356,Function module: identification-Module Name,CPU                              ,
IDE10857-MAS02476,Touchless loading of mobile phone: status-install,Not available,
IDE10857-MAS11500,Touchless loading of mobile phone: status-Foreign object,No,
IDE10857-MAS11501,Touchless loading of mobile phone: status-charge,No,
IDE11127-IDE04332,Error-causing FS ID with status-Release code for a SWaP function,Not available,
IDE11127-IDE05814,Error-causing FS ID with status-Individualization characteristic,invalid,
IDE11127-IDE06260,Error-causing FS ID with status-ID number,00 00 00 00,
IDE11127-MAS01340,Error-causing FS ID with status-Functions,Not available,
IDE11127-MAS01903,Error-causing FS ID with status-Configuration,not OK,
IDE11127-MAS02934,Error-causing FS ID with status-Prerequisites met,Condition not met,
IDE11127-MAS05616,Error-causing FS ID with status-Cancellation,Yes,
IDE11127-MAS05617,Error-causing FS ID with status-Authentication,Condition not met,
IDE12277-MAS01632,External optical drive (USB): status-Status,Measured value not available,
IDE12420-MAS01482,iPod chip: identification-Hardwareversion,01,
IDE12420-MAS01483,iPod chip: identification-Softwareversion,03,
IDE12420-MAS02832,iPod chip: identification-Malfunction status,00,
MAS00464-MAS00106,Standard - ambient data 1-Year,2019,
MAS00464-MAS00107,Standard - ambient data 1-Month,3,
MAS00464-MAS00108,Standard - ambient data 1-Day,18,
MAS00464-MAS00109,Standard - ambient data 1-Hours,10,
MAS00464-MAS00110,Standard - ambient data 1-Minutes,54,
MAS00464-MAS00111,Standard - ambient data 1-Seconds,59,
MAS00464-MAS00468,Standard - ambient data 1-Unlearning counter,188,
MAS00464-MAS00711,Standard - ambient data 1-Odometer reading,4134, km
MAS00481-ENG117777,BAP-BAP_Function_ID,00,
MAS00951-IDE04058,Bluetooth-Bluetooth: devices found,0,
MAS00951-MAS04324,Bluetooth-Bluetooth: connected devices,1,
MAS00951-MAS04325,Bluetooth-Bluetooth: Paired devices,3,
MAS01760-MAS01765,Radio Tuner 1-Audio Signal,Analog,
MAS01760-MAS02949,Radio Tuner 1-Frequency,100.7, MHz
MAS01760-MAS03991,Radio Tuner 1-Reception level antenna 1,47, dBµV
MAS01760-MAS04344,Radio Tuner 1-Reception level antenna 2,24, dBµV
MAS01760-MAS04345,Radio Tuner 1-Frequency (AM),540, kHz
MAS01760-ENG117356,Radio Tuner 1-iboc_audio_signal,Not available,
MAS01760-ENG117358,Radio Tuner 1-iboc_count,0,
MAS01760-ENG117355,Radio Tuner 1-iboc_error_rate,255,
MAS01760-ENG117357,Radio Tuner 1-iboc_service,no tuned IBOC Audio Service,
MAS01991-IDE00010,Card reader-Serial number,FF FF FF FF,
MAS01991-IDE01001,Card reader-Application,--,
MAS01991-MAS01632,Card reader-Status,not connected,
MAS01991-MAS03159,Card reader-Manufacturer,FF,
MAS01991-MAS03375,Card reader-Major version,15,
MAS01991-MAS03376,Card reader-Minor version,15,
MAS01991-MAS03959,Card reader-Write-protection,Not available,
MAS01991-MAS04388,Card reader-Card type,-----,
MAS01991-MAS13476,Card reader-Manufacturing date: month,15, mon
MAS01991-MAS13477,Card reader-Manufacturing date: year,2255, yr
MAS04324-MAS04326,Bluetooth: connected devices-Device name,22633963955429426,
MAS04324-MAS04327,Bluetooth: connected devices-Bluetooth connection profile,Hands free profile (HFP),
MAS04325-MAS04326,Bluetooth: Paired devices-Device name,932838851832864,
MAS04325-MAS04327,Bluetooth: Paired devices-Bluetooth connection profile,Hands free profile (HFP),
ENG117872-ENG117778,Byte_Coding_Condition-byte_0_condition,OK,
ENG117872-ENG117779,Byte_Coding_Condition-byte_1_condition,OK,
ENG117872-ENG117788,Byte_Coding_Condition-byte_10_condition,OK,
ENG117872-ENG117789,Byte_Coding_Condition-byte_11_condition,OK,
ENG117872-ENG117790,Byte_Coding_Condition-byte_12_condition,OK,
ENG117872-ENG117791,Byte_Coding_Condition-byte_13_condition,OK,
ENG117872-ENG117792,Byte_Coding_Condition-byte_14_condition,OK,
ENG117872-ENG117793,Byte_Coding_Condition-byte_15_condition,OK,
ENG117872-ENG117794,Byte_Coding_Condition-byte_16_condition,OK,
ENG117872-ENG117795,Byte_Coding_Condition-byte_17_condition,OK,
ENG117872-ENG117796,Byte_Coding_Condition-byte_18_condition,OK,
ENG117872-ENG117797,Byte_Coding_Condition-byte_19_condition,OK,
ENG117872-ENG117780,Byte_Coding_Condition-byte_2_condition,OK,
ENG117872-ENG117798,Byte_Coding_Condition-byte_20_condition,OK,
ENG117872-ENG117799,Byte_Coding_Condition-byte_21_condition,OK,
ENG117872-ENG117800,Byte_Coding_Condition-byte_22_condition,OK,
ENG117872-ENG117801,Byte_Coding_Condition-byte_23_condition,OK,
ENG117872-ENG117802,Byte_Coding_Condition-byte_24_condition,OK,
ENG117872-ENG117803,Byte_Coding_Condition-byte_25_condition,dont care,
ENG117872-ENG117804,Byte_Coding_Condition-byte_26_condition,dont care,
ENG117872-ENG117805,Byte_Coding_Condition-byte_27_condition,dont care,
ENG117872-ENG117781,Byte_Coding_Condition-byte_3_condition,OK,
ENG117872-ENG117782,Byte_Coding_Condition-byte_4_condition,OK,
ENG117872-ENG117783,Byte_Coding_Condition-byte_5_condition,OK,
ENG117872-ENG117784,Byte_Coding_Condition-byte_6_condition,OK,
ENG117872-ENG117785,Byte_Coding_Condition-byte_7_condition,OK,
ENG117872-ENG117786,Byte_Coding_Condition-byte_8_condition,OK,
ENG117872-ENG117787,Byte_Coding_Condition-byte_9_condition,OK,
ENG117866-ENG117457,DAB_FM_linking-dab_mute_status,Mute,
ENG117866-ENG117456,DAB_FM_linking-DAB_quality,0, %
ENG117866-ENG117455,DAB_FM_linking-fm_quality,0, %
ENG117866-ENG117458,DAB_FM_linking-service_linking_status,no_link,
ENG117857-MAS00109,Last_System_Operating_Time-Hours,0, H
ENG117857-MAS00110,Last_System_Operating_Time-Minutes,32, min
ENG117856-MAS00106,Last_System_Operating_Time/Mins.-Year,0, yr
ENG117856-MAS00107,Last_System_Operating_Time/Mins.-Month,0, mon
ENG117856-MAS00108,Last_System_Operating_Time/Mins.-Day,0, d
ENG117856-MAS00109,Last_System_Operating_Time/Mins.-Hours,0, H
ENG117856-MAS00110,Last_System_Operating_Time/Mins.-Minutes,0, min
ENG117856-MAS00111,Last_System_Operating_Time/Mins.-Seconds,0, s
ENG117864-MAS01632,Status_Position_Touchscreen_1-Status,not activated,
ENG117864-ENG117402,Status_Position_Touchscreen_1-calibrate_delta_x,65535,
ENG117864-ENG117403,Status_Position_Touchscreen_1-calibrate_delta_y,65535,
ENG117864-ENG117396,Status_Position_Touchscreen_1-position_x1,0,
ENG117864-ENG117397,Status_Position_Touchscreen_1-position_x2,65535,
ENG117864-ENG117398,Status_Position_Touchscreen_1-position_x3,65535,
ENG117864-ENG117399,Status_Position_Touchscreen_1-position_y1,0,
ENG117864-ENG117400,Status_Position_Touchscreen_1-position_y2,65535,
ENG117864-ENG117401,Status_Position_Touchscreen_1-position_y3,65535,
Elapsed Time: 00:16
Edit. Files moved to: https://drive.google.com/open?id=12QiF6vVYYFW7z59varMVdISNvOhAr3iG
New Edit. I was looking for something unrelated (offroad mode) and made a comparison of my 5F changes to date. I'm gonna paste those here using this thread like a 5F changelog: https://pastebin.com/YeKjMiNd
DV52
C?ID=194404
^^^^Dana: hmm......nothing remarkable about your admap!!:)
The 3 x DSM channels are as I had postulated in the first post. I guess TBAx is correct - he (she?) normally is correct. DSM must be restrict to the lower-end 5F units - I wonder why ths is so?
Again - thanks for enabling the tweak on your car and for confirming that it's not possible to add DSM to the higher end MIBs
jyoung8607
FoRT
Cincinnati, OH
C?ID=25607
It works on my 2018 Golf R with Discover Media. I forget how the hell I turned it on, I did it ages ago. I'll take a map later tonight.
jyoung8607
FoRT
Cincinnati, OH
C?ID=25607
   Part No SW: 3Q0 035 876 B    HW: 3Q0 035 876 B
   Component: MU-S-NS-US    851 0867
   Coding: 027310020000000051220002001808009F0507F401200405C6
   Shop #: WSC 08607 444 00001
   ROD: EV_MUStd4CDELP_VW37.rod
   VCID: B3265EA41A676AD1F4-80E6
   Subsystem 1 - Part No SW: 5G6 919 605 D    HW: 5G6 919 605 D
   Component: ABT_Std-2_Nav  H50 8130
   Serial number: VWZ6ZJT3480215
   Subsystem 2 - Part No SW: 3G0 919 866 BP    HW: -----------
   Component: NAR 2018  --- 0715
7184 - Function Restricted due to Missing Message(s)
          U1111 00 [009] - -
          [Seat adjustment/seat memory (0x10) - function restriction due to communication error - BapErr_retry not successful]
                    Reset counter: 154
                    Mileage: 24018 km
                    Date: 2019.02.18
                    Time: 17:32:31
                    Voltage terminal 30: 14.9 V
                    BAP-BAP_Function_ID: 02
;SW:3Q0-035-876-B   HW:3Q0-035-876-B ---  Information Electr.
;Component:MU-S-NS-US    851 0867, Coding:027310020000000051220002001808009F0507F401200405C6
;EV_MUStd4CDELP,001001,EV_MUStd4CDELP_VW37.rod
;Monday,18,March,2019,23:45:11:21122
;VCDS Version: Beta 19.1.3 (x64)  Data version: 20190114 DS301.0
;VCID: B3265EA41A676AD1F4-80E6
IDE00019,Voltage terminal 30,11.7, V
IDE00021,Engine speed,0.00, /min
IDE00323,Security Access: Number of invalid keys,1,
IDE00668-MAS03231,Microphone current consumption-Microphone 1,6.00, mA
IDE00767,No. of unscheduled ECU resets,0, counts
IDE00916-IDE02127,Speaker status-Left front speaker,Measured value not available,
IDE00916-IDE02128,Speaker status-Right front speaker,Measured value not available,
IDE00916-IDE02129,Speaker status-Left rear speaker,Measured value not available,
IDE00916-IDE02130,Speaker status-Right rear speaker,Measured value not available,
IDE01285-ENG101364,Counter of component protection malfunctions-Theft Protection Error Counter,00 00,
IDE01351,Terminal 75 status,OFF,
IDE01442-MAS06123,Pressing a button-Eject button,not activated,
IDE01712-MAS01779,GPS Position-Length,075°09'26.30"W,
IDE01712-MAS01780,GPS Position-Width,039°57'49.88"N,
IDE01713-MAS01632,Status GPS reception-Status,GPS data is being received: position completely determined,
IDE01713-MAS01785,Status GPS reception-Number of visible satellites,13,
IDE01713-MAS01786,Status GPS reception-Number of tracked satellites,10,
IDE01768-MAS01808,Status of antenna 1 for radio-Antenna current,61, mA
IDE01768-MAS03991,Status of antenna 1 for radio-Reception level antenna 1,17, dBµV
IDE01769-MAS01808,Status of antenna 2 for radio-Antenna current,52, mA
IDE01769-MAS04344,Status of antenna 2 for radio-Reception level antenna 2,34, dBµV
IDE01770-MAS01632,Status of GPS antenna-Status,Electrical OK,
IDE01770-MAS01808,Status of GPS antenna-Antenna current,25, mA
IDE01868-MAS00839,Ring break diagnostic result-TV Tuner,Not available,
IDE01868-MAS00840,Ring break diagnostic result-Media Player: Position 1,Not available,
IDE01868-MAS00844,Ring break diagnostic result-Radio,Not available,
IDE01868-MAS00847,Ring break diagnostic result-Digital Sound System Control Module,Not available,
IDE01868-MAS00849,Ring break diagnostic result-Information electronics control module 1,System OK,
IDE01868-MAS00850,Ring break diagnostic result-Information electronics control module 2,Not available,
IDE01868-MAS02840,Ring break diagnostic result-Instrument cluster display,Not available,
IDE01868-MAS14306,Ring break diagnostic result-Windshield projection head up display control module,Not available,
IDE01868-ENG117473,Ring break diagnostic result-MOST_Component_10,Not available,
IDE01868-ENG117474,Ring break diagnostic result-MOST_Component_11,Not available,
IDE01868-ENG117475,Ring break diagnostic result-MOST_Component_12,Not available,
IDE01868-ENG117476,Ring break diagnostic result-MOST_Component_13,Not available,
IDE01868-ENG117477,Ring break diagnostic result-MOST_Component_14,Not available,
IDE01868-ENG117478,Ring break diagnostic result-MOST_Component_15,Not available,
IDE01868-ENG117479,Ring break diagnostic result-MOST_Component_16,Not available,
IDE01868-ENG117480,Ring break diagnostic result-MOST_Component_17,Not available,
IDE01868-ENG117481,Ring break diagnostic result-MOST_Component_18,Not available,
IDE01868-ENG117482,Ring break diagnostic result-MOST_Component_19,Not available,
IDE01868-ENG117483,Ring break diagnostic result-MOST_Component_20,Not available,
IDE01868-ENG117472,Ring break diagnostic result-MOST_Component_9,Not available,
IDE01992-ENG16230,Installation list: current installations-ECU present Bit 0,not installed,
IDE01992-ENG20557,Installation list: current installations-ECU present Bit 0 Main_Unit,installed,
IDE01992-ENG45410,Installation list: current installations-ECU present Bit 1,not installed,
IDE01992-ENG20556,Installation list: current installations-ECU present Bit 1 reserved,not installed,
IDE01992-ENG20933,Installation list: current installations-ECU present Bit 10 SmartControlCarrier2,not installed,
IDE01992-ENG20932,Installation list: current installations-ECU present Bit 11 WirelessCharger1,not installed,
IDE01992-ENG20931,Installation list: current installations-ECU present Bit 12 WirelessCharger2,not installed,
IDE01992-ENG20930,Installation list: current installations-ECU present Bit 13 Multimedia Operating Unit,not installed,
IDE01992-ENG20929,Installation list: current installations-ECU present Bit 14 Head-up Display,not installed,
IDE01992-ENG20950,Installation list: current installations-ECU present Bit 15,not installed,
IDE01992-ENG45396,Installation list: current installations-ECU present Bit 2,not installed,
IDE01992-ENG20555,Installation list: current installations-ECU present Bit 2 Sound_System,installed,
IDE01992-ENG45402,Installation list: current installations-ECU present Bit 3,not installed,
IDE01992-ENG20554,Installation list: current installations-ECU present Bit 3 TV_Tuner,not installed,
IDE01992-ENG45430,Installation list: current installations-ECU present Bit 4,not installed,
IDE01992-ENG20553,Installation list: current installations-ECU present Bit 4 DVD_Changer,not installed,
IDE01992-ENG45377,Installation list: current installations-ECU present Bit 5,not installed,
IDE01992-ENG20552,Installation list: current installations-ECU present Bit 5 RearSeatEntertainment,not installed,
IDE01992-ENG21674,Installation list: current installations-ECU present Bit 6,not installed,
IDE01992-ENG20919,Installation list: current installations-ECU present Bit 6 MOST Kombi-Display,installed,
IDE01992-ENG16217,Installation list: current installations-ECU present Bit 7,not installed,
IDE01992-ENG20918,Installation list: current installations-ECU present Bit 7 SmartDisplayCarrier1,not installed,
IDE01992-ENG20935,Installation list: current installations-ECU present Bit 8 SmartDisplayCarrier2,not installed,
IDE01992-ENG20934,Installation list: current installations-ECU present Bit 9 SmartControlCarrier1,not installed,
IDE01995-ENG16990,Control module protocol information-Ethernet,No,
IDE01995-ENG16987,Control module protocol information-ISO-TP,Yes,
IDE01995-ENG16989,Control module protocol information-K Line,No,
IDE01995-ENG16988,Control module protocol information-TP 1.6,No,
IDE01995-ENG16991,Control module protocol information-TP 2.0,No,
IDE02326-ENG117459,GPS signal strength-ID_GPS_satellite_no_1,25,
IDE02326-ENG117461,GPS signal strength-ID_GPS_satellite_no_2,5,
IDE02326-ENG117463,GPS signal strength-ID_GPS_satellite_no_3,12,
IDE02326-ENG117465,GPS signal strength-ID_GPS_satellite_no_4,29,
IDE02326-ENG117460,GPS signal strength-S/N_GPS_satellite_no_1,37, dBµV
IDE02326-ENG117462,GPS signal strength-S/N_GPS_satellite_no_2,35, dBµV
IDE02326-ENG117464,GPS signal strength-S/N_GPS_satellite_no_3,34, dBµV
IDE02326-ENG117466,GPS signal strength-S/N_GPS_satellite_no_4,33, dBµV
IDE02384-ENG16210,Status of event memory-ECU Dtc Bit 0,OK,
IDE02384-ENG20563,Status of event memory-ECU Dtc Bit 0 Main_Unit,ERROR,
IDE02384-ENG45352,Status of event memory-ECU Dtc Bit 1,OK,
IDE02384-ENG20562,Status of event memory-ECU Dtc Bit 1 reserved,OK,
IDE02384-ENG20924,Status of event memory-ECU Dtc Bit 10 SmartControlCarrier2,OK,
IDE02384-ENG20923,Status of event memory-ECU Dtc Bit 11 WirelessCharger1,OK,
IDE02384-ENG20922,Status of event memory-ECU Dtc Bit 12 WirelessCharger2,OK,
IDE02384-ENG20921,Status of event memory-ECU Dtc Bit 13 Multimedia Operating Unit,OK,
IDE02384-ENG20920,Status of event memory-ECU Dtc Bit 14 Head-up Display,OK,
IDE02384-ENG20949,Status of event memory-ECU Dtc Bit 15,OK,
IDE02384-ENG45386,Status of event memory-ECU Dtc Bit 2,OK,
IDE02384-ENG20561,Status of event memory-ECU Dtc Bit 2 Sound_System,OK,
IDE02384-ENG45404,Status of event memory-ECU Dtc Bit 3,OK,
IDE02384-ENG20560,Status of event memory-ECU Dtc Bit 3 TV_Tuner,OK,
IDE02384-ENG45387,Status of event memory-ECU Dtc Bit 4,OK,
IDE02384-ENG20559,Status of event memory-ECU Dtc Bit 4 DVD_Changer,OK,
IDE02384-ENG45440,Status of event memory-ECU Dtc Bit 5,OK,
IDE02384-ENG20558,Status of event memory-ECU Dtc Bit 5 Rear_Seat_Entertainment,OK,
IDE02384-ENG21671,Status of event memory-ECU Dtc Bit 6,OK,
IDE02384-ENG20945,Status of event memory-ECU Dtc Bit 6 MOST Kombi-Display,ERROR,
IDE02384-ENG16227,Status of event memory-ECU Dtc Bit 7,OK,
IDE02384-ENG20944,Status of event memory-ECU Dtc Bit 7 SmartDisplayCarrier1,OK,
IDE02384-ENG20926,Status of event memory-ECU Dtc Bit 8 SmartDisplayCarrier2,OK,
IDE02384-ENG20925,Status of event memory-ECU Dtc Bit 9 SmartControlCarrier1,OK,
IDE02508-MAS03001,Bluetooth: Visibility-Mode,Bluetooth not visible: connection possible,
IDE02766,Malfunction status,FF FB,
IDE03150-ENG16256,Readiness for bus sleep mode-Sleep Bit 0,Sleep mode,
IDE03150-ENG20569,Readiness for bus sleep mode-Sleep Bit 0 Main_Unit,End busstat,
IDE03150-ENG45492,Readiness for bus sleep mode-Sleep Bit 1,Sleep mode,
IDE03150-ENG20568,Readiness for bus sleep mode-Sleep Bit 1 reserved,Sleep mode,
IDE03150-ENG20941,Readiness for bus sleep mode-Sleep Bit 10 SmartControlCarrier2,Sleep mode,
IDE03150-ENG20940,Readiness for bus sleep mode-Sleep Bit 11 WirelessCharger1,Sleep mode,
IDE03150-ENG20939,Readiness for bus sleep mode-Sleep Bit 12 WirelessCharger2,Sleep mode,
IDE03150-ENG20938,Readiness for bus sleep mode-Sleep Bit 13 Bedienteil vorne,Sleep mode,
IDE03150-ENG20937,Readiness for bus sleep mode-Sleep Bit 14 Head-up Display,Sleep mode,
IDE03150-ENG20936,Readiness for bus sleep mode-Sleep Bit 15,Sleep mode,
IDE03150-ENG45491,Readiness for bus sleep mode-Sleep Bit 2,Sleep mode,
IDE03150-ENG20567,Readiness for bus sleep mode-Sleep Bit 2 Sound_System,End busstat,
IDE03150-ENG45490,Readiness for bus sleep mode-Sleep Bit 3,Sleep mode,
IDE03150-ENG20566,Readiness for bus sleep mode-Sleep Bit 3 TV_Tuner,Sleep mode,
IDE03150-ENG45489,Readiness for bus sleep mode-Sleep Bit 4,Sleep mode,
IDE03150-ENG20565,Readiness for bus sleep mode-Sleep Bit 4 DVD_Changer,Sleep mode,
IDE03150-ENG45488,Readiness for bus sleep mode-Sleep Bit 5,Sleep mode,
IDE03150-ENG20564,Readiness for bus sleep mode-Sleep Bit 5 RearSeatEntertainment,Sleep mode,
IDE03150-ENG21675,Readiness for bus sleep mode-Sleep Bit 6,Sleep mode,
IDE03150-ENG20928,Readiness for bus sleep mode-Sleep Bit 6 MOST Kombi-Display,End busstat,
IDE03150-ENG16255,Readiness for bus sleep mode-Sleep Bit 7,Sleep mode,
IDE03150-ENG20927,Readiness for bus sleep mode-Sleep Bit 7 SmartDisplayCarrier1,Sleep mode,
IDE03150-ENG20943,Readiness for bus sleep mode-Sleep Bit 8 SmartDisplayCarrier2,Sleep mode,
IDE03150-ENG20942,Readiness for bus sleep mode-Sleep Bit 9 SmartControlCarrier1,Sleep mode,
IDE03151-ENG20551,TP CAN identifier-ECU TP-CAN-Identifier-Request Bit 0,1907,
IDE03151-ENG20550,TP CAN identifier-ECU TP-CAN-Identifier-Response Bit 0,2013,
IDE03477-MAS00106,GPS time-Year,2019,
IDE03477-MAS00107,GPS time-Month,3,
IDE03477-MAS00108,GPS time-Day,19,
IDE03477-MAS00109,GPS time-Hours,3,
IDE03477-MAS00110,GPS time-Minutes,45,
IDE03477-MAS00111,GPS time-Seconds,16,
IDE03477-MAS01632,GPS time-Status,valid,
IDE03610-MAS02573,Voice operation: last detected command-Reception quality,255, %
IDE03610-MAS03874,Voice operation: last detected command-last detected command,0,
IDE03610-MAS03875,Voice operation: last detected command-Reliability,255, %
IDE03880-MAS03119,MOST address-Functional block: diagnostic instance,5F,
IDE03880-MAS03425,MOST address-Physical address,04 00,
IDE04312-MAS00110,System run time-Minutes,1, min
IDE04317-MAS00108,Total system run time-Day,24, d
IDE04317-MAS00109,Total system run time-Hours,9, H
IDE04317-MAS00110,Total system run time-Minutes,10, min
IDE04329-IDE06260,Status of all SWaP functions-ID number,00 03 00 00,
IDE04334-MAS02643,Public key for SWaP function-Key,C2 93 92 9A 21 E4 DC EB 18 D7 5C 0E 67 EF 75 08 4A CA 81 A8 8A A1 CD 26 08 6F 9F 96 D8 F8 FA 57 23 75 F8 CC AC 03 B4 32 29 83 5E E1 8C CD 2B D4 35 44 5F C3 B1 B5 E4 E7 66 80 2B 94 D4 EA 91 A0 D0 58 AD 49 5A 16 DA 8D 0F 9C 65 A1 83 35 8B 85 CC 77 97 7A DE 07 49 4C A7 F9 AB 60 20 54 F1 F2 8B 52 39 6F 6C 41 24 BF 24 89 4D E5 3F AA 8B 5B 5C 19 D2 F4 80 50 F8 3C 6B 82 87 B2 35 B9 4D 43 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 03,
IDE04343-ENG20542,Bus identification-Bus Identifier,Busmaster,
IDE04344-ENG20451,Control module assignment-ECU ID,5F,
IDE04344-ENG20480,Control module assignment-ECU Name,Information Control Unit 1,
IDE04541-MAS03778,Status of active media source at output 1-Active media source,Not available,
IDE04544,Media type in optical drive,Audio CD,
IDE04545-IDE01588,Vehicle state-Driving direction,Measured value not available,
IDE04545-IDE01714,Vehicle state-Status reverse gear,not selected,
IDE04545-IDE01766,Vehicle state-Distance impulses,0,
IDE04545-IDE03684,Vehicle state-Vehicle stopped,Yes,
IDE04546-IDE00301,Navigation calibration-Distance,0.450, mm
IDE04546-MAS03647,Navigation calibration-Calibration condition,complete,
IDE04605-MAS01779,Navigation: Corrected position-Length,075°09'25.59"W,
IDE04605-MAS01780,Navigation: Corrected position-Width,039°57'50.59"N,
IDE04607-IDE03661,Angle of turn sensor for navigation-Rotation rate,4.4, °/s
IDE04607-ENG117452,Angle of turn sensor for navigation-gyro_sensor_x_acceleration,20.08, m/s²
IDE04607-ENG117453,Angle of turn sensor for navigation-gyro_sensor_y_acceleration,20.08, m/s²
IDE04607-ENG117454,Angle of turn sensor for navigation-gyro_sensor_z_acceleration,20.08, m/s²
IDE04649-MAS01968,Activation for housing fan-Fan,OFF,
IDE04649-MAS06857,Activation for housing fan-Speed,0, /min
IDE04748,Microphone override meter,0,
IDE04768,Bluetooth device address,30 C3 D9 C6 57 37,
IDE05536-MAS01632,GPS almanac-Status,valid,
IDE05595-MAS00106,Last time GPS without satellite reception-Year,2019,
IDE05595-MAS00107,Last time GPS without satellite reception-Month,3,
IDE05595-MAS00108,Last time GPS without satellite reception-Day,19,
IDE05595-MAS00109,Last time GPS without satellite reception-Hours,3,
IDE05595-MAS00110,Last time GPS without satellite reception-Minutes,44,
IDE05595-MAS00111,Last time GPS without satellite reception-Seconds,29,
IDE05596-MAS00106,Last time GPS position outside map-Year,2000,
IDE05596-MAS00107,Last time GPS position outside map-Month,0,
IDE05596-MAS00108,Last time GPS position outside map-Day,0,
IDE05596-MAS00109,Last time GPS position outside map-Hours,0,
IDE05596-MAS00110,Last time GPS position outside map-Minutes,0,
IDE05596-MAS00111,Last time GPS position outside map-Seconds,0,
IDE05597-IDE03615,Bluetooth: Paired device 1-Version,‹Ážá
Jason Young Galaxy S8AsamsungSM-G892A--ÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿ,
IDE05597-IDE04768,Bluetooth: Paired device 1-Bluetooth device address,94 8B C1 9E E1 0D,
IDE05597-MAS01483,Bluetooth: Paired device 1-Softwareversion,‹Ážá
IDE05597-MAS02159,Bluetooth: Paired device 1-Remote SIM Access Profile (rSAP),94 8B,
IDE05597-MAS02160,Bluetooth: Paired device 1-Hands free profile (HFP),94 8B,
IDE05597-MAS03159,Bluetooth: Paired device 1-Manufacturer,‹Ážá
IDE05597-MAS04326,Bluetooth: Paired device 1-Device name,Jason Young Galaxy S8A
samsung
SM-G892A
IDE05597-ENG117431,Bluetooth: Paired device 1-A2DP,94 8B,
IDE05597-ENG117440,Bluetooth: Paired device 1-ACTIVESYNCML,94 8B,
IDE05597-ENG105233,Bluetooth: Paired device 1-AT,94 8B,
IDE05597-ENG117432,Bluetooth: Paired device 1-AVRCP,94 8B,
IDE05597-ENG117434,Bluetooth: Paired device 1-DUN,94 8B,
IDE05597-ENG106692,Bluetooth: Paired device 1-FTP,94 8B,
IDE05597-ENG117435,Bluetooth: Paired device 1-HIDP,94 8B,
IDE05597-ENG117429,Bluetooth: Paired device 1-HSP,94 8B,
IDE05597-ENG117437,Bluetooth: Paired device 1-IRMC,94 8B,
IDE05597-ENG101499,Bluetooth: Paired device 1-map,94 8B,
IDE05597-ENG117436,Bluetooth: Paired device 1-OBEX,94 8B,
IDE05597-ENG117439,Bluetooth: Paired device 1-OPP,94 8B,
IDE05597-ENG117433,Bluetooth: Paired device 1-PAN,94 8B,
IDE05597-ENG108174,Bluetooth: Paired device 1-PBAP,94 8B,
IDE05597-ENG117427,Bluetooth: Paired device 1-SDAP,94 8B,
IDE05597-ENG117428,Bluetooth: Paired device 1-SPP,94 8B,
IDE05597-ENG117438,Bluetooth: Paired device 1-SYNCML,94 8B,
IDE05598-IDE03615,Bluetooth: Paired device 2-Version,‹Á‚fsSAMSUNG-SM-G892AsamsungSM-G892A--ÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿ,
IDE05598-IDE04768,Bluetooth: Paired device 2-Bluetooth device address,94 8B C1 82 66 73,
IDE05598-MAS01483,Bluetooth: Paired device 2-Softwareversion,‹Á‚fsSAMSUNG-SM-G892AsamsungSM-G892A--ÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿ,
IDE05598-MAS02159,Bluetooth: Paired device 2-Remote SIM Access Profile (rSAP),94 8B,
IDE05598-MAS02160,Bluetooth: Paired device 2-Hands free profile (HFP),94 8B,
IDE05598-MAS03159,Bluetooth: Paired device 2-Manufacturer,‹Á‚fsSAMSUNG-SM-G892AsamsungSM-G892A--ÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿ,
IDE05598-MAS04326,Bluetooth: Paired device 2-Device name,SAMSUNG-SM-G892A
samsung
SM-G892A
IDE05598-ENG117431,Bluetooth: Paired device 2-A2DP,94 8B,
IDE05598-ENG117440,Bluetooth: Paired device 2-ACTIVESYNCML,94 8B,
IDE05598-ENG105233,Bluetooth: Paired device 2-AT,94 8B,
IDE05598-ENG117432,Bluetooth: Paired device 2-AVRCP,94 8B,
IDE05598-ENG117434,Bluetooth: Paired device 2-DUN,94 8B,
IDE05598-ENG106692,Bluetooth: Paired device 2-FTP,94 8B,
IDE05598-ENG117435,Bluetooth: Paired device 2-HIDP,94 8B,
IDE05598-ENG117429,Bluetooth: Paired device 2-HSP,94 8B,
IDE05598-ENG117437,Bluetooth: Paired device 2-IRMC,94 8B,
IDE05598-ENG101499,Bluetooth: Paired device 2-map,94 8B,
IDE05598-ENG117436,Bluetooth: Paired device 2-OBEX,94 8B,
IDE05598-ENG117439,Bluetooth: Paired device 2-OPP,94 8B,
IDE05598-ENG117433,Bluetooth: Paired device 2-PAN,94 8B,
IDE05598-ENG108174,Bluetooth: Paired device 2-PBAP,94 8B,
IDE05598-ENG117427,Bluetooth: Paired device 2-SDAP,94 8B,
IDE05598-ENG117428,Bluetooth: Paired device 2-SPP,94 8B,
IDE05598-ENG117438,Bluetooth: Paired device 2-SYNCML,94 8B,
IDE05599-IDE03615,Bluetooth: Paired device 3-Version,--
IDE05599-IDE04768,Bluetooth: Paired device 3-Bluetooth device address,00 00 00 00 00 00,
IDE05599-MAS01483,Bluetooth: Paired device 3-Softwareversion,--
IDE05599-MAS02159,Bluetooth: Paired device 3-Remote SIM Access Profile (rSAP),00 00,
IDE05599-MAS02160,Bluetooth: Paired device 3-Hands free profile (HFP),00 00,
IDE05599-MAS03159,Bluetooth: Paired device 3-Manufacturer,--
IDE05599-MAS04326,Bluetooth: Paired device 3-Device name,--
IDE05599-ENG117431,Bluetooth: Paired device 3-A2DP,00 00,
IDE05599-ENG117440,Bluetooth: Paired device 3-ACTIVESYNCML,00 00,
IDE05599-ENG105233,Bluetooth: Paired device 3-AT,00 00,
IDE05599-ENG117432,Bluetooth: Paired device 3-AVRCP,00 00,
IDE05599-ENG117434,Bluetooth: Paired device 3-DUN,00 00,
IDE05599-ENG106692,Bluetooth: Paired device 3-FTP,00 00,
IDE05599-ENG117435,Bluetooth: Paired device 3-HIDP,00 00,
IDE05599-ENG117429,Bluetooth: Paired device 3-HSP,00 00,
IDE05599-ENG117437,Bluetooth: Paired device 3-IRMC,00 00,
IDE05599-ENG101499,Bluetooth: Paired device 3-map,00 00,
IDE05599-ENG117436,Bluetooth: Paired device 3-OBEX,00 00,
IDE05599-ENG117439,Bluetooth: Paired device 3-OPP,00 00,
IDE05599-ENG117433,Bluetooth: Paired device 3-PAN,00 00,
IDE05599-ENG108174,Bluetooth: Paired device 3-PBAP,00 00,
IDE05599-ENG117427,Bluetooth: Paired device 3-SDAP,00 00,
IDE05599-ENG117428,Bluetooth: Paired device 3-SPP,00 00,
IDE05599-ENG117438,Bluetooth: Paired device 3-SYNCML,00 00,
IDE05600-IDE03615,Bluetooth: Paired device 4-Version,--
IDE05600-IDE04768,Bluetooth: Paired device 4-Bluetooth device address,00 00 00 00 00 00,
IDE05600-MAS01483,Bluetooth: Paired device 4-Softwareversion,--
IDE05600-MAS02159,Bluetooth: Paired device 4-Remote SIM Access Profile (rSAP),00 00,
IDE05600-MAS02160,Bluetooth: Paired device 4-Hands free profile (HFP),00 00,
IDE05600-MAS03159,Bluetooth: Paired device 4-Manufacturer,--
IDE05600-ENG117431,Bluetooth: Paired device 4-A2DP,00 00,
IDE05600-ENG117440,Bluetooth: Paired device 4-ACTIVESYNCML,00 00,
IDE05600-ENG105233,Bluetooth: Paired device 4-AT,00 00,
IDE05600-ENG117432,Bluetooth: Paired device 4-AVRCP,00 00,
IDE05600-ENG117434,Bluetooth: Paired device 4-DUN,00 00,
IDE05600-ENG106692,Bluetooth: Paired device 4-FTP,00 00,
IDE05600-ENG117435,Bluetooth: Paired device 4-HIDP,00 00,
IDE05600-ENG117429,Bluetooth: Paired device 4-HSP,00 00,
IDE05600-ENG117437,Bluetooth: Paired device 4-IRMC,00 00,
IDE05600-ENG101499,Bluetooth: Paired device 4-map,00 00,
IDE05600-ENG117436,Bluetooth: Paired device 4-OBEX,00 00,
IDE05600-ENG117439,Bluetooth: Paired device 4-OPP,00 00,
IDE05600-ENG117433,Bluetooth: Paired device 4-PAN,00 00,
IDE05600-ENG108174,Bluetooth: Paired device 4-PBAP,00 00,
IDE05600-ENG117427,Bluetooth: Paired device 4-SDAP,00 00,
IDE05600-ENG117428,Bluetooth: Paired device 4-SPP,00 00,
IDE05600-ENG117438,Bluetooth: Paired device 4-SYNCML,00 00,
IDE05601-IDE03615,Bluetooth: Paired device 5-Version,--
IDE05601-IDE04768,Bluetooth: Paired device 5-Bluetooth device address,00 00 00 00 00 00,
IDE05601-MAS01483,Bluetooth: Paired device 5-Softwareversion,--
IDE05601-MAS02159,Bluetooth: Paired device 5-Remote SIM Access Profile (rSAP),00 00,
IDE05601-MAS02160,Bluetooth: Paired device 5-Hands free profile (HFP),00 00,
IDE05601-MAS03159,Bluetooth: Paired device 5-Manufacturer,--
IDE05601-ENG117431,Bluetooth: Paired device 5-A2DP,00 00,
IDE05601-ENG117440,Bluetooth: Paired device 5-ACTIVESYNCML,00 00,
IDE05601-ENG105233,Bluetooth: Paired device 5-AT,00 00,
IDE05601-ENG117432,Bluetooth: Paired device 5-AVRCP,00 00,
IDE05601-ENG117434,Bluetooth: Paired device 5-DUN,00 00,
IDE05601-ENG106692,Bluetooth: Paired device 5-FTP,00 00,
IDE05601-ENG117435,Bluetooth: Paired device 5-HIDP,00 00,
IDE05601-ENG117429,Bluetooth: Paired device 5-HSP,00 00,
IDE05601-ENG117437,Bluetooth: Paired device 5-IRMC,00 00,
IDE05601-ENG101499,Bluetooth: Paired device 5-map,00 00,
IDE05601-ENG117436,Bluetooth: Paired device 5-OBEX,00 00,
IDE05601-ENG117439,Bluetooth: Paired device 5-OPP,00 00,
IDE05601-ENG117433,Bluetooth: Paired device 5-PAN,00 00,
IDE05601-ENG108174,Bluetooth: Paired device 5-PBAP,00 00,
IDE05601-ENG117427,Bluetooth: Paired device 5-SDAP,00 00,
IDE05601-ENG117428,Bluetooth: Paired device 5-SPP,00 00,
IDE05601-ENG117438,Bluetooth: Paired device 5-SYNCML,00 00,
IDE05602-MAS01763,Bluetooth: connected device 1-Signal Strength,-7,
IDE05602-MAS04326,Bluetooth: connected device 1-Device name,20936296695210073,
IDE05700-MAS01632,USB connection-Status,OK,
IDE05726,Terminal 58xd dimmer,3.95, %
IDE05814,Individualization characteristic,E1 20 CE BF 3C,
IDE06028-MAS04151,Control head button operation-Joystick,00,
IDE09563-MAS09154,Proximity detection for touchscreen 1-Proximity sensor 1,Object in sector,
IDE10843-MAS01482,Function module: identification-Hardwareversion,1,
IDE10843-MAS04326,Function module: identification-Device name,AP_FLASH,
IDE10843-MAS11354,Function module: identification-Bootloader version,60,
IDE10843-MAS11355,Function module: identification-Application version,0,
IDE10843-MAS11356,Function module: identification-Module Name,IPL,
IDE11034-MAS01482,Satellite radio: module information-Hardwareversion,01-00-01---,
IDE11034-MAS11961,Satellite radio: module information-Serial number,6TMMHAH1,
IDE11034-MAS11962,Satellite radio: module information-Pre-activation key,8E D0 08 00 36 54 4D 4D 48 41 48 31 00 02 98 07 8A 38 64 68 F5 31 71 89 46 FF 18 07 39 84 73 F9 D5 A5 15 5C 65 DF 00 08 00 66 03 41 00 09 00 66 00 07,
IDE11034-MAS11963,Satellite radio: module information-Firmware version,0b-26-00---,
IDE11034-MAS11964,Satellite radio: module information-Satellite Module Services Version,02-04-04---,
IDE11034-MAS11965,Satellite radio: module information-SiriusXM Interconnect Version,03-05-00---,
IDE11034-MAS11966,Satellite radio: module information-Database Version,02-04-04--A,
IDE11504-ENG127677,Satellite radio tuner: pre-activated subscription-SDARS_preactivation_coding status,Yes,
MAS00464-MAS00109,Standard - ambient data 1-Hours,23,
MAS00464-MAS00110,Standard - ambient data 1-Minutes,45,
MAS00464-MAS00111,Standard - ambient data 1-Seconds,30,
MAS00464-MAS00468,Standard - ambient data 1-Unlearning counter,234,
MAS00464-MAS00711,Standard - ambient data 1-Odometer reading,27830, km
MAS00481-ENG117777,BAP-BAP_Function_ID,02,
MAS00778-IDE03619,Multimedia display unit 1-System status,On,
MAS00778-IDE05228,Multimedia display unit 1-Operating hour counter,532, H
MAS00778-MAS00110,Multimedia display unit 1-Minutes,16, min
MAS00778-MAS00362,Multimedia display unit 1-Battery voltage,11.7, V
MAS00778-MAS02200,Multimedia display unit 1-Highest measured temperature,74, °C
MAS00778-MAS02201,Multimedia display unit 1-Temperature,16, °C
MAS00778-MAS03691,Multimedia display unit 1-Dimming,100, %
MAS00951-MAS04325,Bluetooth-Bluetooth: Paired devices,2,
MAS01760-MAS01765,Radio Tuner 1-Audio Signal,Mute,
MAS01760-MAS02949,Radio Tuner 1-Frequency,102.7, MHz
MAS01760-MAS03991,Radio Tuner 1-Reception level antenna 1,18, dBµV
MAS01760-MAS04344,Radio Tuner 1-Reception level antenna 2,32, dBµV
MAS01760-MAS04345,Radio Tuner 1-Frequency (AM),65535, kHz
MAS01760-ENG117357,Radio Tuner 1-iboc_service,1,
MAS01761-MAS01763,Radio Tuner 2-Signal Strength,32, dBµV
MAS01991-IDE00010,Card reader-Serial number,19 F0 A2 DF,
MAS01991-IDE01001,Card reader-Application,AP,
MAS01991-MAS01632,Card reader-Status,connected,
MAS01991-MAS03159,Card reader-Manufacturer,09,
MAS01991-MAS03375,Card reader-Major version,2,
MAS01991-MAS03376,Card reader-Minor version,0,
MAS01991-MAS03959,Card reader-Write-protection,activated,
MAS01991-MAS04388,Card reader-Card type,MIBST,
MAS01991-MAS13476,Card reader-Manufacturing date: month,10, mon
MAS01991-MAS13477,Card reader-Manufacturing date: year,2017, yr
MAS03121,Ring break diagnostic line status,Supply voltage,
MAS03780-IDE00010,Card reader 2-Serial number,25 54 B2 8E,
MAS03780-IDE01001,Card reader 2-Application,SD,
MAS03780-MAS01632,Card reader 2-Status,connected,
MAS03780-MAS03159,Card reader 2-Manufacturer,03,
MAS03780-MAS03375,Card reader 2-Major version,0,
MAS03780-MAS03376,Card reader 2-Minor version,8,
MAS03780-MAS03959,Card reader 2-Write-protection,not activated,
MAS03780-MAS04388,Card reader 2-Card type,SL16G,
MAS03780-MAS13476,Card reader 2-Manufacturing date: month,4, mon
MAS03780-MAS13477,Card reader 2-Manufacturing date: year,2014, yr
MAS04324-MAS04326,Bluetooth: connected devices-Device name,20936296695210073,
MAS04325-MAS04326,Bluetooth: Paired devices-Device name,20936296695210073,
ENG117867-ENG117773,GPS_Count_Satellite_Phase_Lock_Counter-satellites,6,
ENG117868-ENG117773,GPS_Satellite_Code_Lock_Counter-satellites,9,
ENG117857-MAS00110,Last_System_Operating_Time-Minutes,0, min
ENG117869-ENG117441,Nav._Calculated_Direction-driving direction corrected,101, °
ENG117869-ENG98933,Nav._Calculated_Direction-Status,OK,
ENG122217-ENG122284,SDARS_service-audio_service,subscribed,
ENG122217-ENG122285,SDARS_service-traffic_service,subscribed,
ENG122217-ENG122286,SDARS_service-travel_link_service,subscribed,
ENG122216-MAS00106,SDARS_subscription_status-Year,2034,
ENG122216-MAS00107,SDARS_subscription_status-Month,1,
ENG122216-MAS00108,SDARS_subscription_status-Day,1,
ENG122216-MAS00109,SDARS_subscription_status-Hours,31,
ENG122216-MAS00110,SDARS_subscription_status-Minutes,63,
ENG122216-MAS00111,SDARS_subscription_status-Seconds,63,
ENG122216-ENG122279,SDARS_subscription_status-SDARS_subscription,subscribed,
ENG122216-ENG125804,SDARS_subscription_status-SDARS_suspend_alert,0,
ENG122216-ENG122280,SDARS_subscription_status-SDARS_suspension,not_suspended,
ENG127487-IDE02451,SDARS_tuner_status_2-Satellite radio antenna status,Electrical OK,
ENG127487-IDE02453,SDARS_tuner_status_2-Channel selection for satellite radio,10,
ENG127487-MAS01765,SDARS_tuner_status_2-Audio Signal,Available,
ENG127487-MAS01808,SDARS_tuner_status_2-Antenna current,106, mA
ENG127487-MAS02573,SDARS_tuner_status_2-Reception quality,optimum_signal,
ENG127487-MAS13343,SDARS_tuner_status_2-Satellite radio tuner: pre-activation status,07,
ENG127487-MAS13344,SDARS_tuner_status_2-Satellite radio tuner: pre-activation value,07,
ENG117864-ENG117396,Status_Position_Touchscreen_1-position_x1,17152,
ENG117864-ENG117399,Status_Position_Touchscreen_1-position_y1,47105,
ENG117858-MAS01424,System_Temperature_Sensor_2-max.value,80, °C
ENG117858-MAS01425,System_Temperature_Sensor_2-min.value,-2, °C
ENG117858-MAS02238,System_Temperature_Sensor_2-Current,26, °C
ENG117860-MAS01424,System_Temperature_Sensor_4-max.value,68, °C
ENG117860-MAS01425,System_Temperature_Sensor_4-min.value,-7, °C
ENG117860-MAS02238,System_Temperature_Sensor_4-Current,18, °C
ENG117862-MAS01424,System_Temperature_Sensor_6-max.value,73, °C
ENG117862-MAS01425,System_Temperature_Sensor_6-min.value,-2, °C
ENG117862-MAS02238,System_Temperature_Sensor_6-Current,25, °C
Elapsed Time: 00:25
;Monday,18,March,2019,23:45:37:21122
IDE00346-Summertime-automatic,USA ,1
IDE00758-Base volume of telephone,50 %,1
IDE00769-Number 1 for Info call,FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF ,23
IDE00770-Number 1 for roadside assistance,FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF ,23
IDE00845-Wheel circ.,0 mm,2
IDE01996-MAS00076-Installation list: specified installations-Instrument cluster control module,Yes ,3
IDE01996-MAS00839-Installation list: specified installations-TV Tuner,No ,3
IDE01996-MAS00844-Installation list: specified installations-Radio,No ,3
IDE01996-MAS00847-Installation list: specified installations-Digital Sound System Control Module,Yes ,3
IDE01996-MAS00849-Installation list: specified installations-Information electronics control module 1,Yes ,3
IDE01996-MAS00850-Installation list: specified installations-Information electronics control module 2,No ,3
IDE01996-MAS04300-Installation list: specified installations-DVD changer,No ,3
IDE01996-MAS14306-Installation list: specified installations-Windshield projection head up display control module,No ,3
IDE01996-SFT271943-Installation list: specified installations-Multimedia Operating Unit,No ,3
IDE01996-ENG154341-Installation list: specified installations-Reserved_8,No ,3
IDE01996-ENG152491-Installation list: specified installations-Smart Control Carrier 1,No ,3
IDE01996-ENG152490-Installation list: specified installations-Smart Control Carrier 2,No ,3
IDE01996-ENG152488-Installation list: specified installations-Smart Display Carrier 1,No ,3
IDE01996-ENG152492-Installation list: specified installations-Smart Display Carrier 2,No ,3
IDE01996-ENG152493-Installation list: specified installations-Wireless Charger 1,Yes ,3
IDE01996-ENG152489-Installation list: specified installations-Wireless Charger 2,No ,3
IDE02330-Number 2 for Info call,FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF ,23
IDE02331-Number 2 for roadside assistance,FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF ,23
IDE02476-ENG117361-Electrical test of loudspeakers-Parameter_AC-Diagnostics_Channel_1_Test_Volume,27 ,49
IDE02476-ENG117379-Electrical test of loudspeakers-Parameter_AC-Diagnostics_Channel_10_Test_Volume,27 ,49
IDE02476-ENG117381-Electrical test of loudspeakers-Parameter_AC-Diagnostics_Channel_11_Test_Volume,27 ,49
IDE02476-ENG117383-Electrical test of loudspeakers-Parameter_AC-Diagnostics_Channel_12_Test_Volume,27 ,49
IDE02476-ENG117385-Electrical test of loudspeakers-Parameter_AC-Diagnostics_Channel_13_Test_Volume,27 ,49
IDE02476-ENG117387-Electrical test of loudspeakers-Parameter_AC-Diagnostics_Channel_14_Test_Volume,27 ,49
IDE02476-ENG117389-Electrical test of loudspeakers-Parameter_AC-Diagnostics_Channel_15_Test_Volume,27 ,49
IDE02476-ENG117391-Electrical test of loudspeakers-Parameter_AC-Diagnostics_Channel_16_Test_Volume,27 ,49
IDE02476-ENG117363-Electrical test of loudspeakers-Parameter_AC-Diagnostics_Channel_2_Test_Volume,27 ,49
IDE02476-ENG117365-Electrical test of loudspeakers-Parameter_AC-Diagnostics_Channel_3_Test_Volume,27 ,49
IDE02476-ENG117367-Electrical test of loudspeakers-Parameter_AC-Diagnostics_Channel_4_Test_Volume,27 ,49
IDE02476-ENG117369-Electrical test of loudspeakers-Parameter_AC-Diagnostics_Channel_5_Test_Volume,27 ,49
IDE02476-ENG117371-Electrical test of loudspeakers-Parameter_AC-Diagnostics_Channel_6_Test_Volume,27 ,49
IDE02476-ENG117373-Electrical test of loudspeakers-Parameter_AC-Diagnostics_Channel_7_Test_Volume,27 ,49
IDE02476-ENG117375-Electrical test of loudspeakers-Parameter_AC-Diagnostics_Channel_8_Test_Volume,27 ,49
IDE02476-ENG117377-Electrical test of loudspeakers-Parameter_AC-Diagnostics_Channel_9_Test_Volume,27 ,49
IDE02502-Confirmation of installation change,36 2D ,2
IDE02607-Wheel pulse,0 ,2
IDE02699-Number 1 for roadside assistance,FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF ,23
IDE02701-Number 1 (roaming) for roadside assistance,FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF ,23
IDE03471-ENG249824-Vehicle configuration-AliBox,OFF ,30
IDE03471-ENG142146-Vehicle configuration-allow_message_editing,OFF ,30
IDE03471-ENG130249-Vehicle configuration-Apple_DIO,On ,30
IDE03471-ENG185764-Vehicle configuration-Apple_DIO_Wireless,OFF ,30
IDE03471-ENG152525-Vehicle configuration-Baidu_Car_Life,OFF ,30
IDE03471-ENG152559-Vehicle configuration-Baidu_Car_Life_ios,OFF ,30
IDE03471-ENG185765-Vehicle configuration-Baidu_Car_Life_ios_Wireless,OFF ,30
IDE03471-ENG185766-Vehicle configuration-Baidu_Car_Life_Wireless,OFF ,30
IDE03471-ENG152560-Vehicle configuration-block_hmi_function_p_epb,blocked ,30
IDE03471-ENG142151-Vehicle configuration-conditioning_variant,0 ,30
IDE03471-ENG142145-Vehicle configuration-esim_data_only_sms_support,OFF ,30
IDE03471-ENG185778-Vehicle configuration-FoD,SWaP ,30
IDE03471-ENG130248-Vehicle configuration-Google_GAL,On ,30
IDE03471-ENG185779-Vehicle configuration-Google_GAL_Wireless,OFF ,30
IDE03471-ENG117850-Vehicle configuration-gracenote_local_coverarts,OFF ,30
IDE03471-ENG117851-Vehicle configuration-gracenote_local_other,OFF ,30
IDE03471-ENG117848-Vehicle configuration-gracenote_online_coverarts,On ,30
IDE03471-ENG117849-Vehicle configuration-gracenote_online_other,On ,30
IDE03471-ENG152533-Vehicle configuration-Hybrid_Radio_additional_online_data,not activated ,30
IDE03471-ENG152534-Vehicle configuration-Hybrid_Radio_Range_Extender,Deactivated ,30
IDE03471-ENG142142-Vehicle configuration-map_email_support,OFF ,30
IDE03471-ENG142143-Vehicle configuration-map_instant_messaging_support,OFF ,30
IDE03471-ENG142141-Vehicle configuration-map_sms_support,OFF ,30
IDE03471-ENG142152-Vehicle configuration-Map_Style,0 ,30
IDE03471-ENG152537-Vehicle configuration-media_control,not activated ,30
IDE03471-ENG138662-Vehicle configuration-Mirror_link,On ,30
IDE03471-ENG142148-Vehicle configuration-MirrorLink_Country_Code,MIB_NAR ,30
IDE03471-ENG142150-Vehicle configuration-MirrorLink_RGB_Preference,RGB565 ,30
IDE03471-ENG117843-Vehicle configuration-my_audi,On ,30
IDE03471-ENG117845-Vehicle configuration-online_dictation,On ,30
IDE03471-ENG127495-Vehicle configuration-online_media,On ,30
IDE03471-ENG117840-Vehicle configuration-online_navigation,On ,30
IDE03471-ENG117837-Vehicle configuration-online_POI,On ,30
IDE03471-ENG117838-Vehicle configuration-online_POI_voice,On ,30
IDE03471-ENG117839-Vehicle configuration-online_portal_browser_services,On ,30
IDE03471-ENG152553-Vehicle configuration-online_radio,native_hmi_and_hmisdk ,30
IDE03471-ENG117841-Vehicle configuration-online_street_view,On ,30
IDE03471-ENG167521-Vehicle configuration-perso_v_threshold,00 ,30
IDE03471-ENG167522-Vehicle configuration-perso_v_threshold_hysteresis,00 ,30
IDE03471-ENG152554-Vehicle configuration-Phone_HMI_Privacy,0 ,30
IDE03471-ENG125046-Vehicle configuration-Phone_module_operation_mode,Data & language service active ,30
IDE03471-ENG117844-Vehicle configuration-picture_navi,On ,30
IDE03471-ENG167523-Vehicle configuration-Pilot_Parking,not activated ,30
IDE03471-ENG167525-Vehicle configuration-Popup_if_GPS_services_in_use,not activated ,30
IDE03471-ENG152555-Vehicle configuration-Privacy_WithPINRequest,0 ,30
IDE03471-ENG125047-Vehicle configuration-PSD_Protocol_Version,PSD_1.5 ,30
IDE03471-ENG117846-Vehicle configuration-remote_HMI,OFF ,30
IDE03471-ENG138661-Vehicle configuration-RSE_software_component,activated ,30
IDE03471-ENG245031-Vehicle configuration-rvc_low_black_screen_trunk_open,not activated ,30
IDE03471-ENG244966-Vehicle configuration-rvc_low_black_screen_velocity_threshold,not activated ,30
IDE03471-ENG245015-Vehicle configuration-rvc_low_failsafe,not activated ,30
IDE03471-ENG152556-Vehicle configuration-scon_telephony,not activated ,30
IDE03471-ENG138660-Vehicle configuration-SDS_Region_Flag,no_region ,30
IDE03471-ENG152557-Vehicle configuration-show_volte_hmi_switch,not activated ,30
IDE03471-ENG142144-Vehicle configuration-sim_data_only_sms_support,OFF ,30
IDE03471-ENG126993-Vehicle configuration-Station_Logo_DB_Mode,0 ,30
IDE03471-ENG125042-Vehicle configuration-Support_of_threeway_calling,On ,30
IDE03471-ENG130247-Vehicle configuration-Support_second_phone,On ,30
IDE03471-ENG167531-Vehicle configuration-Tencent_myCar_canceling_share_location,OFF ,30
IDE03471-ENG152571-Vehicle configuration-unblock_functions_while_piloted_driving,Enabled ,30
IDE03471-ENG167532-Vehicle configuration-UOTA_2,OFF ,30
IDE03471-ENG117852-Vehicle configuration-UPnP,OFF ,30
IDE03471-ENG142149-Vehicle configuration-vehicle_leaving_sound,activated ,30
IDE03471-ENG142147-Vehicle configuration-vehicle_readiness_sound,activated ,30
IDE03471-ENG152558-Vehicle configuration-voice_over_lte,not activated ,30
IDE03471-ENG117836-Vehicle configuration-VZAPro,On ,30
IDE03471-ENG137648-Vehicle configuration-WiFi_Client_HMI,On ,30
IDE03471-ENG117842-Vehicle configuration-WIFI_Hotspot,On ,30
IDE03471-ENG152572-Vehicle configuration-wlan_5ghz_switch,not activated ,30
IDE05111-Fee-based traffic information (TMC),1537 ,2
IDE08814-IDE04033-Navigation receiver GNSS configuration-Compass,OFF ,1
IDE08814-MAS01570-Navigation receiver GNSS configuration-Default,On ,1
IDE08814-MAS02614-Navigation receiver GNSS configuration-GPS,OFF ,1
IDE08814-MAS07828-Navigation receiver GNSS configuration-Galileo,OFF ,1
IDE08814-MAS07829-Navigation receiver GNSS configuration-Glonass,OFF ,1
IDE08814-ENG142047-Navigation receiver GNSS configuration-external_gps_1,OFF ,1
IDE08814-ENG142048-Navigation receiver GNSS configuration-external_gps_2,OFF ,1
IDE10221-MAS00846-Audio Management Input Gain Generation 2-Satellite radio,5 ,40
IDE10221-ENG125860-Audio Management Input Gain Generation 2-Phone_Ringer_OB,-3 ,40
IDE10221-ENG125852-Audio Management Input Gain Generation 2-Tone_Touchscreen,6 ,40
IDE10480-MAS10742-Interface for external media: activation-Connection 2,not activated ,4
IDE10604-Menu entries for mobile online services,activated ,1
IDE11122-Country identification: country of sale HMI,US ,2
IDE11502-ENG127601-Locked menu contents-FB_CAR_0,non_blocked ,21
IDE11502-ENG127522-Locked menu contents-FB_MEDIA_1,non_blocked ,21
IDE11502-ENG127625-Locked menu contents-FB_MISC_0,non_blocked ,21
IDE11502-ENG127630-Locked menu contents-FB_MISC_5,non_blocked ,21
IDE11502-ENG127561-Locked menu contents-FB_NAV_0,non_blocked ,21
IDE11502-ENG127564-Locked menu contents-FB_NAV_3,non_blocked ,21
IDE11502-ENG127545-Locked menu contents-FB_PHONE_0,non_blocked ,21
IDE11503-Satellite radio tuner: pre-activated subscription,07 ,1
IDE11524-ENG249835-Vehicle function list BAP 2nd generation: expansion-chassis_control_0x57,not activated ,192
IDE11524-ENG249836-Vehicle function list BAP 2nd generation: expansion-chassis_control_0x57_msg_bus,not activated ,192
IDE11524-ENG142156-Vehicle function list BAP 2nd generation: expansion-climate_mastet_0x42,not activated ,192
IDE11524-ENG142157-Vehicle function list BAP 2nd generation: expansion-climate_mastet_0x42_msg_bus,not activated ,192
IDE11524-ENG142158-Vehicle function list BAP 2nd generation: expansion-connection_manager_0x47,not activated ,192
IDE11524-ENG142159-Vehicle function list BAP 2nd generation: expansion-connection_manager_0x47_msg_bus,not activated ,192
IDE11524-ENG249837-Vehicle function list BAP 2nd generation: expansion-convertibleTop_0x6C,not activated ,192
IDE11524-ENG249838-Vehicle function list BAP 2nd generation: expansion-convertibleTop_0x6C_msg_bus,not activated ,192
IDE11524-ENG152529-Vehicle function list BAP 2nd generation: expansion-daf_profile_0x51,not activated ,192
IDE11524-ENG152530-Vehicle function list BAP 2nd generation: expansion-daf_profile_0x51_msg_bus,not activated ,192
IDE11524-ENG137043-Vehicle function list BAP 2nd generation: expansion-display_configuration_0x45,not activated ,192
IDE11524-ENG137044-Vehicle function list BAP 2nd generation: expansion-display_configuration_0x45_msg_bus,not activated ,192
IDE11524-ENG185772-Vehicle function list BAP 2nd generation: expansion-engine_functions_0x5D,not activated ,192
IDE11524-ENG185773-Vehicle function list BAP 2nd generation: expansion-engine_functions_0x5D_msg_bus,not activated ,192
IDE11524-ENG142168-Vehicle function list BAP 2nd generation: expansion-fas_profile_0x4D,not activated ,192
IDE11524-ENG142169-Vehicle function list BAP 2nd generation: expansion-fas_profile_0x4D_msg_bus,not activated ,192
IDE11524-ENG142154-Vehicle function list BAP 2nd generation: expansion-front_traffic_assist_0x41,not activated ,192
IDE11524-ENG142155-Vehicle function list BAP 2nd generation: expansion-front_traffic_assist_0x41_msg_bus,not activated ,192
IDE11524-ENG152535-Vehicle function list BAP 2nd generation: expansion-infotainmentsettings_profile_0x50,not activated ,192
IDE11524-ENG152536-Vehicle function list BAP 2nd generation: expansion-infotainmentsettings_profile_0x50_msg_bus,not activated ,192
IDE11524-ENG248719-Vehicle function list BAP 2nd generation: expansion-ITM_0x65,not activated ,192
IDE11524-ENG248720-Vehicle function list BAP 2nd generation: expansion-ITM_0x65_msg_bus,not activated ,192
IDE11524-ENG249902-Vehicle function list BAP 2nd generation: expansion-lift_0x64,not activated ,192
IDE11524-ENG249903-Vehicle function list BAP 2nd generation: expansion-lift_0x64_msg_bus,not activated ,192
IDE11524-ENG185787-Vehicle function list BAP 2nd generation: expansion-mascot_0x83,not activated ,192
IDE11524-ENG185788-Vehicle function list BAP 2nd generation: expansion-mascot_0x83_msg_bus,not activated ,192
IDE11524-ENG152569-Vehicle function list BAP 2nd generation: expansion-remote_services_profile_0x4E,not activated ,192
IDE11524-ENG152570-Vehicle function list BAP 2nd generation: expansion-remote_services_profile_0x4E_msg_bus,not activated ,192
IDE11524-ENG139202-Vehicle function list BAP 2nd generation: expansion-Soundcontrol_0x44,not activated ,192
IDE11524-ENG139203-Vehicle function list BAP 2nd generation: expansion-Soundcontrol_0x44_msg_bus,not activated ,192
IDE11524-ENG127678-Vehicle function list BAP 2nd generation: expansion-spoiler_0x40,not activated ,192
IDE11524-ENG127679-Vehicle function list BAP 2nd generation: expansion-spoiler_0x40_msg_bus,not activated ,192
IDE11524-ENG142162-Vehicle function list BAP 2nd generation: expansion-statistic_0x4A,not activated ,192
IDE11524-ENG142163-Vehicle function list BAP 2nd generation: expansion-statistic_0x4A_msg_bus,not activated ,192
IDE11524-ENG142164-Vehicle function list BAP 2nd generation: expansion-sunroof_front_0x4B,not activated ,192
IDE11524-ENG142165-Vehicle function list BAP 2nd generation: expansion-sunroof_front_0x4B_msg_bus,not activated ,192
IDE11524-ENG142166-Vehicle function list BAP 2nd generation: expansion-sunroof_rear_0x4C,not activated ,192
IDE11524-ENG142167-Vehicle function list BAP 2nd generation: expansion-sunroof_rear_0x4C_msg_bus,not activated ,192
IDE11524-ENG185817-Vehicle function list BAP 2nd generation: expansion-vas_0x54,not activated ,192
IDE11524-ENG185818-Vehicle function list BAP 2nd generation: expansion-vas_0x54_msg_bus,not activated ,192
IDE11524-ENG142160-Vehicle function list BAP 2nd generation: expansion-wireless_charging_0x48,not activated ,192
IDE11524-ENG142161-Vehicle function list BAP 2nd generation: expansion-wireless_charging_0x48_msg_bus,not activated ,192
IDE13183-Deactivation/activation of the pop-up for active tracking services,00 00 00 00 ,4
MAS00951-Bluetooth,On ,1
MAS01968-Fan,normal ,1
MAS03782-WLAN,On ,1
ENG122227-ENG125812-Car_Function_Adaptations_Gen2-menu_auxiliary_climatization_over_threshold_high,activated ,60
ENG122227-ENG117486-Car_Function_Adaptations_Gen2-menu_display_ACC,activated ,60
ENG122227-ENG117488-Car_Function_Adaptations_Gen2-menu_display_ACC_over_threshold_high,activated ,60
ENG122227-ENG117648-Car_Function_Adaptations_Gen2-menu_display_adaptive_key_over_threshold_high,not activated ,60
ENG122227-ENG117531-Car_Function_Adaptations_Gen2-menu_display_auxiliary_heating,activated ,60
ENG122227-ENG117501-Car_Function_Adaptations_Gen2-menu_display_awv,activated ,60
ENG122227-ENG117503-Car_Function_Adaptations_Gen2-menu_display_awv_over_threshold_high,activated ,60
ENG122227-ENG117666-Car_Function_Adaptations_Gen2-menu_display_BCmE,activated ,60
ENG122227-ENG117668-Car_Function_Adaptations_Gen2-menu_display_BCmE_over_threshold_high,activated ,60
ENG122227-ENG117671-Car_Function_Adaptations_Gen2-menu_display_Brake_Function,activated ,60
ENG122227-ENG117673-Car_Function_Adaptations_Gen2-menu_display_Brake_Function_over_threshold_high,activated ,60
ENG122227-ENG117651-Car_Function_Adaptations_Gen2-menu_display_car_mirror,activated ,60
ENG122227-ENG117653-Car_Function_Adaptations_Gen2-menu_display_car_mirror_over_threshold_high,activated ,60
ENG122227-ENG117566-Car_Function_Adaptations_Gen2-menu_display_compass,activated ,60
ENG122227-ENG142087-Car_Function_Adaptations_Gen2-menu_display_Display_Configuration,activated ,60
ENG122227-ENG117656-Car_Function_Adaptations_Gen2-menu_display_driving_school,activated ,60
ENG122227-ENG125034-Car_Function_Adaptations_Gen2-menu_display_Ecall,activated ,60
ENG122227-ENG125036-Car_Function_Adaptations_Gen2-menu_display_Ecall_over_threshold_high,activated ,60
ENG122227-ENG126144-Car_Function_Adaptations_Gen2-menu_display_ENI,activated ,60
ENG122227-ENG126145-Car_Function_Adaptations_Gen2-menu_display_ENI_over_threshold_high,activated ,60
ENG122227-ENG125805-Car_Function_Adaptations_Gen2-menu_display_lane_assistant,activated ,60
ENG122227-ENG125807-Car_Function_Adaptations_Gen2-menu_display_lane_assistant_over_threshold_high,activated ,60
ENG122227-ENG117506-Car_Function_Adaptations_Gen2-menu_display_Lane_Departure_Warning,activated ,60
ENG122227-ENG117508-Car_Function_Adaptations_Gen2-menu_display_Lane_Departure_Warning_over_threshold_high,activated ,60
ENG122227-ENG117576-Car_Function_Adaptations_Gen2-menu_display_oil_level,activated ,60
ENG122227-ENG117498-Car_Function_Adaptations_Gen2-menu_display_pdc_over_threshold_high,activated ,60
ENG122227-ENG117543-Car_Function_Adaptations_Gen2-menu_display_rdk_over_threshold_high,activated ,60
ENG122227-ENG117638-Car_Function_Adaptations_Gen2-menu_display_road_sign_identification_over_threshold_high,not activated ,60
ENG122227-ENG117556-Car_Function_Adaptations_Gen2-menu_display_seat_configuration,activated ,60
ENG122227-ENG126148-Car_Function_Adaptations_Gen2-menu_display_SportHMI,activated ,60
ENG122227-ENG117676-Car_Function_Adaptations_Gen2-menu_display_Start_Stop_reasons,activated ,60
ENG122227-ENG117678-Car_Function_Adaptations_Gen2-menu_display_Start_Stop_reasons_over_threshold_high,not activated ,60
ENG122227-ENG122291-Car_Function_Adaptations_Gen2-menu_display_user_eco_rating,activated ,60
ENG122227-ENG122293-Car_Function_Adaptations_Gen2-menu_display_user_eco_rating_over_threshold_high,activated ,60
ENG122227-ENG117661-Car_Function_Adaptations_Gen2-menu_display_weariness_recognition,activated ,60
ENG122227-ENG117663-Car_Function_Adaptations_Gen2-menu_display_weariness_recognition_over_threshold_high,not activated ,60
ENG122227-ENG117521-Car_Function_Adaptations_Gen2-menu_display_windows,activated ,60
ENG122227-ENG117523-Car_Function_Adaptations_Gen2-menu_display_windows_over_threshold_high,activated ,60
ENG122227-ENG142092-Car_Function_Adaptations_Gen2-menu_soundcontrol,activated ,60
ENG122229-ENG117700-Car_Function_List_BAP_Gen2-ACC_0x05,activated ,64
ENG122229-ENG117701-Car_Function_List_BAP_Gen2-ACC_0x05_msg_bus,Databus extended ,64
ENG122229-ENG117703-Car_Function_List_BAP_Gen2-air_suspension_0x06_msg_bus,Suspension data bus ,64
ENG122229-ENG117765-Car_Function_List_BAP_Gen2-Amplifier_0x2D_msg_bus,Databus Infotainment ,64
ENG122229-ENG117697-Car_Function_List_BAP_Gen2-auxilary_heating_0x03_msg_bus,Comfort data bus ,64
ENG122229-ENG117744-Car_Function_List_BAP_Gen2-AWV_0x1B,activated ,64
ENG122229-ENG117745-Car_Function_List_BAP_Gen2-AWV_0x1B_msg_bus,Terminal 15 ,64
ENG122229-ENG122337-Car_Function_List_BAP_Gen2-Battery_Management_0x25_msg_bus,Databus drivetrain ,64
ENG122229-ENG117758-Car_Function_List_BAP_Gen2-BCmE_0x23,activated ,64
ENG122229-ENG117759-Car_Function_List_BAP_Gen2-BCmE_0x23_msg_bus,Databus Infotainment ,64
ENG122229-ENG117760-Car_Function_List_BAP_Gen2-Brake_0x26,activated ,64
ENG122229-ENG117761-Car_Function_List_BAP_Gen2-Brake_0x26_msg_bus,Suspension data bus ,64
ENG122229-ENG117716-Car_Function_List_BAP_Gen2-central_locking_0x0D_msg_bus,Comfort data bus ,64
ENG122229-ENG117737-Car_Function_List_BAP_Gen2-charisma_0x17_msg_bus,Databus Infotainment ,64
ENG122229-ENG117735-Car_Function_List_BAP_Gen2-clima_slave_2_0x16_msg_bus,Comfort data bus ,64
ENG122229-ENG117693-Car_Function_List_BAP_Gen2-climatic_master_0x01_msg_bus,Comfort data bus ,64
ENG122229-ENG117695-Car_Function_List_BAP_Gen2-climatic_slave_0x02_msg_bus,Comfort data bus ,64
ENG122229-ENG117725-Car_Function_List_BAP_Gen2-clock_0x11_msg_bus,Comfort data bus ,64
ENG122229-ENG117722-Car_Function_List_BAP_Gen2-driver_seat_0x10,activated ,64
ENG122229-ENG117723-Car_Function_List_BAP_Gen2-driver_seat_0x10_msg_bus,Comfort data bus ,64
ENG122229-ENG125039-Car_Function_List_BAP_Gen2-Ecall_0x33,activated ,64
ENG122229-ENG125828-Car_Function_List_BAP_Gen2-eCall_0x33_msg_bus,Comfort data bus ,64
ENG122229-ENG127500-Car_Function_List_BAP_Gen2-efficiency_assis_msg_bus_0x3C,not activated ,64
ENG122229-ENG125829-Car_Function_List_BAP_Gen2-ENI_0x37,activated ,64
ENG122229-ENG125830-Car_Function_List_BAP_Gen2-ENI_0x37_msg_bus,Comfort data bus ,64
ENG122229-ENG152532-Car_Function_List_BAP_Gen2-ExBoxM2_0x38_msg_bus,Comfort data bus ,64
ENG122229-ENG117709-Car_Function_List_BAP_Gen2-exterieur_light_0x09_msg_bus,Comfort data bus ,64
ENG122229-ENG117699-Car_Function_List_BAP_Gen2-headup_displ_0x04_msg_bus,Comfort data bus ,64
ENG122229-ENG117747-Car_Function_List_BAP_Gen2-Hybrid_0x1D_msg_bus,Databus drivetrain ,64
ENG122229-ENG117707-Car_Function_List_BAP_Gen2-interieur_light_0x08_msg_bus,Comfort data bus ,64
ENG122229-ENG117740-Car_Function_List_BAP_Gen2-LDW_HCA_0x19,activated ,64
ENG122229-ENG117741-Car_Function_List_BAP_Gen2-LDW_HCA_0x19_msg_bus,Databus extended ,64
ENG122229-ENG117721-Car_Function_List_BAP_Gen2-MFA_0x0F_msg_bus,Comfort data bus ,64
ENG122229-ENG117766-Car_Function_List_BAP_Gen2-MFL_Jocker_msg_bus_0x34,Databus Infotainment ,64
ENG122229-ENG117719-Car_Function_List_BAP_Gen2-mirror_0x0E,activated ,64
ENG122229-ENG117718-Car_Function_List_BAP_Gen2-mirror_0x0E_msg_bus,Comfort data bus ,64
ENG122229-ENG117753-Car_Function_List_BAP_Gen2-Passenger_Seat_0x20_msg_bus,Comfort data bus ,64
ENG122229-ENG125832-Car_Function_List_BAP_Gen2-Pedestrian_Assist_msg_bus_0x3A,Databus extended ,64
ENG122229-ENG125827-Car_Function_List_BAP_Gen2-Range_Data_msg_bus_0x39,Databus Infotainment ,64
ENG122229-ENG122328-Car_Function_List_BAP_Gen2-RearSeatEntertainment_0x2E_msg_bus,Comfort data bus ,64
ENG122229-ENG117751-Car_Function_List_BAP_Gen2-Reversible_Seat_Belt_Tightener_0x1F_msg_bus,Databus drivetrain ,64
ENG122229-ENG125834-Car_Function_List_BAP_Gen2-Seat_Pneumatic_msg_bus_0x3B,Comfort data bus ,64
ENG122229-ENG139201-Car_Function_List_BAP_Gen2-Seatmemory_codriver_rear_msg_bus_0x3F,Comfort data bus ,64
ENG122229-ENG139199-Car_Function_List_BAP_Gen2-Seatmemory_driver_rear_msg_bus_0x3E,Comfort data bus ,64
ENG122229-ENG117727-Car_Function_List_BAP_Gen2-service_interval_display_0x12_msg_bus,Comfort data bus ,64
ENG122229-ENG122330-Car_Function_List_BAP_Gen2-Special_Functions_msg_bus_0x35,Comfort data bus ,64
ENG122229-ENG117762-Car_Function_List_BAP_Gen2-Start_Stop_reasons_0x27,activated ,64
ENG122229-ENG117763-Car_Function_List_BAP_Gen2-Start_Stop_reasons_0x27_msg_bus,Comfort data bus ,64
ENG122229-ENG117742-Car_Function_List_BAP_Gen2-SWA_0x1A,activated ,64
ENG122229-ENG117743-Car_Function_List_BAP_Gen2-SWA_0x1A_msg_bus,Databus extended ,64
ENG122229-ENG117705-Car_Function_List_BAP_Gen2-tire_pressure_system_0x07_msg_bus,Suspension data bus ,64
ENG122229-ENG117755-Car_Function_List_BAP_Gen2-traffic_sign_recognition_0x21_msg_bus,Databus extended ,64
ENG122229-ENG122332-Car_Function_List_BAP_Gen2-Trailer_Assistant_msg_bus_0x36,Comfort data bus ,64
ENG122229-ENG122326-Car_Function_List_BAP_Gen2-TV_tuner_0x2C_msg_bus,Comfort data bus ,64
ENG122229-ENG117731-Car_Function_List_BAP_Gen2-UGDO_0x14_msg_bus,Terminal 15 ,64
ENG122229-ENG117729-Car_Function_List_BAP_Gen2-unit_master_0x13_msg_bus,Comfort data bus ,64
ENG122229-ENG117712-Car_Function_List_BAP_Gen2-VPS_0x0B,not activated ,64
ENG122229-ENG117713-Car_Function_List_BAP_Gen2-VPS_0x0B_msg_bus,Databus Infotainment ,64
ENG122229-ENG117756-Car_Function_List_BAP_Gen2-weariness_rcognition_0x22,activated ,64
ENG122229-ENG117757-Car_Function_List_BAP_Gen2-weariness_rcognition_0x22_msg_bus,Databus Infotainment ,64
ENG122229-ENG117715-Car_Function_List_BAP_Gen2-wiper_comfort_0x0C_msg_bus,Comfort data bus ,64
ENG122228-ENG117690-Car_Function_List_CAN_Gen2-Adaptive_key_msg_bus,Comfort data bus ,8
ENG122228-ENG117688-Car_Function_List_CAN_Gen2-Driving_school,Available ,8
ENG122228-ENG117689-Car_Function_List_CAN_Gen2-Driving_school_msg_bus,Databus Infotainment ,8
ENG122228-ENG117683-Car_Function_List_CAN_Gen2-Oil_level,Available ,8
ENG122228-ENG117684-Car_Function_List_CAN_Gen2-Oil_level_msg_bus,Databus drivetrain ,8
ENG122228-ENG117686-Car_Function_List_CAN_Gen2-PDC_audio_lowering_msg_bus,Suspension data bus ,8
ENG122228-ENG101416-Car_Function_List_CAN_Gen2-Reserved_1,Comfort data bus ,8
ENG122228-ENG99458-Car_Function_List_CAN_Gen2-Reserved_2,Comfort data bus ,8
ENG122228-ENG117687-Car_Function_List_CAN_Gen2-VIN_msg_bus,Comfort data bus ,8
ENG122230-ENG142097-Dashboard_Display_Configuration-ability_switch_nav_maps,On ,10
ENG122230-ENG122343-Dashboard_Display_Configuration-call_picture,On ,10
ENG122230-ENG122341-Dashboard_Display_Configuration-coverart,On ,10
ENG122230-ENG122340-Dashboard_Display_Configuration-crossroad_detail_map_compression_mode,H264 ,10
ENG122230-ENG127006-Dashboard_Display_Configuration-crossroad_detail_map_transmission_mode,MOST_streaming ,10
ENG122230-ENG127501-Dashboard_Display_Configuration-fastlist_most,On ,10
ENG122230-ENG122338-Dashboard_Display_Configuration-navigation_map_compression_mode,H264 ,10
ENG122230-ENG127005-Dashboard_Display_Configuration-navigation_map_transmission_mode,MOST_streaming ,10
ENG122230-ENG122342-Dashboard_Display_Configuration-stationart,On ,10
ENG117916-ENG102140-Dimming_Illumination_for_Display_Unit-X3,50 ,12
ENG117916-ENG102936-Dimming_Illumination_for_Display_Unit-X4,100 ,12
ENG117916-ENG103548-Dimming_Illumination_for_Display_Unit-X5,150 ,12
ENG117916-ENG100480-Dimming_Illumination_for_Display_Unit-Y2,1 %,12
ENG117916-ENG100773-Dimming_Illumination_for_Display_Unit-Y3,3 %,12
ENG117916-ENG100631-Dimming_Illumination_for_Display_Unit-Y4,6 %,12
ENG117916-ENG102174-Dimming_Illumination_for_Display_Unit-Y5,44 %,12
ENG167428-ENG167502-nhtsa_properties-limitation_dependency,Speed_threshold ,5
ENG167428-ENG167510-nhtsa_properties-nhtsa_limitation_switches_for_androidauto_limit_displayed_message_length,activated ,5
ENG167428-ENG167511-nhtsa_properties-nhtsa_limitation_switches_for_androidauto_no_setup_configuration,activated ,5
ENG167428-ENG167512-nhtsa_properties-nhtsa_limitation_switches_for_androidauto_no_text_input,activated ,5
ENG167428-ENG167513-nhtsa_properties-nhtsa_limitation_switches_for_androidauto_no_video_playback,activated ,5
ENG167428-ENG167514-nhtsa_properties-nhtsa_limitation_switches_for_androidauto_no_voice _input,not activated ,5
ENG167428-ENG167515-nhtsa_properties-nhtsa_limitation_switches_for_carplay_limit_musicLists,not activated ,5
ENG167428-ENG167516-nhtsa_properties-nhtsa_limitation_switches_for_carplay_limit_nonMusicLists,not activated ,5
ENG167428-ENG167517-nhtsa_properties-nhtsa_limitation_switches_for_carplay_no_japanMaps,not activated ,5
ENG167428-ENG167518-nhtsa_properties-nhtsa_limitation_switches_for_carplay_no_softKeyboard,activated ,5
ENG167428-ENG167519-nhtsa_properties-nhtsa_limitation_switches_for_carplay_no_softPhoneKeypad,not activated ,5
ENG117921-Operating_and_Display_Unit_1_Proximity_Sensor_Basic_Adaptation,01 01 3C 02 3C 02 3C 02 50 02 50 02 64 02 6E 02 78 02 3C 02 3C 02 3C 02 50 02 1E 02 1E 02 1E 02 1E 02 02 02 02 14 05 5C ,40
ENG117808-p_HMI_Display,13 %,1
ENG117919-Startup_Screen_Sticker_HMI,00 01 ,2
Elapsed Time: 00:45
DV52
C?ID=194404
^^^ yep - same as Dana. More confirmation of TBAx's sage advice!!
Thanks for posting - much appreciated
jyoung8607
FoRT
Cincinnati, OH
C?ID=25607
Not sure I'd call a Discover Media low-end per TBAx's comment, the only step up from there is Discover Pro with all glass/no physical buttons or knobs.
But alas no DSM option appears under the CAR option in the MIB.
Hrm, I wonder if he's looking in the right place. In mine, it doesn't add anything to the Car menu. It becomes part of the Driving Data option along with from-start and extended-period mileage.
DV52
C?ID=194404
^^ Again my thanks for your response - I'm both humbled and honored that you have gone to the effort of providing all the information - including creating the video. As I said in the 1st post -I'm trying to emulate the mk7 facility on my Audi A3 8V in an attempt to help a local lad (more as proof-of-concept than because I actually want DSM on my car)
I've not seen DSM on an Audi, but as I understand from watching videos on sites like Stemei.de (see below) it is meant to happen from the CAR menu. This said, I'm more than happy to be told otherwise - always willing to learn new stuff!!
Andy
Sector 7G
HC424490
Hey Don, I can check tomorrow on my 2018 A3 e-tron to see if I can enable driving school mode. At the very least it looks like there are some adaptation channels in the maps:
https://forums.ross-tech.com/showthread.php?12616-2018-Audi-A3-e-tron&p=114633&viewfull=1#post114633
BTW, in my long gone 2015 GTI I had driving school mode enabled and displayed on the center screen most of the time, that way I could have trip computer info always visible plus I could have oil temp displayed in the cluster:
