Page 1 of 3 123 LastLast
Results 1 to 10 of 21
Thread: 2018 NAR Alltrack S with 6-speed DSG and 1.8T (CXBB)
    United States
    This 2018 left over Alltrack S is the latest addition to our family. It doesn't have much but we did get a RLS (Auto wipers/Auto headlights w/coming and leaving home) and heated (fake leather) front seats.
    Original files located here: https://drive.google.com/drive/folde...7W?usp=sharing
    Scan shortly after delivery @ Mileage: 138km-85mi:
    Sunday,26,August,2018,11:23:08:04045
    VCDS Version: 18.7.2.1 (x64)  HEX-V2 CB: 0.4432.4
    Data version: 20180808 DS295.0
    VIN: 3VWH17AU5JM758941   License Plate: 2018 ALLTRACK MAP SCAN
    Mileage: 138km-85mi   Repair Order:
    Chassis Type: AU-VW37 (3Q0)
    Scan: 01 02 03 08 09 15 16 17 19 22 42 44 52 5F
    VIN: 3VWH17AU5JM758941   Mileage: 138km-85miles
    Address 01: Engine (J623-CXBB)       Labels:. 06K-907-425-V1.clb
       Part No SW: 8V0 906 264 M    HW: 06K 907 425 B
       Component: 1.8l R4 TFSI  H13 0001
       Revision: --H13---
       Coding: 311D00122426002F0000
       Shop #: WSC 00066 790 00075
       ASAM Dataset: EV_ECM18TFS0208V0906264M 001003
       ROD: EV_ECM18TFS0208V0906264M.rod
       VCID: 46D65C71682711E7EBE-8012
    Readiness: 0000 0100
       Part No SW: 0D9 300 018     HW: 02E 927 770 AS
       Component: DQ250-6A MQB  H54 5201
       Revision: 06454104    Serial number: TFK01706220029
       ROD: EV_TCMDQ250021.rod
       VCID: 59EC870DC9998E1FB6C-800C
    Address 03: ABS Brakes (J104)       Labels:| 5Q0-907-379-ESP-V1.clb
       Part No SW: 5Q0 614 517 AQ    HW: 5Q0 614 517 AF
       Component: ESC           H62 0400
       Revision: 00000000    Serial number: 52407000000109
       Coding: 43FA6AA1342509748080030480C429C2562C9001C001943C00435050E009430000010312121212B435351919323200
       Shop #: WSC 01383 790 50316
       ASAM Dataset: EV_Brake1UDSContiMK100ESP 036010
       ROD: EV_Brake1UDSContiMK100ESP_036.rod
       VCID: 005A8A690A83FFD7912-8054
       Part No SW: 5GM 907 426 G    HW: 5GM 907 426 G
       Component: AC Manuell    H03 2001
       Revision: 00001K05
       Coding: 02020004200110000000000000000002
       ASAM Dataset: EV_ACManueBHBVW37X 004134
       ROD: EV_ACManueBHBVW37X_004_VW37.rod
       VCID: 4CC26E59764BEBB73DA-8018
              B10CD 00 [008] -  -
                        Reset counter: 58
                        Mileage: 58 km
                        Date: 2011.10.25
                        Time: 06:30:10
                        Voltage terminal 30: 11.9 V
       Part No SW: 5Q0 937 087 AR    HW: 5Q0 937 087 AN
       Component: BCM PQ37BOSCH 034 0243
       Revision: --------    Serial number: C864290917029K
       Shop #: WSC 00066 790 00249
       ROD: EV_BCMBOSCH_018.rod
       VCID: 0B40AD4533C5AC8FF40-805E
       Subsystem 1 - Part No SW: 5G1 955 119 A    HW: 5G1 955 119   Labels: 5QX-955-119-V1.CLB
       Component: WWS    170803  043 0551
       Serial number: 97022066170820234314
       Subsystem 2 - Part No SW: 5Q0 955 559 B    HW: 5Q0 955 559 B  Labels: 5Q0-955-547.CLB
       Component: RLS  042 0105
       Serial number: S7Y17M07D24H00M23S20
       Coding: 00A8DD
       Serial number: 003GCR08WNXP
       ROD: EV_AirbaVW20SMEVW37X.rod
       VCID: 47C851756F2D08EF108-8012
       Occupant Detection:
       Serial number: IBH000000000007SMW28
       Coding: 303135
       Subsystem 2 - Part No SW: -----------    HW: 480 000 508 17
       Serial number: 3570000000099CB0A62V
       Subsystem 3 - Part No SW: -----------    HW: 480 000 508 17
       Serial number: 35800000000CACB0A62-
       Subsystem 4 - Part No SW: -----------    HW: 480 401 209 17
       Serial number: 351000199270BC657721
       Subsystem 5 - Part No SW: -----------    HW: 480 401 109 17
       Serial number: 3520001AB269FFC4D2D.
       Subsystem 6 - Part No SW: -----------    HW: 480 400 707 17
       Serial number: 3550002B324F3852D140
       Front Sensor Passenger:
       Subsystem 7 - Part No SW: -----------    HW: 480 400 707 17
       Serial number: 3560002B124F3852108X
       Part No SW: 5Q0 953 507 GH    HW: 5Q0 953 549 E
       Revision: --------    Serial number: 29091708490917
       Coding: 0410
       ROD: EV_SMLSKLOMQB_VW37.rod
       VCID: 025E8061048FEDC7876-8056
       Part No SW: 5G1 920 840 C    HW: 5G1 920 840 C
       Component: KOMBI         242 0310
       Coding: 0BB4100DA180CF0502082B001000000000000000
       VCID: 2708F1F5CF6DE8EFF08-8072
       Part No SW: 3Q0 907 530 F    HW: 3Q0 907 530 B
       Component: GW MQB Mid    517 5304
       Serial number: 11101700842535
       Coding: 0101000830085900FB0020081E0F00000001070000000000000000000000
       Shop #: WSC 00066 790 00067
       ROD: EV_GatewNF_VW27.rod
       VCID: 323E10A1F4AF9D47576-8066
       Subsystem 2 - Part No SW: 5G0 959 442 P    HW: 5G0 959 442 P  Labels: 3C8-959-537.CLB
       Component: E221__MFL-DC1  H17 0103
       Serial number: 26170001893500121439
       Coding: 31FFFF
       Serial number: HA1-00010.07.17
       Coding: 0001
       VCID: 4ACE68417C3FF5870F6-801E
       Serial number: 5037727600716
       Coding: 003A03200000020000000000
       Serial number: 00000000000007088038
       Coding: 011000
       Part No SW: 5QM 909 144 A    HW: 5QM 909 144 A
       Component: EPS_MQB_ZFLS  171 1072
       Coding: 8102
       ROD: EV_SteerAssisMQB_013.rod
       VCID: 4FF87955875DD0AF588-801A
       Serial number: 6038726301305
       Serial number: 00000000000007073405
       Coding: 091000
    Address 5F: Information Electr. (J794)       Labels:| 5G0-035-MIB-ENT2.clb
       Part No SW: 5G6 035 868     HW: 5G6 035 868
       Component: MU-E--ER      671 8395
       Serial number: 07081700021741
       Coding: 02731200FF00000041220001001000009F0008D40000010000
       ASAM Dataset: EV_MUEnt4CGen2LGE 001041
       ROD: EV_MUEnt4CGen2LGE_VW12.rod
       VCID: 70BADAA93A23EF57612-8024
    End------(Elapsed Time: 10:17, VBatt start/end: 14.4V/14.4V, Deb=2)--------
    Vehicle Identification No. 3VWH17AU5JM758941
    Model Golf variant 1,8 GOV
    Date of production 30.10.2017
    Year 2018
    Sales type BX6CN7
    Engine Code CXBB
    Transmission Code SYL
    Axle drive 6A
    Equipment XW
    Roof color 2T
    Carpet color code
    Exterior color / Paint Code 2T / C9X
    Special editions E0A No special edition
    Lockable wheel bolts 1PF Standard wheel bolts
    Vehicle class differentiation units/platform components 7II Vehicle class differentiation -5GM-
    tail pipe 0P1 Rear side exhaust tailpipe
    drive-off assistance UG1 Hill hold control
    Emission standard 0GT Emission standard SULEV
    Trailer hitch 1D0 without trailer towing
    airbag 4UM Airbag für Fahrer und Beifahrer (NAR) mit Beifahrer-Airbag-Deaktivierung (zweistufig)
    Aktivkohlebehälter / Ottopartikelfilter 1E7 Activated carbon canister (ORVR), for intensified evaporation system, siphoning device for fueling
    Tray areas package QE0 Without tray areas package/box
    Storage compartment 7N3 Comfort overhead storage compartment
    Aerials 8L6 "diversity" window antenna
    Exterior mirror setting 6XN Exterior mirrors, power-adjustable/ separately heated
    Follow-on warranty EA0 Without subsequent warranty
    Left exterior mirror 5SH Left exterior mirror, flat (US)
    Electronic engine sound measures GM1 Standard electronic engine sound
    Right exterior mirror 5RR Right exterior mirror, convex (US)
    Alternative drive system 0K0 Without alternative drive system
    Drive type 1X1 Four-wheel drive
    "Multimedia"video/DVD/notebook connection 9WT Mirror Link
    Equipment levels A8T Executive equipment
    Area monitoring systems 6K0 Without forward collision warning/ autonomous emergency braking
    Brake type in rear 1KS Disc brakes in rear (Geomet D)
    batteries J1L Battery 280 A (60 Ah)
    Brake type, front 1ZD Disc brakes in front (Geomet D)
    Components with special surface 6FJ Black exterior mirror housings
    Battery/alternator capacity NY0 Standard battery/alternator capacity
    Component part sets with country-specific design requirements B0D Assembly kit, USA corresponding vehicle version (not California), various parts
    vehicle tools and jack 1S1 vehicle tools and jack
    Brake systems 1AT Electronic stability control (ESC)
    Owner's manuals 0VM Information kit in American English
    Operating voltage 9Z0 Operating voltage 12 V
    brake wear indicator 9U0 Without brake pad wear indicator
    Heated washer nozzles 9T1 Heated washer nozzles in front
    CD ROM/DVD/SD card 7QA Without CD/DVD for navigation
    "Charism" 2H5 Driving profile selection and conventional shock absorber
    Chrome package QJ1 Chrome package
    General operating permit, alterations C00 Operating permit, initial registration
    Roof rails/roof load rack 3S1 Bright roof rails
    Roof insert/convertible top 3FA roof without cut out
    Suspension system in rear UC5 Rear shock absorption
    Suspension system in front G25 Shock absorption in front
    Differential lock 1Y3 Electronic differential lock XDS, dynamic traction support
    ECO function for driving profiles and Drive select EF0 Without ECO function
    Installation differentiation for components 0ES Installation differentiation for transmission DQ250 -- vehicle components --
    Theft protection system 7AZ Preparation for anti-theft alarm system
    Inserts 5MQ Decorative inserts
    Scuff plates 7M5 Without protective film for scuff plate
    Park distance control 7X0 Without park distance control
    Extended safety system 7W0 Without extended safety system
    Electric interface for external use UI5 External, USB type A, 1x USB socket
    Manufacturing sequence differentiation 0FA Standard manufacturing sequence
    window regulator 4R4 Power windows with comfort operation and circuit breaker
    fire extinguisher 6A0 without fire extinguisher
    Pedestrian protection VL0 Standard pedestrian protection measures
    Pedal cluster VF1 pedal cluster
    Headlight activation 9C9 Separate daytime running light and automatic headlight control -NAR- with Coming Home and Leaving Home feature
    Fresh air intake for passenger compartment (with particulate filter) 2V5 Fresh air intake with activated charcoal filter
    Parking brake UH0 Parking brake
    Alternators 9G2 Alternator 100-150 A
    Weight category rear axle 0YK Weight range 10 installation control only, no requirement forecast
    Weight category front axle L47 Suspension range 47 installation control only, no requirement forecast
    Base engine TI5 4-cylinder SI engine 1.8 l unit 06K.K
    Luggage netting/pocket on backrest(s) 4U5 Luggage pockets on backrest
    Luggage compartment cover 3U2 Sliding trunk cover
    cruise control system 8T2 Electronic cruise control system (CCS)
    Transmission specifications G0R 6-speed automatic transmission for four-wheel drive
    handle for hand brake lever 6PC handbrake lever grip (leather)
    Rear spoiler 5J0 Without rear spoiler
    Rear window wiper and washer system 8M1 Rear window wiper and washer system with intermittent control
    Rear axle 0N4 4-link rear suspension
    Molded headliner 6NA Unsplit molding roof liner
    Rear seats 3NU Rücksitzbank ungeteilt, Lehne geteilt umlegbar mit Mittelarmlehne
    Heating and air-conditioning system KH6 Air conditioning system with electronic control
    Headlamps 8IE H7 headlamps with separate LED daytime running lights
    Interior light in footwell 6T1 Interior light in footwell
    Instrument clusters U5C Instrument cluster, mph speedometer - USA -
    Breakaway interior rearview mirror 4L2 Breakaway interior rearview mirror, dimming
    Body style K8D Wagon/Avant
    Camera/distance sensor QK0 Without multifunction camera
    Folding table 1U8 W/o folding table on front seat backrest
    Climatic zones 0Y4 Cold and tropical climatic zones (US)
    Compass/road sign display QR8 without road sign recognition
    headrest for seat, rear 3Q9 Three rear head restraints
    Head restraints 5ZF Front head restraints
    Fuel quantity for initial filling 1Z0 Initial standard fuel filling
    Fuel systems 1A5 Fuel system for SI engine
    Body measures 5C1 Body measures for increased safety requirements
    Camera systems/accident sensors KA1 With rear view camera system (type 1)
    Radiator grille 6KG Radiator grille
    refrigerant KK3 Refrigerant R1234yf
    License plate lighting KL1 LED license plate lighting
    License plate carrier 31N License plate carrier in front and rear (NAR)
    Paint preservative/transit coating 5K7 Transport protection film (minimum protection) with additional transport protection measures
    Paint coating FB0 standard paint coating
    Rear cargo area 3GD Plane rear cargo area
    Light package (lighting) QQ3 Interior ambient lighting and surround lighting
    Vehicle inlet ES0 Without vehicle inlet
    Steering system arrangement L0L Left-hand drive
    Reading lamp 8S6 2 reading lights in front
    steering 1N3 Speed-related variable steering assist (Servotronic)
    Backrest release 3H0 Without backrest release for front seats
    Light control systems 8G0 Without Light Assist
    Lumbar support 7P4 Manually adjustable lumbar support in front seats
    steering wheels 1XX Leather-wrapped multi-function sports steering wheel with tiptronic
    Driving on the left/on the right AV2 Driving on the right (NAR)
    Speaker installation 8RM 8 speakers (passive)
    Headlight range control 8Q0 Without headlight range control
    Center armrest 6E3 Front center armrest
    Versions FM0 Basic equipment variant
    Multi-function display/trip computer 9S5 Multi-function display/trip computer "Medium"
    center console 3D2 center console
    Driver alert system EM0 Without driver alert system
    Engine cooling 8Z6 Hot country
    Engine specifications D6J 4-cylinder SI engine 1.8 l/125 kW (16V) turbo FSI, homogeneous, base engine is TH2/TJ2/TF6/TQ6/TF5/TK5/TI5
    Navigation device 7Q0 without navigation system
    rear fog lamp 8TA witout rear fog lamp
    Front fog lamp/additional headlamp 8WH Front fog lamp and cornering lamp
    Online services EL0 Without online service
    Rear of platform module base 4P3 Rear floor panel module, type 4
    Hubcaps 1NL Trims for alloy wheels
    Wheels U89 Alloy wheels 7J x 17
    Radios I8C .
    Smoker's/non-smoker's package 9JF Non-smoking package (NAR)
    Regional code for radio ER3 Regional code " NAR " for radio
    Tire pressure monitoring system 7K6 Tire pressure monitoring system
    tire I84 All-season tires 205/55 R17 95H xl (NAR)
    Tire suppliers V0A Tires without specification of tire brand
    Spare wheel/breakdown kit 1G9 Space-saving spare wheel for temporary use, radial tire (5-hole)
    Wheelbases 0B1 Wheelbase
    Restraint systems, front 4QQ 3-point seat belts in front with pretensioner and height adjustment, US label
    Side airbag 4X3 Side airbag in front, with curtain airbag
    Gearshift knob/handle 6Q2 Gearshift knob/handle in leather
    Special labels/plates 0SC Labels in English
    Tail lamp assemblies 8SQ LED rear combination lamp
    Service indicator QI7 Service indicator 10 000 miles or 1 year (fix)
    Seat belt check 9P7 Visual and acoustic seat belt reminder, electric contact in buckle
    Outer rear seat belts 3ZD 3-point seat belts, outer rear with US label
    Center rear seat belts 3C8 3-point seat belt, center rear with US label
    seat covers N4Q Seat trim covers in leatherette
    Seat adjustment 3PT Manual height adjustment for front seats
    seat heater 4A3 Seat heater for front seats separately controlled
    Start-stop system/regenerative braking 7L3 Without start/stop system without regenerative braking
    Horns 8Y1 Two-tone horn
    sun visors 5XX Sun visors with mirror, illuminated (NAR)
    Audio-response system/voice control QH0 without voice control
    Lane change assist/lane keeping system 7Y0 Without lane change assist
    Side and rear windows 4KC Side and rear windows in heat-insulating glass
    power outlet 7B3 12-volt socket(s)
    Bumper 2JE Partially painted bumpers
    Rear stabilizer 0BF Rear stabilizer
    Front stabilizer bar 0AF Front stabilizer bar
    Drawers under front seats QN0 Without drawers under front seats
    Headlamp washer system 8X0 Without headlamp washer system
    Windshield wiper intermittent control/ light/rain sensor 8N6 Windshield wiper intermittent control with light/rain sensor
    Nameplate set 0NW Nameplate set "TSI"
    Mass damper for steering wheels 1Q2 Mass damper for steering wheel, 36 Hz
    Door and lid locking system 4K0 Central locking w/ radio remote control and interior controls
    Type approval countries/countries with special requirements BU2 Legal requirements for USA 2 States with CARB requirement
    Carrier frequency for remote control 5D2 Carrier frequency 315 MHz
    Partition 3CA Without partition
    Door and side trim panels 3LJ Door and side trim panel in foam film, insert in leatherette
    doors 0A2 4 doors
    TV reception/digital radio reception QV0 without TV/digital radio reception
    Front underbody guard 1SB Additional front underbody guard
    Identification plates 1EB Ohne Typschild
    Delivery equipment 2A8 Delivery equipment, water border
    First aid kit / warning triangle 1T0 Without first-aid material, without warning triangle
    Two-way radio installation preparation 9D0 without prepared for two way radio system
    Front seats Q2J convenience seat
    Rear seat catch UK3 Mechanical rear seat release
    Telephone / telematics 9ZX Telephone preparation for cellphone
    Additional warning lights 9TC Additional retro-reflectors (door area)
    LongLife Service Regime QG1 LongLife Service Regime
    Heat accumulator system/auxiliary heater 7E0 W/o heat accumulator/auxiliary heating
    Windshield Glass 4GF Windshield in heat-insulating glass
    Washer fluid level indicator 8W1 Washer fluid level indicator
    Additional tires (snow tires) 2WA without spare tyre
    floor mats 0TD Floor mats in front and rear
    Decorative trims 4ZN Bright decorative trims
    Additional child seat anchors 3B7 Child seat anchors as per Canadian requirements a. ISOFIX child seat system
    Auxiliary heating system 9M0 Without auxiliary heater/parking heater
    Press release info https://newspress-vwusamedia.s3.amaz...ackRelease.pdf
    Press kit main page: https://media.vw.com/press-kits/2018...rack-press-kit
  2. Likes jyoung8607, Keithuk, Andy, NZDubNurd, Uwe, Boki Ar liked this post
  3. #2
    United States
    01-Engine
    adpmap-01-8V0-906-264-M_3VWH17AU5JM758941-20180826-1114.CSV
    ;SW:8V0-906-264-M   HW:06K-907-425-B ---  Engine
    ;Component:1.8l R4 TFSI  H13 0001	 Coding:311D00122426002F0000
    ;EV_ECM18TFS0208V0906264M	1003	EV_ECM18TFS0208V0906264M.rod
    ;Sunday	26	August	2018	11:14:48:04045
    ;VCDS Version: Beta 18.7.2 (x64)  Data version: 20180808 DS295.0
    ;VCID: 46D65C71682711E7EBE-8012
    IDE00001-Production mode	00 00 00 	3
    IDE00259-Idle RPM correction	0 /min	1
    IDE01945-Engine run-in oil pressure	active 	1
    IDE02332-Deactivate production mode	00 00 00 	3
    IDE04158-Activation of start-stop function	not active 	1
    IDE04617-Protective function	Enabled 	1
    IDE06425-Roller test bench mode: functional	not activated 	1
    IDE06726-Timing deviation after chain replacement: intake bank 1	-1.44 °	2
    IDE06728-Timing deviation after chain replacement: exhaust bank 1	0.00 °	2
    IDE06730-Timing deviation after other repairs: intake bank 1	0.00 °	2
    IDE06732-Timing deviation after other repairs: exhaust bank 1	0.00 °	2
    IDE06734-Timing deviation: current value intake bank 1	0.00 °	2
    IDE06736-Timing deviation: current value exhaust bank 1	0.00 °	2
    IDE06738-Chain elongation: no. of valid initial values: intake bank 1	1	1
    IDE06740-Chain elongation: no. of valid initial values: exhaust bank 1	0	1
    IDE06742-Chain elongation: initial values valid: intake bank 1	not active 	1
    IDE06744-Chain elongation: initial values valid: exhaust bank 1	not active 	1
    IDE10261-MAS10172-Operating mode selec.-DI operation	not activated 	4
    IDE10261-MAS10174-Operating mode selec.-CNG operation	not activated 	4
    IDE10261-Operating mode selec.-	not activated 	4
    Elapsed Time: 00:04
    blockmap-01-8V0-906-264-M_3VWH17AU5JM758941-20180826-1113.CSV
    KOEO
    ;Sunday	26	August	2018	11:13:42:04045
    Group	Description	Actual
    IDE00011	Vehicle Identification Number (VIN)	3VWH17AU5JM758941
    IDE00018	Voltage terminal 15	14.082	 V
    IDE00019	Voltage terminal 30	14.453	 V
    IDE00021	Engine speed	0	 /min
    IDE00025	Coolant temperature	81	 °C
    IDE00030	Status of actuator test	not active
    IDE00075	Vehicle speed	0	 km/h
    IDE00076	Status of initial fuel filling	was not yet started
    IDE00078	Time since engine start	0	 s
    IDE00083	Throttle valve position (absolute)	15.3	 %
    IDE00084	Absolute load value	0	 %
    IDE00085	Normed load value	0	 %
    IDE00086	Accelerator position	16	 %
    IDE00090	selected gear	Shifting process active
    IDE00097	OBD - requirements for which this vehicle is designed	OBD + OBD II
    IDE00102	Control Module temperature	52	 °
    IDE00148	Median injection timing	0	 ms
    IDE00149	Ignition angle of current cylinder: actual value	-1.12	 °
    IDE00150	Pressure in brake booster	1.15	 bar
    IDE00151	Oil fill level	90	 mm
    IDE00155	Timing angle retardation cylinder 1	0	 °
    IDE00156	Timing angle retardation cylinder 2	0	 °
    IDE00157	Timing angle retardation cylinder 3	0	 °
    IDE00158	Timing angle retardation cylinder 4	0	 °
    IDE00167	Exhaust temperature 1 bank 1	264.9	 °C
    IDE00172	A/C compressor torque	0	 Nm
    IDE00173	Cruise Control System: specified speed	0	 km/h
    IDE00174	Camshaft adjustment: exhaust: bank 1: specified value	0	 °
    IDE00175	Camshaft adjustment: exhaust: bank 1: actual value	0	 °
    IDE00178	Camshaft adjustment intake bank 1: specified value	0	 °
    IDE00179	Camshaft adjustment intake bank 1: actual value	0	 °
    IDE00182	Camshaft adaptation intake bank 1: phase position	-1.1	 °
    IDE00184	Camshaft adaptation exhaust bank 1: phase position	47.6	 °
    IDE00186	Fuel low pressure: actual value	11.003	 bar
    IDE00187	Coolant temperature at engine start	82.5	 °
    IDE00188	Fuel high pressure: actual value	44.6	 bar
    IDE00189	Activation of fuel pump electronics	10	 %
    IDE00190	Charge air pressure specified value	0.986	 bar
    IDE00191	Charge air pressure: actual value	0.982	 bar
    IDE00192	Coolant temperature at radiator outlet: actual value	30.1	 °
    IDE00193	Coolant temperature at engine outlet: specified value	81.7	 °
    IDE00194	Coolant temperature at radiator output: specified value	-48	 °
    IDE00195	Coolant temperature difference between engine and radiator	51	 °
    IDE00196	Engine oil temperature	80	 °C
    IDE00199	Mean engine air mass	0	 kg/h
    IDE00200	Median vehicle speed	0	 km/h
    IDE00201	High fuel pressure: specified value	103	 bar
    IDE00202	Low fuel pressure: specified value	5.462	 bar
    IDE00252	Brake system vacuum pump	Pump off
    IDE00304	Fuel level	49	 l
    IDE00322	Status of basic setting	not active
    IDE00323	Security Access: Number of invalid keys	0
    IDE00348	Intake air temperature	54	 °C
    IDE00349	Throttle valve position: normed	5	 %
    IDE00350	Air mass: specified value	0	 kg/h
    IDE00355	Cruise Control System (CCS): status	main switch off
    IDE00357	Fuel temperature	79.5	 °
    IDE00358	Limitation: torque	290	 Nm
    IDE00371	Fuel consumption	0	 l/h
    IDE00375	Generator: load signal	0.03	 %
    IDE00380	Coolant fan 1: activation	10.16	 %
    IDE00381	Coolant fan 2: activation	0	 %
    IDE00392	Accelerator pedal: sensor voltage 1	0.796	 V
    IDE00393	Accelerator pedal: sensor voltage 2	0.386	 V
    IDE00396	Charge Pressure Actuator: acknowledgment	1.284	 V
    IDE00400	Intake manifold Runner Control (IMRC): activation	100	 %
    IDE00401	Intake manifold Runner Control (IMRC): acknowledgment	100	 %
    IDE00404	Throttle valve: activation	0	 %
    IDE00405	Crankshaft speed (RPM)	0	 /min
    IDE00406	Camshaft speed (RPM)	0	 /min
    IDE00407	Rail pressure regulation: status	Control operation
    IDE00408	Engine mount 1	not active
    IDE00409	Engine mount 2	not active
    IDE00412	Starter control: terminal 50	not active
    IDE00413	Starter control: Interlock- or P/N-signal	0
    IDE00414	Starter control: relay 1	0
    IDE00415	Starter control: relay 2	0
    IDE00416	Starter control: terminal 50 acknowledgment	1
    IDE00417	Starter control: shut-off conditions 1	00 00
    IDE00445	Unlearning counter according OBD	255
    IDE00450	Operating Instructions	--no display--
    IDE00451	Currently running routine	Unknown (0)
    IDE00472	Mean injection quantity	19	 mg/stroke
    IDE00474	Ambient air pressure	98	 kPa abs
    IDE00476	Fuel Metering Valve	0	 %
    IDE00477	Torque request: sum of auxiliary aggregate	0	 Nm
    IDE00478	Engine-drag torque	16.5	 Nm
    IDE00482	Limitation: torque of clutch protection	1024	 Nm
    IDE00495	Calculated oil temperature	80	 °
    IDE00496	Activation of oil pressure switch valve	High pressure
    IDE00497-MAS00627	Status of oil pressure switches-Oil pressure switch for high pressure	Open
    IDE00497-MAS00628	Status of oil pressure switches-Oil pressure switch for low pressure	Open
    IDE00556	Outside air temperature	23	 °C
    IDE00559	Current of oxygen sensor bank 1 sensor 1 (broadband sensor)	0.000 Lambda / -128.000 mA
    IDE00560-MAS04121	Oxygen sensor bank 1 sensor 2 (jump sensor)-Voltage	1.275	 V
    IDE00560-MAS04122	Oxygen sensor bank 1 sensor 2 (jump sensor)-Short term adaptation of mixture formation	99.2	 %
    IDE00582	Equivalence ratio target value	1	 Lambda
    IDE00583	Throttle valve specified value	5	 %
    IDE00584	Distance driven since erasing DTC memory	121	 km
    IDE00585	Dist. driven with exh. Malfunction Indicator Lamp activated	0	 km
    IDE00588	Fuel tank fill level	92.2	 %
    IDE00589	Fuel pressure	4330	 kPa rel
    IDE00592	Oxygen sensor control status	Engine off
    IDE00593	Ignition timing adjustment cylinder 1	-1	 Degrees
    IDE00594	Absolute intake pressure	98	 kPa abs
    IDE00595	Allocation of oxygen sensors	B1S1 B1S2
    IDE00597	Long term adaptation of mixture formation bank 1	4.7	 %
    IDE00601	Monitoring status since erasing DTC memory
    IDE00602	Monitoring status in current driving cycle
    IDE00603	Number of driving cycles since erasing DTC memory	22
    IDE00604	Short term adaptation of mixture formation bank 1	0	 %
    IDE00608	Type of fuel	Gasoline
    IDE00612	Target position of EVAP canister valve	0	 %
    IDE00727	Test steps still to be performed	0
    IDE00787	Cause for cancellation	0
    IDE00949-ENG98517	Hide cylinder-Cylinder 1	active
    IDE00949-ENG98491	Hide cylinder-Cylinder 10	not active
    IDE00949-ENG98492	Hide cylinder-Cylinder 11	not active
    IDE00949-ENG98493	Hide cylinder-Cylinder 12	not active
    IDE00949-ENG98518	Hide cylinder-Cylinder 13	not active
    IDE00949-ENG98519	Hide cylinder-Cylinder 14	not active
    IDE00949-ENG98520	Hide cylinder-Cylinder 15	not active
    IDE00949-ENG98494	Hide cylinder-Cylinder 16	not active
    IDE00949-ENG98521	Hide cylinder-Cylinder 2	active
    IDE00949-ENG98522	Hide cylinder-Cylinder 3	active
    IDE00949-ENG98523	Hide cylinder-Cylinder 4	active
    IDE00949-ENG98495	Hide cylinder-Cylinder 5	not active
    IDE00949-ENG98524	Hide cylinder-Cylinder 6	not active
    IDE00949-ENG98496	Hide cylinder-Cylinder 7	not active
    IDE00949-ENG98497	Hide cylinder-Cylinder 8	not active
    IDE00949-ENG98498	Hide cylinder-Cylinder 9	not active
    IDE00968	Compressor speed	0	 /min
    IDE01076-MAS00109	Time since ignition off-Hours	0	 H
    IDE01076-MAS00110	Time since ignition off-Minutes	6	 min
    IDE01076-MAS00111	Time since ignition off-Seconds	36	 s
    IDE01098	Test of knock sensors: short trip result	Test not started
    IDE01196	Dynamic factor O2 sensors bank 1 or bank 3 before cat. conv.	0
    IDE01266	Coolant shut-off valve	closed
    IDE01369	Intake manifold runner control (IMRC): offset closed	0	 V
    IDE01377	Throttle valve adapter: actual value	6.1	 °
    IDE01378	High fuel pressure: control deviation	58.6	 bar
    IDE01385	Wear index	0
    IDE01405-MAS05513	Status of starter activation-Bit 0	OK
    IDE01405-MAS05514	Status of starter activation-Bit 1	Before starter activation
    IDE01405-MAS05515	Status of starter activation-Bit 2	After starter activation
    IDE01638	Result O2 sensor aging test bank 1 or 3 before cat. conv.	Test not started
    IDE01644	Oxygen sensor voltage bank 1 after catalytic converter	0.592	 V
    IDE01649	Throttle valve position 1	0.791	 V
    IDE01650	Throttle valve position 2	16	 %
    IDE01665	Result of test of camshaft adjustment intake bank 1	Test not started
    IDE01667	Result of test of camshaft adjustment outlet bank 1	Test not started
    IDE01670	Short trip status for oil pressure control	Test not started
    IDE01671	Starter control: clutch switch	not pressed
    IDE01672	Starter control: automatic start	not possible
    IDE01673-MAS05513	Starter control: readiness bits-Bit 0	Mech. test of starter not complete
    IDE01673-MAS05514	Starter control: readiness bits-Bit 1	Test of starter relay switching contacts not complete
    IDE01673-MAS05515	Starter control: readiness bits-Bit 2	Test of starter relay activation not complete
    IDE01673-MAS05516	Starter control: readiness bits-Bit 3	Test of terminal 50R return measuring line not completed
    IDE01673-MAS05517	Starter control: readiness bits-Bit 4	Test of starter request double injection not complete
    IDE01673-MAS05518	Starter control: readiness bits-Bit 5	Test of PN signal not complete
    IDE01673-MAS05519	Starter control: readiness bits-Bit 6	Test of interlock switch not complete
    IDE01673-MAS05520	Starter control: readiness bits-Bit 7	Test of clutch pedal switch not complete
    IDE01677	Result of O2 sensor test ready bank 1 after cat. conv.	Test not started
    IDE01683-MAS05304	Valve stroke switch of AVS from small to large-Cylinder 1	switched
    IDE01683-MAS05305	Valve stroke switch of AVS from small to large-Cylinder 2	switched
    IDE01683-MAS05306	Valve stroke switch of AVS from small to large-Cylinder 3	switched
    IDE01683-MAS05307	Valve stroke switch of AVS from small to large-Cylinder 4	switched
    IDE01683-MAS05308	Valve stroke switch of AVS from small to large-Cylinder 5	switched
    IDE01683-MAS05309	Valve stroke switch of AVS from small to large-Cylinder 6	switched
    IDE01683-MAS05310	Valve stroke switch of AVS from small to large-Cylinder 7	switched
    IDE01683-MAS05311	Valve stroke switch of AVS from small to large-Cylinder 8	switched
    IDE01684-MAS05304	Valve stroke switch of AVS from large to small-Cylinder 1	switched
    IDE01684-MAS05305	Valve stroke switch of AVS from large to small-Cylinder 2	switched
    IDE01684-MAS05306	Valve stroke switch of AVS from large to small-Cylinder 3	switched
    IDE01684-MAS05307	Valve stroke switch of AVS from large to small-Cylinder 4	switched
    IDE01684-MAS05308	Valve stroke switch of AVS from large to small-Cylinder 5	switched
    IDE01684-MAS05309	Valve stroke switch of AVS from large to small-Cylinder 6	switched
    IDE01684-MAS05310	Valve stroke switch of AVS from large to small-Cylinder 7	switched
    IDE01684-MAS05311	Valve stroke switch of AVS from large to small-Cylinder 8	switched
    IDE01685	Result of test of valve stroke switch AVS	Test not started
    IDE01773	Misfire sum counter	0
    IDE01774	Status misfire recognition	not active
    IDE01775	Misfires per 1000 revolutions of cylinder 1	0
    IDE01776	Misfires per 1000 revolutions of cylinder 2	0
    IDE01777	Misfires per 1000 revolutions of cylinder 3	0
    IDE01778	Misfires per 1000 revolutions of cylinder 4	0
    IDE01870	Oxygen sensor after catalytic converter: operating status	Bank 1: sensor 1 not OK
    IDE01873	Test of catalytic converter: measured value	0.016
    IDE01874	Test of catalytic converter: result	Test not started
    IDE01876	Adaptation of loss torque	-0.1	 Nm
    IDE01878	Adaptation of throttle valve	Test of closing springs ended
    IDE01880	Accelerator position 2	15	 %
    IDE01881	Adaptation of kick-down shifting point	4.126	 V
    IDE01884	Camshaft adjustment intake bank 1: activation	9.38	 %
    IDE01886	Number of high pressure incursions	0
    IDE01894	Charge press. ctrl.: adapt. higher than max. threshold	0.39	 %
    IDE01895	Charge pressure control: less than min. threshold adaptation	0.78	 %
    IDE01901	Lost torque adaptation: idle	-1	 Nm
    IDE01905	Average of ignition timing angle delay adjustment	0	 °
    IDE01906	Dynamic average of ignition timing angle delay adjustment	-1.12	 °
    IDE01912	Oxygen sensor bank 1 sensor 1: specified value	1
    IDE01913	Number of oxygen sensor dynamic tests: bank 1 sensor 1	0
    IDE01922	Vehicle distance driven	138	 km
    IDE01923	Control module distance driven	138	 km
    IDE01924	Load shift flaps: actual value	closed
    IDE01925	Load shift flaps: specified value	closed
    IDE01926	Adaptation of load shift flaps	Cancel: prerequisites have not been met
    IDE01928	Close cam shaft angle at quantity control valve	0	 °
    IDE01929	Open cam shaft angle at quantity control valve	0	 °
    IDE01931	High pressure pump injection volume control deviation	114	 mg/stroke
    IDE01932	High pressure pump injection volume	0	 mg/stroke
    IDE01975	Numb.of misfir.: cylinder 1	0
    IDE01976	Numb.of misfir.: cylinder 2	0
    IDE01977	Numb.of misfir.: cylinder 3	0
    IDE01978	Numb.of misfir.: cylinder 4	0
    IDE01986	Contact for tank leak test	Open
    IDE02116	Exhaust gas temperature before catalytic converter	224.8	 °
    IDE02119	Long term adaptation of oxygen sensor control: bank 1	0	 %
    IDE02229	Exh.gas temp.sen 1	1110	 °
    IDE02756	Number of manual engine starts	123
    IDE02757	Number of automatic engine starts	0
    IDE03008-MAS04415	Stop process prevented-Ambient air pressure	not active
    IDE03008-MAS04416	Stop process prevented-Sporadic function restriction	not active
    IDE03008-MAS04417	Stop process prevented-Poor start detection	not active
    IDE03008-MAS04590	Stop process prevented-Mixture adaptation	not active
    IDE03008-MAS06602	Stop process prevented-Engine temperature	active
    IDE03008-MAS06604	Stop process prevented-Start-stop sensor system	not active
    IDE03008-MAS06605	Stop process prevented-Regeneration operation	not active
    IDE03008-MAS06606	Stop process prevented-Brake under pressure too low	not active
    IDE03010-IDE00924	Number of prevented stop processes-Steering angle	0
    IDE03010-MAS01627	Number of prevented stop processes-Steering	0
    IDE03010-MAS02040	Number of prevented stop processes-Play protection	0
    IDE03010-MAS04415	Number of prevented stop processes-Ambient air pressure	0
    IDE03010-MAS04416	Number of prevented stop processes-Sporadic function restriction	36
    IDE03010-MAS04417	Number of prevented stop processes-Poor start detection	0
    IDE03010-MAS04589	Number of prevented stop processes-Diagnosis of exhaust system	0
    IDE03010-MAS04590	Number of prevented stop processes-Mixture adaptation	0
    IDE03010-MAS04591	Number of prevented stop processes-Diagnosis of air system	0
    IDE03010-MAS04592	Number of prevented stop processes-Hybrid battery power insufficient	0
    IDE03010-MAS04593	Number of prevented stop processes-Auxiliary consumers power too high	0
    IDE03010-MAS04595	Number of prevented stop processes-Deceleration takeover active	0
    IDE03010-MAS04805	Number of prevented stop processes-Clutch protection K0	0
    IDE03010-MAS04870	Number of prevented stop processes-Test of thermostat not complete	0
    IDE03010-MAS05758	Number of prevented stop processes-Driving situation	0
    IDE03010-MAS06602	Number of prevented stop processes-Engine temperature	274
    IDE03010-MAS06605	Number of prevented stop processes-Regeneration operation	0
    IDE03010-MAS06606	Number of prevented stop processes-Brake under pressure too low	0
    IDE03010-MAS08032	Number of prevented stop processes-Event memory entry in engine control module	0
    IDE03010-MAS09416	Number of prevented stop processes-Adaptation active	0
    IDE03010-MAS11563	Number of prevented stop processes-Engine hood open	0
    IDE03010-MAS11835	Number of prevented stop processes-Function locked due to excessive stalling	0
    IDE03010-MAS12085	Number of prevented stop processes-Brake pedal information: plausibility	0
    IDE03010-MAS12864	Number of prevented stop processes-Tighter traffic flow detected	0
    IDE03010-MAS13643	Number of prevented stop processes-E machine output too low	0
    IDE03010-MAS13644	Number of prevented stop processes-Motor protection active	0
    IDE03010-MAS13645	Number of prevented stop processes-Fuel salinization protection active	0
    IDE03010-MAS13661	Number of prevented stop processes-Exhaust emission control diagnosis	0
    IDE03010-MAS16918	Number of prevented stop processes-Restriction in the start system	0
    IDE03011-MAS01627	Number of requested start processes-Steering	0
    IDE03011-MAS04369	Number of requested start processes-Engine temperature too high	0
    IDE03011-MAS04370	Number of requested start processes-Engine temperature too low	0
    IDE03011-MAS04416	Number of requested start processes-Sporadic function restriction	0
    IDE03011-MAS04592	Number of requested start processes-Hybrid battery power insufficient	0
    IDE03011-MAS04593	Number of requested start processes-Auxiliary consumers power too high	0
    IDE03011-MAS04595	Number of requested start processes-Deceleration takeover active	0
    IDE03011-MAS06606	Number of requested start processes-Brake under pressure too low	0
    IDE03011-MAS06607	Number of requested start processes-SCR System requires restart	0
    IDE03011-MAS09730	Number of requested start processes-Cat. heater	0
    IDE03011-MAS11563	Number of requested start processes-Engine hood open	0
    IDE03011-MAS11834	Number of requested start processes-Rolling vehicle	0
    IDE03011-MAS13644	Number of requested start processes-Motor protection active	0
    IDE03011-MAS13645	Number of requested start processes-Fuel salinization protection active	0
    IDE03011-MAS16918	Number of requested start processes-Restriction in the start system	0
    IDE03108	Result of test of oxygen sensors bank 1	Test not started
    IDE03235	Neutral position sensor: current transmission angle	20	 °
    IDE03236	Neutral position sensor: adapted transmission angle	-179.96	 °
    IDE03246	Neutral position sensor: upper adaptation value	0	 V
    IDE03247	Neutral position sensor: lower adaptation value	0	 V
    IDE03262	Adapt of angle sensor 1 f throttle valve	0.503	 V
    IDE03263	Adapt of angle sensor 2 f throttle valve	4.488	 V
    IDE03264	Adaptation of angle sensor 1 throttle valve: emerg. air gap	0.791	 V
    IDE03265	Adaptation of angle sensor 2 throttle valve: emerg. air gap	4.199	 V
    IDE03267	Intake air temperature: unconditioned voltage	1.084	 V
    IDE03276	Charge air pressure sensor: unconditioned voltage	1.587	 V
    IDE03277	Intake manifold Runner Control (IMRC): unconditioned voltage	3.916	 V
    IDE03328	Transmission neutral position sensor voltage	0	 V
    IDE03361	Driver request torque	20.5	 Nm
    IDE03362	Requested transmission torque	1024	 Nm
    IDE03375	Adaptation status for transmission neutral position sensor	0
    IDE03377	Coolant temp at radiator output: unconditioned voltage	3.126	 V
    IDE03582	Temperature sensor for engine temperature management	81	 °
    IDE03585	System status for the start/stop function master	System malfunction
    IDE03587-IDE02697	Stop overrides for active participants-Multifunction unit control module	not active
    IDE03587-MAS00124	Stop overrides for active participants-A/C	not active
    IDE03587-MAS00127	Stop overrides for active participants-brakes	not active
    IDE03587-MAS00506	Stop overrides for active participants-Adaptive Cruise Control	not active
    IDE03587-MAS00832	Stop overrides for active participants-Convertible top control module	not active
    IDE03587-MAS01090	Stop overrides for active participants-Transmission	not active
    IDE03587-MAS01106	Stop overrides for active participants-Level control system	not active
    IDE03587-MAS01490	Stop overrides for active participants-Energy management	not active
    IDE03587-MAS01627	Stop overrides for active participants-Steering	not active
    IDE03587-MAS02237	Stop overrides for active participants-Body computer 1/ veh. elec sys CM / cent elec.	not active
    IDE03587-MAS02569	Stop overrides for active participants-All-wheel electronics	not active
    IDE03587-MAS03757	Stop overrides for active participants-Quattro Sport	not active
    IDE03587-MAS05129	Stop overrides for active participants-Engine	active
    IDE03587-MAS06709	Stop overrides for active participants-Keyless operation	not active
    IDE03587-MAS08785	Stop overrides for active participants-Parking aid	not active
    IDE03587-MAS13018	Stop overrides for active participants-Front sensor system for driver assistance systems	not active
    IDE03588-IDE02697	System malfunctions for active participants start/stop-Multifunction unit control module	not active
    IDE03588-MAS00124	System malfunctions for active participants start/stop-A/C	not active
    IDE03588-MAS00127	System malfunctions for active participants start/stop-brakes	not active
    IDE03588-MAS00506	System malfunctions for active participants start/stop-Adaptive Cruise Control	not active
    IDE03588-MAS00832	System malfunctions for active participants start/stop-Convertible top control module	not active
    IDE03588-MAS01090	System malfunctions for active participants start/stop-Transmission	not active
    IDE03588-MAS01106	System malfunctions for active participants start/stop-Level control system	not active
    IDE03588-MAS01490	System malfunctions for active participants start/stop-Energy management	not active
    IDE03588-MAS01627	System malfunctions for active participants start/stop-Steering	not active
    IDE03588-MAS02237	System malfunctions for active participants start/stop-Body computer 1/ veh. elec sys CM / cent elec.	not active
    IDE03588-MAS02569	System malfunctions for active participants start/stop-All-wheel electronics	not active
    IDE03588-MAS03757	System malfunctions for active participants start/stop-Quattro Sport	not active
    IDE03588-MAS05129	System malfunctions for active participants start/stop-Engine	not active
    IDE03588-MAS06709	System malfunctions for active participants start/stop-Keyless operation	not active
    IDE03588-MAS08785	System malfunctions for active participants start/stop-Parking aid	not active
    IDE03588-MAS13018	System malfunctions for active participants start/stop-Front sensor system for driver assistance systems	not active
    IDE03589-MAS01161	Error status for start-stop related sensors-Communication error	not active
    IDE03589-MAS11563	Error status for start-stop related sensors-Engine hood open	active
    IDE03589-MAS11868	Error status for start-stop related sensors-Driver door status	active
    IDE03589-MAS12097	Error status for start-stop related sensors-driver door open	active
    IDE03589-MAS12098	Error status for start-stop related sensors-Start/Stop deactivated with button	active
    IDE03589-MAS12099	Error status for start-stop related sensors-Clutch signal error	not active
    IDE03589-MAS12100	Error status for start-stop related sensors-Brake or speed signal error	not active
    IDE03589-MAS12101	Error status for start-stop related sensors-Steering signal error	not active
    IDE03692-MAS05513	Monitoring status Onboard Diagnosis camshaft and knock sensor-Bit 0	Test of camshaft adjustment bank 2 outlet not complete
    IDE03692-MAS05514	Monitoring status Onboard Diagnosis camshaft and knock sensor-Bit 1	Test of camshaft adjustment bank 1 outlet not complete
    IDE03692-MAS05515	Monitoring status Onboard Diagnosis camshaft and knock sensor-Bit 2	Test of camshaft adjustment bank 2 intake not complete
    IDE03692-MAS05516	Monitoring status Onboard Diagnosis camshaft and knock sensor-Bit 3	Test of camshaft adjustment bank 1 intake complete
    IDE03692-MAS05517	Monitoring status Onboard Diagnosis camshaft and knock sensor-Bit 4	Test of knock sensor 4 not complete
    IDE03692-MAS05518	Monitoring status Onboard Diagnosis camshaft and knock sensor-Bit 5	Test of knock sensor 3 not complete
    IDE03692-MAS05519	Monitoring status Onboard Diagnosis camshaft and knock sensor-Bit 6	Test of knock sensor 2 not complete
    IDE03692-MAS05520	Monitoring status Onboard Diagnosis camshaft and knock sensor-Bit 7	Test of knock sensor 1 complete
    IDE03693-MAS05513	Monitoring status of additional Onboard Diagnosis-Bit 0	Test of brake light switch not complete
    IDE03693-MAS05514	Monitoring status of additional Onboard Diagnosis-Bit 1	Test of clutch switch not complete
    IDE03693-MAS05515	Monitoring status of additional Onboard Diagnosis-Bit 2	Test of idle control complete
    IDE03693-MAS05516	Monitoring status of additional Onboard Diagnosis-Bit 3	Test of coolant temperature sensor not complete
    IDE03693-MAS05517	Monitoring status of additional Onboard Diagnosis-Bit 4	Test of throttle valve potentiometer not complete
    IDE03693-MAS05518	Monitoring status of additional Onboard Diagnosis-Bit 5	Test of thermostat complete
    IDE03693-MAS05519	Monitoring status of additional Onboard Diagnosis-Bit 6	Test of charge pressure control complete
    IDE03693-MAS05520	Monitoring status of additional Onboard Diagnosis-Bit 7	Test of CCS switch not complete
    IDE03693-MAS05521	Monitoring status of additional Onboard Diagnosis-Bit 8	Test of oxygen adaptation bank 1 complete
    IDE03711	Mass flow through throttle valve	0	 kg/h
    IDE03767	Engine status	Stop
    IDE03795	Camshaft adjustment: exhaust: bank 1: activation	9.37	 %
    IDE03806	Oxygen sensor bank 1 sensor 1: status	0
    IDE03807	Oxygen sensor bank 1 sensor 2: status	0
    IDE03816	Exhaust flap bank 1	Open
    IDE03818	Heated oxygen sensor bank 1: sensor 2: resistance	65535	 Ohm
    IDE03819	Heated oxygen sensor bank 1: sensor 2: activation	0	 %
    IDE03820	Heated oxygen sensor bank 1: sensor 1: resistance	16383	 Ohm
    IDE03821	Heated oxygen sensor bank 1: sensor 1: activation	0	 %
    IDE03832	Oxygen sensor bank 1 sensor 2: response time	0	 ms
    IDE03834	Oxygen sensor bank 1 sensor 2: response time filtered	0	 ms
    IDE03836	Result of O2 sensor aging test bank 1 after cat. conv.	Test not started
    IDE03892	Fuel high pressure sensor: unconditioned voltage	1.117	 V
    IDE03918	Engine reverse rotation recognition	not recognized
    IDE03919	Oxygen regulation operability and status	OFF
    IDE03920	Oxygen adaptation status	Initializing
    IDE03921	Mixture adaptation factor at partial load	-1.77	 %
    IDE03922	Mixture adaptation factor at idle speed	0	 %
    IDE03923	Adaptive long-term value of mix. condition after cat. conv	0
    IDE03924	Relay for reserve coolant pump: status	not activated
    IDE03928	Counter for fuel entry in oil	0
    IDE03930	Charge pressure actuator: operating status	Operating mode
    IDE03931	Charge pressure actuator: actual position	57.98	 %
    IDE03932	Charge pressure actuator: specified position	0	 %
    IDE03933	Charge pressure actuator: specified value	0	 %
    IDE03934	Charge pressure actuator: adaptation for lower stop	3.525	 V
    IDE03935	Charge pressure actuator: adaptation for upper stop	0.57	 V
    IDE03953	Oxygen control: adaptation value at partial load: bank 1	-1.77	 %
    IDE03957	Throttle valve angle: specified value	6	 °
    IDE03963	Low fuel pressure adaptation value for EFP	1200	 mbar
    IDE03966	Transmission neutral position sensor PWM signal	0	 %
    IDE03998	Clutch Position Sensor	99.61	 %
    IDE04002	Charge press. ctrl.	BP_A act:98	 kPa
    IDE04405	Mixture deviation in adapted partial load range 1	0	 %
    IDE04409	Intake manifold pressure: corrected	0.982	 bar
    IDE04410	Intake manifold pressure: target value	0	 bar
    IDE04412	Pressure before throttle valve: corrected	0.982	 bar
    IDE04415	Oxygen ctrl factor with precontrol correction	0	 %
    IDE04420	Activation of secondary air system	Atmosphere/off
    IDE04629	AVS operating condition	No enabling
    IDE04630	AVS valve stroke position: current	Standard
    IDE04632-MAS05304	AVS error status of last switch-over standard stroke direction-Cylinder 1	OK
    IDE04632-MAS05305	AVS error status of last switch-over standard stroke direction-Cylinder 2	OK
    IDE04632-MAS05306	AVS error status of last switch-over standard stroke direction-Cylinder 3	OK
    IDE04632-MAS05307	AVS error status of last switch-over standard stroke direction-Cylinder 4	OK
    IDE04632-MAS05308	AVS error status of last switch-over standard stroke direction-Cylinder 5	OK
    IDE04632-MAS05309	AVS error status of last switch-over standard stroke direction-Cylinder 6	OK
    IDE04632-MAS05310	AVS error status of last switch-over standard stroke direction-Cylinder 7	OK
    IDE04632-MAS05311	AVS error status of last switch-over standard stroke direction-Cylinder 8	OK
    IDE04633-MAS05304	AVS error status of last switch-over AVS stroke direction-Cylinder 1	OK
    IDE04633-MAS05305	AVS error status of last switch-over AVS stroke direction-Cylinder 2	OK
    IDE04633-MAS05306	AVS error status of last switch-over AVS stroke direction-Cylinder 3	OK
    IDE04633-MAS05307	AVS error status of last switch-over AVS stroke direction-Cylinder 4	OK
    IDE04633-MAS05308	AVS error status of last switch-over AVS stroke direction-Cylinder 5	OK
    IDE04633-MAS05309	AVS error status of last switch-over AVS stroke direction-Cylinder 6	OK
    IDE04633-MAS05310	AVS error status of last switch-over AVS stroke direction-Cylinder 7	OK
    IDE04633-MAS05311	AVS error status of last switch-over AVS stroke direction-Cylinder 8	OK
    IDE04634	AVS switch-over meter for reg activation of curr. drive cycle	0
    IDE04635	AVS switch-over meter: total	8
    IDE04636	AVS overflow meter for all switch-overs	0
    IDE04637	Engine temperature management actuator	99.75	 %
    IDE04638	Transmission coolant valve	closed
    IDE04677	O2 sensor 1 bank 1: O2 sensor actual value	1
    IDE04680	O2 sensor 1: bank 1: voltage raw value O2 signal	1.997	 V
    IDE04713	Active brake system status	Not operated
    IDE04814	Transmission oil cooler valve	closed
    IDE04937	Sensor for engine block temperature: raw value	-48	 °
    IDE05140	Intake manifold pressure raw value	0.984	 bar
    IDE05259	Gear position sensor: raw value	0	 %
    IDE05260	Gear position sensor: current value	Neutral
    IDE05261	Gear position sensor: last valid value	Neutral
    IDE05262	Gear position sensor: gear position valid	invalid
    IDE05310	Charge air pressure control valve position: target value	0	 %
    IDE05311	Charge air pressure control valve position: actual value	57.98	 %
    IDE05312	Charge air pressure control valve uncond voltage sensor	1.2842	 V
    IDE05313	Charge air pressure control valve activation pulse duty factor	0	 %
    IDE05314-ENG112584	Status of charge air pressure control valve basic setting-LV_BPA_AD_REQ[0]	0
    IDE05315	Charge air pressure control valve voltage: position closed	3.5254	 V
    IDE05316	Charge air pressure control valve voltage: position open	0.5701	 V
    IDE05317-ENG112583	Charge air pressure control valve adaptation performed-LV_BPA_AD_ASA_SUC[0]	0
    IDE05508	Adaptation val cyl 1 with slow diagnosis	0
    IDE05509	Adaptation val cyl 3 with slow diagnosis	0
    IDE05510	Adaptation val cyl 4 with slow diagnosis	0
    IDE05511	Adaptation val cyl 2 with slow diagnosis	0
    IDE05512	Adaptation val cyl 1 with fast diagnosis	0
    IDE05513	Adaptation val cyl 3 with fast diagnosis	0
    IDE05514	Adaptation val cyl 4 with fast diagnosis	0
    IDE05515	Adaptation val cyl 2 with fast diagnosis	0
    IDE05593	Secondary air injection sensor 1	0.984	 bar
    IDE05622-ENG125277	Status of tank leak diagnosis with electrical diagnostic pump-STATE_DMTL_EOL	0
    IDE06006	Idle speed specified value	1100	 /min
    IDE06192	Knock sensor: cylinder 2: voltage	2.5	 V
    IDE06193	Knock sensor: cylinder 3: voltage	2.5	 V
    IDE06194	Knock sensor: cylinder 4: voltage	2.5	 V
    IDE06195	Knock sensor: cylinder 1: voltage	2.5	 V
    IDE06296-ENG104200	Activation of oxygen control after main cat-Lambda probe 2: bank 1: status	0
    IDE06307-MAS00106	Stop prevention history data-Year	2018
    IDE06307-MAS00107	Stop prevention history data-Month	8
    IDE06307-MAS00108	Stop prevention history data-Day	26
    IDE06307-MAS00109	Stop prevention history data-Hours	10
    IDE06307-MAS00110	Stop prevention history data-Minutes	33
    IDE06307-MAS00111	Stop prevention history data-Seconds	2
    IDE06307	Stop prevention history data	not active
    IDE06307	Stop prevention history data	Engine temperature
    IDE06308-MAS00106	Start request history data-Year	2127
    IDE06308-MAS00107	Start request history data-Month	15
    IDE06308-MAS00108	Start request history data-Day	31
    IDE06308-MAS00109	Start request history data-Hours	31
    IDE06308-MAS00110	Start request history data-Minutes	63
    IDE06308-MAS00111	Start request history data-Seconds	63
    IDE06308	Start request history data	Hybrid battery power insufficient
    IDE06308	Start request history data	Steering
    IDE06308	Start request history data	Cat. heater
    IDE06308	Start request history data	Restriction in the start system
    IDE06308	Start request history data	Engine temperature too low
    IDE06308	Start request history data	Brake under pressure too low
    IDE06308	Start request history data	Fuel salinization protection active
    IDE06308	Start request history data	Deceleration takeover active
    IDE06308	Start request history data	Motor protection active
    IDE06308	Start request history data	SCR System requires restart
    IDE06308	Start request history data	Engine hood open
    IDE06308	Start request history data	Rolling vehicle
    IDE06308	Start request history data	Auxiliary consumers power too high
    IDE06308	Start request history data	Engine temperature too high
    IDE06308	Start request history data	Sporadic function restriction
    IDE06386	Oil level: static measurement	0	 mm
    IDE06387	Oil level: last valid dynamic value	0	 mm
    IDE06388	Oil level: condition for static measurement fulfilled	Condition not met
    IDE06389	Oil level: maximum value	-127	 mm
    IDE06390	Oil level: minimum value	127	 mm
    IDE06391	Oil temperature sensor 2	66	 °
    IDE06392	Oil temperature sensor 2: raw value	65.535	 V
    IDE06393	Oil level: dynamic average value	0	 mm
    IDE06394	Sensor 1 for secondary air pressure: unconditioned voltage	2.437	 V
    IDE06395	Fuel low pressure sensor: unconditioned voltage	4.995	 V
    IDE06396	Coolant temperature at engine outlet: unconditioned voltage	1.168	 V
    IDE06397	Temperature sensor for engine temp. management: target value	107.3	 °
    IDE06398	Temperature sensor for engine temp. management: uncond. voltage	1.167	 V
    IDE06399	Manifold absolute pressure sensor: unconditioned voltage	1.689	 V
    IDE06425-IDE02766	Roller test bench mode: functional-Malfunction status	no error
    IDE06425-MAS06026	Roller test bench mode: functional-Activation stages	not activated
    IDE06432	Oxygen sensor 1 bank 1 signal status	not active
    IDE06444	Oxygen sensor before cat bank 1 (LSB) voltage	1.997	 V
    IDE06567	Start-stop function deactivation frequency counter	0
    IDE06568	Stop prevention by driver frequency counter	0
    IDE06569	Vehicle stopped frequency counter	0
    IDE06573	Long-term adaptation of intake manifold injection	0	 %
    IDE06574	Long-term adaptation of intake manifold injection in idle	0	 mg/stroke
    IDE06610	Vehicle standstill with stop frequency counter	0
    IDE06703-IDE12714	Drivetrain coordinator: ACC fault status-ACC is active despite EPB deceleration	No
    IDE06703-MAS14977	Drivetrain coordinator: ACC fault status-ACC active: although TSK passive	No
    IDE06703-MAS14978	Drivetrain coordinator: ACC fault status-Start off or stop request at stopping speed not set	No
    IDE06703-MAS14979	Drivetrain coordinator: ACC fault status-Start off and stop request sent simultaneously	No
    IDE06703-MAS14980	Drivetrain coordinator: ACC fault status-ACC active: although limiter active	No
    IDE06703-MAS14981	Drivetrain coordinator: ACC fault status-ACC reactivates itself after locking	No
    IDE06703-MAS14982	Drivetrain coordinator: ACC fault status-ACC sends undefined signals	No
    IDE06703-MAS14983	Drivetrain coordinator: ACC fault status-ACC active although main switch off	No
    IDE06703-MAS14984	Drivetrain coordinator: ACC fault status-ACC is active despite driver braking	No
    IDE06703-MAS14985	Drivetrain coordinator: ACC fault status-ACC is active despite ESP/ASR passive sampling	No
    IDE06704-MAS14986	Drivetrain coordinator: brake fault status-Deceleration sensor not available	No
    IDE06704-MAS14987	Drivetrain coordinator: brake fault status-Deceleration sensor malfunction	No
    IDE06704-MAS14988	Drivetrain coordinator: brake fault status-ESP system error	No
    IDE06704-MAS14989	Drivetrain coordinator: brake fault status-ESP system malfunction due to inaccurate engine torque	No
    IDE06704-MAS14990	Drivetrain coordinator: brake fault status-ESP indicates TSK message consistency error	No
    IDE06704-MAS14991	Drivetrain coordinator: brake fault status-TSK/ESP handshake error	No
    IDE06704-MAS14992	Drivetrain coordinator: brake fault status-ESP automatic engagement malfunction	No
    IDE06704-MAS14993	Drivetrain coordinator: brake fault status-Brake light implausible	No
    IDE06705-MAS05179	Drivetrain coordinator: brake function status-ABS intervention	No
    IDE06705-MAS05180	Drivetrain coordinator: brake function status-ESP intervention	No
    IDE06705-MAS05181	Drivetrain coordinator: brake function status-EDL intervention	No
    IDE06705-MAS05186	Drivetrain coordinator: brake function status-ASR intervention	No
    IDE06705-MAS05187	Drivetrain coordinator: brake function status-MSR intervention	No
    IDE06705-MAS05192	Drivetrain coordinator: brake function status-Driver braking	No
    IDE06705-MAS05195	Drivetrain coordinator: brake function status-HDC active	No
    IDE06705-MAS15001	Drivetrain coordinator: brake function status-ESP invokes TSK braking	No
    IDE06705-MAS15002	Drivetrain coordinator: brake function status-EPB active	No
    IDE06705-MAS15003	Drivetrain coordinator: brake function status-ASP intervention	No
    IDE06705-MAS15004	Drivetrain coordinator: brake function status-ADS intervention	No
    IDE06705-MAS15006	Drivetrain coordinator: brake function status-Stopping distance reduction2 warning jolt	No
    IDE06705-MAS15007	Drivetrain coordinator: brake function status-ESP sampled passive (ESP off)	No
    IDE06705-MAS15008	Drivetrain coordinator: brake function status-ASR sampled passive (ASR off)	No
    IDE06705-MAS15009	Drivetrain coordinator: brake function status-ESP recognizes vehicle at rest	No
    IDE06705-MAS15010	Drivetrain coordinator: brake function status-ACC stopping distance control active	No
    IDE06706	ACC variants	ACC
    IDE06707	CCS Switch	CCS operating unit
    IDE06709	ACC variants (coding)	CCS
    IDE06710	Cruise control system: permanent deactivation	No switch-off occurs
    IDE06726	Timing deviation after chain replacement: intake bank 1	-1.44	 °
    IDE06728	Timing deviation after chain replacement: exhaust bank 1	0	 °
    IDE06730	Timing deviation after other repairs: intake bank 1	0	 °
    IDE06732	Timing deviation after other repairs: exhaust bank 1	0	 °
    IDE06734	Timing deviation: current value intake bank 1	0	 °
    IDE06736	Timing deviation: current value exhaust bank 1	0	 °
    IDE06738	Chain elongation: no. of valid initial values: intake bank 1	1
    IDE06740	Chain elongation: no. of valid initial values: exhaust bank 1	0
    IDE06742	Chain elongation: initial values valid: intake bank 1	not active
    IDE06744	Chain elongation: initial values valid: exhaust bank 1	not active
    IDE07001	Piston-cooling jets: activation	On
    IDE07008	Tank leak: number no leak detected	19
    IDE07011	Tank leak: number communication errors to engine control	6
    IDE07014	Tank leak: number very small leaks detected	0
    IDE07019	Number of ignitions direct injection	1021392
    IDE07020	Number of ignitions intake manifold injection	0
    IDE07023	Misfires per 1000 revolutions of cyl. 1 intake manif. injection	0
    IDE07024	Misfires per 1000 revolutions of cyl. 2 intake manif. injection	0
    IDE07025	Misfires per 1000 revolutions of cyl. 3 intake manif. injection	0
    IDE07026	Misfires per 1000 revolutions of cyl. 4 intake manif. injection	0
    IDE07027	Heat quantity that was transported via the catalytic converter	2.43E+08	 J
    IDE07031	Oil pressure switch for piston-cooling jets: status	Open
    IDE07242	Heater support pump: spec. value	10	 %
    IDE07548	Engine temp. mangmt. actuator: specified value of angle	88.75	 °
    IDE07549	Engine temp. mangmt. actuator: actual value of angle	88.72	 °
    IDE07550	Engine temp. management actuator: raw value	1470
    IDE07551	Engine temp. management actuator: duty cycle activation	0	 %
    IDE07552	Engine temper.managem.actuator adaptation: result adaptation	Adaptation successfully finished
    IDE07553	Engine temperature management actuator: after-run stop	3961
    IDE07554	Engine temperature management actuator: stop open	141
    IDE07564	Required torque adjustment by idling regulator	0	 Nm
    IDE07571	Engine torque	-16.5	 Nm
    IDE07572	High pressure regulation: adaptation value	-5.3	 mg
    IDE07574	Long-term fuel trim bank 1 at idle	0	 mg/stroke
    IDE07575	Driver request torque	4	 Nm
    IDE07576	Lost torque adaptation driving mode	3.3	 Nm
    IDE07577	Lost torque adaptation A/C compressor and driving mode	-6.8	 Nm
    IDE07598-MAS00320	Cruise control switch actuation-Main switch	not activated
    IDE07598-MAS00325	Cruise control switch actuation-Setting	not activated
    IDE07598-MAS00326	Cruise control switch actuation-Activation	not activated
    IDE07598-MAS01632	Cruise control switch actuation-Status	OK
    IDE07598-MAS02309	Cruise control switch actuation-Accelerate	not activated
    IDE07598-MAS02310	Cruise control switch actuation-Decelerate	not activated
    IDE07598-MAS05172	Cruise control switch actuation-Cancel	not activated
    IDE07598-MAS05806	Cruise control switch actuation-Main switch hardware	not activated
    IDE07598-MAS05807	Cruise control switch actuation-Coding	plausible
    IDE07598-MAS05809	Cruise control switch actuation-Limit function	not selected
    IDE07598-MAS05812	Cruise control switch actuation-Limit button	not activated
    IDE07598-MAS05813	Cruise control switch actuation-Main switch CAN	not activated
    IDE07598-MAS05842	Cruise control switch actuation-Large increment	not activated
    IDE07598-MAS05843	Cruise control switch actuation-Control component verified	Yes
    IDE07599-MAS01505	Drivetrain coord: cause of shutdown in cruise cntr and ACC mode-Engine off	Yes
    IDE07599-MAS03849	Drivetrain coord: cause of shutdown in cruise cntr and ACC mode-Crash signal	No
    IDE07599-MAS04795	Drivetrain coord: cause of shutdown in cruise cntr and ACC mode-main switch off	Yes
    IDE07599-MAS05135	Drivetrain coord: cause of shutdown in cruise cntr and ACC mode-Open or no gear selected	No
    IDE07599-MAS05136	Drivetrain coord: cause of shutdown in cruise cntr and ACC mode-Hill descent control	No
    IDE07599-MAS05190	Drivetrain coord: cause of shutdown in cruise cntr and ACC mode-Parking brake or hand brake actuated	No
    IDE07599-MAS05192	Drivetrain coord: cause of shutdown in cruise cntr and ACC mode-Driver braking	No
    IDE07599-MAS05196	Drivetrain coord: cause of shutdown in cruise cntr and ACC mode-Speed signal error	No
    IDE07599-MAS05814	Drivetrain coord: cause of shutdown in cruise cntr and ACC mode-CAN communication error	No
    IDE07599-MAS05815	Drivetrain coord: cause of shutdown in cruise cntr and ACC mode-CAN signal error	No
    IDE07599-MAS05816	Drivetrain coord: cause of shutdown in cruise cntr and ACC mode-ESP control response error	No
    IDE07599-MAS05817	Drivetrain coord: cause of shutdown in cruise cntr and ACC mode-RPM limitation	No
    IDE07599-MAS05818	Drivetrain coord: cause of shutdown in cruise cntr and ACC mode-Transmission coding not plausible	No
    IDE07599-MAS05819	Drivetrain coord: cause of shutdown in cruise cntr and ACC mode-ACC active during braking	No
    IDE07599-MAS05820	Drivetrain coord: cause of shutdown in cruise cntr and ACC mode-ACC error	No
    IDE07599-MAS05821	Drivetrain coord: cause of shutdown in cruise cntr and ACC mode-Braking intervention too weak	No
    IDE07599-MAS05822	Drivetrain coord: cause of shutdown in cruise cntr and ACC mode-Braking control not available	No
    IDE07599-MAS05823	Drivetrain coord: cause of shutdown in cruise cntr and ACC mode-Speed signal error during initialization	No
    IDE07599-MAS05824	Drivetrain coord: cause of shutdown in cruise cntr and ACC mode-Emer. engine operation	No
    IDE07599-MAS05825	Drivetrain coord: cause of shutdown in cruise cntr and ACC mode-Engine control module fault	No
    IDE07599-MAS05826	Drivetrain coord: cause of shutdown in cruise cntr and ACC mode-Torque reduction due to fault	No
    IDE07599-MAS05827	Drivetrain coord: cause of shutdown in cruise cntr and ACC mode-Diagnosis requirements not met	No
    IDE07599-MAS05828	Drivetrain coord: cause of shutdown in cruise cntr and ACC mode-Brake excess temperature	No
    IDE07599-MAS05829	Drivetrain coord: cause of shutdown in cruise cntr and ACC mode-Brake light fault	No
    IDE07599-MAS05830	Drivetrain coord: cause of shutdown in cruise cntr and ACC mode-CCS deactivated due to fault in control component	No
    IDE07599-MAS05831	Drivetrain coord: cause of shutdown in cruise cntr and ACC mode-ACC deactivated due to fault in control component	No
    IDE07599-MAS05832	Drivetrain coord: cause of shutdown in cruise cntr and ACC mode-Coding error	No
    IDE07599-MAS05833	Drivetrain coord: cause of shutdown in cruise cntr and ACC mode-ESC error	No
    IDE07599-MAS05834	Drivetrain coord: cause of shutdown in cruise cntr and ACC mode-Brake pedal fault	No
    IDE07599-MAS05835	Drivetrain coord: cause of shutdown in cruise cntr and ACC mode-Clutch pedal fault	No
    IDE07599-MAS05836	Drivetrain coord: cause of shutdown in cruise cntr and ACC mode-Acceleration monitoring error	No
    IDE07599-MAS05837	Drivetrain coord: cause of shutdown in cruise cntr and ACC mode-ACC control response error	No
    IDE07605	Cruise control system: temporary deactivation	No switch-off
    IDE07669	Oxygen sensor 2 Bank 1 after cat operation readiness Status	not active
    IDE07901	Error counter bad fuel	0
    IDE07904-ENG118117	Brake test switch status-actuated__activated	not activated
    IDE07904-ENG114825	Brake test switch status-Ident_32	0
    IDE07905-ENG118117	Brake light switch status-actuated__activated	not activated
    IDE07905-ENG114825	Brake light switch status-Ident_32	0
    IDE07906-ENG118117	Upper clutch switch: status-actuated__activated	not activated
    IDE07906-ENG114825	Upper clutch switch: status-Ident_32	0
    IDE07945-MAS00334	Status of intermittent monitoring-Catalytic converter monitoring	completed successfully
    IDE07945-MAS00335	Status of intermittent monitoring-Monitoring of catalytic converter at operating temperature	completed successfully
    IDE07945-MAS00336	Status of intermittent monitoring-Monitoring of tank ventilation system	not completed successfully
    IDE07945-MAS00337	Status of intermittent monitoring-Monitoring of Secondary Air Injection (AIR) system	completed successfully
    IDE07945-MAS00338	Status of intermittent monitoring-Monitoring of A/C system refrigerant	completed successfully
    IDE07945-MAS00339	Status of intermittent monitoring-Monitoring of oxygen sensor	completed successfully
    IDE07945-MAS00340	Status of intermittent monitoring-Monitoring of oxygen sensor heater	completed successfully
    IDE07945-MAS00341	Status of intermittent monitoring-Monitoring of Exhaust Gas recirc. (EGR)	not completed successfully
    IDE08071-ENG119931	Remote start cancellation reason store 1-LF_ST_REQ_EXT_DVC_DEAC_1	0
    IDE08072-ENG119932	Remote start cancellation reason store 2-LF_ST_REQ_EXT_DVC_DEAC_2	0
    IDE08073-ENG119933	Remote start cancellation reason store 3-LF_ST_REQ_EXT_DVC_DEAC_3	0
    IDE08074-ENG119934	Remote start cancellation reason store 4-LF_ST_REQ_EXT_DVC_DEAC_4	0
    IDE08075-ENG119935	Remote start cancellation reason store 5-LF_ST_REQ_EXT_DVC_DEAC_5	0
    IDE08495	Activation radiator shutter result	0	 %
    IDE08805	EVAP valve diag. activation condition at minimal load	0	 counts
    IDE08806	EVAP valve diag. activation condition at maximum load	2	 mbar
    IDE10366	Chg. press. ctrl. valve: sensor voltage max. value	3.568	 V
    IDE10380	Knock sensor average voltage bank 1	0	 V
    IDE10551-MAS05304	Pre-ignition counter for oxygen shift-Cylinder 1	0
    IDE10551-MAS05305	Pre-ignition counter for oxygen shift-Cylinder 2	0
    IDE10551-MAS05306	Pre-ignition counter for oxygen shift-Cylinder 3	0
    IDE10551-MAS05307	Pre-ignition counter for oxygen shift-Cylinder 4	0
    IDE10551-MAS05308	Pre-ignition counter for oxygen shift-Cylinder 5	0
    IDE10551-MAS05309	Pre-ignition counter for oxygen shift-Cylinder 6	0
    IDE10551-MAS05310	Pre-ignition counter for oxygen shift-Cylinder 7	0
    IDE10551-MAS05311	Pre-ignition counter for oxygen shift-Cylinder 8	0
    IDE10552-MAS05304	Pre-ignition counter for torque reduction-Cylinder 1	0
    IDE10552-MAS05305	Pre-ignition counter for torque reduction-Cylinder 2	0
    IDE10552-MAS05306	Pre-ignition counter for torque reduction-Cylinder 3	0
    IDE10552-MAS05307	Pre-ignition counter for torque reduction-Cylinder 4	0
    IDE10552-MAS05308	Pre-ignition counter for torque reduction-Cylinder 5	0
    IDE10552-MAS05309	Pre-ignition counter for torque reduction-Cylinder 6	0
    IDE10552-MAS05310	Pre-ignition counter for torque reduction-Cylinder 7	0
    IDE10552-MAS05311	Pre-ignition counter for torque reduction-Cylinder 8	0
    IDE10553-MAS05304	Pre-ignition counter: cylinder suppress. pre-ignition-Cylinder 1	0
    IDE10553-MAS05305	Pre-ignition counter: cylinder suppress. pre-ignition-Cylinder 2	0
    IDE10553-MAS05306	Pre-ignition counter: cylinder suppress. pre-ignition-Cylinder 3	0
    IDE10553-MAS05307	Pre-ignition counter: cylinder suppress. pre-ignition-Cylinder 4	0
    IDE10553-MAS05308	Pre-ignition counter: cylinder suppress. pre-ignition-Cylinder 5	0
    IDE10553-MAS05309	Pre-ignition counter: cylinder suppress. pre-ignition-Cylinder 6	0
    IDE10553-MAS05310	Pre-ignition counter: cylinder suppress. pre-ignition-Cylinder 7	0
    IDE10553-MAS05311	Pre-ignition counter: cylinder suppress. pre-ignition-Cylinder 8	0
    IDE10554-MAS05304	Pre-ignition counter: cylinder suppress. glow ignition-Cylinder 1	0
    IDE10554-MAS05305	Pre-ignition counter: cylinder suppress. glow ignition-Cylinder 2	0
    IDE10554-MAS05306	Pre-ignition counter: cylinder suppress. glow ignition-Cylinder 3	0
    IDE10554-MAS05307	Pre-ignition counter: cylinder suppress. glow ignition-Cylinder 4	0
    IDE10554-MAS05308	Pre-ignition counter: cylinder suppress. glow ignition-Cylinder 5	0
    IDE10554-MAS05309	Pre-ignition counter: cylinder suppress. glow ignition-Cylinder 6	0
    IDE10554-MAS05310	Pre-ignition counter: cylinder suppress. glow ignition-Cylinder 7	0
    IDE10554-MAS05311	Pre-ignition counter: cylinder suppress. glow ignition-Cylinder 8	0
    IDE10922	Pump current of tank leakage diag.: corrected & filtered	0	 mA
    IDE10970-MAS11563	Number of prevented stop processes-Engine hood open	0
    IDE10970-MAS11835	Number of prevented stop processes-Function locked due to excessive stalling	0
    IDE10970-MAS12085	Number of prevented stop processes-Brake pedal information: plausibility	0
    IDE10989-MAS00106	Immobilizer: historic data-Year	2127
    IDE10989-MAS00107	Immobilizer: historic data-Month	15
    IDE10989-MAS00108	Immobilizer: historic data-Day	31
    IDE10989-MAS00109	Immobilizer: historic data-Hours	31
    IDE10989-MAS00110	Immobilizer: historic data-Minutes	63
    IDE10989-MAS00111	Immobilizer: historic data-Seconds	63
    IDE10989	Immobilizer: historic data	Engine hood open
    IDE10989	Immobilizer: historic data	Brake pedal information: plausibility
    IDE10989	Immobilizer: historic data	Function locked due to excessive stalling
    IDE10994	Poor start counter at start-stop	0
    IDE11115	Start/stop driver request: counter restart by starter	0
    IDE11116	Start/stop driver request: counter internal-motor restart	0
    IDE11598	Tank deaeration valve diagnosis: unweighted input value	0	 counts
    IDE11599	Tank deaeration valve diagnosis: weighted output value	0	 counts
    IDE11600	Tank tightness: ambient temperature	-48	 °C
    IDE11919	Lock time for cooling down of secondary air pump	0	 s
    IDE12137	Tank fill level diagnostic reference value	54	 l
    IDE12138	Fuel consumption per driving cycle	92.52	 l/100km
    ENG102981	AC compressor: speed increase	0
    ENG103860	AC request: speed increase	0
    ENG103042	Accelerator pedal sender: learned end stop	4.126	 V
    ENG103719	Accelerator position	0	 %
    ENG101488	ACF: load	0
    ENG103474	Activation of oil pressure switching valve	0
    ENG103323	Additional water pump	1
    ENG101828	Air mass	0	 kg/h
    ENG104264	Alternator load	0	 W
    ENG103910	Ambient temperature	21	 °C
    ENG112539	AR_THR_AD_ADD_MMV	-0.008	 cm²
    ENG98377	As	none
    ENG103165	Battery voltage	14.4	 V
    ENG07601	Bypasstool_a2l_name	ORIGINAL A2L
    ENG07600	Bypasstool_manipulation_bit	not active
    ENG101413	Calibration Identification	8V0264M 0001AXAK
    ENG99697	Calibration Verification Number	C8 7B A4 D6
    ENG128780	CAM_DIF_VCP[EX_1]	0	 °
    ENG128781	CAM_DIF_VCP[IN_1]	0	 °
    ENG102002	CAM_OFS_IVVT_IN[1]	0	 °
    ENG112540	CAM_PHA_ENG[GES_EX][CBK_1]	0	 °
    ENG112541	CAM_PHA_ENG[GES_IN][CBK_1]	0	 °
    ENG101169	CAM_PHA_OFS_MAF[IN][1]	0	 °
    ENG112542	CAM_SP_IND_VCP[EX_1]	0	 °
    ENG112543	CAM_SP_IND_VCP[IN_1]	0	 °
    ENG112544	CAM_VCP[EX_1]	0	 °
    ENG112545	CAM_VCP[IN_1]	0	 °
    ENG103849	Cat. ageing: bank 1: actual	0.016
    ENG101785	Cat. temperature: bank 1	262.0375	 °C
    ENG102214	CPU_LOAD	41.4	 %
    ENG125189	CTR_CAM_IN_SP_PI_DET_REQ[0]	0
    ENG125190	CTR_CAM_IN_SP_PI_DET_REQ[1]	0
    ENG125191	CTR_CAM_IN_SP_PI_DET_REQ[2]	0
    ENG125192	CTR_CAM_IN_SP_PI_DET_REQ[3]	0
    ENG101127	CTR_CDN_OBD_RBM	6
    ENG114826	CTR_EDGE_CAM_EX[1]	0
    ENG114827	CTR_EDGE_CAM_IN[1]	0
    ENG100536	CTR_IGK_CYC_RBM	123
    ENG125193	CTR_LAMB_SP_PI_REQ[0]	0
    ENG125194	CTR_LAMB_SP_PI_REQ[1]	0
    ENG125195	CTR_LAMB_SP_PI_REQ[2]	0
    ENG125196	CTR_LAMB_SP_PI_REQ[3]	0
    ENG112554	CTR_MIS_DC_MMV_CYL_SAE[0]	0
    ENG112555	CTR_MIS_DC_MMV_CYL_SAE[1]	0
    ENG112556	CTR_MIS_DC_MMV_CYL_SAE[2]	0
    ENG112557	CTR_MIS_DC_MMV_CYL_SAE[3]	1
    ENG112558	CTR_MIS_TOT_NVMY_SAE	120
    ENG125197	CTR_REQ_IV_OFF_PI_FAST[0]	0
    ENG125198	CTR_REQ_IV_OFF_PI_FAST[1]	0
    ENG125199	CTR_REQ_IV_OFF_PI_FAST[2]	0
    ENG125200	CTR_REQ_IV_OFF_PI_FAST[3]	0
    ENG125201	CTR_REQ_IV_OFF_PI_SLOW[0]	0
    ENG125202	CTR_REQ_IV_OFF_PI_SLOW[1]	0
    ENG125203	CTR_REQ_IV_OFF_PI_SLOW[2]	0
    ENG125204	CTR_REQ_IV_OFF_PI_SLOW[3]	0
    ENG128782	CTR_REQ_IV_OFF_PI_SLOW_TMP[0]	0
    ENG128783	CTR_REQ_IV_OFF_PI_SLOW_TMP[1]	0
    ENG128784	CTR_REQ_IV_OFF_PI_SLOW_TMP[2]	0
    ENG128785	CTR_REQ_IV_OFF_PI_SLOW_TMP[3]	0
    ENG100764	CTR_SUM_SRV_INTL	0
    ENG125205	CTR_TQI_POW_MAX_PI_REQ[0]	0
    ENG125206	CTR_TQI_POW_MAX_PI_REQ[1]	0
    ENG125207	CTR_TQI_POW_MAX_PI_REQ[2]	0
    ENG125208	CTR_TQI_POW_MAX_PI_REQ[3]	0
    ENG119929	CTR_VLD_CAT_GAP_AFL[1]	0
    ENG119930	CTR_VLD_CAT_GAP_AFR[1]	0
    ENG99428	CTR_VLFT_1_SWI_NOT[0]	0
    ENG103626	CTR_VLFT_1_SWI_NOT[1]	0
    ENG100809	CTR_VLFT_1_SWI_NOT[2]	0
    ENG99336	CTR_VLFT_1_SWI_NOT[3]	0
    ENG103025	CTR_VLFT_STND_SWI_NOT[0]	0
    ENG100017	CTR_VLFT_STND_SWI_NOT[1]	0
    ENG100438	CTR_VLFT_STND_SWI_NOT[2]	0
    ENG100736	CTR_VLFT_STND_SWI_NOT[3]	0
    ENG112559	CTR_VVL_LIH_ACT	0
    ENG101271	CTR_VVL_LIH_DEAC	0
    ENG100551	CTR_VVL_SWI_DC	0
    ENG99561	CTR_VVL_SWI_H	0
    ENG101173	CTR_VVL_SWI_L	8
    ENG99084	Cycle flags: (completed cycles): cat: lambda probe heater	57
    ENG100943	Cycle flags: (completed cycles): lambda probes: EGR	0
    ENG99495	Cycle flags: (completed tests): lambda adaption:	8
    ENG103597	Cycle flags:(completed cycles):lambda probes:sec.air sys.	59
    ENG101652	Cylinder shut-off: cylinder suppression	1
    ENG102657	DIAG_INST[0]	NO_ERROR
    ENG99120	DIAG_INST[1]	NO_ERROR
    ENG103260	DIAG_INST[2]	NO_ERROR
    ENG99710	DIAG_INST[3]	NO_ERROR
    ENG102667	DIAG_INST[4]	NO_ERROR
    ENG102739	DIAG_INST[5]	NO_ERROR
    ENG100162	DIAG_INST[6]	NO_ERROR
    ENG99103	DIAG_INST[7]	NO_ERROR
    ENG99261	DIAG_INST[8]	NO_ERROR
    ENG103622	DIAG_INST[9]	NO_ERROR
    ENG112560	DIST_ACT_MIL_SAE	0	 km
    ENG112561	DIST_DTC_CLR_SAE	121	 km
    ENG103766	DIST_ENG_RUN_IN	138386.7	 m
    ENG100531	DIST_ST	138400	 m
    ENG100131	ECU_STATE	ENG_STOP
    ENG100152-ENG104003	ECUNAME-ECU	ECM
    ENG100152	ECUNAME	EngineControl
    ENG103712	EFPPWM_MIN_AD	0	 %
    ENG104044	Engine load	0	 %
    ENG102494	Engine speed: actual	0	 /min
    ENG102783	Engine: operating status	ES
    ENG103667	ENVD_0_MON	0
    ENG100777	ENVD_0_MON_3	0
    ENG126934	ENVD_0_MON_3_VD	0
    ENG99424	ENVD_1_MON	0
    ENG100344	ENVD_1_MON_3	0
    ENG126935	ENVD_1_MON_3_VD	0
    ENG99790	ENVD_2_MON	0
    ENG100541	ENVD_2_MON_3	0
    ENG126936	ENVD_2_MON_3_VD	0
    ENG99455	ENVD_3_MON	0
    ENG101268	ENVD_3_MON_3	0
    ENG126937	ENVD_3_MON_3_VD	0
    ENG01743	ENVD_4_MON	0
    ENG01744	ENVD_5_MON	0
    ENG01745	ENVD_6_MON	0
    ENG99752	Error flags: (completed cycles): cat: lambda probe heater	0
    ENG101275	Error flags: (completed cycles): lambda probes: EGR	0
    ENG104132	Error flags: (completed cycles): lambda probes:sec.air sys.	0
    ENG101942	ESI (extended service intervals) oil warning threshold	59.25	 mm
    ENG112562	FAC_AR_THR_AD	0	 %
    ENG104194	FAC_H_RNG_LAM_AD[1]	0	 %
    ENG104151	FAC_L_RNG_LAM_AD[1]	0	 %
    ENG100298	FAC_LAM_CP	0	 %
    ENG100108	FAC_LAM_LIM[1]	0	 %
    ENG99722	FAC_LAM_TCO_A[1]	0	 %
    ENG103521	FAC_LAM_TCO_B[1]	0	 %
    ENG103641	FAC_LAM_TCO_C[1]	0	 %
    ENG101578	FAC_LAM_TCO_D[1]	0	 %
    ENG100685	FAC_LAM_TCO_E[1]	0	 %
    ENG103307	FAC_MAF_MAX	0
    ENG99791	FAC_SLOP_IV[1]	0
    ENG102306	FAC_TPS_1_SAE	15.625	 %
    ENG102292	FAC_TPS_1_SAE	16.015625	 %
    ENG99630	Fan control relay: fan run-on	2
    ENG101437	Fan request from air conditioner	0	 %
    ENG103644	FRF_IMMO_SNAPSHOT_BYTE1	0
    ENG102892	FRF_IMMO_SNAPSHOT_BYTE2	0
    ENG100521	FRF_IMMO_SNAPSHOT_BYTE3	0
    ENG101852	FRF_IMMO_SNAPSHOT_BYTE4	0
    ENG99312	FRF_IMMO_SNAPSHOT_BYTE5	0
    ENG103956	FRF_IMMO_SNAPSHOT_BYTE6	0
    ENG128786	FTL_SAE	92.15686426	 %
    ENG104248	Fuel consumption signal	0	 µl
    ENG101667	Fuel pump: adaption value	0	 %
    ENG100969	Fuel pump: fuel pressure: I-controller	0	 %
    ENG100250	Fuel regulating valve: duty cycle	0	 %
    ENG101692	Fuel supply system: high-pressure regulator	59360.3	 hPa
    ENG114828	FUP_EFP_MES	11000.8	 hPa
    ENG103553	FUP_EFP_ST_H	0	 hPa
    ENG101056	FUP_EFP_ST_L	0	 hPa
    ENG99950	FUP_EFP_STOP_H	0	 hPa
    ENG100784	FUP_EFP_STOP_L	0	 hPa
    ENG102108	FUP_H	43562.9	 hPa
    ENG112563	FUP_H_SAE	4260	 kPa
    ENG103368	Gearbox -CAN bus messages	126839
    ENG99170	Height correction	985.64	 hPa
    ENG103575	High-pressure system: regulator	119.03	 mg
    ENG103879	High-pressure system: regulator: mobile part	0	 mg
    ENG102603	High-pressure system: status	VCV_OPEN
    ENG101567	Idling speed stabilisation: duty cycle/AC compressor torque	0.5	 Nm
    ENG101946	Idling stabilisation: operating status	0
    ENG100345	IGA_ADJ_KNK[0]	0	 °
    ENG103593	IGA_ADJ_KNK[1]	0	 °
    ENG103360	IGA_ADJ_KNK[2]	0	 °
    ENG99404	IGA_ADJ_KNK[3]	0	 °
    ENG100425	IGA_IGC[0]	-1.125	 °
    ENG101655	IGA_IGC[1]	-1.125	 °
    ENG100410	IGA_IGC[2]	-1.125	 °
    ENG100407	IGA_IGC[3]	-1.125	 °
    ENG112564	IGA_IGC_SAE	-1	 °
    ENG101741	Intake air temperature	54	 °C
    ENG100634	In-use Per Tr: 16 or 20 cou sec O2 Sens Mon Con Enc Cou B 1	6	 counts
    ENG125209	KNKS_ERR_REL[0]	0	 V
    ENG99741	LAMB_DELTA_AD_LAM_ADJ[1]	0.00006
    ENG99601	LAMB_DELTA_I_LAM_ADJ[1]	0
    ENG112565	LAMB_DELTA_SUM_LAM_ADJ_AD[1]	0.00006
    ENG99674	Lambda controller: bank 1 (averaged value)	0	 %
    ENG101381	Lambda probe 1: bank 1: status	0
    ENG101039	Lambda probe 1: bank 1: status	0
    ENG102886	Lambda probe 1: bank 1: status	0
    ENG104200	Lambda probe 2: bank 1: status	0
    ENG101336	Lambda probe 2: bank 1: status	0
    ENG99661	Lambda probe ageing: bank 1: dynamic factor	0
    ENG101869	Lambda probe ageing: bank 1: probe 1: short trip result	228.6625	 °C
    ENG100478	Lambda probe correction: duty cycle offset: bank 1	0
    ENG103776	Lambda probe heater: bank 1: probe 2: short trip result	1
    ENG102380	Lambda probe heater: resistance: bank 1: probe 2	65535	 Ohm
    ENG99353	Lambda probe voltage: bank 1: probe 1 (broadband probe)	1.997	 V
    ENG102763	Lambda probes actual: bank1	1
    ENG104114	Lambda probes specified: bank1	0
    ENG06592	LF_COSI_CTL_ERR_A	0
    ENG06593	LF_COSI_CTL_ERR_B	0
    ENG112566	LF_DPS_CYC_ERR_RAW_BSW[1]	0
    ENG112567	LF_DPS_CYC_ERR_RAW_BSW[2]	0
    ENG112568	LF_DPS_CYC_ERR_VLD_BSW[1]	0
    ENG112569	LF_DPS_CYC_ERR_VLD_BSW[2]	0
    ENG112570	LF_DPS_INI_ERR_RAW_BSW[1]	0
    ENG112571	LF_DPS_INI_ERR_RAW_BSW[2]	0
    ENG112572	LF_IV_ERR_RAW_BSW[0]	0
    ENG112573	LF_IV_ERR_RAW_BSW[1]	0
    ENG112574	LF_IV_ERR_RAW_BSW[2]	0
    ENG112575	LF_IV_ERR_RAW_BSW[3]	0
    ENG112576	LF_IV_ERR_VLD_BSW[0]	0
    ENG112577	LF_IV_ERR_VLD_BSW[1]	0
    ENG112578	LF_IV_ERR_VLD_BSW[2]	0
    ENG112579	LF_IV_ERR_VLD_BSW[3]	0
    ENG101645	LF_VVL_DIAG_SWI_NOT	0
    ENG127734-MAS00106	Life_cycle_data_start_requirement_development-Year	2127
    ENG127734-MAS00107	Life_cycle_data_start_requirement_development-Month	15
    ENG127734-MAS00108	Life_cycle_data_start_requirement_development-Day	31
    ENG127734-MAS00109	Life_cycle_data_start_requirement_development-Hours	31
    ENG127734-MAS00110	Life_cycle_data_start_requirement_development-Minutes	63
    ENG127734-MAS00111	Life_cycle_data_start_requirement_development-Seconds	63
    ENG127734	Life_cycle_data_start_requirement_development	Steering
    ENG127734	Life_cycle_data_start_requirement_development	Quattro Sport
    ENG127734	Life_cycle_data_start_requirement_development	Multifunction unit control module
    ENG127734	Life_cycle_data_start_requirement_development	Parking aid
    ENG127734	Life_cycle_data_start_requirement_development	brakes
    ENG127734	Life_cycle_data_start_requirement_development	Immobilizer
    ENG127734	Life_cycle_data_start_requirement_development	Kessy
    ENG127734	Life_cycle_data_start_requirement_development	Engine
    ENG127734	Life_cycle_data_start_requirement_development	Level control system
    ENG127734	Life_cycle_data_start_requirement_development	ACC
    ENG127734	Life_cycle_data_start_requirement_development	Front sensor system for driver assistance systems
    ENG127734	Life_cycle_data_start_requirement_development	All-wheel electronics
    ENG127734	Life_cycle_data_start_requirement_development	12 V electrical system
    ENG127734	Life_cycle_data_start_requirement_development	Transmission
    ENG127734	Life_cycle_data_start_requirement_development	Front axis lift system
    ENG127734	Life_cycle_data_start_requirement_development	A/C
    ENG127734	Life_cycle_data_start_requirement_development	Convertible top control module
    ENG127735-MAS00106	Life_cycle_data_stop_prohibition_development-Year	2127
    ENG127735-MAS00107	Life_cycle_data_stop_prohibition_development-Month	15
    ENG127735-MAS00108	Life_cycle_data_stop_prohibition_development-Day	31
    ENG127735-MAS00109	Life_cycle_data_stop_prohibition_development-Hours	31
    ENG127735-MAS00110	Life_cycle_data_stop_prohibition_development-Minutes	63
    ENG127735-MAS00111	Life_cycle_data_stop_prohibition_development-Seconds	63
    ENG127735	Life_cycle_data_stop_prohibition_development	Engine
    ENG127735	Life_cycle_data_stop_prohibition_development	A/C
    ENG127735	Life_cycle_data_stop_prohibition_development	Convertible top control module
    ENG127735	Life_cycle_data_stop_prohibition_development	Steering
    ENG127735	Life_cycle_data_stop_prohibition_development	Multifunction unit control module
    ENG127735	Life_cycle_data_stop_prohibition_development	Parking aid
    ENG127735	Life_cycle_data_stop_prohibition_development	ACC
    ENG127735	Life_cycle_data_stop_prohibition_development	12 V electrical system
    ENG127735	Life_cycle_data_stop_prohibition_development	Transmission
    ENG127735	Life_cycle_data_stop_prohibition_development	Front axis lift system
    ENG127735	Life_cycle_data_stop_prohibition_development	Quattro Sport
    ENG127735	Life_cycle_data_stop_prohibition_development	Level control system
    ENG127735	Life_cycle_data_stop_prohibition_development	Front sensor system for driver assistance systems
    ENG127735	Life_cycle_data_stop_prohibition_development	All-wheel electronics
    ENG127735	Life_cycle_data_stop_prohibition_development	brakes
    ENG127735	Life_cycle_data_stop_prohibition_development	Immobilizer
    ENG127735	Life_cycle_data_stop_prohibition_development	Kessy
    ENG127733-MAS00106	Life_cycle_data_system_failure-Year	2127
    ENG127733-MAS00107	Life_cycle_data_system_failure-Month	15
    ENG127733-MAS00108	Life_cycle_data_system_failure-Day	31
    ENG127733-MAS00109	Life_cycle_data_system_failure-Hours	31
    ENG127733-MAS00110	Life_cycle_data_system_failure-Minutes	63
    ENG127733-MAS00111	Life_cycle_data_system_failure-Seconds	63
    ENG127733	Life_cycle_data_system_failure	Quattro Sport
    ENG127733	Life_cycle_data_system_failure	Steering
    ENG127733	Life_cycle_data_system_failure	Immobilizer
    ENG127733	Life_cycle_data_system_failure	Kessy
    ENG127733	Life_cycle_data_system_failure	Engine
    ENG127733	Life_cycle_data_system_failure	Multifunction unit control module
    ENG127733	Life_cycle_data_system_failure	Parking aid
    ENG127733	Life_cycle_data_system_failure	12 V electrical system
    ENG127733	Life_cycle_data_system_failure	Transmission
    ENG127733	Life_cycle_data_system_failure	Convertible top control module
    ENG127733	Life_cycle_data_system_failure	A/C
    ENG127733	Life_cycle_data_system_failure	Level control system
    ENG127733	Life_cycle_data_system_failure	ACC
    ENG127733	Life_cycle_data_system_failure	Front sensor system for driver assistance systems
    ENG127733	Life_cycle_data_system_failure	All-wheel electronics
    ENG127733	Life_cycle_data_system_failure	brakes
    ENG127733	Life_cycle_data_system_failure	Front axis lift system
    ENG122701	LMVDes_st_Mod_Out_VW	8
    ENG122702	LMVDes_v_Max_Man_Lim_VW	511.992	 km/h
    ENG122703	LMVLim_v_Auth_Max_Out_VW	200	 km/h
    ENG100402	LOIL_SUM_SRV_INTL	0	 mm
    ENG99162	LV_ACC_RED_CMD	0
    ENG102235	LV_ATB_ACT_1	0
    ENG102541	LV_ATB_ACT_2	0
    ENG114829	LV_BPA_LIH_REQ[0]	0
    ENG99095	LV_CAN_HOOD_SWI	1
    ENG128787	LV_CMD_RCL_OPEN	0
    ENG128788	LV_ECRAS_FB_DIAG_POS_RESP[0]	0
    ENG103049	LV_EFPPWM_AD_STOP	1
    ENG101712	LV_ENG_RUN_IN	1
    ENG100267	LV_ENG_RUN_IN_EXT_ADJ	0
    ENG103319	LV_ERR_VLFT_1_SWI[1]	0
    ENG103549	LV_ERR_VLFT_1_SWI[2]	0
    ENG103191	LV_ERR_VLFT_1_SWI[3]	0
    ENG101989	LV_ERR_VLFT_1_SWI[4]	0
    ENG102313	LV_ERR_VLFT_STND_SWI[1]	0
    ENG103044	LV_ERR_VLFT_STND_SWI[2]	0
    ENG103443	LV_ERR_VLFT_STND_SWI[3]	0
    ENG100487	LV_ERR_VLFT_STND_SWI[4]	0
    ENG112471	LV_IGK	1
    ENG103773	LV_INH_STR_RLY	0
    ENG100044	LV_LOIL_L_WARN	0
    ENG103492	LV_LOIL_L_WARN_ACT	0
    ENG103908	LV_LOIL_L_WARN_TMP	0
    ENG103716	LV_POIL_SWI_H	0
    ENG100912	LV_POIL_SWI_L	0
    ENG112586	LV_PWR_RLY[0]	1
    ENG102417	LV_TPS_AD_ACT	0
    ENG100842	LV_TPS_AD_DIAG_ERR	0
    ENG103996	LV_TPS_AD_REQ	0
    ENG112587	LV_VCP_AD_END	0
    ENG102523	MAF	0	 mg/stroke
    ENG99288	MAF_DIF_CAM_OFS_AD_SQ_TOT	0	 kg²/h²
    ENG112588	MAP_MES_SAE	98	 kPa
    ENG103501	MASS_SA_REL[0]	0
    ENG100896	MASS_SA_REL_21_PHA	0
    ENG103045	MASS_SA_REL_22_PHA	0
    ENG103346	MFF_ADD_LAM_AD[1]	0	 mg/stroke
    ENG126493	MFF_MPL_ADD_LAM_AD[1][1]	0.53	 mg/stroke
    ENG101360	Misfire detection active	1
    ENG102335	Misfires all cylinders per 1000 rpm	0
    ENG128796	N_SP_IS_CLC	1100	 /min
    ENG103004	N_TCHA	12908.9	 /min
    ENG112590	N_TOOTH	0	 /min
    ENG107737-ENG112538	NC_NR_DIAG_RBM-NC Value	154
    ENG126111	NL_PRE[0]	0	 V
    ENG126112	NL_PRE[1]	0	 V
    ENG126113	NL_PRE[2]	0	 V
    ENG126114	NL_PRE[3]	0	 V
    ENG128789	NR_CYC_AD_DC_BAL_HOM[RNG_H]	0
    ENG128790	NR_CYC_AD_DC_BAL_HOM[RNG_IS]	0
    ENG128791	NR_CYC_AD_DC_BAL_HOM[RNG_L]	0
    ENG128792	NR_CYC_AD_DIAG_BAL_HOM[0]	0
    ENG128793	NR_CYC_AD_DIAG_BAL_HOM[1]	0
    ENG128794	NR_CYC_AD_DIAG_BAL_HOM[2]	0
    ENG128795	NR_CYC_AD_DIAG_BAL_HOM[3]	0
    ENG112589	NR_CYL_FIRST_VVL_SWI	0
    ENG99776	NR_CYL_VVL_H_ACK	4
    ENG119936	O2L_MAX_CAT_GAP_AFL_MV[1]	0	 g
    ENG119937	O2L_MAX_CAT_GAP_AFR_MV[1]	0	 g
    ENG99157	PRS_SA_DIF	0	 hPa
    ENG02464	PRS_UP_THR_MES	981.66	 hPa
    ENG112591	PSN_EDGE_REL_AD_CAM_EX[1][1]	0	 °
    ENG112592	PSN_EDGE_REL_AD_CAM_IN[1][1]	-0.25	 °
    ENG114830	PSN_EDGE_REL_AD_CAM_SAVE_EX[1][1]	0	 °
    ENG114831	PSN_EDGE_REL_AD_CAM_SAVE_EX[1][2]	0	 °
    ENG114832	PSN_EDGE_REL_AD_CAM_SAVE_IN[1][1]	-0.25	 °
    ENG114833	PSN_EDGE_REL_AD_CAM_SAVE_IN[1][2]	-1.5625	 °
    ENG128797	PV	0	 %
    ENG102195	PV_AV_1	0	 %
    ENG99137	PV_AV_2	0	 %
    ENG101068	PV_AV_H	0	 %
    ENG112593	PWM_ACT_VCP[EX_1]	90.002	 %
    ENG112594	PWM_ACT_VCP[IN_1]	90.002	 %
    ENG101350	PWM_ETC	0	 %
    ENG112595	PWM_HLD_VCP[EX_1]	9.375	 %
    ENG112596	PWM_HLD_VCP[IN_1]	9.375	 %
    ENG112597	PWM_PAS_VCP[EX_1]	9.375	 %
    ENG112598	PWM_PAS_VCP[IN_1]	9.375	 %
    ENG101201	Radiator fan 1: run-on: status	600W
    ENG102359	Radiator fan 2: run-on: status	NO_ECF
    ENG119939	RATIO_O2L_LIM_CAT_GAP_AFL_MV[1]	0
    ENG119940	RATIO_O2L_LIM_CAT_GAP_AFR_MV[1]	0
    ENG102377	Ready and error flags	4
    ENG112599	RVC_AV	88.72	 °
    ENG112601	RVC_SP	88.75	 °
    ENG112600	RVCPWM	0	 %
    ENG103248	SEG_AD_MMV_ER[0]	0	 ‰
    ENG101135	SEG_AD_MMV_ER[1]	0.4027	 ‰
    ENG99078	SEG_AD_MMV_ER[2]	-0.0865	 ‰
    ENG103257	SEG_AD_MMV_ER[3]	0.4614	 ‰
    ENG102511	SEG_AD_MMV_ER_H[0]	0	 ‰
    ENG103258	SEG_AD_MMV_ER_H[1]	0.6588	 ‰
    ENG99291	SEG_AD_MMV_ER_H[2]	-0.0665	 ‰
    ENG99954	SEG_AD_MMV_ER_H[3]	0.7043	 ‰
    ENG100568	SEG_AD_MMV_ER_L[0]	0	 ‰
    ENG100601	SEG_AD_MMV_ER_L[1]	0.4027	 ‰
    ENG102668	SEG_AD_MMV_ER_L[2]	-0.0865	 ‰
    ENG101232	SEG_AD_MMV_ER_L[3]	0.4614	 ‰
    ENG101561	SEG_AD_MMV_ER_MID[0]	0	 ‰
    ENG102964	SEG_AD_MMV_ER_MID[1]	0.6271	 ‰
    ENG100890	SEG_AD_MMV_ER_MID[2]	-0.0624	 ‰
    ENG99793	SEG_AD_MMV_ER_MID[3]	0.6712	 ‰
    ENG103381	Shut-off time	3.5	 s
    ENG109006-ENG100882	Spark_efficiency_deviation_at_idle_maximum-EFF_IGA_CST_QUO_IS_MAX	15	 %
    ENG109007-ENG99938	Spark_efficiency_deviation_at_part_load_maximum-EFF_IGA_CST_QUO_PL_MAX	0	 %
    ENG102971	Start adaption: temperature adaption factor 1	1
    ENG102489	Start adaption: temperature adaption factor 2	1
    ENG100723	Start adaption: temperature adaption factor 3	1
    ENG100919	Starter control: interlock switch	0
    ENG100800	Starter: start relay 1	0
    ENG99979	Starter: start relay 2	0
    ENG102033	STATE_BPA[0]	OPM
    ENG102127	STATE_COMC_NVLD	Wait
    ENG112602	STATE_CRK_STST	CRK_STST_PAS
    ENG114834	STATE_CRU_OFF_IRR_CUS	0
    ENG114835	STATE_CRU_OFF_REV_CUS	18416704
    ENG112603	STATE_EOL_VVL	DEAC
    ENG112605	STATE_LS_SAE[1]	INI
    ENG104238	STATE_NVLD	READ_INI
    ENG112606	STATE_PWM_VCP[EX_1]	HLD
    ENG112607	STATE_PWM_VCP[IN_1]	HLD
    ENG101078	STATE_READY_OBD_1	7
    ENG100369	STATE_READY_OBD_3	0
    ENG100342	STATE_REQ_NVLD	NO_REQ
    ENG109090	STATE_SW_MVB	SC8S5010 CBS00I0
    ENG128798	STATE_T_ES_RD	0
    ENG128799	STATE_T_ES_VLD_RD	1
    ENG112608	STATE_VCP	passive
    ENG114836	STATE_VCV_CLOSE_SL	OFF
    ENG103723	STATE_VVL_MNG	VVL_H
    ENG112609	T_ACT_MIL_SAE	0	 min
    ENG112494	T_AST_SAE	0	 s
    ENG104148	T_COOL_LOIL	372.3	 ms
    ENG112613	T_DTC_CLR_SAE	251	 min
    ENG102790	T_EFP_MEM_H	0	 s
    ENG102123	T_EFP_MEM_L	0	 s
    ENG109299	T_ES	7	 min
    ENG112615	T_ES_CNT	0
    ENG112616	T_ES_DC	3	 min
    ENG99463	T_ES_H	448	 s
    ENG128802	T_IGK	263.44	 s
    ENG99398	T_POP_COC_INTER_1	0	 s
    ENG102747	T_PWL	0	 s
    ENG128803	T_PWL_CAN	76	 s
    ENG112636	T_SWI_VVL_ACR	0	 ms
    ENG101325	T_TEMP_SIG_LOIL	54.5	 ms
    ENG99126	T_VS_TOL_LOCK	0	 min
    ENG125440	TAA	21	 °C
    ENG102048	Tank breather valve: duty cycle	0	 %
    ENG101339	Tank breather valve: short trip result	0	 kg/h
    ENG100439	Tank level	0
    ENG112610	TCO_1_FIRST_ST	83	 °C
    ENG112611	TCO_1_ST	83	 °C
    ENG112612	TCO_1_SYS	81	 °C
    ENG103434	TCO_A_LAM_AD_WUP[1]	-5.25	 °C
    ENG100381	TCO_B_LAM_AD_WUP[1]	9.75	 °C
    ENG101581	TCO_C_LAM_AD_WUP[1]	24.75	 °C
    ENG100354	TCO_D_LAM_AD_WUP[1]	35.25	 °C
    ENG101973	TCO_E_LAM_AD_WUP[1]	45	 °C
    ENG128800	TCO_MDL[STUCK_L_COOL_MON]	70	 °C
    ENG124460	TCO_MDL[TH]	73.68	 °C
    ENG100390	TCO_MIN_INTER_LAM_AD_WUP[1]	81	 °C
    ENG100853	TCO_MIN_LAM_AD_WUP[1]	50.25	 °C
    ENG102279	TCS/ESP: specified torque	16.53	 Nm
    ENG99857	TCS: status	0
    ENG110436	TEG_DYN_LS_DOWN[1]	242.35	 °C
    ENG110437	TEG_DYN_LS_UP[1]	220.725	 °C
    ENG101941	TEMP_CAT_STAT_MDL[1]	19.975	 °C
    ENG112614	TEMP_CAT_UP_1_SAE	259.8	 °C
    ENG114837	TFPA	77	 °C
    ENG114838	TFU_HPP	79.5	 °C
    ENG99608	Throttle valve adjuster: adaption status	ST_CHK_END
    ENG101411	Throttle valve angle	6.098	 °
    ENG102845	Throttle valve deviation	0	 %
    ENG126115	TI_1_MES_MPI[0]	0	 ms
    ENG126116	TI_1_MES_MPI[1]	0	 ms
    ENG126117	TI_1_MES_MPI[2]	0	 ms
    ENG126118	TI_1_MES_MPI[3]	0	 ms
    ENG126119	TI_MES_4[PLS_1][0]	0	 ms
    ENG126120	TI_MES_4[PLS_1][1]	0	 ms
    ENG126121	TI_MES_4[PLS_1][2]	0	 ms
    ENG126122	TI_MES_4[PLS_1][3]	0	 ms
    ENG126123	TI_MES_4[PLS_2][0]	0	 ms
    ENG126124	TI_MES_4[PLS_2][1]	0	 ms
    ENG126125	TI_MES_4[PLS_2][2]	0	 ms
    ENG126126	TI_MES_4[PLS_2][3]	0	 ms
    ENG126127	TI_MES_4[PLS_3][0]	0	 ms
    ENG126128	TI_MES_4[PLS_3][1]	0	 ms
    ENG126129	TI_MES_4[PLS_3][2]	0	 ms
    ENG126130	TI_MES_4[PLS_3][3]	0	 ms
    ENG128801	TIA_CHA_DOWN_MV	67.494	 °C
    ENG125276	TIG_MES_SAE[IM]	54	 °C
    ENG103351	Time since engine start	0	 s
    ENG112634	TLTS_MES[TCE]	81.203	 °C
    ENG112635	TMAG_VCP	80	 °C
    ENG110444	TPS_AD_CDN_MIS	0
    ENG114839	TPS_ETC	6.098	 °
    ENG99274	TPS_SP	6.047	 °
    ENG103021	TQ_CONV	4	 Nm
    ENG128804	TQI_ADD_ACT	0.03125	 Nm
    ENG101426	TQI_GS_FAST_INC	0	 Nm
    ENG128805	TQI_N_TCHA_MAX	1023.96875	 Nm
    ENG102329	TTIP_MES_LS_UP[1]	-2048	 °C
    ENG100355	V_FUP_EFP_MV	4.995	 V
    ENG100739	V_PVS_1_BAS	0.7959	 V
    ENG114840	V_PVS_KD	0	 V
    ENG99514	VBOOST	64.5	 V
    ENG103201	VCV_CLOSE_RNG	0	 °
    ENG102311	Vehicle speed: filtered	0	 km/h
    ENG122704	VLCAvl_st_Pt_VW	4
    ENG122705	VLCReq_st_Dem_VW	0
    ENG112639	VLS_DOWN_SAE[1]	1.275	 V
    ENG128806	VOL_FLOW_CHA_UP_RED_MV	0	 m³/s
    ENG101929	VP_TPS_1	0.791	 V
    ENG102985	VP_TPS_2	4.1943	 V
    ENG100421	VP_TPS_AD_EL_BOL_1	0.5029	 V
    ENG103444	VP_TPS_AD_EL_BOL_2	4.4876	 V
    ENG101674	VP_TPS_AD_LIH_1	0.791	 V
    ENG99507	VP_TPS_AD_LIH_2	4.1992	 V
    Elapsed Time: 01:05
    Idle
    ;SW:8V0-906-264-M   HW:06K-907-425-B ---  Engine
    ;Component:1.8l R4 TFSI  H13 0001	 Coding:311D00122426002F0000
    ;EV_ECM18TFS0208V0906264M	1003	EV_ECM18TFS0208V0906264M.rod
    ;Sunday	26	August	2018	11:27:28:04045
    ;VCDS Version: Beta 18.7.2 (x64)  Data version: 20180808 DS295.0
    ;VCID: 46D65C71682711E7EBE-8012
    Group	Description	Actual
    IDE00011	Vehicle Identification Number (VIN)	3VWH17AU5JM758941
    IDE00018	Voltage terminal 15	13.574	 V
    IDE00019	Voltage terminal 30	13.867	 V
    IDE00021	Engine speed	699	 /min
    IDE00025	Coolant temperature	96	 °C
    IDE00030	Status of actuator test	not active
    IDE00075	Vehicle speed	0	 km/h
    IDE00076	Status of initial fuel filling	was not yet started
    IDE00078	Time since engine start	114	 s
    IDE00083	Throttle valve position (absolute)	11.4	 %
    IDE00084	Absolute load value	20	 %
    IDE00085	Normed load value	25.1	 %
    IDE00086	Accelerator position	16	 %
    IDE00090	selected gear	Shifting process active
    IDE00097	OBD - requirements for which this vehicle is designed	OBD + OBD II
    IDE00102	Control Module temperature	57	 °
    IDE00148	Median injection timing	1	 ms
    IDE00149	Ignition angle of current cylinder: actual value	-1.12	 °
    IDE00150	Pressure in brake booster	1.15	 bar
    IDE00151	Oil fill level	79	 mm
    IDE00155	Timing angle retardation cylinder 1	0	 °
    IDE00156	Timing angle retardation cylinder 2	0	 °
    IDE00157	Timing angle retardation cylinder 3	0	 °
    IDE00158	Timing angle retardation cylinder 4	0	 °
    IDE00167	Exhaust temperature 1 bank 1	643.7	 °C
    IDE00172	A/C compressor torque	0	 Nm
    IDE00173	Cruise Control System: specified speed	0	 km/h
    IDE00174	Camshaft adjustment: exhaust: bank 1: specified value	0	 °
    IDE00175	Camshaft adjustment: exhaust: bank 1: actual value	0	 °
    IDE00178	Camshaft adjustment intake bank 1: specified value	0	 °
    IDE00179	Camshaft adjustment intake bank 1: actual value	0	 °
    IDE00182	Camshaft adaptation intake bank 1: phase position	-1.1	 °
    IDE00184	Camshaft adaptation exhaust bank 1: phase position	47.6	 °
    IDE00186	Fuel low pressure: actual value	11.003	 bar
    IDE00187	Coolant temperature at engine start	75.7	 °
    IDE00188	Fuel high pressure: actual value	45.2	 bar
    IDE00189	Activation of fuel pump electronics	62.82	 %
    IDE00190	Charge air pressure specified value	0.981	 bar
    IDE00191	Charge air pressure: actual value	0.981	 bar
    IDE00192	Coolant temperature at radiator outlet: actual value	30.1	 °
    IDE00193	Coolant temperature at engine outlet: specified value	96.7	 °
    IDE00194	Coolant temperature at radiator output: specified value	-48	 °
    IDE00195	Coolant temperature difference between engine and radiator	66	 °
    IDE00196	Engine oil temperature	77	 °C
    IDE00199	Mean engine air mass	9	 kg/h
    IDE00200	Median vehicle speed	0	 km/h
    IDE00201	High fuel pressure: specified value	45.1	 bar
    IDE00202	Low fuel pressure: specified value	5	 bar
    IDE00252	Brake system vacuum pump	Pump off
    IDE00304	Fuel level	49	 l
    IDE00322	Status of basic setting	not active
    IDE00323	Security Access: Number of invalid keys	0
    IDE00348	Intake air temperature	44	 °C
    IDE00349	Throttle valve position: normed	2	 %
    IDE00350	Air mass: specified value	9	 kg/h
    IDE00355	Cruise Control System (CCS): status	main switch off
    IDE00357	Fuel temperature	64.5	 °
    IDE00358	Limitation: torque	290	 Nm
    IDE00371	Fuel consumption	1.31	 l/h
    IDE00375	Generator: load signal	29.05	 %
    IDE00380	Coolant fan 1: activation	10.16	 %
    IDE00381	Coolant fan 2: activation	0	 %
    IDE00392	Accelerator pedal: sensor voltage 1	0.796	 V
    IDE00393	Accelerator pedal: sensor voltage 2	0.386	 V
    IDE00396	Charge Pressure Actuator: acknowledgment	3.477	 V
    IDE00400	Intake manifold Runner Control (IMRC): activation	100	 %
    IDE00401	Intake manifold Runner Control (IMRC): acknowledgment	100	 %
    IDE00404	Throttle valve: activation	13.95	 %
    IDE00405	Crankshaft speed (RPM)	694	 /min
    IDE00406	Camshaft speed (RPM)	0	 /min
    IDE00407	Rail pressure regulation: status	Regulated operation via quantity control valve
    IDE00408	Engine mount 1	not active
    IDE00409	Engine mount 2	not active
    IDE00412	Starter control: terminal 50	not active
    IDE00413	Starter control: Interlock- or P/N-signal	0
    IDE00414	Starter control: relay 1	0
    IDE00415	Starter control: relay 2	0
    IDE00416	Starter control: terminal 50 acknowledgment	1
    IDE00417	Starter control: shut-off conditions 1	00 01
    IDE00445	Unlearning counter according OBD	255
    IDE00450	Operating Instructions	--no display--
    IDE00451	Currently running routine	Unknown (0)
    IDE00472	Mean injection quantity	7	 mg/stroke
    IDE00474	Ambient air pressure	98	 kPa abs
    IDE00476	Fuel Metering Valve	26.37	 %
    IDE00477	Torque request: sum of auxiliary aggregate	4.7	 Nm
    IDE00478	Engine-drag torque	21	 Nm
    IDE00482	Limitation: torque of clutch protection	1024	 Nm
    IDE00495	Calculated oil temperature	77	 °
    IDE00496	Activation of oil pressure switch valve	High pressure
    IDE00497-MAS00627	Status of oil pressure switches-Oil pressure switch for high pressure	closed
    IDE00497-MAS00628	Status of oil pressure switches-Oil pressure switch for low pressure	closed
    IDE00556	Outside air temperature	23	 °C
    IDE00559	Current of oxygen sensor bank 1 sensor 1 (broadband sensor)	1.004 Lambda / -0.012 mA
    IDE00560-MAS04121	Oxygen sensor bank 1 sensor 2 (jump sensor)-Voltage	0.82	 V
    IDE00560-MAS04122	Oxygen sensor bank 1 sensor 2 (jump sensor)-Short term adaptation of mixture formation	99.2	 %
    IDE00582	Equivalence ratio target value	1.01	 Lambda
    IDE00583	Throttle valve specified value	2	 %
    IDE00584	Distance driven since erasing DTC memory	121	 km
    IDE00585	Dist. driven with exh. Malfunction Indicator Lamp activated	0	 km
    IDE00588	Fuel tank fill level	92.2	 %
    IDE00589	Fuel pressure	4420	 kPa rel
    IDE00592	Oxygen sensor control status	Closed loop	  / using O2 sensors
    IDE00593	Ignition timing adjustment cylinder 1	-4.5	 Degrees
    IDE00594	Absolute intake pressure	36	 kPa abs
    IDE00595	Allocation of oxygen sensors	B1S1 B1S2
    IDE00597	Long term adaptation of mixture formation bank 1	5.5	 %
    IDE00601	Monitoring status since erasing DTC memory
    IDE00602	Monitoring status in current driving cycle
    IDE00603	Number of driving cycles since erasing DTC memory	22
    IDE00604	Short term adaptation of mixture formation bank 1	-9.4	 %
    IDE00608	Type of fuel	Gasoline
    IDE00612	Target position of EVAP canister valve	12.2	 %
    IDE00727	Test steps still to be performed	0
    IDE00787	Cause for cancellation	0
    IDE00949-ENG98517	Hide cylinder-Cylinder 1	not active
    IDE00949-ENG98491	Hide cylinder-Cylinder 10	not active
    IDE00949-ENG98492	Hide cylinder-Cylinder 11	not active
    IDE00949-ENG98493	Hide cylinder-Cylinder 12	not active
    IDE00949-ENG98518	Hide cylinder-Cylinder 13	not active
    IDE00949-ENG98519	Hide cylinder-Cylinder 14	not active
    IDE00949-ENG98520	Hide cylinder-Cylinder 15	not active
    IDE00949-ENG98494	Hide cylinder-Cylinder 16	not active
    IDE00949-ENG98521	Hide cylinder-Cylinder 2	not active
    IDE00949-ENG98522	Hide cylinder-Cylinder 3	not active
    IDE00949-ENG98523	Hide cylinder-Cylinder 4	not active
    IDE00949-ENG98495	Hide cylinder-Cylinder 5	not active
    IDE00949-ENG98524	Hide cylinder-Cylinder 6	not active
    IDE00949-ENG98496	Hide cylinder-Cylinder 7	not active
    IDE00949-ENG98497	Hide cylinder-Cylinder 8	not active
    IDE00949-ENG98498	Hide cylinder-Cylinder 9	not active
    IDE00968	Compressor speed	0	 /min
    IDE01076-MAS00109	Time since ignition off-Hours	0	 H
    IDE01076-MAS00110	Time since ignition off-Minutes	0	 min
    IDE01076-MAS00111	Time since ignition off-Seconds	0	 s
    IDE01098	Test of knock sensors: short trip result	Test not started
    IDE01196	Dynamic factor O2 sensors bank 1 or bank 3 before cat. conv.	0
    IDE01266	Coolant shut-off valve	closed
    IDE01369	Intake manifold runner control (IMRC): offset closed	0	 V
    IDE01377	Throttle valve adapter: actual value	1.8	 °
    IDE01378	High fuel pressure: control deviation	-0.8	 bar
    IDE01385	Wear index	0.00000028
    IDE01405-MAS05513	Status of starter activation-Bit 0	OK
    IDE01405-MAS05514	Status of starter activation-Bit 1	Before starter activation
    IDE01405-MAS05515	Status of starter activation-Bit 2	After starter activation
    IDE01638	Result O2 sensor aging test bank 1 or 3 before cat. conv.	Test not started
    IDE01644	Oxygen sensor voltage bank 1 after catalytic converter	0.823	 V
    IDE01649	Throttle valve position 1	0.586	 V
    IDE01650	Throttle valve position 2	11	 %
    IDE01665	Result of test of camshaft adjustment intake bank 1	Test not started
    IDE01667	Result of test of camshaft adjustment outlet bank 1	Test not started
    IDE01670	Short trip status for oil pressure control	Test not started
    IDE01671	Starter control: clutch switch	not pressed
    IDE01672	Starter control: automatic start	not possible
    IDE01673-MAS05513	Starter control: readiness bits-Bit 0	Mech. test of starter not complete
    IDE01673-MAS05514	Starter control: readiness bits-Bit 1	Test of starter relay switching contacts not complete
    IDE01673-MAS05515	Starter control: readiness bits-Bit 2	Test of starter relay activation not complete
    IDE01673-MAS05516	Starter control: readiness bits-Bit 3	Test of terminal 50R return measuring line not completed
    IDE01673-MAS05517	Starter control: readiness bits-Bit 4	Test of starter request double injection not complete
    IDE01673-MAS05518	Starter control: readiness bits-Bit 5	Test of PN signal not complete
    IDE01673-MAS05519	Starter control: readiness bits-Bit 6	Test of interlock switch not complete
    IDE01673-MAS05520	Starter control: readiness bits-Bit 7	Test of clutch pedal switch not complete
    IDE01677	Result of O2 sensor test ready bank 1 after cat. conv.	Test not started
    IDE01683-MAS05304	Valve stroke switch of AVS from small to large-Cylinder 1	switched
    IDE01683-MAS05305	Valve stroke switch of AVS from small to large-Cylinder 2	switched
    IDE01683-MAS05306	Valve stroke switch of AVS from small to large-Cylinder 3	switched
    IDE01683-MAS05307	Valve stroke switch of AVS from small to large-Cylinder 4	switched
    IDE01683-MAS05308	Valve stroke switch of AVS from small to large-Cylinder 5	switched
    IDE01683-MAS05309	Valve stroke switch of AVS from small to large-Cylinder 6	switched
    IDE01683-MAS05310	Valve stroke switch of AVS from small to large-Cylinder 7	switched
    IDE01683-MAS05311	Valve stroke switch of AVS from small to large-Cylinder 8	switched
    IDE01684-MAS05304	Valve stroke switch of AVS from large to small-Cylinder 1	switched
    IDE01684-MAS05305	Valve stroke switch of AVS from large to small-Cylinder 2	switched
    IDE01684-MAS05306	Valve stroke switch of AVS from large to small-Cylinder 3	switched
    IDE01684-MAS05307	Valve stroke switch of AVS from large to small-Cylinder 4	switched
    IDE01684-MAS05308	Valve stroke switch of AVS from large to small-Cylinder 5	switched
    IDE01684-MAS05309	Valve stroke switch of AVS from large to small-Cylinder 6	switched
    IDE01684-MAS05310	Valve stroke switch of AVS from large to small-Cylinder 7	switched
    IDE01684-MAS05311	Valve stroke switch of AVS from large to small-Cylinder 8	switched
    IDE01685	Result of test of valve stroke switch AVS	Test not started
    IDE01773	Misfire sum counter	0
    IDE01774	Status misfire recognition	active
    IDE01775	Misfires per 1000 revolutions of cylinder 1	0
    IDE01776	Misfires per 1000 revolutions of cylinder 2	0
    IDE01777	Misfires per 1000 revolutions of cylinder 3	0
    IDE01778	Misfires per 1000 revolutions of cylinder 4	0
    IDE01870	Oxygen sensor after catalytic converter: operating status	Bank 1: sensor 1 OK
    IDE01873	Test of catalytic converter: measured value	0.016
    IDE01874	Test of catalytic converter: result	Test not started
    IDE01876	Adaptation of loss torque	-0.1	 Nm
    IDE01878	Adaptation of throttle valve	Test of closing springs ended
    IDE01880	Accelerator position 2	15	 %
    IDE01881	Adaptation of kick-down shifting point	4.126	 V
    IDE01884	Camshaft adjustment intake bank 1: activation	10.08	 %
    IDE01886	Number of high pressure incursions	0
    IDE01894	Charge press. ctrl.: adapt. higher than max. threshold	0.39	 %
    IDE01895	Charge pressure control: less than min. threshold adaptation	0.78	 %
    IDE01901	Lost torque adaptation: idle	-5.2	 Nm
    IDE01905	Average of ignition timing angle delay adjustment	14.25	 °
    IDE01906	Dynamic average of ignition timing angle delay adjustment	-3	 °
    IDE01912	Oxygen sensor bank 1 sensor 1: specified value	1
    IDE01913	Number of oxygen sensor dynamic tests: bank 1 sensor 1	0
    IDE01922	Vehicle distance driven	138	 km
    IDE01923	Control module distance driven	138	 km
    IDE01924	Load shift flaps: actual value	closed
    IDE01925	Load shift flaps: specified value	closed
    IDE01926	Adaptation of load shift flaps	Cancel: prerequisites have not been met
    IDE01928	Close cam shaft angle at quantity control valve	33.9	 °
    IDE01929	Open cam shaft angle at quantity control valve	-32	 °
    IDE01931	High pressure pump injection volume control deviation	2	 mg/stroke
    IDE01932	High pressure pump injection volume	7	 mg/stroke
    IDE01975	Numb.of misfir.: cylinder 1	0
    IDE01976	Numb.of misfir.: cylinder 2	0
    IDE01977	Numb.of misfir.: cylinder 3	0
    IDE01978	Numb.of misfir.: cylinder 4	0
    IDE01986	Contact for tank leak test	closed
    IDE02116	Exhaust gas temperature before catalytic converter	409.4	 °
    IDE02119	Long term adaptation of oxygen sensor control: bank 1	0	 %
    IDE02229	Exh.gas temp.sen 1	1110	 °
    IDE02756	Number of manual engine starts	125
    IDE02757	Number of automatic engine starts	0
    IDE03008-MAS04415	Stop process prevented-Ambient air pressure	not active
    IDE03008-MAS04416	Stop process prevented-Sporadic function restriction	not active
    IDE03008-MAS04417	Stop process prevented-Poor start detection	not active
    IDE03008-MAS04590	Stop process prevented-Mixture adaptation	not active
    IDE03008-MAS06602	Stop process prevented-Engine temperature	not active
    IDE03008-MAS06604	Stop process prevented-Start-stop sensor system	not active
    IDE03008-MAS06605	Stop process prevented-Regeneration operation	not active
    IDE03008-MAS06606	Stop process prevented-Brake under pressure too low	not active
    IDE03010-IDE00924	Number of prevented stop processes-Steering angle	0
    IDE03010-MAS01627	Number of prevented stop processes-Steering	0
    IDE03010-MAS02040	Number of prevented stop processes-Play protection	0
    IDE03010-MAS04415	Number of prevented stop processes-Ambient air pressure	0
    IDE03010-MAS04416	Number of prevented stop processes-Sporadic function restriction	36
    IDE03010-MAS04417	Number of prevented stop processes-Poor start detection	0
    IDE03010-MAS04589	Number of prevented stop processes-Diagnosis of exhaust system	0
    IDE03010-MAS04590	Number of prevented stop processes-Mixture adaptation	0
    IDE03010-MAS04591	Number of prevented stop processes-Diagnosis of air system	0
    IDE03010-MAS04592	Number of prevented stop processes-Hybrid battery power insufficient	0
    IDE03010-MAS04593	Number of prevented stop processes-Auxiliary consumers power too high	0
    IDE03010-MAS04595	Number of prevented stop processes-Deceleration takeover active	0
    IDE03010-MAS04805	Number of prevented stop processes-Clutch protection K0	0
    IDE03010-MAS04870	Number of prevented stop processes-Test of thermostat not complete	0
    IDE03010-MAS05758	Number of prevented stop processes-Driving situation	0
    IDE03010-MAS06602	Number of prevented stop processes-Engine temperature	274
    IDE03010-MAS06605	Number of prevented stop processes-Regeneration operation	0
    IDE03010-MAS06606	Number of prevented stop processes-Brake under pressure too low	0
    IDE03010-MAS08032	Number of prevented stop processes-Event memory entry in engine control module	0
    IDE03010-MAS09416	Number of prevented stop processes-Adaptation active	0
    IDE03010-MAS11563	Number of prevented stop processes-Engine hood open	0
    IDE03010-MAS11835	Number of prevented stop processes-Function locked due to excessive stalling	0
    IDE03010-MAS12085	Number of prevented stop processes-Brake pedal information: plausibility	0
    IDE03010-MAS12864	Number of prevented stop processes-Tighter traffic flow detected	0
    IDE03010-MAS13643	Number of prevented stop processes-E machine output too low	0
    IDE03010-MAS13644	Number of prevented stop processes-Motor protection active	0
    IDE03010-MAS13645	Number of prevented stop processes-Fuel salinization protection active	0
    IDE03010-MAS13661	Number of prevented stop processes-Exhaust emission control diagnosis	0
    IDE03010-MAS16918	Number of prevented stop processes-Restriction in the start system	0
    IDE03011-MAS01627	Number of requested start processes-Steering	0
    IDE03011-MAS04369	Number of requested start processes-Engine temperature too high	0
    IDE03011-MAS04370	Number of requested start processes-Engine temperature too low	0
    IDE03011-MAS04416	Number of requested start processes-Sporadic function restriction	0
    IDE03011-MAS04592	Number of requested start processes-Hybrid battery power insufficient	0
    IDE03011-MAS04593	Number of requested start processes-Auxiliary consumers power too high	0
    IDE03011-MAS04595	Number of requested start processes-Deceleration takeover active	0
    IDE03011-MAS06606	Number of requested start processes-Brake under pressure too low	0
    IDE03011-MAS06607	Number of requested start processes-SCR System requires restart	0
    IDE03011-MAS09730	Number of requested start processes-Cat. heater	0
    IDE03011-MAS11563	Number of requested start processes-Engine hood open	0
    IDE03011-MAS11834	Number of requested start processes-Rolling vehicle	0
    IDE03011-MAS13644	Number of requested start processes-Motor protection active	0
    IDE03011-MAS13645	Number of requested start processes-Fuel salinization protection active	0
    IDE03011-MAS16918	Number of requested start processes-Restriction in the start system	0
    IDE03108	Result of test of oxygen sensors bank 1	Test not started
    IDE03235	Neutral position sensor: current transmission angle	20	 °
    IDE03236	Neutral position sensor: adapted transmission angle	-179.96	 °
    IDE03246	Neutral position sensor: upper adaptation value	0	 V
    IDE03247	Neutral position sensor: lower adaptation value	0	 V
    IDE03262	Adapt of angle sensor 1 f throttle valve	0.503	 V
    IDE03263	Adapt of angle sensor 2 f throttle valve	4.488	 V
    IDE03264	Adaptation of angle sensor 1 throttle valve: emerg. air gap	0.791	 V
    IDE03265	Adaptation of angle sensor 2 throttle valve: emerg. air gap	4.199	 V
    IDE03267	Intake air temperature: unconditioned voltage	1.401	 V
    IDE03276	Charge air pressure sensor: unconditioned voltage	1.587	 V
    IDE03277	Intake manifold Runner Control (IMRC): unconditioned voltage	3.911	 V
    IDE03328	Transmission neutral position sensor voltage	0	 V
    IDE03361	Driver request torque	25.5	 Nm
    IDE03362	Requested transmission torque	1024	 Nm
    IDE03375	Adaptation status for transmission neutral position sensor	0
    IDE03377	Coolant temp at radiator output: unconditioned voltage	3.121	 V
    IDE03582	Temperature sensor for engine temperature management	96.7	 °
    IDE03585	System status for the start/stop function master	System malfunction
    IDE03587-IDE02697	Stop overrides for active participants-Multifunction unit control module	not active
    IDE03587-MAS00124	Stop overrides for active participants-A/C	not active
    IDE03587-MAS00127	Stop overrides for active participants-brakes	not active
    IDE03587-MAS00506	Stop overrides for active participants-Adaptive Cruise Control	not active
    IDE03587-MAS00832	Stop overrides for active participants-Convertible top control module	not active
    IDE03587-MAS01090	Stop overrides for active participants-Transmission	not active
    IDE03587-MAS01106	Stop overrides for active participants-Level control system	not active
    IDE03587-MAS01490	Stop overrides for active participants-Energy management	not active
    IDE03587-MAS01627	Stop overrides for active participants-Steering	not active
    IDE03587-MAS02237	Stop overrides for active participants-Body computer 1/ veh. elec sys CM / cent elec.	not active
    IDE03587-MAS02569	Stop overrides for active participants-All-wheel electronics	not active
    IDE03587-MAS03757	Stop overrides for active participants-Quattro Sport	not active
    IDE03587-MAS05129	Stop overrides for active participants-Engine	not active
    IDE03587-MAS06709	Stop overrides for active participants-Keyless operation	not active
    IDE03587-MAS08785	Stop overrides for active participants-Parking aid	not active
    IDE03587-MAS13018	Stop overrides for active participants-Front sensor system for driver assistance systems	not active
    IDE03588-IDE02697	System malfunctions for active participants start/stop-Multifunction unit control module	not active
    IDE03588-MAS00124	System malfunctions for active participants start/stop-A/C	not active
    IDE03588-MAS00127	System malfunctions for active participants start/stop-brakes	not active
    IDE03588-MAS00506	System malfunctions for active participants start/stop-Adaptive Cruise Control	not active
    IDE03588-MAS00832	System malfunctions for active participants start/stop-Convertible top control module	not active
    IDE03588-MAS01090	System malfunctions for active participants start/stop-Transmission	not active
    IDE03588-MAS01106	System malfunctions for active participants start/stop-Level control system	not active
    IDE03588-MAS01490	System malfunctions for active participants start/stop-Energy management	not active
    IDE03588-MAS01627	System malfunctions for active participants start/stop-Steering	not active
    IDE03588-MAS02237	System malfunctions for active participants start/stop-Body computer 1/ veh. elec sys CM / cent elec.	not active
    IDE03588-MAS02569	System malfunctions for active participants start/stop-All-wheel electronics	not active
    IDE03588-MAS03757	System malfunctions for active participants start/stop-Quattro Sport	not active
    IDE03588-MAS05129	System malfunctions for active participants start/stop-Engine	not active
    IDE03588-MAS06709	System malfunctions for active participants start/stop-Keyless operation	not active
    IDE03588-MAS08785	System malfunctions for active participants start/stop-Parking aid	not active
    IDE03588-MAS13018	System malfunctions for active participants start/stop-Front sensor system for driver assistance systems	not active
    IDE03589-MAS01161	Error status for start-stop related sensors-Communication error	not active
    IDE03589-MAS11563	Error status for start-stop related sensors-Engine hood open	active
    IDE03589-MAS11868	Error status for start-stop related sensors-Driver door status	not active
    IDE03589-MAS12097	Error status for start-stop related sensors-driver door open	active
    IDE03589-MAS12098	Error status for start-stop related sensors-Start/Stop deactivated with button	active
    IDE03589-MAS12099	Error status for start-stop related sensors-Clutch signal error	not active
    IDE03589-MAS12100	Error status for start-stop related sensors-Brake or speed signal error	not active
    IDE03589-MAS12101	Error status for start-stop related sensors-Steering signal error	not active
    IDE03692-MAS05513	Monitoring status Onboard Diagnosis camshaft and knock sensor-Bit 0	Test of camshaft adjustment bank 2 outlet not complete
    IDE03692-MAS05514	Monitoring status Onboard Diagnosis camshaft and knock sensor-Bit 1	Test of camshaft adjustment bank 1 outlet not complete
    IDE03692-MAS05515	Monitoring status Onboard Diagnosis camshaft and knock sensor-Bit 2	Test of camshaft adjustment bank 2 intake not complete
    IDE03692-MAS05516	Monitoring status Onboard Diagnosis camshaft and knock sensor-Bit 3	Test of camshaft adjustment bank 1 intake complete
    IDE03692-MAS05517	Monitoring status Onboard Diagnosis camshaft and knock sensor-Bit 4	Test of knock sensor 4 not complete
    IDE03692-MAS05518	Monitoring status Onboard Diagnosis camshaft and knock sensor-Bit 5	Test of knock sensor 3 not complete
    IDE03692-MAS05519	Monitoring status Onboard Diagnosis camshaft and knock sensor-Bit 6	Test of knock sensor 2 not complete
    IDE03692-MAS05520	Monitoring status Onboard Diagnosis camshaft and knock sensor-Bit 7	Test of knock sensor 1 complete
    IDE03693-MAS05513	Monitoring status of additional Onboard Diagnosis-Bit 0	Test of brake light switch not complete
    IDE03693-MAS05514	Monitoring status of additional Onboard Diagnosis-Bit 1	Test of clutch switch not complete
    IDE03693-MAS05515	Monitoring status of additional Onboard Diagnosis-Bit 2	Test of idle control not complete
    IDE03693-MAS05516	Monitoring status of additional Onboard Diagnosis-Bit 3	Test of coolant temperature sensor not complete
    IDE03693-MAS05517	Monitoring status of additional Onboard Diagnosis-Bit 4	Test of throttle valve potentiometer not complete
    IDE03693-MAS05518	Monitoring status of additional Onboard Diagnosis-Bit 5	Test of thermostat not complete
    IDE03693-MAS05519	Monitoring status of additional Onboard Diagnosis-Bit 6	Test of charge pressure control complete
    IDE03693-MAS05520	Monitoring status of additional Onboard Diagnosis-Bit 7	Test of CCS switch not complete
    IDE03693-MAS05521	Monitoring status of additional Onboard Diagnosis-Bit 8	Test of oxygen adaptation bank 1 complete
    IDE03711	Mass flow through throttle valve	6	 kg/h
    IDE03767	Engine status	Idling
    IDE03795	Camshaft adjustment: exhaust: bank 1: activation	14.92	 %
    IDE03806	Oxygen sensor bank 1 sensor 1: status	1
    IDE03807	Oxygen sensor bank 1 sensor 2: status	1
    IDE03816	Exhaust flap bank 1	Open
    IDE03818	Heated oxygen sensor bank 1: sensor 2: resistance	328	 Ohm
    IDE03819	Heated oxygen sensor bank 1: sensor 2: activation	32.42	 %
    IDE03820	Heated oxygen sensor bank 1: sensor 1: resistance	304	 Ohm
    IDE03821	Heated oxygen sensor bank 1: sensor 1: activation	27.73	 %
    IDE03832	Oxygen sensor bank 1 sensor 2: response time	0	 ms
    IDE03834	Oxygen sensor bank 1 sensor 2: response time filtered	0	 ms
    IDE03836	Result of O2 sensor aging test bank 1 after cat. conv.	Test not started
    IDE03892	Fuel high pressure sensor: unconditioned voltage	1.127	 V
    IDE03918	Engine reverse rotation recognition	not recognized
    IDE03919	Oxygen regulation operability and status	On
    IDE03920	Oxygen adaptation status	Condition not met
    IDE03921	Mixture adaptation factor at partial load	-1.77	 %
    IDE03922	Mixture adaptation factor at idle speed	7.77	 %
    IDE03923	Adaptive long-term value of mix. condition after cat. conv	0.0001
    IDE03924	Relay for reserve coolant pump: status	not activated
    IDE03928	Counter for fuel entry in oil	0
    IDE03930	Charge pressure actuator: operating status	Operating mode
    IDE03931	Charge pressure actuator: actual position	1.32	 %
    IDE03932	Charge pressure actuator: specified position	0	 %
    IDE03933	Charge pressure actuator: specified value	0	 %
    IDE03934	Charge pressure actuator: adaptation for lower stop	3.53	 V
    IDE03935	Charge pressure actuator: adaptation for upper stop	0.57	 V
    IDE03953	Oxygen control: adaptation value at partial load: bank 1	-1.77	 %
    IDE03957	Throttle valve angle: specified value	1.8	 °
    IDE03963	Low fuel pressure adaptation value for EFP	1200	 mbar
    IDE03966	Transmission neutral position sensor PWM signal	0	 %
    IDE03998	Clutch Position Sensor	99.61	 %
    IDE04002	Charge press. ctrl.	BP_A act:98	 kPa
    IDE04405	Mixture deviation in adapted partial load range 1	0	 %
    IDE04409	Intake manifold pressure: corrected	0.363	 bar
    IDE04410	Intake manifold pressure: target value	0.368	 bar
    IDE04412	Pressure before throttle valve: corrected	0.98	 bar
    IDE04415	Oxygen ctrl factor with precontrol correction	-13.67	 %
    IDE04420	Activation of secondary air system	Atmosphere/off
    IDE04629	AVS operating condition	Test is running
    IDE04630	AVS valve stroke position: current	Standard
    IDE04632-MAS05304	AVS error status of last switch-over standard stroke direction-Cylinder 1	OK
    IDE04632-MAS05305	AVS error status of last switch-over standard stroke direction-Cylinder 2	OK
    IDE04632-MAS05306	AVS error status of last switch-over standard stroke direction-Cylinder 3	OK
    IDE04632-MAS05307	AVS error status of last switch-over standard stroke direction-Cylinder 4	OK
    IDE04632-MAS05308	AVS error status of last switch-over standard stroke direction-Cylinder 5	OK
    IDE04632-MAS05309	AVS error status of last switch-over standard stroke direction-Cylinder 6	OK
    IDE04632-MAS05310	AVS error status of last switch-over standard stroke direction-Cylinder 7	OK
    IDE04632-MAS05311	AVS error status of last switch-over standard stroke direction-Cylinder 8	OK
    IDE04633-MAS05304	AVS error status of last switch-over AVS stroke direction-Cylinder 1	OK
    IDE04633-MAS05305	AVS error status of last switch-over AVS stroke direction-Cylinder 2	OK
    IDE04633-MAS05306	AVS error status of last switch-over AVS stroke direction-Cylinder 3	OK
    IDE04633-MAS05307	AVS error status of last switch-over AVS stroke direction-Cylinder 4	OK
    IDE04633-MAS05308	AVS error status of last switch-over AVS stroke direction-Cylinder 5	OK
    IDE04633-MAS05309	AVS error status of last switch-over AVS stroke direction-Cylinder 6	OK
    IDE04633-MAS05310	AVS error status of last switch-over AVS stroke direction-Cylinder 7	OK
    IDE04633-MAS05311	AVS error status of last switch-over AVS stroke direction-Cylinder 8	OK
    IDE04634	AVS switch-over meter for reg activation of curr. drive cycle	0
    IDE04635	AVS switch-over meter: total	8
    IDE04636	AVS overflow meter for all switch-overs	0
    IDE04637	Engine temperature management actuator	99.75	 %
    IDE04638	Transmission coolant valve	closed
    IDE04677	O2 sensor 1 bank 1: O2 sensor actual value	1
    IDE04680	O2 sensor 1: bank 1: voltage raw value O2 signal	1.997	 V
    IDE04713	Active brake system status	Not operated
    IDE04814	Transmission oil cooler valve	closed
    IDE04937	Sensor for engine block temperature: raw value	-48	 °
    IDE05140	Intake manifold pressure raw value	0.369	 bar
    IDE05259	Gear position sensor: raw value	0	 %
    IDE05260	Gear position sensor: current value	Neutral
    IDE05261	Gear position sensor: last valid value	Neutral
    IDE05262	Gear position sensor: gear position valid	invalid
    IDE05310	Charge air pressure control valve position: target value	0	 %
    IDE05311	Charge air pressure control valve position: actual value	1.32	 %
    IDE05312	Charge air pressure control valve uncond voltage sensor	3.4766	 V
    IDE05313	Charge air pressure control valve activation pulse duty factor	-15.08	 %
    IDE05314-ENG112584	Status of charge air pressure control valve basic setting-LV_BPA_AD_REQ[0]	0
    IDE05315	Charge air pressure control valve voltage: position closed	3.5303	 V
    IDE05316	Charge air pressure control valve voltage: position open	0.5701	 V
    IDE05317-ENG112583	Charge air pressure control valve adaptation performed-LV_BPA_AD_ASA_SUC[0]	0
    IDE05508	Adaptation val cyl 1 with slow diagnosis	0
    IDE05509	Adaptation val cyl 3 with slow diagnosis	0
    IDE05510	Adaptation val cyl 4 with slow diagnosis	0
    IDE05511	Adaptation val cyl 2 with slow diagnosis	0
    IDE05512	Adaptation val cyl 1 with fast diagnosis	0
    IDE05513	Adaptation val cyl 3 with fast diagnosis	0
    IDE05514	Adaptation val cyl 4 with fast diagnosis	0
    IDE05515	Adaptation val cyl 2 with fast diagnosis	0
    IDE05593	Secondary air injection sensor 1	0.983	 bar
    IDE05622-ENG125277	Status of tank leak diagnosis with electrical diagnostic pump-STATE_DMTL_EOL	0
    IDE06006	Idle speed specified value	700	 /min
    IDE06192	Knock sensor: cylinder 2: voltage	0.281	 V
    IDE06193	Knock sensor: cylinder 3: voltage	0.302	 V
    IDE06194	Knock sensor: cylinder 4: voltage	0.239	 V
    IDE06195	Knock sensor: cylinder 1: voltage	0.259	 V
    IDE06296-ENG104200	Activation of oxygen control after main cat-Lambda probe 2: bank 1: status	1
    IDE06307-MAS00106	Stop prevention history data-Year	2018
    IDE06307-MAS00107	Stop prevention history data-Month	8
    IDE06307-MAS00108	Stop prevention history data-Day	26
    IDE06307-MAS00109	Stop prevention history data-Hours	10
    IDE06307-MAS00110	Stop prevention history data-Minutes	33
    IDE06307-MAS00111	Stop prevention history data-Seconds	2
    IDE06307	Stop prevention history data	not active
    IDE06307	Stop prevention history data	Engine temperature
    IDE06308-MAS00106	Start request history data-Year	2127
    IDE06308-MAS00107	Start request history data-Month	15
    IDE06308-MAS00108	Start request history data-Day	31
    IDE06308-MAS00109	Start request history data-Hours	31
    IDE06308-MAS00110	Start request history data-Minutes	63
    IDE06308-MAS00111	Start request history data-Seconds	63
    IDE06308	Start request history data	Hybrid battery power insufficient
    IDE06308	Start request history data	Steering
    IDE06308	Start request history data	Cat. heater
    IDE06308	Start request history data	Restriction in the start system
    IDE06308	Start request history data	Engine temperature too low
    IDE06308	Start request history data	Brake under pressure too low
    IDE06308	Start request history data	Fuel salinization protection active
    IDE06308	Start request history data	Deceleration takeover active
    IDE06308	Start request history data	Motor protection active
    IDE06308	Start request history data	SCR System requires restart
    IDE06308	Start request history data	Engine hood open
    IDE06308	Start request history data	Rolling vehicle
    IDE06308	Start request history data	Auxiliary consumers power too high
    IDE06308	Start request history data	Engine temperature too high
    IDE06308	Start request history data	Sporadic function restriction
    IDE06386	Oil level: static measurement	0	 mm
    IDE06387	Oil level: last valid dynamic value	0	 mm
    IDE06388	Oil level: condition for static measurement fulfilled	Condition not met
    IDE06389	Oil level: maximum value	-127	 mm
    IDE06390	Oil level: minimum value	127	 mm
    IDE06391	Oil temperature sensor 2	70	 °
    IDE06392	Oil temperature sensor 2: raw value	65.535	 V
    IDE06393	Oil level: dynamic average value	0	 mm
    IDE06394	Sensor 1 for secondary air pressure: unconditioned voltage	2.437	 V
    IDE06395	Fuel low pressure sensor: unconditioned voltage	4.995	 V
    IDE06396	Coolant temperature at engine outlet: unconditioned voltage	0.844	 V
    IDE06397	Temperature sensor for engine temp. management: target value	99.8	 °
    IDE06398	Temperature sensor for engine temp. management: uncond. voltage	0.845	 V
    IDE06399	Manifold absolute pressure sensor: unconditioned voltage	0.776	 V
    IDE06425-IDE02766	Roller test bench mode: functional-Malfunction status	no error
    IDE06425-MAS06026	Roller test bench mode: functional-Activation stages	not activated
    IDE06432	Oxygen sensor 1 bank 1 signal status	active
    IDE06444	Oxygen sensor before cat bank 1 (LSB) voltage	1.982	 V
    IDE06567	Start-stop function deactivation frequency counter	0
    IDE06568	Stop prevention by driver frequency counter	0
    IDE06569	Vehicle stopped frequency counter	0
    IDE06573	Long-term adaptation of intake manifold injection	0	 %
    IDE06574	Long-term adaptation of intake manifold injection in idle	0	 mg/stroke
    IDE06610	Vehicle standstill with stop frequency counter	0
    IDE06703-IDE12714	Drivetrain coordinator: ACC fault status-ACC is active despite EPB deceleration	No
    IDE06703-MAS14977	Drivetrain coordinator: ACC fault status-ACC active: although TSK passive	No
    IDE06703-MAS14978	Drivetrain coordinator: ACC fault status-Start off or stop request at stopping speed not set	No
    IDE06703-MAS14979	Drivetrain coordinator: ACC fault status-Start off and stop request sent simultaneously	No
    IDE06703-MAS14980	Drivetrain coordinator: ACC fault status-ACC active: although limiter active	No
    IDE06703-MAS14981	Drivetrain coordinator: ACC fault status-ACC reactivates itself after locking	No
    IDE06703-MAS14982	Drivetrain coordinator: ACC fault status-ACC sends undefined signals	No
    IDE06703-MAS14983	Drivetrain coordinator: ACC fault status-ACC active although main switch off	No
    IDE06703-MAS14984	Drivetrain coordinator: ACC fault status-ACC is active despite driver braking	No
    IDE06703-MAS14985	Drivetrain coordinator: ACC fault status-ACC is active despite ESP/ASR passive sampling	No
    IDE06704-MAS14986	Drivetrain coordinator: brake fault status-Deceleration sensor not available	No
    IDE06704-MAS14987	Drivetrain coordinator: brake fault status-Deceleration sensor malfunction	No
    IDE06704-MAS14988	Drivetrain coordinator: brake fault status-ESP system error	No
    IDE06704-MAS14989	Drivetrain coordinator: brake fault status-ESP system malfunction due to inaccurate engine torque	No
    IDE06704-MAS14990	Drivetrain coordinator: brake fault status-ESP indicates TSK message consistency error	No
    IDE06704-MAS14991	Drivetrain coordinator: brake fault status-TSK/ESP handshake error	No
    IDE06704-MAS14992	Drivetrain coordinator: brake fault status-ESP automatic engagement malfunction	No
    IDE06704-MAS14993	Drivetrain coordinator: brake fault status-Brake light implausible	No
    IDE06705-MAS05179	Drivetrain coordinator: brake function status-ABS intervention	No
    IDE06705-MAS05180	Drivetrain coordinator: brake function status-ESP intervention	No
    IDE06705-MAS05181	Drivetrain coordinator: brake function status-EDL intervention	No
    IDE06705-MAS05186	Drivetrain coordinator: brake function status-ASR intervention	No
    IDE06705-MAS05187	Drivetrain coordinator: brake function status-MSR intervention	No
    IDE06705-MAS05192	Drivetrain coordinator: brake function status-Driver braking	No
    IDE06705-MAS05195	Drivetrain coordinator: brake function status-HDC active	No
    IDE06705-MAS15001	Drivetrain coordinator: brake function status-ESP invokes TSK braking	No
    IDE06705-MAS15002	Drivetrain coordinator: brake function status-EPB active	No
    IDE06705-MAS15003	Drivetrain coordinator: brake function status-ASP intervention	No
    IDE06705-MAS15004	Drivetrain coordinator: brake function status-ADS intervention	No
    IDE06705-MAS15006	Drivetrain coordinator: brake function status-Stopping distance reduction2 warning jolt	No
    IDE06705-MAS15007	Drivetrain coordinator: brake function status-ESP sampled passive (ESP off)	No
    IDE06705-MAS15008	Drivetrain coordinator: brake function status-ASR sampled passive (ASR off)	No
    IDE06705-MAS15009	Drivetrain coordinator: brake function status-ESP recognizes vehicle at rest	No
    IDE06705-MAS15010	Drivetrain coordinator: brake function status-ACC stopping distance control active	No
    IDE06706	ACC variants	ACC
    IDE06707	CCS Switch	CCS operating unit
    IDE06709	ACC variants (coding)	CCS
    IDE06710	Cruise control system: permanent deactivation	No switch-off occurs
    IDE06726	Timing deviation after chain replacement: intake bank 1	-1.44	 °
    IDE06728	Timing deviation after chain replacement: exhaust bank 1	0	 °
    IDE06730	Timing deviation after other repairs: intake bank 1	0	 °
    IDE06732	Timing deviation after other repairs: exhaust bank 1	0	 °
    IDE06734	Timing deviation: current value intake bank 1	0	 °
    IDE06736	Timing deviation: current value exhaust bank 1	0	 °
    IDE06738	Chain elongation: no. of valid initial values: intake bank 1	1
    IDE06740	Chain elongation: no. of valid initial values: exhaust bank 1	0
    IDE06742	Chain elongation: initial values valid: intake bank 1	not active
    IDE06744	Chain elongation: initial values valid: exhaust bank 1	not active
    IDE07001	Piston-cooling jets: activation	On
    IDE07008	Tank leak: number no leak detected	19
    IDE07011	Tank leak: number communication errors to engine control	6
    IDE07014	Tank leak: number very small leaks detected	0
    IDE07019	Number of ignitions direct injection	1026209
    IDE07020	Number of ignitions intake manifold injection	0
    IDE07023	Misfires per 1000 revolutions of cyl. 1 intake manif. injection	0
    IDE07024	Misfires per 1000 revolutions of cyl. 2 intake manif. injection	0
    IDE07025	Misfires per 1000 revolutions of cyl. 3 intake manif. injection	0
    IDE07026	Misfires per 1000 revolutions of cyl. 4 intake manif. injection	0
    IDE07027	Heat quantity that was transported via the catalytic converter	2.44E+08	 J
    IDE07031	Oil pressure switch for piston-cooling jets: status	Open
    IDE07242	Heater support pump: spec. value	10	 %
    IDE07548	Engine temp. mangmt. actuator: specified value of angle	129.25	 °
    IDE07549	Engine temp. mangmt. actuator: actual value of angle	128.78	 °
    IDE07550	Engine temp. management actuator: raw value	2070
    IDE07551	Engine temp. management actuator: duty cycle activation	0	 %
    IDE07552	Engine temper.managem.actuator adaptation: result adaptation	Adaptation successfully finished
    IDE07553	Engine temperature management actuator: after-run stop	3961
    IDE07554	Engine temperature management actuator: stop open	141
    IDE07564	Required torque adjustment by idling regulator	-2.8	 Nm
    IDE07571	Engine torque	5.4	 Nm
    IDE07572	High pressure regulation: adaptation value	-3.2	 mg
    IDE07574	Long-term fuel trim bank 1 at idle	0.53	 mg/stroke
    IDE07575	Driver request torque	1.2	 Nm
    IDE07576	Lost torque adaptation driving mode	3.3	 Nm
    IDE07577	Lost torque adaptation A/C compressor and driving mode	-6.8	 Nm
    IDE07598-MAS00320	Cruise control switch actuation-Main switch	not activated
    IDE07598-MAS00325	Cruise control switch actuation-Setting	not activated
    IDE07598-MAS00326	Cruise control switch actuation-Activation	not activated
    IDE07598-MAS01632	Cruise control switch actuation-Status	OK
    IDE07598-MAS02309	Cruise control switch actuation-Accelerate	not activated
    IDE07598-MAS02310	Cruise control switch actuation-Decelerate	not activated
    IDE07598-MAS05172	Cruise control switch actuation-Cancel	not activated
    IDE07598-MAS05806	Cruise control switch actuation-Main switch hardware	not activated
    IDE07598-MAS05807	Cruise control switch actuation-Coding	plausible
    IDE07598-MAS05809	Cruise control switch actuation-Limit function	not selected
    IDE07598-MAS05812	Cruise control switch actuation-Limit button	not activated
    IDE07598-MAS05813	Cruise control switch actuation-Main switch CAN	not activated
    IDE07598-MAS05842	Cruise control switch actuation-Large increment	not activated
    IDE07598-MAS05843	Cruise control switch actuation-Control component verified	Yes
    IDE07599-MAS01505	Drivetrain coord: cause of shutdown in cruise cntr and ACC mode-Engine off	No
    IDE07599-MAS03849	Drivetrain coord: cause of shutdown in cruise cntr and ACC mode-Crash signal	No
    IDE07599-MAS04795	Drivetrain coord: cause of shutdown in cruise cntr and ACC mode-main switch off	Yes
    IDE07599-MAS05135	Drivetrain coord: cause of shutdown in cruise cntr and ACC mode-Open or no gear selected	No
    IDE07599-MAS05136	Drivetrain coord: cause of shutdown in cruise cntr and ACC mode-Hill descent control	No
    IDE07599-MAS05190	Drivetrain coord: cause of shutdown in cruise cntr and ACC mode-Parking brake or hand brake actuated	No
    IDE07599-MAS05192	Drivetrain coord: cause of shutdown in cruise cntr and ACC mode-Driver braking	No
    IDE07599-MAS05196	Drivetrain coord: cause of shutdown in cruise cntr and ACC mode-Speed signal error	No
    IDE07599-MAS05814	Drivetrain coord: cause of shutdown in cruise cntr and ACC mode-CAN communication error	No
    IDE07599-MAS05815	Drivetrain coord: cause of shutdown in cruise cntr and ACC mode-CAN signal error	No
    IDE07599-MAS05816	Drivetrain coord: cause of shutdown in cruise cntr and ACC mode-ESP control response error	No
    IDE07599-MAS05817	Drivetrain coord: cause of shutdown in cruise cntr and ACC mode-RPM limitation	No
    IDE07599-MAS05818	Drivetrain coord: cause of shutdown in cruise cntr and ACC mode-Transmission coding not plausible	No
    IDE07599-MAS05819	Drivetrain coord: cause of shutdown in cruise cntr and ACC mode-ACC active during braking	No
    IDE07599-MAS05820	Drivetrain coord: cause of shutdown in cruise cntr and ACC mode-ACC error	No
    IDE07599-MAS05821	Drivetrain coord: cause of shutdown in cruise cntr and ACC mode-Braking intervention too weak	No
    IDE07599-MAS05822	Drivetrain coord: cause of shutdown in cruise cntr and ACC mode-Braking control not available	No
    IDE07599-MAS05823	Drivetrain coord: cause of shutdown in cruise cntr and ACC mode-Speed signal error during initialization	No
    IDE07599-MAS05824	Drivetrain coord: cause of shutdown in cruise cntr and ACC mode-Emer. engine operation	No
    IDE07599-MAS05825	Drivetrain coord: cause of shutdown in cruise cntr and ACC mode-Engine control module fault	No
    IDE07599-MAS05826	Drivetrain coord: cause of shutdown in cruise cntr and ACC mode-Torque reduction due to fault	No
    IDE07599-MAS05827	Drivetrain coord: cause of shutdown in cruise cntr and ACC mode-Diagnosis requirements not met	No
    IDE07599-MAS05828	Drivetrain coord: cause of shutdown in cruise cntr and ACC mode-Brake excess temperature	No
    IDE07599-MAS05829	Drivetrain coord: cause of shutdown in cruise cntr and ACC mode-Brake light fault	No
    IDE07599-MAS05830	Drivetrain coord: cause of shutdown in cruise cntr and ACC mode-CCS deactivated due to fault in control component	No
    IDE07599-MAS05831	Drivetrain coord: cause of shutdown in cruise cntr and ACC mode-ACC deactivated due to fault in control component	No
    IDE07599-MAS05832	Drivetrain coord: cause of shutdown in cruise cntr and ACC mode-Coding error	No
    IDE07599-MAS05833	Drivetrain coord: cause of shutdown in cruise cntr and ACC mode-ESC error	No
    IDE07599-MAS05834	Drivetrain coord: cause of shutdown in cruise cntr and ACC mode-Brake pedal fault	No
    IDE07599-MAS05835	Drivetrain coord: cause of shutdown in cruise cntr and ACC mode-Clutch pedal fault	No
    IDE07599-MAS05836	Drivetrain coord: cause of shutdown in cruise cntr and ACC mode-Acceleration monitoring error	No
    IDE07599-MAS05837	Drivetrain coord: cause of shutdown in cruise cntr and ACC mode-ACC control response error	No
    IDE07605	Cruise control system: temporary deactivation	No switch-off
    IDE07669	Oxygen sensor 2 Bank 1 after cat operation readiness Status	active
    IDE07901	Error counter bad fuel	0
    IDE07904-ENG118117	Brake test switch status-actuated__activated	not activated
    IDE07904-ENG114825	Brake test switch status-Ident_32	0
    IDE07905-ENG118117	Brake light switch status-actuated__activated	not activated
    IDE07905-ENG114825	Brake light switch status-Ident_32	0
    IDE07906-ENG118117	Upper clutch switch: status-actuated__activated	not activated
    IDE07906-ENG114825	Upper clutch switch: status-Ident_32	0
    IDE07945-MAS00334	Status of intermittent monitoring-Catalytic converter monitoring	completed successfully
    IDE07945-MAS00335	Status of intermittent monitoring-Monitoring of catalytic converter at operating temperature	completed successfully
    IDE07945-MAS00336	Status of intermittent monitoring-Monitoring of tank ventilation system	not completed successfully
    IDE07945-MAS00337	Status of intermittent monitoring-Monitoring of Secondary Air Injection (AIR) system	completed successfully
    IDE07945-MAS00338	Status of intermittent monitoring-Monitoring of A/C system refrigerant	completed successfully
    IDE07945-MAS00339	Status of intermittent monitoring-Monitoring of oxygen sensor	completed successfully
    IDE07945-MAS00340	Status of intermittent monitoring-Monitoring of oxygen sensor heater	completed successfully
    IDE07945-MAS00341	Status of intermittent monitoring-Monitoring of Exhaust Gas recirc. (EGR)	not completed successfully
    IDE08071-ENG119931	Remote start cancellation reason store 1-LF_ST_REQ_EXT_DVC_DEAC_1	0
    IDE08072-ENG119932	Remote start cancellation reason store 2-LF_ST_REQ_EXT_DVC_DEAC_2	0
    IDE08073-ENG119933	Remote start cancellation reason store 3-LF_ST_REQ_EXT_DVC_DEAC_3	0
    IDE08074-ENG119934	Remote start cancellation reason store 4-LF_ST_REQ_EXT_DVC_DEAC_4	0
    IDE08075-ENG119935	Remote start cancellation reason store 5-LF_ST_REQ_EXT_DVC_DEAC_5	0
    IDE08495	Activation radiator shutter result	0	 %
    IDE08805	EVAP valve diag. activation condition at minimal load	0.267	 counts
    IDE08806	EVAP valve diag. activation condition at maximum load	613	 mbar
    IDE10366	Chg. press. ctrl. valve: sensor voltage max. value	3.568	 V
    IDE10380	Knock sensor average voltage bank 1	0.234	 V
    IDE10551-MAS05304	Pre-ignition counter for oxygen shift-Cylinder 1	0
    IDE10551-MAS05305	Pre-ignition counter for oxygen shift-Cylinder 2	0
    IDE10551-MAS05306	Pre-ignition counter for oxygen shift-Cylinder 3	0
    IDE10551-MAS05307	Pre-ignition counter for oxygen shift-Cylinder 4	0
    IDE10551-MAS05308	Pre-ignition counter for oxygen shift-Cylinder 5	0
    IDE10551-MAS05309	Pre-ignition counter for oxygen shift-Cylinder 6	0
    IDE10551-MAS05310	Pre-ignition counter for oxygen shift-Cylinder 7	0
    IDE10551-MAS05311	Pre-ignition counter for oxygen shift-Cylinder 8	0
    IDE10552-MAS05304	Pre-ignition counter for torque reduction-Cylinder 1	0
    IDE10552-MAS05305	Pre-ignition counter for torque reduction-Cylinder 2	0
    IDE10552-MAS05306	Pre-ignition counter for torque reduction-Cylinder 3	0
    IDE10552-MAS05307	Pre-ignition counter for torque reduction-Cylinder 4	0
    IDE10552-MAS05308	Pre-ignition counter for torque reduction-Cylinder 5	0
    IDE10552-MAS05309	Pre-ignition counter for torque reduction-Cylinder 6	0
    IDE10552-MAS05310	Pre-ignition counter for torque reduction-Cylinder 7	0
    IDE10552-MAS05311	Pre-ignition counter for torque reduction-Cylinder 8	0
    IDE10553-MAS05304	Pre-ignition counter: cylinder suppress. pre-ignition-Cylinder 1	0
    IDE10553-MAS05305	Pre-ignition counter: cylinder suppress. pre-ignition-Cylinder 2	0
    IDE10553-MAS05306	Pre-ignition counter: cylinder suppress. pre-ignition-Cylinder 3	0
    IDE10553-MAS05307	Pre-ignition counter: cylinder suppress. pre-ignition-Cylinder 4	0
    IDE10553-MAS05308	Pre-ignition counter: cylinder suppress. pre-ignition-Cylinder 5	0
    IDE10553-MAS05309	Pre-ignition counter: cylinder suppress. pre-ignition-Cylinder 6	0
    IDE10553-MAS05310	Pre-ignition counter: cylinder suppress. pre-ignition-Cylinder 7	0
    IDE10553-MAS05311	Pre-ignition counter: cylinder suppress. pre-ignition-Cylinder 8	0
    IDE10554-MAS05304	Pre-ignition counter: cylinder suppress. glow ignition-Cylinder 1	0
    IDE10554-MAS05305	Pre-ignition counter: cylinder suppress. glow ignition-Cylinder 2	0
    IDE10554-MAS05306	Pre-ignition counter: cylinder suppress. glow ignition-Cylinder 3	0
    IDE10554-MAS05307	Pre-ignition counter: cylinder suppress. glow ignition-Cylinder 4	0
    IDE10554-MAS05308	Pre-ignition counter: cylinder suppress. glow ignition-Cylinder 5	0
    IDE10554-MAS05309	Pre-ignition counter: cylinder suppress. glow ignition-Cylinder 6	0
    IDE10554-MAS05310	Pre-ignition counter: cylinder suppress. glow ignition-Cylinder 7	0
    IDE10554-MAS05311	Pre-ignition counter: cylinder suppress. glow ignition-Cylinder 8	0
    IDE10922	Pump current of tank leakage diag.: corrected & filtered	0	 mA
    IDE10970-MAS11563	Number of prevented stop processes-Engine hood open	0
    IDE10970-MAS11835	Number of prevented stop processes-Function locked due to excessive stalling	0
    IDE10970-MAS12085	Number of prevented stop processes-Brake pedal information: plausibility	0
    IDE10989-MAS00106	Immobilizer: historic data-Year	2127
    IDE10989-MAS00107	Immobilizer: historic data-Month	15
    IDE10989-MAS00108	Immobilizer: historic data-Day	31
    IDE10989-MAS00109	Immobilizer: historic data-Hours	31
    IDE10989-MAS00110	Immobilizer: historic data-Minutes	63
    IDE10989-MAS00111	Immobilizer: historic data-Seconds	63
    IDE10989	Immobilizer: historic data	Engine hood open
    IDE10989	Immobilizer: historic data	Brake pedal information: plausibility
    IDE10989	Immobilizer: historic data	Function locked due to excessive stalling
    IDE10994	Poor start counter at start-stop	0
    IDE11115	Start/stop driver request: counter restart by starter	0
    IDE11116	Start/stop driver request: counter internal-motor restart	0
    IDE11598	Tank deaeration valve diagnosis: unweighted input value	0	 counts
    IDE11599	Tank deaeration valve diagnosis: weighted output value	0	 counts
    IDE11600	Tank tightness: ambient temperature	-48	 °C
    IDE11919	Lock time for cooling down of secondary air pump	0	 s
    IDE12137	Tank fill level diagnostic reference value	54	 l
    IDE12138	Fuel consumption per driving cycle	92.52	 l/100km
    ENG102981	AC compressor: speed increase	0
    ENG103860	AC request: speed increase	0
    ENG103042	Accelerator pedal sender: learned end stop	4.126	 V
    ENG103719	Accelerator position	0	 %
    ENG101488	ACF: load	0.064
    ENG103474	Activation of oil pressure switching valve	0
    ENG103323	Additional water pump	1
    ENG101828	Air mass	6.31	 kg/h
    ENG104264	Alternator load	350	 W
    ENG103910	Ambient temperature	21	 °C
    ENG112539	AR_THR_AD_ADD_MMV	-0.008	 cm²
    ENG98377	As	none
    ENG103165	Battery voltage	13.9	 V
    ENG07601	Bypasstool_a2l_name	ORIGINAL A2L
    ENG07600	Bypasstool_manipulation_bit	not active
    ENG101413	Calibration Identification	8V0264M 0001AXAK
    ENG99697	Calibration Verification Number	C8 7B A4 D6
    ENG128780	CAM_DIF_VCP[EX_1]	0	 °
    ENG128781	CAM_DIF_VCP[IN_1]	0	 °
    ENG102002	CAM_OFS_IVVT_IN[1]	0	 °
    ENG112540	CAM_PHA_ENG[GES_EX][CBK_1]	0	 °
    ENG112541	CAM_PHA_ENG[GES_IN][CBK_1]	0	 °
    ENG101169	CAM_PHA_OFS_MAF[IN][1]	0	 °
    ENG112542	CAM_SP_IND_VCP[EX_1]	0	 °
    ENG112543	CAM_SP_IND_VCP[IN_1]	0	 °
    ENG112544	CAM_VCP[EX_1]	0	 °
    ENG112545	CAM_VCP[IN_1]	0	 °
    ENG103849	Cat. ageing: bank 1: actual	0.016
    ENG101785	Cat. temperature: bank 1	563.2875	 °C
    ENG102214	CPU_LOAD	46.8	 %
    ENG125189	CTR_CAM_IN_SP_PI_DET_REQ[0]	0
    ENG125190	CTR_CAM_IN_SP_PI_DET_REQ[1]	0
    ENG125191	CTR_CAM_IN_SP_PI_DET_REQ[2]	0
    ENG125192	CTR_CAM_IN_SP_PI_DET_REQ[3]	0
    ENG101127	CTR_CDN_OBD_RBM	6
    ENG114826	CTR_EDGE_CAM_EX[1]	0
    ENG114827	CTR_EDGE_CAM_IN[1]	11
    ENG100536	CTR_IGK_CYC_RBM	124
    ENG125193	CTR_LAMB_SP_PI_REQ[0]	0
    ENG125194	CTR_LAMB_SP_PI_REQ[1]	0
    ENG125195	CTR_LAMB_SP_PI_REQ[2]	0
    ENG125196	CTR_LAMB_SP_PI_REQ[3]	0
    ENG112554	CTR_MIS_DC_MMV_CYL_SAE[0]	0
    ENG112555	CTR_MIS_DC_MMV_CYL_SAE[1]	0
    ENG112556	CTR_MIS_DC_MMV_CYL_SAE[2]	0
    ENG112557	CTR_MIS_DC_MMV_CYL_SAE[3]	1
    ENG112558	CTR_MIS_TOT_NVMY_SAE	120
    ENG125197	CTR_REQ_IV_OFF_PI_FAST[0]	0
    ENG125198	CTR_REQ_IV_OFF_PI_FAST[1]	0
    ENG125199	CTR_REQ_IV_OFF_PI_FAST[2]	0
    ENG125200	CTR_REQ_IV_OFF_PI_FAST[3]	0
    ENG125201	CTR_REQ_IV_OFF_PI_SLOW[0]	0
    ENG125202	CTR_REQ_IV_OFF_PI_SLOW[1]	0
    ENG125203	CTR_REQ_IV_OFF_PI_SLOW[2]	0
    ENG125204	CTR_REQ_IV_OFF_PI_SLOW[3]	0
    ENG128782	CTR_REQ_IV_OFF_PI_SLOW_TMP[0]	0
    ENG128783	CTR_REQ_IV_OFF_PI_SLOW_TMP[1]	0
    ENG128784	CTR_REQ_IV_OFF_PI_SLOW_TMP[2]	0
    ENG128785	CTR_REQ_IV_OFF_PI_SLOW_TMP[3]	0
    ENG100764	CTR_SUM_SRV_INTL	0
    ENG125205	CTR_TQI_POW_MAX_PI_REQ[0]	0
    ENG125206	CTR_TQI_POW_MAX_PI_REQ[1]	0
    ENG125207	CTR_TQI_POW_MAX_PI_REQ[2]	0
    ENG125208	CTR_TQI_POW_MAX_PI_REQ[3]	0
    ENG119929	CTR_VLD_CAT_GAP_AFL[1]	0
    ENG119930	CTR_VLD_CAT_GAP_AFR[1]	0
    ENG99428	CTR_VLFT_1_SWI_NOT[0]	0
    ENG103626	CTR_VLFT_1_SWI_NOT[1]	0
    ENG100809	CTR_VLFT_1_SWI_NOT[2]	0
    ENG99336	CTR_VLFT_1_SWI_NOT[3]	0
    ENG103025	CTR_VLFT_STND_SWI_NOT[0]	0
    ENG100017	CTR_VLFT_STND_SWI_NOT[1]	0
    ENG100438	CTR_VLFT_STND_SWI_NOT[2]	0
    ENG100736	CTR_VLFT_STND_SWI_NOT[3]	0
    ENG112559	CTR_VVL_LIH_ACT	0
    ENG101271	CTR_VVL_LIH_DEAC	0
    ENG100551	CTR_VVL_SWI_DC	0
    ENG99561	CTR_VVL_SWI_H	0
    ENG101173	CTR_VVL_SWI_L	8
    ENG99084	Cycle flags: (completed cycles): cat: lambda probe heater	9
    ENG100943	Cycle flags: (completed cycles): lambda probes: EGR	0
    ENG99495	Cycle flags: (completed tests): lambda adaption:	8
    ENG103597	Cycle flags:(completed cycles):lambda probes:sec.air sys.	48
    ENG101652	Cylinder shut-off: cylinder suppression	0
    ENG102657	DIAG_INST[0]	NO_ERROR
    ENG99120	DIAG_INST[1]	NO_ERROR
    ENG103260	DIAG_INST[2]	NO_ERROR
    ENG99710	DIAG_INST[3]	NO_ERROR
    ENG102667	DIAG_INST[4]	NO_ERROR
    ENG102739	DIAG_INST[5]	NO_ERROR
    ENG100162	DIAG_INST[6]	NO_ERROR
    ENG99103	DIAG_INST[7]	NO_ERROR
    ENG99261	DIAG_INST[8]	NO_ERROR
    ENG103622	DIAG_INST[9]	NO_ERROR
    ENG112560	DIST_ACT_MIL_SAE	0	 km
    ENG112561	DIST_DTC_CLR_SAE	121	 km
    ENG103766	DIST_ENG_RUN_IN	138386.7	 m
    ENG100531	DIST_ST	138400	 m
    ENG100131	ECU_STATE	SYN_ENG_IGK_ON
    ENG100152-ENG104003	ECUNAME-ECU	ECM
    ENG100152	ECUNAME	EngineControl
    ENG103712	EFPPWM_MIN_AD	0	 %
    ENG104044	Engine load	8.984375	 %
    ENG102494	Engine speed: actual	704	 /min
    ENG102783	Engine: operating status	IS
    ENG103667	ENVD_0_MON	0
    ENG100777	ENVD_0_MON_3	0
    ENG126934	ENVD_0_MON_3_VD	0
    ENG99424	ENVD_1_MON	0
    ENG100344	ENVD_1_MON_3	0
    ENG126935	ENVD_1_MON_3_VD	0
    ENG99790	ENVD_2_MON	0
    ENG100541	ENVD_2_MON_3	0
    ENG126936	ENVD_2_MON_3_VD	0
    ENG99455	ENVD_3_MON	0
    ENG101268	ENVD_3_MON_3	0
    ENG126937	ENVD_3_MON_3_VD	0
    ENG01743	ENVD_4_MON	0
    ENG01744	ENVD_5_MON	0
    ENG01745	ENVD_6_MON	0
    ENG99752	Error flags: (completed cycles): cat: lambda probe heater	0
    ENG101275	Error flags: (completed cycles): lambda probes: EGR	0
    ENG104132	Error flags: (completed cycles): lambda probes:sec.air sys.	0
    ENG101942	ESI (extended service intervals) oil warning threshold	53.8125	 mm
    ENG112562	FAC_AR_THR_AD	0	 %
    ENG104194	FAC_H_RNG_LAM_AD[1]	0	 %
    ENG104151	FAC_L_RNG_LAM_AD[1]	-1.772	 %
    ENG100298	FAC_LAM_CP	-12.939	 %
    ENG100108	FAC_LAM_LIM[1]	-13.141	 %
    ENG99722	FAC_LAM_TCO_A[1]	0	 %
    ENG103521	FAC_LAM_TCO_B[1]	0	 %
    ENG103641	FAC_LAM_TCO_C[1]	0	 %
    ENG101578	FAC_LAM_TCO_D[1]	0	 %
    ENG100685	FAC_LAM_TCO_E[1]	0	 %
    ENG103307	FAC_MAF_MAX	0.26297
    ENG99791	FAC_SLOP_IV[1]	0
    ENG102306	FAC_TPS_1_SAE	11.71875	 %
    ENG102292	FAC_TPS_1_SAE	11.71875	 %
    ENG99630	Fan control relay: fan run-on	2
    ENG101437	Fan request from air conditioner	0	 %
    ENG103644	FRF_IMMO_SNAPSHOT_BYTE1	0
    ENG102892	FRF_IMMO_SNAPSHOT_BYTE2	0
    ENG100521	FRF_IMMO_SNAPSHOT_BYTE3	0
    ENG101852	FRF_IMMO_SNAPSHOT_BYTE4	0
    ENG99312	FRF_IMMO_SNAPSHOT_BYTE5	0
    ENG103956	FRF_IMMO_SNAPSHOT_BYTE6	0
    ENG128786	FTL_SAE	92.15686426	 %
    ENG104248	Fuel consumption signal	11474	 µl
    ENG101667	Fuel pump: adaption value	0	 %
    ENG100969	Fuel pump: fuel pressure: I-controller	0	 %
    ENG100250	Fuel regulating valve: duty cycle	15.39	 %
    ENG101692	Fuel supply system: high-pressure regulator	344.588	 hPa
    ENG114828	FUP_EFP_MES	11000.8	 hPa
    ENG103553	FUP_EFP_ST_H	0	 hPa
    ENG101056	FUP_EFP_ST_L	0	 hPa
    ENG99950	FUP_EFP_STOP_H	0	 hPa
    ENG100784	FUP_EFP_STOP_L	0	 hPa
    ENG102108	FUP_H	45192	 hPa
    ENG112563	FUP_H_SAE	4420	 kPa
    ENG103368	Gearbox -CAN bus messages	126839
    ENG99170	Height correction	981.25	 hPa
    ENG103575	High-pressure system: regulator	-0.55	 mg
    ENG103879	High-pressure system: regulator: mobile part	2.46	 mg
    ENG102603	High-pressure system: status	MFP_CTL
    ENG101567	Idling speed stabilisation: duty cycle/AC compressor torque	0.5	 Nm
    ENG101946	Idling stabilisation: operating status	0
    ENG100345	IGA_ADJ_KNK[0]	0	 °
    ENG103593	IGA_ADJ_KNK[1]	0	 °
    ENG103360	IGA_ADJ_KNK[2]	0	 °
    ENG99404	IGA_ADJ_KNK[3]	0	 °
    ENG100425	IGA_IGC[0]	-6	 °
    ENG101655	IGA_IGC[1]	-6.375	 °
    ENG100410	IGA_IGC[2]	-5.25	 °
    ENG100407	IGA_IGC[3]	-4.5	 °
    ENG112564	IGA_IGC_SAE	-3.5	 °
    ENG101741	Intake air temperature	44.25	 °C
    ENG100634	In-use Per Tr: 16 or 20 cou sec O2 Sens Mon Con Enc Cou B 1	6	 counts
    ENG125209	KNKS_ERR_REL[0]	0.0977	 V
    ENG99741	LAMB_DELTA_AD_LAM_ADJ[1]	0.00006
    ENG99601	LAMB_DELTA_I_LAM_ADJ[1]	0.00006
    ENG112565	LAMB_DELTA_SUM_LAM_ADJ_AD[1]	0.00006
    ENG99674	Lambda controller: bank 1 (averaged value)	-12.929	 %
    ENG101381	Lambda probe 1: bank 1: status	1
    ENG101039	Lambda probe 1: bank 1: status	0
    ENG102886	Lambda probe 1: bank 1: status	0
    ENG104200	Lambda probe 2: bank 1: status	0
    ENG101336	Lambda probe 2: bank 1: status	1
    ENG99661	Lambda probe ageing: bank 1: dynamic factor	0
    ENG101869	Lambda probe ageing: bank 1: probe 1: short trip result	311.85	 °C
    ENG100478	Lambda probe correction: duty cycle offset: bank 1	-0.00592
    ENG103776	Lambda probe heater: bank 1: probe 2: short trip result	0
    ENG102380	Lambda probe heater: resistance: bank 1: probe 2	328	 Ohm
    ENG99353	Lambda probe voltage: bank 1: probe 1 (broadband probe)	1.987	 V
    ENG102763	Lambda probes actual: bank1	1.0107
    ENG104114	Lambda probes specified: bank1	1.0029
    ENG06592	LF_COSI_CTL_ERR_A	0
    ENG06593	LF_COSI_CTL_ERR_B	0
    ENG112566	LF_DPS_CYC_ERR_RAW_BSW[1]	16384
    ENG112567	LF_DPS_CYC_ERR_RAW_BSW[2]	16384
    ENG112568	LF_DPS_CYC_ERR_VLD_BSW[1]	65535
    ENG112569	LF_DPS_CYC_ERR_VLD_BSW[2]	65535
    ENG112570	LF_DPS_INI_ERR_RAW_BSW[1]	0
    ENG112571	LF_DPS_INI_ERR_RAW_BSW[2]	0
    ENG112572	LF_IV_ERR_RAW_BSW[0]	0
    ENG112573	LF_IV_ERR_RAW_BSW[1]	0
    ENG112574	LF_IV_ERR_RAW_BSW[2]	0
    ENG112575	LF_IV_ERR_RAW_BSW[3]	0
    ENG112576	LF_IV_ERR_VLD_BSW[0]	8191
    ENG112577	LF_IV_ERR_VLD_BSW[1]	8191
    ENG112578	LF_IV_ERR_VLD_BSW[2]	8191
    ENG112579	LF_IV_ERR_VLD_BSW[3]	8191
    ENG101645	LF_VVL_DIAG_SWI_NOT	0
    ENG127734-MAS00106	Life_cycle_data_start_requirement_development-Year	2127
    ENG127734-MAS00107	Life_cycle_data_start_requirement_development-Month	15
    ENG127734-MAS00108	Life_cycle_data_start_requirement_development-Day	31
    ENG127734-MAS00109	Life_cycle_data_start_requirement_development-Hours	31
    ENG127734-MAS00110	Life_cycle_data_start_requirement_development-Minutes	63
    ENG127734-MAS00111	Life_cycle_data_start_requirement_development-Seconds	63
    ENG127734	Life_cycle_data_start_requirement_development	Steering
    ENG127734	Life_cycle_data_start_requirement_development	Quattro Sport
    ENG127734	Life_cycle_data_start_requirement_development	Multifunction unit control module
    ENG127734	Life_cycle_data_start_requirement_development	Parking aid
    ENG127734	Life_cycle_data_start_requirement_development	brakes
    ENG127734	Life_cycle_data_start_requirement_development	Immobilizer
    ENG127734	Life_cycle_data_start_requirement_development	Kessy
    ENG127734	Life_cycle_data_start_requirement_development	Engine
    ENG127734	Life_cycle_data_start_requirement_development	Level control system
    ENG127734	Life_cycle_data_start_requirement_development	ACC
    ENG127734	Life_cycle_data_start_requirement_development	Front sensor system for driver assistance systems
    ENG127734	Life_cycle_data_start_requirement_development	All-wheel electronics
    ENG127734	Life_cycle_data_start_requirement_development	12 V electrical system
    ENG127734	Life_cycle_data_start_requirement_development	Transmission
    ENG127734	Life_cycle_data_start_requirement_development	Front axis lift system
    ENG127734	Life_cycle_data_start_requirement_development	A/C
    ENG127734	Life_cycle_data_start_requirement_development	Convertible top control module
    ENG127735-MAS00106	Life_cycle_data_stop_prohibition_development-Year	2127
    ENG127735-MAS00107	Life_cycle_data_stop_prohibition_development-Month	15
    ENG127735-MAS00108	Life_cycle_data_stop_prohibition_development-Day	31
    ENG127735-MAS00109	Life_cycle_data_stop_prohibition_development-Hours	31
    ENG127735-MAS00110	Life_cycle_data_stop_prohibition_development-Minutes	63
    ENG127735-MAS00111	Life_cycle_data_stop_prohibition_development-Seconds	63
    ENG127735	Life_cycle_data_stop_prohibition_development	Engine
    ENG127735	Life_cycle_data_stop_prohibition_development	A/C
    ENG127735	Life_cycle_data_stop_prohibition_development	Convertible top control module
    ENG127735	Life_cycle_data_stop_prohibition_development	Steering
    ENG127735	Life_cycle_data_stop_prohibition_development	Multifunction unit control module
    ENG127735	Life_cycle_data_stop_prohibition_development	Parking aid
    ENG127735	Life_cycle_data_stop_prohibition_development	ACC
    ENG127735	Life_cycle_data_stop_prohibition_development	12 V electrical system
    ENG127735	Life_cycle_data_stop_prohibition_development	Transmission
    ENG127735	Life_cycle_data_stop_prohibition_development	Front axis lift system
    ENG127735	Life_cycle_data_stop_prohibition_development	Quattro Sport
    ENG127735	Life_cycle_data_stop_prohibition_development	Level control system
    ENG127735	Life_cycle_data_stop_prohibition_development	Front sensor system for driver assistance systems
    ENG127735	Life_cycle_data_stop_prohibition_development	All-wheel electronics
    ENG127735	Life_cycle_data_stop_prohibition_development	brakes
    ENG127735	Life_cycle_data_stop_prohibition_development	Immobilizer
    ENG127735	Life_cycle_data_stop_prohibition_development	Kessy
    ENG127733-MAS00106	Life_cycle_data_system_failure-Year	2127
    ENG127733-MAS00107	Life_cycle_data_system_failure-Month	15
    ENG127733-MAS00108	Life_cycle_data_system_failure-Day	31
    ENG127733-MAS00109	Life_cycle_data_system_failure-Hours	31
    ENG127733-MAS00110	Life_cycle_data_system_failure-Minutes	63
    ENG127733-MAS00111	Life_cycle_data_system_failure-Seconds	63
    ENG127733	Life_cycle_data_system_failure	Quattro Sport
    ENG127733	Life_cycle_data_system_failure	Steering
    ENG127733	Life_cycle_data_system_failure	Immobilizer
    ENG127733	Life_cycle_data_system_failure	Kessy
    ENG127733	Life_cycle_data_system_failure	Engine
    ENG127733	Life_cycle_data_system_failure	Multifunction unit control module
    ENG127733	Life_cycle_data_system_failure	Parking aid
    ENG127733	Life_cycle_data_system_failure	12 V electrical system
    ENG127733	Life_cycle_data_system_failure	Transmission
    ENG127733	Life_cycle_data_system_failure	Convertible top control module
    ENG127733	Life_cycle_data_system_failure	A/C
    ENG127733	Life_cycle_data_system_failure	Level control system
    ENG127733	Life_cycle_data_system_failure	ACC
    ENG127733	Life_cycle_data_system_failure	Front sensor system for driver assistance systems
    ENG127733	Life_cycle_data_system_failure	All-wheel electronics
    ENG127733	Life_cycle_data_system_failure	brakes
    ENG127733	Life_cycle_data_system_failure	Front axis lift system
    ENG122701	LMVDes_st_Mod_Out_VW	8
    ENG122702	LMVDes_v_Max_Man_Lim_VW	511.992	 km/h
    ENG122703	LMVLim_v_Auth_Max_Out_VW	200	 km/h
    ENG100402	LOIL_SUM_SRV_INTL	0	 mm
    ENG99162	LV_ACC_RED_CMD	0
    ENG102235	LV_ATB_ACT_1	0
    ENG102541	LV_ATB_ACT_2	0
    ENG114829	LV_BPA_LIH_REQ[0]	0
    ENG99095	LV_CAN_HOOD_SWI	1
    ENG128787	LV_CMD_RCL_OPEN	0
    ENG128788	LV_ECRAS_FB_DIAG_POS_RESP[0]	0
    ENG103049	LV_EFPPWM_AD_STOP	1
    ENG101712	LV_ENG_RUN_IN	1
    ENG100267	LV_ENG_RUN_IN_EXT_ADJ	0
    ENG103319	LV_ERR_VLFT_1_SWI[1]	0
    ENG103549	LV_ERR_VLFT_1_SWI[2]	0
    ENG103191	LV_ERR_VLFT_1_SWI[3]	0
    ENG101989	LV_ERR_VLFT_1_SWI[4]	0
    ENG102313	LV_ERR_VLFT_STND_SWI[1]	0
    ENG103044	LV_ERR_VLFT_STND_SWI[2]	0
    ENG103443	LV_ERR_VLFT_STND_SWI[3]	0
    ENG100487	LV_ERR_VLFT_STND_SWI[4]	0
    ENG112471	LV_IGK	1
    ENG103773	LV_INH_STR_RLY	0
    ENG100044	LV_LOIL_L_WARN	0
    ENG103492	LV_LOIL_L_WARN_ACT	0
    ENG103908	LV_LOIL_L_WARN_TMP	0
    ENG103716	LV_POIL_SWI_H	1
    ENG100912	LV_POIL_SWI_L	1
    ENG112586	LV_PWR_RLY[0]	1
    ENG102417	LV_TPS_AD_ACT	0
    ENG100842	LV_TPS_AD_DIAG_ERR	0
    ENG103996	LV_TPS_AD_REQ	0
    ENG112587	LV_VCP_AD_END	1
    ENG102523	MAF	108.71	 mg/stroke
    ENG99288	MAF_DIF_CAM_OFS_AD_SQ_TOT	0	 kg²/h²
    ENG112588	MAP_MES_SAE	36	 kPa
    ENG103501	MASS_SA_REL[0]	0
    ENG100896	MASS_SA_REL_21_PHA	0
    ENG103045	MASS_SA_REL_22_PHA	0
    ENG103346	MFF_ADD_LAM_AD[1]	0.53	 mg/stroke
    ENG126493	MFF_MPL_ADD_LAM_AD[1][1]	0.53	 mg/stroke
    ENG101360	Misfire detection active	0
    ENG102335	Misfires all cylinders per 1000 rpm	0
    ENG128796	N_SP_IS_CLC	700	 /min
    ENG103004	N_TCHA	15045.2	 /min
    ENG112590	N_TOOTH	715	 /min
    ENG107737-ENG112538	NC_NR_DIAG_RBM-NC Value	154
    ENG126111	NL_PRE[0]	0.15327	 V
    ENG126112	NL_PRE[1]	0.16365	 V
    ENG126113	NL_PRE[2]	0.14938	 V
    ENG126114	NL_PRE[3]	0.1722	 V
    ENG128789	NR_CYC_AD_DC_BAL_HOM[RNG_H]	0
    ENG128790	NR_CYC_AD_DC_BAL_HOM[RNG_IS]	0
    ENG128791	NR_CYC_AD_DC_BAL_HOM[RNG_L]	0
    ENG128792	NR_CYC_AD_DIAG_BAL_HOM[0]	0
    ENG128793	NR_CYC_AD_DIAG_BAL_HOM[1]	0
    ENG128794	NR_CYC_AD_DIAG_BAL_HOM[2]	0
    ENG128795	NR_CYC_AD_DIAG_BAL_HOM[3]	0
    ENG112589	NR_CYL_FIRST_VVL_SWI	0
    ENG99776	NR_CYL_VVL_H_ACK	4
    ENG119936	O2L_MAX_CAT_GAP_AFL_MV[1]	0	 g
    ENG119937	O2L_MAX_CAT_GAP_AFR_MV[1]	0	 g
    ENG99157	PRS_SA_DIF	0	 hPa
    ENG02464	PRS_UP_THR_MES	980.75	 hPa
    ENG112591	PSN_EDGE_REL_AD_CAM_EX[1][1]	0	 °
    ENG112592	PSN_EDGE_REL_AD_CAM_IN[1][1]	-0.25	 °
    ENG114830	PSN_EDGE_REL_AD_CAM_SAVE_EX[1][1]	0	 °
    ENG114831	PSN_EDGE_REL_AD_CAM_SAVE_EX[1][2]	0	 °
    ENG114832	PSN_EDGE_REL_AD_CAM_SAVE_IN[1][1]	-0.25	 °
    ENG114833	PSN_EDGE_REL_AD_CAM_SAVE_IN[1][2]	-1.625	 °
    ENG128797	PV	0	 %
    ENG102195	PV_AV_1	0	 %
    ENG99137	PV_AV_2	0	 %
    ENG101068	PV_AV_H	0	 %
    ENG112593	PWM_ACT_VCP[EX_1]	90.002	 %
    ENG112594	PWM_ACT_VCP[IN_1]	90.002	 %
    ENG101350	PWM_ETC	-12.546	 %
    ENG112595	PWM_HLD_VCP[EX_1]	14.923	 %
    ENG112596	PWM_HLD_VCP[IN_1]	10.077	 %
    ENG112597	PWM_PAS_VCP[EX_1]	10.236	 %
    ENG112598	PWM_PAS_VCP[IN_1]	10.077	 %
    ENG101201	Radiator fan 1: run-on: status	600W
    ENG102359	Radiator fan 2: run-on: status	NO_ECF
    ENG119939	RATIO_O2L_LIM_CAT_GAP_AFL_MV[1]	0
    ENG119940	RATIO_O2L_LIM_CAT_GAP_AFR_MV[1]	0
    ENG102377	Ready and error flags	4
    ENG112599	RVC_AV	128.78	 °
    ENG112601	RVC_SP	128.5	 °
    ENG112600	RVCPWM	0	 %
    ENG103248	SEG_AD_MMV_ER[0]	0	 ‰
    ENG101135	SEG_AD_MMV_ER[1]	0.4027	 ‰
    ENG99078	SEG_AD_MMV_ER[2]	-0.0865	 ‰
    ENG103257	SEG_AD_MMV_ER[3]	0.4614	 ‰
    ENG102511	SEG_AD_MMV_ER_H[0]	0	 ‰
    ENG103258	SEG_AD_MMV_ER_H[1]	0.6588	 ‰
    ENG99291	SEG_AD_MMV_ER_H[2]	-0.0665	 ‰
    ENG99954	SEG_AD_MMV_ER_H[3]	0.7043	 ‰
    ENG100568	SEG_AD_MMV_ER_L[0]	0	 ‰
    ENG100601	SEG_AD_MMV_ER_L[1]	0.4027	 ‰
    ENG102668	SEG_AD_MMV_ER_L[2]	-0.0865	 ‰
    ENG101232	SEG_AD_MMV_ER_L[3]	0.4614	 ‰
    ENG101561	SEG_AD_MMV_ER_MID[0]	0	 ‰
    ENG102964	SEG_AD_MMV_ER_MID[1]	0.6271	 ‰
    ENG100890	SEG_AD_MMV_ER_MID[2]	-0.0624	 ‰
    ENG99793	SEG_AD_MMV_ER_MID[3]	0.6712	 ‰
    ENG103381	Shut-off time	3.5	 s
    ENG109006-ENG100882	Spark_efficiency_deviation_at_idle_maximum-EFF_IGA_CST_QUO_IS_MAX	15	 %
    ENG109007-ENG99938	Spark_efficiency_deviation_at_part_load_maximum-EFF_IGA_CST_QUO_PL_MAX	0	 %
    ENG102971	Start adaption: temperature adaption factor 1	1
    ENG102489	Start adaption: temperature adaption factor 2	1
    ENG100723	Start adaption: temperature adaption factor 3	1
    ENG100919	Starter control: interlock switch	0
    ENG100800	Starter: start relay 1	0
    ENG99979	Starter: start relay 2	0
    ENG102033	STATE_BPA[0]	OPM
    ENG102127	STATE_COMC_NVLD	Wait
    ENG112602	STATE_CRK_STST	CRK_STST_ACQ_SHO_LEVEL
    ENG114834	STATE_CRU_OFF_IRR_CUS	0
    ENG114835	STATE_CRU_OFF_REV_CUS	18415680
    ENG112603	STATE_EOL_VVL	DEAC
    ENG112605	STATE_LS_SAE[1]	CL
    ENG104238	STATE_NVLD	COMPLETE_DIAG
    ENG112606	STATE_PWM_VCP[EX_1]	pas
    ENG112607	STATE_PWM_VCP[IN_1]	HLD
    ENG101078	STATE_READY_OBD_1	7
    ENG100369	STATE_READY_OBD_3	0
    ENG100342	STATE_REQ_NVLD	NO_REQ
    ENG109090	STATE_SW_MVB	SC8S5010 CBS00I0
    ENG128798	STATE_T_ES_RD	0
    ENG128799	STATE_T_ES_VLD_RD	1
    ENG112608	STATE_VCP	ACT_ADAPT
    ENG114836	STATE_VCV_CLOSE_SL	AD_ON
    ENG103723	STATE_VVL_MNG	VVL_H
    ENG112609	T_ACT_MIL_SAE	0	 min
    ENG112494	T_AST_SAE	173	 s
    ENG104148	T_COOL_LOIL	454.8	 ms
    ENG112613	T_DTC_CLR_SAE	254	 min
    ENG102790	T_EFP_MEM_H	0	 s
    ENG102123	T_EFP_MEM_L	0	 s
    ENG109299	T_ES	0	 min
    ENG112615	T_ES_CNT	0
    ENG112616	T_ES_DC	3	 min
    ENG99463	T_ES_H	0	 s
    ENG128802	T_IGK	176.55	 s
    ENG99398	T_POP_COC_INTER_1	0	 s
    ENG102747	T_PWL	0	 s
    ENG128803	T_PWL_CAN	37.6	 s
    ENG112636	T_SWI_VVL_ACR	69.4	 ms
    ENG101325	T_TEMP_SIG_LOIL	56.3	 ms
    ENG99126	T_VS_TOL_LOCK	0	 min
    ENG125440	TAA	21	 °C
    ENG102048	Tank breather valve: duty cycle	21.09375	 %
    ENG101339	Tank breather valve: short trip result	0.5452	 kg/h
    ENG100439	Tank level	0
    ENG112610	TCO_1_FIRST_ST	76	 °C
    ENG112611	TCO_1_ST	76	 °C
    ENG112612	TCO_1_SYS	98	 °C
    ENG103434	TCO_A_LAM_AD_WUP[1]	-5.25	 °C
    ENG100381	TCO_B_LAM_AD_WUP[1]	9.75	 °C
    ENG101581	TCO_C_LAM_AD_WUP[1]	24.75	 °C
    ENG100354	TCO_D_LAM_AD_WUP[1]	35.25	 °C
    ENG101973	TCO_E_LAM_AD_WUP[1]	45	 °C
    ENG128800	TCO_MDL[STUCK_L_COOL_MON]	53.289	 °C
    ENG124460	TCO_MDL[TH]	64.031	 °C
    ENG100390	TCO_MIN_INTER_LAM_AD_WUP[1]	97.5	 °C
    ENG100853	TCO_MIN_LAM_AD_WUP[1]	50.25	 °C
    ENG102279	TCS/ESP: specified torque	23.75	 Nm
    ENG99857	TCS: status	0
    ENG110436	TEG_DYN_LS_DOWN[1]	481.1625	 °C
    ENG110437	TEG_DYN_LS_UP[1]	408.6625	 °C
    ENG101941	TEMP_CAT_STAT_MDL[1]	437.6	 °C
    ENG112614	TEMP_CAT_UP_1_SAE	529.7	 °C
    ENG114837	TFPA	80	 °C
    ENG114838	TFU_HPP	66	 °C
    ENG99608	Throttle valve adjuster: adaption status	ST_CHK_END
    ENG101411	Throttle valve angle	1.736	 °
    ENG102845	Throttle valve deviation	1.547	 %
    ENG126115	TI_1_MES_MPI[0]	0	 ms
    ENG126116	TI_1_MES_MPI[1]	0	 ms
    ENG126117	TI_1_MES_MPI[2]	0	 ms
    ENG126118	TI_1_MES_MPI[3]	0	 ms
    ENG126119	TI_MES_4[PLS_1][0]	0.876	 ms
    ENG126120	TI_MES_4[PLS_1][1]	0.832	 ms
    ENG126121	TI_MES_4[PLS_1][2]	0.844	 ms
    ENG126122	TI_MES_4[PLS_1][3]	0.944	 ms
    ENG126123	TI_MES_4[PLS_2][0]	0	 ms
    ENG126124	TI_MES_4[PLS_2][1]	0	 ms
    ENG126125	TI_MES_4[PLS_2][2]	0	 ms
    ENG126126	TI_MES_4[PLS_2][3]	0	 ms
    ENG126127	TI_MES_4[PLS_3][0]	0	 ms
    ENG126128	TI_MES_4[PLS_3][1]	0	 ms
    ENG126129	TI_MES_4[PLS_3][2]	0	 ms
    ENG126130	TI_MES_4[PLS_3][3]	0	 ms
    ENG128801	TIA_CHA_DOWN_MV	55.77	 °C
    ENG125276	TIG_MES_SAE[IM]	45	 °C
    ENG103351	Time since engine start	179.2	 s
    ENG112634	TLTS_MES[TCE]	98.555	 °C
    ENG112635	TMAG_VCP	78	 °C
    ENG110444	TPS_AD_CDN_MIS	32
    ENG114839	TPS_ETC	1.736	 °
    ENG99274	TPS_SP	1.729	 °
    ENG103021	TQ_CONV	4	 Nm
    ENG128804	TQI_ADD_ACT	29.84375	 Nm
    ENG101426	TQI_GS_FAST_INC	0	 Nm
    ENG128805	TQI_N_TCHA_MAX	1023.96875	 Nm
    ENG102329	TTIP_MES_LS_UP[1]	785	 °C
    ENG100355	V_FUP_EFP_MV	4.995	 V
    ENG100739	V_PVS_1_BAS	0.7959	 V
    ENG114840	V_PVS_KD	0	 V
    ENG99514	VBOOST	64.5	 V
    ENG103201	VCV_CLOSE_RNG	25.5	 °
    ENG102311	Vehicle speed: filtered	0	 km/h
    ENG122704	VLCAvl_st_Pt_VW	4
    ENG122705	VLCReq_st_Dem_VW	0
    ENG112639	VLS_DOWN_SAE[1]	0.78	 V
    ENG128806	VOL_FLOW_CHA_UP_RED_MV	0.001526	 m³/s
    ENG101929	VP_TPS_1	0.5859	 V
    ENG102985	VP_TPS_2	4.4043	 V
    ENG100421	VP_TPS_AD_EL_BOL_1	0.5029	 V
    ENG103444	VP_TPS_AD_EL_BOL_2	4.4876	 V
    ENG101674	VP_TPS_AD_LIH_1	0.791	 V
    ENG99507	VP_TPS_AD_LIH_2	4.1992	 V
    Elapsed Time: 01:06
    blockmap-OBD_3VWH17AU5JM758941-20180826-1121.CSV
    ;33-OBD2
    ;Sunday	26	August	2018	11:21:36:04045
    ;VCDS Version: Beta 18.7.2 (x64)  Data version: 20180808 DS295.0
    ;VCID: 70BADAA93A23EF57612-8024
    3	Fuel system 1/2 status	Engine off	Engine off
    4	Calculated load value	0.00%
    5	Engine coolant temperature	77 °C
    6	Short Term Trim - Bank 1	0.00%
    7	Long Term Trim - Bank 1	4.70%
    0B	Intake Manifold Absolute Pressure	98 kPa abs
    0C	Engine RPM	0 /min
    0D	Vehicle speed	0 km/h
    0E	Ignition timing advance for cyl #1	-1.0 Degrees
    0F	Intake air temperature	54 °C
    11	Throttle position sensor	15.30%
    12	Secondary Air Status	Atmosphere/off
    13	Location of O2 sensors	B1S1 B1S2
    15	Bank 1 Sensor 2 Status	1.275 V
    1C	OBD Requirements Met	OBD + OBD II
    1F	Time since engine start	0 s
    21	Distance travelled with MIL on	0 km
    23	Fuel Rail Press (rel)	3010 kPa rel
    2E	Commanded Evaporative Purge	0.00%
    2F	Fuel Level Input	92.20%
    30	Warm-ups since DTC cleared	22
    31	Distance since DTC cleared	121 km
    33	Barometric pressure	98 kPa abs
    34	Bank 1 Sensor 1 Status	0.000 Lambda	-128.000 mA
    3C	B1S1 Cat. Temp.	225.0 °C
    42	Control module voltage	14.433 V	14.000 V
    43	Absolute Load Value	0%
    44	Commanded Equivalence Ratio	1.000 Lambda
    45	Relative Throttle Position	5%
    46	Ambient Air Temp	24 °C
    47	Absolute Throttle Position B	16%
    49	Accelerator Pedal Position D	16%	16%
    4A	Accelerator Pedal Position E	15%
    4C	Commanded Throttle Actuator Control	5%
    51	Fuel type	Gasoline
    56	Long term sec. O2 trim bank 1/3	0.00%
    70	Boost Press Ctrl A/B	BP_A act:98 kPa
    Mode 9 : Calibration Identification
    Type 02 - VIN : 3VWH17AU5JM758941 (Address E8)
    Type 04 - Calibration ID : 8V0264M 0001AXAK (Address E8)
    Type 04 - Calibration ID : 0D9300018   5201 (Address E9)
    Type 06 - Calibration Verification Number : C87BA4D6 (Address E8)
    Type 06 - Calibration Verification Number : 0000F57F (Address E9)
    Type 08 - In-use performance tracking :
        OBD Monitoring Conditions Encountered count : 6
        Ignition cycle count : 123
        Conditions completion count / Specified conditions encountered count
             Catalyst monitor bank 1 : 5 / 6
             Catalyst monitor bank 2 : 0 / 0
             O2 Sensor monitor bank 1 : 7 / 6
             O2 Sensor monitor bank 2 : 0 / 0
             EGR-VVT monitor : 26 / 6
             AIR monitor : 32 / 3
             EVAP monitor : 9 / 3
             Secondary O2 Sensor monitor bank 1 : 4 / 6
             Secondary O2 Sensor monitor bank 2 : 0 / 0
    Type 0A - Controller Name : ECM-EngineControl (Address E8)
    Type 0A - Controller Name : TCM-TransmisCtrl (Address E9)
    United States
    02-Auto Trans
    adpmap-02-0D9-300-018_3VWH17AU5JM758941-20180826-1115.CSV
    KOEO
    ;SW:0D9-300-018   HW:02E-927-770-AS ---  Auto Trans
    ;Component:DQ250-6A MQB  H54 5201	 Coding:0014
    ;EV_TCMDQ250021	1001	EV_TCMDQ250021.rod
    ;Sunday	26	August	2018	11:15:16:04045
    ;VCID: 59EC870DC9998E1FB6C-800C
    IDE06425-Roller test bench mode: functional	not activated 	1
    Elapsed Time: 00:00
    blockmap-02-0D9-300-018_3VWH17AU5JM758941-20180826-1114.CSV
    KOEO
    ;Sunday	26	August	2018	11:14:55:04045
    Group	Description	Actual
    IDE00018	Voltage terminal 15	14	 V
    IDE00019	Voltage terminal 30	14	 V
    IDE00021-ENG99543	Engine speed-Engine RPM	0	 /min
    IDE00022-ENG103074	Transmission input speed-Transmission Input Speed Sensor	0	 /min
    IDE00024	Transmission fluid temperature	59	 °C
    IDE00075-ENG99967	Vehicle speed-Vehicle Speed Sensor	0	 km/h
    IDE00086-ENG98363	Accelerator position-Accelerator pedal position	0	 %
    IDE00091-ENG101172	Status of starter lock-Status Engine Starter Lock	Activate
    IDE00094	Kick-down status	OFF
    IDE00095-ENG101643	Status of selector lever lock-Status Shift Lock	active
    IDE00096-ENG100569	Selector lever position-Shift Position	Position P Stop
    IDE00102-ENG102028	Control Module temperature-Control modul temperature	61	 °C
    IDE00130-ENG103124	Transmission specified idle RPM-Idle Speed Commanded Value	600	 /min
    IDE00322-ENG100540	Status of basic setting-Basic Settings Status	0
    IDE00323-ENG09093	Security Access: Number of invalid keys-Counter Value	0
    IDE00451-ENG103018	Currently running routine-Current Test Routine	0
    IDE00872-ENG102188	Current of main pressure valve-Oil Pressure Actual Current	0	 mA
    IDE01588-ENG101855	Driving direction-M015 SvnNAbRichtung	not known
    IDE02221	Engine torque: qualification	valid
    IDE02713	Brake Light Switch	not activated
    IDE02714	Brake test switch	not activated
    IDE02717-ENG102076	Tiptronic upshift-Tiptronic Up	OFF
    IDE02718-ENG101063	Tiptronic downshift-Tiptronic Down	OFF
    IDE02719-ENG99606	Selector lever position made plausible-Shift Position Plausible	P
    IDE02720-ENG103810	Transmission input speed (RPM) shaft 1-Transmission Input Speed Shaft 1	0	 /min
    IDE02721-ENG100916	Transmission input speed (RPM) shaft 2-Transmission Input Speed Shaft 2	0	 /min
    IDE02722-ENG101964	Transmission output speed (RPM) shaft 1-Transmission Output Speed Shaft 1	0	 /min
    IDE02723-ENG100382	Transmission output speed (RPM) shaft 2-Transmission Output Speed Shaft 2	0	 /min
    IDE02735-ENG100209	Display of driving mode in instrument panel-Display Driving Position	P
    IDE02736-ENG100252	Display of gear in instrument panel-Display Driving Gear	no gear engaged
    IDE02790-ENG104124	Specified torque clutch 1-Clutch 1 Commanded Torque	-600	 Nm
    IDE02796-ENG103463	Current of valve for clutch 1 specified value-Current Valve Clutch 1 Commanded Value	0	 mA
    IDE02797-ENG100730	Current of valve for clutch 1 actual value-Current Valve Clutch 1 Actual Value	0	 mA
    IDE02800-ENG100171	Specified torque clutch 2-Clutch 2 Commanded Torque	-600	 Nm
    IDE02805-ENG99237	Current of valve for clutch 2 specified value-Current Valve Clutch 2 Commanded Value	0	 mA
    IDE02806-ENG103118	Current of valve for clutch 2 actual value-Current Valve Clutch 2 Actual Value	0.4	 mA
    IDE02862-ENG103213	Production data transmission-Aggregatekennzeichnung (Getriebe)	6
    IDE02862-ENG103083	Production data transmission-Baudatum	170718
    IDE02862-ENG104019	Production data transmission-Getriebekennbuchstabe	SYL
    IDE02862-ENG99175	Production data transmission-Kassel	K
    IDE02862-ENG101707	Production data transmission-Kennung der Montagelinie	D11
    IDE02862-ENG103830	Production data transmission-Lfd.-Nr	3257
    IDE02864-ENG99505	Actual position of gear positioner A-Gearpositioner A Actual Position	-0.16	 mm
    IDE02865-ENG104121	AD value 1 of actual position of gear positioner A-Gearpositioner A Actual Position AD Value 1	2058
    IDE02870-ENG120871	Duty cycle of gear Solen.val. A-Gearpositioner_A_Valve_Duty_Factor	0	 %
    IDE02872-ENG102218	Actual position of gear adjuster B-Gearpositioner B Actual Position	-8.16	 mm
    IDE02873-ENG101728	AD value 1 of actual position of gear positioner B-Gearpositioner B Actual Position AD Value 1	1083
    IDE02878-ENG120875	Pulse duty factor of gear Solen.val. B-Gearpositioner_B_Valve_Duty_Factor	0	 %
    IDE02880-ENG103036	Actual position of gear positioner C-Gearpositioner C Actual Position	-0.3	 mm
    IDE02881-ENG99453	AD value 1 of actual position of gear positioner C-Gearpositioner C Actual Position AD Value 1	2055
    IDE02886-ENG120879	Pulse duty factor of gear Solen.val. C-Gearpositioner_C_Valve_Duty_Factor	0	 %
    IDE02888-ENG103826	Actual position of gear positioner D-Gearpositioner D Actual Position	-8.06	 mm
    IDE02889-ENG100525	AD value 1 of actual position of gear positioner D-Gearpositioner D Actual Position AD Value 1	1172
    IDE02894-ENG120883	Duty cycle of gear Solen.val. D-Gearpositioner_D_Valve_Duty_Factor	0	 %
    IDE03008-ENG122550	Stop process prevented-GE_StartStopp_Info	Stop release
    IDE03008-ENG122551	Stop process prevented-MO_StartStopp_Status	0
    IDE03008-ENG122546	Stop process prevented-Stopp-Verbot-Grund 1	not active
    IDE03008-ENG122547	Stop process prevented-Stopp-Verbot-Grund 2	not active
    IDE03008-ENG122548	Stop process prevented-Stopp-Verbot-Grund 3	not active
    IDE03008-ENG122549	Stop process prevented-Stopp-Verbot-Grund 4	not active
    IDE03008-ENG122552	Stop process prevented-Stopp-Verbot-Grund 5	not active
    IDE03008-ENG122553	Stop process prevented-Stopp-Verbot-Grund 6	not active
    IDE03008-ENG122554	Stop process prevented-Stopp-Verbot-Grund 8	not active
    IDE03171-ENG102987	Driving strategy transmission mileage-Q002 Total Driving Time	137.4	 km
    IDE03172-ENG100789	Driving strategy driving portions in D or S w/ CCS-Q003 Driving Time Ecological	87	 %
    IDE03173-ENG103567	Driving strategy driving portions in S w/o CCS-Q004 Driving Time Sporty	0	 %
    IDE03174-ENG100415	Driving strategy driving portions in Tiptronic-Q005 Driving Time Manual	10	 %
    IDE03180-ENG103176	Number of standard trips-General Denominator	6
    IDE03181-ENG102823	Number of ignition cycles-Ignition Cycle Counter	123
    IDE03182-ENG120927	Lower adapted coupling point K1 from kiss point adaptation-lower_Adapted_Clutchpoint_K1_Of_Kisspoint_Adaption	0.26	 A
    IDE03183-ENG120930	Lower adapted coupling point K2 from kiss point adaptation-lower_Adapted_Clutchpoint_K2_Of_Kisspoint_Adaption	0.23	 A
    IDE03184-ENG120928	Upper adapted coupling point K1 from microslip adaptation-Upper_Adapted_Clutchpoint_K1_Of_Microslip_Adaption	0.76	 A
    IDE03185-ENG120929	Upper adapted coupling point K2 from microslip adaptation-Upper_Adapted_Clutchpoint_K2_Of_Microslip_Adaption	0.695	 A
    IDE03189-ENG110524	Number of prevented stop processes (statistics)-Basic setting	not active
    IDE03189-ENG28506	Number of prevented stop processes (statistics)-Demontagestellung	not active
    IDE03189-ENG28505	Number of prevented stop processes (statistics)-Drucksensorausfall	not active
    IDE03189-ENG28507	Number of prevented stop processes (statistics)-Eingeschränkte Fahrfunktion / Notlauf / Liegenbleiber	not active
    IDE03189-ENG110508	Number of prevented stop processes (statistics)-km-Stand des letzten Stoppverbots	0	 km
    IDE03189-ENG28638	Number of prevented stop processes (statistics)-Motorstoppverbote Anzahl Stoppverbote	0
    IDE03189-ENG110525	Number of prevented stop processes (statistics)-Stop prohibition via application	not active
    IDE03189-ENG28504	Number of prevented stop processes (statistics)-Temperaturbedingung	not active
    IDE03189-ENG122385	Number of prevented stop processes (statistics)-unsortierte Gangsteller im Stand	not active
    IDE04612-ENG101246	Clutch temperature air / splash oil-Centrifugal oil temperature	59	 °C
    IDE04805-IDE02955	Driving profile selection-System status	not_available
    IDE04805-IDE02955	Driving profile selection-System status	Available
    IDE04805-IDE06419	Driving profile selection-Driving profile switchover	performed
    IDE04805-IDE06419	Driving profile selection-Driving profile switchover	no request
    IDE04805-MAS01447	Driving profile selection-Act.val.	0
    IDE04805-MAS01447	Driving profile selection-Act.val.	2
    IDE04805-MAS01448	Driving profile selection-Specified value	2
    IDE04805-MAS01448	Driving profile selection-Specified value	0
    IDE04805-MAS05058	Driving profile selection-Compatibility	Yes
    IDE05987-ENG110524	Engine stop prohibitions-Basic setting	not active
    IDE05987-ENG28506	Engine stop prohibitions-Demontagestellung	not active
    IDE05987-ENG28505	Engine stop prohibitions-Drucksensorausfall	not active
    IDE05987-ENG28507	Engine stop prohibitions-Eingeschränkte Fahrfunktion / Notlauf / Liegenbleiber	not active
    IDE05987-ENG110508	Engine stop prohibitions-km-Stand des letzten Stoppverbots	0	 km
    IDE05987-ENG28638	Engine stop prohibitions-Motorstoppverbote Anzahl Stoppverbote	0
    IDE05987-ENG110525	Engine stop prohibitions-Stop prohibition via application	not active
    IDE05987-ENG28504	Engine stop prohibitions-Temperaturbedingung	not active
    IDE05987-ENG122385	Engine stop prohibitions-unsortierte Gangsteller im Stand	not active
    IDE05988-ENG110505	Pressure of clutch 2: actual value-Clutch_2_actual_value	0	 bar
    IDE05989-ENG110503	Pressure of clutch 1: actual value-Clutch_1_actual_value	0	 bar
    IDE06425	Roller test bench mode: functional	not activated
    IDE80001-ENG100467	Analysis 1-Snapshot 1 Failure ID	65535
    IDE80002-ENG102386	Analysis 2-Snapshot 1 Mileage	0	 km
    IDE80003-ENG101467	Analysis 3-Snapshot 1 Counter	0
    IDE80005-ENG103330	Analysis 5-Snapshot 1 Shift Position Plausible	ERROR
    IDE80007-ENG101090	Analysis 7-Snapshot 1  Commanded Gear	GANG N
    IDE80008-ENG100048	Analysis 8-Snapshot 1 Preselection Gear	GANG N
    IDE80009-ENG102100	Analysis 9-Snapshot 1 Transmission Input Speed	0	 /min
    IDE80010-ENG101565	Analysis 10-Snapshot 1 Transmission Output Speed Shaft 1	0	 /min
    IDE80011-ENG100379	Analysis 11-Snapshot 1 Transmission Speed Shaft 1	0	 /min
    IDE80012-ENG103459	Analysis 12-Snapshot 1 Transmission Speed Shaft 2	0	 /min
    IDE80021-ENG102762	Analysis 21-Snapshot 1 Clutch 1 Actual Pressure	0	 bar
    IDE80022-ENG100347	Analysis 22-Snapshot 1 Clutch 2 Actual Pressure	0	 bar
    IDE80023-ENG99119	Analysis 23-Snapshot 1 Current Valve Clutch 1 Actual Value	0	 mA
    IDE80024-ENG101123	Analysis 24-Snapshot 1 Current Valve Clutch 2 Actual Value	0	 mA
    IDE80025-ENG103611	Analysis 25-Snapshot 1 Accelerator Pedal Position	0	 %
    IDE80026-ENG101503	Analysis 26-Snapshot 1 Engine torque	-50	 Nm
    IDE80029-ENG103070	Analysis 29-Snapshot 1 Voltage Terminal 15	0	 V
    IDE80031-ENG102899	Analysis 31-Snapshot 1 Transmission Fluid Temperature	-60	 °C
    IDE80033-ENG103098	Analysis 33-Snapshot 2 Failure ID	65535
    IDE80034-ENG101047	Analysis 34-Snapshot 2 Mileage	0	 km
    IDE80035-ENG99915	Analysis 35-Snapshot 2 Counter	0
    IDE80037-ENG99369	Analysis 37-Snapshot 2 Shift Position Plausible	ERROR
    IDE80039-ENG101369	Analysis 39-Snapshot 2  Commanded Gear	GANG N
    IDE80040-ENG103638	Analysis 40-Snapshot 2 Preselection Gear	GANG N
    IDE80041-ENG103367	Analysis 41-Snapshot 2 Transmission Input Speed	0	 /min
    IDE80042-ENG102476	Analysis 42-Snapshot 2 Transmission Output Speed Shaft 1	0	 /min
    IDE80043-ENG102699	Analysis 43-Snapshot 2 Transmission Speed Shaft 1	0	 /min
    IDE80044-ENG101900	Analysis 44-Snapshot 2 Transmission Speed Shaft 2	0	 /min
    IDE80053-ENG102973	Analysis 53-Snapshot 2 Clutch 1 Actual Pressure	0	 bar
    IDE80054-ENG100122	Analysis 54-Snapshot 2 Clutch 2 Actual Pressure	0	 bar
    IDE80055-ENG103189	Analysis 55-Snapshot 2 Current Valve Clutch 1 Actual Value	0	 mA
    IDE80056-ENG103616	Analysis 56-Snapshot 2 Current Valve Clutch 2 Actual Value	0	 mA
    IDE80057-ENG102447	Analysis 57-Snapshot 2 Accelerator Pedal Position	0	 %
    IDE80058-ENG103198	Analysis 58-Snapshot 2 Engine torque	-50	 Nm
    IDE80061-ENG101449	Analysis 61-Snapshot 2 Voltage Terminal 15	0	 V
    IDE80063-ENG104157	Analysis 63-Snapshot 2 Transmission Fluid Temperature	-60	 °C
    IDE80065-ENG122555	Analysis 65-Snapshot 1 Weg Gangsteller 1-3	0
    IDE80065-ENG122556	Analysis 65-Snapshot 1 Weg Gangsteller 2-4	0
    IDE80065-ENG122557	Analysis 65-Snapshot 1 Weg Gangsteller 5-N	0
    IDE80065-ENG122558	Analysis 65-Snapshot 1 Weg Gangsteller 6-R	0
    IDE80066-ENG122559	Analysis 66-Snapshot 2 Weg Gangsteller 1-3	0
    IDE80066-ENG122560	Analysis 66-Snapshot 2 Weg Gangsteller 2-4	0
    IDE80066-ENG122561	Analysis 66-Snapshot 2 Weg Gangsteller 5-N	0
    IDE80066-ENG122562	Analysis 66-Snapshot 2 Weg Gangsteller 6-R	0
    IDE80071-ENG127839	Analysis 71-FID event memory entry 1	FF FF
    IDE80071-ENG127848	Analysis 71-FID event memory entry 10	FF FF
    IDE80071-ENG127849	Analysis 71-FID event memory entry 11	FF FF
    IDE80071-ENG127850	Analysis 71-FID event memory entry 12	FF FF
    IDE80071-ENG127840	Analysis 71-FID event memory entry 2	FF FF
    IDE80071-ENG127841	Analysis 71-FID event memory entry 3	FF FF
    IDE80071-ENG127842	Analysis 71-FID event memory entry 4	FF FF
    IDE80071-ENG127843	Analysis 71-FID event memory entry 5	FF FF
    IDE80071-ENG127844	Analysis 71-FID event memory entry 6	FF FF
    IDE80071-ENG127845	Analysis 71-FID event memory entry 7	FF FF
    IDE80071-ENG127846	Analysis 71-FID event memory entry 8	FF FF
    IDE80071-ENG127847	Analysis 71-FID event memory entry 9	FF FF
    IDE80296-ENG127853	Clutch 1 adaption kiss point part 1 success counter-Clutch 1 adaption part 1 positive case counter	28
    IDE80298-ENG127880	Clutch 2 adaption kiss point part 1 success counter-Clutch 2 adaption part 1 positive case counter	23
    IDE80302-ENG122492	Selector lever information-Datenstand	L4
    IDE80302-ENG111628	Selector lever information-Part Number	5Q1713025A
    IDE80302-ENG98856	Selector lever information-Programmability	0
    IDE80302-ENG122491	Selector lever information-Programm-Stand	 V
    IDE80303-ENG127833	Overall software description-Software full name	F52M
    IDE80304-ENG120779	Mechatronics identification DQ250-Änderungsstand BorgWarner	64
    IDE80304-ENG120778	Mechatronics identification DQ250-Mechatronik-Identifikation	T25W0432
    IDE80305-ENG125922	Parameter set description-Data set name	0D9300018_5201_HDYH
    IDE80312-ENG122524	CAN bus installation information-ACC_06	Unknown
    IDE80312-ENG122528	CAN bus installation information-BEM_05	installed
    IDE80312-ENG113024	CAN bus installation information-Charisma_01	installed
    IDE80312-ENG122522	CAN bus installation information-EPB_01	not installed
    IDE80312-ENG122525	CAN bus installation information-GRA_ACC_01	installed
    IDE80312-ENG122511	CAN bus installation information-TSK_06	installed
    ENG120958	Abbruchcode	GSA_ABBRUCH_CODE_OK
    ENG122365-ENG104207	Abschaltpfadtest Fehlerursache aus dem SCM-Bit 0	Abschalten ENA erfolgreich
    ENG122365-ENG102209	Abschaltpfadtest Fehlerursache aus dem SCM-Bit 1	Abschalten WDA erfolgreich
    ENG122365-ENG99197	Abschaltpfadtest Fehlerursache aus dem SCM-Bit 2	EInschalten Endstufen erfolgreich
    ENG122365-ENG102937	Abschaltpfadtest Fehlerursache aus dem SCM-Bit 3	Keine Unterspannung im Abschaltpfadtest
    ENG122363	Abschaltpfadtest Maximaler AD-Wert im Off-Fall	247
    ENG122364	Abschaltpfadtest Minimaler AD-Wert im On-Fall	353
    ENG120920	Abtriebsdrehzahl CAN	0	 /min
    ENG98625-ENG103724	Accelerator position: qualification-Accelerator pedal position: qualification	OK
    ENG100091	Ambient temperature	22	 °C
    ENG120963	Anzahl der Überschreitungen der zulässigen Schleuderöltemperatur	0
    ENG120964	Anzahl der Warnungen aufgrund erhöhter Schleuderöltemperatur	0
    ENG122366	Anzahl der wegen Unterspannung abgebrochenen Abschaltpfadtests	470
    ENG120970	Anzahl Ereignisse auf K1	0
    ENG120972	Anzahl Ereignisse auf K2	0
    ENG98482-ENG99180	Checksum of flash-Calibration Checksumme	EA E8 B9 6C
    ENG98482-ENG100495	Checksum of flash-Cboot Checksumme	31 82 84 67
    ENG98482-ENG100117	Checksum of flash-Checksumme ECU + CAL	00 00 F5 7F
    ENG98482-ENG102221	Checksum of flash-ECU Checksumme	68 DF BC 44
    ENG110530	Clutch 1 adaption kiss point part 1 fault counter	0
    ENG110536	Clutch 2 adaption kiss point part 1 fault counter	0
    ENG99212	Common highside 1 specified condition	Common Highside soll ausgeschaltet werden
    ENG99878	Common highside 2 specified condition	Common Highside soll ausgeschaltet werden
    ENG103403	Converter Loss Torque	4	 Nm
    ENG100625	Coolant temperature	69	 °C
    ENG98602	Driver request torque	4	 Nm
    ENG100746	Driving strategy: sport factor	0	 %
    ENG120931	Eingelegtposition Seite A: Gangsteller 1-3	0	 %
    ENG120932	Eingelegtposition Seite A: Gangsteller 2-4	0	 %
    ENG120933	Eingelegtposition Seite A: Gangsteller 5-N	0	 %
    ENG120934	Eingelegtposition Seite A: Gangsteller 6-R	0	 %
    ENG120943	Eingelegtposition Seite B: Gangsteller 1-3	0	 %
    ENG120944	Eingelegtposition Seite B: Gangsteller 2-4	0	 %
    ENG120945	Eingelegtposition Seite B: Gangsteller 5-N	0	 %
    ENG120946	Eingelegtposition Seite B: Gangsteller 6-R	0	 %
    ENG101251	Empty	kein Leergas
    ENG98756	Engine torque	-17	 Nm
    ENG104230	Engine torque loss	-17	 Nm
    ENG123019-ENG99024	Fahrgeschwindigkeit vom Getriebe-Vehicle speed from transmission	0	 km/h
    ENG120799	Gangsteller A Adaption Flags	00 1F
    ENG120808	Gangsteller B Adaption Flags	00 1F
    ENG120817	Gangsteller C Adaption Flags	00 15
    ENG120826	Gangsteller D Adaption Flags	00 1F
    ENG121005	Gangsteller Synchronposition G1 (Prozent)	55.29	 %
    ENG121006	Gangsteller Synchronposition G2 (Prozent)	45.36	 %
    ENG121007	Gangsteller Synchronposition G3 (Prozent)	46.37	 %
    ENG121008	Gangsteller Synchronposition G4 (Prozent)	54	 %
    ENG121009	Gangsteller Synchronposition G5 (Prozent)	53.94	 %
    ENG121010	Gangsteller Synchronposition G6 (Prozent)	54.53	 %
    ENG121011	Gangsteller Synchronposition GR (Prozent)	46.59	 %
    ENG120961	Gangsteller_Index	GS_13
    ENG120962	Gangsteller_Seite	Neutrallage
    ENG120957	Gangstellerposition zum Zeitpunkt eines Abbruchs	Neutral
    ENG120969	Gefahrene km seit letztem Ereignis auf K1	10	 km
    ENG120971	Gefahrene km seit letztem Ereignis auf K2	10	 km
    ENG99720	Height info	974	 mbar
    ENG98604	Hill factor driving strategy	0	 %
    ENG99596	Indicated engine torque without external interventions	0	 Nm
    ENG99582	Intake air temperature	2	 °C
    ENG122357-ENG122524	Kommunikationsstatus Datenbus 1 MQB-ACC_06	Unknown
    ENG122357-ENG122528	Kommunikationsstatus Datenbus 1 MQB-BEM_05	received
    ENG122357-ENG113024	Kommunikationsstatus Datenbus 1 MQB-Charisma_01	received
    ENG122357-ENG122523	Kommunikationsstatus Datenbus 1 MQB-Diagnose_01	received
    ENG122357-ENG122522	Kommunikationsstatus Datenbus 1 MQB-EPB_01	Unknown
    ENG122357-ENG122513	Kommunikationsstatus Datenbus 1 MQB-ESP_02	received
    ENG122357-ENG122514	Kommunikationsstatus Datenbus 1 MQB-ESP_05	received
    ENG122357-ENG110808	Kommunikationsstatus Datenbus 1 MQB-ESP_07	received
    ENG122357-ENG122515	Kommunikationsstatus Datenbus 1 MQB-ESP_10	Unknown
    ENG122357-ENG122516	Kommunikationsstatus Datenbus 1 MQB-ESP_19	received
    ENG122357-ENG122517	Kommunikationsstatus Datenbus 1 MQB-ESP_20	received
    ENG122357-ENG122518	Kommunikationsstatus Datenbus 1 MQB-ESP_21	received
    ENG122357-ENG122519	Kommunikationsstatus Datenbus 1 MQB-Gateway_72	received
    ENG122357-ENG122520	Kommunikationsstatus Datenbus 1 MQB-Gateway_74	received
    ENG122357-ENG122525	Kommunikationsstatus Datenbus 1 MQB-GRA_ACC_01	received
    ENG122357-ENG00240	Kommunikationsstatus Datenbus 1 MQB-Klemmen_Status_01	received
    ENG122357-ENG110802	Kommunikationsstatus Datenbus 1 MQB-Kombi_01	received
    ENG122357-ENG122521	Kommunikationsstatus Datenbus 1 MQB-Kombi_02	received
    ENG122357-ENG110799	Kommunikationsstatus Datenbus 1 MQB-LWI_01	received
    ENG122357-ENG122512	Kommunikationsstatus Datenbus 1 MQB-Motor_04	received
    ENG122357-ENG122502	Kommunikationsstatus Datenbus 1 MQB-Motor_07	received
    ENG122357-ENG122503	Kommunikationsstatus Datenbus 1 MQB-Motor_11	received
    ENG122357-ENG122504	Kommunikationsstatus Datenbus 1 MQB-Motor_12	received
    ENG122357-ENG122505	Kommunikationsstatus Datenbus 1 MQB-Motor_14	received
    ENG122357-ENG122506	Kommunikationsstatus Datenbus 1 MQB-Motor_16	received
    ENG122357-ENG122507	Kommunikationsstatus Datenbus 1 MQB-Motor_17	received
    ENG122357-ENG122529	Kommunikationsstatus Datenbus 1 MQB-Motor_18	received
    ENG122357-ENG122508	Kommunikationsstatus Datenbus 1 MQB-Motor_20	received
    ENG122357-ENG122509	Kommunikationsstatus Datenbus 1 MQB-Motor_26	Unknown
    ENG122357-ENG06581	Kommunikationsstatus Datenbus 1 MQB-Motor_35	Unknown
    ENG122357-ENG122510	Kommunikationsstatus Datenbus 1 MQB-Motor_Code_01	received
    ENG122357-ENG122526	Kommunikationsstatus Datenbus 1 MQB-OBD_01	received
    ENG122357-ENG122511	Kommunikationsstatus Datenbus 1 MQB-TSK_06	received
    ENG122357-ENG122527	Kommunikationsstatus Datenbus 1 MQB-Waehlhebel_03	received
    ENG126632	Korrekturwerte Hauptdruckadaption	0.39	 bar
    ENG121002	Korrekturwerte Hauptdruckadaption: großer Druck auf K1	0.3	 bar
    ENG121004	Korrekturwerte Hauptdruckadaption: großer Druck auf K2	0.25	 bar
    ENG121001	Korrekturwerte Hauptdruckadaption: kleiner Druck auf K1	0.35	 bar
    ENG121003	Korrekturwerte Hauptdruckadaption: kleiner Druck auf K2	0.2	 bar
    ENG99297	Kupplung 1 Adaption Grundkennlinie Bereich 1 Schnelladaptionen verbleibende Anzahl	0
    ENG100826	Kupplung 2 Adaption Grundkennlinie Bereich 1 Schnelladaptionen verbleibende Anzahl	0
    ENG120965	Kupplungsadaptionswerte: IKp0 fuer K1	260	 mA
    ENG120966	Kupplungsadaptionswerte: IKp0 fuer K2	230	 mA
    ENG120967	Kupplungsadaptionswerte: unterer Strompunkt Adaption K1	235	 mA
    ENG120968	Kupplungsadaptionswerte: unterer Strompunkt Adaption K2	220	 mA
    ENG110556-ENG110541	Leak oil compensation K1-Abbruch Zähler K1 Drucküberwachung	0
    ENG110556-ENG110542	Leak oil compensation K1-Abbruch Zähler K1 Solldruckintegral zu groß	0
    ENG110556-ENG110543	Leak oil compensation K1-Abbruch Zähler K1 Solldruckintegral zu klein	0
    ENG110556-ENG120771	Leak oil compensation K1-Erfolgreiche K1 Leckölkompensationen	124
    ENG110557-ENG110545	Leak oil compensation K2-Abbruch Zähler K2 Drucküberwachung	0
    ENG110557-ENG110546	Leak oil compensation K2-Abbruch Zähler K2 Solldruckintegral zu groß	0
    ENG110557-ENG110547	Leak oil compensation K2-Abbruch Zähler K2 Solldruckintegral zu klein	0
    ENG110557-ENG110544	Leak oil compensation K2-Erfolgreiche K2 Leckölkompensationen	62
    ENG120996	Maximale Spannung an UH1	9.2	 V
    ENG120998	Maximale Spannung an UH2	4.9	 V
    ENG120995	Minimale Spannung an UH1	0.2	 V
    ENG120997	Minimale Spannung an UH2	4.9	 V
    ENG111613-ENG101555	Motordrehmoment Begrenzung-Engine torque limitation	273	 Nm
    ENG120939	Neutralposition: Gangsteller 1-3	50.2	 %
    ENG120940	Neutralposition: Gangsteller 2-4	50.01	 %
    ENG120941	Neutralposition: Gangsteller 5-N	50.03	 %
    ENG120942	Neutralposition: Gangsteller 6-R	50.71	 %
    ENG120993	Oberer adaptierter Kupplungspunkt K1 aus Makroschlupfadaption	760	 mA
    ENG120994	Oberer adaptierter Kupplungspunkt K2 aus Makroschlupfadaption	695	 mA
    ENG105329-ENG101124	Operating time CU (temp range 1-6) / operating time CU (temp-Betriebszeit STG (Temperaturbereich 1)	9.2	 H
    ENG105329-ENG100216	Operating time CU (temp range 1-6) / operating time CU (temp-Betriebszeit STG (Temperaturbereich 2)	0.6	 H
    ENG105329-ENG103067	Operating time CU (temp range 1-6) / operating time CU (temp-Betriebszeit STG (Temperaturbereich 3)	0	 H
    ENG105329-ENG101168	Operating time CU (temp range 1-6) / operating time CU (temp-Betriebszeit STG (Temperaturbereich 4)	0	 H
    ENG105329-ENG104150	Operating time CU (temp range 1-6) / operating time CU (temp-Betriebszeit STG (Temperaturbereich 5)	0	 H
    ENG105329-ENG100130	Operating time CU (temp range 1-6) / operating time CU (temp-Betriebszeit STG (Temperaturbereich 6)	0	 H
    ENG120987	Ratio FID 256	100	 %
    ENG120989	Ratio FID 257	100	 %
    ENG120988	Ratio FID 330	100	 %
    ENG120990	Ratio FID 333	100	 %
    ENG120975	Ratio FID 52	100	 %
    ENG120976	Ratio FID 53	100	 %
    ENG120977	Ratio FID 54	100	 %
    ENG120978	Ratio FID 55	100	 %
    ENG120986	Ratio FID 56	100	 %
    ENG120973	Ratio FID 57	100	 %
    ENG120974	Ratio FID 58	100	 %
    ENG120979	Ratio FID 78	100	 %
    ENG120980	Ratio FID 79	100	 %
    ENG120981	Ratio FID 80	100	 %
    ENG120982	Ratio FID 81	100	 %
    ENG120983	Ratio FID 82	100	 %
    ENG120984	Ratio FID 83	100	 %
    ENG120985	Ratio FID 84	100	 %
    ENG100188	Reached maximum temperature control module	101	 °C
    ENG123020-ENG102793	Rollwiderstand-Road Resistance	0	 %
    ENG102748	Selector lever error flags	00 00
    ENG122375-ENG122573	Snapshot 1 Ansteuerung Gangsteller / Sonderzustände-ABS-Flag	ABS-Flag nicht gesetzt
    ENG122375-ENG122571	Snapshot 1 Ansteuerung Gangsteller / Sonderzustände-ASR-Flag	ASR-Flag nicht gesetzt
    ENG122375-ENG122570	Snapshot 1 Ansteuerung Gangsteller / Sonderzustände-CHS-Flag	CHS1 oder CHS2 oder beide ausgeschaltet
    ENG122375-ENG122574	Snapshot 1 Ansteuerung Gangsteller / Sonderzustände-EDS-Flag	EDS-Flag nicht gesetzt
    ENG122375-ENG122575	Snapshot 1 Ansteuerung Gangsteller / Sonderzustände-FDR-Flag	FDR-Flag nicht gesetzt
    ENG122375-ENG122563	Snapshot 1 Ansteuerung Gangsteller / Sonderzustände-GV1-Flag	GV1-Flag nicht gesetzt
    ENG122375-ENG122564	Snapshot 1 Ansteuerung Gangsteller / Sonderzustände-GV2-Flag	GV2-Flag nicht gesetzt
    ENG122375-ENG122565	Snapshot 1 Ansteuerung Gangsteller / Sonderzustände-GV3-Flag	GV3-Flag nicht gesetzt
    ENG122375-ENG122566	Snapshot 1 Ansteuerung Gangsteller / Sonderzustände-GV4-Flag	GV4-Flag nicht gesetzt
    ENG122375-ENG122569	Snapshot 1 Ansteuerung Gangsteller / Sonderzustände-MPX-Flag	MPX-Flag nicht gesetzt
    ENG122375-ENG122572	Snapshot 1 Ansteuerung Gangsteller / Sonderzustände-MSR-Flag	MSR-Flag nicht gesetzt
    ENG122375-ENG122567	Snapshot 1 Ansteuerung Gangsteller / Sonderzustände-SV1-Flag	SV1-Flag nicht gesetzt
    ENG122375-ENG122568	Snapshot 1 Ansteuerung Gangsteller / Sonderzustände-SV2-Flag	SV2-Flag nicht gesetzt
    ENG122375-ENG122576	Snapshot 1 Ansteuerung Gangsteller / Sonderzustände-Tipp-Gasse-Flag	Tipp-Gasse-Flag nicht gesetzt
    ENG122375-ENG122578	Snapshot 1 Ansteuerung Gangsteller / Sonderzustände-Tipp-hoch-Flag	Tipp-hoch-Flag nicht gesetzt
    ENG122375-ENG122577	Snapshot 1 Ansteuerung Gangsteller / Sonderzustände-Tipp-runter-Flag	Tipp-runter-Flag nicht gesetzt
    ENG122369	Snapshot 1 Iststrom Hauptdruckventil	0	 mA
    ENG122367	Snapshot 1 Kupplungszustand	New
    ENG122371	Snapshot 1 unterer Strompunkt Adaption K1	0	 mA
    ENG122372	Snapshot 1 unterer Strompunkt Adaption K2	0	 mA
    ENG122376-ENG122573	Snapshot 2 Ansteuerung Gangsteller / Sonderzustände-ABS-Flag	ABS-Flag nicht gesetzt
    ENG122376-ENG122571	Snapshot 2 Ansteuerung Gangsteller / Sonderzustände-ASR-Flag	ASR-Flag nicht gesetzt
    ENG122376-ENG122570	Snapshot 2 Ansteuerung Gangsteller / Sonderzustände-CHS-Flag	CHS1 oder CHS2 oder beide ausgeschaltet
    ENG122376-ENG122574	Snapshot 2 Ansteuerung Gangsteller / Sonderzustände-EDS-Flag	EDS-Flag nicht gesetzt
    ENG122376-ENG122575	Snapshot 2 Ansteuerung Gangsteller / Sonderzustände-FDR-Flag	FDR-Flag nicht gesetzt
    ENG122376-ENG122563	Snapshot 2 Ansteuerung Gangsteller / Sonderzustände-GV1-Flag	GV1-Flag nicht gesetzt
    ENG122376-ENG122564	Snapshot 2 Ansteuerung Gangsteller / Sonderzustände-GV2-Flag	GV2-Flag nicht gesetzt
    ENG122376-ENG122565	Snapshot 2 Ansteuerung Gangsteller / Sonderzustände-GV3-Flag	GV3-Flag nicht gesetzt
    ENG122376-ENG122566	Snapshot 2 Ansteuerung Gangsteller / Sonderzustände-GV4-Flag	GV4-Flag nicht gesetzt
    ENG122376-ENG122569	Snapshot 2 Ansteuerung Gangsteller / Sonderzustände-MPX-Flag	MPX-Flag nicht gesetzt
    ENG122376-ENG122572	Snapshot 2 Ansteuerung Gangsteller / Sonderzustände-MSR-Flag	MSR-Flag nicht gesetzt
    ENG122376-ENG122567	Snapshot 2 Ansteuerung Gangsteller / Sonderzustände-SV1-Flag	SV1-Flag nicht gesetzt
    ENG122376-ENG122568	Snapshot 2 Ansteuerung Gangsteller / Sonderzustände-SV2-Flag	SV2-Flag nicht gesetzt
    ENG122376-ENG122576	Snapshot 2 Ansteuerung Gangsteller / Sonderzustände-Tipp-Gasse-Flag	Tipp-Gasse-Flag nicht gesetzt
    ENG122376-ENG122578	Snapshot 2 Ansteuerung Gangsteller / Sonderzustände-Tipp-hoch-Flag	Tipp-hoch-Flag nicht gesetzt
    ENG122376-ENG122577	Snapshot 2 Ansteuerung Gangsteller / Sonderzustände-Tipp-runter-Flag	Tipp-runter-Flag nicht gesetzt
    ENG122370	Snapshot 2 Iststrom Hauptdruckventil	0	 mA
    ENG122368	Snapshot 2 Kupplungszustand	New
    ENG122373	Snapshot 2 unterer Strompunkt Adaption K1	0	 mA
    ENG122374	Snapshot 2 unterer Strompunkt Adaption K2	0	 mA
    ENG120921	Sollgang der Fahrstrategie	 R
    ENG101057	Specified idle speed	1100	 /min
    ENG100803	Speed: output	0	 /min
    ENG122358-ENG122550	Start Stopp Statusinformationen aktuell-GE_StartStopp_Info	Stop release
    ENG122358-ENG122551	Start Stopp Statusinformationen aktuell-MO_StartStopp_Status	0
    ENG122358-ENG122500	Start Stopp Statusinformationen aktuell-Start Stopp Stoppverbot Häufigkeitszähler 1	0
    ENG122358-ENG122501	Start Stopp Statusinformationen aktuell-Start Stopp Stoppverbot Häufigkeitszähler 2	0
    ENG122358-ENG122546	Start Stopp Statusinformationen aktuell-Stopp-Verbot-Grund 1	not active
    ENG122358-ENG122547	Start Stopp Statusinformationen aktuell-Stopp-Verbot-Grund 2	not active
    ENG122358-ENG122548	Start Stopp Statusinformationen aktuell-Stopp-Verbot-Grund 3	not active
    ENG122358-ENG122549	Start Stopp Statusinformationen aktuell-Stopp-Verbot-Grund 4	not active
    ENG122358-ENG122552	Start Stopp Statusinformationen aktuell-Stopp-Verbot-Grund 5	not active
    ENG122358-ENG122553	Start Stopp Statusinformationen aktuell-Stopp-Verbot-Grund 6	not active
    ENG122358-ENG122554	Start Stopp Statusinformationen aktuell-Stopp-Verbot-Grund 8	not active
    ENG120924	Strom oberer Druckpunkt Kupplung 1 aus Strom-zu-Druck-Adaption	1000	 mA
    ENG120926	Strom oberer Druckpunkt Kupplung 2 aus Strom-zu-Druck-Adaption	1000	 mA
    ENG120923	Strom unterer Druckpunkt Kupplung 1 aus Strom-zu-Druck-Adaption	235	 mA
    ENG120925	Strom unterer Druckpunkt Kupplung 2 aus Strom-zu-Druck-Adaption	220	 mA
    ENG120935	Synchronposition Seite A: Gangsteller 1-3	46.37	 %
    ENG120936	Synchronposition Seite A: Gangsteller 2-4	45.36	 %
    ENG120937	Synchronposition Seite A: Gangsteller 5-N	47.12	 %
    ENG120938	Synchronposition Seite A: Gangsteller 6-R	46.59	 %
    ENG120947	Synchronposition Seite B: Gangsteller 1-3	55.29	 %
    ENG120948	Synchronposition Seite B: Gangsteller 2-4	54	 %
    ENG120949	Synchronposition Seite B: Gangsteller 5-N	53.94	 %
    ENG120950	Synchronposition Seite B: Gangsteller 6-R	54.53	 %
    ENG120999	Tastverhältnis Sicherheitsventil 1	0	 %
    ENG121000	Tastverhältnis Sicherheitsventil 2	0	 %
    ENG120991	Unterer adaptierter Kupplungspunkt K1 aus Mikroschlupfadaption	245	 mA
    ENG120992	Unterer adaptierter Kupplungspunkt K2 aus Mikroschlupfadaption	235	 mA
    ENG120960	Unterzustand Gangstelleradaption	Synchron_GSA_SUB_SYNC_ADAPTION_SETZEMPX
    ENG120956	Unterzustand Gangstelleradaption zum Zeitpunkt eines Abbruchs	Synchron_GSA_SUB_SYNC_ADAPTION_SETZEMPX
    ENG101346	Version info driving strategy	Temic
    ENG109005	Voltage Common Highside 1	0	 V
    ENG99955	Voltage Common Highside 2	0	 V
    ENG120922	Vorwahlgang der Fahrstrategie	2
    ENG120952	Zählerstände der Hauptdruckadaption:Abbruchzähler auf K1	0
    ENG120954	Zählerstände der Hauptdruckadaption:Abbruchzähler auf K2	0
    ENG120951	Zählerstände der Hauptdruckadaption:Erfolgszähler auf K1	17
    ENG120953	Zählerstände der Hauptdruckadaption:Erfolgszähler auf K2	12
    ENG120959	Zustand Gangstelleradaption	Synchron_GSA_AUS
    ENG120955	Zustand Gangstelleradaption zum Zeitpunkt eines Abbruchs	Synchron_GSA_AUS
    Elapsed Time: 00:21
    Idle in Park
    ;Sunday	26	August	2018	11:26:56:04045
    IDE00018	Voltage terminal 15	13.3	 V
    IDE00019	Voltage terminal 30	13.7	 V
    IDE00021-ENG99543	Engine speed-Engine RPM	701	 /min
    IDE00022-ENG103074	Transmission input speed-Transmission Input Speed Sensor	698	 /min
    IDE00024	Transmission fluid temperature	61	 °C
    IDE00872-ENG102188	Current of main pressure valve-Oil Pressure Actual Current	799.8	 mA
    IDE02797-ENG100730	Current of valve for clutch 1 actual value-Current Valve Clutch 1 Actual Value	0.1	 mA
    IDE02806-ENG103118	Current of valve for clutch 2 actual value-Current Valve Clutch 2 Actual Value	0.7	 mA
    IDE02872-ENG102218	Actual position of gear adjuster B-Gearpositioner B Actual Position	-8.08	 mm
    IDE02873-ENG101728	AD value 1 of actual position of gear positioner B-Gearpositioner B Actual Position AD Value 1	1096
    IDE02888-ENG103826	Actual position of gear positioner D-Gearpositioner D Actual Position	-8	 mm
    IDE02889-ENG100525	AD value 1 of actual position of gear positioner D-Gearpositioner D Actual Position AD Value 1	1181
    IDE03181-ENG102823	Number of ignition cycles-Ignition Cycle Counter	124
    IDE04612-ENG101246	Clutch temperature air / splash oil-Centrifugal oil temperature	61	 °C
    IDE05988-ENG110505	Pressure of clutch 2: actual value-Clutch_2_actual_value	0.02	 bar
    ENG122366	Anzahl der wegen Unterspannung abgebrochenen Abschaltpfadtests	471
    ENG99212	Common highside 1 specified condition	Common Highside soll eingeschaltet werden
    ENG99878	Common highside 2 specified condition	Common Highside soll eingeschaltet werden
    ENG100625	Coolant temperature	96	 °C
    ENG98602	Driver request torque	-2	 Nm
    ENG101251	Empty	Empty
    ENG98756	Engine torque	-2	 Nm
    ENG104230	Engine torque loss	-27	 Nm
    ENG99720	Height info	965	 mbar
    ENG99596	Indicated engine torque without external interventions	26	 Nm
    ENG111613-ENG101555	Motordrehmoment Begrenzung-Engine torque limitation	263	 Nm
    ENG105329-ENG101124	Operating time CU (temp range 1-6) / operating time CU (temp-Betriebszeit STG (Temperaturbereich 1)	9.4	 H
    ENG101057	Specified idle speed	700	 /min
    ENG120999	Tastverhältnis Sicherheitsventil 1	18	 %
    ENG121000	Tastverhältnis Sicherheitsventil 2	18	 %
    ENG109005	Voltage Common Highside 1	13.7	 V
    ENG99955	Voltage Common Highside 2	13.7	 V
    Elapsed Time: 00:21
  5. Likes Eric liked this post
  6. #4
    United States
    03-ABS Brakes
    adpmap-03-5Q0-614-517-AQ_3VWH17AU5JM758941-20180826-1115.CSV
    ;SW:5Q0-614-517-AQ   HW:5Q0-614-517-AF ---  ABS Brakes
    ;Component:ESC           H62 0400	 Coding:43FA6AA1342509748080030480C429C2562C9001C001943C00435050E009430000010312121212B435351919323200
    ;EV_Brake1UDSContiMK100ESP	36010	EV_Brake1UDSContiMK100ESP_036.rod
    ;Sunday	26	August	2018	11:15:33:04045
    ;VCID: 005A8A690A83FFD7912-8054
    IDE00001-Production mode	not active 	3
    IDE00252-Brake system vacuum pump	5	1
    IDE00820-Activating and deactivating all development messages	0	1
    IDE02332-Deactivate production mode	Deactivating 	3
    IDE03659-Roller test bench mode	Manual activation: possible 	1
    IDE04456-Brake disk drying	Medium 	1
    IDE04508-Hydraulic brake booster	8	1
    IDE04643-Overboost in brake system	activated 	1
    IDE04774-Vehicle and trailer stabilization	not activated 	1
    IDE04939-Tire pressure monitoring display	2	1
    IDE04949-Engine drag torque control	activated 	1
    IDE04951-Brake booster	4	1
    IDE04952-Braking torque boost for distance regulation	3	1
    IDE05055-Hydraulic brake assistant	normal 	1
    IDE05057-Brake prefill	activated 	1
    IDE05161-Straight ahead brake stabilization	activated 	1
    IDE05337-Starting vibration reduction-	Strong 	1
    IDE05337-MAS02653-Starting vibration reduction-Torque limitation	Deactivated 	1
    IDE07006-Tire pressure monitoring display: tire selection	1	1
    IDE07292-Brake pre-filling	not completed successfully 	1
    IDE07565-ABS in lower speed range	activated 	1
    IDE07848-Thresholds for brake performance	activated 	1
    IDE12030-Rough road optimization	activated 	1
    MAS00122-Electronic Stability Program	not activated 	1
    MAS00194---no display--	Standard 	1
    MAS00970-Running manufacturer number	activated 	1
    MAS01299-Offroad	0	1
    MAS02080-XCP calibration protocol	not activated 	1
    MAS02138-Hill-start assistant	normal 	1
    ENG118148-Developer_Function_1	0	1
    ENG130301-Developer_Function_121	not activated 	1
    Elapsed Time: 00:10
    blockmap-03-5Q0-614-517-AQ_3VWH17AU5JM758941-20180826-1115.CSV
    ;Sunday	26	August	2018	11:15:21:04045
    IDE00323	Security Access: Number of invalid keys	0
    IDE00609-MAS01155	Communication status of data bus 1-Control module	Engine Control Module 1
    IDE00609-MAS01156	Communication status of data bus 1-Communication status	active
    IDE00780	Mode	running_mode
    IDE02270-IDE00086	CAN input signal(s) status-Accelerator position	0	 %
    IDE02270-IDE02049	CAN input signal(s) status-Trailer detected	ERROR
    IDE02270-IDE02713	CAN input signal(s) status-Brake Light Switch	not activated
    IDE02270-MAS00025	CAN input signal(s) status-Driver seat belt switch	not connected
    IDE02270-MAS00218	CAN input signal(s) status-Driver door	Open
    IDE02270-MAS00314	CAN input signal(s) status-Clutch Pedal Switch	operated
    IDE02270-MAS00364	CAN input signal(s) status-Shift lever / selector lever position	Neutral
    IDE02270-MAS01281	CAN input signal(s) status-Back-up light	OFF
    IDE02270-MAS02357	CAN input signal(s) status-Vehicle identification	AU58941
    IDE02270-MAS03992	CAN input signal(s) status-Clutch pedal switch: interlock position	active
    IDE02271-IDE03311	CAN output signal(s) status-Emergency brake display	not active
    IDE02271-IDE03660	CAN output signal(s) status-Longitudinal acceleration	-0.15625	 m/s²
    IDE02486	Data logger triggering	not active
    IDE02492	Start-stop function: coding information	Start-stop function in control module not active
    IDE02986-IDE04431	indicator lights-ASR and ESP indicator lamp	OFF
    IDE02986-IDE04451	indicator lights-Tire press monitoring display indictor lamp	OFF
    IDE02986-IDE04498	indicator lights--AUTO HOLD- Indicator Lamp	Not available due to specific system
    IDE02986-IDE04771	indicator lights-Indicator lamp for electro-mechanical parking brake malfunction	Not available due to specific system
    IDE02986-MAS00253	indicator lights-ABS indicator lamp	OFF
    IDE02986-MAS00556	indicator lights-Electromechanical parking brake indicator lamp	Not available due to specific system
    IDE02986-MAS01206	indicator lights-Hill descent control indicator lamp	OFF
    IDE02986-MAS02925	indicator lights-Brake system indicator lamp	OFF
    IDE02986-MAS03234	indicator lights-ESP_off indicator lamp	OFF
    IDE03008-IDE04446	Stop process prevented-Hill descent control	not active
    IDE03008-IDE05181	Stop process prevented-Emerg.brake	not active
    IDE03008-IDE06139	Stop process prevented-AUTO HOLD slippage recognition	not active
    IDE03008-MAS04485	Stop process prevented-ESP function deactivation	not active
    IDE03008-MAS04513	Stop process prevented-Brake control module pump operation	not active
    IDE03008-MAS04515	Stop process prevented-Roll-back detected	not active
    IDE03008-MAS07931	Stop process prevented-Retaining function unavailable	not active
    IDE03008-MAS07932	Stop process prevented-Inclination limit	not active
    IDE03009-IDE04446	Start process requested-Hill descent control	not active
    IDE03009-IDE06139	Start process requested-AUTO HOLD slippage recognition	not active
    IDE03009-MAS02515	Start process requested-System malfunction	not active
    IDE03009-MAS04485	Start process requested-ESP function deactivation	not active
    IDE03009-MAS04515	Start process requested-Roll-back detected	not active
    IDE03010-IDE04446	Number of prevented stop processes-Hill descent control	0
    IDE03010-IDE05181	Number of prevented stop processes-Emerg.brake	0
    IDE03010-IDE06139	Number of prevented stop processes-AUTO HOLD slippage recognition	0
    IDE03010-MAS04485	Number of prevented stop processes-ESP function deactivation	0
    IDE03010-MAS04513	Number of prevented stop processes-Brake control module pump operation	0
    IDE03010-MAS04515	Number of prevented stop processes-Roll-back detected	0
    IDE03010-MAS07931	Number of prevented stop processes-Retaining function unavailable	0
    IDE03010-MAS07932	Number of prevented stop processes-Inclination limit	17
    IDE03011-IDE04446	Number of requested start processes-Hill descent control	0
    IDE03011-IDE06139	Number of requested start processes-AUTO HOLD slippage recognition	0
    IDE03011-MAS02515	Number of requested start processes-System malfunction	0
    IDE03011-MAS04485	Number of requested start processes-ESP function deactivation	0
    IDE03011-MAS04515	Number of requested start processes-Roll-back detected	0
    IDE03127-MAS00106	Prevented stop processes (ring memory)-Year	2126
    IDE03127-MAS00107	Prevented stop processes (ring memory)-Month	14
    IDE03127-MAS00108	Prevented stop processes (ring memory)-Day	0
    IDE03127-MAS00109	Prevented stop processes (ring memory)-Hours	30
    IDE03127-MAS00110	Prevented stop processes (ring memory)-Minutes	62
    IDE03127-MAS00111	Prevented stop processes (ring memory)-Seconds	62
    IDE03127	Prevented stop processes (ring memory)	Initial value
    IDE03128-MAS00106	Requested start processes (ring memory)-Year	2126
    IDE03128-MAS00107	Requested start processes (ring memory)-Month	14
    IDE03128-MAS00108	Requested start processes (ring memory)-Day	0
    IDE03128-MAS00109	Requested start processes (ring memory)-Hours	30
    IDE03128-MAS00110	Requested start processes (ring memory)-Minutes	62
    IDE03128-MAS00111	Requested start processes (ring memory)-Seconds	62
    IDE03128	Requested start processes (ring memory)	Initial value
    IDE03207	Hardware version for suppliers	Freescale
    IDE03212	Start-stop conditions	System malfunction
    IDE03213	Start-stop enabling	At least one release missing
    IDE03527-IDE02070	CAN signals-Wake-up cause	1
    IDE03527-IDE02445	CAN signals-Transmission type	19
    IDE03651	Bleed brake system (rework bleeding)	0	 s
    IDE03680-IDE00018	Supply voltages-Voltage terminal 15	On
    IDE03680-IDE01232	Supply voltages-Supply voltage for external components	4.994	 V
    IDE03680-IDE04444	Supply voltages-Terminal 30 voltage for pump	0.014	 V
    IDE03680-IDE04445	Supply voltages-Terminal 30 voltage for valves	14.391	 V
    IDE03680-IDE04500	Supply voltages-Terminal 30 voltage for logic	OFF
    IDE04422-IDE04442	Brake system sensor-Vacuum sensor	-1	 mbar
    IDE04422-IDE04450	Brake system sensor-Brake pressure sensor 1	-0.4	 bar
    IDE04422-IDE04494	Brake system sensor-Brake pressure sensor 1: uncond voltage 1	Not available due to specific system
    IDE04422-IDE04495	Brake system sensor-Brake pressure sensor 1: uncond voltage 2	Not available due to specific system
    IDE04422-MAS00179	Brake system sensor-Brake Light Switch	not activated
    IDE04422-MAS02152	Brake system sensor-EPB clutch pedal travel	Not available due to specific system
    IDE04425-IDE00920	Left front ABS wheel speed sensor-Front left wheel speed	0	 km/h
    IDE04425-IDE04435	Left front ABS wheel speed sensor-Air gap	65535	 mm
    IDE04425-IDE04436	Left front ABS wheel speed sensor-Minimum division value	Condition not met
    IDE04425-IDE04437	Left front ABS wheel speed sensor-Maximum division value	Condition not met
    IDE04425-IDE04438	Left front ABS wheel speed sensor-Average division value	Condition not met
    IDE04425-IDE04440	Left front ABS wheel speed sensor-Validity of direction of rotation	invalid
    IDE04425-IDE04441	Left front ABS wheel speed sensor-Validity of gap information	invalid
    IDE04425-MAS01466	Left front ABS wheel speed sensor-Direction of rotation	Not available due to specific system
    IDE04426-IDE00921	Right front ABS wheel speed sensor-Front right wheel speed	0	 km/h
    IDE04426-IDE04435	Right front ABS wheel speed sensor-Air gap	65535	 mm
    IDE04426-IDE04436	Right front ABS wheel speed sensor-Minimum division value	Condition not met
    IDE04426-IDE04437	Right front ABS wheel speed sensor-Maximum division value	Condition not met
    IDE04426-IDE04438	Right front ABS wheel speed sensor-Average division value	Condition not met
    IDE04426-IDE04440	Right front ABS wheel speed sensor-Validity of direction of rotation	invalid
    IDE04426-IDE04441	Right front ABS wheel speed sensor-Validity of gap information	invalid
    IDE04426-MAS01466	Right front ABS wheel speed sensor-Direction of rotation	Not available due to specific system
    IDE04427-IDE00922	Left rear ABS wheel speed sensor-Left rear wheel speed	0	 km/h
    IDE04427-IDE04435	Left rear ABS wheel speed sensor-Air gap	65535	 mm
    IDE04427-IDE04436	Left rear ABS wheel speed sensor-Minimum division value	Condition not met
    IDE04427-IDE04437	Left rear ABS wheel speed sensor-Maximum division value	Condition not met
    IDE04427-IDE04438	Left rear ABS wheel speed sensor-Average division value	Condition not met
    IDE04427-IDE04440	Left rear ABS wheel speed sensor-Validity of direction of rotation	invalid
    IDE04427-IDE04441	Left rear ABS wheel speed sensor-Validity of gap information	invalid
    IDE04427-MAS01466	Left rear ABS wheel speed sensor-Direction of rotation	forwards
    IDE04428-IDE00923	Right rear ABS wheel speed sensor-Right rear wheel speed	0	 km/h
    IDE04428-IDE04435	Right rear ABS wheel speed sensor-Air gap	65535	 mm
    IDE04428-IDE04436	Right rear ABS wheel speed sensor-Minimum division value	Condition not met
    IDE04428-IDE04437	Right rear ABS wheel speed sensor-Maximum division value	Condition not met
    IDE04428-IDE04438	Right rear ABS wheel speed sensor-Average division value	Condition not met
    IDE04428-IDE04440	Right rear ABS wheel speed sensor-Validity of direction of rotation	invalid
    IDE04428-IDE04441	Right rear ABS wheel speed sensor-Validity of gap information	invalid
    IDE04428-MAS01466	Right rear ABS wheel speed sensor-Direction of rotation	forwards
    IDE04442-IDE00009	Vacuum sensor-Date of manufacture	ÿÿÿÿÿÿÿÿÿÿ
    IDE04442-IDE00010	Vacuum sensor-Serial number	FF FF FF FF FF
    IDE04442-IDE00104	Vacuum sensor-DTC	0
    IDE04442-IDE02955	Vacuum sensor-System status	Not available due to specific system
    IDE04442-IDE03205	Vacuum sensor-Manufacturer code	65535
    IDE04442	Vacuum sensor	-1	 mbar
    IDE04442-MAS12759	Vacuum sensor-Type of individual vacuum sensor	65535
    IDE04443-IDE02241	Traction control system sensor-Lateral acceleration sensor 1	0	 m/s²
    IDE04443-IDE02538	Traction control system sensor-Longitudinal acceleration sensor	-0.27468	 m/s²
    IDE04443-IDE04429	Traction control system sensor-Lateral acceleration sensor 1: offset	0	 m/s²
    IDE04443-IDE04430	Traction control system sensor-Longitudinal acceleration sensor: offset	-0.1875	 m/s²
    IDE04443-IDE04449	Traction control system sensor-Rotation rate sensor 1: Z-axis	-0.214	 °/s
    IDE04443-IDE04460	Traction control system sensor-Steering angle sensor: offset straight line running	-4.287	 °
    IDE04443-MAS00815	Traction control system sensor-Steering angle sensor	-4.287	 °
    IDE04446-IDE01599	Hill descent control-Slope	-1	 %
    IDE04446-IDE02955	Hill descent control-System status	Available
    IDE04446-IDE03664	Hill descent control-Button for driving program	not activated
    IDE04446-MAS03095	Hill descent control-Function status	not active
    IDE04452-IDE03662	Brake system button-ASR/ESP button	not activated
    IDE04452-IDE03663	Brake system button--AUTO HOLD- Button	Not available due to specific system
    IDE04452-IDE03664	Brake system button-Button for driving program	not activated
    IDE04452-IDE04432	Brake system button-Tire Pressure Monitoring Display Button	not activated
    IDE04452-IDE04769	Brake system button-Electro-mechanical parking brake button: status	Not available due to specific system
    IDE04456-IDE02955	Brake disk drying-System status	Available
    IDE04456-IDE04775	Brake disk drying-Odometer reading of last activation	0	 km
    IDE04456-MAS01282	Brake disk drying-Wiper	not active
    IDE04456-MAS03095	Brake disk drying-Function status	not active
    IDE04461-IDE03208	Internal measured values-Software version for suppliers	MZARAB00010
    IDE04461-IDE03649	Internal measured values-Fill/bleed brake system	not completed successfully
    IDE04461-IDE03659	Internal measured values-Roller test bench mode	not active
    IDE04461-MAS01481	Internal measured values-Temperature in control module	48	 °C
    IDE04461-MAS04484	Internal measured values-Flashloader version	 TSCBAE00004
    IDE04499-IDE02955	Sensor for roof rack recognition-System status	Not available due to specific system
    IDE04499-MAS03095	Sensor for roof rack recognition-Function status	not recognized
    IDE04508-IDE02955	Hydraulic brake booster-System status	Not available due to specific system
    IDE04508-IDE04442	Hydraulic brake booster-Vacuum sensor	ERROR
    IDE04508-IDE04450	Hydraulic brake booster-Brake pressure sensor 1	-0.4	 bar
    IDE04508-MAS03095	Hydraulic brake booster-Function status	not active
    IDE04508-MAS04002	Hydraulic brake booster-Low intake manifold pressure	ERROR
    IDE04644-IDE02955	Roll-over protection-System status	Available
    IDE04644-IDE04775	Roll-over protection-Odometer reading of last activation	0	 km
    IDE04644-MAS03095	Roll-over protection-Function status	not active
    IDE04765-IDE02955	Counter steer support-System status	Available
    IDE04765-IDE03735	Counter steer support-Steering torque	0	 Nm
    IDE04765-IDE04775	Counter steer support-Odometer reading of last activation	81	 km
    IDE04765-MAS03095	Counter steer support-Function status	not active
    IDE04774-IDE02955	Vehicle and trailer stabilization-System status	Not available due to specific system
    IDE04774-IDE04775	Vehicle and trailer stabilization-Odometer reading of last activation	0	 km
    IDE04774-MAS03095	Vehicle and trailer stabilization-Function status	not active
    IDE04939-IDE02955	Tire pressure monitoring display-System status	Available
    IDE04939-IDE04248	Tire pressure monitoring display-Left front tire pressure diffusion indicator	251
    IDE04939-IDE04249	Tire pressure monitoring display-Right front tire pressure diffusion indicator	251
    IDE04939-IDE04250	Tire pressure monitoring display-Left rear tire pressure diffusion indicator	251
    IDE04939-IDE04251	Tire pressure monitoring display-Right rear tire pressure diffusion indicator	246
    IDE04939-IDE04432	Tire pressure monitoring display-Tire Pressure Monitoring Display Button	not activated
    IDE04939-IDE04946	Tire pressure monitoring display-Odometer reading at last adaptation	0	 km
    IDE04939-IDE04947	Tire pressure monitoring display-Odometer reading of last warning	0	 km
    IDE04939-MAS04538	Tire pressure monitoring display-Odometer reading two adaptations ago	0	 km
    IDE04939-MAS04539	Tire pressure monitoring display-Odometer reading three adaptations ago	0	 km
    IDE04939-MAS04540	Tire pressure monitoring display-Odometer reading four adaptations ago	0	 km
    IDE04939-MAS04541	Tire pressure monitoring display-Odometer reading of next-to-last warning	0	 km
    IDE04939-MAS04542	Tire pressure monitoring display-Odometer reading of third-to-last warning	0	 km
    IDE04939-MAS04543	Tire pressure monitoring display-Odometer reading of fourth-to-last warning	0	 km
    IDE04939-MAS04544	Tire pressure monitoring display-Left front flat tire indicator	255
    IDE04939-MAS04545	Tire pressure monitoring display-Right front flat tire indicator	248
    IDE04939-MAS04546	Tire pressure monitoring display-Left rear flat tire indicator	252
    IDE04939-MAS04547	Tire pressure monitoring display-Right rear flat tire indicator	248
    IDE06425-IDE02766	Roller test bench mode: functional-Malfunction status	no error
    IDE06425-MAS06026	Roller test bench mode: functional-Activation stages	not activated
    IDE06591-ENG118150	Pump load counter-Comp_Rotatation_of_pump_motor	1679
    IDE06591-ENG118152	Pump load counter-Load_on_feeding_side_of_Pump	50169
    IDE06591-ENG118151	Pump load counter-Load_on_suction_side_of_Pump	3
    IDE06591-ENG118153	Pump load counter-Pump_motor_start_counter	95
    IDE07280-IDE04775	Multiple collision brake-Odometer reading of last activation	0	 km
    IDE07280-IDE06609	Multiple collision brake-Odometer reading of last deactivation	0	 km
    IDE07280-MAS00106	Multiple collision brake-Year	2127
    IDE07280-MAS00107	Multiple collision brake-Month	15
    IDE07280-MAS00108	Multiple collision brake-Day	0
    IDE07280-MAS00109	Multiple collision brake-Hours	31
    IDE07280-MAS00110	Multiple collision brake-Minutes	63
    IDE07280-MAS00111	Multiple collision brake-Seconds	63
    IDE07280-MAS07659	Multiple collision brake-Frequency counter for multi-collision brake active	0
    IDE07280-MAS07660	Multiple collision brake-Frequency counter for multi-collision brake deactivated	0
    IDE07280-MAS07661	Multiple collision brake-Frequency counter function deactivated by driver	0
    IDE07280-MAS07662	Multiple collision brake-Mileage reading of the last deactivation by driver	0	 km
    IDE80101	Analysis 101	A3 32 38 35 31 35 34 37 31 33 31 33 30 30 30 30 35 31 37 38 32 38 30 30 30 36 44 2F 02 13 1E 45 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00
    IDE80102-ENG122580	Analysis 102-value_1_percentaged	94.1346	 %
    IDE80102-ENG122579	Analysis 102-value_1_quantity	0
    IDE80102-ENG122582	Analysis 102-value_2_percentaged	99.9936	 %
    IDE80102-ENG122581	Analysis 102-value_2_quantity	0
    IDE80102-ENG122584	Analysis 102-value_3_percentaged	94.9158	 %
    IDE80102-ENG122583	Analysis 102-value_3_quantity	10
    IDE80102-ENG122586	Analysis 102-value_4_percentaged	98.4312	 %
    IDE80102-ENG122585	Analysis 102-value_4_quantity	8
    IDE80102-ENG122588	Analysis 102-value_5_percentaged	98.0406	 %
    IDE80102-ENG122587	Analysis 102-value_5_quantity	4
    IDE80102-ENG122590	Analysis 102-value_6_percentaged	99.9936	 %
    IDE80102-ENG122589	Analysis 102-value_6_quantity	0
    IDE80103-MAS00976	Analysis 103-Counter	0
    MAS00121-IDE02955	Electronic Differential Lock-System status	Available
    MAS00121-IDE04504	Electronic Differential Lock-Calculated left front brake temperature	22.5	 °C
    MAS00121-IDE04505	Electronic Differential Lock-Calculated right front brake temperature	22.5	 °C
    MAS00121-IDE04506	Electronic Differential Lock-Calculated left rear brake temperature	22.5	 °C
    MAS00121-IDE04507	Electronic Differential Lock-Calculated right rear brake temperature	22.5	 °C
    MAS00121-MAS00179	Electronic Differential Lock-Brake Light Switch	not activated
    MAS00121-MAS01853	Electronic Differential Lock-Left front	Available
    MAS00121-MAS01854	Electronic Differential Lock-Right front	Available
    MAS00121-MAS01855	Electronic Differential Lock-Left rear	Available
    MAS00121-MAS01856	Electronic Differential Lock-Right rear	Available
    MAS00121-MAS03095	Electronic Differential Lock-Function status	not active
    MAS00911-IDE02955	All Wheel Drive (AWD)-System status	Available
    MAS00911-IDE04502	All Wheel Drive (AWD)-Haldex clutch status	No malfunction detected
    MAS00911-IDE04943	All Wheel Drive (AWD)-Haldex clutch	Fully open
    MAS00911-MAS01464	All Wheel Drive (AWD)-Emergency running mode	not active
    MAS00911-MAS04730	All Wheel Drive (AWD)-Degree of blockage	0	 %
    MAS02138-IDE02955	Hill-start assistant-System status	Available
    MAS02138-MAS00025	Hill-start assistant-Driver seat belt switch	not connected
    MAS02138-MAS00218	Hill-start assistant-Driver door	Open
    MAS02138-MAS00988	Hill-start assistant-Reverse gear	not selected
    MAS02138-MAS03095	Hill-start assistant-Function status	Condition not met
    MAS02426-MAS00580	Text display in instrument panel insert-Electromechanical parking brake text 1	0
    MAS02426-MAS03359	Text display in instrument panel insert-Text	0
    MAS02672-IDE02955	Start-stop-System status	Not available due to specific system
    MAS02672-IDE03214	Start-stop-Engine stop using start-stop function	not active
    MAS02672-IDE03215	Start-stop-Engine start using start-stop function	not active
    MAS02672-MAS00025	Start-stop-Driver seat belt switch	not connected
    MAS08072-MAS13685	Driving profile selection-Actual value of downhill driving assistant	2
    MAS08072-MAS13686	Driving profile selection-Actual value uphill driving assistant	0
    MAS08072-MAS13687	Driving profile selection-Actual value of differential lock	0
    MAS08072-MAS13688	Driving profile selection-ESC actual value	2
    MAS08072-MAS13689	Driving profile selection-Compatibility of downhill driving assistant	Yes
    MAS08072-MAS13690	Driving profile selection-Compatibility of uphill driving assistant	Yes
    MAS08072-MAS13691	Driving profile selection-Compatibility of differential lock	Yes
    MAS08072-MAS13692	Driving profile selection-ESC compatibility	Yes
    MAS08072-MAS13693	Driving profile selection-Spec. value of downhill driving assistant	2
    MAS08072-MAS13694	Driving profile selection-Spec. value of uphill driving assistant	0
    MAS08072-MAS13695	Driving profile selection-Spec. value of differential lock	0
    MAS08072-MAS13696	Driving profile selection-ESC spec. value	2
    MAS08072-MAS13697	Driving profile selection-System status of downhill driving assistant	Available
    MAS08072-MAS13698	Driving profile selection-System status uphill driving assistant	Not available
    MAS08072-MAS13699	Driving profile selection-System status of differential lock	Not available
    MAS08072-MAS13700	Driving profile selection-ESC system status	Available
    MAS08072-MAS13701	Driving profile selection-Switchover status of downhill driving assistant	Shifting carried out
    MAS08072-MAS13702	Driving profile selection-Switchover status of uphill driving assistant	Shifting carried out
    MAS08072-MAS13703	Driving profile selection-ESC switchover status	Shifting carried out
    MAS08072-MAS13704	Driving profile selection-Switchover status_differential lock	Shifting carried out
    ENG26281-IDE01011	HBV_Event_Counter-Data record	0
    Elapsed Time: 00:12
    United States
    08-Auto HVAC
    adpmap-08-5GM-907-426-G_3VWH17AU5JM758941-20180826-1116.CSV
    ;SW:5GM-907-426-G   HW:5GM-907-426-G ---  Auto HVAC
    ;Component:AC Manuell    H03 2001	 Coding:02020004200110000000000000000002
    ;EV_ACManueBHBVW37X	4134	EV_ACManueBHBVW37X_004_VW37.rod
    ;Sunday	26	August	2018	11:16:07:04045
    ;VCID: 4CC26E59764BEBB73DA-8018
    IDE00001-Production mode	Deactivating 	3
    IDE01067-Retention of driver's seat heater level	active for 10 minutes 	1
    IDE01478-Ignore compressor switch-off by Engine Control Module	Do not ignore 	1
    IDE01479-Gear ratio of engine - A/C compressor	0	1
    IDE01483-Blower voltage for voice operation	not activated 	1
    IDE01488-Retrofitting of parking heater without CAN	not installed 	1
    IDE01503-Runtime for compressor run-in basic setting	60 s	1
    IDE02155-Reset all counters	not activated 	1
    IDE02332-Deactivate production mode	0	3
    IDE03176-Duration of compressor run in	60 s	1
    IDE03251-Stop release for start-stop function	According to function requirements 	1
    IDE04159-Deactivation of start-stop function	not active 	1
    IDE06097-Target temperature of A/C - heater function via remote control	22.0 °C	1
    IDE06544-Speed switch-off threshold for compressor run-in (engine speed)	1500 /min	1
    IDE06545-Blower voltage for production routines	9.0 V	1
    IDE06546-Interior target temperature for production routines	22 °C	1
    IDE06547-Air distribution for production routines	No effect 	1
    IDE06593-Recirculation air for production routines	No effect 	1
    IDE07160-MAS01155-Control module switch-off: switch-off time-Control module	20 min	2
    IDE07160-MAS05583-Control module switch-off: switch-off time-Data bus	30 min	2
    IDE07301-Remote start function: activation of seat heating	Seat heater front 	1
    IDE07302-Remote start function: interior climate control status	Remote start function with fixed rated temperature active 	1
    IDE07303-Rem.start funct.:activ.temper. of windshield defrost.heat.	4 °C	1
    IDE07304-Remote start function: activation of seat ventilation	activated 	1
    IDE07305-Rem. start funct.: activat.temper. of seat heating	15 °C	1
    IDE07306-Rem. start funct.: activat.temper. of seat ventilation	20 °C	1
    IDE07307-Remote start function: activation stage of seat heating	2	1
    IDE07308-Remote start function: activation stage of seat ventilation	2	1
    IDE07865-Automatic Activation of front windshield heater at MAX-Defrost	not active 	1
    IDE07948-Retention of frt.pass. seat heater level	not active 	1
    IDE12229-Filtering of interior air: store	Service life-dependent store 	1
    IDE80007-Analysis 7	00000000 00000000  	2
    IDE80008-Analysis 8	not active 	1
    MAS14860-Remote start function: windshield defogger takeover	activated 	1
    MAS14861-Remote start function: windshield defogger	activated 	1
    ENG122844-ENG101574-dimming_characteristic_1-X1	0	12
    ENG122844-ENG99557-dimming_characteristic_1-X2	6	12
    ENG122844-ENG102140-dimming_characteristic_1-X3	40	12
    ENG122844-ENG102936-dimming_characteristic_1-X4	60	12
    ENG122844-ENG103548-dimming_characteristic_1-X5	80	12
    ENG122844-ENG113992-dimming_characteristic_1-X6	100	12
    ENG122844-ENG99777-dimming_characteristic_1-Y1	0%	12
    ENG122844-ENG100480-dimming_characteristic_1-Y2	6%	12
    ENG122844-ENG100773-dimming_characteristic_1-Y3	40%	12
    ENG122844-ENG100631-dimming_characteristic_1-Y4	60%	12
    ENG122844-ENG102174-dimming_characteristic_1-Y5	80%	12
    ENG122844-ENG113993-dimming_characteristic_1-Y6	100%	12
    ENG122845-ENG101574-dimming_characteristic_2-X1	0	12
    ENG122845-ENG99557-dimming_characteristic_2-X2	6	12
    ENG122845-ENG102140-dimming_characteristic_2-X3	40	12
    ENG122845-ENG102936-dimming_characteristic_2-X4	60	12
    ENG122845-ENG103548-dimming_characteristic_2-X5	80	12
    ENG122845-ENG113992-dimming_characteristic_2-X6	100	12
    ENG122845-ENG99777-dimming_characteristic_2-Y1	0%	12
    ENG122845-ENG100480-dimming_characteristic_2-Y2	6%	12
    ENG122845-ENG100773-dimming_characteristic_2-Y3	40%	12
    ENG122845-ENG100631-dimming_characteristic_2-Y4	60%	12
    ENG122845-ENG102174-dimming_characteristic_2-Y5	80%	12
    ENG122845-ENG113993-dimming_characteristic_2-Y6	100%	12
    ENG122846-ENG101574-dimming_characteristic_3-X1	0	12
    ENG122846-ENG99557-dimming_characteristic_3-X2	6	12
    ENG122846-ENG102140-dimming_characteristic_3-X3	40	12
    ENG122846-ENG102936-dimming_characteristic_3-X4	60	12
    ENG122846-ENG103548-dimming_characteristic_3-X5	80	12
    ENG122846-ENG113992-dimming_characteristic_3-X6	100	12
    ENG122846-ENG99777-dimming_characteristic_3-Y1	0%	12
    ENG122846-ENG100480-dimming_characteristic_3-Y2	6%	12
    ENG122846-ENG100773-dimming_characteristic_3-Y3	40%	12
    ENG122846-ENG100631-dimming_characteristic_3-Y4	60%	12
    ENG122846-ENG102174-dimming_characteristic_3-Y5	80%	12
    ENG122846-ENG113993-dimming_characteristic_3-Y6	100%	12
    ENG122847-ENG101574-dimming_characteristic_4-X1	0	12
    ENG122847-ENG99557-dimming_characteristic_4-X2	6	12
    ENG122847-ENG102140-dimming_characteristic_4-X3	40	12
    ENG122847-ENG102936-dimming_characteristic_4-X4	60	12
    ENG122847-ENG103548-dimming_characteristic_4-X5	80	12
    ENG122847-ENG113992-dimming_characteristic_4-X6	100	12
    ENG122847-ENG99777-dimming_characteristic_4-Y1	0%	12
    ENG122847-ENG100480-dimming_characteristic_4-Y2	6%	12
    ENG122847-ENG100773-dimming_characteristic_4-Y3	40%	12
    ENG122847-ENG100631-dimming_characteristic_4-Y4	60%	12
    ENG122847-ENG102174-dimming_characteristic_4-Y5	80%	12
    ENG122847-ENG113993-dimming_characteristic_4-Y6	100%	12
    ENG122848-ENG101574-dimming_characteristic_5-X1	0	12
    ENG122848-ENG99557-dimming_characteristic_5-X2	10	12
    ENG122848-ENG102140-dimming_characteristic_5-X3	50	12
    ENG122848-ENG102936-dimming_characteristic_5-X4	100	12
    ENG122848-ENG103548-dimming_characteristic_5-X5	220	12
    ENG122848-ENG113992-dimming_characteristic_5-X6	253	12
    ENG122848-ENG99777-dimming_characteristic_5-Y1	2%	12
    ENG122848-ENG100480-dimming_characteristic_5-Y2	2%	12
    ENG122848-ENG100773-dimming_characteristic_5-Y3	5%	12
    ENG122848-ENG100631-dimming_characteristic_5-Y4	10%	12
    ENG122848-ENG102174-dimming_characteristic_5-Y5	85%	12
    ENG122848-ENG113993-dimming_characteristic_5-Y6	100%	12
    ENG122849-illumination index grain rotary knob	search illumination 	1
    ENG130577-Knockout_timer_activation	not activated 	1
    Elapsed Time: 00:11
    blockmap-08-5GM-907-426-G_3VWH17AU5JM758941-20180826-1115.CSV
    ;Sunday	26	August	2018	11:15:59:04045
    ;VCDS Version: Beta 18.7.2 (x64)  Data version: 20180808 DS295.0
    Group	Description	Actual
    IDE00019	Voltage terminal 30	14.5	 V
    IDE00021	Engine speed	0	 /min
    IDE00025	Coolant temperature	68	 °C
    IDE00030	Status of actuator test	not active
    IDE00075	Vehicle speed	0	 km/h
    IDE00198	Refrigerant pressure	6.6	 bar
    IDE00322	Status of basic setting	was not yet started
    IDE00767	No. of unscheduled ECU resets	1
    IDE00965	Compressor shut-off requirement	A/C off or fan control switch in 0 position
    IDE00966	Compressor current: actual value	0	 A
    IDE00967	Compressor current: specified value	0	 A
    IDE00968	Compressor speed	0	 /min
    IDE00969	Compressor load	0.5	 Nm
    IDE00970	Coolant fan activation: actual value	10	 %
    IDE00971	Coolant fan activation: specified value	0	 %
    IDE00973	Outside air temperature	23.5	 °C
    IDE00974	Outside air temperature internally calculated	21	 °C
    IDE00982	Temperature after evaporator	29	 °C
    IDE00987	Blower voltage: specified value	0	 V
    IDE00989	Blower status	not active
    IDE00992	Recirculation flap specified value	Fresh air
    IDE01046	Temperature flap: actual value	55
    IDE01046	Temperature flap: actual value	12.5	 %
    IDE01047	Temperature flap: specified value	55
    IDE01048	Temperature flap: cold stop	29
    IDE01049	Temperature flap: warm stop	234
    IDE01059	Air distribution flap: actual value	79
    IDE01059	Air distribution flap: actual value	19.5	 %
    IDE01060	Air distribution flap: specified value	78
    IDE01063	Status of recirculation air	Fresh air
    IDE01066	Convertible top status	closed
    IDE01076	Time since ignition off	3	 min
    IDE01217-MAS01447	Left heated seat stage-Act.val.	0
    IDE01217-MAS01448	Left heated seat stage-Specified value	0
    IDE01218-MAS01447	Right heated seat stage-Act.val.	0
    IDE01218-MAS01448	Right heated seat stage-Specified value	0
    IDE01226	Blower voltage: actual value	0	 V
    IDE01227	Blower current	0	 A
    IDE01232	Supply voltage for external components	5.1	 V
    IDE01264	Remaining time of parking heater/ventilation operation	0	 min
    IDE01287-MAS01260	Counter of compressor switch-offs-Shut-off from Engine Control Module (ECM) via CAN	57
    IDE01287-MAS01265	Counter of compressor switch-offs-Speed shut-off	0
    IDE01419	Compressor shut-off condition: last	Low pressure event
    IDE01420	Compressor shut-off requirement: penultimate	Low pressure event
    IDE01421	Compressor shut-off requirement: antepenultimate	Low pressure event
    IDE01442-MAS01533	Pressing a button-Defrost	not activated
    IDE01442-MAS01534	Pressing a button-Recirculating air	not activated
    IDE01442-MAS01535	Pressing a button-Rear window defogger	not activated
    IDE01442-MAS01550	Pressing a button-AC	not activated
    IDE01442-MAS01554	Pressing a button-Left heated seat	not activated
    IDE01442-MAS01556	Pressing a button-Right heated seat	not activated
    IDE01442-MAS01560	Pressing a button-OFF	not activated
    IDE01442-MAS01577	Pressing a button-Parking heater	not activated
    IDE01442-MAS02015	Pressing a button-AUTO	not activated
    IDE01442-MAS02192	Pressing a button-SYNC	not activated
    IDE01442-MAS03196	Pressing a button-Menu	not activated
    IDE01442-MAS03830	Pressing a button-Footwell air distribution	not activated
    IDE01442-MAS03831	Pressing a button-Upper body vent air distribution	not activated
    IDE01442-MAS03832	Pressing a button-Air distribution up	not activated
    IDE01442-MAS04605	Pressing a button-AC MAX	not activated
    IDE01443	Left push-and-rotary knob counter	82
    IDE01444	Right push-and-rotary knob counter	148
    IDE02270-IDE00002	CAN input signal(s) status-Transport mode	OFF
    IDE02270-IDE01211	CAN input signal(s) status-Static current measuring mode	OFF
    IDE02270-IDE01268	CAN input signal(s) status-Windshield wiper	OFF
    IDE02270-IDE01457	CAN input signal(s) status-Energy management deactivation stage	Deactivation stage 0
    IDE02270-MAS01269	CAN input signal(s) status-Wipe wash	OFF
    IDE02270-MAS01277	CAN input signal(s) status-Rear window heater actual value	OFF
    IDE02270-MAS01283	CAN input signal(s) status-Actual value of windshield heater	OFF
    IDE02271-IDE00972	CAN output signal(s) status-Idle speed increase	not active
    IDE02271-MAS00130	CAN output signal(s) status-Compressor on	OFF
    IDE03008-MAS01517	Stop process prevented-Defrost active	not active
    IDE03008-MAS01564	Stop process prevented-Windshield defogger	not active
    IDE03008-MAS02802	Stop process prevented-Interior temperature difference to setting	not active
    IDE03008-MAS02803	Stop process prevented-Interior vent difference to setting	not active
    IDE03008-MAS02804	Stop process prevented-Manual fan speed increase	not active
    IDE03008-MAS04353	Stop process prevented-Fogging hazard (humidity sensor)	not active
    IDE03008-MAS04354	Stop process prevented-Interior comfort humidity too high (humidity sensor)	not active
    IDE03008-MAS05009	Stop process prevented-A/C request: auxil. heat mode	not active
    IDE03008-MAS05047	Stop process prevented-Maximum cooling and heating set	not active
    IDE03008-MAS06551	Stop process prevented-Seat ventilation	not active
    IDE03008-MAS09538	Stop process prevented-max A/C	not active
    IDE03009-MAS01517	Start process requested-Defrost active	not active
    IDE03009-MAS01564	Start process requested-Windshield defogger	not active
    IDE03009-MAS02802	Start process requested-Interior temperature difference to setting	not active
    IDE03009-MAS02803	Start process requested-Interior vent difference to setting	not active
    IDE03009-MAS02804	Start process requested-Manual fan speed increase	not active
    IDE03009-MAS04353	Start process requested-Fogging hazard (humidity sensor)	not active
    IDE03009-MAS04354	Start process requested-Interior comfort humidity too high (humidity sensor)	not active
    IDE03009-MAS05009	Start process requested-A/C request: auxil. heat mode	not active
    IDE03009-MAS05047	Start process requested-Maximum cooling and heating set	not active
    IDE03009-MAS06551	Start process requested-Seat ventilation	not active
    IDE03009-MAS09538	Start process requested-max A/C	not active
    IDE03010-MAS00478	Number of prevented stop processes-Reserved	0
    IDE03010-MAS01517	Number of prevented stop processes-Defrost active	0
    IDE03010-MAS01564	Number of prevented stop processes-Windshield defogger	0
    IDE03010-MAS02802	Number of prevented stop processes-Interior temperature difference to setting	0
    IDE03010-MAS02803	Number of prevented stop processes-Interior vent difference to setting	0
    IDE03010-MAS02804	Number of prevented stop processes-Manual fan speed increase	0
    IDE03010-MAS04353	Number of prevented stop processes-Fogging hazard (humidity sensor)	0
    IDE03010-MAS04354	Number of prevented stop processes-Interior comfort humidity too high (humidity sensor)	0
    IDE03010-MAS05009	Number of prevented stop processes-A/C request: auxil. heat mode	0
    IDE03010-MAS05047	Number of prevented stop processes-Maximum cooling and heating set	0
    IDE03010-MAS06551	Number of prevented stop processes-Seat ventilation	0
    IDE03010-MAS09538	Number of prevented stop processes-max A/C	0
    IDE03011-MAS00478	Number of requested start processes-Reserved	0
    IDE03011-MAS01517	Number of requested start processes-Defrost active	0
    IDE03011-MAS01564	Number of requested start processes-Windshield defogger	0
    IDE03011-MAS02802	Number of requested start processes-Interior temperature difference to setting	0
    IDE03011-MAS02803	Number of requested start processes-Interior vent difference to setting	0
    IDE03011-MAS02804	Number of requested start processes-Manual fan speed increase	0
    IDE03011-MAS04353	Number of requested start processes-Fogging hazard (humidity sensor)	0
    IDE03011-MAS04354	Number of requested start processes-Interior comfort humidity too high (humidity sensor)	0
    IDE03011-MAS05009	Number of requested start processes-A/C request: auxil. heat mode	0
    IDE03011-MAS05047	Number of requested start processes-Maximum cooling and heating set	0
    IDE03011-MAS06551	Number of requested start processes-Seat ventilation	0
    IDE03011-MAS09538	Number of requested start processes-max A/C	0
    IDE03127-MAS00106	Prevented stop processes (ring memory)-Year	2127
    IDE03127-MAS00107	Prevented stop processes (ring memory)-Month	15
    IDE03127-MAS00108	Prevented stop processes (ring memory)-Day	31
    IDE03127-MAS00109	Prevented stop processes (ring memory)-Hours	31
    IDE03127-MAS00110	Prevented stop processes (ring memory)-Minutes	63
    IDE03127-MAS00111	Prevented stop processes (ring memory)-Seconds	63
    IDE03127	Prevented stop processes (ring memory)	Measured value not available
    IDE03128-MAS00106	Requested start processes (ring memory)-Year	2127
    IDE03128-MAS00107	Requested start processes (ring memory)-Month	15
    IDE03128-MAS00108	Requested start processes (ring memory)-Day	31
    IDE03128-MAS00109	Requested start processes (ring memory)-Hours	31
    IDE03128-MAS00110	Requested start processes (ring memory)-Minutes	63
    IDE03128-MAS00111	Requested start processes (ring memory)-Seconds	63
    IDE03128	Requested start processes (ring memory)	Measured value not available
    IDE03212	Start-stop conditions	Stop release
    IDE03213	Start-stop enabling	System malfunction
    IDE03214	Engine stop using start-stop function	not active
    IDE03215	Engine start using start-stop function	not active
    IDE03488	Driving time remaining for basic setting of compressor run in	0	 s
    IDE04312-IDE04095	System run time-Engine running time	0	 s
    IDE04312-MAS00084	System run time-Terminal 15 on	255	 s
    IDE04797	Center push-and-rotary knob counter	61
    IDE05725	Terminal 58xs dimmer	0	 %
    IDE05726	Terminal 58xd dimmer	253
    IDE06201	Blower reduction	No switch-off: no reduction
    IDE07159-MAS01155	Control module switch-off: counter-Control module	0
    IDE07159-MAS05583	Control module switch-off: counter-Data bus	0
    IDE12141-MAS00106	History memory: parking heater-Year	2127
    IDE12141-MAS00107	History memory: parking heater-Month	15
    IDE12141-MAS00108	History memory: parking heater-Day	31
    IDE12141-MAS00109	History memory: parking heater-Hours	31
    IDE12141-MAS00110	History memory: parking heater-Minutes	63
    IDE12141-MAS00111	History memory: parking heater-Seconds	63
    IDE12141-MAS02526	History memory: parking heater-Activation	Measured value not available
    IDE12141-MAS04390	History memory: parking heater-Active source	Measured value not available
    IDE12499-IDE08704	A/C compressor initial running in: start prevention-Load mgmnt.	not active
    IDE12499-MAS01250	A/C compressor initial running in: start prevention-Malfunction on fresh air blower	not active
    IDE12499-MAS01493	A/C compressor initial running in: start prevention-Engine running	Yes
    IDE12499-MAS10030	A/C compressor initial running in: start prevention-Adapt. of run-in time: compressor initial operation: written	Yes
    IDE12499-MAS14625	A/C compressor initial running in: start prevention-High-voltage vehicle electrical system	active
    IDE12499-MAS14626	A/C compressor initial running in: start prevention-High-voltage current limitations	not active
    IDE12499-MAS14891	A/C compressor initial running in: start prevention-Flaps not calibrated	not active
    IDE12500-MAS01250	A/C compressor initial running in: interruption conditions-Malfunction on fresh air blower	not active
    IDE12500-MAS01254	A/C compressor initial running in: interruption conditions-AC button off	not active
    IDE12500-MAS01256	A/C compressor initial running in: interruption conditions-Outside air temperature too low	not active
    IDE12500-MAS01261	A/C compressor initial running in: interruption conditions-Evaporator temperature ice-up danger	not active
    IDE12500-MAS01263	A/C compressor initial running in: interruption conditions-Compressor activation: malfunction in activation path	not active
    IDE12500-MAS01264	A/C compressor initial running in: interruption conditions-Malfunction at refrigerant pressure sensor	not active
    IDE12500-MAS01265	A/C compressor initial running in: interruption conditions-Speed shut-off	not active
    IDE12500-MAS01504	A/C compressor initial running in: interruption conditions-Supply voltage too high	not active
    IDE12500-MAS01508	A/C compressor initial running in: interruption conditions-High pressure event	not active
    IDE12500-MAS01509	A/C compressor initial running in: interruption conditions-Low pressure event	not active
    IDE12500-MAS14892	A/C compressor initial running in: interruption conditions-Pressure test not successful	not active
    IDE12500-MAS14893	A/C compressor initial running in: interruption conditions-Fault on the evaporator temperature sensor	not active
    MAS00464-MAS00106	Standard - ambient data 1-Year	2018
    MAS00464-MAS00107	Standard - ambient data 1-Month	8
    MAS00464-MAS00108	Standard - ambient data 1-Day	26
    MAS00464-MAS00109	Standard - ambient data 1-Hours	11
    MAS00464-MAS00110	Standard - ambient data 1-Minutes	15
    MAS00464-MAS00111	Standard - ambient data 1-Seconds	45
    MAS00464-MAS00468	Standard - ambient data 1-Unlearning counter	28
    MAS00464-MAS00711	Standard - ambient data 1-Odometer reading	138	 km
    Elapsed Time: 00:07
    United States
    09-Cent. Elect.
    adpmap-09-5Q0-937-087-AR_3VWH17AU5JM758941-20180826-1117.CSV
    ;SW:5Q0-937-087-AR   HW:5Q0-937-087-AN ---  Cent. Elect.
    ;Component:BCM PQ37BOSCH 034 0243	 Coding:
    ;EV_BodyContrModul1UDSBosc	18001	EV_BCMBOSCH_018.rod
    ;Sunday	26	August	2018	11:17:05:04045
    ;VCID: 0B40AD4533C5AC8FF40-805E
    IDE00001-ENG99061-Production mode-Access control	not active 	3
    IDE00001-ENG115730-Production mode-Aussenbeleuchtung	not active 	3
    IDE00001-ENG112304-Production mode-Heckwischer	not active 	3
    IDE00001-ENG98647-Production mode-Interior lighting	not active 	3
    IDE00001-ENG115729-Production mode-Scheinwerferreinigung	not active 	3
    IDE00001-ENG115731-Production mode-Virtuel_pedal	not active 	3
    IDE00002-Transport mode	active 	1
    IDE00820-Activating and deactivating all development messages	not active 	1
    IDE01550-Service position	170.494336 °	2
    IDE02152-Characteristics in production mode	2000 ms	4
    IDE02269-MAS04382-Acknowledgement signals-Optical feedback during locking	Decelerate 	10
    IDE02269-ENG116666-Acknowledgement signals-Akustische Rueckmeldung entriegeln	not active 	10
    IDE02269-ENG116669-Acknowledgement signals-Akustische Rueckmeldung global	active 	10
    IDE02269-ENG116670-Acknowledgement signals-Akustische Rueckmeldung Signalhorn	active 	10
    IDE02269-ENG116667-Acknowledgement signals-Akustische Rueckmeldung verriegeln	active 	10
    IDE02269-ENG122187-Acknowledgement signals-Dauer der Akustischen Rueckmeldung vom Einfachhorn	short 	10
    IDE02269-ENG122188-Acknowledgement signals-Menuesteuerung akustische Rueckmeldung	active 	10
    IDE02269-ENG122995-Acknowledgement signals-Optische Rueckmeldung 3.Bremsleuchte	not active 	10
    IDE02269-ENG116668-Acknowledgement signals-Optische Rueckmeldung Komfortschliessen	active 	10
    IDE02269-ENG133344-Acknowledgement signals-Quittierton bei zweitem ZV-AUF-Befehl	not active 	10
    IDE02269-ENG133345-Acknowledgement signals-Quittierton bei zweitem ZV-ZU-Befehl	active 	10
    IDE02269-ENG142248-Acknowledgement signals-ZV-Blinken_Abschluss_Dunkelzeit	200 ms	10
    IDE02269-ENG142247-Acknowledgement signals-ZV-Blinken_Dunkelzeit	200 ms	10
    IDE02269-ENG142246-Acknowledgement signals-ZV-Blinken_Hellzeit	200 ms	10
    IDE02711-ENG116690-Rear Window Wiper-Automatisches Heckwischen	not active 	8
    IDE02711-ENG133397-Rear Window Wiper-Einzelansteuerung Heckintervallwischen	not active 	8
    IDE02711-ENG133395-Rear Window Wiper-Einzelansteuerung Heckintervallwischen Zeitintervall 1	8 s	8
    IDE02711-ENG133396-Rear Window Wiper-Einzelansteuerung Heckintervallwischen Zeitintervall 2	16 s	8
    IDE02711-ENG112304-Rear Window Wiper-Heckwischer	logikgesteuert 	8
    IDE02711-ENG114947-Rear Window Wiper-Heckwischer Weiterlauf	not active 	8
    IDE02711-ENG114946-Rear Window Wiper-Komfortwischen Heck	active 	8
    IDE02711-ENG116695-Rear Window Wiper-Komofortwischen Heck Intervallpausenzeit Stufe 1	5 s	8
    IDE02711-ENG116696-Rear Window Wiper-Komofortwischen Heck Intervallpausenzeit Stufe 2	3 s	8
    IDE02711-ENG116694-Rear Window Wiper-Komofortwischen Heck Intervallpausenzeit Stufe Automatik	7 s	8
    IDE02711-ENG116693-Rear Window Wiper-Komofortwischen Heck Intervallpausenzeit Stufe Intervall	7 s	8
    IDE02711-ENG116689-Rear Window Wiper-Menuesteuerung Komfortwischen HW	active 	8
    IDE02711-ENG154784-Rear Window Wiper-Spannungsanforderung_konfig_Wischer	Keine_Spannungsanforderung 	8
    IDE02711-ENG116691-Rear Window Wiper-Traenenwischen Heck	active 	8
    IDE02711-ENG154831-Rear Window Wiper-Zeit_wasch_min_heck	0 ms	8
    IDE03638-IDE04231-static AFS light-Steering wheel angle: offset	0.3 °	16
    IDE03638-ENG116677-static AFS light-Abdimmgeschwindigkeit	50.0 %/s	16
    IDE03638-ENG116673-static AFS light-bei Rueckwaertsfahrt	both sides 	16
    IDE03638-ENG116675-static AFS light-Lower speed threshold	0.0 km/h	16
    IDE03638-ENG116682-static AFS light-Maximaltemperatur	100.0 °C	16
    IDE03638-ENG116679-static AFS light-obere Grenztemperatur	95.0 °C	16
    IDE03638-ENG116681-static AFS light-Oberer Lenkradwinkel	120 °	16
    IDE03638-ENG116680-static AFS light-untere Grenztemperatur	80.0 °C	16
    IDE03638-ENG116678-static AFS light-Unterer Lenkradwinkel	80 °	16
    IDE03638-ENG116676-static AFS light-Upper speed threshold	40.0 km/h	16
    IDE03638-ENG116674-static AFS light-Vorschrift	ECE R119 	16
    IDE03638-ENG115830-static AFS light-Zeitwert Einschaltzeit Abbiegelicht	15 min	16
    IDE03787-Activate left/right hand drive switch-over	not active 	1
    IDE04927-IDE01446-Window heater-Running time of heated front window	240 s	11
    IDE04927-ENG126847-Window heater-Abschalttemperatur fuer Frontscheibenheizung	35.0 °C	11
    IDE04927-ENG126846-Window heater-Abschalttemperatur fuer Heckscheibenheizung	35.0 °C	11
    IDE04927-ENG142251-Window heater-Frontscheibenheizung _maximale_Dauer	0 s	11
    IDE04927-ENG142035-Window heater-Frontscheibenheizung_LED_direkt	not installed 	11
    IDE04927-ENG142018-Window heater-Frontscheibenheizungsansteuerung direkt von externem Algorithmus	not installed 	11
    IDE04927-ENG126845-Window heater-FSH Automatik	active 	11
    IDE04927-ENG115736-Window heater-Heckscheibenheizung Zeitwert	320 s	11
    IDE04927-ENG141955-Window heater-heizbare Heckscheibe	installed 	11
    IDE04927-ENG142021-Window heater-Heizbare_Frontscheibe	not installed 	11
    IDE04927-ENG116620-Window heater-Temperaturabhaengige Einschaltzeit FSH	active 	11
    IDE04927-ENG116619-Window heater-Temperaturabhaengige Einschaltzeit HSH	active 	11
    IDE04927-ENG141962-Window heater-Waschduesenheizung	installed 	11
    IDE04927-ENG154810-Window heater-window heating front activation time pause	240 s	11
    IDE04928-MAS01577-Anti-theft device-Parking heater	not installed 	8
    IDE04928-ENG115867-Anti-theft device-Akustischer Alarm Signalhorn	active 	8
    IDE04928-ENG115864-Anti-theft device-Alarmsignal	frequency modulated 	8
    IDE04928-ENG141960-Anti-theft device-Anti-theft alarm system	not active 	8
    IDE04928-ENG154588-Anti-theft device-Deaktivierung DWA-Sensoren via Doppelklick	not_active 	8
    IDE04928-ENG154589-Anti-theft device-Deaktivierung_DWA_Sensoren_HMI	not_active 	8
    IDE04928-ENG115865-Anti-theft device-DWA Alarmverzoegerung	not active 	8
    IDE04928-ENG115812-Anti-theft device-DWA Camper Modus	not active 	8
    IDE04928-ENG142007-Anti-theft device-DWA_Einfachhorn_oder_Sounder	not installed 	8
    IDE04928-ENG141961-Anti-theft device-Heckscheibenbruchsensor	not installed 	8
    IDE04928-ENG142006-Anti-theft device-IRUE_NGS_Deaktivierungstaster_direkt_am BCM_verdrahtet	No 	8
    IDE04928-ENG142249-Anti-theft device-OBD Alarm	not_active 	8
    IDE04928-ENG154722-Anti-theft device-RHF_Panikalarm	not_active 	8
    IDE04928-ENG142009-Anti-theft device-Schliesszylinder in_Richtung Oeffnen_aktiv (Thatcham inaktiv)	No 	8
    IDE04928-ENG142010-Anti-theft device-Sensor_fuer_Innenraumueberwachung	No 	8
    IDE04928-ENG115866-Anti-theft device-Sirenen Alarmzahl	1 Alarm 	8
    IDE04928-ENG142008-Anti-theft device-tilt_sensor	No 	8
    IDE04928-ENG126842-Anti-theft device-Ueberwachung Innenentriegelungshebel	not active 	8
    IDE04928-ENG115868-Anti-theft device-Verzoegerung Panikalarm	keine verzoegerung 	8
    IDE05143-MAS02985-Writing parameter-Value	130	5
    IDE05143-MAS04381-Writing parameter-Parameter address	FE 00 00 	5
    IDE05144-Read parameter address	FE 00 00 	3
    IDE05145-Light configuration	0C 34 00 14 02 00 64 00 00 00 00 00 00 00 00 00 0C 3E 00 15 04 00 64 00 00 00 00 00 00 00 00 00 04 48 00 4A 14 00 64 06 12 9C 08 09 1C 00 00 00 04 4C 00 4C 14 00 64 07 13 9C 08 0A 1C 00 00 00 01 3A 00 49 14 00 7F 06 00 80 08 09 7F 00 00 00 01 44 00 4B 14 00 7F 07 00 80 08 0A 7F 00 00 00 0B 36 00 1A 0B 00 64 00 00 00 00 00 00 00 00 00 0B 40 00 1B 0C 00 64 00 00 00 00 00 00 00 00 00 0A 37 00 1C 0D 0F 64 00 00 00 00 00 00 00 00 00 0A 41 00 1D 0E 0F 64 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 0A 38 00 22 12 16 64 00 00 00 00 00 00 00 00 00 0A 42 00 23 13 17 64 00 00 00 00 00 00 00 00 00 	224
    IDE06089-ENG141976-Seat heater level current consumption allocation-Sitzheitzung_CAN	Heizmatten am BCM 	30
    IDE06089-ENG116683-Seat heater level current consumption allocation-Sitzheizung Filterkonstante fuer Waermefluss	1 s	30
    IDE06089-ENG116684-Seat heater level current consumption allocation-Sitzheizung Regeltemperaturkorrektur bei Waermefluss	0.00 °C	30
    IDE06089-ENG115738-Seat heater level current consumption allocation-Sitzheizung Stufe 1 obere Schaltschwelle	22.50 °C	30
    IDE06089-ENG115737-Seat heater level current consumption allocation-Sitzheizung Stufe 1 untere Schaltschwelle	21.50 °C	30
    IDE06089-ENG115740-Seat heater level current consumption allocation-Sitzheizung Stufe 2 obere Schaltschwelle	22.50 °C	30
    IDE06089-ENG115739-Seat heater level current consumption allocation-Sitzheizung Stufe 2 untere Schaltschwelle	21.50 °C	30
    IDE06089-ENG115742-Seat heater level current consumption allocation-Sitzheizung Stufe 3 obere Schaltschwelle	36.00 °C	30
    IDE06089-ENG115741-Seat heater level current consumption allocation-Sitzheizung Stufe 3 untere Schaltschwelle	34.00 °C	30
    IDE06089-ENG115744-Seat heater level current consumption allocation-Sitzheizung Stufe 4 obere Schaltschwelle	36.00 °C	30
    IDE06089-ENG115743-Seat heater level current consumption allocation-Sitzheizung Stufe 4 untere Schaltschwelle	34.00 °C	30
    IDE06089-ENG115746-Seat heater level current consumption allocation-Sitzheizung Stufe 5 obere Schaltschwelle	50.00 °C	30
    IDE06089-ENG115745-Seat heater level current consumption allocation-Sitzheizung Stufe 5 untere Schaltschwelle	49.00 °C	30
    IDE06089-ENG115748-Seat heater level current consumption allocation-Sitzheizung Stufe 6 obere Schaltschwelle	50.00 °C	30
    IDE06089-ENG115747-Seat heater level current consumption allocation-Sitzheizung Stufe 6 untere Schaltschwelle	49.00 °C	30
    IDE06089-ENG154774-Seat heater level current consumption allocation-Sitzheizung.Aufheizphase HI	Keine_Spannungsanforderung 	30
    IDE06089-ENG154775-Seat heater level current consumption allocation-Sitzheizung.Regelbetrieb LO	Keine_Spannungsanforderung 	30
    IDE06089-ENG141977-Seat heater level current consumption allocation-Sitzheizungsfreigabe	not installed 	30
    IDE06089-ENG154785-Seat heater level current consumption allocation-Spannungsoffset SIH_75	15.0 V	30
    IDE06425-Roller test bench mode: functional	not active 	1
    IDE06507-MAS13125-Button in center console-Function of button 1	not coded/not installed 	8
    IDE06507-MAS13129-Button in center console-Function of button 2	not coded/not installed 	8
    IDE06507-MAS13132-Button in center console-Function of button 3	Driving program 	8
    IDE06507-MAS13135-Button in center console-Function of button 4	not coded/not installed 	8
    IDE06507-ENG140243-Button in center console-Zusatzcodierung Fahrprofiltaster hat keine LED	LED installed 	8
    IDE07007-ENG142253-A/C heater function via remote control-Abbruch_d_Warnblinker_moeglich	active 	8
    IDE07007-ENG142252-A/C heater function via remote control-Abbruch_Hupen_RSt	not active 	8
    IDE07007-ENG142255-A/C heater function via remote control-Aktivierung_Drehzahlanzeige	active 	8
    IDE07007-ENG142254-A/C heater function via remote control-Kombi_Fahrerhinweis_m_Akustik	active 	8
    IDE07007-ENG128461-A/C heater function via remote control-Kombi_Fahrerhinweis_m_Uebernahme_RSt	active 	8
    IDE07007-ENG115720-A/C heater function via remote control-Remote Start	not installed 	8
    IDE07007-ENG128460-A/C heater function via remote control-Rueckmeldung_bei_Aktivierung	active 	8
    IDE07356-Position during interval mode	31.494474 °	2
    IDE07470-ENG116719-After-run for park light-Bedingungen zur Beendigung des Standlichtnachlaufs	not active 	6
    IDE07470-ENG116720-After-run for park light-Standlicht-Nachlaufzeit	255 min	6
    IDE07470-ENG126843-After-run for park light-ZV verriegeln bei Klemme 15 Ein	active 	6
    IDE08786-ENG115723-Assistance light functions-Assistenzfahrlicht bei Regen	active 	9
    IDE08786-ENG141956-Assistance light functions-Humidity sensor	not installed 	9
    IDE08786-ENG115724-Assistance light functions-Lichtsensorempfindlichkeit	normal 	9
    IDE08786-ENG126628-Assistance light functions-LS_Error_Ausgabe	not active 	9
    IDE08786-ENG142228-Assistance light functions-Maskierung_Regenfunktion	not active 	9
    IDE08786-ENG141985-Assistance light functions-Regen_Lichtsensor	LIN_REGEN_LICHT_SENSOR 	9
    IDE08786-ENG124476-Assistance light functions-Sunlight Sensor	not installed 	9
    IDE09731-ENG154511-Int. light: 2nd generation-Ambiente_Fahrprofil_Individual	7	19
    IDE09731-ENG154512-Int. light: 2nd generation-Ambiente_Farbliste_HMI_mit_Farbtransformation	not active 	19
    IDE09731-ENG154513-Int. light: 2nd generation-Ambiente_Farbwahl_FPA_waehlbare_Kopplung	not active 	19
    IDE09731-ENG154514-Int. light: 2nd generation-Ambiente_Farbwahl_FPA_waehlbare_Kopplung_Status_hmi_default	active 	19
    IDE09731-ENG125014-Int. light: 2nd generation-Aufloesung Dimmzeit	0.10 s	19
    IDE09731-ENG125024-Int. light: 2nd generation-BAP Farbwert Farbe 1	2	19
    IDE09731-ENG125025-Int. light: 2nd generation-BAP Farbwert Farbe 2	3	19
    IDE09731-ENG125026-Int. light: 2nd generation-BAP Farbwert Farbe 3	1	19
    IDE09731-ENG125018-Int. light: 2nd generation-Cockpitbeleuchtung mehrfarbig	not active 	19
    IDE09731-ENG125021-Int. light: 2nd generation-Dachbeleuchtung mehrfarbig	not active 	19
    IDE09731-ENG125028-Int. light: 2nd generation-Defaultwert Ambienteprofil Dach	80%	19
    IDE09731-ENG125029-Int. light: 2nd generation-Defaultwert Ambienteprofil Farbe	0	19
    IDE09731-ENG115822-Int. light: 2nd generation-Defaultwert Ambienteprofil Fussraum	50%	19
    IDE09731-ENG125027-Int. light: 2nd generation-Defaultwert Ambienteprofil Mittelkonsole	80%	19
    IDE09731-ENG116685-Int. light: 2nd generation-Defaultwert Ambienteprofil Tuer	50%	19
    IDE09731-ENG115823-Int. light: 2nd generation-Defaultwert Ambienteprofil Vorn	50%	19
    IDE09731-ENG125641-Int. light: 2nd generation-Farbausgabe Cockpitbeleuchtung nicht berechnen	active 	19
    IDE09731-ENG125644-Int. light: 2nd generation-Farbausgabe Dachbeleuchtung nicht berechnen	active 	19
    IDE09731-ENG125640-Int. light: 2nd generation-Farbausgabe Instrumententafelbeleuchtung nicht berechnen	active 	19
    IDE09731-ENG125642-Int. light: 2nd generation-Farbausgabe Lautsprecherbeleuchtung nicht berechnen	active 	19
    IDE09731-ENG125643-Int. light: 2nd generation-Farbausgabe Mittelkonsolenbeleuchtung nicht berechnen	active 	19
    IDE09731-ENG125645-Int. light: 2nd generation-Farbausgabe Panoramaschiebedachbeleuchtung nicht berechnen	active 	19
    IDE09731-ENG125639-Int. light: 2nd generation-Farbausgabe Tuertafelbeleuchtung nicht berechnen	active 	19
    IDE09731-ENG125634-Int. light: 2nd generation-Helligkeit Cockpitbeleuchtung nicht berechnen	active 	19
    IDE09731-ENG125637-Int. light: 2nd generation-Helligkeit Dachbeleuchtung nicht berechnen	active 	19
    IDE09731-ENG125633-Int. light: 2nd generation-Helligkeit Instrumententafelbeleuchtung nicht berechnen	active 	19
    IDE09731-ENG125635-Int. light: 2nd generation-Helligkeit Lautsprecherbeleuchtung nicht berechnen	active 	19
    IDE09731-ENG125636-Int. light: 2nd generation-Helligkeit Mittelkonsolenbeleuchtung nicht berechnen	active 	19
    IDE09731-ENG125638-Int. light: 2nd generation-Helligkeit Panoramaschiebedachbeleuchtung nicht berechnen	active 	19
    IDE09731-ENG142233-Int. light: 2nd generation-Helligkeit_Tuertafelbeleuchtung_nicht_berechnen	not active 	19
    IDE09731-ENG116596-Int. light: 2nd generation-Innenlicht bei offenem Heckdeckel einschalten	active 	19
    IDE09731-ENG125017-Int. light: 2nd generation-Instrumententafelbeleuchtung mehrfarbig	not active 	19
    IDE09731-ENG98648-Int. light: 2nd generation-Interior light	Keine_Spannungsanforderung 	19
    IDE09731-ENG116597-Int. light: 2nd generation-KL30G ohne PWM	not active 	19
    IDE09731-ENG125019-Int. light: 2nd generation-Lautsprecherbeleuchtung mehrfarbig	not active 	19
    IDE09731-ENG142031-Int. light: 2nd generation-LIN-Dachkonsole mit Flaechenlicht	not installed 	19
    IDE09731-ENG125020-Int. light: 2nd generation-Mittelkonsolenbeleuchtung mehrfarbig	not active 	19
    IDE09731-ENG125023-Int. light: 2nd generation-Panoramaschiebedachbeleuchtung bei geoeffnetem Rollo deaktivieren	not active 	19
    IDE09731-ENG125022-Int. light: 2nd generation-Panoramaschiebedachbeleuchtung mehrfarbig	not active 	19
    IDE09731-ENG116687-Int. light: 2nd generation-Tuerinnengriff mit Tuertafel	not installed 	19
    IDE09731-ENG116686-Int. light: 2nd generation-Tuerinnengriffbeleuchtung mit I-Tafel	not installed 	19
    IDE09731-ENG125016-Int. light: 2nd generation-Tuertafelbeleuchtung mehrfarbig	not active 	19
    IDE09731-ENG142184-Int. light: 2nd generation-Weckfaehigkeit_klemme_30G	installed 	19
    IDE09731-ENG125015-Int. light: 2nd generation-weicher Farbwechsel	not active 	19
    IDE09732-ENG154509-Interior light: light configuration-Ambience_light_colorlist_default	0	5
    IDE09732-ENG133384-Interior light: light configuration-Ambient_Farbliste_HMI	not active 	5
    IDE09732-ENG115870-Interior light: light configuration-Ambiente_Applikationsleisten_in_Instrumententafel	not installed 	5
    IDE09732-ENG115871-Interior light: light configuration-Ambiente_Applikationsleisten_in_Tuertafel	installed 	5
    IDE09732-ENG115872-Interior light: light configuration-Ambiente_Lautsprecher	not installed 	5
    IDE09732-ENG126836-Interior light: light configuration-Ambientemenue mit alle Zonen	not active 	5
    IDE09732-ENG126835-Interior light: light configuration-Ambientemenue mit globalem aus	not active 	5
    IDE09732-ENG125646-Interior light: light configuration-Cockpitbeleuchtung	not installed 	5
    IDE09732-ENG125648-Interior light: light configuration-Dachbeleuchtung	not installed 	5
    IDE09732-ENG125651-Interior light: light configuration-Farbwahl ueber Fahrprofil	not installed 	5
    IDE09732-ENG125650-Interior light: light configuration-Farbwahl ueber HMI	not installed 	5
    IDE09732-ENG114629-Interior light: light configuration-Foot well lighting	installed 	5
    IDE09732-ENG133385-Interior light: light configuration-Frei_Farbwahl_ueber_HMI	not active 	5
    IDE09732-ENG126834-Interior light: light configuration-LIN-Dachkonsole lokal aktivierbar	not active 	5
    IDE09732-ENG125647-Interior light: light configuration-Mittelkonsolenbeleuchtung	not installed 	5
    IDE09732-ENG125649-Interior light: light configuration-Panoramaschiebedachbeleuchtung	not installed 	5
    IDE09761-ENG126617-Seat fan charac. curve-Level_1_Lehne	30%	17
    IDE09761-ENG126616-Seat fan charac. curve-Level_1_Sitz	25%	17
    IDE09761-ENG126619-Seat fan charac. curve-Level_2_Lehne	30%	17
    IDE09761-ENG126618-Seat fan charac. curve-Level_2_Sitz	25%	17
    IDE09761-ENG126621-Seat fan charac. curve-Level_3_Lehne	58%	17
    IDE09761-ENG126620-Seat fan charac. curve-Level_3_Sitz	53%	17
    IDE09761-ENG126623-Seat fan charac. curve-Level_4_Lehne	58%	17
    IDE09761-ENG126622-Seat fan charac. curve-Level_4_Sitz	53%	17
    IDE09761-ENG126625-Seat fan charac. curve-Level_5_Lehne	85%	17
    IDE09761-ENG126624-Seat fan charac. curve-Level_5_Sitz	80%	17
    IDE09761-ENG126627-Seat fan charac. curve-Level_6_Lehne	85%	17
    IDE09761-ENG126626-Seat fan charac. curve-Level_6_Sitz	80%	17
    IDE09761-ENG142024-Seat fan charac. curve-Sitzlueftung	not installed 	17
    IDE09761-ENG142183-Seat fan charac. curve-Sitzlueftung_reduzierbar	installed 	17
    IDE09761-ENG142025-Seat fan charac. curve-Sitzpneumatik	not installed 	17
    IDE10298-Alternating park position 1	7.494498 °	2
    IDE10299-Alternating park position 2	29.494476 °	2
    IDE11477-ENG128587-Interior lighting: parameter-p_adaption_kundenwunsch_cockpit	1	256
    IDE11477-ENG128619-Interior lighting: parameter-p_adaption_kundenwunsch_dach	1	256
    IDE11477-ENG128539-Interior lighting: parameter-p_adaption_kundenwunsch_fussraum	0.2	256
    IDE11477-ENG128571-Interior lighting: parameter-p_adaption_kundenwunsch_itafel	1	256
    IDE11477-ENG128555-Interior lighting: parameter-p_adaption_kundenwunsch_lautsprecher	1	256
    IDE11477-ENG128603-Interior lighting: parameter-p_adaption_kundenwunsch_miko	1	256
    IDE11477-ENG128635-Interior lighting: parameter-p_adaption_kundenwunsch_psd	1	256
    IDE11477-ENG128523-Interior lighting: parameter-p_adaption_kundenwunsch_tuer	0.6	256
    IDE11477-ENG128659-Interior lighting: parameter-p_ambientelicht_verbauinformation_HMI	0	256
    IDE11477-ENG128660-Interior lighting: parameter-p_ambientelicht_verbauinformation_HMI_2	0	256
    IDE11477-ENG128661-Interior lighting: parameter-p_ambientelicht_verbauinformation_HMI_3	0	256
    IDE11477-ENG128662-Interior lighting: parameter-p_ambientelicht_verbauinformation_HMI_4	0	256
    IDE11477-ENG128655-Interior lighting: parameter-p_ambienteumfang_mehrfarbig_HMI	0	256
    IDE11477-ENG128656-Interior lighting: parameter-p_ambienteumfang_mehrfarbig_HMI_2	0	256
    IDE11477-ENG128657-Interior lighting: parameter-p_ambienteumfang_mehrfarbig_HMI_3	0	256
    IDE11477-ENG128658-Interior lighting: parameter-p_ambienteumfang_mehrfarbig_HMI_4	0	256
    IDE11477-ENG128652-Interior lighting: parameter-p_dimmfaktor_farbwechsel_ab	1	256
    IDE11477-ENG128651-Interior lighting: parameter-p_dimmfaktor_farbwechsel_auf	1	256
    IDE11477-ENG128654-Interior lighting: parameter-p_farbauswahl_HMI	0	256
    IDE11477-ENG128653-Interior lighting: parameter-p_farbwechsel_delay	0	256
    IDE11477-ENG128596-Interior lighting: parameter-p_helligkeit_andereTuer_auf_zuendung_aus_cockpit	100%	256
    IDE11477-ENG128628-Interior lighting: parameter-p_helligkeit_andereTuer_auf_zuendung_aus_dach	100%	256
    IDE11477-ENG128548-Interior lighting: parameter-p_helligkeit_andereTuer_auf_zuendung_aus_fussraum	70%	256
    IDE11477-ENG128516-Interior lighting: parameter-p_helligkeit_andereTuer_auf_zuendung_aus_innenlicht	100%	256
    IDE11477-ENG128580-Interior lighting: parameter-p_helligkeit_andereTuer_auf_zuendung_aus_itafel	100%	256
    IDE11477-ENG128564-Interior lighting: parameter-p_helligkeit_andereTuer_auf_zuendung_aus_lautsprecher	100%	256
    IDE11477-ENG128612-Interior lighting: parameter-p_helligkeit_andereTuer_auf_zuendung_aus_miko	100%	256
    IDE11477-ENG128644-Interior lighting: parameter-p_helligkeit_andereTuer_auf_zuendung_aus_psd	100%	256
    IDE11477-ENG128532-Interior lighting: parameter-p_helligkeit_andereTuer_auf_zuendung_aus_tueren	96%	256
    IDE11477-ENG128593-Interior lighting: parameter-p_helligkeit_andereTuer_auf_zuendung_ein_cockpit	100%	256
    IDE11477-ENG128625-Interior lighting: parameter-p_helligkeit_andereTuer_auf_zuendung_ein_dach	100%	256
    IDE11477-ENG128545-Interior lighting: parameter-p_helligkeit_andereTuer_auf_zuendung_ein_fussraum	70%	256
    IDE11477-ENG128513-Interior lighting: parameter-p_helligkeit_andereTuer_auf_zuendung_ein_innenlicht	100%	256
    IDE11477-ENG128577-Interior lighting: parameter-p_helligkeit_andereTuer_auf_zuendung_ein_itafel	100%	256
    IDE11477-ENG128561-Interior lighting: parameter-p_helligkeit_andereTuer_auf_zuendung_ein_lautsprecher	100%	256
    IDE11477-ENG128609-Interior lighting: parameter-p_helligkeit_andereTuer_auf_zuendung_ein_miko	100%	256
    IDE11477-ENG128641-Interior lighting: parameter-p_helligkeit_andereTuer_auf_zuendung_ein_psd	100%	256
    IDE11477-ENG128529-Interior lighting: parameter-p_helligkeit_andereTuer_auf_zuendung_ein_tueren	96%	256
    IDE11477-ENG128595-Interior lighting: parameter-p_helligkeit_dieseTuer_auf_zuendung_aus_cockpit	100%	256
    IDE11477-ENG128627-Interior lighting: parameter-p_helligkeit_dieseTuer_auf_zuendung_aus_dach	100%	256
    IDE11477-ENG128547-Interior lighting: parameter-p_helligkeit_dieseTuer_auf_zuendung_aus_fussraum	70%	256
    IDE11477-ENG128515-Interior lighting: parameter-p_helligkeit_dieseTuer_auf_zuendung_aus_innenlicht	100%	256
    IDE11477-ENG128579-Interior lighting: parameter-p_helligkeit_dieseTuer_auf_zuendung_aus_itafel	100%	256
    IDE11477-ENG128563-Interior lighting: parameter-p_helligkeit_dieseTuer_auf_zuendung_aus_lautsprecher	100%	256
    IDE11477-ENG128611-Interior lighting: parameter-p_helligkeit_dieseTuer_auf_zuendung_aus_miko	100%	256
    IDE11477-ENG128643-Interior lighting: parameter-p_helligkeit_dieseTuer_auf_zuendung_aus_psd	100%	256
    IDE11477-ENG128531-Interior lighting: parameter-p_helligkeit_dieseTuer_auf_zuendung_aus_tueren	96%	256
    IDE11477-ENG128592-Interior lighting: parameter-p_helligkeit_dieseTuer_auf_zuendung_ein_cockpit	100%	256
    IDE11477-ENG128624-Interior lighting: parameter-p_helligkeit_dieseTuer_auf_zuendung_ein_dach	100%	256
    IDE11477-ENG128544-Interior lighting: parameter-p_helligkeit_dieseTuer_auf_zuendung_ein_fussraum	70%	256
    IDE11477-ENG128512-Interior lighting: parameter-p_helligkeit_dieseTuer_auf_zuendung_ein_innenlicht	100%	256
    IDE11477-ENG128576-Interior lighting: parameter-p_helligkeit_dieseTuer_auf_zuendung_ein_itafel	100%	256
    IDE11477-ENG128560-Interior lighting: parameter-p_helligkeit_dieseTuer_auf_zuendung_ein_lautsprecher	100%	256
    IDE11477-ENG128608-Interior lighting: parameter-p_helligkeit_dieseTuer_auf_zuendung_ein_miko	100%	256
    IDE11477-ENG128640-Interior lighting: parameter-p_helligkeit_dieseTuer_auf_zuendung_ein_psd	100%	256
    IDE11477-ENG128528-Interior lighting: parameter-p_helligkeit_dieseTuer_auf_zuendung_ein_tueren	96%	256
    IDE11477-ENG128597-Interior lighting: parameter-p_helligkeit_einausstieg_cockpit	100%	256
    IDE11477-ENG128629-Interior lighting: parameter-p_helligkeit_einausstieg_dach	100%	256
    IDE11477-ENG128549-Interior lighting: parameter-p_helligkeit_einausstieg_fussraum	70%	256
    IDE11477-ENG128517-Interior lighting: parameter-p_helligkeit_einausstieg_innenlicht	100%	256
    IDE11477-ENG128581-Interior lighting: parameter-p_helligkeit_einausstieg_itafel	100%	256
    IDE11477-ENG128565-Interior lighting: parameter-p_helligkeit_einausstieg_lautsprecher	100%	256
    IDE11477-ENG128613-Interior lighting: parameter-p_helligkeit_einausstieg_miko	100%	256
    IDE11477-ENG128645-Interior lighting: parameter-p_helligkeit_einausstieg_psd	100%	256
    IDE11477-ENG128533-Interior lighting: parameter-p_helligkeit_einausstieg_tueren	96%	256
    IDE11477-ENG128588-Interior lighting: parameter-p_helligkeit_entriegelt_cockpit	100%	256
    IDE11477-ENG128620-Interior lighting: parameter-p_helligkeit_entriegelt_dach	100%	256
    IDE11477-ENG128540-Interior lighting: parameter-p_helligkeit_entriegelt_fussraum	0%	256
    IDE11477-ENG128508-Interior lighting: parameter-p_helligkeit_entriegelt_innenlicht	100%	256
    IDE11477-ENG128572-Interior lighting: parameter-p_helligkeit_entriegelt_itafel	100%	256
    IDE11477-ENG128556-Interior lighting: parameter-p_helligkeit_entriegelt_lautsprecher	100%	256
    IDE11477-ENG128604-Interior lighting: parameter-p_helligkeit_entriegelt_miko	100%	256
    IDE11477-ENG128636-Interior lighting: parameter-p_helligkeit_entriegelt_psd	100%	256
    IDE11477-ENG128524-Interior lighting: parameter-p_helligkeit_entriegelt_tueren	0%	256
    IDE11477-ENG128602-Interior lighting: parameter-p_helligkeit_Fzg_geschlossen_schluessel_ab_cockpit	100%	256
    IDE11477-ENG128634-Interior lighting: parameter-p_helligkeit_Fzg_geschlossen_schluessel_ab_dach	100%	256
    IDE11477-ENG128554-Interior lighting: parameter-p_helligkeit_Fzg_geschlossen_schluessel_ab_fussraum	70%	256
    IDE11477-ENG128522-Interior lighting: parameter-p_helligkeit_Fzg_geschlossen_schluessel_ab_innenlicht	100%	256
    IDE11477-ENG128586-Interior lighting: parameter-p_helligkeit_Fzg_geschlossen_schluessel_ab_itafel	100%	256
    IDE11477-ENG128570-Interior lighting: parameter-p_helligkeit_Fzg_geschlossen_schluessel_ab_lautsprecher	100%	256
    IDE11477-ENG128618-Interior lighting: parameter-p_helligkeit_Fzg_geschlossen_schluessel_ab_miko	100%	256
    IDE11477-ENG128650-Interior lighting: parameter-p_helligkeit_Fzg_geschlossen_schluessel_ab_psd	100%	256
    IDE11477-ENG128538-Interior lighting: parameter-p_helligkeit_Fzg_geschlossen_schluessel_ab_tueren	96%	256
    IDE11477-ENG128598-Interior lighting: parameter-p_helligkeit_Fzg_geschlossen_zuendung_aus_cockpit	100%	256
    IDE11477-ENG128630-Interior lighting: parameter-p_helligkeit_Fzg_geschlossen_zuendung_aus_dach	100%	256
    IDE11477-ENG128550-Interior lighting: parameter-p_helligkeit_Fzg_geschlossen_zuendung_aus_fussraum	127%	256
    IDE11477-ENG128518-Interior lighting: parameter-p_helligkeit_Fzg_geschlossen_zuendung_aus_innenlicht	100%	256
    IDE11477-ENG128582-Interior lighting: parameter-p_helligkeit_Fzg_geschlossen_zuendung_aus_itafel	100%	256
    IDE11477-ENG128566-Interior lighting: parameter-p_helligkeit_Fzg_geschlossen_zuendung_aus_lautsprecher	100%	256
    IDE11477-ENG128614-Interior lighting: parameter-p_helligkeit_Fzg_geschlossen_zuendung_aus_miko	100%	256
    IDE11477-ENG128646-Interior lighting: parameter-p_helligkeit_Fzg_geschlossen_zuendung_aus_psd	100%	256
    IDE11477-ENG128534-Interior lighting: parameter-p_helligkeit_Fzg_geschlossen_zuendung_aus_tueren	127%	256
    IDE11477-ENG128594-Interior lighting: parameter-p_helligkeit_Fzg_geschlossen_zuendung_ein_cockpit	126%	256
    IDE11477-ENG128626-Interior lighting: parameter-p_helligkeit_Fzg_geschlossen_zuendung_ein_dach	126%	256
    IDE11477-ENG128546-Interior lighting: parameter-p_helligkeit_Fzg_geschlossen_zuendung_ein_fussraum	126%	256
    IDE11477-ENG128514-Interior lighting: parameter-p_helligkeit_Fzg_geschlossen_zuendung_ein_innenlicht	0%	256
    IDE11477-ENG128578-Interior lighting: parameter-p_helligkeit_Fzg_geschlossen_zuendung_ein_itafel	126%	256
    IDE11477-ENG128562-Interior lighting: parameter-p_helligkeit_Fzg_geschlossen_zuendung_ein_lautsprecher	126%	256
    IDE11477-ENG128610-Interior lighting: parameter-p_helligkeit_Fzg_geschlossen_zuendung_ein_miko	126%	256
    IDE11477-ENG128642-Interior lighting: parameter-p_helligkeit_Fzg_geschlossen_zuendung_ein_psd	126%	256
    IDE11477-ENG128530-Interior lighting: parameter-p_helligkeit_Fzg_geschlossen_zuendung_ein_tueren	126%	256
    IDE11477-ENG128591-Interior lighting: parameter-p_helligkeit_HD_auf_zuendung_aus_cockpit	100%	256
    IDE11477-ENG128623-Interior lighting: parameter-p_helligkeit_HD_auf_zuendung_aus_dach	100%	256
    IDE11477-ENG128543-Interior lighting: parameter-p_helligkeit_HD_auf_zuendung_aus_fussraum	127%	256
    IDE11477-ENG128511-Interior lighting: parameter-p_helligkeit_HD_auf_zuendung_aus_innenlicht	100%	256
    IDE11477-ENG128575-Interior lighting: parameter-p_helligkeit_HD_auf_zuendung_aus_itafel	100%	256
    IDE11477-ENG128559-Interior lighting: parameter-p_helligkeit_HD_auf_zuendung_aus_lautsprecher	100%	256
    IDE11477-ENG128607-Interior lighting: parameter-p_helligkeit_HD_auf_zuendung_aus_miko	100%	256
    IDE11477-ENG128639-Interior lighting: parameter-p_helligkeit_HD_auf_zuendung_aus_psd	100%	256
    IDE11477-ENG128527-Interior lighting: parameter-p_helligkeit_HD_auf_zuendung_aus_tueren	127%	256
    IDE11477-ENG128590-Interior lighting: parameter-p_helligkeit_HD_auf_zuendung_ein_cockpit	100%	256
    IDE11477-ENG128622-Interior lighting: parameter-p_helligkeit_HD_auf_zuendung_ein_dach	100%	256
    IDE11477-ENG128542-Interior lighting: parameter-p_helligkeit_HD_auf_zuendung_ein_fussraum	126%	256
    IDE11477-ENG128510-Interior lighting: parameter-p_helligkeit_HD_auf_zuendung_ein_innenlicht	100%	256
    IDE11477-ENG128574-Interior lighting: parameter-p_helligkeit_HD_auf_zuendung_ein_itafel	100%	256
    IDE11477-ENG128558-Interior lighting: parameter-p_helligkeit_HD_auf_zuendung_ein_lautsprecher	100%	256
    IDE11477-ENG128606-Interior lighting: parameter-p_helligkeit_HD_auf_zuendung_ein_miko	100%	256
    IDE11477-ENG128638-Interior lighting: parameter-p_helligkeit_HD_auf_zuendung_ein_psd	100%	256
    IDE11477-ENG128526-Interior lighting: parameter-p_helligkeit_HD_auf_zuendung_ein_tueren	126%	256
    IDE11477-ENG128589-Interior lighting: parameter-p_helligkeit_max_cockpit	100%	256
    IDE11477-ENG128621-Interior lighting: parameter-p_helligkeit_max_dach	100%	256
    IDE11477-ENG128541-Interior lighting: parameter-p_helligkeit_max_fussraum	70%	256
    IDE11477-ENG128509-Interior lighting: parameter-p_helligkeit_max_innenlicht	100%	256
    IDE11477-ENG128573-Interior lighting: parameter-p_helligkeit_max_itafel	100%	256
    IDE11477-ENG128557-Interior lighting: parameter-p_helligkeit_max_lautsprecher	100%	256
    IDE11477-ENG128605-Interior lighting: parameter-p_helligkeit_max_miko	100%	256
    IDE11477-ENG128637-Interior lighting: parameter-p_helligkeit_max_psd	100%	256
    IDE11477-ENG128525-Interior lighting: parameter-p_helligkeit_max_tueren	96%	256
    IDE11477-ENG128599-Interior lighting: parameter-p_helligkeit_Tueren_geschlossen_HD_auf_zuendung_aus_cockpit	100%	256
    IDE11477-ENG128631-Interior lighting: parameter-p_helligkeit_Tueren_geschlossen_HD_auf_zuendung_aus_dach	100%	256
    IDE11477-ENG128551-Interior lighting: parameter-p_helligkeit_Tueren_geschlossen_HD_auf_zuendung_aus_fussraum	70%	256
    IDE11477-ENG128519-Interior lighting: parameter-p_helligkeit_Tueren_geschlossen_HD_auf_zuendung_aus_innenlicht	100%	256
    IDE11477-ENG128583-Interior lighting: parameter-p_helligkeit_Tueren_geschlossen_HD_auf_zuendung_aus_itafel	100%	256
    IDE11477-ENG128567-Interior lighting: parameter-p_helligkeit_Tueren_geschlossen_HD_auf_zuendung_aus_lautsprecher	100%	256
    IDE11477-ENG128615-Interior lighting: parameter-p_helligkeit_Tueren_geschlossen_HD_auf_zuendung_aus_miko	100%	256
    IDE11477-ENG128647-Interior lighting: parameter-p_helligkeit_Tueren_geschlossen_HD_auf_zuendung_aus_psd	100%	256
    IDE11477-ENG128535-Interior lighting: parameter-p_helligkeit_Tueren_geschlossen_HD_auf_zuendung_aus_tueren	96%	256
    IDE11477-ENG128600-Interior lighting: parameter-p_helligkeit_Tueren_geschlossen_HD_zu_zuendung_aus_cockpit	100%	256
    IDE11477-ENG128632-Interior lighting: parameter-p_helligkeit_Tueren_geschlossen_HD_zu_zuendung_aus_dach	100%	256
    IDE11477-ENG128552-Interior lighting: parameter-p_helligkeit_Tueren_geschlossen_HD_zu_zuendung_aus_fussraum	70%	256
    IDE11477-ENG128520-Interior lighting: parameter-p_helligkeit_Tueren_geschlossen_HD_zu_zuendung_aus_innenlicht	100%	256
    IDE11477-ENG128584-Interior lighting: parameter-p_helligkeit_Tueren_geschlossen_HD_zu_zuendung_aus_itafel	100%	256
    IDE11477-ENG128568-Interior lighting: parameter-p_helligkeit_Tueren_geschlossen_HD_zu_zuendung_aus_lautsprecher	100%	256
    IDE11477-ENG128616-Interior lighting: parameter-p_helligkeit_Tueren_geschlossen_HD_zu_zuendung_aus_miko	100%	256
    IDE11477-ENG128648-Interior lighting: parameter-p_helligkeit_Tueren_geschlossen_HD_zu_zuendung_aus_psd	100%	256
    IDE11477-ENG128536-Interior lighting: parameter-p_helligkeit_Tueren_geschlossen_HD_zu_zuendung_aus_tueren	96%	256
    IDE11477-ENG128601-Interior lighting: parameter-p_helligkeit_Tueren_geschlossen_schluessel_ab_cockpit	100%	256
    IDE11477-ENG128633-Interior lighting: parameter-p_helligkeit_Tueren_geschlossen_schluessel_ab_dach	100%	256
    IDE11477-ENG128553-Interior lighting: parameter-p_helligkeit_Tueren_geschlossen_schluessel_ab_fussraum	70%	256
    IDE11477-ENG128521-Interior lighting: parameter-p_helligkeit_Tueren_geschlossen_schluessel_ab_innenlicht	100%	256
    IDE11477-ENG128585-Interior lighting: parameter-p_helligkeit_Tueren_geschlossen_schluessel_ab_itafel	100%	256
    IDE11477-ENG128569-Interior lighting: parameter-p_helligkeit_Tueren_geschlossen_schluessel_ab_lautsprecher	100%	256
    IDE11477-ENG128617-Interior lighting: parameter-p_helligkeit_Tueren_geschlossen_schluessel_ab_miko	100%	256
    IDE11477-ENG128649-Interior lighting: parameter-p_helligkeit_Tueren_geschlossen_schluessel_ab_psd	100%	256
    IDE11477-ENG128537-Interior lighting: parameter-p_helligkeit_Tueren_geschlossen_schluessel_ab_tueren	96%	256
    IDE11477-ENG137165-Interior lighting: parameter-p_t_HMI_verzoegerung_helligkeitswerte	200 ms	256
    IDE11477-ENG128488-Interior lighting: parameter-p_t_verzoegerung_ausstieg_cockpit	0.0 s	256
    IDE11477-ENG128502-Interior lighting: parameter-p_t_verzoegerung_ausstieg_dach	0.0 s	256
    IDE11477-ENG128481-Interior lighting: parameter-p_t_verzoegerung_ausstieg_fussraum	0.0 s	256
    IDE11477-ENG128467-Interior lighting: parameter-p_t_verzoegerung_ausstieg_innenlicht	0.0 s	256
    IDE11477-ENG128495-Interior lighting: parameter-p_t_verzoegerung_ausstieg_miko	0.0 s	256
    IDE11477-ENG128474-Interior lighting: parameter-p_t_verzoegerung_ausstieg_tueren	0.0 s	256
    IDE11477-ENG128487-Interior lighting: parameter-p_t_verzoegerung_einstieg_cockpit	0.0 s	256
    IDE11477-ENG128501-Interior lighting: parameter-p_t_verzoegerung_einstieg_dach	0.0 s	256
    IDE11477-ENG128480-Interior lighting: parameter-p_t_verzoegerung_einstieg_fussraum	2.0 s	256
    IDE11477-ENG128466-Interior lighting: parameter-p_t_verzoegerung_einstieg_innenlicht	0.0 s	256
    IDE11477-ENG128494-Interior lighting: parameter-p_t_verzoegerung_einstieg_miko	0.0 s	256
    IDE11477-ENG128473-Interior lighting: parameter-p_t_verzoegerung_einstieg_tueren	0.5 s	256
    IDE11477-ENG128490-Interior lighting: parameter-p_t_verzoegerung_entriegelt_cockpit	0.0 s	256
    IDE11477-ENG128504-Interior lighting: parameter-p_t_verzoegerung_entriegelt_dach	0.0 s	256
    IDE11477-ENG128483-Interior lighting: parameter-p_t_verzoegerung_entriegelt_fussraum	0.0 s	256
    IDE11477-ENG128469-Interior lighting: parameter-p_t_verzoegerung_entriegelt_innenlicht	0.0 s	256
    IDE11477-ENG128497-Interior lighting: parameter-p_t_verzoegerung_entriegelt_miko	0.0 s	256
    IDE11477-ENG128476-Interior lighting: parameter-p_t_verzoegerung_entriegelt_tueren	0.0 s	256
    IDE11477-ENG128489-Interior lighting: parameter-p_t_verzoegerung_oeffnen_cockpit	0.0 s	256
    IDE11477-ENG128503-Interior lighting: parameter-p_t_verzoegerung_oeffnen_dach	0.0 s	256
    IDE11477-ENG128482-Interior lighting: parameter-p_t_verzoegerung_oeffnen_fussraum	0.0 s	256
    IDE11477-ENG128468-Interior lighting: parameter-p_t_verzoegerung_oeffnen_innenlicht	0.0 s	256
    IDE11477-ENG128496-Interior lighting: parameter-p_t_verzoegerung_oeffnen_miko	0.0 s	256
    IDE11477-ENG128475-Interior lighting: parameter-p_t_verzoegerung_oeffnen_tueren	0.0 s	256
    IDE11477-ENG128491-Interior lighting: parameter-p_t_verzoegerung_schliessen_cockpit	0.0 s	256
    IDE11477-ENG128505-Interior lighting: parameter-p_t_verzoegerung_schliessen_dach	0.0 s	256
    IDE11477-ENG128484-Interior lighting: parameter-p_t_verzoegerung_schliessen_fussraum	0.0 s	256
    IDE11477-ENG128470-Interior lighting: parameter-p_t_verzoegerung_schliessen_innenlicht	0.0 s	256
    IDE11477-ENG128498-Interior lighting: parameter-p_t_verzoegerung_schliessen_miko	0.0 s	256
    IDE11477-ENG128477-Interior lighting: parameter-p_t_verzoegerung_schliessen_tueren	0.0 s	256
    IDE11477-ENG128492-Interior lighting: parameter-p_t_verzoegerung_schluessel_ab_cockpit	0.0 s	256
    IDE11477-ENG128506-Interior lighting: parameter-p_t_verzoegerung_schluessel_ab_dach	0.0 s	256
    IDE11477-ENG128485-Interior lighting: parameter-p_t_verzoegerung_schluessel_ab_fussraum	0.0 s	256
    IDE11477-ENG128471-Interior lighting: parameter-p_t_verzoegerung_schluessel_ab_innenlicht	0.0 s	256
    IDE11477-ENG128499-Interior lighting: parameter-p_t_verzoegerung_schluessel_ab_miko	0.0 s	256
    IDE11477-ENG128478-Interior lighting: parameter-p_t_verzoegerung_schluessel_ab_tueren	0.0 s	256
    IDE11477-ENG128493-Interior lighting: parameter-p_t_verzoegerung_verriegelt_cockpit	0.0 s	256
    IDE11477-ENG128507-Interior lighting: parameter-p_t_verzoegerung_verriegelt_dach	0.0 s	256
    IDE11477-ENG128486-Interior lighting: parameter-p_t_verzoegerung_verriegelt_fussraum	0.0 s	256
    IDE11477-ENG128472-Interior lighting: parameter-p_t_verzoegerung_verriegelt_innenlicht	0.0 s	256
    IDE11477-ENG128500-Interior lighting: parameter-p_t_verzoegerung_verriegelt_miko	0.0 s	256
    IDE11477-ENG128479-Interior lighting: parameter-p_t_verzoegerung_verriegelt_tueren	0.0 s	256
    IDE11477-ENG128663-Interior lighting: parameter-p_verzoegerung_berechnen	0	256
    IDE11714-ENG126827-Ambient light color list-Blauwert Farbe 1	0	30
    IDE11714-ENG133432-Ambient light color list-Blauwert Farbe 10	0	30
    IDE11714-ENG126830-Ambient light color list-Blauwert Farbe 2	0	30
    IDE11714-ENG126833-Ambient light color list-Blauwert Farbe 3	0	30
    IDE11714-ENG133414-Ambient light color list-Blauwert Farbe 4	0	30
    IDE11714-ENG133417-Ambient light color list-Blauwert Farbe 5	0	30
    IDE11714-ENG133420-Ambient light color list-Blauwert Farbe 6	0	30
    IDE11714-ENG133423-Ambient light color list-Blauwert Farbe 7	0	30
    IDE11714-ENG133426-Ambient light color list-Blauwert Farbe 8	0	30
    IDE11714-ENG133429-Ambient light color list-Blauwert Farbe 9	0	30
    IDE11714-ENG126826-Ambient light color list-Gruenwert Farbe 1	0	30
    IDE11714-ENG133431-Ambient light color list-Gruenwert Farbe 10	0	30
    IDE11714-ENG126829-Ambient light color list-Gruenwert Farbe 2	0	30
    IDE11714-ENG126832-Ambient light color list-Gruenwert Farbe 3	0	30
    IDE11714-ENG133413-Ambient light color list-Gruenwert Farbe 4	0	30
    IDE11714-ENG133416-Ambient light color list-Gruenwert Farbe 5	0	30
    IDE11714-ENG133419-Ambient light color list-Gruenwert Farbe 6	0	30
    IDE11714-ENG133422-Ambient light color list-Gruenwert Farbe 7	0	30
    IDE11714-ENG133425-Ambient light color list-Gruenwert Farbe 8	0	30
    IDE11714-ENG133428-Ambient light color list-Gruenwert Farbe 9	0	30
    IDE11714-ENG126825-Ambient light color list-Rotwert Farbe 1	0	30
    IDE11714-ENG133430-Ambient light color list-Rotwert Farbe 10	0	30
    IDE11714-ENG126828-Ambient light color list-Rotwert Farbe 2	0	30
    IDE11714-ENG126831-Ambient light color list-Rotwert Farbe 3	0	30
    IDE11714-ENG133412-Ambient light color list-Rotwert Farbe 4	0	30
    IDE11714-ENG133415-Ambient light color list-Rotwert Farbe 5	0	30
    IDE11714-ENG133418-Ambient light color list-Rotwert Farbe 6	0	30
    IDE11714-ENG133421-Ambient light color list-Rotwert Farbe 7	0	30
    IDE11714-ENG133424-Ambient light color list-Rotwert Farbe 8	0	30
    IDE11714-ENG133427-Ambient light color list-Rotwert Farbe 9	0	30
    IDE11944-ENG142014-Keyless access and start authorization-Elektische_Lenkradverriegelung	not installed 	3
    IDE11944-ENG141948-Keyless access and start authorization-Kessy	not installed 	3
    IDE11944-ENG116653-Keyless access and start authorization-Kessy Komfort oeffnen	not active 	3
    IDE11944-ENG116654-Keyless access and start authorization-Kessy Komfort schliessen	active 	3
    IDE11944-ENG116655-Keyless access and start authorization-Kessy Komfortbedienung Reichweitenbegrenzung	not active 	3
    IDE11944-ENG116626-Keyless access and start authorization-Oeffnung Heckdeckel bei Wiederentriegelung	not active 	3
    IDE12412-ENG154526-LIN Ambient light color list-Blauwert_Farbe_1_lin	0	30
    IDE12412-ENG154527-LIN Ambient light color list-Blauwert_Farbe_10_lin	0	30
    IDE12412-ENG154537-LIN Ambient light color list-Blauwert_Farbe_2_lin	0	30
    IDE12412-ENG154557-LIN Ambient light color list-Blauwert_Farbe_3_lin	0	30
    IDE12412-ENG154560-LIN Ambient light color list-Blauwert_Farbe_4_lin	0	30
    IDE12412-ENG154561-LIN Ambient light color list-Blauwert_Farbe_5_lin	0	30
    IDE12412-ENG154562-LIN Ambient light color list-Blauwert_Farbe_6_lin	0	30
    IDE12412-ENG154563-LIN Ambient light color list-Blauwert_Farbe_7_lin	0	30
    IDE12412-ENG154564-LIN Ambient light color list-Blauwert_Farbe_8_lin	0	30
    IDE12412-ENG154565-LIN Ambient light color list-Blauwert_Farbe_9_lin	0	30
    IDE12412-ENG154645-LIN Ambient light color list-Gruenwert_Farbe_1_lin	0	30
    IDE12412-ENG154646-LIN Ambient light color list-Gruenwert_Farbe_10_lin	0	30
    IDE12412-ENG154656-LIN Ambient light color list-Gruenwert_Farbe_2_lin	0	30
    IDE12412-ENG154676-LIN Ambient light color list-Gruenwert_Farbe_3_lin	0	30
    IDE12412-ENG154679-LIN Ambient light color list-Gruenwert_Farbe_4_lin	0	30
    IDE12412-ENG154680-LIN Ambient light color list-Gruenwert_Farbe_5_lin	0	30
    IDE12412-ENG154681-LIN Ambient light color list-Gruenwert_Farbe_6_lin	0	30
    IDE12412-ENG154682-LIN Ambient light color list-Gruenwert_Farbe_7_lin	0	30
    IDE12412-ENG154683-LIN Ambient light color list-Gruenwert_Farbe_8_lin	0	30
    IDE12412-ENG154684-LIN Ambient light color list-Gruenwert_Farbe_9_lin	0	30
    IDE12412-ENG154733-LIN Ambient light color list-Rotwert_Farbe_1_lin	0	30
    IDE12412-ENG154734-LIN Ambient light color list-Rotwert_Farbe_10_lin	0	30
    IDE12412-ENG154744-LIN Ambient light color list-Rotwert_Farbe_2_lin	0	30
    IDE12412-ENG154764-LIN Ambient light color list-Rotwert_Farbe_3_lin	0	30
    IDE12412-ENG154767-LIN Ambient light color list-Rotwert_Farbe_4_lin	0	30
    IDE12412-ENG154768-LIN Ambient light color list-Rotwert_Farbe_5_lin	0	30
    IDE12412-ENG154769-LIN Ambient light color list-Rotwert_Farbe_6_lin	0	30
    IDE12412-ENG154770-LIN Ambient light color list-Rotwert_Farbe_7_lin	0	30
    IDE12412-ENG154771-LIN Ambient light color list-Rotwert_Farbe_8_lin	0	30
    IDE12412-ENG154772-LIN Ambient light color list-Rotwert_Farbe_9_lin	0	30
    MAS01490-ENG142027-Energy management-Energiemanagement Abschaltung	active 	5
    MAS01490-ENG116830-Energy management-Energy_Management_Adaptation	Energy management active 	5
    MAS01490-ENG142256-Energy management-Hochvoltfahrzeug	not installed 	5
    MAS01490-ENG141950-Energy management-Hybrid vehicle	No 	5
    MAS01490-ENG133400-Energy management-Praediktives_Energiemanagement	not active 	5
    MAS01490-ENG141978-Energy management-Recuperation	not active 	5
    MAS01490-ENG142037-Energy management-Zweitbatterie	not installed 	5
    MAS05055-lower turn position	31.494474 °	2
    MAS05056-upper turn position	170.494336 °	2
    MAS08228-ENG133434-Light sensor-Daemmerungsgrenze: Hysterese_obergrenze	1200 lx	24
    MAS08228-ENG133435-Light sensor-Daemmerungsgrenze_Hysterese_untergrenze	2200 lx	24
    MAS08228-ENG133444-Light sensor-ECE_Lichteinschaltschwelle	0 lx	24
    MAS08228-ENG133433-Light sensor-Einschaltgrenze_CHO_LHO	600 lx	24
    MAS08228-ENG133437-Light sensor-Helligkeitsgrenze_Licht__einschalten	1200 lx	24
    MAS08228-ENG133438-Light sensor-Helligkeitsgrenze_Licht_ausschalten	2200 lx	24
    MAS08228-ENG133445-Light sensor-Helligkeitsgrenze_Licht_ausschalten_red	00 00 	24
    MAS08228-ENG133436-Light sensor-Helligkeitsgrenze_sehr_hell	2000 lx	24
    MAS08228-ENG142230-Light sensor-HMI_Exterior_light_on_highway	not active 	24
    MAS08228-ENG142231-Light sensor-HMI_Exterior_light_on_rain	not active 	24
    MAS08228-ENG142232-Light sensor-HMI_exterior_light_sensitivity	frueh 	24
    MAS08228-ENG142229-Light sensor-HMI_Wiper_Comfort_Rain_Sensor_OFF	not active 	24
    MAS08228-ENG126628-Light sensor-LS_Error_Ausgabe	not active 	24
    MAS08228-ENG133442-Light sensor-Maximale_Ausgangsspannung	0 mV	24
    MAS08228-ENG133440-Light sensor-Maximale_Beleuchtungsstaerke	0 lx	24
    MAS08228-ENG133441-Light sensor-Minimale_Ausgangsspannung	0 mV	24
    MAS08228-ENG133439-Light sensor-Minimale_Beleuchtungsstaerke	0 lx	24
    MAS08228-ENG133443-Light sensor-Tunnel_einschalt_verzoegerung	2	24
    ENG153709-ENG154696-Aktivierung_Entwicklungsdiagnose-log_dtc_status	not active 	9
    ENG153709-ENG154697-Aktivierung_Entwicklungsdiagnose-log-dtc_DFCC	00 00 00 	9
    ENG153709-ENG154714-Aktivierung_Entwicklungsdiagnose-Reaktion_LOG-DTC	First_dtc 	9
    ENG141683-ENG116672-Allwetterlicht_Spoiler-Spoiler Einfahrunterdrueckung nach manuellem Ausfahren	not active 	4
    ENG141683-ENG116671-Allwetterlicht_Spoiler-Spoiler Komfortsenken des Spoiler ueber Schliesszylinder FT	not active 	4
    ENG141683-ENG141975-Allwetterlicht_Spoiler-tt_spoiler	not installed 	4
    ENG153710-ENG154516-Ambience_lightning_color_list_2-Blauwert Farbe 11	0	60
    ENG153710-ENG154517-Ambience_lightning_color_list_2-Blauwert Farbe 12	0	60
    ENG153710-ENG154518-Ambience_lightning_color_list_2-Blauwert Farbe 13	0	60
    ENG153710-ENG154519-Ambience_lightning_color_list_2-Blauwert Farbe 14	0	60
    ENG153710-ENG154520-Ambience_lightning_color_list_2-Blauwert Farbe 15	0	60
    ENG153710-ENG154521-Ambience_lightning_color_list_2-Blauwert Farbe 16	0	60
    ENG153710-ENG154522-Ambience_lightning_color_list_2-Blauwert Farbe 17	0	60
    ENG153710-ENG154523-Ambience_lightning_color_list_2-Blauwert Farbe 18	0	60
    ENG153710-ENG154524-Ambience_lightning_color_list_2-Blauwert Farbe 19	0	60
    ENG153710-ENG154525-Ambience_lightning_color_list_2-Blauwert Farbe 20	0	60
    ENG153710-ENG154539-Ambience_lightning_color_list_2-Blauwert_Farbe_21	0	60
    ENG153710-ENG154541-Ambience_lightning_color_list_2-Blauwert_Farbe_22	0	60
    ENG153710-ENG154543-Ambience_lightning_color_list_2-Blauwert_Farbe_23	0	60
    ENG153710-ENG154545-Ambience_lightning_color_list_2-Blauwert_Farbe_24	0	60
    ENG153710-ENG154547-Ambience_lightning_color_list_2-Blauwert_Farbe_25	0	60
    ENG153710-ENG154549-Ambience_lightning_color_list_2-Blauwert_Farbe_26	0	60
    ENG153710-ENG154551-Ambience_lightning_color_list_2-Blauwert_Farbe_27	0	60
    ENG153710-ENG154553-Ambience_lightning_color_list_2-Blauwert_Farbe_28	0	60
    ENG153710-ENG154555-Ambience_lightning_color_list_2-Blauwert_Farbe_29	0	60
    ENG153710-ENG154558-Ambience_lightning_color_list_2-Blauwert_Farbe_30	0	60
    ENG153710-ENG154635-Ambience_lightning_color_list_2-Gruenwert Farbe 11	0	60
    ENG153710-ENG154636-Ambience_lightning_color_list_2-Gruenwert Farbe 12	0	60
    ENG153710-ENG154637-Ambience_lightning_color_list_2-Gruenwert Farbe 13	0	60
    ENG153710-ENG154638-Ambience_lightning_color_list_2-Gruenwert Farbe 14	0	60
    ENG153710-ENG154639-Ambience_lightning_color_list_2-Gruenwert Farbe 15	0	60
    ENG153710-ENG154640-Ambience_lightning_color_list_2-Gruenwert Farbe 16	0	60
    ENG153710-ENG154641-Ambience_lightning_color_list_2-Gruenwert Farbe 17	0	60
    ENG153710-ENG154642-Ambience_lightning_color_list_2-Gruenwert Farbe 18	0	60
    ENG153710-ENG154643-Ambience_lightning_color_list_2-Gruenwert Farbe 19	0	60
    ENG153710-ENG154644-Ambience_lightning_color_list_2-Gruenwert Farbe 20	0	60
    ENG153710-ENG154658-Ambience_lightning_color_list_2-Gruenwert_Farbe_21	0	60
    ENG153710-ENG154660-Ambience_lightning_color_list_2-Gruenwert_Farbe_22	0	60
    ENG153710-ENG154662-Ambience_lightning_color_list_2-Gruenwert_Farbe_23	0	60
    ENG153710-ENG154664-Ambience_lightning_color_list_2-Gruenwert_Farbe_24	0	60
    ENG153710-ENG154666-Ambience_lightning_color_list_2-Gruenwert_Farbe_25	0	60
    ENG153710-ENG154668-Ambience_lightning_color_list_2-Gruenwert_Farbe_26	0	60
    ENG153710-ENG154670-Ambience_lightning_color_list_2-Gruenwert_Farbe_27	0	60
    ENG153710-ENG154672-Ambience_lightning_color_list_2-Gruenwert_Farbe_28	0	60
    ENG153710-ENG154674-Ambience_lightning_color_list_2-Gruenwert_Farbe_29	0	60
    ENG153710-ENG154677-Ambience_lightning_color_list_2-Gruenwert_Farbe_30	0	60
    ENG153710-ENG154723-Ambience_lightning_color_list_2-Rotwert Farbe 11	0	60
    ENG153710-ENG154724-Ambience_lightning_color_list_2-Rotwert Farbe 12	0	60
    ENG153710-ENG154725-Ambience_lightning_color_list_2-Rotwert Farbe 13	0	60
    ENG153710-ENG154726-Ambience_lightning_color_list_2-Rotwert Farbe 14	0	60
    ENG153710-ENG154727-Ambience_lightning_color_list_2-Rotwert Farbe 15	0	60
    ENG153710-ENG154728-Ambience_lightning_color_list_2-Rotwert Farbe 16	0	60
    ENG153710-ENG154729-Ambience_lightning_color_list_2-Rotwert Farbe 17	0	60
    ENG153710-ENG154730-Ambience_lightning_color_list_2-Rotwert Farbe 18	0	60
    ENG153710-ENG154731-Ambience_lightning_color_list_2-Rotwert Farbe 19	0	60
    ENG153710-ENG154732-Ambience_lightning_color_list_2-Rotwert Farbe 20	0	60
    ENG153710-ENG154746-Ambience_lightning_color_list_2-Rotwert_Farbe_21	0	60
    ENG153710-ENG154748-Ambience_lightning_color_list_2-Rotwert_Farbe_22	0	60
    ENG153710-ENG154750-Ambience_lightning_color_list_2-Rotwert_Farbe_23	0	60
    ENG153710-ENG154752-Ambience_lightning_color_list_2-Rotwert_Farbe_24	0	60
    ENG153710-ENG154754-Ambience_lightning_color_list_2-Rotwert_Farbe_25	0	60
    ENG153710-ENG154756-Ambience_lightning_color_list_2-Rotwert_Farbe_26	0	60
    ENG153710-ENG154758-Ambience_lightning_color_list_2-Rotwert_Farbe_27	0	60
    ENG153710-ENG154760-Ambience_lightning_color_list_2-Rotwert_Farbe_28	0	60
    ENG153710-ENG154762-Ambience_lightning_color_list_2-Rotwert_Farbe_29	0	60
    ENG153710-ENG154765-Ambience_lightning_color_list_2-Rotwert_Farbe_30	0	60
    ENG153711-ENG154528-Ambience_lightning_color_list_lin_2-Blauwert_Farbe_11_lin	0	60
    ENG153711-ENG154529-Ambience_lightning_color_list_lin_2-Blauwert_Farbe_12_lin	0	60
    ENG153711-ENG154530-Ambience_lightning_color_list_lin_2-Blauwert_Farbe_13_lin	0	60
    ENG153711-ENG154531-Ambience_lightning_color_list_lin_2-Blauwert_Farbe_14_lin	0	60
    ENG153711-ENG154532-Ambience_lightning_color_list_lin_2-Blauwert_Farbe_15_lin	0	60
    ENG153711-ENG154533-Ambience_lightning_color_list_lin_2-Blauwert_Farbe_16_lin	0	60
    ENG153711-ENG154534-Ambience_lightning_color_list_lin_2-Blauwert_Farbe_17_lin	0	60
    ENG153711-ENG154535-Ambience_lightning_color_list_lin_2-Blauwert_Farbe_18_lin	0	60
    ENG153711-ENG154536-Ambience_lightning_color_list_lin_2-Blauwert_Farbe_19_lin	0	60
    ENG153711-ENG154538-Ambience_lightning_color_list_lin_2-Blauwert_Farbe_20_lin	0	60
    ENG153711-ENG154540-Ambience_lightning_color_list_lin_2-Blauwert_Farbe_21_lin	0	60
    ENG153711-ENG154542-Ambience_lightning_color_list_lin_2-Blauwert_Farbe_22_lin	0	60
    ENG153711-ENG154544-Ambience_lightning_color_list_lin_2-Blauwert_Farbe_23_lin	0	60
    ENG153711-ENG154546-Ambience_lightning_color_list_lin_2-Blauwert_Farbe_24_lin	0	60
    ENG153711-ENG154548-Ambience_lightning_color_list_lin_2-Blauwert_Farbe_25_lin	0	60
    ENG153711-ENG154550-Ambience_lightning_color_list_lin_2-Blauwert_Farbe_26_lin	0	60
    ENG153711-ENG154552-Ambience_lightning_color_list_lin_2-Blauwert_Farbe_27_lin	0	60
    ENG153711-ENG154554-Ambience_lightning_color_list_lin_2-Blauwert_Farbe_28_lin	0	60
    ENG153711-ENG154556-Ambience_lightning_color_list_lin_2-Blauwert_Farbe_29_lin	0	60
    ENG153711-ENG154559-Ambience_lightning_color_list_lin_2-Blauwert_Farbe_30_lin	0	60
    ENG153711-ENG154647-Ambience_lightning_color_list_lin_2-Gruenwert_Farbe_11_lin	0	60
    ENG153711-ENG154648-Ambience_lightning_color_list_lin_2-Gruenwert_Farbe_12_lin	0	60
    ENG153711-ENG154649-Ambience_lightning_color_list_lin_2-Gruenwert_Farbe_13_lin	0	60
    ENG153711-ENG154650-Ambience_lightning_color_list_lin_2-Gruenwert_Farbe_14_lin	0	60
    ENG153711-ENG154651-Ambience_lightning_color_list_lin_2-Gruenwert_Farbe_15_lin	0	60
    ENG153711-ENG154652-Ambience_lightning_color_list_lin_2-Gruenwert_Farbe_16_lin	0	60
    ENG153711-ENG154653-Ambience_lightning_color_list_lin_2-Gruenwert_Farbe_17_lin	0	60
    ENG153711-ENG154654-Ambience_lightning_color_list_lin_2-Gruenwert_Farbe_18_lin	0	60
    ENG153711-ENG154655-Ambience_lightning_color_list_lin_2-Gruenwert_Farbe_19_lin	0	60
    ENG153711-ENG154657-Ambience_lightning_color_list_lin_2-Gruenwert_Farbe_20_lin	0	60
    ENG153711-ENG154659-Ambience_lightning_color_list_lin_2-Gruenwert_Farbe_21_lin	0	60
    ENG153711-ENG154661-Ambience_lightning_color_list_lin_2-Gruenwert_Farbe_22_lin	0	60
    ENG153711-ENG154663-Ambience_lightning_color_list_lin_2-Gruenwert_Farbe_23_lin	0	60
    ENG153711-ENG154665-Ambience_lightning_color_list_lin_2-Gruenwert_Farbe_24_lin	0	60
    ENG153711-ENG154667-Ambience_lightning_color_list_lin_2-Gruenwert_Farbe_25_lin	0	60
    ENG153711-ENG154669-Ambience_lightning_color_list_lin_2-Gruenwert_Farbe_26_lin	0	60
    ENG153711-ENG154671-Ambience_lightning_color_list_lin_2-Gruenwert_Farbe_27_lin	0	60
    ENG153711-ENG154673-Ambience_lightning_color_list_lin_2-Gruenwert_Farbe_28_lin	0	60
    ENG153711-ENG154675-Ambience_lightning_color_list_lin_2-Gruenwert_Farbe_29_lin	0	60
    ENG153711-ENG154678-Ambience_lightning_color_list_lin_2-Gruenwert_Farbe_30_lin	0	60
    ENG153711-ENG154735-Ambience_lightning_color_list_lin_2-Rotwert_Farbe_11_lin	0	60
    ENG153711-ENG154736-Ambience_lightning_color_list_lin_2-Rotwert_Farbe_12_lin	0	60
    ENG153711-ENG154737-Ambience_lightning_color_list_lin_2-Rotwert_Farbe_13_lin	0	60
    ENG153711-ENG154738-Ambience_lightning_color_list_lin_2-Rotwert_Farbe_14_lin	0	60
    ENG153711-ENG154739-Ambience_lightning_color_list_lin_2-Rotwert_Farbe_15_lin	0	60
    ENG153711-ENG154740-Ambience_lightning_color_list_lin_2-Rotwert_Farbe_16_lin	0	60
    ENG153711-ENG154741-Ambience_lightning_color_list_lin_2-Rotwert_Farbe_17_lin	0	60
    ENG153711-ENG154742-Ambience_lightning_color_list_lin_2-Rotwert_Farbe_18_lin	0	60
    ENG153711-ENG154743-Ambience_lightning_color_list_lin_2-Rotwert_Farbe_19_lin	0	60
    ENG153711-ENG154745-Ambience_lightning_color_list_lin_2-Rotwert_Farbe_20_lin	0	60
    ENG153711-ENG154747-Ambience_lightning_color_list_lin_2-Rotwert_Farbe_21_lin	0	60
    ENG153711-ENG154749-Ambience_lightning_color_list_lin_2-Rotwert_Farbe_22_lin	0	60
    ENG153711-ENG154751-Ambience_lightning_color_list_lin_2-Rotwert_Farbe_23_lin	0	60
    ENG153711-ENG154753-Ambience_lightning_color_list_lin_2-Rotwert_Farbe_24_lin	0	60
    ENG153711-ENG154755-Ambience_lightning_color_list_lin_2-Rotwert_Farbe_25_lin	0	60
    ENG153711-ENG154757-Ambience_lightning_color_list_lin_2-Rotwert_Farbe_26_lin	0	60
    ENG153711-ENG154759-Ambience_lightning_color_list_lin_2-Rotwert_Farbe_27_lin	0	60
    ENG153711-ENG154761-Ambience_lightning_color_list_lin_2-Rotwert_Farbe_28_lin	0	60
    ENG153711-ENG154763-Ambience_lightning_color_list_lin_2-Rotwert_Farbe_29_lin	0	60
    ENG153711-ENG154766-Ambience_lightning_color_list_lin_2-Rotwert_Farbe_30_lin	0	60
    ENG126649-ENG126874-ambient_lighting_lin_slaves_groups-pa_korrekturfaktor_gruppe_1	1	30
    ENG126649-ENG126901-ambient_lighting_lin_slaves_groups-pa_korrekturfaktor_gruppe_10	1	30
    ENG126649-ENG126904-ambient_lighting_lin_slaves_groups-pa_korrekturfaktor_gruppe_11	1	30
    ENG126649-ENG126907-ambient_lighting_lin_slaves_groups-pa_korrekturfaktor_gruppe_12	1	30
    ENG126649-ENG126910-ambient_lighting_lin_slaves_groups-pa_korrekturfaktor_gruppe_13	1	30
    ENG126649-ENG126913-ambient_lighting_lin_slaves_groups-pa_korrekturfaktor_gruppe_14	1	30
    ENG126649-ENG126916-ambient_lighting_lin_slaves_groups-pa_korrekturfaktor_gruppe_15	1	30
    ENG126649-ENG126877-ambient_lighting_lin_slaves_groups-pa_korrekturfaktor_gruppe_2	1	30
    ENG126649-ENG126880-ambient_lighting_lin_slaves_groups-pa_korrekturfaktor_gruppe_3	1	30
    ENG126649-ENG126883-ambient_lighting_lin_slaves_groups-pa_korrekturfaktor_gruppe_4	1	30
    ENG126649-ENG126886-ambient_lighting_lin_slaves_groups-pa_korrekturfaktor_gruppe_5	1	30
    ENG126649-ENG126889-ambient_lighting_lin_slaves_groups-pa_korrekturfaktor_gruppe_6	1	30
    ENG126649-ENG126892-ambient_lighting_lin_slaves_groups-pa_korrekturfaktor_gruppe_7	1	30
    ENG126649-ENG126895-ambient_lighting_lin_slaves_groups-pa_korrekturfaktor_gruppe_8	1	30
    ENG126649-ENG126898-ambient_lighting_lin_slaves_groups-pa_korrekturfaktor_gruppe_9	1	30
    ENG126649-ENG126873-ambient_lighting_lin_slaves_groups-pa_lichtfunktion_gruppe_1	door 	30
    ENG126649-ENG126900-ambient_lighting_lin_slaves_groups-pa_lichtfunktion_gruppe_10	door 	30
    ENG126649-ENG126903-ambient_lighting_lin_slaves_groups-pa_lichtfunktion_gruppe_11	door 	30
    ENG126649-ENG126906-ambient_lighting_lin_slaves_groups-pa_lichtfunktion_gruppe_12	door 	30
    ENG126649-ENG126909-ambient_lighting_lin_slaves_groups-pa_lichtfunktion_gruppe_13	door 	30
    ENG126649-ENG126912-ambient_lighting_lin_slaves_groups-pa_lichtfunktion_gruppe_14	door 	30
    ENG126649-ENG126915-ambient_lighting_lin_slaves_groups-pa_lichtfunktion_gruppe_15	door 	30
    ENG126649-ENG126876-ambient_lighting_lin_slaves_groups-pa_lichtfunktion_gruppe_2	door 	30
    ENG126649-ENG126879-ambient_lighting_lin_slaves_groups-pa_lichtfunktion_gruppe_3	door 	30
    ENG126649-ENG126882-ambient_lighting_lin_slaves_groups-pa_lichtfunktion_gruppe_4	door 	30
    ENG126649-ENG126885-ambient_lighting_lin_slaves_groups-pa_lichtfunktion_gruppe_5	door 	30
    ENG126649-ENG126888-ambient_lighting_lin_slaves_groups-pa_lichtfunktion_gruppe_6	door 	30
    ENG126649-ENG126891-ambient_lighting_lin_slaves_groups-pa_lichtfunktion_gruppe_7	door 	30
    ENG126649-ENG126894-ambient_lighting_lin_slaves_groups-pa_lichtfunktion_gruppe_8	door 	30
    ENG126649-ENG126897-ambient_lighting_lin_slaves_groups-pa_lichtfunktion_gruppe_9	door 	30
    ENG126649-ENG126872-ambient_lighting_lin_slaves_groups-pa_verbauinfo_gruppe_1	not installed 	30
    ENG126649-ENG126899-ambient_lighting_lin_slaves_groups-pa_verbauinfo_gruppe_10	not installed 	30
    ENG126649-ENG126902-ambient_lighting_lin_slaves_groups-pa_verbauinfo_gruppe_11	not installed 	30
    ENG126649-ENG126905-ambient_lighting_lin_slaves_groups-pa_verbauinfo_gruppe_12	not installed 	30
    ENG126649-ENG126908-ambient_lighting_lin_slaves_groups-pa_verbauinfo_gruppe_13	not installed 	30
    ENG126649-ENG126911-ambient_lighting_lin_slaves_groups-pa_verbauinfo_gruppe_14	not installed 	30
    ENG126649-ENG126914-ambient_lighting_lin_slaves_groups-pa_verbauinfo_gruppe_15	not installed 	30
    ENG126649-ENG126875-ambient_lighting_lin_slaves_groups-pa_verbauinfo_gruppe_2	not installed 	30
    ENG126649-ENG126878-ambient_lighting_lin_slaves_groups-pa_verbauinfo_gruppe_3	not installed 	30
    ENG126649-ENG126881-ambient_lighting_lin_slaves_groups-pa_verbauinfo_gruppe_4	not installed 	30
    ENG126649-ENG126884-ambient_lighting_lin_slaves_groups-pa_verbauinfo_gruppe_5	not installed 	30
    ENG126649-ENG126887-ambient_lighting_lin_slaves_groups-pa_verbauinfo_gruppe_6	not installed 	30
    ENG126649-ENG126890-ambient_lighting_lin_slaves_groups-pa_verbauinfo_gruppe_7	not installed 	30
    ENG126649-ENG126893-ambient_lighting_lin_slaves_groups-pa_verbauinfo_gruppe_8	not installed 	30
    ENG126649-ENG126896-ambient_lighting_lin_slaves_groups-pa_verbauinfo_gruppe_9	not installed 	30
    ENG128379-ENG128424-ambient_lighting_lin_slaves_modules-pa_einzeladresse_slave_:12	0	60
    ENG128379-ENG128391-ambient_lighting_lin_slaves_modules-pa_einzeladresse_slave_1	0	60
    ENG128379-ENG128418-ambient_lighting_lin_slaves_modules-pa_einzeladresse_slave_10	0	60
    ENG128379-ENG128421-ambient_lighting_lin_slaves_modules-pa_einzeladresse_slave_11	0	60
    ENG128379-ENG128427-ambient_lighting_lin_slaves_modules-pa_einzeladresse_slave_13	0	60
    ENG128379-ENG128430-ambient_lighting_lin_slaves_modules-pa_einzeladresse_slave_14	0	60
    ENG128379-ENG128433-ambient_lighting_lin_slaves_modules-pa_einzeladresse_slave_15	0	60
    ENG128379-ENG128436-ambient_lighting_lin_slaves_modules-pa_einzeladresse_slave_16	0	60
    ENG128379-ENG128439-ambient_lighting_lin_slaves_modules-pa_einzeladresse_slave_17	0	60
    ENG128379-ENG128442-ambient_lighting_lin_slaves_modules-pa_einzeladresse_slave_18	0	60
    ENG128379-ENG128445-ambient_lighting_lin_slaves_modules-pa_einzeladresse_slave_19	0	60
    ENG128379-ENG128394-ambient_lighting_lin_slaves_modules-pa_einzeladresse_slave_2	0	60
    ENG128379-ENG128448-ambient_lighting_lin_slaves_modules-pa_einzeladresse_slave_20	0	60
    ENG128379-ENG128397-ambient_lighting_lin_slaves_modules-pa_einzeladresse_slave_3	0	60
    ENG128379-ENG128400-ambient_lighting_lin_slaves_modules-pa_einzeladresse_slave_4	0	60
    ENG128379-ENG128403-ambient_lighting_lin_slaves_modules-pa_einzeladresse_slave_5	0	60
    ENG128379-ENG128406-ambient_lighting_lin_slaves_modules-pa_einzeladresse_slave_6	0	60
    ENG128379-ENG128409-ambient_lighting_lin_slaves_modules-pa_einzeladresse_slave_7	0	60
    ENG128379-ENG128412-ambient_lighting_lin_slaves_modules-pa_einzeladresse_slave_8	0	60
    ENG128379-ENG128415-ambient_lighting_lin_slaves_modules-pa_einzeladresse_slave_9	0	60
    ENG128379-ENG128393-ambient_lighting_lin_slaves_modules-pa_fehlerort_slave_1	0	60
    ENG128379-ENG128420-ambient_lighting_lin_slaves_modules-pa_fehlerort_slave_10	0	60
    ENG128379-ENG128423-ambient_lighting_lin_slaves_modules-pa_fehlerort_slave_11	0	60
    ENG128379-ENG128426-ambient_lighting_lin_slaves_modules-pa_fehlerort_slave_12	0	60
    ENG128379-ENG128429-ambient_lighting_lin_slaves_modules-pa_fehlerort_slave_13	0	60
    ENG128379-ENG128432-ambient_lighting_lin_slaves_modules-pa_fehlerort_slave_14	0	60
    ENG128379-ENG128435-ambient_lighting_lin_slaves_modules-pa_fehlerort_slave_15	0	60
    ENG128379-ENG128438-ambient_lighting_lin_slaves_modules-pa_fehlerort_slave_16	0	60
    ENG128379-ENG128441-ambient_lighting_lin_slaves_modules-pa_fehlerort_slave_17	0	60
    ENG128379-ENG128444-ambient_lighting_lin_slaves_modules-pa_fehlerort_slave_18	0	60
    ENG128379-ENG128447-ambient_lighting_lin_slaves_modules-pa_fehlerort_slave_19	0	60
    ENG128379-ENG128396-ambient_lighting_lin_slaves_modules-pa_fehlerort_slave_2	0	60
    ENG128379-ENG128450-ambient_lighting_lin_slaves_modules-pa_fehlerort_slave_20	0	60
    ENG128379-ENG128399-ambient_lighting_lin_slaves_modules-pa_fehlerort_slave_3	0	60
    ENG128379-ENG128402-ambient_lighting_lin_slaves_modules-pa_fehlerort_slave_4	0	60
    ENG128379-ENG128405-ambient_lighting_lin_slaves_modules-pa_fehlerort_slave_5	0	60
    ENG128379-ENG128408-ambient_lighting_lin_slaves_modules-pa_fehlerort_slave_6	0	60
    ENG128379-ENG128411-ambient_lighting_lin_slaves_modules-pa_fehlerort_slave_7	0	60
    ENG128379-ENG128417-ambient_lighting_lin_slaves_modules-pa_fehlerort_slave_9	0	60
    ENG128379-ENG128414-ambient_lighting_lin_slaves_modules-pa_fehlerort_slave8	0	60
    ENG128379-ENG128392-ambient_lighting_lin_slaves_modules-pa_verbauinfo_slave_1	not installed 	60
    ENG128379-ENG128419-ambient_lighting_lin_slaves_modules-pa_verbauinfo_slave_10	not installed 	60
    ENG128379-ENG128422-ambient_lighting_lin_slaves_modules-pa_verbauinfo_slave_11	not installed 	60
    ENG128379-ENG128425-ambient_lighting_lin_slaves_modules-pa_verbauinfo_slave_12	not installed 	60
    ENG128379-ENG128428-ambient_lighting_lin_slaves_modules-pa_verbauinfo_slave_13	not installed 	60
    ENG128379-ENG128431-ambient_lighting_lin_slaves_modules-pa_verbauinfo_slave_14	not installed 	60
    ENG128379-ENG128434-ambient_lighting_lin_slaves_modules-pa_verbauinfo_slave_15	not installed 	60
    ENG128379-ENG128437-ambient_lighting_lin_slaves_modules-pa_verbauinfo_slave_16	not installed 	60
    ENG128379-ENG128440-ambient_lighting_lin_slaves_modules-pa_verbauinfo_slave_17	not installed 	60
    ENG128379-ENG128443-ambient_lighting_lin_slaves_modules-pa_verbauinfo_slave_18	not installed 	60
    ENG128379-ENG128446-ambient_lighting_lin_slaves_modules-pa_verbauinfo_slave_19	not installed 	60
    ENG128379-ENG128395-ambient_lighting_lin_slaves_modules-pa_verbauinfo_slave_2	not installed 	60
    ENG128379-ENG128449-ambient_lighting_lin_slaves_modules-pa_verbauinfo_slave_20	not installed 	60
    ENG128379-ENG128398-ambient_lighting_lin_slaves_modules-pa_verbauinfo_slave_3	not installed 	60
    ENG128379-ENG128401-ambient_lighting_lin_slaves_modules-pa_verbauinfo_slave_4	not installed 	60
    ENG128379-ENG128404-ambient_lighting_lin_slaves_modules-pa_verbauinfo_slave_5	not installed 	60
    ENG128379-ENG128407-ambient_lighting_lin_slaves_modules-pa_verbauinfo_slave_6	not installed 	60
    ENG128379-ENG128410-ambient_lighting_lin_slaves_modules-pa_verbauinfo_slave_7	not installed 	60
    ENG128379-ENG128416-ambient_lighting_lin_slaves_modules-pa_verbauinfo_slave_9	not installed 	60
    ENG128379-ENG128413-ambient_lighting_lin_slaves_modules-pa_verbauinfo_slave8	not installed 	60
    ENG153712-ENG154510-Ambientelicht Zuordnung der Farbe zum Fahrprofil-Ambiente	Keine_Spannungsanforderung 	23
    ENG153712-ENG154602-Ambientelicht Zuordnung der Farbe zum Fahrprofil-Fahrprofil_0	1	23
    ENG153712-ENG154603-Ambientelicht Zuordnung der Farbe zum Fahrprofil-Fahrprofil_1	1	23
    ENG153712-ENG154604-Ambientelicht Zuordnung der Farbe zum Fahrprofil-Fahrprofil_10	1	23
    ENG153712-ENG154605-Ambientelicht Zuordnung der Farbe zum Fahrprofil-Fahrprofil_11	1	23
    ENG153712-ENG154606-Ambientelicht Zuordnung der Farbe zum Fahrprofil-Fahrprofil_12	1	23
    ENG153712-ENG154607-Ambientelicht Zuordnung der Farbe zum Fahrprofil-Fahrprofil_13	1	23
    ENG153712-ENG154608-Ambientelicht Zuordnung der Farbe zum Fahrprofil-Fahrprofil_14	1	23
    ENG153712-ENG154609-Ambientelicht Zuordnung der Farbe zum Fahrprofil-Fahrprofil_15	1	23
    ENG153712-ENG154610-Ambientelicht Zuordnung der Farbe zum Fahrprofil-Fahrprofil_2	1	23
    ENG153712-ENG154611-Ambientelicht Zuordnung der Farbe zum Fahrprofil-Fahrprofil_3	1	23
    ENG153712-ENG154612-Ambientelicht Zuordnung der Farbe zum Fahrprofil-Fahrprofil_4	1	23
    ENG153712-ENG154613-Ambientelicht Zuordnung der Farbe zum Fahrprofil-Fahrprofil_5	1	23
    ENG153712-ENG154614-Ambientelicht Zuordnung der Farbe zum Fahrprofil-Fahrprofil_6	1	23
    ENG153712-ENG154615-Ambientelicht Zuordnung der Farbe zum Fahrprofil-Fahrprofil_7	1	23
    ENG153712-ENG154616-Ambientelicht Zuordnung der Farbe zum Fahrprofil-Fahrprofil_8	1	23
    ENG153712-ENG154617-Ambientelicht Zuordnung der Farbe zum Fahrprofil-Fahrprofil_9	1	23
    ENG141649-ENG122212-Außenlicht_Blinker-ABBA_Blinken	not active 	10
    ENG141649-ENG133379-Außenlicht_Blinker-Abbruch Komfortblinken	active 	10
    ENG141649-ENG116590-Außenlicht_Blinker-Blinkkontrolleuchte fuer Anhaenger	separte 	10
    ENG141649-ENG121966-Außenlicht_Blinker-Crash flashing	not active 	10
    ENG141649-ENG122207-Außenlicht_Blinker-DWA_Alarm_Blinken	not active 	10
    ENG141649-ENG122206-Außenlicht_Blinker-DWA_Schaerfungsquittung	not active 	10
    ENG141649-ENG142194-Außenlicht_Blinker-dynamisch_blinken_10	not active 	10
    ENG141649-ENG142195-Außenlicht_Blinker-Dynamische_Blink_Delay	50 ms	10
    ENG141649-ENG126819-Außenlicht_Blinker-Emergency_alert_blinken	not active 	10
    ENG141649-ENG154601-Außenlicht_Blinker-Fahrerassistenz_Blinkenfunktionen	Warnblinke_zulaessig 	10
    ENG141649-ENG115774-Außenlicht_Blinker-Komfortblinken	active 	10
    ENG141649-ENG116587-Außenlicht_Blinker-Komfortblinken Blinkzyklen	3	10
    ENG141649-ENG122208-Außenlicht_Blinker-Multi_kollisions_Blinken	not active 	10
    ENG141649-ENG122209-Außenlicht_Blinker-Notwarn_blinken_NBA_Phase_2	not active 	10
    ENG141649-ENG121967-Außenlicht_Blinker-Panic flashing	not active 	10
    ENG141649-ENG154711-Außenlicht_Blinker-PreCrash_RECAS	PreCrash_passiv 	10
    ENG141649-ENG122211-Außenlicht_Blinker-Richtungs_blinken_links	active 	10
    ENG141649-ENG122210-Außenlicht_Blinker-Richtungs_blinken_rechts	active 	10
    ENG141649-ENG122201-Außenlicht_Blinker-Schluessel_Anlern_Blinken	not active 	10
    ENG141649-ENG121968-Außenlicht_Blinker-Taxi alarm flashing	not active 	10
    ENG141649-ENG126629-Außenlicht_Blinker-Telematikblinken1_STS_Blinken Telematikblinken2_OCU_Blinken	not active 	10
    ENG141649-ENG122202-Außenlicht_Blinker-UGDO_ Anlern_Blinken	not active 	10
    ENG141649-ENG142029-Außenlicht_Blinker-Warnblinken_durch_Fahrerassistenz	not active 	10
    ENG141649-ENG122214-Außenlicht_Blinker-Warnblinken_Zuendung_AUS	active 	10
    ENG141649-ENG122213-Außenlicht_Blinker-Warnblinken_Zuendung_EIN	active 	10
    ENG141649-ENG122204-Außenlicht_Blinker-ZV_Blinken_auf	not active 	10
    ENG141649-ENG122203-Außenlicht_Blinker-ZV_Blinken_zu	not active 	10
    ENG141647-ENG141986-Außenlicht_Front-Abblendlicht_Leuchtentyp	H7 	9
    ENG141647-ENG116705-Außenlicht_Front-Allwetterlicht Ausschaltgrenze	350 km/h	9
    ENG141647-ENG116704-Außenlicht_Front-Allwetterlicht Einschaltgrenze	350 km/h	9
    ENG141647-ENG115833-Außenlicht_Front-Fahrlicht bei Tag	Daytime running lights 	9
    ENG141647-ENG142193-Außenlicht_Front-Geschwindigkeitsabhaengiges TFL	5 km/h	9
    ENG141647-ENG115861-Außenlicht_Front-Lichthupe bei Zuendung aus moeglich	active 	9
    ENG141647-ENG115832-Außenlicht_Front-Scheinwerferferreinigungsansteuerung und Abblendlichtanzeige bei Dauerfahrlicht	not active 	9
    ENG141647-ENG142191-Außenlicht_Front-Signaturlicht HMI-default Anzeige im Kombiinstrument	not active 	9
    ENG141647-ENG142190-Außenlicht_Front-Signaturlicht_verbaut	not installed 	9
    ENG141647-ENG116592-Außenlicht_Front-Standlicht aktiviert zusaetzlich Tagfahrlicht	active 	9
    ENG141647-ENG116594-Außenlicht_Front-Tagfahrlicht Aktivierung durch BAP oder Bedienfolge moeglich	not active 	9
    ENG141647-ENG122184-Außenlicht_Front-Tagfahrlicht Dauerfahrlicht bei Handbremse abschalten	active 	9
    ENG141647-ENG115734-Außenlicht_Front-Tagfahrlicht nur in Schalterstellung AUTO	not active 	9
    ENG141647-ENG116593-Außenlicht_Front-Tagfahrlicht-Dauerfahrlicht aktiviert zusaetzlich Standlicht	not active 	9
    ENG141647-ENG115733-Außenlicht_Front-Tagfahrlichtkontrollleuchte	not active 	9
    ENG141647-ENG142192-Außenlicht_Front-TFL_Abschaltung_ueber_Geschwindigkeit	not active 	9
    ENG141647-ENG116591-Außenlicht_Front-Werkseinstellung fuer Tagfahrlicht Freischaltung BAP / Bedienfolge	active 	9
    ENG141647-ENG115860-Außenlicht_Front-Zahl der aktiven Scheinwerfer auf 2 limitieren	limitieren 	9
    ENG141648-ENG141987-Aussenlicht_Heck-Bremslicht_ist_auch_Blinklicht	Yes 	5
    ENG141648-ENG115782-Aussenlicht_Heck-Nebelschlusslicht Warngeschwindigkeit	0 km/h	5
    ENG141648-ENG116636-Aussenlicht_Heck-Notbremsanzeige NBA	not active 	5
    ENG141648-ENG115831-Aussenlicht_Heck-Schlusslicht mit Bremslichtfunktion	not active 	5
    ENG141648-ENG142004-Aussenlicht_Heck-Umgreifende_Heckklappe	not installed 	5
    ENG141656-ENG142020-Außenlicht_uebergreifend-All-weather lights	not installed 	18
    ENG141656-ENG133381-Außenlicht_uebergreifend-Bedingungen zur Parklichtbegrenzung	begrenzen auf Mindestverfügbarkeit 	18
    ENG141656-ENG133380-Außenlicht_uebergreifend-Bedingungen zur Standlichtbegrenzung	begrenzen auf Mindestverfügbarkeit 	18
    ENG141656-ENG142188-Außenlicht_uebergreifend-bewusstes Standlicht	Aktive Begrenzung 	18
    ENG141656-ENG115656-Außenlicht_uebergreifend-Coming Home Leuchten	Low beam 	18
    ENG141656-ENG116601-Außenlicht_uebergreifend-Coming Home Verbaustatus	automatic 	18
    ENG141656-ENG116604-Außenlicht_uebergreifend-Coming-home Einschaltereignis	Driver door 	18
    ENG141656-ENG130581-Außenlicht_uebergreifend-Fahrlicht_Hinweis_mehrfach	not active 	18
    ENG141656-ENG126818-Außenlicht_uebergreifend-Fahrlichtwarnung_Hinweis_Konfig	kein_Hinweis 	18
    ENG141656-ENG137034-Außenlicht_uebergreifend-Faktor fuer Verfuegbarkeitstimer	Faktor fuer x5 Minuten 	18
    ENG141656-ENG154619-Außenlicht_uebergreifend-Fernlicht_LH	Sollspannungsanforderung 13.5 	18
    ENG141656-ENG154177-Außenlicht_uebergreifend-Fog light	Sollspannungsanforderung 13.5 	18
    ENG141656-ENG116608-Außenlicht_uebergreifend-Helligkeitsschwelle Forward-Messung	46400 lx	18
    ENG141656-ENG116605-Außenlicht_uebergreifend-Helligkeitsschwelle Infrarot-Messung	12 lx	18
    ENG141656-ENG142189-Außenlicht_uebergreifend-HVLM_Ladezustandsanzeige	No 	18
    ENG141656-ENG115858-Außenlicht_uebergreifend-Kontrollleuchte fuer Begrenzungslicht	integriert in Suchbeleuchtung 	18
    ENG141656-ENG142185-Außenlicht_uebergreifend-LCM_blinker	true 	18
    ENG141656-ENG141992-Außenlicht_uebergreifend-LDS_mit_AFL	Yes 	18
    ENG141656-ENG141991-Außenlicht_uebergreifend-LDS_mit_Nebel_Schlusslicht	No 	18
    ENG141656-ENG141990-Außenlicht_uebergreifend-LDS_mit_Nebellicht	Yes 	18
    ENG141656-ENG141993-Außenlicht_uebergreifend-LDS_mit_Standlichtstellung	Yes 	18
    ENG141656-ENG115657-Außenlicht_uebergreifend-Leaving-Home Verbausstatus	Enabled 	18
    ENG141656-ENG141989-Außenlicht_uebergreifend-Lichtdrehschalter (LDS)	discrete 	18
    ENG141656-ENG115862-Außenlicht_uebergreifend-Lichtwarnungsverhalten	klemmenabhaengig 	18
    ENG141656-ENG142034-Außenlicht_uebergreifend-Light_Control_Module	not installed 	18
    ENG141656-ENG98354-Außenlicht_uebergreifend-Low beam	Sollspannungsanforderung 13.5 	18
    ENG141656-ENG115863-Außenlicht_uebergreifend-Menueeinstellung CHO LHO	Menuesteuerung Zeit aktivieren 	18
    ENG141656-ENG116603-Außenlicht_uebergreifend-Menueeinstellung Cominghome	10 seconds 	18
    ENG141656-ENG116607-Außenlicht_uebergreifend-Menueeinstellung Leaving-home Zeit per BAP	10 seconds 	18
    ENG141656-ENG116602-Außenlicht_uebergreifend-Menuesteuerung Coming Home Werkseinstellung	active 	18
    ENG141656-ENG116606-Außenlicht_uebergreifend-Menuesteuerung Leaving-home Freischaltung per BAP	active 	18
    ENG141656-ENG115859-Außenlicht_uebergreifend-Parklicht ueber LSS aktiviert	not active 	18
    ENG141656-ENG126816-Außenlicht_uebergreifend-Standlicht aus	active 	18
    ENG141656-ENG115829-Außenlicht_uebergreifend-Standlichtreduzierung mit beidseitigem Parklicht	not active 	18
    ENG141656-ENG133383-Außenlicht_uebergreifend-Standlicht-Verfügbarkeit	6 s	18
    ENG141656-ENG154174-Außenlicht_uebergreifend-Turn signal	Sollspannungsanforderung 13.5 	18
    ENG141656-ENG126817-Außenlicht_uebergreifend-Umfeldleuchte als Manoevrierleuchte	not active 	18
    ENG126647-ENG98399-debug_light_function-Activation	0	11
    ENG126647-ENG101417-debug_light_function-Adresse	0	11
    ENG126647-ENG126820-debug_light_function-Bitmask	0	11
    ENG126647-ENG126821-debug_light_function-Divisor	0	11
    ENG126647-ENG98827-debug_light_function-Offset	0	11
    ENG126647-ENG126822-debug_light_function-Polaritaet	0	11
    ENG141675-ENG115658-Dimmunt_KL_58xs_PWM-x0	0.00%	6
    ENG141675-ENG101574-Dimmunt_KL_58xs_PWM-X1	50.00%	6
    ENG141675-ENG99557-Dimmunt_KL_58xs_PWM-X2	100.00%	6
    ENG141675-ENG115659-Dimmunt_KL_58xs_PWM-y0	0.00%	6
    ENG141675-ENG99777-Dimmunt_KL_58xs_PWM-Y1	50.00%	6
    ENG141675-ENG100480-Dimmunt_KL_58xs_PWM-Y2	100.00%	6
    ENG141650-MAS13782-Fernlicht_assistent-Will Beam assistant: responsivity adjustable via BAP	present 	6
    ENG141650-ENG141973-Fernlicht_assistent-Erweiterte_Fernlichtsteuerung	Basis 	6
    ENG141650-ENG116639-Fernlicht_assistent-Fernlichtassistent Reset	not active 	6
    ENG141650-ENG116637-Fernlicht_assistent-Menuesteuerung Fernlichtassistent	Not Present 	6
    ENG141650-ENG116641-Fernlicht_assistent-Menuesteuerung Fernlichtassistent Werkseinstellung	present 	6
    ENG141682-ENG115835-Front_wiper-Adaptives Nachwischen bei SRA	not active 	6
    ENG141682-ENG142250-Front_wiper-Anfahrzeit_servicestellung	800 ms	6
    ENG141682-ENG115836-Front_wiper-Frontwischer Notlaufprogramm	active 	6
    ENG141682-ENG116614-Front_wiper-Frontwischer Referenzlauf	active 	6
    ENG141682-ENG154620-Front_wiper-Frontwischer Spannungsanforderung_konfig	Keine_Spannungsanforderung 	6
    ENG141682-ENG133394-Front_wiper-Frontwischer_Abtauposition	not active 	6
    ENG141682-ENG141966-Front_wiper-Frontwischertyp	LIN 	6
    ENG141682-ENG116617-Front_wiper-Geschwindigkeitsabhaengige Wischstufenrueckschaltung	active 	6
    ENG141682-ENG116615-Front_wiper-Menuesteuerung Frontwischer	not active 	6
    ENG141682-ENG154706-Front_wiper-Mindestwaschzeit_Frontwischer	0 ms	6
    ENG141682-ENG115771-Front_wiper-Regensensor aktivieren	Deactivating 	6
    ENG141682-ENG154790-Front_wiper-Timer_DWP_SRA_delay	300 ms	6
    ENG141682-ENG116616-Front_wiper-Tippwischen mit erhoehter Wischfrequenz	active 	6
    ENG141682-ENG116618-Front_wiper-Traenenwischen Front Status	not active 	6
    ENG141682-ENG115770-Front_wiper-Variable Regensensoraktivierung	not active 	6
    ENG141682-ENG126844-Front_wiper-Washer_Tipwiping_Variant	not active 	6
    ENG141682-ENG116613-Front_wiper-Wischer abparken bei Oeffnen der Motorhaube	not active 	6
    ENG141682-ENG116612-Front_wiper-Wischer stop bei KL15 aus	not active 	6
    ENG141682-ENG122185-Front_wiper-Wischer Stopp bei Oeffnen der Motorhaube	active 	6
    ENG99457-ENG117394-Head area heater-blower_speed	1	2
    ENG99457-ENG98971-Head area heater-Temperature	-2	2
    ENG141645-MAS00211-HW_Verbau-Insufficient brake fluid	installed 	8
    ENG141645-MAS00212-HW_Verbau-Insufficient washer fluid	installed 	8
    ENG141645-MAS00213-HW_Verbau-Insufficient coolant	installed 	8
    ENG141645-MAS00214-HW_Verbau-Brake pad wear	not installed 	8
    ENG141645-ENG142026-HW_Verbau-Druckklappe	not installed 	8
    ENG141645-ENG141963-HW_Verbau-Elektrische Laderaumabdeckung aktiv	not active 	8
    ENG141645-ENG142012-HW_Verbau-Elektrische_Laderaumabdeckung	not installed 	8
    ENG141645-ENG141952-HW_Verbau-Exterior temp. sensor	installed 	8
    ENG141645-ENG142005-HW_Verbau-Kontaktschalter_fuer_Motorhaube	installed 	8
    ENG141645-ENG142186-HW_Verbau-Ladesteckerverriegelung	not installed 	8
    ENG141645-ENG142036-HW_Verbau-PTC Zuheizer	not installed 	8
    ENG141645-ENG115809-HW_Verbau-Signalhorn ohne KL15	active 	8
    ENG141645-ENG142003-HW_Verbau-Status_Tankdeckelverriegelung	not active 	8
    ENG141660-ENG115658-Kennlinie_sLWR_Soll-x0	100.00%	30
    ENG141660-ENG101574-Kennlinie_sLWR_Soll-X1	100.00%	30
    ENG141660-ENG99557-Kennlinie_sLWR_Soll-X2	100.00%	30
    ENG141660-ENG102140-Kennlinie_sLWR_Soll-X3	100.00%	30
    ENG141660-ENG102936-Kennlinie_sLWR_Soll-X4	83.00%	30
    ENG141660-ENG103548-Kennlinie_sLWR_Soll-X5	67.00%	30
    ENG141660-ENG113992-Kennlinie_sLWR_Soll-X6	50.00%	30
    ENG141660-ENG115661-Kennlinie_sLWR_Soll-x7	33	30
    ENG141660-ENG115662-Kennlinie_sLWR_Soll-x8	17.00%	30
    ENG141660-ENG115663-Kennlinie_sLWR_Soll-x9	0.00%	30
    ENG141660-ENG115659-Kennlinie_sLWR_Soll-y0	58.50%	30
    ENG141660-ENG99777-Kennlinie_sLWR_Soll-Y1	58.50%	30
    ENG141660-ENG100480-Kennlinie_sLWR_Soll-Y2	58.50%	30
    ENG141660-ENG100773-Kennlinie_sLWR_Soll-Y3	58.50%	30
    ENG141660-ENG100631-Kennlinie_sLWR_Soll-Y4	54.50%	30
    ENG141660-ENG102174-Kennlinie_sLWR_Soll-Y5	49.50%	30
    ENG141660-ENG113993-Kennlinie_sLWR_Soll-Y6	46.50%	30
    ENG141660-ENG115665-Kennlinie_sLWR_Soll-y7	35.50%	30
    ENG141660-ENG115666-Kennlinie_sLWR_Soll-y8	31.50%	30
    ENG141660-ENG115667-Kennlinie_sLWR_Soll-y9	20.00%	30
    ENG116936-ENG115883-Leuchte 0 BLK VL B36-Dimming Direction CD 0	maximize 	16
    ENG116936-ENG115887-Leuchte 0 BLK VL B36-Dimming Direction EF 0	maximize 	16
    ENG116936-ENG115891-Leuchte 0 BLK VL B36-Dimming Direction GH 0	maximize 	16
    ENG116936-ENG115878-Leuchte 0 BLK VL B36-Dimmwert AB 0	100	16
    ENG116936-ENG115882-Leuchte 0 BLK VL B36-Dimmwert CD 0	0	16
    ENG116936-ENG115886-Leuchte 0 BLK VL B36-Dimmwert EF 0	0	16
    ENG116936-ENG115890-Leuchte 0 BLK VL B36-Dimmwert GH 0	0	16
    ENG116936-ENG115875-Leuchte 0 BLK VL B36-Fehlerort mittleres Byte DTC-DFCC 0	14	16
    ENG116936-ENG116547-Leuchte 0 BLK VL B36-Lampendefektbit Position 0	34	16
    ENG116936-ENG115873-Leuchte 0 BLK VL B36-Lasttyp 0	12 - Blinkleuchten 	16
    ENG116936-ENG115879-Leuchte 0 BLK VL B36-Lichtansteuerung HD AB 0	Always 	16
    ENG116936-ENG115876-Leuchte 0 BLK VL B36-Lichtfunktion A 0	Blinken links Hellphase 	16
    ENG116936-ENG115877-Leuchte 0 BLK VL B36-Lichtfunktion B 0	not active 	16
    ENG116936-ENG115880-Leuchte 0 BLK VL B36-Lichtfunktion C 0	not active 	16
    ENG116936-ENG115881-Leuchte 0 BLK VL B36-Lichtfunktion D 0	not active 	16
    ENG116936-ENG115884-Leuchte 0 BLK VL B36-Lichtfunktion E 0	not active 	16
    ENG116936-ENG115885-Leuchte 0 BLK VL B36-Lichtfunktion F 0	not active 	16
    ENG116936-ENG115888-Leuchte 0 BLK VL B36-Lichtfunktion G 0	not active 	16
    ENG116936-ENG115889-Leuchte 0 BLK VL B36-Lichtfunktion H 0	not active 	16
    ENG141657-ENG116167-Leuchte 35 LED Warnblinktaster C48-Dimming Direction CD 15	maximize 	16
    ENG141657-ENG116171-Leuchte 35 LED Warnblinktaster C48-Dimming Direction EF 15	maximize 	16
    ENG141657-ENG116175-Leuchte 35 LED Warnblinktaster C48-Dimming Direction GH 15	maximize 	16
    ENG141657-ENG116162-Leuchte 35 LED Warnblinktaster C48-Dimmwert AB 15	100	16
    ENG141657-ENG116166-Leuchte 35 LED Warnblinktaster C48-Dimmwert CD 15	0	16
    ENG141657-ENG116170-Leuchte 35 LED Warnblinktaster C48-Dimmwert EF 15	0	16
    ENG141657-ENG116174-Leuchte 35 LED Warnblinktaster C48-Dimmwert GH 15	0	16
    ENG141657-ENG116159-Leuchte 35 LED Warnblinktaster C48-Fehlerort mittleres Byte DTC-DFCC 15	63	16
    ENG141657-ENG116566-Leuchte 35 LED Warnblinktaster C48-Lampendefektbitposition 15	0	16
    ENG141657-ENG116157-Leuchte 35 LED Warnblinktaster C48-Lasttyp 15	41 - LED Kleinleistung 	16
    ENG141657-ENG116163-Leuchte 35 LED Warnblinktaster C48-Lichtansteuerung HD AB 15	Always 	16
    ENG141657-ENG116160-Leuchte 35 LED Warnblinktaster C48-Lichtfunktion A 15	Unknown (76)	16
    ENG141657-ENG116161-Leuchte 35 LED Warnblinktaster C48-Lichtfunktion B 15	not active 	16
    ENG141657-ENG116164-Leuchte 35 LED Warnblinktaster C48-Lichtfunktion C 15	not active 	16
    ENG141657-ENG116165-Leuchte 35 LED Warnblinktaster C48-Lichtfunktion D 15	not active 	16
    ENG141657-ENG116168-Leuchte 35 LED Warnblinktaster C48-Lichtfunktion E 15	not active 	16
    ENG141657-ENG116169-Leuchte 35 LED Warnblinktaster C48-Lichtfunktion F 15	not active 	16
    ENG141657-ENG116172-Leuchte 35 LED Warnblinktaster C48-Lichtfunktion G 15	not active 	16
    ENG141657-ENG116173-Leuchte 35 LED Warnblinktaster C48-Lichtfunktion H 15	not active 	16
    ENG116946-ENG116072-Leuchte10SHUTTER LB23-Dimming Direction CD 10	maximize 	16
    ENG116946-ENG116076-Leuchte10SHUTTER LB23-Dimming Direction EF 10	maximize 	16
    ENG116946-ENG116080-Leuchte10SHUTTER LB23-Dimming Direction GH 10	maximize 	16
    ENG116946-ENG116067-Leuchte10SHUTTER LB23-Dimmwert AB 10	0	16
    ENG116946-ENG116071-Leuchte10SHUTTER LB23-Dimmwert CD 10	0	16
    ENG116946-ENG116075-Leuchte10SHUTTER LB23-Dimmwert EF 10	0	16
    ENG116946-ENG116079-Leuchte10SHUTTER LB23-Dimmwert GH 10	0	16
    ENG116946-ENG116064-Leuchte10SHUTTER LB23-Fehlerort mittleres Byte DTC-DFCC 10	0	16
    ENG116946-ENG116560-Leuchte10SHUTTER LB23-Lampendefektbitposition 10	0	16
    ENG116946-ENG116062-Leuchte10SHUTTER LB23-Lasttyp 10	not active 	16
    ENG116946-ENG116068-Leuchte10SHUTTER LB23-Lichtansteuerung HD AB 10	Always 	16
    ENG116946-ENG116065-Leuchte10SHUTTER LB23-Lichtfunktion A 10	not active 	16
    ENG116946-ENG116066-Leuchte10SHUTTER LB23-Lichtfunktion B 10	not active 	16
    ENG116946-ENG116069-Leuchte10SHUTTER LB23-Lichtfunktion C 10	not active 	16
    ENG116946-ENG116070-Leuchte10SHUTTER LB23-Lichtfunktion D 10	not active 	16
    ENG116946-ENG116073-Leuchte10SHUTTER LB23-Lichtfunktion E 10	not active 	16
    ENG116946-ENG116074-Leuchte10SHUTTER LB23-Lichtfunktion F 10	not active 	16
    ENG116946-ENG116077-Leuchte10SHUTTER LB23-Lichtfunktion G 10	not active 	16
    ENG116946-ENG116078-Leuchte10SHUTTER LB23-Lichtfunktion H 10	not active 	16
    ENG116947-ENG116091-Leuchte11SHUTTER RB22-Dimming Direction CD 11	maximize 	16
    ENG116947-ENG116095-Leuchte11SHUTTER RB22-Dimming Direction EF 11	maximize 	16
    ENG116947-ENG116099-Leuchte11SHUTTER RB22-Dimming Direction GH 11	maximize 	16
    ENG116947-ENG116086-Leuchte11SHUTTER RB22-Dimmwert AB 11	0	16
    ENG116947-ENG116090-Leuchte11SHUTTER RB22-Dimmwert CD 11	0	16
    ENG116947-ENG116094-Leuchte11SHUTTER RB22-Dimmwert EF 11	0	16
    ENG116947-ENG116098-Leuchte11SHUTTER RB22-Dimmwert GH 11	0	16
    ENG116947-ENG116083-Leuchte11SHUTTER RB22-Fehlerort mittleres Byte DTC-DFCC 11	0	16
    ENG116947-ENG116561-Leuchte11SHUTTER RB22-Lampendefektbitposition 11	0	16
    ENG116947-ENG116081-Leuchte11SHUTTER RB22-Lasttyp 11	not active 	16
    ENG116947-ENG116087-Leuchte11SHUTTER RB22-Lichtansteuerung HD AB 11	Always 	16
    ENG116947-ENG116084-Leuchte11SHUTTER RB22-Lichtfunktion A 11	not active 	16
    ENG116947-ENG116085-Leuchte11SHUTTER RB22-Lichtfunktion B 11	not active 	16
    ENG116947-ENG116088-Leuchte11SHUTTER RB22-Lichtfunktion C 11	not active 	16
    ENG116947-ENG116089-Leuchte11SHUTTER RB22-Lichtfunktion D 11	not active 	16
    ENG116947-ENG116092-Leuchte11SHUTTER RB22-Lichtfunktion E 11	not active 	16
    ENG116947-ENG116093-Leuchte11SHUTTER RB22-Lichtfunktion F 11	not active 	16
    ENG116947-ENG116096-Leuchte11SHUTTER RB22-Lichtfunktion G 11	not active 	16
    ENG116947-ENG116097-Leuchte11SHUTTER RB22-Lichtfunktion H 11	not active 	16
    ENG116948-ENG116110-Leuchte12NL LB45-Dimming Direction CD 12	maximize 	16
    ENG116948-ENG116114-Leuchte12NL LB45-Dimming Direction EF 12	maximize 	16
    ENG116948-ENG116118-Leuchte12NL LB45-Dimming Direction GH 12	maximize 	16
    ENG116948-ENG116105-Leuchte12NL LB45-Dimmwert AB 12	100	16
    ENG116948-ENG116109-Leuchte12NL LB45-Dimmwert CD 12	0	16
    ENG116948-ENG116113-Leuchte12NL LB45-Dimmwert EF 12	0	16
    ENG116948-ENG116117-Leuchte12NL LB45-Dimmwert GH 12	0	16
    ENG116948-ENG116102-Leuchte12NL LB45-Fehlerort mittleres Byte DTC-DFCC 12	22	16
    ENG116948-ENG116562-Leuchte12NL LB45-Lampendefektbitposition 12	38	16
    ENG116948-ENG116100-Leuchte12NL LB45-Lasttyp 12	10 - allgemeine Scheinwerfer 	16
    ENG116948-ENG116106-Leuchte12NL LB45-Lichtansteuerung HD AB 12	Always 	16
    ENG116948-ENG116103-Leuchte12NL LB45-Lichtfunktion A 12	Nebellicht links 	16
    ENG116948-ENG116104-Leuchte12NL LB45-Lichtfunktion B 12	Abbiegelicht links 	16
    ENG116948-ENG116107-Leuchte12NL LB45-Lichtfunktion C 12	not active 	16
    ENG116948-ENG116108-Leuchte12NL LB45-Lichtfunktion D 12	not active 	16
    ENG116948-ENG116111-Leuchte12NL LB45-Lichtfunktion E 12	not active 	16
    ENG116948-ENG116112-Leuchte12NL LB45-Lichtfunktion F 12	not active 	16
    ENG116948-ENG116115-Leuchte12NL LB45-Lichtfunktion G 12	not active 	16
    ENG116948-ENG116116-Leuchte12NL LB45-Lichtfunktion H 12	not active 	16
    ENG116949-ENG116129-Leuchte13NL RB5-Dimming Direction CD 13	maximize 	16
    ENG116949-ENG116133-Leuchte13NL RB5-Dimming Direction EF 13	maximize 	16
    ENG116949-ENG116137-Leuchte13NL RB5-Dimming Direction GH 13	maximize 	16
    ENG116949-ENG116124-Leuchte13NL RB5-Dimmwert AB 13	100	16
    ENG116949-ENG116128-Leuchte13NL RB5-Dimmwert CD 13	0	16
    ENG116949-ENG116132-Leuchte13NL RB5-Dimmwert EF 13	0	16
    ENG116949-ENG116136-Leuchte13NL RB5-Dimmwert GH 13	0	16
    ENG116949-ENG116121-Leuchte13NL RB5-Fehlerort mittleres Byte DTC-DFCC 13	23	16
    ENG116949-ENG116563-Leuchte13NL RB5-Lampendefektbitposition 13	42	16
    ENG116949-ENG116119-Leuchte13NL RB5-Lasttyp 13	10 - allgemeine Scheinwerfer 	16
    ENG116949-ENG116125-Leuchte13NL RB5-Lichtansteuerung HD AB 13	Always 	16
    ENG116949-ENG116122-Leuchte13NL RB5-Lichtfunktion A 13	Nebellicht rechts 	16
    ENG116949-ENG116123-Leuchte13NL RB5-Lichtfunktion B 13	Abbiegelicht rechts 	16
    ENG116949-ENG116564-Leuchte13NL RB5-Lichtfunktion C 13	not active 	16
    ENG116949-ENG116127-Leuchte13NL RB5-Lichtfunktion D 13	not active 	16
    ENG116949-ENG116130-Leuchte13NL RB5-Lichtfunktion E 13	not active 	16
    ENG116949-ENG116131-Leuchte13NL RB5-Lichtfunktion F 13	not active 	16
    ENG116949-ENG116134-Leuchte13NL RB5-Lichtfunktion G 13	not active 	16
    ENG116949-ENG116135-Leuchte13NL RB5-Lichtfunktion H 13	not active 	16
    ENG116952-ENG116186-Leuchte16BLK SLB35BLK SL KC9-Dimming Direction CD 16	maximize 	16
    ENG116952-ENG116190-Leuchte16BLK SLB35BLK SL KC9-Dimming Direction EF 16	maximize 	16
    ENG116952-ENG116194-Leuchte16BLK SLB35BLK SL KC9-Dimming Direction GH 16	maximize 	16
    ENG116952-ENG116181-Leuchte16BLK SLB35BLK SL KC9-Dimmwert AB 16	127	16
    ENG116952-ENG116185-Leuchte16BLK SLB35BLK SL KC9-Dimmwert CD 16	0	16
    ENG116952-ENG116189-Leuchte16BLK SLB35BLK SL KC9-Dimmwert EF 16	0	16
    ENG116952-ENG116193-Leuchte16BLK SLB35BLK SL KC9-Dimmwert GH 16	0	16
    ENG116952-ENG116178-Leuchte16BLK SLB35BLK SL KC9-Fehlerort mittleres Byte DTC-DFCC 16	36	16
    ENG116952-ENG116567-Leuchte16BLK SLB35BLK SL KC9-Lampendefektbitposition 16	0	16
    ENG116952-ENG116176-Leuchte16BLK SLB35BLK SL KC9-Lasttyp 16	43 - allgemeine LED 	16
    ENG116952-ENG116182-Leuchte16BLK SLB35BLK SL KC9-Lichtansteuerung HD AB 16	only_if_closed 	16
    ENG116952-ENG116179-Leuchte16BLK SLB35BLK SL KC9-Lichtfunktion A 16	Standlicht allgemein (Schlusslicht: Positionslicht: Begrenzungslicht) 	16
    ENG116952-ENG116180-Leuchte16BLK SLB35BLK SL KC9-Lichtfunktion B 16	not active 	16
    ENG116952-ENG116183-Leuchte16BLK SLB35BLK SL KC9-Lichtfunktion C 16	not active 	16
    ENG116952-ENG116184-Leuchte16BLK SLB35BLK SL KC9-Lichtfunktion D 16	not active 	16
    ENG116952-ENG116187-Leuchte16BLK SLB35BLK SL KC9-Lichtfunktion E 16	not active 	16
    ENG116952-ENG116188-Leuchte16BLK SLB35BLK SL KC9-Lichtfunktion F 16	not active 	16
    ENG116952-ENG116191-Leuchte16BLK SLB35BLK SL KC9-Lichtfunktion G 16	not active 	16
    ENG116952-ENG116192-Leuchte16BLK SLB35BLK SL KC9-Lichtfunktion H 16	not active 	16
    ENG116953-ENG116205-Leuchte17TFL R BLK SRB3TFL R BLK SR KC3-Dimming Direction CD 17	maximize 	16
    ENG116953-ENG116209-Leuchte17TFL R BLK SRB3TFL R BLK SR KC3-Dimming Direction EF 17	maximize 	16
    ENG116953-ENG116213-Leuchte17TFL R BLK SRB3TFL R BLK SR KC3-Dimming Direction GH 17	maximize 	16
    ENG116953-ENG116200-Leuchte17TFL R BLK SRB3TFL R BLK SR KC3-Dimmwert AB 17	127	16
    ENG116953-ENG116204-Leuchte17TFL R BLK SRB3TFL R BLK SR KC3-Dimmwert CD 17	0	16
    ENG116953-ENG116208-Leuchte17TFL R BLK SRB3TFL R BLK SR KC3-Dimmwert EF 17	0	16
    ENG116953-ENG116212-Leuchte17TFL R BLK SRB3TFL R BLK SR KC3-Dimmwert GH 17	0	16
    ENG116953-ENG116197-Leuchte17TFL R BLK SRB3TFL R BLK SR KC3-Fehlerort mittleres Byte DTC-DFCC 17	35	16
    ENG116953-ENG116568-Leuchte17TFL R BLK SRB3TFL R BLK SR KC3-Lampendefektbitposition 17	0	16
    ENG116953-ENG116195-Leuchte17TFL R BLK SRB3TFL R BLK SR KC3-Lasttyp 17	43 - allgemeine LED 	16
    ENG116953-ENG116201-Leuchte17TFL R BLK SRB3TFL R BLK SR KC3-Lichtansteuerung HD AB 17	only_if_closed 	16
    ENG116953-ENG116198-Leuchte17TFL R BLK SRB3TFL R BLK SR KC3-Lichtfunktion A 17	Standlicht allgemein (Schlusslicht: Positionslicht: Begrenzungslicht) 	16
    ENG116953-ENG116569-Leuchte17TFL R BLK SRB3TFL R BLK SR KC3-Lichtfunktion B 17	not active 	16
    ENG116953-ENG116202-Leuchte17TFL R BLK SRB3TFL R BLK SR KC3-Lichtfunktion C 17	not active 	16
    ENG116953-ENG116203-Leuchte17TFL R BLK SRB3TFL R BLK SR KC3-Lichtfunktion D 17	not active 	16
    ENG116953-ENG116206-Leuchte17TFL R BLK SRB3TFL R BLK SR KC3-Lichtfunktion E 17	not active 	16
    ENG116953-ENG116207-Leuchte17TFL R BLK SRB3TFL R BLK SR KC3-Lichtfunktion F 17	not active 	16
    ENG116953-ENG116210-Leuchte17TFL R BLK SRB3TFL R BLK SR KC3-Lichtfunktion G 17	not active 	16
    ENG116953-ENG116211-Leuchte17TFL R BLK SRB3TFL R BLK SR KC3-Lichtfunktion H 17	not active 	16
    ENG116954-ENG116224-Leuchte18BLK HLA60-Dimming Direction CD 18	maximize 	16
    ENG116954-ENG116228-Leuchte18BLK HLA60-Dimming Direction EF 18	maximize 	16
    ENG116954-ENG116232-Leuchte18BLK HLA60-Dimming Direction GH 18	maximize 	16
    ENG116954-ENG116219-Leuchte18BLK HLA60-Dimmwert AB 18	0	16
    ENG116954-ENG116223-Leuchte18BLK HLA60-Dimmwert CD 18	0	16
    ENG116954-ENG116227-Leuchte18BLK HLA60-Dimmwert EF 18	0	16
    ENG116954-ENG116231-Leuchte18BLK HLA60-Dimmwert GH 18	0	16
    ENG116954-ENG116216-Leuchte18BLK HLA60-Fehlerort mittleres Byte DTC-DFCC 18	0	16
    ENG116954-ENG116570-Leuchte18BLK HLA60-Lampendefektbitposition 18	0	16
    ENG116954-ENG116214-Leuchte18BLK HLA60-Lasttyp 18	not active 	16
    ENG116954-ENG116220-Leuchte18BLK HLA60-Lichtansteuerung HD AB 18	Always 	16
    ENG116954-ENG116217-Leuchte18BLK HLA60-Lichtfunktion A 18	not active 	16
    ENG116954-ENG116218-Leuchte18BLK HLA60-Lichtfunktion B 18	not active 	16
    ENG116954-ENG116221-Leuchte18BLK HLA60-Lichtfunktion C 18	not active 	16
    ENG116954-ENG116222-Leuchte18BLK HLA60-Lichtfunktion D 18	not active 	16
    ENG116954-ENG116225-Leuchte18BLK HLA60-Lichtfunktion E 18	not active 	16
    ENG116954-ENG116226-Leuchte18BLK HLA60-Lichtfunktion F 18	not active 	16
    ENG116954-ENG116229-Leuchte18BLK HLA60-Lichtfunktion G 18	not active 	16
    ENG116954-ENG116230-Leuchte18BLK HLA60-Lichtfunktion H 18	not active 	16
    ENG116955-ENG116243-Leuchte19BLK HRC31-Dimming Direction CD 19	maximize 	16
    ENG116955-ENG116247-Leuchte19BLK HRC31-Dimming Direction EF 19	maximize 	16
    ENG116955-ENG116251-Leuchte19BLK HRC31-Dimming Direction GH 19	maximize 	16
    ENG116955-ENG116238-Leuchte19BLK HRC31-Dimmwert AB 19	0	16
    ENG116955-ENG116242-Leuchte19BLK HRC31-Dimmwert CD 19	0	16
    ENG116955-ENG116246-Leuchte19BLK HRC31-Dimmwert EF 19	0	16
    ENG116955-ENG116250-Leuchte19BLK HRC31-Dimmwert GH 19	0	16
    ENG116955-ENG116235-Leuchte19BLK HRC31-Fehlerort mittleres Byte DTC-DFCC 19	0	16
    ENG116955-ENG116571-Leuchte19BLK HRC31-Lampendefektbitposition 19	0	16
    ENG116955-ENG116233-Leuchte19BLK HRC31-Lasttyp 19	not active 	16
    ENG116955-ENG116239-Leuchte19BLK HRC31-Lichtansteuerung HD AB 19	Always 	16
    ENG116955-ENG116236-Leuchte19BLK HRC31-Lichtfunktion A 19	not active 	16
    ENG116955-ENG116237-Leuchte19BLK HRC31-Lichtfunktion B 19	not active 	16
    ENG116955-ENG116240-Leuchte19BLK HRC31-Lichtfunktion C 19	not active 	16
    ENG116955-ENG116241-Leuchte19BLK HRC31-Lichtfunktion D 19	not active 	16
    ENG116955-ENG116244-Leuchte19BLK HRC31-Lichtfunktion E 19	not active 	16
    ENG116955-ENG116245-Leuchte19BLK HRC31-Lichtfunktion F 19	not active 	16
    ENG116955-ENG116248-Leuchte19BLK HRC31-Lichtfunktion G 19	not active 	16
    ENG116955-ENG116249-Leuchte19BLK HRC31-Lichtfunktion H 19	not active 	16
    ENG116937-ENG115902-Leuchte1BLK VRB20-Dimming Direction CD 1	maximize 	16
    ENG116937-ENG115906-Leuchte1BLK VRB20-Dimming Direction EF 1	maximize 	16
    ENG116937-ENG115909-Leuchte1BLK VRB20-Dimming Direction GH 1	maximize 	16
    ENG116937-ENG115897-Leuchte1BLK VRB20-Dimmwert AB 1	100	16
    ENG116937-ENG115901-Leuchte1BLK VRB20-Dimmwert CD 1	0	16
    ENG116937-ENG115905-Leuchte1BLK VRB20-Dimmwert EF 1	0	16
    ENG116937-ENG115908-Leuchte1BLK VRB20-Dimmwert GH 1	0	16
    ENG116937-ENG115894-Leuchte1BLK VRB20-Fehlerort mittleres Byte DTC-DFCC 1	15	16
    ENG116937-ENG116548-Leuchte1BLK VRB20-Lampendefektbitposition 1	3E 	16
    ENG116937-ENG115892-Leuchte1BLK VRB20-Lasttyp 1	12 - Blinkleuchten 	16
    ENG116937-ENG115898-Leuchte1BLK VRB20-Lichtansteuerung HD AB 1	Always 	16
    ENG116937-ENG115895-Leuchte1BLK VRB20-Lichtfunktion A 1	Blinken rechts Hellphase 	16
    ENG116937-ENG115896-Leuchte1BLK VRB20-Lichtfunktion B 1	not active 	16
    ENG116937-ENG115899-Leuchte1BLK VRB20-Lichtfunktion C 1	not active 	16
    ENG116937-ENG115900-Leuchte1BLK VRB20-Lichtfunktion D 1	not active 	16
    ENG116937-ENG115903-Leuchte1BLK VRB20-Lichtfunktion E 1	not active 	16
    ENG116937-ENG115904-Leuchte1BLK VRB20-Lichtfunktion F 1	not active 	16
    ENG116937-ENG115907-Leuchte1BLK VRB20-Lichtfunktion G 1	not active 	16
    ENG116937-ENG116549-Leuchte1BLK VRB20-Lichtfunktion H 1	not active 	16
    ENG116956-ENG116262-Leuchte20BR LA71-Dimming Direction CD 20	minimize 	16
    ENG116956-ENG116266-Leuchte20BR LA71-Dimming Direction EF 20	maximize 	16
    ENG116956-ENG116270-Leuchte20BR LA71-Dimming Direction GH 20	maximize 	16
    ENG116956-ENG116257-Leuchte20BR LA71-Dimmwert AB 20	100	16
    ENG116956-ENG116261-Leuchte20BR LA71-Dimmwert CD 20	0	16
    ENG116956-ENG116265-Leuchte20BR LA71-Dimmwert EF 20	0	16
    ENG116956-ENG116269-Leuchte20BR LA71-Dimmwert GH 20	0	16
    ENG116956-ENG116254-Leuchte20BR LA71-Fehlerort mittleres Byte DTC-DFCC 20	3D 	16
    ENG116956-ENG116572-Leuchte20BR LA71-Lampendefektbitposition 20	13	16
    ENG116956-ENG116252-Leuchte20BR LA71-Lasttyp 20	43 - allgemeine LED 	16
    ENG116956-ENG116258-Leuchte20BR LA71-Lichtansteuerung HD AB 20	Always 	16
    ENG116956-ENG116255-Leuchte20BR LA71-Lichtfunktion A 20	Brake light 	16
    ENG116956-ENG116256-Leuchte20BR LA71-Lichtfunktion B 20	Blinken links Hellphase 	16
    ENG116956-ENG116259-Leuchte20BR LA71-Lichtfunktion C 20	Blinken links Dunkelphase 	16
    ENG116956-ENG116260-Leuchte20BR LA71-Lichtfunktion D 20	not active 	16
    ENG116956-ENG116263-Leuchte20BR LA71-Lichtfunktion E 20	not active 	16
    ENG116956-ENG116264-Leuchte20BR LA71-Lichtfunktion F 20	not active 	16
    ENG116956-ENG116267-Leuchte20BR LA71-Lichtfunktion G 20	not active 	16
    ENG116956-ENG116268-Leuchte20BR LA71-Lichtfunktion H 20	not active 	16
    ENG116957-ENG116281-Leuchte21BR RC8-Dimming Direction CD 21	minimize 	16
    ENG116957-ENG116285-Leuchte21BR RC8-Dimming Direction EF 21	maximize 	16
    ENG116957-ENG116289-Leuchte21BR RC8-Dimming Direction GH 21	maximize 	16
    ENG116957-ENG116276-Leuchte21BR RC8-Dimmwert AB 21	100	16
    ENG116957-ENG116280-Leuchte21BR RC8-Dimmwert CD 21	0	16
    ENG116957-ENG116284-Leuchte21BR RC8-Dimmwert EF 21	0	16
    ENG116957-ENG116288-Leuchte21BR RC8-Dimmwert GH 21	0	16
    ENG116957-ENG116273-Leuchte21BR RC8-Fehlerort mittleres Byte DTC-DFCC 21	3E 	16
    ENG116957-ENG116573-Leuchte21BR RC8-Lampendefektbitposition 21	23	16
    ENG116957-ENG116271-Leuchte21BR RC8-Lasttyp 21	43 - allgemeine LED 	16
    ENG116957-ENG116277-Leuchte21BR RC8-Lichtansteuerung HD AB 21	Always 	16
    ENG116957-ENG116274-Leuchte21BR RC8-Lichtfunktion A 21	Brake light 	16
    ENG116957-ENG116275-Leuchte21BR RC8-Lichtfunktion B 21	Blinken rechts Hellphase 	16
    ENG116957-ENG116278-Leuchte21BR RC8-Lichtfunktion C 21	Blinken rechts Dunkelphase 	16
    ENG116957-ENG116279-Leuchte21BR RC8-Lichtfunktion D 21	not active 	16
    ENG116957-ENG116282-Leuchte21BR RC8-Lichtfunktion E 21	not active 	16
    ENG116957-ENG116283-Leuchte21BR RC8-Lichtfunktion F 21	not active 	16
    ENG116957-ENG116286-Leuchte21BR RC8-Lichtfunktion G 21	not active 	16
    ENG116957-ENG116287-Leuchte21BR RC8-Lichtfunktion H 21	not active 	16
    ENG116958-ENG116300-Leuchte22BR MA57-Dimming Direction CD 22	maximize 	16
    ENG116958-ENG116304-Leuchte22BR MA57-Dimming Direction EF 22	maximize 	16
    ENG116958-ENG116308-Leuchte22BR MA57-Dimming Direction GH 22	maximize 	16
    ENG116958-ENG116295-Leuchte22BR MA57-Dimmwert AB 22	127	16
    ENG116958-ENG116299-Leuchte22BR MA57-Dimmwert CD 22	0	16
    ENG116958-ENG116303-Leuchte22BR MA57-Dimmwert EF 22	0	16
    ENG116958-ENG116307-Leuchte22BR MA57-Dimmwert GH 22	0	16
    ENG116958-ENG116292-Leuchte22BR MA57-Fehlerort mittleres Byte DTC-DFCC 22	2C 	16
    ENG116958-ENG116574-Leuchte22BR MA57-Lampendefektbitposition 22	29	16
    ENG116958-ENG116290-Leuchte22BR MA57-Lasttyp 22	42 - LED dritte Bremsleuchte 	16
    ENG116958-ENG116296-Leuchte22BR MA57-Lichtansteuerung HD AB 22	Always 	16
    ENG116958-ENG116293-Leuchte22BR MA57-Lichtfunktion A 22	Brake light 	16
    ENG116958-ENG116294-Leuchte22BR MA57-Lichtfunktion B 22	Quittierungsfunktion 1 	16
    ENG116958-ENG116297-Leuchte22BR MA57-Lichtfunktion C 22	not active 	16
    ENG116958-ENG116298-Leuchte22BR MA57-Lichtfunktion D 22	not active 	16
    ENG116958-ENG116301-Leuchte22BR MA57-Lichtfunktion E 22	not active 	16
    ENG116958-ENG116302-Leuchte22BR MA57-Lichtfunktion F 22	not active 	16
    ENG116958-ENG116305-Leuchte22BR MA57-Lichtfunktion G 22	not active 	16
    ENG116958-ENG116306-Leuchte22BR MA57-Lichtfunktion H 22	not active 	16
    ENG116959-ENG116319-Leuchte23SL HLC10-Dimming Direction CD 23	maximize 	16
    ENG116959-ENG116323-Leuchte23SL HLC10-Dimming Direction EF 23	maximize 	16
    ENG116959-ENG116327-Leuchte23SL HLC10-Dimming Direction GH 23	maximize 	16
    ENG116959-ENG116314-Leuchte23SL HLC10-Dimmwert AB 23	127	16
    ENG116959-ENG116318-Leuchte23SL HLC10-Dimmwert CD 23	0	16
    ENG116959-ENG116322-Leuchte23SL HLC10-Dimmwert EF 23	0	16
    ENG116959-ENG116326-Leuchte23SL HLC10-Dimmwert GH 23	0	16
    ENG116959-ENG116311-Leuchte23SL HLC10-Fehlerort mittleres Byte DTC-DFCC 23	29	16
    ENG116959-ENG116575-Leuchte23SL HLC10-Lampendefektbitposition 23	0A 	16
    ENG116959-ENG116309-Leuchte23SL HLC10-Lasttyp 23	43 - allgemeine LED 	16
    ENG116959-ENG116315-Leuchte23SL HLC10-Lichtansteuerung HD AB 23	Always 	16
    ENG116959-ENG116312-Leuchte23SL HLC10-Lichtfunktion A 23	Standlicht allgemein (Schlusslicht: Positionslicht: Begrenzungslicht) 	16
    ENG116959-ENG116313-Leuchte23SL HLC10-Lichtfunktion B 23	not active 	16
    ENG116959-ENG116316-Leuchte23SL HLC10-Lichtfunktion C 23	not active 	16
    ENG116959-ENG116317-Leuchte23SL HLC10-Lichtfunktion D 23	not active 	16
    ENG116959-ENG116320-Leuchte23SL HLC10-Lichtfunktion E 23	not active 	16
    ENG116959-ENG116321-Leuchte23SL HLC10-Lichtfunktion F 23	not active 	16
    ENG116959-ENG116324-Leuchte23SL HLC10-Lichtfunktion G 23	not active 	16
    ENG116959-ENG116325-Leuchte23SL HLC10-Lichtfunktion H 23	not active 	16
    ENG116960-ENG116338-Leuchte24SL HRA65-Dimming Direction CD 24	maximize 	16
    ENG116960-ENG116342-Leuchte24SL HRA65-Dimming Direction EF 24	maximize 	16
    ENG116960-ENG116346-Leuchte24SL HRA65-Dimming Direction GH 24	maximize 	16
    ENG116960-ENG116333-Leuchte24SL HRA65-Dimmwert AB 24	127	16
    ENG116960-ENG116337-Leuchte24SL HRA65-Dimmwert CD 24	0	16
    ENG116960-ENG116341-Leuchte24SL HRA65-Dimmwert EF 24	0	16
    ENG116960-ENG116345-Leuchte24SL HRA65-Dimmwert GH 24	0	16
    ENG116960-ENG116330-Leuchte24SL HRA65-Fehlerort mittleres Byte DTC-DFCC 24	2A 	16
    ENG116960-ENG116576-Leuchte24SL HRA65-Lampendefektbitposition 24	1A 	16
    ENG116960-ENG116328-Leuchte24SL HRA65-Lasttyp 24	43 - allgemeine LED 	16
    ENG116960-ENG116334-Leuchte24SL HRA65-Lichtansteuerung HD AB 24	Always 	16
    ENG116960-ENG116331-Leuchte24SL HRA65-Lichtfunktion A 24	Standlicht allgemein (Schlusslicht: Positionslicht: Begrenzungslicht) 	16
    ENG116960-ENG116332-Leuchte24SL HRA65-Lichtfunktion B 24	not active 	16
    ENG116960-ENG116335-Leuchte24SL HRA65-Lichtfunktion C 24	not active 	16
    ENG116960-ENG116336-Leuchte24SL HRA65-Lichtfunktion D 24	not active 	16
    ENG116960-ENG116339-Leuchte24SL HRA65-Lichtfunktion E 24	not active 	16
    ENG116960-ENG116340-Leuchte24SL HRA65-Lichtfunktion F 24	not active 	16
    ENG116960-ENG116343-Leuchte24SL HRA65-Lichtfunktion G 24	not active 	16
    ENG116960-ENG116344-Leuchte24SL HRA65-Lichtfunktion H 24	not active 	16
    ENG116961-ENG116357-Leuchte25KZL HA59-Dimming Direction CD 25	maximize 	16
    ENG116961-ENG116361-Leuchte25KZL HA59-Dimming Direction EF 25	maximize 	16
    ENG116961-ENG116365-Leuchte25KZL HA59-Dimming Direction GH 25	maximize 	16
    ENG116961-ENG116352-Leuchte25KZL HA59-Dimmwert AB 25	127	16
    ENG116961-ENG116356-Leuchte25KZL HA59-Dimmwert CD 25	0	16
    ENG116961-ENG116360-Leuchte25KZL HA59-Dimmwert EF 25	0	16
    ENG116961-ENG116364-Leuchte25KZL HA59-Dimmwert GH 25	0	16
    ENG116961-ENG116349-Leuchte25KZL HA59-Fehlerort mittleres Byte DTC-DFCC 25	30	16
    ENG116961-ENG116577-Leuchte25KZL HA59-Lampendefektbitposition 25	28	16
    ENG116961-ENG116347-Leuchte25KZL HA59-Lasttyp 25	43 - allgemeine LED 	16
    ENG116961-ENG116353-Leuchte25KZL HA59-Lichtansteuerung HD AB 25	Always 	16
    ENG116961-ENG116350-Leuchte25KZL HA59-Lichtfunktion A 25	Standlicht allgemein (Schlusslicht: Positionslicht: Begrenzungslicht) 	16
    ENG116961-ENG116351-Leuchte25KZL HA59-Lichtfunktion B 25	not active 	16
    ENG116961-ENG116354-Leuchte25KZL HA59-Lichtfunktion C 25	not active 	16
    ENG116961-ENG116355-Leuchte25KZL HA59-Lichtfunktion D 25	not active 	16
    ENG116961-ENG116358-Leuchte25KZL HA59-Lichtfunktion E 25	not active 	16
    ENG116961-ENG116359-Leuchte25KZL HA59-Lichtfunktion F 25	not active 	16
    ENG116961-ENG116362-Leuchte25KZL HA59-Lichtfunktion G 25	not active 	16
    ENG116961-ENG116363-Leuchte25KZL HA59-Lichtfunktion H 25	not active 	16
    ENG116962-ENG116376-Leuchte26NSL LA72-Dimming Direction CD 26	maximize 	16
    ENG116962-ENG116380-Leuchte26NSL LA72-Dimming Direction EF 26	maximize 	16
    ENG116962-ENG116384-Leuchte26NSL LA72-Dimming Direction GH 26	maximize 	16
    ENG116962-ENG116371-Leuchte26NSL LA72-Dimmwert AB 26	127	16
    ENG116962-ENG116375-Leuchte26NSL LA72-Dimmwert CD 26	0	16
    ENG116962-ENG116379-Leuchte26NSL LA72-Dimmwert EF 26	0	16
    ENG116962-ENG116383-Leuchte26NSL LA72-Dimmwert GH 26	0	16
    ENG116962-ENG116368-Leuchte26NSL LA72-Fehlerort mittleres Byte DTC-DFCC 26	54	16
    ENG116962-ENG116578-Leuchte26NSL LA72-Lampendefektbitposition 26	0	16
    ENG116962-ENG116366-Leuchte26NSL LA72-Lasttyp 26	43 - allgemeine LED 	16
    ENG116962-ENG116372-Leuchte26NSL LA72-Lichtansteuerung HD AB 26	Always 	16
    ENG116962-ENG116369-Leuchte26NSL LA72-Lichtfunktion A 26	Standlicht allgemein (Schlusslicht: Positionslicht: Begrenzungslicht) 	16
    ENG116962-ENG116370-Leuchte26NSL LA72-Lichtfunktion B 26	not active 	16
    ENG116962-ENG116373-Leuchte26NSL LA72-Lichtfunktion C 26	not active 	16
    ENG116962-ENG116374-Leuchte26NSL LA72-Lichtfunktion D 26	not active 	16
    ENG116962-ENG116377-Leuchte26NSL LA72-Lichtfunktion E 26	not active 	16
    ENG116962-ENG116378-Leuchte26NSL LA72-Lichtfunktion F 26	not active 	16
    ENG116962-ENG116381-Leuchte26NSL LA72-Lichtfunktion G 26	not active 	16
    ENG116962-ENG116382-Leuchte26NSL LA72-Lichtfunktion H 26	not active 	16
    ENG116963-ENG116395-Leuchte27NSL RC6-Dimming Direction CD 27	maximize 	16
    ENG116963-ENG116399-Leuchte27NSL RC6-Dimming Direction EF 27	maximize 	16
    ENG116963-ENG116403-Leuchte27NSL RC6-Dimming Direction GH 27	maximize 	16
    ENG116963-ENG116390-Leuchte27NSL RC6-Dimmwert AB 27	127	16
    ENG116963-ENG116394-Leuchte27NSL RC6-Dimmwert CD 27	0	16
    ENG116963-ENG116398-Leuchte27NSL RC6-Dimmwert EF 27	0	16
    ENG116963-ENG116402-Leuchte27NSL RC6-Dimmwert GH 27	0	16
    ENG116963-ENG116387-Leuchte27NSL RC6-Fehlerort mittleres Byte DTC-DFCC 27	53	16
    ENG116963-ENG116579-Leuchte27NSL RC6-Lampendefektbitposition 27	0	16
    ENG116963-ENG116385-Leuchte27NSL RC6-Lasttyp 27	43 - allgemeine LED 	16
    ENG116963-ENG116391-Leuchte27NSL RC6-Lichtansteuerung HD AB 27	Always 	16
    ENG116963-ENG116388-Leuchte27NSL RC6-Lichtfunktion A 27	Standlicht allgemein (Schlusslicht: Positionslicht: Begrenzungslicht) 	16
    ENG116963-ENG116389-Leuchte27NSL RC6-Lichtfunktion B 27	not active 	16
    ENG116963-ENG116392-Leuchte27NSL RC6-Lichtfunktion C 27	not active 	16
    ENG116963-ENG116393-Leuchte27NSL RC6-Lichtfunktion D 27	not active 	16
    ENG116963-ENG116396-Leuchte27NSL RC6-Lichtfunktion E 27	not active 	16
    ENG116963-ENG116397-Leuchte27NSL RC6-Lichtfunktion F 27	not active 	16
    ENG116963-ENG116400-Leuchte27NSL RC6-Lichtfunktion G 27	not active 	16
    ENG116963-ENG116401-Leuchte27NSL RC6-Lichtfunktion H 27	not active 	16
    ENG116964-ENG116414-Leuchte28RFL LC11-Dimming Direction CD 28	maximize 	16
    ENG116964-ENG116418-Leuchte28RFL LC11-Dimming Direction EF 28	maximize 	16
    ENG116964-ENG116422-Leuchte28RFL LC11-Dimming Direction GH 28	maximize 	16
    ENG116964-ENG116409-Leuchte28RFL LC11-Dimmwert AB 28	127	16
    ENG116964-ENG116413-Leuchte28RFL LC11-Dimmwert CD 28	0	16
    ENG116964-ENG116417-Leuchte28RFL LC11-Dimmwert EF 28	0	16
    ENG116964-ENG116421-Leuchte28RFL LC11-Dimmwert GH 28	0	16
    ENG116964-ENG116406-Leuchte28RFL LC11-Fehlerort mittleres Byte DTC-DFCC 28	31	16
    ENG116964-ENG116580-Leuchte28RFL LC11-Lampendefektbitposition 28	0B 	16
    ENG116964-ENG116404-Leuchte28RFL LC11-Lasttyp 28	43 - allgemeine LED 	16
    ENG116964-ENG116410-Leuchte28RFL LC11-Lichtansteuerung HD AB 28	Always 	16
    ENG116964-ENG116407-Leuchte28RFL LC11-Lichtfunktion A 28	Rueckfahrlicht 	16
    ENG116964-ENG116408-Leuchte28RFL LC11-Lichtfunktion B 28	not active 	16
    ENG116964-ENG116411-Leuchte28RFL LC11-Lichtfunktion C 28	not active 	16
    ENG116964-ENG116412-Leuchte28RFL LC11-Lichtfunktion D 28	not active 	16
    ENG116964-ENG116415-Leuchte28RFL LC11-Lichtfunktion E 28	not active 	16
    ENG116964-ENG116416-Leuchte28RFL LC11-Lichtfunktion F 28	not active 	16
    ENG116964-ENG116419-Leuchte28RFL LC11-Lichtfunktion G 28	not active 	16
    ENG116964-ENG116420-Leuchte28RFL LC11-Lichtfunktion H 28	not active 	16
    ENG116965-ENG116433-Leuchte29RFL RA64-Dimming Direction CD 29	maximize 	16
    ENG116965-ENG116437-Leuchte29RFL RA64-Dimming Direction EF 29	maximize 	16
    ENG116965-ENG116441-Leuchte29RFL RA64-Dimming Direction GH 29	maximize 	16
    ENG116965-ENG116428-Leuchte29RFL RA64-Dimmwert AB 29	127	16
    ENG116965-ENG116432-Leuchte29RFL RA64-Dimmwert CD 29	0	16
    ENG116965-ENG116436-Leuchte29RFL RA64-Dimmwert EF 29	0	16
    ENG116965-ENG116440-Leuchte29RFL RA64-Dimmwert GH 29	0	16
    ENG116965-ENG116425-Leuchte29RFL RA64-Fehlerort mittleres Byte DTC-DFCC 29	32	16
    ENG116965-ENG116581-Leuchte29RFL RA64-Lampendefektbitposition 29	1B 	16
    ENG116965-ENG116423-Leuchte29RFL RA64-Lasttyp 29	43 - allgemeine LED 	16
    ENG116965-ENG116430-Leuchte29RFL RA64-Lichtansteuerung HD AB 29	Always 	16
    ENG116965-ENG116426-Leuchte29RFL RA64-Lichtfunktion A 29	Rueckfahrlicht 	16
    ENG116965-ENG116427-Leuchte29RFL RA64-Lichtfunktion B 29	not active 	16
    ENG116965-ENG116429-Leuchte29RFL RA64-Lichtfunktion C 29	not active 	16
    ENG116965-ENG116431-Leuchte29RFL RA64-Lichtfunktion D 29	not active 	16
    ENG116965-ENG116434-Leuchte29RFL RA64-Lichtfunktion E 29	not active 	16
    ENG116965-ENG116435-Leuchte29RFL RA64-Lichtfunktion F 29	not active 	16
    ENG116965-ENG116438-Leuchte29RFL RA64-Lichtfunktion G 29	not active 	16
    ENG116965-ENG116439-Leuchte29RFL RA64-Lichtfunktion H 29	not active 	16
    ENG116938-ENG115920-Leuchte2SL VLB10-Dimming Direction CD 2	minimize 	16
    ENG116938-ENG115924-Leuchte2SL VLB10-Dimming Direction EF 2	maximize 	16
    ENG116938-ENG115928-Leuchte2SL VLB10-Dimming Direction GH 2	maximize 	16
    ENG116938-ENG115915-Leuchte2SL VLB10-Dimmwert AB 2	100	16
    ENG116938-ENG115919-Leuchte2SL VLB10-Dimmwert CD 2	28	16
    ENG116938-ENG115923-Leuchte2SL VLB10-Dimmwert EF 2	28	16
    ENG116938-ENG115927-Leuchte2SL VLB10-Dimmwert GH 2	0	16
    ENG116938-ENG115912-Leuchte2SL VLB10-Fehlerort mittleres Byte DTC-DFCC 2	4A 	16
    ENG116938-ENG116550-Leuchte2SL VLB10-Lampendefektbitposition 2	48	16
    ENG116938-ENG115910-Leuchte2SL VLB10-Lasttyp 2	4 - LED Tagfahrlichtmodul Signal 	16
    ENG116938-ENG115916-Leuchte2SL VLB10-Lichtansteuerung HD AB 2	Always 	16
    ENG116938-ENG115913-Leuchte2SL VLB10-Lichtfunktion A 2	Daytime running lights 	16
    ENG116938-ENG115914-Leuchte2SL VLB10-Lichtfunktion B 2	not active 	16
    ENG116938-ENG115917-Leuchte2SL VLB10-Lichtfunktion C 2	Blinken links aktiv (beide Phasen) 	16
    ENG116938-ENG115918-Leuchte2SL VLB10-Lichtfunktion D 2	Nebellicht links 	16
    ENG116938-ENG115921-Leuchte2SL VLB10-Lichtfunktion E 2	Standlicht allgemein (Schlusslicht: Positionslicht: Begrenzungslicht) 	16
    ENG116938-ENG115922-Leuchte2SL VLB10-Lichtfunktion F 2	Parklicht links (beidseitiges Parklicht aktiviert li & re) 	16
    ENG116938-ENG115925-Leuchte2SL VLB10-Lichtfunktion G 2	not active 	16
    ENG116938-ENG115926-Leuchte2SL VLB10-Lichtfunktion H 2	not active 	16
    ENG116966-ENG116452-Leuchte30FR LC72-Dimming Direction CD 30	maximize 	16
    ENG116966-ENG116456-Leuchte30FR LC72-Dimming Direction EF 30	maximize 	16
    ENG116966-ENG116460-Leuchte30FR LC72-Dimming Direction GH 30	maximize 	16
    ENG116966-ENG116447-Leuchte30FR LC72-Dimmwert AB 30	89	16
    ENG116966-ENG116451-Leuchte30FR LC72-Dimmwert CD 30	0	16
    ENG116966-ENG116455-Leuchte30FR LC72-Dimmwert EF 30	0	16
    ENG116966-ENG116459-Leuchte30FR LC72-Dimmwert GH 30	0	16
    ENG116966-ENG116444-Leuchte30FR LC72-Fehlerort mittleres Byte DTC-DFCC 30	2	16
    ENG116966-ENG116582-Leuchte30FR LC72-Lampendefektbitposition 30	0	16
    ENG116966-ENG116442-Leuchte30FR LC72-Lasttyp 30	36 - LED Kleinleistung 	16
    ENG116966-ENG116448-Leuchte30FR LC72-Lichtansteuerung HD AB 30	Always 	16
    ENG116966-ENG116445-Leuchte30FR LC72-Lichtfunktion A 30	Footwell light 	16
    ENG116966-ENG116446-Leuchte30FR LC72-Lichtfunktion B 30	not active 	16
    ENG116966-ENG116449-Leuchte30FR LC72-Lichtfunktion C 30	not active 	16
    ENG116966-ENG116450-Leuchte30FR LC72-Lichtfunktion D 30	not active 	16
    ENG116966-ENG116453-Leuchte30FR LC72-Lichtfunktion E 30	not active 	16
    ENG116966-ENG116454-Leuchte30FR LC72-Lichtfunktion F 30	not active 	16
    ENG116966-ENG116457-Leuchte30FR LC72-Lichtfunktion G 30	not active 	16
    ENG116966-ENG116458-Leuchte30FR LC72-Lichtfunktion H 30	not active 	16
    ENG116967-ENG116471-Leuchte31AMBL 1C61-Dimming Direction CD 31	maximize 	16
    ENG116967-ENG116475-Leuchte31AMBL 1C61-Dimming Direction EF 31	maximize 	16
    ENG116967-ENG116479-Leuchte31AMBL 1C61-Dimming Direction GH 31	maximize 	16
    ENG116967-ENG116466-Leuchte31AMBL 1C61-Dimmwert AB 31	0	16
    ENG116967-ENG116470-Leuchte31AMBL 1C61-Dimmwert CD 31	0	16
    ENG116967-ENG116474-Leuchte31AMBL 1C61-Dimmwert EF 31	0	16
    ENG116967-ENG116478-Leuchte31AMBL 1C61-Dimmwert GH 31	0	16
    ENG116967-ENG116463-Leuchte31AMBL 1C61-Fehlerort mittleres Byte DTC-DFCC 31	0	16
    ENG116967-ENG116583-Leuchte31AMBL 1C61-Lampendefektbitposition 31	0	16
    ENG116967-ENG116461-Leuchte31AMBL 1C61-Lasttyp 31	not active 	16
    ENG116967-ENG116467-Leuchte31AMBL 1C61-Lichtansteuerung HD AB 31	Always 	16
    ENG116967-ENG116464-Leuchte31AMBL 1C61-Lichtfunktion A 31	not active 	16
    ENG116967-ENG116465-Leuchte31AMBL 1C61-Lichtfunktion B 31	not active 	16
    ENG116967-ENG116468-Leuchte31AMBL 1C61-Lichtfunktion C 31	not active 	16
    ENG116967-ENG116469-Leuchte31AMBL 1C61-Lichtfunktion D 31	not active 	16
    ENG116967-ENG116472-Leuchte31AMBL 1C61-Lichtfunktion E 31	not active 	16
    ENG116967-ENG116473-Leuchte31AMBL 1C61-Lichtfunktion F 31	not active 	16
    ENG116967-ENG116476-Leuchte31AMBL 1C61-Lichtfunktion G 31	not active 	16
    ENG116967-ENG116477-Leuchte31AMBL 1C61-Lichtfunktion H 31	not active 	16
    ENG116968-ENG116490-Leuchte32AMBL 2C35-Dimming Direction CD 32	maximize 	16
    ENG116968-ENG116494-Leuchte32AMBL 2C35-Dimming Direction EF 32	maximize 	16
    ENG116968-ENG116498-Leuchte32AMBL 2C35-Dimming Direction GH 32	maximize 	16
    ENG116968-ENG116485-Leuchte32AMBL 2C35-Dimmwert AB 32	0	16
    ENG116968-ENG116489-Leuchte32AMBL 2C35-Dimmwert CD 32	0	16
    ENG116968-ENG116493-Leuchte32AMBL 2C35-Dimmwert EF 32	0	16
    ENG116968-ENG116497-Leuchte32AMBL 2C35-Dimmwert GH 32	0	16
    ENG116968-ENG116482-Leuchte32AMBL 2C35-Fehlerort mittleres Byte DTC-DFCC 32	0	16
    ENG116968-ENG116584-Leuchte32AMBL 2C35-Lampendefektbitposition 32	0	16
    ENG116968-ENG116480-Leuchte32AMBL 2C35-Lasttyp 32	not active 	16
    ENG116968-ENG116486-Leuchte32AMBL 2C35-Lichtansteuerung HD AB 32	Always 	16
    ENG116968-ENG116483-Leuchte32AMBL 2C35-Lichtfunktion A 32	not active 	16
    ENG116968-ENG116484-Leuchte32AMBL 2C35-Lichtfunktion B 32	not active 	16
    ENG116968-ENG116487-Leuchte32AMBL 2C35-Lichtfunktion C 32	not active 	16
    ENG116968-ENG116488-Leuchte32AMBL 2C35-Lichtfunktion D 32	not active 	16
    ENG116968-ENG116491-Leuchte32AMBL 2C35-Lichtfunktion E 32	not active 	16
    ENG116968-ENG116492-Leuchte32AMBL 2C35-Lichtfunktion F 32	not active 	16
    ENG116968-ENG116495-Leuchte32AMBL 2C35-Lichtfunktion G 32	not active 	16
    ENG116968-ENG116496-Leuchte32AMBL 2C35-Lichtfunktion H 32	not active 	16
    ENG116969-ENG116509-Leuchte33AMBL 3C36-Dimming Direction CD 33	maximize 	16
    ENG116969-ENG116513-Leuchte33AMBL 3C36-Dimming Direction EF 33	maximize 	16
    ENG116969-ENG116517-Leuchte33AMBL 3C36-Dimming Direction GH 33	maximize 	16
    ENG116969-ENG116504-Leuchte33AMBL 3C36-Dimmwert AB 33	0	16
    ENG116969-ENG116508-Leuchte33AMBL 3C36-Dimmwert CD 33	0	16
    ENG116969-ENG116512-Leuchte33AMBL 3C36-Dimmwert EF 33	0	16
    ENG116969-ENG116516-Leuchte33AMBL 3C36-Dimmwert GH 33	0	16
    ENG116969-ENG116501-Leuchte33AMBL 3C36-Fehlerort mittleres Byte DTC-DFCC 33	0	16
    ENG116969-ENG116585-Leuchte33AMBL 3C36-Lampendefektbitposition 33	0	16
    ENG116969-ENG116499-Leuchte33AMBL 3C36-Lasttyp 33	not active 	16
    ENG116969-ENG116505-Leuchte33AMBL 3C36-Lichtansteuerung HD AB 33	Always 	16
    ENG116969-ENG116502-Leuchte33AMBL 3C36-Lichtfunktion A 33	not active 	16
    ENG116969-ENG116503-Leuchte33AMBL 3C36-Lichtfunktion B 33	not active 	16
    ENG116969-ENG116506-Leuchte33AMBL 3C36-Lichtfunktion C 33	not active 	16
    ENG116969-ENG116507-Leuchte33AMBL 3C36-Lichtfunktion D 33	not active 	16
    ENG116969-ENG116510-Leuchte33AMBL 3C36-Lichtfunktion E 33	not active 	16
    ENG116969-ENG116511-Leuchte33AMBL 3C36-Lichtfunktion F 33	not active 	16
    ENG116969-ENG116514-Leuchte33AMBL 3C36-Lichtfunktion G 33	not active 	16
    ENG116969-ENG116515-Leuchte33AMBL 3C36-Lichtfunktion H 33	not active 	16
    ENG116970-ENG116528-Leuchte34AMBL 4C37-Dimming Direction CD 34	maximize 	16
    ENG116970-ENG116532-Leuchte34AMBL 4C37-Dimming Direction EF 34	maximize 	16
    ENG116970-ENG116536-Leuchte34AMBL 4C37-Dimming Direction GH 34	maximize 	16
    ENG116970-ENG116523-Leuchte34AMBL 4C37-Dimmwert AB 34	0	16
    ENG116970-ENG116527-Leuchte34AMBL 4C37-Dimmwert CD 34	0	16
    ENG116970-ENG116531-Leuchte34AMBL 4C37-Dimmwert EF 34	0	16
    ENG116970-ENG116535-Leuchte34AMBL 4C37-Dimmwert GH 34	0	16
    ENG116970-ENG116520-Leuchte34AMBL 4C37-Fehlerort mittleres Byte DTC-DFCC 34	0	16
    ENG116970-ENG116586-Leuchte34AMBL 4C37-Lampendefektbitposition 34	0	16
    ENG116970-ENG116518-Leuchte34AMBL 4C37-Lasttyp 34	not active 	16
    ENG116970-ENG116524-Leuchte34AMBL 4C37-Lichtansteuerung HD AB 34	Always 	16
    ENG116970-ENG116521-Leuchte34AMBL 4C37-Lichtfunktion A 34	not active 	16
    ENG116970-ENG116522-Leuchte34AMBL 4C37-Lichtfunktion B 34	not active 	16
    ENG116970-ENG116525-Leuchte34AMBL 4C37-Lichtfunktion C 34	not active 	16
    ENG116970-ENG116526-Leuchte34AMBL 4C37-Lichtfunktion D 34	not active 	16
    ENG116970-ENG116529-Leuchte34AMBL 4C37-Lichtfunktion E 34	not active 	16
    ENG116970-ENG116530-Leuchte34AMBL 4C37-Lichtfunktion F 34	not active 	16
    ENG116970-ENG116533-Leuchte34AMBL 4C37-Lichtfunktion G 34	not active 	16
    ENG116970-ENG116534-Leuchte34AMBL 4C37-Lichtfunktion H 34	not active 	16
    ENG116939-ENG115939-Leuchte3SL VRB21-Dimming Direction CD 3	minimize 	16
    ENG116939-ENG115943-Leuchte3SL VRB21-Dimming Direction EF 3	maximize 	16
    ENG116939-ENG115947-Leuchte3SL VRB21-Dimming Direction GH 3	maximize 	16
    ENG116939-ENG115934-Leuchte3SL VRB21-Dimmwert AB 3	100	16
    ENG116939-ENG115938-Leuchte3SL VRB21-Dimmwert CD 3	28	16
    ENG116939-ENG115942-Leuchte3SL VRB21-Dimmwert EF 3	28	16
    ENG116939-ENG115946-Leuchte3SL VRB21-Dimmwert GH 3	0	16
    ENG116939-ENG115931-Leuchte3SL VRB21-Fehlerort mittleres Byte DTC-DFCC 3	4C 	16
    ENG116939-ENG116551-Leuchte3SL VRB21-Lampendefektbitposition 3	4C 	16
    ENG116939-ENG115929-Leuchte3SL VRB21-Lasttyp 3	4 - LED Tagfahrlichtmodul Signal 	16
    ENG116939-ENG115935-Leuchte3SL VRB21-Lichtansteuerung HD AB 3	Always 	16
    ENG116939-ENG115932-Leuchte3SL VRB21-Lichtfunktion A 3	Daytime running lights 	16
    ENG116939-ENG115933-Leuchte3SL VRB21-Lichtfunktion B 3	not active 	16
    ENG116939-ENG115936-Leuchte3SL VRB21-Lichtfunktion C 3	Blinken rechts aktiv (beide Phasen) 	16
    ENG116939-ENG115937-Leuchte3SL VRB21-Lichtfunktion D 3	Nebellicht rechts 	16
    ENG116939-ENG115940-Leuchte3SL VRB21-Lichtfunktion E 3	Standlicht allgemein (Schlusslicht: Positionslicht: Begrenzungslicht) 	16
    ENG116939-ENG116552-Leuchte3SL VRB21-Lichtfunktion F 3	Parking light right 	16
    ENG116939-ENG115944-Leuchte3SL VRB21-Lichtfunktion G 3	not active 	16
    ENG116939-ENG115945-Leuchte3SL VRB21-Lichtfunktion H 3	not active 	16
    ENG116940-ENG115958-Leuchte4TFL LB4-Dimming Direction CD 4	minimize 	16
    ENG116940-ENG115962-Leuchte4TFL LB4-Dimming Direction EF 4	maximize 	16
    ENG116940-ENG115966-Leuchte4TFL LB4-Dimming Direction GH 4	maximize 	16
    ENG116940-ENG115953-Leuchte4TFL LB4-Dimmwert AB 4	127	16
    ENG116940-ENG115957-Leuchte4TFL LB4-Dimmwert CD 4	0	16
    ENG116940-ENG115961-Leuchte4TFL LB4-Dimmwert EF 4	127	16
    ENG116940-ENG115965-Leuchte4TFL LB4-Dimmwert GH 4	0	16
    ENG116940-ENG115950-Leuchte4TFL LB4-Fehlerort mittleres Byte DTC-DFCC 4	49	16
    ENG116940-ENG116553-Leuchte4TFL LB4-Lampendefektbitposition 4	3A 	16
    ENG116940-ENG115948-Leuchte4TFL LB4-Lasttyp 4	1 - LED Tagfahrlichtmodul Versorgung 	16
    ENG116940-ENG115954-Leuchte4TFL LB4-Lichtansteuerung HD AB 4	Always 	16
    ENG116940-ENG115951-Leuchte4TFL LB4-Lichtfunktion A 4	Daytime running lights 	16
    ENG116940-ENG115952-Leuchte4TFL LB4-Lichtfunktion B 4	not active 	16
    ENG116940-ENG115955-Leuchte4TFL LB4-Lichtfunktion C 4	Blinken links aktiv (beide Phasen) 	16
    ENG116940-ENG115956-Leuchte4TFL LB4-Lichtfunktion D 4	not active 	16
    ENG116940-ENG115959-Leuchte4TFL LB4-Lichtfunktion E 4	Standlicht allgemein (Schlusslicht: Positionslicht: Begrenzungslicht) 	16
    ENG116940-ENG115960-Leuchte4TFL LB4-Lichtfunktion F 4	Parklicht links (beidseitiges Parklicht aktiviert li & re) 	16
    ENG116940-ENG115963-Leuchte4TFL LB4-Lichtfunktion G 4	not active 	16
    ENG116940-ENG115964-Leuchte4TFL LB4-Lichtfunktion H 4	not active 	16
    ENG116941-ENG115977-Leuchte5 TFL RB32-Dimming Direction CD 5	minimize 	16
    ENG116941-ENG115981-Leuchte5 TFL RB32-Dimming Direction EF 5	maximize 	16
    ENG116941-ENG115985-Leuchte5 TFL RB32-Dimming Direction GH 5	maximize 	16
    ENG116941-ENG115972-Leuchte5 TFL RB32-Dimmwert AB 5	127	16
    ENG116941-ENG115976-Leuchte5 TFL RB32-Dimmwert CD 5	0	16
    ENG116941-ENG115980-Leuchte5 TFL RB32-Dimmwert EF 5	127	16
    ENG116941-ENG115984-Leuchte5 TFL RB32-Dimmwert GH 5	0	16
    ENG116941-ENG115969-Leuchte5 TFL RB32-Fehlerort mittleres Byte DTC-DFCC 5	4B 	16
    ENG116941-ENG116554-Leuchte5 TFL RB32-Lampendefektbitposition 5	44	16
    ENG116941-ENG115967-Leuchte5 TFL RB32-Lasttyp 5	1 - LED Tagfahrlichtmodul Versorgung 	16
    ENG116941-ENG115973-Leuchte5 TFL RB32-Lichtansteuerung HD AB 5	Always 	16
    ENG116941-ENG115970-Leuchte5 TFL RB32-Lichtfunktion A 5	Daytime running lights 	16
    ENG116941-ENG115971-Leuchte5 TFL RB32-Lichtfunktion B 5	not active 	16
    ENG116941-ENG115974-Leuchte5 TFL RB32-Lichtfunktion C 5	Blinken rechts aktiv (beide Phasen) 	16
    ENG116941-ENG115975-Leuchte5 TFL RB32-Lichtfunktion D 5	not active 	16
    ENG116941-ENG115978-Leuchte5 TFL RB32-Lichtfunktion E 5	Standlicht allgemein (Schlusslicht: Positionslicht: Begrenzungslicht) 	16
    ENG116941-ENG116555-Leuchte5 TFL RB32-Lichtfunktion F 5	Parking light right 	16
    ENG116941-ENG115982-Leuchte5 TFL RB32-Lichtfunktion G 5	not active 	16
    ENG116941-ENG115983-Leuchte5 TFL RB32-Lichtfunktion H 5	not active 	16
    ENG116942-ENG115996-Leuchte6ABL LC5-Dimming Direction CD 6	maximize 	16
    ENG116942-ENG116000-Leuchte6ABL LC5-Dimming Direction EF 6	maximize 	16
    ENG116942-ENG116004-Leuchte6ABL LC5-Dimming Direction GH 6	maximize 	16
    ENG116942-ENG115991-Leuchte6ABL LC5-Dimmwert AB 6	100	16
    ENG116942-ENG115995-Leuchte6ABL LC5-Dimmwert CD 6	0	16
    ENG116942-ENG115999-Leuchte6ABL LC5-Dimmwert EF 6	0	16
    ENG116942-ENG116003-Leuchte6ABL LC5-Dimmwert GH 6	0	16
    ENG116942-ENG115988-Leuchte6ABL LC5-Fehlerort mittleres Byte DTC-DFCC 6	1A 	16
    ENG116942-ENG116556-Leuchte6ABL LC5-Lampendefektbitposition 6	36	16
    ENG116942-ENG115986-Leuchte6ABL LC5-Lasttyp 6	11 - Abblendlicht 	16
    ENG116942-ENG115992-Leuchte6ABL LC5-Lichtansteuerung HD AB 6	Always 	16
    ENG116942-ENG115989-Leuchte6ABL LC5-Lichtfunktion A 6	Abblendlicht links 	16
    ENG116942-ENG115990-Leuchte6ABL LC5-Lichtfunktion B 6	not active 	16
    ENG116942-ENG115993-Leuchte6ABL LC5-Lichtfunktion C 6	not active 	16
    ENG116942-ENG115994-Leuchte6ABL LC5-Lichtfunktion D 6	not active 	16
    ENG116942-ENG115997-Leuchte6ABL LC5-Lichtfunktion E 6	not active 	16
    ENG116942-ENG115998-Leuchte6ABL LC5-Lichtfunktion F 6	not active 	16
    ENG116942-ENG116001-Leuchte6ABL LC5-Lichtfunktion G 6	not active 	16
    ENG116942-ENG116002-Leuchte6ABL LC5-Lichtfunktion H 6	not active 	16
    ENG116943-ENG116015-Leuchte7ABL RB1-Dimming Direction CD 7	maximize 	16
    ENG116943-ENG116019-Leuchte7ABL RB1-Dimming Direction EF 7	maximize 	16
    ENG116943-ENG116023-Leuchte7ABL RB1-Dimming Direction GH 7	maximize 	16
    ENG116943-ENG116010-Leuchte7ABL RB1-Dimmwert AB 7	100	16
    ENG116943-ENG116014-Leuchte7ABL RB1-Dimmwert CD 7	0	16
    ENG116943-ENG116018-Leuchte7ABL RB1-Dimmwert EF 7	0	16
    ENG116943-ENG116022-Leuchte7ABL RB1-Dimmwert GH 7	0	16
    ENG116943-ENG116007-Leuchte7ABL RB1-Fehlerort mittleres Byte DTC-DFCC 7	1B 	16
    ENG116943-ENG116557-Leuchte7ABL RB1-Lampendefektbitposition 7	40	16
    ENG116943-ENG116005-Leuchte7ABL RB1-Lasttyp 7	11 - Abblendlicht 	16
    ENG116943-ENG116011-Leuchte7ABL RB1-Lichtansteuerung HD AB 7	Always 	16
    ENG116943-ENG116008-Leuchte7ABL RB1-Lichtfunktion A 7	Abblendlicht rechts 	16
    ENG116943-ENG116009-Leuchte7ABL RB1-Lichtfunktion B 7	not active 	16
    ENG116943-ENG116012-Leuchte7ABL RB1-Lichtfunktion C 7	not active 	16
    ENG116943-ENG116013-Leuchte7ABL RB1-Lichtfunktion D 7	not active 	16
    ENG116943-ENG116016-Leuchte7ABL RB1-Lichtfunktion E 7	not active 	16
    ENG116943-ENG116017-Leuchte7ABL RB1-Lichtfunktion F 7	not active 	16
    ENG116943-ENG116020-Leuchte7ABL RB1-Lichtfunktion G 7	not active 	16
    ENG116943-ENG116021-Leuchte7ABL RB1-Lichtfunktion H 7	not active 	16
    ENG116944-ENG116034-Leuchte8FL LB39-Dimming Direction CD 8	maximize 	16
    ENG116944-ENG116038-Leuchte8FL LB39-Dimming Direction EF 8	maximize 	16
    ENG116944-ENG116042-Leuchte8FL LB39-Dimming Direction GH 8	maximize 	16
    ENG116944-ENG116029-Leuchte8FL LB39-Dimmwert AB 8	100	16
    ENG116944-ENG116033-Leuchte8FL LB39-Dimmwert CD 8	0	16
    ENG116944-ENG116037-Leuchte8FL LB39-Dimmwert EF 8	0	16
    ENG116944-ENG116041-Leuchte8FL LB39-Dimmwert GH 8	0	16
    ENG116944-ENG116026-Leuchte8FL LB39-Fehlerort mittleres Byte DTC-DFCC 8	1C 	16
    ENG116944-ENG116558-Leuchte8FL LB39-Lampendefektbitposition 8	37	16
    ENG116944-ENG116024-Leuchte8FL LB39-Lasttyp 8	10 - allgemeine Scheinwerfer 	16
    ENG116944-ENG116030-Leuchte8FL LB39-Lichtansteuerung HD AB 8	Always 	16
    ENG116944-ENG116027-Leuchte8FL LB39-Lichtfunktion A 8	Left high beam 	16
    ENG116944-ENG116028-Leuchte8FL LB39-Lichtfunktion B 8	Lichthupe generell 	16
    ENG116944-ENG116031-Leuchte8FL LB39-Lichtfunktion C 8	not active 	16
    ENG116944-ENG116032-Leuchte8FL LB39-Lichtfunktion D 8	not active 	16
    ENG116944-ENG116035-Leuchte8FL LB39-Lichtfunktion E 8	not active 	16
    ENG116944-ENG116036-Leuchte8FL LB39-Lichtfunktion F 8	not active 	16
    ENG116944-ENG116039-Leuchte8FL LB39-Lichtfunktion G 8	not active 	16
    ENG116944-ENG116040-Leuchte8FL LB39-Lichtfunktion H 8	not active 	16
    ENG116945-ENG116053-Leuchte9FL RB2-Dimming Direction CD 9	maximize 	16
    ENG116945-ENG116057-Leuchte9FL RB2-Dimming Direction EF 9	maximize 	16
    ENG116945-ENG116061-Leuchte9FL RB2-Dimming Direction GH 9	maximize 	16
    ENG116945-ENG116048-Leuchte9FL RB2-Dimmwert AB 9	100	16
    ENG116945-ENG116052-Leuchte9FL RB2-Dimmwert CD 9	0	16
    ENG116945-ENG116056-Leuchte9FL RB2-Dimmwert EF 9	0	16
    ENG116945-ENG116060-Leuchte9FL RB2-Dimmwert GH 9	0	16
    ENG116945-ENG116045-Leuchte9FL RB2-Fehlerort mittleres Byte DTC-DFCC 9	1D 	16
    ENG116945-ENG116559-Leuchte9FL RB2-Lampendefektbitposition 9	41	16
    ENG116945-ENG116043-Leuchte9FL RB2-Lasttyp 9	10 - allgemeine Scheinwerfer 	16
    ENG116945-ENG116049-Leuchte9FL RB2-Lichtansteuerung HD AB 9	Always 	16
    ENG116945-ENG116046-Leuchte9FL RB2-Lichtfunktion A 9	Right high beam 	16
    ENG116945-ENG116047-Leuchte9FL RB2-Lichtfunktion B 9	Lichthupe generell 	16
    ENG116945-ENG116050-Leuchte9FL RB2-Lichtfunktion C 9	not active 	16
    ENG116945-ENG116051-Leuchte9FL RB2-Lichtfunktion D 9	not active 	16
    ENG116945-ENG116054-Leuchte9FL RB2-Lichtfunktion E 9	not active 	16
    ENG116945-ENG116055-Leuchte9FL RB2-Lichtfunktion F 9	not active 	16
    ENG116945-ENG116058-Leuchte9FL RB2-Lichtfunktion G 9	not active 	16
    ENG116945-ENG116059-Leuchte9FL RB2-Lichtfunktion H 9	not active 	16
    ENG141661-Leuchtenkonfiguration_Aussenlich_Heck	00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 2B 13 00 3D 18 02 64 03 00 80 00 00 00 00 00 00 2B 23 00 3E 18 04 64 05 00 80 00 00 00 00 00 00 2A 29 00 2C 18 24 7F 00 00 00 00 00 00 00 00 00 2B 0A 00 29 08 00 7F 00 00 00 00 00 00 00 00 00 2B 1A 00 2A 08 00 7F 00 00 00 00 00 00 00 00 00 2B 28 00 30 08 00 7F 00 00 00 00 00 00 00 00 00 2B 00 00 54 08 00 7F 00 00 00 00 00 00 00 00 00 2B 00 00 53 08 00 7F 00 00 00 00 00 00 00 00 00 2B 0B 00 31 19 00 7F 00 00 00 00 00 00 00 00 00 2B 1B 00 32 19 00 7F 00 00 00 00 00 00 00 00 00 	192
    ENG141662-Leuchtenkonfiguration_Sonstiges	2B 00 00 36 08 00 FF 00 00 00 00 00 00 00 00 00 2B 00 00 35 08 00 FF 00 00 00 00 00 00 00 00 00 24 00 00 02 2B 00 59 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 29 00 00 63 4C 00 64 00 00 00 00 00 00 00 00 00 	128
    ENG141658-ENG142197-Leuchtweitenregulierung-1_Sensor_LWR	1-Sensor_LWR 	62
    ENG141658-ENG142219-Leuchtweitenregulierung-Achsabstand_des_Fahrzeuges	0 mm	62
    ENG141658-ENG142201-Leuchtweitenregulierung-Aktivierung_LWR_Fehlerlampe	not active 	62
    ENG141658-ENG142211-Leuchtweitenregulierung-Ansteuerung_obere_grenze	100.00%	62
    ENG141658-ENG142210-Leuchtweitenregulierung-Ansteuerung_untere_grenze	0.00%	62
    ENG141658-ENG154591-Leuchtweitenregulierung-Delay_DC_Motor_Versorgung	-101.5 ms	62
    ENG141658-ENG142209-Leuchtweitenregulierung-diagnose_soll_toleranz	15%	62
    ENG141658-ENG142203-Leuchtweitenregulierung-Entprellung_Fehlerlampe	10.0 s	62
    ENG141658-ENG142214-Leuchtweitenregulierung-fac_Pwm_Zu_Hoehe_H_1	-8.00 mm/%	62
    ENG141658-ENG142216-Leuchtweitenregulierung-fac_Pwm_Zu_Hoehe_H_2	-8.00 mm/%	62
    ENG141658-ENG154599-Leuchtweitenregulierung-fac_Pwm_Zu_Hoehe_H_3	-8.00 mm/%	62
    ENG141658-ENG142213-Leuchtweitenregulierung-fac_Pwm_Zu_Hoehe_V_1	-8.00 mm/%	62
    ENG141658-ENG142215-Leuchtweitenregulierung-fac_Pwm_Zu_Hoehe_V_2	-8.00 mm/%	62
    ENG141658-ENG154600-Leuchtweitenregulierung-fac_Pwm_Zu_Hoehe_V_3	-8.00 mm/%	62
    ENG141658-ENG142198-Leuchtweitenregulierung-Fahrwerk_Variante	Variante_1 	62
    ENG141658-ENG142204-Leuchtweitenregulierung-Fail_Safe_sLWR	0.00%	62
    ENG141658-ENG142223-Leuchtweitenregulierung-fFiltEinf	0.00 Hz	62
    ENG141658-ENG142212-Leuchtweitenregulierung-Lineare_Abbildung	normal 	62
    ENG141658-ENG142202-Leuchtweitenregulierung-Logik_PWM_Signal	Negative 	62
    ENG141658-ENG154702-Leuchtweitenregulierung-lwr_lEinfOffsHFahrw_1	0 mm	62
    ENG141658-ENG154703-Leuchtweitenregulierung-lwr_lEinfOffsHFahrw_2	0 mm	62
    ENG141658-ENG154704-Leuchtweitenregulierung-lwr_lEinfOffsHFahrw_3	0 mm	62
    ENG141658-ENG154705-Leuchtweitenregulierung-lwr_lEinfOffsHFahrw_4	0 mm	62
    ENG141658-ENG142220-Leuchtweitenregulierung-lwr_lFzg_Sw_Abstand	0 mm	62
    ENG141658-ENG142221-Leuchtweitenregulierung-lwr_lFzg_Sw_Hoehe	0 mm	62
    ENG141658-ENG142226-Leuchtweitenregulierung-lwr_pwm_obere_schwelle	95.00%	62
    ENG141658-ENG142225-Leuchtweitenregulierung-lwr_pwm_untere_schwelle	2.50%	62
    ENG141658-ENG142227-Leuchtweitenregulierung-max_v_slwr	0 km/h	62
    ENG141658-ENG142222-Leuchtweitenregulierung-pa_fDynFiltStatLwr	100 Hz	62
    ENG141658-ENG142224-Leuchtweitenregulierung-pa_fFiltSwNeigung	0.00 Hz	62
    ENG141658-ENG142200-Leuchtweitenregulierung-Quelle_Hoehenwerte	BCM 	62
    ENG141658-ENG142042-Leuchtweitenregulierung-sensor_headlight_range_control_installed	not installed 	62
    ENG141658-ENG142199-Leuchtweitenregulierung-sLWR_bei_Abblendlicht	active 	62
    ENG141658-ENG142208-Leuchtweitenregulierung-sLWR_Hysterese	1.00%	62
    ENG141658-ENG154776-Leuchtweitenregulierung-sLWR_nach_Motorstart	not active 	62
    ENG141658-ENG142207-Leuchtweitenregulierung-sLWR_SW_Grad	10.0 %/s	62
    ENG141658-ENG142206-Leuchtweitenregulierung-sLWR_Touristenlicht	-100.00%	62
    ENG141658-ENG142196-Leuchtweitenregulierung-sLWR_verbaut	not installed 	62
    ENG141658-ENG142205-Leuchtweitenregulierung-Zyklus_sLWR	1.00 s	62
    ENG126648-MAS10452-LIN-Mirrormode-Data bus LIN 1	not active 	1
    ENG126648-MAS10453-LIN-Mirrormode-Data bus LIN 2	not active 	1
    ENG126648-MAS10454-LIN-Mirrormode-Data bus LIN 3	not active 	1
    ENG126648-MAS12782-LIN-Mirrormode-Data bus LIN 4	not active 	1
    ENG126648-MAS12783-LIN-Mirrormode-Data bus LIN 5	not active 	1
    ENG126648-MAS12784-LIN-Mirrormode-Data bus LIN 6	not active 	1
    ENG126648-ENG118465-LIN-Mirrormode-mirror_mode_typ	not active 	1
    ENG117284-ENG115658-LuB Lichtrouter Kennlinie 1-x0	0.00%	12
    ENG117284-ENG101574-LuB Lichtrouter Kennlinie 1-X1	5.00%	12
    ENG117284-ENG99557-LuB Lichtrouter Kennlinie 1-X2	50.00%	12
    ENG117284-ENG102140-LuB Lichtrouter Kennlinie 1-X3	75.00%	12
    ENG117284-ENG102936-LuB Lichtrouter Kennlinie 1-X4	110	12
    ENG117284-ENG103548-LuB Lichtrouter Kennlinie 1-X5	126.5	12
    ENG117284-ENG115659-LuB Lichtrouter Kennlinie 1-y0	0.00%	12
    ENG117284-ENG99777-LuB Lichtrouter Kennlinie 1-Y1	6.00%	12
    ENG117284-ENG100480-LuB Lichtrouter Kennlinie 1-Y2	16.00%	12
    ENG117284-ENG100773-LuB Lichtrouter Kennlinie 1-Y3	30.00%	12
    ENG117284-ENG100631-LuB Lichtrouter Kennlinie 1-Y4	60.00%	12
    ENG117284-ENG102174-LuB Lichtrouter Kennlinie 1-Y5	100.00%	12
    ENG141659-ENG115658-lwr_ofs_RSw_Ah1S-x0	-5.00%	20
    ENG141659-ENG101574-lwr_ofs_RSw_Ah1S-X1	-5.00%	20
    ENG141659-ENG99557-lwr_ofs_RSw_Ah1S-X2	-5.00%	20
    ENG141659-ENG102140-lwr_ofs_RSw_Ah1S-X3	-5.00%	20
    ENG141659-ENG102936-lwr_ofs_RSw_Ah1S-X4	-5.00%	20
    ENG141659-ENG115659-lwr_ofs_RSw_Ah1S-y0	-5	20
    ENG141659-ENG99777-lwr_ofs_RSw_Ah1S-Y1	-5	20
    ENG141659-ENG100480-lwr_ofs_RSw_Ah1S-Y2	-5	20
    ENG141659-ENG100773-lwr_ofs_RSw_Ah1S-Y3	-5	20
    ENG141659-ENG100631-lwr_ofs_RSw_Ah1S-Y4	-5	20
    ENG122979-ENG141954-Networking-A/C electronics	installed 	8
    ENG122979-ENG141968-Networking-Anhaengeranschlussgeraet	not installed 	8
    ENG122979-ENG141974-Networking-Bremsen_Steuergeraet	installed 	8
    ENG122979-ENG141953-Networking-Getriebesteuergeraet	installed 	8
    ENG122979-ENG99457-Networking-Head area heater	not installed 	8
    ENG122979-ENG142040-Networking-Kunden_spezifisches_Funktions_SG	not installed 	8
    ENG122979-ENG141969-Networking-UGDO	not installed 	8
    ENG124714-ENG142044-OCU-DWA_push	not active 	8
    ENG124714-ENG142260-OCU-Honk DWA_Ausgabe_Fanfare	not active 	8
    ENG124714-OCU-	not installed 	8
    ENG124714-ENG142261-OCU-Remote HuF Abbruch	20 km/h	8
    ENG124714-ENG142262-OCU-Remote HuF Hupfrequenz	3 Hz	8
    ENG124714-ENG133391-OCU-Remote Lock Unlock Timer s1	80 s	8
    ENG124714-ENG133392-OCU-Remote Lock Unlock Timer s3	2000 ms	8
    ENG124714-ENG125657-OCU-Remote_Unlock_Lock	not_active 	8
    ENG98831-ENG126849-Personalization-Aktivierungsoption_im_HMI-Menue_sichtbar	active 	16
    ENG98831-ENG133401-Personalization-Anzahl_Benutzerkonten	4	16
    ENG98831-ENG133402-Personalization-Automatische_ Schluesselzuordnung	not active 	16
    ENG98831-ENG126850-Personalization-Benutzerkontenverwaltung_in_HMI-Menue_sichtbar	active 	16
    ENG98831-ENG126848-Personalization-Personalisierung_aktiv	active 	16
    ENG98831-ENG141994-Personalization-Personalisierung_Profilfunkion	profiles_active 	16
    ENG98831-ENG126851-Personalization-Personalisierungsfunktionen_in_HMI-Menue_sichtbar	active 	16
    ENG98831-ENG142030-Personalization-Profil_Variante	Konto (v. 1.x) 	16
    ENG98831-ENG133404-Personalization-PSO_FSG_Setup2_Bit_1	active 	16
    ENG98831-ENG133405-Personalization-PSO_FSG_Setup2_Bit_2	active 	16
    ENG98831-ENG133406-Personalization-PSO_FSG_Setup2_Bit_3	not active 	16
    ENG98831-ENG133407-Personalization-PSO_FSG_Setup2_Bit_4	not active 	16
    ENG141646-MAS01065-Querschnitts_funktionen-Brand	VW 	5
    ENG141646-ENG141980-Querschnitts_funktionen-Bedien_und_Anzeigeprotokoll	active 	5
    ENG141646-ENG116624-Querschnitts_funktionen-CAN Wecken bei Softtouchbetaetigung	not active 	5
    ENG141646-ENG141967-Querschnitts_funktionen-Codierungsabsicherung	not active 	5
    ENG141646-ENG142028-Querschnitts_funktionen-Fahrgeschwindigkeit_aus_ESP_21	active 	5
    ENG141646-ENG142187-Querschnitts_funktionen-Hardware_Eingang_Drucktankklappenstatus	Pin A31 	5
    ENG141646-ENG154685-Querschnitts_funktionen-Hupe	Sollspannungsanforderung 13.5 	5
    ENG141646-ENG115810-Querschnitts_funktionen-Klemmenfehler auf CAN ausgeben	active 	5
    ENG141646-ENG142015-Querschnitts_funktionen-Personalisierungsuebernahme	not_installed 	5
    ENG141646-ENG141983-Querschnitts_funktionen-Schnittstelle_TrackingSystem	not active 	5
    ENG141646-ENG141964-Querschnitts_funktionen-Steering alignment	Left 	5
    ENG141646-ENG141965-Querschnitts_funktionen-Traffic side	Right 	5
    ENG115729-ENG116609-Scheinwerferreinigung-Anzahl Betaetigungen Frontwaschanlage pro SRA Aktivierung	0	10
    ENG115729-ENG141949-Scheinwerferreinigung-Headlamp washer system	not installed 	10
    ENG115729-ENG115769-Scheinwerferreinigung-SRA bei Waschwassermangel	not active 	10
    ENG115729-ENG115767-Scheinwerferreinigung-SRA Einweichpausenzeit	0 ms	10
    ENG115729-ENG115768-Scheinwerferreinigung-SRA Nachwaschzeit	0 ms	10
    ENG115729-ENG116611-Scheinwerferreinigung-SRA Pausenzeit	0 ms	10
    ENG115729-ENG116610-Scheinwerferreinigung-SRA Verzoegerungszeit	0 ms	10
    ENG115729-ENG115766-Scheinwerferreinigung-SRA Waschzeit	0 ms	10
    ENG115729-ENG154424-Scheinwerferreinigung-Waschen	Keine_Spannungsanforderung 	10
    ENG141684-SFT271873-Slave_systems_identification-Control Unit For Wiper Motor	Not available 	6
    ENG141684-SFT271874-Slave_systems_identification-Rain Light Recognition Sensor	Not available 	6
    ENG141684-SFT271875-Slave_systems_identification-Light switch	Not available 	6
    ENG141684-SFT271876-Slave_systems_identification-Garage door opener control module	Not available 	6
    ENG141684-SFT271877-Slave_systems_identification-Garage Door Opener Operating Unit	Not available 	6
    ENG141684-SFT271894-Slave_systems_identification-Sensor For Anti Theft Alarm System	Not available 	6
    ENG141684-SFT271896-Slave_systems_identification-Alarm horn	Not available 	6
    ENG141684-SFT271904-Slave_systems_identification-Sun Roof	Not available 	6
    ENG141684-SFT271910-Slave_systems_identification-Ceiling Light Module	Not available 	6
    ENG141684-SFT271928-Slave_systems_identification-Roof Blind	Not available 	6
    ENG141684-SFT271947-Slave_systems_identification-Relative Air Humidity Interior Sender	Not available 	6
    ENG141684-SFT271966-Slave_systems_identification-Neck Heating Left	Not available 	6
    ENG141684-SFT271967-Slave_systems_identification-Neck Heating Right	Not available 	6
    ENG141684-SFT272065-Slave_systems_identification-Seat Backrest Fan 1 Front Left	Not available 	6
    ENG141684-SFT272067-Slave_systems_identification-Seat Cushion Fan 1 Front Left	Not available 	6
    ENG141684-SFT272069-Slave_systems_identification-Seat Backrest Fan 1 Front Right	Not available 	6
    ENG141684-SFT272071-Slave_systems_identification-Seat Cushion Fan 1 Front Right	Not available 	6
    ENG116588-ENG116589-Sonderfunktionen-Signalprioritaet fuer Blinker	MFG 	4
    ENG116588-Sonderfunktionen-	not enabled 	4
    ENG116588-ENG141979-Sonderfunktionen-Sonderfunktionen 1	not installed 	4
    ENG141635-ENG116658-Spiegelverstellung-Funk Spiegelanklappen	not active 	5
    ENG141635-ENG116665-Spiegelverstellung-Funk Spiegelanklappung Modus	by convenience operation via remote control key 	5
    ENG141635-ENG116660-Spiegelverstellung-Menuesteuerung Funk Spiegel anklappen	not active 	5
    ENG141635-ENG116657-Spiegelverstellung-Menuesteuerung Spiegelabsenkung	not active 	5
    ENG141635-ENG116659-Spiegelverstellung-Menuesteuerung synchrone Spiegelverstellung	not active 	5
    ENG141635-ENG126841-Spiegelverstellung-Profilfunktion fuer Anklappung der Aussenspiegel	active 	5
    ENG141635-ENG126610-Spiegelverstellung-Signalisierung_Spiegelanklappung	active 	5
    ENG141635-ENG116650-Spiegelverstellung-Spiegelabsenkung bei Rueckwaertsfahrt	not active 	5
    ENG141635-ENG133411-Spiegelverstellung-Spiegelanklappen_bei_Wiederverriegelung	not active 	5
    ENG141635-ENG116656-Spiegelverstellung-Spiegelverstellung Synchron	not active 	5
    ENG153700-ENG154515-Steering Column Switch-Anzahl_fehler_P-verriegelt	25	10
    ENG153700-ENG154621-Steering Column Switch-Geschwindigkeitesschwele_erkennung_fahrt_P_plausibel	10 km/h	10
    ENG153700-ENG154803-Steering Column Switch-Verbauort_Lenkstockschalter	CAN 	10
    ENG153700-ENG154828-Steering Column Switch-Zeit_erkennung_fahrt_für_P_plausibel	10.0 min	10
    ENG153700-ENG154829-Steering Column Switch-Zeit_t_P-verriegelt_entprellen	40 ms	10
    ENG141678-ENG115658-Suchbeleuchtung_58_xs_Bus_Kennlinie-x0	0.0 lx	10
    ENG141678-ENG101574-Suchbeleuchtung_58_xs_Bus_Kennlinie-X1	8.0 lx	10
    ENG141678-ENG99557-Suchbeleuchtung_58_xs_Bus_Kennlinie-X2	50.0 lx	10
    ENG141678-ENG102140-Suchbeleuchtung_58_xs_Bus_Kennlinie-X3	80.0 lx	10
    ENG141678-ENG102936-Suchbeleuchtung_58_xs_Bus_Kennlinie-X4	100.0 lx	10
    ENG141678-ENG115659-Suchbeleuchtung_58_xs_Bus_Kennlinie-y0	6	10
    ENG141678-ENG99777-Suchbeleuchtung_58_xs_Bus_Kennlinie-Y1	6	10
    ENG141678-ENG100480-Suchbeleuchtung_58_xs_Bus_Kennlinie-Y2	20	10
    ENG141678-ENG100773-Suchbeleuchtung_58_xs_Bus_Kennlinie-Y3	50	10
    ENG141678-ENG100631-Suchbeleuchtung_58_xs_Bus_Kennlinie-Y4	100	10
    ENG141679-ENG115658-Suchbeleuchtung_58xt_Bus_Kennlinie-x0	0.0 lx	10
    ENG141679-ENG101574-Suchbeleuchtung_58xt_Bus_Kennlinie-X1	8.0 lx	10
    ENG141679-ENG99557-Suchbeleuchtung_58xt_Bus_Kennlinie-X2	50.0 lx	10
    ENG141679-ENG102140-Suchbeleuchtung_58xt_Bus_Kennlinie-X3	80.0 lx	10
    ENG141679-ENG102936-Suchbeleuchtung_58xt_Bus_Kennlinie-X4	100.0 lx	10
    ENG141679-ENG115659-Suchbeleuchtung_58xt_Bus_Kennlinie-y0	6	10
    ENG141679-ENG99777-Suchbeleuchtung_58xt_Bus_Kennlinie-Y1	6	10
    ENG141679-ENG100480-Suchbeleuchtung_58xt_Bus_Kennlinie-Y2	20	10
    ENG141679-ENG100773-Suchbeleuchtung_58xt_Bus_Kennlinie-Y3	50	10
    ENG141679-ENG100631-Suchbeleuchtung_58xt_Bus_Kennlinie-Y4	100	10
    ENG141666-ENG115658-Suchbeleuchtung_Abdimmen-x0	0 ms	22
    ENG141666-ENG101574-Suchbeleuchtung_Abdimmen-X1	200 ms	22
    ENG141666-ENG115664-Suchbeleuchtung_Abdimmen-x10	2000 ms	22
    ENG141666-ENG99557-Suchbeleuchtung_Abdimmen-X2	400 ms	22
    ENG141666-ENG102140-Suchbeleuchtung_Abdimmen-X3	600 ms	22
    ENG141666-ENG102936-Suchbeleuchtung_Abdimmen-X4	800 ms	22
    ENG141666-ENG103548-Suchbeleuchtung_Abdimmen-X5	1000 ms	22
    ENG141666-ENG113992-Suchbeleuchtung_Abdimmen-X6	1200 ms	22
    ENG141666-ENG115661-Suchbeleuchtung_Abdimmen-x7	1400 ms	22
    ENG141666-ENG115662-Suchbeleuchtung_Abdimmen-x8	1600 ms	22
    ENG141666-ENG115663-Suchbeleuchtung_Abdimmen-x9	1800 ms	22
    ENG141666-ENG115659-Suchbeleuchtung_Abdimmen-y0	100.00%	22
    ENG141666-ENG99777-Suchbeleuchtung_Abdimmen-Y1	100.00%	22
    ENG141666-ENG115668-Suchbeleuchtung_Abdimmen-y10	0.00%	22
    ENG141666-ENG100480-Suchbeleuchtung_Abdimmen-Y2	95.00%	22
    ENG141666-ENG100773-Suchbeleuchtung_Abdimmen-Y3	80.00%	22
    ENG141666-ENG100631-Suchbeleuchtung_Abdimmen-Y4	40.00%	22
    ENG141666-ENG102174-Suchbeleuchtung_Abdimmen-Y5	20.00%	22
    ENG141666-ENG113993-Suchbeleuchtung_Abdimmen-Y6	10.00%	22
    ENG141666-ENG115665-Suchbeleuchtung_Abdimmen-y7	5.00%	22
    ENG141666-ENG115666-Suchbeleuchtung_Abdimmen-y8	3.00%	22
    ENG141666-ENG115667-Suchbeleuchtung_Abdimmen-y9	1.00%	22
    ENG141663-ENG142240-Suchbeleuchtung_allgemein-Daempfung Abdimmen KL 58xd PWM	0.00 s	21
    ENG141663-ENG154582-Suchbeleuchtung_allgemein-Daempfung_Abdimmen_KL_58xs_PWM	0.00 s	21
    ENG141663-ENG154583-Suchbeleuchtung_allgemein-Daempfung_Abdimmen_KL_58xt_PWM	0.00 s	21
    ENG141663-ENG154584-Suchbeleuchtung_allgemein-Daempfung_Aufdimmen_KL_58xd_PWM	0.00 s	21
    ENG141663-ENG154585-Suchbeleuchtung_allgemein-Daempfung_Aufdimmen_KL_58xt_PWM	0.00 s	21
    ENG141663-ENG141988-Suchbeleuchtung_allgemein-Eingabemedium_Suchbeleuchtung	Potentiometer 	21
    ENG141663-ENG142242-Suchbeleuchtung_allgemein-Helligkeit_RLS_Daempfung_Abdimmen	20.0 s	21
    ENG141663-ENG142241-Suchbeleuchtung_allgemein-Helligkeit_RLS_Daempfung_Aufdimmen	3.0 s	21
    ENG141663-ENG116598-Suchbeleuchtung_allgemein-KL58 Einschalten mit Rampe	not active 	21
    ENG141663-ENG116599-Suchbeleuchtung_allgemein-KL58 Verriegelungsausschalten	not_active 	21
    ENG141663-ENG116600-Suchbeleuchtung_allgemein-Lichtsensor wirkt auf Suchbeleuchtung	active 	21
    ENG141663-ENG142243-Suchbeleuchtung_allgemein-pa_Hysterese_RLS	2	21
    ENG141663-ENG154712-Suchbeleuchtung_allgemein-PWM_Daempfung_Aufdimmen_KL58xs_PWM	0.00 s	21
    ENG141663-ENG115631-Suchbeleuchtung_allgemein-Suchbeleuchtung Festwert	100%	21
    ENG141663-ENG142234-Suchbeleuchtung_allgemein-Umgebungs_helligkeit_auswahl	Fotosensor_Kombi 	21
    ENG141663-ENG115819-Suchbeleuchtung_allgemein-Warnblinktastersuchbeleuchtung Aktivierung	Always active 	21
    ENG141663-ENG115821-Suchbeleuchtung_allgemein-Warnblinktastersuchbeleuchtung Faktor	0.1	21
    ENG141663-ENG115820-Suchbeleuchtung_allgemein-Warnblinktastersuchbeleuchtung Grundwert	10.00%	21
    ENG141667-ENG115658-Suchbeleuchtung_Fotosensor-x0	0	22
    ENG141667-ENG101574-Suchbeleuchtung_Fotosensor-X1	50	22
    ENG141667-ENG115664-Suchbeleuchtung_Fotosensor-x10	0	22
    ENG141667-ENG99557-Suchbeleuchtung_Fotosensor-X2	100	22
    ENG141667-ENG102140-Suchbeleuchtung_Fotosensor-X3	200	22
    ENG141667-ENG102936-Suchbeleuchtung_Fotosensor-X4	253	22
    ENG141667-ENG103548-Suchbeleuchtung_Fotosensor-X5	0	22
    ENG141667-ENG113992-Suchbeleuchtung_Fotosensor-X6	0	22
    ENG141667-ENG115661-Suchbeleuchtung_Fotosensor-x7	0	22
    ENG141667-ENG115662-Suchbeleuchtung_Fotosensor-x8	0	22
    ENG141667-ENG115663-Suchbeleuchtung_Fotosensor-x9	0	22
    ENG141667-ENG115659-Suchbeleuchtung_Fotosensor-y0	0 lx	22
    ENG141667-ENG99777-Suchbeleuchtung_Fotosensor-Y1	50 lx	22
    ENG141667-ENG115668-Suchbeleuchtung_Fotosensor-y10	0 lx	22
    ENG141667-ENG100480-Suchbeleuchtung_Fotosensor-Y2	100 lx	22
    ENG141667-ENG100773-Suchbeleuchtung_Fotosensor-Y3	200	22
    ENG141667-ENG100631-Suchbeleuchtung_Fotosensor-Y4	500	22
    ENG141667-ENG102174-Suchbeleuchtung_Fotosensor-Y5	0	22
    ENG141667-ENG113993-Suchbeleuchtung_Fotosensor-Y6	0 lx	22
    ENG141667-ENG115665-Suchbeleuchtung_Fotosensor-y7	0 lx	22
    ENG141667-ENG115666-Suchbeleuchtung_Fotosensor-y8	0 lx	22
    ENG141667-ENG115667-Suchbeleuchtung_Fotosensor-y9	0 lx	22
    ENG141665-ENG115658-Suchbeleuchtung_Hochdimmen-x0	0 ms	22
    ENG141665-ENG101574-Suchbeleuchtung_Hochdimmen-X1	200 ms	22
    ENG141665-ENG115664-Suchbeleuchtung_Hochdimmen-x10	2000 ms	22
    ENG141665-ENG99557-Suchbeleuchtung_Hochdimmen-X2	400 ms	22
    ENG141665-ENG102140-Suchbeleuchtung_Hochdimmen-X3	600 ms	22
    ENG141665-ENG102936-Suchbeleuchtung_Hochdimmen-X4	800 ms	22
    ENG141665-ENG103548-Suchbeleuchtung_Hochdimmen-X5	1000 ms	22
    ENG141665-ENG113992-Suchbeleuchtung_Hochdimmen-X6	1200 ms	22
    ENG141665-ENG115661-Suchbeleuchtung_Hochdimmen-x7	1400 ms	22
    ENG141665-ENG115662-Suchbeleuchtung_Hochdimmen-x8	1600 ms	22
    ENG141665-ENG115663-Suchbeleuchtung_Hochdimmen-x9	1800 ms	22
    ENG141665-ENG115659-Suchbeleuchtung_Hochdimmen-y0	0.00%	22
    ENG141665-ENG99777-Suchbeleuchtung_Hochdimmen-Y1	1.00%	22
    ENG141665-ENG115668-Suchbeleuchtung_Hochdimmen-y10	100.00%	22
    ENG141665-ENG100480-Suchbeleuchtung_Hochdimmen-Y2	3.00%	22
    ENG141665-ENG100773-Suchbeleuchtung_Hochdimmen-Y3	5.00%	22
    ENG141665-ENG100631-Suchbeleuchtung_Hochdimmen-Y4	11.00%	22
    ENG141665-ENG102174-Suchbeleuchtung_Hochdimmen-Y5	22.00%	22
    ENG141665-ENG113993-Suchbeleuchtung_Hochdimmen-Y6	40.00%	22
    ENG141665-ENG115665-Suchbeleuchtung_Hochdimmen-y7	80.00%	22
    ENG141665-ENG115666-Suchbeleuchtung_Hochdimmen-y8	95.00%	22
    ENG141665-ENG115667-Suchbeleuchtung_Hochdimmen-y9	100.00%	22
    ENG141669-ENG115658-Suchbeleuchtung_KL 58xs max-x0	0 lx	8
    ENG141669-ENG101574-Suchbeleuchtung_KL 58xs max-X1	8 lx	8
    ENG141669-ENG99557-Suchbeleuchtung_KL 58xs max-X2	50 lx	8
    ENG141669-ENG102140-Suchbeleuchtung_KL 58xs max-X3	500 lx	8
    ENG141669-ENG115659-Suchbeleuchtung_KL 58xs max-y0	100	8
    ENG141669-ENG99777-Suchbeleuchtung_KL 58xs max-Y1	100	8
    ENG141669-ENG100480-Suchbeleuchtung_KL 58xs max-Y2	100	8
    ENG141669-ENG100773-Suchbeleuchtung_KL 58xs max-Y3	100	8
    ENG141668-ENG115658-Suchbeleuchtung_KL 58xs min-x0	0 lx	8
    ENG141668-ENG101574-Suchbeleuchtung_KL 58xs min-X1	8 lx	8
    ENG141668-ENG99557-Suchbeleuchtung_KL 58xs min-X2	50 lx	8
    ENG141668-ENG102140-Suchbeleuchtung_KL 58xs min-X3	500 lx	8
    ENG141668-ENG115659-Suchbeleuchtung_KL 58xs min-y0	6	8
    ENG141668-ENG99777-Suchbeleuchtung_KL 58xs min-Y1	6	8
    ENG141668-ENG100480-Suchbeleuchtung_KL 58xs min-Y2	100	8
    ENG141668-ENG100773-Suchbeleuchtung_KL 58xs min-Y3	100	8
    ENG141674-ENG115658-Suchbeleuchtung_KL_58xd_log_Bus-x0	0.00%	12
    ENG141674-ENG101574-Suchbeleuchtung_KL_58xd_log_Bus-X1	6.00%	12
    ENG141674-ENG99557-Suchbeleuchtung_KL_58xd_log_Bus-X2	16.00%	12
    ENG141674-ENG102140-Suchbeleuchtung_KL_58xd_log_Bus-X3	30.00%	12
    ENG141674-ENG102936-Suchbeleuchtung_KL_58xd_log_Bus-X4	60.00%	12
    ENG141674-ENG103548-Suchbeleuchtung_KL_58xd_log_Bus-X5	100.00%	12
    ENG141674-ENG115659-Suchbeleuchtung_KL_58xd_log_Bus-y0	10	12
    ENG141674-ENG99777-Suchbeleuchtung_KL_58xd_log_Bus-Y1	10	12
    ENG141674-ENG100480-Suchbeleuchtung_KL_58xd_log_Bus-Y2	100	12
    ENG141674-ENG100773-Suchbeleuchtung_KL_58xd_log_Bus-Y3	150	12
    ENG141674-ENG100631-Suchbeleuchtung_KL_58xd_log_Bus-Y4	220	12
    ENG141674-ENG102174-Suchbeleuchtung_KL_58xd_log_Bus-Y5	253	12
    ENG141673-ENG115658-Suchbeleuchtung_KL_58xd_max-x0	0 lx	10
    ENG141673-ENG101574-Suchbeleuchtung_KL_58xd_max-X1	8 lx	10
    ENG141673-ENG99557-Suchbeleuchtung_KL_58xd_max-X2	200 lx	10
    ENG141673-ENG102140-Suchbeleuchtung_KL_58xd_max-X3	300 lx	10
    ENG141673-ENG102936-Suchbeleuchtung_KL_58xd_max-X4	500 lx	10
    ENG141673-ENG115659-Suchbeleuchtung_KL_58xd_max-y0	16	10
    ENG141673-ENG99777-Suchbeleuchtung_KL_58xd_max-Y1	16	10
    ENG141673-ENG100480-Suchbeleuchtung_KL_58xd_max-Y2	100	10
    ENG141673-ENG100773-Suchbeleuchtung_KL_58xd_max-Y3	100	10
    ENG141673-ENG100631-Suchbeleuchtung_KL_58xd_max-Y4	100	10
    ENG141672-ENG115658-Suchbeleuchtung_KL_58xd_min-x0	0 lx	10
    ENG141672-ENG101574-Suchbeleuchtung_KL_58xd_min-X1	8 lx	10
    ENG141672-ENG99557-Suchbeleuchtung_KL_58xd_min-X2	220 lx	10
    ENG141672-ENG102140-Suchbeleuchtung_KL_58xd_min-X3	300 lx	10
    ENG141672-ENG102936-Suchbeleuchtung_KL_58xd_min-X4	500 lx	10
    ENG141672-ENG115659-Suchbeleuchtung_KL_58xd_min-y0	6	10
    ENG141672-ENG99777-Suchbeleuchtung_KL_58xd_min-Y1	6	10
    ENG141672-ENG100480-Suchbeleuchtung_KL_58xd_min-Y2	100	10
    ENG141672-ENG100773-Suchbeleuchtung_KL_58xd_min-Y3	100	10
    ENG141672-ENG100631-Suchbeleuchtung_KL_58xd_min-Y4	100	10
    ENG141677-ENG115658-Suchbeleuchtung_KL_58xd_PWM-x0	0	12
    ENG141677-ENG101574-Suchbeleuchtung_KL_58xd_PWM-X1	10	12
    ENG141677-ENG99557-Suchbeleuchtung_KL_58xd_PWM-X2	50	12
    ENG141677-ENG102140-Suchbeleuchtung_KL_58xd_PWM-X3	100	12
    ENG141677-ENG102936-Suchbeleuchtung_KL_58xd_PWM-X4	220	12
    ENG141677-ENG103548-Suchbeleuchtung_KL_58xd_PWM-X5	253	12
    ENG141677-ENG115659-Suchbeleuchtung_KL_58xd_PWM-y0	2.00%	12
    ENG141677-ENG99777-Suchbeleuchtung_KL_58xd_PWM-Y1	2.00%	12
    ENG141677-ENG100480-Suchbeleuchtung_KL_58xd_PWM-Y2	6.00%	12
    ENG141677-ENG100773-Suchbeleuchtung_KL_58xd_PWM-Y3	10.00%	12
    ENG141677-ENG100631-Suchbeleuchtung_KL_58xd_PWM-Y4	80.00%	12
    ENG141677-ENG102174-Suchbeleuchtung_KL_58xd_PWM-Y5	100.00%	12
    ENG141670-ENG115658-Suchbeleuchtung_KL_58xt min-x0	0 lx	8
    ENG141670-ENG101574-Suchbeleuchtung_KL_58xt min-X1	8 lx	8
    ENG141670-ENG99557-Suchbeleuchtung_KL_58xt min-X2	50 lx	8
    ENG141670-ENG102140-Suchbeleuchtung_KL_58xt min-X3	500 lx	8
    ENG141670-ENG115659-Suchbeleuchtung_KL_58xt min-y0	6	8
    ENG141670-ENG99777-Suchbeleuchtung_KL_58xt min-Y1	6	8
    ENG141670-ENG100480-Suchbeleuchtung_KL_58xt min-Y2	100	8
    ENG141670-ENG100773-Suchbeleuchtung_KL_58xt min-Y3	100	8
    ENG141671-ENG115658-Suchbeleuchtung_KL_58xt_max-x0	0 lx	8
    ENG141671-ENG101574-Suchbeleuchtung_KL_58xt_max-X1	8 lx	8
    ENG141671-ENG99557-Suchbeleuchtung_KL_58xt_max-X2	50 lx	8
    ENG141671-ENG102140-Suchbeleuchtung_KL_58xt_max-X3	500 lx	8
    ENG141671-ENG115659-Suchbeleuchtung_KL_58xt_max-y0	100	8
    ENG141671-ENG99777-Suchbeleuchtung_KL_58xt_max-Y1	100	8
    ENG141671-ENG100480-Suchbeleuchtung_KL_58xt_max-Y2	100	8
    ENG141671-ENG100773-Suchbeleuchtung_KL_58xt_max-Y3	100	8
    ENG141676-ENG115658-Suchbeleuchtung_KL_58xt_PWM-x0	0.00%	6
    ENG141676-ENG101574-Suchbeleuchtung_KL_58xt_PWM-X1	50.00%	6
    ENG141676-ENG99557-Suchbeleuchtung_KL_58xt_PWM-X2	100.00%	6
    ENG141676-ENG115659-Suchbeleuchtung_KL_58xt_PWM-y0	0.00%	6
    ENG141676-ENG99777-Suchbeleuchtung_KL_58xt_PWM-Y1	50.00%	6
    ENG141676-ENG100480-Suchbeleuchtung_KL_58xt_PWM-Y2	100.00%	6
    ENG141680-ENG115658-Suchbeleuchtung_Regen_Licht_Sensor_Mapping_Kennlinie-x0	0 lx	12
    ENG141680-ENG101574-Suchbeleuchtung_Regen_Licht_Sensor_Mapping_Kennlinie-X1	10 lx	12
    ENG141680-ENG99557-Suchbeleuchtung_Regen_Licht_Sensor_Mapping_Kennlinie-X2	100 lx	12
    ENG141680-ENG102140-Suchbeleuchtung_Regen_Licht_Sensor_Mapping_Kennlinie-X3	500 lx	12
    ENG141680-ENG102936-Suchbeleuchtung_Regen_Licht_Sensor_Mapping_Kennlinie-X4	800 lx	12
    ENG141680-ENG103548-Suchbeleuchtung_Regen_Licht_Sensor_Mapping_Kennlinie-X5	1020 lx	12
    ENG141680-ENG115659-Suchbeleuchtung_Regen_Licht_Sensor_Mapping_Kennlinie-y0	0	12
    ENG141680-ENG99777-Suchbeleuchtung_Regen_Licht_Sensor_Mapping_Kennlinie-Y1	20	12
    ENG141680-ENG100480-Suchbeleuchtung_Regen_Licht_Sensor_Mapping_Kennlinie-Y2	80	12
    ENG141680-ENG100773-Suchbeleuchtung_Regen_Licht_Sensor_Mapping_Kennlinie-Y3	180	12
    ENG141680-ENG100631-Suchbeleuchtung_Regen_Licht_Sensor_Mapping_Kennlinie-Y4	300	12
    ENG141680-ENG102174-Suchbeleuchtung_Regen_Licht_Sensor_Mapping_Kennlinie-Y5	500	12
    ENG141664-ENG115633-Suchbeleuchtung_Tasterdimmung-Tasterdimmung x0	0 ms	10
    ENG141664-ENG115634-Suchbeleuchtung_Tasterdimmung-Tasterdimmung x1	2000 ms	10
    ENG141664-ENG115635-Suchbeleuchtung_Tasterdimmung-Tasterdimmung x2	3000 ms	10
    ENG141664-ENG115636-Suchbeleuchtung_Tasterdimmung-Tasterdimmung x3	4000 ms	10
    ENG141664-ENG115637-Suchbeleuchtung_Tasterdimmung-Tasterdimmung x4	5100 ms	10
    ENG141664-ENG115638-Suchbeleuchtung_Tasterdimmung-Tasterdimmung y0	1.00%	10
    ENG141664-ENG115639-Suchbeleuchtung_Tasterdimmung-Tasterdimmung y1	5	10
    ENG141664-ENG115640-Suchbeleuchtung_Tasterdimmung-Tasterdimmung y2	15	10
    ENG141664-ENG115641-Suchbeleuchtung_Tasterdimmung-Tasterdimmung y3	40	10
    ENG141664-ENG115642-Suchbeleuchtung_Tasterdimmung-Tasterdimmung y4	100	10
    ENG141632-ENG116647-Sunroof-SAD Komfort oeffnen	not active 	4
    ENG141632-ENG116646-Sunroof-SAD Komfort schliessen	not active 	4
    ENG141632-ENG116645-Sunroof-SAD Richtung Komfortoeffnen	tilting 	4
    ENG141632-ENG141970-Sunroof-Schiebedachmodul_MD_1	not installed 	4
    ENG141632-ENG141971-Sunroof-Schiebedachmodul_MD_3	not installed 	4
    ENG141632-ENG141972-Sunroof-Schiebedachmodul_MD_Rollo	not installed 	4
    ENG141632-ENG142022-Sunroof-Verortung Schiebedachmodule	LIN 	4
    ENG141634-ENG142013-Verdecksteuergeraet-Cabrio_Verdeck	not_installed 	9
    ENG141634-ENG116716-Verdecksteuergeraet-Doppelpuls nur Verdeck	not active 	9
    ENG141634-ENG128459-Verdecksteuergeraet-easycloselight_aktiv	not active 	9
    ENG141634-ENG116718-Verdecksteuergeraet-Heckdeckel sperren bei Verdeckbetrieb	not active 	9
    ENG141634-ENG142259-Verdecksteuergeraet-Kick_and_close	not installed 	9
    ENG141634-ENG116711-Verdecksteuergeraet-Komfortbedienung Verdeck global	not active 	9
    ENG141634-ENG122189-Verdecksteuergeraet-Komfortbedienung Verdeck oeffnen	not active 	9
    ENG141634-ENG116712-Verdecksteuergeraet-Komfortbedienung Verdeck schließen	not active 	9
    ENG141634-ENG125654-Verdecksteuergeraet-Nachsaven_nach_Verdecklauf	not active 	9
    ENG141634-ENG126630-Verdecksteuergeraet-Reichweitenbegrenzung fuer Servoheck schliessen	not active 	9
    ENG141634-ENG125652-Verdecksteuergeraet-Servoheck Schlossansteuerung	Always 	9
    ENG141634-ENG126838-Verdecksteuergeraet-Softtouch-Betaetigung senden	Always 	9
    ENG141634-ENG142011-Verdecksteuergeraet-trunk_lid_conrol_unit	not installed 	9
    ENG141634-ENG116717-Verdecksteuergeraet-Verdeck mit Schiebedach	not active 	9
    ENG141634-ENG122191-Verdecksteuergeraet-Verdeck oeffnen via Funkfernbedienung	not active 	9
    ENG141634-ENG122192-Verdecksteuergeraet-Verdeck oeffnen via Kessy	not active 	9
    ENG141634-ENG122190-Verdecksteuergeraet-Verdeck oeffnen via Schliesszylinder	not active 	9
    ENG141634-ENG116714-Verdecksteuergeraet-Verdeck schließen via Funkfernbedienung	not active 	9
    ENG141634-ENG116715-Verdecksteuergeraet-Verdeck schließen via Kessy	not active 	9
    ENG141634-ENG116713-Verdecksteuergeraet-Verdeck schließen via Schließzylinder	not active 	9
    ENG141634-ENG115869-Verdecksteuergeraet-Virtuelles_Pedal	not active 	9
    ENG141634-ENG142258-Verdecksteuergeraet-Virtuelles_Pedal_HMI_einstellba	not active 	9
    ENG141634-ENG142257-Verdecksteuergeraet-Virtuelles_Pedal_Verbau	not installed 	9
    ENG116971-ENG116537-Vernetzungs- Diagnosefunktionen-can msg 1	00 00 	20
    ENG116971-ENG116538-Vernetzungs- Diagnosefunktionen-can msg 2	00 00 	20
    ENG116971-ENG116539-Vernetzungs- Diagnosefunktionen-can msg 3	00 00 	20
    ENG116971-ENG116540-Vernetzungs- Diagnosefunktionen-can msg 4	00 00 	20
    ENG116971-ENG116541-Vernetzungs- Diagnosefunktionen-lin msg 1	00 00 	20
    ENG116971-ENG116542-Vernetzungs- Diagnosefunktionen-lin msg 2	00 00 	20
    ENG116971-ENG116543-Vernetzungs- Diagnosefunktionen-lin msg 3	00 00 	20
    ENG116971-ENG116544-Vernetzungs- Diagnosefunktionen-lin msg 4	00 00 	20
    ENG116971-ENG116545-Vernetzungs- Diagnosefunktionen-lin msg 5	00 00 	20
    ENG116971-ENG116546-Vernetzungs- Diagnosefunktionen-lin msg 6	00 00 	20
    ENG141651-ENG116632-ZV allgemein-Bewusstes Safe mit 2. Betaetigung der FFB	not active 	7
    ENG141651-ENG133387-ZV allgemein-Deaktivierung_Laderaumschliessung_extern	not active 	7
    ENG141651-ENG125653-ZV allgemein-Deaktivierung_SAFE_ueber_DWA_Deaktivierungstaster	active 	7
    ENG141651-ENG126837-ZV allgemein-Entsafen mit autorisierte Klemme 15 Ein	not active 	7
    ENG141651-ENG115754-ZV allgemein-Funk bei Klemme 15 ein	not active 	7
    ENG141651-ENG141981-ZV allgemein-Lock_Unlock_Taster_direkt	not installed 	7
    ENG141651-ENG142019-ZV allgemein-Lock_Unlock_Toggle_Taster	not installed 	7
    ENG141651-ENG133388-ZV allgemein-LS_Taster_Togglefunktion	not active 	7
    ENG141651-ENG116633-ZV allgemein-Menuesteuerung Tuerentriegelung	active 	7
    ENG141651-ENG115755-ZV allgemein-Notschließfunktion	active 	7
    ENG141651-ENG133389-ZV allgemein-Nutzfahrzeug_Schliessung	not active 	7
    ENG141651-ENG141957-ZV allgemein-Radio freq.	315MHz 	7
    ENG141651-ENG141958-ZV allgemein-Tankschloss	Bidirectional 	7
    ENG141651-ENG133390-ZV allgemein-Wiederverriegelung_Laderaum	Freigabe_Softtouch 	7
    ENG141651-ENG116623-ZV allgemein-ZV Tuerentriegelung	Einzeltuerentriegelung 	7
    ENG141651-ENG141996-ZV allgemein-ZV_ohne_Safe_Funktion	installed 	7
    ENG141654-ENG116628-ZV Autolock-Autolock Autounlock wirkt auf Heck	active 	3
    ENG141654-ENG116621-ZV Autolock-automatisches Entriegeln	active 	3
    ENG141654-ENG115756-ZV Autolock-automatisches Verriegeln bei Geschwindigkeit	active 	3
    ENG141654-ENG116706-ZV Autolock-Autounlock NAR	active 	3
    ENG141654-ENG116622-ZV Autolock-Geschwindigkeitsabhaengige Tankdeckelverriegelung	not active 	3
    ENG141654-ENG116634-ZV Autolock-Menuesteuerung ZV Autolock-Unlock	adjustable 	3
    ENG141655-ENG116627-ZV Crash-Heckdeckel-Bedienstellen nachCrash temporaer sperren	active 	4
    ENG141655-ENG116661-ZV Crash-SAD PreCrash Konturschliessen	not active 	4
    ENG141655-ENG116635-ZV Crash-ZV-Entriegelung nach Seitencrash	not active 	4
    ENG141653-ENG115759-ZV Heck-Direkter Auswurf des Heckdeckels	not active 	7
    ENG141653-ENG126839-ZV Heck-Entriegelungwunsch_verzoegert_waehrend_Zuziehvorgang	not active 	7
    ENG141653-ENG116707-ZV Heck-Freigabenachlauf Heck nach Einzeloeffnung ueber HDF-Funktaster	not active 	7
    ENG141653-ENG142016-ZV Heck-Heckdeckelentriegelung_HDF_Innentaster	not installed 	7
    ENG141653-ENG133386-ZV Heck-Heckfreigabe_Ohne_Verzoegerung	active 	7
    ENG141653-ENG142245-ZV Heck-Heckoeffnung_ueber_2_Bedienhandlungen	not active 	7
    ENG141653-ENG141998-ZV Heck-Heckschloss_mit_Vorraste	Yes 	7
    ENG141653-ENG141995-ZV Heck-Heckschloss_Steuerung	Contact control 	7
    ENG141653-ENG137162-ZV Heck-Mindestbetaetigung_HDF_Innentaster	0.0 s	7
    ENG141653-ENG115761-ZV Heck-Nach externer Verriegelung ist Heck noch zeitbegrenzt entriegelt	not active 	7
    ENG141653-ENG141982-ZV Heck-Tausch_Tank_Hecktreiberausgang	No 	7
    ENG141653-ENG115760-ZV Heck-ZV entriegelt auch Heckdeckel	active 	7
    ENG141653-ENG116629-ZV Heck-ZV Heck nur direkt auswerfen	not active 	7
    ENG141653-ENG141997-ZV Heck-ZV_Heck_Schlosstyp	1 or 2 notch rear actuator 	7
    ENG141681-IDE02021-ZV Komfort-Comfort closing	active 	8
    ENG141681-IDE02022-ZV Komfort-Comfort opening	not active 	8
    ENG141681-ENG141984-ZV Komfort-elektrischer_Fensterheber_hinten	Yes 	8
    ENG141681-ENG116663-ZV Komfort-Fahrertuerbedienung Fensterheber oeffnen	active 	8
    ENG141681-ENG116664-ZV Komfort-Fahrertuerbedienung Fensterheber schliessen	not active 	8
    ENG141681-ENG116662-ZV Komfort-FH SAD Kl15Aus Freigabezeit	600 s	8
    ENG141681-ENG116648-ZV Komfort-Freigabenachlauf FH bei Kl 15 aus	active 	8
    ENG141681-ENG122993-ZV Komfort-Freigabenachlauf FH bei Tueroeffnen abbrechen	active 	8
    ENG141681-ENG116652-ZV Komfort-Funk Komfort oeffnen	not active 	8
    ENG141681-ENG116651-ZV Komfort-Funk Komfort schliessen	not active 	8
    ENG141681-ENG115670-ZV Komfort-Komfortbedienung global	active 	8
    ENG141681-ENG116642-ZV Komfort-Komfortoeffnen nur FH Fahrertuer	not active 	8
    ENG141681-ENG122994-ZV Komfort-Menuesteuerung Komfortbedienung einstellbar	adjustable 	8
    ENG141681-ENG122186-ZV Komfort-Menuesteuerung Regenschliessen	not active 	8
    ENG141681-ENG125656-ZV Komfort-Regenschliessen_art	once 	8
    ENG141681-ENG125655-ZV Komfort-Regenschliessen_ein_aus	not active 	8
    ENG141681-ENG116643-ZV Komfort-Schliesszylinder Komfort oeffnen	not active 	8
    ENG141681-ENG116644-ZV Komfort-Schliesszylinder Komfort schliessen	not active 	8
    ENG141652-ENG141999-ZV Türkonfiguration-Fond_Schloss	2-Motorenschloesser 	5
    ENG141652-ENG142043-ZV Türkonfiguration-HFT_Invertierung_Drehfallensignal	nicht invertiert 	5
    ENG141652-ENG142039-ZV Türkonfiguration-Schiebetuer_Kontaktmodul_Beifahrerseite	not installed 	5
    ENG141652-ENG142038-ZV Türkonfiguration-Schiebetuer_Kontaktmodul_Fahrerseite	not installed 	5
    ENG141652-ENG142001-ZV Türkonfiguration-Schiebetuer_links	No 	5
    ENG141652-ENG142002-ZV Türkonfiguration-Schiebetuer_rechts	No 	5
    ENG141652-ENG142041-ZV Türkonfiguration-Schiebetueren_Crafter	not installed 	5
    ENG141652-ENG142244-ZV Türkonfiguration-Schiebetuerschloss_direkt_BCM	Driver side 	5
    ENG141652-ENG116631-ZV Türkonfiguration-Schliessung der Schiebetuer bei geoeffneter Tankklappe	not active 	5
    ENG141652-ENG142000-ZV Türkonfiguration-Schlosstyp_NAR	Yes 	5
    ENG141652-ENG141959-ZV Türkonfiguration-Viertuerer	Yes 	5
    Elapsed Time: 01:47
    09 Adps with SA code 31347
    ;SW:5Q0-937-087-AR   HW:5Q0-937-087-AN ---  Cent. Elect. --- SA: 31347
    ;Component:BCM PQ37BOSCH 034 0243	 Coding:
    ;EV_BodyContrModul1UDSBosc	18001	EV_BCMBOSCH_018.rod
    ;Sunday	26	August	2018	11:29:50:04045
    ;VCDS Version: Beta 18.7.2 (x64)  Data version: 20180808 DS295.0
    ;VCID: 0B40AD4533C5AC8FF40-805E
    IDE00001-ENG99061-Production mode-Access control	not active 	3
    IDE00001-ENG115730-Production mode-Aussenbeleuchtung	not active 	3
    IDE00001-ENG112304-Production mode-Heckwischer	not active 	3
    IDE00001-ENG98647-Production mode-Interior lighting	not active 	3
    IDE00001-ENG115729-Production mode-Scheinwerferreinigung	not active 	3
    IDE00001-ENG115731-Production mode-Virtuel_pedal	not active 	3
    IDE00002-Transport mode	active 	1
    IDE00820-Activating and deactivating all development messages	not active 	1
    IDE01550-Service position	170.494336 °	2
    IDE02152-Characteristics in production mode	2000 ms	4
    IDE02269-MAS04382-Acknowledgement signals-Optical feedback during locking	Decelerate 	10
    IDE02269-ENG116666-Acknowledgement signals-Akustische Rueckmeldung entriegeln	not active 	10
    IDE02269-ENG116669-Acknowledgement signals-Akustische Rueckmeldung global	active 	10
    IDE02269-ENG116670-Acknowledgement signals-Akustische Rueckmeldung Signalhorn	active 	10
    IDE02269-ENG116667-Acknowledgement signals-Akustische Rueckmeldung verriegeln	active 	10
    IDE02269-ENG122187-Acknowledgement signals-Dauer der Akustischen Rueckmeldung vom Einfachhorn	short 	10
    IDE02269-ENG122188-Acknowledgement signals-Menuesteuerung akustische Rueckmeldung	active 	10
    IDE02269-ENG122995-Acknowledgement signals-Optische Rueckmeldung 3.Bremsleuchte	not active 	10
    IDE02269-ENG116668-Acknowledgement signals-Optische Rueckmeldung Komfortschliessen	active 	10
    IDE02269-ENG133344-Acknowledgement signals-Quittierton bei zweitem ZV-AUF-Befehl	not active 	10
    IDE02269-ENG133345-Acknowledgement signals-Quittierton bei zweitem ZV-ZU-Befehl	active 	10
    IDE02269-ENG142248-Acknowledgement signals-ZV-Blinken_Abschluss_Dunkelzeit	200 ms	10
    IDE02269-ENG142247-Acknowledgement signals-ZV-Blinken_Dunkelzeit	200 ms	10
    IDE02269-ENG142246-Acknowledgement signals-ZV-Blinken_Hellzeit	200 ms	10
    IDE02332-Deactivate production mode	0	3
    IDE02711-ENG116690-Rear Window Wiper-Automatisches Heckwischen	not active 	8
    IDE02711-ENG133397-Rear Window Wiper-Einzelansteuerung Heckintervallwischen	not active 	8
    IDE02711-ENG133395-Rear Window Wiper-Einzelansteuerung Heckintervallwischen Zeitintervall 1	8 s	8
    IDE02711-ENG133396-Rear Window Wiper-Einzelansteuerung Heckintervallwischen Zeitintervall 2	16 s	8
    IDE02711-ENG112304-Rear Window Wiper-Heckwischer	logikgesteuert 	8
    IDE02711-ENG114947-Rear Window Wiper-Heckwischer Weiterlauf	not active 	8
    IDE02711-ENG114946-Rear Window Wiper-Komfortwischen Heck	active 	8
    IDE02711-ENG116695-Rear Window Wiper-Komofortwischen Heck Intervallpausenzeit Stufe 1	5 s	8
    IDE02711-ENG116696-Rear Window Wiper-Komofortwischen Heck Intervallpausenzeit Stufe 2	3 s	8
    IDE02711-ENG116694-Rear Window Wiper-Komofortwischen Heck Intervallpausenzeit Stufe Automatik	7 s	8
    IDE02711-ENG116693-Rear Window Wiper-Komofortwischen Heck Intervallpausenzeit Stufe Intervall	7 s	8
    IDE02711-ENG116689-Rear Window Wiper-Menuesteuerung Komfortwischen HW	active 	8
    IDE02711-ENG154784-Rear Window Wiper-Spannungsanforderung_konfig_Wischer	Keine_Spannungsanforderung 	8
    IDE02711-ENG116691-Rear Window Wiper-Traenenwischen Heck	active 	8
    IDE02711-ENG154831-Rear Window Wiper-Zeit_wasch_min_heck	0 ms	8
    IDE03638-IDE04231-static AFS light-Steering wheel angle: offset	0.3 °	16
    IDE03638-ENG116677-static AFS light-Abdimmgeschwindigkeit	50.0 %/s	16
    IDE03638-ENG116673-static AFS light-bei Rueckwaertsfahrt	both sides 	16
    IDE03638-ENG116675-static AFS light-Lower speed threshold	0.0 km/h	16
    IDE03638-ENG116682-static AFS light-Maximaltemperatur	100.0 °C	16
    IDE03638-ENG116679-static AFS light-obere Grenztemperatur	95.0 °C	16
    IDE03638-ENG116681-static AFS light-Oberer Lenkradwinkel	120 °	16
    IDE03638-ENG116680-static AFS light-untere Grenztemperatur	80.0 °C	16
    IDE03638-ENG116678-static AFS light-Unterer Lenkradwinkel	80 °	16
    IDE03638-ENG116676-static AFS light-Upper speed threshold	40.0 km/h	16
    IDE03638-ENG116674-static AFS light-Vorschrift	ECE R119 	16
    IDE03638-ENG115830-static AFS light-Zeitwert Einschaltzeit Abbiegelicht	15 min	16
    IDE03787-Activate left/right hand drive switch-over	not active 	1
    IDE04927-IDE01446-Window heater-Running time of heated front window	240 s	11
    IDE04927-ENG126847-Window heater-Abschalttemperatur fuer Frontscheibenheizung	35.0 °C	11
    IDE04927-ENG126846-Window heater-Abschalttemperatur fuer Heckscheibenheizung	35.0 °C	11
    IDE04927-ENG142251-Window heater-Frontscheibenheizung _maximale_Dauer	0 s	11
    IDE04927-ENG142035-Window heater-Frontscheibenheizung_LED_direkt	not installed 	11
    IDE04927-ENG142018-Window heater-Frontscheibenheizungsansteuerung direkt von externem Algorithmus	not installed 	11
    IDE04927-ENG126845-Window heater-FSH Automatik	active 	11
    IDE04927-ENG115736-Window heater-Heckscheibenheizung Zeitwert	320 s	11
    IDE04927-ENG141955-Window heater-heizbare Heckscheibe	installed 	11
    IDE04927-ENG142021-Window heater-Heizbare_Frontscheibe	not installed 	11
    IDE04927-ENG116620-Window heater-Temperaturabhaengige Einschaltzeit FSH	active 	11
    IDE04927-ENG116619-Window heater-Temperaturabhaengige Einschaltzeit HSH	active 	11
    IDE04927-ENG141962-Window heater-Waschduesenheizung	installed 	11
    IDE04927-ENG154810-Window heater-window heating front activation time pause	240 s	11
    IDE04928-MAS01577-Anti-theft device-Parking heater	not installed 	8
    IDE04928-ENG115867-Anti-theft device-Akustischer Alarm Signalhorn	active 	8
    IDE04928-ENG115864-Anti-theft device-Alarmsignal	frequency modulated 	8
    IDE04928-ENG141960-Anti-theft device-Anti-theft alarm system	not active 	8
    IDE04928-ENG154588-Anti-theft device-Deaktivierung DWA-Sensoren via Doppelklick	not_active 	8
    IDE04928-ENG154589-Anti-theft device-Deaktivierung_DWA_Sensoren_HMI	not_active 	8
    IDE04928-ENG115865-Anti-theft device-DWA Alarmverzoegerung	not active 	8
    IDE04928-ENG115812-Anti-theft device-DWA Camper Modus	not active 	8
    IDE04928-ENG142007-Anti-theft device-DWA_Einfachhorn_oder_Sounder	not installed 	8
    IDE04928-ENG141961-Anti-theft device-Heckscheibenbruchsensor	not installed 	8
    IDE04928-ENG142006-Anti-theft device-IRUE_NGS_Deaktivierungstaster_direkt_am BCM_verdrahtet	No 	8
    IDE04928-ENG142249-Anti-theft device-OBD Alarm	not_active 	8
    IDE04928-ENG154722-Anti-theft device-RHF_Panikalarm	not_active 	8
    IDE04928-ENG142009-Anti-theft device-Schliesszylinder in_Richtung Oeffnen_aktiv (Thatcham inaktiv)	No 	8
    IDE04928-ENG142010-Anti-theft device-Sensor_fuer_Innenraumueberwachung	No 	8
    IDE04928-ENG115866-Anti-theft device-Sirenen Alarmzahl	1 Alarm 	8
    IDE04928-ENG142008-Anti-theft device-tilt_sensor	No 	8
    IDE04928-ENG126842-Anti-theft device-Ueberwachung Innenentriegelungshebel	not active 	8
    IDE04928-ENG115868-Anti-theft device-Verzoegerung Panikalarm	keine verzoegerung 	8
    IDE05143-MAS02985-Writing parameter-Value	130	5
    IDE05143-MAS04381-Writing parameter-Parameter address	FE 00 00 	5
    IDE05144-Read parameter address	FE 00 00 	3
    IDE05145-Light configuration	0C 34 00 14 02 00 64 00 00 00 00 00 00 00 00 00 0C 3E 00 15 04 00 64 00 00 00 00 00 00 00 00 00 04 48 00 4A 14 00 64 06 12 9C 08 09 1C 00 00 00 04 4C 00 4C 14 00 64 07 13 9C 08 0A 1C 00 00 00 01 3A 00 49 14 00 7F 06 00 80 08 09 7F 00 00 00 01 44 00 4B 14 00 7F 07 00 80 08 0A 7F 00 00 00 0B 36 00 1A 0B 00 64 00 00 00 00 00 00 00 00 00 0B 40 00 1B 0C 00 64 00 00 00 00 00 00 00 00 00 0A 37 00 1C 0D 0F 64 00 00 00 00 00 00 00 00 00 0A 41 00 1D 0E 0F 64 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 0A 38 00 22 12 16 64 00 00 00 00 00 00 00 00 00 0A 42 00 23 13 17 64 00 00 00 00 00 00 00 00 00 	224
    IDE06089-ENG141976-Seat heater level current consumption allocation-Sitzheitzung_CAN	Heizmatten am BCM 	30
    IDE06089-ENG116683-Seat heater level current consumption allocation-Sitzheizung Filterkonstante fuer Waermefluss	1 s	30
    IDE06089-ENG116684-Seat heater level current consumption allocation-Sitzheizung Regeltemperaturkorrektur bei Waermefluss	0.00 °C	30
    IDE06089-ENG115738-Seat heater level current consumption allocation-Sitzheizung Stufe 1 obere Schaltschwelle	22.50 °C	30
    IDE06089-ENG115737-Seat heater level current consumption allocation-Sitzheizung Stufe 1 untere Schaltschwelle	21.50 °C	30
    IDE06089-ENG115740-Seat heater level current consumption allocation-Sitzheizung Stufe 2 obere Schaltschwelle	22.50 °C	30
    IDE06089-ENG115739-Seat heater level current consumption allocation-Sitzheizung Stufe 2 untere Schaltschwelle	21.50 °C	30
    IDE06089-ENG115742-Seat heater level current consumption allocation-Sitzheizung Stufe 3 obere Schaltschwelle	36.00 °C	30
    IDE06089-ENG115741-Seat heater level current consumption allocation-Sitzheizung Stufe 3 untere Schaltschwelle	34.00 °C	30
    IDE06089-ENG115744-Seat heater level current consumption allocation-Sitzheizung Stufe 4 obere Schaltschwelle	36.00 °C	30
    IDE06089-ENG115743-Seat heater level current consumption allocation-Sitzheizung Stufe 4 untere Schaltschwelle	34.00 °C	30
    IDE06089-ENG115746-Seat heater level current consumption allocation-Sitzheizung Stufe 5 obere Schaltschwelle	50.00 °C	30
    IDE06089-ENG115745-Seat heater level current consumption allocation-Sitzheizung Stufe 5 untere Schaltschwelle	49.00 °C	30
    IDE06089-ENG115748-Seat heater level current consumption allocation-Sitzheizung Stufe 6 obere Schaltschwelle	50.00 °C	30
    IDE06089-ENG115747-Seat heater level current consumption allocation-Sitzheizung Stufe 6 untere Schaltschwelle	49.00 °C	30
    IDE06089-ENG154774-Seat heater level current consumption allocation-Sitzheizung.Aufheizphase HI	Keine_Spannungsanforderung 	30
    IDE06089-ENG154775-Seat heater level current consumption allocation-Sitzheizung.Regelbetrieb LO	Keine_Spannungsanforderung 	30
    IDE06089-ENG141977-Seat heater level current consumption allocation-Sitzheizungsfreigabe	not installed 	30
    IDE06089-ENG154785-Seat heater level current consumption allocation-Spannungsoffset SIH_75	15.0 V	30
    IDE06425-Roller test bench mode: functional	not active 	1
    IDE06507-MAS13125-Button in center console-Function of button 1	not coded/not installed 	8
    IDE06507-MAS13129-Button in center console-Function of button 2	not coded/not installed 	8
    IDE06507-MAS13132-Button in center console-Function of button 3	Driving program 	8
    IDE06507-MAS13135-Button in center console-Function of button 4	not coded/not installed 	8
    IDE06507-ENG140243-Button in center console-Zusatzcodierung Fahrprofiltaster hat keine LED	LED installed 	8
    IDE07007-ENG142253-A/C heater function via remote control-Abbruch_d_Warnblinker_moeglich	active 	8
    IDE07007-ENG142252-A/C heater function via remote control-Abbruch_Hupen_RSt	not active 	8
    IDE07007-ENG142255-A/C heater function via remote control-Aktivierung_Drehzahlanzeige	active 	8
    IDE07007-ENG142254-A/C heater function via remote control-Kombi_Fahrerhinweis_m_Akustik	active 	8
    IDE07007-ENG128461-A/C heater function via remote control-Kombi_Fahrerhinweis_m_Uebernahme_RSt	active 	8
    IDE07007-ENG115720-A/C heater function via remote control-Remote Start	not installed 	8
    IDE07007-ENG128460-A/C heater function via remote control-Rueckmeldung_bei_Aktivierung	active 	8
    IDE07356-Position during interval mode	31.494474 °	2
    IDE07470-ENG116719-After-run for park light-Bedingungen zur Beendigung des Standlichtnachlaufs	not active 	6
    IDE07470-ENG116720-After-run for park light-Standlicht-Nachlaufzeit	255 min	6
    IDE07470-ENG126843-After-run for park light-ZV verriegeln bei Klemme 15 Ein	active 	6
    IDE08786-ENG115723-Assistance light functions-Assistenzfahrlicht bei Regen	active 	9
    IDE08786-ENG141956-Assistance light functions-Humidity sensor	not installed 	9
    IDE08786-ENG115724-Assistance light functions-Lichtsensorempfindlichkeit	normal 	9
    IDE08786-ENG126628-Assistance light functions-LS_Error_Ausgabe	not active 	9
    IDE08786-ENG142228-Assistance light functions-Maskierung_Regenfunktion	not active 	9
    IDE08786-ENG141985-Assistance light functions-Regen_Lichtsensor	LIN_REGEN_LICHT_SENSOR 	9
    IDE08786-ENG124476-Assistance light functions-Sunlight Sensor	not installed 	9
    IDE09731-ENG154511-Int. light: 2nd generation-Ambiente_Fahrprofil_Individual	7	19
    IDE09731-ENG154512-Int. light: 2nd generation-Ambiente_Farbliste_HMI_mit_Farbtransformation	not active 	19
    IDE09731-ENG154513-Int. light: 2nd generation-Ambiente_Farbwahl_FPA_waehlbare_Kopplung	not active 	19
    IDE09731-ENG154514-Int. light: 2nd generation-Ambiente_Farbwahl_FPA_waehlbare_Kopplung_Status_hmi_default	active 	19
    IDE09731-ENG125014-Int. light: 2nd generation-Aufloesung Dimmzeit	0.10 s	19
    IDE09731-ENG125024-Int. light: 2nd generation-BAP Farbwert Farbe 1	2	19
    IDE09731-ENG125025-Int. light: 2nd generation-BAP Farbwert Farbe 2	3	19
    IDE09731-ENG125026-Int. light: 2nd generation-BAP Farbwert Farbe 3	1	19
    IDE09731-ENG125018-Int. light: 2nd generation-Cockpitbeleuchtung mehrfarbig	not active 	19
    IDE09731-ENG125021-Int. light: 2nd generation-Dachbeleuchtung mehrfarbig	not active 	19
    IDE09731-ENG125028-Int. light: 2nd generation-Defaultwert Ambienteprofil Dach	80%	19
    IDE09731-ENG125029-Int. light: 2nd generation-Defaultwert Ambienteprofil Farbe	0	19
    IDE09731-ENG115822-Int. light: 2nd generation-Defaultwert Ambienteprofil Fussraum	50%	19
    IDE09731-ENG125027-Int. light: 2nd generation-Defaultwert Ambienteprofil Mittelkonsole	80%	19
    IDE09731-ENG116685-Int. light: 2nd generation-Defaultwert Ambienteprofil Tuer	50%	19
    IDE09731-ENG115823-Int. light: 2nd generation-Defaultwert Ambienteprofil Vorn	50%	19
    IDE09731-ENG125641-Int. light: 2nd generation-Farbausgabe Cockpitbeleuchtung nicht berechnen	active 	19
    IDE09731-ENG125644-Int. light: 2nd generation-Farbausgabe Dachbeleuchtung nicht berechnen	active 	19
    IDE09731-ENG125640-Int. light: 2nd generation-Farbausgabe Instrumententafelbeleuchtung nicht berechnen	active 	19
    IDE09731-ENG125642-Int. light: 2nd generation-Farbausgabe Lautsprecherbeleuchtung nicht berechnen	active 	19
    IDE09731-ENG125643-Int. light: 2nd generation-Farbausgabe Mittelkonsolenbeleuchtung nicht berechnen	active 	19
    IDE09731-ENG125645-Int. light: 2nd generation-Farbausgabe Panoramaschiebedachbeleuchtung nicht berechnen	active 	19
    IDE09731-ENG125639-Int. light: 2nd generation-Farbausgabe Tuertafelbeleuchtung nicht berechnen	active 	19
    IDE09731-ENG125634-Int. light: 2nd generation-Helligkeit Cockpitbeleuchtung nicht berechnen	active 	19
    IDE09731-ENG125637-Int. light: 2nd generation-Helligkeit Dachbeleuchtung nicht berechnen	active 	19
    IDE09731-ENG125633-Int. light: 2nd generation-Helligkeit Instrumententafelbeleuchtung nicht berechnen	active 	19
    IDE09731-ENG125635-Int. light: 2nd generation-Helligkeit Lautsprecherbeleuchtung nicht berechnen	active 	19
    IDE09731-ENG125636-Int. light: 2nd generation-Helligkeit Mittelkonsolenbeleuchtung nicht berechnen	active 	19
    IDE09731-ENG125638-Int. light: 2nd generation-Helligkeit Panoramaschiebedachbeleuchtung nicht berechnen	active 	19
    IDE09731-ENG142233-Int. light: 2nd generation-Helligkeit_Tuertafelbeleuchtung_nicht_berechnen	not active 	19
    IDE09731-ENG116596-Int. light: 2nd generation-Innenlicht bei offenem Heckdeckel einschalten	active 	19
    IDE09731-ENG125017-Int. light: 2nd generation-Instrumententafelbeleuchtung mehrfarbig	not active 	19
    IDE09731-ENG98648-Int. light: 2nd generation-Interior light	Keine_Spannungsanforderung 	19
    IDE09731-ENG116597-Int. light: 2nd generation-KL30G ohne PWM	not active 	19
    IDE09731-ENG125019-Int. light: 2nd generation-Lautsprecherbeleuchtung mehrfarbig	not active 	19
    IDE09731-ENG142031-Int. light: 2nd generation-LIN-Dachkonsole mit Flaechenlicht	not installed 	19
    IDE09731-ENG125020-Int. light: 2nd generation-Mittelkonsolenbeleuchtung mehrfarbig	not active 	19
    IDE09731-ENG125023-Int. light: 2nd generation-Panoramaschiebedachbeleuchtung bei geoeffnetem Rollo deaktivieren	not active 	19
    IDE09731-ENG125022-Int. light: 2nd generation-Panoramaschiebedachbeleuchtung mehrfarbig	not active 	19
    IDE09731-ENG116687-Int. light: 2nd generation-Tuerinnengriff mit Tuertafel	not installed 	19
    IDE09731-ENG116686-Int. light: 2nd generation-Tuerinnengriffbeleuchtung mit I-Tafel	not installed 	19
    IDE09731-ENG125016-Int. light: 2nd generation-Tuertafelbeleuchtung mehrfarbig	not active 	19
    IDE09731-ENG142184-Int. light: 2nd generation-Weckfaehigkeit_klemme_30G	installed 	19
    IDE09731-ENG125015-Int. light: 2nd generation-weicher Farbwechsel	not active 	19
    IDE09732-ENG154509-Interior light: light configuration-Ambience_light_colorlist_default	0	5
    IDE09732-ENG133384-Interior light: light configuration-Ambient_Farbliste_HMI	not active 	5
    IDE09732-ENG115870-Interior light: light configuration-Ambiente_Applikationsleisten_in_Instrumententafel	not installed 	5
    IDE09732-ENG115871-Interior light: light configuration-Ambiente_Applikationsleisten_in_Tuertafel	installed 	5
    IDE09732-ENG115872-Interior light: light configuration-Ambiente_Lautsprecher	not installed 	5
    IDE09732-ENG126836-Interior light: light configuration-Ambientemenue mit alle Zonen	not active 	5
    IDE09732-ENG126835-Interior light: light configuration-Ambientemenue mit globalem aus	not active 	5
    IDE09732-ENG125646-Interior light: light configuration-Cockpitbeleuchtung	not installed 	5
    IDE09732-ENG125648-Interior light: light configuration-Dachbeleuchtung	not installed 	5
    IDE09732-ENG125651-Interior light: light configuration-Farbwahl ueber Fahrprofil	not installed 	5
    IDE09732-ENG125650-Interior light: light configuration-Farbwahl ueber HMI	not installed 	5
    IDE09732-ENG114629-Interior light: light configuration-Foot well lighting	installed 	5
    IDE09732-ENG133385-Interior light: light configuration-Frei_Farbwahl_ueber_HMI	not active 	5
    IDE09732-ENG126834-Interior light: light configuration-LIN-Dachkonsole lokal aktivierbar	not active 	5
    IDE09732-ENG125647-Interior light: light configuration-Mittelkonsolenbeleuchtung	not installed 	5
    IDE09732-ENG125649-Interior light: light configuration-Panoramaschiebedachbeleuchtung	not installed 	5
    IDE09761-ENG126617-Seat fan charac. curve-Level_1_Lehne	30%	17
    IDE09761-ENG126616-Seat fan charac. curve-Level_1_Sitz	25%	17
    IDE09761-ENG126619-Seat fan charac. curve-Level_2_Lehne	30%	17
    IDE09761-ENG126618-Seat fan charac. curve-Level_2_Sitz	25%	17
    IDE09761-ENG126621-Seat fan charac. curve-Level_3_Lehne	58%	17
    IDE09761-ENG126620-Seat fan charac. curve-Level_3_Sitz	53%	17
    IDE09761-ENG126623-Seat fan charac. curve-Level_4_Lehne	58%	17
    IDE09761-ENG126622-Seat fan charac. curve-Level_4_Sitz	53%	17
    IDE09761-ENG126625-Seat fan charac. curve-Level_5_Lehne	85%	17
    IDE09761-ENG126624-Seat fan charac. curve-Level_5_Sitz	80%	17
    IDE09761-ENG126627-Seat fan charac. curve-Level_6_Lehne	85%	17
    IDE09761-ENG126626-Seat fan charac. curve-Level_6_Sitz	80%	17
    IDE09761-ENG142024-Seat fan charac. curve-Sitzlueftung	not installed 	17
    IDE09761-ENG142183-Seat fan charac. curve-Sitzlueftung_reduzierbar	installed 	17
    IDE09761-ENG142025-Seat fan charac. curve-Sitzpneumatik	not installed 	17
    IDE10298-Alternating park position 1	7.494498 °	2
    IDE10299-Alternating park position 2	29.494476 °	2
    IDE11477-ENG128587-Interior lighting: parameter-p_adaption_kundenwunsch_cockpit	1	256
    IDE11477-ENG128619-Interior lighting: parameter-p_adaption_kundenwunsch_dach	1	256
    IDE11477-ENG128539-Interior lighting: parameter-p_adaption_kundenwunsch_fussraum	0.2	256
    IDE11477-ENG128571-Interior lighting: parameter-p_adaption_kundenwunsch_itafel	1	256
    IDE11477-ENG128555-Interior lighting: parameter-p_adaption_kundenwunsch_lautsprecher	1	256
    IDE11477-ENG128603-Interior lighting: parameter-p_adaption_kundenwunsch_miko	1	256
    IDE11477-ENG128635-Interior lighting: parameter-p_adaption_kundenwunsch_psd	1	256
    IDE11477-ENG128523-Interior lighting: parameter-p_adaption_kundenwunsch_tuer	0.6	256
    IDE11477-ENG128659-Interior lighting: parameter-p_ambientelicht_verbauinformation_HMI	0	256
    IDE11477-ENG128660-Interior lighting: parameter-p_ambientelicht_verbauinformation_HMI_2	0	256
    IDE11477-ENG128661-Interior lighting: parameter-p_ambientelicht_verbauinformation_HMI_3	0	256
    IDE11477-ENG128662-Interior lighting: parameter-p_ambientelicht_verbauinformation_HMI_4	0	256
    IDE11477-ENG128655-Interior lighting: parameter-p_ambienteumfang_mehrfarbig_HMI	0	256
    IDE11477-ENG128656-Interior lighting: parameter-p_ambienteumfang_mehrfarbig_HMI_2	0	256
    IDE11477-ENG128657-Interior lighting: parameter-p_ambienteumfang_mehrfarbig_HMI_3	0	256
    IDE11477-ENG128658-Interior lighting: parameter-p_ambienteumfang_mehrfarbig_HMI_4	0	256
    IDE11477-ENG128652-Interior lighting: parameter-p_dimmfaktor_farbwechsel_ab	1	256
    IDE11477-ENG128651-Interior lighting: parameter-p_dimmfaktor_farbwechsel_auf	1	256
    IDE11477-ENG128654-Interior lighting: parameter-p_farbauswahl_HMI	0	256
    IDE11477-ENG128653-Interior lighting: parameter-p_farbwechsel_delay	0	256
    IDE11477-ENG128596-Interior lighting: parameter-p_helligkeit_andereTuer_auf_zuendung_aus_cockpit	100%	256
    IDE11477-ENG128628-Interior lighting: parameter-p_helligkeit_andereTuer_auf_zuendung_aus_dach	100%	256
    IDE11477-ENG128548-Interior lighting: parameter-p_helligkeit_andereTuer_auf_zuendung_aus_fussraum	70%	256
    IDE11477-ENG128516-Interior lighting: parameter-p_helligkeit_andereTuer_auf_zuendung_aus_innenlicht	100%	256
    IDE11477-ENG128580-Interior lighting: parameter-p_helligkeit_andereTuer_auf_zuendung_aus_itafel	100%	256
    IDE11477-ENG128564-Interior lighting: parameter-p_helligkeit_andereTuer_auf_zuendung_aus_lautsprecher	100%	256
    IDE11477-ENG128612-Interior lighting: parameter-p_helligkeit_andereTuer_auf_zuendung_aus_miko	100%	256
    IDE11477-ENG128644-Interior lighting: parameter-p_helligkeit_andereTuer_auf_zuendung_aus_psd	100%	256
    IDE11477-ENG128532-Interior lighting: parameter-p_helligkeit_andereTuer_auf_zuendung_aus_tueren	96%	256
    IDE11477-ENG128593-Interior lighting: parameter-p_helligkeit_andereTuer_auf_zuendung_ein_cockpit	100%	256
    IDE11477-ENG128625-Interior lighting: parameter-p_helligkeit_andereTuer_auf_zuendung_ein_dach	100%	256
    IDE11477-ENG128545-Interior lighting: parameter-p_helligkeit_andereTuer_auf_zuendung_ein_fussraum	70%	256
    IDE11477-ENG128513-Interior lighting: parameter-p_helligkeit_andereTuer_auf_zuendung_ein_innenlicht	100%	256
    IDE11477-ENG128577-Interior lighting: parameter-p_helligkeit_andereTuer_auf_zuendung_ein_itafel	100%	256
    IDE11477-ENG128561-Interior lighting: parameter-p_helligkeit_andereTuer_auf_zuendung_ein_lautsprecher	100%	256
    IDE11477-ENG128609-Interior lighting: parameter-p_helligkeit_andereTuer_auf_zuendung_ein_miko	100%	256
    IDE11477-ENG128641-Interior lighting: parameter-p_helligkeit_andereTuer_auf_zuendung_ein_psd	100%	256
    IDE11477-ENG128529-Interior lighting: parameter-p_helligkeit_andereTuer_auf_zuendung_ein_tueren	96%	256
    IDE11477-ENG128595-Interior lighting: parameter-p_helligkeit_dieseTuer_auf_zuendung_aus_cockpit	100%	256
    IDE11477-ENG128627-Interior lighting: parameter-p_helligkeit_dieseTuer_auf_zuendung_aus_dach	100%	256
    IDE11477-ENG128547-Interior lighting: parameter-p_helligkeit_dieseTuer_auf_zuendung_aus_fussraum	70%	256
    IDE11477-ENG128515-Interior lighting: parameter-p_helligkeit_dieseTuer_auf_zuendung_aus_innenlicht	100%	256
    IDE11477-ENG128579-Interior lighting: parameter-p_helligkeit_dieseTuer_auf_zuendung_aus_itafel	100%	256
    IDE11477-ENG128563-Interior lighting: parameter-p_helligkeit_dieseTuer_auf_zuendung_aus_lautsprecher	100%	256
    IDE11477-ENG128611-Interior lighting: parameter-p_helligkeit_dieseTuer_auf_zuendung_aus_miko	100%	256
    IDE11477-ENG128643-Interior lighting: parameter-p_helligkeit_dieseTuer_auf_zuendung_aus_psd	100%	256
    IDE11477-ENG128531-Interior lighting: parameter-p_helligkeit_dieseTuer_auf_zuendung_aus_tueren	96%	256
    IDE11477-ENG128592-Interior lighting: parameter-p_helligkeit_dieseTuer_auf_zuendung_ein_cockpit	100%	256
    IDE11477-ENG128624-Interior lighting: parameter-p_helligkeit_dieseTuer_auf_zuendung_ein_dach	100%	256
    IDE11477-ENG128544-Interior lighting: parameter-p_helligkeit_dieseTuer_auf_zuendung_ein_fussraum	70%	256
    IDE11477-ENG128512-Interior lighting: parameter-p_helligkeit_dieseTuer_auf_zuendung_ein_innenlicht	100%	256
    IDE11477-ENG128576-Interior lighting: parameter-p_helligkeit_dieseTuer_auf_zuendung_ein_itafel	100%	256
    IDE11477-ENG128560-Interior lighting: parameter-p_helligkeit_dieseTuer_auf_zuendung_ein_lautsprecher	100%	256
    IDE11477-ENG128608-Interior lighting: parameter-p_helligkeit_dieseTuer_auf_zuendung_ein_miko	100%	256
    IDE11477-ENG128640-Interior lighting: parameter-p_helligkeit_dieseTuer_auf_zuendung_ein_psd	100%	256
    IDE11477-ENG128528-Interior lighting: parameter-p_helligkeit_dieseTuer_auf_zuendung_ein_tueren	96%	256
    IDE11477-ENG128597-Interior lighting: parameter-p_helligkeit_einausstieg_cockpit	100%	256
    IDE11477-ENG128629-Interior lighting: parameter-p_helligkeit_einausstieg_dach	100%	256
    IDE11477-ENG128549-Interior lighting: parameter-p_helligkeit_einausstieg_fussraum	70%	256
    IDE11477-ENG128517-Interior lighting: parameter-p_helligkeit_einausstieg_innenlicht	100%	256
    IDE11477-ENG128581-Interior lighting: parameter-p_helligkeit_einausstieg_itafel	100%	256
    IDE11477-ENG128565-Interior lighting: parameter-p_helligkeit_einausstieg_lautsprecher	100%	256
    IDE11477-ENG128613-Interior lighting: parameter-p_helligkeit_einausstieg_miko	100%	256
    IDE11477-ENG128645-Interior lighting: parameter-p_helligkeit_einausstieg_psd	100%	256
    IDE11477-ENG128533-Interior lighting: parameter-p_helligkeit_einausstieg_tueren	96%	256
    IDE11477-ENG128588-Interior lighting: parameter-p_helligkeit_entriegelt_cockpit	100%	256
    IDE11477-ENG128620-Interior lighting: parameter-p_helligkeit_entriegelt_dach	100%	256
    IDE11477-ENG128540-Interior lighting: parameter-p_helligkeit_entriegelt_fussraum	0%	256
    IDE11477-ENG128508-Interior lighting: parameter-p_helligkeit_entriegelt_innenlicht	100%	256
    IDE11477-ENG128572-Interior lighting: parameter-p_helligkeit_entriegelt_itafel	100%	256
    IDE11477-ENG128556-Interior lighting: parameter-p_helligkeit_entriegelt_lautsprecher	100%	256
    IDE11477-ENG128604-Interior lighting: parameter-p_helligkeit_entriegelt_miko	100%	256
    IDE11477-ENG128636-Interior lighting: parameter-p_helligkeit_entriegelt_psd	100%	256
    IDE11477-ENG128524-Interior lighting: parameter-p_helligkeit_entriegelt_tueren	0%	256
    IDE11477-ENG128602-Interior lighting: parameter-p_helligkeit_Fzg_geschlossen_schluessel_ab_cockpit	100%	256
    IDE11477-ENG128634-Interior lighting: parameter-p_helligkeit_Fzg_geschlossen_schluessel_ab_dach	100%	256
    IDE11477-ENG128554-Interior lighting: parameter-p_helligkeit_Fzg_geschlossen_schluessel_ab_fussraum	70%	256
    IDE11477-ENG128522-Interior lighting: parameter-p_helligkeit_Fzg_geschlossen_schluessel_ab_innenlicht	100%	256
    IDE11477-ENG128586-Interior lighting: parameter-p_helligkeit_Fzg_geschlossen_schluessel_ab_itafel	100%	256
    IDE11477-ENG128570-Interior lighting: parameter-p_helligkeit_Fzg_geschlossen_schluessel_ab_lautsprecher	100%	256
    IDE11477-ENG128618-Interior lighting: parameter-p_helligkeit_Fzg_geschlossen_schluessel_ab_miko	100%	256
    IDE11477-ENG128650-Interior lighting: parameter-p_helligkeit_Fzg_geschlossen_schluessel_ab_psd	100%	256
    IDE11477-ENG128538-Interior lighting: parameter-p_helligkeit_Fzg_geschlossen_schluessel_ab_tueren	96%	256
    IDE11477-ENG128598-Interior lighting: parameter-p_helligkeit_Fzg_geschlossen_zuendung_aus_cockpit	100%	256
    IDE11477-ENG128630-Interior lighting: parameter-p_helligkeit_Fzg_geschlossen_zuendung_aus_dach	100%	256
    IDE11477-ENG128550-Interior lighting: parameter-p_helligkeit_Fzg_geschlossen_zuendung_aus_fussraum	127%	256
    IDE11477-ENG128518-Interior lighting: parameter-p_helligkeit_Fzg_geschlossen_zuendung_aus_innenlicht	100%	256
    IDE11477-ENG128582-Interior lighting: parameter-p_helligkeit_Fzg_geschlossen_zuendung_aus_itafel	100%	256
    IDE11477-ENG128566-Interior lighting: parameter-p_helligkeit_Fzg_geschlossen_zuendung_aus_lautsprecher	100%	256
    IDE11477-ENG128614-Interior lighting: parameter-p_helligkeit_Fzg_geschlossen_zuendung_aus_miko	100%	256
    IDE11477-ENG128646-Interior lighting: parameter-p_helligkeit_Fzg_geschlossen_zuendung_aus_psd	100%	256
    IDE11477-ENG128534-Interior lighting: parameter-p_helligkeit_Fzg_geschlossen_zuendung_aus_tueren	127%	256
    IDE11477-ENG128594-Interior lighting: parameter-p_helligkeit_Fzg_geschlossen_zuendung_ein_cockpit	126%	256
    IDE11477-ENG128626-Interior lighting: parameter-p_helligkeit_Fzg_geschlossen_zuendung_ein_dach	126%	256
    IDE11477-ENG128546-Interior lighting: parameter-p_helligkeit_Fzg_geschlossen_zuendung_ein_fussraum	126%	256
    IDE11477-ENG128514-Interior lighting: parameter-p_helligkeit_Fzg_geschlossen_zuendung_ein_innenlicht	0%	256
    IDE11477-ENG128578-Interior lighting: parameter-p_helligkeit_Fzg_geschlossen_zuendung_ein_itafel	126%	256
    IDE11477-ENG128562-Interior lighting: parameter-p_helligkeit_Fzg_geschlossen_zuendung_ein_lautsprecher	126%	256
    IDE11477-ENG128610-Interior lighting: parameter-p_helligkeit_Fzg_geschlossen_zuendung_ein_miko	126%	256
    IDE11477-ENG128642-Interior lighting: parameter-p_helligkeit_Fzg_geschlossen_zuendung_ein_psd	126%	256
    IDE11477-ENG128530-Interior lighting: parameter-p_helligkeit_Fzg_geschlossen_zuendung_ein_tueren	126%	256
    IDE11477-ENG128591-Interior lighting: parameter-p_helligkeit_HD_auf_zuendung_aus_cockpit	100%	256
    IDE11477-ENG128623-Interior lighting: parameter-p_helligkeit_HD_auf_zuendung_aus_dach	100%	256
    IDE11477-ENG128543-Interior lighting: parameter-p_helligkeit_HD_auf_zuendung_aus_fussraum	127%	256
    IDE11477-ENG128511-Interior lighting: parameter-p_helligkeit_HD_auf_zuendung_aus_innenlicht	100%	256
    IDE11477-ENG128575-Interior lighting: parameter-p_helligkeit_HD_auf_zuendung_aus_itafel	100%	256
    IDE11477-ENG128559-Interior lighting: parameter-p_helligkeit_HD_auf_zuendung_aus_lautsprecher	100%	256
    IDE11477-ENG128607-Interior lighting: parameter-p_helligkeit_HD_auf_zuendung_aus_miko	100%	256
    IDE11477-ENG128639-Interior lighting: parameter-p_helligkeit_HD_auf_zuendung_aus_psd	100%	256
    IDE11477-ENG128527-Interior lighting: parameter-p_helligkeit_HD_auf_zuendung_aus_tueren	127%	256
    IDE11477-ENG128590-Interior lighting: parameter-p_helligkeit_HD_auf_zuendung_ein_cockpit	100%	256
    IDE11477-ENG128622-Interior lighting: parameter-p_helligkeit_HD_auf_zuendung_ein_dach	100%	256
    IDE11477-ENG128542-Interior lighting: parameter-p_helligkeit_HD_auf_zuendung_ein_fussraum	126%	256
    IDE11477-ENG128510-Interior lighting: parameter-p_helligkeit_HD_auf_zuendung_ein_innenlicht	100%	256
    IDE11477-ENG128574-Interior lighting: parameter-p_helligkeit_HD_auf_zuendung_ein_itafel	100%	256
    IDE11477-ENG128558-Interior lighting: parameter-p_helligkeit_HD_auf_zuendung_ein_lautsprecher	100%	256
    IDE11477-ENG128606-Interior lighting: parameter-p_helligkeit_HD_auf_zuendung_ein_miko	100%	256
    IDE11477-ENG128638-Interior lighting: parameter-p_helligkeit_HD_auf_zuendung_ein_psd	100%	256
    IDE11477-ENG128526-Interior lighting: parameter-p_helligkeit_HD_auf_zuendung_ein_tueren	126%	256
    IDE11477-ENG128589-Interior lighting: parameter-p_helligkeit_max_cockpit	100%	256
    IDE11477-ENG128621-Interior lighting: parameter-p_helligkeit_max_dach	100%	256
    IDE11477-ENG128541-Interior lighting: parameter-p_helligkeit_max_fussraum	70%	256
    IDE11477-ENG128509-Interior lighting: parameter-p_helligkeit_max_innenlicht	100%	256
    IDE11477-ENG128573-Interior lighting: parameter-p_helligkeit_max_itafel	100%	256
    IDE11477-ENG128557-Interior lighting: parameter-p_helligkeit_max_lautsprecher	100%	256
    IDE11477-ENG128605-Interior lighting: parameter-p_helligkeit_max_miko	100%	256
    IDE11477-ENG128637-Interior lighting: parameter-p_helligkeit_max_psd	100%	256
    IDE11477-ENG128525-Interior lighting: parameter-p_helligkeit_max_tueren	96%	256
    IDE11477-ENG128599-Interior lighting: parameter-p_helligkeit_Tueren_geschlossen_HD_auf_zuendung_aus_cockpit	100%	256
    IDE11477-ENG128631-Interior lighting: parameter-p_helligkeit_Tueren_geschlossen_HD_auf_zuendung_aus_dach	100%	256
    IDE11477-ENG128551-Interior lighting: parameter-p_helligkeit_Tueren_geschlossen_HD_auf_zuendung_aus_fussraum	70%	256
    IDE11477-ENG128519-Interior lighting: parameter-p_helligkeit_Tueren_geschlossen_HD_auf_zuendung_aus_innenlicht	100%	256
    IDE11477-ENG128583-Interior lighting: parameter-p_helligkeit_Tueren_geschlossen_HD_auf_zuendung_aus_itafel	100%	256
    IDE11477-ENG128567-Interior lighting: parameter-p_helligkeit_Tueren_geschlossen_HD_auf_zuendung_aus_lautsprecher	100%	256
    IDE11477-ENG128615-Interior lighting: parameter-p_helligkeit_Tueren_geschlossen_HD_auf_zuendung_aus_miko	100%	256
    IDE11477-ENG128647-Interior lighting: parameter-p_helligkeit_Tueren_geschlossen_HD_auf_zuendung_aus_psd	100%	256
    IDE11477-ENG128535-Interior lighting: parameter-p_helligkeit_Tueren_geschlossen_HD_auf_zuendung_aus_tueren	96%	256
    IDE11477-ENG128600-Interior lighting: parameter-p_helligkeit_Tueren_geschlossen_HD_zu_zuendung_aus_cockpit	100%	256
    IDE11477-ENG128632-Interior lighting: parameter-p_helligkeit_Tueren_geschlossen_HD_zu_zuendung_aus_dach	100%	256
    IDE11477-ENG128552-Interior lighting: parameter-p_helligkeit_Tueren_geschlossen_HD_zu_zuendung_aus_fussraum	70%	256
    IDE11477-ENG128520-Interior lighting: parameter-p_helligkeit_Tueren_geschlossen_HD_zu_zuendung_aus_innenlicht	100%	256
    IDE11477-ENG128584-Interior lighting: parameter-p_helligkeit_Tueren_geschlossen_HD_zu_zuendung_aus_itafel	100%	256
    IDE11477-ENG128568-Interior lighting: parameter-p_helligkeit_Tueren_geschlossen_HD_zu_zuendung_aus_lautsprecher	100%	256
    IDE11477-ENG128616-Interior lighting: parameter-p_helligkeit_Tueren_geschlossen_HD_zu_zuendung_aus_miko	100%	256
    IDE11477-ENG128648-Interior lighting: parameter-p_helligkeit_Tueren_geschlossen_HD_zu_zuendung_aus_psd	100%	256
    IDE11477-ENG128536-Interior lighting: parameter-p_helligkeit_Tueren_geschlossen_HD_zu_zuendung_aus_tueren	96%	256
    IDE11477-ENG128601-Interior lighting: parameter-p_helligkeit_Tueren_geschlossen_schluessel_ab_cockpit	100%	256
    IDE11477-ENG128633-Interior lighting: parameter-p_helligkeit_Tueren_geschlossen_schluessel_ab_dach	100%	256
    IDE11477-ENG128553-Interior lighting: parameter-p_helligkeit_Tueren_geschlossen_schluessel_ab_fussraum	70%	256
    IDE11477-ENG128521-Interior lighting: parameter-p_helligkeit_Tueren_geschlossen_schluessel_ab_innenlicht	100%	256
    IDE11477-ENG128585-Interior lighting: parameter-p_helligkeit_Tueren_geschlossen_schluessel_ab_itafel	100%	256
    IDE11477-ENG128569-Interior lighting: parameter-p_helligkeit_Tueren_geschlossen_schluessel_ab_lautsprecher	100%	256
    IDE11477-ENG128617-Interior lighting: parameter-p_helligkeit_Tueren_geschlossen_schluessel_ab_miko	100%	256
    IDE11477-ENG128649-Interior lighting: parameter-p_helligkeit_Tueren_geschlossen_schluessel_ab_psd	100%	256
    IDE11477-ENG128537-Interior lighting: parameter-p_helligkeit_Tueren_geschlossen_schluessel_ab_tueren	96%	256
    IDE11477-ENG137165-Interior lighting: parameter-p_t_HMI_verzoegerung_helligkeitswerte	200 ms	256
    IDE11477-ENG128488-Interior lighting: parameter-p_t_verzoegerung_ausstieg_cockpit	0.0 s	256
    IDE11477-ENG128502-Interior lighting: parameter-p_t_verzoegerung_ausstieg_dach	0.0 s	256
    IDE11477-ENG128481-Interior lighting: parameter-p_t_verzoegerung_ausstieg_fussraum	0.0 s	256
    IDE11477-ENG128467-Interior lighting: parameter-p_t_verzoegerung_ausstieg_innenlicht	0.0 s	256
    IDE11477-ENG128495-Interior lighting: parameter-p_t_verzoegerung_ausstieg_miko	0.0 s	256
    IDE11477-ENG128474-Interior lighting: parameter-p_t_verzoegerung_ausstieg_tueren	0.0 s	256
    IDE11477-ENG128487-Interior lighting: parameter-p_t_verzoegerung_einstieg_cockpit	0.0 s	256
    IDE11477-ENG128501-Interior lighting: parameter-p_t_verzoegerung_einstieg_dach	0.0 s	256
    IDE11477-ENG128480-Interior lighting: parameter-p_t_verzoegerung_einstieg_fussraum	2.0 s	256
    IDE11477-ENG128466-Interior lighting: parameter-p_t_verzoegerung_einstieg_innenlicht	0.0 s	256
    IDE11477-ENG128494-Interior lighting: parameter-p_t_verzoegerung_einstieg_miko	0.0 s	256
    IDE11477-ENG128473-Interior lighting: parameter-p_t_verzoegerung_einstieg_tueren	0.5 s	256
    IDE11477-ENG128490-Interior lighting: parameter-p_t_verzoegerung_entriegelt_cockpit	0.0 s	256
    IDE11477-ENG128504-Interior lighting: parameter-p_t_verzoegerung_entriegelt_dach	0.0 s	256
    IDE11477-ENG128483-Interior lighting: parameter-p_t_verzoegerung_entriegelt_fussraum	0.0 s	256
    IDE11477-ENG128469-Interior lighting: parameter-p_t_verzoegerung_entriegelt_innenlicht	0.0 s	256
    IDE11477-ENG128497-Interior lighting: parameter-p_t_verzoegerung_entriegelt_miko	0.0 s	256
    IDE11477-ENG128476-Interior lighting: parameter-p_t_verzoegerung_entriegelt_tueren	0.0 s	256
    IDE11477-ENG128489-Interior lighting: parameter-p_t_verzoegerung_oeffnen_cockpit	0.0 s	256
    IDE11477-ENG128503-Interior lighting: parameter-p_t_verzoegerung_oeffnen_dach	0.0 s	256
    IDE11477-ENG128482-Interior lighting: parameter-p_t_verzoegerung_oeffnen_fussraum	0.0 s	256
    IDE11477-ENG128468-Interior lighting: parameter-p_t_verzoegerung_oeffnen_innenlicht	0.0 s	256
    IDE11477-ENG128496-Interior lighting: parameter-p_t_verzoegerung_oeffnen_miko	0.0 s	256
    IDE11477-ENG128475-Interior lighting: parameter-p_t_verzoegerung_oeffnen_tueren	0.0 s	256
    IDE11477-ENG128491-Interior lighting: parameter-p_t_verzoegerung_schliessen_cockpit	0.0 s	256
    IDE11477-ENG128505-Interior lighting: parameter-p_t_verzoegerung_schliessen_dach	0.0 s	256
    IDE11477-ENG128484-Interior lighting: parameter-p_t_verzoegerung_schliessen_fussraum	0.0 s	256
    IDE11477-ENG128470-Interior lighting: parameter-p_t_verzoegerung_schliessen_innenlicht	0.0 s	256
    IDE11477-ENG128498-Interior lighting: parameter-p_t_verzoegerung_schliessen_miko	0.0 s	256
    IDE11477-ENG128477-Interior lighting: parameter-p_t_verzoegerung_schliessen_tueren	0.0 s	256
    IDE11477-ENG128492-Interior lighting: parameter-p_t_verzoegerung_schluessel_ab_cockpit	0.0 s	256
    IDE11477-ENG128506-Interior lighting: parameter-p_t_verzoegerung_schluessel_ab_dach	0.0 s	256
    IDE11477-ENG128485-Interior lighting: parameter-p_t_verzoegerung_schluessel_ab_fussraum	0.0 s	256
    IDE11477-ENG128471-Interior lighting: parameter-p_t_verzoegerung_schluessel_ab_innenlicht	0.0 s	256
    IDE11477-ENG128499-Interior lighting: parameter-p_t_verzoegerung_schluessel_ab_miko	0.0 s	256
    IDE11477-ENG128478-Interior lighting: parameter-p_t_verzoegerung_schluessel_ab_tueren	0.0 s	256
    IDE11477-ENG128493-Interior lighting: parameter-p_t_verzoegerung_verriegelt_cockpit	0.0 s	256
    IDE11477-ENG128507-Interior lighting: parameter-p_t_verzoegerung_verriegelt_dach	0.0 s	256
    IDE11477-ENG128486-Interior lighting: parameter-p_t_verzoegerung_verriegelt_fussraum	0.0 s	256
    IDE11477-ENG128472-Interior lighting: parameter-p_t_verzoegerung_verriegelt_innenlicht	0.0 s	256
    IDE11477-ENG128500-Interior lighting: parameter-p_t_verzoegerung_verriegelt_miko	0.0 s	256
    IDE11477-ENG128479-Interior lighting: parameter-p_t_verzoegerung_verriegelt_tueren	0.0 s	256
    IDE11477-ENG128663-Interior lighting: parameter-p_verzoegerung_berechnen	0	256
    IDE11714-ENG126827-Ambient light color list-Blauwert Farbe 1	0	30
    IDE11714-ENG133432-Ambient light color list-Blauwert Farbe 10	0	30
    IDE11714-ENG126830-Ambient light color list-Blauwert Farbe 2	0	30
    IDE11714-ENG126833-Ambient light color list-Blauwert Farbe 3	0	30
    IDE11714-ENG133414-Ambient light color list-Blauwert Farbe 4	0	30
    IDE11714-ENG133417-Ambient light color list-Blauwert Farbe 5	0	30
    IDE11714-ENG133420-Ambient light color list-Blauwert Farbe 6	0	30
    IDE11714-ENG133423-Ambient light color list-Blauwert Farbe 7	0	30
    IDE11714-ENG133426-Ambient light color list-Blauwert Farbe 8	0	30
    IDE11714-ENG133429-Ambient light color list-Blauwert Farbe 9	0	30
    IDE11714-ENG126826-Ambient light color list-Gruenwert Farbe 1	0	30
    IDE11714-ENG133431-Ambient light color list-Gruenwert Farbe 10	0	30
    IDE11714-ENG126829-Ambient light color list-Gruenwert Farbe 2	0	30
    IDE11714-ENG126832-Ambient light color list-Gruenwert Farbe 3	0	30
    IDE11714-ENG133413-Ambient light color list-Gruenwert Farbe 4	0	30
    IDE11714-ENG133416-Ambient light color list-Gruenwert Farbe 5	0	30
    IDE11714-ENG133419-Ambient light color list-Gruenwert Farbe 6	0	30
    IDE11714-ENG133422-Ambient light color list-Gruenwert Farbe 7	0	30
    IDE11714-ENG133425-Ambient light color list-Gruenwert Farbe 8	0	30
    IDE11714-ENG133428-Ambient light color list-Gruenwert Farbe 9	0	30
    IDE11714-ENG126825-Ambient light color list-Rotwert Farbe 1	0	30
    IDE11714-ENG133430-Ambient light color list-Rotwert Farbe 10	0	30
    IDE11714-ENG126828-Ambient light color list-Rotwert Farbe 2	0	30
    IDE11714-ENG126831-Ambient light color list-Rotwert Farbe 3	0	30
    IDE11714-ENG133412-Ambient light color list-Rotwert Farbe 4	0	30
    IDE11714-ENG133415-Ambient light color list-Rotwert Farbe 5	0	30
    IDE11714-ENG133418-Ambient light color list-Rotwert Farbe 6	0	30
    IDE11714-ENG133421-Ambient light color list-Rotwert Farbe 7	0	30
    IDE11714-ENG133424-Ambient light color list-Rotwert Farbe 8	0	30
    IDE11714-ENG133427-Ambient light color list-Rotwert Farbe 9	0	30
    IDE11944-ENG142014-Keyless access and start authorization-Elektische_Lenkradverriegelung	not installed 	3
    IDE11944-ENG141948-Keyless access and start authorization-Kessy	not installed 	3
    IDE11944-ENG116653-Keyless access and start authorization-Kessy Komfort oeffnen	not active 	3
    IDE11944-ENG116654-Keyless access and start authorization-Kessy Komfort schliessen	active 	3
    IDE11944-ENG116655-Keyless access and start authorization-Kessy Komfortbedienung Reichweitenbegrenzung	not active 	3
    IDE11944-ENG116626-Keyless access and start authorization-Oeffnung Heckdeckel bei Wiederentriegelung	not active 	3
    IDE12412-ENG154526-LIN Ambient light color list-Blauwert_Farbe_1_lin	0	30
    IDE12412-ENG154527-LIN Ambient light color list-Blauwert_Farbe_10_lin	0	30
    IDE12412-ENG154537-LIN Ambient light color list-Blauwert_Farbe_2_lin	0	30
    IDE12412-ENG154557-LIN Ambient light color list-Blauwert_Farbe_3_lin	0	30
    IDE12412-ENG154560-LIN Ambient light color list-Blauwert_Farbe_4_lin	0	30
    IDE12412-ENG154561-LIN Ambient light color list-Blauwert_Farbe_5_lin	0	30
    IDE12412-ENG154562-LIN Ambient light color list-Blauwert_Farbe_6_lin	0	30
    IDE12412-ENG154563-LIN Ambient light color list-Blauwert_Farbe_7_lin	0	30
    IDE12412-ENG154564-LIN Ambient light color list-Blauwert_Farbe_8_lin	0	30
    IDE12412-ENG154565-LIN Ambient light color list-Blauwert_Farbe_9_lin	0	30
    IDE12412-ENG154645-LIN Ambient light color list-Gruenwert_Farbe_1_lin	0	30
    IDE12412-ENG154646-LIN Ambient light color list-Gruenwert_Farbe_10_lin	0	30
    IDE12412-ENG154656-LIN Ambient light color list-Gruenwert_Farbe_2_lin	0	30
    IDE12412-ENG154676-LIN Ambient light color list-Gruenwert_Farbe_3_lin	0	30
    IDE12412-ENG154679-LIN Ambient light color list-Gruenwert_Farbe_4_lin	0	30
    IDE12412-ENG154680-LIN Ambient light color list-Gruenwert_Farbe_5_lin	0	30
    IDE12412-ENG154681-LIN Ambient light color list-Gruenwert_Farbe_6_lin	0	30
    IDE12412-ENG154682-LIN Ambient light color list-Gruenwert_Farbe_7_lin	0	30
    IDE12412-ENG154683-LIN Ambient light color list-Gruenwert_Farbe_8_lin	0	30
    IDE12412-ENG154684-LIN Ambient light color list-Gruenwert_Farbe_9_lin	0	30
    IDE12412-ENG154733-LIN Ambient light color list-Rotwert_Farbe_1_lin	0	30
    IDE12412-ENG154734-LIN Ambient light color list-Rotwert_Farbe_10_lin	0	30
    IDE12412-ENG154744-LIN Ambient light color list-Rotwert_Farbe_2_lin	0	30
    IDE12412-ENG154764-LIN Ambient light color list-Rotwert_Farbe_3_lin	0	30
    IDE12412-ENG154767-LIN Ambient light color list-Rotwert_Farbe_4_lin	0	30
    IDE12412-ENG154768-LIN Ambient light color list-Rotwert_Farbe_5_lin	0	30
    IDE12412-ENG154769-LIN Ambient light color list-Rotwert_Farbe_6_lin	0	30
    IDE12412-ENG154770-LIN Ambient light color list-Rotwert_Farbe_7_lin	0	30
    IDE12412-ENG154771-LIN Ambient light color list-Rotwert_Farbe_8_lin	0	30
    IDE12412-ENG154772-LIN Ambient light color list-Rotwert_Farbe_9_lin	0	30
    MAS01490-ENG142027-Energy management-Energiemanagement Abschaltung	active 	5
    MAS01490-ENG116830-Energy management-Energy_Management_Adaptation	Energy management active 	5
    MAS01490-ENG142256-Energy management-Hochvoltfahrzeug	not installed 	5
    MAS01490-ENG141950-Energy management-Hybrid vehicle	No 	5
    MAS01490-ENG133400-Energy management-Praediktives_Energiemanagement	not active 	5
    MAS01490-ENG141978-Energy management-Recuperation	not active 	5
    MAS01490-ENG142037-Energy management-Zweitbatterie	not installed 	5
    MAS05055-lower turn position	31.494474 °	2
    MAS05056-upper turn position	170.494336 °	2
    MAS08228-ENG133434-Light sensor-Daemmerungsgrenze: Hysterese_obergrenze	1200 lx	24
    MAS08228-ENG133435-Light sensor-Daemmerungsgrenze_Hysterese_untergrenze	2200 lx	24
    MAS08228-ENG133444-Light sensor-ECE_Lichteinschaltschwelle	0 lx	24
    MAS08228-ENG133433-Light sensor-Einschaltgrenze_CHO_LHO	600 lx	24
    MAS08228-ENG133437-Light sensor-Helligkeitsgrenze_Licht__einschalten	1200 lx	24
    MAS08228-ENG133438-Light sensor-Helligkeitsgrenze_Licht_ausschalten	2200 lx	24
    MAS08228-ENG133445-Light sensor-Helligkeitsgrenze_Licht_ausschalten_red	00 00 	24
    MAS08228-ENG133436-Light sensor-Helligkeitsgrenze_sehr_hell	2000 lx	24
    MAS08228-ENG142230-Light sensor-HMI_Exterior_light_on_highway	not active 	24
    MAS08228-ENG142231-Light sensor-HMI_Exterior_light_on_rain	not active 	24
    MAS08228-ENG142232-Light sensor-HMI_exterior_light_sensitivity	frueh 	24
    MAS08228-ENG142229-Light sensor-HMI_Wiper_Comfort_Rain_Sensor_OFF	not active 	24
    MAS08228-ENG126628-Light sensor-LS_Error_Ausgabe	not active 	24
    MAS08228-ENG133442-Light sensor-Maximale_Ausgangsspannung	0 mV	24
    MAS08228-ENG133440-Light sensor-Maximale_Beleuchtungsstaerke	0 lx	24
    MAS08228-ENG133441-Light sensor-Minimale_Ausgangsspannung	0 mV	24
    MAS08228-ENG133439-Light sensor-Minimale_Beleuchtungsstaerke	0 lx	24
    MAS08228-ENG133443-Light sensor-Tunnel_einschalt_verzoegerung	2	24
    ENG153709-ENG154696-Aktivierung_Entwicklungsdiagnose-log_dtc_status	not active 	9
    ENG153709-ENG154697-Aktivierung_Entwicklungsdiagnose-log-dtc_DFCC	00 00 00 	9
    ENG153709-ENG154714-Aktivierung_Entwicklungsdiagnose-Reaktion_LOG-DTC	First_dtc 	9
    ENG141683-ENG116672-Allwetterlicht_Spoiler-Spoiler Einfahrunterdrueckung nach manuellem Ausfahren	not active 	4
    ENG141683-ENG116671-Allwetterlicht_Spoiler-Spoiler Komfortsenken des Spoiler ueber Schliesszylinder FT	not active 	4
    ENG141683-ENG141975-Allwetterlicht_Spoiler-tt_spoiler	not installed 	4
    ENG153710-ENG154516-Ambience_lightning_color_list_2-Blauwert Farbe 11	0	60
    ENG153710-ENG154517-Ambience_lightning_color_list_2-Blauwert Farbe 12	0	60
    ENG153710-ENG154518-Ambience_lightning_color_list_2-Blauwert Farbe 13	0	60
    ENG153710-ENG154519-Ambience_lightning_color_list_2-Blauwert Farbe 14	0	60
    ENG153710-ENG154520-Ambience_lightning_color_list_2-Blauwert Farbe 15	0	60
    ENG153710-ENG154521-Ambience_lightning_color_list_2-Blauwert Farbe 16	0	60
    ENG153710-ENG154522-Ambience_lightning_color_list_2-Blauwert Farbe 17	0	60
    ENG153710-ENG154523-Ambience_lightning_color_list_2-Blauwert Farbe 18	0	60
    ENG153710-ENG154524-Ambience_lightning_color_list_2-Blauwert Farbe 19	0	60
    ENG153710-ENG154525-Ambience_lightning_color_list_2-Blauwert Farbe 20	0	60
    ENG153710-ENG154539-Ambience_lightning_color_list_2-Blauwert_Farbe_21	0	60
    ENG153710-ENG154541-Ambience_lightning_color_list_2-Blauwert_Farbe_22	0	60
    ENG153710-ENG154543-Ambience_lightning_color_list_2-Blauwert_Farbe_23	0	60
    ENG153710-ENG154545-Ambience_lightning_color_list_2-Blauwert_Farbe_24	0	60
    ENG153710-ENG154547-Ambience_lightning_color_list_2-Blauwert_Farbe_25	0	60
    ENG153710-ENG154549-Ambience_lightning_color_list_2-Blauwert_Farbe_26	0	60
    ENG153710-ENG154551-Ambience_lightning_color_list_2-Blauwert_Farbe_27	0	60
    ENG153710-ENG154553-Ambience_lightning_color_list_2-Blauwert_Farbe_28	0	60
    ENG153710-ENG154555-Ambience_lightning_color_list_2-Blauwert_Farbe_29	0	60
    ENG153710-ENG154558-Ambience_lightning_color_list_2-Blauwert_Farbe_30	0	60
    ENG153710-ENG154635-Ambience_lightning_color_list_2-Gruenwert Farbe 11	0	60
    ENG153710-ENG154636-Ambience_lightning_color_list_2-Gruenwert Farbe 12	0	60
    ENG153710-ENG154637-Ambience_lightning_color_list_2-Gruenwert Farbe 13	0	60
    ENG153710-ENG154638-Ambience_lightning_color_list_2-Gruenwert Farbe 14	0	60
    ENG153710-ENG154639-Ambience_lightning_color_list_2-Gruenwert Farbe 15	0	60
    ENG153710-ENG154640-Ambience_lightning_color_list_2-Gruenwert Farbe 16	0	60
    ENG153710-ENG154641-Ambience_lightning_color_list_2-Gruenwert Farbe 17	0	60
    ENG153710-ENG154642-Ambience_lightning_color_list_2-Gruenwert Farbe 18	0	60
    ENG153710-ENG154643-Ambience_lightning_color_list_2-Gruenwert Farbe 19	0	60
    ENG153710-ENG154644-Ambience_lightning_color_list_2-Gruenwert Farbe 20	0	60
    ENG153710-ENG154658-Ambience_lightning_color_list_2-Gruenwert_Farbe_21	0	60
    ENG153710-ENG154660-Ambience_lightning_color_list_2-Gruenwert_Farbe_22	0	60
    ENG153710-ENG154662-Ambience_lightning_color_list_2-Gruenwert_Farbe_23	0	60
    ENG153710-ENG154664-Ambience_lightning_color_list_2-Gruenwert_Farbe_24	0	60
    ENG153710-ENG154666-Ambience_lightning_color_list_2-Gruenwert_Farbe_25	0	60
    ENG153710-ENG154668-Ambience_lightning_color_list_2-Gruenwert_Farbe_26	0	60
    ENG153710-ENG154670-Ambience_lightning_color_list_2-Gruenwert_Farbe_27	0	60
    ENG153710-ENG154672-Ambience_lightning_color_list_2-Gruenwert_Farbe_28	0	60
    ENG153710-ENG154674-Ambience_lightning_color_list_2-Gruenwert_Farbe_29	0	60
    ENG153710-ENG154677-Ambience_lightning_color_list_2-Gruenwert_Farbe_30	0	60
    ENG153710-ENG154723-Ambience_lightning_color_list_2-Rotwert Farbe 11	0	60
    ENG153710-ENG154724-Ambience_lightning_color_list_2-Rotwert Farbe 12	0	60
    ENG153710-ENG154725-Ambience_lightning_color_list_2-Rotwert Farbe 13	0	60
    ENG153710-ENG154726-Ambience_lightning_color_list_2-Rotwert Farbe 14	0	60
    ENG153710-ENG154727-Ambience_lightning_color_list_2-Rotwert Farbe 15	0	60
    ENG153710-ENG154728-Ambience_lightning_color_list_2-Rotwert Farbe 16	0	60
    ENG153710-ENG154729-Ambience_lightning_color_list_2-Rotwert Farbe 17	0	60
    ENG153710-ENG154730-Ambience_lightning_color_list_2-Rotwert Farbe 18	0	60
    ENG153710-ENG154731-Ambience_lightning_color_list_2-Rotwert Farbe 19	0	60
    ENG153710-ENG154732-Ambience_lightning_color_list_2-Rotwert Farbe 20	0	60
    ENG153710-ENG154746-Ambience_lightning_color_list_2-Rotwert_Farbe_21	0	60
    ENG153710-ENG154748-Ambience_lightning_color_list_2-Rotwert_Farbe_22	0	60
    ENG153710-ENG154750-Ambience_lightning_color_list_2-Rotwert_Farbe_23	0	60
    ENG153710-ENG154752-Ambience_lightning_color_list_2-Rotwert_Farbe_24	0	60
    ENG153710-ENG154754-Ambience_lightning_color_list_2-Rotwert_Farbe_25	0	60
    ENG153710-ENG154756-Ambience_lightning_color_list_2-Rotwert_Farbe_26	0	60
    ENG153710-ENG154758-Ambience_lightning_color_list_2-Rotwert_Farbe_27	0	60
    ENG153710-ENG154760-Ambience_lightning_color_list_2-Rotwert_Farbe_28	0	60
    ENG153710-ENG154762-Ambience_lightning_color_list_2-Rotwert_Farbe_29	0	60
    ENG153710-ENG154765-Ambience_lightning_color_list_2-Rotwert_Farbe_30	0	60
    ENG153711-ENG154528-Ambience_lightning_color_list_lin_2-Blauwert_Farbe_11_lin	0	60
    ENG153711-ENG154529-Ambience_lightning_color_list_lin_2-Blauwert_Farbe_12_lin	0	60
    ENG153711-ENG154530-Ambience_lightning_color_list_lin_2-Blauwert_Farbe_13_lin	0	60
    ENG153711-ENG154531-Ambience_lightning_color_list_lin_2-Blauwert_Farbe_14_lin	0	60
    ENG153711-ENG154532-Ambience_lightning_color_list_lin_2-Blauwert_Farbe_15_lin	0	60
    ENG153711-ENG154533-Ambience_lightning_color_list_lin_2-Blauwert_Farbe_16_lin	0	60
    ENG153711-ENG154534-Ambience_lightning_color_list_lin_2-Blauwert_Farbe_17_lin	0	60
    ENG153711-ENG154535-Ambience_lightning_color_list_lin_2-Blauwert_Farbe_18_lin	0	60
    ENG153711-ENG154536-Ambience_lightning_color_list_lin_2-Blauwert_Farbe_19_lin	0	60
    ENG153711-ENG154538-Ambience_lightning_color_list_lin_2-Blauwert_Farbe_20_lin	0	60
    ENG153711-ENG154540-Ambience_lightning_color_list_lin_2-Blauwert_Farbe_21_lin	0	60
    ENG153711-ENG154542-Ambience_lightning_color_list_lin_2-Blauwert_Farbe_22_lin	0	60
    ENG153711-ENG154544-Ambience_lightning_color_list_lin_2-Blauwert_Farbe_23_lin	0	60
    ENG153711-ENG154546-Ambience_lightning_color_list_lin_2-Blauwert_Farbe_24_lin	0	60
    ENG153711-ENG154548-Ambience_lightning_color_list_lin_2-Blauwert_Farbe_25_lin	0	60
    ENG153711-ENG154550-Ambience_lightning_color_list_lin_2-Blauwert_Farbe_26_lin	0	60
    ENG153711-ENG154552-Ambience_lightning_color_list_lin_2-Blauwert_Farbe_27_lin	0	60
    ENG153711-ENG154554-Ambience_lightning_color_list_lin_2-Blauwert_Farbe_28_lin	0	60
    ENG153711-ENG154556-Ambience_lightning_color_list_lin_2-Blauwert_Farbe_29_lin	0	60
    ENG153711-ENG154559-Ambience_lightning_color_list_lin_2-Blauwert_Farbe_30_lin	0	60
    ENG153711-ENG154647-Ambience_lightning_color_list_lin_2-Gruenwert_Farbe_11_lin	0	60
    ENG153711-ENG154648-Ambience_lightning_color_list_lin_2-Gruenwert_Farbe_12_lin	0	60
    ENG153711-ENG154649-Ambience_lightning_color_list_lin_2-Gruenwert_Farbe_13_lin	0	60
    ENG153711-ENG154650-Ambience_lightning_color_list_lin_2-Gruenwert_Farbe_14_lin	0	60
    ENG153711-ENG154651-Ambience_lightning_color_list_lin_2-Gruenwert_Farbe_15_lin	0	60
    ENG153711-ENG154652-Ambience_lightning_color_list_lin_2-Gruenwert_Farbe_16_lin	0	60
    ENG153711-ENG154653-Ambience_lightning_color_list_lin_2-Gruenwert_Farbe_17_lin	0	60
    ENG153711-ENG154654-Ambience_lightning_color_list_lin_2-Gruenwert_Farbe_18_lin	0	60
    ENG153711-ENG154655-Ambience_lightning_color_list_lin_2-Gruenwert_Farbe_19_lin	0	60
    ENG153711-ENG154657-Ambience_lightning_color_list_lin_2-Gruenwert_Farbe_20_lin	0	60
    ENG153711-ENG154659-Ambience_lightning_color_list_lin_2-Gruenwert_Farbe_21_lin	0	60
    ENG153711-ENG154661-Ambience_lightning_color_list_lin_2-Gruenwert_Farbe_22_lin	0	60
    ENG153711-ENG154663-Ambience_lightning_color_list_lin_2-Gruenwert_Farbe_23_lin	0	60
    ENG153711-ENG154665-Ambience_lightning_color_list_lin_2-Gruenwert_Farbe_24_lin	0	60
    ENG153711-ENG154667-Ambience_lightning_color_list_lin_2-Gruenwert_Farbe_25_lin	0	60
    ENG153711-ENG154669-Ambience_lightning_color_list_lin_2-Gruenwert_Farbe_26_lin	0	60
    ENG153711-ENG154671-Ambience_lightning_color_list_lin_2-Gruenwert_Farbe_27_lin	0	60
    ENG153711-ENG154673-Ambience_lightning_color_list_lin_2-Gruenwert_Farbe_28_lin	0	60
    ENG153711-ENG154675-Ambience_lightning_color_list_lin_2-Gruenwert_Farbe_29_lin	0	60
    ENG153711-ENG154678-Ambience_lightning_color_list_lin_2-Gruenwert_Farbe_30_lin	0	60
    ENG153711-ENG154735-Ambience_lightning_color_list_lin_2-Rotwert_Farbe_11_lin	0	60
    ENG153711-ENG154736-Ambience_lightning_color_list_lin_2-Rotwert_Farbe_12_lin	0	60
    ENG153711-ENG154737-Ambience_lightning_color_list_lin_2-Rotwert_Farbe_13_lin	0	60
    ENG153711-ENG154738-Ambience_lightning_color_list_lin_2-Rotwert_Farbe_14_lin	0	60
    ENG153711-ENG154739-Ambience_lightning_color_list_lin_2-Rotwert_Farbe_15_lin	0	60
    ENG153711-ENG154740-Ambience_lightning_color_list_lin_2-Rotwert_Farbe_16_lin	0	60
    ENG153711-ENG154741-Ambience_lightning_color_list_lin_2-Rotwert_Farbe_17_lin	0	60
    ENG153711-ENG154742-Ambience_lightning_color_list_lin_2-Rotwert_Farbe_18_lin	0	60
    ENG153711-ENG154743-Ambience_lightning_color_list_lin_2-Rotwert_Farbe_19_lin	0	60
    ENG153711-ENG154745-Ambience_lightning_color_list_lin_2-Rotwert_Farbe_20_lin	0	60
    ENG153711-ENG154747-Ambience_lightning_color_list_lin_2-Rotwert_Farbe_21_lin	0	60
    ENG153711-ENG154749-Ambience_lightning_color_list_lin_2-Rotwert_Farbe_22_lin	0	60
    ENG153711-ENG154751-Ambience_lightning_color_list_lin_2-Rotwert_Farbe_23_lin	0	60
    ENG153711-ENG154753-Ambience_lightning_color_list_lin_2-Rotwert_Farbe_24_lin	0	60
    ENG153711-ENG154755-Ambience_lightning_color_list_lin_2-Rotwert_Farbe_25_lin	0	60
    ENG153711-ENG154757-Ambience_lightning_color_list_lin_2-Rotwert_Farbe_26_lin	0	60
    ENG153711-ENG154759-Ambience_lightning_color_list_lin_2-Rotwert_Farbe_27_lin	0	60
    ENG153711-ENG154761-Ambience_lightning_color_list_lin_2-Rotwert_Farbe_28_lin	0	60
    ENG153711-ENG154763-Ambience_lightning_color_list_lin_2-Rotwert_Farbe_29_lin	0	60
    ENG153711-ENG154766-Ambience_lightning_color_list_lin_2-Rotwert_Farbe_30_lin	0	60
    ENG126649-ENG126874-ambient_lighting_lin_slaves_groups-pa_korrekturfaktor_gruppe_1	1	30
    ENG126649-ENG126901-ambient_lighting_lin_slaves_groups-pa_korrekturfaktor_gruppe_10	1	30
    ENG126649-ENG126904-ambient_lighting_lin_slaves_groups-pa_korrekturfaktor_gruppe_11	1	30
    ENG126649-ENG126907-ambient_lighting_lin_slaves_groups-pa_korrekturfaktor_gruppe_12	1	30
    ENG126649-ENG126910-ambient_lighting_lin_slaves_groups-pa_korrekturfaktor_gruppe_13	1	30
    ENG126649-ENG126913-ambient_lighting_lin_slaves_groups-pa_korrekturfaktor_gruppe_14	1	30
    ENG126649-ENG126916-ambient_lighting_lin_slaves_groups-pa_korrekturfaktor_gruppe_15	1	30
    ENG126649-ENG126877-ambient_lighting_lin_slaves_groups-pa_korrekturfaktor_gruppe_2	1	30
    ENG126649-ENG126880-ambient_lighting_lin_slaves_groups-pa_korrekturfaktor_gruppe_3	1	30
    ENG126649-ENG126883-ambient_lighting_lin_slaves_groups-pa_korrekturfaktor_gruppe_4	1	30
    ENG126649-ENG126886-ambient_lighting_lin_slaves_groups-pa_korrekturfaktor_gruppe_5	1	30
    ENG126649-ENG126889-ambient_lighting_lin_slaves_groups-pa_korrekturfaktor_gruppe_6	1	30
    ENG126649-ENG126892-ambient_lighting_lin_slaves_groups-pa_korrekturfaktor_gruppe_7	1	30
    ENG126649-ENG126895-ambient_lighting_lin_slaves_groups-pa_korrekturfaktor_gruppe_8	1	30
    ENG126649-ENG126898-ambient_lighting_lin_slaves_groups-pa_korrekturfaktor_gruppe_9	1	30
    ENG126649-ENG126873-ambient_lighting_lin_slaves_groups-pa_lichtfunktion_gruppe_1	door 	30
    ENG126649-ENG126900-ambient_lighting_lin_slaves_groups-pa_lichtfunktion_gruppe_10	door 	30
    ENG126649-ENG126903-ambient_lighting_lin_slaves_groups-pa_lichtfunktion_gruppe_11	door 	30
    ENG126649-ENG126906-ambient_lighting_lin_slaves_groups-pa_lichtfunktion_gruppe_12	door 	30
    ENG126649-ENG126909-ambient_lighting_lin_slaves_groups-pa_lichtfunktion_gruppe_13	door 	30
    ENG126649-ENG126912-ambient_lighting_lin_slaves_groups-pa_lichtfunktion_gruppe_14	door 	30
    ENG126649-ENG126915-ambient_lighting_lin_slaves_groups-pa_lichtfunktion_gruppe_15	door 	30
    ENG126649-ENG126876-ambient_lighting_lin_slaves_groups-pa_lichtfunktion_gruppe_2	door 	30
    ENG126649-ENG126879-ambient_lighting_lin_slaves_groups-pa_lichtfunktion_gruppe_3	door 	30
    ENG126649-ENG126882-ambient_lighting_lin_slaves_groups-pa_lichtfunktion_gruppe_4	door 	30
    ENG126649-ENG126885-ambient_lighting_lin_slaves_groups-pa_lichtfunktion_gruppe_5	door 	30
    ENG126649-ENG126888-ambient_lighting_lin_slaves_groups-pa_lichtfunktion_gruppe_6	door 	30
    ENG126649-ENG126891-ambient_lighting_lin_slaves_groups-pa_lichtfunktion_gruppe_7	door 	30
    ENG126649-ENG126894-ambient_lighting_lin_slaves_groups-pa_lichtfunktion_gruppe_8	door 	30
    ENG126649-ENG126897-ambient_lighting_lin_slaves_groups-pa_lichtfunktion_gruppe_9	door 	30
    ENG126649-ENG126872-ambient_lighting_lin_slaves_groups-pa_verbauinfo_gruppe_1	not installed 	30
    ENG126649-ENG126899-ambient_lighting_lin_slaves_groups-pa_verbauinfo_gruppe_10	not installed 	30
    ENG126649-ENG126902-ambient_lighting_lin_slaves_groups-pa_verbauinfo_gruppe_11	not installed 	30
    ENG126649-ENG126905-ambient_lighting_lin_slaves_groups-pa_verbauinfo_gruppe_12	not installed 	30
    ENG126649-ENG126908-ambient_lighting_lin_slaves_groups-pa_verbauinfo_gruppe_13	not installed 	30
    ENG126649-ENG126911-ambient_lighting_lin_slaves_groups-pa_verbauinfo_gruppe_14	not installed 	30
    ENG126649-ENG126914-ambient_lighting_lin_slaves_groups-pa_verbauinfo_gruppe_15	not installed 	30
    ENG126649-ENG126875-ambient_lighting_lin_slaves_groups-pa_verbauinfo_gruppe_2	not installed 	30
    ENG126649-ENG126878-ambient_lighting_lin_slaves_groups-pa_verbauinfo_gruppe_3	not installed 	30
    ENG126649-ENG126881-ambient_lighting_lin_slaves_groups-pa_verbauinfo_gruppe_4	not installed 	30
    ENG126649-ENG126884-ambient_lighting_lin_slaves_groups-pa_verbauinfo_gruppe_5	not installed 	30
    ENG126649-ENG126887-ambient_lighting_lin_slaves_groups-pa_verbauinfo_gruppe_6	not installed 	30
    ENG126649-ENG126890-ambient_lighting_lin_slaves_groups-pa_verbauinfo_gruppe_7	not installed 	30
    ENG126649-ENG126893-ambient_lighting_lin_slaves_groups-pa_verbauinfo_gruppe_8	not installed 	30
    ENG126649-ENG126896-ambient_lighting_lin_slaves_groups-pa_verbauinfo_gruppe_9	not installed 	30
    ENG128379-ENG128424-ambient_lighting_lin_slaves_modules-pa_einzeladresse_slave_:12	0	60
    ENG128379-ENG128391-ambient_lighting_lin_slaves_modules-pa_einzeladresse_slave_1	0	60
    ENG128379-ENG128418-ambient_lighting_lin_slaves_modules-pa_einzeladresse_slave_10	0	60
    ENG128379-ENG128421-ambient_lighting_lin_slaves_modules-pa_einzeladresse_slave_11	0	60
    ENG128379-ENG128427-ambient_lighting_lin_slaves_modules-pa_einzeladresse_slave_13	0	60
    ENG128379-ENG128430-ambient_lighting_lin_slaves_modules-pa_einzeladresse_slave_14	0	60
    ENG128379-ENG128433-ambient_lighting_lin_slaves_modules-pa_einzeladresse_slave_15	0	60
    ENG128379-ENG128436-ambient_lighting_lin_slaves_modules-pa_einzeladresse_slave_16	0	60
    ENG128379-ENG128439-ambient_lighting_lin_slaves_modules-pa_einzeladresse_slave_17	0	60
    ENG128379-ENG128442-ambient_lighting_lin_slaves_modules-pa_einzeladresse_slave_18	0	60
    ENG128379-ENG128445-ambient_lighting_lin_slaves_modules-pa_einzeladresse_slave_19	0	60
    ENG128379-ENG128394-ambient_lighting_lin_slaves_modules-pa_einzeladresse_slave_2	0	60
    ENG128379-ENG128448-ambient_lighting_lin_slaves_modules-pa_einzeladresse_slave_20	0	60
    ENG128379-ENG128397-ambient_lighting_lin_slaves_modules-pa_einzeladresse_slave_3	0	60
    ENG128379-ENG128400-ambient_lighting_lin_slaves_modules-pa_einzeladresse_slave_4	0	60
    ENG128379-ENG128403-ambient_lighting_lin_slaves_modules-pa_einzeladresse_slave_5	0	60
    ENG128379-ENG128406-ambient_lighting_lin_slaves_modules-pa_einzeladresse_slave_6	0	60
    ENG128379-ENG128409-ambient_lighting_lin_slaves_modules-pa_einzeladresse_slave_7	0	60
    ENG128379-ENG128412-ambient_lighting_lin_slaves_modules-pa_einzeladresse_slave_8	0	60
    ENG128379-ENG128415-ambient_lighting_lin_slaves_modules-pa_einzeladresse_slave_9	0	60
    ENG128379-ENG128393-ambient_lighting_lin_slaves_modules-pa_fehlerort_slave_1	0	60
    ENG128379-ENG128420-ambient_lighting_lin_slaves_modules-pa_fehlerort_slave_10	0	60
    ENG128379-ENG128423-ambient_lighting_lin_slaves_modules-pa_fehlerort_slave_11	0	60
    ENG128379-ENG128426-ambient_lighting_lin_slaves_modules-pa_fehlerort_slave_12	0	60
    ENG128379-ENG128429-ambient_lighting_lin_slaves_modules-pa_fehlerort_slave_13	0	60
    ENG128379-ENG128432-ambient_lighting_lin_slaves_modules-pa_fehlerort_slave_14	0	60
    ENG128379-ENG128435-ambient_lighting_lin_slaves_modules-pa_fehlerort_slave_15	0	60
    ENG128379-ENG128438-ambient_lighting_lin_slaves_modules-pa_fehlerort_slave_16	0	60
    ENG128379-ENG128441-ambient_lighting_lin_slaves_modules-pa_fehlerort_slave_17	0	60
    ENG128379-ENG128444-ambient_lighting_lin_slaves_modules-pa_fehlerort_slave_18	0	60
    ENG128379-ENG128447-ambient_lighting_lin_slaves_modules-pa_fehlerort_slave_19	0	60
    ENG128379-ENG128396-ambient_lighting_lin_slaves_modules-pa_fehlerort_slave_2	0	60
    ENG128379-ENG128450-ambient_lighting_lin_slaves_modules-pa_fehlerort_slave_20	0	60
    ENG128379-ENG128399-ambient_lighting_lin_slaves_modules-pa_fehlerort_slave_3	0	60
    ENG128379-ENG128402-ambient_lighting_lin_slaves_modules-pa_fehlerort_slave_4	0	60
    ENG128379-ENG128405-ambient_lighting_lin_slaves_modules-pa_fehlerort_slave_5	0	60
    ENG128379-ENG128408-ambient_lighting_lin_slaves_modules-pa_fehlerort_slave_6	0	60
    ENG128379-ENG128411-ambient_lighting_lin_slaves_modules-pa_fehlerort_slave_7	0	60
    ENG128379-ENG128417-ambient_lighting_lin_slaves_modules-pa_fehlerort_slave_9	0	60
    ENG128379-ENG128414-ambient_lighting_lin_slaves_modules-pa_fehlerort_slave8	0	60
    ENG128379-ENG128392-ambient_lighting_lin_slaves_modules-pa_verbauinfo_slave_1	not installed 	60
    ENG128379-ENG128419-ambient_lighting_lin_slaves_modules-pa_verbauinfo_slave_10	not installed 	60
    ENG128379-ENG128422-ambient_lighting_lin_slaves_modules-pa_verbauinfo_slave_11	not installed 	60
    ENG128379-ENG128425-ambient_lighting_lin_slaves_modules-pa_verbauinfo_slave_12	not installed 	60
    ENG128379-ENG128428-ambient_lighting_lin_slaves_modules-pa_verbauinfo_slave_13	not installed 	60
    ENG128379-ENG128431-ambient_lighting_lin_slaves_modules-pa_verbauinfo_slave_14	not installed 	60
    ENG128379-ENG128434-ambient_lighting_lin_slaves_modules-pa_verbauinfo_slave_15	not installed 	60
    ENG128379-ENG128437-ambient_lighting_lin_slaves_modules-pa_verbauinfo_slave_16	not installed 	60
    ENG128379-ENG128440-ambient_lighting_lin_slaves_modules-pa_verbauinfo_slave_17	not installed 	60
    ENG128379-ENG128443-ambient_lighting_lin_slaves_modules-pa_verbauinfo_slave_18	not installed 	60
    ENG128379-ENG128446-ambient_lighting_lin_slaves_modules-pa_verbauinfo_slave_19	not installed 	60
    ENG128379-ENG128395-ambient_lighting_lin_slaves_modules-pa_verbauinfo_slave_2	not installed 	60
    ENG128379-ENG128449-ambient_lighting_lin_slaves_modules-pa_verbauinfo_slave_20	not installed 	60
    ENG128379-ENG128398-ambient_lighting_lin_slaves_modules-pa_verbauinfo_slave_3	not installed 	60
    ENG128379-ENG128401-ambient_lighting_lin_slaves_modules-pa_verbauinfo_slave_4	not installed 	60
    ENG128379-ENG128404-ambient_lighting_lin_slaves_modules-pa_verbauinfo_slave_5	not installed 	60
    ENG128379-ENG128407-ambient_lighting_lin_slaves_modules-pa_verbauinfo_slave_6	not installed 	60
    ENG128379-ENG128410-ambient_lighting_lin_slaves_modules-pa_verbauinfo_slave_7	not installed 	60
    ENG128379-ENG128416-ambient_lighting_lin_slaves_modules-pa_verbauinfo_slave_9	not installed 	60
    ENG128379-ENG128413-ambient_lighting_lin_slaves_modules-pa_verbauinfo_slave8	not installed 	60
    ENG153712-ENG154510-Ambientelicht Zuordnung der Farbe zum Fahrprofil-Ambiente	Keine_Spannungsanforderung 	23
    ENG153712-ENG154602-Ambientelicht Zuordnung der Farbe zum Fahrprofil-Fahrprofil_0	1	23
    ENG153712-ENG154603-Ambientelicht Zuordnung der Farbe zum Fahrprofil-Fahrprofil_1	1	23
    ENG153712-ENG154604-Ambientelicht Zuordnung der Farbe zum Fahrprofil-Fahrprofil_10	1	23
    ENG153712-ENG154605-Ambientelicht Zuordnung der Farbe zum Fahrprofil-Fahrprofil_11	1	23
    ENG153712-ENG154606-Ambientelicht Zuordnung der Farbe zum Fahrprofil-Fahrprofil_12	1	23
    ENG153712-ENG154607-Ambientelicht Zuordnung der Farbe zum Fahrprofil-Fahrprofil_13	1	23
    ENG153712-ENG154608-Ambientelicht Zuordnung der Farbe zum Fahrprofil-Fahrprofil_14	1	23
    ENG153712-ENG154609-Ambientelicht Zuordnung der Farbe zum Fahrprofil-Fahrprofil_15	1	23
    ENG153712-ENG154610-Ambientelicht Zuordnung der Farbe zum Fahrprofil-Fahrprofil_2	1	23
    ENG153712-ENG154611-Ambientelicht Zuordnung der Farbe zum Fahrprofil-Fahrprofil_3	1	23
    ENG153712-ENG154612-Ambientelicht Zuordnung der Farbe zum Fahrprofil-Fahrprofil_4	1	23
    ENG153712-ENG154613-Ambientelicht Zuordnung der Farbe zum Fahrprofil-Fahrprofil_5	1	23
    ENG153712-ENG154614-Ambientelicht Zuordnung der Farbe zum Fahrprofil-Fahrprofil_6	1	23
    ENG153712-ENG154615-Ambientelicht Zuordnung der Farbe zum Fahrprofil-Fahrprofil_7	1	23
    ENG153712-ENG154616-Ambientelicht Zuordnung der Farbe zum Fahrprofil-Fahrprofil_8	1	23
    ENG153712-ENG154617-Ambientelicht Zuordnung der Farbe zum Fahrprofil-Fahrprofil_9	1	23
    ENG141649-ENG122212-Außenlicht_Blinker-ABBA_Blinken	not active 	10
    ENG141649-ENG133379-Außenlicht_Blinker-Abbruch Komfortblinken	active 	10
    ENG141649-ENG116590-Außenlicht_Blinker-Blinkkontrolleuchte fuer Anhaenger	separte 	10
    ENG141649-ENG121966-Außenlicht_Blinker-Crash flashing	not active 	10
    ENG141649-ENG122207-Außenlicht_Blinker-DWA_Alarm_Blinken	not active 	10
    ENG141649-ENG122206-Außenlicht_Blinker-DWA_Schaerfungsquittung	not active 	10
    ENG141649-ENG142194-Außenlicht_Blinker-dynamisch_blinken_10	not active 	10
    ENG141649-ENG142195-Außenlicht_Blinker-Dynamische_Blink_Delay	50 ms	10
    ENG141649-ENG126819-Außenlicht_Blinker-Emergency_alert_blinken	not active 	10
    ENG141649-ENG154601-Außenlicht_Blinker-Fahrerassistenz_Blinkenfunktionen	Warnblinke_zulaessig 	10
    ENG141649-ENG115774-Außenlicht_Blinker-Komfortblinken	active 	10
    ENG141649-ENG116587-Außenlicht_Blinker-Komfortblinken Blinkzyklen	3	10
    ENG141649-ENG122208-Außenlicht_Blinker-Multi_kollisions_Blinken	not active 	10
    ENG141649-ENG122209-Außenlicht_Blinker-Notwarn_blinken_NBA_Phase_2	not active 	10
    ENG141649-ENG121967-Außenlicht_Blinker-Panic flashing	not active 	10
    ENG141649-ENG154711-Außenlicht_Blinker-PreCrash_RECAS	PreCrash_passiv 	10
    ENG141649-ENG122211-Außenlicht_Blinker-Richtungs_blinken_links	active 	10
    ENG141649-ENG122210-Außenlicht_Blinker-Richtungs_blinken_rechts	active 	10
    ENG141649-ENG122201-Außenlicht_Blinker-Schluessel_Anlern_Blinken	not active 	10
    ENG141649-ENG121968-Außenlicht_Blinker-Taxi alarm flashing	not active 	10
    ENG141649-ENG126629-Außenlicht_Blinker-Telematikblinken1_STS_Blinken Telematikblinken2_OCU_Blinken	not active 	10
    ENG141649-ENG122202-Außenlicht_Blinker-UGDO_ Anlern_Blinken	not active 	10
    ENG141649-ENG142029-Außenlicht_Blinker-Warnblinken_durch_Fahrerassistenz	not active 	10
    ENG141649-ENG122214-Außenlicht_Blinker-Warnblinken_Zuendung_AUS	active 	10
    ENG141649-ENG122213-Außenlicht_Blinker-Warnblinken_Zuendung_EIN	active 	10
    ENG141649-ENG122204-Außenlicht_Blinker-ZV_Blinken_auf	not active 	10
    ENG141649-ENG122203-Außenlicht_Blinker-ZV_Blinken_zu	not active 	10
    ENG141647-ENG141986-Außenlicht_Front-Abblendlicht_Leuchtentyp	H7 	9
    ENG141647-ENG116705-Außenlicht_Front-Allwetterlicht Ausschaltgrenze	350 km/h	9
    ENG141647-ENG116704-Außenlicht_Front-Allwetterlicht Einschaltgrenze	350 km/h	9
    ENG141647-ENG115833-Außenlicht_Front-Fahrlicht bei Tag	Daytime running lights 	9
    ENG141647-ENG142193-Außenlicht_Front-Geschwindigkeitsabhaengiges TFL	5 km/h	9
    ENG141647-ENG115861-Außenlicht_Front-Lichthupe bei Zuendung aus moeglich	active 	9
    ENG141647-ENG115832-Außenlicht_Front-Scheinwerferferreinigungsansteuerung und Abblendlichtanzeige bei Dauerfahrlicht	not active 	9
    ENG141647-ENG142191-Außenlicht_Front-Signaturlicht HMI-default Anzeige im Kombiinstrument	not active 	9
    ENG141647-ENG142190-Außenlicht_Front-Signaturlicht_verbaut	not installed 	9
    ENG141647-ENG116592-Außenlicht_Front-Standlicht aktiviert zusaetzlich Tagfahrlicht	active 	9
    ENG141647-ENG116594-Außenlicht_Front-Tagfahrlicht Aktivierung durch BAP oder Bedienfolge moeglich	not active 	9
    ENG141647-ENG122184-Außenlicht_Front-Tagfahrlicht Dauerfahrlicht bei Handbremse abschalten	active 	9
    ENG141647-ENG115734-Außenlicht_Front-Tagfahrlicht nur in Schalterstellung AUTO	not active 	9
    ENG141647-ENG116593-Außenlicht_Front-Tagfahrlicht-Dauerfahrlicht aktiviert zusaetzlich Standlicht	not active 	9
    ENG141647-ENG115733-Außenlicht_Front-Tagfahrlichtkontrollleuchte	not active 	9
    ENG141647-ENG142192-Außenlicht_Front-TFL_Abschaltung_ueber_Geschwindigkeit	not active 	9
    ENG141647-ENG116591-Außenlicht_Front-Werkseinstellung fuer Tagfahrlicht Freischaltung BAP / Bedienfolge	active 	9
    ENG141647-ENG115860-Außenlicht_Front-Zahl der aktiven Scheinwerfer auf 2 limitieren	limitieren 	9
    ENG141648-ENG141987-Aussenlicht_Heck-Bremslicht_ist_auch_Blinklicht	Yes 	5
    ENG141648-ENG115782-Aussenlicht_Heck-Nebelschlusslicht Warngeschwindigkeit	0 km/h	5
    ENG141648-ENG116636-Aussenlicht_Heck-Notbremsanzeige NBA	not active 	5
    ENG141648-ENG115831-Aussenlicht_Heck-Schlusslicht mit Bremslichtfunktion	not active 	5
    ENG141648-ENG142004-Aussenlicht_Heck-Umgreifende_Heckklappe	not installed 	5
    ENG141656-ENG142020-Außenlicht_uebergreifend-All-weather lights	not installed 	18
    ENG141656-ENG133381-Außenlicht_uebergreifend-Bedingungen zur Parklichtbegrenzung	begrenzen auf Mindestverfügbarkeit 	18
    ENG141656-ENG133380-Außenlicht_uebergreifend-Bedingungen zur Standlichtbegrenzung	begrenzen auf Mindestverfügbarkeit 	18
    ENG141656-ENG142188-Außenlicht_uebergreifend-bewusstes Standlicht	Aktive Begrenzung 	18
    ENG141656-ENG115656-Außenlicht_uebergreifend-Coming Home Leuchten	Low beam 	18
    ENG141656-ENG116601-Außenlicht_uebergreifend-Coming Home Verbaustatus	automatic 	18
    ENG141656-ENG116604-Außenlicht_uebergreifend-Coming-home Einschaltereignis	Driver door 	18
    ENG141656-ENG130581-Außenlicht_uebergreifend-Fahrlicht_Hinweis_mehrfach	not active 	18
    ENG141656-ENG126818-Außenlicht_uebergreifend-Fahrlichtwarnung_Hinweis_Konfig	kein_Hinweis 	18
    ENG141656-ENG137034-Außenlicht_uebergreifend-Faktor fuer Verfuegbarkeitstimer	Faktor fuer x5 Minuten 	18
    ENG141656-ENG154619-Außenlicht_uebergreifend-Fernlicht_LH	Sollspannungsanforderung 13.5 	18
    ENG141656-ENG154177-Außenlicht_uebergreifend-Fog light	Sollspannungsanforderung 13.5 	18
    ENG141656-ENG116608-Außenlicht_uebergreifend-Helligkeitsschwelle Forward-Messung	46400 lx	18
    ENG141656-ENG116605-Außenlicht_uebergreifend-Helligkeitsschwelle Infrarot-Messung	12 lx	18
    ENG141656-ENG142189-Außenlicht_uebergreifend-HVLM_Ladezustandsanzeige	No 	18
    ENG141656-ENG115858-Außenlicht_uebergreifend-Kontrollleuchte fuer Begrenzungslicht	integriert in Suchbeleuchtung 	18
    ENG141656-ENG142185-Außenlicht_uebergreifend-LCM_blinker	true 	18
    ENG141656-ENG141992-Außenlicht_uebergreifend-LDS_mit_AFL	Yes 	18
    ENG141656-ENG141991-Außenlicht_uebergreifend-LDS_mit_Nebel_Schlusslicht	No 	18
    ENG141656-ENG141990-Außenlicht_uebergreifend-LDS_mit_Nebellicht	Yes 	18
    ENG141656-ENG141993-Außenlicht_uebergreifend-LDS_mit_Standlichtstellung	Yes 	18
    ENG141656-ENG115657-Außenlicht_uebergreifend-Leaving-Home Verbausstatus	Enabled 	18
    ENG141656-ENG141989-Außenlicht_uebergreifend-Lichtdrehschalter (LDS)	discrete 	18
    ENG141656-ENG115862-Außenlicht_uebergreifend-Lichtwarnungsverhalten	klemmenabhaengig 	18
    ENG141656-ENG142034-Außenlicht_uebergreifend-Light_Control_Module	not installed 	18
    ENG141656-ENG98354-Außenlicht_uebergreifend-Low beam	Sollspannungsanforderung 13.5 	18
    ENG141656-ENG115863-Außenlicht_uebergreifend-Menueeinstellung CHO LHO	Menuesteuerung Zeit aktivieren 	18
    ENG141656-ENG116603-Außenlicht_uebergreifend-Menueeinstellung Cominghome	10 seconds 	18
    ENG141656-ENG116607-Außenlicht_uebergreifend-Menueeinstellung Leaving-home Zeit per BAP	10 seconds 	18
    ENG141656-ENG116602-Außenlicht_uebergreifend-Menuesteuerung Coming Home Werkseinstellung	active 	18
    ENG141656-ENG116606-Außenlicht_uebergreifend-Menuesteuerung Leaving-home Freischaltung per BAP	active 	18
    ENG141656-ENG115859-Außenlicht_uebergreifend-Parklicht ueber LSS aktiviert	not active 	18
    ENG141656-ENG126816-Außenlicht_uebergreifend-Standlicht aus	active 	18
    ENG141656-ENG115829-Außenlicht_uebergreifend-Standlichtreduzierung mit beidseitigem Parklicht	not active 	18
    ENG141656-ENG133383-Außenlicht_uebergreifend-Standlicht-Verfügbarkeit	6 s	18
    ENG141656-ENG154174-Außenlicht_uebergreifend-Turn signal	Sollspannungsanforderung 13.5 	18
    ENG141656-ENG126817-Außenlicht_uebergreifend-Umfeldleuchte als Manoevrierleuchte	not active 	18
    ENG126647-ENG98399-debug_light_function-Activation	0	11
    ENG126647-ENG101417-debug_light_function-Adresse	0	11
    ENG126647-ENG126820-debug_light_function-Bitmask	0	11
    ENG126647-ENG126821-debug_light_function-Divisor	0	11
    ENG126647-ENG98827-debug_light_function-Offset	0	11
    ENG126647-ENG126822-debug_light_function-Polaritaet	0	11
    ENG141675-ENG115658-Dimmunt_KL_58xs_PWM-x0	0.00%	6
    ENG141675-ENG101574-Dimmunt_KL_58xs_PWM-X1	50.00%	6
    ENG141675-ENG99557-Dimmunt_KL_58xs_PWM-X2	100.00%	6
    ENG141675-ENG115659-Dimmunt_KL_58xs_PWM-y0	0.00%	6
    ENG141675-ENG99777-Dimmunt_KL_58xs_PWM-Y1	50.00%	6
    ENG141675-ENG100480-Dimmunt_KL_58xs_PWM-Y2	100.00%	6
    ENG141650-MAS13782-Fernlicht_assistent-Will Beam assistant: responsivity adjustable via BAP	present 	6
    ENG141650-ENG141973-Fernlicht_assistent-Erweiterte_Fernlichtsteuerung	Basis 	6
    ENG141650-ENG116639-Fernlicht_assistent-Fernlichtassistent Reset	not active 	6
    ENG141650-ENG116637-Fernlicht_assistent-Menuesteuerung Fernlichtassistent	Not Present 	6
    ENG141650-ENG116641-Fernlicht_assistent-Menuesteuerung Fernlichtassistent Werkseinstellung	present 	6
    ENG141682-ENG115835-Front_wiper-Adaptives Nachwischen bei SRA	not active 	6
    ENG141682-ENG142250-Front_wiper-Anfahrzeit_servicestellung	800 ms	6
    ENG141682-ENG115836-Front_wiper-Frontwischer Notlaufprogramm	active 	6
    ENG141682-ENG116614-Front_wiper-Frontwischer Referenzlauf	active 	6
    ENG141682-ENG154620-Front_wiper-Frontwischer Spannungsanforderung_konfig	Keine_Spannungsanforderung 	6
    ENG141682-ENG133394-Front_wiper-Frontwischer_Abtauposition	not active 	6
    ENG141682-ENG141966-Front_wiper-Frontwischertyp	LIN 	6
    ENG141682-ENG116617-Front_wiper-Geschwindigkeitsabhaengige Wischstufenrueckschaltung	active 	6
    ENG141682-ENG116615-Front_wiper-Menuesteuerung Frontwischer	not active 	6
    ENG141682-ENG154706-Front_wiper-Mindestwaschzeit_Frontwischer	0 ms	6
    ENG141682-ENG115771-Front_wiper-Regensensor aktivieren	Deactivating 	6
    ENG141682-ENG154790-Front_wiper-Timer_DWP_SRA_delay	300 ms	6
    ENG141682-ENG116616-Front_wiper-Tippwischen mit erhoehter Wischfrequenz	active 	6
    ENG141682-ENG116618-Front_wiper-Traenenwischen Front Status	not active 	6
    ENG141682-ENG115770-Front_wiper-Variable Regensensoraktivierung	not active 	6
    ENG141682-ENG126844-Front_wiper-Washer_Tipwiping_Variant	not active 	6
    ENG141682-ENG116613-Front_wiper-Wischer abparken bei Oeffnen der Motorhaube	not active 	6
    ENG141682-ENG116612-Front_wiper-Wischer stop bei KL15 aus	not active 	6
    ENG141682-ENG122185-Front_wiper-Wischer Stopp bei Oeffnen der Motorhaube	active 	6
    ENG99457-ENG117394-Head area heater-blower_speed	1	2
    ENG99457-ENG98971-Head area heater-Temperature	-2	2
    ENG141645-MAS00211-HW_Verbau-Insufficient brake fluid	installed 	8
    ENG141645-MAS00212-HW_Verbau-Insufficient washer fluid	installed 	8
    ENG141645-MAS00213-HW_Verbau-Insufficient coolant	installed 	8
    ENG141645-MAS00214-HW_Verbau-Brake pad wear	not installed 	8
    ENG141645-ENG142026-HW_Verbau-Druckklappe	not installed 	8
    ENG141645-ENG141963-HW_Verbau-Elektrische Laderaumabdeckung aktiv	not active 	8
    ENG141645-ENG142012-HW_Verbau-Elektrische_Laderaumabdeckung	not installed 	8
    ENG141645-ENG141952-HW_Verbau-Exterior temp. sensor	installed 	8
    ENG141645-ENG142005-HW_Verbau-Kontaktschalter_fuer_Motorhaube	installed 	8
    ENG141645-ENG142186-HW_Verbau-Ladesteckerverriegelung	not installed 	8
    ENG141645-ENG142036-HW_Verbau-PTC Zuheizer	not installed 	8
    ENG141645-ENG115809-HW_Verbau-Signalhorn ohne KL15	active 	8
    ENG141645-ENG142003-HW_Verbau-Status_Tankdeckelverriegelung	not active 	8
    ENG141660-ENG115658-Kennlinie_sLWR_Soll-x0	100.00%	30
    ENG141660-ENG101574-Kennlinie_sLWR_Soll-X1	100.00%	30
    ENG141660-ENG99557-Kennlinie_sLWR_Soll-X2	100.00%	30
    ENG141660-ENG102140-Kennlinie_sLWR_Soll-X3	100.00%	30
    ENG141660-ENG102936-Kennlinie_sLWR_Soll-X4	83.00%	30
    ENG141660-ENG103548-Kennlinie_sLWR_Soll-X5	67.00%	30
    ENG141660-ENG113992-Kennlinie_sLWR_Soll-X6	50.00%	30
    ENG141660-ENG115661-Kennlinie_sLWR_Soll-x7	33	30
    ENG141660-ENG115662-Kennlinie_sLWR_Soll-x8	17.00%	30
    ENG141660-ENG115663-Kennlinie_sLWR_Soll-x9	0.00%	30
    ENG141660-ENG115659-Kennlinie_sLWR_Soll-y0	58.50%	30
    ENG141660-ENG99777-Kennlinie_sLWR_Soll-Y1	58.50%	30
    ENG141660-ENG100480-Kennlinie_sLWR_Soll-Y2	58.50%	30
    ENG141660-ENG100773-Kennlinie_sLWR_Soll-Y3	58.50%	30
    ENG141660-ENG100631-Kennlinie_sLWR_Soll-Y4	54.50%	30
    ENG141660-ENG102174-Kennlinie_sLWR_Soll-Y5	49.50%	30
    ENG141660-ENG113993-Kennlinie_sLWR_Soll-Y6	46.50%	30
    ENG141660-ENG115665-Kennlinie_sLWR_Soll-y7	35.50%	30
    ENG141660-ENG115666-Kennlinie_sLWR_Soll-y8	31.50%	30
    ENG141660-ENG115667-Kennlinie_sLWR_Soll-y9	20.00%	30
    ENG116936-ENG115883-Leuchte 0 BLK VL B36-Dimming Direction CD 0	maximize 	16
    ENG116936-ENG115887-Leuchte 0 BLK VL B36-Dimming Direction EF 0	maximize 	16
    ENG116936-ENG115891-Leuchte 0 BLK VL B36-Dimming Direction GH 0	maximize 	16
    ENG116936-ENG115878-Leuchte 0 BLK VL B36-Dimmwert AB 0	100	16
    ENG116936-ENG115882-Leuchte 0 BLK VL B36-Dimmwert CD 0	0	16
    ENG116936-ENG115886-Leuchte 0 BLK VL B36-Dimmwert EF 0	0	16
    ENG116936-ENG115890-Leuchte 0 BLK VL B36-Dimmwert GH 0	0	16
    ENG116936-ENG115875-Leuchte 0 BLK VL B36-Fehlerort mittleres Byte DTC-DFCC 0	14	16
    ENG116936-ENG116547-Leuchte 0 BLK VL B36-Lampendefektbit Position 0	34	16
    ENG116936-ENG115873-Leuchte 0 BLK VL B36-Lasttyp 0	12 - Blinkleuchten 	16
    ENG116936-ENG115879-Leuchte 0 BLK VL B36-Lichtansteuerung HD AB 0	Always 	16
    ENG116936-ENG115876-Leuchte 0 BLK VL B36-Lichtfunktion A 0	Blinken links Hellphase 	16
    ENG116936-ENG115877-Leuchte 0 BLK VL B36-Lichtfunktion B 0	not active 	16
    ENG116936-ENG115880-Leuchte 0 BLK VL B36-Lichtfunktion C 0	not active 	16
    ENG116936-ENG115881-Leuchte 0 BLK VL B36-Lichtfunktion D 0	not active 	16
    ENG116936-ENG115884-Leuchte 0 BLK VL B36-Lichtfunktion E 0	not active 	16
    ENG116936-ENG115885-Leuchte 0 BLK VL B36-Lichtfunktion F 0	not active 	16
    ENG116936-ENG115888-Leuchte 0 BLK VL B36-Lichtfunktion G 0	not active 	16
    ENG116936-ENG115889-Leuchte 0 BLK VL B36-Lichtfunktion H 0	not active 	16
    ENG141657-ENG116167-Leuchte 35 LED Warnblinktaster C48-Dimming Direction CD 15	maximize 	16
    ENG141657-ENG116171-Leuchte 35 LED Warnblinktaster C48-Dimming Direction EF 15	maximize 	16
    ENG141657-ENG116175-Leuchte 35 LED Warnblinktaster C48-Dimming Direction GH 15	maximize 	16
    ENG141657-ENG116162-Leuchte 35 LED Warnblinktaster C48-Dimmwert AB 15	100	16
    ENG141657-ENG116166-Leuchte 35 LED Warnblinktaster C48-Dimmwert CD 15	0	16
    ENG141657-ENG116170-Leuchte 35 LED Warnblinktaster C48-Dimmwert EF 15	0	16
    ENG141657-ENG116174-Leuchte 35 LED Warnblinktaster C48-Dimmwert GH 15	0	16
    ENG141657-ENG116159-Leuchte 35 LED Warnblinktaster C48-Fehlerort mittleres Byte DTC-DFCC 15	63	16
    ENG141657-ENG116566-Leuchte 35 LED Warnblinktaster C48-Lampendefektbitposition 15	0	16
    ENG141657-ENG116157-Leuchte 35 LED Warnblinktaster C48-Lasttyp 15	41 - LED Kleinleistung 	16
    ENG141657-ENG116163-Leuchte 35 LED Warnblinktaster C48-Lichtansteuerung HD AB 15	Always 	16
    ENG141657-ENG116160-Leuchte 35 LED Warnblinktaster C48-Lichtfunktion A 15	Unknown (76)	16
    ENG141657-ENG116161-Leuchte 35 LED Warnblinktaster C48-Lichtfunktion B 15	not active 	16
    ENG141657-ENG116164-Leuchte 35 LED Warnblinktaster C48-Lichtfunktion C 15	not active 	16
    ENG141657-ENG116165-Leuchte 35 LED Warnblinktaster C48-Lichtfunktion D 15	not active 	16
    ENG141657-ENG116168-Leuchte 35 LED Warnblinktaster C48-Lichtfunktion E 15	not active 	16
    ENG141657-ENG116169-Leuchte 35 LED Warnblinktaster C48-Lichtfunktion F 15	not active 	16
    ENG141657-ENG116172-Leuchte 35 LED Warnblinktaster C48-Lichtfunktion G 15	not active 	16
    ENG141657-ENG116173-Leuchte 35 LED Warnblinktaster C48-Lichtfunktion H 15	not active 	16
    ENG116946-ENG116072-Leuchte10SHUTTER LB23-Dimming Direction CD 10	maximize 	16
    ENG116946-ENG116076-Leuchte10SHUTTER LB23-Dimming Direction EF 10	maximize 	16
    ENG116946-ENG116080-Leuchte10SHUTTER LB23-Dimming Direction GH 10	maximize 	16
    ENG116946-ENG116067-Leuchte10SHUTTER LB23-Dimmwert AB 10	0	16
    ENG116946-ENG116071-Leuchte10SHUTTER LB23-Dimmwert CD 10	0	16
    ENG116946-ENG116075-Leuchte10SHUTTER LB23-Dimmwert EF 10	0	16
    ENG116946-ENG116079-Leuchte10SHUTTER LB23-Dimmwert GH 10	0	16
    ENG116946-ENG116064-Leuchte10SHUTTER LB23-Fehlerort mittleres Byte DTC-DFCC 10	0	16
    ENG116946-ENG116560-Leuchte10SHUTTER LB23-Lampendefektbitposition 10	0	16
    ENG116946-ENG116062-Leuchte10SHUTTER LB23-Lasttyp 10	not active 	16
    ENG116946-ENG116068-Leuchte10SHUTTER LB23-Lichtansteuerung HD AB 10	Always 	16
    ENG116946-ENG116065-Leuchte10SHUTTER LB23-Lichtfunktion A 10	not active 	16
    ENG116946-ENG116066-Leuchte10SHUTTER LB23-Lichtfunktion B 10	not active 	16
    ENG116946-ENG116069-Leuchte10SHUTTER LB23-Lichtfunktion C 10	not active 	16
    ENG116946-ENG116070-Leuchte10SHUTTER LB23-Lichtfunktion D 10	not active 	16
    ENG116946-ENG116073-Leuchte10SHUTTER LB23-Lichtfunktion E 10	not active 	16
    ENG116946-ENG116074-Leuchte10SHUTTER LB23-Lichtfunktion F 10	not active 	16
    ENG116946-ENG116077-Leuchte10SHUTTER LB23-Lichtfunktion G 10	not active 	16
    ENG116946-ENG116078-Leuchte10SHUTTER LB23-Lichtfunktion H 10	not active 	16
    ENG116947-ENG116091-Leuchte11SHUTTER RB22-Dimming Direction CD 11	maximize 	16
    ENG116947-ENG116095-Leuchte11SHUTTER RB22-Dimming Direction EF 11	maximize 	16
    ENG116947-ENG116099-Leuchte11SHUTTER RB22-Dimming Direction GH 11	maximize 	16
    ENG116947-ENG116086-Leuchte11SHUTTER RB22-Dimmwert AB 11	0	16
    ENG116947-ENG116090-Leuchte11SHUTTER RB22-Dimmwert CD 11	0	16
    ENG116947-ENG116094-Leuchte11SHUTTER RB22-Dimmwert EF 11	0	16
    ENG116947-ENG116098-Leuchte11SHUTTER RB22-Dimmwert GH 11	0	16
    ENG116947-ENG116083-Leuchte11SHUTTER RB22-Fehlerort mittleres Byte DTC-DFCC 11	0	16
    ENG116947-ENG116561-Leuchte11SHUTTER RB22-Lampendefektbitposition 11	0	16
    ENG116947-ENG116081-Leuchte11SHUTTER RB22-Lasttyp 11	not active 	16
    ENG116947-ENG116087-Leuchte11SHUTTER RB22-Lichtansteuerung HD AB 11	Always 	16
    ENG116947-ENG116084-Leuchte11SHUTTER RB22-Lichtfunktion A 11	not active 	16
    ENG116947-ENG116085-Leuchte11SHUTTER RB22-Lichtfunktion B 11	not active 	16
    ENG116947-ENG116088-Leuchte11SHUTTER RB22-Lichtfunktion C 11	not active 	16
    ENG116947-ENG116089-Leuchte11SHUTTER RB22-Lichtfunktion D 11	not active 	16
    ENG116947-ENG116092-Leuchte11SHUTTER RB22-Lichtfunktion E 11	not active 	16
    ENG116947-ENG116093-Leuchte11SHUTTER RB22-Lichtfunktion F 11	not active 	16
    ENG116947-ENG116096-Leuchte11SHUTTER RB22-Lichtfunktion G 11	not active 	16
    ENG116947-ENG116097-Leuchte11SHUTTER RB22-Lichtfunktion H 11	not active 	16
    ENG116948-ENG116110-Leuchte12NL LB45-Dimming Direction CD 12	maximize 	16
    ENG116948-ENG116114-Leuchte12NL LB45-Dimming Direction EF 12	maximize 	16
    ENG116948-ENG116118-Leuchte12NL LB45-Dimming Direction GH 12	maximize 	16
    ENG116948-ENG116105-Leuchte12NL LB45-Dimmwert AB 12	100	16
    ENG116948-ENG116109-Leuchte12NL LB45-Dimmwert CD 12	0	16
    ENG116948-ENG116113-Leuchte12NL LB45-Dimmwert EF 12	0	16
    ENG116948-ENG116117-Leuchte12NL LB45-Dimmwert GH 12	0	16
    ENG116948-ENG116102-Leuchte12NL LB45-Fehlerort mittleres Byte DTC-DFCC 12	22	16
    ENG116948-ENG116562-Leuchte12NL LB45-Lampendefektbitposition 12	38	16
    ENG116948-ENG116100-Leuchte12NL LB45-Lasttyp 12	10 - allgemeine Scheinwerfer 	16
    ENG116948-ENG116106-Leuchte12NL LB45-Lichtansteuerung HD AB 12	Always 	16
    ENG116948-ENG116103-Leuchte12NL LB45-Lichtfunktion A 12	Nebellicht links 	16
    ENG116948-ENG116104-Leuchte12NL LB45-Lichtfunktion B 12	Abbiegelicht links 	16
    ENG116948-ENG116107-Leuchte12NL LB45-Lichtfunktion C 12	not active 	16
    ENG116948-ENG116108-Leuchte12NL LB45-Lichtfunktion D 12	not active 	16
    ENG116948-ENG116111-Leuchte12NL LB45-Lichtfunktion E 12	not active 	16
    ENG116948-ENG116112-Leuchte12NL LB45-Lichtfunktion F 12	not active 	16
    ENG116948-ENG116115-Leuchte12NL LB45-Lichtfunktion G 12	not active 	16
    ENG116948-ENG116116-Leuchte12NL LB45-Lichtfunktion H 12	not active 	16
    ENG116949-ENG116129-Leuchte13NL RB5-Dimming Direction CD 13	maximize 	16
    ENG116949-ENG116133-Leuchte13NL RB5-Dimming Direction EF 13	maximize 	16
    ENG116949-ENG116137-Leuchte13NL RB5-Dimming Direction GH 13	maximize 	16
    ENG116949-ENG116124-Leuchte13NL RB5-Dimmwert AB 13	100	16
    ENG116949-ENG116128-Leuchte13NL RB5-Dimmwert CD 13	0	16
    ENG116949-ENG116132-Leuchte13NL RB5-Dimmwert EF 13	0	16
    ENG116949-ENG116136-Leuchte13NL RB5-Dimmwert GH 13	0	16
    ENG116949-ENG116121-Leuchte13NL RB5-Fehlerort mittleres Byte DTC-DFCC 13	23	16
    ENG116949-ENG116563-Leuchte13NL RB5-Lampendefektbitposition 13	42	16
    ENG116949-ENG116119-Leuchte13NL RB5-Lasttyp 13	10 - allgemeine Scheinwerfer 	16
    ENG116949-ENG116125-Leuchte13NL RB5-Lichtansteuerung HD AB 13	Always 	16
    ENG116949-ENG116122-Leuchte13NL RB5-Lichtfunktion A 13	Nebellicht rechts 	16
    ENG116949-ENG116123-Leuchte13NL RB5-Lichtfunktion B 13	Abbiegelicht rechts 	16
    ENG116949-ENG116564-Leuchte13NL RB5-Lichtfunktion C 13	not active 	16
    ENG116949-ENG116127-Leuchte13NL RB5-Lichtfunktion D 13	not active 	16
    ENG116949-ENG116130-Leuchte13NL RB5-Lichtfunktion E 13	not active 	16
    ENG116949-ENG116131-Leuchte13NL RB5-Lichtfunktion F 13	not active 	16
    ENG116949-ENG116134-Leuchte13NL RB5-Lichtfunktion G 13	not active 	16
    ENG116949-ENG116135-Leuchte13NL RB5-Lichtfunktion H 13	not active 	16
    ENG116952-ENG116186-Leuchte16BLK SLB35BLK SL KC9-Dimming Direction CD 16	maximize 	16
    ENG116952-ENG116190-Leuchte16BLK SLB35BLK SL KC9-Dimming Direction EF 16	maximize 	16
    ENG116952-ENG116194-Leuchte16BLK SLB35BLK SL KC9-Dimming Direction GH 16	maximize 	16
    ENG116952-ENG116181-Leuchte16BLK SLB35BLK SL KC9-Dimmwert AB 16	127	16
    ENG116952-ENG116185-Leuchte16BLK SLB35BLK SL KC9-Dimmwert CD 16	0	16
    ENG116952-ENG116189-Leuchte16BLK SLB35BLK SL KC9-Dimmwert EF 16	0	16
    ENG116952-ENG116193-Leuchte16BLK SLB35BLK SL KC9-Dimmwert GH 16	0	16
    ENG116952-ENG116178-Leuchte16BLK SLB35BLK SL KC9-Fehlerort mittleres Byte DTC-DFCC 16	36	16
    ENG116952-ENG116567-Leuchte16BLK SLB35BLK SL KC9-Lampendefektbitposition 16	0	16
    ENG116952-ENG116176-Leuchte16BLK SLB35BLK SL KC9-Lasttyp 16	43 - allgemeine LED 	16
    ENG116952-ENG116182-Leuchte16BLK SLB35BLK SL KC9-Lichtansteuerung HD AB 16	only_if_closed 	16
    ENG116952-ENG116179-Leuchte16BLK SLB35BLK SL KC9-Lichtfunktion A 16	Standlicht allgemein (Schlusslicht: Positionslicht: Begrenzungslicht) 	16
    ENG116952-ENG116180-Leuchte16BLK SLB35BLK SL KC9-Lichtfunktion B 16	not active 	16
    ENG116952-ENG116183-Leuchte16BLK SLB35BLK SL KC9-Lichtfunktion C 16	not active 	16
    ENG116952-ENG116184-Leuchte16BLK SLB35BLK SL KC9-Lichtfunktion D 16	not active 	16
    ENG116952-ENG116187-Leuchte16BLK SLB35BLK SL KC9-Lichtfunktion E 16	not active 	16
    ENG116952-ENG116188-Leuchte16BLK SLB35BLK SL KC9-Lichtfunktion F 16	not active 	16
    ENG116952-ENG116191-Leuchte16BLK SLB35BLK SL KC9-Lichtfunktion G 16	not active 	16
    ENG116952-ENG116192-Leuchte16BLK SLB35BLK SL KC9-Lichtfunktion H 16	not active 	16
    ENG116953-ENG116205-Leuchte17TFL R BLK SRB3TFL R BLK SR KC3-Dimming Direction CD 17	maximize 	16
    ENG116953-ENG116209-Leuchte17TFL R BLK SRB3TFL R BLK SR KC3-Dimming Direction EF 17	maximize 	16
    ENG116953-ENG116213-Leuchte17TFL R BLK SRB3TFL R BLK SR KC3-Dimming Direction GH 17	maximize 	16
    ENG116953-ENG116200-Leuchte17TFL R BLK SRB3TFL R BLK SR KC3-Dimmwert AB 17	127	16
    ENG116953-ENG116204-Leuchte17TFL R BLK SRB3TFL R BLK SR KC3-Dimmwert CD 17	0	16
    ENG116953-ENG116208-Leuchte17TFL R BLK SRB3TFL R BLK SR KC3-Dimmwert EF 17	0	16
    ENG116953-ENG116212-Leuchte17TFL R BLK SRB3TFL R BLK SR KC3-Dimmwert GH 17	0	16
    ENG116953-ENG116197-Leuchte17TFL R BLK SRB3TFL R BLK SR KC3-Fehlerort mittleres Byte DTC-DFCC 17	35	16
    ENG116953-ENG116568-Leuchte17TFL R BLK SRB3TFL R BLK SR KC3-Lampendefektbitposition 17	0	16
    ENG116953-ENG116195-Leuchte17TFL R BLK SRB3TFL R BLK SR KC3-Lasttyp 17	43 - allgemeine LED 	16
    ENG116953-ENG116201-Leuchte17TFL R BLK SRB3TFL R BLK SR KC3-Lichtansteuerung HD AB 17	only_if_closed 	16
    ENG116953-ENG116198-Leuchte17TFL R BLK SRB3TFL R BLK SR KC3-Lichtfunktion A 17	Standlicht allgemein (Schlusslicht: Positionslicht: Begrenzungslicht) 	16
    ENG116953-ENG116569-Leuchte17TFL R BLK SRB3TFL R BLK SR KC3-Lichtfunktion B 17	not active 	16
    ENG116953-ENG116202-Leuchte17TFL R BLK SRB3TFL R BLK SR KC3-Lichtfunktion C 17	not active 	16
    ENG116953-ENG116203-Leuchte17TFL R BLK SRB3TFL R BLK SR KC3-Lichtfunktion D 17	not active 	16
    ENG116953-ENG116206-Leuchte17TFL R BLK SRB3TFL R BLK SR KC3-Lichtfunktion E 17	not active 	16
    ENG116953-ENG116207-Leuchte17TFL R BLK SRB3TFL R BLK SR KC3-Lichtfunktion F 17	not active 	16
    ENG116953-ENG116210-Leuchte17TFL R BLK SRB3TFL R BLK SR KC3-Lichtfunktion G 17	not active 	16
    ENG116953-ENG116211-Leuchte17TFL R BLK SRB3TFL R BLK SR KC3-Lichtfunktion H 17	not active 	16
    ENG116954-ENG116224-Leuchte18BLK HLA60-Dimming Direction CD 18	maximize 	16
    ENG116954-ENG116228-Leuchte18BLK HLA60-Dimming Direction EF 18	maximize 	16
    ENG116954-ENG116232-Leuchte18BLK HLA60-Dimming Direction GH 18	maximize 	16
    ENG116954-ENG116219-Leuchte18BLK HLA60-Dimmwert AB 18	0	16
    ENG116954-ENG116223-Leuchte18BLK HLA60-Dimmwert CD 18	0	16
    ENG116954-ENG116227-Leuchte18BLK HLA60-Dimmwert EF 18	0	16
    ENG116954-ENG116231-Leuchte18BLK HLA60-Dimmwert GH 18	0	16
    ENG116954-ENG116216-Leuchte18BLK HLA60-Fehlerort mittleres Byte DTC-DFCC 18	0	16
    ENG116954-ENG116570-Leuchte18BLK HLA60-Lampendefektbitposition 18	0	16
    ENG116954-ENG116214-Leuchte18BLK HLA60-Lasttyp 18	not active 	16
    ENG116954-ENG116220-Leuchte18BLK HLA60-Lichtansteuerung HD AB 18	Always 	16
    ENG116954-ENG116217-Leuchte18BLK HLA60-Lichtfunktion A 18	not active 	16
    ENG116954-ENG116218-Leuchte18BLK HLA60-Lichtfunktion B 18	not active 	16
    ENG116954-ENG116221-Leuchte18BLK HLA60-Lichtfunktion C 18	not active 	16
    ENG116954-ENG116222-Leuchte18BLK HLA60-Lichtfunktion D 18	not active 	16
    ENG116954-ENG116225-Leuchte18BLK HLA60-Lichtfunktion E 18	not active 	16
    ENG116954-ENG116226-Leuchte18BLK HLA60-Lichtfunktion F 18	not active 	16
    ENG116954-ENG116229-Leuchte18BLK HLA60-Lichtfunktion G 18	not active 	16
    ENG116954-ENG116230-Leuchte18BLK HLA60-Lichtfunktion H 18	not active 	16
    ENG116955-ENG116243-Leuchte19BLK HRC31-Dimming Direction CD 19	maximize 	16
    ENG116955-ENG116247-Leuchte19BLK HRC31-Dimming Direction EF 19	maximize 	16
    ENG116955-ENG116251-Leuchte19BLK HRC31-Dimming Direction GH 19	maximize 	16
    ENG116955-ENG116238-Leuchte19BLK HRC31-Dimmwert AB 19	0	16
    ENG116955-ENG116242-Leuchte19BLK HRC31-Dimmwert CD 19	0	16
    ENG116955-ENG116246-Leuchte19BLK HRC31-Dimmwert EF 19	0	16
    ENG116955-ENG116250-Leuchte19BLK HRC31-Dimmwert GH 19	0	16
    ENG116955-ENG116235-Leuchte19BLK HRC31-Fehlerort mittleres Byte DTC-DFCC 19	0	16
    ENG116955-ENG116571-Leuchte19BLK HRC31-Lampendefektbitposition 19	0	16
    ENG116955-ENG116233-Leuchte19BLK HRC31-Lasttyp 19	not active 	16
    ENG116955-ENG116239-Leuchte19BLK HRC31-Lichtansteuerung HD AB 19	Always 	16
    ENG116955-ENG116236-Leuchte19BLK HRC31-Lichtfunktion A 19	not active 	16
    ENG116955-ENG116237-Leuchte19BLK HRC31-Lichtfunktion B 19	not active 	16
    ENG116955-ENG116240-Leuchte19BLK HRC31-Lichtfunktion C 19	not active 	16
    ENG116955-ENG116241-Leuchte19BLK HRC31-Lichtfunktion D 19	not active 	16
    ENG116955-ENG116244-Leuchte19BLK HRC31-Lichtfunktion E 19	not active 	16
    ENG116955-ENG116245-Leuchte19BLK HRC31-Lichtfunktion F 19	not active 	16
    ENG116955-ENG116248-Leuchte19BLK HRC31-Lichtfunktion G 19	not active 	16
    ENG116955-ENG116249-Leuchte19BLK HRC31-Lichtfunktion H 19	not active 	16
    ENG116937-ENG115902-Leuchte1BLK VRB20-Dimming Direction CD 1	maximize 	16
    ENG116937-ENG115906-Leuchte1BLK VRB20-Dimming Direction EF 1	maximize 	16
    ENG116937-ENG115909-Leuchte1BLK VRB20-Dimming Direction GH 1	maximize 	16
    ENG116937-ENG115897-Leuchte1BLK VRB20-Dimmwert AB 1	100	16
    ENG116937-ENG115901-Leuchte1BLK VRB20-Dimmwert CD 1	0	16
    ENG116937-ENG115905-Leuchte1BLK VRB20-Dimmwert EF 1	0	16
    ENG116937-ENG115908-Leuchte1BLK VRB20-Dimmwert GH 1	0	16
    ENG116937-ENG115894-Leuchte1BLK VRB20-Fehlerort mittleres Byte DTC-DFCC 1	15	16
    ENG116937-ENG116548-Leuchte1BLK VRB20-Lampendefektbitposition 1	3E 	16
    ENG116937-ENG115892-Leuchte1BLK VRB20-Lasttyp 1	12 - Blinkleuchten 	16
    ENG116937-ENG115898-Leuchte1BLK VRB20-Lichtansteuerung HD AB 1	Always 	16
    ENG116937-ENG115895-Leuchte1BLK VRB20-Lichtfunktion A 1	Blinken rechts Hellphase 	16
    ENG116937-ENG115896-Leuchte1BLK VRB20-Lichtfunktion B 1	not active 	16
    ENG116937-ENG115899-Leuchte1BLK VRB20-Lichtfunktion C 1	not active 	16
    ENG116937-ENG115900-Leuchte1BLK VRB20-Lichtfunktion D 1	not active 	16
    ENG116937-ENG115903-Leuchte1BLK VRB20-Lichtfunktion E 1	not active 	16
    ENG116937-ENG115904-Leuchte1BLK VRB20-Lichtfunktion F 1	not active 	16
    ENG116937-ENG115907-Leuchte1BLK VRB20-Lichtfunktion G 1	not active 	16
    ENG116937-ENG116549-Leuchte1BLK VRB20-Lichtfunktion H 1	not active 	16
    ENG116956-ENG116262-Leuchte20BR LA71-Dimming Direction CD 20	minimize 	16
    ENG116956-ENG116266-Leuchte20BR LA71-Dimming Direction EF 20	maximize 	16
    ENG116956-ENG116270-Leuchte20BR LA71-Dimming Direction GH 20	maximize 	16
    ENG116956-ENG116257-Leuchte20BR LA71-Dimmwert AB 20	100	16
    ENG116956-ENG116261-Leuchte20BR LA71-Dimmwert CD 20	0	16
    ENG116956-ENG116265-Leuchte20BR LA71-Dimmwert EF 20	0	16
    ENG116956-ENG116269-Leuchte20BR LA71-Dimmwert GH 20	0	16
    ENG116956-ENG116254-Leuchte20BR LA71-Fehlerort mittleres Byte DTC-DFCC 20	3D 	16
    ENG116956-ENG116572-Leuchte20BR LA71-Lampendefektbitposition 20	13	16
    ENG116956-ENG116252-Leuchte20BR LA71-Lasttyp 20	43 - allgemeine LED 	16
    ENG116956-ENG116258-Leuchte20BR LA71-Lichtansteuerung HD AB 20	Always 	16
    ENG116956-ENG116255-Leuchte20BR LA71-Lichtfunktion A 20	Brake light 	16
    ENG116956-ENG116256-Leuchte20BR LA71-Lichtfunktion B 20	Blinken links Hellphase 	16
    ENG116956-ENG116259-Leuchte20BR LA71-Lichtfunktion C 20	Blinken links Dunkelphase 	16
    ENG116956-ENG116260-Leuchte20BR LA71-Lichtfunktion D 20	not active 	16
    ENG116956-ENG116263-Leuchte20BR LA71-Lichtfunktion E 20	not active 	16
    ENG116956-ENG116264-Leuchte20BR LA71-Lichtfunktion F 20	not active 	16
    ENG116956-ENG116267-Leuchte20BR LA71-Lichtfunktion G 20	not active 	16
    ENG116956-ENG116268-Leuchte20BR LA71-Lichtfunktion H 20	not active 	16
    ENG116957-ENG116281-Leuchte21BR RC8-Dimming Direction CD 21	minimize 	16
    ENG116957-ENG116285-Leuchte21BR RC8-Dimming Direction EF 21	maximize 	16
    ENG116957-ENG116289-Leuchte21BR RC8-Dimming Direction GH 21	maximize 	16
    ENG116957-ENG116276-Leuchte21BR RC8-Dimmwert AB 21	100	16
    ENG116957-ENG116280-Leuchte21BR RC8-Dimmwert CD 21	0	16
    ENG116957-ENG116284-Leuchte21BR RC8-Dimmwert EF 21	0	16
    ENG116957-ENG116288-Leuchte21BR RC8-Dimmwert GH 21	0	16
    ENG116957-ENG116273-Leuchte21BR RC8-Fehlerort mittleres Byte DTC-DFCC 21	3E 	16
    ENG116957-ENG116573-Leuchte21BR RC8-Lampendefektbitposition 21	23	16
    ENG116957-ENG116271-Leuchte21BR RC8-Lasttyp 21	43 - allgemeine LED 	16
    ENG116957-ENG116277-Leuchte21BR RC8-Lichtansteuerung HD AB 21	Always 	16
    ENG116957-ENG116274-Leuchte21BR RC8-Lichtfunktion A 21	Brake light 	16
    ENG116957-ENG116275-Leuchte21BR RC8-Lichtfunktion B 21	Blinken rechts Hellphase 	16
    ENG116957-ENG116278-Leuchte21BR RC8-Lichtfunktion C 21	Blinken rechts Dunkelphase 	16
    ENG116957-ENG116279-Leuchte21BR RC8-Lichtfunktion D 21	not active 	16
    ENG116957-ENG116282-Leuchte21BR RC8-Lichtfunktion E 21	not active 	16
    ENG116957-ENG116283-Leuchte21BR RC8-Lichtfunktion F 21	not active 	16
    ENG116957-ENG116286-Leuchte21BR RC8-Lichtfunktion G 21	not active 	16
    ENG116957-ENG116287-Leuchte21BR RC8-Lichtfunktion H 21	not active 	16
    ENG116958-ENG116300-Leuchte22BR MA57-Dimming Direction CD 22	maximize 	16
    ENG116958-ENG116304-Leuchte22BR MA57-Dimming Direction EF 22	maximize 	16
    ENG116958-ENG116308-Leuchte22BR MA57-Dimming Direction GH 22	maximize 	16
    ENG116958-ENG116295-Leuchte22BR MA57-Dimmwert AB 22	127	16
    ENG116958-ENG116299-Leuchte22BR MA57-Dimmwert CD 22	0	16
    ENG116958-ENG116303-Leuchte22BR MA57-Dimmwert EF 22	0	16
    ENG116958-ENG116307-Leuchte22BR MA57-Dimmwert GH 22	0	16
    ENG116958-ENG116292-Leuchte22BR MA57-Fehlerort mittleres Byte DTC-DFCC 22	2C 	16
    ENG116958-ENG116574-Leuchte22BR MA57-Lampendefektbitposition 22	29	16
    ENG116958-ENG116290-Leuchte22BR MA57-Lasttyp 22	42 - LED dritte Bremsleuchte 	16
    ENG116958-ENG116296-Leuchte22BR MA57-Lichtansteuerung HD AB 22	Always 	16
    ENG116958-ENG116293-Leuchte22BR MA57-Lichtfunktion A 22	Brake light 	16
    ENG116958-ENG116294-Leuchte22BR MA57-Lichtfunktion B 22	Quittierungsfunktion 1 	16
    ENG116958-ENG116297-Leuchte22BR MA57-Lichtfunktion C 22	not active 	16
    ENG116958-ENG116298-Leuchte22BR MA57-Lichtfunktion D 22	not active 	16
    ENG116958-ENG116301-Leuchte22BR MA57-Lichtfunktion E 22	not active 	16
    ENG116958-ENG116302-Leuchte22BR MA57-Lichtfunktion F 22	not active 	16
    ENG116958-ENG116305-Leuchte22BR MA57-Lichtfunktion G 22	not active 	16
    ENG116958-ENG116306-Leuchte22BR MA57-Lichtfunktion H 22	not active 	16
    ENG116959-ENG116319-Leuchte23SL HLC10-Dimming Direction CD 23	maximize 	16
    ENG116959-ENG116323-Leuchte23SL HLC10-Dimming Direction EF 23	maximize 	16
    ENG116959-ENG116327-Leuchte23SL HLC10-Dimming Direction GH 23	maximize 	16
    ENG116959-ENG116314-Leuchte23SL HLC10-Dimmwert AB 23	127	16
    ENG116959-ENG116318-Leuchte23SL HLC10-Dimmwert CD 23	0	16
    ENG116959-ENG116322-Leuchte23SL HLC10-Dimmwert EF 23	0	16
    ENG116959-ENG116326-Leuchte23SL HLC10-Dimmwert GH 23	0	16
    ENG116959-ENG116311-Leuchte23SL HLC10-Fehlerort mittleres Byte DTC-DFCC 23	29	16
    ENG116959-ENG116575-Leuchte23SL HLC10-Lampendefektbitposition 23	0A 	16
    ENG116959-ENG116309-Leuchte23SL HLC10-Lasttyp 23	43 - allgemeine LED 	16
    ENG116959-ENG116315-Leuchte23SL HLC10-Lichtansteuerung HD AB 23	Always 	16
    ENG116959-ENG116312-Leuchte23SL HLC10-Lichtfunktion A 23	Standlicht allgemein (Schlusslicht: Positionslicht: Begrenzungslicht) 	16
    ENG116959-ENG116313-Leuchte23SL HLC10-Lichtfunktion B 23	not active 	16
    ENG116959-ENG116316-Leuchte23SL HLC10-Lichtfunktion C 23	not active 	16
    ENG116959-ENG116317-Leuchte23SL HLC10-Lichtfunktion D 23	not active 	16
    ENG116959-ENG116320-Leuchte23SL HLC10-Lichtfunktion E 23	not active 	16
    ENG116959-ENG116321-Leuchte23SL HLC10-Lichtfunktion F 23	not active 	16
    ENG116959-ENG116324-Leuchte23SL HLC10-Lichtfunktion G 23	not active 	16
    ENG116959-ENG116325-Leuchte23SL HLC10-Lichtfunktion H 23	not active 	16
    ENG116960-ENG116338-Leuchte24SL HRA65-Dimming Direction CD 24	maximize 	16
    ENG116960-ENG116342-Leuchte24SL HRA65-Dimming Direction EF 24	maximize 	16
    ENG116960-ENG116346-Leuchte24SL HRA65-Dimming Direction GH 24	maximize 	16
    ENG116960-ENG116333-Leuchte24SL HRA65-Dimmwert AB 24	127	16
    ENG116960-ENG116337-Leuchte24SL HRA65-Dimmwert CD 24	0	16
    ENG116960-ENG116341-Leuchte24SL HRA65-Dimmwert EF 24	0	16
    ENG116960-ENG116345-Leuchte24SL HRA65-Dimmwert GH 24	0	16
    ENG116960-ENG116330-Leuchte24SL HRA65-Fehlerort mittleres Byte DTC-DFCC 24	2A 	16
    ENG116960-ENG116576-Leuchte24SL HRA65-Lampendefektbitposition 24	1A 	16
    ENG116960-ENG116328-Leuchte24SL HRA65-Lasttyp 24	43 - allgemeine LED 	16
    ENG116960-ENG116334-Leuchte24SL HRA65-Lichtansteuerung HD AB 24	Always 	16
    ENG116960-ENG116331-Leuchte24SL HRA65-Lichtfunktion A 24	Standlicht allgemein (Schlusslicht: Positionslicht: Begrenzungslicht) 	16
    ENG116960-ENG116332-Leuchte24SL HRA65-Lichtfunktion B 24	not active 	16
    ENG116960-ENG116335-Leuchte24SL HRA65-Lichtfunktion C 24	not active 	16
    ENG116960-ENG116336-Leuchte24SL HRA65-Lichtfunktion D 24	not active 	16
    ENG116960-ENG116339-Leuchte24SL HRA65-Lichtfunktion E 24	not active 	16
    ENG116960-ENG116340-Leuchte24SL HRA65-Lichtfunktion F 24	not active 	16
    ENG116960-ENG116343-Leuchte24SL HRA65-Lichtfunktion G 24	not active 	16
    ENG116960-ENG116344-Leuchte24SL HRA65-Lichtfunktion H 24	not active 	16
    ENG116961-ENG116357-Leuchte25KZL HA59-Dimming Direction CD 25	maximize 	16
    ENG116961-ENG116361-Leuchte25KZL HA59-Dimming Direction EF 25	maximize 	16
    ENG116961-ENG116365-Leuchte25KZL HA59-Dimming Direction GH 25	maximize 	16
    ENG116961-ENG116352-Leuchte25KZL HA59-Dimmwert AB 25	127	16
    ENG116961-ENG116356-Leuchte25KZL HA59-Dimmwert CD 25	0	16
    ENG116961-ENG116360-Leuchte25KZL HA59-Dimmwert EF 25	0	16
    ENG116961-ENG116364-Leuchte25KZL HA59-Dimmwert GH 25	0	16
    ENG116961-ENG116349-Leuchte25KZL HA59-Fehlerort mittleres Byte DTC-DFCC 25	30	16
    ENG116961-ENG116577-Leuchte25KZL HA59-Lampendefektbitposition 25	28	16
    ENG116961-ENG116347-Leuchte25KZL HA59-Lasttyp 25	43 - allgemeine LED 	16
    ENG116961-ENG116353-Leuchte25KZL HA59-Lichtansteuerung HD AB 25	Always 	16
    ENG116961-ENG116350-Leuchte25KZL HA59-Lichtfunktion A 25	Standlicht allgemein (Schlusslicht: Positionslicht: Begrenzungslicht) 	16
    ENG116961-ENG116351-Leuchte25KZL HA59-Lichtfunktion B 25	not active 	16
    ENG116961-ENG116354-Leuchte25KZL HA59-Lichtfunktion C 25	not active 	16
    ENG116961-ENG116355-Leuchte25KZL HA59-Lichtfunktion D 25	not active 	16
    ENG116961-ENG116358-Leuchte25KZL HA59-Lichtfunktion E 25	not active 	16
    ENG116961-ENG116359-Leuchte25KZL HA59-Lichtfunktion F 25	not active 	16
    ENG116961-ENG116362-Leuchte25KZL HA59-Lichtfunktion G 25	not active 	16
    ENG116961-ENG116363-Leuchte25KZL HA59-Lichtfunktion H 25	not active 	16
    ENG116962-ENG116376-Leuchte26NSL LA72-Dimming Direction CD 26	maximize 	16
    ENG116962-ENG116380-Leuchte26NSL LA72-Dimming Direction EF 26	maximize 	16
    ENG116962-ENG116384-Leuchte26NSL LA72-Dimming Direction GH 26	maximize 	16
    ENG116962-ENG116371-Leuchte26NSL LA72-Dimmwert AB 26	127	16
    ENG116962-ENG116375-Leuchte26NSL LA72-Dimmwert CD 26	0	16
    ENG116962-ENG116379-Leuchte26NSL LA72-Dimmwert EF 26	0	16
    ENG116962-ENG116383-Leuchte26NSL LA72-Dimmwert GH 26	0	16
    ENG116962-ENG116368-Leuchte26NSL LA72-Fehlerort mittleres Byte DTC-DFCC 26	54	16
    ENG116962-ENG116578-Leuchte26NSL LA72-Lampendefektbitposition 26	0	16
    ENG116962-ENG116366-Leuchte26NSL LA72-Lasttyp 26	43 - allgemeine LED 	16
    ENG116962-ENG116372-Leuchte26NSL LA72-Lichtansteuerung HD AB 26	Always 	16
    ENG116962-ENG116369-Leuchte26NSL LA72-Lichtfunktion A 26	Standlicht allgemein (Schlusslicht: Positionslicht: Begrenzungslicht) 	16
    ENG116962-ENG116370-Leuchte26NSL LA72-Lichtfunktion B 26	not active 	16
    ENG116962-ENG116373-Leuchte26NSL LA72-Lichtfunktion C 26	not active 	16
    ENG116962-ENG116374-Leuchte26NSL LA72-Lichtfunktion D 26	not active 	16
    ENG116962-ENG116377-Leuchte26NSL LA72-Lichtfunktion E 26	not active 	16
    ENG116962-ENG116378-Leuchte26NSL LA72-Lichtfunktion F 26	not active 	16
    ENG116962-ENG116381-Leuchte26NSL LA72-Lichtfunktion G 26	not active 	16
    ENG116962-ENG116382-Leuchte26NSL LA72-Lichtfunktion H 26	not active 	16
    ENG116963-ENG116395-Leuchte27NSL RC6-Dimming Direction CD 27	maximize 	16
    ENG116963-ENG116399-Leuchte27NSL RC6-Dimming Direction EF 27	maximize 	16
    ENG116963-ENG116403-Leuchte27NSL RC6-Dimming Direction GH 27	maximize 	16
    ENG116963-ENG116390-Leuchte27NSL RC6-Dimmwert AB 27	127	16
    ENG116963-ENG116394-Leuchte27NSL RC6-Dimmwert CD 27	0	16
    ENG116963-ENG116398-Leuchte27NSL RC6-Dimmwert EF 27	0	16
    ENG116963-ENG116402-Leuchte27NSL RC6-Dimmwert GH 27	0	16
    ENG116963-ENG116387-Leuchte27NSL RC6-Fehlerort mittleres Byte DTC-DFCC 27	53	16
    ENG116963-ENG116579-Leuchte27NSL RC6-Lampendefektbitposition 27	0	16
    ENG116963-ENG116385-Leuchte27NSL RC6-Lasttyp 27	43 - allgemeine LED 	16
    ENG116963-ENG116391-Leuchte27NSL RC6-Lichtansteuerung HD AB 27	Always 	16
    ENG116963-ENG116388-Leuchte27NSL RC6-Lichtfunktion A 27	Standlicht allgemein (Schlusslicht: Positionslicht: Begrenzungslicht) 	16
    ENG116963-ENG116389-Leuchte27NSL RC6-Lichtfunktion B 27	not active 	16
    ENG116963-ENG116392-Leuchte27NSL RC6-Lichtfunktion C 27	not active 	16
    ENG116963-ENG116393-Leuchte27NSL RC6-Lichtfunktion D 27	not active 	16
    ENG116963-ENG116396-Leuchte27NSL RC6-Lichtfunktion E 27	not active 	16
    ENG116963-ENG116397-Leuchte27NSL RC6-Lichtfunktion F 27	not active 	16
    ENG116963-ENG116400-Leuchte27NSL RC6-Lichtfunktion G 27	not active 	16
    ENG116963-ENG116401-Leuchte27NSL RC6-Lichtfunktion H 27	not active 	16
    ENG116964-ENG116414-Leuchte28RFL LC11-Dimming Direction CD 28	maximize 	16
    ENG116964-ENG116418-Leuchte28RFL LC11-Dimming Direction EF 28	maximize 	16
    ENG116964-ENG116422-Leuchte28RFL LC11-Dimming Direction GH 28	maximize 	16
    ENG116964-ENG116409-Leuchte28RFL LC11-Dimmwert AB 28	127	16
    ENG116964-ENG116413-Leuchte28RFL LC11-Dimmwert CD 28	0	16
    ENG116964-ENG116417-Leuchte28RFL LC11-Dimmwert EF 28	0	16
    ENG116964-ENG116421-Leuchte28RFL LC11-Dimmwert GH 28	0	16
    ENG116964-ENG116406-Leuchte28RFL LC11-Fehlerort mittleres Byte DTC-DFCC 28	31	16
    ENG116964-ENG116580-Leuchte28RFL LC11-Lampendefektbitposition 28	0B 	16
    ENG116964-ENG116404-Leuchte28RFL LC11-Lasttyp 28	43 - allgemeine LED 	16
    ENG116964-ENG116410-Leuchte28RFL LC11-Lichtansteuerung HD AB 28	Always 	16
    ENG116964-ENG116407-Leuchte28RFL LC11-Lichtfunktion A 28	Rueckfahrlicht 	16
    ENG116964-ENG116408-Leuchte28RFL LC11-Lichtfunktion B 28	not active 	16
    ENG116964-ENG116411-Leuchte28RFL LC11-Lichtfunktion C 28	not active 	16
    ENG116964-ENG116412-Leuchte28RFL LC11-Lichtfunktion D 28	not active 	16
    ENG116964-ENG116415-Leuchte28RFL LC11-Lichtfunktion E 28	not active 	16
    ENG116964-ENG116416-Leuchte28RFL LC11-Lichtfunktion F 28	not active 	16
    ENG116964-ENG116419-Leuchte28RFL LC11-Lichtfunktion G 28	not active 	16
    ENG116964-ENG116420-Leuchte28RFL LC11-Lichtfunktion H 28	not active 	16
    ENG116965-ENG116433-Leuchte29RFL RA64-Dimming Direction CD 29	maximize 	16
    ENG116965-ENG116437-Leuchte29RFL RA64-Dimming Direction EF 29	maximize 	16
    ENG116965-ENG116441-Leuchte29RFL RA64-Dimming Direction GH 29	maximize 	16
    ENG116965-ENG116428-Leuchte29RFL RA64-Dimmwert AB 29	127	16
    ENG116965-ENG116432-Leuchte29RFL RA64-Dimmwert CD 29	0	16
    ENG116965-ENG116436-Leuchte29RFL RA64-Dimmwert EF 29	0	16
    ENG116965-ENG116440-Leuchte29RFL RA64-Dimmwert GH 29	0	16
    ENG116965-ENG116425-Leuchte29RFL RA64-Fehlerort mittleres Byte DTC-DFCC 29	32	16
    ENG116965-ENG116581-Leuchte29RFL RA64-Lampendefektbitposition 29	1B 	16
    ENG116965-ENG116423-Leuchte29RFL RA64-Lasttyp 29	43 - allgemeine LED 	16
    ENG116965-ENG116430-Leuchte29RFL RA64-Lichtansteuerung HD AB 29	Always 	16
    ENG116965-ENG116426-Leuchte29RFL RA64-Lichtfunktion A 29	Rueckfahrlicht 	16
    ENG116965-ENG116427-Leuchte29RFL RA64-Lichtfunktion B 29	not active 	16
    ENG116965-ENG116429-Leuchte29RFL RA64-Lichtfunktion C 29	not active 	16
    ENG116965-ENG116431-Leuchte29RFL RA64-Lichtfunktion D 29	not active 	16
    ENG116965-ENG116434-Leuchte29RFL RA64-Lichtfunktion E 29	not active 	16
    ENG116965-ENG116435-Leuchte29RFL RA64-Lichtfunktion F 29	not active 	16
    ENG116965-ENG116438-Leuchte29RFL RA64-Lichtfunktion G 29	not active 	16
    ENG116965-ENG116439-Leuchte29RFL RA64-Lichtfunktion H 29	not active 	16
    ENG116938-ENG115920-Leuchte2SL VLB10-Dimming Direction CD 2	minimize 	16
    ENG116938-ENG115924-Leuchte2SL VLB10-Dimming Direction EF 2	maximize 	16
    ENG116938-ENG115928-Leuchte2SL VLB10-Dimming Direction GH 2	maximize 	16
    ENG116938-ENG115915-Leuchte2SL VLB10-Dimmwert AB 2	100	16
    ENG116938-ENG115919-Leuchte2SL VLB10-Dimmwert CD 2	28	16
    ENG116938-ENG115923-Leuchte2SL VLB10-Dimmwert EF 2	28	16
    ENG116938-ENG115927-Leuchte2SL VLB10-Dimmwert GH 2	0	16
    ENG116938-ENG115912-Leuchte2SL VLB10-Fehlerort mittleres Byte DTC-DFCC 2	4A 	16
    ENG116938-ENG116550-Leuchte2SL VLB10-Lampendefektbitposition 2	48	16
    ENG116938-ENG115910-Leuchte2SL VLB10-Lasttyp 2	4 - LED Tagfahrlichtmodul Signal 	16
    ENG116938-ENG115916-Leuchte2SL VLB10-Lichtansteuerung HD AB 2	Always 	16
    ENG116938-ENG115913-Leuchte2SL VLB10-Lichtfunktion A 2	Daytime running lights 	16
    ENG116938-ENG115914-Leuchte2SL VLB10-Lichtfunktion B 2	not active 	16
    ENG116938-ENG115917-Leuchte2SL VLB10-Lichtfunktion C 2	Blinken links aktiv (beide Phasen) 	16
    ENG116938-ENG115918-Leuchte2SL VLB10-Lichtfunktion D 2	Nebellicht links 	16
    ENG116938-ENG115921-Leuchte2SL VLB10-Lichtfunktion E 2	Standlicht allgemein (Schlusslicht: Positionslicht: Begrenzungslicht) 	16
    ENG116938-ENG115922-Leuchte2SL VLB10-Lichtfunktion F 2	Parklicht links (beidseitiges Parklicht aktiviert li & re) 	16
    ENG116938-ENG115925-Leuchte2SL VLB10-Lichtfunktion G 2	not active 	16
    ENG116938-ENG115926-Leuchte2SL VLB10-Lichtfunktion H 2	not active 	16
    ENG116966-ENG116452-Leuchte30FR LC72-Dimming Direction CD 30	maximize 	16
    ENG116966-ENG116456-Leuchte30FR LC72-Dimming Direction EF 30	maximize 	16
    ENG116966-ENG116460-Leuchte30FR LC72-Dimming Direction GH 30	maximize 	16
    ENG116966-ENG116447-Leuchte30FR LC72-Dimmwert AB 30	89	16
    ENG116966-ENG116451-Leuchte30FR LC72-Dimmwert CD 30	0	16
    ENG116966-ENG116455-Leuchte30FR LC72-Dimmwert EF 30	0	16
    ENG116966-ENG116459-Leuchte30FR LC72-Dimmwert GH 30	0	16
    ENG116966-ENG116444-Leuchte30FR LC72-Fehlerort mittleres Byte DTC-DFCC 30	2	16
    ENG116966-ENG116582-Leuchte30FR LC72-Lampendefektbitposition 30	0	16
    ENG116966-ENG116442-Leuchte30FR LC72-Lasttyp 30	36 - LED Kleinleistung 	16
    ENG116966-ENG116448-Leuchte30FR LC72-Lichtansteuerung HD AB 30	Always 	16
    ENG116966-ENG116445-Leuchte30FR LC72-Lichtfunktion A 30	Footwell light 	16
    ENG116966-ENG116446-Leuchte30FR LC72-Lichtfunktion B 30	not active 	16
    ENG116966-ENG116449-Leuchte30FR LC72-Lichtfunktion C 30	not active 	16
    ENG116966-ENG116450-Leuchte30FR LC72-Lichtfunktion D 30	not active 	16
    ENG116966-ENG116453-Leuchte30FR LC72-Lichtfunktion E 30	not active 	16
    ENG116966-ENG116454-Leuchte30FR LC72-Lichtfunktion F 30	not active 	16
    ENG116966-ENG116457-Leuchte30FR LC72-Lichtfunktion G 30	not active 	16
    ENG116966-ENG116458-Leuchte30FR LC72-Lichtfunktion H 30	not active 	16
    ENG116967-ENG116471-Leuchte31AMBL 1C61-Dimming Direction CD 31	maximize 	16
    ENG116967-ENG116475-Leuchte31AMBL 1C61-Dimming Direction EF 31	maximize 	16
    ENG116967-ENG116479-Leuchte31AMBL 1C61-Dimming Direction GH 31	maximize 	16
    ENG116967-ENG116466-Leuchte31AMBL 1C61-Dimmwert AB 31	0	16
    ENG116967-ENG116470-Leuchte31AMBL 1C61-Dimmwert CD 31	0	16
    ENG116967-ENG116474-Leuchte31AMBL 1C61-Dimmwert EF 31	0	16
    ENG116967-ENG116478-Leuchte31AMBL 1C61-Dimmwert GH 31	0	16
    ENG116967-ENG116463-Leuchte31AMBL 1C61-Fehlerort mittleres Byte DTC-DFCC 31	0	16
    ENG116967-ENG116583-Leuchte31AMBL 1C61-Lampendefektbitposition 31	0	16
    ENG116967-ENG116461-Leuchte31AMBL 1C61-Lasttyp 31	not active 	16
    ENG116967-ENG116467-Leuchte31AMBL 1C61-Lichtansteuerung HD AB 31	Always 	16
    ENG116967-ENG116464-Leuchte31AMBL 1C61-Lichtfunktion A 31	not active 	16
    ENG116967-ENG116465-Leuchte31AMBL 1C61-Lichtfunktion B 31	not active 	16
    ENG116967-ENG116468-Leuchte31AMBL 1C61-Lichtfunktion C 31	not active 	16
    ENG116967-ENG116469-Leuchte31AMBL 1C61-Lichtfunktion D 31	not active 	16
    ENG116967-ENG116472-Leuchte31AMBL 1C61-Lichtfunktion E 31	not active 	16
    ENG116967-ENG116473-Leuchte31AMBL 1C61-Lichtfunktion F 31	not active 	16
    ENG116967-ENG116476-Leuchte31AMBL 1C61-Lichtfunktion G 31	not active 	16
    ENG116967-ENG116477-Leuchte31AMBL 1C61-Lichtfunktion H 31	not active 	16
    ENG116968-ENG116490-Leuchte32AMBL 2C35-Dimming Direction CD 32	maximize 	16
    ENG116968-ENG116494-Leuchte32AMBL 2C35-Dimming Direction EF 32	maximize 	16
    ENG116968-ENG116498-Leuchte32AMBL 2C35-Dimming Direction GH 32	maximize 	16
    ENG116968-ENG116485-Leuchte32AMBL 2C35-Dimmwert AB 32	0	16
    ENG116968-ENG116489-Leuchte32AMBL 2C35-Dimmwert CD 32	0	16
    ENG116968-ENG116493-Leuchte32AMBL 2C35-Dimmwert EF 32	0	16
    ENG116968-ENG116497-Leuchte32AMBL 2C35-Dimmwert GH 32	0	16
    ENG116968-ENG116482-Leuchte32AMBL 2C35-Fehlerort mittleres Byte DTC-DFCC 32	0	16
    ENG116968-ENG116584-Leuchte32AMBL 2C35-Lampendefektbitposition 32	0	16
    ENG116968-ENG116480-Leuchte32AMBL 2C35-Lasttyp 32	not active 	16
    ENG116968-ENG116486-Leuchte32AMBL 2C35-Lichtansteuerung HD AB 32	Always 	16
    ENG116968-ENG116483-Leuchte32AMBL 2C35-Lichtfunktion A 32	not active 	16
    ENG116968-ENG116484-Leuchte32AMBL 2C35-Lichtfunktion B 32	not active 	16
    ENG116968-ENG116487-Leuchte32AMBL 2C35-Lichtfunktion C 32	not active 	16
    ENG116968-ENG116488-Leuchte32AMBL 2C35-Lichtfunktion D 32	not active 	16
    ENG116968-ENG116491-Leuchte32AMBL 2C35-Lichtfunktion E 32	not active 	16
    ENG116968-ENG116492-Leuchte32AMBL 2C35-Lichtfunktion F 32	not active 	16
    ENG116968-ENG116495-Leuchte32AMBL 2C35-Lichtfunktion G 32	not active 	16
    ENG116968-ENG116496-Leuchte32AMBL 2C35-Lichtfunktion H 32	not active 	16
    ENG116969-ENG116509-Leuchte33AMBL 3C36-Dimming Direction CD 33	maximize 	16
    ENG116969-ENG116513-Leuchte33AMBL 3C36-Dimming Direction EF 33	maximize 	16
    ENG116969-ENG116517-Leuchte33AMBL 3C36-Dimming Direction GH 33	maximize 	16
    ENG116969-ENG116504-Leuchte33AMBL 3C36-Dimmwert AB 33	0	16
    ENG116969-ENG116508-Leuchte33AMBL 3C36-Dimmwert CD 33	0	16
    ENG116969-ENG116512-Leuchte33AMBL 3C36-Dimmwert EF 33	0	16
    ENG116969-ENG116516-Leuchte33AMBL 3C36-Dimmwert GH 33	0	16
    ENG116969-ENG116501-Leuchte33AMBL 3C36-Fehlerort mittleres Byte DTC-DFCC 33	0	16
    ENG116969-ENG116585-Leuchte33AMBL 3C36-Lampendefektbitposition 33	0	16
    ENG116969-ENG116499-Leuchte33AMBL 3C36-Lasttyp 33	not active 	16
    ENG116969-ENG116505-Leuchte33AMBL 3C36-Lichtansteuerung HD AB 33	Always 	16
    ENG116969-ENG116502-Leuchte33AMBL 3C36-Lichtfunktion A 33	not active 	16
    ENG116969-ENG116503-Leuchte33AMBL 3C36-Lichtfunktion B 33	not active 	16
    ENG116969-ENG116506-Leuchte33AMBL 3C36-Lichtfunktion C 33	not active 	16
    ENG116969-ENG116507-Leuchte33AMBL 3C36-Lichtfunktion D 33	not active 	16
    ENG116969-ENG116510-Leuchte33AMBL 3C36-Lichtfunktion E 33	not active 	16
    ENG116969-ENG116511-Leuchte33AMBL 3C36-Lichtfunktion F 33	not active 	16
    ENG116969-ENG116514-Leuchte33AMBL 3C36-Lichtfunktion G 33	not active 	16
    ENG116969-ENG116515-Leuchte33AMBL 3C36-Lichtfunktion H 33	not active 	16
    ENG116970-ENG116528-Leuchte34AMBL 4C37-Dimming Direction CD 34	maximize 	16
    ENG116970-ENG116532-Leuchte34AMBL 4C37-Dimming Direction EF 34	maximize 	16
    ENG116970-ENG116536-Leuchte34AMBL 4C37-Dimming Direction GH 34	maximize 	16
    ENG116970-ENG116523-Leuchte34AMBL 4C37-Dimmwert AB 34	0	16
    ENG116970-ENG116527-Leuchte34AMBL 4C37-Dimmwert CD 34	0	16
    ENG116970-ENG116531-Leuchte34AMBL 4C37-Dimmwert EF 34	0	16
    ENG116970-ENG116535-Leuchte34AMBL 4C37-Dimmwert GH 34	0	16
    ENG116970-ENG116520-Leuchte34AMBL 4C37-Fehlerort mittleres Byte DTC-DFCC 34	0	16
    ENG116970-ENG116586-Leuchte34AMBL 4C37-Lampendefektbitposition 34	0	16
    ENG116970-ENG116518-Leuchte34AMBL 4C37-Lasttyp 34	not active 	16
    ENG116970-ENG116524-Leuchte34AMBL 4C37-Lichtansteuerung HD AB 34	Always 	16
    ENG116970-ENG116521-Leuchte34AMBL 4C37-Lichtfunktion A 34	not active 	16
    ENG116970-ENG116522-Leuchte34AMBL 4C37-Lichtfunktion B 34	not active 	16
    ENG116970-ENG116525-Leuchte34AMBL 4C37-Lichtfunktion C 34	not active 	16
    ENG116970-ENG116526-Leuchte34AMBL 4C37-Lichtfunktion D 34	not active 	16
    ENG116970-ENG116529-Leuchte34AMBL 4C37-Lichtfunktion E 34	not active 	16
    ENG116970-ENG116530-Leuchte34AMBL 4C37-Lichtfunktion F 34	not active 	16
    ENG116970-ENG116533-Leuchte34AMBL 4C37-Lichtfunktion G 34	not active 	16
    ENG116970-ENG116534-Leuchte34AMBL 4C37-Lichtfunktion H 34	not active 	16
    ENG116939-ENG115939-Leuchte3SL VRB21-Dimming Direction CD 3	minimize 	16
    ENG116939-ENG115943-Leuchte3SL VRB21-Dimming Direction EF 3	maximize 	16
    ENG116939-ENG115947-Leuchte3SL VRB21-Dimming Direction GH 3	maximize 	16
    ENG116939-ENG115934-Leuchte3SL VRB21-Dimmwert AB 3	100	16
    ENG116939-ENG115938-Leuchte3SL VRB21-Dimmwert CD 3	28	16
    ENG116939-ENG115942-Leuchte3SL VRB21-Dimmwert EF 3	28	16
    ENG116939-ENG115946-Leuchte3SL VRB21-Dimmwert GH 3	0	16
    ENG116939-ENG115931-Leuchte3SL VRB21-Fehlerort mittleres Byte DTC-DFCC 3	4C 	16
    ENG116939-ENG116551-Leuchte3SL VRB21-Lampendefektbitposition 3	4C 	16
    ENG116939-ENG115929-Leuchte3SL VRB21-Lasttyp 3	4 - LED Tagfahrlichtmodul Signal 	16
    ENG116939-ENG115935-Leuchte3SL VRB21-Lichtansteuerung HD AB 3	Always 	16
    ENG116939-ENG115932-Leuchte3SL VRB21-Lichtfunktion A 3	Daytime running lights 	16
    ENG116939-ENG115933-Leuchte3SL VRB21-Lichtfunktion B 3	not active 	16
    ENG116939-ENG115936-Leuchte3SL VRB21-Lichtfunktion C 3	Blinken rechts aktiv (beide Phasen) 	16
    ENG116939-ENG115937-Leuchte3SL VRB21-Lichtfunktion D 3	Nebellicht rechts 	16
    ENG116939-ENG115940-Leuchte3SL VRB21-Lichtfunktion E 3	Standlicht allgemein (Schlusslicht: Positionslicht: Begrenzungslicht) 	16
    ENG116939-ENG116552-Leuchte3SL VRB21-Lichtfunktion F 3	Parking light right 	16
    ENG116939-ENG115944-Leuchte3SL VRB21-Lichtfunktion G 3	not active 	16
    ENG116939-ENG115945-Leuchte3SL VRB21-Lichtfunktion H 3	not active 	16
    ENG116940-ENG115958-Leuchte4TFL LB4-Dimming Direction CD 4	minimize 	16
    ENG116940-ENG115962-Leuchte4TFL LB4-Dimming Direction EF 4	maximize 	16
    ENG116940-ENG115966-Leuchte4TFL LB4-Dimming Direction GH 4	maximize 	16
    ENG116940-ENG115953-Leuchte4TFL LB4-Dimmwert AB 4	127	16
    ENG116940-ENG115957-Leuchte4TFL LB4-Dimmwert CD 4	0	16
    ENG116940-ENG115961-Leuchte4TFL LB4-Dimmwert EF 4	127	16
    ENG116940-ENG115965-Leuchte4TFL LB4-Dimmwert GH 4	0	16
    ENG116940-ENG115950-Leuchte4TFL LB4-Fehlerort mittleres Byte DTC-DFCC 4	49	16
    ENG116940-ENG116553-Leuchte4TFL LB4-Lampendefektbitposition 4	3A 	16
    ENG116940-ENG115948-Leuchte4TFL LB4-Lasttyp 4	1 - LED Tagfahrlichtmodul Versorgung 	16
    ENG116940-ENG115954-Leuchte4TFL LB4-Lichtansteuerung HD AB 4	Always 	16
    ENG116940-ENG115951-Leuchte4TFL LB4-Lichtfunktion A 4	Daytime running lights 	16
    ENG116940-ENG115952-Leuchte4TFL LB4-Lichtfunktion B 4	not active 	16
    ENG116940-ENG115955-Leuchte4TFL LB4-Lichtfunktion C 4	Blinken links aktiv (beide Phasen) 	16
    ENG116940-ENG115956-Leuchte4TFL LB4-Lichtfunktion D 4	not active 	16
    ENG116940-ENG115959-Leuchte4TFL LB4-Lichtfunktion E 4	Standlicht allgemein (Schlusslicht: Positionslicht: Begrenzungslicht) 	16
    ENG116940-ENG115960-Leuchte4TFL LB4-Lichtfunktion F 4	Parklicht links (beidseitiges Parklicht aktiviert li & re) 	16
    ENG116940-ENG115963-Leuchte4TFL LB4-Lichtfunktion G 4	not active 	16
    ENG116940-ENG115964-Leuchte4TFL LB4-Lichtfunktion H 4	not active 	16
    ENG116941-ENG115977-Leuchte5 TFL RB32-Dimming Direction CD 5	minimize 	16
    ENG116941-ENG115981-Leuchte5 TFL RB32-Dimming Direction EF 5	maximize 	16
    ENG116941-ENG115985-Leuchte5 TFL RB32-Dimming Direction GH 5	maximize 	16
    ENG116941-ENG115972-Leuchte5 TFL RB32-Dimmwert AB 5	127	16
    ENG116941-ENG115976-Leuchte5 TFL RB32-Dimmwert CD 5	0	16
    ENG116941-ENG115980-Leuchte5 TFL RB32-Dimmwert EF 5	127	16
    ENG116941-ENG115984-Leuchte5 TFL RB32-Dimmwert GH 5	0	16
    ENG116941-ENG115969-Leuchte5 TFL RB32-Fehlerort mittleres Byte DTC-DFCC 5	4B 	16
    ENG116941-ENG116554-Leuchte5 TFL RB32-Lampendefektbitposition 5	44	16
    ENG116941-ENG115967-Leuchte5 TFL RB32-Lasttyp 5	1 - LED Tagfahrlichtmodul Versorgung 	16
    ENG116941-ENG115973-Leuchte5 TFL RB32-Lichtansteuerung HD AB 5	Always 	16
    ENG116941-ENG115970-Leuchte5 TFL RB32-Lichtfunktion A 5	Daytime running lights 	16
    ENG116941-ENG115971-Leuchte5 TFL RB32-Lichtfunktion B 5	not active 	16
    ENG116941-ENG115974-Leuchte5 TFL RB32-Lichtfunktion C 5	Blinken rechts aktiv (beide Phasen) 	16
    ENG116941-ENG115975-Leuchte5 TFL RB32-Lichtfunktion D 5	not active 	16
    ENG116941-ENG115978-Leuchte5 TFL RB32-Lichtfunktion E 5	Standlicht allgemein (Schlusslicht: Positionslicht: Begrenzungslicht) 	16
    ENG116941-ENG116555-Leuchte5 TFL RB32-Lichtfunktion F 5	Parking light right 	16
    ENG116941-ENG115982-Leuchte5 TFL RB32-Lichtfunktion G 5	not active 	16
    ENG116941-ENG115983-Leuchte5 TFL RB32-Lichtfunktion H 5	not active 	16
    ENG116942-ENG115996-Leuchte6ABL LC5-Dimming Direction CD 6	maximize 	16
    ENG116942-ENG116000-Leuchte6ABL LC5-Dimming Direction EF 6	maximize 	16
    ENG116942-ENG116004-Leuchte6ABL LC5-Dimming Direction GH 6	maximize 	16
    ENG116942-ENG115991-Leuchte6ABL LC5-Dimmwert AB 6	100	16
    ENG116942-ENG115995-Leuchte6ABL LC5-Dimmwert CD 6	0	16
    ENG116942-ENG115999-Leuchte6ABL LC5-Dimmwert EF 6	0	16
    ENG116942-ENG116003-Leuchte6ABL LC5-Dimmwert GH 6	0	16
    ENG116942-ENG115988-Leuchte6ABL LC5-Fehlerort mittleres Byte DTC-DFCC 6	1A 	16
    ENG116942-ENG116556-Leuchte6ABL LC5-Lampendefektbitposition 6	36	16
    ENG116942-ENG115986-Leuchte6ABL LC5-Lasttyp 6	11 - Abblendlicht 	16
    ENG116942-ENG115992-Leuchte6ABL LC5-Lichtansteuerung HD AB 6	Always 	16
    ENG116942-ENG115989-Leuchte6ABL LC5-Lichtfunktion A 6	Abblendlicht links 	16
    ENG116942-ENG115990-Leuchte6ABL LC5-Lichtfunktion B 6	not active 	16
    ENG116942-ENG115993-Leuchte6ABL LC5-Lichtfunktion C 6	not active 	16
    ENG116942-ENG115994-Leuchte6ABL LC5-Lichtfunktion D 6	not active 	16
    ENG116942-ENG115997-Leuchte6ABL LC5-Lichtfunktion E 6	not active 	16
    ENG116942-ENG115998-Leuchte6ABL LC5-Lichtfunktion F 6	not active 	16
    ENG116942-ENG116001-Leuchte6ABL LC5-Lichtfunktion G 6	not active 	16
    ENG116942-ENG116002-Leuchte6ABL LC5-Lichtfunktion H 6	not active 	16
    ENG116943-ENG116015-Leuchte7ABL RB1-Dimming Direction CD 7	maximize 	16
    ENG116943-ENG116019-Leuchte7ABL RB1-Dimming Direction EF 7	maximize 	16
    ENG116943-ENG116023-Leuchte7ABL RB1-Dimming Direction GH 7	maximize 	16
    ENG116943-ENG116010-Leuchte7ABL RB1-Dimmwert AB 7	100	16
    ENG116943-ENG116014-Leuchte7ABL RB1-Dimmwert CD 7	0	16
    ENG116943-ENG116018-Leuchte7ABL RB1-Dimmwert EF 7	0	16
    ENG116943-ENG116022-Leuchte7ABL RB1-Dimmwert GH 7	0	16
    ENG116943-ENG116007-Leuchte7ABL RB1-Fehlerort mittleres Byte DTC-DFCC 7	1B 	16
    ENG116943-ENG116557-Leuchte7ABL RB1-Lampendefektbitposition 7	40	16
    ENG116943-ENG116005-Leuchte7ABL RB1-Lasttyp 7	11 - Abblendlicht 	16
    ENG116943-ENG116011-Leuchte7ABL RB1-Lichtansteuerung HD AB 7	Always 	16
    ENG116943-ENG116008-Leuchte7ABL RB1-Lichtfunktion A 7	Abblendlicht rechts 	16
    ENG116943-ENG116009-Leuchte7ABL RB1-Lichtfunktion B 7	not active 	16
    ENG116943-ENG116012-Leuchte7ABL RB1-Lichtfunktion C 7	not active 	16
    ENG116943-ENG116013-Leuchte7ABL RB1-Lichtfunktion D 7	not active 	16
    ENG116943-ENG116016-Leuchte7ABL RB1-Lichtfunktion E 7	not active 	16
    ENG116943-ENG116017-Leuchte7ABL RB1-Lichtfunktion F 7	not active 	16
    ENG116943-ENG116020-Leuchte7ABL RB1-Lichtfunktion G 7	not active 	16
    ENG116943-ENG116021-Leuchte7ABL RB1-Lichtfunktion H 7	not active 	16
    ENG116944-ENG116034-Leuchte8FL LB39-Dimming Direction CD 8	maximize 	16
    ENG116944-ENG116038-Leuchte8FL LB39-Dimming Direction EF 8	maximize 	16
    ENG116944-ENG116042-Leuchte8FL LB39-Dimming Direction GH 8	maximize 	16
    ENG116944-ENG116029-Leuchte8FL LB39-Dimmwert AB 8	100	16
    ENG116944-ENG116033-Leuchte8FL LB39-Dimmwert CD 8	0	16
    ENG116944-ENG116037-Leuchte8FL LB39-Dimmwert EF 8	0	16
    ENG116944-ENG116041-Leuchte8FL LB39-Dimmwert GH 8	0	16
    ENG116944-ENG116026-Leuchte8FL LB39-Fehlerort mittleres Byte DTC-DFCC 8	1C 	16
    ENG116944-ENG116558-Leuchte8FL LB39-Lampendefektbitposition 8	37	16
    ENG116944-ENG116024-Leuchte8FL LB39-Lasttyp 8	10 - allgemeine Scheinwerfer 	16
    ENG116944-ENG116030-Leuchte8FL LB39-Lichtansteuerung HD AB 8	Always 	16
    ENG116944-ENG116027-Leuchte8FL LB39-Lichtfunktion A 8	Left high beam 	16
    ENG116944-ENG116028-Leuchte8FL LB39-Lichtfunktion B 8	Lichthupe generell 	16
    ENG116944-ENG116031-Leuchte8FL LB39-Lichtfunktion C 8	not active 	16
    ENG116944-ENG116032-Leuchte8FL LB39-Lichtfunktion D 8	not active 	16
    ENG116944-ENG116035-Leuchte8FL LB39-Lichtfunktion E 8	not active 	16
    ENG116944-ENG116036-Leuchte8FL LB39-Lichtfunktion F 8	not active 	16
    ENG116944-ENG116039-Leuchte8FL LB39-Lichtfunktion G 8	not active 	16
    ENG116944-ENG116040-Leuchte8FL LB39-Lichtfunktion H 8	not active 	16
    ENG116945-ENG116053-Leuchte9FL RB2-Dimming Direction CD 9	maximize 	16
    ENG116945-ENG116057-Leuchte9FL RB2-Dimming Direction EF 9	maximize 	16
    ENG116945-ENG116061-Leuchte9FL RB2-Dimming Direction GH 9	maximize 	16
    ENG116945-ENG116048-Leuchte9FL RB2-Dimmwert AB 9	100	16
    ENG116945-ENG116052-Leuchte9FL RB2-Dimmwert CD 9	0	16
    ENG116945-ENG116056-Leuchte9FL RB2-Dimmwert EF 9	0	16
    ENG116945-ENG116060-Leuchte9FL RB2-Dimmwert GH 9	0	16
    ENG116945-ENG116045-Leuchte9FL RB2-Fehlerort mittleres Byte DTC-DFCC 9	1D 	16
    ENG116945-ENG116559-Leuchte9FL RB2-Lampendefektbitposition 9	41	16
    ENG116945-ENG116043-Leuchte9FL RB2-Lasttyp 9	10 - allgemeine Scheinwerfer 	16
    ENG116945-ENG116049-Leuchte9FL RB2-Lichtansteuerung HD AB 9	Always 	16
    ENG116945-ENG116046-Leuchte9FL RB2-Lichtfunktion A 9	Right high beam 	16
    ENG116945-ENG116047-Leuchte9FL RB2-Lichtfunktion B 9	Lichthupe generell 	16
    ENG116945-ENG116050-Leuchte9FL RB2-Lichtfunktion C 9	not active 	16
    ENG116945-ENG116051-Leuchte9FL RB2-Lichtfunktion D 9	not active 	16
    ENG116945-ENG116054-Leuchte9FL RB2-Lichtfunktion E 9	not active 	16
    ENG116945-ENG116055-Leuchte9FL RB2-Lichtfunktion F 9	not active 	16
    ENG116945-ENG116058-Leuchte9FL RB2-Lichtfunktion G 9	not active 	16
    ENG116945-ENG116059-Leuchte9FL RB2-Lichtfunktion H 9	not active 	16
    ENG141661-Leuchtenkonfiguration_Aussenlich_Heck	00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 2B 13 00 3D 18 02 64 03 00 80 00 00 00 00 00 00 2B 23 00 3E 18 04 64 05 00 80 00 00 00 00 00 00 2A 29 00 2C 18 24 7F 00 00 00 00 00 00 00 00 00 2B 0A 00 29 08 00 7F 00 00 00 00 00 00 00 00 00 2B 1A 00 2A 08 00 7F 00 00 00 00 00 00 00 00 00 2B 28 00 30 08 00 7F 00 00 00 00 00 00 00 00 00 2B 00 00 54 08 00 7F 00 00 00 00 00 00 00 00 00 2B 00 00 53 08 00 7F 00 00 00 00 00 00 00 00 00 2B 0B 00 31 19 00 7F 00 00 00 00 00 00 00 00 00 2B 1B 00 32 19 00 7F 00 00 00 00 00 00 00 00 00 	192
    ENG141662-Leuchtenkonfiguration_Sonstiges	2B 00 00 36 08 00 FF 00 00 00 00 00 00 00 00 00 2B 00 00 35 08 00 FF 00 00 00 00 00 00 00 00 00 24 00 00 02 2B 00 59 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 29 00 00 63 4C 00 64 00 00 00 00 00 00 00 00 00 	128
    ENG141658-ENG142197-Leuchtweitenregulierung-1_Sensor_LWR	1-Sensor_LWR 	62
    ENG141658-ENG142219-Leuchtweitenregulierung-Achsabstand_des_Fahrzeuges	0 mm	62
    ENG141658-ENG142201-Leuchtweitenregulierung-Aktivierung_LWR_Fehlerlampe	not active 	62
    ENG141658-ENG142211-Leuchtweitenregulierung-Ansteuerung_obere_grenze	100.00%	62
    ENG141658-ENG142210-Leuchtweitenregulierung-Ansteuerung_untere_grenze	0.00%	62
    ENG141658-ENG154591-Leuchtweitenregulierung-Delay_DC_Motor_Versorgung	-101.5 ms	62
    ENG141658-ENG142209-Leuchtweitenregulierung-diagnose_soll_toleranz	15%	62
    ENG141658-ENG142203-Leuchtweitenregulierung-Entprellung_Fehlerlampe	10.0 s	62
    ENG141658-ENG142214-Leuchtweitenregulierung-fac_Pwm_Zu_Hoehe_H_1	-8.00 mm/%	62
    ENG141658-ENG142216-Leuchtweitenregulierung-fac_Pwm_Zu_Hoehe_H_2	-8.00 mm/%	62
    ENG141658-ENG154599-Leuchtweitenregulierung-fac_Pwm_Zu_Hoehe_H_3	-8.00 mm/%	62
    ENG141658-ENG142213-Leuchtweitenregulierung-fac_Pwm_Zu_Hoehe_V_1	-8.00 mm/%	62
    ENG141658-ENG142215-Leuchtweitenregulierung-fac_Pwm_Zu_Hoehe_V_2	-8.00 mm/%	62
    ENG141658-ENG154600-Leuchtweitenregulierung-fac_Pwm_Zu_Hoehe_V_3	-8.00 mm/%	62
    ENG141658-ENG142198-Leuchtweitenregulierung-Fahrwerk_Variante	Variante_1 	62
    ENG141658-ENG142204-Leuchtweitenregulierung-Fail_Safe_sLWR	0.00%	62
    ENG141658-ENG142223-Leuchtweitenregulierung-fFiltEinf	0.00 Hz	62
    ENG141658-ENG142212-Leuchtweitenregulierung-Lineare_Abbildung	normal 	62
    ENG141658-ENG142202-Leuchtweitenregulierung-Logik_PWM_Signal	Negative 	62
    ENG141658-ENG154702-Leuchtweitenregulierung-lwr_lEinfOffsHFahrw_1	0 mm	62
    ENG141658-ENG154703-Leuchtweitenregulierung-lwr_lEinfOffsHFahrw_2	0 mm	62
    ENG141658-ENG154704-Leuchtweitenregulierung-lwr_lEinfOffsHFahrw_3	0 mm	62
    ENG141658-ENG154705-Leuchtweitenregulierung-lwr_lEinfOffsHFahrw_4	0 mm	62
    ENG141658-ENG142220-Leuchtweitenregulierung-lwr_lFzg_Sw_Abstand	0 mm	62
    ENG141658-ENG142221-Leuchtweitenregulierung-lwr_lFzg_Sw_Hoehe	0 mm	62
    ENG141658-ENG142226-Leuchtweitenregulierung-lwr_pwm_obere_schwelle	95.00%	62
    ENG141658-ENG142225-Leuchtweitenregulierung-lwr_pwm_untere_schwelle	2.50%	62
    ENG141658-ENG142227-Leuchtweitenregulierung-max_v_slwr	0 km/h	62
    ENG141658-ENG142222-Leuchtweitenregulierung-pa_fDynFiltStatLwr	100 Hz	62
    ENG141658-ENG142224-Leuchtweitenregulierung-pa_fFiltSwNeigung	0.00 Hz	62
    ENG141658-ENG142200-Leuchtweitenregulierung-Quelle_Hoehenwerte	BCM 	62
    ENG141658-ENG142042-Leuchtweitenregulierung-sensor_headlight_range_control_installed	not installed 	62
    ENG141658-ENG142199-Leuchtweitenregulierung-sLWR_bei_Abblendlicht	active 	62
    ENG141658-ENG142208-Leuchtweitenregulierung-sLWR_Hysterese	1.00%	62
    ENG141658-ENG154776-Leuchtweitenregulierung-sLWR_nach_Motorstart	not active 	62
    ENG141658-ENG142207-Leuchtweitenregulierung-sLWR_SW_Grad	10.0 %/s	62
    ENG141658-ENG142206-Leuchtweitenregulierung-sLWR_Touristenlicht	-100.00%	62
    ENG141658-ENG142196-Leuchtweitenregulierung-sLWR_verbaut	not installed 	62
    ENG141658-ENG142205-Leuchtweitenregulierung-Zyklus_sLWR	1.00 s	62
    ENG126648-MAS10452-LIN-Mirrormode-Data bus LIN 1	not active 	1
    ENG126648-MAS10453-LIN-Mirrormode-Data bus LIN 2	not active 	1
    ENG126648-MAS10454-LIN-Mirrormode-Data bus LIN 3	not active 	1
    ENG126648-MAS12782-LIN-Mirrormode-Data bus LIN 4	not active 	1
    ENG126648-MAS12783-LIN-Mirrormode-Data bus LIN 5	not active 	1
    ENG126648-MAS12784-LIN-Mirrormode-Data bus LIN 6	not active 	1
    ENG126648-ENG118465-LIN-Mirrormode-mirror_mode_typ	not active 	1
    ENG117284-ENG115658-LuB Lichtrouter Kennlinie 1-x0	0.00%	12
    ENG117284-ENG101574-LuB Lichtrouter Kennlinie 1-X1	5.00%	12
    ENG117284-ENG99557-LuB Lichtrouter Kennlinie 1-X2	50.00%	12
    ENG117284-ENG102140-LuB Lichtrouter Kennlinie 1-X3	75.00%	12
    ENG117284-ENG102936-LuB Lichtrouter Kennlinie 1-X4	110	12
    ENG117284-ENG103548-LuB Lichtrouter Kennlinie 1-X5	126.5	12
    ENG117284-ENG115659-LuB Lichtrouter Kennlinie 1-y0	0.00%	12
    ENG117284-ENG99777-LuB Lichtrouter Kennlinie 1-Y1	6.00%	12
    ENG117284-ENG100480-LuB Lichtrouter Kennlinie 1-Y2	16.00%	12
    ENG117284-ENG100773-LuB Lichtrouter Kennlinie 1-Y3	30.00%	12
    ENG117284-ENG100631-LuB Lichtrouter Kennlinie 1-Y4	60.00%	12
    ENG117284-ENG102174-LuB Lichtrouter Kennlinie 1-Y5	100.00%	12
    ENG141659-ENG115658-lwr_ofs_RSw_Ah1S-x0	-5.00%	20
    ENG141659-ENG101574-lwr_ofs_RSw_Ah1S-X1	-5.00%	20
    ENG141659-ENG99557-lwr_ofs_RSw_Ah1S-X2	-5.00%	20
    ENG141659-ENG102140-lwr_ofs_RSw_Ah1S-X3	-5.00%	20
    ENG141659-ENG102936-lwr_ofs_RSw_Ah1S-X4	-5.00%	20
    ENG141659-ENG115659-lwr_ofs_RSw_Ah1S-y0	-5	20
    ENG141659-ENG99777-lwr_ofs_RSw_Ah1S-Y1	-5	20
    ENG141659-ENG100480-lwr_ofs_RSw_Ah1S-Y2	-5	20
    ENG141659-ENG100773-lwr_ofs_RSw_Ah1S-Y3	-5	20
    ENG141659-ENG100631-lwr_ofs_RSw_Ah1S-Y4	-5	20
    ENG122979-ENG141954-Networking-A/C electronics	installed 	8
    ENG122979-ENG141968-Networking-Anhaengeranschlussgeraet	not installed 	8
    ENG122979-ENG141974-Networking-Bremsen_Steuergeraet	installed 	8
    ENG122979-ENG141953-Networking-Getriebesteuergeraet	installed 	8
    ENG122979-ENG99457-Networking-Head area heater	not installed 	8
    ENG122979-ENG142040-Networking-Kunden_spezifisches_Funktions_SG	not installed 	8
    ENG122979-ENG141969-Networking-UGDO	not installed 	8
    ENG124714-ENG142044-OCU-DWA_push	not active 	8
    ENG124714-ENG142260-OCU-Honk DWA_Ausgabe_Fanfare	not active 	8
    ENG124714-OCU-	not installed 	8
    ENG124714-ENG142261-OCU-Remote HuF Abbruch	20 km/h	8
    ENG124714-ENG142262-OCU-Remote HuF Hupfrequenz	3 Hz	8
    ENG124714-ENG133391-OCU-Remote Lock Unlock Timer s1	80 s	8
    ENG124714-ENG133392-OCU-Remote Lock Unlock Timer s3	2000 ms	8
    ENG124714-ENG125657-OCU-Remote_Unlock_Lock	not_active 	8
    ENG98831-ENG126849-Personalization-Aktivierungsoption_im_HMI-Menue_sichtbar	active 	16
    ENG98831-ENG133401-Personalization-Anzahl_Benutzerkonten	4	16
    ENG98831-ENG133402-Personalization-Automatische_ Schluesselzuordnung	not active 	16
    ENG98831-ENG126850-Personalization-Benutzerkontenverwaltung_in_HMI-Menue_sichtbar	active 	16
    ENG98831-ENG126848-Personalization-Personalisierung_aktiv	active 	16
    ENG98831-ENG141994-Personalization-Personalisierung_Profilfunkion	profiles_active 	16
    ENG98831-ENG126851-Personalization-Personalisierungsfunktionen_in_HMI-Menue_sichtbar	active 	16
    ENG98831-ENG142030-Personalization-Profil_Variante	Konto (v. 1.x) 	16
    ENG98831-ENG133404-Personalization-PSO_FSG_Setup2_Bit_1	active 	16
    ENG98831-ENG133405-Personalization-PSO_FSG_Setup2_Bit_2	active 	16
    ENG98831-ENG133406-Personalization-PSO_FSG_Setup2_Bit_3	not active 	16
    ENG98831-ENG133407-Personalization-PSO_FSG_Setup2_Bit_4	not active 	16
    ENG141646-MAS01065-Querschnitts_funktionen-Brand	VW 	5
    ENG141646-ENG141980-Querschnitts_funktionen-Bedien_und_Anzeigeprotokoll	active 	5
    ENG141646-ENG116624-Querschnitts_funktionen-CAN Wecken bei Softtouchbetaetigung	not active 	5
    ENG141646-ENG141967-Querschnitts_funktionen-Codierungsabsicherung	not active 	5
    ENG141646-ENG142028-Querschnitts_funktionen-Fahrgeschwindigkeit_aus_ESP_21	active 	5
    ENG141646-ENG142187-Querschnitts_funktionen-Hardware_Eingang_Drucktankklappenstatus	Pin A31 	5
    ENG141646-ENG154685-Querschnitts_funktionen-Hupe	Sollspannungsanforderung 13.5 	5
    ENG141646-ENG115810-Querschnitts_funktionen-Klemmenfehler auf CAN ausgeben	active 	5
    ENG141646-ENG142015-Querschnitts_funktionen-Personalisierungsuebernahme	not_installed 	5
    ENG141646-ENG141983-Querschnitts_funktionen-Schnittstelle_TrackingSystem	not active 	5
    ENG141646-ENG141964-Querschnitts_funktionen-Steering alignment	Left 	5
    ENG141646-ENG141965-Querschnitts_funktionen-Traffic side	Right 	5
    ENG115729-ENG116609-Scheinwerferreinigung-Anzahl Betaetigungen Frontwaschanlage pro SRA Aktivierung	0	10
    ENG115729-ENG141949-Scheinwerferreinigung-Headlamp washer system	not installed 	10
    ENG115729-ENG115769-Scheinwerferreinigung-SRA bei Waschwassermangel	not active 	10
    ENG115729-ENG115767-Scheinwerferreinigung-SRA Einweichpausenzeit	0 ms	10
    ENG115729-ENG115768-Scheinwerferreinigung-SRA Nachwaschzeit	0 ms	10
    ENG115729-ENG116611-Scheinwerferreinigung-SRA Pausenzeit	0 ms	10
    ENG115729-ENG116610-Scheinwerferreinigung-SRA Verzoegerungszeit	0 ms	10
    ENG115729-ENG115766-Scheinwerferreinigung-SRA Waschzeit	0 ms	10
    ENG115729-ENG154424-Scheinwerferreinigung-Waschen	Keine_Spannungsanforderung 	10
    ENG141684-SFT271873-Slave_systems_identification-Control Unit For Wiper Motor	Not available 	6
    ENG141684-SFT271874-Slave_systems_identification-Rain Light Recognition Sensor	Not available 	6
    ENG141684-SFT271875-Slave_systems_identification-Light switch	Not available 	6
    ENG141684-SFT271876-Slave_systems_identification-Garage door opener control module	Not available 	6
    ENG141684-SFT271877-Slave_systems_identification-Garage Door Opener Operating Unit	Not available 	6
    ENG141684-SFT271894-Slave_systems_identification-Sensor For Anti Theft Alarm System	Not available 	6
    ENG141684-SFT271896-Slave_systems_identification-Alarm horn	Not available 	6
    ENG141684-SFT271904-Slave_systems_identification-Sun Roof	Not available 	6
    ENG141684-SFT271910-Slave_systems_identification-Ceiling Light Module	Not available 	6
    ENG141684-SFT271928-Slave_systems_identification-Roof Blind	Not available 	6
    ENG141684-SFT271947-Slave_systems_identification-Relative Air Humidity Interior Sender	Not available 	6
    ENG141684-SFT271966-Slave_systems_identification-Neck Heating Left	Not available 	6
    ENG141684-SFT271967-Slave_systems_identification-Neck Heating Right	Not available 	6
    ENG141684-SFT272065-Slave_systems_identification-Seat Backrest Fan 1 Front Left	Not available 	6
    ENG141684-SFT272067-Slave_systems_identification-Seat Cushion Fan 1 Front Left	Not available 	6
    ENG141684-SFT272069-Slave_systems_identification-Seat Backrest Fan 1 Front Right	Not available 	6
    ENG141684-SFT272071-Slave_systems_identification-Seat Cushion Fan 1 Front Right	Not available 	6
    ENG116588-ENG116589-Sonderfunktionen-Signalprioritaet fuer Blinker	MFG 	4
    ENG116588-Sonderfunktionen-	not enabled 	4
    ENG116588-ENG141979-Sonderfunktionen-Sonderfunktionen 1	not installed 	4
    ENG141635-ENG116658-Spiegelverstellung-Funk Spiegelanklappen	not active 	5
    ENG141635-ENG116665-Spiegelverstellung-Funk Spiegelanklappung Modus	by convenience operation via remote control key 	5
    ENG141635-ENG116660-Spiegelverstellung-Menuesteuerung Funk Spiegel anklappen	not active 	5
    ENG141635-ENG116657-Spiegelverstellung-Menuesteuerung Spiegelabsenkung	not active 	5
    ENG141635-ENG116659-Spiegelverstellung-Menuesteuerung synchrone Spiegelverstellung	not active 	5
    ENG141635-ENG126841-Spiegelverstellung-Profilfunktion fuer Anklappung der Aussenspiegel	active 	5
    ENG141635-ENG126610-Spiegelverstellung-Signalisierung_Spiegelanklappung	active 	5
    ENG141635-ENG116650-Spiegelverstellung-Spiegelabsenkung bei Rueckwaertsfahrt	not active 	5
    ENG141635-ENG133411-Spiegelverstellung-Spiegelanklappen_bei_Wiederverriegelung	not active 	5
    ENG141635-ENG116656-Spiegelverstellung-Spiegelverstellung Synchron	not active 	5
    ENG153700-ENG154515-Steering Column Switch-Anzahl_fehler_P-verriegelt	25	10
    ENG153700-ENG154621-Steering Column Switch-Geschwindigkeitesschwele_erkennung_fahrt_P_plausibel	10 km/h	10
    ENG153700-ENG154803-Steering Column Switch-Verbauort_Lenkstockschalter	CAN 	10
    ENG153700-ENG154828-Steering Column Switch-Zeit_erkennung_fahrt_für_P_plausibel	10.0 min	10
    ENG153700-ENG154829-Steering Column Switch-Zeit_t_P-verriegelt_entprellen	40 ms	10
    ENG141678-ENG115658-Suchbeleuchtung_58_xs_Bus_Kennlinie-x0	0.0 lx	10
    ENG141678-ENG101574-Suchbeleuchtung_58_xs_Bus_Kennlinie-X1	8.0 lx	10
    ENG141678-ENG99557-Suchbeleuchtung_58_xs_Bus_Kennlinie-X2	50.0 lx	10
    ENG141678-ENG102140-Suchbeleuchtung_58_xs_Bus_Kennlinie-X3	80.0 lx	10
    ENG141678-ENG102936-Suchbeleuchtung_58_xs_Bus_Kennlinie-X4	100.0 lx	10
    ENG141678-ENG115659-Suchbeleuchtung_58_xs_Bus_Kennlinie-y0	6	10
    ENG141678-ENG99777-Suchbeleuchtung_58_xs_Bus_Kennlinie-Y1	6	10
    ENG141678-ENG100480-Suchbeleuchtung_58_xs_Bus_Kennlinie-Y2	20	10
    ENG141678-ENG100773-Suchbeleuchtung_58_xs_Bus_Kennlinie-Y3	50	10
    ENG141678-ENG100631-Suchbeleuchtung_58_xs_Bus_Kennlinie-Y4	100	10
    ENG141679-ENG115658-Suchbeleuchtung_58xt_Bus_Kennlinie-x0	0.0 lx	10
    ENG141679-ENG101574-Suchbeleuchtung_58xt_Bus_Kennlinie-X1	8.0 lx	10
    ENG141679-ENG99557-Suchbeleuchtung_58xt_Bus_Kennlinie-X2	50.0 lx	10
    ENG141679-ENG102140-Suchbeleuchtung_58xt_Bus_Kennlinie-X3	80.0 lx	10
    ENG141679-ENG102936-Suchbeleuchtung_58xt_Bus_Kennlinie-X4	100.0 lx	10
    ENG141679-ENG115659-Suchbeleuchtung_58xt_Bus_Kennlinie-y0	6	10
    ENG141679-ENG99777-Suchbeleuchtung_58xt_Bus_Kennlinie-Y1	6	10
    ENG141679-ENG100480-Suchbeleuchtung_58xt_Bus_Kennlinie-Y2	20	10
    ENG141679-ENG100773-Suchbeleuchtung_58xt_Bus_Kennlinie-Y3	50	10
    ENG141679-ENG100631-Suchbeleuchtung_58xt_Bus_Kennlinie-Y4	100	10
    ENG141666-ENG115658-Suchbeleuchtung_Abdimmen-x0	0 ms	22
    ENG141666-ENG101574-Suchbeleuchtung_Abdimmen-X1	200 ms	22
    ENG141666-ENG115664-Suchbeleuchtung_Abdimmen-x10	2000 ms	22
    ENG141666-ENG99557-Suchbeleuchtung_Abdimmen-X2	400 ms	22
    ENG141666-ENG102140-Suchbeleuchtung_Abdimmen-X3	600 ms	22
    ENG141666-ENG102936-Suchbeleuchtung_Abdimmen-X4	800 ms	22
    ENG141666-ENG103548-Suchbeleuchtung_Abdimmen-X5	1000 ms	22
    ENG141666-ENG113992-Suchbeleuchtung_Abdimmen-X6	1200 ms	22
    ENG141666-ENG115661-Suchbeleuchtung_Abdimmen-x7	1400 ms	22
    ENG141666-ENG115662-Suchbeleuchtung_Abdimmen-x8	1600 ms	22
    ENG141666-ENG115663-Suchbeleuchtung_Abdimmen-x9	1800 ms	22
    ENG141666-ENG115659-Suchbeleuchtung_Abdimmen-y0	100.00%	22
    ENG141666-ENG99777-Suchbeleuchtung_Abdimmen-Y1	100.00%	22
    ENG141666-ENG115668-Suchbeleuchtung_Abdimmen-y10	0.00%	22
    ENG141666-ENG100480-Suchbeleuchtung_Abdimmen-Y2	95.00%	22
    ENG141666-ENG100773-Suchbeleuchtung_Abdimmen-Y3	80.00%	22
    ENG141666-ENG100631-Suchbeleuchtung_Abdimmen-Y4	40.00%	22
    ENG141666-ENG102174-Suchbeleuchtung_Abdimmen-Y5	20.00%	22
    ENG141666-ENG113993-Suchbeleuchtung_Abdimmen-Y6	10.00%	22
    ENG141666-ENG115665-Suchbeleuchtung_Abdimmen-y7	5.00%	22
    ENG141666-ENG115666-Suchbeleuchtung_Abdimmen-y8	3.00%	22
    ENG141666-ENG115667-Suchbeleuchtung_Abdimmen-y9	1.00%	22
    ENG141663-ENG142240-Suchbeleuchtung_allgemein-Daempfung Abdimmen KL 58xd PWM	0.00 s	21
    ENG141663-ENG154582-Suchbeleuchtung_allgemein-Daempfung_Abdimmen_KL_58xs_PWM	0.00 s	21
    ENG141663-ENG154583-Suchbeleuchtung_allgemein-Daempfung_Abdimmen_KL_58xt_PWM	0.00 s	21
    ENG141663-ENG154584-Suchbeleuchtung_allgemein-Daempfung_Aufdimmen_KL_58xd_PWM	0.00 s	21
    ENG141663-ENG154585-Suchbeleuchtung_allgemein-Daempfung_Aufdimmen_KL_58xt_PWM	0.00 s	21
    ENG141663-ENG141988-Suchbeleuchtung_allgemein-Eingabemedium_Suchbeleuchtung	Potentiometer 	21
    ENG141663-ENG142242-Suchbeleuchtung_allgemein-Helligkeit_RLS_Daempfung_Abdimmen	20.0 s	21
    ENG141663-ENG142241-Suchbeleuchtung_allgemein-Helligkeit_RLS_Daempfung_Aufdimmen	3.0 s	21
    ENG141663-ENG116598-Suchbeleuchtung_allgemein-KL58 Einschalten mit Rampe	not active 	21
    ENG141663-ENG116599-Suchbeleuchtung_allgemein-KL58 Verriegelungsausschalten	not_active 	21
    ENG141663-ENG116600-Suchbeleuchtung_allgemein-Lichtsensor wirkt auf Suchbeleuchtung	active 	21
    ENG141663-ENG142243-Suchbeleuchtung_allgemein-pa_Hysterese_RLS	2	21
    ENG141663-ENG154712-Suchbeleuchtung_allgemein-PWM_Daempfung_Aufdimmen_KL58xs_PWM	0.00 s	21
    ENG141663-ENG115631-Suchbeleuchtung_allgemein-Suchbeleuchtung Festwert	100%	21
    ENG141663-ENG142234-Suchbeleuchtung_allgemein-Umgebungs_helligkeit_auswahl	Fotosensor_Kombi 	21
    ENG141663-ENG115819-Suchbeleuchtung_allgemein-Warnblinktastersuchbeleuchtung Aktivierung	Always active 	21
    ENG141663-ENG115821-Suchbeleuchtung_allgemein-Warnblinktastersuchbeleuchtung Faktor	0.1	21
    ENG141663-ENG115820-Suchbeleuchtung_allgemein-Warnblinktastersuchbeleuchtung Grundwert	10.00%	21
    ENG141667-ENG115658-Suchbeleuchtung_Fotosensor-x0	0	22
    ENG141667-ENG101574-Suchbeleuchtung_Fotosensor-X1	50	22
    ENG141667-ENG115664-Suchbeleuchtung_Fotosensor-x10	0	22
    ENG141667-ENG99557-Suchbeleuchtung_Fotosensor-X2	100	22
    ENG141667-ENG102140-Suchbeleuchtung_Fotosensor-X3	200	22
    ENG141667-ENG102936-Suchbeleuchtung_Fotosensor-X4	253	22
    ENG141667-ENG103548-Suchbeleuchtung_Fotosensor-X5	0	22
    ENG141667-ENG113992-Suchbeleuchtung_Fotosensor-X6	0	22
    ENG141667-ENG115661-Suchbeleuchtung_Fotosensor-x7	0	22
    ENG141667-ENG115662-Suchbeleuchtung_Fotosensor-x8	0	22
    ENG141667-ENG115663-Suchbeleuchtung_Fotosensor-x9	0	22
    ENG141667-ENG115659-Suchbeleuchtung_Fotosensor-y0	0 lx	22
    ENG141667-ENG99777-Suchbeleuchtung_Fotosensor-Y1	50 lx	22
    ENG141667-ENG115668-Suchbeleuchtung_Fotosensor-y10	0 lx	22
    ENG141667-ENG100480-Suchbeleuchtung_Fotosensor-Y2	100 lx	22
    ENG141667-ENG100773-Suchbeleuchtung_Fotosensor-Y3	200	22
    ENG141667-ENG100631-Suchbeleuchtung_Fotosensor-Y4	500	22
    ENG141667-ENG102174-Suchbeleuchtung_Fotosensor-Y5	0	22
    ENG141667-ENG113993-Suchbeleuchtung_Fotosensor-Y6	0 lx	22
    ENG141667-ENG115665-Suchbeleuchtung_Fotosensor-y7	0 lx	22
    ENG141667-ENG115666-Suchbeleuchtung_Fotosensor-y8	0 lx	22
    ENG141667-ENG115667-Suchbeleuchtung_Fotosensor-y9	0 lx	22
    ENG141665-ENG115658-Suchbeleuchtung_Hochdimmen-x0	0 ms	22
    ENG141665-ENG101574-Suchbeleuchtung_Hochdimmen-X1	200 ms	22
    ENG141665-ENG115664-Suchbeleuchtung_Hochdimmen-x10	2000 ms	22
    ENG141665-ENG99557-Suchbeleuchtung_Hochdimmen-X2	400 ms	22
    ENG141665-ENG102140-Suchbeleuchtung_Hochdimmen-X3	600 ms	22
    ENG141665-ENG102936-Suchbeleuchtung_Hochdimmen-X4	800 ms	22
    ENG141665-ENG103548-Suchbeleuchtung_Hochdimmen-X5	1000 ms	22
    ENG141665-ENG113992-Suchbeleuchtung_Hochdimmen-X6	1200 ms	22
    ENG141665-ENG115661-Suchbeleuchtung_Hochdimmen-x7	1400 ms	22
    ENG141665-ENG115662-Suchbeleuchtung_Hochdimmen-x8	1600 ms	22
    ENG141665-ENG115663-Suchbeleuchtung_Hochdimmen-x9	1800 ms	22
    ENG141665-ENG115659-Suchbeleuchtung_Hochdimmen-y0	0.00%	22
    ENG141665-ENG99777-Suchbeleuchtung_Hochdimmen-Y1	1.00%	22
    ENG141665-ENG115668-Suchbeleuchtung_Hochdimmen-y10	100.00%	22
    ENG141665-ENG100480-Suchbeleuchtung_Hochdimmen-Y2	3.00%	22
    ENG141665-ENG100773-Suchbeleuchtung_Hochdimmen-Y3	5.00%	22
    ENG141665-ENG100631-Suchbeleuchtung_Hochdimmen-Y4	11.00%	22
    ENG141665-ENG102174-Suchbeleuchtung_Hochdimmen-Y5	22.00%	22
    ENG141665-ENG113993-Suchbeleuchtung_Hochdimmen-Y6	40.00%	22
    ENG141665-ENG115665-Suchbeleuchtung_Hochdimmen-y7	80.00%	22
    ENG141665-ENG115666-Suchbeleuchtung_Hochdimmen-y8	95.00%	22
    ENG141665-ENG115667-Suchbeleuchtung_Hochdimmen-y9	100.00%	22
    ENG141669-ENG115658-Suchbeleuchtung_KL 58xs max-x0	0 lx	8
    ENG141669-ENG101574-Suchbeleuchtung_KL 58xs max-X1	8 lx	8
    ENG141669-ENG99557-Suchbeleuchtung_KL 58xs max-X2	50 lx	8
    ENG141669-ENG102140-Suchbeleuchtung_KL 58xs max-X3	500 lx	8
    ENG141669-ENG115659-Suchbeleuchtung_KL 58xs max-y0	100	8
    ENG141669-ENG99777-Suchbeleuchtung_KL 58xs max-Y1	100	8
    ENG141669-ENG100480-Suchbeleuchtung_KL 58xs max-Y2	100	8
    ENG141669-ENG100773-Suchbeleuchtung_KL 58xs max-Y3	100	8
    ENG141668-ENG115658-Suchbeleuchtung_KL 58xs min-x0	0 lx	8
    ENG141668-ENG101574-Suchbeleuchtung_KL 58xs min-X1	8 lx	8
    ENG141668-ENG99557-Suchbeleuchtung_KL 58xs min-X2	50 lx	8
    ENG141668-ENG102140-Suchbeleuchtung_KL 58xs min-X3	500 lx	8
    ENG141668-ENG115659-Suchbeleuchtung_KL 58xs min-y0	6	8
    ENG141668-ENG99777-Suchbeleuchtung_KL 58xs min-Y1	6	8
    ENG141668-ENG100480-Suchbeleuchtung_KL 58xs min-Y2	100	8
    ENG141668-ENG100773-Suchbeleuchtung_KL 58xs min-Y3	100	8
    ENG141674-ENG115658-Suchbeleuchtung_KL_58xd_log_Bus-x0	0.00%	12
    ENG141674-ENG101574-Suchbeleuchtung_KL_58xd_log_Bus-X1	6.00%	12
    ENG141674-ENG99557-Suchbeleuchtung_KL_58xd_log_Bus-X2	16.00%	12
    ENG141674-ENG102140-Suchbeleuchtung_KL_58xd_log_Bus-X3	30.00%	12
    ENG141674-ENG102936-Suchbeleuchtung_KL_58xd_log_Bus-X4	60.00%	12
    ENG141674-ENG103548-Suchbeleuchtung_KL_58xd_log_Bus-X5	100.00%	12
    ENG141674-ENG115659-Suchbeleuchtung_KL_58xd_log_Bus-y0	10	12
    ENG141674-ENG99777-Suchbeleuchtung_KL_58xd_log_Bus-Y1	10	12
    ENG141674-ENG100480-Suchbeleuchtung_KL_58xd_log_Bus-Y2	100	12
    ENG141674-ENG100773-Suchbeleuchtung_KL_58xd_log_Bus-Y3	150	12
    ENG141674-ENG100631-Suchbeleuchtung_KL_58xd_log_Bus-Y4	220	12
    ENG141674-ENG102174-Suchbeleuchtung_KL_58xd_log_Bus-Y5	253	12
    ENG141673-ENG115658-Suchbeleuchtung_KL_58xd_max-x0	0 lx	10
    ENG141673-ENG101574-Suchbeleuchtung_KL_58xd_max-X1	8 lx	10
    ENG141673-ENG99557-Suchbeleuchtung_KL_58xd_max-X2	200 lx	10
    ENG141673-ENG102140-Suchbeleuchtung_KL_58xd_max-X3	300 lx	10
    ENG141673-ENG102936-Suchbeleuchtung_KL_58xd_max-X4	500 lx	10
    ENG141673-ENG115659-Suchbeleuchtung_KL_58xd_max-y0	16	10
    ENG141673-ENG99777-Suchbeleuchtung_KL_58xd_max-Y1	16	10
    ENG141673-ENG100480-Suchbeleuchtung_KL_58xd_max-Y2	100	10
    ENG141673-ENG100773-Suchbeleuchtung_KL_58xd_max-Y3	100	10
    ENG141673-ENG100631-Suchbeleuchtung_KL_58xd_max-Y4	100	10
    ENG141672-ENG115658-Suchbeleuchtung_KL_58xd_min-x0	0 lx	10
    ENG141672-ENG101574-Suchbeleuchtung_KL_58xd_min-X1	8 lx	10
    ENG141672-ENG99557-Suchbeleuchtung_KL_58xd_min-X2	220 lx	10
    ENG141672-ENG102140-Suchbeleuchtung_KL_58xd_min-X3	300 lx	10
    ENG141672-ENG102936-Suchbeleuchtung_KL_58xd_min-X4	500 lx	10
    ENG141672-ENG115659-Suchbeleuchtung_KL_58xd_min-y0	6	10
    ENG141672-ENG99777-Suchbeleuchtung_KL_58xd_min-Y1	6	10
    ENG141672-ENG100480-Suchbeleuchtung_KL_58xd_min-Y2	100	10
    ENG141672-ENG100773-Suchbeleuchtung_KL_58xd_min-Y3	100	10
    ENG141672-ENG100631-Suchbeleuchtung_KL_58xd_min-Y4	100	10
    ENG141677-ENG115658-Suchbeleuchtung_KL_58xd_PWM-x0	0	12
    ENG141677-ENG101574-Suchbeleuchtung_KL_58xd_PWM-X1	10	12
    ENG141677-ENG99557-Suchbeleuchtung_KL_58xd_PWM-X2	50	12
    ENG141677-ENG102140-Suchbeleuchtung_KL_58xd_PWM-X3	100	12
    ENG141677-ENG102936-Suchbeleuchtung_KL_58xd_PWM-X4	220	12
    ENG141677-ENG103548-Suchbeleuchtung_KL_58xd_PWM-X5	253	12
    ENG141677-ENG115659-Suchbeleuchtung_KL_58xd_PWM-y0	2.00%	12
    ENG141677-ENG99777-Suchbeleuchtung_KL_58xd_PWM-Y1	2.00%	12
    ENG141677-ENG100480-Suchbeleuchtung_KL_58xd_PWM-Y2	6.00%	12
    ENG141677-ENG100773-Suchbeleuchtung_KL_58xd_PWM-Y3	10.00%	12
    ENG141677-ENG100631-Suchbeleuchtung_KL_58xd_PWM-Y4	80.00%	12
    ENG141677-ENG102174-Suchbeleuchtung_KL_58xd_PWM-Y5	100.00%	12
    ENG141670-ENG115658-Suchbeleuchtung_KL_58xt min-x0	0 lx	8
    ENG141670-ENG101574-Suchbeleuchtung_KL_58xt min-X1	8 lx	8
    ENG141670-ENG99557-Suchbeleuchtung_KL_58xt min-X2	50 lx	8
    ENG141670-ENG102140-Suchbeleuchtung_KL_58xt min-X3	500 lx	8
    ENG141670-ENG115659-Suchbeleuchtung_KL_58xt min-y0	6	8
    ENG141670-ENG99777-Suchbeleuchtung_KL_58xt min-Y1	6	8
    ENG141670-ENG100480-Suchbeleuchtung_KL_58xt min-Y2	100	8
    ENG141670-ENG100773-Suchbeleuchtung_KL_58xt min-Y3	100	8
    ENG141671-ENG115658-Suchbeleuchtung_KL_58xt_max-x0	0 lx	8
    ENG141671-ENG101574-Suchbeleuchtung_KL_58xt_max-X1	8 lx	8
    ENG141671-ENG99557-Suchbeleuchtung_KL_58xt_max-X2	50 lx	8
    ENG141671-ENG102140-Suchbeleuchtung_KL_58xt_max-X3	500 lx	8
    ENG141671-ENG115659-Suchbeleuchtung_KL_58xt_max-y0	100	8
    ENG141671-ENG99777-Suchbeleuchtung_KL_58xt_max-Y1	100	8
    ENG141671-ENG100480-Suchbeleuchtung_KL_58xt_max-Y2	100	8
    ENG141671-ENG100773-Suchbeleuchtung_KL_58xt_max-Y3	100	8
    ENG141676-ENG115658-Suchbeleuchtung_KL_58xt_PWM-x0	0.00%	6
    ENG141676-ENG101574-Suchbeleuchtung_KL_58xt_PWM-X1	50.00%	6
    ENG141676-ENG99557-Suchbeleuchtung_KL_58xt_PWM-X2	100.00%	6
    ENG141676-ENG115659-Suchbeleuchtung_KL_58xt_PWM-y0	0.00%	6
    ENG141676-ENG99777-Suchbeleuchtung_KL_58xt_PWM-Y1	50.00%	6
    ENG141676-ENG100480-Suchbeleuchtung_KL_58xt_PWM-Y2	100.00%	6
    ENG141680-ENG115658-Suchbeleuchtung_Regen_Licht_Sensor_Mapping_Kennlinie-x0	0 lx	12
    ENG141680-ENG101574-Suchbeleuchtung_Regen_Licht_Sensor_Mapping_Kennlinie-X1	10 lx	12
    ENG141680-ENG99557-Suchbeleuchtung_Regen_Licht_Sensor_Mapping_Kennlinie-X2	100 lx	12
    ENG141680-ENG102140-Suchbeleuchtung_Regen_Licht_Sensor_Mapping_Kennlinie-X3	500 lx	12
    ENG141680-ENG102936-Suchbeleuchtung_Regen_Licht_Sensor_Mapping_Kennlinie-X4	800 lx	12
    ENG141680-ENG103548-Suchbeleuchtung_Regen_Licht_Sensor_Mapping_Kennlinie-X5	1020 lx	12
    ENG141680-ENG115659-Suchbeleuchtung_Regen_Licht_Sensor_Mapping_Kennlinie-y0	0	12
    ENG141680-ENG99777-Suchbeleuchtung_Regen_Licht_Sensor_Mapping_Kennlinie-Y1	20	12
    ENG141680-ENG100480-Suchbeleuchtung_Regen_Licht_Sensor_Mapping_Kennlinie-Y2	80	12
    ENG141680-ENG100773-Suchbeleuchtung_Regen_Licht_Sensor_Mapping_Kennlinie-Y3	180	12
    ENG141680-ENG100631-Suchbeleuchtung_Regen_Licht_Sensor_Mapping_Kennlinie-Y4	300	12
    ENG141680-ENG102174-Suchbeleuchtung_Regen_Licht_Sensor_Mapping_Kennlinie-Y5	500	12
    ENG141664-ENG115633-Suchbeleuchtung_Tasterdimmung-Tasterdimmung x0	0 ms	10
    ENG141664-ENG115634-Suchbeleuchtung_Tasterdimmung-Tasterdimmung x1	2000 ms	10
    ENG141664-ENG115635-Suchbeleuchtung_Tasterdimmung-Tasterdimmung x2	3000 ms	10
    ENG141664-ENG115636-Suchbeleuchtung_Tasterdimmung-Tasterdimmung x3	4000 ms	10
    ENG141664-ENG115637-Suchbeleuchtung_Tasterdimmung-Tasterdimmung x4	5100 ms	10
    ENG141664-ENG115638-Suchbeleuchtung_Tasterdimmung-Tasterdimmung y0	1.00%	10
    ENG141664-ENG115639-Suchbeleuchtung_Tasterdimmung-Tasterdimmung y1	5	10
    ENG141664-ENG115640-Suchbeleuchtung_Tasterdimmung-Tasterdimmung y2	15	10
    ENG141664-ENG115641-Suchbeleuchtung_Tasterdimmung-Tasterdimmung y3	40	10
    ENG141664-ENG115642-Suchbeleuchtung_Tasterdimmung-Tasterdimmung y4	100	10
    ENG141632-ENG116647-Sunroof-SAD Komfort oeffnen	not active 	4
    ENG141632-ENG116646-Sunroof-SAD Komfort schliessen	not active 	4
    ENG141632-ENG116645-Sunroof-SAD Richtung Komfortoeffnen	tilting 	4
    ENG141632-ENG141970-Sunroof-Schiebedachmodul_MD_1	not installed 	4
    ENG141632-ENG141971-Sunroof-Schiebedachmodul_MD_3	not installed 	4
    ENG141632-ENG141972-Sunroof-Schiebedachmodul_MD_Rollo	not installed 	4
    ENG141632-ENG142022-Sunroof-Verortung Schiebedachmodule	LIN 	4
    ENG141634-ENG142013-Verdecksteuergeraet-Cabrio_Verdeck	not_installed 	9
    ENG141634-ENG116716-Verdecksteuergeraet-Doppelpuls nur Verdeck	not active 	9
    ENG141634-ENG128459-Verdecksteuergeraet-easycloselight_aktiv	not active 	9
    ENG141634-ENG116718-Verdecksteuergeraet-Heckdeckel sperren bei Verdeckbetrieb	not active 	9
    ENG141634-ENG142259-Verdecksteuergeraet-Kick_and_close	not installed 	9
    ENG141634-ENG116711-Verdecksteuergeraet-Komfortbedienung Verdeck global	not active 	9
    ENG141634-ENG122189-Verdecksteuergeraet-Komfortbedienung Verdeck oeffnen	not active 	9
    ENG141634-ENG116712-Verdecksteuergeraet-Komfortbedienung Verdeck schließen	not active 	9
    ENG141634-ENG125654-Verdecksteuergeraet-Nachsaven_nach_Verdecklauf	not active 	9
    ENG141634-ENG126630-Verdecksteuergeraet-Reichweitenbegrenzung fuer Servoheck schliessen	not active 	9
    ENG141634-ENG125652-Verdecksteuergeraet-Servoheck Schlossansteuerung	Always 	9
    ENG141634-ENG126838-Verdecksteuergeraet-Softtouch-Betaetigung senden	Always 	9
    ENG141634-ENG142011-Verdecksteuergeraet-trunk_lid_conrol_unit	not installed 	9
    ENG141634-ENG116717-Verdecksteuergeraet-Verdeck mit Schiebedach	not active 	9
    ENG141634-ENG122191-Verdecksteuergeraet-Verdeck oeffnen via Funkfernbedienung	not active 	9
    ENG141634-ENG122192-Verdecksteuergeraet-Verdeck oeffnen via Kessy	not active 	9
    ENG141634-ENG122190-Verdecksteuergeraet-Verdeck oeffnen via Schliesszylinder	not active 	9
    ENG141634-ENG116714-Verdecksteuergeraet-Verdeck schließen via Funkfernbedienung	not active 	9
    ENG141634-ENG116715-Verdecksteuergeraet-Verdeck schließen via Kessy	not active 	9
    ENG141634-ENG116713-Verdecksteuergeraet-Verdeck schließen via Schließzylinder	not active 	9
    ENG141634-ENG115869-Verdecksteuergeraet-Virtuelles_Pedal	not active 	9
    ENG141634-ENG142258-Verdecksteuergeraet-Virtuelles_Pedal_HMI_einstellba	not active 	9
    ENG141634-ENG142257-Verdecksteuergeraet-Virtuelles_Pedal_Verbau	not installed 	9
    ENG116971-ENG116537-Vernetzungs- Diagnosefunktionen-can msg 1	00 00 	20
    ENG116971-ENG116538-Vernetzungs- Diagnosefunktionen-can msg 2	00 00 	20
    ENG116971-ENG116539-Vernetzungs- Diagnosefunktionen-can msg 3	00 00 	20
    ENG116971-ENG116540-Vernetzungs- Diagnosefunktionen-can msg 4	00 00 	20
    ENG116971-ENG116541-Vernetzungs- Diagnosefunktionen-lin msg 1	00 00 	20
    ENG116971-ENG116542-Vernetzungs- Diagnosefunktionen-lin msg 2	00 00 	20
    ENG116971-ENG116543-Vernetzungs- Diagnosefunktionen-lin msg 3	00 00 	20
    ENG116971-ENG116544-Vernetzungs- Diagnosefunktionen-lin msg 4	00 00 	20
    ENG116971-ENG116545-Vernetzungs- Diagnosefunktionen-lin msg 5	00 00 	20
    ENG116971-ENG116546-Vernetzungs- Diagnosefunktionen-lin msg 6	00 00 	20
    ENG141651-ENG116632-ZV allgemein-Bewusstes Safe mit 2. Betaetigung der FFB	not active 	7
    ENG141651-ENG133387-ZV allgemein-Deaktivierung_Laderaumschliessung_extern	not active 	7
    ENG141651-ENG125653-ZV allgemein-Deaktivierung_SAFE_ueber_DWA_Deaktivierungstaster	active 	7
    ENG141651-ENG126837-ZV allgemein-Entsafen mit autorisierte Klemme 15 Ein	not active 	7
    ENG141651-ENG115754-ZV allgemein-Funk bei Klemme 15 ein	not active 	7
    ENG141651-ENG141981-ZV allgemein-Lock_Unlock_Taster_direkt	not installed 	7
    ENG141651-ENG142019-ZV allgemein-Lock_Unlock_Toggle_Taster	not installed 	7
    ENG141651-ENG133388-ZV allgemein-LS_Taster_Togglefunktion	not active 	7
    ENG141651-ENG116633-ZV allgemein-Menuesteuerung Tuerentriegelung	active 	7
    ENG141651-ENG115755-ZV allgemein-Notschließfunktion	active 	7
    ENG141651-ENG133389-ZV allgemein-Nutzfahrzeug_Schliessung	not active 	7
    ENG141651-ENG141957-ZV allgemein-Radio freq.	315MHz 	7
    ENG141651-ENG141958-ZV allgemein-Tankschloss	Bidirectional 	7
    ENG141651-ENG133390-ZV allgemein-Wiederverriegelung_Laderaum	Freigabe_Softtouch 	7
    ENG141651-ENG116623-ZV allgemein-ZV Tuerentriegelung	Einzeltuerentriegelung 	7
    ENG141651-ENG141996-ZV allgemein-ZV_ohne_Safe_Funktion	installed 	7
    ENG141654-ENG116628-ZV Autolock-Autolock Autounlock wirkt auf Heck	active 	3
    ENG141654-ENG116621-ZV Autolock-automatisches Entriegeln	active 	3
    ENG141654-ENG115756-ZV Autolock-automatisches Verriegeln bei Geschwindigkeit	active 	3
    ENG141654-ENG116706-ZV Autolock-Autounlock NAR	active 	3
    ENG141654-ENG116622-ZV Autolock-Geschwindigkeitsabhaengige Tankdeckelverriegelung	not active 	3
    ENG141654-ENG116634-ZV Autolock-Menuesteuerung ZV Autolock-Unlock	adjustable 	3
    ENG141655-ENG116627-ZV Crash-Heckdeckel-Bedienstellen nachCrash temporaer sperren	active 	4
    ENG141655-ENG116661-ZV Crash-SAD PreCrash Konturschliessen	not active 	4
    ENG141655-ENG116635-ZV Crash-ZV-Entriegelung nach Seitencrash	not active 	4
    ENG141653-ENG115759-ZV Heck-Direkter Auswurf des Heckdeckels	not active 	7
    ENG141653-ENG126839-ZV Heck-Entriegelungwunsch_verzoegert_waehrend_Zuziehvorgang	not active 	7
    ENG141653-ENG116707-ZV Heck-Freigabenachlauf Heck nach Einzeloeffnung ueber HDF-Funktaster	not active 	7
    ENG141653-ENG142016-ZV Heck-Heckdeckelentriegelung_HDF_Innentaster	not installed 	7
    ENG141653-ENG133386-ZV Heck-Heckfreigabe_Ohne_Verzoegerung	active 	7
    ENG141653-ENG142245-ZV Heck-Heckoeffnung_ueber_2_Bedienhandlungen	not active 	7
    ENG141653-ENG141998-ZV Heck-Heckschloss_mit_Vorraste	Yes 	7
    ENG141653-ENG141995-ZV Heck-Heckschloss_Steuerung	Contact control 	7
    ENG141653-ENG137162-ZV Heck-Mindestbetaetigung_HDF_Innentaster	0.0 s	7
    ENG141653-ENG115761-ZV Heck-Nach externer Verriegelung ist Heck noch zeitbegrenzt entriegelt	not active 	7
    ENG141653-ENG141982-ZV Heck-Tausch_Tank_Hecktreiberausgang	No 	7
    ENG141653-ENG115760-ZV Heck-ZV entriegelt auch Heckdeckel	active 	7
    ENG141653-ENG116629-ZV Heck-ZV Heck nur direkt auswerfen	not active 	7
    ENG141653-ENG141997-ZV Heck-ZV_Heck_Schlosstyp	1 or 2 notch rear actuator 	7
    ENG141681-IDE02021-ZV Komfort-Comfort closing	active 	8
    ENG141681-IDE02022-ZV Komfort-Comfort opening	not active 	8
    ENG141681-ENG141984-ZV Komfort-elektrischer_Fensterheber_hinten	Yes 	8
    ENG141681-ENG116663-ZV Komfort-Fahrertuerbedienung Fensterheber oeffnen	active 	8
    ENG141681-ENG116664-ZV Komfort-Fahrertuerbedienung Fensterheber schliessen	not active 	8
    ENG141681-ENG116662-ZV Komfort-FH SAD Kl15Aus Freigabezeit	600 s	8
    ENG141681-ENG116648-ZV Komfort-Freigabenachlauf FH bei Kl 15 aus	active 	8
    ENG141681-ENG122993-ZV Komfort-Freigabenachlauf FH bei Tueroeffnen abbrechen	active 	8
    ENG141681-ENG116652-ZV Komfort-Funk Komfort oeffnen	not active 	8
    ENG141681-ENG116651-ZV Komfort-Funk Komfort schliessen	not active 	8
    ENG141681-ENG115670-ZV Komfort-Komfortbedienung global	active 	8
    ENG141681-ENG116642-ZV Komfort-Komfortoeffnen nur FH Fahrertuer	not active 	8
    ENG141681-ENG122994-ZV Komfort-Menuesteuerung Komfortbedienung einstellbar	adjustable 	8
    ENG141681-ENG122186-ZV Komfort-Menuesteuerung Regenschliessen	not active 	8
    ENG141681-ENG125656-ZV Komfort-Regenschliessen_art	once 	8
    ENG141681-ENG125655-ZV Komfort-Regenschliessen_ein_aus	not active 	8
    ENG141681-ENG116643-ZV Komfort-Schliesszylinder Komfort oeffnen	not active 	8
    ENG141681-ENG116644-ZV Komfort-Schliesszylinder Komfort schliessen	not active 	8
    ENG141652-ENG141999-ZV Türkonfiguration-Fond_Schloss	2-Motorenschloesser 	5
    ENG141652-ENG142043-ZV Türkonfiguration-HFT_Invertierung_Drehfallensignal	nicht invertiert 	5
    ENG141652-ENG142039-ZV Türkonfiguration-Schiebetuer_Kontaktmodul_Beifahrerseite	not installed 	5
    ENG141652-ENG142038-ZV Türkonfiguration-Schiebetuer_Kontaktmodul_Fahrerseite	not installed 	5
    ENG141652-ENG142001-ZV Türkonfiguration-Schiebetuer_links	No 	5
    ENG141652-ENG142002-ZV Türkonfiguration-Schiebetuer_rechts	No 	5
    ENG141652-ENG142041-ZV Türkonfiguration-Schiebetueren_Crafter	not installed 	5
    ENG141652-ENG142244-ZV Türkonfiguration-Schiebetuerschloss_direkt_BCM	Driver side 	5
    ENG141652-ENG116631-ZV Türkonfiguration-Schliessung der Schiebetuer bei geoeffneter Tankklappe	not active 	5
    ENG141652-ENG142000-ZV Türkonfiguration-Schlosstyp_NAR	Yes 	5
    ENG141652-ENG141959-ZV Türkonfiguration-Viertuerer	Yes 	5
    Elapsed Time: 01:47
    blockmap-09-5Q0-937-087-AR_3VWH17AU5JM758941-20180826-1116.CSV
    ;SW:5Q0-937-087-AR   HW:5Q0-937-087-AN ---  Cent. Elect.
    ;Component:BCM PQ37BOSCH 034 0243	 Coding:
    ;EV_BodyContrModul1UDSBosc	18001	EV_BCMBOSCH_018.rod
    ;Sunday	26	August	2018	11:16:23:04045
    ;VCDS Version: Beta 18.7.2 (x64)  Data version: 20180808 DS295.0
    ;VCID: 0B40AD4533C5AC8FF40-805E
    Group	Description	Actual
    IDE00030	Status of actuator test	not active
    IDE00075	Vehicle speed	0	 km/h
    IDE00322	Status of basic setting	was not yet started
    IDE00323	Security Access: Number of invalid keys	0
    IDE00356-IDE00355	Cruise Control System (CCS): switch position-Cruise Control System (CCS): status	not coded/not installed
    IDE00356-MAS00125	Cruise Control System (CCS): switch position-Cruise control system	not coded/not installed
    IDE00356-MAS00128	Cruise Control System (CCS): switch position-Distance Regulation	not coded/not installed
    IDE00356-MAS00320	Cruise Control System (CCS): switch position-Main switch	not coded/not installed
    IDE00356-MAS00323	Cruise Control System (CCS): switch position-Decelerate tap	not coded/not installed
    IDE00356-MAS00325	Cruise Control System (CCS): switch position-Setting	not coded/not installed
    IDE00356-MAS00326	Cruise Control System (CCS): switch position-Activation	not coded/not installed
    IDE00356-MAS02321	Cruise Control System (CCS): switch position-Cancel	not_defined
    IDE00356-MAS02343	Cruise Control System (CCS): switch position-Station coding	not coded/not installed
    IDE00356-MAS03758	Cruise Control System (CCS): switch position-Not Used	not coded/not installed
    IDE00356-MAS05138	Cruise Control System (CCS): switch position-Control unit	not coded/not installed
    IDE00374-MAS05377	Electric auxiliary heater: relay activation-Low heat output relay	not coded/not installed
    IDE00374-MAS05378	Electric auxiliary heater: relay activation-High heat output relay	not coded/not installed
    IDE00844-MAS07314	Switch for engine hood-Status engine hood contact	Open
    IDE00844-ENG122175	Switch for engine hood-Bonnet_Magnetic_Lock	not coded/not installed
    IDE00973	Outside air temperature	23.5	 °C
    IDE01066-IDE02092	Convertible top status-Tailgate condition	not coded/not installed
    IDE01066	Convertible top status	not coded/not installed
    IDE01285	Counter of component protection malfunctions	0
    IDE01464-IDE04741	Rear window defogger-Rear window defogger button	not activated
    IDE01464-IDE04744	Rear window defogger-Rear window defogger indicator lamp	OFF
    IDE01464-MAS01580	Rear window defogger-Activation	not active
    IDE01537-IDE04742	Windshield defogger-Windshield defogger button	not coded/not installed
    IDE01537-IDE04743	Windshield defogger-Windshield defogger indicator lamp	not coded/not installed
    IDE01537-MAS01580	Windshield defogger-Activation	not coded/not installed
    IDE01943-MAS01737	Turn signal-Diagnosis	normal
    IDE01943-MAS02248	Turn signal-Signal state	not active
    IDE01943-MAS03873	Turn signal-Duty cycle	0	 %
    IDE01943-MAS04351	Turn signal-Connector terminal number	36
    IDE01943-MAS04352	Turn signal-Connector number	Plug B
    IDE02092-IDE02093	Tailgate condition-Status of rear lid lock	not coded/not installed
    IDE02092-IDE02133	Tailgate condition-Activation using rear lid unlocking button	OFF
    IDE02092-MAS01872	Tailgate condition-Rear lid remote release button	not coded/not installed
    IDE02092-MAS02405	Tailgate condition-Pre-engagement contact for rotary latch	closed
    IDE02092-MAS02447	Tailgate condition-Release	Enabled
    IDE02092-MAS06265	Tailgate condition-Release button in rear lid handle	not activated
    IDE02092-MAS06430	Tailgate condition-Main notch contact of rotary latch	closed
    IDE02486	Data logger triggering	not active
    IDE02488-MAS01632	DWA Interior monitoring-Status	not coded/not installed
    IDE02488-MAS04508	DWA Interior monitoring-Alarm detected	not coded/not installed
    IDE02515-MAS01737	Low beam-Diagnosis	normal
    IDE02515-MAS02248	Low beam-Signal state	not active
    IDE02515-MAS03873	Low beam-Duty cycle	0	 %
    IDE02515-MAS04351	Low beam-Connector terminal number	5
    IDE02515-MAS04352	Low beam-Connector number	Plug C
    IDE02588-IDE00020	Terminal signals and start release-Terminal 15 status	active
    IDE02588-IDE00773	Terminal signals and start release-Terminal 15 status via CAN	active
    IDE02588-IDE01351	Terminal signals and start release-Terminal 75 status	On
    IDE02588-IDE01715	Terminal signals and start release-Status terminal S	active
    IDE02588-IDE01716	Terminal signals and start release-Terminal 50 status	OFF
    IDE02588-IDE06027	Terminal signals and start release-Terminal S status via CAN	active
    IDE02588-MAS12787	Terminal signals and start release-Terminal 15 ignition switch signal 1	active
    IDE02588-MAS12788	Terminal signals and start release-Terminal 15 ignition switch signal 2	active
    IDE02614-MAS02788	Reversing light switch-CAN	not active
    IDE02614-MAS05360	Reversing light switch-Discreet wire	not active
    IDE02711	Rear Window Wiper	not active
    IDE02743-MAS01737	High Beam-Diagnosis	normal
    IDE02743-MAS02248	High Beam-Signal state	not active
    IDE02743-MAS03873	High Beam-Duty cycle	0	 %
    IDE02743-MAS04351	High Beam-Connector terminal number	39
    IDE02743-MAS04352	High Beam-Connector number	Plug B
    IDE02744-MAS01632	Steering wheel heater-Status	not coded/not installed
    IDE02744-MAS02311	Steering wheel heater-Steering wheel heating button	not coded/not installed
    IDE02744-MAS04136	Steering wheel heater-Current	0	 A
    IDE02744-MAS09758	Steering wheel heater-Temperature sensor	188	 °C
    IDE02857-IDE03111	Activation current-Interior light	0	 mA
    IDE02857-IDE05533	Activation current-Spray nozzle heater	0	 mA
    IDE02857-IDE06012	Activation current-Search lights	0	 mA
    IDE02857-MAS01554	Activation current-Left heated seat	0	 mA
    IDE02857-MAS01556	Activation current-Right heated seat	0	 mA
    IDE02857-MAS05942	Activation current-Windshield and rear window washer pump	0	 mA
    IDE02857-ENG128454	Activation current-Cockpittaster_1	65532	 mA
    IDE02857-ENG128455	Activation current-Cockpittaster_2	65532	 mA
    IDE02857-ENG128456	Activation current-Cockpittaster_3	0	 mA
    IDE02857-ENG128457	Activation current-Cockpittaster_4	65532	 mA
    IDE02857-ENG128458	Activation current-DWA_Einfachhorn	65532	 mV
    IDE02857-ENG126436	Activation current-signal_horn	65533	 mV
    IDE02957-MAS01737	Ambient lighting-Diagnosis	not coded/not installed
    IDE02957-MAS02248	Ambient lighting-Signal state	not_defined
    IDE02957-MAS03873	Ambient lighting-Duty cycle	0	 %
    IDE02957-MAS04351	Ambient lighting-Connector terminal number	0
    IDE02957-MAS04352	Ambient lighting-Connector number	not_defined
    IDE02957-MAS06670	Ambient lighting-Channel	Not available
    IDE03111-MAS01737	Interior light-Diagnosis	normal
    IDE03111-MAS02248	Interior light-Signal state	active
    IDE03111-MAS03873	Interior light-Duty cycle	87	 %
    IDE03111-MAS04351	Interior light-Connector terminal number	12
    IDE03111-MAS04352	Interior light-Connector number	Plug C
    IDE03195-IDE03854	High values for automatic vertical headlight aim-Left front level control system sensor: height value current	0
    IDE03195-IDE04144	High values for automatic vertical headlight aim-Left rear level control system sensor: height value current	0
    IDE03195-IDE07143	High values for automatic vertical headlight aim-Vehicle level sensor: supply voltage	0	 V
    IDE03195-MAS13964	High values for automatic vertical headlight aim-Spec. value: activation vehicle level sensor	0
    IDE03195-MAS13965	High values for automatic vertical headlight aim-Vehicle level sensor: control voltage	0	 V
    IDE03310-MAS01737	Brake light-Diagnosis	normal
    IDE03310-MAS02248	Brake light-Signal state	not active
    IDE03310-MAS03873	Brake light-Duty cycle	0	 %
    IDE03310-MAS04351	Brake light-Connector terminal number	71
    IDE03310-MAS04352	Brake light-Connector number	Plug A
    IDE03388-IDE01217	Left front heated seat: status-Left heated seat stage	OFF
    IDE03388-MAS02201	Left front heated seat: status-Temperature	22.5	 °C
    IDE03389-IDE01218	Right front heated seat: status-Right heated seat stage	OFF
    IDE03389-MAS02201	Right front heated seat: status-Temperature	22	 °C
    IDE03504-IDE02022	Personalized settings-Comfort opening	All windows
    IDE03504-IDE03679	Personalized settings-Adaptive light functions	not active
    IDE03504-IDE04036	Personalized settings-High beam assistant: status	active
    IDE03504-MAS01597	Personalized settings-Sunroof	not active
    IDE03504-MAS04322	Personalized settings-Masked continuous high beam	active
    IDE03504-MAS06456	Personalized settings-Autolock	active
    IDE03504-MAS06457	Personalized settings-autounlock	active
    IDE03504-MAS06911	Personalized settings-Status Coming Home	active
    IDE03504-MAS06912	Personalized settings-Status Leaving Home	active
    IDE03504-MAS07014	Personalized settings-Tourist light	not active
    IDE03504-MAS07967	Personalized settings-profile	1
    IDE03504-MAS07971	Personalized settings-Electrical rear lid	not active
    IDE03504-MAS07972	Personalized settings-Manual door unlock	all
    IDE03504-MAS07973	Personalized settings-Rain closure	not active
    IDE03504-MAS07978	Personalized settings-Mirror adjustment	INDIVIDUAL
    IDE03504-MAS07980	Personalized settings-Mirror lowering	not active
    IDE03504-MAS07981	Personalized settings-Automatic mirror fold-in	not active
    IDE03504-MAS07982	Personalized settings-Activation sound: theft warning system	active
    IDE03504-MAS07983	Personalized settings-Virtual pedal	not active
    IDE03504-MAS07984	Personalized settings-Automatic rear window wiper	active
    IDE03504-MAS07985	Personalized settings-Coming Home set point	5	 s
    IDE03504-MAS07986	Personalized settings-Leaving Home set point	5	 s
    IDE03504-MAS07987	Personalized settings-Light intensity	normal
    IDE03504-MAS07990	Personalized settings-Comfort flasher	active
    IDE03504-MAS07991	Personalized settings-Comfort flasher set point	3
    IDE03504-MAS07992	Personalized settings-Sliding beam range	active
    IDE03504-MAS07993	Personalized settings-Rain light	active
    IDE03504-ENG29901	Personalized settings-Touristenlicht Einstellwert	not active
    IDE03638-MAS01737	static AFS light-Diagnosis	normal
    IDE03638-MAS02248	static AFS light-Signal state	not active
    IDE03638-MAS03873	static AFS light-Duty cycle	0	 %
    IDE03638-MAS04351	static AFS light-Connector terminal number	45
    IDE03638-MAS04352	static AFS light-Connector number	Plug B
    IDE04213	Central locking button	not coded/not installed
    IDE04213-IDE07357	Central locking button-Indicator light for central locking	not coded/not installed
    IDE04254-MAS06517	Play protection for central locking-Rear spoiler counter	not active
    IDE04347-IDE00104	Expanded environmental conditions-DTC	00 00 00
    IDE04347-IDE07836	Expanded environmental conditions-Log data	00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00
    IDE04925-MAS01737	Daytime running lights-Diagnosis	not coded/not installed
    IDE04925-MAS02248	Daytime running lights-Signal state	Measured value not available
    IDE04925-MAS03873	Daytime running lights-Duty cycle	0	 %
    IDE04925-MAS04351	Daytime running lights-Connector terminal number	0
    IDE04925-MAS04352	Daytime running lights-Connector number	not coded/not installed
    IDE05042-IDE05043	Emergency flasher button-Emergency flasher indicator lamp	On
    IDE05042-MAS02158	Emergency flasher button-Actuation condition	Not operated
    IDE05042-MAS03873	Emergency flasher button-Duty cycle	23	 %
    IDE05045-IDE05183	Front windshield wiper module-Malfunction left	no error
    IDE05045-IDE05184	Front windshield wiper module-Malfunction right	no error
    IDE05045-MAS01632	Front windshield wiper module-Status	not active
    IDE05045-MAS02282	Front windshield wiper module-Position	park position
    IDE05045-MAS03638	Front windshield wiper module-Wipe speed	0	 /min
    IDE05045-MAS05057	Front windshield wiper module-Number of wiper cycles	0
    IDE05045-MAS05878	Front windshield wiper module-Stage	not coded/not installed
    IDE05323-MAS01737	Fog light-Diagnosis	normal
    IDE05323-MAS02248	Fog light-Signal state	not active
    IDE05323-MAS03873	Fog light-Duty cycle	0	 %
    IDE05323-MAS04351	Fog light-Connector terminal number	10
    IDE05323-MAS04352	Fog light-Connector number	Plug B
    IDE05434-MAS01737	Rear entry light-Diagnosis	not coded/not installed
    IDE05434-MAS02248	Rear entry light-Signal state	Measured value not available
    IDE05434-MAS03873	Rear entry light-Duty cycle	0	 %
    IDE05434-MAS04150	Rear entry light-Side	not_defined
    IDE05434-MAS04351	Rear entry light-Connector terminal number	0
    IDE05434-MAS04352	Rear entry light-Connector number	not_defined
    IDE05533	Spray nozzle heater	not active
    IDE05719-IDE05534	Window washer system-Headlamp washer system	not coded/not installed
    IDE05719-MAS02339	Window washer system-Windshield washer system	not active
    IDE05719-MAS02341	Window washer system-Rear window washer system	not active
    IDE05720-IDE02589	Front driver side door status-Rotary latch status	Open
    IDE05720-IDE04213	Front driver side door status-Central locking button	Not operated
    IDE05720-IDE04214	Front driver side door status-Key switch in door lock	Not operated
    IDE05720-MAS06256	Front driver side door status-Status door lock	Signal from door lock: released
    IDE05722-IDE02589	Door status: driver side rear-Rotary latch status	closed
    IDE05722-IDE04213	Door status: driver side rear-Central locking button	not coded/not installed
    IDE05722-MAS06256	Door status: driver side rear-Status door lock	Signal from door lock: released
    IDE05727-IDE02589	Front passenger side door status-Rotary latch status	closed
    IDE05727-IDE04213	Front passenger side door status-Central locking button	Not operated
    IDE05727-IDE04214	Front passenger side door status-Key switch in door lock	Not operated
    IDE05727-MAS06256	Front passenger side door status-Status door lock	Signal from door lock: released
    IDE05729-IDE02589	Door status: frt. pass. side rear-Rotary latch status	closed
    IDE05729-IDE04213	Door status: frt. pass. side rear-Central locking button	not coded/not installed
    IDE05729-MAS06256	Door status: frt. pass. side rear-Status door lock	Signal from door lock: released
    IDE05730-MAS01737	Luggage compartment light-Diagnosis	not coded/not installed
    IDE05730-MAS02248	Luggage compartment light-Signal state	Measured value not available
    IDE05730-MAS03873	Luggage compartment light-Duty cycle	0	 %
    IDE05730-MAS04351	Luggage compartment light-Connector terminal number	0
    IDE05730-MAS04352	Luggage compartment light-Connector number	not_defined
    IDE05739-MAS01737	Footwell light-Diagnosis	normal
    IDE05739-MAS02248	Footwell light-Signal state	active
    IDE05739-MAS03873	Footwell light-Duty cycle	54.5	 %
    IDE05739-MAS04351	Footwell light-Connector terminal number	72
    IDE05739-MAS04352	Footwell light-Connector number	Plug C
    IDE05742-IDE02515	Light switch position-Low beam	not activated
    IDE05742-IDE05323	Light switch position-Fog light	not activated
    IDE05742-IDE07956	Light switch position-redundant signal line	OFF
    IDE05742-MAS00063	Light switch position-OFF	operated
    IDE05742-MAS02462	Light switch position-Automatic high beam assist	not activated
    IDE05742-MAS03835	Light switch position-Parking light	not activated
    IDE05742-MAS03836	Light switch position-Rear fog light	not coded/not installed
    IDE05822-MAS01632	DWA Vehicle inclination sensor-Status	not coded/not installed
    IDE05822-MAS04508	DWA Vehicle inclination sensor-Alarm detected	not coded/not installed
    IDE05825-MAS02594	DWA Interior monitoring/vehicle inclination sensor button-Indicator light in switch	not coded/not installed
    IDE05825-MAS04247	DWA Interior monitoring/vehicle inclination sensor button-Button	not coded/not installed
    IDE05826-MAS01632	DWA Sirens / alarm horn for anti-theft warning system-Status	not coded/not installed
    IDE05826-MAS04508	DWA Sirens / alarm horn for anti-theft warning system-Alarm detected	No
    IDE05826-MAS04509	DWA Sirens / alarm horn for anti-theft warning system-Alarm activated	No
    IDE05827	Alarm horn for anti-theft warning system	not coded/not installed
    IDE05829-ENG28562	Rear spoiler history data-Spoiler_Activation_Trigger	NoEntry
    IDE05829-ENG28563	Rear spoiler history data-Spoiler_Activation_Trigger_Date	0
    IDE05829-ENG28565	Rear spoiler history data-Spoiler_Activation_Trigger_Milage	0	 km
    IDE05829-ENG28564	Rear spoiler history data-Spoiler_Activation_Trigger_Time	0
    IDE05830-MAS02282	Rear Spoiler-Position	not coded/not installed
    IDE05830-ENG115793	Rear Spoiler-Spoiler_Button	not coded/not installed
    IDE05830-ENG115792	Rear Spoiler-Spoiler_Cycle_Protection	not coded/not installed
    IDE05830-ENG115794	Rear Spoiler-Spoiler_Indication_Light	not coded/not installed
    IDE05830-ENG115791	Rear Spoiler-Spoiler_Position	not coded/not installed
    IDE05833-MAS00106	Anti-theft warning system: history data-Year	2000
    IDE05833-MAS00107	Anti-theft warning system: history data-Month	0
    IDE05833-MAS00108	Anti-theft warning system: history data-Day	0
    IDE05833-MAS00109	Anti-theft warning system: history data-Hours	0
    IDE05833-MAS00110	Anti-theft warning system: history data-Minutes	0
    IDE05833-MAS00111	Anti-theft warning system: history data-Seconds	0
    IDE05833-MAS00711	Anti-theft warning system: history data-Odometer reading	0	 km
    IDE05833-MAS04478	Anti-theft warning system: history data-Cause for alarm activation	No alarm
    IDE05834-IDE01718	Driver info-Crash signal	not active
    IDE05834-MAS00211	Driver info-Insufficient brake fluid	not active
    IDE05834-MAS00212	Driver info-Insufficient washer fluid	not active
    IDE05834-MAS00213	Driver info-Insufficient coolant	not active
    IDE05834-MAS00214	Driver info-Brake pad wear	not coded/not installed
    IDE05836-MAS03637	Rain recognition sensor-Rain quantity	0
    IDE05836-MAS03638	Rain recognition sensor-Wipe speed	0
    IDE05836-MAS04806	Rain recognition sensor-Splash	not active
    IDE05836-MAS04807	Rain recognition sensor-park position	active
    IDE05837	Activation for signal horn	not active
    IDE05838-MAS01794	Light recognition sensor-Freeway	OFF
    IDE05838-MAS02248	Light recognition sensor-Signal state	active
    IDE05838-MAS02475	Light recognition sensor-Brightness infrared	2400	 lx
    IDE05838-MAS02851	Light recognition sensor-Brightness	240	 lx
    IDE05838-MAS04808	Light recognition sensor-Rain	OFF
    IDE05838-MAS04809	Light recognition sensor-Darkness	On
    IDE05838-MAS04810	Light recognition sensor-Request for light activation	On
    IDE05839-MAS01737	Parking light-Diagnosis	normal
    IDE05839-MAS02248	Parking light-Signal state	not active
    IDE05839-MAS03873	Parking light-Duty cycle	0	 %
    IDE05839-MAS04351	Parking light-Connector terminal number	10
    IDE05839-MAS04352	Parking light-Connector number	Plug B
    IDE05841-MAS06441	Central locking history data-Control-section / cause	autounlock
    IDE05841-MAS07519	Central locking history data-Command	Unlocking of entire vehicle
    IDE05841-MAS07942	Central locking history data-Additional information	Measured value not available
    IDE05841-ENG29969	Central locking history data-command_direction_locking	Lock door
    IDE05841-ENG29970	Central locking history data-command_direction_unlocking	no_unlocking
    IDE05842-MAS00218	Comfort function history data-Driver door	not active
    IDE05842-MAS00219	Comfort function history data-Front Passenger Door	not active
    IDE05842-MAS00220	Comfort function history data-Left rear door	not active
    IDE05842-MAS00221	Comfort function history data-Right rear door	not active
    IDE05842-MAS06441	Comfort function history data-Control-section / cause	keine Bedienstelle
    IDE05842-MAS07560	Comfort function history data-Top	not active
    IDE05842-MAS07561	Comfort function history data-Sun roof/tilt roof	not active
    IDE05842-MAS07941	Comfort function history data-Operating command	Open
    IDE06012-MAS01737	Search lights-Diagnosis	normal
    IDE06012-MAS02248	Search lights-Signal state	not active
    IDE06012-MAS03873	Search lights-Duty cycle	0	 %
    IDE06012-MAS04351	Search lights-Connector terminal number	62
    IDE06012-MAS04352	Search lights-Connector number	Plug C
    IDE06012-MAS15156	Search lights-terminal	Variant A
    IDE06091-IDE01440	Humidity sensor: internal-Windshield temperature	-38.1	 °C
    IDE06091-MAS04629	Humidity sensor: internal-Sensor temperature	87.5	 °C
    IDE06091-MAS04630	Humidity sensor: internal-Relative humidity	127	 %
    IDE06091-MAS04647	Humidity sensor: internal-Dew point	-38.1	 °C
    IDE06096-IDE03111	Interior lighting-Interior light	100	 %
    IDE06096-IDE05724	Interior lighting-Terminal 58xt dimmer	100	 %
    IDE06096-IDE05725	Interior lighting-Terminal 58xs dimmer	0	 %
    IDE06096-IDE05726	Interior lighting-Terminal 58xd dimmer	100	 %
    IDE06096-MAS01634	Interior lighting-Supply voltage	87	 %
    IDE06096-MAS04528	Interior lighting-Instrument panel and switch illumination dimmer switch	100	 %
    IDE06324-IDE04217	Tank cap lock-Fuel filler door release button	not coded/not installed
    IDE06324-MAS01580	Tank cap lock-Activation	not active
    IDE06324-MAS06251	Tank cap lock-Contact switch	not coded/not installed
    IDE06470-MAS01737	Ambience lighting-Diagnosis	not coded/not installed
    IDE06470-MAS02248	Ambience lighting-Signal state	Measured value not available
    IDE06470-MAS03873	Ambience lighting-Duty cycle	0	 %
    IDE06470-MAS04351	Ambience lighting-Connector terminal number	0
    IDE06470-MAS04352	Ambience lighting-Connector number	not coded/not installed
    IDE06507-MAS13127	Button in center console-Status of button 1	not coded/not installed
    IDE06507-MAS13128	Button in center console-Indicator lamp button 1	not coded/not installed
    IDE06507-MAS13130	Button in center console-Status of button 2	not coded/not installed
    IDE06507-MAS13131	Button in center console-Indicator lamp button 2	not coded/not installed
    IDE06507-MAS13133	Button in center console-Status of button 3	not activated
    IDE06507-MAS13134	Button in center console-Indicator lamp button 3	OFF
    IDE06507-MAS13136	Button in center console-Indicator lamp button 4	not coded/not installed
    IDE06507-MAS13137	Button in center console-Status of button 4	not coded/not installed
    IDE06592-MAS05002	Status: special functions-Showroom mode	OFF
    IDE06592-MAS05003	Status: special functions-Debug functions	OFF
    IDE06644-IDE06864	Vehicle positioning system-Daytime running lights	not coded/not installed
    IDE06644-MAS01288	Vehicle positioning system-Signal horn	not coded/not installed
    IDE06644-MAS03834	Vehicle positioning system-Emergency signal flashing	not coded/not installed
    IDE06644-MAS03835	Vehicle positioning system-Parking light	not coded/not installed
    IDE06695-IDE01459	Energy management: last critical state-Energy management heat output control status	0
    IDE06695-MAS00107	Energy management: last critical state-Month	0
    IDE06695-MAS00108	Energy management: last critical state-Day	0
    IDE06695-MAS06555	Energy management: last critical state-Maximum switch-off priority while driving	0
    IDE06695-MAS06570	Energy management: last critical state-Number of critical operation cycles	0
    IDE06695-ENG28924	Energy management: last critical state-Anz_erreichte_Max_Freigaben	0
    IDE06695-ENG28921	Energy management: last critical state-Anz_krit_Betriebszyklen	0
    IDE06695-ENG28922	Energy management: last critical state-Bedingung_Tab_NQ	0
    IDE06695-ENG28920	Energy management: last critical state-min_prio_Tab_K	0
    IDE06695-ENG28919	Energy management: last critical state-min_prio_Tab_M	0
    IDE06695-ENG28923	Energy management: last critical state-min_prio_Tab_NQ	0
    IDE06695-ENG99063	Energy management: last critical state-Year	2000
    IDE06864-MAS01737	Daytime running lights-Diagnosis	normal
    IDE06864-MAS02248	Daytime running lights-Signal state	not active
    IDE06864-MAS03873	Daytime running lights-Duty cycle	0	 %
    IDE06864-MAS04351	Daytime running lights-Connector terminal number	10
    IDE06864-MAS04352	Daytime running lights-Connector number	Plug B
    IDE07145-MAS06772	Component protection properties-Component protection generation	2
    IDE07145-MAS06773	Component protection properties-KS Standard software main version nummer	2
    IDE07145-MAS06774	Component protection properties-KS Standard software secondary version number	0
    IDE07145-MAS06775	Component protection properties-KS Standard software correct number	1
    IDE07145-MAS06776	Component protection properties-Komponent protection role	KS Slave
    IDE07145-MAS06781	Component protection properties-Secure Hardware Extension	Not Used
    IDE07145-MAS06782	Component protection properties-Master ECU Key	not administered by component protection
    IDE07145-MAS06785	Component protection properties-GFA key	used
    IDE07145-MAS06786	Component protection properties-SSW RND Generation	Not Used
    IDE07145-MAS06787	Component protection properties-Indiv Key Generation	Not Used
    IDE07145-MAS06788	Component protection properties-SHE Secure Boot	Not Used
    IDE07145-MAS07187	Component protection properties-KS Data version	1
    IDE07145-MAS09609	Component protection properties-Status IKA start key	not active
    IDE07145-MAS09610	Component protection properties-Status GFA Key	valid
    IDE07145-MAS09611	Component protection properties-Status Master ECU Key	stored
    IDE07187-MAS06538	Level control system sensor-Left Front Level Control System Sensor: PWM signal	655.35	 %
    IDE07187-MAS06539	Level control system sensor-Left Rear Level Control System Sensor: PWM signal	655.35	 %
    IDE07187-MAS06540	Level control system sensor-Left front level control system sensor: frequency	6553.5	 Hz
    IDE07187-MAS06541	Level control system sensor-Left Rear Left Control System Sensor: frequency	6553.5	 Hz
    IDE07187-MAS06542	Level control system sensor-Vehicle level sensor: supply voltage	65.535	 V
    IDE07344-IDE00542	Sunroof shade-Excessive temperature protection	not active
    IDE07344-IDE03114	Sunroof shade-Comfort function	not active
    IDE07344-MAS01979	Sunroof shade-Adapting	Not adapted
    IDE07344-MAS02282	Sunroof shade-Position	0	 %
    IDE07344-MAS02447	Sunroof shade-Release	not active
    IDE07344-MAS03656	Sunroof shade-Reverse	not active
    IDE07344-MAS05563	Sunroof shade-Norming	not normed
    IDE07345-MAS07997	Sunroof front closed position switch-Rotary switch activation	Implausible
    IDE07345	Sunroof front closed position switch	not activated
    IDE07345-ENG122183	Sunroof front closed position switch-rotary_switch_position	closed
    IDE07346	Sunroof shade switches	not activated
    IDE08125-MAS01458	Left cabin heater-Operating condition	not coded/not installed
    IDE08125-MAS06651	Left cabin heater-PTC heater element: current consumption	not coded/not installed
    IDE08125-MAS06652	Left cabin heater-Blower motor: speed	not coded/not installed
    IDE08125-MAS06653	Left cabin heater-Indicator light for head area heater	not coded/not installed
    IDE08126-MAS01458	Right cabin heater-Operating condition	not coded/not installed
    IDE08126-MAS06651	Right cabin heater-PTC heater element: current consumption	not coded/not installed
    IDE08126-MAS06652	Right cabin heater-Blower motor: speed	not coded/not installed
    IDE08126-MAS06653	Right cabin heater-Indicator light for head area heater	not coded/not installed
    IDE08177-MAS06456	Central locking-Autolock	not active
    IDE08177-MAS06740	Central locking-Release button in rear lid handle locked	not active
    IDE08177-MAS09894	Central locking-Status exterior skin	Open
    IDE08177-MAS09896	Central locking-Act. condition: Status central locking internal locked	not active
    IDE08177-MAS09897	Central locking-Act. condition: Status central locking external locked	not active
    IDE08177-MAS09898	Central locking-Act. condition: Status central locking safe	not active
    IDE08177-MAS09900	Central locking-Spec. condition: Status central lock	Signal from door lock: released
    IDE08177-ENG09185	Central locking-Load_compartment_closing	not coded/not installed
    IDE08211-MAS00106	History data control module reset-Year	2000
    IDE08211-MAS00107	History data control module reset-Month	0
    IDE08211-MAS00108	History data control module reset-Day	0
    IDE08211-MAS00109	History data control module reset-Hours	0
    IDE08211-MAS00110	History data control module reset-Minutes	0
    IDE08211-MAS03129	History data control module reset-Reset counter	9
    IDE08211-MAS06734	History data control module reset-last cause of reset	Application 9
    IDE08343	Immobilizer Challenge	0A 62 FA E1
    IDE08949-MAS07867	Operating current: light driver-Conn. pin 0	0	 mA
    IDE08949-MAS07868	Operating current: light driver-Conn. pin 1	0	 mA
    IDE08949-MAS07869	Operating current: light driver-Conn. pin 2	0	 mA
    IDE08949-MAS07870	Operating current: light driver-Conn. pin 3	0	 mA
    IDE08949-MAS07871	Operating current: light driver-Conn. pin 4	0	 mA
    IDE08949-MAS07872	Operating current: light driver-Conn. pin 5	0	 mA
    IDE08949-MAS07873	Operating current: light driver-Conn. pin 6	0	 mA
    IDE08949-MAS07874	Operating current: light driver-Conn. pin 7	0	 mA
    IDE08949-MAS07875	Operating current: light driver-Conn. pin 8	0	 mA
    IDE08949-MAS07876	Operating current: light driver-Conn. pin 9	0	 mA
    IDE08949-MAS07877	Operating current: light driver-Conn. pin 10	0	 mA
    IDE08949-MAS07878	Operating current: light driver-Conn. pin 11	0	 mA
    IDE08949-MAS07879	Operating current: light driver-Conn. pin 12	0	 mA
    IDE08949-MAS07880	Operating current: light driver-Conn. pin 13	0	 mA
    IDE08949-MAS07881	Operating current: light driver-Conn. pin 14	0	 mA
    IDE08949-MAS07882	Operating current: light driver-Conn. pin 15	0	 mA
    IDE08949-MAS07883	Operating current: light driver-Conn. pin 16	0	 mA
    IDE08949-MAS07884	Operating current: light driver-Conn. pin 17	0	 mA
    IDE08949-MAS07885	Operating current: light driver-Conn. pin 18	0	 mA
    IDE08949-MAS07886	Operating current: light driver-Conn. pin 19	0	 mA
    IDE08949-MAS07887	Operating current: light driver-Conn. pin 20	0	 mA
    IDE08949-MAS07888	Operating current: light driver-Conn. pin 21	0	 mA
    IDE08949-MAS07889	Operating current: light driver-Conn. pin 22	0	 mA
    IDE08949-MAS07890	Operating current: light driver-Conn. pin 23	0	 mA
    IDE08949-MAS07891	Operating current: light driver-Conn. pin 24	0	 mA
    IDE08949-MAS07892	Operating current: light driver-Conn. pin 25	0	 mA
    IDE08949-MAS07893	Operating current: light driver-Conn. pin 26	0	 mA
    IDE08949-MAS07894	Operating current: light driver-Conn. pin 27	0	 mA
    IDE08949-MAS07895	Operating current: light driver-Conn. pin 28	0	 mA
    IDE08949-MAS07896	Operating current: light driver-Conn. pin 29	0	 mA
    IDE08949-MAS07897	Operating current: light driver-Conn. pin 30	40	 mA
    IDE08949-MAS07898	Operating current: light driver-Conn. pin 31	0	 mA
    IDE08949-MAS07899	Operating current: light driver-Conn. pin 32	0	 mA
    IDE08949-MAS07900	Operating current: light driver-Conn. pin 33	0	 mA
    IDE08949-MAS07901	Operating current: light driver-Conn. pin 34	0	 mA
    IDE09065-MAS07964	Status: remote start-Engine run time after remote start	0	 s
    IDE09065-MAS16464	Status: remote start-Number of RemoteStarts carried out	0
    IDE09850-MAS07146	Garage Door Opener Operating Unit-Button 1	not coded/not installed
    IDE09850-MAS07147	Garage Door Opener Operating Unit-Button 2	not coded/not installed
    IDE09850-MAS07148	Garage Door Opener Operating Unit-Button 3	not coded/not installed
    IDE11134-IDE01943	Light sequence HU test result-Turn signal	Installed: not active
    IDE11134-IDE02515	Light sequence HU test result-Low beam	Installed: not active
    IDE11134-IDE02614	Light sequence HU test result-Reversing light switch	Installed: not active
    IDE11134-IDE02743	Light sequence HU test result-High Beam	Installed: not active
    IDE11134-IDE03310	Light sequence HU test result-Brake light	Installed: not active
    IDE11134-IDE03638	Light sequence HU test result-static AFS light	Installed: not active
    IDE11134-IDE05323	Light sequence HU test result-Fog light	Installed: not active
    IDE11134-IDE05839	Light sequence HU test result-Parking light	not installed / not active
    IDE11134-IDE06470	Light sequence HU test result-Ambience lighting	not installed / not active
    IDE11134-IDE06864	Light sequence HU test result-Daytime running lights	Installed: not active
    IDE11134-MAS02354	Light sequence HU test result-Headlamp flasher	Installed: not active
    IDE11134-MAS03835	Light sequence HU test result-Parking light	Installed: not active
    IDE11134-MAS03836	Light sequence HU test result-Rear fog light	not installed / not active
    IDE11134-MAS11025	Light sequence HU test result-Status	no restriction
    IDE11350-MAS12597	Sunlight photo sensor-Sun intensity left	327670	 W/m²
    IDE11350-MAS12598	Sunlight photo sensor-Sun intensity right	327670	 W/m²
    IDE11668-MAS06256	Driver side rear sliding door: central locking signals-Status door lock	not coded/not installed
    IDE11668-MAS06431	Driver side rear sliding door: central locking signals-Door contact switch	not coded/not installed
    IDE11668-MAS06433	Driver side rear sliding door: central locking signals-Door lock: safe status	not coded/not installed
    IDE11669-MAS06256	Passenger side rear sliding door: central locking signals-Status door lock	not coded/not installed
    IDE11669-MAS06431	Passenger side rear sliding door: central locking signals-Door contact switch	not coded/not installed
    IDE11669-MAS06433	Passenger side rear sliding door: central locking signals-Door lock: safe status	not coded/not installed
    IDE11670-MAS06256	Rear wing door: central locking signals-Status door lock	not coded/not installed
    IDE11670-MAS06431	Rear wing door: central locking signals-Door contact switch	not coded/not installed
    IDE11670-MAS06433	Rear wing door: central locking signals-Door lock: safe status	not coded/not installed
    IDE11727-IDE04806	Function of the central console button-Driving profile selection button	LED installed
    IDE11727-MAS13125	Function of the central console button-Function of button 1	not coded/not installed
    IDE11727-MAS13129	Function of the central console button-Function of button 2	not coded/not installed
    IDE11727-MAS13132	Function of the central console button-Function of button 3	Driving program
    IDE11727-MAS13135	Function of the central console button-Function of button 4	not coded/not installed
    IDE11943-MAS01737	Signature light-Diagnosis	not coded/not installed
    IDE11943-MAS02248	Signature light-Signal state	Measured value not available
    IDE11943-MAS03873	Signature light-Duty cycle	0	 %
    IDE11943-MAS04351	Signature light-Connector terminal number	0
    IDE11943-MAS04352	Signature light-Connector number	not coded/not installed
    IDE11999-IDE03853	High values of headlight range adjustment: basic setting-Left front level control system sensor: height value adapted	-100
    IDE11999-IDE04143	High values of headlight range adjustment: basic setting-Left rear level control system sensor: height value adapted	-100
    IDE12060	Headlight range adjustment counter	00 00 00 00
    IDE12212	Cause control module incorrectly coded	Not Present
    IDE12940-IDE01268	Lever functions of the steering column electronics-Windshield wiper	not coded/not installed
    IDE12940-IDE02335	Lever functions of the steering column electronics-Signal light switch position	not coded/not installed
    IDE12940-IDE02711	Lever functions of the steering column electronics-Rear Window Wiper	not coded/not installed
    IDE12940-MAS00232	Lever functions of the steering column electronics-MFI button UP	not_defined
    IDE12940-MAS00233	Lever functions of the steering column electronics-MFI button DOWN	not_defined
    IDE12940-MAS00234	Lever functions of the steering column electronics-MFI button RESET / OK	not_defined
    IDE12940-MAS00242	Lever functions of the steering column electronics-Driver assistance systems button	not coded/not installed
    IDE12940-MAS00243	Lever functions of the steering column electronics-Buttons for driver assistance systems: status	not coded/not installed
    IDE12940-MAS01288	Lever functions of the steering column electronics-Signal horn	not coded/not installed
    IDE12940-MAS02338	Lever functions of the steering column electronics-Windshield wiper: intermittent stage	not coded/not installed
    IDE12940-MAS02339	Lever functions of the steering column electronics-Windshield washer system	not coded/not installed
    IDE12940-MAS02341	Lever functions of the steering column electronics-Rear window washer system	not coded/not installed
    IDE12940	Lever functions of the steering column electronics	not coded/not installed
    IDE80251-MAS06439	Head area heater-Crash status	not coded/not installed
    IDE80251-MAS06646	Head area heater-Head area heater left: specified level	not coded/not installed
    IDE80251-MAS06647	Head area heater-Head area heater right: specified level	not coded/not installed
    IDE80251-MAS06648	Head area heater-Continuation at terminal 15 on	not coded/not installed
    IDE80251-MAS06649	Head area heater-Left front seat occupation status	not coded/not installed
    IDE80251-MAS06650	Head area heater-Right front occupation status	not coded/not installed
    MAS00043-IDE00019	Supply voltage: Terminal 30-Voltage terminal 30	14.65	 V
    MAS00043-IDE05835	Supply voltage: Terminal 30-Supply voltage for central locking	14.5	 V
    MAS00043-IDE05967	Supply voltage: Terminal 30-Voltage terminal 30 left	14.55	 V
    MAS00043-IDE05968	Supply voltage: Terminal 30-Voltage terminal 30 right	14.55	 V
    MAS00043-IDE08734	Supply voltage: Terminal 30-Supply voltage for anti-theft alarm system	14.45	 V
    MAS00043-IDE08735	Supply voltage: Terminal 30-Supply voltage for seat heater	14.5	 V
    MAS00043-MAS00362	Supply voltage: Terminal 30-Battery voltage	8.45	 V
    MAS00043-MAS07472	Supply voltage: Terminal 30-Battery voltage BEM	14.4	 V
    MAS00043-MAS07473	Supply voltage: Terminal 30-Test voltage rear window defogger	0	 V
    MAS00043-MAS07474	Supply voltage: Terminal 30-Test voltage windshield defogger	0	 V
    MAS00179-MAS04422	Brake Light Switch-Brake light signal via CAN	OFF
    MAS00179-MAS07313	Brake Light Switch-Brake light signal via HW	OFF
    MAS00464-MAS00106	Standard - ambient data 1-Year	2018
    MAS00464-MAS00107	Standard - ambient data 1-Month	8
    MAS00464-MAS00108	Standard - ambient data 1-Day	26
    MAS00464-MAS00109	Standard - ambient data 1-Hours	11
    MAS00464-MAS00110	Standard - ambient data 1-Minutes	16
    MAS00464-MAS00111	Standard - ambient data 1-Seconds	26
    MAS00464-MAS00468	Standard - ambient data 1-Unlearning counter	28
    MAS00464-MAS00711	Standard - ambient data 1-Odometer reading	138	 km
    MAS00829-MAS00244	Access and start authorization-Awakening wire	not coded/not installed
    MAS00829-MAS01763	Access and start authorization-Signal Strength	0
    MAS00829-MAS07866	Access and start authorization-Duration: last awakening wire actua.	0	 ms
    MAS01281-MAS01737	Back-up light-Diagnosis	normal
    MAS01281-MAS02248	Back-up light-Signal state	not active
    MAS01281-MAS03873	Back-up light-Duty cycle	0	 %
    MAS01281-MAS04351	Back-up light-Connector terminal number	11
    MAS01281-MAS04352	Back-up light-Connector number	Plug C
    MAS01431-IDE01442	Vehicle key with remote control-Pressing a button	not activated
    MAS01431-IDE01839	Vehicle key with remote control-Battery charge condition	Not available
    MAS01431-MAS00077	Vehicle key with remote control-Immobilizer	OK
    MAS01431-MAS01551	Vehicle key with remote control-Key number	255
    MAS01431-MAS05048	Vehicle key with remote control-Number of transmitters adapted	2
    MAS01431-MAS06362	Vehicle key with remote control-Code in detection area	Not available
    MAS01490-IDE02744	Energy management-Steering wheel heater	Enabled
    MAS01490-IDE04216	Energy management-Mirror heater	Enabled
    MAS01490-IDE80251	Energy management-Head area heater	not coded/not installed
    MAS01490-MAS01535	Energy management-Rear window defogger	Enabled
    MAS01490-MAS01563	Energy management-Auxiliary Air Heater	not coded/not installed
    MAS01490-MAS01564	Energy management-Windshield defogger	not coded/not installed
    MAS01490-MAS01632	Energy management-Status	not active
    MAS01490-MAS02390	Energy management-Shutoff	67
    MAS01490-MAS05795	Energy management-Rear seat heater	Enabled
    MAS01490-MAS05796	Energy management-Emergency shut-down	0
    MAS01490-MAS05887	Energy management-Battery cut out relay 2	not enabled
    MAS01490-MAS06551	Energy management-Seat ventilation	not coded/not installed
    MAS01490-MAS06552	Energy management-Seat heater front	Enabling stage 3
    MAS01490-MAS06553	Energy management-Display consumer switch-off	not active
    MAS01490-MAS06554	Energy management-Switch-off priority while driving	0
    MAS01490-MAS06555	Energy management-Maximum switch-off priority while driving	6
    MAS01490-MAS06556	Energy management-Switch-off with voltage drops	0
    MAS01490-MAS06557	Energy management-Switch-off priority with vehicle crash	0
    MAS01490-MAS06558	Energy management-Current negative charge balance	0	 %
    MAS01490-MAS06559	Energy management-Switch-off priority with engine off	0
    MAS01490-MAS06560	Energy management-Short distance drive	1
    MAS01597-IDE00542	Sunroof-Excessive temperature protection	not active
    MAS01597-IDE03114	Sunroof-Comfort function	not active
    MAS01597-MAS01979	Sunroof-Adapting	Not adapted
    MAS01597-MAS02282	Sunroof-Position	0	 %
    MAS01597-MAS02447	Sunroof-Release	not active
    MAS01597-MAS03656	Sunroof-Reverse	not active
    MAS01597-MAS05563	Sunroof-Norming	not normed
    MAS01597-MAS05737	Sunroof-Position	Tilt out posi.
    MAS03835-MAS01737	Parking light-Diagnosis	normal
    MAS03835-MAS02248	Parking light-Signal state	not active
    MAS03835-MAS03873	Parking light-Duty cycle	0	 %
    MAS03835-MAS04351	Parking light-Connector terminal number	10
    MAS03835-MAS04352	Parking light-Connector number	Plug B
    MAS03836-MAS01737	Rear fog light-Diagnosis	not coded/not installed
    MAS03836-MAS02248	Rear fog light-Signal state	Measured value not available
    MAS03836-MAS03873	Rear fog light-Duty cycle	0	 %
    MAS03836-MAS04351	Rear fog light-Connector terminal number	0
    MAS03836-MAS04352	Rear fog light-Connector number	not coded/not installed
    MAS07959-IDE00787	Remote start history data-Cause for cancellation	no reason for cancellation
    MAS07959-MAS00107	Remote start history data-Month	15
    MAS07959-MAS00108	Remote start history data-Day	31
    MAS07959-MAS00109	Remote start history data-Hours	31
    MAS07959-MAS00110	Remote start history data-Minutes	63
    MAS07959-MAS07960	Remote start history data-Stop or cancel cause	No reason for prevention
    MAS08228-MAS01632	Light sensor-Status	not coded/not installed
    MAS08228-MAS02851	Light sensor-Brightness	22860	 lx
    MAS08228-MAS04121	Light sensor-Voltage	25.4	 V
    MAS13141	Test voltage	0	 V
    ENG116910	Control unit internal measured value (supplier)	31 36 30 32 30 30 30 33 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00
    ENG117285-ENG115839	Cycle_Protection_Counter-central_locking_cycle_protection_counter	0
    ENG117285-ENG115840	Cycle_Protection_Counter-general_cycle_protection_counter	0
    ENG117285-ENG124947	Cycle_Protection_Counter-last_wake_up	keine Stoerschutzursache
    ENG116908-ENG115779	Ecu_Intern_Meas._Values_2-Betriebsstunden_Abblendlicht_an	0	 H
    ENG116908-ENG115778	Ecu_Intern_Meas._Values_2-Hours_of_operation	0	 H
    ENG116908-ENG115775	Ecu_Intern_Meas._Values_2-Hours_of_operation_front_window_wiper	0
    ENG116908-ENG115776	Ecu_Intern_Meas._Values_2-Number of_the_wisp_cycles_front_window_wiper	0
    ENG116908-ENG115777	Ecu_Intern_Meas._Values_2-Number of_the_wisp_cycles_rear_window_wiper	0
    ENG117286-ENG116724	Kopfraumheizung_Entwicklung-KRH_l_Error	not coded/not installed
    ENG117286-ENG116725	Kopfraumheizung_Entwicklung-KRH_l_Error_Gueltigkeit	not coded/not installed
    ENG117286-ENG116723	Kopfraumheizung_Entwicklung-KRH_l_Luefter_Error	not coded/not installed
    ENG117286-ENG116727	Kopfraumheizung_Entwicklung-KRH_l_PTC_Error	not coded/not installed
    ENG117286-ENG116726	Kopfraumheizung_Entwicklung-KRH_l_ResponseError	not coded/not installed
    ENG117286-ENG116730	Kopfraumheizung_Entwicklung-KRH_r_Error	not coded/not installed
    ENG117286-ENG116731	Kopfraumheizung_Entwicklung-KRH_r_Error_Gueltigkeit	not coded/not installed
    ENG117286-ENG116728	Kopfraumheizung_Entwicklung-KRH_r_Luefter_Error	not coded/not installed
    ENG117286-ENG116729	Kopfraumheizung_Entwicklung-KRH_r_PTC_Error	not coded/not installed
    ENG117286-ENG116732	Kopfraumheizung_Entwicklung-KRH_r_ResponseError	not coded/not installed
    ENG116909-ENG107391	LIN activity-LIN 1	active
    ENG116909-ENG107392	LIN activity-LIN 2	not coded/not installed
    ENG116909-ENG114948	LIN activity-LIN 3	not coded/not installed
    ENG116909-ENG114949	LIN activity-LIN 4	not coded/not installed
    ENG116909-ENG114950	LIN activity-LIN 5	not coded/not installed
    ENG116909-ENG114951	LIN activity-LIN 6	not coded/not installed
    ENG116793	Monitor 1	00 00 00 00 00 00 00 00
    ENG116802	Monitor 10	00 00 00 00 00 00 00 00
    ENG116794	Monitor 2	00 00 00 00 00 00 00 00
    ENG116795	Monitor 3	00 00 00 00 00 00 00 00
    ENG116796	Monitor 4	00 00 00 00 00 00 00 00
    ENG116797	Monitor 5	00 00 00 00 00 00 00 00
    ENG116798	Monitor 6	00 00 00 00 00 00 00 00
    ENG116799	Monitor 7	00 00 00 00 00 00 00 00
    ENG116800	Monitor 8	00 00 00 00 00 00 00 00
    ENG116801	Monitor 9	00 00 00 00 00 00 00 00
    ENG128380	Parametermonitor_0	82 14 64 64 A0 00 00 00 00 00 00 00 00 00 00 00 50 50 32 32 00 50 50 50 50 3E 3E 62 62 00 00 64 3C 01 21 21 0A 04 00 00 1E 0A 1E 1E 03 07 00 00 06 06 28 00 3C 03 1E 22 00 04 19 05 00 01 01 28 00 02 00 02 1E 64 05 B4 1E 00 00 00 00 00 26 1D 5A 96 02 05 0A 6E 96 05 00 00 00 00 00 00 00 00 0A 1E 3C 42 0F 00 00 00 00 00 00 00 00 00 00 00 64 0A 01 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 1E 5A 19 E1 32 01 0A 00 00 00 00 00 A0 00 00 00 A0 00 00 00 A0 06 0C 0A 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00
    ENG116806	Parametermonitor_1	00 00 00 00 00 00 00 05 00 00 00 00 00 00 14 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 64 64 64 64 64 64 00 64 64 64 64 64 64 64 64 3C 00 60 7E 7F 60 60 7E 60 60 60 7F 60 60 60 60 14 00 46 7E 7F 46 46 7E 46 46 46 7F 46 46 46 46 64 64 64 64 64 64 64 7E 64 64 64 64 64 64 64 64 64 64 64 64 64 64 64 7E 64 64 64 64 64 64 64 64 64 64 64 64 64 64 64 7E 64 64 64 64 64 64 64 64 64 64 64 64 64 64 64 7E 64 64 64 64 64 64 64 64 64 64 64 64 64 64 64 7E 64 64 64 64 64 64 64 64 64 64 64 64 64 64 64 7E 64 64 64 64 64 64 64 64 01 01 00 00 00 00 00 00 00 00 00 00 00 0A 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00
    ENG130145	Parametermonitor_10	00 5A 00 F0 05 05 05 2D 0F 32 32 0A 01 2C 14 01 03 0A 0A 05 01 02 05 01 09 00 9E 02 BC 5F 4B 41 06 9A A7 00 32 00 01 00 01 02 08 04 05 05 05 06 03 09 0A 07 07 FF FF FF 01 02 02 03 03 04 05 05 05 FF 01 01 01 01 01 01 01 01 01 FF 01 01 01 01 01 01 01 01 01 FF 02 01 03 03 04 06 07 05 FF FF 01 02 03 03 03 04 05 06 07 FF 00 00 00 00 00 00 28 12 10 0E 0C 0A 06 04 00 00 19 16 15 18 16 1D 15 16 14 14 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00
    ENG116807	Parametermonitor_2	0F 05 0A 00 16 00 00 14 28 14 00 14 32 5A 32 0A 1E 12 00 4B 0A 01 1E 5A 0F 3C 3C 05 0A 01 0A 78 00 FA 01 1C 00 0F 00 05 0A 14 03 02 00 19 64 00 64 1E 32 18 18 7D 28 05 28 28 7D 3C 3C 7D 7D 0A 19 3C 7D 2B 00 00 02 00 00 01 28 0A 28 19 0A 23 04 C8 FA 17 16 88 00 1E 05 00 01 C8 32 C8 14 00 5A 03 00 03 03 00 00 04 01 05 32 32 32 64 03 00 00 00 00 00 22 00 00 00 00 00 00 00 00 00 00 00 0F 14 50 78 32 3C 02 58 00 00 0A 6E 05 64 28 00 0A 06 05 02 0A 28 00 00 00 00 00 00 00 00 00 00 14 14 14 00 32 00 00 00 00 28 64 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00
    ENG116808-ENG115827	Parametermonitor_3-parameter_monitor_3_climatic	FF 02 32 00 3C FF 80 05 05 00 00 00 00 00 00 00 80 FF 02 32 3C 00 05 00 00 00 00 00 00 00 00 00 00 00 0A 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 02 0A 28 0F 1E 06 1E 0A 0B 0B 01 64 64 03 0A 05 01 0A 46 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00
    ENG116808-ENG115828	Parametermonitor_3-parameter_monitor_3_wiper	0A 00 00 19 19 00 03 06 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 1E 50 46 00 58 8B FF 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 0A 0A 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00
    ENG116809	Parametermonitor_4	04 04 14 1E 03 B4 00 0A 05 05 0A 4B 4B 32 0A 03 00 1E 32 05 14 00 00 00 00 00 00 00 00 00 00 00 01 02 02 01 0A 28 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 04 04 0C 78 04 04 0C 01 04 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 2A 3E 00 00 00 00 00 00 00 00 00 00 00 05 03 00 00 00 00 00 00 00 00 00 00 00 00 00 0A FF 04 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 03 03 0A 00 00 00 00 00 04 0A 00 00 00 00 00 00 00 00 00 00 00 00 00 00 04 32 28 00 00 00 00 00 05 05 3C 04 01 01 01 01 96 01 01 C8 01 01 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 FF FE FD FF 00 00 00 00 00 00 00 00 00 00 00 00 3C 14 37 28 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00
    ENG116810	Parametermonitor_5	0A 00 0C 08 09 0A 05 0A 0A 14 08 0A 03 00 0A 00 00 00 02 00 00 00 00 00 00 00 00 00 00 00 00 00 04 00 04 00 00 1E 0A 05 01 01 00 00 00 00 00 00 00 00 00 00 00 00 00 46 00 03 09 01 05 00 00 00 00 00 00 0A 0F 0F 00 00 60 06 16 06 19 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00
    ENG116811	Parametermonitor_6	00 46 32 FA 3C 00 1E 32 05 04 3C 00 08 05 01 00 01 00 00 00 05 0A 50 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 01 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00
    ENG116911	Parametermonitor_7	00 0A 00 0A 00 0A FF FF 00 0A 00 0A FF FF FF FF 0F A0 00 32 00 32 00 32 00 32 00 32 00 0A 00 0A 00 32 FF FE 00 0A 00 32 00 32 00 00 00 0A 00 0A 00 00 FF FF 00 00 00 00 FF FF 00 00 00 00 00 00 00 00 00 0A 00 04 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00
    ENG116812	Parametermonitor_FF	00 00 05 30 30 00 0A 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00
    ENG126653-MAS00107	Personalized_Account_Key_History-Month	8
    ENG126653-MAS00108	Personalized_Account_Key_History-Day	26
    ENG126653-MAS00109	Personalized_Account_Key_History-Hours	9
    ENG126653-MAS00110	Personalized_Account_Key_History-Minutes	18
    ENG126653-MAS01551	Personalized_Account_Key_History-Key number	1
    ENG126653-ENG28771	Personalized_Account_Key_History-Account	2
    ENG126652-MAS03692	Personalized_key__Setting-Key 1	1
    ENG126652-MAS03693	Personalized_key__Setting-Key 2	1
    ENG126652-MAS03694	Personalized_key__Setting-Key 3	0
    ENG126652-MAS03695	Personalized_key__Setting-Key 4	0
    ENG126652-MAS03696	Personalized_key__Setting-Key 5	0
    ENG126652-MAS03697	Personalized_key__Setting-Key 6	0
    ENG126652-MAS03698	Personalized_key__Setting-Key 7	0
    ENG126654-MAS00107	Personalized_Signals-Month	8
    ENG126654-MAS00108	Personalized_Signals-Day	26
    ENG126654-MAS00109	Personalized_Signals-Hours	9
    ENG126654-MAS00110	Personalized_Signals-Minutes	18
    ENG126654-ENG30061	Personalized_Signals-Perso_Aktiv	1
    ENG126654-ENG28925	Personalized_Signals-Perso_Bedienstelle	0
    ENG126654-ENG28926	Personalized_Signals-Perso_Freigabe_Verstellung	0
    ENG126654-ENG28772	Personalized_Signals-Perso_Konto	2
    ENG126654-ENG28775	Personalized_Signals-Perso_Status	1
    ENG126654-ENG28773	Personalized_Signals-Perso_Steuerung	0
    ENG126654-ENG28774	Personalized_Signals-Perso_Steuerungs_parameter	0
    ENG116792-ENG115817	Power up history-Funktionsanforderung	1
    ENG130589-MAS16304	Remotestart_Monitor-Number of driver takeovers from RemoteStart	0
    ENG130589-MAS16305	Remotestart_Monitor-Number of duplicate activations	0
    ENG130589-MAS16306	Remotestart_Monitor-Number of incorrect takeovers	0
    ENG130589-MAS16307	Remotestart_Monitor-Average running time: group 1	0
    ENG130589-MAS16308	Remotestart_Monitor-Average running time: group 2	0
    ENG130589-MAS16309	Remotestart_Monitor-Average running time: group 3	0
    ENG130589-MAS16333	Remotestart_Monitor-Number of RemoteStarts	0
    ENG130589-MAS16334	Remotestart_Monitor-RemoteStart cancellations counter	0
    ENG116790-MAS00711	Supply voltage history-Odometer reading	22	 km
    ENG116790-ENG115814	Supply voltage history-highest voltage ever measured	15.6	 V
    ENG116790-ENG115815	Supply voltage history-hoechste im letzten Fahrzyklus gemessen Batteriespannung	15	 V
    ENG116790-ENG115816	Supply voltage history-voltage measurement: intern	14.6	 V
    ENG116791	Temperatures	23.5	 °C
    ENG116907-IDE00020	Zusaetzliche Umgebungsdaten-Terminal 15 status	On
    ENG116907-IDE01716	Zusaetzliche Umgebungsdaten-Terminal 50 status	OFF
    ENG116907-IDE02515	Zusaetzliche Umgebungsdaten-Low beam	not activated
    ENG116907-IDE07956	Zusaetzliche Umgebungsdaten-redundant signal line	infinite
    ENG116907-MAS01957	Zusaetzliche Umgebungsdaten-Outside air temperature	23.5	 °C
    ENG116907-MAS02462	Zusaetzliche Umgebungsdaten-Automatic high beam assist	not activated
    ENG116907-MAS02788	Zusaetzliche Umgebungsdaten-CAN	On
    ENG116907-MAS03835	Zusaetzliche Umgebungsdaten-Parking light	not activated
    ENG116907-MAS04121	Zusaetzliche Umgebungsdaten-Voltage	14.6	 V
    ENG116907-MAS06466	Zusaetzliche Umgebungsdaten-Parking light left	not activated
    ENG116907-MAS06467	Zusaetzliche Umgebungsdaten-Parking light right	not activated
    ENG116907-ENG124952	Zusaetzliche Umgebungsdaten-last_wakeup	keine Stoerschutzursache
    ENG116907-ENG09169	Zusaetzliche Umgebungsdaten-LDS 0-Stellung	operated
    ENG116907-ENG115838	Zusaetzliche Umgebungsdaten-Status Bremslichtschalter (CAN)	OFF
    ENG116907-ENG115837	Zusaetzliche Umgebungsdaten-Status Bremslichtschalter (HW)	OFF
    Elapsed Time: 00:41
    United States
    15-Airbags
    adpmap-15-5Q0-959-655-J_3VWH17AU5JM758941-20180826-1119.CSV
    ;SW:5Q0-959-655-J   HW:5Q0-959-655-J ---  Airbags
    ;Component:AirbagVW20    010 0830	 Coding:8CCCFC00000000005000001AC24800000065
    ;EV_AirbaVW20SMEVW37X	2144	EV_AirbaVW20SMEVW37X.rod
    ;Sunday	26	August	2018	11:19:10:04045
    ;VCID: 47C851756F2D08EF108-8012
    IDE06314-Calibration data: pre-crash	00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 	18
    MAS00975-IDE01755-Airbag adaptations-Rollover protection system	not defined 	8
    MAS00975-IDE02852-Airbag adaptations-Igniter for battery interrupt: high voltage battery	not defined 	8
    MAS00975-MAS00001-Airbag adaptations-Driver airbag igniter	activated 	8
    MAS00975-MAS00003-Airbag adaptations-Passenger airbag igniter	activated 	8
    MAS00975-MAS00005-Airbag adaptations-Driver thorax airbag igniter	activated 	8
    MAS00975-MAS00006-Airbag adaptations-Front passenger side airbag igniter	activated 	8
    MAS00975-MAS00007-Airbag adaptations-Driver side rear thorax airbag igniter	not defined 	8
    MAS00975-MAS00008-Airbag adaptations-Passenger side rear thorax airbag igniter	not defined 	8
    MAS00975-MAS00009-Airbag adaptations-Driver head curtain airbag igniter	activated 	8
    MAS00975-MAS00010-Airbag adaptations-Front passenger head curtain airbag igniter	activated 	8
    MAS00975-MAS00011-Airbag adaptations-Driver knee airbag igniter	not defined 	8
    MAS00975-MAS00012-Airbag adaptations-Front passenger knee airbag igniter	not defined 	8
    MAS00975-MAS00013-Airbag adaptations-Driver side seat belt tension igniter	activated 	8
    MAS00975-MAS00014-Airbag adaptations-Front passenger side seat belt tension igniter	activated 	8
    MAS00975-MAS00019-Airbag adaptations-Driver side rear safety belt tension igniter	not defined 	8
    MAS00975-MAS00020-Airbag adaptations-Passenger side rear safety belt tension igniter	not defined 	8
    MAS00975-MAS00022-Airbag adaptations-Igniter for battery interrupt	not defined 	8
    MAS00975-MAS00030-Airbag adaptations-Seat occupied recognition	not defined 	8
    MAS00975-MAS00079-Airbag adaptations-Key switch	Airbag deactivation key switch not parameterized 	8
    MAS00975-MAS00478-Airbag adaptations-Reserved	2	8
    MAS00975-MAS01503-Airbag adaptations-Pedestrian protection igniter engine hood	not defined 	8
    Elapsed Time: 00:03
    blockmap-15-5Q0-959-655-J_3VWH17AU5JM758941-20180826-1118.CSV
    ;Sunday	26	August	2018	11:18:59:04045
    IDE00821	Safety belt switch 2nd row driver side	not installed
    IDE00822	Safety belt switch 2nd row frt.passenger side	not installed
    IDE00823	Safety belt switch 2nd row center	not installed
    IDE00824	Driver side 3rd row seat belt switch	not installed
    IDE00825	Passenger side 3rd row seat belt switch	not installed
    IDE00919	Driver side airbag igniter ohm value	3.1	 Ohm
    IDE00956	Occupation status: frt.passenger seat	Adult
    IDE01100	Passenger side airbag igniter ohm value	2.3	 Ohm
    IDE01101	Passenger side airbag igniter 2 ohm value	2.2	 Ohm
    IDE01102	Driver's side airbag igniter ohm value	2.5	 Ohm
    IDE01103	Passenger side side airbag igniter ohm value	2.5	 Ohm
    IDE01104	driver side rear airbag igniter ohm value	no measured value present
    IDE01105	Ft. pass.side rear airbag igniter ohm value	no measured value present
    IDE01106	Driver side head curtain airbag igniter ohm value	2.4	 Ohm
    IDE01107	Frt.pass. side head curtain airbag igniter ohm value	2.4	 Ohm
    IDE01108	Driver side knee airbag igniter ohm value	no measured value present
    IDE01109	Frt.pass. side knee airbag igniter ohm value	no measured value present
    IDE01110	Driver side belt tensioner igniter ohm value	2.4	 Ohm
    IDE01111	Frt.pass. side belt tensioner igniter ohm value	2.4	 Ohm
    IDE01112	Driver side belt tensioner igniter 2 ohm value	2.2	 Ohm
    IDE01113	Frt.pass. side belt tensioner igniter 2 ohm value	2.3	 Ohm
    IDE01114	Driver side belt force limiter igniter ohm value	2.4	 Ohm
    IDE01115	side belt force limiter igniter ohm value	2.4	 Ohm
    IDE01116	driver side rear belt tensioner igniter ohm value	no measured value present
    IDE01117	Passenger side rear belt tensioner igniter ohm value	no measured value present
    IDE01119	Battery open circuit igniter ohm value	no measured value present
    IDE01193	Driver belt tensioner ohm value	too Low
    IDE01194	Frt.pass. belt tensioner ohm value	too Low
    IDE01195	Front passenger side seat occupancy detection: Ohm value	no measured value present
    IDE01197	Key switch contact 1 ohm value	too High
    IDE01198	Key switch contact 2 ohm value	too High
    IDE01200	Driver seat position sensor current value	6.1	 mA
    IDE01201	Frt.pass. seat position sensor current value	6	 mA
    IDE01205	Safety belt switch 2nd row driver side ohm value	no measured value present
    IDE01206	Safety belt switch 2nd row frt.pass. side ohm value	no measured value present
    IDE01207	Safety belt switch center 2nd row ohm value	no measured value present
    IDE01208	Seat belt switch 3rd row driver side ohm value	no measured value present
    IDE01209	Seat belt switch 3rd row frt.pass. side ohm value	no measured value present
    IDE01271	Number of rollover bar deployments	0
    IDE01555	Number of frontal crashes	0
    IDE01556	Number of side crashes driver side	0
    IDE01557	Number of side crashes frt.pass. side	0
    IDE01558	Number of rear crashes	0
    IDE01559	Number of rollover crashes	0
    IDE02246	Number of activations of pedestrian protection	0
    IDE02852	Igniter for battery interrupt: high voltage battery	not installed
    IDE02853	Igniter for batt. interrupt: high volt. batt. ohm value	no measured value present
    IDE03870	Seat occupied recognition malfunction status	0
    IDE06959	Seat occupant detection: diagnosis signal	33.5	 %
    IDE06960	Seat occupant detection: msmt. signal	17	 %
    IDE06961	Seat occupant detection: ref. signal	2	 %
    MAS00001	Driver airbag igniter	correct
    MAS00003	Passenger airbag igniter	correct
    MAS00004	Front passenger airbag igniter 2	correct
    MAS00005	Driver thorax airbag igniter	correct
    MAS00006	Front passenger side airbag igniter	correct
    MAS00007	Driver side rear thorax airbag igniter	cannot be measured currently
    MAS00008	Passenger side rear thorax airbag igniter	cannot be measured currently
    MAS00009	Driver head curtain airbag igniter	correct
    MAS00010	Front passenger head curtain airbag igniter	correct
    MAS00011	Driver knee airbag igniter	cannot be measured currently
    MAS00012	Front passenger knee airbag igniter	cannot be measured currently
    MAS00013	Driver side seat belt tension igniter	correct
    MAS00014	Front passenger side seat belt tension igniter	correct
    MAS00015	Driver seat belt tensioner igniter 2	correct
    MAS00016	Front passenger side seat belt tensioner igniter 2	correct
    MAS00017	Driver side belt force limiter igniter	correct
    MAS00018	Front passenger side belt force limiter igniter	correct
    MAS00019	Driver side rear safety belt tension igniter	cannot be measured currently
    MAS00020	Passenger side rear safety belt tension igniter	cannot be measured currently
    MAS00022	Igniter for battery interrupt	cannot be measured currently
    MAS00025	Driver seat belt switch	not connected
    MAS00026	Front passenger side safety belt switch	not connected
    MAS00030	Seat occupied recognition	assigned
    MAS00031	Airbag deactivation status	On
    MAS00032	Key switch terminal 1	not installed
    MAS00033	Key switch terminal 2	not installed
    MAS00035	Seat position sensor: driver side	Rear
    MAS00036	Seat position sensor: front passenger side	Rear
    MAS00037	Calibration status	0
    MAS00044	Supply voltage: Terminal 15	14.5	 V
    MAS01634	Supply voltage	correct
    Elapsed Time: 00:10
  10. #8
    United States
    16-Steering wheel
    adpmap-16-5Q0-953-507-GH_3VWH17AU5JM758941-20180826-1119.CSV
    ;SW:5Q0-953-507-GH   HW:5Q0-953-549-E ---  Steering wheel
    ;Component:Lenks. Modul  003 0140	 Coding:0410
    ;EV_SMLSKLOMQB	20002	EV_SMLSKLOMQB_VW37.rod
    ;Sunday	26	August	2018	11:19:20:04045
    ;VCDS Version: Beta 18.7.2 (x64)  Data version: 20180808 DS295.0
    ;VCID: 025E8061048FEDC7876-8056
    ENG126411-p_k_i	0.040 %/s	1
    ENG126415-p_k_i_offset	4 K	1
    ENG126410-p_k_p	13.00%	1
    ENG126419-p_leistung_lrh	110 W	1
    ENG126417-p_n_fehler_p_verriegelt	250	1
    ENG120504-p_s_NWDF_spg	0	1
    ENG102189-p_t_blinker_entprellen	40 ms	1
    ENG102332-p_t_blinker_err_el_kurzschluss	200 ms	1
    ENG104011-p_t_blinker_err_el_unterbrechung	1000 ms	1
    ENG120503-p_t_blinker_err_fernlicht_haengt_aus	5000 ms	1
    ENG120502-p_t_blinker_err_fernlicht_haengt_ein	300 s	1
    ENG104185-p_t_blinker_err_gra_haengt_aus	5000 ms	1
    ENG100988-p_t_blinker_err_gra_haengt_ein	300 s	1
    ENG103202-p_t_blinker_err_lichthupe_haengt_aus	5000 ms	1
    ENG100154-p_t_blinker_err_lichthupe_haengt_ein	300 s	1
    ENG100923-p_t_blinker_err_unplausibel	200 ms	1
    ENG103471-p_t_blinker_gra_entprellen	40 ms	1
    ENG101294-p_t_blinker_sperrzeit	100 ms	1
    ENG127114-p_t_entprellung_p_unplausibel	400 ms	1
    ENG104033-p_t_entprellzeit_ueberspannung	90000 ms	1
    ENG101392-p_t_entprellzeit_unterspannung	90000 ms	1
    ENG102689-p_t_fas_entprellen	40 ms	1
    ENG120505-p_t_gra_ea_error	200 ms	1
    ENG101014-p_t_grahebel_entprellen	40 ms	1
    ENG104117-p_t_grahebel_err_el_kurzschluss	200 ms	1
    ENG102950-p_t_grahebel_err_el_unterbrechung	1000 ms	1
    ENG103784-p_t_grahebel_err_gra_haengt_aus	5000 ms	1
    ENG102546-p_t_grahebel_err_gra_haengt_ein	300 s	1
    ENG103536-p_t_grahebel_err_unplausibel	200 ms	1
    ENG126416-p_t_grenze_v	10 km/h	1
    ENG99436-p_t_hupe_entprellen	40 ms	1
    ENG102496-p_t_hupe_err_hinweis	2000 ms	1
    ENG101071-p_t_hupe_err_hupe_haengt_aus	5000 ms	1
    ENG101518-p_t_hupe_err_hupe_haengt_ein	60 s	1
    ENG101702-p_t_hupe_indien_entprellen	500 ms	1
    ENG126421-p_t_lrh_kurzschluss_entprellen	200 ms	1
    ENG126422-p_t_lrh_unterbrechung_entprellen	1000 ms	1
    ENG103999-p_t_p_verriegelt_entprellen	40 ms	1
    ENG126412-p_t_soll_0	39 °C	1
    ENG126413-p_t_soll_1	43 °C	1
    ENG126414-p_t_soll_2	47 °C	1
    ENG100796-p_t_spannung_obere_schwelle	16.7 V	1
    ENG102338-p_t_spannung_untere_schwelle	8.5 V	1
    ENG100559-p_t_wischer_entprellen	40 ms	1
    ENG103039-p_t_wischer_err_el_kurzschluss	200 ms	1
    ENG101343-p_t_wischer_err_el_unterbrechung	1000 ms	1
    ENG108143-p_t_wischer_err_intervallpoti_haengt_aus	5000 ms	1
    ENG102443-p_t_wischer_err_intervallpoti_haengt_ein	300 s	1
    ENG101059-p_t_wischer_err_mfa_haengt_aus	5000 ms	1
    ENG100346-p_t_wischer_err_mfa_haengt_ein	300 s	1
    ENG103464-p_t_wischer_err_waschen_haengt_aus	5000 ms	1
    ENG100423-p_t_wischer_err_waschen_haengt_ein	300 s	1
    ENG99933-p_t_wischer_err_wischen_haengt_aus	5000 ms	1
    ENG102586-p_t_wischer_err_wischen_haengt_ein	300 s	1
    ENG101592-p_t_wischer_intervall_entprellen	40 ms	1
    ENG103607-p_t_wischer_winterstellung	60 s	1
    ENG126423-p_temp_lenkradheizung_aus	50 °C	1
    ENG126420-p_zeit_temperatur_statisch_lrh	300 s	1
    Elapsed Time: 00:26
    blockmap-16-5Q0-953-507-GH_3VWH17AU5JM758941-20180826-1119.CSV
    ;Sunday	26	August	2018	11:19:18:04045
    Group	Description	Actual
    IDE00030-ENG99298	Status of actuator test-State	not active
    IDE00323	Security Access: Number of invalid keys	0
    IDE00329-MAS00232	Buttons for multi-function display-MFI button UP	not coded/not installed
    IDE00329-MAS00233	Buttons for multi-function display-MFI button DOWN	not coded/not installed
    IDE00329-MAS00234	Buttons for multi-function display-MFI button RESET / OK	not coded/not installed
    IDE00329-MAS00236	Buttons for multi-function display-MFI buttons: number 3/4	not coded/not installed
    IDE00329-MAS00688	Buttons for multi-function display-Multifunction indicator	not coded/not installed
    IDE00333	Driver assistance systems button	not coded/not installed
    IDE00333-MAS00243	Driver assistance systems button-Buttons for driver assistance systems: status	not coded/not installed
    IDE00356-IDE00355	Cruise Control System (CCS): switch position-Cruise Control System (CCS): status	not coded/not installed
    IDE00356-MAS00125	Cruise Control System (CCS): switch position-Cruise control system	not coded/not installed
    IDE00356-MAS00128	Cruise Control System (CCS): switch position-Distance Regulation	not coded/not installed
    IDE00356-MAS00320	Cruise Control System (CCS): switch position-Main switch	not coded/not installed
    IDE00356-MAS00323	Cruise Control System (CCS): switch position-Decelerate tap	not coded/not installed
    IDE00356-MAS00324	Cruise Control System (CCS): switch position-Accelerate tap	not coded/not installed
    IDE00356-MAS00325	Cruise Control System (CCS): switch position-Setting	not coded/not installed
    IDE00356-MAS00326	Cruise Control System (CCS): switch position-Activation	not coded/not installed
    IDE00356-MAS02321	Cruise Control System (CCS): switch position-Cancel	not coded/not installed
    IDE00356-MAS02343	Cruise Control System (CCS): switch position-Station coding	not coded/not installed
    IDE00356-MAS03758	Cruise Control System (CCS): switch position-Not Used	not coded/not installed
    IDE00356-MAS04522	Cruise Control System (CCS): switch position-Delay tip level 2	not coded/not installed
    IDE00356-MAS04523	Cruise Control System (CCS): switch position-Accelerate tip level 2	not coded/not installed
    IDE00356-MAS05138	Cruise Control System (CCS): switch position-Control unit	Initializing
    IDE02486	Data logger triggering	not active
    IDE02588-IDE00020	Terminal signals and start release-Terminal 15 status	On
    IDE02588-IDE01715	Terminal signals and start release-Status terminal S	On
    IDE02588-IDE01716	Terminal signals and start release-Terminal 50 status	OFF
    IDE02693-IDE02335	Turn signals and parking lights-Signal light switch position	not activated
    IDE02694-MAS01288	Signal horn activation-Signal horn	not activated
    IDE02695-IDE01268	Front wiping: front washing-Windshield wiper	not activated
    IDE02695-MAS02338	Front wiping: front washing-Windshield wiper: intermittent stage	Stage 1
    IDE02695-MAS02339	Front wiping: front washing-Windshield washer system	not activated
    IDE02696-IDE02711	Rear wiping: rear washing-Rear Window Wiper	not activated
    IDE02696-MAS02341	Rear wiping: rear washing-Rear window washer system	not activated
    IDE02743	High Beam	not activated
    IDE02744-MAS01632	Steering wheel heater-Status	OFF
    IDE02744-MAS04136	Steering wheel heater-Current	0	 A
    IDE02744-MAS09022	Steering wheel heater-PWM value	0	 %
    IDE02744-MAS09758	Steering wheel heater-Temperature sensor	-50	 °C
    IDE02745-IDE00096	Ignition key removal lock-Selector lever position	Current
    IDE02745-MAS08202	Ignition key removal lock-CAN p locked	Engaged and locked
    IDE02745-MAS08203	Ignition key removal lock-CAN p locked: qualified	Not qualified
    IDE02745-MAS08204	Ignition key removal lock-Hardware input: p_verriegelt	Open
    IDE02745-MAS08205	Ignition key removal lock-CAN ESP valid speed	Qualified
    IDE02745-MAS08206	Ignition key removal lock-CAN ESP speed	0	 km/h
    IDE02745-MAS08207	Ignition key removal lock-CAN GWB obsolete transmission	Current
    ENG120506-ENG100300	CCS_in_indic-lever-E: Blinkerhebel GRA Cancel	not activated
    ENG120506-ENG103377	CCS_in_indic-lever-E: Blinkerhebel GRA Fehler	No malfunction detected
    ENG120506-ENG103714	CCS_in_indic-lever-E: Blinkerhebel GRA OFF	not activated
    ENG120506-ENG102330	CCS_in_indic-lever-E: Blinkerhebel GRA ON	not activated
    ENG120506-ENG120475	CCS_in_indic-lever-E: Blinkerhebel GRA Speedlimiter	OFF
    ENG120506-ENG103991	CCS_in_indic-lever-E: Blinkerhebel GRA Tip Resume/Plus	not activated
    ENG120506-ENG100605	CCS_in_indic-lever-E: Blinkerhebel GRA Tip Set/Minus	not activated
    ENG120506-ENG120476	CCS_in_indic-lever-E: GRA_E_A	OFF
    ENG120507-ENG100163	CCS_in_third_lever-E: 3.ter Hebel ADR Fehler	No malfunction detected
    ENG120507-ENG99937	CCS_in_third_lever-E: 3.ter Hebel ADR Minus	not activated
    ENG120507-ENG101800	CCS_in_third_lever-E: 3.ter Hebel ADR Plus	not activated
    ENG120507-ENG101234	CCS_in_third_lever-E: 3.ter Hebel GRA Cancel	not activated
    ENG120507-ENG103820	CCS_in_third_lever-E: 3.ter Hebel GRA Fehler	No malfunction detected
    ENG120507-ENG99143	CCS_in_third_lever-E: 3.ter Hebel GRA OFF	not activated
    ENG120507-ENG100333	CCS_in_third_lever-E: 3.ter Hebel GRA ON	not activated
    ENG120507-ENG101903	CCS_in_third_lever-E: 3.ter Hebel GRA Resume	not activated
    ENG120507-ENG101230	CCS_in_third_lever-E: 3.ter Hebel GRA Set	not activated
    ENG120507-ENG129309	CCS_in_third_lever-E: 3.ter Hebel GRA Speedlimiter	not activated
    ENG120507-ENG126425	CCS_in_third_lever-E: 3.ter Hebel GRA Tip 2 Beschleunigen	not activated
    ENG120507-ENG126426	CCS_in_third_lever-E: 3.ter Hebel GRA Tip 2 Verzögern	not activated
    ENG120507-ENG120477	CCS_in_third_lever-E: 3.ter Hebel GRA Tip Beschleunigen	not activated
    ENG120507-ENG120478	CCS_in_third_lever-E: 3.ter Hebel GRA Tip Verzögern	not activated
    ENG120507-ENG120476	CCS_in_third_lever-E: GRA_E_A	OFF
    ENG126424-ENG126428	LRH-LRH_current	0	 A
    ENG126424-ENG126430	LRH-LRH_level	Middle
    ENG126424-ENG126429	LRH-LRH_status	OFF
    ENG126424-ENG126427	LRH-LRH_temperature_NTC	204	 °C
    Elapsed Time: 00:02
  11. #9
    United States
    17-Instruments
    adpmap-17-5G1-920-840-C_3VWH17AU5JM758941-20180826-1111.CSV
    ;SW:5G1-920-840-C   HW:5G1-920-840-C ---  Instruments
    ;Component:KOMBI         242 0310	 Coding:0BB4100DA180CF0502082B001000000000000000
    ;EV_DashBoardVDDMQBAB	9060	EV_DashBoardVDDMQBAB_009_VW37.rod
    ;Sunday	26	August	2018	11:11:45:04045
    ;VCID: 2708F1F5CF6DE8EFF08-8072
    IDE00295-Oil temperature display	OFF 	1
    IDE00301-Distance	138 km	3
    IDE00342-ESI: Resetting ESI	no warning 	1
    IDE00343-Language version	US English 	1
    IDE00345-MAS00234-MFA3-Reset-MFI button RESET / OK	Manual reset: not possible 	3
    IDE00345-MAS05463-MFA3-Reset-Refuel detection gasoline / diesel	MFA3-Reset 	3
    IDE00345-MAS05464-MFA3-Reset-Refuel detection gas	MFA3-Reset 	3
    IDE00345-MAS12879-MFA3-Reset-Electrical refueling detection	MFA3-Reset 	3
    IDE00499-Display correction of consumptions and operating range	100%	1
    IDE00500-Hour	11 H	1
    IDE00501-Minute	11 min	1
    IDE00502-Year	2018 yr	2
    IDE00503-Month	8 mon	1
    IDE00504-Day	26 d	1
    IDE00510-ESI: distance driven from inspection	138 km	3
    IDE00511-ESI: time from inspection	303 d	2
    IDE00512-ESI: minimum value km-driving distance/inspection	15000 km	2
    IDE00513-ESI: maximum value km-driving distance/inspection	30000 km	2
    IDE00514-ESI: maximum value of time between inspections	730 d	2
    IDE00515-ESI: oil quality	poor oil quality 	1
    IDE00517-ESI: soot entry	0 km	2
    IDE00518-ESI: thermal load	1100 km	2
    IDE00819-Day counter	302 d	2
    IDE00820-Activating and deactivating all development messages	not active 	1
    IDE00827-ESI: minimum value of time between inspections	365 d	2
    IDE01153-SIA: maximum value of distance to service	16100 km	2
    IDE01154-SIA: maximum value of time to service	365 d	2
    IDE02489-Display depiction	Version 1 	1
    IDE02818-IDE02689-Offset for tank calibration values-Complete tank calibration	-12.8 l	5
    IDE02818-MAS02376-Offset for tank calibration values-Offset sensor 1	-12.8 l	5
    IDE02818-MAS02377-Offset for tank calibration values-Offset sensor 2	-12.8 l	5
    IDE02818-MAS02378-Offset for tank calibration values-Offset sensor 3	12.7 l	5
    IDE02818-MAS02379-Offset for tank calibration values-Offset sensor 4	12.7 l	5
    IDE03329-Driving profiled for range remaining	8.6 l/100km	2
    IDE03346-IDE00301-Units adjusted-Distance	Kilometers 	3
    IDE03346-MAS01230-Units adjusted-Date	mm_dd_yy 	3
    IDE03346-MAS01456-Units adjusted-Speed	Kilometers per hour 	3
    IDE03346-MAS02201-Units adjusted-Temperature	Degrees Celsius 	3
    IDE03346-MAS02957-Units adjusted-Time	12h AM_PM 	3
    IDE03346-MAS03032-Units adjusted-Volume	Liter 	3
    IDE03346-MAS03034-Units adjusted-Pressure	bar 	3
    IDE03346-MAS05637-Units adjusted-Operating range consumption: CNG (compressed natural gas)	kg per 100 km 	3
    IDE03346-MAS05638-Units adjusted-Consumption gasoline / diesel - LPG (liquefied petroleum gas)	Liters per 100 km 	3
    IDE03346-MAS05875-Units adjusted-Average consumption: electric drive	kWh per 100 km 	3
    IDE03346-MAS13665-Units adjusted-Trailer/support load ground	kilogram (kg) 	3
    IDE03348-MAS01456-Speed warning-Speed	0	2
    IDE03348-MAS01561-Speed warning-Unit	Kilometers per hour 	2
    IDE03348-Speed warning-	not active 	2
    IDE03349-FIX: Max. distance until next mileage-related inspection	32200 km	2
    IDE03350-FIX: Maximum time until next time-dependent inspection	730 d	2
    IDE03351-FIX: Distance covered since last mileage-dependent inspection	100 km	2
    IDE03352-FIX: Time since last time-dependent inspection	303 d	2
    IDE03372-Source for synchronization of time	internal clock 	1
    IDE03568-ENG119828-Service-key settings-p_deactivate_SK_Function	On 	5
    IDE03568-ENG99943-Service-key settings-p_forcewrite_qual_time	10 s	5
    IDE03568-ENG119827-Service-key settings-p_main_switch_Basic	On 	5
    IDE03568-ENG102414-Service-key settings-p_main_switch_keyless	On 	5
    IDE03568-ENG102611-Service-key settings-p_write_delay_speed	20 km/h	5
    IDE03568-ENG103545-Service-key settings-p_write_delay_time	40 s	5
    IDE03568-ENG104099-Service-key settings-p_write_distance	20 km	5
    IDE03867-Deactivate seat belt warning	No 	1
    IDE05930-Service notification in days	30 d	1
    IDE05931-FIX: Reset value for next mileage-dependent inspection	32200 km	2
    IDE05932-FIX: Reset value for next time-dependent inspections	730 d	2
    IDE05971-Vehicle Positioning System Interface Control Module	not installed 	1
    IDE06425-Roller test bench mode: functional	not activated 	1
    IDE06588-Ignition active message: actuator	Driver door 	1
    IDE06922-No-voltage display	Unknown (2)	1
    IDE07221-Cylinder shut-off	Display 	1
    IDE11086-Service notification	30 d	1
    IDE12226-MAS03686-Display of longitudinal regulation coordinator-Automatic distance regulation	not active 	1
    IDE12226-MAS05203-Display of longitudinal regulation coordinator-CCS	not active 	1
    IDE12226-MAS10720-Display of longitudinal regulation coordinator-Speed limiter	not active 	1
    MAS03685-Digital speedometer	Display 	1
    ENG117917-BAP_Debug_Mode_Release	not_released 	1
    ENG119877-ENG98401-Configuration of Development CAN-Messages-Block 1	OFF 	20
    ENG119877-ENG98402-Configuration of Development CAN-Messages-Block 10	OFF 	20
    ENG119877-ENG98445-Configuration of Development CAN-Messages-Block 11	OFF 	20
    ENG119877-ENG98403-Configuration of Development CAN-Messages-Block 12	OFF 	20
    ENG119877-ENG98446-Configuration of Development CAN-Messages-Block 13	OFF 	20
    ENG119877-ENG98447-Configuration of Development CAN-Messages-Block 14	OFF 	20
    ENG119877-ENG98448-Configuration of Development CAN-Messages-Block 15	OFF 	20
    ENG119877-ENG98404-Configuration of Development CAN-Messages-Block 16	OFF 	20
    ENG119877-ENG98449-Configuration of Development CAN-Messages-Block 17	OFF 	20
    ENG119877-ENG98450-Configuration of Development CAN-Messages-Block 18	OFF 	20
    ENG119877-ENG98451-Configuration of Development CAN-Messages-Block 19	OFF 	20
    ENG119877-ENG98452-Configuration of Development CAN-Messages-Block 2	OFF 	20
    ENG119877-ENG98405-Configuration of Development CAN-Messages-Block 20	OFF 	20
    ENG119877-ENG98453-Configuration of Development CAN-Messages-Block 21	OFF 	20
    ENG119877-ENG98406-Configuration of Development CAN-Messages-Block 22	OFF 	20
    ENG119877-ENG98454-Configuration of Development CAN-Messages-Block 23	OFF 	20
    ENG119877-ENG98455-Configuration of Development CAN-Messages-Block 24	OFF 	20
    ENG119877-ENG98456-Configuration of Development CAN-Messages-Block 25	OFF 	20
    ENG119877-ENG98407-Configuration of Development CAN-Messages-Block 26	OFF 	20
    ENG119877-ENG98457-Configuration of Development CAN-Messages-Block 27	OFF 	20
    ENG119877-ENG98458-Configuration of Development CAN-Messages-Block 28	OFF 	20
    ENG119877-ENG98459-Configuration of Development CAN-Messages-Block 29	OFF 	20
    ENG119877-ENG98408-Configuration of Development CAN-Messages-Block 3	OFF 	20
    ENG119877-ENG98409-Configuration of Development CAN-Messages-Block 30	OFF 	20
    ENG119877-ENG125180-Configuration of Development CAN-Messages-Block 31	OFF 	20
    ENG119877-ENG125181-Configuration of Development CAN-Messages-Block 32	OFF 	20
    ENG119877-ENG125182-Configuration of Development CAN-Messages-Block 33	OFF 	20
    ENG119877-ENG125183-Configuration of Development CAN-Messages-Block 34	OFF 	20
    ENG119877-ENG125184-Configuration of Development CAN-Messages-Block 35	OFF 	20
    ENG119877-ENG125185-Configuration of Development CAN-Messages-Block 36	OFF 	20
    ENG119877-ENG125186-Configuration of Development CAN-Messages-Block 37	OFF 	20
    ENG119877-ENG125187-Configuration of Development CAN-Messages-Block 38	OFF 	20
    ENG119877-ENG125188-Configuration of Development CAN-Messages-Block 39	OFF 	20
    ENG119877-ENG98410-Configuration of Development CAN-Messages-Block 4	OFF 	20
    ENG119877-ENG98460-Configuration of Development CAN-Messages-Block 5	OFF 	20
    ENG119877-ENG98461-Configuration of Development CAN-Messages-Block 6	OFF 	20
    ENG119877-ENG98462-Configuration of Development CAN-Messages-Block 7	OFF 	20
    ENG119877-ENG98411-Configuration of Development CAN-Messages-Block 8	OFF 	20
    ENG119877-ENG98463-Configuration of Development CAN-Messages-Block 9	OFF 	20
    ENG119875-defuel_threshold	9 l	1
    ENG105831-ENG101574-dimming_characteristic_curve_adjustment_clock_dial_day-X1	0	12
    ENG105831-ENG99557-dimming_characteristic_curve_adjustment_clock_dial_day-X2	32	12
    ENG105831-ENG102140-dimming_characteristic_curve_adjustment_clock_dial_day-X3	66	12
    ENG105831-ENG102936-dimming_characteristic_curve_adjustment_clock_dial_day-X4	96	12
    ENG105831-ENG103548-dimming_characteristic_curve_adjustment_clock_dial_day-X5	DC 	12
    ENG105831-ENG113992-dimming_characteristic_curve_adjustment_clock_dial_day-X6	FD 	12
    ENG105831-ENG99777-dimming_characteristic_curve_adjustment_clock_dial_day-Y1	0	12
    ENG105831-ENG100480-dimming_characteristic_curve_adjustment_clock_dial_day-Y2	0	12
    ENG105831-ENG100773-dimming_characteristic_curve_adjustment_clock_dial_day-Y3	0	12
    ENG105831-ENG100631-dimming_characteristic_curve_adjustment_clock_dial_day-Y4	5	12
    ENG105831-ENG102174-dimming_characteristic_curve_adjustment_clock_dial_day-Y5	14	12
    ENG105831-ENG113993-dimming_characteristic_curve_adjustment_clock_dial_day-Y6	64	12
    ENG105832-ENG101574-dimming_characteristic_curve_adjustment_clock_dial_night-X1	0	12
    ENG105832-ENG99557-dimming_characteristic_curve_adjustment_clock_dial_night-X2	0A 	12
    ENG105832-ENG102140-dimming_characteristic_curve_adjustment_clock_dial_night-X3	32	12
    ENG105832-ENG102936-dimming_characteristic_curve_adjustment_clock_dial_night-X4	64	12
    ENG105832-ENG103548-dimming_characteristic_curve_adjustment_clock_dial_night-X5	96	12
    ENG105832-ENG113992-dimming_characteristic_curve_adjustment_clock_dial_night-X6	FD 	12
    ENG105832-ENG99777-dimming_characteristic_curve_adjustment_clock_dial_night-Y1	2	12
    ENG105832-ENG100480-dimming_characteristic_curve_adjustment_clock_dial_night-Y2	2	12
    ENG105832-ENG100773-dimming_characteristic_curve_adjustment_clock_dial_night-Y3	0E 	12
    ENG105832-ENG100631-dimming_characteristic_curve_adjustment_clock_dial_night-Y4	1E 	12
    ENG105832-ENG102174-dimming_characteristic_curve_adjustment_clock_dial_night-Y5	32	12
    ENG105832-ENG113993-dimming_characteristic_curve_adjustment_clock_dial_night-Y6	64	12
    ENG105834-ENG101574-dimming_characteristic_curve_adjustment_gauge-X1	0	12
    ENG105834-ENG99557-dimming_characteristic_curve_adjustment_gauge-X2	0A 	12
    ENG105834-ENG102140-dimming_characteristic_curve_adjustment_gauge-X3	32	12
    ENG105834-ENG102936-dimming_characteristic_curve_adjustment_gauge-X4	64	12
    ENG105834-ENG103548-dimming_characteristic_curve_adjustment_gauge-X5	DC 	12
    ENG105834-ENG113992-dimming_characteristic_curve_adjustment_gauge-X6	FD 	12
    ENG105834-ENG99777-dimming_characteristic_curve_adjustment_gauge-Y1	3	12
    ENG105834-ENG100480-dimming_characteristic_curve_adjustment_gauge-Y2	3	12
    ENG105834-ENG100773-dimming_characteristic_curve_adjustment_gauge-Y3	10	12
    ENG105834-ENG100631-dimming_characteristic_curve_adjustment_gauge-Y4	1E 	12
    ENG105834-ENG102174-dimming_characteristic_curve_adjustment_gauge-Y5	55	12
    ENG105834-ENG113993-dimming_characteristic_curve_adjustment_gauge-Y6	64	12
    ENG105835-ENG101574-dimming_characteristic_curve_adjustment_indicator_lights-X1	0	12
    ENG105835-ENG99557-dimming_characteristic_curve_adjustment_indicator_lights-X2	0A 	12
    ENG105835-ENG102140-dimming_characteristic_curve_adjustment_indicator_lights-X3	32	12
    ENG105835-ENG102936-dimming_characteristic_curve_adjustment_indicator_lights-X4	64	12
    ENG105835-ENG103548-dimming_characteristic_curve_adjustment_indicator_lights-X5	96	12
    ENG105835-ENG113992-dimming_characteristic_curve_adjustment_indicator_lights-X6	FD 	12
    ENG105835-ENG99777-dimming_characteristic_curve_adjustment_indicator_lights-Y1	5	12
    ENG105835-ENG100480-dimming_characteristic_curve_adjustment_indicator_lights-Y2	5	12
    ENG105835-ENG100773-dimming_characteristic_curve_adjustment_indicator_lights-Y3	0C 	12
    ENG105835-ENG100631-dimming_characteristic_curve_adjustment_indicator_lights-Y4	17	12
    ENG105835-ENG102174-dimming_characteristic_curve_adjustment_indicator_lights-Y5	32	12
    ENG105835-ENG113993-dimming_characteristic_curve_adjustment_indicator_lights-Y6	64	12
    ENG119878-ENG101574-dimming_characteristic_curve_adjustment_internal_phototransistor-X1	00 00 	20
    ENG119878-ENG99557-dimming_characteristic_curve_adjustment_internal_phototransistor-X2	00 32 	20
    ENG119878-ENG102140-dimming_characteristic_curve_adjustment_internal_phototransistor-X3	00 64 	20
    ENG119878-ENG102936-dimming_characteristic_curve_adjustment_internal_phototransistor-X4	00 C8 	20
    ENG119878-ENG103548-dimming_characteristic_curve_adjustment_internal_phototransistor-X5	01 F4 	20
    ENG119878-ENG99777-dimming_characteristic_curve_adjustment_internal_phototransistor-Y1	00 00 	20
    ENG119878-ENG100480-dimming_characteristic_curve_adjustment_internal_phototransistor-Y2	00 0E 	20
    ENG119878-ENG100773-dimming_characteristic_curve_adjustment_internal_phototransistor-Y3	00 41 	20
    ENG119878-ENG100631-dimming_characteristic_curve_adjustment_internal_phototransistor-Y4	00 C8 	20
    ENG119878-ENG102174-dimming_characteristic_curve_adjustment_internal_phototransistor-Y5	00 FD 	20
    ENG105836-ENG101574-dimming_characteristic_curve_adjustment_middle_display_main_field-X1	0	12
    ENG105836-ENG99557-dimming_characteristic_curve_adjustment_middle_display_main_field-X2	0A 	12
    ENG105836-ENG102140-dimming_characteristic_curve_adjustment_middle_display_main_field-X3	32	12
    ENG105836-ENG102936-dimming_characteristic_curve_adjustment_middle_display_main_field-X4	64	12
    ENG105836-ENG103548-dimming_characteristic_curve_adjustment_middle_display_main_field-X5	96	12
    ENG105836-ENG113992-dimming_characteristic_curve_adjustment_middle_display_main_field-X6	FD 	12
    ENG105836-ENG99777-dimming_characteristic_curve_adjustment_middle_display_main_field-Y1	1	12
    ENG105836-ENG100480-dimming_characteristic_curve_adjustment_middle_display_main_field-Y2	1	12
    ENG105836-ENG100773-dimming_characteristic_curve_adjustment_middle_display_main_field-Y3	7	12
    ENG105836-ENG100631-dimming_characteristic_curve_adjustment_middle_display_main_field-Y4	0E 	12
    ENG105836-ENG102174-dimming_characteristic_curve_adjustment_middle_display_main_field-Y5	1E 	12
    ENG105836-ENG113993-dimming_characteristic_curve_adjustment_middle_display_main_field-Y6	64	12
    ENG119874-Gas_functionality	not active 	1
    ENG125906-ENG125912-Illumination_algorithm-Pointer_illumination_algorithim	terminal_58xd_log_bus_parkinglight 	1
    ENG125906-ENG126396-Illumination_algorithm-Scale_switching_algorithm	parking_light 	1
    ENG119882-init_fuel_algorithm	No 	1
    ENG130585-Leaving_warning_delay	1.6 s	1
    ENG102605-ENG103211-outside_temperature-p_blocking_time_after_v_bigger_0	15 s	16
    ENG102605-ENG100239-outside_temperature-p_ice_warning_entry_temperature	4 °C	16
    ENG102605-ENG103023-outside_temperature-p_ice_warning_exit_temperature	6 °C	16
    ENG102605-ENG102658-outside_temperature-p_kmt_at_delta	25 °C	16
    ENG102605-ENG99866-outside_temperature-p_mileage_after_v_bigger_0	5.0 km	16
    ENG102605-ENG103631-outside_temperature-P_speed_threshold	20 km/h	16
    ENG102605-ENG99450-outside_temperature-p_storage_time_engine_off	180 min	16
    ENG102605-ENG104179-outside_temperature-p_tendency_damping	15 s	16
    ENG102605-ENG103335-outside_temperature-p_tendency_threshold	1.0 °C	16
    ENG102605-ENG100500-outside_temperature-p_time_constant_pt1	40 s	16
    ENG102605-ENG103256-outside_temperature-p_time_constant_slow_damping	2	16
    ENG119825-Picture_Upload_Download	not active 	1
    ENG126396-Scale_switching_algorithm	lowbeam_foglight 	1
    ENG119876-Service_Key_Clear_All_Counter	Yes 	1
    ENG130584-Statistic_phev_mileage	5 km	1
    ENG109442-ENG119793-time_parameter_display-hmi_t_Dreiter_ms	2.0 s	18
    ENG109442-ENG119794-time_parameter_display-hmi_t_dummyMenuTimeout_ms	5 s	18
    ENG109442-ENG119802-time_parameter_display-hmi_t_FondGurt	35 s	18
    ENG109442-ENG119804-time_parameter_display-hmi_t_FTuerAUF	300 ms	18
    ENG109442-ENG119796-time_parameter_display-hmi_t_MenuTimeout_ms	255 s	18
    ENG109442-ENG119799-time_parameter_display-hmi_t_NextServiceAnz_ms	5 s	18
    ENG109442-ENG119798-time_parameter_display-hmi_t_NextWarning_ms	6 s	18
    ENG109442-ENG119805-time_parameter_display-hmi_t_P1Pause_ms	20 s	18
    ENG109442-ENG119800-time_parameter_display-hmi_t_P2Pause_ms	900 s	18
    ENG109442-ENG119801-time_parameter_display-hmi_t_Quit_ms	10 s	18
    ENG109442-ENG119797-time_parameter_display-hmi_t_TWSAnz_ms	3 s	18
    ENG109442-ENG119795-time_parameter_display-hmi_t_UhrTimeout_ms	10 s	18
    ENG109442-ENG119803-time_parameter_display-hmi_t_USZ	0.40 s	18
    ENG109442-ENG119806-time_parameter_display-rollierblockgroesse	3	18
    ENG109442-ENG101663-time_parameter_display-tDD15_off	0.3	18
    ENG109442-ENG103975-time_parameter_display-tDD15_on	0	18
    ENG109442-ENG100026-time_parameter_display-tDDWUP	0	18
    ENG112418-ENG112412-total_range_gas-consumption_factor	0	4
    ENG112418-ENG112411-total_range_gas-consumption_profile	consumption_profile_calculation 	4
    ENG112418-ENG112410-total_range_gas-selection_consumption_factor	consumption_factor_CAN 	4
    ENG112418-ENG99298-total_range_gas-State	not active 	4
    Elapsed Time: 00:25
    blockmap-17-5G1-920-840-C_3VWH17AU5JM758941-20180826-1111.CSV
    ;Sunday	26	August	2018	11:11:32:04045
    IDE00019	Voltage terminal 30	14.4	 V
    IDE00021	Engine speed	0	 /min
    IDE00025	Coolant temperature	81	 °C
    IDE00075	Vehicle speed	0	 km/h
    IDE00196	Engine oil temperature	67	 °C
    IDE00301	Distance	138	 km
    IDE00310	Outside air temperature	23.5	 °C
    IDE00316-IDE00500	Time-Hour	11	 H
    IDE00316-IDE00501	Time-Minute	11	 min
    IDE00316-MAS00111	Time-Seconds	13	 s
    IDE00317-IDE00502	Date-Year	2018	 yr
    IDE00317-IDE00503	Date-Month	8	 mon
    IDE00317-IDE00504	Date-Day	26	 d
    IDE00510	ESI: distance driven from inspection	138	 km
    IDE00511	ESI: time from inspection	303	 d
    IDE00512	ESI: minimum value km-driving distance/inspection	15000	 km
    IDE00513	ESI: maximum value km-driving distance/inspection	30000	 km
    IDE00514	ESI: maximum value of time between inspections	730	 d
    IDE00515	ESI: oil quality	poor oil quality
    IDE00517	ESI: soot entry	0	 km
    IDE00518	ESI: thermal load	1100	 km
    IDE00520	Phototransistor	251
    IDE00695	ESI: service exceedance in km	0	 km
    IDE00696	ESI: service exceedance in days	0	 d
    IDE00697	ESI: remaining distance	15970	 km
    IDE00698	ESI: remaining running time	62	 d
    IDE00787-IDE02689	Cause for cancellation-Complete tank calibration	not performed
    IDE00787-IDE02690	Cause for cancellation-Wet dry tank calibration	not performed
    IDE00819	Day counter	302	 d
    IDE00827	ESI: minimum value of time between inspections	365	 d
    IDE00843	Starting impulse recognized	No
    IDE00845-MAS03213	Wheel circ.-Average wheel circumference for trip distance	1976	 mm
    IDE00845-MAS03214	Wheel circ.-Maximum wheel circumference for speed	1976	 mm
    IDE00935	ESI: Theoretical service interval	15000	 km
    IDE01076	Time since ignition off	260	 s
    IDE01153	SIA: maximum value of distance to service	16100	 km
    IDE01154	SIA: maximum value of time to service	365	 d
    IDE01285	Counter of component protection malfunctions	0
    IDE01985-MAS06854	FAZIT identification test sum-Version	3
    IDE01985-MAS06855	FAZIT identification test sum-Test sum	AE 46 D0 B8
    IDE02307	Parking brake status	operated
    IDE02642	Outside temp.: displayed value	22.5	 °C
    IDE03193-MAS02352	Terminal 58 status-Display dimming terminal 58d	FD
    IDE03193-MAS02353	Terminal 58 status-Switch dimming terminal 58s	0
    IDE03193-MAS02916	Terminal 58 status-Dimmer: duty cycle terminal 58st	64
    IDE03193-MAS02917	Terminal 58 status-Sensor for detecting light in the instrument panel insert	122
    IDE03349	FIX: Max. distance until next mileage-related inspection	32200	 km
    IDE03350	FIX: Maximum time until next time-dependent inspection	730	 d
    IDE03351	FIX: Distance covered since last mileage-dependent inspection	100	 km
    IDE03352	FIX: Time since last time-dependent inspection	303	 d
    IDE03471-IDE03640	Vehicle configuration-Dynamic AFS light	Correct coding
    IDE03471-IDE03726	Vehicle configuration-Parallel Parking Assistance	Correct coding
    IDE03471-IDE04525	Vehicle configuration-Wheel Dampening Electronics	Correct coding
    IDE03471-IDE04939	Vehicle configuration-Tire pressure monitoring display	Correct coding
    IDE03471-IDE07016	Vehicle configuration-Tire Pressure Monitoring	Correct coding
    IDE03471-MAS00809	Vehicle configuration-Electro-Mechanical Parking Brake Control Module	Correct coding
    IDE03471-MAS00811	Vehicle configuration-Active steering control module	Correct coding
    IDE03471-MAS00911	Vehicle configuration-All Wheel Drive (AWD)	Correct coding
    IDE03471-MAS01091	Vehicle configuration-Automated manual transmission	Correct coding
    IDE03471-MAS01891	Vehicle configuration-Lane assistant	Correct coding
    IDE03471-MAS01938	Vehicle configuration-Road sign detection	Correct coding
    IDE03471-MAS02570	Vehicle configuration-Lock Electronics	Correct coding
    IDE03471-MAS03385	Vehicle configuration-Lane change assistance	Correct coding
    IDE03471-MAS04384	Vehicle configuration-Electrical steering column lock control module	Correct coding
    IDE03471-MAS05723	Vehicle configuration-Adaptive cruise control or reducing stopping distance	Correct coding
    IDE03471-MAS08201	Vehicle configuration-Trailer positioning assistant	Correct coding
    IDE03472-MAS03806	Volume after refueling-Last displayed quantity before refueling	18	 l
    IDE03472-MAS03807	Volume after refueling-Last displayed quantity after refueling	54	 l
    IDE03472-MAS03808	Volume after refueling-Last sensor final value at end of refueling	57.5	 l
    IDE03472-MAS03809	Volume after refueling-Last reference quantity	19.5	 l
    IDE03472-MAS03810	Volume after refueling-Penultimate displayed quantity before refueling	5.4	 l
    IDE03472-MAS03811	Volume after refueling-Penultimate displayed quantity after refueling	20.9	 l
    IDE03472-MAS03812	Volume after refueling-Penultimate sensor final value at end of refueling	18.5	 l
    IDE03472-MAS03813	Volume after refueling-Penultimate reference quantity	3	 l
    IDE03472-MAS03814	Volume after refueling-Third-last displayed volume before refueling	1.7	 l
    IDE03472-MAS03815	Volume after refueling-Third-last displayed volume after refueling	14.3	 l
    IDE03472-MAS03816	Volume after refueling-Third-last sensor final value at end of refueling	12.6	 l
    IDE03472-MAS03817	Volume after refueling-Third-last reference quantity	0	 l
    IDE03472-MAS03818	Volume after refueling-Fourth-last displayed volume before refueling	0.7	 l
    IDE03472-MAS03819	Volume after refueling-Fourth-last displayed volume after refueling	9.2	 l
    IDE03472-MAS03820	Volume after refueling-Fourth-last sensor final value at end of refueling	9.2	 l
    IDE03472-MAS03821	Volume after refueling-Fourth-last reference quantity	0.7	 l
    IDE03472-MAS03822	Volume after refueling-Last error status	0
    IDE03472-MAS03823	Volume after refueling-Penultimate error status	0
    IDE03472-MAS03824	Volume after refueling-Third-last error status	0
    IDE03472-MAS03825	Volume after refueling-Fourth-last error status	0
    IDE03472-MAS06153	Volume after refueling-Last distance	0
    IDE03472-MAS06154	Volume after refueling-Penultimate distance	0
    IDE03472-MAS06155	Volume after refueling-Third to last distance	0
    IDE03472-MAS06156	Volume after refueling-Fourth to last distance	0
    IDE03473-IDE00730	Fuel tank sens-Fuel level sensor 1 including soiling resistance	79	 Ohm
    IDE03473-IDE00731	Fuel tank sens-Fuel level sensor 2 including soiling resistance	94	 Ohm
    IDE03473-IDE00732	Fuel tank sens-Fuel level sensor 1 soiling resistance	2	 Ohm
    IDE03473-IDE00733	Fuel tank sens-Fuel level sensor 2 soiling resistance	2	 Ohm
    IDE03473-IDE03494	Fuel tank sens-Fuel level sensor 3 including soiling resistance	65535	 Ohm
    IDE03473-IDE03495	Fuel tank sens-Fuel level sensor 3 soiling resistance	-32768	 Ohm
    IDE03473-IDE03496	Fuel tank sens-Fuel level sensor 4 including soiling resistance	65535	 Ohm
    IDE03473-IDE03497	Fuel tank sens-Fuel level sensor 4 soiling resistance	-32768	 Ohm
    IDE03473-MAS03798	Fuel tank sens-Raw value sensor 1 resistor 1	1176
    IDE03473-MAS03799	Fuel tank sens-Raw value sensor 1 resistor 2	2340
    IDE03473-MAS03800	Fuel tank sens-Raw value sensor 2 resistor 1	1328
    IDE03473-MAS03801	Fuel tank sens-Raw value sensor 2 resistor 2	2286
    IDE03473-MAS03802	Fuel tank sens-Raw value sensor 3 resistor 1	65535
    IDE03473-MAS03803	Fuel tank sens-Raw value sensor 3 resistor 2	65535
    IDE03473-MAS03804	Fuel tank sens-Raw value sensor 4 resistor 1	65535
    IDE03473-MAS03805	Fuel tank sens-Raw value sensor 4 resistor 2	65535
    IDE03474-IDE00304	Calculated volume-Fuel level	49.9	 l
    IDE03474-IDE00306	Calculated volume-Fuel Level Sensor 1	77	 Ohm
    IDE03474-IDE00307	Calculated volume-Fuel Level Sensor 2	92	 Ohm
    IDE03474-IDE00308	Calculated volume-Fuel Level Sensor 3	65535	 Ohm
    IDE03474-IDE00309	Calculated volume-Fuel Level Sensor 4	65535	 Ohm
    IDE03474-IDE00312	Calculated volume-Fuel level from sensor 1	22.8	 l
    IDE03474-IDE00313	Calculated volume-Fuel level from sensor 2	27.5	 l
    IDE03474-IDE00314	Calculated volume-Fuel level from sensor 3	0	 l
    IDE03474-IDE00315	Calculated volume-Fuel level from sensor 4	0	 l
    IDE03474-MAS03826	Calculated volume-Quality sensor 1	10
    IDE03474-MAS03827	Calculated volume-Quality sensor 2	10
    IDE03474-MAS03828	Calculated volume-Quality sensor 3	not installed
    IDE03474-MAS03829	Calculated volume-Quality sensor 4	not installed
    IDE03474-MAS10338	Calculated volume-Non-calibrated volume: sensor 1	23.2	 l
    IDE03474-MAS10339	Calculated volume-Non-calibrated volume: sensor 2	27.5	 l
    IDE03474-MAS10340	Calculated volume-Non-calibrated volume: sensor 3	-32768	 l
    IDE03474-MAS10341	Calculated volume-Non-calibrated volume: sensor 4	-32768	 l
    IDE03474-ENG103155	Calculated volume-accelerated_linking_x	1	 m/s
    IDE03474-ENG103517	Calculated volume-accelerated_linking_y	1	 m/s
    IDE03474-ENG102894	Calculated volume-averaged_volume	50.3	 l
    IDE03474-ENG99406	Calculated volume-averaged_volume_clipped	50.3	 l
    IDE03474-ENG101619	Calculated volume-calibrated_volume_total	50.3	 l
    IDE03474-ENG99553	Calculated volume-linking	0
    IDE03474-ENG101669	Calculated volume-prefiltered_acceleration_x	-0.1875	 m/s
    IDE03474-ENG102339	Calculated volume-prefiltered_acceleration_y	0
    IDE03474-ENG101623	Calculated volume-reference_volume	50.2	 l
    IDE03474-ENG102479	Calculated volume-speed_based_linking	0	 m/s
    IDE03474-ENG99683	Calculated volume-version_of_application	111
    IDE03474-ENG102081	Calculated volume-volume_based_linking	0.0016661
    IDE03475-MAS00216	Control button in instrument cluster-External button for daily distance driven	not active
    IDE03475-MAS02915	Control button in instrument cluster-Button for auto check system	not active
    IDE03475-MAS03929	Control button in instrument cluster-Menu button	not active
    IDE03477-IDE00500	GPS time-Hour	0	 H
    IDE03477-IDE00501	GPS time-Minute	0	 min
    IDE03477-IDE00502	GPS time-Year	2000	 yr
    IDE03477-IDE00503	GPS time-Month	1	 mon
    IDE03477-IDE00504	GPS time-Day	1	 d
    IDE03477-MAS00111	GPS time-Seconds	0	 s
    IDE03477-MAS03493	GPS time-last synchronization year	2000	 yr
    IDE03506	Distance: high resolution	00 02 1C 9A
    IDE03911-MAS01390	Service -interval- display: history 1-Block 1	FF FF FF FF
    IDE03911-MAS01391	Service -interval- display: history 1-Block 2	FF FF FF FF
    IDE03911-MAS01392	Service -interval- display: history 1-Block 3	FF FF FF FF
    IDE03911-MAS01393	Service -interval- display: history 1-Block 4	FF FF FF FF
    IDE03911-MAS01394	Service -interval- display: history 1-Block 5	FF FF FF FF
    IDE03911-MAS01395	Service -interval- display: history 1-Block 6	FF FF FF FF
    IDE03911-MAS01396	Service -interval- display: history 1-Block 7	FF FF FF FF
    IDE03911-MAS01397	Service -interval- display: history 1-Block 8	FF FF FF FF
    IDE03911-MAS01398	Service -interval- display: history 1-Block 9	FF FF FF FF
    IDE03911-MAS01399	Service -interval- display: history 1-Block 10	FF FF FF FF
    IDE03911-MAS01400	Service -interval- display: history 1-Block 11	FF FF FF FF
    IDE03911-MAS01401	Service -interval- display: history 1-Block 12	FF FF FF FF
    IDE03911-MAS01402	Service -interval- display: history 1-Block 13	FF FF FF FF
    IDE03911-MAS01403	Service -interval- display: history 1-Block 14	FF FF FF FF
    IDE03911-MAS01404	Service -interval- display: history 1-Block 15	FF FF FF FF
    IDE03911-MAS01405	Service -interval- display: history 1-Block 16	FF FF FF FF
    IDE03912-MAS01390	Service -interval- display: history 2-Block 1	FF FF FF FF
    IDE03912-MAS01391	Service -interval- display: history 2-Block 2	FF FF FF FF
    IDE03912-MAS01392	Service -interval- display: history 2-Block 3	FF FF FF FF
    IDE03912-MAS01393	Service -interval- display: history 2-Block 4	FF FF FF FF
    IDE03912-MAS01394	Service -interval- display: history 2-Block 5	FF FF FF FF
    IDE03912-MAS01395	Service -interval- display: history 2-Block 6	FF FF FF FF
    IDE03912-MAS01396	Service -interval- display: history 2-Block 7	FF FF FF FF
    IDE03912-MAS01397	Service -interval- display: history 2-Block 8	FF FF FF FF
    IDE03912-MAS01398	Service -interval- display: history 2-Block 9	FF FF FF FF
    IDE03912-MAS01399	Service -interval- display: history 2-Block 10	FF FF FF FF
    IDE03912-MAS01400	Service -interval- display: history 2-Block 11	FF FF FF FF
    IDE03912-MAS01401	Service -interval- display: history 2-Block 12	FF FF FF FF
    IDE03912-MAS01402	Service -interval- display: history 2-Block 13	FF FF FF FF
    IDE03912-MAS01403	Service -interval- display: history 2-Block 14	FF FF FF FF
    IDE03912-MAS01404	Service -interval- display: history 2-Block 15	FF FF FF FF
    IDE03912-MAS01405	Service -interval- display: history 2-Block 16	FF FF FF FF
    IDE03913-MAS01390	Service -interval- display: history 3-Block 1	FF FF FF FF
    IDE03913-MAS01391	Service -interval- display: history 3-Block 2	FF FF FF FF
    IDE03913-MAS01392	Service -interval- display: history 3-Block 3	FF FF FF FF
    IDE03913-MAS01393	Service -interval- display: history 3-Block 4	FF FF FF FF
    IDE03913-MAS01394	Service -interval- display: history 3-Block 5	FF FF FF FF
    IDE03913-MAS01395	Service -interval- display: history 3-Block 6	FF FF FF FF
    IDE03913-MAS01396	Service -interval- display: history 3-Block 7	FF FF FF FF
    IDE03913-MAS01397	Service -interval- display: history 3-Block 8	FF FF FF FF
    IDE03913-MAS01398	Service -interval- display: history 3-Block 9	FF FF FF FF
    IDE03913-MAS01399	Service -interval- display: history 3-Block 10	FF FF FF FF
    IDE03913-MAS01400	Service -interval- display: history 3-Block 11	FF FF FF FF
    IDE03913-MAS01401	Service -interval- display: history 3-Block 12	FF FF FF FF
    IDE03913-MAS01402	Service -interval- display: history 3-Block 13	FF FF FF FF
    IDE03913-MAS01403	Service -interval- display: history 3-Block 14	FF FF FF FF
    IDE03913-MAS01404	Service -interval- display: history 3-Block 15	FF FF FF FF
    IDE03913-MAS01405	Service -interval- display: history 3-Block 16	FF FF FF FF
    IDE03914-MAS01390	Service -interval- display: history 4-Block 1	FF FF FF FF
    IDE03914-MAS01391	Service -interval- display: history 4-Block 2	FF FF FF FF
    IDE03914-MAS01392	Service -interval- display: history 4-Block 3	FF FF FF FF
    IDE03914-MAS01393	Service -interval- display: history 4-Block 4	FF FF FF FF
    IDE03914-MAS01394	Service -interval- display: history 4-Block 5	FF FF FF FF
    IDE03914-MAS01395	Service -interval- display: history 4-Block 6	FF FF FF FF
    IDE03914-MAS01396	Service -interval- display: history 4-Block 7	FF FF FF FF
    IDE03914-MAS01397	Service -interval- display: history 4-Block 8	FF FF FF FF
    IDE03914-MAS01398	Service -interval- display: history 4-Block 9	FF FF FF FF
    IDE03914-MAS01399	Service -interval- display: history 4-Block 10	FF FF FF FF
    IDE03914-MAS01400	Service -interval- display: history 4-Block 11	FF FF FF FF
    IDE03914-MAS01401	Service -interval- display: history 4-Block 12	FF FF FF FF
    IDE03914-MAS01402	Service -interval- display: history 4-Block 13	FF FF FF FF
    IDE03914-MAS01403	Service -interval- display: history 4-Block 14	FF FF FF FF
    IDE03914-MAS01404	Service -interval- display: history 4-Block 15	FF FF FF FF
    IDE03914-MAS01405	Service -interval- display: history 4-Block 16	FF FF FF FF
    IDE05931	FIX: Reset value for next mileage-dependent inspection	32200	 km
    IDE05932	FIX: Reset value for next time-dependent inspections	730	 d
    IDE06566-IDE00008	Key identification-Softwareversion	006A
    IDE06566-IDE00016	Key identification-Hardwareversion	H91
    IDE06566-MAS04970	Key identification-Part Number	5G0959753BD
    IDE09552-IDE07944	Vehicle configuration 2-electronic brake booster	Correct coding
    IDE09552-MAS06008	Vehicle configuration 2-Internal noise sound actuator	Correct coding
    IDE09552-MAS08940	Vehicle configuration 2-Collision warning	Correct coding
    ENG124477-MAS06854	Adapted_transponders_checksum-Version	1
    ENG124477-MAS06855	Adapted_transponders_checksum-Test sum	5E 80 C1 23
    ENG105830-ENG104002	dmmng_chan_instr_clust/dmmng_char_curve_gauge/fnger-dimming_characteristic_curve_bar_graph_and_ACC	53	 %
    ENG105830-ENG119807	dmmng_chan_instr_clust/dmmng_char_curve_gauge/fnger-dimming_characteristic_curve_clock_dial	64	 %
    ENG105830-ENG101889	dmmng_chan_instr_clust/dmmng_char_curve_gauge/fnger-dimming_characteristic_curve_gauge/finger/hand	73	 %
    ENG105830-ENG100477	dmmng_chan_instr_clust/dmmng_char_curve_gauge/fnger-dimming_characteristic_curve_indicator_lights	75	 %
    ENG105830-ENG103803	dmmng_chan_instr_clust/dmmng_char_curve_gauge/fnger-dimming_characteristic_curve_middle_display_main_field	68	 %
    ENG106303-ENG99140	ESI_active_warning-advance_warning_fixed_days	not active
    ENG106303-ENG100265	ESI_active_warning-advance_warning_fixed_km	not active
    ENG106303-ENG101600	ESI_active_warning-advance_warning_WIV_days	not active
    ENG106303-ENG102887	ESI_active_warning-advance_warning_WIV_km	not active
    ENG106303-ENG99971	ESI_active_warning-in_calculation	not active
    ENG106303-ENG101015	ESI_active_warning-no_calculation_available	active
    ENG106303-ENG101477	ESI_active_warning-service_warning_fixed_days	not active
    ENG106303-ENG101550	ESI_active_warning-service_warning_fixed_km	not active
    ENG106303-ENG101709	ESI_active_warning-service_warning_WIV_days	not active
    ENG106303-ENG102993	ESI_active_warning-service_warning_WIV_km	not active
    ENG119883	ESI_mileage_per_day	100	 km
    ENG106922	Immobilizer - Challenge	8D 32 37 C6
    ENG99439	Instrument_recorder	03 03 31 00 4D 51 42 56 57 31 37 53 31 4D 00 00 00 00 00 00 00 01 4A 00 3E 00 00 00 00 00 00 00 00 00 00 00 00 01 4A 00 3E 00 00 00 00 00 00 00 00 00 00 00 00 01 4A 00 3E 00 00 00 00 00 00 00 00 00 00 00 00 01 4A 00 3E 00 00 00 00 00 00 00 00 00 00 00 00 01 4A 00 3E 00 00 00 00 00 00 00 00 00 00 00 00 01 4A 00 3E 00 00 00 00 00 00 00 00 00 00 00 00 01 4A 00 3E 00 00 00 00 00 00 00 00 00 00 00 00 01 4A 00 3E 00 00 00 00 00 00 00 00 00 00 00 00 01 4A 00 3E 00 00 00 00 00 00 00 00 00 00 00 00 01 4A 00 3E 00 00 00 00 00 00 00 00 00 00 00 00 01 4A 00 3E 00 00 00 00 00 00 00 00 00 00 00 00 01 4A 00 3E 00 00 00 00 00 00 00 00 00 00 00 00 01 4A 00 3E 00 00 00 00 00 00 00 00 00 00 00 00 01 4A 00 3E 00 00 00 00 00 00 00 00 00 00 00 00 01 4A 00 3E 00 00 00 00 00 00 00 00 00 00 00 00 01 4A 00 3E 00 00 00 00 00 00 00 00 00 00 00 00 01 4A 00 3E 00 00 00 00 00 00 00 00 00 00 00 00 01 4A 00 3E 00 00 00 00 00 00 00 00 00 00 00 00 01 4A 00 3E 00 00 00 00 00 00 00 00 00 00 00 00 01 4A 00 3E 00 00 00 00 00 00 00 00 00 00 00 00 00 80 00 00 0A FF FF FF FF FF FF FF FF FF 00 00 FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF 00 00 7E 3B
    ENG107920-ENG100914	onboard_computer-current_consumption	0
    ENG107920-ENG119788	onboard_computer-range_average_consumption	8.6	 l/100km
    ENG107920-ENG119789	onboard_computer-range_average_consumption_high	8.6	 l/100km
    ENG107920-ENG119790	onboard_computer-range_average_consumption_low	9	 l/100km
    ENG107920-ENG119791	onboard_computer-range_display_value	540	 km
    ENG107920-ENG119792	onboard_computer-range_R	541
    ENG107920-ENG112418	onboard_computer-total_range_gas	540	 km
    ENG107953-ENG100938	outside_temp_algorithm_group-coolant_temperature_outdated_bit	not active
    ENG107953-ENG101136	outside_temp_algorithm_group-distance_threshold_not_yet_reached	active
    ENG107953-ENG99778	outside_temp_algorithm_group-downward_tendency	not active
    ENG107953-ENG99788	outside_temp_algorithm_group-engine_running_detection_MSG	not active
    ENG107953-ENG102352	outside_temp_algorithm_group-ice_warning_symbol	not active
    ENG107953-ENG99520	outside_temp_algorithm_group-no_blockage_active	not active
    ENG107953-ENG99784	outside_temp_algorithm_group-outside_temperature_filtered	145
    ENG107953-ENG99258	outside_temp_algorithm_group-outside_temperature_filtered_error_state_bit	not active
    ENG107953-ENG102589	outside_temp_algorithm_group-outside_temperature_old	not active
    ENG107953-ENG102387	outside_temp_algorithm_group-outside_temperature_raw_score_error_state_bit	not active
    ENG103405	read_out_measured_value_block	0
    ENG119885-ENG103300	Service_Key_current_data-Service_Data	00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00
    ENG108925-ENG103300	Service_Key_Data_Current_Page-Service_Data	D7 95 07 22 28 C0 12 08 1A 0A 24 00 89 00 00 00 A0 10 3E 10 41 11 AB 11 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 5C FF FF 00 00 40 10
    ENG108926-ENG103300	Service_Key_Data_Previous_Page-Service_Data	F0 E9 07 22 28 80 0B 04 0D 03 20 0B 13 00 00 00 64 30 07 11 C8 30 74 12 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 08 00 00 00 00 00 00 00 00 1A FF FF 00 00 40 10
    ENG108927-ENG119819	Service_Key_Master_Counter-Counter_ID_Kessy	27
    ENG108927-ENG119811	Service_Key_Master_Counter-Counter_Key_ID_1	4
    ENG108927-ENG119812	Service_Key_Master_Counter-Counter_Key_ID_2	23
    ENG108927-ENG119813	Service_Key_Master_Counter-Counter_Key_ID_3	0
    ENG108927-ENG119814	Service_Key_Master_Counter-Counter_Key_ID_4	0
    ENG108927-ENG119815	Service_Key_Master_Counter-Counter_Key_ID_5	0
    ENG108927-ENG119816	Service_Key_Master_Counter-Counter_Key_ID_6	0
    ENG108927-ENG119817	Service_Key_Master_Counter-Counter_Key_ID_7	0
    ENG108927-ENG119818	Service_Key_Master_Counter-Counter_Key_ID_8	0
    ENG108927-ENG119821	Service_Key_Master_Counter-Counter_Trigger	0
    ENG108927-ENG119822	Service_Key_Master_Counter-Error_Counter	0
    ENG108927-ENG119823	Service_Key_Master_Counter-Immo_Key	0
    ENG108927-ENG119820	Service_Key_Master_Counter-Last_Key	Update_Error
    ENG108927-ENG99298	Service_Key_Master_Counter-State	Engine_off
    ENG119884-ENG119838	Service_Key_Mileage_Date-CRC_Block_0	BF B1
    ENG119884-ENG119860	Service_Key_Mileage_Date-CRC_Block_1	BF B3
    ENG119884-ENG119856	Service_Key_Mileage_Date-CRC_Block_2	E2 33
    ENG119884-ENG119857	Service_Key_Mileage_Date-CRC_Block_3	00 00
    ENG119884-ENG119858	Service_Key_Mileage_Date-CRC_Block_4	00 00
    ENG119884-ENG119859	Service_Key_Mileage_Date-CRC_Block_5	00 00
    ENG119884-ENG119861	Service_Key_Mileage_Date-CRC_Block_6	00 00
    ENG119884-ENG119873	Service_Key_Mileage_Date-CRC_Block_7	38 4E
    ENG119884-ENG119837	Service_Key_Mileage_Date-Date_Day_Secure_Total_Distance_Block_0	13	 d
    ENG119884-ENG119867	Service_Key_Mileage_Date-Date_Day_Secure_Total_Distance_Block_1	13	 d
    ENG119884-ENG119868	Service_Key_Mileage_Date-Date_Day_Secure_Total_Distance_Block_2	26	 d
    ENG119884-ENG119866	Service_Key_Mileage_Date-Date_Day_Secure_Total_Distance_Block_3	0	 d
    ENG119884-ENG119865	Service_Key_Mileage_Date-Date_Day_Secure_Total_Distance_Block_4	0	 d
    ENG119884-ENG119864	Service_Key_Mileage_Date-Date_Day_Secure_Total_Distance_Block_5	0	 d
    ENG119884-ENG119863	Service_Key_Mileage_Date-Date_Day_Secure_Total_Distance_Block_6	0	 d
    ENG119884-ENG119872	Service_Key_Mileage_Date-Date_Day_Secure_Total_Distance_Block_7	1	 d
    ENG119884-ENG119870	Service_Key_Mileage_Date-Date_Month_Secure_Total_Distance_Block_0	4	 mon
    ENG119884-ENG119836	Service_Key_Mileage_Date-Date_Month_Secure_Total_Distance_Block_1	4	 mon
    ENG119884-ENG119850	Service_Key_Mileage_Date-Date_Month_Secure_Total_Distance_Block_2	8	 mon
    ENG119884-ENG119851	Service_Key_Mileage_Date-Date_Month_Secure_Total_Distance_Block_3	0	 mon
    ENG119884-ENG119852	Service_Key_Mileage_Date-Date_Month_Secure_Total_Distance_Block_4	0	 mon
    ENG119884-ENG119853	Service_Key_Mileage_Date-Date_Month_Secure_Total_Distance_Block_5	0	 mon
    ENG119884-ENG119854	Service_Key_Mileage_Date-Date_Month_Secure_Total_Distance_Block_6	0	 mon
    ENG119884-ENG119855	Service_Key_Mileage_Date-Date_Month_Secure_Total_Distance_Block_7	1	 mon
    ENG119884-ENG119869	Service_Key_Mileage_Date-Date_Year_Secure_Total_Distance_Block_0	2011	 yr
    ENG119884-ENG119835	Service_Key_Mileage_Date-Date_Year_Secure_Total_Distance_Block_1	2011	 yr
    ENG119884-ENG119845	Service_Key_Mileage_Date-Date_Year_Secure_Total_Distance_Block_2	2018	 yr
    ENG119884-ENG119846	Service_Key_Mileage_Date-Date_Year_Secure_Total_Distance_Block_3	2000	 yr
    ENG119884-ENG119847	Service_Key_Mileage_Date-Date_Year_Secure_Total_Distance_Block_4	2000	 yr
    ENG119884-ENG119848	Service_Key_Mileage_Date-Date_Year_Secure_Total_Distance_Block_5	2000	 yr
    ENG119884-ENG119849	Service_Key_Mileage_Date-Date_Year_Secure_Total_Distance_Block_6	2000	 yr
    ENG119884-ENG119862	Service_Key_Mileage_Date-Date_Year_Secure_Total_Distance_Block_7	2011	 yr
    ENG119884-ENG119834	Service_Key_Mileage_Date-Secure_Total_Distance_Km_Block_0	17
    ENG119884-ENG119839	Service_Key_Mileage_Date-Secure_Total_Distance_Km_Block_1	19
    ENG119884-ENG119840	Service_Key_Mileage_Date-Secure_Total_Distance_Km_Block_2	137
    ENG119884-ENG119841	Service_Key_Mileage_Date-Secure_Total_Distance_Km_Block_3	0
    ENG119884-ENG119842	Service_Key_Mileage_Date-Secure_Total_Distance_Km_Block_4	0
    ENG119884-ENG119843	Service_Key_Mileage_Date-Secure_Total_Distance_Km_Block_5	0
    ENG119884-ENG119844	Service_Key_Mileage_Date-Secure_Total_Distance_Km_Block_6	0
    ENG119884-ENG119871	Service_Key_Mileage_Date-Secure_Total_Distance_Km_Block_7	7
    ENG108929-ENG99961	Service_Key_Pointer-Current_Bank	Bank_1
    ENG108929-ENG119808	Service_Key_Pointer-Write_Pointer_Adr_159	4
    ENG108929-ENG119809	Service_Key_Pointer-Write_Pointer_Adr_191	4
    ENG108929-ENG119810	Service_Key_Pointer-Write_Pointer_Adr_223	4
    ENG100879-ENG118224	State Blocking Time-blocking_time	00 00 00 00 00 00
    ENG103899-ENG99298	State of Immobilizer-State	02 01 03 6A 02 00 00 00 00 00
    ENG103284-ENG118223	State of Immobilizer Slaves-ELV_State	0
    ENG103284-ENG118222	State of Immobilizer Slaves-GSG_State	F8
    ENG103284-ENG118217	State of Immobilizer Slaves-Immobilizer_State	0
    ENG103284-ENG118216	State of Immobilizer Slaves-key_state	FC
    ENG103284-ENG118218	State of Immobilizer Slaves-MSG_1_State	F8
    ENG103284-ENG118219	State of Immobilizer Slaves-MSG_2_State	0
    ENG103284-ENG118220	State of Immobilizer Slaves-MSG_3_State	0
    ENG103284-ENG118221	State of Immobilizer Slaves-MSG_4_State	0
    ENG103284-ENG20775	State of Immobilizer Slaves-OCU_state	0
    ENG103284-ENG20776	State of Immobilizer Slaves-VTS_state	0
    ENG109575	Transponder ID current Key	09 88 8F 19
    ENG109576	Transponder ID Key 1	09 88 8F 19
    ENG109577	Transponder ID Key 2	09 88 E6 91
    Elapsed Time: 00:12
  12. Likes Boki Ar liked this post
  13. #10
    Stoke on Trent, England
    Chassis Type: AU-VW37 (3Q0)
    AutoScan.txt doesn't list 3Q or Alltrack are you using your works VCDS?
    BA,VW Golf Variant VII (2014 >),00
    New User Keith
