Audi A4 saloon 2.7 TDI 2009 - coil light flashing loosing power
GL_v1
Ireland
C?ID=195949
Hello - coil light started flashing and some time later despite pushing the accelerator and the engine revving the car did not increase speed (possible limp home mode?).
Light appears to reset and turn off when you turn the ignition off/on again.
Ran a scan - details below - appear to have several fault codes which might be originating from a common source.
Any help, advice, suggestions welcomed.
Tuesday,26,February,2019,23:09:15:64743
VCDS Version: 18.9.1.0 (x64)
VIN: WAUZZZ8K99A085397   License Plate:
Mileage: 240120km-149203mi   Repair Order:
Chassis Type: 8K-AU48 (8T0)
Scan: 01 02 03 05 07 08 09 0E 10 15 16 17 19 1E 37 42 46 47 52 53
          56 62 72 77
VIN: WAUZZZ8K99A085397   Mileage: 240120km-149203miles
Address 01: Engine (J623-CGKA)       Labels:| 059-907-401-V1.clb
   Part No SW: 8K1 907 401 A    HW: 8K1 907 401 A
   Component: 2.7TDI EDC17  H01 0008
   Revision: 15H01---
   Coding: 0104002C02070020
   Shop #: WSC 06325 000 00000
   ASAM Dataset: EV_ECM27TDI0118K1907401A 001012
   ROD: EV_ECM27TDI0118K1907401A.rod
   VCID: 2A5B77D94D03CE1AA3-807E
5211 - Fuel Rail/System Pressure
          P0087 00 [036] - Too Low
                    Mileage: 240117 km
                    Date: 2019.02.26
                    Time: 21:37:35
                    Engine speed: 1392.00 /min
                    Normed load value: 91.0 %
                    Vehicle speed: 4 km/h
                    Coolant temperature: 86 °C
                    Intake air temperature: 12 °C
                    Voltage terminal 30: 14.140 V
                    Unlearning counter according OBD: 80
                    Crankshaft speed (RPM): 1392.0 /min
                    Vehicle speed: 2.23 km/h
                    Mean injection quantity: 28.39 mg/stroke
                    Fuel temperature: 24.3 °C
                    Fuel high pressure: actual: 654700 hPa
                    Rail pressure regulation: status-Bits 0-7: 00000101
                    Inj Crv st Inj Char Act Val 0-Bits 0-7: 00110100
5212 - Fuel Rail/System Pressure
          P0087 00 [096] - Too Low
5215 - Fuel Rail/System Pressure
          P0087 00 [032] - Too Low
                    Mileage: 239236 km
                    Date: 2019.02.04
                    Time: 14:41:10
                    Engine speed: 775.50 /min
                    Normed load value: 50.6 %
                    Vehicle speed: 6 km/h
                    Coolant temperature: 73 °C
                    Intake air temperature: 23 °C
                    Voltage terminal 30: 14.240 V
                    Unlearning counter according OBD: 21
                    Crankshaft speed (RPM): 649.5 /min
                    Vehicle speed: 4.05 km/h
                    Mean injection quantity: 17.73 mg/stroke
                    Fuel temperature: 23.6 °C
                    Fuel high pressure: actual: 112700 hPa
7156 - Intake Manifold Flap Position Sensor (Bank 1)
          P2015 00 [168] - Implausible Signal
                    Mileage: 234848 km
                    Date: 2018.10.20
                    Time: 13:04:31
                    Engine speed: 638.00 /min
                    Normed load value: 20.0 %
                    Coolant temperature: 53 °C
                    Intake air temperature: 19 °C
                    Crankshaft speed (RPM): 638.0 /min
                    Vehicle speed: 0.00 km/h
                    Vehicle voltage terminal 30: 14240 mV
                    Intake manifold flap offset position open: 14.47 %
                    Intake manifold flap offset position closed: 3.81 %
                    Intake manifold flap position sensor: 521.8 mV
                    V Sw Vlv st Mon B1-Bits 0-7: 00000000
7157 - Intake Manifold Flap Position Sensor (Bank 2)
          P2020 00 [032] - Implausible Signal
Readiness: 1 1 0 0 0
Address 02: Auto Trans (J217)       Labels:| 0AW-927-156.clb
   Part No SW: 8K0 927 155 AG    HW: 0AW 927 156 G
   Component: 0AW 27 TDIRdW H01 0002
   Revision: --H01---    Serial number: 0000000064
   Coding: 000001
   ASAM Dataset: EV_TCMVL381 A01015
   ROD: EV_TCMVL381_A01.rod
   VCID: 78FF9D91C32FAC8AE5-802C
   Part No SW: 8K0 907 379 AC    HW: 8K0 907 379 AC
   Component: ESP8 front    H04 0060
   Coding: 1A4D00
   VCID: 7AFB8799F523BE9A93-802E
02214 - Tire Pressure Warning
            000 -  -  - Intermittent
                    Reset counter: 179
                    Mileage: 239084 km
                    Date: 2019.01.29
                    Time: 18:29:03
                    Hex Value: 0x4F00
                    Hex Value: 0x4006
                    Hex Value: 0x121A
                    Hex Value: 0x0EB7
                    Hex Value: 0x00FF
   Part No SW: 8K0 907 064 C    HW: 8K0 907 064 C
   Component: BCM2 1.1      H70 0134
   Coding: 011100
   VCID: 306F65B163DFB4CA6D-8064
   Subsystem 1 - Part No SW: 8T0 959 754 D    HW: 8T0 959 754 D
   Serial number: 0508000033260014
   Component: ELVAUDIB8  H36 0041
   Serial number: 0208000036375006
Address 07: Control Head        Labels: 8T0-035-7xx-07-H.clb
   Part No SW: 8T0 035 729 T    HW: 4E0 035 729
   Component: Interfacebox    H43 5570
   Revision: 00000000    Serial number: 329G.087591068
   VCID: 4A9B17592543EE1A43-801E
   Subsystem 1 - Part No: 8T0 919 609
   Component: E0380 BedienteilH08 0100
   Subsystem 2 - Serial number: 00000000119443
   Subsystem 3 - Serial number: 0121.07.080000000100010345ÿ
   Subsystem 4 - Serial number: 010345ÿ
   Part No SW: 8T2 820 043 T    HW: 8T2 820 043 T
   Component: KLIMA 3 ZONEN H06 0140
   Revision: D1000000    Serial number: 0109.07.080362
   Coding: 36040000
   VCID: 43853A7DC2693F5280-8016
                    Reset counter: 26
                    Mileage: 234848 km
                    Date: 2018.10.20
                    Time: 13:04:32
                    Temperature: 17.0°C
                    Fault Status: 01100101
                    Reset counter: 26
                    Mileage: 234848 km
                    Date: 2018.10.20
                    Time: 13:04:30
00710 - Defroster Flap Positioning Motor (V107)
                    Fault Status: 00100001
                    Reset counter: 151
                    Mileage: 238026 km
                    Date: 2019.01.07
                    Time: 22:22:49
                    Voltage: 13.30 V
                    Temperature: 22.0°C
                    Temperature: 28.0°C
                    Count: 11271
                    Count: 11640
                    Bin. Bits: 00000000
                    Bin. Bits: 10001011
   Part No SW: 8K0 907 063 B    HW: 8K0 907 063 B
   Component: BCM1 1.0      H22 0253
   Revision: 03022001    Serial number: 00000000078808
   Coding: 690040B10034A7010001000300005F5F001D420800000141000000
   VCID: 2E537BC979EBA23A7F-807A
   Subsystem 1 - Part No SW: 8K2 955 119 A    HW: 8T2 955 119   Labels: 1KX-955-119.CLB
   Component: WWS 130708  H05 0070
   Serial number: SWFBIE 0000242
   Coding: 00FD11
   Component: RLS  H04 0003
   Serial number: 10196602
   Coding: 025028
   Subsystem 3 - Part No SW: 8K0 941 531 G    HW: 8K0 941 531 G
   Component: E1 - LDS  H07 0070
   Serial number: 00000000002507081271
01854 - Heated Seat; Front Right (Z46)
                    Reset counter: 108
                    Mileage: 238391 km
                    Date: 2019.01.16
                    Time: 11:19:00
                    Reset counter: 26
                    Mileage: 234848 km
                    Date: 2018.10.20
                    Time: 13:04:00
   Part No SW: 8T2 035 110 C    HW: 8T2 035 110 C
   Component: MP3-Changer     H44 0390
   Revision: 00044003    Serial number: AUZ5ZBH8521853
   VCID: 2B5572DD8AF9D71258-807E
   Part No SW: 8K0 919 475 E    HW: 8K0 919 475 A
   Component: PARKHILFE 8K  H06 0020
   Revision: 11001001    Serial number: 52840820607885
   Coding: 100103
   VCID: 3B75429DBA994792C8-806E
   Part No SW: 8K0 959 655 B    HW: 8K0 959 655 B
   Component: AirbagVW-AU10 H26 0410
   Serial number: 0038JD17VCY%
   Coding: 30363434363030303030554A3052384B3053
   VCID: 3C774181B79740AAC1-8068
   Serial number: 6334MSME3F435A2AP
   Serial number: 6344MSME3F436468N
   Serial number: 6352QSME7B413777O
   Serial number: 6362QSME78764D73X
   Serial number: 63732SME6E773B0FJ
   Serial number: 63832SME6E783F1DO
   Component: Lenks.Modul   H13 0013
   Revision: --------    Serial number: 90304HGO0000S
   Coding: 000032
   VCID: 3D714C85A48D49A2F6-8068
   Part No SW: 8K0 920 980 B    HW: 8K0 920 980 B
   Component: KOMBIINSTR.   H16 0224
   Revision: 00000000    Serial number: 9E352TY78
   Coding: 2F06080003002600010000
   VCID: 316960B568D5BDC262-8064
   Part No SW: 8T0 907 468 K    HW: 8T0 907 468 K
   Component: GW-BEM 4CAN-M H09 0092
   Revision: EB302042    Serial number: 4200E086038015
   Coding: 000303
   VCID: 49992855E045E5024A-801C
   Subsystem 1 - Part No SW: 8K0 915 181 B    HW: 8K0 915 181 B
   Component: J367-BDM  H04 0150
   Serial number: 180316E8110708
Address 1E: Media Player 2 (R199)       Labels:. 4E0-035-785.lbl
   Part No SW: 4E0 035 785 F    HW: 4E0 035 785 C
   Component: SG ext.Player H15 0850
   Revision: 00000000
   VCID: 2B5572DD4AF9D71258-807E
   Part No SW: 4E0 910 888 P    HW: 4E0 919 887 M
   Component: MNS ECE         H51 1060
   Revision: 00000000    Serial number: 333GX087596226
   Shop #: WSC 06342 000 00000
   VCID: 3B75429D7A994792C8-806E
   Part No SW: 8K0 959 793 C    HW: 8K0 959 793 A
   Component: TSG FA        H10 0170
   Revision:             Serial number: 0000007506853
   Coding: 011002204001410001
   VCID: 408F3571D37F244A9D-8014
   Revision: 00002001    Serial number: 0112712610
   Coding: 011B062200390400002001
   Part No SW: 8T0 035 223 T    HW: 8T0 035 223 F
   Component: DSP Prem      H14 0400
   Revision: 00H14003    Serial number: 34814002359801
   Coding: 020101
   Shop #: WSC 12336 024 394758
   VCID: 3F8D368DAE815BB2E4-806A
   Part No SW: 8K0 959 792 C    HW: 8K0 959 792 A
   Component: TSG BF        H10 0170
   Revision:             Serial number: 0000007466061
                    Reset counter: 179
                    Mileage: 239530 km
                    Date: 2019.02.09
                    Time: 19:42:59
   Part No SW: 8K0 907 801 E    HW: 8K0 907 801 E
   Component: EPB Audi B8   H05 0060
   Revision: 00000003    Serial number: 00000000184545
   Part No SW: 4E0 910 541 T    HW: 4F0 035 541 L
   Revision: 00000000    Serial number: 336G-087581844
   VCID: 316960B5A8D5BDC262-8064
   Part No SW: 8K0 959 795 A    HW: 8K0 959 795 A
   Component: TSG HL        H06 0170
   Revision:             Serial number: 0000100158818
   Coding: 010002204001210001
   Part No SW: 8K0 959 794 A    HW: 8K0 959 795 A
   Component: TSG HR        H06 0170
   Revision:             Serial number: 0000100162984
Address 77: Telephone        Labels: 4F1-910-336.lbl
   Part No SW: 4F1 910 336 D    HW: 4F1 862 335
   Component: BTA             H11 1120
   Revision: 00H11000    Serial number: 00000007585967
   Coding: 0010021
   VCID: 254184E5EC1DE1628E-8070
End-------------------------(Elapsed Time: 03:43)--------------------------
VCDS Release 18.9.1:  SRI Reset
Control Module Part Number: 8K0 920 980 B       Labels:  .8T0-920-xxx-17.clb
Component:KOMBIINSTR.   H16 0224, Coding:2F06080003002600010000
Channel  	Description                                       	Unit      	Current val.  	New val.
02       	Service Reminder Status                           	          	2             	---
40       	Distance since Service                            	km x100   	306           	---
41       	Time since Service                                	Days      	544           	---
42       	Minimum Distance to Service                       	km x100   	145           	---
43       	Maximum Distance to Service                       	km x100   	306           	---
44       	Maximum Time to Service                           	Days      	730           	---
45       	Oil Quality                                       	          	2             	---
47       	Soot Quantity                                     	DIST x100 	464           	---
48       	Thermal Load                                      	DIST x100 	325           	---
49       	Minimum Time to Service                           	Days      	730           	---
50       	Basic Distance Value for Oil Change               	km x100   	150           	---
51       	Basic Time Value for Oil Change                   	Days      	365           	---
52       	Basic Distance Value for Inspection               	km x100   	190           	---
53       	Distance since Inspection                         	km x100   	544           	---
54       	Basic Time Value for Inspection                   	Days      	730           	---
55       	Time since Inspection                             	Days      	973           	---
56       	Day Counter                                       	Days      	3858          	---
Readiness Status: 00000000 00001110 10000000 10000000
MIL Status: MIL OFF
Comprehensive Components: Passed
Fuel System: Passed
Exhaust Gas Recirculation: Failed or Incomplete
Number of EOBD-related DTC(s): 0
MIL Status: MIL OFF
Fuel System: Passed
You have two sets of problems:
1) Fuel pressure too low
2) Intake Manifold Flap Position Sensor on both banks.
If these have a common source, it would have to be electrical. Check wiring diagrams to see if those sensors and the fuel pressure regulator have something in common.
You may also want to look at the following measuring values:
IDE00201 - High fuel pressure: specified value
IDE00589-ENG167462 - Fuel pressure
