3.0 TDI engine code CDYA
snowmad
Sweden
C?ID=335258
Hi!
2010 Audi A6 Quattro 3.0 TDI engine code CDYA (240hp)
What options do I have with VCDS to “command” a DPF regeneration?
Vcds activated emergency regeneration when driving and/or when standing/idle?
And how to perform / activate it?
Engine ECU/ECM uses the “CAN” protocol, but VCDS gives no hint “bubbles” or security code “bubbles ”
And no “drop down” list with choices in basic settings.
In [8] measuring blocks there’s not much info on what it’s showing, so a “nob” like me is left in the dark..
MIL was on for some time due to a faulty temp sensor “3B” according to VCDS, at vag (etos/etka/elsa) the same sensor is called “4”
So now I also would like to know how to see the measured ach volume/weight on the DPF as the faulty sensor did not allow any “by normal driving” regeneration.
and if volume/weight is on the high side force a regeneration before I get “blinking glow spiral” and “limp home” mode.
Lars in sweden
Hi and welcome to our forum.
Please post an Auto-Scan for context, so people can see the exact ECU ID info.
snowmad
Sweden
C?ID=335258
I just realized I used the Swedish translated version, does it work for you or shall I do it again?
måndag,11,Februari,2019,14:01:43:17293
VCDS -- Windows-baserad VAG/VAS-emulator Tändningen Windows 7 x64
VCDS version: AER 18.9.0.2  HEX-V2 CB: 0.4437.4
Dataversion: 20181218 DS296.0
www.vcds.se
VIN: WAUZZZ4F1ANxxxxxx   Reg.nr:
Mätarställning: 160230km   Rep.order:
Chassityp: 4F-AU56 (4F0)
Skanna: 01 02 03 05 08 09 15 16 17 18 19 42 46 4F 52 53 55 56 5F 62
          69 72 76
VIN: WAUZZZ4F1AN048589   Mätarställning: 160230km
01-Motor -- Status: OK 0000
02-Automatväxel -- Status: Felfunktion 0010
03-Bromselektronik -- Status: OK 0000
04-Styrposition -- Status: OK 0000
05-Behör.kontroll -- Status: OK 0000
08-Klimatanläggning -- Status: OK 0000
09-Elektron. elcentral -- Status: Felfunktion 0010
15-Krockkuddar -- Status: OK 0000
16-Rattelektronik -- Status: OK 0000
17-Instrument -- Status: OK 0000
18-Extra/p-värmare -- Status: Felfunktion 0010
19-CAN Gateway -- Status: Felfunktion 0010
42-Dörrel. förare -- Status: OK 0000
46-Komfortcentral -- Status: OK 0000
4F-Elektr. centralenh. II -- Status: OK 0000
52-Dörrelektr. pass. -- Status: OK 0000
53-Parkeringsbroms -- Status: OK 0000
55-Helljusområde -- Status: OK 0000
5F-Information Elektr. -- Status: OK 0000
62-Dörr, Vä Bak -- Status: OK 0000
69-Släpvagn -- Status: Felfunktion 0010
72-Dörr hö bak -- Status: OK 0000
76-Parkeringshjälp -- Status: Felfunktion 0010
Adress 01: Motor (CDY)       Labels: Textfil saknas
   Artikelnr SW: 4F9 910 402 A    HW: 4F0 907 401 E
   Komponent: 3.0TDI EDC17G004AG  0080
   Revision: 16H03---    Serienummer:
   Kodning: 0105002C191F0928
   Verkstad #: WSC 80093 222 69422
   VCID: 241110D8E2DFC7F7DAD-8070
Ingen felkod funnen.
Adress 02: Automatväxel        Labels: AER\09L-927-760.lbl
   Artikelnr SW: 4F2 910 156 Q    HW: 09L 927 156 C
   Komponent: AG6 09L 3,0 TDI RdW 0040
   Revision: --H05---    Serienummer:        4546441
   Kodning: 0000001
   Verkstad #: WSC 02325 785 00200
   VCID: 3333E3845731504F537-8066
1 fel funnet:
005913 - Nedsatt funktion p.g.a. motorstyrdonet
               P1719 - 002 -  - Intermittent fel
             frysta data:
                    Felstatus: 00100010
                    Felprioritet: 0
                    Felfrekvens: 24
                    Reset-räknare: 255
                    Mätarställning: 159444 km
                    Tidsindikering: 0
                    Datum: 2019.01.09
                    Tid: 18:22:17
Adress 03: Bromselektronik        Labels: AER\4F0-910-517.lbl
   Artikelnr SW: 4F0 910 517 AL    HW: 4F0 614 517 BA
   Komponent: ESP8 quattro    H03 0060
   Revision: 00000000    Serienummer: 00000000000000
   Kodning: 0004492
   VCID: 6E8532F07C933DA77C9-803A
Adress 05: Behör.kontroll        Labels:. AER\4F0-910-852.clb
   Artikelnr SW: 4F0 910 852 B    HW: 4F0 905 852 D
   Komponent: FBSAUDIC6 ELV   H05 0100
   Revision: 00H05000    Serienummer: 10602601459789
   Kodning: 0000003
   Verkstad #: WSC 02323 785 00200
   VCID: 25170DDCE9E53EFFCD3-8070
   Subsystem 1 - Artikelnr: 4F0 910 132 E
   Komponent: FBSAUDIC6 EZS   H03 0020
   Subsystem 2 - Artikelnr: 4F0 910 220 D
   Komponent: FBSAUDIC6 IDG   H01 0054
Adress 08: Klimatanläggning        Labels: AER\4F0-910-043.lbl
   Artikelnr SW: 4F0 910 043     HW: 4F1 820 043 AA
   Komponent: KLIMABETAETIGUNGH20 0170
   Revision: 00000033    Serienummer: 00000000692588
   Kodning: 0002070
   VCID: 5BE36B249F21B80FAB7-800E
Adress 09: Elektron. elcentral        Labels: AER\4F0-910-279.lbl
   Artikelnr SW: 4F0 910 279 N    HW: 4F0 907 279
   Komponent: ILM Fahrer      H22 0320
   Revision: 00000000    Serienummer: 4F0907279
   Kodning: 0003122
   Verkstad #: WSC 02335 785 00200
   VCID: 3431E098523F57774AD-8060
   Subsystem 1 - Artikelnr: 4F1 910 113 D  Labels: AER\1KX-955-119.CLB
   Komponent: Wischer AudiC6  H10 0040
   Kodning: 00056595
   Subsystem 2 - Artikelnr: 8K0 910 557   Labels: AER\8K0-955-559.CLB
   Komponent: REGENLICHTSENSORH04 0003
   Kodning: 00146221
1 fel funnet:
00156 - Styrning för spolarvätskepump
            007 - kortsl. till jord - Intermittent fel
             frysta data:
                    Felstatus: 00110111
                    Felprioritet: 2
                    Felfrekvens: 1
                    Reset-räknare: 61
                    Mätarställning: 158976 km
                    Tidsindikering: 0
                    Datum: 2018.11.23
                    Tid: 17:33:00
Adress 15: Krockkuddar (J234)       Labels:* AER\4F0-910-655-10.clb
   Artikelnr SW: 4F0 910 655 Q    HW: 4F0 959 655 G
   Komponent: Airbag AU1042 H06 0160
   Revision: --------    Serienummer: 003F9001ZXW%
   Kodning: 30314236303630303031554A304C34463053
   ROD: EV_Airba10AURB4.rod
   VCID: 3537DD9C55C54E7F7D3-8060
   krocksensor för sidoairbag på förarsidan:
   Serienummer: 3574SRB40000A488D8CN
   krocksensor för sidoairbag på passagerarsidan:
   Serienummer: 3584SRB40000A4C51913
   krocksensor för sidoairbag bak på förarsidan:
   Serienummer: 3516HRB402B9MGGL5CR0
   Krocksensor för sidoairbag bak: passagerarsidan:
   Serienummer: 3526HRB401TCD7SOVKM4
   krocksensor för airbag fram på förarsidan:
   Serienummer: 3554NRB4000052B088A/
   krocksensor för airbag fram på passagerarsidan:
   Serienummer: 3564NRB4000052AFE6DJ
Adress 16: Rattelektronik        Labels: AER\4F0-910-549.lbl
   Artikelnr SW: 4F0 910 549 A    HW: 4F0 953 549 D
   Komponent: J0527               0530
   Revision: 00H05000    Serienummer: 90055093310200
   Kodning: 0002041
   VCID: 270B07D493E92CEFFFF-8072
   Subsystem 1 - Artikelnr: XXXXXXXXXXX
   Komponent: E0221           H02 0030
Adress 17: Instrument (J285)       Labels:. AER\4F0-920-xxx-17.clb
   Artikelnr SW: 4F0 920 933 Q    HW: 4F0 920 933 Q
   Komponent: KOMBIINSTR.   H08 0144
   Revision: 00100000    Serienummer: CN102KVC9
   Kodning: 0F560A0502000008010100
   Verkstad #: WSC 02391 823 56573
   VCID: 3537DD9C55454E7F7D3-8060
Adress 18: Extra/p-värmare        Labels: saknas
   Artikelnr SW: 4F0 910 105 A    HW: 4F0 265 081 AA
   Komponent: Heizgeraet      H08 0100
   Revision:        B    Serienummer: 09018641
   Kodning: 0000111
   Verkstad #: WSC 02145 785 00200
   VCID: 1B632B24DFA1F80F6B7-804E
2 Funna fel:
00664 - Bränslemätare
            002 - Undre gräns överskriden - Intermittent fel
             frysta data:
                    Felstatus: 00100010
                    Felprioritet: 0
                    Felfrekvens: 1
                    Reset-räknare: 68
                    Mätarställning: 159518 km
                    Tidsindikering: 0
                    Datum: 2019.01.12
                    Tid: 16:55:46
01407 - Flamavbrott
            000 - - - Intermittent fel
             frysta data:
                    Felstatus: 00100000
                    Felprioritet: 0
                    Felfrekvens: 1
                    Reset-räknare: 77
                    Mätarställning: 160019 km
                    Tidsindikering: 0
                    Datum: 2019.02.04
                    Tid: 02:15:41
             frysta data:
                        Start
                    Temperatur: 21.0°C
                    Temperatur: -48.0°C
Adress 19: CAN Gateway (J533)       Labels:. AER\4F0-907-468.clb
   Artikelnr SW: 4F0 907 468 M    HW: 4F0 907 468 F
   Komponent: GW-BEM 4CAN-M H06 0035
   Revision: LB100029    Serienummer: 2900L09B288028
   Kodning: 000303
   VCID: 392FD1AC795DAA1F99B-806C
   Subsystem 1 - Artikelnr SW: 8K0 915 181 C    HW: 8K0 915 181 C
   Komponent: J367-BDM  H07 0125
   Serienummer: 00000000002790838416
1 fel funnet:
03041 - Energimanagement aktiv
             frysta data:
                    Felstatus: 00100000
                    Felprioritet: 7
                    Felfrekvens: 16
                    Reset-räknare: 68
                    Mätarställning: 158972 km
                    Tidsindikering: 0
                    Datum: 2018.10.23
                    Tid: 06:06:00
             frysta data:
                    Binära Bitar:    00000
                    Spänning: 11.90 V
                    Räkna: 18
Adress 42: Dörrel. förare (J386)       Labels:. AER\4F0-959-793.clb
   Artikelnr SW: 4F0 959 793 R    HW: 8K0 959 793 D
   Komponent: TSG FA        H11 0250
   Revision:             Serienummer: 0000102440014
   Kodning: 011C06204040410001
   VCID: 46D5AA5038A3D5E7E49-8012
Adress 46: Komfortcentral        Labels:. AER\4F0-910-289.lbl
   Artikelnr SW: 4F0 910 289 N    HW: 4F0 907 289 N
   Komponent: Komfortgeraet   H29 0250
   Revision: 02500029    Serienummer: 01247056780000
   Kodning: 0196849
   VCID: 3537DD9C59454E7F7D3-8060
   Subsystem 1 - Artikelnr: 1K0 951 605 C
   Komponent: LIN BACKUP HORN H05 1501
   Subsystem 2 - Artikelnr: 4F0 910 177
   Komponent: Innenraumueberw.H01 0020
Adress 4F: Elektr. centralenh. II        Labels: AER\4F0-910-280.lbl
   Artikelnr SW: 4F0 910 280     HW: 4F0 907 280 A
   Komponent: ILM Beifahrer   H13 0100
   Revision:             Serienummer: 00000000676359
   Kodning: 0001103
   VCID: 5EE562308C33AD27CC9-800A
Adress 52: Dörrelektr. pass. (J387)       Labels:. AER\4F0-959-792.clb
   Artikelnr SW: 4F0 959 792 R    HW: 8K0 959 792 D
   Komponent: TSG BF        H11 0250
   Revision:             Serienummer: 0000102452401
   VCID: 45D7AD5C05A5DEFFED3-8010
Adress 53: Parkeringsbroms        Labels: AER\4F0-910-801.clb
   Artikelnr SW: 4F0 910 801 D    HW: 4F0 907 801 B
   Komponent: EPB  CEFC0090   H05 0090
   Revision: --H05---
   Kodning: 0000321
   VCID: 211F19CCFDCDD2DFB1B-8074
Adress 55: Helljusområde        Labels: AER\8P0-907-357.lbl
   Artikelnr: 8P0 907 357 H
   Komponent: Dynamische LWR  H02 0010
   Revision: 00000001    Serienummer:
   Kodning: 0000003
   VCID: 3FDBBFB46B79842FA7F-806A
Adress 56: Radio (R)       Labels: Textfil saknas
   Artikelnr SW: 4F0 035 056 B    HW: 4F0 035 056
   Komponent: Radio U STD   H45 0020
   Revision: AB001007    Serienummer: 342L0097733657
   Kodning: 010003020100000000
   VCID: 1F1B1F34C7B9E42F87F-804A
Adress 5F: Information Elektr. (J794)       Labels:. AER\4E0-035-6xx-5F.clb
   Artikelnr SW: 4E0 035 652 A    HW: 4E0 035 652
   Komponent: B-BN-EU       H56 0048
   Revision: --------    Serienummer: 349L9097528576
   Kodning: 01010000010282ED01002305EF6300030000
   Subsystem 1 - Artikelnr SW: 4L0 919 604     HW: 4L0 919 604
   Komponent: DU6 Basic  H43 0306
   Serienummer: 9355L 091054964
   Subsystem 2 - Artikelnr SW: 4F0 910 609 E    HW: 4F1 919 611 M
   Komponent: Bedienteil MM  H01 0060
   Serienummer: 00000001469119
Adress 62: Dörr, Vä Bak (J388)       Labels:. AER\4F0-959-795.clb
   Artikelnr SW: 4F0 959 795 M    HW: 8K0 959 795 B
   Komponent: TSG HL        H10 0251
   Revision:             Serienummer: 0000102446957
   Kodning: 010804204040220001
   VCID: 43D3B3440B91E0CFC37-8016
Adress 69: Släpvagn (J345)       Labels:. AER\4F0-907-383.clb
   Artikelnr SW: 4F0 907 383 D    HW: 4F0 907 383 D
   Komponent: Anhaenger     H08 0080
   Revision: 2B002002    Serienummer: 00000124441180
   Kodning: 0103030000000000
   VCID: 2C01F8F8860F0FB712D-8078
1 fel funnet:
00532 - Spänning
            011 - avbrott - Fellampa(MIL) tänd
             frysta data:
                    Felstatus: 11101011
                    Felprioritet: 3
                    Felfrekvens: 11
                    Reset-räknare: 157
                    Mätarställning: 151975 km
                    Tidsindikering: 0
                    Datum: 2017.09.24
                    Tid: 17:19:00
Adress 72: Dörr hö bak (J389)       Labels:. AER\4F0-959-795.clb
   Komponent: TSG HR        H10 0251
   Revision:             Serienummer: 0000102446971
Adress 76: Parkeringshjälp        Labels: AER\4Fx-910-283.lbl
   Artikelnr SW: 4L0 910 283 C    HW: 4L0 919 283 C
   Komponent: Parkhilfe 8-Kan H02 0500
   Revision: 00H02000    Serienummer: 12630933604038
   Kodning: 0211006
   VCID: 2A0DFEE080FB1187E01-807E
3 Funna fel:
01545 - Givare för parkeringshjälp: vänster bak (G203)
            004 - Ingen signal/förbindelse - Intermittent fel
             frysta data:
                    Felstatus: 00100100
                    Felprioritet: 3
                    Felfrekvens: 1
                    Reset-räknare: 58
                    Mätarställning: 159177 km
                    Tidsindikering: 0
                    Datum: 2018.11.26
                    Tid: 17:47:40
01547 - Givare för parkeringshjälp: höger bak: mitten (G205)
             frysta data:
                    Felstatus: 00100100
                    Felprioritet: 3
                    Felfrekvens: 1
                    Reset-räknare: 58
                    Tidsindikering: 0
                    Datum: 2018.11.26
                    Tid: 17:46:00
02069 - Givare för parkeringshjälp fram
            011 - avbrott - Intermittent fel
             frysta data:
                    Felstatus: 00101011
                    Felprioritet: 3
                    Felfrekvens: 1
                    Reset-räknare: 66
                    Mätarställning: 159400 km
                    Tidsindikering: 0
                    Datum: 2019.01.05
                    Tid: 21:59:37
Slut--------(Förfluten tid: 01:38, Vbatt start/stopp: 13.2V/14.2V)---------
I got the English version of VCDS installed as well, just to be up to date..
The translation to Swedish isn’t that fast and English isn’t so hard for me to understand…. I think 😊
I always have versions on both languages installed.
//Lars
It's always best to post here using the English version of VCDS.
Hmm, VCDS is aware that 4F9-910-402-A exists as an ECU part number and wants to re-direct it to 059-907-401-CDY, but I do see such a file in either English or German. I wonder if the Danish distributor has one? ;)
NEtech
C?ID=56995
Yes I have one :cool:
I find wiki procedure later (out of time now).
NEtech
C?ID=56995
Here is some procedure.
Oil and cooling water Min 73°C
Cooling water Max 117°C
Fuel temp. Max 68°C
Probably this is used instead of [Coding II]:
Security Access code 27971
Basic Setting Enabling (e.g. Regeneration while Standing) is used in conjunction with Basic Setting MWB 226
Read showed information in MWB, what to do.
snowmad
Sweden
C?ID=335258
thank you.
If I understand the link right MVB 104.3 is showing measured sot? "## Particle Filter Load below 68g (see MVB 104.3)" ?
"Read showed information in MWB, what to do." as I wrote in the beginning of the tread, no info is shown to me..
I ben “all over” with the curser/pointer but no yellow “bubbles” appears!
I try to make some screen dumps and a “English auto scan” later today (if my son shows up with the car)
NEtech
C?ID=56995
No as Uwe wrote there is currently no label file.
On the wiki link you could see a few explained.
snowmad
Sweden
C?ID=335258
ok!:thumbs:
still same car:
how to "register" a new DPF and a new DPF difference pressure sensor?
this question is just out off curiosity as the car runs like a bat out of he.. right now :D
FandaTDI
Czech Republic
C?ID=204559
Hi, I would also appreciate some label, even Adv.MVB would be great (and selectable output test the best :-D ), when it is a "4-letter type of engine"... I am/we are trying to solve(few experts "break their teeth" on it... :-D ) the problem of voltage drops on 5V sensor circuit A (reference voltage - sometimes G274-fuel pressure, G79-accelerator pedal sender, G40/G28 synchro). Far now we have sprinkled it and with scope on a ref.voltage on 1 and 3 of G274 went for a ride and found out, that the "blackouts" are PWM and in moment of probable activation of solenoid mounting valve (when steering to the right, so if I am not wrong, it should be N144...), sometimes in case of longer braking... The "suspect" is pretty clear (and now imho/ioho :-) even without water/humidity), but any tips?
