Permission on likes links
Mike@Gendan
Swansea, UK
C?ID=57030
Really petty and unimportant I know, but if you get more than 5 likes on a post, it lists 5 of them by name and "x others":
But if I click on the "others" link, rather than listing the likes it gives me this:
Is that a known (and fixable) issue?
Santos
i need to find the permission setting. I've temporarily set the plugin to display all "likes" inline.
Don't take it personally Mike; even I can't see 'em all when there's more than five. :rolleyes:
barstanders
C?ID=277262
Hello All and of course ( Sebastian, Uwe, jyoung8607,and Dana )
Just a question about Post Thanks / Like.
Mike@Gendan put a reaction at 05.51 AM
See below
Wait a minute.
You have replaced the BCM on a Mk7 with one from a Mk7.5 (i.e. MY2017 or newer), and that's what you're having problems with?
https://forums.ross-tech.com/showth...ffer-distributor-PCI-Germany-ridiculous/page2
I correct his wrong assumption at 05.59 AM
No, I flashed my BCM to higher version, so the same BCM!
What I do not really understand is that there are several people like the message writen by Mike@Gendan what is incorrect and corrected a few minutes later by me again.
And that after a few hours by some people the still like!
Sebastian 06.55 AM
UWE 09.20 AM
jyoung8607 11.15 AM
Dana 12.45 AM
In other words, a few minutes later I give a correction, and all these persons read the wrong assumption, but still like this message after varies from an hour to longer!
I thought that liking would be meant if you had a good solution or gave a correct answer!
Giving Like Post Thanks you can earn something with it ( money, extra appreciation, Moderator, senior )or is it a custom belongs to this site!! like on everthing what you want...
This will happen when people read a thread sequentially. They read a post and click Like before they have read anything further down the thread. When I got to reading that thread this morning, it already had 24 messages (half way into the third page). Moreover, the plug-in we are using does not allow a Like to be un-done.
barstanders
C?ID=277262
Uwe,
Like Sabastian says You always have choices to ( like ore not to like )
I would almost think they all work at ross tech or have an interest in it.
No 1 of the 16 reactions from that thread from me me has been like!!!! ( This will happen when people read a thread sequentially ) of course..
( You can call out what you want as long as the ears are closed it has no effect!)
Maybe that in the future you can adjust this bit of nonsense.
