Audi A8 D4 - Ambient Light Changes
Sawdusty Dan
C?ID=345699
Hi everybody, new on the Ross Tech Forums! Gotta set up a profile, too.
Here's what's going on: I have a 2011 Audi A8L with lots-o-goodies and I love it. However comma I'd like to change the interior ambient lighting schemes from the pre-set 'Red/Polar/Ivory' palette. I've dug through here a bit and found posts for various VWs, but nada for my beloved A8. I'd like to mix it up a lot and I have a gut feeling there are tons of other colors the system is capable of producing, but VAG felt it unnecessary to include the option.
I have my HEX-V2, a trusty laptop and no fear of mucking about in the digital (or mechanical!) guts of most machines. I also know when to keep my dexterous digits out of the soup!
So . . . Is this something that can be done? Has it been done before and documented here, or elsewhere?
Thanks in advance, y'all! I look forward to spending time here, learning and sharing.
BTW, by a conservative estimate, my HEX-V2 setup has already saved me over five times its cost and will continue to do so for as long as I own my A8! Thanks Ross-Tech!!!
Welcome.
Since we don't all have D4 A8s, the best way to start with this would be to post an Auto-Scan so people can see exactly what control modules this car has.
I'm going to speculate that additional info beyond that will also be needed, specifically in the form of an Adaptation channel map from your BCM, but let's start with the above.
Sawdusty Dan
C?ID=345699
VCDS Scan
Sunday,03,February,2019,12:19:48:62207
VCDS Version: 18.9.0.2 (x64)  HEX-V2 CB: 0.4436.4
VIN: WAURVAFD7BN0xxxxx   License Plate:
Chassis Type: FD-AU64 (4H0)
Scan: 01 02 03 05 06 08 09 0E 10 13 15 16 17 19 34 36 3B 3C 42 46
          47 52 53 56 5F 62 6C 6D 6F 72 7F 81 85 88 89 8B 8E 8F 90
VIN: WAURVAFD7BN019415   Mileage: 91119km-56618miles
7F-Inform. Electr. II -- Status: OK 0000
Address 01: Engine (------CDRA)       Labels:| 079-907-560-CFS.clb
   Part No SW: 4H0 907 560 C    HW: 4H0 907 560
   Component: 4.2l V8/4V    H07 0004
   Revision: N5H07---
   Coding: 0106000A290F0268
   Shop #: WSC 24219 444 100841
   ASAM Dataset: EV_ECM42FSI0114H0907560C 001005
   ROD: EV_ECM42FSI0114H0907560C.rod
   VCID: 2A0D01C94C7006A7E01-807E
Readiness: 0100 1101
   Part No SW: 4H1 927 158 AD    HW: 0BK 927 156 K
   Component: 0BK 42 FSIUSA H08 1006
   Revision: --H08---
   Coding: 000002
   ROD: EV_TCMALX51011.rod
   VCID: 72BDD9A9A4200E67981-8026
Address 03: ABS Brakes (J104)       Labels: 4H0-907-379.clb
   Part No SW: 4H0 907 379 C    HW: 4H0 907 379 C
   Component: ESP PREMIUM   H10 0273
   Coding: 44E6F20022674F00E200
   Shop #: WSC 02311 785 00200
   ASAM Dataset: EV_ESPPremi 005006
   ROD: EV_ESPPremi_005_AU64.rod
   VCID: 323D19A964A04E67581-8066
   Part No SW: 4H0 907 064 DD    HW: 4H0 907 064 AD
   Component: BCM2 2.0      H24 0510
   Coding: 0D872000000000000000
   Shop #: WSC 44214 000 1048576
   VCID: 6E85CDD9B0982A877C9-803A
   Subsystem 2 - Part No SW: 4H0 905 852 B    HW: 4H0 905 852 B
   Component: J764 ELV MLB  H38 0044
   Serial number: 2311000024788007
   Part No SW: 4H0 959 760 E    HW: 4H0 959 760 E
   Component: MEM-BFS       H08 0153
   Revision: AA000000    Serial number: 00001002340998
   Coding: C018320085043201010001010101112131313333283333
   Shop #: WSC 02313 785 00200
   VCID: 353722B5954E595F7D3-8060
Address 08: Auto HVAC (J255)       Labels:| 4H0-820-043.clb
   Part No SW: 4H0 820 043 E    HW: 4H0 820 043 E
   Component: Klima 3 Zonen H14 0063
   Coding: 4881232E8C
   ROD: EV_AirCondiFront_001_AU64.rod
   VCID: 221DE9E93440DEE7A81-8076
0137 - Motor for  Right Side Window Defrost Flap
          B10D8 22 [009] - Signal Amplitude Too High
                    Reset counter: 72
                    Mileage: 91104 km
                    Date: 2019.02.03
                    Time: 11:55:33
0378 - Coolant Circulation Pump
          B10D0 04 [009] - Internal System Fault
                    Reset counter: 73
                    Mileage: 91107 km
                    Date: 2019.02.03
                    Time: 12:04:56
   Part No SW: 4H0 907 063 G    HW: 4H0 907 063
   Component: BCM1 2.0      H12 0092
   Revision: 11012002    Serial number: 00000000952604
   Coding: 09072091073C9FE18B000804A0003800009CD308820001218001085C3B00
   VCID: 2C0107D14604189712D-8078
   Subsystem 1 - Part No SW: 4H1 955 119 C    HW: 4H1 955 119 A  Labels: 1KX-955-119.CLB
   Component: WWS641 110209  H32 0040
   Serial number:         110220170843
   Coding: 0045F7
   Subsystem 2 - Part No SW: 8K0 955 559 C    HW: 8K0 955 559 C  Labels: 8K0-955-559.CLB
   Component: RLS  H04 0003
   Serial number: 10062711
   Coding: 025523
   Subsystem 3 - Part No SW: 4H0 941 531 B    HW: 4H0 941 531 B
   Component: E1 - LDS  H07 0044
   Serial number: 14 02 2011  00000170
   Subsystem 4 - Part No SW: 4H0 907 410 A    HW: 4H0 907 410 A
   Component: USHL4.2  H30 0020
   Serial number: 0000001805569R0B7S06
   Subsystem 5 - Part No SW: 4H0 907 472 B    HW: 4H0 907 472 B
   Component: A31 LED Mod1L  H03 0006
   Serial number: 00000002021100010414
   Coding: 100000
   Subsystem 6 - Part No SW: 4H0 907 472 B    HW: 4H0 907 472 B
   Component: A27 LED Mod1R  H03 0006
   Serial number: 00000002021100010613
   Coding: 100000
   Subsystem 7 - Part No SW: 4H0 907 705 J    HW: 4H0 907 705 C
   Component: EVLS-SG  H08 0280
   Serial number: WA101933000000180409
   Coding: 020300
   Subsystem 8 - Part No SW: 4H0 907 658     HW: 4H0 907 658
   Serial number: 1038C095000000000001
Address 0E: Media Player 1 (R161)       Labels: None
   Part No SW: 4H0 035 108 D    HW: 4H0 035 108
   Component: DVDCAlpine    H42 0180
   Revision: AA001001
   Coding: 020000
   VCID: 211FE6E531C6C5FFB1B-8074
03230 - Video Input for Rear Seat Entertainment
                    Fault Status: 00101010
                    Reset counter: 113
                    Mileage: 91107 km
                    Date: 2019.02.03
                    Time: 12:05:55
   Part No SW: 4H0 919 475 H    HW: 4H0 919 475 C
   Component: PARKHILFE ACC H07 0030
   Revision: 11001001    Serial number: 55901103502910
   Coding: 300902
   ASAM Dataset: EV_EPHVA18AU57X0000 001002
   ROD: EV_EPHVA18AU57X0000_001.rod
   VCID: 372B28BD8FC2AB4F6FF-8062
   Part No SW: 4H0 907 561 A    HW: 4H0 907 561
   Component: ACC3          H15 0160
   Coding: 3601020201
   ASAM Dataset: EV_AdaptCruisContrAU64X 001012
   ROD: EV_AdaptCruisContrAU64X_001.rod
   VCID: 290FFEC549760DBFE9B-807C
   Part No SW: 4H0 959 655 D    HW: 4H0 959 655 D
   Component: Airbag10.43   H41 0041
   Revision: --------    Serial number: 003JS001215G
   Coding: 303143303230303030314A55304C34483053
   Subsystem 1 - Part No SW: 4H0 959 339     HW: 4H0 959 339
   Serial number: 5850000R1112701DMH
   Serial number: 3575HRB405V0ATOC80J2
   Serial number: 3585HRB405P09RF2FONA
   Serial number: 3515JRB404T0BTBGBG4Y
   Serial number: 3525JRB404P0BTBG2OJ2
   Serial number: 3554VRB40670AMH8NP70
   Serial number: 3564VRB40650AMH83GU-
   Part No SW: 4H0 953 568 B    HW: 4H0 953 568 B
   Component: Lenks.Modul   H08 0007
   Revision: --------    Serial number: 90815KB30001D
   Coding: 0004BC
   VCID: 323D19A964204E67581-8066
   Subsystem 1 - Part No SW: 4H0 951 528 L    HW: 4H0 951 528 L
   Component: E221 - MFL  H04 0009
   Serial number: 04 01 2011  33037865
   Part No SW: 4H0 920 980 C    HW: 4H0 920 980
   Component: TBenUSAACC--- H30 0309
   Revision: 26110011    Serial number: 658250111593003
   Coding: 0B4608015700D705020000
   ASAM Dataset: EV_RBD4K 004033
   ROD: EV_RBD4K.rod
   VCID: 2B0304CD438A1FAF1B7-807E
   Analog_clock:
   Subsystem 1 - Part No SW: 4H0 919 204 G    HW: 4H0 919 204 G
   Component: Analoguhr D4  H05 0224
   Serial number: 1110210000411
   Part No SW: 4H0 907 468 E    HW: 4H0 907 468 C
   Component: J533--Gateway H08 0204
   Revision: --------    Serial number: 00000000100444
   Coding: 00C1034A00
   ROD: EV_GatewUDS_AU57.rod
   VCID: 33331CAD9BBA476F537-8066
   Subsystem 1 - Part No SW: 4H0 915 181     HW: 4H0 915 181
   Component: J367-BDM  H07 0140
   Serial number: 00000000005650565978
   Part No SW: 4H0 907 553 C    HW: 4H0 907 553
   Component: LUFE-DAEMPFER H17 0096
   Coding: 008002
   ROD: EV_AirSuspe_VW51.rod
   VCID: 2C0107D14684189712D-8078
   Revision: AA000000    Serial number: 00001002340431
   Coding: C0183B0085053201010001010101112131313333203333
Address 3B: Sensor Elect. (J849)       Labels: None
   Part No SW: 4H0 907 637     HW: 4H0 907 637
   Component: SARA 6D       H02 0015
   Revision: --------    Serial number: EJ1BPA3100D31F0
   ASAM Dataset: EV_SARA 006014
   ROD: EV_SARA_006.rod
   VCID: 6C81C7D18604D89752D-8038
Address 3C: Lane Change        Labels: Redir Fail!
   Part No SW: 4H0 907 566     HW: 4H0 907 566
   Component: J769  SWA MasterH02 0100
   Revision: 00H02000    Serial number: 6PZ 010 287-00
   VCID: 6D87CAD5B19ED19F453-8038
   Subsystem 1 - Part No: 4H0 907 568
   Component: J770  SWA Slave H01 0100
   Subsystem 2 - Serial number: 6PZ 010 287-20
   Subsystem 3 - Serial number: 5F17.02.1100H010003CH10119ÿ
   Subsystem 4 - Serial number: H10119ÿ
   Part No SW: 4H0 959 793 E    HW: 4H0 959 793 E
   Component: TSG FA        H02 0162
   Revision: --------    Serial number: 0000113121958
   Coding: 011F1F205E0062C202000007
   VCID: 3B23348DB36A8F2F8B7-806E
   Revision: 00002001    Serial number: 0143183433
   Coding: 0106023A00FA7585B0B0C7C0020100000000000000000000000000000000
   Subsystem 1 - Part No SW: 4H0 959 719     HW: 4H0 959 719
   Component: GTO BF  H01 0070
   Serial number: 00000000000000019957
   Subsystem 3 - Part No SW: 4H0 959 591     HW: 4H0 959 591
   Component: J245 PS50.028  H06 0006
   Serial number:     WOO1122065Y
   Coding: 020200
   Subsystem 4 - Part No SW: 4H0 947 135 BK    HW: 4H0 947 135 BK
   Component: Dachelektroni  H11 0080
   Serial number: A2011000000000340718
   Subsystem 5 - Part No SW: 4H0 959 591 A    HW: 4H0 959 591 A
   Component: V252 PS009  H05 0004
   Serial number:     WOO1000BRQ$
   Part No SW: 4H0 035 465 A    HW: 4G0 035 465
   Component: BO G3 D4      H06 0150
   Revision: 04S00000    Serial number: 0012765
   VCID: 2411EFF12ED4D0D7DAD-8070
   Subsystem 1 - Part No SW: 4H0 035 466     HW: 4H0 035 466
   Component: BO D4 SLAVE  H51 0180
   Serial number: 00110100002197
   Part No SW: 4H0 959 792 E    HW: 4H0 959 792 E
   Component: TSG BF        H02 0162
   Revision: --------    Serial number: 0000113125040
   VCID: 3A2D3189BC50B627901-806E
   Revision: --------    Serial number: 00000000040905
   ROD: EV_ParkiBrake_VW51.rod
   Part No SW: 4H0 035 082 A    HW: 4H0 035 082
   Component: Radio U SIRIU H51 0068
   Revision: AB001007    Serial number: 155BJ0B7501060
   Coding: 020007010003000001
   VCID: 1F1BE01D07B2F30F87F-804A
   Part No SW: 4H0 035 664 B    HW: 4H0 035 664
   Component: H-BN-NA       H48 0294
   Revision: --------    Serial number: 098B.0B7501792
   Coding: 020200000001F9EF7D128B0E00000003F400010000000000
   VCID: 2615F5F958E822C7C49-8072
   Subsystem 1 - Part No: 8R0 060 884 AC
   Component: NAR 2011  0503
   Subsystem 2 - Part No SW: 4H0 919 604 C    HW: 4H0 919 604 C
   Component: DU8 D4 SV NB  H46 0021
   Serial number: AUZ8ZDB1100CAJD
   Subsystem 3 - Part No SW: 4H1 919 600 D    HW: 4H1 919 600
   Component: E380 BDT D4  H09 0063
   Serial number: 00000000029306
   Subsystem 4 - Part No: 8R0 060 961 A
   Component: CD-Database  2712
   Part No SW: 4H0 959 795 A    HW: 4H0 959 795 A
   Component: TSG HL        H04 0162
   Revision: --------    Serial number: 0000113074527
   Coding: 010F1F20400062C202000007
   VCID: 392F2E85B956BD3F99B-806C
   Part No SW: 4H0 907 441     HW: 4H0 907 441
   Component: SG Rueckfahrkamera  0030
   Revision: --H04---    Serial number: 525 PA8J11D18L
   Coding: 1020003
   VCID: 6597B2F5696EE9DF0D3-8030
Address 6D: Trunk Elect. (----)       Labels:* None
   Part No SW: 4H0 959 107 P    HW: 4H0 959 107 M
   Component: HDSG-Modul    H11 0036
   Revision: 10011001    Serial number: 039100194
   Coding: 0210044100
   ROD: EV_DeckLidContrUnit.rod
   VCID: 3B23348DB3EA8F2F8B7-806E
Address 6F: Centr. Conv. II (J773)       Labels:* None
   Part No SW: 4H0 907 412     HW: 4H0 907 412
   Component: ALM           H05 0004
   Revision: --------    Serial number: 000000024159
   ASAM Dataset: EV_Ambie 001008
   ROD: EV_Ambie.rod
   VCID: 6393ACED6BDA97EFE37-8036
   Component: TSG HR        H04 0162
   Revision: --------    Serial number: 0000113074718
Address 7F: Inform. Electr. II (J829)       Labels: None
   Part No SW: 4H0 035 774 B    HW: 4H0 035 774
   Component: H-BN-NA       H48 0295
   Revision: --------    Serial number: 108AP0B7501069
   Coding: 020200000001004001000004000013000000000000000000
   VCID: 2809FBC152FC34B7F65-807C
   Subsystem 1 - Part No SW: 4H0 919 607     HW: 4H0 919 607
   Component: DU10 RSE  H41 0021
   Serial number: AUZ8ZDB1200745W
   Subsystem 2 - Part No SW: 4H0 919 607     HW: 4H0 919 607
   Serial number: AUZ8ZDB120074YI
   Subsystem 3 - Part No SW: 4H0 919 709 C    HW: 4H0 919 709 C
   Component: E499 BDT 2  H07 0019
   Serial number: 90238KBG0000Q
   Subsystem 5 - Part No: 8R0 060 884 AC
Address 81: Gear Shift (J587)       Labels: 3Y0-927-731.clb
   Part No SW: 4H1 927 731 A    HW: 4H1 927 731 A
   Component: GSM-LL        H05 0081
   Revision: 0L0D5012    Serial number: SN110120  0083
   ASAM Dataset: EV_GSM2x3Mono 001014
   ROD: EV_GSM2x3Mono.rod
   Part No SW: 4G0 907 217     HW: 4H0 907 217 A
   Component: DPC-SG        H24 0034
   Coding: E9060000
   ROD: EV_OnBoardCamerDPC.rod
   VCID: 6597B2F565EEE9DF0D3-8030
Address 88: Multicont. Seat Driver (J873)       Labels:* None
   Part No SW: 4H0 907 182 H    HW: 4H0 907 182 H
   Component: IVB           H07 0042
   Serial number: 00000003190402
   Coding: 764FF2
   ROD: EV_IVBDriveSideFrnt.rod
   VCID: 2F3B10DD7792638F37F-807A
Address 89: Multicont. Seat Pass. (J872)       Labels:* None
   Serial number: 00000003156502
   Coding: 364FF2
   Part No SW: 4H0 907 541 A    HW: 4H0 907 541
   Coding: 3601020201
   ASAM Dataset: EV_AdaptCruisContr2AU64X 001010
   ROD: EV_AdaptCruisContr2AU64X_001.rod
   VCID: 270BF8FD5F623BCFFFF-8072
   Part No SW: 4G0 907 107 B    HW: 4H0 907 107
   Component: BV-SG         H28 0034
   Serial number: 000040181102117
   Coding: 02A19A000111
   ASAM Dataset: EV_BC7 001001
   ROD: EV_BC7.rod
   VCID: 2517F2F5256E29DFCD3-8070
   Part No SW: 4H0 980 945     HW: 4H0 980 945
   Component: RGS-VL        H05 0070
   Coding: 0066F609031F007E070308014240C2010000
   ASAM Dataset: EV_RGS_L 002004
   ROD: EV_RGS_L.rod
   VCID: 6FBBD0DDB712238F77F-803A
   Part No SW: 4H0 980 946     HW: 4H0 980 946
   Component: RGS-VR        H05 0070
   ASAM Dataset: EV_RGS_R 002004
   ROD: EV_RGS_R.rod
   VCID: 70B9D3A1AA2C3C776E5-8024
End----------(Elapsed Time: 03:13, VBatt start/end: 14.3V/14.5V)-----------
Interesting. That's a more old-school BCM than I was thinking would be in this car.
Try changing the coding from:
to:
09072091073C9FE18B000804A0003800409CD308820001218001085C3B00
or even:
09072091073C9FE18B000804A0003800C09CD308820001218001085C3B00
Sawdusty Dan
C?ID=345699
Not that I doubt you know a LOT more about this particular operation than I do, but I would like some clarification first. What, specifically, will changing this section of code (hexidecimal I'm guessing? llooonnng time since basic electronics!) do and to what? Sure I'm missing something, but it looked to me, via web searches, that this section dealt with the headlights and other exterior lights.
I'd just like to know what I should be looking for, after making the change.
For now, all I want to do is shine some different colors inside the cabin. Unless Red, Ivory and Polar are the *only* colors possible with the factory LEDs.... :(
Cheers! :)
Cheers! :)
Well, one of those two bits is "Ambient Lighting Installed", which your BCM does not have set. That one should be documented in Long Coding Helper. I think the other bit enables "Personalization of Ambient Lighting via MMI/Car Menu", but this is less certain, which is why it's not currently documented.
As far as exactly what your LEDs (and the module controlling them) are really capable of, I don't know.
Sawdusty Dan
C?ID=345699
I'm not ignoring you, I've just been fairly tied up with other stuff. Likely to be a couple-few days before I have the time/ambition to delve into the digital mind of my A8. I've looked at the Help pages for this and found the Long Coding Helper section - things are getting clearer. Now, I'm wondering if my A8 is hiding the same kind of multi-color light selection function that I've seen on other Audi models online (unless that was aftermarket stuff?).
"Baby Steps..."
Sawdusty Dan
C?ID=345699
OK, so I finally had the chance to get into this. I found and changed the noted byte from "00" to "40" and "C0" on the Long Coding page. Each one checked the box for 'Interior/Ambient Lighting Adaptability' (or close to that...), but neither made any noticeable change to the MMI or the interior lights. I tried, on a whim, loading hex codes '1-F' in each bit, but nothing else changed, with the exception of the entry for "Footwell Lighting", which went checked/unchecked, along with the interior lights. I did try shutting the car off and turning it back on (not a joke, I really did that) after loading "40" and "C0" and that didn't change anything, either. I also looked at all the other code strings in Module 09 on the Long Code page, but didn't see any that dealt with interior or ambient lighting.
So, I figure it's one of two things - Either my car has three sets of fixed-color LEDs in all of the ambient light strips and other locations, or there exists somewhere in the code (or the Hidden Menu?) a bit/byte/string that tells the LEDs what color to produce, or activates another function within MMI that allows the user to change lighting colors.
MasterTommy
Amsterdam
C?ID=295586
You really want to reboot the MMI after making a coding change. Generally the infotainment system will only pick up configuration changes of other modules at boot. Ignition off is not really useful since it takes a long time before the infotainment system actually shuts down, instead of turning only the screen off. After trying this with said bit changed to C0, my best guess is theres also some adaptation channels to be tweaked in the MMI. We might be able to help if you make an adaptation channel map of both 09 and 5F and post them here.
Sawdusty Dan
C?ID=345699
Sorry about my slow replies - I'm usually either fairly busy, or fairly lazy, and don't get 'round to doing the things I ought to...
You said "...it takes a long time before the infotainment system actually shuts down" How long should I let the car/MMI set, after shutting it off, to get a clean re-boot? I did let it set for just a few seconds after shutting it off, before. I'm really curious to see if anything is different, with a longer wait.
I'll figure out how to do an adaptation channel map and post that, as well, when I get back to it.
Cheers!
MasterTommy
Amsterdam
C?ID=295586
How long? I dont know, thats why a reboot is done manually, so youre certain the unit actually reboots.
