- Aug 22, 2014
- 500
- 231
- Maryland, USA
- C?ID=66650
Hi Folks,
I have this A6 with CEL on. I have tried to look out for air leaks but none. I also cannot seem to believe both banks secondary injection system have failed. Visual inspection shows all hose connections are ok. All fuses tested ok.Also I could not use VCDS to carry out actuator diagnosis on the secondary air pump to run, the sequence goes through but Sec air did not come up on VCDS screen as part of the test during the actuator diagnosis, like as it is in most cases for other audi/vw models.
Is there any measured value blocks I could use to check the fuel trim codes logged? I heard the secondary air ports block sometimes but wondering if all 2 banks ports could block same time or what to look out for?
Any inputs appreciated!
Thanks guys.
Thanks guys.
Friday,23,November,2018,13:32:40:46890
VCDS Version: 18.9.0.2 (x64)
VIN: License Plate: AsiaT
Address 01: Engine Labels: 06E-907-551-CAJ.clb
Control Module Part Number: 4F1 910 551 A HW: 4F1 907 551
Component and/or Version: 3.0l V6 TFSI 0080
Software Coding: 0105000A190F0120
Work Shop Code: WSC 40864 444 84539
VCID: 21422C9DF87EC042FA-8074
053271 - Please Check Fault Codes in Control Module for ABS Brakes
U1017 - 000 - - Intermittent
Mileage: 217274 km
Date: 2008.06.07
Time: 20:49:20
RPM: 896 /min
Mass Air / Rev.: 87.2 mg/str
Temperature: 49.5°C
Bin. Bits: 00000010
Load: 8.6 %
001170 - Secondary Air Injection System: Bank 2
P0492 - 000 - Insufficient Flow - MIL ON
Fault Status: 11100010
Mileage: 217310 km
Date: 2018.11.22
Time: 10:52:50
RPM: 864 /min
Mass Air / Rev.: 256.2 mg/str
Temperature: 27.0°C
Bin. Bits: 00000010
Voltage: 13.67 V
Bin. Bits: 00000010
001169 - Secondary Air Injection System: Bank 1
P0491 - 000 - Insufficient Flow - MIL ON
Mileage: 217310 km
Date: 2018.11.22
Time: 10:52:40
RPM: 896 /min
Mass Air / Rev.: 305.2 mg/str
Temperature: 24.0°C
Bin. Bits: 00000010
Voltage: 13.46 V
Bin. Bits: 00000010
Address 01: DTCs cleared
Address 03: DTCs clearedMonday,28,January,2019,16:33:25:46890
VCDS Version: 18.9.1.0 (x64)
VIN: License Plate: ASIATU
VCID: 21422C9DF87EC042F2-8074
Mileage: 217352 km
Date: 2018.11.23
Time: 09:40:55
RPM: 1280 /min
Mass Air / Rev.: 185.3 mg/str
Temperature: 16.5°C
Bin. Bits: 00000010
Voltage: 13.46 V
Bin. Bits: 00000010
Mileage: 217352 km
Date: 2018.11.23
Time: 09:40:45
RPM: 1280 /min
Mass Air / Rev.: 234.4 mg/str
Temperature: 15.0°C
Bin. Bits: 00000010
Voltage: 13.57 V
Bin. Bits: 00000010
004408 - Fuel Trim: Bank 2 (Add)
P1138 - 000 - System too Lean - Intermittent
Fault Status: 00100001
Mileage: 219142 km
Date: 2019.01.05
Time: 00:46:05
RPM: 672 /min
Mass Air / Rev.: 158.1 mg/str
Temperature: 84.0°C
Bin. Bits: 00000010
Time: 204.8 s
Bin. Bits: 00000010
Chassis Type: 4F-AU56 (4F0)
Scan: 01 02 03 05 07 08 09 0E 0F 15 16 17 19 1E 36 37 42 46 47 4C
4F 52 53 55 56 62 72 77
VIN: WAUSG74FX9N014545 Mileage: 219370km-136310miles
4C-Tire Pressure II -- Status: Malfunction 0010
Address 01: Engine (CCA) Labels:. 06E-907-551-CAJ.clb
Part No SW: 4F1 910 551 A HW: 4F1 907 551
Component: 3.0l V6 TFSI 0080
Revision: --H02--- Serial number:
Shop #: WSC 40864 444 84539
Mileage: 217352 km
Date: 2018.11.23
Time: 09:40:55
RPM: 1280 /min
Temperature: 16.5°C
Bin. Bits: 00000010
Voltage: 13.46 V
Bin. Bits: 00000010
Mileage: 217352 km
Date: 2018.11.23
Time: 09:40:45
RPM: 1280 /min
Temperature: 15.0°C
Bin. Bits: 00000010
Voltage: 13.57 V
Bin. Bits: 00000010
Mileage: 219142 km
Date: 2019.01.05
Time: 00:46:05
RPM: 672 /min
Temperature: 84.0°C
Bin. Bits: 00000010
Time: 204.8 s
Bin. Bits: 00000010
Part No SW: 4F1 910 156 K HW: 09L 927 156 C
Component: AG6 09L 3,0TFSI USA 0020
Revision: --H04--- Serial number: 4488831
Shop #: WSC 02325 785 00200
VCID: 2C5CCDA98FBC1D2A51-8078
Address 03: ABS Brakes Labels: 4F0-910-517.lbl
Part No SW: 4F0 910 517 AL HW: 4F0 614 517 BA
Component: ESP8 quattro H01 0060
Coding: 0020921
VCID: 6ED807A179202F3A3F-803A
Part No SW: 4F0 910 852 B HW: 4F0 905 852 D
Component: FBSAUDIC6 ELV H05 0100
Revision: 00H05000 Serial number: 10602601208775
Coding: 0000003
Shop #: WSC 02323 785 00200
VCID: 254A388DEC562C628E-8070
Subsystem 1 - Part No: 4F0 910 132 J
Component: FBSAUDIC6 EZS H03 0020
Subsystem 2 - Part No: 4F0 910 220 A
Component: FBSAUDIC6 IDG H01 0040
Address 07: Control Head Labels: 4F0-910-7xx-07-H.clb
Part No SW: 4F0 910 732 Q HW: 4E0 035 729
Component: Interfacebox H43 4610
Revision: 00000000 Serial number: 303IY087564962
Coding: 0000003
Shop #: WSC 02335 785 00200
VCID: 3162DCDDA89E70C262-8064
Component: Bedienteil MMIC6H01 0060
Subsystem 2 - Serial number: 00000001194191
Subsystem 3 - Serial number: 0107.10.080000000100011120ÿ
Subsystem 4 - Serial number: 011120ÿ
Part No SW: 4F0 910 043 A HW: 4F1 820 043 AG
Component: KLIMABETAETIGUNGH30 0020
Revision: 00000054 Serial number: 00000000575467
Coding: 0524326
VCID: 1C3C1D69DF1CEDAA21-8048
Part No SW: 4F0 910 279 N HW: 4F0 907 279
Component: ILM Fahrer H22 0320
Coding: 0013123
VCID: 346CD5C9578C45EA09-8060
Subsystem 1 - Part No: 4F1 910 113 D Labels: 1KX-955-119.CLB
Component: Wischer AudiC6 H10 0040
Coding: 00056595
Shop #: WSC 02335
Coding: 00146221
Shop #: WSC 02335
Address 0E: Media Player 1 (R199) Labels:. 4E0-035-785.lbl
Component: SG ext.Player H15 0850
Revision: 00000000
VCID: 2B5ECEB54AB21A1258-807E
Address 0F: Digital Radio Labels: 4E0-910-593-SIR.lbl
Part No SW: 4E0 910 593 M HW: 4E0 035 593 F
Component: SDAR SIRIUS H07 0160
Revision: 00000000 Serial number: AUZ4Z7H0421462
Coding: 0000100
Address 15: Airbags (J234) Labels:* 4F0-910-655-10.clb
Part No SW: 4F0 910 655 M HW: 4F0 959 655 F
Component: Airbag AU1042 H06 0090
Revision: -------- Serial number: 003000000000
Coding: 303142373034303030314A55304C34463053
ROD: EV_Airba10AURB4.rod
VCID: 3162DCDD609E70C262-8064
Subsystem 1 - Part No SW: 4F0 910 339 B HW: 4F0 959 339 B
Component: BF-Gewichtss. H03 0060
Serial number: 5810000R0000002TSL
Serial number: 3574SRB4000081E0625$
Serial number: 3584SRB4000081E4A8CI
Serial number: 35152RB402V7EMTB4KM5
Serial number: 35252RB402P7EMTASSOX
Serial number: 3554NRB40000458B4C63
Serial number: 3564NRB40000458CA98A
Part No SW: 4F0 910 549 A HW: 4F0 953 549 D
Component: J0527 0410
Revision: 00H03000 Serial number: 90026082700132
Coding: 0002041
VCID: 27563285965A3E72BC-8072
Component: E0221 H02 0030
Address 17: Instruments (J285) Labels:. 4F0-920-xxx-17.clb
Part No SW: 4F0 920 951 D HW: 4F0 920 951 D
Component: KOMBIINSTR. H06 0133
Revision: 00200000 Serial number: 9IW441AA8
Coding: 8B960A050300CF05020201
Shop #: WSC 02391 823 56573
VCID: 285431B95B44310AB5-807C
Address 19: CAN Gateway (J533) Labels:. 4F0-907-468.clb
Part No SW: 4F0 907 468 F HW: 4F0 907 468 F
Component: GW-BEM 4CAN-M H06 0024
Revision: 4LA70021 Serial number: 2100L08A050004
Coding: 000303
VCID: 3260D3D16D984BDA1B-8066
Subsystem 1 - Part No SW: 8K0 915 181 C HW: 8K0 915 181 C
Component: J367-BDM H07 0100
Serial number: 00000000002730027267
Address 1E: Media Player 2 Labels: 4E0-910-111.lbl
Part No SW: 4E0 910 110 E HW: 4E0 035 110 A
Component: MP3-Changer H47 0390
Revision: 00047003 Serial number: AUZ5ZBH8619501
VCID: 1A301B71D528939A33-804E
Part No SW: 4F0 959 760 C HW: 4F0 959 760 C
Component: MEM-FS H08 0062
Revision: AA000000 Serial number: 00001001160747
Coding: 00581300004011110000
VCID: 3162DCDD689E70C262-8064
Part No SW: 4E0 910 888 M HW: 4E0 919 887 M
Component: MNS US H52 1100
Revision: 00000000 Serial number: 341JS097816101
Shop #: WSC 08201 444 85739
VCID: 3874E1F94BE4A18A25-806C
Address 42: Door Elect, Driver (J386) Labels:. 4F0-959-793.clb
Part No SW: 4F0 959 793 R HW: 8K0 959 793 D
Component: TSG FA H11 0250
Revision: Serial number: 0000100349455
Coding: 011F07204E40410001
VCID: 46889F01F110C77AA7-8012
008 - Implausible Signal
Fault Status: 01101000
Fault Frequency: 9
Reset counter: 91
Mileage: 215411 km
Date: 2018.09.26
Time: 15:53:12
Part No SW: 4F0 910 289 N HW: 4F0 907 289 N
Component: Komfortgeraet H28 0240
Revision: 02400028 Serial number: 01151969620000
Coding: 4618269
VCID: 356AE8CD5CF65CE23E-8060
Address 47: Sound System (J525) Labels: Redir Fail!
Part No SW: 4F0 910 223 M HW: 4F0 035 223 N
Component: Amp.-ASK-RD H07 0270
Revision: S1400000
Coding: 060000
Fault Frequency: 8
Reset counter: 31
Mileage: 217213 km
Date: 2018.11.11
Time: 17:39:53
Voltage: 11.10 V
Temperature: 20.0°C
Bin. Bits: 00000011
Fault Status: 00101011
Reset counter: 144
Mileage: 218927 km
Date: 2019.01.02
Time: 15:04:59
Voltage: 12.40 V
Temperature: 30.0°C
Bin. Bits: 00000011
Address 4C: Tire Pressure II Labels: 4F0-910-274.clb
Part No SW: 4F0 910 274 A HW: 4F0 907 274
Component: J793 RKA+ H02 0100
Revision: 00000000 Serial number: 00008390032710
Coding: 0623301
Shop #: WSC 00477 128 42026
VCID: 22402391FD78DB5AEB-8076
02214 - Tire Pressure Warning
Reset counter: 162
Mileage: 219282 km
Date: 2019.01.25
Time: 19:49:50
Hex Value: 0x0004
Hex Value: 0x0000
Hex Value: 0x0007
Voltage: 14.30 V
Temperature: 2.0°C
(no units): 53.0
Part No SW: 4F0 910 280 HW: 4F0 907 280 C
Component: ILM Beifahrer H12 0100
Revision: Serial number: 00000000247969
Coding: 0002014
VCID: 5EB857618980BFBA8F-800A
Address 52: Door Elect, Pass. (J387) Labels:. 4F0-959-792.clb
Part No SW: 4F0 959 792 R HW: 8K0 959 792 D
Component: TSG BF H11 0250
Revision: Serial number: 0000100351239
VCID: 458A980DCC16CC62AE-8010
Reset counter: 144
Mileage: 215370 km
Date: 2018.09.25
Time: 11:46:47
Part No SW: 4F0 910 801 D HW: 4F0 907 801 B
Component: EPB CEFC0090 H05 0090
Revision: --H05---
Coding: 0000222
Shop #: WSC 02145 785 00200
Address 55: Headlight Range Labels: 8P0-907-357.lbl
Part No: 8P0 907 357 H
Component: Dynamische LWR H02 0010
Coding: 0000003
VCID: 3F868AE56ECA96B2E4-806A
Part No SW: 4E0 910 541 T HW: 4F0 035 541 N
Revision: 00000000 Serial number: 379J3087539076
Address 62: Door, Rear Left (J388) Labels:. 4F0-959-795.clb
Part No SW: 4F0 959 795 M HW: 8K0 959 795 B
Component: TSG HL H10 0251
Revision: Serial number: 0000100345865
Coding: 010E07204040220001
VCID: 438E8615C222F25280-8016
Address 72: Door, Rear Right (J389) Labels:. 4F0-959-795.clb
Component: TSG HR H10 0251
Revision: Serial number: 0000100365817
Part No SW: 4F0 910 336 H HW: 4E0 862 335
Component: Handyvorb2 H20 1130
Revision: 00000000 Serial number: 00000005064905
Coding: 0010900
VCID: 285431B99B44310AB5-807C
End-------------------------(Elapsed Time: 03:54)--------------------------
