2009 AUDI A6 3.0T Engine light
TFSI
Maryland, USA
C?ID=66650
Hi Folks,
I have this A6 with CEL on. I have tried to look out for air leaks but none. I also cannot seem to believe both banks secondary injection system have failed. Visual inspection shows all hose connections are ok. All fuses tested ok.Also I could not use VCDS to carry out actuator diagnosis on the secondary air pump to run, the sequence goes through but Sec air did not come up on VCDS screen as part of the test during the actuator diagnosis, like as it is in most cases for other audi/vw models.
Is there any measured value blocks I could use to check the fuel trim codes logged? I heard the secondary air ports block sometimes but wondering if all 2 banks ports could block same time or what to look out for?
Any inputs appreciated!
Thanks guys.
Friday,23,November,2018,13:32:40:46890
VCDS Version: 18.9.0.2 (x64)
VIN:    License Plate: AsiaT
                Address 01: Engine       Labels: 06E-907-551-CAJ.clb
Control Module Part Number: 4F1 910 551 A    HW: 4F1 907 551
  Component and/or Version: 3.0l V6 TFSI        0080
           Software Coding: 0105000A190F0120
            Work Shop Code: WSC 40864 444 84539
                      VCID: 21422C9DF87EC042FA-8074
               U1017 - 000 -  - Intermittent
                    Mileage: 217274 km
                    Date: 2008.06.07
                    Time: 20:49:20
                    RPM: 896 /min
                    Mass Air / Rev.: 87.2 mg/str
                    Temperature: 49.5°C
                    Bin. Bits: 00000010
                    Load: 8.6 %
001170 - Secondary Air Injection System: Bank 2
               P0492 - 000 - Insufficient Flow - MIL ON
                    Fault Status: 11100010
                    Mileage: 217310 km
                    Date: 2018.11.22
                    Time: 10:52:50
                    RPM: 864 /min
                    Mass Air / Rev.: 256.2 mg/str
                    Temperature: 27.0°C
                    Bin. Bits: 00000010
                    Voltage: 13.67 V
                    Bin. Bits: 00000010
001169 - Secondary Air Injection System: Bank 1
               P0491 - 000 - Insufficient Flow - MIL ON
                    Mileage: 217310 km
                    Date: 2018.11.22
                    Time: 10:52:40
                    RPM: 896 /min
                    Mass Air / Rev.: 305.2 mg/str
                    Temperature: 24.0°C
                    Bin. Bits: 00000010
                    Voltage: 13.46 V
                    Bin. Bits: 00000010
Address 01: DTCs cleared
Address 03: DTCs clearedMonday,28,January,2019,16:33:25:46890
VCDS Version: 18.9.1.0 (x64)
VIN:    License Plate: ASIATU
                      VCID: 21422C9DF87EC042F2-8074
                    Mileage: 217352 km
                    Date: 2018.11.23
                    Time: 09:40:55
                    RPM: 1280 /min
                    Mass Air / Rev.: 185.3 mg/str
                    Temperature: 16.5°C
                    Bin. Bits: 00000010
                    Voltage: 13.46 V
                    Bin. Bits: 00000010
                    Mileage: 217352 km
                    Date: 2018.11.23
                    Time: 09:40:45
                    RPM: 1280 /min
                    Mass Air / Rev.: 234.4 mg/str
                    Temperature: 15.0°C
                    Bin. Bits: 00000010
                    Voltage: 13.57 V
                    Bin. Bits: 00000010
004408 - Fuel Trim: Bank 2 (Add)
               P1138 - 000 - System too Lean - Intermittent
                    Fault Status: 00100001
                    Mileage: 219142 km
                    Date: 2019.01.05
                    Time: 00:46:05
                    RPM: 672 /min
                    Mass Air / Rev.: 158.1 mg/str
                    Temperature: 84.0°C
                    Bin. Bits: 00000010
                    Time: 204.8 s
                    Bin. Bits: 00000010
Chassis Type: 4F-AU56 (4F0)
Scan: 01 02 03 05 07 08 09 0E 0F 15 16 17 19 1E 36 37 42 46 47 4C
          4F 52 53 55 56 62 72 77
VIN: WAUSG74FX9N014545   Mileage: 219370km-136310miles
4C-Tire Pressure II -- Status: Malfunction 0010
Address 01: Engine (CCA)       Labels:. 06E-907-551-CAJ.clb
   Part No SW: 4F1 910 551 A    HW: 4F1 907 551
   Component: 3.0l V6 TFSI        0080
   Revision: --H02---    Serial number:
   Shop #: WSC 40864 444 84539
                    Mileage: 217352 km
                    Date: 2018.11.23
                    Time: 09:40:55
                    RPM: 1280 /min
                    Temperature: 16.5°C
                    Bin. Bits: 00000010
                    Voltage: 13.46 V
                    Bin. Bits: 00000010
                    Mileage: 217352 km
                    Date: 2018.11.23
                    Time: 09:40:45
                    RPM: 1280 /min
                    Temperature: 15.0°C
                    Bin. Bits: 00000010
                    Voltage: 13.57 V
                    Bin. Bits: 00000010
                    Mileage: 219142 km
                    Date: 2019.01.05
                    Time: 00:46:05
                    RPM: 672 /min
                    Temperature: 84.0°C
                    Bin. Bits: 00000010
                    Time: 204.8 s
                    Bin. Bits: 00000010
   Part No SW: 4F1 910 156 K    HW: 09L 927 156 C
   Component: AG6 09L 3,0TFSI USA 0020
   Revision: --H04---    Serial number:        4488831
   Coding: 0000002
   Shop #: WSC 02325 785 00200
   VCID: 2C5CCDA98FBC1D2A51-8078
Address 03: ABS Brakes        Labels: 4F0-910-517.lbl
   Part No SW: 4F0 910 517 AL    HW: 4F0 614 517 BA
   Component: ESP8 quattro    H01 0060
   Coding: 0020921
   VCID: 6ED807A179202F3A3F-803A
   Part No SW: 4F0 910 852 B    HW: 4F0 905 852 D
   Component: FBSAUDIC6 ELV   H05 0100
   Revision: 00H05000    Serial number: 10602601208775
   Coding: 0000003
   Shop #: WSC 02323 785 00200
   VCID: 254A388DEC562C628E-8070
   Subsystem 1 - Part No: 4F0 910 132 J
   Component: FBSAUDIC6 EZS   H03 0020
   Subsystem 2 - Part No: 4F0 910 220 A
   Component: FBSAUDIC6 IDG   H01 0040
Address 07: Control Head        Labels: 4F0-910-7xx-07-H.clb
   Part No SW: 4F0 910 732 Q    HW: 4E0 035 729
   Component: Interfacebox    H43 4610
   Revision: 00000000    Serial number: 303IY087564962
   Coding: 0000003
   Shop #: WSC 02335 785 00200
   VCID: 3162DCDDA89E70C262-8064
   Component: Bedienteil MMIC6H01 0060
   Subsystem 2 - Serial number: 00000001194191
   Subsystem 3 - Serial number: 0107.10.080000000100011120ÿ
   Subsystem 4 - Serial number: 011120ÿ
Address 08: Auto HVAC        Labels: 4F0-910-043.clb
   Part No SW: 4F0 910 043 A    HW: 4F1 820 043 AG
   Component: KLIMABETAETIGUNGH30 0020
   Revision: 00000054    Serial number: 00000000575467
   Coding: 0524326
   VCID: 1C3C1D69DF1CEDAA21-8048
   Part No SW: 4F0 910 279 N    HW: 4F0 907 279
   Component: ILM Fahrer      H22 0320
   Coding: 0013123
   VCID: 346CD5C9578C45EA09-8060
   Subsystem 1 - Part No: 4F1 910 113 D  Labels: 1KX-955-119.CLB
   Component: Wischer AudiC6  H10 0040
   Coding: 00056595
   Shop #: WSC 02335
   Coding: 00146221
   Shop #: WSC 02335
Address 0E: Media Player 1 (R199)       Labels:. 4E0-035-785.lbl
   Part No SW: 4E0 035 785 F    HW: 4E0 035 785 C
   Component: SG ext.Player H15 0850
   Revision: 00000000
   VCID: 2B5ECEB54AB21A1258-807E
Address 0F: Digital Radio        Labels: 4E0-910-593-SIR.lbl
   Part No SW: 4E0 910 593 M    HW: 4E0 035 593 F
   Component: SDAR SIRIUS     H07 0160
   Revision: 00000000    Serial number: AUZ4Z7H0421462
   Coding: 0000100
Address 15: Airbags (J234)       Labels:* 4F0-910-655-10.clb
   Part No SW: 4F0 910 655 M    HW: 4F0 959 655 F
   Component: Airbag AU1042 H06 0090
   Revision: --------    Serial number: 003000000000
   Coding: 303142373034303030314A55304C34463053
   ROD: EV_Airba10AURB4.rod
   VCID: 3162DCDD609E70C262-8064
   Subsystem 1 - Part No SW: 4F0 910 339 B    HW: 4F0 959 339 B
   Component: BF-Gewichtss.  H03  0060
   Serial number: 5810000R0000002TSL
   Serial number: 3574SRB4000081E0625$
   Serial number: 3584SRB4000081E4A8CI
   Serial number: 35152RB402V7EMTB4KM5
   Serial number: 35252RB402P7EMTASSOX
   Serial number: 3554NRB40000458B4C63
   Serial number: 3564NRB40000458CA98A
   Part No SW: 4F0 910 549 A    HW: 4F0 953 549 D
   Component: J0527               0410
   Revision: 00H03000    Serial number: 90026082700132
   Coding: 0002041
   VCID: 27563285965A3E72BC-8072
   Component: E0221           H02 0030
Address 17: Instruments (J285)       Labels:. 4F0-920-xxx-17.clb
   Part No SW: 4F0 920 951 D    HW: 4F0 920 951 D
   Component: KOMBIINSTR.   H06 0133
   Revision: 00200000    Serial number: 9IW441AA8
   Coding: 8B960A050300CF05020201
   Shop #: WSC 02391 823 56573
   VCID: 285431B95B44310AB5-807C
   Part No SW: 4F0 907 468 F    HW: 4F0 907 468 F
   Component: GW-BEM 4CAN-M H06 0024
   Revision: 4LA70021    Serial number: 2100L08A050004
   Coding: 000303
   VCID: 3260D3D16D984BDA1B-8066
   Subsystem 1 - Part No SW: 8K0 915 181 C    HW: 8K0 915 181 C
   Component: J367-BDM  H07 0100
   Serial number: 00000000002730027267
Address 1E: Media Player 2        Labels: 4E0-910-111.lbl
   Part No SW: 4E0 910 110 E    HW: 4E0 035 110 A
   Component: MP3-Changer     H47 0390
   Revision: 00047003    Serial number: AUZ5ZBH8619501
   VCID: 1A301B71D528939A33-804E
   Part No SW: 4F0 959 760 C    HW: 4F0 959 760 C
   Component: MEM-FS        H08 0062
   Revision: AA000000    Serial number: 00001001160747
   Coding: 00581300004011110000
   VCID: 3162DCDD689E70C262-8064
   Part No SW: 4E0 910 888 M    HW: 4E0 919 887 M
   Component: MNS US          H52 1100
   Revision: 00000000    Serial number: 341JS097816101
   Shop #: WSC 08201 444 85739
   VCID: 3874E1F94BE4A18A25-806C
   Part No SW: 4F0 959 793 R    HW: 8K0 959 793 D
   Revision:             Serial number: 0000100349455
   Coding: 011F07204E40410001
   VCID: 46889F01F110C77AA7-8012
                    Fault Status: 01101000
                    Fault Frequency: 9
                    Reset counter: 91
                    Mileage: 215411 km
                    Date: 2018.09.26
                    Time: 15:53:12
Address 46: Central Conv.        Labels:. 4F0-910-289.lbl
   Part No SW: 4F0 910 289 N    HW: 4F0 907 289 N
   Component: Komfortgeraet   H28 0240
   Revision: 02400028    Serial number: 01151969620000
   Coding: 4618269
   VCID: 356AE8CD5CF65CE23E-8060
Address 47: Sound System (J525)       Labels: Redir Fail!
   Part No SW: 4F0 910 223 M    HW: 4F0 035 223 N
   Component: Amp.-ASK-RD   H07 0270
   Revision: S1400000
   Coding: 060000
            000 -  -  - Intermittent
                    Fault Frequency: 8
                    Reset counter: 31
                    Mileage: 217213 km
                    Date: 2018.11.11
                    Time: 17:39:53
                    Voltage: 11.10 V
                    Temperature: 20.0°C
                    Bin. Bits: 00000011
                    Fault Status: 00101011
                    Reset counter: 144
                    Mileage: 218927 km
                    Date: 2019.01.02
                    Time: 15:04:59
                    Voltage: 12.40 V
                    Temperature: 30.0°C
                    Bin. Bits: 00000011
Address 4C: Tire Pressure II        Labels: 4F0-910-274.clb
   Part No SW: 4F0 910 274 A    HW: 4F0 907 274
   Component: J793  RKA+      H02 0100
   Revision: 00000000    Serial number: 00008390032710
   Coding: 0623301
   Shop #: WSC 00477 128 42026
   VCID: 22402391FD78DB5AEB-8076
02214 - Tire Pressure Warning
                    Reset counter: 162
                    Mileage: 219282 km
                    Date: 2019.01.25
                    Time: 19:49:50
                    Hex Value: 0x0004
                    Hex Value: 0x0000
                    Hex Value: 0x0007
                    Voltage: 14.30 V
                    Temperature: 2.0°C
                    (no units): 53.0
   Part No SW: 4F0 910 280     HW: 4F0 907 280 C
   Component: ILM Beifahrer   H12 0100
   Revision:             Serial number: 00000000247969
   Coding: 0002014
   VCID: 5EB857618980BFBA8F-800A
   Part No SW: 4F0 959 792 R    HW: 8K0 959 792 D
   Revision:             Serial number: 0000100351239
   VCID: 458A980DCC16CC62AE-8010
                    Reset counter: 144
                    Mileage: 215370 km
                    Date: 2018.09.25
                    Time: 11:46:47
Address 53: Parking Brake        Labels: 4F0-910-801.clb
   Part No SW: 4F0 910 801 D    HW: 4F0 907 801 B
   Component: EPB  CEFC0090   H05 0090
   Revision: --H05---
   Coding: 0000222
   Shop #: WSC 02145 785 00200
   Part No: 8P0 907 357 H
   Coding: 0000003
   VCID: 3F868AE56ECA96B2E4-806A
   Part No SW: 4E0 910 541 T    HW: 4F0 035 541 N
   Component: TUNER EU/US/RDW H42 0630
   Revision: 00000000    Serial number: 379J3087539076
   Coding: 0000002
   Part No SW: 4F0 959 795 M    HW: 8K0 959 795 B
   Revision:             Serial number: 0000100345865
   Coding: 010E07204040220001
   VCID: 438E8615C222F25280-8016
   Revision:             Serial number: 0000100365817
   Part No SW: 4F0 910 336 H    HW: 4E0 862 335
   Component: Handyvorb2      H20 1130
   Revision: 00000000    Serial number: 00000005064905
   Coding: 0010900
   VCID: 285431B99B44310AB5-807C
End-------------------------(Elapsed Time: 03:54)--------------------------
NostraJackAss
Please clear codes and post a fresh auto-scan and with Mode 9 of OBD2 please.
Thank you
Jef
HQ
Under certain driving conditions, the secondary air ports in the cylinder head can accumulate carbon over time, causing a restriction.
- Technical Service Bulletin 2033001
This is a very common issue for older V6 engines in the Audi fleet. The fix is to drop the exhaust, expose the front end of the engine and with special adapters pressure wash the ports in the cylinder heads. Then, X miles later, it will do it again. :cry:
