this its the actually adaptation Chanel
SW:3Q0-907-379-AB HW:3Q0-907-379-G --- ABS Brakes --- SA: 20103
Component:ESC H42 0723, Coding:12F162A224280A75017C060641C72548462450806082A4F21441F0080608
EV_Brake1UDSContiMK100IPB,034036,EV_Brake1UDSContiMK100IPB_034.rod
Wednesday,17,June,2020,23:21:05:64015
VCDS Version: Release 20.4.0 Data version: 20200331 DS317.0
VCID: 7AADF0910C50F92B1D6-802E
IDE00001-Production mode,not active ,3
IDE00252-Brake system vacuum pump,5 ,1
IDE00820-Activating and deactivating all development messages,0 ,1
IDE01763-Dimming,activated ,1
IDE02332-Deactivate production mode,Deactivating ,3
IDE03493-Driver door status,activated ,1
IDE03659-Roller test bench mode,Manual activation: possible ,1
IDE04456-Brake disk drying,Medium ,1
IDE04508-Hydraulic brake booster,8 ,1
IDE04643-Overboost in brake system,activated ,1
IDE04645-IDE05287-Electromechanical parking brake-Automatic application,activated ,2
IDE04645-MAS05667-Electromechanical parking brake-Driver presence recognition via brake pedal,not activated ,2
IDE04765-Counter steer support,Strong ,1
IDE04774-Vehicle and trailer stabilization,not activated ,1
IDE04871-Dynamic starting assist,normal ,1
IDE04939-Tire pressure monitoring display,0 ,1
IDE04944-Brake pedal evaluation,activated ,1
IDE04949-Engine drag torque control,activated ,1
IDE04951-Brake booster,4 ,1
IDE04952-Braking torque boost for distance regulation,3 ,1
IDE05055-Hydraulic brake assistant,normal ,1
IDE05057-Brake prefill,activated ,1
IDE05161-Straight ahead brake stabilization,activated ,1
IDE05263-AUTO HOLD functionality,not activated ,1
IDE05264-AUTO HOLD increase threshold: reduced tensioning force,0 %,1
IDE05265-AUTO HOLD increase threshold: full tensioning force,10 %,1
IDE05286-Expanded electronic differential lock,Standard ,1
IDE05337-Starting vibration reduction-,Strong ,1
IDE05337-MAS02653-Starting vibration reduction-Torque limitation,Deactivated ,1
IDE05711-Automatic application during engine stalling,activated ,1
IDE06137-IDE04772-Monitoring of functional lights-Indicator light in the button for electromech. parking brake,7 ,2
IDE06137-IDE05333-Monitoring of functional lights-Indicator light in AUTO HOLD button,7 ,2
IDE06139-AUTO HOLD slippage recognition,activated ,1
IDE06505-Electromechanical parking brake: delay level,6 ,1
IDE07006-Tire pressure monitoring display: tire selection,0 ,1
IDE07565-ABS in lower speed range,activated ,1
IDE07848-Thresholds for brake performance,activated ,1
MAS00122-Electronic Stability Program,not activated ,1
MAS00970-Running manufacturer number,activated ,1
MAS01180-AUTO HOLD functional status,Last setting ,1
MAS01299-Offroad,0 ,1
MAS02080-XCP calibration protocol,not activated ,1
MAS02138-Hill-start assistant,normal ,1
MAS02666-Seat belt buckle scan,activated ,1
MAS08145-Hill-start assistant: increase threshold,3 %,1
MAS09008-MAS00988-Plausibility check-Reverse gear,activated ,3
MAS09008-MAS09009-Plausibility check-Neutral gear sensor,activated ,3
MAS09008-MAS10668-Plausibility check-Clutch movement,activated ,3
ENG118148-Developer_Function_1,0 ,1
ENG130301-Developer_Function_121,not activated ,1
ENG122844-ENG101574-dimming_characteristic_1-X1,0 ,12
ENG122844-ENG99557-dimming_characteristic_1-X2,50 ,12
ENG122844-ENG102140-dimming_characteristic_1-X3,220 ,12
ENG122844-ENG102936-dimming_characteristic_1-X4,6 ,12
ENG122844-ENG103548-dimming_characteristic_1-X5,8 ,12
ENG122844-ENG113992-dimming_characteristic_1-X6,80 ,12
ENG122844-ENG99777-dimming_characteristic_1-Y1,10 ,12
ENG122844-ENG100480-dimming_characteristic_1-Y2,100 ,12
ENG122844-ENG100773-dimming_characteristic_1-Y3,253 ,12
ENG122844-ENG100631-dimming_characteristic_1-Y4,6 ,12
ENG122844-ENG102174-dimming_characteristic_1-Y5,12 ,12
ENG122844-ENG113993-dimming_characteristic_1-Y6,100 ,12
ENG122845-ENG101574-dimming_characteristic_2-X1,0 ,12
ENG122845-ENG99557-dimming_characteristic_2-X2,50 ,12
ENG122845-ENG102140-dimming_characteristic_2-X3,220 ,12
ENG122845-ENG102936-dimming_characteristic_2-X4,6 ,12
ENG122845-ENG103548-dimming_characteristic_2-X5,8 ,12
ENG122845-ENG113992-dimming_characteristic_2-X6,80 ,12
ENG122845-ENG99777-dimming_characteristic_2-Y1,10 ,12
ENG122845-ENG100480-dimming_characteristic_2-Y2,100 ,12
ENG122845-ENG100773-dimming_characteristic_2-Y3,253 ,12
ENG122845-ENG100631-dimming_characteristic_2-Y4,6 ,12
ENG122845-ENG102174-dimming_characteristic_2-Y5,12 ,12
ENG122845-ENG113993-dimming_characteristic_2-Y6,100 ,12
Elapsed Time: 00:16
