Friday,05,April,2019,18:13:55:58300
VCDS Version: 18.9.1.0 (x64) HEX-V2 CB: 0.4437.4
Dealer/Shop Name: VW UK
VIN: WVWZZZAUZEP074956 License Plate:
Mileage: 54148km-33646mi Repair Order:
Chassis Type: AU-VW37 (5Q0)
Scan: 01 02 03 08 09 10 13 15 16 17 19 3C 42 44 52 55 5F A5
VIN: WVWZZZAUZEP074956 Mileage: 54148km-33646miles
Address 01: Engine (J623-CRBC) Labels:. 04L-907-309-V1.clb
Part No SW: 04L 906 021 DT HW: 04L 907 309 D
Component: R4 2,0L EDC H22 5520
Revision: 83H22---
Coding: 011D0032036505082000
Shop #: WSC 12345 123 12345
ASAM Dataset: EV_ECM20TDI01104L906021DT 002004
ROD: EV_ECM20TDI01104L906021DT_002.rod
VCID: 7AAC0754FC516217D09-802E
17158 - Databus
Mileage: 54144 km
Date: 2019.04.05
Time: 06:59:16
Coolant temperature: 13 °C
Intake air temperature: 13 °C
Voltage terminal 30: 11.200 V
Drivetrain coordinator: brake fault status-Bits 0-7: 5
Drivetrain coordinator: brake function status-Bits 0-7: 4
Acceleration: 0.000 m/s²
Part No SW: 0D9 300 040 N HW: 02E 927 770 AQ
Component: DQ250-6F MQB H52 4305
Revision: 03252204 Serial number: TFK01401250588
Shop #: WSC 00028 028 00066
ROD: EV_TCMDQ250021.rod
VCID: 221C1F343441CAD7A89-8076
P1734 00 [002] - -
Part No SW: 3Q0 907 379 AB HW: 3Q0 907 379 G
Component: ESC H42 0723
Revision: 00000000 Serial number: 60496000000281
Coding: 01FA8AA1242709700380060541C92980512490C0608294F338625078C282
7 Faults Found:
0212 - Longitudinal Acceleration Sensor
C1017 54 [137] - Missing Calibration / Basic Setting
Reset counter: 18
Date: 2019.04.05
Time: 06:57:52
0270 - Lateral Acceleration Sensor
C1079 54 [137] - Missing Calibration / Basic Setting
Reset counter: 18
Date: 2019.04.05
Time: 06:57:52
0279 - Brake Pressure Sensor 1
C107A 54 [137] - Missing Calibration / Basic Setting
Reset counter: 18
Date: 2019.04.05
Time: 06:57:52
0295 - Steering angle sensor
Reset counter: 18
Date: 2019.04.05
Time: 06:57:52
8299 - Databus
[FCAN: Anhaenger_01_alt veraltet bit is set]
Reset counter: 18
Date: 2019.04.05
Time: 06:57:52
16413 - Display for Tire Pressure Monitoring
Reset counter: 18
Mileage: 54144 km
Date: 2019.04.05
Time: 06:59:26
33000 - Longitudinal Acceleration
C10B1 29 [137] - Signal Implausible
[IPB-Sensor: Longitudinal acceleration sensor failure]
Reset counter: 18
Date: 2019.04.05
Time: 06:57:52
Part No SW: 5G0 907 426 AK HW: 5G0 907 426 AK
Component: AC Manuell H03 1601
Revision: 00001K06
Coding: 00120104202110001000000000000002
Shop #: WSC 00028 028 00024
ASAM Dataset: EV_ACManueBHBVW37X 004132
ROD: EV_ACManueBHBVW37X_004_VW37.rod
VCID: 74B0296CDE3514678A5-8020
262914 - Refrigerant Pressure
B10AB F0 [009] - Too Low
Reset counter: 18
Mileage: 54144 km
Date: 2019.04.05
Time: 06:57:51
Outside air temperature: 12.0 °C
Engine speed: 0 /min
Temperature after evaporator: 14.3 °C
System run time-Terminal 15 on: 75 s
Part No SW: 5Q0 937 084 AJ HW: 5Q0 937 084 AJ
Component: BCM MQBAB H H18 0134
Serial number: 01011411900972
Coding: 03041A44C241227B0BA44080B10403281000000000000000000000000000
ROD: EV_BCMBOSCH_013.rod
VCID: 005875BC9A8D38C79ED-8054
Component: WWS 140216 042 0551
Serial number: 140218200751
Subsystem 2 - Part No SW: 5Q0 955 559 HW: 5Q0 955 559 Labels: 5Q0-955-547.CLB
Component: RLS 024 0042
Serial number: Y14M02D28H03M27S12S8
Coding: 00A8DD
Component: Sensor, DWA 005 0315
Serial number: 000000000ZY140340CLY
Serial number: 00000000000028780639
Part No SW: 5QA 919 298 C HW: 5QA 919 298 A
Serial number: 000308417617293
Coding: 0371265851
VCID: 50F885FC0A6D08474ED-8004
13637426 - Databus
Reset counter: 18
Mileage: 54144 km
Date: 2019.04.05
Time: 06:57:51
13688835 - Databus
[Steuergerät für Rear Cross Traffic Alert - RCTA_01.RCTA_Status - Fehlerspeicher auslesen]
Reset counter: 18
Mileage: 54148 km
Date: 2019.04.05
Time: 07:15:52
Address 13: Auto Dist. Reg (J428) Labels:| 5Q0-907-572-V1.clb
Part No SW: 5Q0 907 572 B HW: 5Q0 907 572 B
Component: ACC Bosch MQB H04 0200
Serial number: 12041476510678
Coding: 001C1300FE0339
ASAM Dataset: EV_ACCMRRBoschVW372 001014
VCID: 3634D36488C94677741-8062
1071 - Databus
[FAULT_CIS_AXV_INVALID]
Reset counter: 18
Mileage: 54144 km
Date: 2019.04.05
Time: 06:57:51
Control Module temperature: 19 °C
Voltage terminal 15: 11.8 V
Vehicle speed: 0.00 m/s
Acceleration: 0.00 m/s²
1056 - Databus
[FAULT_CIS_ECD_FAIL]
Reset counter: 18
Mileage: 54144 km
Date: 2019.04.05
Time: 06:57:51
1058 - Databus
[FAULT_CIS_ECD_NOTAVAILABLE]
Reset counter: 18
Mileage: 54144 km
Date: 2019.04.05
Time: 06:57:51
1059 - Databus
[FAULT_CIS_ESP_FAIL]
Reset counter: 18
Mileage: 54144 km
Date: 2019.04.05
Time: 06:57:51
Control Module temperature: 20 °C
1043 - Automatic Distance Control
B10E7 F0 [009] - Disconnected
[FAULT_CIS_TSK_IRREV_FAIL]
Reset counter: 18
Mileage: 54144 km
Date: 2019.04.05
Time: 06:57:51
Part No SW: 5Q0 959 655 AA HW: 5Q0 959 655 AA
Component: AirbagVW20 014 0386
Serial number: 003MLR03W5K4
Shop #: WSC 00028 028 00061
ROD: EV_AirbaVW20SMEVW37X.rod
VCID: 7F5AF640E773473FE77-802A
Belt Pretensioner left:
Component: BeltPretRevFL H35 0341
Serial number: 34169677B28021450347
Coding: 333135
Belt Pretensioner right:
Component: BeltPretRevFR H35 0341
Serial number: 34169676B27021450365
Coding: 333135
Subsystem 3 - Part No SW: ----------- HW: 480 002 402 14
Serial number: 35767000000705E00F0Q
Subsystem 4 - Part No SW: ----------- HW: 480 002 702 14
Serial number: 35867000000A4B251F0Y
Subsystem 5 - Part No SW: ----------- HW: 480 402 502 14
Serial number: 3516502BB142B1C08210
Subsystem 6 - Part No SW: ----------- HW: 480 402 802 14
Serial number: 3526502A312F6292D3FI
Subsystem 7 - Part No SW: ----------- HW: 480 402 402 14
Serial number: 3556502C112F62954096
1049094 - Databus
[NWD: 0x101 ESP_02 error value ESP_Laengsbeschleunigung]
Reset counter: 18
Mileage: 54148 km
Date: 2019.04.05
Time: 07:16:53
Part No SW: 5Q0 953 507 DD HW: 5Q0 953 549 C
Component: Lenks. Modul 002 0110
Revision: -------- Serial number: 03031404220519
Coding: 0C10
Shop #: WSC 40898 002 1048576
ROD: EV_SMLSKLOMQB_VW37.rod
VCID: 7BA20250F36B5B1FCBF-802E
Part No SW: 5G0 920 961 A HW: 5G0 920 961 A
Component: KOMBI 252 2210
Coding: 27A519086F882E0001886A0B040000
VCID: 28080D1C527D2087F6D-807C
Part No SW: 5Q0 907 530 Q HW: 5Q0 907 530 M
Component: GW MQB High 212 2163
Revision: -------- Serial number: 04031410800267
Coding: 030100040B087300EF00005C1C0F00010001000000000000000000000000
ASAM Dataset: EV_GatewConti 010015
ROD: EV_GatewConti_010.rod
VCID: 3FDAB640A7F3873FA77-806A
Component: E221__MFL-DC1 H15 0038
Serial number: 29140000230530104075
Coding: 2DFFFF
Subsystem 3 - Part No SW: 5Q0 915 181 E HW: 5Q0 915 181 E
Component: J367-BDMHella H03 8043
Serial number: 5289432703
Component: HRE_Master H12 0071
Serial number: 0400936029
Coding: 02031203
ROD: EV_HREntryHella_VW37.rod
VCID: 3C20C14CB6E59C27825-8068
Subsystem 1 - Part No SW: 5Q0 907 685 B HW: 5Q0 907 685 B
Component: HRE_Slave H12 0071
Serial number: 0400325995
Coding: 020312
730378 - Warning Lamp for Blind Spot Detection in Left Exterior Mirror
C122C 15 [009] - Open or Short to Plus
Reset counter: 18
Mileage: 54148 km
Date: 2019.04.05
Time: 07:15:51
Part No SW: 5Q4 959 593 B HW: 5Q4 959 593 B
Component: TSG FS 009 0014
Serial number: 0000093468588
Coding: 003F0220D001048000001000
VCID: 44D0B9ACCE15E4E7FA5-8010
Subsystem 1 - Part No SW: 5Q4 959 812 A HW: 5Q4 959 812 A Labels: 5QX-959-81X-V1.CLB
Serial number: 00000000000004375448
Coding: 0D0000
Part No SW: 5Q0 909 144 P HW: 5Q0 909 144 P
Component: EPS_MQB_ZFLS 122 1043
Coding: 9303
ROD: EV_SteerAssisMQB_010.rod
VCID: 41DEB0B8D107F1CFD13-8014
19204 - Databus
[ESP_02 Botschaft - SNA_Check]
Reset counter: 40
Mileage: 54144 km
Date: 2019.04.05
Time: 07:00:26
Motor status: 01
System status: Driving mode
Supply voltage: 11.25 V
Temperature: 22.0 °C
KFC: 4B
KFA: 00 04
Environmental conditions: 21
uioUdNotFilt_xdu16: 11.52 V
uAdSensI_SwitchedKl30_xdu16: 11.52 V
Part No SW: 5Q4 959 592 B HW: 5Q4 959 592 B
Component: TSG BFS 009 0014
Serial number: 0000093350543
Coding: 003F0020DE01048000801000
VCID: 43D2BAB0CB1BE3DFC3F-8016
Subsystem 1 - Part No SW: 5Q4 959 811 A HW: 5Q4 959 811 A Labels: 5QX-959-81X-V1.CLB
Serial number: 00000000000004391698
Coding: 050000
Component: AFS-ECU H07 0090
Coding: 06AE01000B000200
Shop #: WSC 00028 028 00068
VCID: 40D8B5BCDA0DF8C7DED-8014
Subsystem 1 - Part No SW: 3D0 941 329 E HW: 3D0 941 329 E Labels: 3D0-941-329.CLB
Component: LeiMo links H01 0002
Coding: 2E0000
Subsystem 2 - Part No SW: 3D0 941 329 E HW: 3D0 941 329 E Labels: 3D0-941-329.CLB
Component: LeiMo rechts H01 0002
Coding: 2E0000
5256725 - Rear Left Ride-Height Sensor
C1036 15 [137] - Open or Short to Plus
Reset counter: 18
Mileage: 54144 km
Date: 2019.04.05
Time: 06:57:51
Address 5F: Information Electr. (J794) Labels:| 5G0-035-MIB-STD1.clb
Part No SW: 5G0 035 874 HW: 5G0 035 874
Component: MU-S-ND-ER 040 0430
Serial number: V7F02202142644
Coding: 02730001FF00000021111201002800001F0106160100010045
ROD: EV_MUStd4CPASE_VW37.rod
VCID: 678A4E209FE3EFFF3F7-8032
Subsystem 1 - Part No SW: 5G0 919 605 D HW: 5G0 919 605 D
Component: ABT_Std_Nav H51 0022
Serial number: VWZ8Z9NJ9037N4
Subsystem 2 - Part No SW: 5G0 919 866 F HW: -----------
Component: ECE 2014 --- 0036
Address A5: Frt Sens. Drv. Assist (R242) Labels:| 5Q0-980-653.clb
Part No SW: 5Q0 980 653 G HW: 5Q0 980 653
Component: MQB_MFK H06 0060
Serial number: 10000102807
Coding: 0100000001020303000300010100010100
ROD: EV_MFKBoschAU370.rod
End----(Elapsed Time: 01:50, VBatt start/end: 12.0V/11.9V. VIgn 12.0V)-----
