MINOR - Different mileage in filenames vs. freeze-frames - normal?
drhaller
Canada
C?ID=4930
My full scan was called Log<licplate>-<vin>-<km>km-<mileage>mi.txt.
For example, Log-XXXX999-WA1C7AFP6GAzzzzzz-36000km-22369mi.txt
The licplate value was filled in by me and I left the repair order blank.
NOTE - a full scan can be made available for Ross-Tech Support. At the top I see the 36000km value.
Mileage: 36000km-22369mi Repair Order:​
BUT - for a fault from today from Address 03: ABS Brakes (J104) the freeze frame shows "Mileage: 36007 km"
Other prior faults have a lower mileage just odd that the file-name did not actually have the latest actual mileage which shows 36007km on the dash.
As I said - this is minor. Cheers,
/dan
That's a "rounding error". In some places in the car, the mileage is stored without the last digit...
drhaller
Canada
C?ID=4930
Rounding...
How un-German of Audi :).
Thanks Uwe... as I said, not an issue just an observation.
I looked at a few of my other logs and I see that pattern now. Pretty funny since the Freeze Frame stores the time (to the second), RPM and the air temperature.
Now if you could work magic on my Steering Assist issue that made my 2016 Q5 a 2.5 ton brick, that would be great :banghead:.
/dan
