I need abs coding for Skoda
SPEEDLINE
Australia
C?ID=350368
VIN: TMBFN65J0D3039322 License Plate:
Chassis Type: 5J-SK25 (6N0)
Scan: 01 02 03 08 09 15 17 19 25 44 56 77
VIN: TMBFN65J0D3039322 Mileage: 59960km-37257miles
Address 01: Engine (J623-CBZB) Labels:. 03F-906-070-CBZ.clb
Part No SW: 03F 906 070 HL HW: 03F 907 309 AK
Component: SIMOS10.22AH10 5491
Revision: --H10--- Serial number:
Coding: 00250056202400080000
Shop #: WSC 13765 031 00018
ASAM Dataset: EV_ECM12TFS02103F906070HL 004006
ROD: EV_ECM12TFS02103F906070FP.rod
VCID: 73A6DCB0DAC9A4D2D6-8026
16712 - System Voltage
P0562 00 [032] - Too Low
Mileage: 59968 km
Date: 2019.01.07
Time: 00:05:41
Vehicle speed: 255 km/h
Coolant temperature: 30 °C
Intake air temperature: 32 °C
Voltage terminal 30: 8.183 V
Engine speed: actual: 0 /min
Air mass: actual value:-MAF: 344.69 mg/stroke
Coolant temperature (unfiltered): 30.0 °C
FRF_IMMO_SNAPSHOT_BYTE1: 255
Readiness: 0110 0101
Address 02: Auto Trans
Address 03: ABS Brakes (J104) Labels:. 6R0-907-37x-ESP82.clb
Part No SW: 6R0 907 379 AL HW: 6R0 907 379 AF
Component: ESP8.2i front H05 0001
Revision: --------
Shop #: WSC 13765 790 00018
VCID: 085C9B5CBF4FB70A93-805C
03306 - Coding Not Valid
Reset counter: 29
Mileage: 59968 km
Date: 2013.05.30
Time: 11:34:34
Hex Value: 0x0007
Hex Value: 0x0000
Hex Value: 0x3209
Hex Value: 0x14AD
Hex Value: 0x007E
Hex Value: 0x7F7F
Hex Value: 0x7F00
Reset counter: 29
Mileage: 59968 km
Date: 2013.05.30
Time: 11:34:34
Hex Value: 0x0007
Hex Value: 0x0000
Hex Value: 0x3211
Hex Value: 0x14AD
Hex Value: 0x007E
Hex Value: 0x7F7F
Hex Value: 0x7F00
SPEEDLINE
Australia
C?ID=350368
can anyone help please
Henrick
Lithuania
LP/IP
If you don't find the code, these ABS can be very easily and correctly coded with ABRITES tool (AVDI). You might want to check your local surroundings if someone neaby has got one and is willing to exchange his 5 minutes of time for a glass of beer :)
SPEEDLINE
Australia
C?ID=350368
how about Carprog? I got Carprog but I didn't try
PetrolDave
Westbury, UK
C?ID=1423
You're going to have to post a full unedited Auto-Scan for someone to be able to suggest possible codings for the ABS.
iichel
Netherlands, eastern part
C?ID=284912
I'm going to need a full scan please. What was the reason the coding was lost? Any idea?
Edit: educated guess:
410128DB216E00BB822514E284D500401300
430128DB217200B4C22D14EA84DA00801700
430128DB217200B4C22D14EA84DA00801300
SPEEDLINE
Australia
C?ID=350368
Hi
I think they changed cluster
Because they told me they change cluster but car won’t starting and then they put original bach
iichel
C?ID=284912
I think you need to adjust the cluster/immobiliser first before you can do anything with ABS coding. The VIN in the engine needs to match that of the immobiliser and cluster. If it doesn't, there is no way we can code the ABS.
SPEEDLINE
Australia
C?ID=350368
Version: 18.9.0.4 (x64)  HEX-NET CB: 0.4437.4
                   Mileage: 59968 km
                   Date: 2019.01.07
                   Time: 00:05:41
  Revision: --------
                   Reset counter: 29
                   Mileage: 59968 km
                   Date: 2013.05.30
                   Time: 11:34:34
                   Hex Value: 0x0007
                   Hex Value: 0x0000
                   Hex Value: 0x3209
                   Hex Value: 0x14AD
                   Hex Value: 0x007E
                   Hex Value: 0x7F7F
                   Hex Value: 0x7F00
                   Reset counter: 29
                   Mileage: 59968 km
                   Date: 2013.05.30
                   Time: 11:34:34
                   Hex Value: 0x0007
                   Hex Value: 0x0000
                   Hex Value: 0x3211
                   Hex Value: 0x14AD
                   Hex Value: 0x007E
                   Hex Value: 0x7F7F
                   Hex Value: 0x7F00
Address 08: Auto HVAC (J301)       Labels: 6R0-820-045-9AB.clb
  Part No SW: 5J0 820 045 D    HW: 5J0 820 045 D
  Component: Man AC        H02 0202
  Revision: 0004SH02
  VCID: 2600F5E4519B817A81-8072
                   Reset counter: 69
                   Mileage: 59968 km
                   Date: 2013.05.30
                   Time: 00:02:59
00532 - Supply Voltage B+
                   Reset counter: 69
                   Mileage: 59968 km
                   Date: 2013.05.30
                   Time: 00:02:59
  Part No SW: 6R7 937 087 M    HW: 6R7 937 087 M
  Component: PQ25 BCM      H28 0555
  Revision: -1------    Serial number: --------------
  Coding: 7D980B380801000000380800242B08C200C0400F60000000020000000000
  Shop #: WSC 12222 000 00000
  VCID: 4ED06D4419ABA93A19-801A
  Subsystem 1 - Part No SW: 6R0 959 802 M    HW: 6R0 959 802 M  Labels:
6R0-959-802.CLB
  Component: J386__TSG_FT  002 3211
  Coding: 030000
  Subsystem 2 - Part No SW: 6R0 959 801 P    HW: 6R0 959 801 P  Labels:
6R0-959-801.CLB
  Component: J387__TSG_BT  002 3211
  Coding: 020000
  Subsystem 3 - Part No SW: 3T0 959 537 D    HW: 3T0 959 537 D
  Component: E221__MFL-URO  H07 0012
  Serial number: 2437586
  Coding: 800000
  Subsystem 4 - Part No SW: 6R0 959 811 D    HW: 6R0 959 811 D
  Component: J388__TSG_HL  002 3211
  Coding: 020000
  Subsystem 5 - Part No SW: 6R0 959 812 D    HW: 6R0 959 812 D
  Component: J389__TSG_HR  002 3211
  Coding: 020000
                   Reset counter: 69
                   Mileage: 59968 km
                   Date: 2013.05.30
                   Time: 00:04:17
                   Reset counter: 69
                   Mileage: 59968 km
                   Date: 2013.05.30
                   Time: 00:04:17
  Part No SW: 6R0 959 655 L    HW: 6R0 959 655 L
  Component: VW10AirbagT2A H10 0020
  Revision: --------    Serial number: 003GY0070UX.
  Coding: 003241
  ROD: EV_AirbaVW10BPAVW250.rod
  VCID: 4BD66450E2B99C127E-801E
  Serial number: 3495RRB40124UHC4MPH9
  Serial number: 3505RRB405D1BBHAIHS+
  Serial number: 3515RRB405H1AP6090E+
  Serial number: 3525RRB405H1AP60MGDR
12854016 - Databus
         [Kombi1 DLC Error]
                   Reset counter: 69
                   Mileage: 59968 km
                   Date: 2019.01.07
                   Time: 00:07:03
  Part No SW: 5J0 920 841 E    HW: 5J0 920 841 E
  Component: KOMBI         H04 0305
  Coding: 110A01
  ASAM Dataset: EV_Kombi_UDS_VDD_RM09 A04113
  VCID: 2C1407CC4777BB2A57-8078
13635840 - Supply voltage
         [Supply voltage too low]
                   Reset counter: 40
                   Mileage: 59968 km
                   Date: 2019.01.07
                   Time: 00:04:07
  Part No SW: 6N0 909 901     HW: 6R7 937 087 M
  Component: GW-K-CAN TP20 H28 0555
  Revision: -1------
  Coding: 032300
  VCID: 70ACD3BCA3DF9FCA2B-8024
  Component: IMMO          H04 0305
  VCID: 6A98C1D48D03651A65-803E
  Part No: 6R0 423 156 C
  Component: LenkhilfeTRW        V278
  Coding: 11210
  Shop #: WSC 13765
  VCID: 302C13BCF75FDFCA6B-8064
  Part No SW: 5J0 035 161 D    HW: 5J0 035 161 D
  Component: Radio-SWING   004 0003
  Revision: -----07S    Serial number: SKZ4Z2M1317378
  Coding: 050004000006
  VCID: 2306ECF022A97452E6-8076
                   Reset counter: 69
                   Mileage: 59968 km
                   Date: 2013.05.30
                   Time: 00:00:51
                   Reset counter: 69
                   Mileage: 59968 km
                   Date: 2013.05.30
                   Time: 00:04:42
  Part No SW: 7P6 035 730 K    HW: 7P6 035 730 K
  Revision: 1B001001    Serial number: 00007663234957
  Coding: 0200000000010110
  ASAM Dataset: EV_UHVNA 002720
  ROD: EV_UHVNA_002.rod
  VCID: 3A383194BD23159AD5-806E
         [Klemme 30: unterer Grenzwert unterschritten]
                   Reset counter: 69
                   Mileage: 59968 km
                   Date: 2019.01.07
                   Time: 00:05:00
         U1400 00 [008] - -
                   Reset counter: 69
                   Mileage: 59968 km
                   Date: 2019.01.07
                   Time: 00:05:00
End----------(Elapsed Time: 01:06, VBatt start/end:
iichel
C?ID=284912
OK charge the battery please, if not done yet.
SPEEDLINE
Australia
C?ID=350368
battery is full charge
car is running
just abs light and traction control light on and abs is not coded
SPEEDLINE
Australia
C?ID=350368
ANYONE ABLE TO GET ABS CODING
I GOT SKODA FOBIA AND NEED ABS CODEING
SAMHOW ABS DEAD AND I CAN NOT SAVE ABS CODE
JUST WONDERING IF ANYONE CAN CALCULATE ABS CODE
                   Mileage: 59968 km
                   Date: 2019.01.07
                   Time: 00:05:41
  Revision: --------
                   Reset counter: 29
                   Mileage: 59968 km
                   Date: 2013.05.30
                   Time: 11:34:34
                   Hex Value: 0x0007
                   Hex Value: 0x0000
                   Hex Value: 0x3209
                   Hex Value: 0x14AD
                   Hex Value: 0x007E
                   Hex Value: 0x7F7F
                   Hex Value: 0x7F00
                   Reset counter: 29
                   Mileage: 59968 km
                   Date: 2013.05.30
                   Time: 11:34:34
                   Hex Value: 0x0007
                   Hex Value: 0x0000
                   Hex Value: 0x3211
                   Hex Value: 0x14AD
                   Hex Value: 0x007E
                   Hex Value: 0x7F7F
                   Hex Value: 0x7F00
  Revision: 0004SH02
                   Reset counter: 69
                   Mileage: 59968 km
                   Date: 2013.05.30
                   Time: 00:02:59
                   Reset counter: 69
                   Mileage: 59968 km
                   Date: 2013.05.30
                   Time: 00:02:59
6R0-959-802.CLB
  Coding: 030000
6R0-959-801.CLB
  Coding: 020000
  Coding: 800000
  Coding: 020000
  Coding: 020000
                   Reset counter: 69
                   Mileage: 59968 km
                   Date: 2013.05.30
                   Time: 00:04:17
                   Reset counter: 69
                   Mileage: 59968 km
                   Date: 2013.05.30
                   Time: 00:04:17
  Coding: 003241
12854016 - Databus
         [Kombi1 DLC Error]
                   Reset counter: 69
                   Mileage: 59968 km
                   Date: 2019.01.07
                   Time: 00:07:03
  Coding: 110A01
                   Reset counter: 40
                   Mileage: 59968 km
                   Date: 2019.01.07
                   Time: 00:04:07
  Revision: -1------
  Coding: 032300
  Coding: 11210
  Shop #: WSC 13765
                   Reset counter: 69
                   Mileage: 59968 km
                   Date: 2013.05.30
                   Time: 00:00:51
                   Reset counter: 69
                   Mileage: 59968 km
                   Date: 2013.05.30
                   Time: 00:04:42
                   Reset counter: 69
                   Mileage: 59968 km
                   Date: 2019.01.07
                   Time: 00:05:00
         U1400 00 [008] - -
                   Reset counter: 69
                   Mileage: 59968 km
                   Date: 2019.01.07
                   Time: 00:05:00
Dana
Western PA, USA
I cannot built that ESP8.2i front coding from scratch but I'll move the thread to our Car Repair Support sub-forum so you receive more views.
Edit. I just noticed you have 2 threads related to this vehicle. I'll merge them before moving to the Car Repair Support sub-forum.
Dana
Western PA, USA
If you haven't done so already make sure this VIN TMBFN65J0D3039322 matches:
The [Advanced ID-1A] in Addresses:
  • 01
  • 17 (If applicable. The VIN may not be shown at all in that module)
  • 25
  • In addition to the VIN plate on the dash
You can click [Save] in each address so the data can be posted here.
If the VIN matches the car and is correct in all diagnostic locations please let us know what the results were when testing iichel's suggestions.
If the Diagnostic VIN isn't correct we can ASSume they replaced the cluster with a random used unit or corrupted the original unit. Either way, iichel is correct and that would need to be corrected before this ABS module will accept coding.
