Greetings guys , I have a Polo 1.4 TDI .
on the right of the steering wheel , it has no buttons for trip computer like other models
I retrofited one . Front and rear washers work ok , but not the buttons
I have an autoscan . Can the Polo have the trip computer work ? Or is it an Instrument cluster limitation.
THank you
THank you
Tuesday,08,January,2019,12:31:08:19672
Dealer/Shop Name:
VIN: WVWZZZ6RZFY316138 License Plate:
Mileage: 76362km-47449mi Repair Order:
Chassis Type: 6R-VW26 (6C0)
Scan: 01 03 08 09 15 17 19 44 5F
VIN: WVWZZZ6RZFY316138 Mileage: 76362km-47449miles
Address 01: Engine (J623-CUSA) Labels: None
Part No SW: 04B 997 027 HW: 04B 907 445
Component: R3 1.4l TDI H08 9430
Revision: 21006001
Coding: 01114012420400080000
Shop #: WSC 00788 648 00255
ASAM Dataset: EV_ECM14TDI03004B997027 004006
ROD: EV_ECM14TDI03004B997027G.rod
VCID: 68884F6272F716C7365-803C
Readiness: N/A
Address 03: ABS Brakes (J104) Labels:. 6R0-907-37x-ESP90.clb
Part No SW: 6C0 907 379 G HW: 6R0 907 379 BA
Component: ESP9.0i H03 0003
Serial number: 08508856150412
Coding: 21DD2485892433C60915006C0059842491CC90000007C9098F00
ASAM Dataset: EV_Brake1ESP90iBOSCHPQ26 100018
VCID: 3332E80E7BB1A51F537-8066
Address 08: Auto HVAC (J301) Labels:| 6C0-820-045.clb
Part No SW: 6C0 820 045 HW: 6C0 820 045
Component: AC Manuell H03 0108
Serial number: 1503261B-1955
Coding: 201000000000000200
ASAM Dataset: EV_ACManueKMMValeoPQ26 002001
ROD: EV_ACManueKMMValeoPQ26.rod
VCID: 5CE063B2B6AF4A67A2D-8008
1048834 - Functional Limitation due to Energy Management
B10CD 00 [012] - -
[Funktionseinschrδnkung durch Energiemanagment]
Reset counter: 101
Mileage: 76299 km
Date: 2019.01.05
Time: 21:47:00
Voltage terminal 30: 14.8 V
Auxiliary heater: in stages-Enabling for auxiliary heater operation: no_enabling
Auxiliary heater: in stages-Act.val.: 0
Auxiliary heater: in stages-Specified value for control: 0
Address 09: Cent. Elect. (J519) Labels:* Redir Fail!
Part No SW: 6C0 937 087 B HW: 6C0 937 087
Component: BCM PQ26 Me4R H07 0065
Serial number: 001088055146
Coding: 00000840401300534B844000400703000000580051010000000000000000
ASAM Dataset: EV_BCMA0 004008
ROD: EV_MQBA0.rod
VCID: 2D06FE769D95F3EF053-8078
Drivers Door Control Module:
Subsystem 1 - Part No SW: 6R0 959 801 AT HW: 6R0 959 801 AT Labels: 6R0-959-801.CLB
Component: J386__TSG_FT 003 8612
Serial number: KU0KU019031550783227
Coding: 0000A0
Subsystem 2 - Part No SW: 6R0 959 802 BE HW: 6R0 959 802 BE Labels: 6R0-959-802.CLB
Component: J387__TSG_BT 003 8612
Serial number: KU0KU024031550834488
Coding: 1000A0
Address 15: Airbags (J234) Labels:| 6C0-959-655.clb
Part No SW: 6C0 959 655 E HW: 6C0 959 655 E
Component: VW20Airbag00B 001 0360
Revision: -------- Serial number: 003RH000617I
Coding: 88C0C000000000005C000000000800000000
ROD: EV_AirbaVW20BPAVW26X.rod
VCID: 3536D61675C5BB2F7D3-8060
Subsystem 1 - Part No SW: ----------- HW: 410 820 304 15
Component: SideSensor_Df 151 0800
Serial number: 3575H00BD19E15A3821T
Subsystem 2 - Part No SW: ----------- HW: 410 820 304 15
Component: SideSensor_Pf 151 0800
Serial number: 3585H000828BDAC3D2D4
Subsystem 3 - Part No SW: ----------- HW: 442 150 504 15
Component: SideSensor_Dr 1CA 0148
Serial number: 3517A00AB1A72834F04F
Subsystem 4 - Part No SW: ----------- HW: 442 150 404 15
Component: SideSensor_Pr 1CA 0148
Serial number: 3527A00AD1A728354318
Part No SW: 6C0 920 731 B HW: 6C0 920 731 B
Component: KOMBI 110 0290
Coding: 0720090021000008000808000000000000000000
VCID: 211E1246D14D278FB1B-8074
Address 19: CAN Gateway (J533) Labels:| 6C0-909-901-V1.clb
Part No SW: 6C0 909 901 HW: 6C0 937 087
Component: GW MQB A0 H07 0065
Revision: -------- Serial number: 001088055146
Coding: 01000008180A590071000000000000000001010000000000000000000000
ASAM Dataset: EV_GatewA0Lear 001001
ROD: EV_GatewA0Lear_001_VW26.rod
VCID: 6596465685E50BAF0D3-8030
Address 44: Steering Assist (J792) Labels:| 6Rx-909-144-V2.clb
Part No SW: 6C1 909 144 M HW: 6C1 909 144 D
Component: EPS_TRW_ALow 312 3211
Serial number: PF4M0765
Coding: 0007
ASAM Dataset: EV_SteerAssisUDSTRW 011021
ROD: EV_SteerAssisUDSTRW_011.rod
VCID: 323CED0A84ABAC17581-8066
Address 5F: Information Electr. (J794) Labels:| 5G0-035-MIB-ENT2.clb
Part No SW: 6C0 035 885 A HW: 6C0 035 885 A
Component: MU-E--ER 820 6230
Serial number: 04021500010186
Coding: 026200003C0000004011000101000000000000040000010000
ASAM Dataset: EV_MUEnt4CGen2LGE 001017
VCID: 270A0C5EBF69D9BFFFF-8072
End----------(Elapsed Time: 00:32, VBatt start/end: 12.6V/14.9V)-----------
