Just to confirm I do have the MFA option.
Although this is speculation I think that fault is a deal breaker.
Based on past experience in addition to some of the tweaks tonight I can change everything except for the chassis code. The chassis code needs to match the sub-system (
4H0 941 329 in my case) in addition to the internal headlight hardware so that's the most likely conflict in my case. I know the master won't code if either of the headlights are offline (unplugged or broken) so I did not try to unplug the lights and recode. My error message was Coding Rejected Error 31: Request Out of range.
In conclusion appears to be OK . Plugging one of those modules into a vehicle born with Xenon would probably be best for the EOL fault code in addition to the chassis code confirmation. The 2012 CC or Tiggy would work but the 2013 + GTI would be a more common option. Either way, you'd probably want to:
1) Confirm one of those modules accept the factory coding for the tester car.
2) Plug the (loaded) Jetta headlights into the tester car to see if the chassis specific coding is accepted. If it isn't we may need to look at wiring diagrams and the coding.
This is my scan which includes a handful of coding sessions with resulting fault codes:
Sunday,07,February,2016,17:57:36:18264
VCDS Version: 15.7.3.0 (x64)
Data version: 20151216
VIN: WVGBV7AX1CW000438 License Plate: TIGGY XENON NIGHT
Mileage: 62340km-38736mi Repair Order:
Chassis Type: AX (7N0)
Scan: 01 02 03 05 08 09 15 16 17 19 22 25 2B 2E 36 37 42 44 46 47
4C 4F 52 53 55 56 62 72 77
VIN: WVGBV7AX1CW000438 Mileage: 62340km-38736miles
Address 01: Engine (CCT) Labels: 06J-906-026-CCT.clb
Part No SW: 06J 997 027 R HW: 06J 907 309 A
Component: MED17.5.2 TFSI 2 0401
Revision: P3H07--- Serial number: 00000000000000
Coding: 0423010A190F0160
Shop #: WSC 61253 000 1048576
VCID: 448CCCE407DC871E15-8010
Part No SW: 09G 927 750 LR HW: 09G 927 750 LR
Component: AQ 250 6F 1971
Revision: 00H90000 Serial number:
Coding: 0000840
Shop #: WSC 01324 020 00200
VCID: 0C1C24C46F0C0F5E1D-8058
Address 03: ABS Brakes Labels: 5N0-614-109-C6.clb
Part No SW: 5N0 614 109 AH HW: 5N0 614 109 AH
Component: J104 C6 450M VD3E 0003
Revision: --H07--- Serial number: 00000004361248
Coding: 0005161
VCID: 71E2553068EE42B68E-8024
Address 05: Acc/Start Auth. (J518) Labels: 5K0-959-434.clb
Part No SW: 5K0 959 434 A HW: 5K0 959 434 A
Component: VWKESSYPQ35GP 085 0802
Revision: 00085000 Serial number: 0148888823
Coding: 030C0C
ASAM Dataset: EV_KESSY_PQ35GP A01018
ROD: EV_KESSY_PQ35GP.rod
VCID: 336E9F389A7230A6BC-8066
Address 08: Auto HVAC (J255) Labels: 5K0-907-044.clb
Part No SW: 5K0 907 044 FS HW: 5K0 907 044 FS
Component: Climatronic H17 1011
Revision: 00003001
Coding: 0000001002
VCID: 010205F0904E52367E-8054
Address 09: Cent. Elect. (J519) Labels: 1K0-937-08x-09.clb
Part No SW: 5K0 937 086 L HW: 5K0 937 086 L
Component: BCM PQ35 M 011 0048
Revision: BJ011001
Coding: 6E180A3BEC232EC4008800C130008DC448750006576D8DF0E4840000A040
VCID: 3D7AB900A436F6D65A-8068
Subsystem 1 - Part No SW: 5N1 955 119 HW: Labels: 1KX-955-119.CLB
Component: Wischer 20061 013 0203
Coding: 009795
Component: RLS 170611 05 54 0403
Coding: 06304D
01259 - Fuel Pump Relay (J17)
009 - Open or Short to Ground
Fault Status: 01101001
Reset counter: 150
Mileage: 59115 km
Date: 2015.10.24
Time: 10:16:05
Term 15 Off
Voltage: 12.55 V
Part No SW: 5N0 959 655 P HW: 5N0 959 655 P
Component: J234__204 VW10 HI 1918
Revision: 22014000 Serial number: 003GJPC1W5N7
Coding: 0012340
VCID: 4A90E2DC25F8516EEF-801E
Subsystem 1 - Part No: 5N0 959 339 B
Subsystem 2 - Serial number: 00000000004T0R
Subsystem 3 - Serial number: 0015.04.110000300000640025ÿ†63
Subsystem 4 - Serial number: 640025ÿ†6332MTS638971611 ÿ†63
Subsystem 5 - Serial number: 71611 ÿ†6342MTS668421631 ÿ†63
Subsystem 6 - Serial number: 21631 ÿ†6351HTS6K29K5AKJ ÿ†63
Subsystem 7 - Serial number: K5AKJ ÿ†6361HTS6KTLL5AKR ÿ†63
Subsystem 8 - Serial number: L5AKR ÿ†63727TS6L2HM4AKR ÿ†63
Subsystem 9 - Serial number: M4AKR ÿ†63827TS6NGEH6AKR ÿ
Subsystem 10 - Serial number: H6AKR ÿ
Address 16: Steering wheel (J527) Labels: 5K0-953-569.clb
Part No SW: 5K0 953 501 BL HW: 5K0 953 569 L
Revision: FF010040 Serial number: 20110614101144
Coding: 110A140000
VCID: 75EA6120D4866E9652-8020
Subsystem 1 - Part No SW: 5K0 959 542 A HW: 5K0 959 542 A Labels: 3C8-959-537.CLB
Component: E221__MFL-TAS H09 0013
Coding: 820000
Part No SW: 5N0 920 972 E HW: 5N0 920 972 E
Component: KOMBI H03 0607
Coding: 211F01
VCID: 356AA12094062E9692-8060
Address 19: CAN Gateway (J533) Labels: 7N0-907-530-V2.clb
Part No SW: 7N0 907 530 K HW: 1K0 907 951
Component: J533 Gateway H40 1620
Revision: H40 Serial number: 150611F2003544
Coding: 356002
VCID: 3874A8148B14D3FE89-806C
Part No SW: 0AY 907 554 D HW: 0AY 907 554 D
Component: Haldex 4Motion 0042
Coding: 0000005
VCID: 4C9CE4C42F8C4F5EDD-8018
Component: IMMO H03 0607
Coding: 000007
VCID: 6AD0425C8D38B16ECF-803E
Address 2B: Steer. Col. Lock (J764) Labels: 5K0-905-861.clb
Part No SW: 5K0 905 861 A HW: 5K0 905 861 A
Component: ELV-PQ35 H20 0230
Revision: 00000000 Serial number: 11000132730004
Coding: 4900000000000000
ROD: EV_ELVMarquMPVW36X.rod
VCID: 2E588E4C71501D4ED3-807A
Address 2E: Media Player 3 (J650) Labels: 5N0-035-342.lbl
Part No SW: 5N0 035 342 E HW: 5N0 035 342 E
Revision: A1001003 Serial number: 7660248343
VCID: 29527D5040BE7A7606-807C
Part No SW: 561 959 760 A HW: 561 959 760 A
Component: MEM-FS H04 0181
Revision: AA000000 Serial number: 00000006146508
Coding: 00581B0000000000000001010101202020202121202020
VCID: 21426570388EB2365E-8074
Address 37: Navigation (J0506) Labels: 1T0-035-680.clb
Part No SW: 3C0 035 684 J HW: 3C0 035 684 E
Component: RNS-MID H08 4354
Revision: AB001001 Serial number: VWZ6Z7L5157148
Coding: 0405000201000084000C
VCID: 2A50825C45B8716E0F-807E
Subsystem 1 - Part No: 7L6 919 859
Component: NAR V10 8246
Reset counter: 102
Mileage: 62296 km
Address 42: Door Elect, Driver Labels: 1K0-959-701-MAX3.lbl
Part No SW: 5N0 959 701 E HW: 5N0 959 701 E
Component: Tuer-SG 009 2111
Coding: 0005566
VCID: 3776AB28460ADC8680-8062
Part No SW: 5N1 909 144 L HW: 5N1 909 148 G
Component: J500__APA-BS KL.287 0802
Revision: 1AH03831 Serial number: 00111610436101
Coding: 0000258
VCID: 3B7EB7187A22F8E664-806E
Part No SW: 5K0 035 456 HW: 5K0 035 456
Component: KonzernAmp 8K H06 0340
Revision: -------- Serial number: BP218119848045
VCID: 67D63B689E2A8C06D0-8032
Address 4C: Tire Pressure II
Address 4F: Centr. Electr. II (J520) Labels: 1K0-907-532.clb
Part No SW: 7N0 907 532 HW: 1K0 907 951
Component: EZE_2 H40 1620
Coding: 05030100
VCID: 6FE65348BEDA544698-803A
Subsystem 1 - Part No SW: 8R0 959 591 A HW: 8R0 959 591
Component: J245EE20SKB13 H02 0220
Subsystem 2 - Part No SW: 8R0 959 591 A HW: 8R0 959 591
Component: J394EE20SKB13 H02 0220
Address 52: Door Elect, Pass. Labels: 1K0-959-702-MAX3.lbl
Part No SW: 5N0 959 702 E HW: 5N0 959 702 E
Coding: 0005566
VCID: 3874A8144B14D3FE89-806C
Part No SW: 3AA 907 801 G HW: 3AA 907 801 G
Component: J540 EPB4 VW-64783 0009
Revision: H19 Serial number: 00000000061009
Coding: 0026156
VCID: 356AA1205C062E9692-8060
Address 55: Headlight Range (J745) Labels: 5M0-907-357-V3.clb
Part No SW: 5M0 907 357 E HW: 7L6 907 357 C
Component: AFS-ECU H04 0100
Coding: 041A00010B000300
ASAM Dataset: EV_HeadlRegulVWAFSPt 002014
ROD: EV_HeadlRegulVWAFSPt_SE36.rod
VCID: 3668A62C8900258E9B-8062
Subsystem 1 - Part No SW: 4H0 941 329 HW: 4H0 941 329 Labels: 3D0-941-329.CLB
Component: LeiMo links H02 0008
Coding: 140000
Subsystem 2 - Part No SW: 4H0 941 329 HW: 4H0 941 329 Labels: 3D0-941-329.CLB
Component: LeiMo rechts H02 0008
Coding: 140000
Address 56: Radio (J0506) Labels: 1T0-035-680.clb
Reset counter: 102
Mileage: 62296 km
Part No SW: 5N0 959 703 E HW: 5N0 959 703 E
Component: Tuer-SG 007 2102
Coding: 0001168
Shop #: WSC 01324 020 1012552
VCID: 3972AD10701ECAF676-806C
Part No SW: 5N0 959 704 E HW: 5N0 959 704 E
Coding: 0001168
Shop #: WSC 01324 020 1012551
VCID: 3A70B21C7518C1EE7F-806E
Address 77: Telephone (J412) Labels: 7P6-035-730.clb
Part No SW: 7P6 035 730 F HW: 7P6 035 730 F
Component: TELEFON H09 2902
Revision: 1B001001 Serial number: 00007660091672
Coding: 0A11040000010100
Shop #: WSC 25807 444 28888
ASAM Dataset: EV_UHVNA A01719
ROD: EV_UHVNA.rod
End-------------------------(Elapsed Time: 03:37)--------------------------
Address 55:5M0 907 357 E recoded (Long Coding) from 041A00010B000300 to 041A00010F000000 (01324/020/00200)
Address 55: Headlight Range Labels: 5M0-907-357-V3.clb
Control Module Part Number: 5M0 907 357 E HW: 7L6 907 357 C
Component and/or Version: AFS-ECU H04 0100
Software Coding: 041A00010F000000
Work Shop Code: WSC 01324 020 00200
ASAM Dataset: EV_HeadlRegulVWAFSPt 002014 (VW36)
VCID: 3668A62C9100258E9B-8062
5275220 - Headlight
Reset counter: 62
Mileage: 62344 km
Date: 2016.02.07
Time: 17:57:00
Address 55: Headlight Range Labels: 5M0-907-357-V3.CLB
Address 55:5M0 907 357 E recoded (Long Coding) from 041A00010F000000 to 041A00010B000300 (01324/020/00200)
Software Coding: 041A00010B000300
5275220 - Headlight
Reset counter: 62
Mileage: 62344 km
Date: 2016.02.07
Time: 17:58:34
Address 55:5M0 907 357 E recoded (Long Coding) from 041A00010B000300 to 081A00010B000300 (01324/020/00200)
Address 55:5M0 907 357 E recoded (Long Coding) from 041A00010B000300 to 001A00010B000300 (01324/020/00200)
Address 55:5M0 907 357 E recoded (Long Coding) from 041A00010B000300 to 031A00010B000300 (01324/020/00200)
Address 55:5M0 907 357 E recoded (Long Coding) from 041A00010B000300 to 051A00010B000300 (01324/020/00200)
Address 55:5M0 907 357 E recoded (Long Coding) from 041A00010B000300 to 091A00010B000300 (01324/020/00200)
Address 55:5M0 907 357 E recoded (Long Coding) from 041A00010B000300 to 041A00110B000300 (01324/020/00200)
Software Coding: 041A00110B000300
5275220 - Headlight
Reset counter: 62
Mileage: 62344 km
Date: 2016.02.07
Time: 18:02:06
5281301 - Adjusting Motor for Variable Lighting Left
C1096 15 [137] - Open or Short to Plus
Reset counter: 62
Mileage: 62344 km
Date: 2016.02.07
Time: 18:02:06
5281557 - Adjusting Motor for Variable Lighting Right
C1097 15 [137] - Open or Short to Plus
Reset counter: 62
Mileage: 62344 km
Date: 2016.02.07
Time: 18:02:06
Address 55:5M0 907 357 E recoded (Long Coding) from 041A00110B000300 to 091A00110B000300 (01324/020/00200)
Address 55:5M0 907 357 E recoded (Long Coding) from 041A00110B000300 to 041A00010B000300 (01324/020/00200)
5275220 - Headlight
Reset counter: 62
Mileage: 62344 km
Date: 2016.02.07
Time: 18:03:29
Address 09: DTCs cleared
