mk6 xenon retrofit
   #101
pillpusher84
C?ID=245751
connect Schottky diode,from pin 11(shutter) to pin 6 (low beam),if you will get hight beam error,connect 50watt 8om ressistor.this way is if you use old wire of high beam wich is 1.5mm with high beam coding
Can you explain about this a little more....
I understand what the diode does ... allows hte low beam voltage to travel to the high beam shutter
I have the PQ25 Max3 CECM coded correctly for Xenon Headlights ... but I still have the error I described above.
Can you tell me what type of Schottky Diode I should be looking for ? 12v /10 Amp
   #102
maniken
Lithuania
C?ID=229989
yes ill trie to explane,you need to alllow high beam vooltage to travel to low beam,because then you flash with high beams shutters worsk but low beams not.so voltage travel to low beam with workin shutter,but didnt goes back to shutter then low beams on.resister for high beam error.if you dont understand somethink ask..:)
   #103
golfi_vend
Tartu, Estonia
C?ID=195131
Wait what?
Power xenon bulbs from shutter pins? - Are we trying to fry the BCM?
pillpusher84
C?ID=245751
Wait what?
Yea, that still doesn't make sense to me. In all of the Xenon conversion threads I have read, I have never seen anything like that. I have ensured that everything is wired up per the OEM Wiring Diagrams for BiXenons for MK6 Jetta.
The shutters are powered correctly from the CECM ... I just don't understand why the "flash to pass" high beam flash only works with the headlights powered on.
I am going to pose this question .... Do I need to also upgrade my headlight switch? I have the original US-spec ON/OFF switch. I do not have the Auto Switch or Euro switch, nor do I have auto headlight sensor installed. Could this possibly be the culprit? If so, does anyone have the correct wiring for adding an auto switch, or can point me in the correct direction on on where to start?
   #105
maniken
Lithuania
C?ID=229989
Wait what?
ill repeat:this way is if you use old wire of high beam wich is 1.5mm with high beam coding
   #106
maniken
Lithuania
C?ID=229989
connect not coded high beam to shutter and diode to low beam(35watt xenon +shutter(i think 5watts)+resistor try 50watt and 15om.wi will get about 55watt.halogen high beam 50watt.reload maximum 10watts fry BCM?
   #107
maniken
Lithuania
C?ID=229989
if you have know high beam error and yours low beam doesnt work when you flashing in 0 light position,i think you are no corectly coded bcm,or your bcm not support
   #108
United States
I know this goes back a while but we just had a similar inquiry in the New User forum that may be related so I wanted to update here.
I don't think so, that NAR switch sends signals (inputs) to the BCM but the Off/DRL and On pins are the same.
Try this coding in the BCM:
6F190A3890252A0480A80080350008B44B650316424D8960648000200040
Byte 17, Bit 2 enabled and Byte 25, Bit 2 undone.
pillpusher84
C?ID=245751
Dana,
I do not have the option for these bits in byte 17 and 25 ... please see below. This is a 2015 Jetta TDI SE w/ CECM: PQ25 Max3
Please advise what the next suggestion to try would be ... I would love to get the high beam flash to pass function working with headlights in OFF position ... everything else is fully functional at this time! :)
--Antonio
   #110
United States
Dana,
--Antonio
Sorry about that Antonio. I screwed up and used the wrong scan. That was PQ35 specific so it doesn't apply to your controller.
I do not have a suggestion for that PQ25 Max3 controller :(
pillpusher84
C?ID=245751
pillpusher84,
I located a diagram but when I went to post the number and details you had already updated with the great erWin (German diagram) news. I however did want to add that the PR code from the TDI club 2015 Jetta TDI SEL w/ Lighting Package was: 8IM - Gas discharge headlights with dynamic bending light
The English wiring diagram appeared to be # 68 (Jetta, Headlamps Bixenon HID with range control and cornering lamp , (8IM) from July 2014). His production date is Jan, 16th 2015 so that production split would be be correct but that VIN also showed Market-specific vehicle version: AW0 - Version (low) (i.e PQ25 level BCM platform) and the diagram had T52 connectors as if it was a PQ35 system. In conclusion that couldn't be correct.
Please do let us know what the diagram number was from that German schematic at some point.
The diagram provided by erWin was titled as follows:
Gasentladungsscheinwerfer (Bi-Xenon) mit automatischer Leuchtweitenregelung und Kurvenlicht , (8IM),(AW0)
ab Juli 2014
I have gone on-site to my local dealership in the past to verify that a brand new TDI SEL that was off-the-assembly-line with BiXexon lighting package physically had the same CECM as I, so I know it is possible with the CECM PQ25 Max3
Your comment about AW0 (lowline) and T52 connectors is exactly what I was thinking ... something wasn't kosher ... so I contacted erWin to report the issue and request assistance, and this is when the I received the german diagram which correctly shows the wiring for the TDI SEL with PQ25 Max3 CECM
I don't read German, however Google translate was a good resource for validating the descriptions for the connections
   #112
pillpusher84
C?ID=245751
No worries ... I'm sure I'll figure it out eventually ... if not we'll see what happens with Dieselgate .... maybe I'll get rid of this thing soon anyway .... I've been eyeing the Golf R for my DD anyway :)
   #113
United States
Antonio, I don't exactly have an answer but another forum user (with a PQ25 BCM in the RLS and the PQ-25 BCM thread) wanted to let me know the coding value in post #14 of that thread enabled flash to pass. I did not compare your last known config to that vehicle however it may add some clarity after the differences are identified.
   #114
TooLittleTime
Canada
C?ID=217224
Hi Dana,
Does the 5M0907357F require SVM or some kind of VW tool to be properly configured?
Were you able to find out what the "no end of line programming" means?
The 5M0907357F is the module with which the newer vehicles come with, and this includes the Jetta.
Thanks,
   #115
United States
5M0 907 357 F should be plug, code and play but we haven't received one of those UDS #55 modules (5M0-907-357-E or newer) with that particular DTC to experiment with either. I would be willing to plug one into my car to see if the EOL problem is fixable via conventional diagnostics - but I don't want to run out and buy one for the experiment since my Tiggy isn't broken.
P.S. Unrelated but please see my post #20 here http://forums.ross-tech.com/showthread.php?4247-2016-Jetta-coding&p=48006#post48006
If you experienced any 2016 Jetta cluster coding problems please let us know if the next release fixes it.
TooLittleTime
Canada
C?ID=217224
Hi Dana,
Thank you for your reply. I have seen two of the 5M0907357F type modules now, and have had issues with doing coding using VCDS.
I am wondering if you are able to code the first byte in your module?
Perhaps to just change the vehicle platform and see if there are any VCDS related issues?
Does your module have a separate AFS enable function under the Assistance menu in the MFD/cluster ?
Also, thanks for the other info.
   #117
United States
I can test that this weekend but I think the chassis selection won't cooperate if I deviate greatly from the installed headlights. What coding were you, or any fellow Mk6 Jetta owners, having problems with? If you paste a list in reply I can use it from the Driver's seat when breaking my car :-)
Edit, separate AFS enable function - I think so but I'll double check to make sure I'm not confusing that with my previous GTI.
   #118
TooLittleTime
Canada
C?ID=217224
I am asking because I have seen two scenarios so far:
1) controller was 'NEW' 5M0907357F that couldn't be coded and had that "no end of line programming"
2) controller was 'USED' 5M0907357F and previously coded to a vehicle, but the coding couldn't be changed, even a basic chassis change couldn't be coded
So I am curious if you are able to at least just temporarily change the coding in your vehicle (Perhaps just a simple chassis change). If you can, then that would tell me VCDS is OK, and these 5M0907357F have something else like SVN or other VW tool is required.
Also, the new one had the AFS Assitance MFD screen and the used one didn't. Exact same software.
Thanks!
   #119
United States
Just to confirm I do have the AFS MFA option.
Although this is speculation I think that fault is a deal breaker.
Based on past experience in addition to some of the tweaks tonight I can change everything except for the chassis code. The chassis code needs to match the sub-system (4H0 941 329 in my case) in addition to the internal headlight hardware so that's the most likely conflict in my case. I know the master won't code if either of the headlights are offline (unplugged or broken) so I did not try to unplug the lights and recode. My error message was Coding Rejected Error 31: Request Out of range.
In conclusion VCDS appears to be OK IMO. Plugging one of those modules into a vehicle born with Xenon would probably be best for the EOL fault code in addition to the chassis code confirmation. The 2012 CC or Tiggy would work but the 2013 + GTI would be a more common option. Either way, you'd probably want to:
1) Confirm one of those modules accept the factory coding for the tester car.
2) Plug the (loaded) Jetta headlights into the tester car to see if the chassis specific coding is accepted. If it isn't we may need to look at wiring diagrams and the BCM coding.
This is my scan which includes a handful of coding sessions with resulting fault codes:
Sunday,07,February,2016,17:57:36:18264
VCDS Version: 15.7.3.0 (x64)
Data version: 20151216
VIN: WVGBV7AX1CW000438   License Plate: TIGGY XENON NIGHT
Mileage: 62340km-38736mi   Repair Order:
Chassis Type: AX (7N0)
Scan: 01 02 03 05 08 09 15 16 17 19 22 25 2B 2E 36 37 42 44 46 47
          4C 4F 52 53 55 56 62 72 77
VIN: WVGBV7AX1CW000438   Mileage: 62340km-38736miles
Address 01: Engine (CCT)       Labels: 06J-906-026-CCT.clb
   Part No SW: 06J 997 027 R    HW: 06J 907 309 A
   Component: MED17.5.2 TFSI 2    0401
   Revision: P3H07---    Serial number: 00000000000000
   Coding: 0423010A190F0160
   Shop #: WSC 61253 000 1048576
   VCID: 448CCCE407DC871E15-8010
   Part No SW: 09G 927 750 LR    HW: 09G 927 750 LR
   Component: AQ 250 6F           1971
   Revision: 00H90000    Serial number:
   Coding: 0000840
   Shop #: WSC 01324 020 00200
   VCID: 0C1C24C46F0C0F5E1D-8058
   Part No SW: 5N0 614 109 AH    HW: 5N0 614 109 AH
   Component: J104   C6 450M VD3E 0003
   Revision: --H07---    Serial number: 00000004361248
   Coding: 0005161
   VCID: 71E2553068EE42B68E-8024
Address 05: Acc/Start Auth. (J518)       Labels: 5K0-959-434.clb
   Part No SW: 5K0 959 434 A    HW: 5K0 959 434 A
   Component: VWKESSYPQ35GP 085 0802
   Revision: 00085000    Serial number: 0148888823
   Coding: 030C0C
   ASAM Dataset: EV_KESSY_PQ35GP A01018
   ROD: EV_KESSY_PQ35GP.rod
   VCID: 336E9F389A7230A6BC-8066
   Part No SW: 5K0 907 044 FS    HW: 5K0 907 044 FS
   Component: Climatronic   H17 1011
   Revision: 00003001
   Coding: 0000001002
   VCID: 010205F0904E52367E-8054
   Part No SW: 5K0 937 086 L    HW: 5K0 937 086 L
   Component: BCM PQ35 M    011 0048
   Revision: BJ011001
   Coding: 6E180A3BEC232EC4008800C130008DC448750006576D8DF0E4840000A040
   VCID: 3D7AB900A436F6D65A-8068
   Subsystem 1 - Part No SW: 5N1 955 119     HW:              Labels: 1KX-955-119.CLB
   Component: Wischer 20061  013 0203
   Coding: 009795
   Component: RLS 170611 05  54  0403
   Coding: 06304D
01259 - Fuel Pump Relay (J17)
            009 - Open or Short to Ground
                    Fault Status: 01101001
                    Reset counter: 150
                    Mileage: 59115 km
                    Date: 2015.10.24
                    Time: 10:16:05
                        Term 15 Off
                    Voltage: 12.55 V
   Part No SW: 5N0 959 655 P    HW: 5N0 959 655 P
   Component: J234__204 VW10 HI   1918
   Revision: 22014000    Serial number: 003GJPC1W5N7
   Coding: 0012340
   VCID: 4A90E2DC25F8516EEF-801E
   Subsystem 1 - Part No: 5N0 959 339 B
   Subsystem 2 - Serial number: 00000000004T0R
   Subsystem 3 - Serial number: 0015.04.110000300000640025ÿ†63
   Subsystem 4 - Serial number: 640025ÿ†6332MTS638971611 ÿ†63
   Subsystem 5 - Serial number: 71611 ÿ†6342MTS668421631 ÿ†63
   Subsystem 6 - Serial number: 21631 ÿ†6351HTS6K29K5AKJ ÿ†63
   Subsystem 7 - Serial number: K5AKJ ÿ†6361HTS6KTLL5AKR ÿ†63
   Subsystem 8 - Serial number: L5AKR ÿ†63727TS6L2HM4AKR ÿ†63
   Subsystem 9 - Serial number: M4AKR ÿ†63827TS6NGEH6AKR ÿ
   Subsystem 10 - Serial number: H6AKR ÿ
   Part No SW: 5K0 953 501 BL    HW: 5K0 953 569 L
   Revision: FF010040    Serial number: 20110614101144
   Coding: 110A140000
   VCID: 75EA6120D4866E9652-8020
   Component: E221__MFL-TAS  H09 0013
   Coding: 820000
   Part No SW: 5N0 920 972 E    HW: 5N0 920 972 E
   Coding: 211F01
   VCID: 356AA12094062E9692-8060
   Part No SW: 7N0 907 530 K    HW: 1K0 907 951
   Component: J533  Gateway H40 1620
   Revision:   H40       Serial number: 150611F2003544
   Coding: 356002
   VCID: 3874A8148B14D3FE89-806C
   Part No SW: 0AY 907 554 D    HW: 0AY 907 554 D
   Component: Haldex 4Motion      0042
   Coding: 0000005
   VCID: 4C9CE4C42F8C4F5EDD-8018
   Coding: 000007
   VCID: 6AD0425C8D38B16ECF-803E
Address 2B: Steer. Col. Lock (J764)       Labels: 5K0-905-861.clb
   Part No SW: 5K0 905 861 A    HW: 5K0 905 861 A
   Component: ELV-PQ35      H20 0230
   Revision: 00000000    Serial number: 11000132730004
   Coding: 4900000000000000
   ROD: EV_ELVMarquMPVW36X.rod
   VCID: 2E588E4C71501D4ED3-807A
   Revision: A1001003    Serial number: 7660248343
   VCID: 29527D5040BE7A7606-807C
   Part No SW: 561 959 760 A    HW: 561 959 760 A
   Component: MEM-FS        H04 0181
   Revision: AA000000    Serial number: 00000006146508
   Coding: 00581B0000000000000001010101202020202121202020
   VCID: 21426570388EB2365E-8074
   Part No SW: 3C0 035 684 J    HW: 3C0 035 684 E
   Component: RNS-MID       H08 4354
   Revision: AB001001    Serial number: VWZ6Z7L5157148
   Coding: 0405000201000084000C
   VCID: 2A50825C45B8716E0F-807E
   Subsystem 1 - Part No: 7L6 919 859
   Component: NAR V10  8246
            000 -  -  - Intermittent
                    Reset counter: 102
                    Mileage: 62296 km
   Part No SW: 5N0 959 701 E    HW: 5N0 959 701 E
   Component: Tuer-SG         009 2111
   Coding: 0005566
   VCID: 3776AB28460ADC8680-8062
   Part No SW: 5N1 909 144 L    HW: 5N1 909 148 G
   Component: J500__APA-BS KL.287 0802
   Revision: 1AH03831    Serial number: 00111610436101
   Coding: 0000258
   VCID: 3B7EB7187A22F8E664-806E
   Part No SW: 5K0 035 456     HW: 5K0 035 456
   Component: KonzernAmp 8K H06 0340
   Revision: --------    Serial number: BP218119848045
   ASAM Dataset: EV_AudioVerst8KanalBNO1 A01003
   ROD: EV_AudioVerst8KanalBNO1.rod
   VCID: 67D63B689E2A8C06D0-8032
Address 4C: Tire Pressure II
   Component: EZE_2         H40 1620
   Coding: 05030100
   VCID: 6FE65348BEDA544698-803A
   Component: J245EE20SKB13  H02 0220
   Part No SW: 5N0 959 702 E    HW: 5N0 959 702 E
   Coding: 0005566
   VCID: 3874A8144B14D3FE89-806C
   Part No SW: 3AA 907 801 G    HW: 3AA 907 801 G
   Component: J540 EPB4  VW-64783 0009
   Revision:   H19       Serial number: 00000000061009
   Coding: 0026156
   VCID: 356AA1205C062E9692-8060
Address 55: Headlight Range (J745)       Labels: 5M0-907-357-V3.clb
   Part No SW: 5M0 907 357 E    HW: 7L6 907 357 C
   Component: AFS-ECU       H04 0100
   Coding: 041A00010B000300
   ASAM Dataset: EV_HeadlRegulVWAFSPt 002014
   ROD: EV_HeadlRegulVWAFSPt_SE36.rod
   VCID: 3668A62C8900258E9B-8062
   Subsystem 1 - Part No SW: 4H0 941 329     HW: 4H0 941 329   Labels: 3D0-941-329.CLB
   Component: LeiMo links  H02 0008
   Coding: 140000
   Subsystem 2 - Part No SW: 4H0 941 329     HW: 4H0 941 329   Labels: 3D0-941-329.CLB
   Component: LeiMo rechts  H02 0008
   Coding: 140000
                    Reset counter: 102
                    Mileage: 62296 km
   Part No SW: 5N0 959 703 E    HW: 5N0 959 703 E
   Component: Tuer-SG         007 2102
   Coding: 0001168
   Shop #: WSC 01324 020 1012552
   VCID: 3972AD10701ECAF676-806C
   Part No SW: 5N0 959 704 E    HW: 5N0 959 704 E
   Coding: 0001168
   Shop #: WSC 01324 020 1012551
   VCID: 3A70B21C7518C1EE7F-806E
   Part No SW: 7P6 035 730 F    HW: 7P6 035 730 F
   Component: TELEFON       H09 2902
   Revision: 1B001001    Serial number: 00007660091672
   Coding: 0A11040000010100
   Shop #: WSC 25807 444 28888
   ASAM Dataset: EV_UHVNA A01719
   ROD: EV_UHVNA.rod
End-------------------------(Elapsed Time: 03:37)--------------------------
Address 55:5M0 907 357 E recoded (Long Coding) from 041A00010B000300 to 041A00010F000000  (01324/020/00200)
                Address 55: Headlight Range       Labels: 5M0-907-357-V3.clb
Control Module Part Number: 5M0 907 357 E    HW: 7L6 907 357 C
  Component and/or Version: AFS-ECU       H04 0100
           Software Coding: 041A00010F000000
            Work Shop Code: WSC 01324 020 00200
              ASAM Dataset: EV_HeadlRegulVWAFSPt 002014 (VW36)
                      VCID: 3668A62C9100258E9B-8062
5275220 - Headlight
          C107E 54 [137] - Missing Calibration / Basic Setting
                    Reset counter: 62
                    Mileage: 62344 km
                    Date: 2016.02.07
                    Time: 17:57:00
                Address 55: Headlight Range       Labels: 5M0-907-357-V3.CLB
Address 55:5M0 907 357 E recoded (Long Coding) from 041A00010F000000 to 041A00010B000300  (01324/020/00200)
           Software Coding: 041A00010B000300
5275220 - Headlight
                    Reset counter: 62
                    Mileage: 62344 km
                    Date: 2016.02.07
                    Time: 17:58:34
Address 55:5M0 907 357 E recoded (Long Coding) from 041A00010B000300 to 081A00010B000300  (01324/020/00200)
Address 55:5M0 907 357 E recoded (Long Coding) from 041A00010B000300 to 001A00010B000300  (01324/020/00200)
Address 55:5M0 907 357 E recoded (Long Coding) from 041A00010B000300 to 031A00010B000300  (01324/020/00200)
Address 55:5M0 907 357 E recoded (Long Coding) from 041A00010B000300 to 051A00010B000300  (01324/020/00200)
Address 55:5M0 907 357 E recoded (Long Coding) from 041A00010B000300 to 091A00010B000300  (01324/020/00200)
Address 55:5M0 907 357 E recoded (Long Coding) from 041A00010B000300 to 041A00110B000300  (01324/020/00200)
           Software Coding: 041A00110B000300
5275220 - Headlight
                    Reset counter: 62
                    Mileage: 62344 km
                    Date: 2016.02.07
                    Time: 18:02:06
5281301 - Adjusting Motor for Variable Lighting Left
          C1096 15 [137] - Open or Short to Plus
                    Reset counter: 62
                    Mileage: 62344 km
                    Date: 2016.02.07
                    Time: 18:02:06
5281557 - Adjusting Motor for Variable Lighting Right
          C1097 15 [137] - Open or Short to Plus
                    Reset counter: 62
                    Mileage: 62344 km
                    Date: 2016.02.07
                    Time: 18:02:06
Address 55:5M0 907 357 E recoded (Long Coding) from 041A00110B000300 to 091A00110B000300  (01324/020/00200)
Address 55:5M0 907 357 E recoded (Long Coding) from 041A00110B000300 to 041A00010B000300  (01324/020/00200)
5275220 - Headlight
                    Reset counter: 62
                    Mileage: 62344 km
                    Date: 2016.02.07
                    Time: 18:03:29
Address 09: DTCs cleared
rentearobert
Romania
C?ID=5652
Hello
I'm new here.
I'm also having the same error on my retrofit AFS Bi-Xenon
Saturday,05,March,2016,11:16:33:60064
VCDS Version: 15.7.4.1
Data version: 20160216
Dealer/Shop Name: robert rentea
Workshop Code: 121 12121 012121
VIN: WVWZZZ16ZBM123294   License Plate: JETTA 2012
Mileage: 40970km-25457mi   Repair Order:
Chassis Type: 16 (7N0)
Scan: 01 03 08 09 10 15 16 17 19 25 42 44 46 52 55 56 62 72
VIN: WVWZZZ16ZBM123294   Mileage: 40970km-25457miles
Address 01: Engine (J623-CBZB)       Labels: 03F-906-070-CBZ.clb
    Part No SW: 03F 906 070 J    HW: 03F 906 070 B
    Component: SIMOS10.12H03 9663
    Revision: --H03---    Serial number: 00000000000000
    Coding: 001900D6232400080000
    Shop #: WSC 00066 123 00184
    ASAM Dataset: EV_ECM12TFS02103F906070J 004007
    ROD: EV_ECM12TFS02103F906070AA_VW32.rod
    VCID: 295248604813827609-807C
Readiness: 0110 0101
    Revision: 00H31001
    Coding: A13B20F8092400FD850D04ED901D0040210000
    Shop #: WSC 00066 000 00000
    VCID: 7BFE4228FA0FC0E62B-802E
    Part No SW: 5K0 907 044 EA    HW: 5K0 907 044 EA
    Component: Climatronic   H17 1010
    Revision: 00003001
    Coding: 0000000002
    Shop #: WSC 00066 000 00146
    ROD: EV_ClimaAutoBasis_SE36.rod
    VCID: 6ED87B7CB17DA54E9C-803A
    Part No SW: 5K0 937 086 J    HW: 5K0 937 086 J
    Component: BCM PQ35 M    011 0046
    Revision: BC011001
    Coding: 00000A3A982D02C04040008410008B4807058C8870808D60E44860040000
    Shop #: WSC 12121 121 12121
    VCID: 3B7E8228BA8F00E66B-806E
             010 - Open or Short to Plus
                     Fault Status: 01101010
                     Reset counter: 106
                     Mileage: 40977 km
                     Date: 2016.03.05
                     Time: 12:11:45
                     Voltage: 12.00 V
                     Reset counter: 106
                     Mileage: 40977 km
                     Date: 2016.03.05
                     Time: 12:11:45
                     Voltage: 12.00 V
Address 10: Park/Steer Assist (J446)       Labels: 1Q0-919-475.clb
    Part No SW: 5C6 919 475     HW: 7E0 919 475 A
    Component: PARKHILFE 8K  H10 0005
    Revision: --------    Serial number: 84091112900438
    Coding: 108001
    ASAM Dataset: EV_EPHVA18VW3610000 001003
    ROD: EV_EPHVA18VW3610000.rod
    VCID: 71E26000A043BAB681-8024
    Part No SW: 5C0 959 655 C    HW: 5C0 959 655 C
    Component: AirbagVW10    013 0613
    Serial number: 003G6D04X5JD
    Coding: 00003242
    ROD: EV_AirbaVW10SMEVW360_SE36.rod
    VCID: 3260AF0C65C5C1AEB8-8066
    Serial number: 3572MSME3D60325EZZZ$
    Serial number: 3582MSME1441525EZZZU
    Serial number: 3516KSME1E1B4F10ZZZ-
    Serial number: 3526KSME65204F10ZZZN
    Part No SW: 5K0 953 501 BH    HW: 5K0 953 569 L
    Revision: FF010041    Serial number: 20121015200930
    Coding: 019A160000
    Coding: E20000
    Part No SW: 5C6 920 860     HW: 5C6 920 860
    Component: KOMBI         H07 0405
    Coding: 170F00
    VCID: 67D60E589E877406DF-8032
    Part No SW: 7N0 907 530 C    HW: 1K0 907 951
    Component: J533  Gateway H37 0614
    Revision:   H37       Serial number: 27051101210466
    Coding: 351002
    VCID: 3064A50463C9F3BECE-8064
    Component: IMMO          H07 0405
    VCID: 6AD0776C8D95496EC0-803E
    Part No SW: 561 959 701 A    HW: 3C0 959 793 C
    Component: TUER-SG FT    002 0515
    Revision: 12110009    Serial number: 0002629415
    Coding: 0000B5
    Shop #: WSC 01383 790 50316
    ROD: EV_TSGFPQ35BRFVW46X.rod
    VCID: 1C3C61B4174167DE82-8048
    Slave Driver:
    Subsystem 1 - Part No SW: 3C0 959 703 B    HW: 3C0 959 795 C  Labels: 1K0-959-70X-GEN4.CLB
    Component: J388__TSG-HL  006 1508
    Serial number: 00000005797227
    Coding: 000090
    Part No: 1K0 909 144 M
    Component: EPS_ZFLS Kl. 68     3201
    Revision: 00H20000
    Shop #: WSC 02069 000 90108
    VCID: 346CA91457D1CF9EAA-8060
    Part No SW: 561 959 702 A    HW: 3C0 959 792 C
    Component: TUER-SG BT    002 0515
    Revision: 14110009    Serial number: 0002686375
    Coding: 0001B4
    ROD: EV_TSGBPQ35BRFVW46X.rod
    VCID: 1D3A6CB00C5B6ED675-8048
    Slave Passenger:
    Subsystem 1 - Part No SW: 3C0 959 704 B    HW: 3C0 959 794 C  Labels: 1K0-959-70X-GEN4.CLB
    Component: J389__TSG-HR  006 1508
    Serial number: 00000005783885
    Coding: 000090
    Coding: 1446940
    Subsystem 1 - Part No: 4H0 941 329   Labels: 3D0-941-329.CLB
    Component: AFS-Lst.-Modul l    0010
    Coding: 00000134
    Subsystem 2 - Part No: 4H0 941 329   Labels: 3D0-941-329.CLB
    Component: AFS-Lst.-Modul r    0010
    Coding: 00000134
             000 -  -  - MIL ON
                     Fault Status: 11100000
                     Reset counter: 106
                         Invalid
                         Invalid
                         Invalid
02656 - Power Output Stage for Left Headlight (J667); Not Coded
             000 -  -  - MIL ON
                     Reset counter: 106
                         Invalid
                         Invalid
                         Invalid
02657 - Power Output Stage for Right Headlight (J668); Not Coded
             000 -  -  - MIL ON
                     Reset counter: 106
                         Invalid
                         Invalid
                         Invalid
                     Fault Status: 11100101
                     Reset counter: 106
                         Invalid
                         Invalid
                         Invalid
Address 56: Radio (J0503)       Labels: 5M0-035-1xx-56.clb
    Part No SW: 3C8 035 195     HW: 3C8 035 195
    Component: Radio RCD510  041 0166
    Revision: 00000001    Serial number: VWZ1Z3L7121956
    Coding: 0500040004
    VCID: 65CA04506C8B6616ED-8030
End-------------------------(Elapsed Time: 02:37)--------------------------
if you did something and I expect AFS coding advice
thanks for understanding
