Power Outlet Timeout through VDCS
SpeedRacerAZ
C?ID=312337
Does anyone have the coding to change the Cig Lighter outlets timeout to 99 Minutes or permanently on? I know you can jumper the fusebox, but I'd rather do it the civilized way.
darkchina811
ITALY
C?ID=333184
I think switching the fuse position actually IS the civilized way, as it's even suggested in the Owner's Manual of the car ;)
SpeedRacerAZ
C?ID=312337
The method I saw was to create a wire jumper with an inline fuse from one side of the fuse panel to the other. There's a way on a B8S4 to move a fuse?
MasterTommy
Amsterdam
C?ID=295586
Most VW's have two fuse positions for the cigarette lighter fuse. Fuse in position 1 = switched power supply, switch the fuse to the other position = constant power supply. RTFM.
SpeedRacerAZ
C?ID=312337
I drive an Audi, not a VW. From what I can see there is no 2nd fuse position. I guess your RTFM has something special in it that doesn't apply to Audi.
https://www.dropbox.com/s/gfos6targ3jh17b/2019-01-14 09.18.48.jpg?dl=0
SpeedRacerAZ
C?ID=312337
Dang Audi elitist! ;)
Is there an Auto-Scan from this car somewhere?
See below for elitist autoscan... lol ;)
Thanks for looking at this Uwe!
Autoscan:
VCDS Version: 18.2.1.2 (x64)  HEX-V2 CB: 0.4411.4
VIN: WAUKGAFL4CA  License Plate:
Mileage: 142220km-88371mi   Repair Order:
Chassis Type: FL-AU48 (8T0)
Scan: 01 02 03 05 08 09 10 15 16 17 19 22 36 3C 42 46 47 52 53 55
          56 5F 62 6C 72
VIN: WAUKGAFL4CA   Mileage: 142220km-88371miles
Address 01: Engine (J623-CCBA)       Labels:. 06E-907-551-CAK.clb
   Part No SW: 8K0 907 551 D    HW: 8K0 907 551 A
   Component: 3.0T SIMOS84  H08 0003
   Revision: --H08---
   Coding: 0104000A240F0128
   Shop #: WSC 06324 123 12345
   ASAM Dataset: EV_ECM30TFS0218K0907551D 001003
   ROD: EV_ECM30TFS0218K0907551D.rod
   VCID: 323E12A8A4A38567B73-8066
   Part No SW: 8K2 927 156 S    HW: 0B5 927 156 F
   Component: 0B5 30TFSINAR H10 0001
   Revision: --H10---    Serial number: 0000000168
   Shop #: WSC 06325 000 00000
   ASAM Dataset: EV_TCMDL501 A02087
   ROD: EV_TCMDL501.rod
   VCID: 46D65E78382B09C70BB-8012
   Part No SW: 8K0 907 379 BJ    HW: 8K0 907 379 BJ
   Component: ESP8 quattro  H04 0060
   Coding: 290D1A
   Shop #: WSC 06324 000 00000
   VCID: 025E82685403F5E7673-8056
   Part No SW: 8K0 907 064 CG    HW: 8K0 907 064 CG
   Component: BCM2 2.0      H05 0435
   Coding: 0D0100
   VCID: 77A8E3BC0FC1A04F40D-8022
   Subsystem 1 - Part No SW: 8K0 905 852 D    HW: 8K0 905 852 D
   Serial number: 2311000262430004
   Part No SW: 8T1 820 043 AQ    HW: 8T1 820 043 AQ
   Component: KLIMA 3 ZONEN H08 0180
   Revision: C1000000    Serial number: 01181220110352
   Coding: 66106000
   VCID: 005A88605A0FE7F7717-8054
                    Fault Status: 00101101
                    Fault Frequency: 13
                    Reset counter: 138
                    Mileage: 141954 km
                    Date: 2018.10.22
                    Time: 17:25:37
   Part No SW: 8K0 907 063 P    HW: 8K0 907 063 P
   Component: BCM1 1.0      H30 0392
   Revision: 10030001    Serial number: 00000001168356
   Coding: 26001091003CAF212700080300003D0D0F9CD24802010161000000
   Shop #: WSC 06325 123 12345
   VCID: 3C223C90766743176DF-8068
   Component: WWS 141211  H07 0070
   Serial number: SWF11120146264
   Coding: 00F511
   Component: RLS  H04 0003
   Serial number: 20010916
   Coding: 025028
   Component: E1 - LDS  H03 0031
   Serial number: 00000000000812110065
   Subsystem 4 - Part No SW: 8K0 907 410 C    HW: 8K0 907 410 C
   Component: HOMELINK  H01 0010
                    Fault Status: 00101110
                    Fault Frequency: 13
                    Reset counter: 138
                    Mileage: 141954 km
                    Date: 2018.10.22
                    Time: 17:25:00
Address 10: Park/Steer Assist (J446)       Labels:. 8K0-919-475.clb
   Part No SW: 8K0 919 475 T    HW: 8P0 919 475 M
   Component: PARKHILFE 4K  H01 0081
   Revision: 11001001    Serial number: 36861134900422
   Coding: 20010D
   VCID: 4ACE6A482CB3EDA7EF3-801E
   Part No SW: 8K0 959 655 K    HW: 8K0 959 655 K
   Serial number: 003GLD90477.
   Coding: 303837354230303030304A55304C384B3053
   VCID: 45D45974052D02DF021-8010
   Subsystem 1 - Part No SW: 8K0 959 339 C    HW: 8K0 959 339 C
   Serial number: 5810000R1100006MMP
   Serial number: 6334MSME6620396FK
   Serial number: 6344MSME49750670C
   Serial number: 6352QSME45684C6E-
   Serial number: 6362QSME0E65104CK
   Serial number: 63732SME7166187A2
   Serial number: 63832SME2766137A%
   Part No SW: 8K0 953 568 G    HW: 8K0 953 568 G
   Component: Lenks.Modul   H17 0014
   Revision: --------    Serial number: 90372KLC001DO
   Coding: 000036
   VCID: 3E263698607B510743B-806A
   Component: E221 - MFL  H02 0010
   Part No SW: 8K0 920 981 Q    HW: 8K0 920 981 Q
   Component: KOMBIINSTR.   H12 0261
   Revision: 00000000    Serial number: ND420FDDC
   Coding: 831709008B00D705020000
   VCID: 41DC4D6411852EFF3E9-8014
   Part No SW: 8T0 907 468 AJ    HW: 8T0 907 468 L
   Component: GW-BEM 5CAN-M H10 0120
   Revision: FC201059    Serial number: 5900F11C028020
   Coding: 00C303
   VCID: 094C95446935A6BF269-805C
   Component: J367-BDMHella  H03 8040
   Serial number: 8540856001
   Part No SW: 8K0 907 163 A    HW: 8K0 907 163 A
   Component: 4 Wheel Drive H13 0025
   Serial number: 000812110001015
   ASAM Dataset: EV_AllWheelDiffeQSPCAN 003016
   VCID: 2E0606D8B09BA187D3B-807A
   Component: MEM-FS        H06 0076
   Revision: AA000000    Serial number: 00000020176063
   Coding: 00581B00000000000000
   VCID: 3B203F8C7369442F645-806E
Address 3C: Lane Change        Labels: None
   Part No SW: 8K0 907 566 H    HW: 4L0 907 566 B
   Component: J0769_SWA_MasterH02 0030
   Revision: 00H02000    Serial number: 6PZ 009 014-82
   Coding: 0000001
   VCID: 3C223C907A6743176DF-8068
   Subsystem 1 - Part No: 8K0 907 568 H
   Component: J0770_SWA_Slave_H01 0030
   Subsystem 2 - Serial number: 6PZ 009 014-92
   Subsystem 3 - Serial number: 5F01.12.1100H010003C322137ÿ
   Subsystem 4 - Serial number: 322137ÿ
   Part No SW: 8T0 959 793 M    HW: 8T0 959 793 D
   Component: TSG FA        H08 1501
   Coding: 011C13204E00410001
   VCID: 53F0772CFBF9AC6F9C5-8006
   Revision: 00002001    Serial number: 0165771988
   Coding: 0106063A00FA44058330013200000000
   Component: GTO BF  H01 0070
   Serial number: 00000000000000463946
   Subsystem 3 - Part No SW: 8K0 959 591 B    HW: 8K0 959 591
   Component: J245 PS050  H08 0043
   Part No SW: 8T0 035 223 AN    HW: 8T0 035 223 AK
   Component: DSP Prem      H10 0190
   Revision: 00010001    Serial number: 34804012392403
   VCID: 7AAEFA883CD3BD273F3-802E
   Part No SW: 8T0 959 792 M    HW: 8T0 959 792 D
   Component: TSG BF        H08 1501
   VCID: 52FE7228C4E3A567973-8006
   Revision: 00000003    Serial number: 00000001074202
   VCID: 343214B05E378B57A5F-8060
Address 55: Headlight Range        Labels: 8T0-907-357.clb
   Part No SW: 8H0 907 357 C    HW: 8H0 907 357 C
   Component: AFS 1           H01 0040
   Revision: 00H01001    Serial number:
   Coding: 0000019
   VCID: 323E12A8A8238567B73-8066
   Subsystem 1 - Part No: 8K0 941 329
   Component: AFS-Modul links H01 S001
   Subsystem 2 - Part No: 8K0 941 329
   Component: AFS-Modul rechtsH01 S001
   Part No SW: 4G0 035 082 B    HW: 4G0 035 082
   Component: Radio U SIRIU H53 0076
   Revision: AB001007    Serial number: 156L/0B7584005
   Coding: 020007010000000001
   VCID: 1F18EB1CC7B1380F68D-804A
   Part No SW: 8T1 035 664 D    HW: 8T1 035 664 B
   Component: H-BN-NA       H52 0165
   Revision: --------    Serial number: 490L90B7656953
   Coding: 010200000206E9FF77091F0E040000030000
   VCID: 392C25847955763F769-806C
   Subsystem 1 - Part No: 8R0 060 884 AD
   Component: NAR 2011  0505
   Subsystem 2 - Part No SW: 8R0 919 604     HW: 8R0 919 604
   Component: DU7 High  H41 0104
   Serial number: A130LA0BS077026
   Subsystem 3 - Part No SW: 8T0 919 609 G    HW: 8T0 919 609 G
   Component: E0380 Bedient  H08 0100
   Serial number: 00000001020292
   Subsystem 4 - Part No: 8R0 060 961 A
   Component: CD-Database  2712
            000 -  -
                    Reset counter: 94
                    Mileage: 141954 km
                    Date: 2018.10.22
                    Time: 17:27:08
                    Bin. Bits: 00000001 00100000
                    Bin. Bits: 01001000 00000000
                    Bin. Bits: 00000000 00000000
   Part No SW: 8T0 959 795 N    HW: 8T0 959 795 B
   Component: TSG HL        H06 1501
   Coding: 010C13204000210001
   VCID: 56F68E38E80BB9477BB-8002
   Revision: --H05---    Serial number: 525PA8-J1892IK
   Coding: 1000006
   VCID: 382A20804E5F6F37897-806C
   Component: TSG HR        H06 1501
End----------(Elapsed Time: 01:55, VBatt start/end: 12.3V/12.2V)-----------
I don't see an obvious way to change that with VCDS. However, your CCM's coding indicates that there is a "Power Outlet Relay" installed. So if you really want to change this behavior, I'd suggest digging into the wiring diagrams to see exactly how that relay is controlled. I would think it should be fairly straightforward to override it...
SpeedRacerAZ
C?ID=312337
It looks like that relay controls that row of fuses, is there a way to put a 99 minute delay on that relay and the entire bank?
OK, but how is that relay controlled? Presumably the J393 CCM turns it on and off. Is it low-side switched or high-side?
I don't see any way to change it in the CCM itself. That's not to say I coudn't have missed something though.
Zenerdiode
Newcastle, England
C?ID=24330
...Presumably the J393 CCM turns it on and off. Is it low-side switched or high-side?
Yes. J393 controls the high side of the relay. I too, have searched for an adaptation channel in 46 to see if I can extend the time. All of the channels with zero were changed but didn't make a difference to the time. Just as well, really, as having 46 awake for a long time would flatten the battery.
All is not lost, though. Just over Christmas, I've bought a couple of these relays that will plug directly into the Power Outlets Relay socket. (You only need one; the other one I bought is for powering the fridge on my work's truck. :D) I've timed mine so it will stay on for 2hrs to charge devices connected to the 12V socket in the boot. The rest of the car goes to sleep as normal. :)
SpeedRacerAZ
C?ID=312337
Exactly what I'm trying to accomplish!
This part seems like it's hard to find in the US. Were you able to directly swap the existing relay with this one?
HC Cargo Part Reference: https://hc-cargo.es/files/billeder/ecom/products/fg_annex/DK060212.pdf
The only US distributor: http://www.wagneralt.com/products/160927.asp
SpeedRacerAZ
C?ID=312337
So it looks like only alternator rebuild shops can purchase from this distributor, I’ll keep trying until I find a source.
SpeedRacerAZ
C?ID=312337
Anyone know where to find this relay in the US or another 12v 5 pin relay that has a 1-2 hour timer?
