Hello all.
I thought "automatic parking brake" was standard, considering it was active in all my former cars. For some reason, in my SQ5 is not activated. I believe (correct me if I'm wrong) this channel is the reason why I have always to manually pull the EPB button up after stop the engine to activate the EPB - in my former Audis, when i stopped the engine (or released the seat belt, can't remember exactly), the EPB was automatically activated.
If this channel is the "problem", I need a security code for him. Does anyone know the right one? Or some other I should try? If the problem is not this adaptation channel, where could it be?
Here's a log:
Cheers
Here's a log:
Monday,17,December,2018,22:06:15:30049
VCDS Version: 18.9.0.2 (x64)
VIN: WAUAGCFY2J2216711 License Plate:
Mileage: 116km-72mi Repair Order:
Chassis Type FY-AU49 (4M4)
Scan: 01 02 03 08 09 13 15 16 17 19 36 42 44 46 47 52 5F 6C 6D 74
81 82 8B A5 A9 BB BC CA
VIN: WAUAGCFY2J2216711 Mileage: 116km-72miles
46-Central Conv. -- Status: INTERFACE NOT COMPATIBLE
74-Chassis Control -- Status: INTERFACE NOT COMPATIBLE
CA-Sunroof -- Status: INTERFACE NOT COMPATIBLE
Address 01: Engine (J623-CWGD) Labels: Redir Fail!
Part No SW: 80A 907 559 B HW: 06M 907 309 D
Component: V6 3.0l TFSI H22 0005
Revision: B2H22000
Coding: 2A2A00322366050B34180000000000000000000000000000
ASAM Dataset: EV_ECM30TFS01180A907559B 001005
ROD: EV_ECM30TFS01180A907559B.rod
VCID: 2E54877B7162243A77-807A
Readiness: 0010 0001
Address 02: Auto Trans (J217) Labels:* None
Part No SW: 80A 927 158 HW: 0D5 927 156 H
Component: 0D5 30TSIRdW H05 1003
Revision: --H05---
Coding: 100000
ASAM Dataset: EV_TCMALX52011 002010
ROD: EV_TCMALX52011.rod
VCID: 69DE3467880C830262-803C
Part No SW: 80A 907 379 K HW: 80A 907 379 A
Component: ESP9 Premium H13 0775
Coding: 1CAA14BE30A30A9C91A55892087E52A2E5B5C238280C50891A104A45A7AD43
ASAM Dataset: EV_ESP9BOSCHCMP 002013
ROD: EV_ESP9BOSCHCMP_002.rod
VCID: 377AA21F8E38E5F224-8062
Address 08: Auto HVAC (E87) Labels:* None
Part No SW: 80A 820 043 J HW: 80A 820 043 J
Component: Klima Zone 3 H60 0210
Coding: 6608098C5544010D10000100080000000000000000000000000000000000
ROD: EV_AirCondiBHTCAU491.rod
VCID: 244065532FAE9E6A91-8070
Subsystem 1 - Part No SW: 4M1 820 021 B HW: 4M1 820 021 B
Component: J126 FLuftV H09 0003
Serial number: 00000000000002325326
Subsystem 2 - Part No SW: 4H0 907 658 A HW: 4H0 907 658 A
Component: AQ_Hum_Sensor H02 0007
Serial number: BF30DE1900PAG0MUFU02
Subsystem 3 - Part No SW: 80A 919 158 HW: 80A 919 158
Component: E265 Kli Fond H40 0080
196896 - Temperature Sensor for Rear Upper Body Vent
B1451 01 [009] - Electrical Failure
Reset counter: 0
Mileage: 45 km
Date: 2018.12.13
Time: 14:20:50
Voltage terminal 30: 13.18 V
Outside air temperature: 28.50 °C
Address 09: Cent. Elect. (J519) Labels:* None
Part No SW: 8W0 907 063 CF HW: 8W0 907 063 BF
Component: BCM1 MLBevo H13 0267
Coding: 07501143E17900CD050C51199C2F0CF9130B71090000000000000000600016810A4501AB22B606
VCID: 010E0CC7907C6B42DA-8054
Subsystem 1 - Part No SW: 80B 955 119 HW: 80B 955 119
Component: 426 LL 180608 040 0570
Serial number: 00000001805202210071
Coding: 5FC7F7
Subsystem 2 - Part No SW: 81A 955 555 A HW: 81A 955 555
Serial number: 21471476X81A955555A0
Coding: 02006E
Light switch:
Subsystem 3 - Part No SW: 4M0 941 531 AH HW: 4M0 941 531 AH
Component: E1 - LDS H06 0008
Serial number: 13 06 2018 81640362
Subsystem 4 - Part No SW: 8W0 857 511 HW: 8W0 857 511
Component: Y7_Innenspieg H09 0002
Serial number: GX1CE111061823810052
Interior Light Module:
Subsystem 5 - Part No SW: 80A 947 135 AB HW: 80A 947 135
Component: Dachmodul Q5 H31 0310
Serial number: Q00006636
Coding: 010101
Electrically Adjustable Steering Column:
Subsystem 6 - Part No SW: 80A 907 705 HW: 80A 907 705
Component: J866-EVLS-SG H03 0100
Serial number: WA131960000048021807
Coding: 0A0700
Cup Holder With Heater And Cooling Element:
Subsystem 7 - Part No SW: 80A 864 981 B HW: 80A 864 981 B
Component: Q5 THERMO CUP H07 0020
Serial number: 0009806910
Subsystem 8 - Part No SW: 8W0 925 301 BG HW: 8W0 925 301 BG
Component: SL-B9/Q5NF H17 0010
Serial number: 2818000105864007
Address 13: Auto Dist. Reg (J428) Labels:* None
Part No SW: 80A 907 561 HW: 8W0 907 561
Component: LRR4 H10 0220
Coding: 3472E7E358FFEC06747860A4
ASAM Dataset: EV_ACCBOSCHAU49X 002018
ROD: EV_ACCBOSCHAU49X_002.rod
VCID: 65C638576414A76246-8030
Address 15: Airbags (J234) Labels:| 80A-959-655.clb
Part No SW: 80A 959 655 N HW: 80A 959 655 N
Component: AirbagVW30 051 0605
Serial number: 003WBM05E6BI
Coding: AACCF00000800000980000FFF00C40000065
ASAM Dataset: EV_AirbaVW31SMEAU65x 001032
ROD: EV_AirbaVW31SMEAU65x_AU49.rod
VCID: 3E74B73BA102D4BAE7-806A
Subsystem 1 - Part No SW: ----------- HW: 480 000 705 18
Serial number: 357000000006877CDE2+
Subsystem 2 - Part No SW: ----------- HW: 480 000 705 18
Serial number: 358000000004EB510D2N
Subsystem 3 - Part No SW: ----------- HW: 480 030 405 18
Component: SideSensor_Dr 002 0149
Serial number: 351001C0C7BB11016D43
Subsystem 4 - Part No SW: ----------- HW: 480 030 505 18
Component: SideSensor_Pr 002 0149
Serial number: 352001C10B0945A0BC88
Subsystem 5 - Part No SW: ----------- HW: 480 030 305 18
Component: FrontSensor_D 002 0149
Serial number: 355001C0C73AF640AAEV
Front Sensor Passenger:
Subsystem 6 - Part No SW: ----------- HW: 480 030 305 18
Component: FrontSensor_P 002 0149
Serial number: 356001C0C73AF2407EFU
Central Sensor XY:
Subsystem 7 - Part No SW: ----------- HW: 480 021 804 18
Component: CentrSensorXY 000 0108
Serial number: I0O0001C929635C1928Z
Address 16: Steering wheel (J527) Labels: None
Part No SW: 80A 907 129 CH HW: 80A 907 129 CH
Component: Lenks.Modul H02 0005
ROD: EV_SMLSKLOAU736_007_AU49.rod
VCID: 70E85903ABD672CA25-8024
Address 17: Instruments (J285) Labels:* Redir Fail!-SRI2
Part No SW: 8W5 920 790 D HW: 8W5 920 790 D
Component: FBenRDW H19 0377
Coding: 048D96C43C9000081AA3E9401000000000000000
ASAM Dataset: EV_DashBoardAU736 001027
VCID: 4382C6CFCAE0B95288-8016
Part No SW: 4M4 907 468 F HW: 4M4 907 468 E
Component: Gateway H22 0123
Revision: 7L010001 Serial number: 01G7L013618610
Coding: 03010001000006405407000000590032F89A0000100000000100000000000000
ASAM Dataset: EV_GatewCONTIAU736 003111
ROD: EV_CGateCONTIAU491_003_AU49.rod
VCID: 3D76B037AC04CFA2FE-8068
Subsystem 1 - Part No SW: 80A 951 523 D HW: 80A 951 523 D
Component: J453 MFL H06 0004
Serial number: 20180628131716 00534
Subsystem 2 - Part No SW: 8S0 915 181 C HW: 8S0 915 181 C
Serial number: 8300445900
Address 36: Seat Mem. Drvr (J136) Labels:* None
Part No SW: 4M1 959 760 HW: 4M1 959 760
Component: MEM-FS 008 0031
Serial number: 11A14818400973
Coding: 00581B000000B0010000010101010000000000000000000000000000000000
VCID: 76E46F1BC9B25CFAFF-8022
Address 42: Door Elect, Driver (J386) Labels:* None
Part No SW: 8W1 959 593 HW: 8W1 959 593
Component: TSG FS001 0737
Serial number: CLSM1RFG004EA
Coding: 005D8A015E00040000011002
VCID: 081811E3B3465A0A9D-805C
Address 44: Steering Assist (J500) Labels:* None
Part No SW: 4M0 909 144 H HW: 4M0 909 144 B
Component: EPS_MLBEVO1BS H22 0005
Serial number: 0000690634
Coding: B0112101000101
ASAM Dataset: EV_EPSVWBSAU736 009023
ROD: EV_EPSVWBSAU736_009.rod
VCID: 346095139F4E0EEA01-8060
Address 46: Central Conv.
Interface not compatible.
Address 47: Sound System (J525) Labels:* None
Part No SW: 80A 035 223 A HW: 80A 035 223
Component: MIB2_amp_P_Q5 H03 0420
Revision: 00000001 Serial number: AUZ8ZAJTK02RDUA
Coding: 0194010800AFAAAFAA0000010000
ASAM Dataset: EV_AMPMst16C2Gen2ALPI 001012
ROD: EV_AMPMst16C2Gen2ALPI_AU49.rod
VCID: 193E44A718ECD38232-804C
Part No SW: 8W1 959 592 HW: 8W1 959 592
Component: TSG BFS001 0737
Serial number: CLSM1RF900T3Y
Coding: 005D8A015E00040000011000
VCID: 071A12DFBE58557294-8052
Part No SW: 8W5 035 039 B HW: 8W5 035 039
Component: MU-P-LN-RW 034 1177
Serial number: A801F0J9402993
Coding: 012456030000000013220002001A00102F001AE401700100DE
ROD: EV_MUHig6C3Gen2HBAS_AU49.rod
VCID: 3A7CBB2BBD2AF89ADB-806E
Subsystem 1 - Part No SW: V03 959 801 PT HW: -----------
Component: ROW 2017/2018 --- 0065
Subsystem 2 - Part No SW: 80A 919 605 HW: 80A 919 605
Component: AU426_DU_HIGH H42 0008
Serial number: AUZ8Z9JBL04YWW
Multimedia Operating Unit:
Subsystem 3 - Part No SW: 80A 919 615 HW: 80A 919 615
Component: ControlUnit_P H15 0209
Serial number: 11051800000000000529
Component: Gracenote2 --- 4012
Address 6C: Back-up Cam. (J772) Labels:* Redir Fail!
Part No SW: 4M0 980 556 A HW: 4M0 980 556 A
Component: RVC Compact H12 0250
Coding: 0224060102002001400040
ASAM Dataset: EV_CamSysRVRVCPANAMLBEv 005010
ROD: EV_CamSysRVRVCPANAMLBEv_005_AU49.rod
VCID: 3362960F9A4009D218-8066
Address 6D: Trunk Elect. (J605) Labels:| 5Q0-959-107.clb
Part No SW: 8W8 959 107 B HW: 8W8 959 107
Component: HDSG-Modul H13 0161
Revision: -------- Serial number: A2-C748-5750-5
Coding: 0730
ROD: EV_DeckLidCONTIAU736_VW41.rod
VCID: 4898D1E3F3C69A0A5D-801C
Address 74: Chassis Control
Address 81: Gear Shift (J587) Labels: 4MX-713-041-81.clb
Part No SW: 80B 713 041 M HW: 80B 713 041 M
Component: GSM-LL H10 0077
Revision: 0L0D5012 Serial number: 20180608000060
ROD: EV_GSMWaehlZFAU736_AU49.rod
VCID: 275A725F5E987572B4-8072
Address 82: Heads Up Display (J898) Labels:* None
Part No SW: 80A 919 617 HW: 80A 919 617
Component: HeadUpDisplay H13 1640
Coding: 4E01C0
ASAM Dataset: EV_HudNSEIKAU736 001017
ROD: EV_HudNSEIKAU736.rod
VCID: 6ADC4B6B8D0A881A6B-803E
Address 8B: Adaptive Cruise 2 (J850) Labels: 4M0-907-541.clb
Part No SW: 80A 907 541 HW: 8W0 907 541
ASAM Dataset: EV_ACC2BOSCHAU49X 002018
ROD: EV_ACC2BOSCHAU736_002_AU73.rod
VCID: 63C2264F6A20D952A8-8036
Address A5: Frt Sens. Drv. Assist (R242) Labels:* Redir Fail!
Part No SW: 80A 907 217 A HW: 80A 907 217 A
Component: BVS H16 0050
Coding: 0404020600000402022023A4CD000000A0000020C020
ROD: EV_BVSMLBevKOSTAAU736.rod
Address A9: Struct. Borne Sound (J869) Labels: None
Part No SW: 80A 907 159 HW: 4H0 907 159 A
Component: SAS-GEN 2 H07 0001
Serial number: 180329200420
VCID: 68D831639306BA0A7D-803C
Part No SW: 8W1 959 595 HW: 8W1 959 595
Component: TSG HFS001 0737
Serial number: CLSM1RFL00EBA
Coding: 000D88000000040000001000
ROD: EV_DCU2RearDriveMAXHCONT.rod
VCID: 0A1C2BEBAD4A281A8B-805E
Part No SW: 8W1 959 595 HW: 8W1 959 595 /
Component: TSG HBFS001 0737
Serial number: CLSM1RFL00E85
ROD: EV_DCU2RearPasseMAXHCONT.rod
Address CA: Sunroof
End-------------------------(Elapsed Time: 05:39)--------------------------
Address 08: DTCs cleared
Address 09,8W0 907 063 CF,channel IDE03782-Switch-off speed for parking assist,adapted from,5 ,to,20 ,
Address 17,8W5 920 790 D,recoded (Long Coding),from,048D96C43C9000081AA3E9401000000000000000,to,148D96C43C9000081AA3E9401000000000000000,(02391/785/00200),
Cheers
