SQ5 : 03-ABS Brakes : IDE08134-Automatic parking brake not active : Security Access?
AMBSC
Brazil
C?ID=233374
Hello all.
I thought "automatic parking brake" was standard, considering it was active in all my former cars. For some reason, in my SQ5 is not activated. I believe (correct me if I'm wrong) this channel is the reason why I have always to manually pull the EPB button up after stop the engine to activate the EPB - in my former Audis, when i stopped the engine (or released the seat belt, can't remember exactly), the EPB was automatically activated.
If this channel is the "problem", I need a security code for him. Does anyone know the right one? Or some other I should try? If the problem is not this adaptation channel, where could it be?
Here's a log:
Monday,17,December,2018,22:06:15:30049
VCDS Version: 18.9.0.2 (x64)
VIN: WAUAGCFY2J2216711   License Plate:
Mileage: 116km-72mi   Repair Order:
Chassis Type  FY-AU49 (4M4)
Scan: 01 02 03 08 09 13 15 16 17 19 36 42 44 46 47 52 5F 6C 6D 74
          81 82 8B A5 A9 BB BC CA
VIN: WAUAGCFY2J2216711   Mileage: 116km-72miles
46-Central Conv. -- Status: INTERFACE NOT COMPATIBLE
74-Chassis Control -- Status: INTERFACE NOT COMPATIBLE
CA-Sunroof -- Status: INTERFACE NOT COMPATIBLE
Address 01: Engine (J623-CWGD)       Labels: Redir Fail!
   Part No SW: 80A 907 559 B    HW: 06M 907 309 D
   Component: V6 3.0l TFSI  H22 0005
   Revision: B2H22000
   Coding: 2A2A00322366050B34180000000000000000000000000000
   Shop #: WSC 02391 785 00200
   ASAM Dataset: EV_ECM30TFS01180A907559B 001005
   ROD: EV_ECM30TFS01180A907559B.rod
   VCID: 2E54877B7162243A77-807A
Readiness: 0010 0001
Address 02: Auto Trans (J217)       Labels:* None
   Part No SW: 80A 927 158     HW: 0D5 927 156 H
   Component: 0D5  30TSIRdW H05 1003
   Revision: --H05---
   Coding: 100000
   ASAM Dataset: EV_TCMALX52011 002010
   ROD: EV_TCMALX52011.rod
   VCID: 69DE3467880C830262-803C
   Part No SW: 80A 907 379 K    HW: 80A 907 379 A
   Component: ESP9 Premium  H13 0775
   Coding: 1CAA14BE30A30A9C91A55892087E52A2E5B5C238280C50891A104A45A7AD43
   ROD: EV_ESP9BOSCHCMP_002.rod
   VCID: 377AA21F8E38E5F224-8062
   Part No SW: 80A 820 043 J    HW: 80A 820 043 J
   Component: Klima Zone 3  H60 0210
   Coding: 6608098C5544010D10000100080000000000000000000000000000000000
   ROD: EV_AirCondiBHTCAU491.rod
   VCID: 244065532FAE9E6A91-8070
   Subsystem 1 - Part No SW: 4M1 820 021 B    HW: 4M1 820 021 B
   Component: J126 FLuftV  H09 0003
   Serial number: 00000000000002325326
   Serial number: BF30DE1900PAG0MUFU02
   Subsystem 3 - Part No SW: 80A 919 158     HW: 80A 919 158
   Component: E265 Kli Fond  H40 0080
196896 - Temperature Sensor for Rear Upper Body Vent
          B1451 01 [009] - Electrical Failure
                    Reset counter: 0
                    Mileage: 45 km
                    Date: 2018.12.13
                    Time: 14:20:50
                    Voltage terminal 30: 13.18 V
                    Outside air temperature: 28.50 °C
   Part No SW: 8W0 907 063 CF    HW: 8W0 907 063 BF
   Component: BCM1 MLBevo   H13 0267
   Coding: 07501143E17900CD050C51199C2F0CF9130B71090000000000000000600016810A4501AB22B606
   VCID: 010E0CC7907C6B42DA-8054
   Subsystem 1 - Part No SW: 80B 955 119     HW: 80B 955 119
   Component: 426 LL 180608  040 0570
   Serial number: 00000001805202210071
   Coding: 5FC7F7
   Serial number: 21471476X81A955555A0
   Coding: 02006E
   Subsystem 3 - Part No SW: 4M0 941 531 AH    HW: 4M0 941 531 AH
   Component: E1 - LDS  H06 0008
   Serial number: 13 06 2018  81640362
   Serial number: GX1CE111061823810052
   Interior Light Module:
   Subsystem 5 - Part No SW: 80A 947 135 AB    HW: 80A 947 135
   Component: Dachmodul Q5  H31 0310
   Serial number: Q00006636
   Coding: 010101
   Electrically Adjustable Steering Column:
   Subsystem 6 - Part No SW: 80A 907 705     HW: 80A 907 705
   Component: J866-EVLS-SG  H03 0100
   Serial number: WA131960000048021807
   Coding: 0A0700
   Cup Holder With Heater And Cooling Element:
   Subsystem 7 - Part No SW: 80A 864 981 B    HW: 80A 864 981 B
   Component: Q5 THERMO CUP  H07 0020
   Serial number: 0009806910
   Subsystem 8 - Part No SW: 8W0 925 301 BG    HW: 8W0 925 301 BG
   Component: SL-B9/Q5NF  H17 0010
   Serial number: 2818000105864007
   Part No SW: 80A 907 561     HW: 8W0 907 561
   Component: LRR4          H10 0220
   Coding: 3472E7E358FFEC06747860A4
   ASAM Dataset: EV_ACCBOSCHAU49X 002018
   ROD: EV_ACCBOSCHAU49X_002.rod
   VCID: 65C638576414A76246-8030
   Part No SW: 80A 959 655 N    HW: 80A 959 655 N
   Component: AirbagVW30    051 0605
   Serial number: 003WBM05E6BI
   Coding: AACCF00000800000980000FFF00C40000065
   ASAM Dataset: EV_AirbaVW31SMEAU65x 001032
   ROD: EV_AirbaVW31SMEAU65x_AU49.rod
   VCID: 3E74B73BA102D4BAE7-806A
   Subsystem 1 - Part No SW: -----------    HW: 480 000 705 18
   Serial number: 357000000006877CDE2+
   Subsystem 2 - Part No SW: -----------    HW: 480 000 705 18
   Serial number: 358000000004EB510D2N
   Subsystem 3 - Part No SW: -----------    HW: 480 030 405 18
   Serial number: 351001C0C7BB11016D43
   Subsystem 4 - Part No SW: -----------    HW: 480 030 505 18
   Serial number: 352001C10B0945A0BC88
   Subsystem 5 - Part No SW: -----------    HW: 480 030 305 18
   Serial number: 355001C0C73AF640AAEV
   Front Sensor Passenger:
   Subsystem 6 - Part No SW: -----------    HW: 480 030 305 18
   Serial number: 356001C0C73AF2407EFU
   Central Sensor XY:
   Subsystem 7 - Part No SW: -----------    HW: 480 021 804 18
   Component: CentrSensorXY  000 0108
   Serial number: I0O0001C929635C1928Z
Address 16: Steering wheel (J527)       Labels: None
   Part No SW: 80A 907 129 CH    HW: 80A 907 129 CH
   Component: Lenks.Modul   H02 0005
   VCID: 70E85903ABD672CA25-8024
   Part No SW: 8W5 920 790 D    HW: 8W5 920 790 D
   Component: FBenRDW       H19 0377
   Coding: 048D96C43C9000081AA3E9401000000000000000
   VCID: 4382C6CFCAE0B95288-8016
   Part No SW: 4M4 907 468 F    HW: 4M4 907 468 E
   Component: Gateway       H22 0123
   Revision: 7L010001    Serial number: 01G7L013618610
   Coding: 03010001000006405407000000590032F89A0000100000000100000000000000
   ASAM Dataset: EV_GatewCONTIAU736 003111
   VCID: 3D76B037AC04CFA2FE-8068
   Subsystem 1 - Part No SW: 80A 951 523 D    HW: 80A 951 523 D
   Component: J453 MFL  H06 0004
   Serial number: 20180628131716 00534
   Serial number: 8300445900
   Part No SW: 4M1 959 760     HW: 4M1 959 760
   Component: MEM-FS        008 0031
   Serial number: 11A14818400973
   Coding: 00581B000000B0010000010101010000000000000000000000000000000000
   VCID: 76E46F1BC9B25CFAFF-8022
   Part No SW: 8W1 959 593     HW: 8W1 959 593
   Component: TSG FS001 0737
   Serial number: CLSM1RFG004EA
   Coding: 005D8A015E00040000011002
   VCID: 081811E3B3465A0A9D-805C
   Part No SW: 4M0 909 144 H    HW: 4M0 909 144 B
   Component: EPS_MLBEVO1BS H22 0005
   Serial number: 0000690634
   Coding: B0112101000101
   ASAM Dataset: EV_EPSVWBSAU736 009023
   ROD: EV_EPSVWBSAU736_009.rod
   VCID: 346095139F4E0EEA01-8060
Address 46: Central Conv.
Interface not compatible.
Please upgrade to a current Ross-Tech interface.
   Part No SW: 80A 035 223 A    HW: 80A 035 223
   Component: MIB2_amp_P_Q5 H03 0420
   Revision: 00000001    Serial number: AUZ8ZAJTK02RDUA
   Coding: 0194010800AFAAAFAA0000010000
   ASAM Dataset: EV_AMPMst16C2Gen2ALPI 001012
   ROD: EV_AMPMst16C2Gen2ALPI_AU49.rod
   VCID: 193E44A718ECD38232-804C
   Part No SW: 8W1 959 592     HW: 8W1 959 592
   Component: TSG BFS001 0737
   Serial number: CLSM1RF900T3Y
   Coding: 005D8A015E00040000011000
   VCID: 071A12DFBE58557294-8052
   Part No SW: 8W5 035 039 B    HW: 8W5 035 039
   Component: MU-P-LN-RW    034 1177
   Serial number: A801F0J9402993
   Coding: 012456030000000013220002001A00102F001AE401700100DE
   VCID: 3A7CBB2BBD2AF89ADB-806E
   Subsystem 1 - Part No SW: V03 959 801 PT    HW: -----------
   Component: ROW 2017/2018  --- 0065
   Subsystem 2 - Part No SW: 80A 919 605     HW: 80A 919 605
   Component: AU426_DU_HIGH  H42 0008
   Serial number: AUZ8Z9JBL04YWW
   Multimedia Operating Unit:
   Subsystem 3 - Part No SW: 80A 919 615     HW: 80A 919 615
   Component: ControlUnit_P  H15 0209
   Serial number: 11051800000000000529
   Compact Disc Database:
   Component: Gracenote2  --- 4012
   Component: RVC Compact   H12 0250
   Coding: 0224060102002001400040
   ROD: EV_CamSysRVRVCPANAMLBEv_005_AU49.rod
   VCID: 3362960F9A4009D218-8066
   Part No SW: 8W8 959 107 B    HW: 8W8 959 107
   Component: HDSG-Modul    H13 0161
   Revision: --------    Serial number: A2-C748-5750-5
   Coding: 0730
   ROD: EV_DeckLidCONTIAU736_VW41.rod
   VCID: 4898D1E3F3C69A0A5D-801C
Address 74: Chassis Control
   Part No SW: 80B 713 041 M    HW: 80B 713 041 M
   Component: GSM-LL        H10 0077
   Revision: 0L0D5012    Serial number: 20180608000060
   ROD: EV_GSMWaehlZFAU736_AU49.rod
   VCID: 275A725F5E987572B4-8072
Address 82: Heads Up Display (J898)       Labels:* None
   Part No SW: 80A 919 617     HW: 80A 919 617
   Component: HeadUpDisplay H13 1640
   Coding: 4E01C0
   ASAM Dataset: EV_HudNSEIKAU736 001017
   ROD: EV_HudNSEIKAU736.rod
   VCID: 6ADC4B6B8D0A881A6B-803E
Address 8B: Adaptive Cruise 2 (J850)       Labels: 4M0-907-541.clb
   Part No SW: 80A 907 541     HW: 8W0 907 541
   ASAM Dataset: EV_ACC2BOSCHAU49X 002018
   ROD: EV_ACC2BOSCHAU736_002_AU73.rod
   VCID: 63C2264F6A20D952A8-8036
Address A5: Frt Sens. Drv. Assist (R242)       Labels:* Redir Fail!
   Part No SW: 80A 907 217 A    HW: 80A 907 217 A
   Component: BVS           H16 0050
   Coding: 0404020600000402022023A4CD000000A0000020C020
   ROD: EV_BVSMLBevKOSTAAU736.rod
Address A9: Struct. Borne Sound (J869)       Labels: None
   Part No SW: 80A 907 159     HW: 4H0 907 159 A
   Serial number: 180329200420
   VCID: 68D831639306BA0A7D-803C
   Part No SW: 8W1 959 595     HW: 8W1 959 595
   Component: TSG HFS001 0737
   Serial number: CLSM1RFL00EBA
   Coding: 000D88000000040000001000
   ROD: EV_DCU2RearDriveMAXHCONT.rod
   VCID: 0A1C2BEBAD4A281A8B-805E
   Part No SW: 8W1 959 595     HW: 8W1 959 595 /
   Component: TSG HBFS001 0737
   Serial number: CLSM1RFL00E85
   ROD: EV_DCU2RearPasseMAXHCONT.rod
Address CA: Sunroof
End-------------------------(Elapsed Time: 05:39)--------------------------
Address 08: DTCs cleared
Address 09,8W0 907 063 CF,channel IDE03782-Switch-off speed for parking assist,adapted from,5 ,to,20 ,
Address 17,8W5 920 790 D,recoded (Long Coding),from,048D96C43C9000081AA3E9401000000000000000,to,148D96C43C9000081AA3E9401000000000000000,(02391/785/00200),
Cheers
