DAB unit change Audi A&6/RS6 2017 Long coding problem.
hhansen
Norway
C?ID=89088
I am trying to get DAB radio with a change used server 5F (4G) and activated with the VCDS, anyone who have a solution?
I will post the auto scan and long code bellow:
Long code:
017562010000000013110002000A00232F0008E5F17001009F
Auto scan:
17-Instruments -- Status: Cannot be reached 0100
Address 01: Engine (------CWUC)       Labels: Redir Fail!
     Part No SW: 4G0 906 560 F    HW: 4H0 906 014
     Component: 4.0l V8TFSI / H63 0001
     Revision: NCH63---
     Coding: 122A00326546090B3000
     Shop #: WSC 02391 785 00200
     ASAM Dataset: EV_ECM40TFS0114G0906560F 001002
     ROD: EV_ECM40TFS0114G0906560F.rod
     VCID: 2B5159C6420000125E-807E
Readiness: 0000 1001
     Part No SW: 4G0 927 158 BH    HW: 0BK 927 156 AM
     Component: 0BK 40TFSIRdW H19 1010
     Revision: --H19---
     VCID: 75E5BFBED4C406E2F8-8020
     Part No SW: 4G0 907 379 T    HW: 4G0 907 379 T
     Component: ESP9 Premium  H01 0100
     Coding: 64BF984926FD19929F00
     ROD: EV_ESP9BOSCHAU57X.rod
     VCID: 428F1462D58AE15A8D-8016
     Part No SW: 4H0 907 064 HP    HW: 4H0 907 064 HP
     Component: BCM2 2.0      H61 0825
     Coding: 05A96F0E000000000000
     VCID: 7EF7A092E9F245BAA9-802A
     Part No SW: 4G0 820 043 BL    HW: 4G0 820 043 BL
     Component: KLIMA 4 ZONEN H14 0113
     Serial number: 13091600040829
     Coding: 680210B8150000
     VCID: 6ADF9CC28D7AD91A65-803E
     Part No SW: 4H0 907 063 GH    HW: 4H0 907 063 AH
     Component: BCM1 2.0      H20 0368
     Revision: 15020001    Serial number: 00001464915102
     Coding: 0105001440349FF2F90140C7A0001800CF9CC7082E08020180000894E10113020040003D030000
     VCID: 74E382BAD7BE1FEACF-8020
     Component: WWS57X 160702  H38 0080
     Serial number:         160715072558
     Coding: 0045F7
     Serial number: 62225934
     Coding: 02006D
     Subsystem 3 - Part No SW: 4G0 941 531 BG    HW: 4G0 941 531 BG
     Component: E1 - LDS  H07 0044
     Serial number: 30 08 2016  00000250
     Subsystem 4 - Part No SW: 4H0 907 705 K    HW: 4H0 907 705 C
     Component: EVLS-SG  H08 0300
     Serial number: WA125088000024927446
     Coding: 020300
     Subsystem 5 - Part No SW: 4H0 907 658 B    HW: 4H0 907 658 B
     Serial number: 62E8854800PAG0MUFU03
     Component: ACC3          H21 0055
     Coding: 7E04010102
     ASAM Dataset: EV_AdaptCruisContrAU57X 002015
     VCID: 295DA3CE48FC1202AC-807C
Address 14: Susp. Elect.        Labels: None
     Part No SW: 4G0 907 376     HW: 4G0 907 376 A
     Component: J250 DRC FahrwerH02 0040
     Revision: 00000000    Serial number: 00894020502600
     Coding: 0000000
     VCID: 6BD199C64A80C0121E-803E
     Revision: --------    Serial number: 003P100B4U8$
     Coding: 30333130313730323535554A304C34473053
     VCID: 3B716986B2609092CE-806E
     Serial number: 3575HRB405R45HVK29I2
     Serial number: 3585HRB405N4529M6OV$
     Serial number: 3515JRB4016578V089T7
     Serial number: 3525JRB400U5744IJPQ%
     Serial number: 3554VRB400857ACIKQ9X
     Serial number: 3564VRB401257ACID8TO
     Revision: --------    Serial number: 90372PI3000ME
     Coding: 0000FD
     VCID: 377975B68648B4F22A-8062
     Subsystem 1 - Part No SW: 4G0 951 528 J    HW: 4G0 951 528 J
     Serial number: 27 07 2016  E0054671
     Part No SW: 4G0 920 931 R    HW: 4G0 920 931 R
     Component: TBenRdwAccNv  H14 0225
     Revision: 11001108    Serial number: 658050916596018
     Coding: 138F910BAFD50008010100
     ASAM Dataset: EV_RBD4K 004060
     ROD: EV_RBD4K.rod
     VCID: 35657FBE944446E238-8060
     Part No SW: 4G8 907 468 H    HW: 4G8 907 468
     Component: J533--Gateway H15 0096
     Revision: --------    Serial number: 00000002363802
     Coding: C0ED07481C
     ASAM Dataset: EV_GatewPkoUDS 002000
     VCID: 3D75679EAC749EA2F0-8068
     Subsystem 1 - Part No SW: 8S0 915 181 B    HW: 8S0 915 181 B
     Serial number: 8149621404
     Voltage stabilizer:
     Serial number: 160628000000000005D5
     Part No SW: 8K0 907 144 N    HW: 8K0 907 144 N
     Component: DYNAMIKLENK.  H06 0740
     Coding: 010100
     VCID: 3A7F6C82B55AA99AD5-806E
Address 22: AWD (J492)       Labels: 4H0-907-163.clb
     Part No SW: 4H0 907 163 B    HW: 4H0 907 163 A
     Component: 4 Wheel Drive H19 0200
     Serial number: 000909160001011
     ASAM Dataset: EV_AllWheelDiffeQSPFR 003026
     VCID: 285BA6CA53F62B0AB3-807C
     Part No SW: 4G0 919 158 R    HW: 4G0 919 158 R
     Component: KLIMA FOND    H08 0113
     Serial number: 09091600040773
     Coding: 20
     VCID: 3E776092A17285BAE9-806A
     Revision: AA000000    Serial number: 00000216332512
     VCID: 77F9B5B6C6C874F2EA-8022
     Component: SARA 6D red   H04 0056
     Revision: --------    Serial number: EJ1BPA7E02CM8G
     ASAM Dataset: EV_SARA2 005012
     ROD: EV_SARA2.rod
     VCID: 377975B68E48B4F22A-8062
     Component: SWA Master    H08 0070
     Serial number: 0415944781
     Coding: 040311
     VCID: 397D738EB85CA282DC-806C
     Component: SWA Slave  H08 0070
     Serial number: 0415109163
     Coding: 040311
     Component: TSG FA        H04 0511
     Coding: 011F16015E00628002080013
     VCID: 45850F7ECCA4D662A8-8010
     Part No SW: 4G0 909 144 T    HW: 4G0 909 144 Q
     Component: RCevo         H54 0202
     Revision: 00000001    Serial number: 0000936767
     Coding: 011001010001
     ASAM Dataset: EV_RCEPS 106007
     ROD: EV_RCEPS_106.rod
     VCID: 3A7F6C82BD5AA99AD5-806E
     Revision: 00002001    Serial number: 0416506207
     Coding: 013A0E20A0B93081C33009840C0312470000000000000000000000000000
     Subsystem 1 - Part No: 4G0 951 177 B
     Component: Sensor, DWA  005 0002
     Subsystem 3 - Part No SW: 4G0 947 135 B    HW: 4G0 947 135
     Serial number: 0000000AP00024070762
     Subsystem 4 - Part No SW: 3AA 962 243 D    HW: 3AA 962 243 D
     Serial number: 93873686
     Coding: 011F16015E00628002080002
     VCID: 46870872F1A2DD7AA1-8012
     Part No SW: 4H0 907 801 L    HW: 4H0 907 801 A
     Component: EPB-4         H05 0017
     Revision: --------    Serial number: 00000001955175
     ASAM Dataset: EV_ParkiBrake 001029
     ROD: EV_ParkiBrake_VW51.rod
     VCID: 316D4BAE602C6AC264-8064
     Coding: 04FA0A202A170200
     VCID: 346342BA9F3E5FEA0F-8060
     Coding: E01F00
     Coding: E01F00
     Matrix Headlamp Powermodule 1 Left:
     Subsystem 3 - Part No SW: 4H0 941 329 A    HW: 4H0 941 329 A  Labels: 3D0-941-329.CLB
     Component: MxB LeiMo li.  H03 0031
     Coding: E01F00
     Matrix Headlamp Powermodule 1 Right:
     Subsystem 4 - Part No SW: 4H0 941 329 A    HW: 4H0 941 329 A  Labels: 3D0-941-329.CLB
     Component: MxB LeiMo re.  H03 0031
     Coding: E01F00
     Part No SW: 4G1 035 020 F    HW: 4G1 035 020 D
     Component: MU-H-ND-EU    051 0670
     Serial number: A735H0G7500829
     Coding: 017562010000000013110002000A00232F0008E5F17001009F
     Shop #: WSC 36248 002 1048576
     VCID: 1C338A1A17AEF7AA27-8048
     Subsystem 1 - Part No SW: V03 959 801 FB    HW: -----------
     Component: ECE 2016/2017  --- 0153
     Subsystem 2 - Part No SW: 4G1 919 605 B    HW: 4G1 919 605 B
     Serial number: AUZ8Z9GY80609J
     Multimedia Operating Unit:
     Serial number: 90349PI5000OI
     Component: Gracenote2---  --- 1013
     Component: TSG HL        H03 0511
     Coding: 010F14004000628002080002
     VCID: 499D034EE0BC32024C-801C
Address 65: Tire Pressure (-----)       Labels: 3Y0-907-273.clb
     Part No SW: 4H0 907 273 B    HW: 4H0 907 273 B
     Component: RDKBERU25     H10 0820
     Serial number: 10000000031529
     ROD: EV_RDKBERU25_AU57.rod
     VCID: 2A5F5CC24DFA191AA5-807E
Address 6C: Back-up Cam. (J772)       Labels:| 4S0-980-556.clb
     Part No SW: 4S0 980 556     HW: 4M0 980 556
     Component: RVC Compact   H08 0140
     Coding: 027500010A002003000040
     ASAM Dataset: EV_CamSysRVRVCPANAAU57X 001001
     ROD: EV_CamSysRVRVCPANAAU57X_001.rod
     VCID: 78FBB68AC3D67B8AE3-802C
     Part No SW: 4G9 959 107 C    HW: 4G9 959 107 B
     Component: HDSG-Modul    H05 0151
     Revision: 14005001    Serial number: 245600092
     Coding: 093205C030
     ROD: EV_HDSGAu571.rod
     VCID: 366778B289424DFA31-8062
     Component: TSG HR        H03 0511
Address 82: Heads Up Display (J898)       Labels:| 4G0-919-604.clb
     Part No SW: 4G0 919 604 M    HW: 4G0 919 604 M
     Component: HeadUpDisplay H09 0306
     Coding: C78000
     ASAM Dataset: EV_HUDContiC7 001027
     ROD: EV_HUDContiC7.rod
     Component: DPC-SG        H27 0081
     Coding: 6A160000
     ROD: EV_OnBoardCamerDPC.rod
     VCID: 2C535ADA470E072A57-8078
     Coding: 7E04010102
     ASAM Dataset: EV_AdaptCruisContr2AU57X 002013
     VCID: 2759A5F65EE82472BA-8072
     Component: BV-SG         H34 0090
     Serial number: 005002452408167
     Coding: 04C0BB1B1111
     ASAM Dataset: EV_BC7 001001
     ROD: EV_BC7.rod
     Component: RGS-VL        H16 0080
     Coding: 0066E608031F0376070308014240C0010000
     ASAM Dataset: EV_RGS_L 002004
     ROD: EV_RGS_L.rod
     Component: RGS-VR        H16 0080
     ASAM Dataset: EV_RGS_R 002004
     ROD: EV_RGS_R.rod
     VCID: 326F44A2652A51DA1D-8066
Address BA: Motor Mounts (J931)       Labels: 4H0-907-145.clb
     Part No SW: 4H0 907 145 B    HW: 4H0 907 145
     Component: AEM - LEAR    H10 0008
     Revision: 00001001    Serial number: 97813007289901
     ROD: EV_AEMLearAU64X_AU57.rod
End-------------------------(Elapsed Time: 06:30)--------------------------
Dana
Western PA, USA
I added that 5F part number to the redirect file so a label file will load with the next version of VCDS. That file will only allow you to enable Developer Mode because we don't have official coding helper information in that label.
We do have Experimental Coding but that only works current generation interfaces. Your interface was assembled by PCI so you may want to contact your distributor to see what upgrade options they can offer directly at some point in the future. https://forums.ross-tech.com/showthread.php?13715-Why-Upgrade
Based on the experimental coding "Band_Settings_DAB_Tuner_Band_1" and "Band_Settings_DAB_Tuner_Band_2" live in Byte 10. "DAB_antenna_1" installed is found in Byte 12.
Your hardware may not support it but I believe this is DAB_Tuner_Band_1 - EU_Band_III-N with DAB_antenna_1 ON:
017562010000000013110102400A00232F0008E5F17001009F
.. where this may enable DAB_Tuner_Band_1 - EU_Band_III with DAB_antenna_1 ON:
017562010000000013110202400A00232F0008E5F17001009F
If both of those are rejected you might want to have a look in this sub-forum to see if any other baseline vehicle scans are helpful:
https://forums.ross-tech.com/forumdisplay.php?45-Reference-Scans-and-Maps-of-Non-Broken-Cars
hhansen
Norway
C?ID=89088
Thank you very much Dana, I solved the problem with a long code from another A6 Allroad 2015 modell year, that had DAB installed. I looks like Byte 10 is where the DAB is activated? I will try to find out exactly witch 0-7 byte to be change soon.
