I am trying to get DAB radio with a change used server 5F (4G) and activated with the VCDS, anyone who have a solution?
I will post the auto scan and long code bellow:
Long code:
017562010000000013110002000A00232F0008E5F17001009F
Auto scan:
Long code:
Auto scan:
17-Instruments -- Status: Cannot be reached 0100
Address 01: Engine (------CWUC) Labels: Redir Fail!
Part No SW: 4G0 906 560 F HW: 4H0 906 014
Component: 4.0l V8TFSI / H63 0001
Revision: NCH63---
Coding: 122A00326546090B3000
Shop #: WSC 02391 785 00200
ASAM Dataset: EV_ECM40TFS0114G0906560F 001002
ROD: EV_ECM40TFS0114G0906560F.rod
VCID: 2B5159C6420000125E-807E
Readiness: 0000 1001
Part No SW: 4G0 927 158 BH HW: 0BK 927 156 AM
Component: 0BK 40TFSIRdW H19 1010
Revision: --H19---
VCID: 75E5BFBED4C406E2F8-8020
Address 03: ABS Brakes (J104) Labels:. 4G0-907-379-V2.clb
Part No SW: 4G0 907 379 T HW: 4G0 907 379 T
Component: ESP9 Premium H01 0100
Coding: 64BF984926FD19929F00
ROD: EV_ESP9BOSCHAU57X.rod
VCID: 428F1462D58AE15A8D-8016
Part No SW: 4H0 907 064 HP HW: 4H0 907 064 HP
Component: BCM2 2.0 H61 0825
Coding: 05A96F0E000000000000
VCID: 7EF7A092E9F245BAA9-802A
Part No SW: 4G0 820 043 BL HW: 4G0 820 043 BL
Serial number: 13091600040829
Coding: 680210B8150000
VCID: 6ADF9CC28D7AD91A65-803E
Address 09: Cent. Elect. (J519) Labels: Redir Fail!
Part No SW: 4H0 907 063 GH HW: 4H0 907 063 AH
Component: BCM1 2.0 H20 0368
Revision: 15020001 Serial number: 00001464915102
Coding: 0105001440349FF2F90140C7A0001800CF9CC7082E08020180000894E10113020040003D030000
VCID: 74E382BAD7BE1FEACF-8020
Component: WWS57X 160702 H38 0080
Serial number: 160715072558
Coding: 0045F7
Component: G397_RLFS H06 0004
Serial number: 62225934
Coding: 02006D
Subsystem 3 - Part No SW: 4G0 941 531 BG HW: 4G0 941 531 BG
Component: E1 - LDS H07 0044
Serial number: 30 08 2016 00000250
Subsystem 4 - Part No SW: 4H0 907 705 K HW: 4H0 907 705 C
Component: EVLS-SG H08 0300
Serial number: WA125088000024927446
Coding: 020300
Subsystem 5 - Part No SW: 4H0 907 658 B HW: 4H0 907 658 B
Component: AQ_Hum_Sensor H01 0005
Serial number: 62E8854800PAG0MUFU03
Component: ACC3 H21 0055
Coding: 7E04010102
ASAM Dataset: EV_AdaptCruisContrAU57X 002015
VCID: 295DA3CE48FC1202AC-807C
Address 14: Susp. Elect. Labels: None
Part No SW: 4G0 907 376 HW: 4G0 907 376 A
Component: J250 DRC FahrwerH02 0040
Revision: 00000000 Serial number: 00894020502600
Coding: 0000000
VCID: 6BD199C64A80C0121E-803E
Revision: -------- Serial number: 003P100B4U8$
Coding: 30333130313730323535554A304C34473053
VCID: 3B716986B2609092CE-806E
Serial number: 3575HRB405R45HVK29I2
Serial number: 3585HRB405N4529M6OV$
Serial number: 3515JRB4016578V089T7
Serial number: 3525JRB400U5744IJPQ%
Serial number: 3554VRB400857ACIKQ9X
Serial number: 3564VRB401257ACID8TO
Revision: -------- Serial number: 90372PI3000ME
Coding: 0000FD
VCID: 377975B68648B4F22A-8062
Subsystem 1 - Part No SW: 4G0 951 528 J HW: 4G0 951 528 J
Serial number: 27 07 2016 E0054671
Address 17: Instruments (J285) Labels:. 4H0-920-xxx-17.clb-SRI1
Part No SW: 4G0 920 931 R HW: 4G0 920 931 R
Component: TBenRdwAccNv H14 0225
Revision: 11001108 Serial number: 658050916596018
Coding: 138F910BAFD50008010100
ASAM Dataset: EV_RBD4K 004060
ROD: EV_RBD4K.rod
VCID: 35657FBE944446E238-8060
Address 19: CAN Gateway (J533) Labels: None
Part No SW: 4G8 907 468 H HW: 4G8 907 468
Revision: -------- Serial number: 00000002363802
Coding: C0ED07481C
VCID: 3D75679EAC749EA2F0-8068
Subsystem 1 - Part No SW: 8S0 915 181 B HW: 8S0 915 181 B
Serial number: 8149621404
Voltage stabilizer:
Serial number: 160628000000000005D5
Address 1B: Active Steering (J792) Labels: None
Part No SW: 8K0 907 144 N HW: 8K0 907 144 N
Component: DYNAMIKLENK. H06 0740
Revision: 52001005 Serial number: --------------
Coding: 010100
VCID: 3A7F6C82B55AA99AD5-806E
Address 22: AWD (J492) Labels: 4H0-907-163.clb
Part No SW: 4H0 907 163 B HW: 4H0 907 163 A
Component: 4 Wheel Drive H19 0200
Serial number: 000909160001011
VCID: 285BA6CA53F62B0AB3-807C
Part No SW: 4G0 919 158 R HW: 4G0 919 158 R
Component: KLIMA FOND H08 0113
Serial number: 09091600040773
Coding: 20
VCID: 3E776092A17285BAE9-806A
Component: MEM-FS H03 0157
Revision: AA000000 Serial number: 00000216332512
VCID: 77F9B5B6C6C874F2EA-8022
Part No SW: 4G0 907 637 L HW: 4G0 907 637 G
Component: SARA 6D red H04 0056
Revision: -------- Serial number: EJ1BPA7E02CM8G
ASAM Dataset: EV_SARA2 005012
ROD: EV_SARA2.rod
VCID: 377975B68E48B4F22A-8062
Component: SWA Master H08 0070
Serial number: 0415944781
Coding: 040311
VCID: 397D738EB85CA282DC-806C
Lane Change Assistant 2:
Component: SWA Slave H08 0070
Serial number: 0415109163
Coding: 040311
Address 42: Door Elect, Driver (J386) Labels: None
Component: TSG FA H04 0511
Coding: 011F16015E00628002080013
VCID: 45850F7ECCA4D662A8-8010
Part No SW: 4G0 909 144 T HW: 4G0 909 144 Q
Component: RCevo H54 0202
Revision: 00000001 Serial number: 0000936767
Coding: 011001010001
ASAM Dataset: EV_RCEPS 106007
ROD: EV_RCEPS_106.rod
VCID: 3A7F6C82BD5AA99AD5-806E
Revision: 00002001 Serial number: 0416506207
Coding: 013A0E20A0B93081C33009840C0312470000000000000000000000000000
Subsystem 1 - Part No: 4G0 951 177 B
Component: Sensor, DWA 005 0002
Subsystem 3 - Part No SW: 4G0 947 135 B HW: 4G0 947 135
Serial number: 0000000AP00024070762
Subsystem 4 - Part No SW: 3AA 962 243 D HW: 3AA 962 243 D
Serial number: 93873686
Address 52: Door Elect, Pass. (J387) Labels: None
Component: TSG BF H03 0511
Coding: 011F16015E00628002080002
VCID: 46870872F1A2DD7AA1-8012
Part No SW: 4H0 907 801 L HW: 4H0 907 801 A
Component: EPB-4 H05 0017
Revision: -------- Serial number: 00000001955175
ASAM Dataset: EV_ParkiBrake 001029
ROD: EV_ParkiBrake_VW51.rod
VCID: 316D4BAE602C6AC264-8064
Component: MxB-ECU 001 0100
Coding: 04FA0A202A170200
VCID: 346342BA9F3E5FEA0F-8060
Coding: E01F00
Coding: E01F00
Matrix Headlamp Powermodule 1 Left:
Subsystem 3 - Part No SW: 4H0 941 329 A HW: 4H0 941 329 A Labels: 3D0-941-329.CLB
Component: MxB LeiMo li. H03 0031
Coding: E01F00
Matrix Headlamp Powermodule 1 Right:
Subsystem 4 - Part No SW: 4H0 941 329 A HW: 4H0 941 329 A Labels: 3D0-941-329.CLB
Component: MxB LeiMo re. H03 0031
Coding: E01F00
Part No SW: 4G1 035 020 F HW: 4G1 035 020 D
Component: MU-H-ND-EU 051 0670
Serial number: A735H0G7500829
Coding: 017562010000000013110002000A00232F0008E5F17001009F
Shop #: WSC 36248 002 1048576
VCID: 1C338A1A17AEF7AA27-8048
Subsystem 1 - Part No SW: V03 959 801 FB HW: -----------
Component: ECE 2016/2017 --- 0153
Subsystem 2 - Part No SW: 4G1 919 605 B HW: 4G1 919 605 B
Component: DU8 C7 SV H63 0007
Serial number: AUZ8Z9GY80609J
Multimedia Operating Unit:
Serial number: 90349PI5000OI
Compact Disc Database:
Component: Gracenote2--- --- 1013
Address 62: Door, Rear Left (J388) Labels: None
Component: TSG HL H03 0511
Coding: 010F14004000628002080002
VCID: 499D034EE0BC32024C-801C
Address 65: Tire Pressure (-----) Labels: 3Y0-907-273.clb
Part No SW: 4H0 907 273 B HW: 4H0 907 273 B
Component: RDKBERU25 H10 0820
Serial number: 10000000031529
ASAM Dataset: EV_RDKBERU25 003014
ROD: EV_RDKBERU25_AU57.rod
VCID: 2A5F5CC24DFA191AA5-807E
Address 6C: Back-up Cam. (J772) Labels:| 4S0-980-556.clb
Part No SW: 4S0 980 556 HW: 4M0 980 556
Component: RVC Compact H08 0140
Coding: 027500010A002003000040
ASAM Dataset: EV_CamSysRVRVCPANAAU57X 001001
ROD: EV_CamSysRVRVCPANAAU57X_001.rod
VCID: 78FBB68AC3D67B8AE3-802C
Part No SW: 4G9 959 107 C HW: 4G9 959 107 B
Component: HDSG-Modul H05 0151
Revision: 14005001 Serial number: 245600092
Coding: 093205C030
ROD: EV_HDSGAu571.rod
VCID: 366778B289424DFA31-8062
Address 72: Door, Rear Right (J389) Labels: None
Component: TSG HR H03 0511
Address 82: Heads Up Display (J898) Labels:| 4G0-919-604.clb
Part No SW: 4G0 919 604 M HW: 4G0 919 604 M
Component: HeadUpDisplay H09 0306
Coding: C78000
ASAM Dataset: EV_HUDContiC7 001027
ROD: EV_HUDContiC7.rod
Component: DPC-SG H27 0081
Coding: 6A160000
ROD: EV_OnBoardCamerDPC.rod
VCID: 2C535ADA470E072A57-8078
Coding: 7E04010102
ASAM Dataset: EV_AdaptCruisContr2AU57X 002013
VCID: 2759A5F65EE82472BA-8072
Component: BV-SG H34 0090
Serial number: 005002452408167
Coding: 04C0BB1B1111
ASAM Dataset: EV_BC7 001001
ROD: EV_BC7.rod
Component: RGS-VL H16 0080
Coding: 0066E608031F0376070308014240C0010000
ASAM Dataset: EV_RGS_L 002004
ROD: EV_RGS_L.rod
Component: RGS-VR H16 0080
ASAM Dataset: EV_RGS_R 002004
ROD: EV_RGS_R.rod
VCID: 326F44A2652A51DA1D-8066
Address BA: Motor Mounts (J931) Labels: 4H0-907-145.clb
Part No SW: 4H0 907 145 B HW: 4H0 907 145
Component: AEM - LEAR H10 0008
Revision: 00001001 Serial number: 97813007289901
ROD: EV_AEMLearAU64X_AU57.rod
End-------------------------(Elapsed Time: 06:30)--------------------------
