Lost my engine noise simulation on my Audi Allroad 3,0Bitdi 313hk 2013
jaendor9
New Member
Norway
HC428297 (2nd hand?)
Address C0: Act. for Ext. Noise (J943) Labels: 4G0-907-160.clb
Part No SW: 4G0 907 160 B HW: 4G0 907 160 B
Component: SAS-GEN 2 AGA H09 0004
Serial number: 120713200186
VCID: 244DE69A2F2AA26A91-8070
0006 - Actuator 1 for Engine Noise Simulation
C113C 13 [008] - Open Circuit
Reset counter: 93
Mileage: 88661 km
Date: 2018.10.03
Time: 07:33:57
0010 - Databus
Mileage: 70694 km
Date: 2017.11.15
Time: 14:24:55
i can't find out whats wrong. any ide where 2 start looking?
have only check 2 fuses. and look on the internet for many hours without any result. tryed looking on Erwin, but nothing there that helps me.
i lost the exhaust sound Date: 2018.10.03. so i think it's the first fault thats my problem.
Well, "Open Circuit" should be pretty clear, no?
jaendor9
New Member
Norway
i think it's cord breakage or loose contact. But could it be a broken actuator? sorry for my stupid question. i just thought maby someone had the same problem one time and could tell me about it. since i couldn't find how that system is build up.
Yes, it could be any of those things. The module just knows the circuit is open. Further trouble-shooting would be done with the aid of wiring diagrams and a mulitmeter.
jaendor9
New Member
Norway
has now crossed actuator 1 and 2. error message is the same. did not change. The cables are in line with the control unit. no breakage. This helps to suspect errors in the control unit itself. but did anyone experience open circuit errors due to errors in the board itself?
Raphae1
New Member
jaendor9 did you ever resolve this issue? I have a similar issue and would like to know.
Christoffer
C?ID=375977
Hi jaendor9 and Raphae1. Did you ever resolve this issue, as I have a similar issue and would like to know? Furthermore were you able to delete error codes on the module? When I try to delete the 0006 error code, I get a message saying, that the attempt to delete the error code wasn't accepted by the control unit.
Mari
C?ID=150535
We have seen jaendor9 for the last time on this forum on 12-17-2018 so I don't think he will answer... Raphael1 is probably also waiting for jaendor9 to answer... so hopefully one of the other forum members know what to do except checking wiring...
