Friday,16,November,2018,19:22:19:50329
VCDS Version: 18.9.0.2 (x64)
VIN: WAUMFBFR9FA059002 License Plate:
Chassis Type: FR-AU48 (8R0)
Scan: 01 02 03 05 06 08 09 15 16 17 19 36 42 44 46 52 53 56 5F 6C
VIN: WAUMFBFR9FA059002 Mileage: 61870km-38444miles
Address 01: Engine (DET-CPMB) Labels:. 06H-907-115-CDN.clb
Part No SW: 8K5 907 115 N HW: 8K2 907 115 L
Component: 2.0l R4/4V TF H09 0005
Revision: ECH09---
Coding: 5A2A0013242600062000
Shop #: WSC 58673 001 1048576
ASAM Dataset: EV_ECM20TFS0118K5907115N 001006
ROD: EV_ECM20TFS0118K5907115N.rod
VCID: 3D7B1384ACB537A2FE-8068
U1113 00 [039] - -
Mileage: 61877 km
Date: 2018.11.16
Time: 19:18:18
Engine speed: 793.00 /min
Normed load value: 21.2 %
Coolant temperature: 48 °C
Intake air temperature: 24 °C
Voltage terminal 30: 14.300 V
Engine status: COENG_RUNNING
5664 - Mass Air Flow Sensor (G70)
P0100 00 [039] - Supply Voltage
Mileage: 61877 km
Date: 2018.11.16
Time: 19:18:18
Voltage terminal 30: 14.324 V
Readiness: 1110 0101
Part No SW: 8K0 927 158 AD HW: 0BK 927 156 AL
Component: 0BK 20TFSIUSA H19 1005
Revision: --H19---
VCID: 78F5C290C317D28AED-802C
2505 - Torque Management Feedback Signal A
P2637 00 [039] - -
Mileage: 61877 km
Date: 2018.11.16
Time: 19:18:20
Voltage terminal 30: 14.344 V
Transmission output speed: 0.00 /min
Driving position: P
M008_Torque Converter Lockup Clutch State-Shift Type / Mode: 0
M008_Torque Converter Lockup Clutch State-Torque Converter Lockup Clutch: Open
M008_Torque Converter Lockup Clutch State-Traction/Coasting Flag: Traction
Transfer speed from ESP: valid
Transfer speed from ESP: 0.00 km/h
Address 03: ABS Brakes (J104) Labels:. 8K0-907-379-V2.clb
Part No SW: 8K0 907 379 CM HW: 8K0 907 379 CM
Component: ESP8 quattro H09 0020
Coding: 2D150001
Shop #: WSC 06325 000 00000
VCID: 0609BC68B1E3B47AEF-8052
013 - Check DTC Memory
Fault Status: 01101101
Fault Frequency: 14
Reset counter: 105
Mileage: 61876 km
Date: 2018.09.27
Time: 11:47:32
Hex Value: 0x00C0
Hex Value: 0x07A2
Hex Value: 0x0009
Hex Value: 0x468B
Hex Value: 0x0000
Part No SW: 8K0 907 064 KM HW: 8K0 907 064 KM
Component: BCM2 2.0 H15 0711
Coding: 0D804040000000000000
VCID: 050BBB648CE5BF62E6-8050
Subsystem 1 - Part No SW: 8K0 905 852 E HW: 8K0 905 852 E
Serial number: 3215000065563010
Address 06: Seat Mem. Pass (J521) Labels:. 8T0-959-760.clb
Part No SW: 8T0 959 760 E HW: 8T0 959 760 E
Component: MEM-BFS H10 0077
Revision: AA000000 Serial number: 00000143751239
Coding: 08037025002400001000
VCID: 458B7B64CC657F62A6-8010
Part No SW: 8K1 820 043 AQ HW: 8K1 820 043 AQ
Revision: C1000000 Serial number: 01170420152293
Coding: 6482208000
VCID: 77F7C1ACC609DDF2E4-8022
Part No SW: 8K0 907 063 DH HW: 8K0 907 063 DH
Component: BCM1 1.0 H16 0103
Revision: 08016001 Serial number: 00001052828401
Coding: 26000096863CAFE00100488300003D0D0F9CD38822090201000008004400030100000030000000
VCID: 78F5C290CB17D28AED-802C
Subsystem 1 - Part No SW: 8T1 955 119 D HW: 8J1 955 119 Labels: 1KX-955-119.CLB
Component: WWS 160415 H15 0080
Serial number: SWF15044165123
Coding: 00FD11
Component: G397_RLFS H06 0004
Serial number: 20248721
Coding: 02005D
Component: E1 - LDS H03 0031
Serial number: 00000000000204150592
Serial number: 8B4844A7000000000001
12 Faults Found:
02895 - Supply Voltage for LED Module for DRL and Parking Light; Left
Fault Status: 01101100
Reset counter: 103
Mileage: 61876 km
Date: 2018.09.27
Time: 11:43:41
03188 - Bulb for Side Marker Light; Front Left
Reset counter: 103
Mileage: 61876 km
Date: 2018.09.27
Time: 11:43:41
Reset counter: 103
Mileage: 61876 km
Date: 2018.09.27
Time: 11:43:41
02897 - Supply Voltage for LED Module for DRL and Parking Light; Right
Reset counter: 103
Mileage: 61876 km
Date: 2018.09.27
Time: 11:43:41
03189 - Bulb for Side Marker Light; Front Right
Reset counter: 103
Mileage: 61876 km
Date: 2018.09.27
Time: 11:43:41
Reset counter: 103
Mileage: 61876 km
Date: 2018.09.27
Time: 11:43:41
Reset counter: 103
Mileage: 61876 km
Date: 2018.09.27
Time: 11:47:36
Reset counter: 103
Mileage: 61876 km
Date: 2018.09.27
Time: 11:47:36
010 - Open or Short to Plus
Fault Status: 01101010
Reset counter: 103
Mileage: 61876 km
Date: 2018.09.27
Time: 11:47:38
Reset counter: 103
Mileage: 61876 km
Date: 2018.09.27
Time: 11:47:38
Reset counter: 103
Mileage: 61877 km
Date: 2018.10.11
Time: 16:19:12
Reset counter: 103
Mileage: 61877 km
Date: 2018.10.11
Time: 16:19:12
Part No SW: 8K0 959 655 Q HW: 8K0 959 655 Q
Component: AirbagVW-AU10 H51 0812
Serial number: 003NDD134KWQ
Coding: 30414333483038313130554A304C38543053
ASAM Dataset: EV_AirbaECUVWAUDI010 003114
VCID: 4B9F4D5CE201891270-801E
Serial number: 6334MSME505D2C77O
Serial number: 6344MSME506C2632A
Serial number: 6352QSME655341708
Serial number: 6362QSME0E5010705
9443859 - Driver's Front Airbag Crash Sensor
B101A 15 [137] - Open or Short to Plus
Mileage: 61876 km
Date: 2018.09.27
Time: 11:47:32
9444115 - Front Passenger's Front Airbag Crash Sensor
B101B 15 [137] - Open or Short to Plus
Mileage: 61876 km
Date: 2018.09.27
Time: 11:47:32
Part No SW: 8K0 953 568 Q HW: 8K0 953 568 Q
Component: Lenks.Modul H03 0003
Revision: C0062331 Serial number: 90862ODD00123
Coding: 000036
VCID: 48957250FB77620A5D-801C
Part No SW: 8T0 920 932 Q HW: 8T0 920 932 Q
Component: KOMBIINSTR. H36 0567
Revision: 00100000 Serial number: 5J+317H4G
Coding: 8BA7010002010008020000
VCID: 46897C68F163747AAF-8012
Part No SW: 8R0 907 468 N HW: 8R0 907 468 C
Component: GW-BEM 4CAN-M H11 0060
Revision: 1Y080030 Serial number: 3041Y1540705A3
Coding: 80C303FF00
VCID: 4A914858E57B901A4B-801E
Serial number: 8818946203
00384 - Optical Databus
Fault Status: 00101011
Reset counter: 143
Mileage: 61877 km
Date: 2018.11.16
Time: 13:21:58
Bin. Bits: 00000
Voltage: 11.60 V
Count: 11
Bin. Bits: 00000
Component: MEM-FS H10 0077
Revision: AA000000 Serial number: 00000143758720
Coding: 081B7B25002400001000
Part No SW: 8T0 959 793 P HW: 8T0 959 793 G
Component: TSG FA H10 0305
Coding: 011C13224E00120102
VCID: 56A9AC2821C3C4FADF-8002
Part No SW: 8K0 909 144 P HW: 8K0 909 144 B
Component: RCEPS H43 0510
Revision: 00001000 Serial number: 0003685798
Coding: 100000010001
Shop #: WSC 06324 000 00000
ASAM Dataset: EV_RCEPSAU48X 008018
ROD: EV_RCEPSAU48X_008.rod
VCID: 3E791488A1B32CBAE7-806A
Revision: 00002001 Serial number: 0364787678
Coding: 0106029A00FA000580B0003200000000
Subsystem 2 - Part No SW: 8R0 959 591 A HW: 8R0 959 591
Component: J245EE20SKB13 H05 0220
Part No SW: 8T0 959 792 P HW: 8T0 959 792 G
Component: TSG BF H10 0305
VCID: 55ABAB243CC5CFE2D6-8000
Part No SW: 8K0 907 801 N HW: 8K0 907 801 J
Component: EPB-4 H02 0005
Revision: -------- Serial number: 00000001649990
ROD: EV_ParkiBrake_AU48.rod
VCID: 3A711898BD9B009ADB-806E
464384 - Function Restriction due to Faults in Other Modules
U1113 00 [009] - -
Reset counter: 103
Mileage: 61876 km
Date: 2018.09.27
Time: 11:47:32
Voltage terminal 30: 11.3 V
Internal Fault ID: 188
Network management state: normal
Function light in parking brake button: On
Red operating lamp: On
Red warning lamp: OFF
Green operating lamp: OFF
Yellow warning lamp: OFF
Terminal 15 status: On
RWU: not active
DSD: not active
HTR: not active
ECD: not active
ACC requested apply: not active
Auto Adjust: not active
General Inspection Function: not active
Internal Parking Brake state: static
Status of parking brake button: Not operated
Status ParkingBrake left: Set
Status ParkingBrake right: Set
Part No SW: 4G0 035 082 G HW: 4G0 035 082
Component: Radio U SIRIU H66 0133
Revision: AB001007 Serial number: 156D 0F8254165
Coding: 020007020100000001
VCID: 244DC6E0271F666A91-8070
Part No SW: 8R1 035 664 G HW: 8R1 035 664 G
Component: H-BN-NA H42 0901
Revision: -------- Serial number: 522DX0F7512851
Coding: 13020002000681EF45008B4E00000403F40000020000000000
VCID: 3A711898B59B009ADB-806E
Subsystem 1 - Part No: 8R0 060 884 CJ
Component: NAR 2015 1102
Component: DU7 High H42 0104
Serial number: A130DR0F3326617
Subsystem 3 - Part No SW: 8T0 919 611 L HW: 8T0 919 611 C
Serial number: 00000002206533
Component: CD-Database 5950
02067 - Optical Databus; Unpermitted Wake-Up Request
Reset counter: 143
Mileage: 61877 km
Date: 2018.11.16
Time: 13:20:56
Voltage: 11.50 V
Part No SW: 8T0 907 441 C HW: 4L0 907 441 B
Revision: --H09--- Serial number: 525PA8-JA2909F
Coding: 1000008
Shop #: WSC 06435 000 00000
VCID: 387502904B97128A2D-806C
End-------------------------(Elapsed Time: 03:18)--------------------------
