G28 Speed Snsor Issue
ak77
Singapore
C?ID=232348
Hi guys,
I'm having another issue s with My GTD Mk5 Golf. The car wont turn on at first key turn , feels like low battery start (full charge).
Second crank last bit longer but it turns on after 5 seconds. This behavior is constant regardless weather or not car is hot or cold.
Car has power and drives with no loss of mpg. I have replaced starter motor and G28 sensor. Both new.
Below from my scan you can see the G28 sensor error keeps repeating and it can not be cleared. After replacing G28, does timing on V belt have to be adjusted or something similar on VCDS.?
Can someone please advise on what it possibly could be . I really don;t want to replace this again on BMN engine as its extremely difficult exercise for the 3rd time.
Also could someone explain priority and frequency of this.
Thanks in advance, help greatly appreciated.
Al
Tuesday,04,December,2018,21:10:54:41771
VCDS -- Windows Based VAG/VAS Emulator Running on Windows XP x86(VMWare)
VCDS Version 18.9.0.2
Chassis Type: 1K (7N0)
Scan: 01 02 03 08 09 15 16 17 19 25 42 44 46 52 56 62 72 76
VIN: WVWZZZ1KZ8U002011   Mileage: 187480km-116494miles
Address 01: Engine        Labels: 03G-906-018-BMN.clb
   Part No SW: 03G 906 018 FC    HW: 03G 906 018 FC
   Component: R4 2.0l PPD1.2 G    1155
   Revision: --H42---    Serial number: VWX7Z0G43NO1FZ
   Coding: 0000078
   Shop #: WSC 00046 412 00000
   VCID: 6BD5F48C4A26DB1210-803F
000801 - Engine Speed Sensor (G28)
               P0321 - 006 - Implausible Signal - Intermittent
                    Fault Frequency: 61
                    Reset counter: 39
                    Mileage: 187434 km
                    Time: 13:55:26
                    RPM: 64 /min
                    Torque: 0.0 Nm
                    Time: 0.02 s
                    Angle: 0.0 °
                    Bin. Bits: 00000000
                    Bin. Bits: 00000001
Readiness: N/A
   Part No SW: 02E 300 044 L    HW: 02E 927 770 AE
   Component: GSG DSG         081 1403
   Revision: 04608010    Serial number: 00000704301340
   Shop #: WSC 44551 111 44551
   VCID: 1E33ED58C914FEBAC7-804B
   Revision: 00H11001
   Coding: 0023170
   VCID: 73E5ECEC121603D2D8-8027
   Part No SW: 1K0 907 044 BR    HW: 1K0 907 044 BR
   Component: ClimatronicPQ35 120 1111
   Revision: 00120021    Serial number: 00000000000000
   VCID: 78FFDBC00B70608AED-802D
   Revision: 00H54000    Serial number: 00000007980938
   Coding: E5890F2700041500471400001400000000087F075C000100000000000000
   VCID: 71E9E6E4680A31C22A-8025
   Component: Wischer 140707 020  0501
   Coding: 00049109
   Shop #: WSC 00046
   Subsystem 2 - Part No: 1K0 955 559 AB  Labels: 1K0-955-559-AF.CLB
   Component: RLS     310806 020  0105
   Coding: 00208933
   Shop #: WSC 00046
   Component: 1P AIRBAG VW8   020 2300
   Revision: 05020000    Serial number: 0038PD19R1ST
   Coding: 0012624
   VCID: 3D710AD464D285A2FE-8069
   Subsystem 1 - Serial number: 6332MSME173C6109A
   Subsystem 2 - Serial number: 6342MSME1A251E29G
   Subsystem 3 - Serial number: 6352QSME265C3269M
   Subsystem 4 - Serial number: 6362QSME274E403BN
   Part No SW: 1K0 953 549 AQ    HW: 1K0 953 549 AQ
   Component: J0527           636 0070
   Coding: 0012122
   VCID: 0109B62458AA2142DA-8055
   Part No SW: 1K0 920 874 B    HW: 1K0 920 874 B
   Component: KOMBIINSTRUMENT VDD 1216
   Revision: V0002000    Serial number: VWX7Z0G43NO1FZ
   Coding: 0003103
   VCID: 2C5737908FA81C2A59-8079
   Revision:   H42       Serial number: 240314F1005704
   Coding: 350003
   VCID: 356112F49CE25DE236-8061
   Component: IMMO            VDD 1216
   Part No SW: 1K0 959 701 N    HW: 1K0 959 701 N
   Component: Tuer-SG         006 120B
   Coding: 0000692
   VCID: 39791EC470FAB982D2-806D
   Part No: 1K2 909 144 M
   Component: EPS_ZFLS Kl.069 H08 1901
   VCID: 366315F841E456FA3F-8063
   Coding: 809002005103087F2D0484056008DF0380FC00
   VCID: 0305BC2C42B63352C8-8057
   Part No SW: 1K0 959 702 N    HW: 1K0 959 702 N
   Component: Tuer-SG         005 090B
   Coding: 0000948
   VCID: 3A7B01C875FCB29ADB-806F
   Part No SW: 56D 035 190 A    HW: 56D 035 190 A
   Component: RCD510USBRVC  001 0003
   Revision: -----001    Serial number: VWZ4Z3M8175927
   Coding: 01000424040000
   Shop #: WSC 00078 790 00230
   VCID: 224BD9A83D6CDA5AE3-8077
                    Reset counter: 131
                    Mileage: 182346 km
                    Time: 00:20:00
   Component: Tuer-SG         006 1201
   Coding: 0000144
   Shop #: WSC 00046 412 1012544
   VCID: 387F1BC04BF0A08A2D-806D
   Coding: 0000144
Address 76: Park Assist        Labels: 1K0-919-283.lbl
   Part No: 1K0 919 283 A
   Component: 22 Einparkhilfe     0101
   VCID: 2D513A94B4B215224E-8079
End-------------------------(Elapsed Time: 02:51)--------------------------
Fault Frequency and Priority are explained in the VCDS manual here:
http://www.ross-tech.com/vcds/tour/dtc_screen.php
G28 replacement should not require any other adjustments.
If you're replaced the G28 sensor already, I hate to ask, but where did you source it?
ak77
Singapore
C?ID=232348
Changed twice now, first one was the ebay Turkish version, but since I have installed VW original.
They behave same . I'm not sure about G40 sensor working in tandem with g28, if that has an issue. But surely it would be recorded by the system ?
At this stage , lots of guesswork/ ie. wires connections all checked and fine?
I'm also suspecting injector seals, possibly leaking and obstructing start? Should I be looking into servicing them . I have no loss o power or cuts while driving.
Would you say I'm looking in wrong direction here?
If the ECU keeps throwing a code for the G28 sensor, then the there's an issue with something directly related to that sensor. Could be the the sensor itself (but this seems unlikely since you've tried two of them), could be the the toothed thing that the sensor reads (flywheel), could be a wiring problem between the sensor or the ECU, or it could be the ECU itself.
HMC
C?ID=28246
How is the airgap? Have you got something stopping the sensor seating correctly like 2 o rings?
Regards HMC
ak77
Singapore
C?ID=232348
Regards HMC
no o rings, it was difficult to see , but I would say No, nothing stayed on Old sensor.
ak77
Singapore
C?ID=232348
That’s a bit left of field ? Why would you say ignition switch ? No other errors present !
Cheers mate
Al
I have seen a situation multiple times now where during the crank period, an undefined condition existed that evaded logs or diagnosis stack and after changing all other suspect sensors, harness overlay, ground enhancements, terminal relays and even ECU, the ignition switch solved it and in some cases on rare days an oil PSI regulation problem can cause this code too!
Just because codes are not there don't mean a problem didn't or doesn't exist.......
Dana
Western PA, USA
I agree with Jack and wanted to add, P0321 can be the direct end result of a long-crank.
Fuel (in-tank electric or high side in this case), compression, timing or similar could be to blame. In my experience PD TDIs often have intermittent in-tank fuel pump issues. If this is easy enough to duplicate it couldn't hurt to see if the filter housing is empty and verify the proper volume of fuel is being pumped up to the front when you're sure it would be a long-crank or no-start initially. Basic Settings 035 should run the in-tank pump: http://wiki.ross-tech.com/wiki/index.php/Fuel_Pump_Basic_Settings_for_PD,_PPD,_and_CR_TDI_Engines
ak77
Singapore
C?ID=232348
Hi Jack,
I have isolated your idea and found not to be the case. I have replaced dash console, immobilizer and key mechanism from another GT.
It does identical start. First time nothing happens. then after 5 sec it cranks.
At least I tried.
Al
ak77
Singapore
C?ID=232348
Hey Dana, I have tested both fuel pumps tank and tandem and the work perfectly. In fact that was the first thing I isolated as it did feel like engine wasn't getting fuel (priming) / or the drained battery (wouldn't turn). What I did, I installed transparent hose to engine from fuel tank filter chamber to see if there is air bubbles in mixture while flowing.... I will look into timing as soon as my new belt tension kit arrives. Keep you posted.
Al
ak77
Singapore
C?ID=232348
One thing its worth a mention , I don't always get the Error Workshop message once cranking. Mostly it just glow plug spiral icon flashing.
On all occasions after scanning , I only get G28 error code. Any thoughts?
Al
