Special editions | E0A | Without special action equipment |
Lockable wheel bolts | 1PA | Standard wheel bolts |
Vehicle class differentiation
units/platform components | 0CU | Vehicle class differentiation -1C0- |
Emission standard | 0GG | Emission standard EU4 |
Trailer hitch | 1D0 | without trailer towing |
airbag | 4UE | driver and front passanger airbags |
Automatic transmission indicator light | 9FA | Without automatic transmission
indicator light |
Aktivkohlebehälter / Ottopartikelfilter | 1E1 | Activated carbon canister |
Storage compartment | 7N1 | Overhead storage compartment |
Exterior mirror setting | 6XN | Exterior mirrors, power-adjustable/
separately heated |
Left exterior mirror | 5SJ | Left exterior mirror, convex |
Right exterior mirror | 5RV | Right exterior mirror, aspherical |
Drive type | 1X0 | Front-wheel drive |
Outside temperature display | 9Y1 | Outside temperature display |
Equipment levels | A8D | luxury version |
Brake type in rear | 1KS | Disc brakes in rear (Geomet D) |
batteries | J1L | Battery 280 A (60 Ah) |
Brake type, front | 1ZM | Disc brakes in front (Geomet D) |
Components with special surface | 6FE | Body-colored exterior mirror housings
and tailgate handle |
Component part sets with
country-specific design requirements | B0N | Component parts set, complying with
vehicle type for Great Britain, various
parts |
floor covering | 3MF | Dilours floor covering with scuff guard |
vehicle tools and jack | 1S1 | vehicle tools and jack |
brake pressure regulator | 1H0 | without brake pressure regulator |
Brake systems | 1AT | electronic satbility programme -ESP- |
Owner's manuals | 0VA | Without owner's manual |
brake wear indicator | 9U1 | brake wear indicator |
Heated washer nozzles | 9T0 | Without heated washer nozzles |
CD changer/CD player | 7A0 | Without CD changer/CD player |
General operating permit, alterations | C12 | Operating permit, alteration |
Cd enhancing underbody panel | 2D1 | Complete cd enhancing underbody panel |
Roof insert/convertible top | 3FA | roof without cut out |
Suspension system in rear | UB1 | Rear shock absorption for sports version |
Suspension system in front | G16 | Shock absorption in front |
Insert for the filling up of unleaded
fuel/fuel type | 2G7 | Filler neck module 1 with insert |
Installation differentiation for components | 0EJ | Installation differentiation for
transmission MQ 250
-- vehicle components -- |
Theft protection system | 7AH | Electronic immobilizer, with anti-theft
alarm system, interior monitoring and
backup horn |
Interference suppression | 8E2 | Local interference suppression for FM/AM
radio reception |
Park distance control | 7X0 | Without park distance control |
Manufacturing sequence differentiation | 0FA | Standard manufacturing sequence |
Vehicle type | AZ0 | Vehicle with production equipment |
window regulator | 4R4 | Power windows with comfort operation and
circuit breaker |
fire extinguisher | 6A0 | without fire extinguisher |
Headlight activation | 8K0 | Without special driving light switching |
Fresh air intake for passenger
compartment (with particulate filter) | 2V5 | Fresh air intake with activated charcoal filter |
Antifreeze | 1C2 | Antifreeze up to -35 degree celsius
tolerance up to -40 degree C |
Vehicle specifications | F0A | No special purpose vehicle, standard
equipment |
throttle control | 0L2 | accelerator pedal with electronic modul |
Alternators | 8GD | Alternator 90 A |
Transmission types/gearshift mechanisms | 0G4 | Cable gearshift |
Transmission shafts | 1WB | Transmission shafts 100 mm in diameter |
Weight category rear axle | 0YZ | Without determination of weight
category for rear axle |
Weight category front axle | L19 | Suspension range 19
installation control only, no
requirement forecast |
Base engine | T53 | 4-cyl. petrol engine 1.6 l assembly 06A.S (ALU) |
Luggage netting/pocket on backrest(s) | 4U5 | Luggage pockets on backrest |
Luggage compartment cover | 3U1 | Folding trunk cover |
cruise control system | 8T0 | Without cruise control system (CCS) |
Exterior noise suppression measures | 2B7 | additional noise dampener |
Transmission specifications | G0C | 5-speed manual transmission |
Cruise control system and speed limiter | 6Y0 | without speed warning system |
Brackets | 3P1 | Bracket for first aid kit and warning
triangle |
Center high-mounted stop light | 8R1 | Center high-mounted stop lamp |
handle for hand brake lever | 6PA | Hand brake lever handle in plastic |
Rear spoiler | 5J0 | Without rear spoiler |
Rear window wiper and washer system | 8M0 | Without rear window wiper and washer
system |
Grab handles at roof frame | 5N7 | Folding grab handle front |
Rear axle | 0N5 | Standard rear axle |
Rear seats | 3NB | Rear seat bench/backrest, completely
folding |
Heating and air-conditioning system | 9AB | Manually controlled air conditioning
system |
Headlamps | 8BF | Halogen headlamp for driving on the left |
Instrument clusters | U0H | Instrument cluster with tachometer, mph
speedometer and trip odometer |
Breakaway interior rearview mirror | 4L2 | Breakaway interior rearview mirror,
dimming |
Sticker (customized or special edition) | 0KA | Without decals and emblems |
Body style | K8F | Roundback |
Luggage compartment floor covering | 6SC | Luggage compartment floor covering in
needle-punched nonwoven |
Electronic map cooling system | QS0 | Without electronic map cooling system |
headrest for seat, rear | 3Q1 | headrest for seat, rear |
Head restraints | 3J7 | Tilt- and height-adjustable head
restraints for front seats |
Fuel tank treatment | 2LC | Fuel tank with special material
treatment (coextrusion) |
Fuel quantity for initial filling | 1Z2 | Increase in initial standard fuel
filling |
Fuel systems | 0F2 | Fuel system for SI engine |
Body measures | 5C0 | Without special body measures |
Catalytic converter control | 8KA | without catalyst control |
Rear license plate bracket | 6P1 | Rear license plate carrier (ECE) |
Front license plate bracket | 6W1 | Front license plate carrier (large) |
Paint preservative/transit coating | 5K5 | Transportation protective film
(instead of paint preservation) |
Country-specific product program | X2B | National sales program Great Britain |
Steering system arrangement | L0R | Right-hand drive |
Reading lamp | 8S3 | Additional reading lights rear |
steering | 1N1 | Power steering |
Backrest release | 3H9 | Backrest release for front seats with
Easy Entry feature |
Lumbar support | 7P0 | Without lumbar support
in seat backrests |
steering wheels | 1MF | Comfort steering wheel for airbag system |
Speaker installation | 8RL | 6 speakers (passive) |
Steering column systems | 2C5 | Steering column, adjusted axially and vertically |
Headlight range control | 8Q1 | Headlight range control |
Center armrest | 6E3 | Front center armrest |
Multi-function display/trip computer | 9Q0 | Without multi-function display/
trip computer |
Engine cooling | 8Z5 | not hot country |
Engine specifications | MW6 | 4-cylinder SI engine 1.6 l/75 kW
with MPI
base engine is T0B/T53/TC2/TL2 |
Left vanity mirror | 4SM | Left vanity mirror illuminated
with cover and pocket |
Right vanity mirror | 4TM | Vanity mirror, right, illuminated
Navigation device | 7Q0 | without navigation system |
rear fog lamp | 8TD | Rear fog light for driving on the left |
Front fog lamp/additional headlamp | 8WA | Without fog lights |
Rear of platform module base | 4P0 | Rear floor panel module, type 1 |
Platform group class | 7PD | Platform group class 4 |
Hubcaps | 1NU | Full wheel covers |
Wheels | C9D | Steel wheels 6.5J x 16 |
Radios | 8AD | Radio "gamma" |
Smoker's/non-smoker's package | 9JB | Smoker's package, ashtrays in front and
rear |
tire | H6U | 205/55 R16 91W tyres |
Tire suppliers | V0A | Tires without specification of tire
brand |
Spare wheel/breakdown kit | 1G2 | Spare wheel with full tyre, steel |
| PE2 | comfort package |
| PH1 | air conditioning system |
| PJ7 | steel wheels 6 1/2J X 16 |
| PS6 | comfort seats package including "Easy
Entry" |
| PT2 | technical equipment package for GB |
| RCA | radio "gamma" in New Beetle design |
Side airbag | 4X1 | Side airbag in front |
Gearshift knob/handle | 6Q1 | Gearshift knob/handle in plastic |
Special labels/plates | 0SC | Labels in English |
Tail lamp assemblies | 8SA | Rear combination lamp, standard design |
Locking mechanism for boot lid/cover
rear | 4E8 | Tailgate/trunk lid release
from inside (electrically) |
Materials of low flammability | 4Q1 | Materials of low flammability |
Seat belt check | 9P0 | without press button buckle with warning contact |
Outer rear seat belts | 3ZM | 3-point seat belts, outer rear |
Center rear seat belts | 3C0 | Without seat belts in center, rear |
Gearshift boot/cover | 6R1 | Gearshift boot in leatherette |
seat covers | N0W | Fabric seat covers
New Beetle packaging |
Seat adjustment | 3L3 | Manual height adjustment for front seats |
seat heater | 4A0 | without seat heater |
Side lights | 8F2 | side-mounted turn signals |
Key for locking system | 8QE | Key for locking system with remote control |
Start-stop system/regenerative braking | 7L0 | Without inertia benefit system/
deceleration fuel cut-off/idle stop
valve |
Side and rear windows | 4KC | Side and rear windows in heat-insulating
glass |
power outlet | 7B0 | without socket |
Bumper | 2JG | bumper in color of vehicle |
Rear stabilizer | 0BC | Rear stabilizer |
Front stabilizer bar | 0AE | Front stabilizer bar |
Heavy-duty/sports version | 2UA | Standard design |
Headlamp washer system | 8X0 | Without headlamp washer system |
Windshield wiper intermittent control/
light/rain sensor | 8N4 | Windshield wiper intermittent control
with potentiometer (four speeds) |
Nameplate set | 0NA | Without nameplate set
(without model designation) |
Fuel filler cap/door, locking option | 2W0 | filler cap for fuel tank |
Mass damper for steering wheels | 1Q0 | steering wheel without balance weight |
Door and lid locking system | 4K3 | Central locking w/ radio remote control,
interior controls and SAFELOCK |
Type approval countries/countries with
special requirements | B09 | Type approval country GB/Northern
Ireland |
Carrier frequency for remote control | 5D1 | Carrier frequency 433.92 to 434.42 Mhz |
Door and side trim panels | 4AF | Door and side trim panel in foam film
and woven fabric |
doors | 0A1 | 2 doors |
Front underbody guard | 1SA | Without additional front underbody guard |
Identification plates | 1EX | Special identification plate for EU |
Fender house liner | VU0 | Without fender house liner |
Two-way radio installation preparation | 9D0 | without prepared for two way radio system |
Front seats | Q1A | Standard seats in front |
Telephone / telematics | 9W0 | Without car phone preparation/
installation |
Additional warning lights | 9TB | Additional warning lights (door area) |
LongLife Service Regime | QG1 | LongLife Service Regime |
Heat accumulator system/auxiliary heater | 7E0 | W/o heat accumulator/auxiliary heating |
Windshield Glass | 4GF | Windshield in heat-insulating glass |
Washer fluid level indicator | 8W0 | without washer water level indicator |
Additional tires (snow tires) | 2WA | without spare tyre |
floor mats | 0TA | without floor mats |
Additional child seat anchors | 3B0 | Without additional child seat anchors |
Zündanlaß/Schloß-Sperrsystem/
Elektrische Lenksäulenverriegelung | 0RA | Without ignition/safety ignition lock |
