Hi.
I got running gear failure on my T-reg 2012 7P.
The rear end is stuck in high position.
Can anyone help where to start solving the problem?
Attached complete scan.
0644 - Level control system
C10D3 07 [008] - Mechanical Failure
Fault Priority: 8
Fault Frequency: 50
Reset counter: 1
Mileage: 3584 km
Date: 2061.02.08
Time: 12:57:04
Default: B2
Default: 7F
Default: 00
Chassis Type: 7P-VW52 (7P6)
Scan: 01 02 03 05 08 09 10 15 16 17 19 34 36 42 46 52 53 55 56 5F
62 65 69 6C 6D 72
VIN: WVGZZZ7PZCD017067 Mileage: 74063km-46020miles
Address 01: Engine (J623-CJMA) Labels:. 059-907-401-V2.clb
Part No SW: 7P0 907 311 C HW: 4G0 907 401
Component: 3.0TDI EDC17 H37 0003
Revision: 53H37---
Coding: 292A4012233E01020000
Shop #: WSC 51734 000 1048576
ASAM Dataset: EV_ECM30TDI0117P0907311C 001003
ROD: EV_ECM30TDI0117P0907311C.rod
VCID: 2F673992768044327C-807A
17403 - ROD - Unknown Error Code
- 00 [032]
Address 02: Auto Trans (J217) Labels:| 0C8-927-750.clb
Part No SW: 0C8 927 750 AM HW: 0C8 927 750 AM
Component: AL1000 AISIN 001 1932
Coding: 001568
Shop #: WSC 36685 001 1048576
ROD: EV_TCMAL991031_002.rod
VCID: 77F7C1F2CE504CF2E4-8022
Address 03: ABS Brakes (J104) Labels:* 7P0-907-379.clb
Part No SW: 7P0 907 379 K HW: 7P0 907 379 A
Component: MK25A H36 0418
Revision: -------- Serial number: 422810010EC010
Coding: 5B6B13C30B25255ADAF4C899D0D9A4507700
Shop #: WSC 31414 790 00001
ASAM Dataset: EV_MK25AXT 007001
ROD: EV_ESPMK25A00700.rod
VCID: 458B7B3AC43CEE62A6-8010
Part No SW: 4H0 907 064 BH HW: 4H0 907 064 BH
Component: BCM2 2.0 H31 0330
Coding: 01A60000000000000000
VCID: 70E5FAEEA33E1BCA25-8024
Subsystem 1 - Part No SW: 7P6 959 754 AA HW: 7P6 959 754 AA
Component: FBSTOUAREGIDG H05 0051
Serial number: 0511000036954015
Subsystem 2 - Part No SW: 4H0 905 852 B HW: 4H0 905 852 B
Component: J764 ELV MLB H38 0044
Serial number: 2311000168458014
Address 08: Auto HVAC (J255) Labels:| 7P6-907-040.clb
Part No SW: 7P6 907 040 BA HW: 7P6 907 040 BA
Component: Klima 2 Zonen H20 1203
Coding: B686000A90
VCID: 74EDF6FEDF2627EAC1-8020
0247 - Function Restriction due to Faults in Other Modules
U1113 00 [008] - -
Fault Frequency: 90
Reset counter: 27
Mileage: 64088 km
Date: 2018.04.06
Time: 15:05:45
Address 09: Cent. Elect. (J519) Labels:. 4H0-907-063-V1.clb
Part No SW: 4H0 907 063 BD HW: 4H0 907 063 D
Component: BCM1 2.0 H12 0100
Revision: 15012002 Serial number: 00000001023988
Coding: 26001011D1345D010021000300005D0C431C670806010241000000020000
VCID: 6BDFED828A18F81210-803E
Subsystem 1 - Part No SW: 7P0 955 119 HW: 7P0 955 119 Labels: 1KX-955-119.CLB
Component: WWS 110727 31 0020
Serial number: 90243400110817150656
Coding: 004DBD
Subsystem 2 - Part No SW: 7P0 955 559 C HW: 7P0 955 559 C Labels: 8K0-955-559.CLB
Component: RLFS H09 0011
Serial number: 10004416
Coding: 004B25
Subsystem 3 - Part No SW: 7P6 941 431 D HW: 7P6 941 431 D
Component: E1 - LDS H04 0031
Serial number: 00000000002508110809
Address 10: Park/Steer Assist (J446) Labels:| 7P6-919-475.clb
Part No SW: 7P6 919 475 B HW: 7N0 919 475
Component: PARKHILFE 8K H05 0021
Revision: -------- Serial number: 28261122900431
Coding: 518501
ASAM Dataset: EV_VW526ParkiAssis2 001011
ROD: EV_VW526ParkiAssis2.rod
VCID: 42816026D512D95A83-8016
Address 15: Airbags (J234) Labels:| 7P0-959-655.clb
Part No SW: 7P0 959 655 B HW: 7P0 959 655 B
Component: VW10Airbag02H H05 0023
Revision: -------- Serial number: 003JX003X1GM
Coding: 000000000000000000000000000000003248
VCID: 40856A2EDB1ECB4A95-8014
Serial number: 3575LRB400G4UNG4G8E%
Serial number: 3585LRB40510NI36E9G7
Serial number: 3515RRB405T0N3MO7PPV
Serial number: 3525RRB405T0N3MOFGU-
Serial number: 3555NRB40670N4A8L1E5
Serial number: 3565NRB40650N4A8CGRN
Part No SW: 4H0 953 568 H HW: 7P6 953 507 M
Component: Lenks.Modul H03 0005
Revision: -------- Serial number: 90815KHN0006K
Coding: 000C15
VCID: 387502CE8BCE838A2D-806C
Subsystem 1 - Part No SW: 7P6 959 542 HW: 7P6 959 542
Component: E221__MFL-TAS H03 0027
Serial number: 0106644
Address 17: Instruments (J285) Labels:| 7P6-920-xxx-17.clb-SRI1
Part No SW: 7P6 920 880 P HW: 7P6 920 880 P
Component: Kombi H13 0239
Revision: 11240062 Serial number: 658270811593048
Coding: 133731003B000008010004
ASAM Dataset: EV_KombiUDSRBVW526 001013
ROD: EV_KombiUDSRBVW526.rod
VCID: 4895720EF32EF30A5D-801C
Part No SW: 7P6 907 530 C HW: 7P6 907 530 A
Component: GW-CAN-L-MOST H08 5202
Revision: -------- Serial number: 00000000233414
Coding: 000D077500
ASAM Dataset: EV_GatewVW526UDS 001006
ROD: EV_GatewUDS_VW52.rod
VCID: 387502CE83CE838A2D-806C
Subsystem 1 - Part No SW: 7P0 915 181 A HW: 7P0 915 181
Component: Batt_Sensor H07 0140
Serial number: 00000000005650159990
Voltage stabilizer:
Subsystem 2 - Part No SW: 7PP 959 663 E HW: 7PP 959 663 E
Component: J532_DCDCStab H17 0042
Serial number: 11232000092011200181
Address 34: Level Control (J197) Labels:. 7P0-907-553.clb
Part No SW: 7P0 907 553 K HW: 7P0 907 553 K
Component: PASM H01 1110
Revision: 00000000 Serial number: 00000112140923
Coding: 14210000
ASAM Dataset: EV_PASMConti 001004
ROD: EV_PASMConti.rod
VCID: 3F8769D2A6E0B4B2EC-806A
Fault Priority: 8
Fault Frequency: 50
Reset counter: 1
Mileage: 3584 km
Date: 2061.02.08
Time: 12:57:04
Default: B2
Default: 7F
Default: 00
Part No SW: 4H0 959 760 D HW: 4H0 959 760 D
Component: MEM-FS H08 0153
Revision: AA000000 Serial number: 00000012604362
Coding: 0058130000004001000001010101202020202121202020
VCID: 346D36FE97A667EA01-8060
Part No SW: 4H0 959 793 N HW: 4H0 959 793 F
Component: TSG FA H07 0166
Revision: -------- Serial number: 0000118932972
Coding: 011D0620DE00451005080002
VCID: 448D663EC706D76AB1-8010
Revision: 00002001 Serial number: 0155940332
Coding: 019A162028B9109483200624210000000000000000000000000000000000
Subsystem 1 - Part No: 7P6 951 171
Component: DWA-Sensor 002 0204
Subsystem 3 - Part No SW: 7P0 959 591 HW: 7P0 959 591
Component: J245 PS30.050 H07 0006
Serial number: WOO1296666A
Coding: 191100
Subsystem 4 - Part No SW: 7P0 959 591 A HW: 4H0 959 591
Component: J394 PS30.050 H07 0006
Serial number: WOO13029975
Coding: 191100
Part No SW: 4H0 959 792 F HW: 4H0 959 792 F
Component: TSG BF H07 0166
Revision: -------- Serial number: 0000118988341
Coding: 011D0620DE00451005080000
VCID: 3B7F1DC2BAF8A892C0-806E
Address 53: Parking Brake (J540-) Labels:| 7P0-907-801.clb
Part No SW: 7P0 907 801 F HW: 7P0 907 801 F
Component: EPB H51 1201
Revision: 00000000 Serial number: A118140006E
Coding: 01040100
ROD: EV_ParkbA7.rod
VCID: 36690CF689DA75FA3F-8062
Slave 3:
Address 55: Headlight Range (J745) Labels:. 7P6-907-357.clb
Part No SW: 7P6 907 357 HW: 7L6 907 357 C
Component: AFS-ECU H04 0110
Coding: 01AA00000F000200
VCID: 7CFDDEDEF7766FAA89-8028
Subsystem 1 - Part No SW: 8U0 941 329 HW: 8U0 941 329 Labels: 3D0-941-329.CLB
Component: LeiMo links H01 0002
Coding: 130000
Subsystem 2 - Part No SW: 8U0 941 329 HW: 8U0 941 329 Labels: 3D0-941-329.CLB
Component: LeiMo rechts H01 0002
Coding: 130000
Part No SW: 4G0 035 061 G HW: 4G0 035 061
Component: Radio U DAB H52 0097
Revision: AB001007 Serial number: 109H/0B7531478
Coding: 010105020100000003
VCID: 2143CFAA3854E242FA-8074
Part No SW: 7P6 035 670 A HW: 7P6 035 670 A
Component: H-BNT-EU H45 0318
Revision: -------- Serial number: 478HB0B7559555
Coding: 010100050040E1EF41002B0E00000003F0040101
VCID: 336F35E292A860D218-8066
Subsystem 1 - Part No: 8R0 060 884 N
Component: EUR 2011 1205
Subsystem 2 - Part No SW: 7P6 919 603 HW: 7P6 919 603
Component: DU8 SV Touch H25 0045
Serial number: VWZ8Z9L78008EY
Subsystem 3 - Part No SW: 7P6 919 603 HW: 7P6 919 603
Component: CD-Database 1886
Reset counter: 186
Mileage: 53781 km
Date: 2017.07.31
Time: 23:27:04
Text: MuGPS,Main,M,0,0,6
01524 - Antenna for Telephone
Fault Status: 00101011
Reset counter: 31
Mileage: 70697 km
Date: 2018.09.19
Time: 17:46:23
Voltage: 12.70 V
Part No SW: 4H0 959 795 B HW: 4H0 959 795 B
Component: TSG HL H09 0162
Revision: -------- Serial number: 0000119342955
Coding: 011C06200000251005080000
VCID: 3A7118C6B5C2919ADB-806E
Address 65: Tire Pressure (J502) Labels: 3Y0-907-273.clb
Part No SW: 7P6 907 273 F HW: 7P6 907 273 F
Component: RDKBERU25 H09 0008
Serial number: 10000000045960
ROD: EV_RDKBERU25_VW52.rod
Address 69: Trailer (J345) Labels: Redir Fail!
Part No SW: 7P0 907 383 G HW: 7P0 907 383 C
Component: Anhaenger H09 0110
Revision: 5H001001 Serial number: 00000152278046
Coding: 0106040000000000
VCID: 3C7D1EDEBFF6AFAAC9-8068
Address 6C: Back-up Cam. (J928) Labels:| 7P6-907-441-V1.clb
Part No SW: 7P6 907 441 E HW: 7P6 907 441 D
Component: TopView H05 0100
Revision: 11001001 Serial number: 82330JF0067907
Coding: 0100000001010000010102000000
ASAM Dataset: EV_CamerSysteTopViewVW 001014
ROD: EV_CamerSysteTopViewVW.rod
VCID: 3B7F1DC2B2F8A892C0-806E
Address 6D: Trunk Elect. (----) Labels:| 7N0-959-107.clb
Part No SW: 7P6 959 107 HW: 7P6 959 107
Component: HDSG-Modul H10 0611
Revision: 22010001 Serial number: 219100537
Coding: 0533314003
ASAM Dataset: EV_HeckkTouar 202135
ROD: EV_HeckkTouar.rod
0051 - Hall Sensors in Motor 1 for Rear Lid
B1211 12 [008] - Short to Plus
Reset counter: 40
Time: 00:00:00
Voltage terminal 30: 12.69 V
0053 - Hall Sensors in Motor 2 for Rear Lid
B120A 15 [008] - Open or Short to Plus
Reset counter: 40
Time: 00:00:00
0055 - Pinch Protection Strip 1
B11DB 12 [008] - Short to Plus
Reset counter: 40
Time: 00:00:00
0058 - Pinch Protection Strip 2
B11DC 12 [008] - Short to Plus
Reset counter: 40
Time: 00:00:00
Component: TSG HR H09 0162
Revision: -------- Serial number: 0000119344228
End-------------------------(Elapsed Time: 05:14)--------------------------
