Hi All,
Perhaps someone can assist. Since I have had it my car, a Golf MK6 2012 Model 1.6TDI (engine CAYC) has suffered from a slight but regular fluctuation in the RPM between 740-820rpm (as per VCDS) which you can feel through the steering wheel. Pre-Requisites for this to occur are engine cold and Electrical Consumers On (i.e rear demister, headlights, Heater on etc). It always disappears as soon as the engine is warmed up (10 mins or so). The fluctuation is regular and not random, like every couple of seconds or so only when the above requirements are met. I am noticing it a lot more since the weather has got colder in the UK and I use more consumers at startup, therefore it's getting more irritating requiring more investigation
The EGR Valve was changed early this year so this has been ruled out. Unfortunately I don't know whether the issue was apparent before then as that was under another owner.
The Injector deviation have been checked on all 4 cylinders and I can't see anything wrong there either (1mg max deviation on any one).
I have had injector issues previously (same engine, different car) and this has resulted in random and sporadic changes to the idle rpm, this is not.
Battery Voltage shows between 12.2-12.6V at rest and alternator shows charging well at between 14.5-14.8V when on. The battery is the original though so I am surprised it's still going strong after 6 years and 80K miles.
The car had the emissions fix performed on it last year but not sure if this would be related as I am not getting any actual driveability issues.
There are no relevant fault codes present in VCDS, I have attached a VCDS dump from earlier this year when the problem first occurred.
Has anyone experienced such an issue as I am running out of things to check? Thanks in advance.
Wednesday,09,May,2018,12:35:32:00352
VCDS Version: 18.2.0.3
VIN: WVWZZZ1KZBW31xxxx License Plate:
Mileage: 127900km-79473mi Repair Order:
Chassis Type: 1K-VW36 (7N0)
Scan: 01 03 08 09 10 15 16 17 19 25 2E 42 44 46 52 56 61 62 72 77
VIN: WVWZZZ1KZBW31xxxx Mileage: 127900km-79473miles
Address 01: Engine (J623-CAYC) Labels:. 03L-906-023-CAY.clb
Part No SW: 03L 997 557 T HW: 03L 907 425 C
Component: R4 1.6l TDI H43 9982
Revision: --H43--- Serial number: 00000000000000
Coding: 08114014032501080000
ASAM Dataset: EV_ECM16TDI02103L997557T 003003
ROD: EV_ECM16TDI.rod
VCID: 4DB75AE91CD07E2CA3-8018
Part No SW: 1K0 907 379 BE HW: 1K0 907 379 BE
Component: ESP MK60EC1 H31 0108
Revision: 00H31001
Coding: 133B200D092300FFC81304E9901A0091310000
VCID: 76C5D505C1C65DF432-8022
Part No SW: 7N0 907 426 K HW: 7N0 907 426 K
Component: AC Manuell H17 0202
Revision: 00001012
Coding: 0000000003
ROD: EV_ClimaBasis_VW36.rod
VCID: 3C51072DB76AC7A404-8068
Part No SW: 1K0 937 084 D HW: 1K0 937 084 D
Component: BCM PQ35 B 103 0615
Revision: 00103 AE
Coding: 48180A3A8825F1C040080080340000E443510088436D8160648087200041
VCID: 2F4B20617E1C2C3CB1-807A
Subsystem 1 - Part No: 5K2 955 119
Component: Wischer 06041 26 0512
Coding: 009795
Component: RLS 200411 05 54 0403
Coding: 0330AD
Component: LIN BACKUP HO H11 9005
007 - Short to Ground
Fault Status: 01100111
Reset counter: 214
Mileage: 127875 km
Date: 2012.09.24
Time: 14:13:36
Term 15 Off
Voltage: 11.85 V
Term 50 Off
Fault Status: 00101010
Reset counter: 254
Mileage: 127875 km
Date: 2012.09.24
Time: 14:17:19
Voltage: 14.65 V
Term 50 On
Address 10: Park/Steer Assist (J446) Labels:. 3C8-919-475.clb
Part No SW: 5K0 919 475 E HW: 5K0 919 475 E
Component: PARKHILFE 8K H01 0012
Revision: -------- Serial number: 12501110100802
Coding: 108001
VCID: 38591B3D8B52EB84E0-806C
Part No SW: 5C0 959 655 B HW: 5C0 959 655 B
Component: AirbagVW10 013 0613
Serial number: 003G5RA42UNY
Coding: 00003948
ROD: EV_AirbaVW10SMEVW360.rod
VCID: 314F261960283ACCA7-8064
Subsystem 1 - Part No SW: 5K0 959 354 HW: 5K0 959 354
Component: S.Sens.Fahr.V H01 ----
Serial number: 3572MSME712E165FZZZ1
Component: S.Sens.Beif.V H01 ----
Serial number: 3582MSME7F34635EZZZ8
Serial number: 3512QSME7A451D4EZZZ6
Serial number: 3522QSME4A441D16ZZZZ
Part No SW: 5K0 953 507 BC HW: 5K0 953 549 E
Component: Lenks.Modul 008 0080
Revision: -------- Serial number: 90440KDJ001AV
Coding: 1082140000
ROD: EV_SMLSNGKUDS_A05.rod
VCID: 72CDE915A5AE41D41E-8026
Component: E221__MFL-TK6 H06 0022
Serial number: 40000000000000324004
Coding: E20000
Part No SW: 5K0 920 971 A HW: 5K0 920 971 A
Component: KOMBI H20 0420
Coding: 470B00
ROD: EV_Kombi_UDS_VDD_RM09_004_VW36.rod
VCID: 2D773A697C105E2C83-8078
Part No SW: 7N0 907 530 D HW: 1K0 907 951
Component: J533 Gateway H35 0614
Revision: H35 Serial number: 140411F2001094
Coding: 350003
VCID: 314F261968283ACCA7-8064
Component: IMMO H20 0420
VCID: 6AFDF1758D7E8914A6-803E
Part No SW: 5N0 035 342 D HW: 5N0 035 342 D
Component: SG EXT.PLAYER H13 0150
Revision: A1001003 Serial number: 7669823626
VCID: 2879CB7D5BF27B0470-807C
Part No SW: 5K0 959 701 B HW: 5K0 959 701 B
Component: Tuer-SG 009 2120
Coding: 0131764
VCID: 314F2619A8283ACCA7-8064
Part No: 1K0 909 144 M
Component: EPS_ZFLS Kl. 69 3201
Revision: 00H20000
VCID: 34412F0D573A0FE4CC-8060
Part No SW: 5K0 959 702 C HW: 5K0 959 702 C
Coding: 0132020
VCID: 33432C11523408DCD5-8066
Address 56: Radio (J0503) Labels:. 5M0-035-1xx-56.clb
Part No SW: 3C8 035 195 A HW: 3C8 035 195 A
Component: Radio RCD510 041 0166
Revision: 00000001 Serial number: VWZ1Z3L0746133
Coding: 0100040004
VCID: 2665C54551E66D7442-8072
Reset counter: 214
Mileage: 127875 km
Date: 2012.09.24
Time: 14:10:37
Part No SW: 7N0 907 534 HW: 1K0 907 951
Component: Batt.regelung H35 0614
Coding: 030B185A
VCID: 71CFE619A8A87ACCE7-8024
Subsystem 1 - Part No SW: 1K0 915 181 F HW: 1K0 915 181 A
Component: J367-BDM H07 0150
Serial number: 00000000009370226942
Part No SW: 5K0 959 703 D HW: 5K0 959 703 D
Component: Tuer-SG 007 2101
Coding: 0131216
Shop #: WSC 01357 011 1012552
VCID: 354712095C4016ECFB-8060
Part No SW: 5K0 959 704 D HW: 5K0 959 704 D
Coding: 0131216
VCID: 3645150541461DF4F2-8062
Part No SW: 5K0 035 730 B HW: 5K0 035 730 B
Component: TELEFON H09 1020
Revision: 1B001001 Serial number: 00007669764269
Coding: 0A01000000010101
ASAM Dataset: UHVNA A01009
ROD: UHVNA.rod
VCID: 2461DF4D2FDA9F645C-8070
End-------------------------(Elapsed Time: 03:02)--------------------------
