We had some actual rain over the last couple days and the TT (which has some annoying vampire drain) wouldn't start due to low battery. Used a charger on it and it started, drove around a bit.
No interior lights (at mirror), can't open trunk or gas door, remote doesn't work, no blinking light on the door when the car is locked (manually with key), very dim BRAKE light on dash but brakes seem fine.
No codes for ABS or engine or instruments but also no alarm controller found, I swore there was one - some folks suggest the controller behind the rear window got wet but it doesn't seem it, no water in the cabin.
Suggests on what to check next?
thanks
thanks
