Tuesday,06,November,2018,11:19:22:49027
VCDS Version: 18.9.0.2 (x64)
VIN: WUABAAFX0J79XXXXX License Plate:
Mileage: 1181km-733mi Repair Order:
Chassis Type: FX-AU72 (4S0)
Scan: 01 02 03 05 06 08 09 11 31 15 16 17 19 20 22 36 3B 42 44 46
52 53 55 5F 65 6C 81 A6 C2
VIN: WUABAAFX0J79XXXXX Mileage: 1181km-733miles
A6-Microphone -- Status: OK 0000
C2-Auto Trans 2 -- Status: OK 0000
Address 01: Engine (------DKAB) Labels: None
Part No SW: 4S0 907 552 AE HW: 4T0 907 552 A
Component: V10 5.2l FSI H57 0003
Revision: NHH57---
Coding: 1A2500320524000D3000
ASAM Dataset: EV_ECM52FSI1114S0907552AE 001003
ROD: EV_ECM52FSI1114S0907552AD.rod
VCID: 79F9E1DAF866D18292-802C
27882 - Intake Air Temp. Sensor (G42)
P0113 00 [032] - Signal too High
Mileage: 564 km
Date: 2018.08.29
Time: 15:04:27
Coolant temperature: 24 °C
Intake air temperature: -40 °C
Voltage terminal 30: 12.203 V
Unlearning counter according OBD: 26
Engine status: COENG_STANDBY
Engine status-Test_Program_Co Eng st COMPU VERB UBYTE: 0
Address 02: Auto Trans (J217) Labels: None
Part No SW: 4S0 927 155 Q HW: 0BH 927 711 F
Component: AU E NAR Z H10 4116
Revision: 00H10V01
ASAM Dataset: EV_TCMDL800041 001015
ROD: EV_TCMDL800041_AU72.rod
VCID: 45815D2AC41E6562A6-8010
Part No SW: 4S0 907 379 G HW: 4S0 907 379 G
Component: ESP PREMIUM H09 0500
Coding: 11A1810B888581D04B00
ASAM Dataset: EV_ESPPremiAU57X 004050
ROD: EV_ESPPremiAU57X_AU72.rod
VCID: 4189493AD03649429A-8014
Part No SW: 4H0 907 064 JD HW: 4H0 907 064 JD
Component: BCM2 2.0 H44 0582
Coding: 0D806506000000000000
VCID: 74E7D0EED704ACEAC1-8020
Serial number: 3218000071392003
Address 06: Seat Mem. Pass (J521) Labels: None
Part No SW: 4S0 959 760 HW: 4S0 959 760
Component: MEM-BFS 001 0020
Revision: AA001003 Serial number: 00000205411028
Coding: 00001000000420F1000001210101210000000000000000
VCID: 7BF5FBD2FA5AE39280-802E
Address 08: Auto HVAC (E87) Labels:* None
Part No SW: 4S0 820 043 K HW: 4S0 820 043 K
Component: AC Automat H08 0050
Revision: 20012000 Serial number: 96800000009468
Coding: 4000A01000000410
ASAM Dataset: EV_AirCondiVAPrehAU72x 003005
ROD: EV_AirCondiVAPrehAU72x.rod
VCID: 336513F29A8AEBD218-8066
Operating and display unit 2 for air conditioning:
Subsystem 1 - Part No SW: 8S0 820 359 A HW: 8S0 820 359 A
Component: E775 BuA_2 H07 0020
Serial number: 00000000000000012036
Operating and display unit 3 for air conditioning:
Subsystem 2 - Part No SW: 8S0 820 359 HW: 8S0 820 359
Component: E776 BuA_3 H07 0020
Operating and display unit 4 for air conditioning:
Subsystem 3 - Part No SW: 8S0 820 359 B HW: 8S0 820 359 B
Component: E777 BuA_4 H07 0020
Address 09: Cent. Elect. (J519) Labels: None
Part No SW: 4H0 907 063 JK HW: 4H0 907 063 EK
Component: BCM1 2.0 H21 0729
Revision: 2502104S Serial number: 00001849436002
Coding: 010D0091143C9FE0450048C380001800C59CD2882A0832210004088461001000006000340B0000
modified: 010D0091143C9FE0450040C380001800C59CD2882A0832210004088461001000006000340B0000
VCID: 7AFBFED6F560DA9A9B-802E
Subsystem 1 - Part No SW: 4S1 955 119 B HW: 8V2 955 119 A
Component: WWS624 180406 043 0081
Serial number: 90248162180416074720
Coding: 3247FD
Component: G397_RLFS H06 0004
Serial number: 63303538
Coding: 02005D
Subsystem 3 - Part No SW: 4S0 941 531 HW: 4S0 941 531
Component: E1 - LDS H01 0044
Serial number: 24 04 2018 00000178
Subsystem 4 - Part No SW: 4G0 907 410 A HW: 4H0 907 410 A
Component: USHL4.2 H30 0030
Serial number: 00000000095Z03D705D0
Subsystem 5 - Part No SW: 4H0 907 658 B HW: 4H0 907 658 B
Component: AQ_Hum_Sensor H02 0007
Serial number: 2DA2962900PAG0MUFU03
02070 - Rear Parking Aid Sensors
Fault Status: 00101011
Reset counter: 68
Mileage: 564 km
Date: 2018.08.29
Time: 20:49:05
Address 11: Engine II (-----) Labels: None
Revision: NHH57---
ASAM Dataset: EV_ECM52FSI2114S0907552AE 001003
ROD: EV_ECM52FSI2114S0907552AD.rod
Address 15: Airbags (J234) Labels:* None
Part No SW: 4S0 959 655 HW: 4S0 959 655
Component: Airbag10.43 H62 0204
Revision: -------- Serial number: 003NJ0019NUM
Coding: 303338453036303038324A55304C34533053
ASAM Dataset: EV_AirbaAU10BPAAU64X 001036
VCID: 7EF3F2C6E148F6BAA7-802A
Subsystem 1 - Part No SW: 5C6 959 339 B HW: 5C6 959 339 B
Serial number: 6940000Y180001RBEL07
Serial number: 3575HRB40045DMLQG8I/
Serial number: 3585HRB401A5DNV0D0GK
Serial number: 3515JRB405F5F0S0GG58
Serial number: 3525JRB40635E9H4GGIC
Serial number: 3554VRB405J5G5EUBG1/
Serial number: 3564VRB405L5G5EUI11Z
Address 16: Steering wheel (J527) Labels: None
Part No SW: 4S0 907 129 K HW: 4S0 907 129 K
Component: Lenks.Modul H06 0007
Revision: C0071527 Serial number: 91335RDR01688-
Coding: 000034
VCID: 3E7332C6A9C836BAE7-806A
Address 17: Instruments (J285) Labels:* None-SRI2
Part No SW: 4S0 920 890 D HW: 4S0 920 890 D
Component: FBenUSA H17 0278
Coding: 086F30C1AA82CF050220ECC41800801000000000
ASAM Dataset: EV_DashBoardBOSCHAU724 001027
ROD: EV_DashBoardBOSCHAU724.rod
VCID: 377D27E28EF207F224-8062
Part No SW: 4S0 907 468 B HW: 4S0 907 468 A
Component: J533--Gateway H15 0074
Revision: -------- Serial number: 00000002960314
Coding: 802103161C
VCID: 3B753BD2B2DA2392C0-806E
Subsystem 1 - Part No SW: 4S0 915 181 HW: 4S0 915 181
Component: J367-BDM H08 0270
Serial number: 55082K25522871930782
12290 - Quiescent Current
U1406 00 [008] - Too High
Fault Frequency: 10
Reset counter: 97
Mileage: 1163 km
Date: 2018.10.29
Time: 15:43:46
Voltage terminal 30: 12.3 V
Voltage terminal 15: 0.0 V
Control Module temperature: 23 °C
System status: LIN_active
Engine running: OFF
IN ZAS_Te_X: OFF
Terminal 15 status: OFF
Datenfeld: 0
U140B 00 [008] - -
Reset counter: 97
Mileage: 1163 km
Date: 2018.10.29
Time: 18:47:06
Voltage terminal 30: 12.2 V
Control Module temperature: 24 °C
Engine running: OFF
IN ZAS_Te_X: OFF
Datenfeld: 1
Address 20: High Beam Assist. (J844) Labels:* None
Part No SW: 81A 857 511 H HW: 81A 857 511 H
Component: FLA H10 0003
Revision: AB001001
Coding: 0404001D00010001000001
ASAM Dataset: EV_HighBeamAssisAU724 001007
ROD: EV_HighBeamAssisAU724.rod
VCID: 2D51058A7CAEBD224E-8078
Address 22: AWD (J492) Labels: None
Part No SW: 4S0 907 160 A HW: 4S0 907 160
Component: 2 Wheel Drive H07 0220
Revision: 00001002 Serial number: 008GOGP
ASAM Dataset: EV_AllWheelContrBORGLB724 006015
ROD: EV_AllWheelContrBORGLB724.rod
VCID: 2F6D1F8276A2CF327C-807A
Component: MEM-FS 001 0020
Revision: AA001003 Serial number: 00000205411027
Coding: 00181900000420F1C00001210101210000000000000000
Part No SW: 4G0 907 637 L HW: 4G0 907 637 G
Component: SARA 6D red H04 0056
Revision: -------- Serial number: EJ1BPA7E03A1D%
ASAM Dataset: EV_SARA2 005012
ROD: EV_SARA2.rod
Component: TSG FA H03 0511
Coding: 011C53425000000300000402
VCID: 479D5722F612777254-8012
Address 44: Steering Assist (J500) Labels:* None
Part No SW: 4S0 909 144 J HW: 4S0 909 144 B
Component: EPS H13 0906
Revision: 00000000 Serial number: L00279400
Coding: 0800
ASAM Dataset: EV_EPSZFAU72X 003010
ROD: EV_EPSZFAU72X_003.rod
VCID: 3C7738CEB7D424AAC9-8068
Revision: 00002001 Serial number: 0476836681
Coding: 0106069A00F2C081E0B0CA00008500000001000000000000000000000000
modified: 0106169A00F2C081E2B0CA00008500000001000000000000000000000000
Subsystem 1 - Part No SW: 4S0 959 719 A HW: 4S0 959 719 A
Component: GTO BF H01 0010
Serial number: 20180330013715 00156
Subsystem 3 - Part No SW: 4G8 959 252 A HW: 4G8 959 252
Component: HSP-SG H11 0031
Serial number: WA131201000045615756
Component: TSG BF H03 0511
Coding: 011C53425E00000300000400
VCID: 46835A26F1186E7AAF-8012
Address 53: Parking Brake (----) Labels: 8K0-907-801-V2.clb
Part No SW: 4S0 907 801 HW: 8K0 907 801 J
Component: EPB-4 H04 0001
Revision: -------- Serial number: 00000000004812
ROD: EV_ParkiBrake_AU72.rod
VCID: 70EFDCFEAB1C90CA25-8024
Address 55: Headlight Range (J745) Labels:* None
Part No SW: 4H4 907 357 G HW: 7P6 907 357 B
Component: MxB-ECU 001 0115
Coding: 077A001122600400
ASAM Dataset: EV_HeadlRegulAUDIMXBAU64X 005011
VCID: 36632AE689F8FEFA3F-8062
Subsystem 1 - Part No SW: 7PP 941 572 AC HW: 7PP 941 572 A Labels: 3D0-941-329.CLB
Component: LED LeiMo li. H09 0008
Coding: E02200
Subsystem 2 - Part No SW: 7PP 941 572 AC HW: 7PP 941 572 A Labels: 3D0-941-329.CLB
Component: LED LeiMo re. H09 0008
Coding: E02200
Part No SW: 4S0 035 025 G HW: 4S0 035 025
Component: MU-H-LNS-US 054 1364
Serial number: A353D0JB001726
Coding: 012704020000000013220002041A00102F0000E1007000047E
ASAM Dataset: EV_MUHig6C8Gen2HBAS 001182
ROD: EV_MUHig6C8Gen2HBAS.rod
Subsystem 1 - Part No SW: V03 959 801 GH HW: -----------
Component: NAR 2017/2018 --- 0060
Multimedia Operating Unit:
Subsystem 2 - Part No SW: 4S1 919 614 D HW: 4S1 919 614 D
Component: ControlUnit_H H30 0206
Serial number: APVAK107031800010015
Subsystem 3 - Part No SW: V03 959 800 EG HW: -----------
Component: Gracenote2 --- 3012
Address 65: Tire Pressure (-----) Labels: 3Y0-907-273.clb
Part No SW: 4H0 907 273 D HW: 4H0 907 273 B
Component: RDKBERU25 H10 0900
Serial number: 10000000050407
ROD: EV_RDKBERU25_AU57.rod
VCID: 2C57088E47B4B42A59-8078
Address 6C: Back-up Cam. (J772) Labels:* None
Part No SW: 4S0 980 556 A HW: 95B 980 551 L
Component: RVC Compact H12 0201
Coding: 0275040102000001000040
ASAM Dataset: EV_CamSysRVRVCPANAAU57X 002003
ROD: EV_CamSysRVRVCPANAAU57X_002.rod
VCID: 397921DAB8E61182D2-806C
Address 81: Gear Shift (J587) Labels: None
Part No SW: 4S1 713 041 D HW: 4M1 713 041 F
Component: GSM-LL H09 0077
Revision: 0L0D5012 Serial number: 18042847123955
ROD: EV_GSMWaehlZFAU736_AU49.rod
Address A6: Microphone (J886) Labels:. 420-907-394.clb
Part No SW: 420 907 394 B HW: 420 907 394
Component: BELTMICBOX H10 0840
Coding: 0101030202
ASAM Dataset: EV_BeltMicPARAGAU335 003011
ROD: EV_BeltMicPARAGAU335.rod
VCID: 183FC45EE32C288A0D-804C
Address C2: Auto Trans 2 (J217) Labels: None
Part No SW: 4S0 927 109 HW: 4S0 927 109
Component: DL800 ZSG H12 0002
Revision: --H12--- Serial number: 0000000161
Coding: 000001
ASAM Dataset: EV_TCMDL800421 001024
ROD: EV_TCMDL800.rod
VCID: 73E5D3F2DA0AABD2D8-8026
End-------------------------(Elapsed Time: 05:10)--------------------------
