Hello guys,after finally fixing G188 issues on this car after it had been through many garages in Nairobi,....before i could celebrate during a test drive....EPC blinked on trying to press accelerator hard to overtake....light went off,reappeared again when i tried to drive aggressively.....this car is petrol engined code CAXA....and i am wondering where this diesel ghost code has come from.....any hints are greatly welcome
Monday,05,November,2018,13:43:33:48669
VCDS Version: 18.9.0.1 (x64) HEX-V2 CB: 0.4436.4
Dealer/Shop Name: VAG AUTO-XRAY
VIN: WVWZZZ1KZAW218486 License Plate:
Mileage: 105180km-65355mi Repair Order:
Chassis Type: 1K-VW36 (1K0)
Scan: 01 02 03 08 09 15 16 17 19 25 42 44 46 52 56 62 72
VIN: WVWZZZ1KZAW218486 Mileage: 105180km-65355miles
Address 01: Engine (CAX) Labels: 03C-906-016-CAX.clb
Part No SW: 03C 906 016 AJ HW: 03C 907 309 A
Component: MED17.5.5 8546
Revision: LCH12--- Serial number:
Coding: 0000077
Shop #: WSC 55455 002 1048576
VCID: 6788B271B36635EF3FC-8032
012398 - Glow Ignition
P306E - 000 - Short Output Reduction - Intermittent
Mileage: 105179 km
Date: 2013.03.28
Time: 01:38:58
RPM: 2462 /min
Load: 87.4 %
Speed: 112.0 km/h
Temperature: 87.0°C
Temperature: 38.0°C
Absolute Pres.: 830.0 mbar
Voltage: 13.843 V
Readiness: 0010 0001
Address 02: Auto Trans Labels: 0AM-927-769.clb
Part No SW: 0AM 300 048 L HW: 0AM 927 769 D
Component: GSG DSG AG7 431 2669
Revision: 00043014 Serial number: CU501311095470
Shop #: WSC 44132 000 1048576
VCID: 392C24099552731F998-806C
Part No SW: 1K0 907 379 AJ HW: 1K0 907 379 AJ
Component: ESP MK60EC1 H30 0107
Revision: 00H30001
Coding: 133B400D11230002C80F02EC881F0080310000
VCID: 7AAEFB05DCD4B807D02-802E
18020 - Engine Control Module Incorrectly Coded
P1612 - 000 - - Intermittent
Reset counter: 20
Mileage: 105013 km
Date: 2013.03.24
Time: 00:00:17
Count: 2
Count: 2
Count: 28928
Count: 8197
Count: 44288
Count: 255
Count: 85
03366 - Vacuuum Sensor
Fault Status: 00101100
Reset counter: 23
Mileage: 104680 km
Date: 2013.03.11
Time: 19:58:49
Count: 16384
Count: 32768
Count: 13056
Count: 213
Count: 49449
Count: 65533
Count: 585
Fault Status: 00101101
Reset counter: 32
Mileage: 105013 km
Date: 2013.03.24
Time: 00:00:17
Count: 2
Count: 2
Count: 28928
Count: 8193
Count: 44288
Count: 255
Count: 85
Part No SW: 5K0 907 044 BS HW: 5K0 907 044 BS
Component: Climatronic H15 0709
Revision: 00003001
Coding: 0000001002
VCID: 7DA4F019CD7A8F3FF50-8028
Address 09: Cent. Elect.
Part No SW: 5K0 959 655 E HW: 5K0 959 655 E
Component: AirbagVW10G 037 0606
Serial number: 003FLR00211R
Coding: 00003133
ROD: EV_AirbaVW10SMEVW360.rod
VCID: 3C223D1D96E0463782E-8068
Subsystem 1 - Part No SW: 5K0 959 354 HW: 5K0 959 354
Component: S.Sens.Fahr.V H01 ----
Serial number: 3572MSME1E43244DZZZ
Component: S.Sens.Beif.V H01 ----
Serial number: 3582MSME2D2A644CZZZ4
Serial number: 3512QSME04263E09ZZZT
Serial number: 3522QSME0E2D3A28ZZZ1
Part No SW: 1K0 953 549 CP HW: 1K0 953 549 CP
Component: J0527 853 0111
Coding: 0001004
VCID: 025E83E5B804F0C7882-8056
Part No SW: 5K0 920 860 H HW: 5K0 920 860 H
Component: KOMBI H04 0308
Coding: 570B00
VCID: 313C1C2941A2BB5F218-8064
Part No SW: 1K0 907 530 AD HW: 1K0 907 951
Component: J533 Gateway H07 0111
Revision: H07 01 Serial number: 101109F1001090
Coding: ED807F06000202000003
VCID: 698CB449A572039F298-803C
Reset counter: 197
Mileage: 103873 km
Date: 2013.03.03
Time: 00:09:36
Component: IMMO H04 0308
VCID: 6A8ECB45ACF40887202-803E
Part No SW: 5K0 959 701 E HW: 5K0 959 701 E
Component: Tuer-SG 009 2140
Coding: 0004790
VCID: 3432153DB2308E774AE-8060
Part No: 1K0 909 144 J
Component: EPS_ZFLS Kl. 69 3001
Revision: 00H17000
VCID: 313C1C294D22BB5F218-8064
Address 46: Central Conv.
Part No SW: 5K0 959 702 C HW: 5K0 959 702 C
Component: Tuer-SG 009 2114
Coding: 0005046
VCID: 33301621B73E894F534-8066
Address 56: Radio
Part No SW: 5K0 959 703 C HW: 5K0 959 703 C
Component: Tuer-SG 007 2101
Coding: 0000144
Shop #: WSC 01357 011 1012552
Part No SW: 5K0 959 704 C HW: 5K0 959 704 C
Coding: 0000144
VCID: 35342839B94A977F7D0-8060
End----------(Elapsed Time: 00:57, VBatt start/end: 13.7V/13.4V)-----------
